楼主 # 2023-01-06 15:32:38
Mr.Liu
已发帖子: 29
F1C200S TF卡启动 卡在 VFS: Cannot open root device "mmcblk0p6" or unknown
使用PhoenixSuit工具烧录成功
tiny200 R3
卡在 VFS: Cannot open root device "mmcblk0p6" or unknown-b
系统 Tina 3.5.1
请问如何处理?
U-Boot 2014.07 (Jul 31 2018 - 14:59:19) Allwinner Technology
uboot commit : 6604446f7bddb8fe53f2b993100929f92a5f4d6e
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[0.444]pmbus:   ready
axp: get node[/soc/pmu0] error
axp_probe error
[0.450]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
key value = 4294967295, fel_key = [256,426]
DRAM:  64 MiB
Relocation Offset is: 03524000
int sunxi_dma_init---
irq enable
workmode = 0,storage type = 6
[0.533]MMC:      1
SUNXI SD/MMC: 1
used mbr [0], count = 8
env and backup env are not synchronized,now to synchronize
logo addr = 0x83f00000
sunxi_read_bootlogo: read bootlogo partition successful
do not find fastboot status flag
-total partitions:8-
bootlogo    : 400000        80000
env         : 480000        40000
boot        : 4c0000        600000
rootfs      : ac0000        1900000
rootfs_data : 23c0000       1900000
misc        : 3cc0000       40000
private     : 3d00000       40000
UDISK       : 3d40000       0
disable nand error: FDT_ERR_BADPATH
## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery exist
sunxi_bmp_logo_display
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   ARM OpenWrt Linux-3.10.65
   Data Size:    2902336 Bytes = 2.8 MiB
   Load Address: 80008000
   Entry Point:  80008000
   XIP Kernel Image ... OK
   reserving fdt memory region: addr=81000000 size=10000
   Using Device Tree in place at 81000000, end 8100f3df
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (l@l-VirtualBox) (gcc version 6.4        .1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #51 Fri Jan 6 07:08:41 UTC 2023
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[    0.000000] cma: CMA: reserved 32 MiB at 82000000
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat c05dd90c, node_mem_map c060e00        0
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 16384 pages, LIFO batch:3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag        es: 16256
[    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c2500        0 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mmcblk0p6 init=/pse        udo_init rdinit=/rdinit partitions=bootlogo@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0        p6:rootfs@mmcblk0p7:rootfs_data@mmcblk0p8:misc@mmcblk0p9:private@mmcblk0p10:UDIS        K@mmcblk0p1 cma=32M rootdelay=5 fb_base=0x83f00000 androidboot.serialno=00000000        00000000000 boot_type=6
[    0.000000] Memory: 25788k/25788k available, 39748k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc04cff84   (4896 kB)
[    0.000000]       .init : 0xc04d0000 - 0xc04ee8e8   ( 123 kB)
[    0.000000]       .data : 0xc04f0000 - 0xc05de228   ( 953 kB)
[    0.000000]        .bss : 0xc05de228 - 0xc060d4c0   ( 189 kB)
[    0.000000] NR_IRQS:256
[    0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[    0.000000] pll_cpu-set_default_rate=552000000 success!
[    0.000000] pll_video-set_default_rate=297000000 success!
[    0.000000] pll_ddr-set_default_rate=312000000 success!
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895        6ms
[    0.005326] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[    0.075252] pid_max: default: 32768 minimum: 301
[    0.080431] Mount-cache hash table entries: 512
[    0.086388] CPU: Testing write buffer coherency: ok
[    0.092164] Setting up static identity map for 0xc03b37f8 - 0xc03b3850
[    0.101428] devtmpfs: initialized
[    0.107067] pinctrl core: initialized pinctrl subsystem
[    0.119420] NET: Registered protocol family 16
[    0.127429] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.135090] dump_class_init,844, success
[    0.143949] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[    0.167944] bio: create slab <bio-0> at 0
[    0.173480] pwm module init!
