求助论坛大佬!!!
有没有大佬弄过tina下的F1C100S的音频驱动配置,
我把Device Drivers->Sound card support->Advanced Linux Sound Architecture->ALSA for audio support->Allwinner SoC Audio support都选上了,还是没法驱动声卡,系统启动时还提示了failed to open for pcm 0,0,但是我在系统内核中并没有找到找到这个驱动选项。
下面系统的启动过程
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.65 (cotodo@cotodo) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #17 Fri Apr 16 01:44:20 UTC 2021
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: failed to reserve 32 MiB
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] free_area_init_node: node 0, pgdat c056ed0c, node_mem_map c059e000
[ 0.000000] Normal zone: 64 pages used for memmap
[ 0.000000] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/nandd init=/pseudo_init rdinit=/rdinit partitions=bootlogo@nanda:env@nandb:boot@nandc:rootfs@nandd:rootfs_data@nande:misc@nandf:private@nandg:UDISK@nandh cma=32M fb_base=0x81f00000 androidboot.serialno=0000000000000000000 boot_type=5
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Memory: 32MB = 32MB total
[ 0.000000] Memory: 26580k/26580k available, 6188k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0468f74 (4484 kB)
[ 0.000000] .init : 0xc0469000 - 0xc04864e4 ( 118 kB)
[ 0.000000] .data : 0xc0488000 - 0xc056f688 ( 926 kB)
[ 0.000000] .bss : 0xc056f688 - 0xc059db80 ( 186 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=552000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.005325] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[ 0.075248] pid_max: default: 32768 minimum: 301
[ 0.080432] Mount-cache hash table entries: 512
[ 0.086392] CPU: Testing write buffer coherency: ok
[ 0.092174] Setting up static identity map for 0xc0368ad0 - 0xc0368b28
[ 0.101481] devtmpfs: initialized
[ 0.106978] pinctrl core: initialized pinctrl subsystem
[ 0.112843] NET: Registered protocol family 16
[ 0.117999] DMA: failed to allocate 256 KiB pool for atomic coherent allocation
[ 0.126036] dump_class_init,844, success
[ 0.134696] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[ 0.158243] bio: create slab <bio-0> at 0
[ 0.163717] pwm module init!
[ 0.168263] usbcore: registered new interface driver usbfs
[ 0.174151] usbcore: registered new interface driver hub
[ 0.179955] usbcore: registered new device driver usb
[ 0.185551] Linux video capture interface: v2.00
[ 0.190533] Advanced Linux Sound Architecture Driver Initialized.
[ 0.198670] cfg80211: Calling CRDA to update world regulatory domain
[ 0.206156] Switching to clocksource sun3i high-res couter
[ 0.231082] get det_vbus is fail, 84
[ 0.236553] NET: Registered protocol family 2
[ 0.243235] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.250346] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.257013] TCP: Hash tables configured (established 512 bind 512)
[ 0.263576] TCP: reno registered
[ 0.266976] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.273094] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.280158] NET: Registered protocol family 1
[ 0.300223] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.306965] msgmni has been set to 51
[ 0.314365] io scheduler noop registered
[ 0.318535] io scheduler cfq registered (default)
[ 0.323515] [pm]aw_pm_init!
[ 0.326796] [pm]valid
[ 0.329204] [pm]valid
[ 0.332026] [DISP]disp_module_init
[ 0.342700] num_screens=1
[ 0.345469] screen_id=0
[ 0.348043] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
[ 0.353089] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
[ 0.358044] disp tv init
[ 0.360708] tcon_clk=0xc180c300, tcon_clk_parent=0x0
[ 0.365884] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
[ 0.371632] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
[ 0.377229] disp al tv init
[ 0.383038] fetch script datadisp.screen2_output_type fail
[ 0.389016] fetch script datadisp.screen2_output_mode fail
[ 0.397380] fetch script datadisp.fb2_format fail
[ 0.402640] fetch script datadisp.fb2_scaler_mode_enable fail
[ 0.408875] fetch script datadisp.fb2_width fail
[ 0.414035] fetch script datadisp.fb2_height fail
[ 0.420075] [DISP]disp_module_init finish
[ 0.438553] uart0: ttyS0 at MMIO 0x1c25000 (irq = 104) is a SUNXI
[ 0.444995] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
[ 0.453218] console [ttyS0] enabled, bootconsole disabled
[ 0.465766] misc dump reg init
[ 0.471060] [NAND]SPIC0_BASE_ADDR f1c05000
[ 0.476372] Failed to get dragonboard_flag
[ 0.480922] [NAND]nand init start
[ 0.484681] SpiNandHwInit: Start Nand Hardware initializing Nov 4 2018 05:15:38.....
