将驱动复制到内核后编译打包烧录,ifconfig会显示wlan0
# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          collisions:0 txqueuelen:1000
wlan0     Link encap:Ethernet  HWaddr 0C:C6:55:11:32:03
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:5 overruns:0 frame:0
然后配置wifi
# cat /etc/wpa_supplicant.conf
ap_scan=1
network={
        ssid="wifi"
        psk="123456789"
通过下面命令连接wifi
# wpa_supplicant -D wext -c /etc/wpa_supplicant.conf -i wlan0
会一直弹下面这些信息,这是什么问题,希望大佬们帮忙指导下。
rfkill: Cannot open RFKILL control device
ioctl[SIOCSIWENCODEEXT]: Invalid argument
wlan0: Trying to associate with dc:fe:18:11:11:12 (SSID='wifi' freq=2437 MHz)
Failed to add supported operating classes IE
wlan0: Authentication with dc:fe:18:11:11:12 timed out.
wlan0: CTRL-EVENT-DISCONNECTED bssid=dc:fe:18:11:11:12 reason=3 locally_generated=1
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="wifi" auth_failures=1 duration=10 reason=CONN_FAILED
wlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid="wifi"
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="wifi" auth_failures=2 duration=23 reason=CONN_FAILED
