楼主 #1 2021-03-11 15:49:53
栗子龙骨汤
关于V3S启动random:crng init done的问题
U-Boot 2017.01-rc2-00057-g32ab180-dirty (Mar 10 2021 - 19:49:13 -0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No controllers found
reading zImage
3926952 bytes read in 205 ms (18.3 MiB/s)
11856 bytes read in 27 ms (428.7 KiB/s)
   Loading Device Tree to 42dfa000, end 42dffe4f ... OK
[    0.000000] Linux version 4.13.16-licheepi-zero (root@ubuntu) (gcc version 4.9.4 (Linaro GCC 4.9-2017.01)) #1 SMP Wed Mar 10 21:49:24 PST 2021
[    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33920 r8192 d23424 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0
[    0.000000] Memory: 53580K/64036K available (6144K kernel code, 217K rwdata, 1436K rodata, 1024K init, 262K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a367c0   ( 218 kB)
[    0.000000]        .bss : 0xc0a3d868 - 0xc0a7f1fc   ( 263 kB)
[    0.000021] Switching to timer-based delay loop, resolution 41ns
[    0.000181] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000415] Console: colour dummy device 80x30
[    0.000450] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000465] pid_max: default: 32768 minimum: 301
[    0.000597] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001223] CPU: Testing write buffer coherency: ok
[    0.001596] /cpus/cpu@0 missing clock-frequency property
[    0.001622] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002067] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002253] Hierarchical SRCU implementation.
[    0.002758] smp: Bringing up secondary CPUs ...
[    0.002775] smp: Brought up 1 node, 1 CPU
[    0.002784] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002791] CPU: All CPU(s) started in SVC mode.
[    0.003560] devtmpfs: initialized
[    0.006770] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007076] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007103] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007279] pinctrl core: initialized pinctrl subsystem
[    0.008165] random: get_random_u32 called from bucket_table_alloc+0xf0/0x240 with crng_init=0
[    0.008304] NET: Registered protocol family 16
[    0.008777] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009897] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.010002] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023316] SCSI subsystem initialized
[    0.023600] usbcore: registered new interface driver usbfs
[    0.023667] usbcore: registered new interface driver hub
[    0.023761] usbcore: registered new device driver usb
[    0.024021] pps_core: LinuxPPS API ver. 1 registered
[    0.024032] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.024057] PTP clock support registered
[    0.024274] Advanced Linux Sound Architecture Driver Initialized.
[    0.026131] clocksource: Switched to clocksource arch_sys_counter
[    0.036845] NET: Registered protocol family 2
[    0.037455] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037492] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037515] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037642] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037695] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.037922] NET: Registered protocol family 1
[    0.038506] RPC: Registered named UNIX socket transport module.
[    0.038526] RPC: Registered udp transport module.
[    0.038532] RPC: Registered tcp transport module.
[    0.038538] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040651] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049804] NFS: Registering the id_resolver key type
[    0.049861] Key type id_resolver registered
[    0.049868] Key type id_legacy registered
[    0.050802] random: fast init done
[    0.053602] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.053626] io scheduler noop registered
[    0.053633] io scheduler deadline registered
[    0.053876] io scheduler cfq registered (default)
[    0.053889] io scheduler mq-deadline registered
[    0.053896] io scheduler kyber registered
[    0.058377] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.125631] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.129124] console [ttyS0] disabled
[    0.149402] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.727378] console [ttyS0] enabled
[    0.734268] libphy: Fixed MDIO Bus: probed
[    0.738969] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.744764] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.750547] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.756732] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.762395] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.769646] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.775301] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.782530] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.787502] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.794459] libphy: stmmac: probed
[    0.799733] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.806394] ehci-platform: EHCI generic platform driver
[    0.811912] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.817601] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.825527] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.856152] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.863394] hub 1-0:1.0: USB hub found
[    0.867366] hub 1-0:1.0: 1 port detected
[    0.871869] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.878176] ohci-platform: OHCI generic platform driver
[    0.883730] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.890457] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.898425] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    0.971221] hub 2-0:1.0: USB hub found
[    0.975048] hub 2-0:1.0: 1 port detected
[    0.982718] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.992286] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.001275] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.008188] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.012728] i2c /dev entries driver
[    1.017756] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.027229] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.096183] sunxi-mmc 1c0f000.mmc: base:0xc41f8000 irq:23
[    1.143555] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.153701] mmc0: new high speed SDHC card at address 1234
[    1.159762] sunxi-mmc 1c10000.mmc: base:0xc41fc000 irq:24
[    1.166381] usbcore: registered new interface driver usbhid
[    1.171960] usbhid: USB HID core driver
[    1.176526] mmcblk0: mmc0:1234 SA08G 7.29 GiB
[    1.182998] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.191039] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.198577]  mmcblk0: p1 p2
[    1.205559] NET: Registered protocol family 17
[    1.210234] Key type dns_resolver registered
[    1.214649] Registering SWP/SWPB emulation handler
[    1.223979] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[    1.234695] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.251017] Console: switching to colour frame buffer device 100x30
[    1.263479] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.272032] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.283422] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.289270] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.298379] hub 3-0:1.0: USB hub found
[    1.302252] hub 3-0:1.0: 1 port detected
[    1.308598] using random self ethernet address
[    1.313058] using random host ethernet address
[    1.318619] usb0: HOST MAC b2:36:12:17:ac:95
[    1.322939] usb0: MAC 12:5f:93:9b:35:15
[    1.326928] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.334406] g_cdc gadget: g_cdc ready
[    1.340763] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.349221] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:04 UTC (4)
[    1.357458] vcc5v0: disabling
[    1.360436] ALSA device list:
[    1.363400]   #0: V3s Audio Codec
[    1.369472] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.379430] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.366895] EXT4-fs (mmcblk0p2): recovery complete
[    2.375087] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.383343] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.395709] devtmpfs: mounted
[    2.400082] Freeing unused kernel memory: 1024K
[    2.527436] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
Starting network: OK
Welcome to Buildroot
[   62.646199] random: crng init done
开机之后在login处输入root没反应,之后弹出random:crng init done
请教各位大神,这个得怎么处理
#2 2021-03-11 17:02:15
歌以咏志
已发帖子: 219
Re: 关于V3S启动random:crng init done的问题
把这个文件删了: /etc/init.d/S20urandom
楼主 #3 2021-03-11 17:06:01
栗子龙骨汤
好的,谢谢大佬
歌以咏志 说:
#4 2024-04-19 22:21:23
Rs428
栗子龙骨汤 说:
好的,谢谢大佬
歌以咏志 说:
楼主大佬解决了嘛,我删也没用哇,和楼主一样的问题,删了还是输入没反应