[ 0.493408] kernel: nand version: 3 6019 20181104 1256
[ 0.499111] print_level is no used
[ 0.502922] request spi gpio ok!
[ 0.506595] request tx DMA
[ 0.509600] request general tx dma channel ok!
[ 0.514560] request rx DMA
[ 0.517563] request general rx dma channel ok!
[ 0.522514] NAND_ClkRequest
[ 0.525655] NAND_ClkRequest: get pll6 rate 200000000HZ
[ 0.531429] SPI nand ID: 21aaef 0
[ 0.535193] [SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
[ 0.543149] id_number_ctl is no used
[ 0.547112] _UpdateExtAccessFreqPara: no para.
[ 0.552727] PHY_Scan_DelayMode: right delay mode 0x0
[ 0.558705] PHY_Scan_DelayMode: right delay mode 0x800
[ 0.564530] _get_spic_clk_v1: sclk0=0x32
[ 0.568891] PHY_Scan_DelayMode: right delay mode,clk 50 MHz, bit[13]=0,bit[11]=0
[ 0.577142] physic_info_read start!!
[ 0.581135] physic_info_get_offset start!!
[ 0.590438] physic_info_get_one_copy start!!
[ 0.596247] block 13 page 40
[ 0.599938] block 13 page 41
[ 0.603707] block 13 page 42
[ 0.607410] block 13 page 43
[ 0.611102] block 13 page 44
[ 0.614879] block 13 page 45
[ 0.618568] block 13 page 46
[ 0.622344] block 13 page 47
[ 0.626039] block 13 page 48
[ 0.629729] block 13 page 49
[ 0.633496] block 13 page 50
[ 0.637206] block 13 page 51
[ 0.640895] block 13 page 52
[ 0.644665] block 13 page 53
[ 0.648354] block 13 page 54
[ 0.652074] block 13 page 55
[ 0.656429] physic info copy is ok
[ 0.660223]
[ 0.660223]
[ 0.663614] [SCAN_DBG] ==============Nand Architecture Parameter==============
[ 0.671629] [SCAN_DBG] Nand Chip ID: 0xff21aaef 0xffffffff
[ 0.678808] [SCAN_DBG] Nand Chip Count: 0x1
[ 0.684246] [SCAN_DBG] Nand Chip Connect: 0x1
[ 0.689653] [SCAN_DBG] Sector Count Of Page: 0x4
[ 0.695085] [SCAN_DBG] Page Count Of Block: 0x40
[ 0.700587] [SCAN_DBG] Block Count Of Die: 0x400
[ 0.706211] [SCAN_DBG] Plane Count Of Die: 0x2
[ 0.711615] [SCAN_DBG] Die Count Of Chip: 0x1
[ 0.717044] [SCAN_DBG] Bank Count Of Chip: 0x1
[ 0.722474] [SCAN_DBG] Optional Operation: 0x6d
[ 0.727975] [SCAN_DBG] Access Frequence: 0x32
[ 0.733500] [SCAN_DBG] =======================================================
[ 0.733500]
[ 0.774957] secure storage updata ok!
