主控F1C200s
交叉编译环境:gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi
uboot:荔枝派nano v2018.01
kernel:Linux5.7.1(主线内核)
参考链接:CSDN参考博客,
问题:正点原子40Pin RGB屏幕无法显示,背光应该是可以的
启动日志:
U-Boot 2018.01-05679-g013ca45-dirty (Jan 04 2023 - 10:02:12 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
reading zImage
4397352 bytes read in 225 ms (18.6 MiB/s)
7332 bytes read in 25 ms (286.1 KiB/s)
## Flattened Device Tree blob at 80c08000
Booting using the fdt blob at 0x80c08000
Loading Device Tree to 816fb000, end 816ffca3 ... OK
[ 0.000000] Linux version 5.7.1 (project01@likaiqin-virtual-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11), GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #3 Sat Jan 7 21:43:12 CST 2023
[ 0.000000] OF: fdt: Machine model: Mango-pi
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 54156K/65536K available (7168K kernel code, 226K rwdata, 1688K rodata, 1024K init, 246K bss, 11380K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_bytes called from start_kernel+0x2a0/0x498 with crng_init=0
[ 0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000135] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000788] Console: colour dummy device 80x30
[ 0.000877] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070249] pid_max: default: 32768 minimum: 301
[ 0.070770] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.070811] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.072626] CPU: Testing write buffer coherency: ok
[ 0.074383] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.075628] devtmpfs: initialized
[ 0.082355] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082421] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.082712] pinctrl core: initialized pinctrl subsystem
[ 0.084079] thermal_sys: Registered thermal governor 'step_wise'
[ 0.085480] NET: Registered protocol family 16
[ 0.086946] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.089104] cpuidle: using governor menu
[ 0.140138] SCSI subsystem initialized
[ 0.140642] usbcore: registered new interface driver usbfs
[ 0.140797] usbcore: registered new interface driver hub
[ 0.141013] usbcore: registered new device driver usb
[ 0.141458] pps_core: LinuxPPS API ver. 1 registered
[ 0.141481] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.141561] PTP clock support registered
[ 0.142064] Advanced Linux Sound Architecture Driver Initialized.
[ 0.143937] clocksource: Switched to clocksource timer
[ 0.174616] NET: Registered protocol family 2
[ 0.176139] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.176216] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.176273] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.176320] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.176593] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.176653] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.177172] NET: Registered protocol family 1
[ 0.178651] RPC: Registered named UNIX socket transport module.
[ 0.178690] RPC: Registered udp transport module.
[ 0.178704] RPC: Registered tcp transport module.
[ 0.178718] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.181065] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.182737] Initialise system trusted keyrings
[ 0.183334] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.207055] NFS: Registering the id_resolver key type
[ 0.207159] Key type id_resolver registered
[ 0.207179] Key type id_legacy registered
[ 0.319945] Key type asymmetric registered
[ 0.319985] Asymmetric key parser 'x509' registered
[ 0.320160] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.320185] io scheduler mq-deadline registered
[ 0.320201] io scheduler kyber registered
[ 0.331916] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.332727] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[ 0.334371] pwm-backlight backlight: supply power not found, using dummy regulator
[ 0.603232] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.610488] printk: console [ttyS0] disabled
[ 0.610665] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 20, base_baud = 6250000) is a 16550A
[ 1.051382] printk: console [ttyS0] enabled
[ 1.065902] SCSI Media Changer driver v0.25
[ 1.071578] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.078233] ehci-platform: EHCI generic platform driver
[ 1.083752] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.090064] ohci-platform: OHCI generic platform driver
[ 1.095777] usbcore: registered new interface driver usb-storage
[ 1.102457] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.111558] i2c /dev entries driver
[ 1.116727] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 1.153283] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.164758] usbcore: registered new interface driver usbhid
[ 1.170339] usbhid: USB HID core driver
[ 1.190691] NET: Registered protocol family 17
[ 1.195498] Key type dns_resolver registered
[ 1.200922] Loading compiled-in X.509 certificates
[ 1.217725] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.236327] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.243083] ALSA device list:
[ 1.246185] #0: Loopback 1
[ 1.250058] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.258812] cfg80211: failed to load regulatory.db
[ 1.264691] Waiting for root device /dev/mmcblk0p2...
[ 1.307552] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.319701] mmc0: new high speed SDHC card at address e624
[ 1.327119] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 1.336087] mmcblk0: p1 p2
[ 1.520933] random: fast init done
[ 2.605789] EXT4-fs (mmcblk0p2): recovery complete
[ 2.612358] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.620686] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.631094] devtmpfs: mounted
[ 2.638685] Freeing unused kernel memory: 1024K
[ 2.643317] Run /sbin/init as init process
[ 3.445867] systemd[1]: System time before build time, advancing clock.
[ 3.473000] systemd[1]: Failed to lookup module alias 'autofs4': Function not implemented
[ 3.521972] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.545507] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
[ 3.586448] systemd[1]: Set hostname to <likaiqin-virtual-machine>.
[ 6.982003] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.999241] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.107570] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.205475] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 8.213856] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.224953] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 8.264702] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.273445] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 8.317091] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 8.355873] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Remote File Systems.
[ 8.526912] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 8.564975] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 8.579334] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 8.616527] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 8.656611] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 8.696078] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 8.737370] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 8.777506] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
[ 8.790834] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.824300] systemd[1]: Mounting Kernel Debug File System...
Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
Starting Journal Service...
[ OK ] Reached target Slices.
Starting udev Coldplug all Devices...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Load/Save Random Seed...
Starting Create System Users...
Activating swap /swap1...
Mounting Kernel Configuration File System...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Journal Service.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create System Users.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
[ 12.985827] systemd-journald[99]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
[ 14.318685] Adding 524284k swap on /swap1. Priority:-2 extents:6 across:565244k SS
[ OK ] Activated swap /swap1.
[ OK ] Reached target Swap.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Found device /dev/ttyS0.
[ OK ] Reached target Sound Card.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen …ness of backlight:backlight...
[ OK ] Started Helper to synchronize boot up for ifupdown.
Starting Raise network interfaces...
[ OK ] Started Load/Save Screen B…htness of backlight:backlight.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
Starting System Logging Service...
[ OK ] Started Daily Cleanup of Temporary Directories.
Starting Login Service...
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant...
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Started System Logging Service.
