按照正点原子的驱动教程 在vscode下写了如下代码
#include <linux/module.h>
static int __init chardevbase_init(void)
static void __exit chardevbase_exit(void)
module_init(chardevbase_init);
module_exit(chardevbase_exit);
在Makefile里写了
KERNELDIR := /home/jonsen/f1c100s/linux
CURRENT_PATH := $(shell pwd)
obj-m := chrdevbase.o
build:kernel_modules
kernel_modules:
$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) kernel_modules
Clean:
$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) chean
c_cpp_properties.json修改了如下
"configurations": [
"name": "Linux",
"includePath": [
"${workspaceFolder}/**",
"/home/jonsen/f1c100s/linux/include",
"/home/jonsen/f1c100s/linux/arch/arm/include/",
"/home/jonsen/f1c100s/linux/arch/arm/include/generated/"
"defines": [],
//"compilerPath": "/usr/bin/gcc",
"compilerPath":"/home/jonsen/f1c100s/buildroot-2017.08/output/host/bin/arm-linux-gcc",
"cStandard": "gnu17",
"cppStandard": "gnu++14",
"intelliSenseMode": "gcc-x64"
"version": 4
make 后
出现 :
jonsen@ubuntu:~/f1c100s/test_chrdevbase$ make
make -C /home/jonsen/f1c100s/linux M=/home/jonsen/f1c100s/test_chrdevbase kernel_modules
make[1]: Entering directory '/home/jonsen/f1c100s/linux'
make[1]: *** No rule to make target 'kernel_modules'. Stop.
make[1]: Leaving directory '/home/jonsen/f1c100s/linux'
make: *** [Makefile:8: kernel_modules] Error 2
不知怎么处理了,大佬们 帮忙指指路。。。
最近编辑记录 LinuxGo (2021-01-21 17:17:18)
写一个简单的V3s@linux4.13-y 中断驱动
http://whycan.com/t_1261.html
(出处:哇酷开发者社区)
把$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) kernel_modules
改成$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) modules
试试
改后有变化,错误信息还是有,大佬再看下
make -C /home/jonsen/f1c100s/linux M=/home/jonsen/f1c100s/test_chrdevbase modules
CC [M] /home/jonsen/f1c100s/test_chrdevbase/chardevbase.o
In file included from ./arch/x86/include/asm/barrier.h:5,
from ./include/linux/compiler.h:242,
from ./include/linux/kernel.h:10,
from ./include/linux/list.h:9,
from ./include/linux/module.h:9,
from /home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:1:
./arch/x86/include/asm/arch_hweight.h: In function ‘__arch_hweight64’:
./arch/x86/include/asm/arch_hweight.h:55:42: error: expected ‘:’ or ‘)’ before ‘POPCNT64’
55 | asm (ALTERNATIVE("call __sw_hweight64", POPCNT64, X86_FEATURE_POPCNT)
./arch/x86/include/asm/alternative.h:133:28: note: in definition of macro ‘ALTINSTR_REPLACEMENT’
133 | b_replacement(num)":\n\t" newinstr "\n" e_replacement(num) ":\n\t"
./arch/x86/include/asm/arch_hweight.h:55:7: note: in expansion of macro ‘ALTERNATIVE’
In file included from ./arch/x86/include/asm/atomic.h:276,
from ./include/linux/atomic.h:5,
from ./include/linux/jump_label.h:186,
from ./arch/x86/include/asm/string_64.h:6,
from ./arch/x86/include/asm/string.h:5,
from ./include/linux/string.h:19,
from ./arch/x86/include/asm/page_32.h:35,
from ./arch/x86/include/asm/page.h:14,
from ./arch/x86/include/asm/thread_info.h:12,
from ./include/linux/thread_info.h:38,
from ./arch/x86/include/asm/preempt.h:7,
from ./include/linux/preempt.h:81,
from ./include/linux/spinlock.h:51,
from ./include/linux/seqlock.h:36,
from ./include/linux/time.h:6,
from ./include/linux/stat.h:19,
from ./include/linux/module.h:10,
./arch/x86/include/asm/atomic64_64.h: At top level:
./arch/x86/include/asm/atomic64_64.h:20:40: error: unknown type name ‘atomic64_t’
20 | static inline long atomic64_read(const atomic64_t *v)
In file included from ./include/linux/kernel.h:10,
./arch/x86/include/asm/atomic64_64.h: In function ‘atomic64_read’:
./arch/x86/include/asm/atomic64_64.h:22:22: error: request for member ‘counter’ in something not a structure or union
22 | return READ_ONCE((v)->counter);
./include/linux/compiler.h:246:17: note: in definition of macro ‘__READ_ONCE’
246 | union { typeof(x) __val; char __c[1]; } __u; \
./arch/x86/include/asm/atomic64_64.h:22:9: note: in expansion of macro ‘READ_ONCE’
./include/linux/compiler.h:248:22: note: in definition of macro ‘__READ_ONCE’
248 | __read_once_size(&(x), __u.__c, sizeof(x)); \
./include/linux/compiler.h:248:42: note: in definition of macro ‘__READ_ONCE’
./include/linux/compiler.h:250:30: note: in definition of macro ‘__READ_ONCE’
250 | __read_once_size_nocheck(&(x), __u.__c, sizeof(x)); \
./include/linux/compiler.h:250:50: note: in definition of macro ‘__READ_ONCE’
./arch/x86/include/asm/atomic64_64.h:32:33: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
32 | static inline void atomic64_set(atomic64_t *v, long i)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:44:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
44 | static __always_inline void atomic64_add(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:58:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
