HELLO! BOOT0 is starting!
BOOT0 commit : #.###
set pll start
periph0 has been enabled
set pll end
board init ok
ZQ value = 0x2d
get_pmu_exist() = -1
ddr_efuse_type: 0xa
mark_id: 0x60
trefi:7.8ms
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0xa
mark_id: 0x60
trefi:7.8ms
[AUTO DEBUG] rank 0 row = 13
[AUTO DEBUG] rank 0 bank = 8
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.32
DRAM CLK = 792 MHz
DRAM Type = 3 (2:DDR2,3:DDR3)
DRAMC read ODT off.
DRAM ODT value: 0x42.
ddr_efuse_type: 0xa
mark_id: 0x60
DRAM SIZE =128 M
PLL_DDR_CTRL_REG:0xf8004100
DRAM_CLK_REG:0xc0000000
[TIMING DEBUG] MR2= 0x18
DRAM simple test OK.
rtc standby flag is 0x0, super standby flag is 0x0
boot0_main.c 71 128 M
spinand/spinand_osal_boot0.c 143 (NAND_CLK_BASE_ADDR + 0x0940) 0x8100000b
spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 16
Jump to second Boot.
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 21 2022 - 23:45:21 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
[00.023]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
MMC:
Loading Environment from FAT... In: serial
Out: serial
Err: serial
No working controllers found
List of MTD devices:
* spi-nand0
- device: spi-nand@0
- parent: spi@4025000
- driver: spi_nand
- path: /spi@4025000/spi-nand@0
- type: NAND flash
- block size: 0x20000 bytes
- min I/O: 0x800 bytes
- OOB size: 64 bytes
- OOB available: 24 bytes
- 0x000000000000-0x000000100000 : "boot0"
- 0x000000100000-0x000000200000 : "u-boot"
- 0x000000200000-0x000000220000 : "dtb"
- 0x000000220000-0x000000820000 : "kernel"
- 0x000000820000-0x000008000000 : "rootfs"
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 22 2022 - 09:02:04 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Kernel image @ 0x40080000 [ 0x000000 - 0x4923a0 ]
## Flattened Device Tree blob at 40020000
Booting using the fdt blob at 0x40020000
Loading Device Tree to 49fef000, end 49fff3e6 ... OK
[ 0.000000] Linux version 5.4.61+ (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP PREEMPT Wed Apr 13 17:16:30 CST 2022
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] 8<--- cut here ---
[ 0.000000] Unable to handle kernel paging request at virtual address c9fef000
[ 0.000000] pgd = (ptrval)
[ 0.000000] [c9fef000] *pgd=00000000
[ 0.000000] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 0.000000] Modules linked in:
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.4.61+ #1
[ 0.000000] Hardware name: Generic DT based system
[ 0.000000] PC is at fdt32_ld+0x0/0xc
[ 0.000000] LR is at fdt_check_header+0xc/0x11c
[ 0.000000] pc : [<c070d934>] lr : [<c070d9f8>] psr: a00000d3
[ 0.000000] sp : c0c01f20 ip : 40c90097 fp : c77fff40
[ 0.000000] r10: c0c0e0e4 r9 : c0c71390 r8 : 00000000
[ 0.000000] r7 : c9fef000 r6 : c0b1d874 r5 : c0c8a73c r4 : c0b1d874
[ 0.000000] r3 : c9fef000 r2 : c0c8a73c r1 : 00000000 r0 : c9fef000
[ 0.000000] Flags: NzCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment none
[ 0.000000] Control: 10c5387d Table: 4000406a DAC: 00000051
[ 0.000000] Process swapper (pid: 0, stack limit = 0x(ptrval))
[ 0.000000] Stack: (0xc0c01f20 to 0xc0c02000)
[ 0.000000] 1f20: c0b1d874 c0c8a73c c0b1d874 c05696a4 c0b1d874 c0c08118 c0c66180 c0c06c40
[ 0.000000] 1f40: 40000000 c0c71390 c0c0e0e4 c0b1e6fc 00000000 0000000c c0b28d4c c0b024c0
[ 0.000000] 1f60: ffffffff 10c5387d 00000051 c09efecc c0c66000 49fef000 410fc075 10c5387d
[ 0.000000] 1f80: 00000000 c01577a4 c0974d79 00000000 00000001 c0b00330 00000051 c0c03dc0
[ 0.000000] 1fa0: c0c66000 49fef000 410fc075 10c5387d 00000000 c0b00968 00000000 00000000
[ 0.000000] 1fc0: 00000000 00000000 00000000 c0b2d0c0 00000000 00000000 00000000 c0b00330
[ 0.000000] 1fe0: 00000051 10c0387d 00000000 49fef000 410fc075 00000000 00000000 00000000
[ 0.000000] [<c070d934>] (fdt32_ld) from [<c070d9f8>] (fdt_check_header+0xc/0x11c)
[ 0.000000] [<c070d9f8>] (fdt_check_header) from [<c05696a4>] (__unflatten_device_tree+0x28/0xfc)
[ 0.000000] [<c05696a4>] (__unflatten_device_tree) from [<c0b1e6fc>] (unflatten_device_tree+0x24/0x40)
[ 0.000000] [<c0b1e6fc>] (unflatten_device_tree) from [<c0b024c0>] (setup_arch+0x618/0xa64)
[ 0.000000] [<c0b024c0>] (setup_arch) from [<c0b00968>] (start_kernel+0x54/0x3e0)
[ 0.000000] [<c0b00968>] (start_kernel) from [<00000000>] (0x0)
[ 0.000000] Code: ebf054cb e28dd014 e49df004 c070d824 (e5900000)
[ 0.000000] random: get_random_bytes called from init_oops_id+0x20/0x3c with crng_init=0
[ 0.000000] ---[ end trace 0000000000000000 ]---
[ 0.000000] Kernel panic - not syncing: Attempted to kill the idle task!
[ 0.000000] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 22 2022 - 17:37:29 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Kernel image @ 0x40080000 [ 0x000000 - 0x3a7760 ]
## Flattened Device Tree blob at 42000000
Booting using the fdt blob at 0x42000000
Loading Device Tree to 43f5b000, end 43f6b3e6 ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #10 SMP PREEMPT Fri Apr 22 17:17:39 CST 2022
[ 0.000000] cma: dma_contiguous_reserve(limit ffffffff)
[ 0.000000] cma: dma_contiguous_reserve: reserving 8 MiB for global area
[ 0.000000] cma: cma_declare_contiguous(size 0x00800000, base 0x00000000, limit 0xffffffff alignment 0x00000000)
[ 0.000000] Bad mode in prefetch abort handler detected
[ 0.000000] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP ARM
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.4.61 #10
[ 0.000000] PC is at 0xa9530408
[ 0.000000] LR is at __invoke_psci_fn_smc+0x40/0x60
[ 0.000000] pc : [<a9530408>] lr : [<c04a2358>] psr: 600001d6
[ 0.000000] sp : c0901e98 ip : c0901ef0 fp : c77fff40
[ 0.000000] r10: c090e064 r9 : c096bd90 r8 : 40000000
[ 0.000000] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
[ 0.000000] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 84000000
[ 0.000000] Flags: nZCv IRQs off FIQs off Mode MON_32 ISA ARM Segment none
[ 0.000000] Control: 10c5387d Table: 4000406a DAC: c0900000
[ 0.000000] Stack: (0xc0901e98 to 0xc0902000)
[ 0.000000] 1e80: 84000000 00000000
[ 0.000000] 1ea0: 00000000 00000000 00000000 00000000 00000000 00000000 40000000 c096bd90
[ 0.000000] 1ec0: c090e064 c77fff40 c0901ef0 c0901e98 c04a2358 a9530408 600001d6 ffffffff
[ 0.000000] 1ee0: c0900000 00000000 c0961180 c0906d80 00000000 00000000 00000000 00000000
[ 0.000000] 1f00: c0901f0c 00000000 c0961180 c04a25b0 c3f5ba04 00000000 00000001 00000000
[ 0.000000] 1f20: c0900000 c081882c c0900000 c76d4980 c0961180 c0906d80 40000000 c0818a94
[ 0.000000] 1f40: c0900000 c0818c40 c08322c0 00000000 00000000 c0823ab8 c0908258 c08024c0
[ 0.000000] 1f60: ffffffff 10c5387d 00000051 c07844a4 c0961000 43f5b000 410fc075 10c5387d
[ 0.000000] 1f80: 00000000 c01575b8 c0721ea5 00000000 00000001 c0800330 00000051 c0903bc0
[ 0.000000] 1fa0: c0961000 43f5b000 410fc075 10c5387d 00000000 c0800968 00000000 00000000
[ 0.000000] 1fc0: 00000000 00000000 00000000 c08270c0 00000000 00000000 00000000 c0800330
[ 0.000000] 1fe0: 00000051 10c0387d 00000000 43f5b000 410fc075 00000000 00000000 00000000
[ 0.000000] [<c04a2358>] (__invoke_psci_fn_smc) from [<c0901e98>] (init_stack+0x1e98/0x2000)
[ 0.000000] Code: bad PC value
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Kernel image @ 0x40080000 [ 0x000000 - 0x3a6ce0 ]
Loading Device Tree to 43f5b000, end 43f6b35f ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #13 SMP PREEMPT Fri Apr 22 18:30:15 CST 2022
[ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
[ 0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init partitions=boot@mmcblk0p1:rootfs@mmcblk0p2 cma=8M ubi.mtd=5 rootfstype=ubifs root=ubi0:rootfs
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 112660K/131072K available (5120K kernel code, 385K rwdata, 1836K rodata, 1024K init, 148K bss, 10220K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x3d8 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008026] Switching to timer-based delay loop, resolution 41ns
[ 0.014206] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023961] Console: colour dummy device 80x30
[ 0.028451] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038831] pid_max: default: 32768 minimum: 301
[ 0.043584] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050902] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059240] CPU: Testing write buffer coherency: ok
[ 0.064506] /cpus/cpu@0 missing clock-frequency property
[ 0.069825] /cpus/cpu@1 missing clock-frequency property
[ 0.075171] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081437] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088132] rcu: Hierarchical SRCU implementation.
[ 0.093414] smp: Bringing up secondary CPUs ...
[ 0.098530] smp: Brought up 1 node, 1 CPU
[ 0.102539] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.108796] CPU: All CPU(s) started in SVC mode.
[ 0.113839] devtmpfs: initialized
[ 0.128503] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.136863] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.147016] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154258] pinctrl core: initialized pinctrl subsystem
[ 0.161610] NET: Registered protocol family 16
[ 0.166308] cma: cma_alloc(cma (ptrval), count 64, align 6)
[ 0.173762] cma: cma_alloc(): returned (ptrval)
[ 0.178476] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.248527] rtc_ccu: sunxi ccu init OK
[ 0.255402] ccu: sunxi ccu init OK
[ 0.259983] r_ccu: sunxi ccu init OK
[ 0.331437] iommu: Default domain type: Translated
[ 0.336533] sunxi iommu: irq = 24
[ 0.343229] SCSI subsystem initialized
[ 0.348177] usbcore: registered new interface driver usbfs
[ 0.354475] usbcore: registered new interface driver hub
[ 0.360062] usbcore: registered new device driver usb
[ 0.368329] pwm module init!
[ 0.373195] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.381822] clocksource: Switched to clocksource arch_sys_counter
[ 0.398209] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.431081] thermal_sys: Registered thermal governor 'step_wise'
[ 0.431088] thermal_sys: Registered thermal governor 'user_space'
[ 0.438160] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.445493] NET: Registered protocol family 2
[ 0.457598] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.466071] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.473807] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.480868] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.487433] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.494059] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.501227] NET: Registered protocol family 1
[ 0.506555] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.517175] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.524188] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.530337] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.536893] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.543417] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.551928] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.558366] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 41
[ 0.569362] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.591740] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.597096] NET: Registered protocol family 38
[ 0.602655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.610073] io scheduler mq-deadline registered
[ 0.614810] io scheduler kyber registered
[ 0.621010] [DISP]disp_module_init
[ 0.625859] disp 5000000.disp: Adding to iommu group 0
[ 0.648198] display_fb_request,fb_id:0
[ 0.656777] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.656783] no boot_fb0
[ 0.664285] disp_al_manager_apply ouput_type:0
[ 0.669627] [DISP]disp_module_init finish
[ 0.673957] [DISP] lcd_clk_config,line:732:
[ 0.673969] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 0.673969] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 0.696246] sunxi_sid_init()551 - insmod ok
[ 0.701409] pwm-regulator: supplied by regulator-dummy
[ 0.708617] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.719558] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.729938] uart uart3: get regulator failed
[ 0.734373] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.742226] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.751512] misc dump reg init
[ 0.757671] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.763455] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.773661] libphy: Fixed MDIO Bus: probed
[ 0.777777] CAN device driver interface
[ 0.783395] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Loading Device Tree to 43f5b000, end 43f6b363 ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #15 SMP PREEMPT Fri Apr 22 21:08:34 CST 2022
[ 0.008018] Switching to timer-based delay loop, resolution 41ns
[ 0.014198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023950] Console: colour dummy device 80x30
[ 0.028422] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038792] pid_max: default: 32768 minimum: 301
[ 0.043537] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050864] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059226] CPU: Testing write buffer coherency: ok
[ 0.064485] /cpus/cpu@0 missing clock-frequency property
[ 0.069822] /cpus/cpu@1 missing clock-frequency property
[ 0.075159] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081401] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088093] rcu: Hierarchical SRCU implementation.
[ 0.093369] smp: Bringing up secondary CPUs ...