[ OK ] Started Raise network interfaces.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
[ OK ] Started Login Service.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
Debian GNU/Linux 10 likaiqin-virtual-machine ttyS0
likaiqin-virtual-machine login: [ 61.961746] random: crng init done
[ 61.965182] random: 7 urandom warning(s) missed due to ratelimiting
likaiqin-virtual-machine login: 设备树dtsi文件:
* Copyright 2018 Mesih Kilinc <mesihkilinc@gmail.com>
// modify by kashine
#include <dt-bindings/clock/suniv-ccu-f1c100s.h>
#include <dt-bindings/reset/suniv-ccu-f1c100s.h>
#address-cells = <1>;
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
cpus {
cpu {
device_type = "cpu";
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,suniv-f1c100s-system-control",
"allwinner,sun4i-a10-system-control";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
compatible = "allwinner,suniv-f1c100s-sram-d",
"allwinner,sun4i-a10-sram-d";
reg = <0x0000 0x1000>;
status = "disabled";
ccu: clock@1c20000 {
compatible = "allwinner,suniv-f1c100s-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-f1c100s-ic";
reg = <0x01c20400 0x400>;
interrupt-controller;
#interrupt-cells = <1>;
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-f1c100s-pinctrl";
reg = <0x01c20800 0x400>;
clocks = <&ccu 37>, <&osc24M>, <&osc32k>;
gpio-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
uart0_pe_pins: uart0-pe-pins {
pins = "PE0", "PE1";
function = "uart0";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
lcd_rgb666_pins: lcd-rgb666-pins{
pins = "PD0", "PD1", "PD2", "PD3","PD4",
"PD5", "PD6", "PD7", "PD8", "PD9",
"PD10", "PD11", "PD12", "PD13", "PD14",
"PD15", "PD16", "PD17", "PD18", "PD19",
"PD20", "PD21";
function = "lcd";
timer@1c20c00 {
compatible = "allwinner,suniv-f1c100s-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
wdt: watchdog@1c20ca0 {
compatible = "allwinner,suniv-f1c100s-wdt",
"allwinner,sun4i-a10-wdt";
reg = <0x01c20ca0 0x20>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 38>;
resets = <&ccu 24>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 39>;
resets = <&ccu 25>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 40>;
resets = <&ccu 26>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,suniv-f1c100s-mmc",
"allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
clock-names = "ahb",
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <23>;
pinctrl-names = "default";
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
};设备树dts文件:
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
aliases {
serial0 = &uart0;
chosen {
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
panel: panel {
compatible = "kashine_lcd,kashine_lcd_7_inch", "simple-panel";
#size-cells = <0>;
reset-gpios = <&pio 4 4 GPIO_ACTIVE_LOW>;// reset pin
power-supply = <®_vcc3v3>;
//backlight = <&backlight>;
port@0 {
reg = <0>;
#size-cells = <0>;
panel_input: endpoint@0 {
reg = <0>;
backlight: backlight {
compatible = "pwm-backlight";
pwms = <&pwm 1 500000 0>;
pwm-names = "backlight";
brightness-levels = <0 4 8 16 32 64 128 255>;
default-brightness-level = <7>;
&uart0 {
pinctrl-0 = <&uart0_pe_pins>;
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
broken-cd;
&tcon0_out {
tcon0_out_lcd: endpoint@0 {
reg = <0>;
&pwm {
pinctrl-0 = <&pwm1_pin>;
&be0 {
&de {
&tcon0 {
pinctrl-0 = <&lcd_rgb666_pins>;
&pio {
panel_reset_pin: panel_reset_pin {
pins = "PE4";
function = "gpio_out";
pwm1_pin: pwm1_pin {
pins = "PE6";
function = "pwm1";
};配置文件.config:
# Linux/arm 5.7.1 Kernel Configuration
# Compiler: arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=70201
CONFIG_LD_VERSION=228020000
CONFIG_CLANG_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_TABLE_SORT=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
# CONFIG_SYSVIPC is not set
# CONFIG_POSIX_MQUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_GENERIC_CLOCKEVENTS=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TINY_SRCU=y
# end of RCU Subsystem
# CONFIG_IKCONFIG is not set
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# end of Scheduler features
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_DEBUG is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
# CONFIG_BOOT_CONFIG is not set
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
CONFIG_SYSFS_SYSCALL=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_BPF_SYSCALL is not set
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_RSEQ=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SYSTEM_DATA_VERIFICATION=y
# CONFIG_PROFILING is not set
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V4 is not set
# CONFIG_ARCH_MULTI_V4T is not set
CONFIG_ARCH_MULTI_V5=y
CONFIG_ARCH_MULTI_V4_V5=y
# CONFIG_ARCH_MULTI_V6 is not set
# CONFIG_ARCH_MULTI_V7 is not set
CONFIG_ARCH_MULTI_CPU_AUTO=y
# end of Multiple platform selection
# CONFIG_MACH_ASM9260 is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_MXS is not set
# CONFIG_ARCH_NOMADIK is not set
# CONFIG_ARCH_NSPIRE is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_OXNAS is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_PLAT_SPEAR is not set
CONFIG_ARCH_SUNXI=y
CONFIG_MACH_SUNIV=y
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_WM8505 is not set
# Processor Type
CONFIG_CPU_ARM926T=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v5=y
CONFIG_CPU_ABRT_EV5TJ=y
CONFIG_CPU_PABRT_LEGACY=y
CONFIG_CPU_CACHE_VIVT=y
CONFIG_CPU_COPY_V4WB=y
CONFIG_CPU_TLB_V4WBI=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
CONFIG_CPU_USE_DOMAINS=y
# Processor Features
CONFIG_ARM_THUMB=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
# CONFIG_CPU_CACHE_ROUND_ROBIN is not set
CONFIG_NEED_KUSER_HELPERS=y
CONFIG_KUSER_HELPERS=y
CONFIG_ARM_L1_CACHE_SHIFT=5
CONFIG_DEBUG_ALIGN_RODATA=y
# end of System Type
# Bus support
# end of Bus support
# Kernel Features
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_ARCH_NR_GPIO=416
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
CONFIG_AEABI=y
CONFIG_OABI_COMPAT=y
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0
CONFIG_ZBOOT_ROM_BSS=0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_STAT is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM is not set
# CONFIG_QORIQ_CPUFREQ is not set
# end of CPU Frequency scaling
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
# CONFIG_CPU_IDLE_GOV_LADDER is not set
CONFIG_CPU_IDLE_GOV_MENU=y
# CONFIG_CPU_IDLE_GOV_TEO is not set
CONFIG_DT_IDLE_STATES=y
# ARM CPU Idle Drivers
CONFIG_ARM_CPUIDLE=y
# end of ARM CPU Idle Drivers
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# CONFIG_FPE_FASTFPE is not set
# CONFIG_VFP is not set
# end of Floating point emulation
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
# Firmware Drivers
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
# CONFIG_ARM_CRYPTO is not set
# General architecture-dependent options
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_HAVE_COPY_THREAD_TLS=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_HAVE_GCC_PLUGINS=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_SPLIT_PTLOCK_CPUS=999999
CONFIG_COMPACTION=y
# CONFIG_PAGE_REPORTING is not set
CONFIG_MIGRATION=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
# CONFIG_CMA is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
# end of Memory Management options
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_MPTCP is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_NET_NCSI is not set
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=y
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
# CONFIG_FAILOVER is not set
CONFIG_ETHTOOL_NETLINK=y
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
CONFIG_FW_CACHE=y
# end of Firmware loader
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
# end of Generic Driver Options
# Bus devices
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_MOXTET is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_SUN50I_DE2_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_VEXPRESS_CONFIG is not set
# CONFIG_MHI_BUS is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# CONFIG_GNSS is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# Partition parsers
# CONFIG_MTD_AR7_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
# CONFIG_MTD_BLOCK is not set
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# CONFIG_MTD_ONENAND is not set
# CONFIG_MTD_RAW_NAND is not set
# CONFIG_MTD_SPI_NAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_MTD_UBI is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# CONFIG_VOP_BUS is not set
# end of Intel MIC & related support
# CONFIG_ECHO is not set
# CONFIG_MISC_RTSX_USB is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_WIREGUARD is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_IPVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_GENEVE is not set
# CONFIG_BAREUDP is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
# Distributed Switch Architecture drivers
# end of Distributed Switch Architecture drivers
# CONFIG_ETHERNET is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_MSCC_MIIM is not set
# CONFIG_MDIO_MVUSB is not set
# CONFIG_MDIO_SUN4I is not set
# CONFIG_MDIO_XPCS is not set
# CONFIG_PHYLIB is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=m
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
CONFIG_USB_RTL8150=m
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_WLAN_VENDOR_ADMTEK is not set