58 | static inline void atomic64_sub(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:74:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
74 | static inline bool atomic64_sub_and_test(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:85:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
85 | static __always_inline void atomic64_inc(atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:98:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
98 | static __always_inline void atomic64_dec(atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:113:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
113 | static inline bool atomic64_dec_and_test(atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:126:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
126 | static inline bool atomic64_inc_and_test(atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:140:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
140 | static inline bool atomic64_add_negative(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:152:57: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
152 | static __always_inline long atomic64_add_return(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:157:48: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
157 | static inline long atomic64_sub_return(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:162:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
162 | static inline long atomic64_fetch_add(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:167:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
167 | static inline long atomic64_fetch_sub(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:175:37: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
175 | static inline long atomic64_cmpxchg(atomic64_t *v, long old, long new)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:181:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
181 | static __always_inline bool atomic64_try_cmpxchg(atomic64_t *v, s64 *old, long new)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:186:34: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
186 | static inline long atomic64_xchg(atomic64_t *v, long new)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:200:40: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
200 | static inline bool atomic64_add_unless(atomic64_t *v, long a, long u)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:219:45: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
219 | static inline long atomic64_dec_if_positive(atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:230:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
230 | static inline void atomic64_and(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:238:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
238 | static inline long atomic64_fetch_and(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:247:40: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
247 | static inline void atomic64_or(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:255:46: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
255 | static inline long atomic64_fetch_or(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:264:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
264 | static inline void atomic64_xor(long i, atomic64_t *v)
| atomic_t
./arch/x86/include/asm/atomic64_64.h:272:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
272 | static inline long atomic64_fetch_xor(long i, atomic64_t *v)
| atomic_t
In file included from ./include/linux/atomic.h:660,
./include/asm-generic/atomic64.h:21:18: error: conflicting types for ‘atomic64_read’
21 | extern long long atomic64_read(const atomic64_t *v);
./arch/x86/include/asm/atomic64_64.h:20:20: note: previous definition of ‘atomic64_read’ was here
./include/asm-generic/atomic64.h:59: warning: "atomic64_inc_return" redefined
59 | #define atomic64_inc_return(v) atomic64_add_return(1LL, (v))
./arch/x86/include/asm/atomic64_64.h:172: note: this is the location of the previous definition
172 | #define atomic64_inc_return(v) (atomic64_add_return(1, (v)))
./include/asm-generic/atomic64.h:63: warning: "atomic64_dec_return" redefined
63 | #define atomic64_dec_return(v) atomic64_sub_return(1LL, (v))
./arch/x86/include/asm/atomic64_64.h:173: note: this is the location of the previous definition
173 | #define atomic64_dec_return(v) (atomic64_sub_return(1, (v)))
./include/asm-generic/atomic64.h:65: warning: "atomic64_inc_not_zero" redefined
65 | #define atomic64_inc_not_zero(v) atomic64_add_unless((v), 1LL, 0LL)
./arch/x86/include/asm/atomic64_64.h:210: note: this is the location of the previous definition
210 | #define atomic64_inc_not_zero(v) atomic64_add_unless((v), 1, 0)
