买了芒果派的f1c200s板子,烧录nano的uboot无LOG输出,最终发现串口终端使用的是uart1,而nano的源码是使用的uart0。
找了很多资料,参考:https://whycan.com/t_1624.html修改u-boot源码uart1为终端输出,并打包成patch分享给大家使用。
补丁包:f1c100s-uboot串口1终端补丁包.zip
详细的修改步骤之前记录在CSDN了:全志F1C100S/F1C200S学习笔记(3)——主线uboot更改默认终端串口为uart1
补丁使用:
1、u-boot-uart1.patch 放在u-boot 同级目录
2、进入u-boot目录
3、执行patch -p1 < ../u-boot-uart1.patch
贴出修改内容:
1、 u-boot/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts 17行:
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
"allwinner,suniv";
aliases {
serial0 = &uart0;
serial1 = &uart1;
spi0 = &spi0;
chosen {
stdout-path = "serial1:115200n8";
&uart1 {
pinctrl-names = "default";
pinctrl-0 = <&uart1_pins_a>;
2、 u-boot/arch/arm/dts/suniv.dtsi 124行:
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-pinctrl";
reg = <0x01c20800 0x400>;
gpio-controller;
interrupt-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
spi0_pins_a: spi0-pins-pc {
function = "spi0";
uart0_pins_a: uart-pins-pe {
pins = "PE0", "PE1";
function = "uart0";
uart1_pins_a: uart-pins-pa {
pins = "PA2", "PA3";
function = "uart1";
3、 /u-boot/arch/arm/include/asm/arch-sunxi/gpio.h 146行:
#define SUNXI_GPA_EMAC 2
#define SUNIV_GPA_UART1 5
4、 u-boot/include/configs/suniv.h 17行:
#include <configs/sunxi-common.h>
#undef CONFIG_CONS_INDEX
#define CONFIG_CONS_INDEX 2 //UART1
#endif /* __CONFIG_H */
5、 u-boot/arch/arm/mach-sunxi/board.c 86行:
#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV)
sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0);
sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP);
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1);
sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1);
sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
最近正好需要把串口从uart0换到uart1,前来学习学习
@丨晋丨
参考链接:https://blog.csdn.net/p1279030826/article/details/113116927
我的调试串口是UART2,F1C100S PE7,PE8
根据参考链接与手册修改了
1./u-boot/arch/arm/include/asm/arch-sunxi/gpio.h 146行
#define SUNIV_GPE_UART2 3
2.u-boot/arch/arm/mach-sunxi/board.c 86行:
sunxi_gpio_set_cfgpin(SUNXI_GPE(7), SUNIV_GPE_UART2);
sunxi_gpio_set_cfgpin(SUNXI_GPE(8), SUNIV_GPE_UART2);
sunxi_gpio_set_pull(SUNXI_GPE(7), SUNXI_GPIO_PULL_UP);
3.u-boot/include/configs/suniv.h17行
4.u-boot/include/configs/sunxi-common.h 276行
#define OF_STDOUT_PATH "/soc@01c00000/serial@01c28400:115200"
修改后,编译正常
LD spl/u-boot-spl
COPY spl/u-boot-spl.bin
MKSUNXI spl/sunxi-spl.bin
OBJCOPY u-boot-nodtb.bin
CAT u-boot-dtb.bin
COPY u-boot.bin
MKIMAGE u-boot.img
COPY u-boot.dtb
BINMAN u-boot-sunxi-with-spl.bin
OBJCOPY u-boot.srec
SYM u-boot.sym
MKIMAGE u-boot-dtb.img
CHK include/config.h
CFG u-boot.cfg
烧录到nor 的零地址
./sunxi-fel -p spiflash-write 0x000000 u-boot-sunxi-with-spl.bin
启动 串口还是没有任何输出:(
@Sam
再附一个 BSP生成的dtb文件,反编译成dts:
/dts-v1/;
/memreserve/ 0x0000000081000000 0x0000000000010000;
model = "sunivw1p1";
compatible = "arm,sunivw1p1", "arm,suniw1p1";
interrupt-parent = <0x1>;
#address-cells = <0x2>;
#size-cells = <0x2>;
clocks {
compatible = "allwinner,sunxi-clk-init";
device_type = "clocks";
ranges;
reg = <0x0 0x1c20000 0x0 0x2d0>;
losc {
#clock-cells = <0x0>;
compatible = "allwinner,fixed-clock";
clock-frequency = <0x8000>;
clock-output-names = "losc";
hosc {
clock-frequency = <0x16e3600>;
clock-output-names = "hosc";
linux,phandle = <0x11>;
phandle = <0x11>;
pll_cpu {