[ 0.098488] smp: Brought up 1 node, 1 CPU
[ 0.102497] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.108757] CPU: All CPU(s) started in SVC mode.
[ 0.113802] devtmpfs: initialized
[ 0.128441] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.136823] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.146961] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154173] pinctrl core: initialized pinctrl subsystem
[ 0.161521] NET: Registered protocol family 16
[ 0.166193] cma: cma_alloc(cma (ptrval), count 64, align 6)
[ 0.173644] cma: cma_alloc(): returned (ptrval)
[ 0.178331] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.247195] rtc_ccu: sunxi ccu init OK
[ 0.254130] ccu: sunxi ccu init OK
[ 0.258684] r_ccu: sunxi ccu init OK
[ 0.330401] iommu: Default domain type: Translated
[ 0.335487] sunxi iommu: irq = 24
[ 0.341900] SCSI subsystem initialized
[ 0.346852] usbcore: registered new interface driver usbfs
[ 0.353270] usbcore: registered new interface driver hub
[ 0.358863] usbcore: registered new device driver usb
[ 0.367122] pwm module init!
[ 0.371957] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.380557] clocksource: Switched to clocksource arch_sys_counter
[ 0.396902] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.429359] thermal_sys: Registered thermal governor 'step_wise'
[ 0.429366] thermal_sys: Registered thermal governor 'user_space'
[ 0.436662] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.443974] NET: Registered protocol family 2
[ 0.456090] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.464571] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.472317] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.479370] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.485928] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.492548] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.499691] NET: Registered protocol family 1
[ 0.505001] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.515626] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.522636] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.528777] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.535310] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.541826] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.550250] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.556774] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 40
[ 0.567746] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.589606] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.594961] NET: Registered protocol family 38
[ 0.599745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.607837] io scheduler mq-deadline registered
[ 0.612573] io scheduler kyber registered
[ 0.618765] [DISP]disp_module_init
[ 0.623577] disp 5000000.disp: Adding to iommu group 0
[ 0.645852] display_fb_request,fb_id:0
[ 0.654557] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.654562] no boot_fb0
[ 0.662009] disp_al_manager_apply ouput_type:0
[ 0.667397] [DISP]disp_module_init finish
[ 0.671735] [DISP] lcd_clk_config,line:732:
[ 0.671746] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 0.671746] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 0.693982] sunxi_sid_init()551 - insmod ok
[ 0.699130] pwm-regulator: supplied by regulator-dummy
[ 0.706320] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.717268] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.727641] uart uart3: get regulator failed
[ 0.732050] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.739812] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.749141] misc dump reg init
[ 0.755269] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.761107] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.771228] libphy: Fixed MDIO Bus: probed
[ 0.775343] CAN device driver interface
[ 0.779444] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.787087] sunxi-ehci: EHCI SUNXI driver
[ 0.791839] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.798051] sunxi-ohci: OHCI SUNXI driver
[ 0.803140] usbcore: registered new interface driver uas
[ 0.808836] usbcore: registered new interface driver usb-storage
[ 0.815108] usbcore: registered new interface driver ums-alauda
[ 0.821390] usbcore: registered new interface driver ums-cypress
[ 0.827620] usbcore: registered new interface driver ums-datafab
[ 0.833806] usbcore: registered new interface driver ums_eneub6250
[ 0.840230] usbcore: registered new interface driver ums-freecom
[ 0.846479] usbcore: registered new interface driver ums-isd200
[ 0.852739] usbcore: registered new interface driver ums-jumpshot
[ 0.859052] usbcore: registered new interface driver ums-karma
[ 0.865111] usbcore: registered new interface driver ums-onetouch
[ 0.871508] usbcore: registered new interface driver ums-realtek
[ 0.877746] usbcore: registered new interface driver ums-sddr09
[ 0.883942] usbcore: registered new interface driver ums-sddr55
[ 0.890112] usbcore: registered new interface driver ums-usbat
[ 0.897410] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 0.906614] sunxi_gpadc_init,2137, success
[ 0.913424] sunxi-rtc 7090000.rtc: registered as rtc0
[ 0.918597] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:14:52 UTC (892)
[ 0.927244] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 0.932939] i2c /dev entries driver
[ 0.936836] IR NEC protocol handler initialized
[ 0.941577] IR RC5(x/sz) protocol handler initialized
[ 0.947075] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.957167] [DISP] disp_device_attached_and_enable,line:233:
[ 0.957172] attached ok, mgr0<-->dev0
[ 0.966893] sunxi_ir_startup: get ir protocol failed
[ 0.966912] (NULL device *): deviceless supply not found, using dummy regulator
[ 0.979452] Registered IR keymap rc_map_sunxi
[ 0.983886] [DISP] disp_device_attached_and_enable,line:236:
[ 0.983895] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 0.998189] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 1.006202] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 1.015602] sunxi cedar version 1.1
[ 1.019292] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.025267] VE: sunxi_cedar_probe power-domain init!!!
[ 1.030448] VE: install start!!!
[ 1.030448]
[ 1.035677] VE: cedar-ve the get irq is 41
[ 1.035677]
[ 1.041738] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.041738]
[ 1.050050] VE: install end!!!
[ 1.050050]
[ 1.054712] VE: sunxi_cedar_probe
[ 1.059706] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.069833] usbcore: registered new interface driver usbhid
[ 1.076010] usbhid: USB HID core driver
[ 1.082683] NET: Registered protocol family 10
[ 1.088926] Segment Routing with IPv6
[ 1.093119] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.101366] NET: Registered protocol family 17
[ 1.105842] NET: Registered protocol family 15
[ 1.110280] can: controller area network core (rev 20170425 abi 9)
[ 1.117141] NET: Registered protocol family 29
[ 1.121665] can: raw protocol (rev 20170425)
[ 1.125949] can: broadcast manager protocol (rev 20170425 t)
[ 1.131712] can: netlink gateway (rev 20190810) max_hops=1
[ 1.137655] Registering SWP/SWPB emulation handler
[ 1.145542] HDMI 2.0 driver init start!
[ 1.149436] boot_hdmi=false
[ 1.152606] ERROR: can not get hdmi_cts_compatibility
[ 1.157670] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 1.164282] HDMI2.0 module init end
[ 1.185545] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.195937] i2c i2c2: i2c2 supply twi not found, using dummy regulator
[ 1.203843] i2c i2c2: probe success
[ 1.251684] get ehci0-controller wakeup-source is fail.
[ 1.257017] sunxi ehci0-controller don't init wakeup source
[ 1.262968] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc097d980, 0x:c887a000, irq_no:37
[ 1.273758] [sunxi-ehci0]: Not init ehci0
[ 1.278252] get ohci0-controller wakeup-source is fail.
[ 1.283834] sunxi ohci0-controller don't init wakeup source
[ 1.289422] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc097dc10
[ 1.298160] [sunxi-ohci0]: Not init ohci0
[ 1.302695] get ehci1-controller wakeup-source is fail.
[ 1.308030] sunxi ehci1-controller don't init wakeup source
[ 1.313823] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc097dea0, 0x:c92b5000, irq_no:39
[ 1.324913] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 1.337329] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 1.343902] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.352635] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 1.358257] cma: cma_alloc(): returned (ptrval)
[ 1.362901] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 1.368411] cma: cma_alloc(): returned (ptrval)
[ 1.373012] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 1.378523] cma: cma_alloc(): returned (ptrval)
[ 1.383193] sunxi-ehci 4200000.ehci1-controller: irq 57, io mem 0x04200000
[ 1.410570] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 1.418584] hub 1-0:1.0: USB hub found
[ 1.422606] hub 1-0:1.0: 1 port detected
[ 1.427585] get ohci1-controller wakeup-source is fail.
[ 1.433308] sunxi ohci1-controller don't init wakeup source
[ 1.438888] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc097e130
[ 1.447997] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 1.459281] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 1.466035] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.474731] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 1.480347] cma: cma_alloc(): returned (ptrval)
[ 1.485057] sunxi-ohci 4200400.ohci1-controller: irq 58, io mem 0x04200400
[ 1.565611] hub 2-0:1.0: USB hub found
[ 1.569575] hub 2-0:1.0: 1 port detected
[ 1.574804] UBI error: cannot open mtd 5, error -19
[ 1.581840] clk: Not disabling unused clocks
[ 1.586144] alloc_fd: slot 0 not NULL!
[ 1.589927] Warning: unable to open an initial console.
[ 1.595556] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -19
[ 1.603757] Please append a correct "root=" boot option; here are the available partitions:
[ 1.612202] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.620476] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #15
[ 1.626471] Hardware name: Generic DT based system
[ 1.631296] [<c010e310>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 1.639042] [<c010a8bc>] (show_stack) from [<c05c9bc4>] (dump_stack+0x7c/0x98)
[ 1.646268] [<c05c9bc4>] (dump_stack) from [<c01193dc>] (panic+0x100/0x3d0)
[ 1.653242] [<c01193dc>] (panic) from [<c0801264>] (mount_block_root+0x248/0x344)
[ 1.660718] [<c0801264>] (mount_block_root) from [<c0801464>] (prepare_namespace+0x84/0x178)
[ 1.669164] [<c0801464>] (prepare_namespace) from [<c05dde20>] (kernel_init+0x8/0x10c)
[ 1.677074] [<c05dde20>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 1.684648] Exception stack(0xc7025fb0 to 0xc7025ff8)
[ 1.689701] 5fa0: 00000000 00000000 00000000 00000000
[ 1.697885] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.706059] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 1.712674] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 22 2022 - 22:42:46 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Kernel image @ 0x40080000 [ 0x000000 - 0x3e64c8 ]
Loading Device Tree to 43f5b000, end 43f6b51d ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #19 SMP PREEMPT Fri Apr 22 23:02:45 CST 2022
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init rootfstype=ext4 partitions=boot@mmcblk0p1:rootfs@mmcblk0p2 cma=8M ubi.mtd=4 root=/dev/mmcblk0p2
[ 0.000000] Memory: 110616K/131072K available (6144K kernel code, 378K rwdata, 1916K rodata, 1024K init, 148K bss, 12264K reserved, 8192K cma-reserved)
[ 0.008009] Switching to timer-based delay loop, resolution 41ns
[ 0.014188] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023935] Console: colour dummy device 80x30
[ 0.028425] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038780] pid_max: default: 32768 minimum: 301
[ 0.043533] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050862] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059216] CPU: Testing write buffer coherency: ok
[ 0.064450] /cpus/cpu@0 missing clock-frequency property
[ 0.069778] /cpus/cpu@1 missing clock-frequency property
[ 0.075124] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081384] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088067] rcu: Hierarchical SRCU implementation.
[ 0.093348] smp: Bringing up secondary CPUs ...
[ 0.098456] smp: Brought up 1 node, 1 CPU
[ 0.102482] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.108750] CPU: All CPU(s) started in SVC mode.
[ 0.113786] devtmpfs: initialized
[ 0.128674] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.137019] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.147159] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154371] pinctrl core: initialized pinctrl subsystem
[ 0.161704] NET: Registered protocol family 16
[ 0.166382] cma: cma_alloc(cma (ptrval), count 64, align 6)
[ 0.173840] cma: cma_alloc(): returned (ptrval)
[ 0.178529] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.241603] rtc_ccu: sunxi ccu init OK
[ 0.248623] ccu: sunxi ccu init OK
[ 0.252571] r_ccu: sunxi ccu init OK
[ 0.319382] iommu: Default domain type: Translated
[ 0.324472] sunxi iommu: irq = 24
[ 0.330970] SCSI subsystem initialized
[ 0.335886] usbcore: registered new interface driver usbfs
[ 0.342293] usbcore: registered new interface driver hub
[ 0.347894] usbcore: registered new device driver usb
[ 0.356669] pwm module init!
