楼主 #1 2021-02-12 20:47:33
zhuacai
已发帖子: 234
v3s BSP内核 重新配置了buildroot,但是一键编译后没反应,请大神帮忙看看!!
下面是BSP内核目录
easyboard@V3S:~/corelinux/v3ssdk$ ls
app buildroot linux-3.4 patch rootfs 执行linux_docker_build.sh
app-bke  build.sh   linux_docker_build.sh  prebuilt  tools
运行linux_docker_build.sh一键编译
linux_docker_build.sh文件内容
TOP_DIR=`pwd`
echo "检查Docker......"
docker -v
if [ $? -eq  0 ]; then
    echo "检查到Docker已安装!"
         sudo apt-get install docker.io -y
fi
# 创建公用网络==bridge模式
#docker network create share_network
sudo
docker run -it -v $TOP_DIR:$TOP_DIR ld3003/v3s_env /bin/bash $TOP_DIR/build.sh $1
build.sh文件内容
#!/bin/bash
physicalNumber=0
coreNumber=0
logicalNumber=0
HTNumber=0
logicalNumber=$(grep "processor" /proc/cpuinfo|sort -u|wc -l)
physicalNumber=$(grep "physical id" /proc/cpuinfo|sort -u|wc -l)
coreNumber=$(grep "cpu cores" /proc/cpuinfo|uniq|awk -F':' '{print $2}'|xargs)
HTNumber=$((logicalNumber / (physicalNumber * coreNumber)))
echo "****** CPU Information ******"
echo "Logical CPU Number : ${logicalNumber}"
echo "Physical CPU Number : ${physicalNumber}"
echo "CPU Core Number : ${coreNumber}"
echo "HT Number : ${HTNumber}"
echo "*****************************"
if [ -L $0 ]
then
	BASE_DIR=`dirname $(readlink $0)`
	BASE_DIR=`dirname $0`
fi
basepath=$(cd $BASE_DIR; pwd)
echo $basepath
set -e
LD_LIBRARY_PATH=
TOP_DIR=$basepath
cd $TOP_DIR
PATH=$TOP_DIR/buildroot/out/host/bin/:$PATH
CROSS_COMPILE=$TOP_DIR/tools/external-toolchain/bin/arm-linux-gnueabi-
UBOOT_DIR=$TOP_DIR/u-boot-2011.09
KERNEL_DIR=$TOP_DIR/linux-3.4
BUILDROOT_DIR=$TOP_DIR/buildroot
BUILDROOT_OUT_DIR=$TOP_DIR/buildroot/out
ROOTFS_DIR=$TOP_DIR/rootfs
HOSTTOOLS_DIR=$TOP_DIR/tools/bin
PACKTOOLS_DIR=$TOP_DIR/tools/pack
ROOTFS_OVERRIDE_DIR=$TOP_DIR/prebuilt/rootfs-override
APP_DIR=$TOP_DIR/app
BR_CROSS_COMPILE=$BUILDROOT_OUT_DIR/host/usr/bin/arm-buildroot-linux-gnueabihf-
copy_file_list=(
$ROOTFS_OVERRIDE_DIR/etc/inittab:$ROOTFS_DIR/etc/inittab
$ROOTFS_OVERRIDE_DIR/etc/profile:$ROOTFS_DIR/etc/profile
$ROOTFS_OVERRIDE_DIR/etc/wpa_supplicant.conf:$ROOTFS_DIR/etc/wpa_supplicant.conf
$ROOTFS_OVERRIDE_DIR/etc/hostapd.conf:$ROOTFS_DIR/etc/hostapd.conf
$ROOTFS_OVERRIDE_DIR/etc/udhcpd.conf:$ROOTFS_DIR/etc/udhcpd.conf
$ROOTFS_OVERRIDE_DIR/etc/mdev.conf:$ROOTFS_DIR/etc/mdev.conf
$ROOTFS_OVERRIDE_DIR/etc/init.d/S50sshd:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90camera:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90wifiap:$ROOTFS_DIR/etc/init.d/_S90wifiap
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90wifista:$ROOTFS_DIR/etc/init.d/_S90wifista
$ROOTFS_OVERRIDE_DIR/etc/init.d/S99appstart:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/ssh/sshd_config:$ROOTFS_DIR/etc/ssh/
$ROOTFS_OVERRIDE_DIR/root/*.sh:$ROOTFS_DIR/root/
$ROOTFS_OVERRIDE_DIR/root/demo-h264enc:$ROOTFS_DIR/usr/bin/
$APP_DIR/demo-camera/demo-camera:$ROOTFS_DIR/usr/bin/
#$APP_DIR/demo-qt/digitalclock:$ROOTFS_DIR/root/