compatible = "allwinner,sunxi-pll-clock";
lock-mode = "none";
assigned-clock-rates = <0x1f78a400>;
clock-output-names = "pll_cpu";
pll_audio {
lock-mode = "none";
clock-output-names = "pll_audio";
linux,phandle = <0x2>;
phandle = <0x2>;
pll_video {
lock-mode = "none";
assigned-clock-rates = <0x11b3dc40>;
clock-output-names = "pll_video";
linux,phandle = <0x3>;
phandle = <0x3>;
pll_ve {
lock-mode = "none";
clock-output-names = "pll_ve";
linux,phandle = <0x6>;
phandle = <0x6>;
pll_ddr {
lock-mode = "none";
assigned-clock-rates = <0x1298be00>;
clock-output-names = "pll_ddr";
pll_periph {
lock-mode = "none";
clock-output-names = "pll_periph";
linux,phandle = <0x4>;
phandle = <0x4>;
pll_audiox8 {
compatible = "allwinner,fixed-factor-clock";
clocks = <0x2>;
clock-mult = <0x8>;
clock-div = <0x1>;
clock-output-names = "pll_audiox8";
pll_audiox4 {
clocks = <0x2>;
clock-mult = <0x8>;
clock-div = <0x2>;
clock-output-names = "pll_audiox4";
pll_audiox2 {
clocks = <0x2>;
clock-mult = <0x8>;
clock-div = <0x4>;
clock-output-names = "pll_audiox2";
pll_videox2 {
clocks = <0x3>;
clock-mult = <0x2>;
clock-div = <0x1>;
clock-output-names = "pll_videox2";
pll_periphx2 {
clocks = <0x4>;
clock-mult = <0x2>;
clock-div = <0x1>;
clock-output-names = "pll_periphx2";
cpu {
compatible = "allwinner,sunxi-periph-clock";
clock-output-names = "cpu";
pll_periphahb {
clock-output-names = "pll_periphahb";
ahb1 {
clock-output-names = "ahb1";
apb1 {
clock-output-names = "apb1";
sdmmc0_mod {
clock-output-names = "sdmmc0_mod";
linux,phandle = <0x27>;
phandle = <0x27>;
sdmmc0_bus {
clock-output-names = "sdmmc0_bus";
linux,phandle = <0x28>;
phandle = <0x28>;
sdmmc0_rst {
clock-output-names = "sdmmc0_rst";
linux,phandle = <0x29>;
phandle = <0x29>;
sdmmc1_mod {
clock-output-names = "sdmmc1_mod";
linux,phandle = <0x2c>;
phandle = <0x2c>;
sdmmc1_bus {
clock-output-names = "sdmmc1_bus";
linux,phandle = <0x2d>;
phandle = <0x2d>;
sdmmc1_rst {
clock-output-names = "sdmmc1_rst";
linux,phandle = <0x2e>;
phandle = <0x2e>;
spi0 {
clock-output-names = "spi0";
linux,phandle = <0x1e>;
phandle = <0x1e>;
spi1 {
clock-output-names = "spi1";
linux,phandle = <0x23>;
phandle = <0x23>;
usbphy0 {
clock-output-names = "usbphy0";
linux,phandle = <0x39>;
phandle = <0x39>;
usbotg {
clock-output-names = "usbotg";
linux,phandle = <0x3a>;
phandle = <0x3a>;
audio {
clock-output-names = "audio";
linux,phandle = <0x3b>;
phandle = <0x3b>;
avs {
clock-output-names = "avs";
codec {
clock-output-names = "codec";
linux,phandle = <0x42>;
phandle = <0x42>;
spdif {
clock-output-names = "spdif";
linux,phandle = <0x3f>;
phandle = <0x3f>;
debe {
clock-output-names = "debe";
linux,phandle = <0x32>;
phandle = <0x32>;
defe {
clock-output-names = "defe";
linux,phandle = <0x31>;
phandle = <0x31>;
tcon {
clock-output-names = "tcon";
linux,phandle = <0x34>;
phandle = <0x34>;
deinterlace {
clock-output-names = "deinterlace";
linux,phandle = <0x33>;
phandle = <0x33>;
tve_clk2 {
clock-output-names = "tve_clk2";
tve_clk1 {
clock-output-names = "tve_clk1";
tvd {
clock-output-names = "tvd";
csi_m {
clock-output-names = "csi_m";
linux,phandle = <0x35>;
phandle = <0x35>;
ve {
clock-output-names = "ve";
linux,phandle = <0x7>;
phandle = <0x7>;
sdram {
clock-output-names = "sdram";
dma {
