源码下载: fbplasma.tgz
M9 直接写屏红绿蓝
编译指令: arm-none-linux-gnueabi-gcc main.c -o test -static
#include <stdio.h>
#include <unistd.h>
#include <stdio.h>
#include <fcntl.h>
#include <linux/fb.h>
#include <sys/mman.h>
#define screen_height 960
#define screen_width 640
int main(void)
int devfb0;
unsigned char * fb0;
unsigned char * framebuff;
int i, j;
printf("starting... ... !n");
devfb0 = open("/dev/fb0", O_RDWR);
fb0 = (char *) mmap(0, 960*640*4, PROT_READ | PROT_WRITE, MAP_SHARED, devfb0, 0);
if ( (int) fb0 == -1)
printf ("Error: failed to map framebuffer device to memory.\n");
exit (2);
printf ("The framebuffer device was mapped to memory successfully.\n");
while(1)
framebuff = fb0;
//printf("AAAAAA........3333..............\n");
for (i = 0; i < screen_height; ++i)
for (j = 0; j < screen_width; ++j)
/* magic transformation: color index to RGB24 */
*framebuff ++ = 0x00; /* blue */
*framebuff ++ = 0x00; /* green */
*framebuff ++ = 0xFF; /* red */
*framebuff ++ = 0xFF; /* alpha */
M9 直接写屏红绿蓝
#include <stdio.h> #include <unistd.h> #include <stdio.h> #include <fcntl.h> #include <linux/fb.h> #include <sys/mman.h> #define screen_height 960 #define screen_width 640 int main(void) { int devfb0; unsigned char * fb0; unsigned char * framebuff; int i, j; printf("starting... ... !n"); devfb0 = open("/dev/fb0", O_RDWR); fb0 = (char *) mmap(0, 960*640*4, PROT_READ | PROT_WRITE, MAP_SHARED, devfb0, 0); if ( (int) fb0 == -1) { printf ("Error: failed to map framebuffer device to memory.\n"); exit (2); } else { printf ("The framebuffer device was mapped to memory successfully.\n"); } while(1) { framebuff = fb0; //printf("AAAAAA........3333..............\n"); for (i = 0; i < screen_height; ++i) { for (j = 0; j < screen_width; ++j) { /* magic transformation: color index to RGB24 */ *framebuff ++ = 0x00; /* blue */ *framebuff ++ = 0x00; /* green */ *framebuff ++ = 0xFF; /* red */ *framebuff ++ = 0xFF; /* alpha */ } } } }
我去 这都行 怎么烧录进去的
gcc 静态链接, 然后用 adb push 到一个有权限的目录, 再执行这个命令.
昨天翻邮箱, 刚好看到就传上来了。
忘记当时有没有root手机了, 按理来说 /dev/fb0 是不能执行写操作的。