# CONFIG_WLAN_VENDOR_ATH is not set
# CONFIG_WLAN_VENDOR_ATMEL is not set
# CONFIG_WLAN_VENDOR_BROADCOM is not set
# CONFIG_WLAN_VENDOR_CISCO is not set
# CONFIG_WLAN_VENDOR_INTEL is not set
# CONFIG_WLAN_VENDOR_INTERSIL is not set
# CONFIG_WLAN_VENDOR_MARVELL is not set
# CONFIG_WLAN_VENDOR_MEDIATEK is not set
# CONFIG_WLAN_VENDOR_RALINK is not set
# CONFIG_WLAN_VENDOR_REALTEK is not set
# CONFIG_WLAN_VENDOR_RSI is not set
# CONFIG_WLAN_VENDOR_ST is not set
# CONFIG_WLAN_VENDOR_TI is not set
# CONFIG_WLAN_VENDOR_ZYDAS is not set
# CONFIG_WLAN_VENDOR_QUANTENNA is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_VIRT_WIFI is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=y
CONFIG_INPUT_POLLDEV=y
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_SUN4I_LRADC=y
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
# CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MSM_VIBRATOR is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
# CONFIG_INPUT_AXP20X_PEK is not set
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_SERPORT is not set
# CONFIG_SERIO_LIBPS2 is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_LDISC_AUTOLOAD=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
# CONFIG_SERIAL_8250_16550A_VARIANTS is not set
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_DWLIB=y
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_SPRD is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_NULL_TTY is not set
# CONFIG_TRACE_SINK is not set
# CONFIG_HVC_DCC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# end of Character devices
# CONFIG_RANDOM_TRUST_BOOTLOADER is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_MV64XXX=y
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
CONFIG_SPI_SUN4I=y
# CONFIG_SPI_SUN6I is not set
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Multiplexer support
# CONFIG_SPI_MUX is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AXP209 is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
CONFIG_PINCTRL_SUNXI=y
CONFIG_PINCTRL_SUNIV_F1C100S=y
# CONFIG_PINCTRL_SUN4I_A10 is not set
# CONFIG_PINCTRL_SUN5I is not set
# CONFIG_PINCTRL_SUN6I_A31 is not set
# CONFIG_PINCTRL_SUN6I_A31_R is not set
# CONFIG_PINCTRL_SUN8I_A23 is not set
# CONFIG_PINCTRL_SUN8I_A33 is not set
# CONFIG_PINCTRL_SUN8I_A83T is not set
# CONFIG_PINCTRL_SUN8I_A83T_R is not set
# CONFIG_PINCTRL_SUN8I_A23_R is not set
# CONFIG_PINCTRL_SUN8I_H3 is not set
# CONFIG_PINCTRL_SUN8I_H3_R is not set
# CONFIG_PINCTRL_SUN8I_V3S is not set
# CONFIG_PINCTRL_SUN9I_A80 is not set
# CONFIG_PINCTRL_SUN9I_A80_R is not set
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
# CONFIG_PINCTRL_SUN50I_H6 is not set
# CONFIG_PINCTRL_SUN50I_H6_R is not set
# CONFIG_PINCTRL_EQUILIBRIUM is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# end of MFD GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_W1 is not set
# CONFIG_POWER_AVS is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_HWMON is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
CONFIG_CPU_THERMAL=y
CONFIG_CPU_FREQ_THERMAL=y
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
# CONFIG_QORIQ_THERMAL is not set
# CONFIG_SUN8I_THERMAL is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AC100 is not set
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_IQS62X is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_AXP20X is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_GPIO is not set
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MP5416 is not set
# CONFIG_REGULATOR_MP8859 is not set
# CONFIG_REGULATOR_MP886X is not set
# CONFIG_REGULATOR_MPQ7920 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
# CONFIG_RC_CORE is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
# CONFIG_MEDIA_CAMERA_SUPPORT is not set
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
# CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# Media drivers
# CONFIG_MEDIA_USB_SUPPORT is not set
# Supported MMC/SDIO adapters
# CONFIG_CYPRESS_FIRMWARE is not set
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
# Media SPI Adapters
# end of Media SPI Adapters
# Customise DVB Frontends
# Tools to develop new frontends
# end of Customise DVB Frontends
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
CONFIG_DRM_SUN4I=y
CONFIG_DRM_SUN4I_HDMI=y
# CONFIG_DRM_SUN4I_HDMI_CEC is not set
CONFIG_DRM_SUN4I_BACKEND=y
# CONFIG_DRM_SUN6I_DSI is not set
# CONFIG_DRM_SUN8I_DW_HDMI is not set
CONFIG_DRM_SUN8I_MIXER=y
CONFIG_DRM_SUN8I_TCON_TOP=y
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_DISPLAY_CONNECTOR is not set
# CONFIG_DRM_LVDS_CODEC is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_PARADE_PS8640 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_SIMPLE_BRIDGE is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_TI_TPD12S015 is not set
# CONFIG_DRM_ANALOGIX_ANX6345 is not set
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# end of Display Interface Bridges
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_GM12U320 is not set
# CONFIG_TINYDRM_HX8357D is not set
# CONFIG_TINYDRM_ILI9225 is not set
# CONFIG_TINYDRM_ILI9341 is not set
# CONFIG_TINYDRM_ILI9486 is not set
# CONFIG_TINYDRM_MI0283QT is not set
# CONFIG_TINYDRM_REPAPER is not set
# CONFIG_TINYDRM_ST7586 is not set
# CONFIG_TINYDRM_ST7735R is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LIMA is not set
# CONFIG_DRM_PANFROST is not set
# CONFIG_DRM_TIDSS is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_BACKLIGHT=y
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=y
# end of Frame buffer Devices
# Backlight & LCD device support
CONFIG_LCD_CLASS_DEVICE=m
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_ILI922X is not set
# CONFIG_LCD_ILI9320 is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
# CONFIG_LCD_PLATFORM is not set
# CONFIG_LCD_AMS369FG06 is not set
# CONFIG_LCD_LMS501KF03 is not set
# CONFIG_LCD_HX8357 is not set
# CONFIG_LCD_OTM3225A is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=y
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_QCOM_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_BACKLIGHT_LED is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
# end of Console display driver support
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=y
CONFIG_SND_PCM_OSS=y
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
CONFIG_SND_ALOOP=y
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
# CONFIG_SND_SPI is not set
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
CONFIG_SND_SUN4I_I2S=y
CONFIG_SND_SUN4I_SPDIF=y
# end of Allwinner SoC Audio support
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DA7213 is not set
# CONFIG_SND_SOC_DMIC is not set
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TLV320ADCX140 is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_MT6660 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=y
CONFIG_SND_SIMPLE_CARD=y
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=y
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_BIGBEN_FF is not set
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELAN is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_GLORIOUS is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
CONFIG_HID_ITE=y
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=y
# CONFIG_HID_LOGITECH_HIDPP is not set
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
CONFIG_HID_REDRAGON=y
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# CONFIG_HID_MCP2221 is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
CONFIG_USB_HIDDEV=y
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_USB_CONN_GPIO is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
CONFIG_USB_DYNAMIC_MINORS=y
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_OTG_FSM is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
CONFIG_USB_MON=m
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
# CONFIG_USB_EHCI_TT_NEWSCHED is not set
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
# CONFIG_USB_CDNS3 is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=y
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_APPLE_MFI_FASTCHARGE is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_AM335X_PHY_USB is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=500
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_MAX3420_UDC is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
CONFIG_USB_LIBCOMPOSITE=y
CONFIG_USB_F_ACM=y
CONFIG_USB_U_SERIAL=y
CONFIG_USB_U_ETHER=y
CONFIG_USB_F_ECM=y
# CONFIG_USB_CONFIGFS is not set
# USB Gadget precomposed configurations
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
CONFIG_USB_CDC_COMPOSITE=y
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_RAW_GADGET is not set
# end of USB Gadget precomposed configurations
# CONFIG_TYPEC is not set
# CONFIG_USB_ROLE_SWITCH is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_HSQ is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_EL15203000 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
# CONFIG_LEDS_TRIGGER_TIMER is not set
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_CPU is not set
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_LEDS_TRIGGER_NETDEV is not set
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
# CONFIG_RTC_CLASS is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_SF_PDMA is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_MOVE_NOTIFY is not set
# CONFIG_DMABUF_SELFTESTS is not set
# CONFIG_DMABUF_HEAPS is not set
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO_MENU=y
# CONFIG_VIRTIO_MMIO is not set
# CONFIG_VDPA is not set
CONFIG_VHOST_DPN=y
CONFIG_VHOST_MENU=y
# CONFIG_VHOST_NET is not set
# CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
CONFIG_STAGING=y
# CONFIG_PRISM2_USB is not set
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
CONFIG_RTL8723BS=m
# CONFIG_R8712U is not set
# CONFIG_R8188EU is not set
# CONFIG_VT6656 is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# end of Speakup console speech
# CONFIG_STAGING_MEDIA is not set
# Android
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_FB_TFT=y