clock-output-names = "dma";
linux,phandle = <0x5>;
phandle = <0x5>;
uart0 {
clock-output-names = "uart0";
linux,phandle = <0x8>;
phandle = <0x8>;
uart1 {
clock-output-names = "uart1";
linux,phandle = <0xb>;
phandle = <0xb>;
uart2 {
clock-output-names = "uart2";
linux,phandle = <0xe>;
phandle = <0xe>;
twi0 {
clock-output-names = "twi0";
linux,phandle = <0x15>;
phandle = <0x15>;
twi1 {
clock-output-names = "twi1";
linux,phandle = <0x18>;
phandle = <0x18>;
twi2 {
clock-output-names = "twi2";
linux,phandle = <0x1b>;
phandle = <0x1b>;
rsb {
clock-output-names = "rsb";
cir {
clock-output-names = "cir";
linux,phandle = <0x12>;
phandle = <0x12>;
soc {
compatible = "simple-bus";
device_type = "soc";
ranges;
pinctrl@01c20800 {
compatible = "allwinner,sunivw1p1-pinctrl";
reg = <0x0 0x1c20800 0x0 0x400>;
interrupts = <0x26 0x27 0x28>;
device_type = "pio";
gpio-controller;
#interrupt-cells = <0x2>;
#size-cells = <0x0>;
#gpio-cells = <0x6>;
linux,phandle = <0x38>;
phandle = <0x38>;
vdevice@0 {
allwinner,pins = "PC0", "PC1";
allwinner,function = "vdevice";
allwinner,muxsel = <0x4>;
allwinner,drive = <0x1>;
allwinner,pull = <0x1>;
uart0@1 {
allwinner,pins = "PF2", "PF4";
allwinner,function = "io_disabled";
allwinner,muxsel = <0x7>;
linux,phandle = <0xa>;
phandle = <0xa>;
uart1@1 {
allwinner,pins = "PA3", "PA2", "PA1", "PA0";
linux,phandle = <0xd>;
phandle = <0xd>;
uart2@1 {
allwinner,pins = "PE7", "PE8", "PE9", "PE10";
linux,phandle = <0x10>;
phandle = <0x10>;
twi0@1 {
allwinner,pins = "PD12", "PD0";
allwinner,pull = <0x0>;
linux,phandle = <0x17>;
phandle = <0x17>;
twi1@1 {
allwinner,pins = "PB0", "PB1";
linux,phandle = <0x1a>;
phandle = <0x1a>;
twi2@1 {
allwinner,pins = "PE0", "PE1";
linux,phandle = <0x1d>;
phandle = <0x1d>;
spi0@2 {
allwinner,pins = "PC0", "PC1", "PC2", "PC3";
linux,phandle = <0x21>;
phandle = <0x21>;
spi1@0 {
allwinner,pins = "PB1", "PB3", "PB2";
allwinner,pname = "spi1_mosi", "spi1_miso", "spi1_sclk";
allwinner,function = "spi1";
allwinner,muxsel = <0x6>;
linux,phandle = <0x24>;
phandle = <0x24>;
spi1@1 {
allwinner,pins = "PB0";
allwinner,pname = "spi1_cs0";
linux,phandle = <0x25>;
phandle = <0x25>;
spi1@2 {
allwinner,pins = "PB0", "PB1", "PB2", "PB3";
linux,phandle = <0x26>;
phandle = <0x26>;
csi0@0 {
allwinner,pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10";
allwinner,pname = "csi0_hsync", "csi0_vsync", "csi0_pck", "csi0_d0", "csi0_d1", "csi0_d2", "csi0_d3", "csi0_d4", "csi0_d5", "csi0_d6", "csi0_d7";
allwinner,function = "csi0";
allwinner,muxsel = <0x2>;
allwinner,data = <0x0>;
linux,phandle = <0x36>;
phandle = <0x36>;
csi0_sleep@0 {
linux,phandle = <0x37>;
phandle = <0x37>;
sdc0@1 {
allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
linux,phandle = <0x2b>;
phandle = <0x2b>;
sdc1@1 {
allwinner,pins = "PC0", "PC1", "PC2";
linux,phandle = <0x30>;
phandle = <0x30>;
daudio0@0 {
allwinner,pins = "PE3", "PE4", "PE5", "PE6";
allwinner,function = "iis0";
linux,phandle = <0x3c>;
phandle = <0x3c>;
daudio0@1 {
allwinner,pins = "PD7";
allwinner,muxsel = <0x3>;
linux,phandle = <0x3d>;
phandle = <0x3d>;
daudio0_sleep@0 {
allwinner,pins = "PE3", "PE4", "PE5", "PE6", "PE12";
linux,phandle = <0x3e>;
phandle = <0x3e>;
spdif@0 {
allwinner,pins = "PD17";
allwinner,function = "spdif0";
linux,phandle = <0x40>;