[ 0.361452] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.369947] clocksource: Switched to clocksource arch_sys_counter
[ 0.386410] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.418851] thermal_sys: Registered thermal governor 'step_wise'
[ 0.418857] thermal_sys: Registered thermal governor 'user_space'
[ 0.425844] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.433138] NET: Registered protocol family 2
[ 0.445237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.453704] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.461440] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.468494] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.475060] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.481666] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.488823] NET: Registered protocol family 1
[ 0.494121] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.504720] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.511737] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.517882] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.524423] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.530930] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.539354] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.545860] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 40
[ 0.556774] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.580537] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.586060] NET: Registered protocol family 38
[ 0.591675] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.599075] io scheduler mq-deadline registered
[ 0.604035] io scheduler kyber registered
[ 0.610371] [DISP]disp_module_init
[ 0.615108] disp 5000000.disp: Adding to iommu group 0
[ 0.637628] display_fb_request,fb_id:0
[ 0.646032] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.646037] no boot_fb0
[ 0.653505] disp_al_manager_apply ouput_type:0
[ 0.658876] [DISP]disp_module_init finish
[ 0.663220] [DISP] lcd_clk_config,line:732:
[ 0.663232] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 0.663232] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 0.685321] sunxi_sid_init()551 - insmod ok
[ 0.690542] pwm-regulator: supplied by regulator-dummy
[ 0.697585] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.708563] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.718843] uart uart3: get regulator failed
[ 0.723340] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.730980] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.740395] misc dump reg init
[ 0.746127] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.752038] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.760832] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.767180] Creating 5 MTD partitions on "spi0.0":
[ 0.772208] 0x000000000000-0x000000100000 : "boot0"
[ 0.780451] 0x000000100000-0x000000200000 : "u-boot"
[ 0.788783] 0x000000200000-0x000000220000 : "dtb"
[ 0.794883] 0x000000220000-0x000000820000 : "kernel"
[ 0.801634] random: fast init done
[ 0.818649] 0x000000820000-0x000008000000 : "rootfs"
[ 0.940142] [DISP] disp_device_attached_and_enable,line:233:
[ 0.940148] attached ok, mgr0<-->dev0
[ 0.949476] [DISP] disp_device_attached_and_enable,line:236:
[ 0.949484] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 1.133692] libphy: Fixed MDIO Bus: probed
[ 1.137799] CAN device driver interface
[ 1.142628] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.149201] sunxi-ehci: EHCI SUNXI driver
[ 1.153817] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.160197] sunxi-ohci: OHCI SUNXI driver
[ 1.164944] usbcore: registered new interface driver uas
[ 1.170833] usbcore: registered new interface driver usb-storage
[ 1.177082] usbcore: registered new interface driver ums-alauda
[ 1.183302] usbcore: registered new interface driver ums-cypress
[ 1.189553] usbcore: registered new interface driver ums-datafab
[ 1.195760] usbcore: registered new interface driver ums_eneub6250
[ 1.202319] usbcore: registered new interface driver ums-freecom
[ 1.208559] usbcore: registered new interface driver ums-isd200
[ 1.214686] usbcore: registered new interface driver ums-jumpshot
[ 1.221045] usbcore: registered new interface driver ums-karma
[ 1.227107] usbcore: registered new interface driver ums-onetouch
[ 1.233488] usbcore: registered new interface driver ums-realtek
[ 1.239738] usbcore: registered new interface driver ums-sddr09
[ 1.245916] usbcore: registered new interface driver ums-sddr55
[ 1.252110] usbcore: registered new interface driver ums-usbat
[ 1.259315] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.268386] sunxi_gpadc_init,2137, success
[ 1.273615] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 1.285183] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.290884] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:23 UTC (23)
[ 1.298946] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.304458] i2c /dev entries driver
[ 1.308340] IR NEC protocol handler initialized
[ 1.312969] IR RC5(x/sz) protocol handler initialized
[ 1.318464] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 1.328766] sunxi_ir_startup: get ir protocol failed
[ 1.328786] (NULL device *): deviceless supply not found, using dummy regulator
[ 1.341367] Registered IR keymap rc_map_sunxi
[ 1.346003] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 1.354076] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 1.363363] sunxi cedar version 1.1
[ 1.367105] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.373062] VE: sunxi_cedar_probe power-domain init!!!
[ 1.378201] VE: install start!!!
[ 1.378201]
[ 1.383480] VE: cedar-ve the get irq is 41
[ 1.383480]
[ 1.389270] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.389270]
[ 1.397873] VE: install end!!!
[ 1.397873]
[ 1.402525] VE: sunxi_cedar_probe
[ 1.407378] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.419605] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 1.429096] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.434802] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.440713] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.446471] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.452294] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 1.458129] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 1.464053] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 1.469887] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 1.476271] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 1.481045] cma: cma_alloc(cma (ptrval), count 2, align 1)
[ 1.486689] cma: cma_alloc(): returned (ptrval)
[ 1.491259] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 1.497329] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.507422] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 1.526830] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.550132] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 1.555212] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.566222] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 1.575296] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 1.581069] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 1.586771] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 1.592620] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 1.598395] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.608804] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 1.614700] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 1.620656] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 1.626517] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 1.632461] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.640561] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.651132] cma: cma_alloc(cma (ptrval), count 4, align 2)
[ 1.656803] cma: cma_alloc(): returned (ptrval)
[ 1.661715] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.671857] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 1.678667] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.699991] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.722986] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 1.729820] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.740968] usbcore: registered new interface driver usbhid
[ 1.746554] usbhid: USB HID core driver
[ 1.753711] NET: Registered protocol family 10
[ 1.758197] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.770558] Segment Routing with IPv6
[ 1.774320] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.782374] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 1.791407] NET: Registered protocol family 17
[ 1.796393] NET: Registered protocol family 15
[ 1.801049] can: controller area network core (rev 20170425 abi 9)
[ 1.807369] NET: Registered protocol family 29
[ 1.812029] can: raw protocol (rev 20170425)
[ 1.816354] can: broadcast manager protocol (rev 20170425 t)
[ 1.822120] can: netlink gateway (rev 20190810) max_hops=1
[ 1.828144] Registering SWP/SWPB emulation handler
[ 1.840747] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.858573] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.870124] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.883549] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.893509] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.903883] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 1.914460] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.925354] i2c i2c2: i2c2 supply twi not found, using dummy regulator
[ 1.933419] i2c i2c2: probe success
[ 1.938276] mmc1: new high speed SDIO card at address 0001
[ 1.945732] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 1.990264] mmc0: new high speed SDHC card at address 59b4
[ 1.997053] get ehci0-controller wakeup-source is fail.
[ 2.003592] mmcblk0: mmc0:59b4 SMI 7.52 GiB
[ 2.008234] sunxi ehci0-controller don't init wakeup source
[ 2.014011] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b7bb18, 0x:c92b1000, irq_no:37
[ 2.024806] [sunxi-ehci0]: Not init ehci0
[ 2.029378] get ohci0-controller wakeup-source is fail.
[ 2.034965] sunxi ohci0-controller don't init wakeup source
[ 2.040620] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b7bda8
[ 2.049250] [sunxi-ohci0]: Not init ohci0
[ 2.053783] get ehci1-controller wakeup-source is fail.
[ 2.059117] sunxi ehci1-controller don't init wakeup source
[ 2.064957] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b7c038, 0x:c92bb000, irq_no:39
[ 2.076061] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.089152] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.096042] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.105026] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.110720] mmcblk0: p1 p2
[ 2.115238] cma: cma_alloc(): returned (ptrval)
[ 2.119806] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.125705] cma: cma_alloc(): returned (ptrval)
[ 2.130333] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.135870] cma: cma_alloc(): returned (ptrval)
[ 2.140549] sunxi-ehci 4200000.ehci1-controller: irq 57, io mem 0x04200000
[ 2.169972] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.178007] hub 1-0:1.0: USB hub found
[ 2.182068] hub 1-0:1.0: 1 port detected
[ 2.187077] get ohci1-controller wakeup-source is fail.
[ 2.192765] sunxi ohci1-controller don't init wakeup source
[ 2.198372] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b7c2c8
[ 2.207384] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.218714] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.225435] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.234168] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.239766] cma: cma_alloc(): returned (ptrval)
[ 2.244465] sunxi-ohci 4200400.ohci1-controller: irq 58, io mem 0x04200400
[ 2.325014] hub 2-0:1.0: USB hub found
[ 2.329003] hub 2-0:1.0: 1 port detected
[ 2.334271] ubi0: attaching mtd4
[ 2.378101] random: crng init done
[ 3.090204] ubi0: scanning is finished
[ 3.104806] ubi0: attached mtd4 (name "rootfs", size 119 MiB)
[ 3.110730] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 3.117620] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 3.124455] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.131519] ubi0: good PEBs: 959, bad PEBs: 0, corrupted PEBs: 0
[ 3.137517] ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[ 3.144807] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 1343052751
[ 3.153997] ubi0: available PEBs: 915, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
[ 3.163349] ubi0: background thread "ubi_bgt0d" started, PID 905
[ 3.171070] clk: Not disabling unused clocks
[ 3.175366] alloc_fd: slot 0 not NULL!
[ 3.179167] Warning: unable to open an initial console.
[ 3.187028] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.194448] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.700451] EXT4-fs (mmcblk0p2): recovery complete
[ 3.712192] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.720454] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.729045] Freeing unused kernel memory: 1024K
[ 3.740110] Run /init as init process
[ 4.833516] udevd[948]: starting version 3.2
[ 4.874240] udevd[949]: starting eudev-3.2
[ 5.002459] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.531496] clk: Not disabling unused clocks
[ 5.539682] cfg80211: failed to load regulatory.db
[ 5.544445] ALSA device list:
[ 5.553120] #0: audiocodec
[ 5.556361] alloc_fd: slot 0 not NULL!
[ 5.591259] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 5.601546] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[ 5.611037] Freeing unused kernel memory: 1024K
[ 5.621591] Kernel init done
[ 5.624821] Run /init as init process
login[971]: root login on 'console'
-bash: cannot set terminal process group (-1): Inappropriate ioctl for device
-bash: no job control in this shell
[root@T113-s3 /root]#
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 23 2022 - 16:39:41 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
MMC:
Out: serial
Err: serial
Kernel image @ 0x40080000 [ 0x000000 - 0x3e6488 ]
Loading Device Tree to 43f5b000, end 43f6b4c9 ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #28 SMP PREEMPT Sat Apr 23 16:07:35 CST 2022
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init partitions=rootfs@mmcblk0p5 cma=8M ubi.mtd=4 rootfstype=ubifs root=ubi0:rootfs ro rootwait
[ 0.008000] Switching to timer-based delay loop, resolution 41ns
[ 0.014183] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023933] Console: colour dummy device 80x30
[ 0.028415] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038777] pid_max: default: 32768 minimum: 301
[ 0.050865] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059223] CPU: Testing write buffer coherency: ok
[ 0.064479] /cpus/cpu@0 missing clock-frequency property
[ 0.069815] /cpus/cpu@1 missing clock-frequency property
[ 0.075168] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081424] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088119] rcu: Hierarchical SRCU implementation.
[ 0.093388] smp: Bringing up secondary CPUs ...
[ 0.098503] smp: Brought up 1 node, 1 CPU
[ 0.102521] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.108784] CPU: All CPU(s) started in SVC mode.
[ 0.113817] devtmpfs: initialized
[ 0.128766] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.137126] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.147270] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.154498] pinctrl core: initialized pinctrl subsystem
[ 0.161804] NET: Registered protocol family 16
[ 0.166521] cma: cma_alloc(cma (ptrval), count 64, align 6)
[ 0.173994] cma: cma_alloc(): returned (ptrval)
[ 0.178690] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.242627] rtc_ccu: sunxi ccu init OK
[ 0.249844] ccu: sunxi ccu init OK
[ 0.253935] r_ccu: sunxi ccu init OK
[ 0.320698] iommu: Default domain type: Translated
[ 0.325785] sunxi iommu: irq = 24
[ 0.332367] SCSI subsystem initialized
[ 0.337300] usbcore: registered new interface driver usbfs
[ 0.343576] usbcore: registered new interface driver hub
[ 0.349163] usbcore: registered new device driver usb
[ 0.357941] pwm module init!
[ 0.362733] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.371253] clocksource: Switched to clocksource arch_sys_counter
[ 0.387697] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.420092] thermal_sys: Registered thermal governor 'step_wise'
[ 0.420098] thermal_sys: Registered thermal governor 'user_space'
[ 0.427095] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.434368] NET: Registered protocol family 2
[ 0.446465] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.454937] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.462667] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.469720] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.476281] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.482885] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.490042] NET: Registered protocol family 1
[ 0.495323] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.505938] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.512947] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.519090] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.525625] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.532141] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.540564] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.547073] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 41
[ 0.558009] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.582064] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.587639] NET: Registered protocol family 38
[ 0.593022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.600414] io scheduler mq-deadline registered
[ 0.605332] io scheduler kyber registered
[ 0.611637] [DISP]disp_module_init
[ 0.616391] disp 5000000.disp: Adding to iommu group 0
[ 0.638903] display_fb_request,fb_id:0
[ 0.647335] [DISP] Fb_copy_boot_fb,line:1443:
[ 0.647340] no boot_fb0
[ 0.654787] disp_al_manager_apply ouput_type:0
[ 0.660108] [DISP]disp_module_init finish
[ 0.664441] [DISP] lcd_clk_config,line:732:
[ 0.664452] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 0.664452] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 0.686571] sunxi_sid_init()551 - insmod ok
[ 0.691831] pwm-regulator: supplied by regulator-dummy
[ 0.698814] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.709783] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.720050] uart uart0: get regulator failed
[ 0.724542] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.732190] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.740028] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 0.748197] printk: console [ttyS0] enabled
[ 0.757133] printk: bootconsole [earlycon0] disabled
[ 0.768610] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.780307] uart uart3: get regulator failed
[ 0.785198] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.793389] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.803733] misc dump reg init
[ 0.809823] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.816377] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.826029] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.833458] Creating 5 MTD partitions on "spi0.0":
[ 0.838841] 0x000000000000-0x000000100000 : "boot0"
[ 0.847555] 0x000000100000-0x000000200000 : "u-boot"
[ 0.856622] 0x000000200000-0x000000220000 : "dtb"
[ 0.863254] 0x000000220000-0x000000820000 : "kernel"
[ 0.870445] random: fast init done
[ 0.888314] 0x000000820000-0x000008000000 : "rootfs"
[ 0.941466] [DISP] disp_device_attached_and_enable,line:233:
[ 0.941473] attached ok, mgr0<-->dev0
[ 0.960661] [DISP] disp_device_attached_and_enable,line:236:
[ 0.960670] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 1.208132] libphy: Fixed MDIO Bus: probed
[ 1.213343] CAN device driver interface
[ 1.218049] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.225549] sunxi-ehci: EHCI SUNXI driver
[ 1.230471] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.237653] sunxi-ohci: OHCI SUNXI driver
[ 1.243051] usbcore: registered new interface driver uas
[ 1.249382] usbcore: registered new interface driver usb-storage
[ 1.256416] usbcore: registered new interface driver ums-alauda
[ 1.263332] usbcore: registered new interface driver ums-cypress
[ 1.270337] usbcore: registered new interface driver ums-datafab
[ 1.277325] usbcore: registered new interface driver ums_eneub6250
[ 1.284606] usbcore: registered new interface driver ums-freecom
[ 1.291584] usbcore: registered new interface driver ums-isd200
[ 1.298446] usbcore: registered new interface driver ums-jumpshot
[ 1.305499] usbcore: registered new interface driver ums-karma
[ 1.312300] usbcore: registered new interface driver ums-onetouch
[ 1.319400] usbcore: registered new interface driver ums-realtek
[ 1.326375] usbcore: registered new interface driver ums-sddr09
[ 1.333321] usbcore: registered new interface driver ums-sddr55
[ 1.340209] usbcore: registered new interface driver ums-usbat
[ 1.348101] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.358216] sunxi_gpadc_init,2137, success
[ 1.363998] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 1.376776] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.383066] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:13 UTC (13)
[ 1.392206] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.398227] i2c /dev entries driver
[ 1.402612] IR NEC protocol handler initialized
[ 1.407696] IR RC5(x/sz) protocol handler initialized
[ 1.414002] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 1.425517] sunxi_ir_startup: get ir protocol failed
[ 1.425537] (NULL device *): deviceless supply not found, using dummy regulator
[ 1.439619] Registered IR keymap rc_map_sunxi
[ 1.444852] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 1.453843] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 1.464159] sunxi cedar version 1.1
[ 1.468315] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.474960] VE: sunxi_cedar_probe power-domain init!!!