# CONFIG_FB_TFT_AGM1264K_FL is not set
# CONFIG_FB_TFT_BD663474 is not set
# CONFIG_FB_TFT_HX8340BN is not set
# CONFIG_FB_TFT_HX8347D is not set
# CONFIG_FB_TFT_HX8353D is not set
# CONFIG_FB_TFT_HX8357D is not set
# CONFIG_FB_TFT_ILI9163 is not set
# CONFIG_FB_TFT_ILI9320 is not set
# CONFIG_FB_TFT_ILI9325 is not set
# CONFIG_FB_TFT_ILI9340 is not set
# CONFIG_FB_TFT_ILI9341 is not set
# CONFIG_FB_TFT_ILI9481 is not set
# CONFIG_FB_TFT_ILI9486 is not set
# CONFIG_FB_TFT_PCD8544 is not set
# CONFIG_FB_TFT_RA8875 is not set
# CONFIG_FB_TFT_S6D02A1 is not set
# CONFIG_FB_TFT_S6D1121 is not set
# CONFIG_FB_TFT_SEPS525 is not set
# CONFIG_FB_TFT_SH1106 is not set
# CONFIG_FB_TFT_SSD1289 is not set
# CONFIG_FB_TFT_SSD1305 is not set
# CONFIG_FB_TFT_SSD1306 is not set
# CONFIG_FB_TFT_SSD1331 is not set
# CONFIG_FB_TFT_SSD1351 is not set
# CONFIG_FB_TFT_ST7735R is not set
# CONFIG_FB_TFT_ST7789V is not set
# CONFIG_FB_TFT_TINYLCD is not set
# CONFIG_FB_TFT_TLS8204 is not set
# CONFIG_FB_TFT_UC1611 is not set
# CONFIG_FB_TFT_UC1701 is not set
# CONFIG_FB_TFT_UPD161704 is not set
# CONFIG_FB_TFT_WATTEROTT is not set
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_KS7010 is not set
# CONFIG_PI433 is not set
# Gasket devices
# end of Gasket devices
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_WFX is not set
# CONFIG_GOLDFISH is not set
# CONFIG_MFD_CROS_EC is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_SUNXI=y
CONFIG_CLK_SUNXI_CLOCKS=y
CONFIG_CLK_SUNXI_PRCM_SUN6I=y
CONFIG_CLK_SUNXI_PRCM_SUN8I=y
CONFIG_CLK_SUNXI_PRCM_SUN9I=y
CONFIG_SUNXI_CCU=y
CONFIG_SUNIV_F1C100S_CCU=y
CONFIG_SUN8I_A83T_CCU=y
CONFIG_SUN8I_DE2_CCU=y
CONFIG_SUN8I_R_CCU=y
# end of Common Clock Framework
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_SUN4I_TIMER=y
# CONFIG_MICROCHIP_PIT64B is not set
# end of Clock Source drivers
# CONFIG_MAILBOX is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
# CONFIG_RPMSG_VIRTIO is not set
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# CONFIG_QUICC_ENGINE is not set
# CONFIG_FSL_RCPM is not set
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SUNXI_SRAM=y
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_FSA9480 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_PTN5150 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_DEBUG is not set
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SUN4I=y
# IRQ chip support
CONFIG_IRQCHIP=y
# CONFIG_AL_FIC is not set
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_BRCMSTB_RESCAL is not set
# CONFIG_RESET_INTEL_GW is not set
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_PHY_SUN4I_USB=y
# CONFIG_PHY_SUN6I_MIPI_DPHY is not set
# CONFIG_PHY_SUN9I_USB is not set
# CONFIG_PHY_SUN50I_USB3 is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_TORRENT is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
# CONFIG_PHY_INTEL_EMMC is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
# end of Performance monitor support
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_SUNXI_SID=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# CONFIG_MOST is not set
# end of Device Drivers
# File systems
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_AUTOFS_FS is not set
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/EXFAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_EXFAT_FS is not set
# CONFIG_NTFS_FS is not set
# end of DOS/FAT/EXFAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_TMPFS_XATTR is not set
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=y
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
# CONFIG_NFS_SWAP is not set
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,bpf"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
# CONFIG_CRYPTO_ECRDSA is not set
# CONFIG_CRYPTO_CURVE25519 is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
# CONFIG_CRYPTO_ESSIV is not set
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_XXHASH is not set
# CONFIG_CRYPTO_BLAKE2B is not set
# CONFIG_CRYPTO_BLAKE2S is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=y
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# CONFIG_CRYPTO_ZSTD is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HASH_INFO=y
# Crypto library routines
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_LIB_ARC4=y
# CONFIG_CRYPTO_LIB_BLAKE2S is not set
# CONFIG_CRYPTO_LIB_CHACHA is not set
# CONFIG_CRYPTO_LIB_CURVE25519 is not set
CONFIG_CRYPTO_LIB_DES=y
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
# CONFIG_CRYPTO_LIB_POLY1305 is not set
# CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_LIB_SHA256=y
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_ALLWINNER=y
CONFIG_CRYPTO_DEV_SUN4I_SS=y
# CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE is not set
# CONFIG_CRYPTO_DEV_SUN8I_SS is not set
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
# Library routines
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
# CONFIG_CRC_CCITT is not set
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_HAS_DMA_WRITE_COMBINE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_REMAP=y
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_DQL=y
CONFIG_NLATTR=y
CONFIG_GENERIC_ATOMIC64=y
CONFIG_CLZ_TAB=y
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_FS=y
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_UBSAN is not set
# end of Generic Kernel Debugging Instruments
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_KASAN_STACK=1
# end of Memory Debugging
# CONFIG_DEBUG_SHIRQ is not set
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHEDSTATS is not set
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
# Debug kernel data structures
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Debug kernel data structures
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_TRACE=y
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_SAMPLES is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# arm Debugging
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_WX is not set
# CONFIG_UNWINDER_FRAME_POINTER is not set
CONFIG_UNWINDER_ARM=y
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_CORESIGHT is not set
# end of arm Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_MIN_HEAP is not set
# CONFIG_TEST_SORT is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_BITFIELD is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_STACKINIT is not set
# CONFIG_TEST_MEMINIT is not set
# CONFIG_MEMTEST is not set
# end of Kernel Testing and Coverage
# end of Kernel hacking最近编辑记录 likaiqin (2023-01-08 00:10:50)
大佬们,救救我吧,在/dev下面没有看到fb0结点
按照解决f1c100s 主线Linux 升级到 4.19 之后的版本没有 framebuffer(fb0)设备问题(转转转)(Linux5.2)中提到的,在 uboot 的 bootargs 中加入 drm.debug=0x1f debug ,让内核打印出drm的信息,但是只有一处:
[ 1.087990] [drm:drm_core_init] Initialized离线
挖个坑吧,使用Linux5.2主线内核修改后能够正常显示,但是使用Linux5.7.1主线内核无法显示,其中各自启动的log如下,设备树和上面的基本一样。
首先是5.2内核成功启动的log:
U-Boot SPL 2018.01-05679-g013ca45-dirty (Jan 08 2023 - 14:52:27)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2018.01-05679-g013ca45-dirty (Jan 08 2023 - 14:52:27 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
reading zImage
4172352 bytes read in 215 ms (18.5 MiB/s)
8003 bytes read in 26 ms (299.8 KiB/s)
## Flattened Device Tree blob at 80c08000
Booting using the fdt blob at 0x80c08000
Loading Device Tree to 816fb000, end 816fff42 ... OK
[ 0.000000] Linux version 5.2.0 (project01@likaiqin-virtual-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #11 Mon Jan 9 21:14:14 CST 2023
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: bootargs=console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw drm.debug=0x1f debug
[ 0.000000] Memory: 55168K/65536K available (6144K kernel code, 240K rwdata, 1556K rodata, 1024K init, 241K bss, 10368K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_bytes called from start_kernel+0x254/0x42c with crng_init=0
[ 0.000047] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000126] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000666] Console: colour dummy device 80x30
[ 0.001453] printk: console [tty0] enabled
[ 0.001561] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070304] pid_max: default: 32768 minimum: 301
[ 0.070772] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070868] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072534] CPU: Testing write buffer coherency: ok
[ 0.074486] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076767] devtmpfs: initialized
[ 0.083849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.084023] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.084368] pinctrl core: initialized pinctrl subsystem
[ 0.086796] NET: Registered protocol family 16
[ 0.088415] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.090685] cpuidle: using governor menu
[ 0.144601] SCSI subsystem initialized
[ 0.145044] usbcore: registered new interface driver usbfs
[ 0.145310] usbcore: registered new interface driver hub
[ 0.145556] usbcore: registered new device driver usb
[ 0.146098] pps_core: LinuxPPS API ver. 1 registered
[ 0.146180] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.146313] PTP clock support registered
[ 0.146912] Advanced Linux Sound Architecture Driver Initialized.
[ 0.148742] clocksource: Switched to clocksource timer
[ 0.178202] NET: Registered protocol family 2
[ 0.179957] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.180142] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.180253] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.180340] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.180666] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.180787] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.181366] NET: Registered protocol family 1
[ 0.182913] RPC: Registered named UNIX socket transport module.