In file included from ./arch/x86/include/asm/pgtable_types.h:324,
from ./arch/x86/include/asm/processor.h:19,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
./include/asm-generic/pgtable-nopud.h:21: warning: "PUD_SHIFT" redefined
21 | #define PUD_SHIFT P4D_SHIFT
In file included from ./arch/x86/include/asm/pgtable_types.h:250,
./arch/x86/include/asm/pgtable_64_types.h:56: note: this is the location of the previous definition
56 | #define PUD_SHIFT 30
./include/asm-generic/pgtable-nopud.h:22: warning: "PTRS_PER_PUD" redefined
22 | #define PTRS_PER_PUD 1
./arch/x86/include/asm/pgtable_64_types.h:57: note: this is the location of the previous definition
57 | #define PTRS_PER_PUD 512
./include/asm-generic/pgtable-nopud.h:23: warning: "PUD_SIZE" redefined
23 | #define PUD_SIZE (1UL << PUD_SHIFT)
./arch/x86/include/asm/pgtable_64_types.h:73: note: this is the location of the previous definition
73 | #define PUD_SIZE (_AC(1, UL) << PUD_SHIFT)
./include/asm-generic/pgtable-nopud.h:24: warning: "PUD_MASK" redefined
24 | #define PUD_MASK (~(PUD_SIZE-1))
./arch/x86/include/asm/pgtable_64_types.h:74: note: this is the location of the previous definition
74 | #define PUD_MASK (~(PUD_SIZE - 1))
In file included from ./arch/x86/include/asm/pgtable_types.h:345,
./include/asm-generic/pgtable-nopmd.h:20: warning: "PMD_SHIFT" redefined
20 | #define PMD_SHIFT PUD_SHIFT
./arch/x86/include/asm/pgtable_64_types.h:63: note: this is the location of the previous definition
63 | #define PMD_SHIFT 21
./include/asm-generic/pgtable-nopmd.h:21: warning: "PTRS_PER_PMD" redefined
21 | #define PTRS_PER_PMD 1
./arch/x86/include/asm/pgtable_64_types.h:64: note: this is the location of the previous definition
64 | #define PTRS_PER_PMD 512
./include/asm-generic/pgtable-nopmd.h:22: warning: "PMD_SIZE" redefined
22 | #define PMD_SIZE (1UL << PMD_SHIFT)
./arch/x86/include/asm/pgtable_64_types.h:71: note: this is the location of the previous definition
71 | #define PMD_SIZE (_AC(1, UL) << PMD_SHIFT)
./include/asm-generic/pgtable-nopmd.h:23: warning: "PMD_MASK" redefined
23 | #define PMD_MASK (~(PMD_SIZE-1))
./arch/x86/include/asm/pgtable_64_types.h:72: note: this is the location of the previous definition
72 | #define PMD_MASK (~(PMD_SIZE - 1))
In file included from ./arch/x86/include/asm/cpufeature.h:5,
./arch/x86/include/asm/processor.h:180: warning: "cache_line_size" redefined
180 | #define cache_line_size() (boot_cpu_data.x86_cache_alignment)
In file included from ./include/linux/printk.h:9,
from ./include/linux/kernel.h:14,
./include/linux/cache.h:79: note: this is the location of the previous definition
79 | #define cache_line_size() L1_CACHE_BYTES
./arch/x86/include/asm/processor.h: In function ‘load_cr3’:
./arch/x86/include/asm/processor.h:253:12: error: implicit declaration of function ‘__sme_pa’ [-Werror=implicit-function-declaration]
253 | write_cr3(__sme_pa(pgdir));
In file included from ./arch/x86/include/asm/preempt.h:7,
./include/linux/thread_info.h: At top level:
./include/linux/thread_info.h:96:19: error: redefinition of ‘arch_within_stack_frames’
96 | static inline int arch_within_stack_frames(const void * const stack,
In file included from ./include/linux/thread_info.h:38,
./arch/x86/include/asm/thread_info.h:171:19: note: previous definition of ‘arch_within_stack_frames’ was here
171 | static inline int arch_within_stack_frames(const void * const stack,
In file included from ./include/linux/elf.h:5,
from ./include/linux/module.h:15,
./arch/x86/include/asm/elf.h: In function ‘elf_common_init’:
./arch/x86/include/asm/elf.h:180:3: error: ‘struct thread_struct’ has no member named ‘fsbase’
180 | t->fsbase = t->gsbase = 0;
./arch/x86/include/asm/elf.h:180:15: error: ‘struct thread_struct’ has no member named ‘gsbase’
./arch/x86/include/asm/elf.h: In function ‘mmap_is_ia32’:
./include/linux/thread_info.h:91:22: error: implicit declaration of function ‘current_thread_info’ [-Werror=implicit-function-declaration]
91 | test_ti_thread_flag(current_thread_info(), flag)
./arch/x86/include/asm/elf.h:306:3: note: in expansion of macro ‘test_thread_flag’
306 | test_thread_flag(TIF_ADDR32));
./include/linux/thread_info.h:91:22: warning: passing argument 1 of ‘test_ti_thread_flag’ makes pointer from integer without a cast [-Wint-conversion]
| int
./include/linux/thread_info.h:77:59: note: expected ‘struct thread_info *’ but argument is of type ‘int’
77 | static inline int test_ti_thread_flag(struct thread_info *ti, int flag)
In file included from ./include/linux/cache.h:6,
./arch/x86/include/asm/elf.h: At top level:
./arch/x86/include/asm/cache.h:8:25: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared here (not in a function); did you mean ‘CONFIG_ARM_L1_CACHE_SHIFT’?