[ 1.480732] VE: install start!!!
[ 1.480732]
[ 1.486556] VE: cedar-ve the get irq is 42
[ 1.486556]
[ 1.493280] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.493280]
[ 1.502719] VE: install end!!!
[ 1.502719]
[ 1.507802] VE: sunxi_cedar_probe
[ 1.513138] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.526295] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 1.536904] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.543241] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.549591] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.556306] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.562799] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 1.569355] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 1.575957] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 1.582515] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 1.589576] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 1.594880] cma: cma_alloc(cma (ptrval), count 2, align 1)
[ 1.601196] cma: cma_alloc(): returned (ptrval)
[ 1.606326] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 1.613132] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.624481] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 1.644678] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.669209] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 1.669267] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.686769] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 1.696939] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 1.703335] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 1.709721] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 1.716233] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 1.722761] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 1.729308] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 1.735908] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 1.742488] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 1.749056] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.758256] cma: cma_alloc(cma (ptrval), count 4, align 2)
[ 1.764526] cma: cma_alloc(): returned (ptrval)
[ 1.769934] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.781295] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 1.801305] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.825580] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 1.833182] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.845473] usbcore: registered new interface driver usbhid
[ 1.852146] usbhid: USB HID core driver
[ 1.859412] NET: Registered protocol family 10
[ 1.864490] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.877862] Segment Routing with IPv6
[ 1.882448] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.889517] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 1.900602] NET: Registered protocol family 17
[ 1.906222] NET: Registered protocol family 15
[ 1.911320] can: controller area network core (rev 20170425 abi 9)
[ 1.918391] NET: Registered protocol family 29
[ 1.923497] can: raw protocol (rev 20170425)
[ 1.928317] can: broadcast manager protocol (rev 20170425 t)
[ 1.934835] can: netlink gateway (rev 20190810) max_hops=1
[ 1.941584] Registering SWP/SWPB emulation handler
[ 1.954348] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.978556] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.991405] i2c i2c2: i2c2 supply twi not found, using dummy regulator
[ 1.999131] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.012086] i2c i2c2: probe success
[ 2.021627] mmc1: new high speed SDIO card at address 0001
[ 2.062378] get ehci0-controller wakeup-source is fail.
[ 2.068385] sunxi ehci0-controller don't init wakeup source
[ 2.075002] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b7bb18, 0x:c92b1000, irq_no:38
[ 2.087096] [sunxi-ehci0]: Not init ehci0
[ 2.092131] get ohci0-controller wakeup-source is fail.
[ 2.098105] sunxi ohci0-controller don't init wakeup source
[ 2.104632] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b7bda8
[ 2.114343] [sunxi-ohci0]: Not init ohci0
[ 2.119318] get ehci1-controller wakeup-source is fail.
[ 2.125476] sunxi ehci1-controller don't init wakeup source
[ 2.131807] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b7c038, 0x:c92bb000, irq_no:3a
[ 2.144212] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.157912] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.165226] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.174987] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.181227] cma: cma_alloc(): returned (ptrval)
[ 2.186437] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.192646] cma: cma_alloc(): returned (ptrval)
[ 2.197738] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.203964] cma: cma_alloc(): returned (ptrval)
[ 2.209125] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
[ 2.241263] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.250145] hub 1-0:1.0: USB hub found
[ 2.254653] hub 1-0:1.0: 1 port detected
[ 2.260133] get ohci1-controller wakeup-source is fail.
[ 2.266457] sunxi ohci1-controller don't init wakeup source
[ 2.272816] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b7c2c8
[ 2.282886] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.295522] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.302981] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.312721] cma: cma_alloc(cma (ptrval), count 1, align 0)
[ 2.318997] cma: cma_alloc(): returned (ptrval)
[ 2.324286] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
[ 2.406291] hub 2-0:1.0: USB hub found
[ 2.410698] hub 2-0:1.0: 1 port detected
[ 2.416373] ubi0: attaching mtd4
[ 2.458590] random: crng init done
[ 3.177011] ubi0: scanning is finished
[ 3.192299] ubi0: attached mtd4 (name "rootfs", size 119 MiB)
[ 3.198749] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 3.206725] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 3.214396] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.222287] ubi0: good PEBs: 959, bad PEBs: 0, corrupted PEBs: 0
[ 3.229023] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 3.237206] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 267458052
[ 3.247394] ubi0: available PEBs: 0, total reserved PEBs: 959, PEBs reserved for bad PEB handling: 40
[ 3.257791] ubi0: background thread "ubi_bgt0d" started, PID 903
[ 3.266181] clk: Not disabling unused clocks
[ 3.271024] alloc_fd: slot 0 not NULL!
[ 3.277186] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 3.333369] UBIFS (ubi0:0): recovery needed
[ 3.393952] UBIFS (ubi0:0): recovery deferred
[ 3.398972] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 3.408282] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.419428] UBIFS (ubi0:0): FS size: 114786304 bytes (109 MiB, 904 LEBs), journal size 5713920 bytes (5 MiB, 45 LEBs)
[ 3.431340] UBIFS (ubi0:0): reserved for root: 4952683 bytes (4836 KiB)
[ 3.438768] UBIFS (ubi0:0): media format: w5/r0 (latest is w5/r0), UUID 4A5D7D8F-3C66-4BB0-8C4C-E59EDCC1D11C, small LPT model
[ 3.454481] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
[ 3.463945] Freeing unused kernel memory: 1024K
[ 3.469184] Run /init as init process
login[917]: root login on 'ttyS0'
启动成功 !...
[root@T113-s3 /root]# du -hd1 /
1.5M /bin
0 /dev
152.0K /etc
9.7M /lib
0 /mnt
0 /run
0 /sys
0 /var
29.9M /usr
0 /proc
0 /sbin
2.6M /root
4.0K /parameters
43.8M /
Mem: 29888K used, 89944K free, 0K shrd, 0K buff, 1740K cached
CPU: 0.0% usr 0.0% sys 0.0% nic 100% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.00 0.83 0.44 1/40 926
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
926 917 root R 2672 2.2 0 0.0 top
917 1 root S 2764 2.3 0 0.0 -bash
1 0 root S 2672 2.2 0 0.0 init
735 2 root IW 0 0.0 0 0.0 [kworker/0:2-eve]
614 2 root SW 0 0.0 0 0.0 [spi0]
9 2 root SW 0 0.0 0 0.0 [ksoftirqd/0]
19 2 root IW 0 0.0 0 0.0 [kworker/u4:1-ev]
905 2 root DW 0 0.0 0 0.0 [usb-hardware-sc]
10 2 root IW 0 0.0 0 0.0 [rcu_preempt]
2 0 root SW 0 0.0 0 0.0 [kthreadd]
3 2 root IW< 0 0.0 0 0.0 [rcu_gp]
4 2 root IW< 0 0.0 0 0.0 [rcu_par_gp]
6 2 root IW< 0 0.0 0 0.0 [kworker/0:0H]
7 2 root IW 0 0.0 0 0.0 [kworker/u4:0-ev]
8 2 root IW< 0 0.0 0 0.0 [mm_percpu_wq]
11 2 root SW 0 0.0 0 0.0 [migration/0]
12 2 root SW 0 0.0 0 0.0 [cpuhp/0]
13 2 root PW 0 0.0 0 0.0 [cpuhp/1]
14 2 root PW 0 0.0 0 0.0 [migration/1]
15 2 root PW 0 0.0 0 0.0 [ksoftirqd/1]
16 2 root IW 0 0.0 0 0.0 [kworker/1:0]
17 2 root IW< 0 0.0 0 0.0 [kworker/1:0H]
18 2 root SW 0 0.0 0 0.0 [kdevtmpfs]
20 2 root SW 0 0.0 0 0.0 [rcu_tasks_kthre]
351 2 root SW 0 0.0 0 0.0 [oom_reaper]
352 2 root IW< 0 0.0 0 0.0 [writeback]
369 2 root IW< 0 0.0 0 0.0 [kblockd]
504 2 root SW 0 0.0 0 0.0 [ion_system_heap]
518 2 root SW 0 0.0 0 0.0 [watchdogd]
625 2 root SW 0 0.0 0 0.0 [kswapd0]
718 2 root SW 0 0.0 0 0.0 [vsync proc 0]
719 2 root SW 0 0.0 0 0.0 [vsync proc 1]
778 2 root IW< 0 0.0 0 0.0 [uas]
814 2 root SW 0 0.0 0 0.0 [rc0]
835 2 root SW 0 0.0 0 0.0 [irq/38-mmc0]
837 2 root SW 0 0.0 0 0.0 [irq/196-4020000]
839 2 root SW 0 0.0 0 0.0 [irq/39-mmc1]
854 2 root IW< 0 0.0 0 0.0 [ipv6_addrconf]
879 2 root IW 0 0.0 0 0.0 [kworker/0:3-pm]
903 2 root SW 0 0.0 0 0.0 [ubi_bgt0d]
最近编辑记录 Cadence (2022-04-23 16:58:00)
[root@T113-s3 /root]# busybox
BusyBox v1.35.0 (2022-04-23 02:16:35 UTC) multi-call binary.
BusyBox is copyrighted by many authors between 1998-2015.
Licensed under GPLv2. See source distribution for detailed
copyright notices.
Usage: busybox [function [arguments]...]
or: busybox --list[-full]
or: busybox --install [-s] [DIR]
or: function [arguments]...
BusyBox is a multi-call binary that combines many common Unix
utilities into a single executable. Most people will create a
link to busybox for each function they wish to use and BusyBox
will act like whatever it was invoked as.