[ 0.183026] RPC: Registered udp transport module.
[ 0.183080] RPC: Registered tcp transport module.
[ 0.183128] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.185634] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.187771] Initialise system trusted keyrings
[ 0.188418] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.212263] NFS: Registering the id_resolver key type
[ 0.212427] Key type id_resolver registered
[ 0.212487] Key type id_legacy registered
[ 0.218551] Key type asymmetric registered
[ 0.218654] Asymmetric key parser 'x509' registered
[ 0.218991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.219095] io scheduler mq-deadline registered
[ 0.219148] io scheduler kyber registered
[ 0.230774] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.231694] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.233277] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.491053] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.518287] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[ 0.970447] printk: console [ttyS0] enabled
[ 0.975794] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[ 1.008125] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 23, base_baud = 6250000) is a 16550A
[ 1.018971] [drm:drm_core_init] Initialized
[ 1.023690] [drm:sun4i_drv_probe] Adding component /soc/display-backend@1e60000
[ 1.031372] [drm:sun4i_drv_probe] Adding component /soc/lcd-controller@1c0c000
[ 1.038865] [drm:sun4i_drv_traverse_endpoints] Endpoint is our panel... skipping
[ 1.048124] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.061334] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/display-backend@1e60000
[ 1.071494] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/lcd-controller@1c0c000
[ 1.087812] SCSI Media Changer driver v0.25
[ 1.093637] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.100360] ehci-platform: EHCI generic platform driver
[ 1.105960] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.112361] ohci-platform: OHCI generic platform driver
[ 1.118095] usbcore: registered new interface driver usb-storage
[ 1.125027] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.134233] i2c /dev entries driver
[ 1.141897] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.179915] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.189630] usbcore: registered new interface driver usbhid
[ 1.195275] usbhid: USB HID core driver
[ 1.215590] NET: Registered protocol family 17
[ 1.220484] Key type dns_resolver registered
[ 1.227375] Loading compiled-in X.509 certificates
[ 1.241677] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.252689] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/lcd-controller@1c0c000
[ 1.262731] [drm:compare_of] Comparing of node /soc/lcd-controller@1c0c000 with /soc/lcd-controller@1c0c000
[ 1.273109] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[ 1.284054] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc073b2f4)
[ 1.293200] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0739f4c)
[ 1.301079] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.307730] [drm] No driver support for vblank timestamp query.
[ 1.313807] [drm:drm_minor_register]
[ 1.317529] [drm:drm_minor_register]
[ 1.322224] [drm:drm_minor_register] new minor registered 0
[ 1.328333] [drm:drm_sysfs_connector_add] adding "Unknown-1" to sysfs
[ 1.334987] [drm:drm_sysfs_hotplug_event] generating hotplug event
[ 1.341450] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.349396] [drm:drm_mode_object_get] OBJ ID: 48 (2)
[ 1.354423] [drm:drm_setup_crtcs]
[ 1.357880] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:48:Unknown-1]
[ 1.365595] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:48:Unknown-1] status updated from unknown to connected
[ 1.376899] [drm:sun4i_rgb_mode_valid] Validating modes...
[ 1.382507] [drm:sun4i_rgb_mode_valid] Horizontal parameters OK
[ 1.388472] [drm:sun4i_rgb_mode_valid] Vertical parameters OK
[ 1.394313] [drm:sun4i_rgb_mode_valid] RGB panel used, skipping clock rate checks
[ 1.394334] [drm:sun4i_rgb_mode_valid] Clock rate OK
[ 1.407190] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:48:Unknown-1] probed modes :
[ 1.416262] [drm:drm_mode_debug_printmodeline] Modeline "800x480": 60 31000 800 848 888 976 480 483 496 528 0x48 0x0
[ 1.426923] [drm:drm_setup_crtcs] connector 48 enabled? yes
[ 1.432613] [drm:drm_setup_crtcs] Not using firmware configuration
[ 1.438905] [drm:drm_setup_crtcs] looking for cmdline mode on connector 48
[ 1.445826] [drm:drm_setup_crtcs] looking for preferred mode on connector 48 0
[ 1.453153] [drm:drm_setup_crtcs] found mode 800x480
[ 1.458164] [drm:drm_setup_crtcs] picking CRTCs for 8192x8192 config
[ 1.464628] [drm:drm_setup_crtcs] desired mode 800x480 set on crtc 46 (0,0)
[ 1.471701] [drm:drm_mode_object_get] OBJ ID: 48 (2)
[ 1.476719] [drm:__drm_fb_helper_initial_config_and_unlock] test CRTC 0 primary plane
[ 1.484683] [drm:drm_fb_helper_generic_probe] surface width(800), height(480) and bpp(32)
[ 1.498149] [drm:drm_mode_addfb2] [FB:49]
[ 1.502410] [drm:drm_mode_object_put.part.0] OBJ ID: 49 (2)
[ 1.509178] [drm:drm_sysfs_hotplug_event] generating hotplug event
[ 1.516796] [drm:drm_atomic_state_init] Allocated atomic state (ptrval)
[ 1.516846] [drm:drm_atomic_get_plane_state] Added [PLANE:30:plane-0] (ptrval) state to (ptrval)
[ 1.516879] [drm:drm_atomic_get_plane_state] Added [PLANE:34:plane-1] (ptrval) state to (ptrval)
[ 1.516930] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:34:plane-1] state (ptrval)
[ 1.516966] [drm:drm_atomic_get_plane_state] Added [PLANE:38:plane-2] (ptrval) state to (ptrval)
[ 1.517081] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:38:plane-2] state (ptrval)
[ 1.517121] [drm:drm_atomic_get_plane_state] Added [PLANE:42:plane-3] (ptrval) state to (ptrval)
[ 1.517149] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:42:plane-3] state (ptrval)
[ 1.517190] [drm:drm_atomic_get_crtc_state] Added [CRTC:46:crtc-0] (ptrval) state to (ptrval)
[ 1.517257] [drm:drm_atomic_set_mode_for_crtc] Set [MODE:800x480] for [CRTC:46:crtc-0] state (ptrval)
[ 1.517290] [drm:drm_atomic_set_crtc_for_plane] Link [PLANE:30:plane-0] state (ptrval) to [CRTC:46:crtc-0]
[ 1.517322] [drm:drm_atomic_set_fb_for_plane] Set [FB:49] for [PLANE:30:plane-0] state (ptrval)
[ 1.517339] [drm:drm_mode_object_get] OBJ ID: 49 (1)
[ 1.517375] [drm:drm_atomic_add_affected_connectors] Adding all current connectors for [CRTC:46:crtc-0] to (ptrval)
[ 1.517410] [drm:drm_mode_object_get] OBJ ID: 48 (3)
[ 1.517436] [drm:drm_atomic_get_connector_state] Added [CONNECTOR:48:Unknown-1] (ptrval) state to (ptrval)
[ 1.517452] [drm:drm_mode_object_get] OBJ ID: 48 (4)
[ 1.517482] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:48:Unknown-1] state (ptrval) to [CRTC:46:crtc-0]
[ 1.517504] [drm:drm_atomic_check_only] checking (ptrval)
[ 1.517560] [drm:drm_atomic_helper_check_modeset] [CRTC:46:crtc-0] mode changed
[ 1.517580] [drm:drm_atomic_helper_check_modeset] [CRTC:46:crtc-0] enable changed
[ 1.517599] [drm:drm_atomic_helper_check_modeset] [CRTC:46:crtc-0] active changed
[ 1.517633] [drm:drm_atomic_helper_check_modeset] Updating routing for [CONNECTOR:48:Unknown-1]
[ 1.517666] [drm:drm_atomic_helper_check_modeset] [CONNECTOR:48:Unknown-1] using [ENCODER:47:None-47] on [CRTC:46:crtc-0]
[ 1.517690] [drm:drm_atomic_helper_check_modeset] [CRTC:46:crtc-0] needs all connectors, enable: y, active: y
[ 1.517721] [drm:drm_atomic_add_affected_connectors] Adding all current connectors for [CRTC:46:crtc-0] to (ptrval)
[ 1.517750] [drm:drm_atomic_add_affected_planes] Adding all current planes for [CRTC:46:crtc-0] to (ptrval)
[ 1.517784] [drm:sun4i_rgb_mode_valid] Validating modes...
