楼主 # 2022-08-26 09:31:25
Mr.Liu
已发帖子: 29
H616+AXP313a boot 不断重启,什么原因?请指教
U-Boot SPL 2021.10-armbian (Aug 25 2022 - 17:13:08 +0800)
WS > Skip chip ID checlDRAM: 1024 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.7(debug):8ef86301-dirty
NOTICE:  BL31: Built : 17:07:29, Aug 25 2022
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a082570, model: OrangePi Zero2
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    BL31: WS-master prevent pmix setup
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
U-Boot 2021.10-armbian (Aug 25 2022 - 17:13:08 +0800) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: OrangePi Zero2
I2C:   ready
DRAM:  1 GiB
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   phy interface7
Could not get PHY for ethernet@5020000: addr 1
No ethernet found.
Autoboot in 1 seconds, press <Space> to stop
=>  setenv bootargs rw init=/bin/bash root=/dev/mmcblk0p1 rootwait console=ttyS0,115200 debug panic=30
=> ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile}
22920 bytes read in 5 ms (4.4 MiB/s)
=> ext4load mmc 0 0x46000000 /boot/Image
21934088 bytes read in 908 ms (23 MiB/s)
=> env set fdt_high ffffffff
=> booti 0x46000000 - 0x49000000
## Flattened Device Tree blob at 49000000
   Booting using the fdt blob at 0x49000000
   Loading Device Tree to 0000000049ff7000, end 0000000049fff987 ... OK
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.60-sunxi64 (root@vmcompiler) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP Thu Aug 25 17:47:19 +08 2022
[    0.000000] Machine model: OrangePi Zero2
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fdde100-0x7fddffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000004007ffff]
[    0.000000]   node   0: [mem 0x0000000040080000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] cma: Reserved 128 MiB at 0x0000000076c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 19 pages/cpu s37144 r8192 d32488 u77824
[    0.000000] pcpu-alloc: s37144 r8192 d32488 u77824 alloc=19*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: rw init=/bin/bash root=/dev/mmcblk0p1 rootwait console=ttyS0,115200 debug panic=30
[    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
[    0.000000] printk: log_buf_len min size: 16384 bytes
[    0.000000] printk: log_buf_len: 32768 bytes
[    0.000000] printk: early log buf free: 14392(87%)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 874652K/1048576K available (13568K kernel code, 1068K rwdata, 4164K rodata, 2496K init, 321K bss, 42852K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000379] Console: colour dummy device 80x25
[    0.000468] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000483] pid_max: default: 32768 minimum: 301
[    0.000557] LSM: Security Framework initializing
[    0.000586] Yama: becoming mindful.
[    0.000675] AppArmor: AppArmor initialized
[    0.000775] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.000790] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.002516] rcu: Hierarchical SRCU implementation.
[    0.003701] smp: Bringing up secondary CPUs ...
[    0.004287] Detected VIPT I-cache on CPU1
[    0.004367] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004975] Detected VIPT I-cache on CPU2
[    0.005043] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005631] Detected VIPT I-cache on CPU3
[    0.005695] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005792] smp: Brought up 1 node, 4 CPUs
[    0.005821] SMP: Total of 4 processors activated.
[    0.005829] CPU features: detected: 32-bit EL0 Support
[    0.005836] CPU features: detected: CRC32 instructions
[    0.017870] CPU: All CPU(s) started at EL2
[    0.017919] alternatives: patching kernel code
[    0.019314] devtmpfs: initialized
[    0.023411] Registered cp15_barrier emulation handler
[    0.023442] Registered setend emulation handler
[    0.023615] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.023637] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.028000] pinctrl core: initialized pinctrl subsystem
[    0.029385] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.030862] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.031017] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.031138] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.031211] audit: initializing netlink subsys (disabled)
[    0.031455] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[    0.032021] thermal_sys: Registered thermal governor 'fair_share'
[    0.032029] thermal_sys: Registered thermal governor 'bang_bang'
[    0.032036] thermal_sys: Registered thermal governor 'step_wise'
[    0.032042] thermal_sys: Registered thermal governor 'user_space'
[    0.032572] cpuidle: using governor menu
[    0.032734] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.032833] ASID allocator initialised with 65536 entries
[    0.033042] Serial: AMBA PL011 UART driver
[    0.046207] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.046234] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.046242] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.046250] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.048057] cryptd: max_cpu_qlen set to 1000
[    0.116413] raid6: neonx8   gen()  1799 MB/s
[    0.184479] raid6: neonx8   xor()  1346 MB/s
[    0.252554] raid6: neonx4   gen()  1843 MB/s
[    0.320622] raid6: neonx4   xor()  1334 MB/s
[    0.388708] raid6: neonx2   gen()  1749 MB/s
[    0.456783] raid6: neonx2   xor()  1223 MB/s
[    0.524864] raid6: neonx1   gen()  1522 MB/s
[    0.592934] raid6: neonx1   xor()  1047 MB/s
[    0.661007] raid6: int64x8  gen()  1252 MB/s
[    0.729085] raid6: int64x8  xor()   659 MB/s
[    0.797161] raid6: int64x4  gen()  1394 MB/s
[    0.865227] raid6: int64x4  xor()   712 MB/s
[    0.933316] raid6: int64x2  gen()  1188 MB/s
[    1.001394] raid6: int64x2  xor()   627 MB/s
[    1.069491] raid6: int64x1  gen()   886 MB/s
[    1.137545] raid6: int64x1  xor()   460 MB/s
[    1.137552] raid6: using algorithm neonx4 gen() 1843 MB/s
[    1.137558] raid6: .... xor() 1334 MB/s, rmw enabled
[    1.137565] raid6: using neon recovery algorithm
[    1.138431] reg-fixed-voltage vccgpu: Fixed regulator specified with variable voltages