Currently defined functions:
[, [[, acpid, add-shell, addgroup, adduser, adjtimex, arch, arp, arping, ascii, awk, base32, base64, basename, bc, beep, blkdiscard, blkid, blockdev, bootchartd, brctl, bunzip2, bzcat, bzip2, cal, cat,
chat, chattr, chgrp, chmod, chown, chpasswd, chpst, chroot, chrt, chvt, cksum, clear, cmp, comm, conspy, cp, cpio, crc32, crond, crontab, cryptpw, cttyhack, cut, date, dc, dd, deallocvt, delgroup,
deluser, depmod, devmem, df, dhcprelay, diff, dirname, dmesg, dnsd, dnsdomainname, dos2unix, dpkg, dpkg-deb, du, dumpkmap, dumpleases, echo, ed, egrep, eject, env, envdir, envuidgid, ether-wake, expand,
expr, factor, fakeidentd, fallocate, false, fatattr, fbset, fbsplash, fdflush, fdformat, fdisk, fgconsole, fgrep, find, findfs, flock, fold, free, freeramdisk, fsck, fsck.minix, fsfreeze, fstrim, fsync,
ftpd, ftpget, ftpput, fuser, getopt, getty, grep, groups, gunzip, gzip, halt, hd, hdparm, head, hexdump, hexedit, hostid, hostname, httpd, hwclock, i2cdetect, i2cdump, i2cget, i2cset, i2ctransfer, id,
ifconfig, ifdown, ifenslave, ifplugd, ifup, inetd, init, inotifyd, insmod, install, ionice, iostat, ip, ipaddr, ipcalc, ipcrm, ipcs, iplink, ipneigh, iproute, iprule, iptunnel, kbd_mode, kill, killall,
killall5, klogd, last, less, link, linux32, linux64, linuxrc, ln, loadfont, loadkmap, logger, login, logname, logread, losetup, lpd, lpq, lpr, ls, lsattr, lsmod, lsof, lspci, lsscsi, lsusb, lzcat, lzma,
lzop, makedevs, makemime, man, md5sum, mdev, mesg, microcom, mkdir, mkdosfs, mke2fs, mkfifo, mkfs.ext2, mkfs.minix, mkfs.vfat, mknod, mkpasswd, mkswap, mktemp, modinfo, modprobe, more, mount, mountpoint,
mpstat, mt, mv, nameif, nanddump, nandwrite, nbd-client, nc, netstat, nice, nl, nmeter, nohup, nproc, nsenter, nslookup, ntpd, od, openvt, partprobe, passwd, paste, patch, pgrep, pidof, ping, ping6,
pipe_progress, pivot_root, pkill, pmap, popmaildir, poweroff, powertop, printenv, printf, ps, pscan, pstree, pwd, pwdx, raidautorun, rdate, rdev, readahead, readlink, readprofile, realpath, reboot,
reformime, remove-shell, renice, reset, resize, resume, rev, rm, rmdir, rmmod, route, rpm, rpm2cpio, rtcwake, run-init, run-parts, runlevel, runsv, runsvdir, rx, script, scriptreplay, sed, sendmail, seq,
setarch, setconsole, setfattr, setfont, setkeycodes, setlogcons, setpriv, setserial, setsid, setuidgid, sha1sum, sha256sum, sha3sum, sha512sum, showkey, shred, shuf, slattach, sleep, smemcap, softlimit,
sort, split, ssl_client, start-stop-daemon, stat, strings, stty, su, sulogin, sum, sv, svc, svlogd, svok, swapoff, swapon, switch_root, sync, sysctl, syslogd, tac, tail, tar, taskset, tc, tcpsvd, tee,
telnet, telnetd, test, tftp, tftpd, time, timeout, top, touch, tr, traceroute, traceroute6, true, truncate, ts, tty, ttysize, tunctl, ubiattach, ubidetach, ubimkvol, ubirename, ubirmvol, ubirsvol,
ubiupdatevol, udhcpc, udhcpc6, udhcpd, udpsvd, uevent, umount, uname, unexpand, uniq, unix2dos, unlink, unlzma, unshare, unxz, unzip, uptime, users, usleep, uudecode, uuencode, vconfig, vi, vlock,
volname, w, wall, watch, watchdog, wc, wget, which, who, whoami, whois, xargs, xxd, xz, xzcat, yes, zcat, zcip
关于 u-boot 的 psci问题
首先 struct sunxi_cpucfg_reg
grep -nr 'struct sunxi_cpucfg_reg'
arch/arm/cpu/armv7/sunxi/psci.c:131: struct sunxi_cpucfg_reg *cpucfg =
arch/arm/cpu/armv7/sunxi/psci.c:132: (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE;
arch/arm/cpu/armv7/sunxi/psci.c:142: struct sunxi_cpucfg_reg *cpucfg =
arch/arm/cpu/armv7/sunxi/psci.c:143: (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE;
arch/arm/cpu/armv7/sunxi/psci.c:151: struct sunxi_cpucfg_reg *cpucfg =
arch/arm/cpu/armv7/sunxi/psci.c:152: (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE;
arch/arm/cpu/armv7/sunxi/psci.c:171: struct sunxi_cpucfg_reg *cpucfg =
arch/arm/cpu/armv7/sunxi/psci.c:172: (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE;
arch/arm/cpu/armv7/sunxi/psci.c:249: struct sunxi_cpucfg_reg *cpucfg =
arch/arm/cpu/armv7/sunxi/psci.c:250: (struct sunxi_cpucfg_reg *)SUNXI_CPUCFG_BASE;
没有找到定义
SUNXI_CPUCFG_BASE
应该是?
arch/arm/include/asm/arch-sunxi/cpu_sun4i.h:34:#define SUNXI_CPUCFG_BASE 0x01700000
arch/arm/include/asm/arch-sunxi/cpu_sun4i.h:129:#define SUNXI_CPUCFG_BASE 0x01c25c00
arch/arm/include/asm/arch-sunxi/cpu_sun4i.h:202:#define SUNXI_CPUCFG_BASE 0x01f01c00
最近编辑记录 Cadence (2022-04-24 15:41:18)
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 24 2022 - 15:42:32 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
[00.024]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
MMC:
Loading Environment from FAT... In: serial
Out: serial
Err: serial
No working controllers found
Kernel image @ 0x40080000 [ 0x000000 - 0x403568 ]
## Flattened Device Tree blob at 40020000
Booting using the fdt blob at 0x40020000
Loading Device Tree to 43f58000, end 43f684c9 ... OK
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #39 SMP PREEMPT Sun Apr 24 09:14:45 CST 2022
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 8 MiB at 0x47400000
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] psci: drivers/firmware/psci/psci.c psci_get_version 155________________84000000
[ 0.000000] psci: drivers/firmware/psci/psci.c __invoke_psci_fn_smc 131________________84000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: drivers/firmware/psci/psci.c __invoke_psci_fn_smc 131________________84000006
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: drivers/firmware/psci/psci.c __invoke_psci_fn_smc 131________________8400000a
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32140 r8192 d21108 u61440
[ 0.000000] pcpu-alloc: s32140 r8192 d21108 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init cma=8M ubi.mtd=4 rootfstype=ubifs root=ubi0:rootfs rw rootwait
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 110580K/131072K available (6144K kernel code, 387K rwdata, 1972K rodata, 1024K init, 163K bss, 12300K reserved, 8192K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] GIC CPU mask not found - kernel will fail to boot.
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x3dc with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008017] Switching to timer-based delay loop, resolution 41ns
[ 0.014200] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023918] Console: colour dummy device 80x30
[ 0.028405] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038749] pid_max: default: 32768 minimum: 301
[ 0.043438] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050760] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059059] CPU: Testing write buffer coherency: ok
[ 0.064253] /cpus/cpu@0 missing clock-frequency property
[ 0.069570] /cpus/cpu@1 missing clock-frequency property
[ 0.074877] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081206] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.087879] rcu: Hierarchical SRCU implementation.
[ 0.093021] BOOTEVENT: 93.012957: ON
[ 0.097413] smp: Bringing up secondary CPUs ...
[ 0.102493] psci: drivers/firmware/psci/psci.c __invoke_psci_fn_smc 131________________84000003
有了
struct __packed sunxi_cpucfg_cpu {
u32 rst; /* base + 0x0 */
u32 ctrl; /* base + 0x4 */
u32 status; /* base + 0x8 */
u8 res[0x34]; /* base + 0xc */
struct __packed sunxi_cpucfg_reg {
u8 res0[0x40]; /* 0x000 */
struct sunxi_cpucfg_cpu cpu[4]; /* 0x040 */
u8 res1[0x44]; /* 0x140 */
u32 gen_ctrl; /* 0x184 */
u32 l2_status; /* 0x188 */
u8 res2[0x4]; /* 0x18c */
u32 event_in; /* 0x190 */
u8 res3[0xc]; /* 0x194 */
u32 super_standy_flag; /* 0x1a0 */
u32 priv0; /* 0x1a4 */
u32 priv1; /* 0x1a8 */
u8 res4[0x4]; /* 0x1ac */
u32 cpu1_pwr_clamp; /* 0x1b0 sun7i only */
u32 cpu1_pwroff; /* 0x1b4 sun7i only */
u8 res5[0x2c]; /* 0x1b8 */
u32 dbg_ctrl1; /* 0x1e4 */
u8 res6[0x18]; /* 0x1e8 */
u32 idle_cnt0_low; /* 0x200 */
u32 idle_cnt0_high; /* 0x204 */
u32 idle_cnt0_ctrl; /* 0x208 */
u8 res8[0x4]; /* 0x20c */
u32 idle_cnt1_low; /* 0x210 */
u32 idle_cnt1_high; /* 0x214 */
u32 idle_cnt1_ctrl; /* 0x218 */
u8 res9[0x4]; /* 0x21c */
u32 idle_cnt2_low; /* 0x220 */
u32 idle_cnt2_high; /* 0x224 */
u32 idle_cnt2_ctrl; /* 0x228 */
u8 res10[0x4]; /* 0x22c */
u32 idle_cnt3_low; /* 0x230 */
u32 idle_cnt3_high; /* 0x234 */
u32 idle_cnt3_ctrl; /* 0x238 */
u8 res11[0x4]; /* 0x23c */
u32 idle_cnt4_low; /* 0x240 */
u32 idle_cnt4_high; /* 0x244 */
u32 idle_cnt4_ctrl; /* 0x248 */
u8 res12[0x34]; /* 0x24c */
u32 cnt64_ctrl; /* 0x280 */
u32 cnt64_low; /* 0x284 */
u32 cnt64_high; /* 0x288 */
最近编辑记录 Cadence (2022-04-24 16:18:33)
[ 0.059113] CPU: Testing write buffer coherency: ok
[ 0.064317] /cpus/cpu@0 missing clock-frequency property
[ 0.069643] /cpus/cpu@1 missing clock-frequency property
[ 0.074986] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.080656] arch/arm/mach-sunxi/plat_t113_smp.c 30 max_cpus 2
[ 0.087073] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.093735] rcu: Hierarchical SRCU implementation.
[ 0.098921] BOOTEVENT: 98.911790: ON
[ 0.103309] smp: Bringing up secondary CPUs ...
[ 0.107845] smp: kernel/smp.c 592 cpu 0 cpu_online 1
[ 0.112850] smp: kernel/smp.c 592 cpu 1 cpu_online 0
[ 0.118351] arch/arm/mach-sunxi/plat_t113_smp.c 40 cpu c7039000
[ 0.124327] arch/arm/mach-sunxi/plat_t113_smp.c 48 cpu c7039000
[ 0.130485] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.130653] smp: Brought up 1 node, 2 CPUs
[ 0.140478] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.146683] CPU: All CPU(s) started in SVC mode.
不用 PSCI 启动第二个CPU
启动第二个CPU驱动 源码
static DEFINE_SPINLOCK(cpu_lock);
static int sun8i_smp_boot_secondary(unsigned int cpu,
struct task_struct *idle)
u32 reg;
void __iomem *cpucfg_membase = ioremap(0x09010000, 0x10);
void __iomem *cpuexec_membase[] = {ioremap(0x070005C4, 0x10),ioremap(0x070005C8, 0x10)};
// pr_info("%s %d cpu %x\n",__FILE__,__LINE__,(u32)idle);
spin_lock(&cpu_lock);
if(cpu != 1)return 0;
/* Set CPU boot address */
writel(__pa_symbol(secondary_startup), cpuexec_membase[cpu]);
// writel((u32)idle, cpuexec_membase[cpu]); /* do not work */
/* Deassert the CPU core reset */
reg = readl(cpucfg_membase);
writel(reg | BIT(cpu), cpucfg_membase);
spin_unlock(&cpu_lock);
static const struct smp_operations sun8i_smp_ops __initconst = {
.smp_boot_secondary = sun8i_smp_boot_secondary,
CPU_METHOD_OF_DECLARE(sun8i_t113_smp, "allwinner,sun8iw20p1", &sun8i_smp_ops);
最近编辑记录 Cadence (2022-04-26 09:15:45)
完整的启动 log
HELLO! BOOT0 is starting!
BOOT0 commit : #.###
set pll start
periph0 has been enabled
set pll end
board init ok
ZQ value = 0x2d
get_pmu_exist() = -1
ddr_efuse_type: 0xa
mark_id: 0x60
trefi:7.8ms
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0xa
mark_id: 0x60
trefi:7.8ms
[AUTO DEBUG] rank 0 row = 13
[AUTO DEBUG] rank 0 bank = 8
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.32
DRAM CLK = 792 MHz
DRAM Type = 3 (2:DDR2,3:DDR3)
DRAMC read ODT off.
DRAM ODT value: 0x42.
ddr_efuse_type: 0xa
mark_id: 0x60
DRAM SIZE =128 M
PLL_DDR_CTRL_REG:0xf8004100
DRAM_CLK_REG:0xc0000000
[TIMING DEBUG] MR2= 0x18
DRAM simple test OK.
rtc standby flag is 0x0, super standby flag is 0x0
spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 16
Jump to second Boot.
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 25 2022 - 21:53:16 +0800) Allwinner Technology
CPU: SUNXI Family
Model: sun20iw1p1
DRAM: 128 MiB
[00.023]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
MMC:
Out: serial
Err: serial
Reading 131072 byte(s) (64 page(s)) at offset 0x00200000
Reading 6291456 byte(s) (3072 page(s)) at offset 0x00220000
Kernel image @ 0x40080000 [ 0x000000 - 0x487ba8 ]
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #76 SMP PREEMPT Tue Apr 26 06:56:22 CST 2022
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] percpu: Embedded 15 pages/cpu s32076 r8192 d21172 u61440
[ 0.000000] pcpu-alloc: s32076 r8192 d21172 u61440 alloc=15*4096
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init cma=8M ubi.mtd=4 rootfstype=ubifs root=ubi0:rootfs ro rootwait
[ 0.000000] Memory: 109464K/131072K available (7168K kernel code, 465K rwdata, 2156K rodata, 1024K init, 189K bss, 13416K reserved, 8192K cma-reserved)
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x3e0 with crng_init=0
[ 0.014176] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023945] Console: colour dummy device 80x30
[ 0.028434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038796] pid_max: default: 32768 minimum: 301
[ 0.043483] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050799] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059116] CPU: Testing write buffer coherency: ok
[ 0.064334] /cpus/cpu@0 missing clock-frequency property
[ 0.069661] /cpus/cpu@1 missing clock-frequency property
[ 0.074996] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081334] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088057] rcu: Hierarchical SRCU implementation.
[ 0.093205] BOOTEVENT: 93.195666: ON
[ 0.097575] smp: Bringing up secondary CPUs ...
[ 0.102957] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103114] smp: Brought up 1 node, 2 CPUs
[ 0.112955] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119125] CPU: All CPU(s) started in SVC mode.
[ 0.124349] devtmpfs: initialized
[ 0.224824] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.235108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.244982] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.252176] pinctrl core: initialized pinctrl subsystem
[ 0.273190] NET: Registered protocol family 16
[ 0.279276] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.301706] cpuidle: using governor ladder
[ 0.305880] cpuidle: using governor menu
[ 0.573870] rtc_ccu: sunxi ccu init OK
[ 0.613198] ccu: sunxi ccu init OK
[ 0.624037] r_ccu: sunxi ccu init OK
[ 1.146594] iommu: Default domain type: Translated
[ 1.153867] sunxi iommu: irq = 24
[ 1.179725] SCSI subsystem initialized
[ 1.191373] usbcore: registered new interface driver usbfs
[ 1.196977] usbcore: registered new interface driver hub
[ 1.204835] usbcore: registered new device driver usb
[ 1.243379] pwm module init!
