楼主 # 2022-09-11 20:30:17
DEQ
求助!!使用mangPi-R3下载到NAND flash 不能不启动运行
求助!!使用allwinner_tina_prj_v1.rar ,编译成功,下载成功,但就是不启动运行。
开发板用的mangPi-R3,板载 spi nand flash 'GD5F1GQ5UExxG' with 134217728 bytes
开发环境:Windows,基于RTThread v4.1.0官方源码包,使用RTT ENV工具开发
按照 https://whycan.com/t_3958.html --基于RTThread的F1C100s开发(带boot启动+硬件多图层+硬件游标+LVGL+SDIO)里面的方法,
先scons ,编译成功
LINK rtthread.elf
arm-none-eabi-objcopy -O binary rtthread.elf rtthread.bin
arm-none-eabi-size rtthread.elf
   text    data     bss     dec     hex filename
861939    3404  153848 1019191   f8d37 rtthread.elf
scons: done building targets.
然后用   tools\mksunxi.exe .\rtthread.bin   修改bootloader头一些校验信息
D:\tools\Allwinner\allwinner_tina_prj_v1>tools\mksunxi.exe .\rtthread.bin
bootloader size= 2200
The bootloader head has been fixed
请按任意键继续. . .
最后用批处理烧录
@xfel.exe  version
@xfel.exe spinand
@xfel.exe spinand write  0x00000 rtthread.bin
@pause
AWUSBFEX ID=0x00166300(F1C100S/F1C200S/F1C500S) dflag=0x44 dlength=0x08 scratchpad=0x00007e00
Found spi nand flash 'GD5F1GQ5UExxG' with 134217728 bytes
100% [================================================] 845.500 KB, 86.019 KB/s
请按任意键继续. . .
然后没有任何反应,复位后USB依然在FEL模式!!