[ 1.517800] [drm:sun4i_rgb_mode_valid] Horizontal parameters OK
[ 1.517815] [drm:sun4i_rgb_mode_valid] Vertical parameters OK
[ 1.517830] [drm:sun4i_rgb_mode_valid] RGB panel used, skipping clock rate checks
[ 1.517845] [drm:sun4i_rgb_mode_valid] Clock rate OK
[ 1.517878] [drm:drm_atomic_normalize_zpos] [CRTC:46:crtc-0] calculating normalized zpos values
[ 1.517902] [drm:drm_atomic_normalize_zpos] [PLANE:30:plane-0] processing zpos value 0
[ 1.517921] [drm:drm_atomic_normalize_zpos] [PLANE:30:plane-0] normalized zpos value 0
[ 1.517954] [drm:sun4i_backend_atomic_check] Starting checking our planes
[ 1.517982] [drm:sun4i_backend_plane_uses_scaler] Input size 800x480, output size 800x480
[ 1.518015] [drm:sun4i_backend_atomic_check] Plane FB format is XR24 little-endian (0x34325258)
[ 1.518032] [drm:sun4i_backend_atomic_check] Plane zpos is 0
[ 1.518057] [drm:sun4i_backend_atomic_check] State valid with 1 planes, 0 alpha, 0 video, 0 YUV
[ 1.518084] [drm:drm_atomic_commit] committing (ptrval)
[ 1.518172] [drm:drm_calc_timestamping_constants] crtc 46: hwmode: htotal 976, vtotal 528, vdisplay 480
[ 1.518201] [drm:drm_calc_timestamping_constants] crtc 46: clock 31000 kHz framedur 16623483 linedur 31483
[ 1.518233] [drm:drm_atomic_helper_commit_modeset_disables] modeset on [CRTC:46:crtc-0]
[ 1.522507] [drm:sun4i_tcon_get_clk_delay] TCON 0 clock delay 30
[ 1.522589] [drm:sun4i_tcon_mode_set] Setting horizontal total 976, backporch 128
[ 1.522612] [drm:sun4i_tcon_mode_set] Setting vertical total 528, backporch 45
[ 1.522632] [drm:sun4i_tcon_mode_set] Setting HSYNC 40, VSYNC 13
[ 1.522661] [drm:sun4i_tcon_set_mux.constprop.5] Muxing encoder None-47 to CRTC crtc-0: -524
[ 1.522700] [drm:drm_atomic_helper_commit_modeset_disables] modeset on [ENCODER:47:None-47]
[ 1.522725] [drm:drm_atomic_helper_commit_modeset_enables] enabling [CRTC:46:crtc-0]
[ 1.522742] [drm:sun4i_crtc_atomic_enable] Enabling the CRTC
[ 1.522801] [drm:drm_atomic_helper_commit_modeset_enables] enabling [ENCODER:47:None-47]
[ 1.522819] [drm:sun4i_rgb_encoder_enable] Enabling RGB output
[ 1.522862] [drm:sun4i_crtc_enable_vblank] Enabling VBLANK on crtc (ptrval)
[ 1.522880] [drm:sun4i_tcon_enable_vblank] Enabling VBLANK interrupt
[ 1.522915] [drm:drm_vblank_enable] enabling vblank on crtc 0, ret: 0
[ 1.522971] [drm:sun4i_backend_update_layer_formats] Switching display backend interlaced mode off
[ 1.523000] [drm:sun4i_backend_update_layer_buffer] Layer line width: 25600 bits
[ 1.523027] [drm:sun4i_backend_update_layer_buffer] Setting buffer address to 0x03000000
[ 1.523046] [drm:sun4i_backend_update_layer_buffer] Setting address lower bits to 0x18000000
[ 1.523065] [drm:sun4i_backend_update_layer_buffer] Setting address high bits to 0x0
[ 1.523085] [drm:sun4i_backend_update_layer_coord] Updating layer 0
[ 1.523106] [drm:sun4i_backend_update_layer_coord] Primary layer, updating global size W: 800 H: 480
[ 1.523126] [drm:sun4i_backend_update_layer_coord] Layer size W: 800 H: 480
[ 1.523145] [drm:sun4i_backend_update_layer_coord] Layer coordinates X: 0 Y: 0
[ 1.523168] [drm:sun4i_backend_update_layer_zpos] Setting layer 0's priority to 0 and pipe 0
[ 1.523187] [drm:sun4i_backend_layer_enable] Enabling layer 0
[ 1.523208] [drm:sun4i_crtc_atomic_flush] Committing plane changes
[ 1.523223] [drm:sun4i_backend_commit] Committing changes
[ 1.539569] [drm:drm_atomic_state_default_clear] Clearing atomic state (ptrval)
[ 1.539663] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (5)
[ 1.539709] [drm:__drm_atomic_state_free] Freeing atomic state (ptrval)
[ 1.539930] [drm:drm_atomic_state_init] Allocated atomic state (ptrval)
[ 1.539965] [drm:drm_mode_object_get] OBJ ID: 49 (2)
[ 1.539994] [drm:drm_atomic_get_plane_state] Added [PLANE:30:plane-0] (ptrval) state to (ptrval)
[ 1.540028] [drm:drm_mode_object_get] OBJ ID: 50 (1)
[ 1.540055] [drm:drm_atomic_get_crtc_state] Added [CRTC:46:crtc-0] (ptrval) state to (ptrval)
[ 1.540084] [drm:drm_atomic_get_plane_state] Added [PLANE:34:plane-1] (ptrval) state to (ptrval)
[ 1.540130] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:34:plane-1] state (ptrval)
[ 1.540165] [drm:drm_atomic_get_plane_state] Added [PLANE:38:plane-2] (ptrval) state to (ptrval)
[ 1.540192] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:38:plane-2] state (ptrval)
[ 1.540221] [drm:drm_atomic_get_plane_state] Added [PLANE:42:plane-3] (ptrval) state to (ptrval)
[ 1.540246] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:42:plane-3] state (ptrval)
[ 1.540290] [drm:drm_atomic_set_fb_for_plane] Set [FB:49] for [PLANE:30:plane-0] state (ptrval)
[ 1.540307] [drm:drm_mode_object_get] OBJ ID: 49 (3)
[ 1.540325] [drm:drm_mode_object_put.part.0] OBJ ID: 49 (4)
[ 1.540358] [drm:drm_atomic_add_affected_connectors] Adding all current connectors for [CRTC:46:crtc-0] to (ptrval)
[ 1.540388] [drm:drm_mode_object_get] OBJ ID: 48 (5)
[ 1.540402] [drm:drm_mode_object_get] OBJ ID: 48 (6)
[ 1.540427] [drm:drm_atomic_get_connector_state] Added [CONNECTOR:48:Unknown-1] (ptrval) state to (ptrval)
[ 1.540447] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (6)
[ 1.540477] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:48:Unknown-1] state (ptrval) to [NOCRTC]
[ 1.540496] [drm:drm_mode_object_get] OBJ ID: 48 (5)
[ 1.540525] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:48:Unknown-1] state (ptrval) to [CRTC:46:crtc-0]
[ 1.540547] [drm:drm_atomic_check_only] checking (ptrval)
[ 1.540627] [drm:drm_atomic_helper_check_modeset] Updating routing for [CONNECTOR:48:Unknown-1]
[ 1.540665] [drm:drm_atomic_helper_check_modeset] [CONNECTOR:48:Unknown-1] keeps [ENCODER:47:None-47], now on [CRTC:46:crtc-0]
[ 1.540718] [drm:sun4i_backend_atomic_check] Starting checking our planes
[ 1.540750] [drm:sun4i_backend_plane_uses_scaler] Input size 800x480, output size 800x480
[ 1.540786] [drm:sun4i_backend_atomic_check] Plane FB format is XR24 little-endian (0x34325258)
[ 1.540805] [drm:sun4i_backend_atomic_check] Plane zpos is 0
[ 1.540832] [drm:sun4i_backend_atomic_check] State valid with 1 planes, 0 alpha, 0 video, 0 YUV
[ 1.540859] [drm:drm_atomic_commit] committing (ptrval)
[ 1.540958] [drm:drm_calc_timestamping_constants] crtc 46: hwmode: htotal 976, vtotal 528, vdisplay 480
[ 1.540987] [drm:drm_calc_timestamping_constants] crtc 46: clock 31000 kHz framedur 16623483 linedur 31483
[ 1.541057] [drm:sun4i_backend_update_layer_formats] Switching display backend interlaced mode off
[ 1.541086] [drm:sun4i_backend_update_layer_buffer] Layer line width: 25600 bits
[ 1.541117] [drm:sun4i_backend_update_layer_buffer] Setting buffer address to 0x03000000