[    0.178247] SCSI subsystem initialized
[    0.182527] usbcore: registered new interface driver usbfs
[    0.188345] usbcore: registered new interface driver hub
[    0.194224] usbcore: registered new device driver usb
[    0.201750] gpio=0,mul_sel=0,pull=0,drv_level=0,data=0
[    0.207471] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.216022] pcf857x 0-0020: retry commucation.7
[    0.220983] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.229506] pcf857x 0-0020: retry commucation.6
[    0.234484] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.243006] pcf857x 0-0020: retry commucation.5
[    0.247955] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.256473] pcf857x 0-0020: retry commucation.4
[    0.261420] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.269940] pcf857x 0-0020: retry commucation.3
[    0.274912] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.283427] pcf857x 0-0020: retry commucation.2
[    0.288373] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.296890] pcf857x 0-0020: retry commucation.1
[    0.301835] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, de        v addr: 0x20)
[    0.310380] pcf857x: probe of 0-0020 failed with error -70
[    0.319965] Linux video capture interface: v2.00
[    0.325382] Advanced Linux Sound Architecture Driver Initialized.
[    0.333353] cfg80211: Calling CRDA to update world regulatory domain
[    0.340857] Switching to clocksource sun3i high-res couter
[    0.366760] get det_vbus is fail, 84
[    0.372119] NET: Registered protocol family 2
[    0.378733] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.385849] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.392520] TCP: Hash tables configured (established 512 bind 512)
[    0.399088] TCP: reno registered
[    0.402484] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.408594] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.415677] NET: Registered protocol family 1
[    0.436050] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.442805] msgmni has been set to 114
[    0.450042] io scheduler noop registered
[    0.454212] io scheduler cfq registered (default)
[    0.459190] [pm]aw_pm_init!
[    0.462470] [pm]valid
[    0.464875] [pm]valid
[    0.467692] [DISP]disp_module_init
[    0.526744] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9
[    0.534153] num_screens=1
[    0.537017] screen_id=0
[    0.539596] para->mclk[MOD_CLK_LCD1CH0]=0xc180c340
[    0.544546] para->mclk[MOD_CLK_LCD1CH1]=0xc180c440
[    0.549546] disp tv init
[    0.552215] tcon_clk=0xc180c340, tcon_clk_parent=0x0
[    0.557387] tcon_clk=0xc180c340, tcon_clk_parent=0xc1804400
[    0.563136] tve_clk=0xc180c440, tve_clk_parent=0xc1804400
[    0.568738] disp al tv init
[    0.574419] fetch script datadisp.screen2_output_type fail
[    0.580509] fetch script datadisp.screen2_output_mode fail
[    0.588871] fetch script datadisp.fb2_format fail
[    0.594047] fetch script datadisp.fb2_scaler_mode_enable fail
[    0.600349] fetch script datadisp.fb2_width fail
[    0.605435] fetch script datadisp.fb2_height fail
[    0.633748] [DISP]disp_module_init finish
[    0.652188] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[    0.658632] sw_console_setup()1324 - console setup baud 115200 parity n bits        8, flow n
[    0.666854] console [ttyS1] enabled, bootconsole disabled
[    0.679426] misc dump reg init
[    0.684584] [NAND]Failed to insmod nand!!!
[    0.689742] sunxi-wlan wlan: wlan_busnum (0)
[    0.694501] sunxi-wlan wlan: wlan_power_num (0)
[    0.699629] sunxi-wlan wlan: Missing wlan_io_regulator.
[    0.705436] sunxi-wlan wlan: io_regulator_name ((null))
[    0.711319] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
[    0.719180] ------------SUNXI_RF: Set regon for SUN3IW1P1_R6!----------------
[    0.727157] sunxi-wlan wlan: wlan_regon gpio=-1048148608  mul-sel=-1048355436        pull=-1048355480  drv_level=-1072827436  data=-1072829732
[    0.740804] sunxi-wlan wlan: can't request wlan_regon gpio 2041
[    0.747441] platform wlan: Driver sunxi-wlan requests probe deferral
[    0.754833] lradc_battery_probe:lradc_battery_probe ++++++
[    0.761012] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
[    0.767952] key base: f1c23400
[    0.771476] irq num: 114 !