[ 1.262737] input: sunxi-keyboard as /devices/virtual/input/input0
[ 1.271738] clocksource: Switched to clocksource arch_sys_counter
[ 1.480368] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 1.837423] thermal_sys: Registered thermal governor 'step_wise'
[ 1.837429] thermal_sys: Registered thermal governor 'user_space'
[ 1.856304] NET: Registered protocol family 2
[ 1.877012] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.885465] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.893157] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.900218] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.906710] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.913300] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.920469] NET: Registered protocol family 1
[ 1.941263] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 1.961015] spi spi0: spi0 supply spi not found, using dummy regulator
[ 1.967875] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 1.974057] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 1.980406] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 1.986861] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 1.995270] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 2.014204] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8827000, irq 41
[ 2.058198] Initialise system trusted keyrings
[ 2.062915] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 2.076331] fuse: init (API version 7.31)
[ 2.137737] NET: Registered protocol family 38
[ 2.142243] Key type asymmetric registered
[ 2.146352] Asymmetric key parser 'x509' registered
[ 2.151319] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.158757] io scheduler mq-deadline registered
[ 2.163297] io scheduler kyber registered
[ 2.178373] [DISP]disp_module_init
[ 2.192224] disp 5000000.disp: Adding to iommu group 0
[ 2.236298] display_fb_request,fb_id:0
[ 2.247840] [DISP] Fb_copy_boot_fb,line:1443:
[ 2.247846] no boot_fb0
[ 2.255656] disp_al_manager_apply ouput_type:0
[ 2.288687] [DISP] lcd_clk_config,line:732:
[ 2.288701] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 2.288701] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 2.288948] [DISP]disp_module_init finish
[ 2.300074] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 2.327911] sunxi_sid_init()551 - insmod ok
[ 2.352136] pwm-regulator: supplied by regulator-dummy
[ 2.371961] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 2.382195] uart uart0: get regulator failed
[ 2.386493] uart uart0: uart0 supply uart not found, using dummy regulator
[ 2.397104] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 2.404970] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 2.412935] printk: console [ttyS0] enabled
[ 2.421810] printk: bootconsole [earlycon0] disabled
[ 2.446287] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 2.457681] uart uart3: get regulator failed
[ 2.462485] uart uart3: uart3 supply uart not found, using dummy regulator
[ 2.473882] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 2.500594] misc dump reg init
[ 2.528461] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 2.532067] [DISP] disp_device_attached_and_enable,line:233:
[ 2.532073] attached ok, mgr0<-->dev0
[ 2.536169] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
[ 2.542139] [DISP] disp_device_attached_and_enable,line:236:
[ 2.542148] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 2.546079] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 2.576549] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 2.583947] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 2.590451] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 2.597379] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 2.605082] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=0
[ 2.612929] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 2.621000] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 2.635323] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 2.642115] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 2.649619] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 2.702672] spi-nand spi0.0: Winbond SPI NAND was found.
[ 2.708605] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 2.721422] 5 fixed-partitions partitions found on MTD device spi0.0
[ 2.728561] Creating 5 MTD partitions on "spi0.0":
[ 2.734047] 0x000000000000-0x000000100000 : "boot0"
[ 2.743463] 0x000000100000-0x000000200000 : "u-boot"
[ 2.765815] 0x000000200000-0x000000220000 : "dtb"
[ 2.785647] 0x000000220000-0x000000820000 : "kernel"
[ 2.793422] random: fast init done
[ 2.822837] 0x000000820000-0x000008000000 : "rootfs"
[ 3.175084] libphy: Fixed MDIO Bus: probed
[ 3.185574] CAN device driver interface
[ 3.190140] RTL871X: module init start
[ 3.194355] RTL871X: rtl8189fs v4.3.24.8_22657.20170607
[ 3.200290] RTL871X: module init ret=0
[ 3.204530] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.217384] usbcore: registered new interface driver hso
[ 3.223421] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.230698] sunxi-ehci: EHCI SUNXI driver
[ 3.235606] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.242555] sunxi-ohci: OHCI SUNXI driver
[ 3.247672] usbcore: registered new interface driver uas
[ 3.257157] usbcore: registered new interface driver usb-storage
[ 3.264047] usbcore: registered new interface driver ums-alauda
[ 3.270718] usbcore: registered new interface driver ums-cypress
[ 3.280901] usbcore: registered new interface driver ums-datafab
[ 3.287753] usbcore: registered new interface driver ums_eneub6250
[ 3.298134] usbcore: registered new interface driver ums-freecom
[ 3.304999] usbcore: registered new interface driver ums-isd200
[ 3.311673] usbcore: registered new interface driver ums-jumpshot
[ 3.321996] usbcore: registered new interface driver ums-karma
[ 3.328620] usbcore: registered new interface driver ums-onetouch
[ 3.335545] usbcore: registered new interface driver ums-realtek
[ 3.342371] usbcore: registered new interface driver ums-sddr09
[ 3.349039] usbcore: registered new interface driver ums-sddr55
[ 3.359130] usbcore: registered new interface driver ums-usbat
[ 3.391075] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 3.411117] sunxi_gpadc_init,2137, success
[ 3.438762] sunxi-rtc 7090000.rtc: registered as rtc0
[ 3.444574] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:12:57 UTC (777)
[ 3.453658] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 3.459570] i2c /dev entries driver
[ 3.463656] IR NEC protocol handler initialized
[ 3.468706] IR RC5(x/sz) protocol handler initialized
[ 3.474797] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 3.493713] sunxi_ir_startup: get ir protocol failed
[ 3.493744] (NULL device *): deviceless supply not found, using dummy regulator
[ 3.507684] Registered IR keymap rc_map_sunxi
[ 3.519210] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 3.531943] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 3.549248] sunxi cedar version 1.1
[ 3.553434] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 3.559678] VE: sunxi_cedar_probe power-domain init!!!
[ 3.565452] VE: install start!!!
[ 3.565452]
[ 3.574288] VE: cedar-ve the get irq is 42
[ 3.574288]
[ 3.581375] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 3.581375]
[ 3.590655] VE: install end!!!
[ 3.590655]
[ 3.595734] VE: sunxi_cedar_probe
[ 3.625028] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 3.642654] /cpus/cpu@0: unsupported enable-method property: psci
[ 3.686989] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 3.697007] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 3.703217] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 3.709526] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 3.715955] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 3.722374] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 3.728874] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 3.735389] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 3.741903] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 3.766646] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 3.772171] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 3.778954] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.790111] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 3.810238] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.837663] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 3.854610] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 3.864560] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 3.870733] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 3.877063] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 3.883480] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 3.889885] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 3.896396] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 3.902916] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 3.909417] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 3.915963] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 3.939850] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.950997] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 3.971115] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.995310] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 4.002862] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.026875] usbcore: registered new interface driver usbhid
[ 4.027411] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.033159] usbhid: USB HID core driver
[ 4.049079] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 4.049106] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.081145] oprofile: hardware counters not available
[ 4.086846] oprofile: using timer interrupt.
[ 4.092063] NET: Registered protocol family 10
[ 4.109264] Segment Routing with IPv6
[ 4.113555] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.166526] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.170229] NET: Registered protocol family 17
[ 4.178285] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.183184] NET: Registered protocol family 15
[ 4.199724] can: controller area network core (rev 20170425 abi 9)
[ 4.199734] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 4.218485] NET: Registered protocol family 29
[ 4.223529] can: raw protocol (rev 20170425)
[ 4.228305] can: broadcast manager protocol (rev 20170425 t)
[ 4.234665] can: netlink gateway (rev 20190810) max_hops=1
[ 4.241205] mmc1: new high speed SDIO card at address 0001
[ 4.245186] Registering SWP/SWPB emulation handler
[ 4.263736] Loading compiled-in X.509 certificates
[ 4.515197] RTL871X: HW EFUSE
[ 4.518540] RTL871X: hal_com_config_channel_plan chplan:0x20
[ 4.674655] i2c i2c2: i2c2 supply twi not found, using dummy regulator
[ 4.698942] i2c i2c2: probe success
[ 4.815217] random: crng init done
[ 4.827230] get ehci0-controller wakeup-source is fail.
[ 4.840440] sunxi ehci0-controller don't init wakeup source
[ 4.846735] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c9b7e8, 0x:c8878000, irq_no:38
[ 4.858728] [sunxi-ehci0]: Not init ehci0
[ 4.864148] get ohci0-controller wakeup-source is fail.
[ 4.870239] sunxi ohci0-controller don't init wakeup source
[ 4.876551] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c9ba78
[ 4.886185] [sunxi-ohci0]: Not init ohci0
[ 4.891546] get ehci1-controller wakeup-source is fail.
[ 4.897732] sunxi ehci1-controller don't init wakeup source
[ 4.903990] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c9bd08, 0x:c92dd000, irq_no:3a
[ 4.923833] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 4.944744] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 4.952091] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 4.962224] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
[ 4.991814] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 5.026754] hub 1-0:1.0: USB hub found
[ 5.038106] hub 1-0:1.0: 1 port detected
[ 5.055150] get ohci1-controller wakeup-source is fail.
[ 5.071939] sunxi ohci1-controller don't init wakeup source
[ 5.078221] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c9bf98
[ 5.088510] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 5.118871] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 5.126208] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 5.136270] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
[ 5.211076] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[ 5.245113] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=94:a4:08:c4:c0:61
[ 5.256440] hub 2-0:1.0: USB hub found
[ 5.271265] hub 2-0:1.0: 1 port detected
[ 5.333035] ubi0: attaching mtd4
[ 20.192916] ubi0: scanning is finished
[ 20.225392] ubi0: attached mtd4 (name "rootfs", size 119 MiB)
[ 20.231830] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 20.239494] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 20.247072] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 20.254847] ubi0: good PEBs: 959, bad PEBs: 0, corrupted PEBs: 0
[ 20.261541] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 20.269603] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 267458052
[ 20.279696] ubi0: available PEBs: 0, total reserved PEBs: 959, PEBs reserved for bad PEB handling: 40
[ 20.290001] ubi0: background thread "ubi_bgt0d" started, PID 975
[ 20.301375] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 20.317085] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 20.328325] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 20.331830] clk: Not disabling unused clocks
[ 20.338007] cfg80211: failed to load regulatory.db
[ 20.342850] alloc_fd: slot 0 not NULL!
[ 20.372329] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 20.440057] UBIFS (ubi0:0): recovery needed
[ 21.389379] UBIFS (ubi0:0): recovery deferred
[ 21.394702] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 21.403975] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.415045] UBIFS (ubi0:0): FS size: 114786304 bytes (109 MiB, 904 LEBs), journal size 5713920 bytes (5 MiB, 45 LEBs)
[ 21.426884] UBIFS (ubi0:0): reserved for root: 4952683 bytes (4836 KiB)
[ 21.434273] UBIFS (ubi0:0): media format: w5/r0 (latest is w5/r0), UUID 4A5D7D8F-3C66-4BB0-8C4C-E59EDCC1D11C, small LPT model
[ 21.449612] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
[ 21.459073] Freeing unused kernel memory: 1024K
[ 21.464303] Kernel init done
[ 21.467512] Run /init as init process
haveged: command socket is listening at fd 3
haveged: haveged starting up
login[997]: root login on 'ttyS0'
[ 23.901809]
[ 23.901809] insmod_device_driver
[ 23.901809]
[ 23.909033] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[root@T113-s3 /root]# ifconfig
[root@T113-s3 /root]# . /etc/wpa_action.sh
udhcpc: started, v1.35.0
udhcpc: broadcasting discover
[ 47.455160] RTL871X: nolinked power save enter
[ 48.156519] RTL871X: nolinked power save leave
[ 48.161574] RTL871X: rtw_set_802_11_connect(wlan0) fw_state=0x00000008
[ 48.273633] RTL871X: start auth
[ 48.279374] RTL871X: auth success, start assoc
[ 48.288239] RTL871X: assoc success
[ 48.530249] RTL871X: recv eapol packet
[ 48.541610] RTL871X: send eapol packet
[ 48.551079] RTL871X: recv eapol packet
[ 48.558365] RTL871X: send eapol packet
[ 48.562901] RTL871X: set pairwise key camid:4, addr:04:5f:a7:5d:59:7c, kid:0, type:AES
[ 48.564444] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 48.579502] RTL871X: set group key camid:5, addr:04:5f:a7:5d:59:7c, kid:2, type:TKIP
udhcpc: broadcasting select for 192.168.10.14, server 192.168.10.1
udhcpc: lease of 192.168.10.14 obtained from 192.168.10.1, lease time 86400
/usr/share/udhcpc/default.script: Adding DNS 192.168.10.1
/usr/share/udhcpc/default.script: Adding DNS 192.168.1.1
wlan0 Link encap:Ethernet HWaddr 94:A4:08:C4:C0:61
inet addr:192.168.10.14 Bcast:192.168.10.255 Mask:255.255.255.0
inet6 addr: fe80::96a4:8ff:fec4:c061/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:6 errors:0 dropped:0 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1982 (1.9 KiB) TX bytes:1834 (1.7 KiB)
[root@T113-s3 /root]# ping www.baidu.com
PING www.baidu.com (103.235.46.39): 56 data bytes
64 bytes from 103.235.46.39: seq=0 ttl=45 time=174.979 ms
64 bytes from 103.235.46.39: seq=1 ttl=45 time=176.345 ms
64 bytes from 103.235.46.39: seq=2 ttl=45 time=171.691 ms
64 bytes from 103.235.46.39: seq=3 ttl=45 time=375.649 ms
64 bytes from 103.235.46.39: seq=4 ttl=45 time=175.896 ms
64 bytes from 103.235.46.39: seq=5 ttl=45 time=320.066 ms
64 bytes from 103.235.46.39: seq=6 ttl=45 time=174.658 ms
^C
--- www.baidu.com ping statistics ---
7 packets transmitted, 7 packets received, 0% packet loss
round-trip min/avg/max = 171.691/224.183/375.649 ms
什么时候挂到github?