[ 1.541137] [drm:sun4i_backend_update_layer_buffer] Setting address lower bits to 0x18000000
[ 1.541155] [drm:sun4i_backend_update_layer_buffer] Setting address high bits to 0x0
[ 1.541175] [drm:sun4i_backend_update_layer_coord] Updating layer 0
[ 1.541197] [drm:sun4i_backend_update_layer_coord] Primary layer, updating global size W: 800 H: 480
[ 1.541217] [drm:sun4i_backend_update_layer_coord] Layer size W: 800 H: 480
[ 1.541237] [drm:sun4i_backend_update_layer_coord] Layer coordinates X: 0 Y: 0
[ 1.541261] [drm:sun4i_backend_update_layer_zpos] Setting layer 0's priority to 0 and pipe 0
[ 1.541281] [drm:sun4i_backend_layer_enable] Enabling layer 0
[ 1.541303] [drm:sun4i_crtc_atomic_flush] Committing plane changes
[ 1.541319] [drm:sun4i_backend_commit] Committing changes
[ 1.551096] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.555263] mmc0: new high speed SDHC card at address e624
[ 1.556363] [drm:drm_atomic_state_default_clear] Clearing atomic state (ptrval)
[ 1.556406] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (6)
[ 1.556426] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (5)
[ 1.556445] [drm:drm_mode_object_put.part.0] OBJ ID: 50 (2)
[ 1.556469] [drm:drm_mode_object_put.part.0] OBJ ID: 49 (3)
[ 1.556509] [drm:__drm_atomic_state_free] Freeing atomic state (ptrval)
[ 1.577428] Console: switching to colour frame buffer device 100x30
[ 1.577602] [drm:drm_atomic_state_init] Allocated atomic state (ptrval)
[ 1.577645] [drm:drm_mode_object_get] OBJ ID: 49 (2)
[ 1.577677] [drm:drm_atomic_get_plane_state] Added [PLANE:30:plane-0] (ptrval) state to (ptrval)
[ 1.577712] [drm:drm_mode_object_get] OBJ ID: 50 (1)
[ 1.577738] [drm:drm_atomic_get_crtc_state] Added [CRTC:46:crtc-0] (ptrval) state to (ptrval)
[ 1.577767] [drm:drm_atomic_get_plane_state] Added [PLANE:34:plane-1] (ptrval) state to (ptrval)
[ 1.577815] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:34:plane-1] state (ptrval)
[ 1.577850] [drm:drm_atomic_get_plane_state] Added [PLANE:38:plane-2] (ptrval) state to (ptrval)
[ 1.577876] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:38:plane-2] state (ptrval)
[ 1.577906] [drm:drm_atomic_get_plane_state] Added [PLANE:42:plane-3] (ptrval) state to (ptrval)
[ 1.577932] [drm:drm_atomic_set_fb_for_plane] Set [NOFB] for [PLANE:42:plane-3] state (ptrval)
[ 1.577977] [drm:drm_atomic_set_fb_for_plane] Set [FB:49] for [PLANE:30:plane-0] state (ptrval)
[ 1.577994] [drm:drm_mode_object_get] OBJ ID: 49 (3)
[ 1.578012] [drm:drm_mode_object_put.part.0] OBJ ID: 49 (4)
[ 1.578047] [drm:drm_atomic_add_affected_connectors] Adding all current connectors for [CRTC:46:crtc-0] to (ptrval)
[ 1.578080] [drm:drm_mode_object_get] OBJ ID: 48 (5)
[ 1.578094] [drm:drm_mode_object_get] OBJ ID: 48 (6)
[ 1.578120] [drm:drm_atomic_get_connector_state] Added [CONNECTOR:48:Unknown-1] (ptrval) state to (ptrval)
[ 1.578140] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (6)
[ 1.578170] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:48:Unknown-1] state (ptrval) to [NOCRTC]
[ 1.578190] [drm:drm_mode_object_get] OBJ ID: 48 (5)
[ 1.578219] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:48:Unknown-1] state (ptrval) to [CRTC:46:crtc-0]
[ 1.578244] [drm:drm_atomic_check_only] checking (ptrval)
[ 1.578329] [drm:drm_atomic_helper_check_modeset] Updating routing for [CONNECTOR:48:Unknown-1]
[ 1.578369] [drm:drm_atomic_helper_check_modeset] [CONNECTOR:48:Unknown-1] keeps [ENCODER:47:None-47], now on [CRTC:46:crtc-0]
[ 1.578429] [drm:sun4i_backend_atomic_check] Starting checking our planes
[ 1.578460] [drm:sun4i_backend_plane_uses_scaler] Input size 800x480, output size 800x480
[ 1.578493] [drm:sun4i_backend_atomic_check] Plane FB format is XR24 little-endian (0x34325258)
[ 1.578512] [drm:sun4i_backend_atomic_check] Plane zpos is 0
[ 1.578540] [drm:sun4i_backend_atomic_check] State valid with 1 planes, 0 alpha, 0 video, 0 YUV
[ 1.578567] [drm:drm_atomic_commit] committing (ptrval)
[ 1.578676] [drm:drm_calc_timestamping_constants] crtc 46: hwmode: htotal 976, vtotal 528, vdisplay 480
[ 1.578707] [drm:drm_calc_timestamping_constants] crtc 46: clock 31000 kHz framedur 16623483 linedur 31483
[ 1.578919] [drm:sun4i_backend_update_layer_formats] Switching display backend interlaced mode off
[ 1.578956] [drm:sun4i_backend_update_layer_buffer] Layer line width: 25600 bits
[ 1.578986] [drm:sun4i_backend_update_layer_buffer] Setting buffer address to 0x03000000
[ 1.579007] [drm:sun4i_backend_update_layer_buffer] Setting address lower bits to 0x18000000
[ 1.579027] [drm:sun4i_backend_update_layer_buffer] Setting address high bits to 0x0
[ 1.579050] [drm:sun4i_backend_update_layer_coord] Updating layer 0
[ 1.579072] [drm:sun4i_backend_update_layer_coord] Primary layer, updating global size W: 800 H: 480
[ 1.579094] [drm:sun4i_backend_update_layer_coord] Layer size W: 800 H: 480
[ 1.579113] [drm:sun4i_backend_update_layer_coord] Layer coordinates X: 0 Y: 0
[ 1.579135] [drm:sun4i_backend_update_layer_zpos] Setting layer 0's priority to 0 and pipe 0
[ 1.579157] [drm:sun4i_backend_layer_enable] Enabling layer 0
[ 1.579179] [drm:sun4i_crtc_atomic_flush] Committing plane changes
[ 1.579195] [drm:sun4i_backend_commit] Committing changes
[ 1.582834] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 1.586146] mmcblk0: p1 p2
[ 1.589745] [drm:drm_atomic_state_default_clear] Clearing atomic state (ptrval)
[ 1.589789] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (6)
[ 1.589812] [drm:drm_mode_object_put.part.0] OBJ ID: 48 (5)
[ 1.589832] [drm:drm_mode_object_put.part.0] OBJ ID: 50 (2)
[ 1.589856] [drm:drm_mode_object_put.part.0] OBJ ID: 49 (3)
[ 1.589892] [drm:__drm_atomic_state_free] Freeing atomic state (ptrval)
[ 2.378472] random: fast init done
[ 5.878038] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 5.898283] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.929615] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.948647] ALSA device list:
[ 5.963335] #0: Loopback 1
[ 5.978327] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.998553] cfg80211: failed to load regulatory.db
[ 6.262431] EXT4-fs (mmcblk0p2): recovery complete
[ 6.279936] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.299538] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 6.320526] devtmpfs: mounted
[ 6.342437] Freeing unused kernel memory: 1024K
[ 6.358928] Run /sbin/init as init process
[ 6.648926] [drm:vblank_disable_fn] disabling vblank on crtc 0
[ 6.666079] [drm:sun4i_crtc_disable_vblank] Disabling VBLANK on crtc (ptrval)
[ 6.684377] [drm:sun4i_tcon_enable_vblank] Disabling VBLANK interrupt
[ 7.281989] systemd[1]: System time before build time, advancing clock.