[    0.774480] battery_data_hw_init:battery_data_hw_init ++++++
[    0.780883] lradc_battery_probe:lradc_battery_probe ------
[    0.787709] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.795515] usbcore: registered new interface driver usb-storage
[    0.802391] usbcore: registered new interface driver ums-alauda
[    0.809151] usbcore: registered new interface driver ums-cypress
[    0.815910] usbcore: registered new interface driver ums-datafab
[    0.822741] usbcore: registered new interface driver ums_eneub6250
[    0.829744] usbcore: registered new interface driver ums-freecom
[    0.836489] usbcore: registered new interface driver ums-isd200
[    0.843235] usbcore: registered new interface driver ums-jumpshot
[    0.850159] usbcore: registered new interface driver ums-karma
[    0.856788] usbcore: registered new interface driver ums-onetouch
[    0.863681] usbcore: registered new interface driver ums-realtek
[    0.870509] usbcore: registered new interface driver ums-sddr09
[    0.877236] usbcore: registered new interface driver ums-sddr55
[    0.883888] usbcore: registered new interface driver ums-usbat
[    0.891321] gpio_request failed
[    0.894830] get regulator_io is no nocare
[    0.899530] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[    0.907549] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registere        d, assigned bus number 1
[    0.919284] hub 1-0:1.0: USB hub found
[    0.923506] hub 1-0:1.0: 1 port detected
[    0.928442] wrn: hcd is not enable, need not stop hcd
[    0.934795] sunxi_keyboard_startup: keyboard has no clk.
[    0.941322] input: sunxi-keyboard as /devices/virtual/input/input0
[    0.949387] rtc-pcf8563 0-0051: chip found, driver version 0.4.3
[    0.956477] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, de        v addr: 0x51)
[    0.965745] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[    0.972942] rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0
[    0.980593] sunxi cedar version 0.1
[    0.984706] VE: install start!!!
[    0.984706]
[    0.990166] cedar_ve: cedar-ve the get irq is 103
[    0.996025] VE: install end!!!
[    0.996025]
[    1.002233] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v0.91 2018-5-2        9 14:19) Compiled in Jan  6 2023 at 02:10:49
[    1.014718] sunxi-mmc sdc1: Can't get vmmc regulator string
[    1.020995] sunxi-mmc sdc1: Can't get vqmmc regulator string
[    1.027353] sunxi-mmc sdc1: Can't get vdmmc regulator string
[    1.033642] sunxi-mmc sdc1: Failed getting OCR mask: 0
[    1.040828] sunxi-mmc sdc1: ***set host ocr***
[    1.046180] sunxi-mmc sdc1: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 t        iming LEGACY(SDR12) dt B
[    1.066751] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt        h 1 timing LEGACY(SDR12) dt B
[    1.096845] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt        h 1 timing LEGACY(SDR12) dt B
[    1.107765] sunxi-mmc sdc1: base:0xf1c10000 irq:106
[    1.117523] failed to get gpio-spk and gpio_num
[    1.125882] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
[    1.133982] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
[    1.141985] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
[    1.149762] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
[    1.157530] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Spea        ker
[    1.166888] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt        h 1 timing LEGACY(SDR12) dt B
[    1.185665] sunxi-codec-machine sound.2:  sun3iw1codec <-> 1c23c00.cpudai0-co        ntroller mapping ok
[    1.195640] sunxi-codec-machine sound.2: ASoC: no sink widget found for MainM        ic Bias
[    1.204323] sunxi-codec-machine sound.2: ASoC: Failed to add route External M        ainMic -> direct -> MainMic Bias
[    1.215374] sunxi-codec-machine sound.2: ASoC: no source widget found for Mai        nMic Bias
[    1.224202] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bi        as -> direct -> MIC1P
[    1.234178] sunxi-codec-machine sound.2: ASoC: no source widget found for Mai        nMic Bias
[    1.243001] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bi        as -> direct -> MIC1N
[    1.254118] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 widt        h 1 timing LEGACY(SDR12) dt B
[    1.265852] sunxi-mmc sdc1: smc 0 p1 err, cmd 1, RTO !!
