折腾一个晚上,终于把 littlevgl移植到新唐N32903U1DN芯片上面裸奔了.
soc只支持16bit颜色,
littlevgl改成16bit编译出错,
所以显示就酱紫了,
接下来继续找bug
差不多搞定N32903显示 littlevgl了。
把我的车载GPS 5寸 800x480 LCD屏点起来!
很好奇littlevgl的流程程度,楼主能否共享一下代码
速度怎么样
能移植到NUC972上吗?
大神,能看下您移植的代码吗,最近也在用N32905移植littlevgl,一直没成功
谢谢,现在才一个积分,怎么才能快点挣积分?
没人告诉吗,怎么样才能快速挣积分
看到酷客的972上有littlevgl,应该可以用在32903
谢谢Lvy,现在已经能够正常显示测试demo了,现在触摸还不行,正在找问题
上传两张照片,下周上班在解决触摸问题
这个是mian函数
这个是实现的tft_init
这个是触摸屏实现函数
现在显示可以,但是触摸没有反应,哪位大神帮忙看看是啥问题,感谢
最近编辑记录 oldersu (2019-05-13 09:00:14)
没有实现,还是官方的源码
这个要怎么实现,晕哥,有没有可以参考的
这个是timer的实现
https://github.com/littlevgl/lvgl/blob/master/lv_misc/lv_task.c
* Call it periodically to handle lv_tasks.
LV_ATTRIBUTE_TASK_HANDLER void lv_task_handler(void)
LV_LOG_TRACE("lv_task_handler started");
/*Avoid concurrent running of the task handler*/
static bool task_handler_mutex = false;
if(task_handler_mutex) return;
task_handler_mutex = true;
static uint32_t idle_period_start = 0;
static uint32_t handler_start = 0;
static uint32_t busy_time = 0;
if(lv_task_run == false) return;
handler_start = lv_tick_get();
/* Run all task from the highest to the lowest priority
* If a lower priority task is executed check task again from the highest priority
* but on the priority of executed tasks don't run tasks before the executed*/
lv_task_t * task_interrupter = NULL;
lv_task_t * next;
bool end_flag;
do {
end_flag = true;
task_deleted = false;
task_created = false;
LV_GC_ROOT(_lv_task_act) = lv_ll_get_head(&LV_GC_ROOT(_lv_task_ll));
while(LV_GC_ROOT(_lv_task_act)) {
/* The task might be deleted if it runs only once ('once = 1')
* So get next element until the current is surely valid*/
next = lv_ll_get_next(&LV_GC_ROOT(_lv_task_ll), LV_GC_ROOT(_lv_task_act));
/*We reach priority of the turned off task. There is nothing more to do.*/
if(((lv_task_t *)LV_GC_ROOT(_lv_task_act))->prio == LV_TASK_PRIO_OFF) {
break;
/*Here is the interrupter task. Don't execute it again.*/
if(LV_GC_ROOT(_lv_task_act) == task_interrupter) {
task_interrupter = NULL; /*From this point only task after the interrupter comes, so the interrupter is not interesting anymore*/
LV_GC_ROOT(_lv_task_act) = next;
continue; /*Load the next task*/
/*Just try to run the tasks with highest priority.*/
if(((lv_task_t *)LV_GC_ROOT(_lv_task_act))->prio == LV_TASK_PRIO_HIGHEST) {
lv_task_exec(LV_GC_ROOT(_lv_task_act));
/*Tasks with higher priority then the interrupted shall be run in every case*/
else if(task_interrupter) {
if(((lv_task_t *)LV_GC_ROOT(_lv_task_act))->prio > task_interrupter->prio) {
if(lv_task_exec(LV_GC_ROOT(_lv_task_act))) {
task_interrupter = LV_GC_ROOT(_lv_task_act); /*Check all tasks again from the highest priority */
end_flag = false;
break;
/* It is no interrupter task or we already reached it earlier.
* Just run the remaining tasks*/
else {
end_flag = false;
break;
if(task_deleted) break; /*If a task was deleted then this or the next item might be corrupted*/
if(task_created) break; /*If a task was deleted then this or the next item might be corrupted*/
LV_GC_ROOT(_lv_task_act) = next; /*Load the next task*/
} while(!end_flag);
busy_time += lv_tick_elaps(handler_start);
uint32_t idle_period_time = lv_tick_elaps(idle_period_start);
if(idle_period_time >= IDLE_MEAS_PERIOD) {
idle_last = (uint32_t)((uint32_t)busy_time * 100) / IDLE_MEAS_PERIOD; /*Calculate the busy percentage*/
idle_last = idle_last > 100 ? 0 : 100 - idle_last; /*But we need idle time*/
busy_time = 0;
idle_period_start = lv_tick_get();
task_handler_mutex = false; /*Release the mutex*/
LV_LOG_TRACE("lv_task_handler ready");
是这个吗?
不对, 上面说错了, 是 lv_tick_inc 这个函数有没有实现?
晕哥,你说的是这个吗
lv_tick_inc() 这个函数实现是这样的
晕哥,加了这句有反应了,这句是干什么用的?
这个是button按钮,现在触摸有反应了,但是button事件还是不响应,我的是电阻触摸屏,需要先上电校准吗?
https://whycan.cn/files/members/1647/button.png
对的, 把触摸获取到的 X/Y 和 LCD 显示的 X/Y 一 一对应起来就可以了, 所以要先校准。
这个相当于单片机的晶振, 提供时钟源。
好的,我去把触摸屏校准下
现在把屏幕校准完毕了,做了个滑块,能够得到滑动的值,但是滑块的指针不跟着动是为啥啊?那位大神告诉下?
创建的slider
slider的action
串口调试的结果,显示能够取得新的slider值,但是指针不变,请晕哥,帮忙看下是哪的问题啊?
模拟器试了可以,正常滑动
好的,那我慢慢调试吧
晕哥,你那有触摸屏滑动触摸的程序吗,能发我参考下吗,不知道滑动触摸程序该怎么处理,看了下littlevgl的程序也没看懂,有其他的程序吗?发我参考学习下
最近编辑记录 oldersu (2019-05-14 08:33:37)
好的
把触摸驱动写好,落笔抬笔,坐标等参数传递正确,滑动肯定没有问题的。
你那有相关程序吗,参考下,折腾好几天了,没进展
刷新慢是什么问题?有人知道吗
1. 优化一下这个函数 lv_tick_inc(1)
2. 可能的键盘/触摸读取函数阻塞了 UI.
如果是裸奔,键盘/触摸由中断去读数据, 读到队列, 或者更简单一点全局变量里面.
如果是OS, 专门开一个线程去读键盘/触摸数据, 读到队列, 或者更简单一点全局变量里面.
这样操作不会塞住 UI 线程。
UI一旦卡住, 给用户非常不好的体验, 就像早期的安卓机。
这是触摸的程序,如何放到中断
把动画关了,不卡了,但是没有之前的动画效果了
不过还是要找原因,不知道中断如何赋值给这个
indev_drv.read=?
sysEnableCache(CACHE_WRITE_BACK);
使能了系统缓存可以了
不卡了,但是光标闪烁太快,受不了,
改到1000了,还是快
# define LV_TA_CURSOR_BLINK_TIME 10000 /*ms*/
需要修改这个,在lv_conf.h中
一波三折,下一步开始编写界面测试
学习一下
支持,我也用N32905,准备移植这个,谢谢
挖出来学习一下,主要想看看有没加速处理。
官方N9H30有lvgl的代码了