[ 7.321633] systemd[1]: Failed to lookup module alias 'autofs4': Function not implemented
[ 7.400058] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.458222] systemd[1]: No virtualization found in DMI
[ 7.476282] systemd[1]: No virtualization found in CPUID
[ 7.494040] systemd[1]: Virtualization XEN not found, /proc/xen does not exist
[ 7.514600] systemd[1]: No virtualization found in /proc/device-tree/*
[ 7.535006] systemd[1]: UML virtualization not found in /proc/cpuinfo.
[ 7.554981] systemd[1]: This platform does not support /proc/sysinfo
[ 7.574644] systemd[1]: Found VM virtualization none
[ 7.592864] systemd[1]: Detected architecture arm.然后是Linux5.7.1内核启动后白屏log:
DRAM: 64 MiB
DRAM: 64 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
reading zImage
4390512 bytes read in 232 ms (18 MiB/s)
8003 bytes read in 25 ms (312.5 KiB/s)
[ 0.000000] Linux version 5.7.1 (project01@likaiqin-virtual-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11), GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #5 Mon Jan 9 22:07:40 CST 2023
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 54152K/65536K available (7168K kernel code, 226K rwdata, 1688K rodata, 1024K init, 246K bss, 11384K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_bytes called from start_kernel+0x2a0/0x498 with crng_init=0
[ 0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000133] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000745] Console: colour dummy device 80x30
[ 0.001599] printk: console [tty0] enabled
[ 0.001699] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070874] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.070987] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.072885] CPU: Testing write buffer coherency: ok
[ 0.074728] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076040] devtmpfs: initialized
[ 0.083155] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.083316] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.083668] pinctrl core: initialized pinctrl subsystem
[ 0.085124] thermal_sys: Registered thermal governor 'step_wise'
[ 0.086540] NET: Registered protocol family 16
[ 0.088175] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.090585] cpuidle: using governor menu
[ 0.143279] SCSI subsystem initialized
[ 0.143728] usbcore: registered new interface driver usbfs
[ 0.143955] usbcore: registered new interface driver hub
[ 0.144187] usbcore: registered new device driver usb
[ 0.144728] pps_core: LinuxPPS API ver. 1 registered
[ 0.144814] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.144946] PTP clock support registered
[ 0.145503] Advanced Linux Sound Architecture Driver Initialized.
[ 0.147561] clocksource: Switched to clocksource timer
[ 0.179182] NET: Registered protocol family 2
[ 0.180802] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.180995] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.181117] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.181202] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.181521] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.181645] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.182249] NET: Registered protocol family 1
[ 0.183858] RPC: Registered named UNIX socket transport module.
[ 0.183970] RPC: Registered udp transport module.
[ 0.184019] RPC: Registered tcp transport module.
[ 0.184063] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.186562] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.188456] Initialise system trusted keyrings
[ 0.189122] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.212926] NFS: Registering the id_resolver key type
[ 0.213086] Key type id_resolver registered
[ 0.213143] Key type id_legacy registered
[ 0.331123] Key type asymmetric registered
[ 0.331236] Asymmetric key parser 'x509' registered
[ 0.331446] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.331535] io scheduler mq-deadline registered
[ 0.331587] io scheduler kyber registered
[ 0.343609] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.344621] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[ 0.346259] pwm-backlight backlight: supply power not found, using dummy regulator
[ 0.612084] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.619713] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[ 1.089744] printk: console [ttyS0] enabled
[ 1.095123] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[ 1.105972] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 23, base_baud = 6250000) is a 16550A
[ 1.116750] [drm:drm_core_init] Initialized
[ 1.121611] [drm:sun4i_drv_probe] Adding component /soc/display-backend@1e60000
[ 1.129292] [drm:sun4i_drv_probe] Adding component /soc/lcd-controller@1c0c000
[ 1.136701] [drm:sun4i_drv_traverse_endpoints] Endpoint is our panel... skipping
[ 1.146113] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.158050] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/display-backend@1e60000
[ 1.168209] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/lcd-controller@1c0c000
[ 1.185288] SCSI Media Changer driver v0.25
[ 1.191283] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.198017] ehci-platform: EHCI generic platform driver
[ 1.203624] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.210007] ohci-platform: OHCI generic platform driver
[ 1.215740] usbcore: registered new interface driver usb-storage
[ 1.222672] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.231886] i2c /dev entries driver
[ 1.239418] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 1.276080] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.285877] usbcore: registered new interface driver usbhid
[ 1.291649] usbhid: USB HID core driver
[ 1.312479] NET: Registered protocol family 17
[ 1.317250] Key type dns_resolver registered
[ 1.322927] Loading compiled-in X.509 certificates
[ 1.340477] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.350182] [drm:compare_of] Comparing of node /soc/display-backend@1e60000 with /soc/lcd-controller@1c0c000
[ 1.360251] [drm:compare_of] Comparing of node /soc/lcd-controller@1c0c000 with /soc/lcd-controller@1c0c000
[ 1.370672] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[ 1.381653] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc083e9ec)
[ 1.390856] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc083d478)
[ 1.398733] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.405480] [drm:drm_minor_register]
[ 1.409281] [drm:drm_minor_register]
[ 1.413918] [drm:drm_minor_register] new minor registered 0
[ 1.420132] [drm:drm_sysfs_connector_add] adding "Unknown-1" to sysfs
[ 1.426659] [drm:drm_sysfs_hotplug_event] generating hotplug event
[ 1.433186] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.441168] [drm:drm_client_modeset_probe]
[ 1.445462] [drm:drm_mode_object_get] OBJ ID: 45 (2)
[ 1.450637] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:45:Unknown-1]
[ 1.458379] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:45:Unknown-1] status updated from unknown to connected
[ 1.469678] [drm:sun4i_rgb_mode_valid] Validating modes...
[ 1.475219] [drm:sun4i_rgb_mode_valid] Horizontal parameters OK
[ 1.481246] [drm:sun4i_rgb_mode_valid] Vertical parameters OK
[ 1.487035] [drm:sun4i_rgb_mode_valid] RGB panel used, skipping clock rate checks
[ 1.487053] [drm:sun4i_rgb_mode_valid] Clock rate OK
[ 1.500092] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:45:Unknown-1] probed modes :
[ 1.509167] [drm:drm_mode_debug_printmodeline] Modeline "800x480": 60 31000 800 848 888 976 480 483 496 528 0x48 0x0
[ 1.519843] [drm:drm_client_modeset_probe] connector 45 enabled? yes
[ 1.526275] [drm:drm_client_modeset_probe] Not using firmware configuration
[ 1.533377] [drm:drm_client_modeset_probe] looking for cmdline mode on connector 45
[ 1.541171] [drm:drm_client_modeset_probe] looking for preferred mode on connector 45 0
[ 1.549300] [drm:drm_client_modeset_probe] found mode 800x480
[ 1.555106] [drm:drm_client_modeset_probe] picking CRTCs for 8192x8192 config
[ 1.562367] [drm:drm_client_modeset_probe] desired mode 800x480 set on crtc 43 (0,0)
[ 1.570270] [drm:drm_mode_object_get] OBJ ID: 45 (2)
[ 1.575310] [drm:drm_mode_object_put.part.0] OBJ ID: 45 (3)
[ 1.581062] sun4i-drm display-engine: [drm:__drm_fb_helper_initial_config_and_unlock] test CRTC 0 primary plane
[ 1.591350] sun4i-drm display-engine: [drm:drm_fb_helper_generic_probe] surface width(800), height(480) and bpp(32)
[ 1.607100] [drm:drm_mode_addfb2] [FB:46]
[ 1.611391] [drm:drm_mode_object_put.part.0] OBJ ID: 46 (2)
[ 1.618042] [drm:drm_sysfs_hotplug_event] generating hotplug event坑:5.2内核可以成功点亮屏幕,5.7.1内核点亮屏幕但一直白屏,log如上。
最近编辑记录 likaiqin (2023-01-10 12:30:40)