[    1.271835] sunxi-mmc sdc1: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 t        iming LEGACY(SDR12) dt B
[    1.284080] ipip: IPv4 over IPv4 tunneling driver
[    1.290600] gre: GRE over IPv4 demultiplexor driver
[    1.296031] ip_gre: GRE over IPv4 tunneling driver
[    1.304836] TCP: cubic registered
[    1.308644] Initializing XFRM netlink socket
[    1.313431] NET: Registered protocol family 17
[    1.318502] NET: Registered protocol family 15
[    1.323977] VFP support v0.3: not present
[    1.329654] [LCD]lcd_module_init
[    1.337237] enhance_en=1
[    1.340114] matrixresult:(0x0, 0x3c4, 0x0, 0x0)
[    1.345282] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9
[    1.352546] clk_div=9
[    1.355086] [DISP] disp_sys_gpio_request,line:303:    disp_sys_gpio_request f        ailed, gpio_name=lcd_gpio_0, gpio=2043, ret=-517
[    1.369187] [LCD]open, step 0 finish
[    1.406749] [LCD]open, step 1 finish
[    1.466718] [LCD]open, step 2 finish
[    1.586733] ------------[ cut here ]------------
[    1.591930] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x28/0x4c()
[    1.599719] invalid GPIO -517
[    1.603039] Modules linked in:
[    1.606445] CPU: 0 PID: 9 Comm: kworker/0:1 Not tainted 3.10.65 #51
[    1.613480] Workqueue: events start_work
[    1.617886] Backtrace:
[    1.620701] [<c0013328>] (dump_backtrace+0x0/0x104) from [<c0013534>] (show_stack+0x18/0x1c)
[    1.630116]  r7:0000007e r6:c047465a r5:00000009 r4:c185bda8
[    1.636516] [<c001351c>] (show_stack+0x0/0x1c) from [<c03b0700>] (dump_stack+0x20/0x28)
[    1.645507] [<c03b06e0>] (dump_stack+0x0/0x28) from [<c001b9dc>] (warn_slowpath_common+0x54/0x70)
[    1.655461] [<c001b988>] (warn_slowpath_common+0x0/0x70) from [<c001ba30>] (warn_slowpath_fmt+0x38/0x40)
[    1.666019]  r9:c05f0380 r8:c04754ea r7:00000001 r6:00000000 r5:c18ce3c0
r4:fffffdfb
[    1.674864] [<c001b9f8>] (warn_slowpath_fmt+0x0/0x40) from [<c017fb98>] (gpio_to_desc+0x28/0x4c)
[    1.684651]  r3:fffffdfb r2:c0474649
[    1.688730] [<c017fb70>] (gpio_to_desc+0x0/0x4c) from [<c017fc3c>] (gpio_get_value_cansleep+0x10/0x44)
[    1.699134] [<c017fc2c>] (gpio_get_value_cansleep+0x0/0x44) from [<c018fbd0>] (disp_sys_gpio_set_direction+0x20/0xb8)
[    1.710994] [<c018fbb0>] (disp_sys_gpio_set_direction+0x0/0xb8) from [<c01a6130>] (disp_lcd_gpio_set_direction+0xa8/0xc8)
[    1.723201]  r5:c18ce3c0 r4:c1814000
[    1.727266] [<c01a6088>] (disp_lcd_gpio_set_direction+0x0/0xc8) from [<c01a1b04>] (bsp_disp_lcd_gpio_set_direction+0x38/0x44)
[    1.739868]  r7:c1814000 r6:c05f0108 r5:00000001 r4:00000000
[    1.746222] [<c01a1acc>] (bsp_disp_lcd_gpio_set_direction+0x0/0x44) from [<c01ac648>] (sunxi_lcd_gpio_set_direction+0x20/0x30)
[    1.758922]  r5:00000000 r4:00000003
[    1.762933] [<c01ac628>] (sunxi_lcd_gpio_set_direction+0x0/0x30) from [<c01afd94>] (LCD_bl_open+0x28/0x3c)
[    1.773743] [<c01afd6c>] (LCD_bl_open+0x0/0x3c) from [<c01893e4>] (drv_lcd_enable+0xa0/0xe0)