[ 0.779046] nand secure storage ok: 58,59
[ 0.783587] start block:60
[ 0.786598] [ND]boot start
[ 0.789695] [ND]boot :0xc1920000
[ 0.793316] [ND]boot->magic :0xaa55a5a5
[ 0.797567] [ND]boot->len :0x8000
[ 0.801238] [ND]boot->no_use_block :0x21
[ 0.805614] [ND]boot->uboot_start_block :0x8
[ 0.810347] [ND]boot->uboot_next_block :0x3a
[ 0.815106] [ND]boot->logic_start_block :0x21
[ 0.819935] [ND]mbr len :4096
[ 0.823250] [ND]_PARTITION len :2560
[ 0.827212] [ND]_NAND_STORAGE_INFO len :512
[ 0.831870] [ND]_FACTORY_BLOCK len :2048
[ 0.836300] [NE]partition_num: 0,size :0x36e00,cross_talk 0
[ 0.842526] [NE]part mbr size: 0x2000 type: 0
[ 0.847358] [NE]part bootlogo size: 0x400 type: 0
[ 0.852604] [NE]part env size: 0x200 type: 0
[ 0.857338] [NE]part boot size: 0x3000 type: 0
[ 0.862292] [NE]part rootfs size: 0xc800 type: 0
[ 0.867414] [NE]part rootfs_data size: 0xc800 type: 0
[ 0.873042] [NE]part misc size: 0x200 type: 0
[ 0.877872] [NE]part private size: 0x200 type: 0
[ 0.883017] [NE]part UDISK size: 0x18400 type: 0
[ 0.888267] [ND]partition->size :224768
[ 0.892551] [ND]partition->cross_talk :0
[ 0.896896] [ND]partition->attribute :0
[ 0.901146] [ND]partition->start.Chip_NO :0
[ 0.905808] [ND]partition->start.Block_NO :33
[ 0.910637] [ND]partition->end.Chip_NO :0
[ 0.915107] [ND]partition->end.Block_NO :511
[ 0.919840] [ND]partition->nand_disk[0].size :8192
[ 0.925175] [ND]partition->nand_disk[0].type :0
[ 0.930198] [ND]partition->nand_disk[1].size :1024
[ 0.935531] [ND]partition->nand_disk[1].type :0
[ 0.940552] [ND]partition->nand_disk[2].size :512
[ 0.945789] [ND]partition->nand_disk[2].type :0
[ 0.950810] [ND]partition->nand_disk[3].size :12288
[ 0.956241] [ND]partition->nand_disk[3].type :0
[ 0.961263] [ND]partition->nand_disk[4].size :51200
[ 0.966694] [ND]partition->nand_disk[4].type :0
[ 0.971716] [ND]partition->nand_disk[5].size :51200
[ 0.977147] [ND]partition->nand_disk[5].type :0
[ 0.982192] [ND]partition->nand_disk[6].size :512
[ 0.987406] [ND]partition->nand_disk[6].type :0
[ 0.992449] [ND]partition->nand_disk[7].size :512
[ 0.997661] [ND]partition->nand_disk[7].type :0
[ 1.002712] [ND]partition->nand_disk[8].size :99328
[ 1.008118] [ND]partition->nand_disk[8].type :0
[ 1.013168] [ND]partition->nand_disk[9].size :-1
[ 1.018286] [ND]partition->nand_disk[9].type :-1
[ 1.023427] [ND]partition->nand_disk[10].size :-1
[ 1.028641] [ND]partition->nand_disk[10].type :-1
[ 1.033876] [ND]partition->nand_disk[11].size :-1
[ 1.039090] [ND]partition->nand_disk[11].type :-1
[ 1.044329] [ND]partition->nand_disk[12].size :-1
[ 1.049544] [ND]partition->nand_disk[12].type :-1
[ 1.054780] [ND]partition->nand_disk[13].size :-1
[ 1.059995] [ND]partition->nand_disk[13].type :-1
[ 1.065233] [ND]partition->nand_disk[14].size :-1
[ 1.070447] [ND]partition->nand_disk[14].type :-1
[ 1.075684] [ND]partition->nand_disk[15].size :-1
[ 1.080897] [ND]partition->nand_disk[15].type :-1
[ 1.086135] [ND]partition->nand_disk[16].size :-1
[ 1.091348] [ND]partition->nand_disk[16].type :-1
[ 1.096586] [ND]partition->nand_disk[17].size :-1
