楼主 # 2022-01-17 19:01:38
jordonwu
已发帖子: 66
mangopi_r3 nand烧录错误
请教下,在FEL模式下,通过如下命令加载了u-boot到mangopi-r3板子后,串口有输出,但是通过如下命令
> mtd erase spi-nand0  擦除nand提示如下错误
=> mtd erase spi-nand0
unknown raw ID 82e678b8
MTD device spi-nand0 not found, ret -19
这个是不是nand有问题呢?谢谢
U-Boot SPL 2020.07 (Nov 18 2020 - 19:31:42 +0800)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2020.07 (Nov 18 2020 - 19:31:42 +0800) Allwinner Technology
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
unrecognized JEDEC id bytes: ff, c8, 51
unknown raw ID 82e68588
List of MTD devices:
No MTD device found
Boot Device: fel
Boot Slot 0: empty
Boot Slot 1: empty
Booting from FEL...
#1 2022-01-17 19:13:55
已发帖子: 3,393
Re: mangopi_r3 nand烧录错误
你的 u-boot 可能不支持这个spi flash?
楼主 #2 2022-01-17 19:28:30
jordonwu
已发帖子: 66
固件直接下载的 http://download.dfrobot.top/f1c/Camera_firmwareV0.1.zip 这个
用了链接 https://mangopi.org.cn/f1c_nand  的 from-fel-to-dfu.bat脚本可以烧写,但是到43%时又提示错误
Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release!!!
Cannot open DFU device 1f3a:1010
Opening DFU capable USB device...
ID 1f3a:1010
Run-time device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Setting #3 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 4096
Copying data from PC to DFU device
Download        [==========               ]  43%     33423360 bytes failed!
state(10) = dfuERROR, status(14) = Something went wrong, but the device does not know what it was
can't detach
Resetting USB to switch back to runtime mode
