楼主 # 2022-09-13 21:52:55
svayrolum
Improving performance of a mini wifi camera ( Chipset: BK7252)
Hi there,
I recently bought a mini Wi-Fi camera (A9 Wi-Fi 1080P Full HD), the image quality is poor, it only accesses one application (V720 app, available on Play Store) the reconnection is not possible and the upload is unstable. the camera does not accept any other application. It should be noted that it also has other defects which are:
The heating of the chip;
A very low autonomy (about 20 minutes);
The lack of data security on the web, something that many Internet users montioned.
I would like to know if modifications are possible on this device to improve its performance without having to reprogram its Beken BK7252 chipset. I would like to change the lens by replacing it with another recovered from another material and possibly changing the battery to have better charge autonomy.
In a second plan, a need in management would also require, a flashing of memory so that it is recognized by applications such as Little stars or V380. Can you direct me to the site where this has been done.
Thanks in advance