#$PREBUILT_DIR/libs/*:$ROOTFS_DIR/lib/
function copy_patch()
	echo "ADD PATCH"
function copy_file_to_rootfs()
  for line in ${copy_file_list[@]} ; do
	  srcfile=`echo $line | awk -F: '{print $1}'`
	  dstfile=`echo $line | awk -F: '{print $2}'`
	  cp -drf $srcfile $dstfile
  done
function build_uboot()
	cd $UBOOT_DIR
	make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} sun8iw8p1_spinand_emmc && \
	make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} fes && \
  	make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} boot0
 	[ $? -ne 0 ] && echo "build u-boot Failed"
function clean_uboot()
	cd $UBOOT_DIR
	make CROSS_COMPILE=${CROSS_COMPILE} distclean
function build_kernel()
	apt-get update
	apt-get install kmod -y
	cd $KERNEL_DIR
	make ARCH=arm -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} && \
	make ARCH=arm -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} uImage modules && \
	make ARCH=arm CROSS_COMPILE=${CROSS_COMPILE} INSTALL_MOD_PATH=${ROOTFS_DIR} modules_install
  	[ $? -ne 0 ] && echo "build kernel Failed"
  	cp -v ./arch/arm/boot/uImage ../tools/pack/chips/sun8iw8p1/boot-resource/boot-resource/
function clean_kernel()
	cd $KERNEL_DIR
	make ARCH=arm -j4 CROSS_COMPILE=${CROSS_COMPILE} distclean
function build_buildroot()
	echo "Build buildroot"
	cd $BUILDROOT_DIR
	mkdir -p $BUILDROOT_OUT_DIR
	#cp $BUILDROOT_OUT_DIR/.config configs/mangopi_defconfig
	#cp configs/mangopi_defconfig $BUILDROOT_OUT_DIR/.config
	make O=$BUILDROOT_OUT_DIR oldconfig
	mkdir -p $ROOTFS_DIR
	rm -r $ROOTFS_DIR
	tar xvf $BUILDROOT_OUT_DIR/images/rootfs.tar.bz2 -C $ROOTFS_DIR
function clean_buildroot()
	cd $BUILDROOT_DIR
	make O=$BUILDROOT_OUT_DIR clean
	rm -r $TOP_DIR/rootfs
function pack()
	copy_file_to_rootfs
	$HOSTTOOLS_DIR/make_ext4fs -s -l 200M /tmp/rootfs-ext4.img $ROOTFS_DIR
	cd $PACKTOOLS_DIR
	./pack -c sun8iw8p1 -p camdroid -b tiger-spinand-standard -e spinand
function build_library()
	cd $APP_DIR/ncnn/
	mkdir build
	cd build
	cmake -DCMAKE_TOOLCHAIN_FILE=../toolchains/arm-buildroot-gnueabihf.toolchain.cmake ..
	cd $APP_DIR/libfacedetection/
	mkdir build
	cd build
	cmake ../
function build_demos()
	cd $APP_DIR/
	bash buildapp.sh
	cp -v $APP_DIR/sdcard/ $TOP_DIR/rootfs/root/bin/ -rf
function clean_demos()
	cd $TOP_DIR
	source env-qt
	cd $APP_DIR/demo-camera/
	make clean
	cd $APP_DIR/demo-qt
	./run_qmake.sh
	make clean
if [ $# -eq 0 ] ; then
	copy_patch
	build_buildroot
	#build_uboot
	build_kernel
	#build_library
	build_demos
	pack
	case $1 in
	clean)
		clean_uboot
		clean_kernel
		clean_buildroot
		clean_demos
	uboot)
		build_uboot
	kernel)
		build_kernel
	buildroot)
		build_buildroot
	lib)
		build_library
	app)
		build_demos
	pack)
		pack
	esac
fi
因为要用mplayer重新配置了buildroot但没效果,是不是上面的编译和buildroot没关系啊!请大神帮忙看看怎么办。
#2 2021-12-05 15:23:27
schallstar
Re: v3s BSP内核 重新配置了buildroot,但是一键编译后没反应,请大神帮忙看看!!
确实没用,配置文件感觉没对上吧
