楼主 #1 2021-03-20 10:48:52
feng888
已发帖子: 59
mount -t ntfs -o nls=utf8 /dev/mmcblk0p1 /mnt/udisk 挂载 ntfs 失败
mount -t ntfs /dev/mmcblk0p1 /mnt/udisk  成功,
但中文不支持,
/ # ls /mnt/udisk
[   23.512525] ntfs: (device mmcblk0p1): ntfs_ucstonls(): Unicode name contains characters that cannot be converted to character set iso8859-1.  You might want to try to use the mount option nls=utf8.
[   23.530239] ntfs: (device mmcblk0p1): ntfs_filldir(): Skipping unrepresentable inode 0x2b.
System Volume Information  cd_5.6M.dff
cd_11.2M.wav               ybk.wav
cd_2.8M.wav
/ # mount -t ntfs -o nls=utf8 /dev/mmcblk0p1 /mnt/udisk
[   89.758490] ntfs: (device mmcblk0p1): parse_options(): NLS character set utf8 not found.
mount: mounting /dev/mmcblk0p1 on /mnt/udisk failed: Invalid argument
#2 2021-03-20 11:07:39
raspberryman
已发帖子: 503
Re: mount -t ntfs -o nls=utf8 /dev/mmcblk0p1 /mnt/udisk 挂载 ntfs 失败
make menuconfig fs nls把编码都勾上
楼主 #3 2021-03-20 17:29:08
feng888
已发帖子: 59
可以了
#4 2021-03-20 17:40:35
奔跑的孩子
已发帖子: 51
feng888 说:
可以了
怎么做到的?