[ 1.101800] [ND]partition->nand_disk[17].type :-1
[ 1.107039] [ND]partition->nand_disk[18].size :-1
[ 1.112277] [ND]partition->nand_disk[18].type :-1
[ 1.117490] [ND]partition->nand_disk[19].size :-1
[ 1.122729] [ND]partition->nand_disk[19].type :-1
[ 1.127943] [ND]partition->nand_disk[20].size :-1
[ 1.133182] [ND]partition->nand_disk[20].type :-1
[ 1.138395] [ND]partition->nand_disk[21].size :-1
[ 1.143633] [ND]partition->nand_disk[21].type :-1
[ 1.148847] [ND]partition->nand_disk[22].size :-1
[ 1.154086] [ND]partition->nand_disk[22].type :-1
[ 1.159301] [ND]partition->nand_disk[23].size :-1
[ 1.164538] [ND]partition->nand_disk[23].type :-1
[ 1.169752] [ND]phy_partition->PartitionNO :0
[ 1.174604] [ND]phy_partition->SectorNumsPerPage :8
[ 1.180008] [ND]phy_partition->PageNumsPerBlk :64
[ 1.185245] [ND]phy_partition->TotalBlkNum :479
[ 1.190266] [ND]phy_partition->FullBitmapPerPage :8
[ 1.195694] [ND]phy_partition->FreeBlock :0
[ 1.200330] [ND]phy_partition->TotalSectors :224768
[ 1.205759] [ND]phy_partition->StartBlock.Chip_NO :0
[ 1.211261] [ND]phy_partition->StartBlock.Block_NO :33
[ 1.216979] [ND]phy_partition->EndBlock.Chip_NO :0
[ 1.222312] [ND]phy_partition->EndBlock.Block_NO :511
[ 1.227911] [ND]phy_partition->next_phy_partition :0
[ 1.233438] [ND]phy_partition->PartitionNO 0 FACTORY BAD BLOCK:
[ 1.240096] [ND]phy_partition->PartitionNO 0 NEW BAD BLOCK:
[ 1.246394] [ND]build 1 phy_partition !
[ 1.250646] [ND]nand_info->type :0
[ 1.254441] [ND]nand_info->SectorNumsPerPage :8
[ 1.259461] [ND]nand_info->BytesUserData :16
[ 1.264218] [ND]nand_info->PageNumsPerBlk :64
[ 1.269046] [ND]nand_info->BlkPerChip :512
[ 1.273616] [ND]nand_info->FirstBuild :0
[ 1.277964] [ND]nand_info->FullBitmap :0
[ 1.282338] [ND]nand_info->bad_block_addr.Chip_NO :0
[ 1.287838] [ND]nand_info->bad_block_addr.Block_NO :0
[ 1.293459] [ND]nand_info->mbr_block_addr.Chip_NO :0
[ 1.298961] [ND]nand_info->mbr_block_addr.Block_NO :0
[ 1.304583] [ND]nand_info->no_used_block_addr.Chip_NO :0
[ 1.310470] [ND]nand_info->no_used_block_addr.Block_NO :33
[ 1.316572] [ND]nand_info->new_bad_block_addr.Chip_NO :0
[ 1.322484] [ND]nand_info->new_bad_block_addr.Block_NO :0
[ 1.328468] [ND]nand_info->new_bad_page_addr :65535
[ 1.333896] [ND]nand_info->partition_nums :1
[ 1.338627] [ND]sizeof partition:2384
[ 1.342706] [ND]nand_info->partition:0:
[ 1.346956] [ND]size:0x36e00
[ 1.350147] [ND]cross_talk:0x0
[ 1.353551] [ND]attribute:0x0
[ 1.356841] [ND]start: chip:0 block:33
[ 1.360994] [ND]end : chip:0 block:511
[ 1.365268] [ND]boot :0xc1920000
[ 1.368846] [ND]boot->magic :0xaa55a5a5
[ 1.373118] [ND]boot->len :0x8000
[ 1.376791] [ND]boot->no_use_block :0x21
[ 1.381137] [ND]boot->uboot_start_block :0x8
[ 1.385894] [ND]boot->uboot_next_block :0x3a
[ 1.390625] [ND]boot->logic_start_block :0x21
[ 1.395478] [ND]mbr len :4096
[ 1.398765] [ND]_PARTITION len :2560
[ 1.402751] [ND]_NAND_STORAGE_INFO len :512
[ 1.407385] [ND]_FACTORY_BLOCK len :2048
[ 1.412133] [ND]nand_partition0
[ 1.415796] [ND]nftl start:479,40
[ 1.419701] [ND]first
[ 1.561237] [ND]before second 479 439.
