楼主 # 2023-03-09 17:48:54
khorght
F1C200S does not start FEL if SD inserted
Hello. Very strange behaviour of F1C200S board from LCTech also known as CherryPI - board with 128Mb GD NAND. If i insert SD-card, device does not boot and even does not enter FEL mode if i hold  BOOT btn and press RESET btn. If i unplug SD-card and reset, device successfully boots, and if i then insert sd again, it detects card, i can mount it and work with it. With inserted card if i fast press multiple times reset, sometimes it start and write muliple
U-Boot SPL 2020.07 (Mar 07 2023 - 15:09:55 +0300)
DRAM: 64 MiB
Trying to boot from MMC1
What may be wrong and is it possible to repair this? Thanx.
最近编辑记录 khorght (2023-03-09 17:53:49)