[    1.783175] [<c0189344>] (drv_lcd_enable+0x0/0xe0) from [<c0189530>] (start_work+0x10c/0x1cc)
[    1.792692]  r9:c05f0380 r8:c0475507 r7:00000001 r6:c0475497 r5:c05f05f4
r4:00000000
[    1.801479] [<c0189424>] (start_work+0x0/0x1cc) from [<c0031cc0>] (process_one_work+0x1e8/0x330)
[    1.811304] [<c0031ad8>] (process_one_work+0x0/0x330) from [<c0031e38>] (process_scheduled_works+0x30/0x34)
[    1.822187] [<c0031e08>] (process_scheduled_works+0x0/0x34) from [<c0032b78>] (worker_thread+0x1e0/0x358)
[    1.832831]  r5:c04fcbd0 r4:c1822e40
[    1.836915] [<c0032998>] (worker_thread+0x0/0x358) from [<c0037cf8>] (kthread+0xa8/0xb4)
[    1.845930] [<c0037c50>] (kthread+0x0/0xb4) from [<c000f930>] (ret_from_fork+0x14/0x24)
[    1.854877]  r7:00000000 r6:00000000 r5:c0037c50 r4:c1849e7c
[    1.861221] ---[ end trace d6a845cbc9034914 ]---
[    1.866341] ------------[ cut here ]------------
[    1.871563] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x28/0x4c()
[    1.879324] invalid GPIO -517
[    1.882610] Modules linked in:
[    1.886014] CPU: 0 PID: 9 Comm: kworker/0:1 Tainted: G        W    3.10.65 #51
[    1.894109] Workqueue: events start_work
[    1.898507] Backtrace:
[    1.901287] [<c0013328>] (dump_backtrace+0x0/0x104) from [<c0013534>] (show_stack+0x18/0x1c)
[    1.910719]  r7:0000007e r6:c047465a r5:00000009 r4:c185bda0
[    1.917108] [<c001351c>] (show_stack+0x0/0x1c) from [<c03b0700>] (dump_stack+0x20/0x28)
[    1.926058] [<c03b06e0>] (dump_stack+0x0/0x28) from [<c001b9dc>] (warn_slowpath_common+0x54/0x70)
[    1.935983] [<c001b988>] (warn_slowpath_common+0x0/0x70) from [<c001ba30>] (warn_slowpath_fmt+0x38/0x40)
[    1.946559]  r9:c05f0380 r8:c04754ea r7:00000001 r6:00000000 r5:c18ce3c0
r4:00000000
[    1.955388] [<c001b9f8>] (warn_slowpath_fmt+0x0/0x40) from [<c017fb98>] (gpio_to_desc+0x28/0x4c)
[    1.965180]  r3:fffffdfb r2:c0474649
[    1.969238] [<c017fb70>] (gpio_to_desc+0x0/0x4c) from [<c0180628>] (gpio_direction_output+0x14/0x20)
[    1.979470] [<c0180614>] (gpio_direction_output+0x0/0x20) from [<c018fbdc>] (disp_sys_gpio_set_direction+0x2c/0xb8)
[    1.991098]  r5:c18ce3c0 r4:fffffdfb
[    1.995102] [<c018fbb0>] (disp_sys_gpio_set_direction+0x0/0xb8) from [<c01a6130>] (disp_lcd_gpio_set_direction+0xa8/0xc8)
[    2.007322]  r5:c18ce3c0 r4:c1814000
[    2.011346] [<c01a6088>] (disp_lcd_gpio_set_direction+0x0/0xc8) from [<c01a1b04>] (bsp_disp_lcd_gpio_set_direction+0x38/0x44)
[    2.023946]  r7:c1814000 r6:c05f0108 r5:00000001 r4:00000000
[    2.030342] [<c01a1acc>] (bsp_disp_lcd_gpio_set_direction+0x0/0x44) from [<c01ac648>] (sunxi_lcd_gpio_set_direction+0x20/0x30)
[    2.043041]  r5:00000000 r4:00000003
[    2.047089] [<c01ac628>] (sunxi_lcd_gpio_set_direction+0x0/0x30) from [<c01afd94>] (LCD_bl_open+0x28/0x3c)
[    2.057897] [<c01afd6c>] (LCD_bl_open+0x0/0x3c) from [<c01893e4>] (drv_lcd_enable+0xa0/0xe0)
