楼主 # 2022-02-23 17:47:09
droptop
已发帖子: 23
Lichee Pi Nano sdcard boot hangs
Hi y'all,
I built and sdcard image for the Lichee Pi Nano using the buildroot image at https://github.com/florpor. However on booting with the flashed sdcard
U-Boot SPL 2018.01-05679-g013ca457fd-dirty (Aug 02 2019 - 09:57:28) DRAM: 32 MiB Trying to boot from MMC1
and it hangs indefinitely. I would be very grateful for any ideas
#1 2022-02-23 18:00:22
tigger
已发帖子: 172
Re: Lichee Pi Nano sdcard boot hangs
试一试 sunxi-fel 的 uboot 命令:
sunxi-fel uboot u-boot-sunxi-with-spl.bin
参考: 荔枝派zero/小智极客S3/V3s使用sunxi-fel 借 u-boot 启动 Linux系统, 无需 spi flash / TF 卡
https://whycan.com/t_2388.html
#2 2022-02-23 18:09:36
wuwuw
顶,我也是,不过我是FLASH启动,可以进入内核;但在插入一张空的SD卡在启动就会卡住在Trying to boot from MMC1,也不知道咋整现在
楼主 #3 2022-02-23 19:02:06
droptop
已发帖子: 23
Hi tigger,
My goal is to boot from an sd card. not the NOR flash. I've swapped sd cards and it is still stuck at trying to boot from mmc1. Is this a general problem with this board?
#4 2022-02-23 22:31:35
X3
已发帖子: 85
mmc1 不支持 启动,
只有 mmc0 / mmc2 支持启动。
楼主 #5 2022-02-23 22:57:28
droptop
已发帖子: 23
Hi X3,
Can you point me to the source of your information ??
#6 2023-05-25 01:21:48
bankbank
I am having a similar issue, I have the lichee pi nano board and have been attempting for several days to get it to boot from the sd card
this is what I always get:
U-Boot SPL 2020.07 (May 24 2023 - 21:04:19 +0800)
DRAM: 32 MiB
U-Boot 2020.07 (May 24 2023 - 21:04:19 +0800) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
DRAM:  32 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
and then it just freezes there
the built-in program that came on the 16mb spi flash works fine, has a littlevgl demo
edit: I was able to finally get this buildroot to work https://github.com/mclewell/licheepi-nano-lcd
now I'm trying to figure out how to use st7789v 320x240 LCD display
最近编辑记录 bankbank (2023-05-25 03:53:29)