8 | #define L1_CACHE_SHIFT (CONFIG_X86_L1_CACHE_SHIFT)
./arch/x86/include/asm/cache.h:9:30: note: in expansion of macro ‘L1_CACHE_SHIFT’
9 | #define L1_CACHE_BYTES (1 << L1_CACHE_SHIFT)
./include/linux/cache.h:13:25: note: in expansion of macro ‘L1_CACHE_BYTES’
13 | #define SMP_CACHE_BYTES L1_CACHE_BYTES
./include/linux/cache.h:35:58: note: in expansion of macro ‘SMP_CACHE_BYTES’
35 | #define ____cacheline_aligned __attribute__((__aligned__(SMP_CACHE_BYTES)))
./arch/x86/include/asm/elf.h:381:3: note: in expansion of macro ‘____cacheline_aligned’
381 | } ____cacheline_aligned;
In file included from ./include/linux/module.h:24,
./arch/x86/include/asm/module.h:67:2: error: #error unknown processor family
67 | #error unknown processor family
In file included from /home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:1:
./include/linux/module.h:131:6: warning: ‘init_module’ specifies less restrictive attribute than its target ‘chardevbase_init’: ‘cold’ [-Wmissing-attributes]
131 | int init_module(void) __attribute__((alias(#initfn)));
/home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:15:1: note: in expansion of macro ‘module_init’
15 | module_init(chardevbase_init);
/home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:3:19: note: ‘init_module’ target declared here
3 | static int __init chardevbase_init(void)
./include/linux/module.h:137:7: warning: ‘cleanup_module’ specifies less restrictive attribute than its target ‘chardevbase_exit’: ‘cold’ [-Wmissing-attributes]
137 | void cleanup_module(void) __attribute__((alias(#exitfn)));
/home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:17:1: note: in expansion of macro ‘module_exit’
17 | module_exit(chardevbase_exit);
/home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:9:20: note: ‘cleanup_module’ target declared here
9 | static void __exit chardevbase_exit(void)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:323: /home/jonsen/f1c100s/test_chrdevbase/chardevbase.o] Error 1
make[1]: *** [Makefile:1508: _module_/home/jonsen/f1c100s/test_chrdevbase] Error 2
试试
ARCH=arm
#当前目录
CUR_DIR = $(shell pwd)
#源码目录
KERNEL_DIR = /home/jonsen/f1c100s/linux
#交叉编译工具链
CROSS_COMPILE = arm-linux-gnueabihf-
#模块名字
MODULE_NAME = chrdevbase
ifeq ($(KERNELRELEASE),)
all:
make ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KERNEL_DIR) M=$(CUR_DIR) modules
clean:
#清除模块
make -C $(KERNEL_DIR) M=$(CUR_DIR) clean
obj-m+=$(MODULE_NAME).o
endif
试试这个
感谢大佬,
目前写成了,顺利编译
KERNELDIR := /home/jonsen/f1c100s/linux/
CROSS_COMPILE:= /home/jonsen/f1c100s/buildroot-2017.08/output/host/bin/arm-linux-
ARCH = arm
obj-m := chardevbase.o
build: kernel_modules
kernel_modules:
$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KERNELDIR) M=$(CURRENT_PATH) modules
clean:
$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) clean
ARCH=arm
#当前目录
#源码目录
#交叉编译工具链
#模块名字
MODULE_NAME = chrdevbaseifeq ($(KERNELRELEASE),)
all:
clean:
#清除模块
obj-m+=$(MODULE_NAME).oendif
试试这个