[    1.138450] reg-fixed-voltage: probe of vccgpu failed with error -22
[    1.138826] iommu: Default domain type: Translated
[    1.138847] iommu: DMA domain TLB invalidation policy: strict mode
[    1.139171] SCSI subsystem initialized
[    1.139365] usbcore: registered new interface driver usbfs
[    1.139423] usbcore: registered new interface driver hub
[    1.139461] usbcore: registered new device driver usb
[    1.139719] pps_core: LinuxPPS API ver. 1 registered
[    1.139727] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.139749] PTP clock support registered
[    1.140166] ARM FF-A: FFA_VERSION returned not supported
[    1.140532] Advanced Linux Sound Architecture Driver Initialized.
[    1.141199] NetLabel: Initializing
[    1.141211] NetLabel:  domain hash size = 128
[    1.141216] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.141281] NetLabel:  unlabeled traffic allowed by default
[    1.141843] clocksource: Switched to clocksource arch_sys_counter
[    1.142052] VFS: Disk quotas dquot_6.6.0
[    1.142108] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.142666] AppArmor: AppArmor Filesystem Enabled
[    1.148488] NET: Registered PF_INET protocol family
[    1.148680] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.149487] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    1.149521] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.149538] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.149612] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    1.149736] TCP: Hash tables configured (established 8192 bind 8192)
[    1.149912] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.149959] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.150193] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.151230] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.156969] Initialise system trusted keyrings
[    1.157053] Key type blacklist registered
[    1.157275] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[    1.162714] zbud: loaded
[    1.164153] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.166472] integrity: Platform Keyring initialized
[    1.210010] xor: automatically using best checksumming function   32regs
[    1.210039] async_tx: api initialized (async)
[    1.210051] Key type asymmetric registered
[    1.210058] Asymmetric key parser 'x509' registered
[    1.210180] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.210356] io scheduler mq-deadline registered
[    1.210367] io scheduler kyber registered
[    1.210555] io scheduler bfq registered
[    1.219177] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    1.219973] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    1.222399] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.223906] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[    1.224443] printk: console [ttyS0] disabled
[    1.224531] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 32, base_baud = 1500000) is a 16550A
[    2.187769] printk: console [ttyS0] enabled
[    2.194458] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.204769] loop: module loaded
[    2.208708] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[    2.217692] sun6i-spi 5010000.spi: Failed to request TX DMA channel
[    2.223982] sun6i-spi 5010000.spi: Failed to request RX DMA channel
[    2.230832] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    2.250073] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    2.256974] spi-nor: probe of spi0.0 failed with error -2
[    2.263673] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.270283] ehci-platform: EHCI generic platform driver
[    2.275618] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.281810] ohci-platform: OHCI generic platform driver
[    2.287326] usbcore: registered new interface driver usb-storage
[    2.293916] mousedev: PS/2 mouse device common for all mice
[    2.300506] sun6i-rtc 7000000.rtc: registered as rtc0
[    2.305620] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T00:00:04 UTC (86404)
[    2.313990] sun6i-rtc 7000000.rtc: RTC enabled
[    2.318543] i2c_dev: i2c /dev entries driver
[    2.323431] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.332706] sdhci: Secure Digital Host Controller Interface driver
[    2.338950] sdhci: Copyright(c) Pierre Ossman
[    2.343335] Synopsys Designware Multimedia Card Interface Driver
[    2.349711] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.349811] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    2.364680] ledtrig-cpu: registered to indicate activity on CPUs
[    2.364975] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator
[    2.371096] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000
[    2.379569] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.386244] hid: raw HID events driver (C) Jiri Kosina
[    2.395621] usbcore: registered new interface driver usbhid
[    2.401199] usbhid: USB HID core driver
[    2.414200] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.414653] NET: Registered PF_INET6 protocol family
[    2.431457] Segment Routing with IPv6
[    2.435222] In-situ OAM (IOAM) with IPv6
[    2.439239] NET: Registered PF_PACKET protocol family
[    2.444507] 8021q: 802.1Q VLAN Support v1.8
[    2.448861] 9pnet: Installing 9P2000 support
[    2.453239] Key type dns_resolver registered
[    2.457945] registered taskstats version 1
[    2.458156] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.462077] Loading compiled-in X.509 certificates
[    2.475686] mmc0: new high speed SDHC card at address aaaa
[    2.478431] Loaded X.509 cert 'Build time autogenerated kernel key: db547b410d67e79c33dc7f5c06b4cd1f4cb3e184'
[    2.482037] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    2.493887] zswap: loaded using pool zstd/z3fold
[    2.501034] Key type ._fscrypt registered
[    2.501534]  mmcblk0: p1
[    2.505080] Key type .fscrypt registered
[    2.511537] Key type fscrypt-provisioning registered
[    2.517567] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[    2.525283] Key type encrypted registered
[    2.529341] AppArmor: AppArmor sha1 policy hashing enabled
[    2.534872] ima: No TPM chip found, activating TPM-bypass!
