楼主 # 2022-06-29 23:09:35
linux-xc
已发帖子: 29
荔枝派zero烧录u-boot后打印错误如何解决?
根据官方办法编译成功得到:u-boot-sunxi-with-spl.bin
并烧录:if=u-boot-sunxi-with-spl.bin of=/dev/sdb1 bs=1024 seek=8
方法来源:http://zero.lichee.pro/%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91/uboot_build.html
最后启动荔枝派,但是串口打印各种错误信息,是否正常?如何解决?我还没烧录Linux
U-Boot SPL 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
挑出错误打印:
xxxxx
最近编辑记录 linux-xc (2022-06-29 23:15:50)
楼主 #1 2022-06-29 23:21:21
linux-xc
已发帖子: 29
Re: 荔枝派zero烧录u-boot后打印错误如何解决?
找到了部分解决办法,来自网上:
https://blog.csdn.net/loveshipting/article/details/106005875
最后打印信息如下:
=> env default -a
## Resetting to default environment
himport_r: can't insert "stdin=serial,usbkbd" into hash table
himport_r: can't insert "stdout=serial,vga" into hash table
himport_r: can't insert "stderr=serial,vga" into hash table
=> saveenv
Saving Environment to MMC...
Writing to MMC(0)... done
小白虽然不知道为何,但看打印信息vga,应该是关于屏幕的问题,没有接入屏幕导致的?
但是后面的驱动依然没有解决
最近编辑记录 linux-xc (2022-06-29 23:24:08)