[    2.067326] [<c0189344>] (drv_lcd_enable+0x0/0xe0) from [<c0189530>] (start_work+0x10c/0x1cc)
[    2.076839]  r9:c05f0380 r8:c0475507 r7:00000001 r6:c0475497 r5:c05f05f4
r4:00000000
[    2.085590] [<c0189424>] (start_work+0x0/0x1cc) from [<c0031cc0>] (process_one_work+0x1e8/0x330)
[    2.095417] [<c0031ad8>] (process_one_work+0x0/0x330) from [<c0031e38>] (process_scheduled_works+0x30/0x34)
[    2.106291] [<c0031e08>] (process_scheduled_works+0x0/0x34) from [<c0032b78>] (worker_thread+0x1e0/0x358)
[    2.116933]  r5:c04fcbd0 r4:c1822e40
[    2.120944] [<c0032998>] (worker_thread+0x0/0x358) from [<c0037cf8>] (kthread+0xa8/0xb4)
[    2.130024] [<c0037c50>] (kthread+0x0/0xb4) from [<c000f930>] (ret_from_fork+0x14/0x24)
[    2.138979]  r7:00000000 r6:00000000 r5:c0037c50 r4:c1849e7c
[    2.145285] ---[ end trace d6a845cbc9034915 ]---
[    2.150450] gpiod_direction_output: invalid GPIO
[    2.155609] [DISP] disp_sys_gpio_set_direction,line:413:    gpio_direction_output fail!
[    2.164542] ------------[ cut here ]------------
[    2.169746] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x28/0x4c()
[    2.177531] invalid GPIO -517
[    2.180819] Modules linked in:
[    2.184225] CPU: 0 PID: 9 Comm: kworker/0:1 Tainted: G        W    3.10.65 #51
[    2.192323] Workqueue: events start_work
[    2.196722] Backtrace:
[    2.199504] [<c0013328>] (dump_backtrace+0x0/0x104) from [<c0013534>] (show_stack+0x18/0x1c)
[    2.208932]  r7:0000007e r6:c047465a r5:00000009 r4:c185bda8
[    2.215282] [<c001351c>] (show_stack+0x0/0x1c) from [<c03b0700>] (dump_stack+0x20/0x28)
[    2.224276] [<c03b06e0>] (dump_stack+0x0/0x28) from [<c001b9dc>] (warn_slowpath_common+0x54/0x70)
[    2.234203] [<c001b988>] (warn_slowpath_common+0x0/0x70) from [<c001ba30>] (warn_slowpath_fmt+0x38/0x40)
[    2.244778]  r9:c05f0380 r8:c04754ea r7:00000001 r6:00000000 r5:c18ce3c0
r4:00000001
[    2.253598] [<c001b9f8>] (warn_slowpath_fmt+0x0/0x40) from [<c017fb98>] (gpio_to_desc+0x28/0x4c)
[    2.263410]  r3:fffffdfb r2:c0474649
[    2.267472] [<c017fb70>] (gpio_to_desc+0x0/0x4c) from [<c017fe10>] (gpio_set_value_cansleep+0x14/0x6c)
[    2.277893] [<c017fdfc>] (gpio_set_value_cansleep+0x0/0x6c) from [<c018fccc>] (disp_sys_gpio_set_value+0x18/0x4c)
[    2.289312]  r5:c18ce3c0 r4:c1814000
[    2.293337] [<c018fcb4>] (disp_sys_gpio_set_value+0x0/0x4c) from [<c01a6068>] (disp_lcd_gpio_set_value+0xa8/0xc8)
[    2.304795] [<c01a5fc0>] (disp_lcd_gpio_set_value+0x0/0xc8) from [<c01a1ac0>] (bsp_disp_lcd_gpio_set_value+0x38/0x44)
[    2.316668]  r7:c1814000 r6:c05f0108 r5:00000001 r4:00000000
[    2.323028] [<c01a1a88>] (bsp_disp_lcd_gpio_set_value+0x0/0x44) from [<c01ac618>] (sunxi_lcd_gpio_set_value+0x20/0x30)
[    2.334965]  r5:00000000 r4:00000003
[    2.339017] [<c01ac5f8>] (sunxi_lcd_gpio_set_value+0x0/0x30) from [<c01afda4>] (LCD_bl_open+0x38/0x3c)
[    2.349436] [<c01afd6c>] (LCD_bl_open+0x0/0x3c) from [<c01893e4>] (drv_lcd_enable+0xa0/0xe0)