[ 1.643124] [NE]recover_phy_page_mapping no used page 33!!
[ 1.649228] [ND]recover 451 33
[ 1.652696] [ND]free block nums is 451 !
[ 1.657049] [NE]not power on gc 451!
[ 1.661007] [ND]nftl ok!
[ 1.663940] [ND]max_erase_times = 65000
[ 1.670719] nanda: unknown partition table
[ 1.678125] nandb: unknown partition table
[ 1.685570] nandc: unknown partition table
[ 1.692879] nandd: unknown partition table
[ 1.699152] nande: unknown partition table
[ 1.705517] nandf: unknown partition table
[ 1.712869] nandg: unknown partition table
[ 1.719151] nandh: unknown partition table
[ 1.724744] [NAND]nand init end
[ 1.729048] lradc_battery_probe:lradc_battery_probe ++++++
[ 1.735263] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
[ 1.742211] key base: f1c23400
[ 1.745736] irq num: 114 !
[ 1.748743] battery_data_hw_init:battery_data_hw_init ++++++
[ 1.755136] lradc_battery_probe:lradc_battery_probe ------
[ 1.761767] usbcore: registered new interface driver asix
[ 1.767906] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.775624] ehci-platform: EHCI generic platform driver
[ 1.781678] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.789248] zero gadget: Gadget Zero, version: Cinco de Mayo 2008
[ 1.796122] zero gadget: zero ready
[ 1.800560] /soc/usbc0@0: could not find phandle
[ 1.805793] get regulator_io is no nocare
[ 1.810394] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 1.818423] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 1.830165] hub 1-0:1.0: USB hub found
[ 1.834502] hub 1-0:1.0: 1 port detected
[ 1.839366] wrn: hcd is not enable, need not stop hcd
[ 1.847720] failed to get gpio-spk and gpio_num
[ 1.852900] headphonevol:59,spkervol:27,maingain:4,pa_sleep_time:350
[ 1.860811] sun3iw1p1-pinctrl pio: missing allwinner,pins property in node daudio0
[ 1.869561] sun3iw1p1-pinctrl pio: missing allwinner,pins property in node daudio0
[ 1.878054] [daudio]request pinctrl handle
[ 1.882539] for audio failed
[ 1.885971] sunxi-daudio: probe of 1c22000.daudio failed with error -22
[ 1.894804] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
[ 1.902861] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
[ 1.910789] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
[ 1.918566] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
[ 1.926329] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker
[ 1.934894] sunxi-internal-cpudai 1c23c00.cpudai0-controller: ASoC: pcm constructor failed: -12
[ 1.944646] sunxi-codec-machine sound.2: ASoC: can't create pcm SUNXI-CODEC :-12
[ 1.952902] sunxi-codec-machine sound.2: ASoC: failed to instantiate card -12
[ 1.961203] snd_soc_register_card failed -12
[ 1.966076] sunxi-codec-machine: probe of sound.2 failed with error -12
[ 1.974186] ipip: IPv4 over IPv4 tunneling driver
[ 1.980550] gre: GRE over IPv4 demultiplexor driver
[ 1.986090] ip_gre: GRE over IPv4 tunneling driver
[ 1.993764] TCP: cubic registered
[ 1.997459] Initializing XFRM netlink socket
[ 2.002362] NET: Registered protocol family 17
[ 2.007382] NET: Registered protocol family 15
[ 2.012854] VFP support v0.3: not present
[ 2.018493] [LCD]lcd_module_init
[ 2.026199] [LCD]lcd_module_init finish
[ 2.030825] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 2.038207] ALSA device list:
[ 2.041514] No soundcards found.
