楼主 # 2023-04-10 18:05:30
ryan_wen
D1s-nezha SD卡启动报错
在Starting kernel时发生以下报错,打不开root fs,请各大指点一下可能的原因,谢谢
VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[    2.133560] ALSA device list:
[    2.136885]   #0: audiocodec
[    2.140123] alloc_fd: slot 0 not NULL!
[    2.144456] cfg80211: failed to load regulatory.db
[    2.150484] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[    2.159187] Please append a correct "root=" boot option; here are the available partitions:
[    2.168639] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    2.177900] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #13
[    2.184426] Call Trace:
[    2.187184] [<ffffffe00002a154>] walk_stackframe+0x0/0x98
[    2.193230] [<ffffffe00002a30c>] show_stack+0x2a/0x34
[    2.198888] [<ffffffe0004c95ac>] dump_stack+0x20/0x28
[    2.204544] [<ffffffe00002e7cc>] panic+0xec/0x272
[    2.209815] [<ffffffe000000ef2>] mount_block_root+0x214/0x27a
[    2.216243] [<ffffffe000000fde>] mount_root+0x86/0x90
[    2.221899] [<ffffffe000001130>] prepare_namespace+0x148/0x152
[    2.228427] [<ffffffe000000b54>] kernel_init_freeable+0x166/0x198
[    2.235256] [<ffffffe0004da17c>] kernel_init+0x12/0xee
[    2.241014] [<ffffffe000028ec0>] ret_from_exception+0x0/0xc
[    2.247255] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
启动SD卡是用phoenixCard(试过4.2.5/4.2.7/4.2.8三个版本都一样)烧的,在uboot控制台mmcinfo查卡信息正常,mmc part查看到有8个分区
=> mmcinfo
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
=> mmc part
Partition Map for MMC device 0  --   Partition Type: EFI
Part    Start LBA       End LBA         Name
        Attributes
        Type GUID
        Partition GUID
  1     0x00012000      0x000121f7      "boot-resource"
        attrs:  0x0000200000000000
        type:   ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
        guid:   a0085546-4166-744a-a353-fca9272b8e45
  2     0x000121f8      0x000123ef      "env"
        attrs:  0xc000200000000000
        guid:   a0085546-4166-744a-a353-fca9272b8e46
  3     0x000123f0      0x000125e7      "env-redund"
        guid:   a0085546-4166-744a-a353-fca9272b8e47
  4     0x000125e8      0x000175e7      "boot"
        guid:   a0085546-4166-744a-a353-fca9272b8e48
  5     0x000175e8      0x000233e7      "rootfs"
        guid:   a0085546-4166-744a-a353-fca9272b8e49
  6     0x000233e8      0x00028b67      "recovery"
        guid:   a0085546-4166-744a-a353-fca9272b8e4a
  7     0x00028b68      0x0002b367      "rootfs_data"
        guid:   a0085546-4166-744a-a353-fca9272b8e4b
  8     0x0002b368      0x01dac3ff      "UDISK"
        attrs:  0xc000000000000000
        guid:   a0085546-4166-744a-a353-fca9272b8e4c