[ 0.000000] Linux version 5.4.61 (root@i9-10920) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #123 SMP PREEMPT Thu Apr 28 10:38:55 CST 2022
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused loglevel=8 init=/init cma=8M root=/dev/ram0 rw
[ 0.000000] Memory: 107416K/131072K available (7168K kernel code, 465K rwdata, 2164K rodata, 3072K init, 189K bss, 15464K reserved, 8192K cma-reserved)
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x440 with crng_init=0
[ 0.007999] Switching to timer-based delay loop, resolution 41ns
[ 0.014185] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023962] Console: colour dummy device 80x30
[ 0.028458] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038831] pid_max: default: 32768 minimum: 301
[ 0.043526] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050870] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059190] CPU: Testing write buffer coherency: ok
[ 0.064404] /cpus/cpu@0 missing clock-frequency property
[ 0.069739] /cpus/cpu@1 missing clock-frequency property
[ 0.075089] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081415] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088135] rcu: Hierarchical SRCU implementation.
[ 0.093274] BOOTEVENT: 93.265415: ON
[ 0.097678] smp: Bringing up secondary CPUs ...
[ 0.103079] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103231] smp: Brought up 1 node, 2 CPUs
[ 0.113062] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119242] CPU: All CPU(s) started in SVC mode.
[ 0.124460] devtmpfs: initialized
[ 0.224204] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.234501] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.244371] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.251559] pinctrl core: initialized pinctrl subsystem
[ 0.270234] NET: Registered protocol family 16
[ 0.278516] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.299778] cpuidle: using governor ladder
[ 0.304013] cpuidle: using governor menu
[ 0.580479] rtc_ccu: sunxi ccu init OK
[ 0.614777] ccu: sunxi ccu init OK
[ 0.624065] r_ccu: sunxi ccu init OK
[ 1.117043] iommu: Default domain type: Translated
[ 1.124493] sunxi iommu: irq = 24
[ 1.156430] SCSI subsystem initialized
[ 1.165319] usbcore: registered new interface driver usbfs
[ 1.173329] usbcore: registered new interface driver hub
[ 1.178861] usbcore: registered new device driver usb
[ 1.213605] pwm module init!
[ 1.238392] input: sunxi-keyboard as /devices/virtual/input/input0
[ 1.253331] clocksource: Switched to clocksource arch_sys_counter
[ 1.455803] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 1.819419] thermal_sys: Registered thermal governor 'step_wise'
[ 1.819425] thermal_sys: Registered thermal governor 'user_space'
[ 1.838177] NET: Registered protocol family 2
[ 1.858796] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.867233] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.874943] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.882013] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.888511] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.895112] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.902306] NET: Registered protocol family 1
[ 1.920296] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 1.939923] spi spi0: spi0 supply spi not found, using dummy regulator
[ 1.946838] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 1.953045] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 1.959428] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 1.965900] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 1.974329] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 1.993241] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8827000, irq 41
[ 2.286218] Initialise system trusted keyrings
[ 2.290829] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 2.297797] fuse: init (API version 7.31)
[ 2.337062] NET: Registered protocol family 38
[ 2.341538] Key type asymmetric registered
[ 2.345670] Asymmetric key parser 'x509' registered
[ 2.350655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.358091] io scheduler mq-deadline registered
[ 2.362626] io scheduler kyber registered
[ 2.380703] [DISP]disp_module_init
[ 2.397326] disp 5000000.disp: Adding to iommu group 0
[ 2.432653] display_fb_request,fb_id:0
[ 2.440972] [DISP] Fb_copy_boot_fb,line:1443:
[ 2.440976] no boot_fb0
[ 2.451632] disp_al_manager_apply ouput_type:0
[ 2.458975] [DISP]disp_module_init finish
[ 2.476420] [DISP] lcd_clk_config,line:732:
[ 2.476433] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 2.476433] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 2.487740] sunxi_sid_init()551 - insmod ok
[ 2.507089] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 2.511938] pwm-regulator: supplied by regulator-dummy
[ 2.555274] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 2.565525] uart uart0: get regulator failed
[ 2.569832] uart uart0: uart0 supply uart not found, using dummy regulator
[ 2.577524] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 2.585418] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 2.593423] printk: console [ttyS0] enabled
[ 2.602272] printk: bootconsole [earlycon0] disabled
[ 2.626834] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 2.638261] uart uart3: get regulator failed
[ 2.643036] uart uart3: uart3 supply uart not found, using dummy regulator
[ 2.660967] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 2.694917] misc dump reg init
[ 2.713276] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 2.720555] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
[ 2.728375] [DISP] disp_device_attached_and_enable,line:233:
[ 2.728380] attached ok, mgr0<-->dev0
[ 2.733455] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 2.734788] [DISP] disp_device_attached_and_enable,line:236:
[ 2.734797] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 2.738797] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 2.769250] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 2.775768] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 2.782676] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 2.790387] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=0
[ 2.798228] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 2.806359] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 2.814068] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 2.820789] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 2.828360] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 2.883593] spi-nand spi0.0: Winbond SPI NAND was found.
[ 2.889528] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 2.917502] 5 fixed-partitions partitions found on MTD device spi0.0
[ 2.924633] Creating 5 MTD partitions on "spi0.0":
[ 2.929981] 0x000000000000-0x000000100000 : "boot0"
[ 2.955587] 0x000000100000-0x000000200000 : "u-boot"
[ 2.971238] 0x000000200000-0x000000220000 : "dtb"
[ 2.990246] 0x000000220000-0x000001220000 : "kernel"
[ 2.996610] random: fast init done
[ 3.052003] 0x000001220000-0x000008000000 : "rootfs"
[ 3.339430] libphy: Fixed MDIO Bus: probed
[ 3.344126] CAN device driver interface
[ 3.348735] RTL871X: module init start
[ 3.352917] RTL871X: rtl8189fs v4.3.24.8_22657.20170607
[ 3.364764] RTL871X: module init ret=0
[ 3.368971] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.374972] usbcore: registered new interface driver hso
[ 3.380901] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.388227] sunxi-ehci: EHCI SUNXI driver
[ 3.393116] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.400077] sunxi-ohci: OHCI SUNXI driver
[ 3.408629] usbcore: registered new interface driver uas
[ 3.414762] usbcore: registered new interface driver usb-storage
[ 3.421555] usbcore: registered new interface driver ums-alauda
[ 3.428269] usbcore: registered new interface driver ums-cypress
[ 3.435086] usbcore: registered new interface driver ums-datafab
[ 3.441891] usbcore: registered new interface driver ums_eneub6250
[ 3.448950] usbcore: registered new interface driver ums-freecom
[ 3.455737] usbcore: registered new interface driver ums-isd200
[ 3.462437] usbcore: registered new interface driver ums-jumpshot
[ 3.469408] usbcore: registered new interface driver ums-karma
[ 3.476019] usbcore: registered new interface driver ums-onetouch
[ 3.489852] usbcore: registered new interface driver ums-realtek
[ 3.496679] usbcore: registered new interface driver ums-sddr09
[ 3.503422] usbcore: registered new interface driver ums-sddr55
[ 3.513609] usbcore: registered new interface driver ums-usbat
[ 3.535544] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 3.548805] sunxi_gpadc_init,2137, success
[ 3.579905] sunxi-rtc 7090000.rtc: registered as rtc0
[ 3.585742] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T06:25:34 UTC (23134)
[ 3.595022] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 3.603401] i2c /dev entries driver
[ 3.607493] IR NEC protocol handler initialized
[ 3.612545] IR RC5(x/sz) protocol handler initialized
[ 3.618690] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 3.637144] sunxi_ir_startup: get ir protocol failed
[ 3.637173] (NULL device *): deviceless supply not found, using dummy regulator
[ 3.651121] Registered IR keymap rc_map_sunxi
[ 3.663235] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 3.679002] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 3.696374] sunxi cedar version 1.1
[ 3.700545] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 3.709312] VE: sunxi_cedar_probe power-domain init!!!
[ 3.715130] VE: install start!!!
[ 3.715130]
[ 3.725534] VE: cedar-ve the get irq is 42
[ 3.725534]
[ 3.734598] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 3.734598]
[ 3.743843] VE: install end!!!
[ 3.743843]
[ 3.748918] VE: sunxi_cedar_probe
[ 3.769349] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 3.789853] /cpus/cpu@0: unsupported enable-method property: psci
[ 3.835153] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 3.852100] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 3.858313] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 3.864638] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 3.871070] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 3.877498] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 3.884022] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 3.890524] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 3.897037] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 3.911275] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 3.916901] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 3.923658] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.934798] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 3.954902] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.982953] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 4.000125] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 4.010131] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 4.016344] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 4.022680] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 4.029102] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 4.035529] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 4.042031] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 4.048573] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 4.055087] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 4.061619] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 4.078643] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.089811] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 4.109929] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.133367] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 4.159549] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.163530] usbcore: registered new interface driver usbhid
[ 4.174420] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.177392] usbhid: USB HID core driver
[ 4.190611] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 4.193176] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.203636] oprofile: hardware counters not available
[ 4.218984] oprofile: using timer interrupt.
[ 4.224305] NET: Registered protocol family 10
[ 4.245412] Segment Routing with IPv6
[ 4.253418] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.292021] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.297964] NET: Registered protocol family 17
[ 4.303918] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 4.308543] NET: Registered protocol family 15
[ 4.327695] can: controller area network core (rev 20170425 abi 9)
[ 4.327771] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 4.341894] NET: Registered protocol family 29
[ 4.347483] mmc1: new high speed SDIO card at address 0001
[ 4.351342] can: raw protocol (rev 20170425)
[ 4.362510] can: broadcast manager protocol (rev 20170425 t)
[ 4.368951] can: netlink gateway (rev 20190810) max_hops=1
[ 4.382828] Registering SWP/SWPB emulation handler
[ 4.392386] Loading compiled-in X.509 certificates
[ 4.403016] RTL871X: HW EFUSE
[ 4.406458] RTL871X: hal_com_config_channel_plan chplan:0x20
[ 4.423316] random: crng init done
[ 4.615602] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[ 4.652647] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=94:a4:08:c4:c0:61
[ 4.845431] i2c i2c2: i2c2 supply twi not found, using dummy regulator
[ 4.869306] i2c i2c2: probe success
[ 4.975491] get ehci0-controller wakeup-source is fail.
[ 4.981439] sunxi ehci0-controller don't init wakeup source
[ 4.987694] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0e9b830, 0x:c932a000, irq_no:38
[ 4.999634] [sunxi-ehci0]: Not init ehci0
[ 5.004598] get ohci0-controller wakeup-source is fail.
[ 5.014156] sunxi ohci0-controller don't init wakeup source
[ 5.020382] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0e9bac0
[ 5.030001] [sunxi-ohci0]: Not init ohci0
[ 5.042315] get ehci1-controller wakeup-source is fail.
[ 5.048301] sunxi ehci1-controller don't init wakeup source
[ 5.054541] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0e9bd50, 0x:c9333000, irq_no:3a
[ 5.077677] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 5.095065] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 5.102291] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 5.115954] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
[ 5.153358] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 5.177093] hub 1-0:1.0: USB hub found
[ 5.181346] hub 1-0:1.0: 1 port detected
[ 5.200055] get ohci1-controller wakeup-source is fail.
[ 5.206043] sunxi ohci1-controller don't init wakeup source
[ 5.212259] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0e9bfe0
[ 5.231430] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 5.247595] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 5.254867] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 5.274119] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
[ 5.359661] hub 2-0:1.0: USB hub found
[ 5.363948] hub 2-0:1.0: 1 port detected
[ 5.417716] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.467316] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.474900] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.484584] clk: Not disabling unused clocks
[ 5.489361] alloc_fd: slot 0 not NULL!
[ 5.493577] cfg80211: failed to load regulatory.db
[ 5.499087] Warning: unable to open an initial console.
[ 5.510184] Freeing unused kernel memory: 3072K
[ 5.543502] Kernel init done
[ 5.546715] Run /init as init process
[ 6.216801] ubi0: default fastmap pool size: 40
[ 6.221877] ubi0: default fastmap WL pool size: 20
[ 6.228217] ubi0: attaching mtd4
[I have no name!@T113-s3 /root]# [ 7.029232] ubi0: scanning is finished
[ 7.051601] ubi0: attached mtd4 (name "rootfs", size 109 MiB)
[ 7.058122] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 7.065891] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 7.073488] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 7.081248] ubi0: good PEBs: 879, bad PEBs: 0, corrupted PEBs: 0
[ 7.087960] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 7.096023] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 2083313605
[ 7.106215] ubi0: available PEBs: 0, total reserved PEBs: 879, PEBs reserved for bad PEB handling: 20
[ 7.116519] ubi0: background thread "ubi_bgt0d" started, PID 1003
[ 7.133442] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 7.261294] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 7.270557] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 7.281631] UBIFS (ubi0:0): FS size: 106913792 bytes (101 MiB, 842 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 7.293486] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 7.299991] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 6581B725-5C85-4A2F-8A81-815A46CDCD6C, small LPT model
启动速度提高的 8秒以内
@Cadence
大佬,用的主线Uboot和内核吗?厉害,能放到github让我们学习下不。
重启出错?