[ 2.052074] VFS: Mounted root (squashfs filesystem) readonly on device 93:48.
[ 2.064305] devtmpfs: mounted
[ 2.068323] Freeing unused kernel memory: 116K (c0469000 - c0486000)
mount: mounting none on /dev failed: Resource busy
mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
mount: mounting /dev/by-name/rootfs_data on /overlay failed: Invalid argument
Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
mke2fs 1.42.12 (29-Aug-2014)
[ 3.691121] EXT4-fs (nande): mounted filesystem with ordered data mode. Opts: (null)
-- run rc.preboot --
-- set volume --
Failed to open mixer
-- play music --
-- end --
[ 6.692062] EXT4-fs (nandh): mounted filesystem with ordered data mode. Opts: (null)
[ 7.004420] usbip_core: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.026495] usbip_core: USB/IP Core v1.0.0
[ 7.041223] usbip_host: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.062946] usbcore: registered new interface driver usbip-host
[ 7.069554] usbip_host: USB/IP Host Driver v1.0.0
[ 7.088435] vhci_hcd: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.123030] vhci_hcd vhci_hcd: USB/IP Virtual Host Controller
[ 7.129453] vhci_hcd vhci_hcd: new USB bus registered, assigned bus number 2
[ 7.161479] hub 2-0:1.0: USB hub found
[ 7.172242] hub 2-0:1.0: 8 ports detected
[ 7.191470] vhci_hcd: USB/IP 'Virtual' Host Controller (VHCI) Driver v1.0.0
-- run rc.final --
insmod F1C200s-board
ax88772c start....
cat /sys/devices/soc/usbc0/usb_host
[ 8.251888]
[ 8.251888] insmod_host_driver
[ 8.251888]
[ 8.259089] /soc/usbc0@0: could not find phandle
[ 8.264352] get regulator_io is no nocare
host_chose finished!
start udhcpc ---------------------
-- end --最近编辑记录 linux小白 (2021-04-30 15:42:38)
什么问题呢?
无法将芯片的音频驱动内核编入内核,我在/dev/snd目录下看到啥东西都没有的,大佬请问一下,知道这是怎么回事嘛
tina 编译的估计默认就已经驱动了集成声卡上面的麦克风和喇叭。
enmm,那我用Tina里面自带的播放音频程序的时候,提示了pcm找不到
root@TinaLinux:/etc# tinyplay kaiji.wav
failed to open for pcm 0,0离线
发一个 widora tiny200 tina3.5 固件@spi nor flash
http://whycan.com/t_6221.html
(出处:哇酷开发者社区)F1C100s tina3 程序, 请教屏闪是怎么回事?
http://whycan.com/t_3156.html#p38277
(出处:哇酷开发者社区)
啊,,大佬,这个都是一些视频的,而且和我的问题好像没啥关系
先测下这些固件能不能放声音
还不是不能啊,,
先测下这些固件能不能放声音
大佬,请问一下你知道在sun3iw1_daudio.c这个文件中下面这个位置失败的原因是什么吗
//代码太长我就不完全粘出来了
static int __init sunxi_daudio_platform_probe(struct platform_device *pdev){
if (!sunxi_daudio->pinctrl) {
sunxi_daudio->pinctrl = devm_pinctrl_get(&pdev->dev);
if (IS_ERR_OR_NULL(sunxi_daudio->pinctrl)) {
pr_warn("[daudio]request pinctrl handle ");
pr_warn("for audio failed\n");
return -EINVAL;
}离线
我用TINA+F1C100S也是搞定这个声音,
V3S 的可以,手册上的配置好好像不对。
我也感觉配置文件怪怪的,大佬,你有没有tina下的f1c200设备树配置文件,能不能发我一份,谢谢了