[    2.358893] [<c0189344>] (drv_lcd_enable+0x0/0xe0) from [<c0189530>] (start_work+0x10c/0x1cc)
[    2.368386]  r9:c05f0380 r8:c0475507 r7:00000001 r6:c0475497 r5:c05f05f4
r4:00000000
[    2.377222] [<c0189424>] (start_work+0x0/0x1cc) from [<c0031cc0>] (process_one_work+0x1e8/0x330)
[    2.387031] [<c0031ad8>] (process_one_work+0x0/0x330) from [<c0031e38>] (process_scheduled_works+0x30/0x34)
[    2.397907] [<c0031e08>] (process_scheduled_works+0x0/0x34) from [<c0032b78>] (worker_thread+0x1e0/0x358)
[    2.408569]  r5:c04fcbd0 r4:c1822e40
[    2.412580] [<c0032998>] (worker_thread+0x0/0x358) from [<c0037cf8>] (kthread+0xa8/0xb4)
[    2.421640] [<c0037c50>] (kthread+0x0/0xb4) from [<c000f930>] (ret_from_fork+0x14/0x24)
[    2.430580]  r7:00000000 r6:00000000 r5:c0037c50 r4:c1849e7c
[    2.436919] ---[ end trace d6a845cbc9034916 ]---
[    2.442061] [LCD]open, step 3 finish
[    2.447243] [LCD]lcd_module_init finish
[    2.452208] sunxi-wlan wlan: wlan_busnum (0)
[    2.457111] sunxi-wlan wlan: wlan_power_num (0)
[    2.462202] sunxi-wlan wlan: Missing wlan_io_regulator.
[    2.468071] sunxi-wlan wlan: io_regulator_name ((null))
[    2.473977] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
[    2.481887] ------------SUNXI_RF: Set regon for SUN3IW1P1_R6!----------------
[    2.489888] sunxi-wlan wlan: wlan_regon gpio=-1048148608  mul-sel=-1047954028  pull=-1047954072  drv_level=-1072827436  data=-1072829732
[    2.503573] sunxi-wlan wlan: can't request wlan_regon gpio 2041
[    2.510249] platform wlan: Driver sunxi-wlan requests probe deferral
[    2.517666] usb_serial_number:20080411
[    2.522432] file system registered
[    2.529200] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.536982] android_usb gadget: Number of LUNs=3
[    2.542222]  lun0: LUN: removable file: (no medium)
[    2.547716]  lun1: LUN: removable file: (no medium)
[    2.553130]  lun2: LUN: removable file: (no medium)
[    2.559502] android_usb gadget: android_usb ready
[    2.565154] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
[    2.574434] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[    2.581191] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    2.589096] ALSA device list:
[    2.592499]   #0: audiocodec
[    2.596450] Waiting 5sec before mounting root device...
[    4.386703]
[    4.386703] insmod_device_driver
[    4.386703]
[    4.393858] device_chose finished 77!
[    7.607106] VFS: Cannot open root device "mmcblk0p6" or unknown-block(0,0): error -6
[    7.615802] Please append a correct "root=" boot option; here are the available partitions:
[    7.625173] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
最近编辑记录 Mr.Liu (2023-01-06 15:33:48)
楼主 #1 2023-01-06 17:12:24
Mr.Liu
已发帖子: 29
Re: F1C200S TF卡启动 卡在 VFS: Cannot open root device "mmcblk0p6" or unknown
已解决!我不知道怎么关闭帖子
最近编辑记录 Mr.Liu (2023-01-06 17:12:43)
#2 2023-02-01 10:14:12
uuid
已发帖子: 45
请问是怎么解决的呢?