Jan 1 08:30:51 T113-s3 daemon.info nit: starting pid 1099, tty '': '/bin/umount -a -r'
[root@T113-s3 /etc]# Jan 1 08:30:51 T113-s3 daemon.info nit: starting pid 1101, tty '': '/sbin/swapoff -a'
Jan 1 08:30:51 T113-s3 daemon.i[ 1846.835865] RTL871X: rtw_cmd_thread(wlan0) _rtw_down_sema(&pcmdpriv->cmd_queue_sema) return _FAIL, break
nfo nit: The system is going down NOW!
Jan 1 08:30:51 T113-s3 syslog.info syslogd exiting
[ 1848.836123] reboot_callback(): empty arg
[ 1848.840563] [ohci1-controller]: ohci shutdown start
[ 1848.846087] [ohci1-controller]: ohci shutdown end
[ 1848.851350] [ehci1-controller]: ehci shutdown start
[ 1848.856842] [ehci1-controller]: ehci shutdown end
[ 1848.862090] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
[ 1848.870643] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
[ 1849.634124] ------------[ cut here ]------------
[ 1849.639294] WARNING: CPU: 1 PID: 1102 at drivers/clk/clk.c:960 clk_core_disable+0x38/0xa8
[ 1849.648406] mipi-dsi already disabled
[ 1849.652482] Modules linked in:
[ 1849.655888] CPU: 1 PID: 1102 Comm: init Not tainted 5.4.61 #136
[ 1849.662483] Hardware name: Generic DT based system
[ 1849.667839] [<c010e390>] (unwind_backtrace) from [<c010a8f4>] (show_stack+0x10/0x14)
[ 1849.676479] [<c010a8f4>] (show_stack) from [<c0727e64>] (dump_stack+0x7c/0x98)
[ 1849.684538] [<c0727e64>] (dump_stack) from [<c0119150>] (__warn+0xb8/0xd0)
[ 1849.692205] [<c0119150>] (__warn) from [<c01191e0>] (warn_slowpath_fmt+0x78/0xa0)
[ 1849.700552] [<c01191e0>] (warn_slowpath_fmt) from [<c03bd8d4>] (clk_core_disable+0x38/0xa8)
[ 1849.709867] [<c03bd8d4>] (clk_core_disable) from [<c03bda18>] (clk_core_disable_lock+0x18/0x24)
[ 1849.719572] [<c03bda18>] (clk_core_disable_lock) from [<c0392970>] (clk_disable_unprepare+0xc/0x18)
[ 1849.729663] [<c0392970>] (clk_disable_unprepare) from [<c0396804>] (disp_lcd_disable+0x27c/0x2d4)
[ 1849.739560] [<c0396804>] (disp_lcd_disable) from [<c0386040>] (disp_shutdown+0x68/0x84)
[ 1849.748490] [<c0386040>] (disp_shutdown) from [<c040ff70>] (device_shutdown+0x138/0x1b8)
[ 1849.757518] [<c040ff70>] (device_shutdown) from [<c0136134>] (kernel_restart+0xc/0x50)
[ 1849.766349] [<c0136134>] (kernel_restart) from [<c01363bc>] (__do_sys_reboot+0x140/0x1cc)
[ 1849.775470] [<c01363bc>] (__do_sys_reboot) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[ 1849.784487] Exception stack(0xc5d53fa8 to 0xc5d53ff0)
[ 1849.790118] 3fa0: 01234567 0053c798 fee1dead 28121969 01234567 00000000
[ 1849.799236] 3fc0: 01234567 0053c798 0053c81c 00000058 00000000 00000000 0053c000 00000000
[ 1849.808350] 3fe0: 00000058 bed09cb4 b6e60255 b6ddec66
[ 1849.813978] ---[ end trace 29d70b923e4002ee ]---
[ 1849.834375] reboot: Restarting system
解决
修改.config
CONFIG_DISP2_SUNXI=y
改为
# CONFIG_DISP2_SUNXI is not set
最近编辑记录 Cadence (2022-05-01 11:17:58)
@yang_AE86
待排除所有已知 bug和整理后,将会放到github
出现以下现象
[root@T113-s3 /]# passwd
Changing password for root
New password:
Bad password: too short
Retype password:
passwd: warning: can't lock '/etc/shadow': Permission denied
Jan 1 10:59:01 T113-s3 auth.err passwd: warning: can't lock '/etc/shadow': Permission denied
passwd: warning: can't lock '/etc/passwd': Permission denied
Jan 1 10:59:01 T113-s3 auth.err passwd: warning: can't lock '/etc/passwd': Permission denied
passwd: password for root changed by root
Jan 1 10:59:01 T113-s3 auth.info passwd: password for root changed by root
解决办法
修改.config
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
T113-s3 hostap 启动脚本
#!/bin/bash
/sbin/ifconfig wlan0 up
/usr/sbin/hostapd /usr/local/hostapd.conf -B
/sbin/ip addr add 192.168.2.1/24 dev wlan0
/sbin/udhcpd /usr/local/udhcpd.conf
[ -d /etc/dropbear/ ] || mkdir -p /etc/dropbear/
[ -d /var/log/ ] || mkdir -p /var/log/
/usr/sbin/dropbear -R -B -W 65536
hostapd.conf 内容
driver=nl80211
ssid=T113_s3
channel=10
interface=wlan0
wpa=2
wpa_passphrase='your_passwd'
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
udhcpd.conf 内容
# The start and end of the IP lease block
start 192.168.2.100
end 192.168.2.200
# The interface that udhcpd will use
interface wlan0
opt dns 192.168.2.1
option subnet 255.255.255.0
opt router 192.168.2.1
最近编辑记录 Cadence (2022-05-02 09:48:09)
xfel spinand erase 0x00000000 0x20000 && xfel spinand write 0x00000000 boot0_nand_sun20iw1p1.bin
xfel spinand erase 0x100000 0xa0000 && xfel spinand write 0x100000 u-boot.bin
xfel spinand erase 0x00200000 0x20000 && xfel spinand write 0x00200000 board.dtb
xfel spinand erase 0x00220000 0x800000 && xfel spinand write 0x00220000 uImage
xfel spinand erase 0x00a20000 0x4000000 && xfel spinand write 0x00a20000 usr_ubi.img
xfel spinand erase 0x04a20000 0x35e0000 && xfel spinand write 0x04a20000 root_ubi.img
如何上传文件?
file_burn.tar.gz
最近编辑记录 Cadence (2022-05-07 09:20:45)
可以直接xfel spinand write,没必要xfel spinand erase
@xboot
OK,thanks
谢谢你的开源 xfel和 xboot
他们给了我很大的帮助
T113_s3 的 coremark.exe
[root@T113-s3 /root]# ./coremark.exe
2K performance run parameters for coremark.
CoreMark Size : 666
Total ticks : 12814
Total time (secs): 12.814000
Iterations/Sec : 3121.585766
Iterations : 40000
Compiler version : GCC10.2.1 20210110
Compiler flags : -O2 -DPERFORMANCE_RUN=1 -lrt
Memory location : Please put data memory location here
(e.g. code in flash, data on heap etc)
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcmatrix : 0x1fd7
[0]crcstate : 0x8e3a
[0]crcfinal : 0x25b5
Correct operation validated. See README.md for run and reporting rules.
CoreMark 1.0 : 3121.585766 / GCC10.2.1 20210110 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Nuv980 的 coremark.exe
[root@Nuv980 /root]# ./coremark.exe
CoreMark Size : 666
Total ticks : 18194
Total time (secs): 18.194000
Iterations/Sec : 604.594921
Iterations : 11000
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcfinal : 0x33ff
CoreMark 1.0 : 604.594921 / GCC10.2.1 20210110 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
D1S 的 coremark.exe
[root@Risc-v /root]# ./coremark.exe
CoreMark Size : 666
Total ticks : 13034
Total time (secs): 13.034000
Iterations/Sec : 2301.672549
Iterations : 30000
Compiler version : GCC10.3.0
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcfinal : 0x5275
CoreMark 1.0 : 2301.672549 / GCC10.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Am3352 的 coremark.exe
[root@Am335x /root]# ./coremark.exe
CoreMark Size : 666
Total ticks : 11397
Total time (secs): 11.397000
Iterations/Sec : 965.166272
Iterations : 11000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 965.166272 / GCC10.2.1 20210110 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
最近编辑记录 Cadence (2022-05-08 21:32:19)
Xilinx 的ZYNQ coremark.exe
root@bohoon:~# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 0 (v7l)
BogoMIPS : 675.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
processor : 1
BogoMIPS : 675.00
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : Xilinx Zynq Platform
Revision : 0003
Serial : 0000000000000000
root@bohoon:~# ./coremark.exe
CoreMark Size : 666
Total ticks : 12170
Total time (secs): 12.170000
Iterations/Sec : 2465.078061
Iterations : 30000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 2465.078061 / GCC10.2.1 20210110 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
在T113_s3上运行 PX4
INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
INFO [px4] assuming working directory is rootfs, no symlinks needed.
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [px4] Calling startup script: /bin/sh etc/init.d/rcS 0
etc/init.d/rcS: line 57: ver: command not found
etc/init.d/rcS: line 120: .: filename argument required
.: usage: . filename [arguments]
ERROR [px4] Startup script returned with return value: 512
大佬威武,,吊翻了
mark
修改 ./.ci/Jenkinsfile-compile
sed -i 's/"beaglebone_blue_default",/"t113_s3_default", "beaglebone_blue_default",/g' ./.ci/Jenkinsfile-compile
修改 Tools/docker_run.sh
第8行
elif [[ $@ =~ .*navio2.* ]] || [[ $@ =~ .*raspberry.* ]] || [[ $@ =~ .*beaglebone.* ]] || [[ $@ =~ .*pilotpi.default ]]; then
改为
elif [[ $@ =~ .*navio2.* ]] || [[ $@ =~ .*raspberry.* ]] || [[ $@ =~ .*beaglebone.* ]] || [[ $@ =~ .*pilotpi.default ]] || [[ $@ =~ .*t113_s3.* ]]; then
建立px4_t113_s3_default
cd boards/px4
mkdir t113_s3
cd t113_s3/
cp -a ../raspberrypi/ ./
cd ../../../
root@i9-10920:/data/Pixhawk/PX4-Autopilot# make px4_t113_s3_default
-- PX4 version: v1.13.0-alpha1-4463-ge080fab8f6
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.6.9", minimum required is "3")
-- PX4 config file: /data/Pixhawk/PX4-Autopilot/boards/px4/t113_s3/default.px4board
-- PLATFORM posix
-- LINUX y
-- TOOLCHAIN arm-linux-gnueabihf
-- ARCHITECTURE cortex-a7
-- ROMFSROOT px4fmu_common
-- TESTING y
-- PX4 config: px4_t113_s3_default
-- PX4 platform: posix
-- PX4 lockstep: disabled
-- cmake build type: RelWithDebInfo
-- The CXX compiler identification is GNU 8.2.0
-- The C compiler identification is GNU 8.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /opt/tools/Xilinx/Vitis/2019.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-gcc
-- Check for working CXX compiler: /opt/tools/Xilinx/Vitis/2019.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-g++
-- Check for working CXX compiler: /opt/tools/Xilinx/Vitis/2019.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /opt/tools/Xilinx/Vitis/2019.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-gcc
-- Check for working C compiler: /opt/tools/Xilinx/Vitis/2019.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/arm-linux-gnueabihf-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Building for code coverage
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
-- ROMFS: ROMFS/px4fmu_common
-- Configuring done
-- Generating done
-- Build files have been written to: /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default
[0/932] git submodule src/drivers/gps/devices
[9/932] git submodule src/modules/mavlink/mavlink
[10/932] Generating Mavlink development: src/modules/mavlink/mavlink/message_definitions/v1.0/development.xml
Validating /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/development.xml
Parsing /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/development.xml
Validating /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/standard.xml
Parsing /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/standard.xml
Validating /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/common.xml
Parsing /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/common.xml
Validating /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/minimal.xml
Parsing /data/Pixhawk/PX4-Autopilot/src/modules/mavlink/mavlink/message_definitions/v1.0/minimal.xml
Merged enum MAV_CMD
Merged enum MAV_CMD
Found 228 MAVLink message types in 4 XML files
Generating C implementation in directory /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default/mavlink/development
Generating C implementation in directory /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default/mavlink/standard
Generating C implementation in directory /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default/mavlink/common
Generating C implementation in directory /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default/mavlink/minimal
Copying fixed headers for protocol 2.0 to /data/Pixhawk/PX4-Autopilot/build/px4_t113_s3_default/mavlink
[932/932] Linking CXX shared library src/examples/dyn_hello/examples__dyn_hello.px4mod
最近编辑记录 Cadence (2022-05-10 16:27:28)
v3s 的 coremark.exe
root:~# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 48.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : Allwinner sun8i Family
Revision : 0000
root:~# ./coremark.exe
CoreMark Size : 666
Total ticks : 14050
Total time (secs): 14.050000
Iterations/Sec : 2846.975089
Iterations : 40000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 2846.975089 / GCC10.2.1 20210110 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