[    2.540398] ima: Allocated hash algorithm: sha1
[    2.544958] ima: No architecture policies found
[    2.549531] evm: Initialising EVM extended attributes:
[    2.554674] evm: security.selinux
[    2.557991] evm: security.SMACK64
[    2.561299] evm: security.SMACK64EXEC
[    2.564961] evm: security.SMACK64TRANSMUTE
[    2.569056] evm: security.SMACK64MMAP
[    2.572718] evm: security.apparmor
[    2.576120] evm: security.ima
[    2.579089] evm: security.capability
[    2.582662] evm: HMAC attrs: 0x1
[    2.594686] usb1-vbus: supplied by vcc-5v
[    2.599017] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[    2.608280] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz
[    2.614127] sunxi-rsb 7083000.rsb: /soc/rsb@7083000/pmic@745: set runtime address failed: -22
[    2.622829] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found
[    2.629244] axp20x-regulator axp20x-regulator.1: Error setting dcdc frequency: -5
[    2.637050] dcdca: supplied by vcc-5v
[    2.641014] dcdcb: supplied by vcc-5v
[    2.644977] dcdcc: supplied by vcc-5v
[    2.648959] dcdcd: supplied by vcc-5v
[    2.652946] dcdce: supplied by vcc-5v
[    2.656928] aldo1: supplied by vcc-5v
[    2.660889] aldo2: supplied by vcc-5v
[    2.664867] aldo3: supplied by vcc-5v
[    2.668819] bldo1: supplied by vcc-5v
[    2.672778] bldo2: supplied by vcc-5v
[    2.676752] bldo3: supplied by vcc-5v
[    2.680714] bldo4: supplied by vcc-5v
[    2.684696] cldo1: supplied by vcc-5v
[    2.688669] cldo2: supplied by vcc-5v
[    2.692619] cldo3: supplied by vcc-5v
[    2.696579] sw: supplied by regulator-dummy
[    2.700896] axp20x-rsb sunxi-rsb-745: AXP20X driver loaded
[    2.708059] ehci-platform 5200000.usb: EHCI Host Controller
[    2.713725] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 1
[    2.721596] ehci-platform 5200000.usb: irq 36, io mem 0x05200000
[    2.741854] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
[    2.748241] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    2.756517] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.763742] usb usb1: Product: EHCI Host Controller
[    2.768622] usb usb1: Manufacturer: Linux 5.15.60-sunxi64 ehci_hcd
[    2.774801] usb usb1: SerialNumber: 5200000.usb
[    2.779886] hub 1-0:1.0: USB hub found
[    2.783723] hub 1-0:1.0: 1 port detected
[    2.788582] ohci-platform 5200400.usb: Generic Platform OHCI controller
[    2.795261] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 2
[    2.803142] ohci-platform 5200400.usb: irq 37, io mem 0x05200400
[    2.870083] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[    2.878368] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.885593] usb usb2: Product: Generic Platform OHCI controller
[    2.891516] usb usb2: Manufacturer: Linux 5.15.60-sunxi64 ohci_hcd
[    2.897698] usb usb2: SerialNumber: 5200400.usb
[    2.902789] hub 2-0:1.0: USB hub found
[    2.906627] hub 2-0:1.0: 1 port detected
[    2.911569] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[    2.920508] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
[    2.932618] of_cfs_init
[    2.935276] of_cfs_init: OK
[    2.938383] ALSA device list:
[    2.941351]   No soundcards found.
[    2.945132] md: Waiting for all devices to be available before autodetect
[    2.951959] md: If you don't use raid, use raid=noautodetect
[    2.957612] md: Autodetecting RAID arrays.
[    2.961709] md: autorun ...
[    2.964505] md: ... autorun DONE.
[    3.063547] EXT4-fs (mmcblk0p1): recovery complete
[    3.072447] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[    3.082457] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    3.092312] devtmpfs: mounted
[    3.096230] Freeing unused kernel memory: 2496K
[    3.100886] Run /bin/bash as init process
[    3.104900]   with arguments:
[    3.107873]     /bin/bash
[    3.110497]   with environment:
[    3.113634]     HOME=/
[    3.116025]     TERM=linux
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
root@(none):/#
