onfigure: WARNING: unrecognized options: --disable-gtk-doc, --disable-gtk-doc-html, --disable-doc, --disable-docs, --disable-documentation, --with-xmlto, --with-fop, --enable-ipv6, --disable-nls
checking whether the C++ compiler works... no
configure: error: in `/home/obm/123/buildroot-2017.08/output/build/tesseract-ocr-3.05.00':
configure: error: C++ compiler cannot create executables
See `config.log' for more details
package/pkg-generic.mk:217: recipe for target '/home/obm/123/buildroot-2017.08/output/build/tesseract-ocr-3.05.00/.stamp_configured' failed
make: *** [/home/obm/123/buildroot-2017.08/output/build/tesseract-ocr-3.05.00/.stamp_configured] Error 77离线
已经添加了C++ support,但是还是没有
把你的 .config 发上来看看
如果你是buildroot buildin的toolchain需要配置c++支持,如果是外部toolchain,一般都是支持c++的
cube wrote:
把你的 .config 发上来看看
你 buildroot make menuconfig 打开了 c++ support 和相关选项后,有没有重新执行 make clean && make all ?
没,我再试试,谢谢
542396750@qq.com wrote:
没,我再试试,谢谢
https://buildroot.org/downloads/manual/manual.html#full-rebuild
建议看一下 buildroot 文档,尤其是 “8.2. Understanding when a full rebuild is necessary” 这一块。buildroot 缺点就是每次menuconfig 做点啥改动,几乎都得重新 make clean all
@unturned3
3Q Thanks
