这是我按照本站的资料编译出来的RNDIS gadget驱动的linux 内核(f1c100s licheepi nano),不知道为什么,出现这种现象。
[ 0.886974] SCSI Media Changer driver v0.25
[ 0.894580] m25p80 spi0.0: xt25f128b (16384 Kbytes)
[ 0.899645] 4 ofpart partitions found on MTD device spi0.0
[ 0.905130] Creating 4 MTD partitions on "spi0.0":
[ 0.909995] 0x000000000000-0x000000100000 : "u-boot"
[ 0.917644] 0x000000100000-0x000000110000 : "dtb"
[ 0.924740] 0x000000110000-0x000000510000 : "kernel"
[ 0.932229] 0x000000510000-0x000001000000 : "rootfs"
[ 0.940264] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.946916] ehci-platform: EHCI generic platform driver
[ 0.952428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.958725] ohci-platform: OHCI generic platform driver
[ 0.965418] i2c /dev entries driver
[ 1.025295] sunxi-mmc 1c0f000.mmc: base:0x8bc3d9cb irq:19
[ 1.032664] usbcore: registered new interface driver usbhid
[ 1.038351] usbhid: USB HID core driver
[ 1.059849] NET: Registered protocol family 17
[ 1.064526] Key type dns_resolver registered
[ 1.071134] Loading compiled-in X.509 certificates
[ 1.086388] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc073a4b8)
[ 1.095322] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073979c)
[ 1.103002] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.109671] [drm] No driver support for vblank timestamp query.
[ 1.163589] Console: switching to colour frame buffer device 60x34
[ 1.186987] sun4i-drm display-engine: fb0: frame buffer device
[ 1.194159] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.203328] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.215355] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.221150] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.231249] hub 1-0:1.0: USB hub found
[ 1.235309] hub 1-0:1.0: 1 port detected
[ 1.241624] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.259296] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.266123] vcc3v3: disabling
[ 1.269105] ALSA device list:
[ 1.272071] #0: Loopback 1
[ 1.275955] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.284568] cfg80211: failed to load regulatory.db
[ 1.386335] random: crng init done
[ 2.705076] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 2.712845] devtmpfs: mounted
[ 2.720588] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting network: OK
Welcome to Buildroot
nano login:我的启动信息