phandle = <0x40>;
spdif_sleep@0 {
linux,phandle = <0x41>;
phandle = <0x41>;
cir@0 {
allwinner,pins = "PE11";
allwinner,function = "cir";
linux,phandle = <0x13>;
phandle = <0x13>;
cir_sleep@0 {
linux,phandle = <0x14>;
phandle = <0x14>;
card0_boot_para@0 {
linux,phandle = <0x47>;
phandle = <0x47>;
allwinner,function = "card0_boot_para";
allwinner,pname = "sdc_d1", "sdc_d0", "sdc_clk", "sdc_cmd", "sdc_d3", "sdc_d2";
allwinner,drive = <0x2>;
allwinner,data = <0xffffffff>;
card2_boot_para@0 {
linux,phandle = <0x48>;
phandle = <0x48>;
allwinner,pins = "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16", "PC1";
allwinner,function = "card2_boot_para";
allwinner,pname = "sdc_clk", "sdc_cmd", "sdc_d0", "sdc_d1", "sdc_d2", "sdc_d3", "sdc_d4", "sdc_d5", "sdc_d6", "sdc_d7", "sdc_emmc_rst", "sdc_ds";
allwinner,drive = <0x3>;
twi_para@0 {
linux,phandle = <0x49>;
phandle = <0x49>;
allwinner,function = "twi_para";
allwinner,pname = "twi_scl", "twi_sda";
allwinner,pull = <0xffffffff>;
allwinner,drive = <0xffffffff>;
uart_para@0 {
linux,phandle = <0x4a>;
phandle = <0x4a>;
allwinner,pins = "PE7", "PE8";
allwinner,function = "uart_para";
allwinner,pname = "uart_debug_tx", "uart_debug_rx";
force_uart_para@0 {
linux,phandle = <0x4b>;
phandle = <0x4b>;
allwinner,function = "force_uart_para";
allwinner,pname = "force_uart__tx", "force_uart__rx";
jtag_para@0 {
linux,phandle = <0x4c>;
phandle = <0x4c>;
allwinner,pins = "PH9", "PH10", "PH11", "PH12";
allwinner,function = "jtag_para";
allwinner,pname = "jtag_ms", "jtag_ck", "jtag_do", "jtag_di";
twi0@0 {
linux,phandle = <0x4d>;
phandle = <0x4d>;
allwinner,function = "twi0";
allwinner,pname = "twi0_scl", "twi0_sda";
twi1@0 {
linux,phandle = <0x4e>;
phandle = <0x4e>;
allwinner,function = "twi1";
allwinner,pname = "twi1_scl", "twi1_sda";
twi2@0 {
linux,phandle = <0x4f>;
phandle = <0x4f>;
allwinner,function = "twi2";
allwinner,pname = "twi2_scl", "twi2_sda";
uart0@0 {
linux,phandle = <0x50>;
phandle = <0x50>;
allwinner,function = "uart0";
allwinner,pname = "uart0_tx", "uart0_rx";
uart1@0 {
linux,phandle = <0x51>;
phandle = <0x51>;
allwinner,pins = "PA2", "PA3";
allwinner,function = "uart1";
allwinner,pname = "uart1_tx", "uart1_rx";
allwinner,muxsel = <0x5>;
uart2@0 {
linux,phandle = <0x52>;
phandle = <0x52>;
allwinner,function = "uart2";
spi0@0 {
linux,phandle = <0x53>;
phandle = <0x53>;
allwinner,pins = "PC1";
allwinner,function = "spi0";
allwinner,pname = "spi0_cs0";
spi0@1 {
linux,phandle = <0x54>;
phandle = <0x54>;
allwinner,pins = "PC0", "PC3", "PC2";
allwinner,pname = "spi0_sclk", "spi0_mosi", "spi0_miso";
nand0@0 {
linux,phandle = <0x55>;
phandle = <0x55>;
allwinner,pins = "PC0", "PC1", "PC2", "PC4", "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14";
allwinner,function = "nand0";
allwinner,pname = "nand0_we", "nand0_ale", "nand0_cle", "nand0_nre", "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3", "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7", "nand0_ndqs";
nand0@1 {
linux,phandle = <0x56>;
phandle = <0x56>;
allwinner,pins = "PC3", "PC5";
allwinner,pname = "nand0_ce0", "nand0_rb0";
lcd0@0 {
linux,phandle = <0x57>;
phandle = <0x57>;
allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
allwinner,function = "lcd0";
allwinner,pname = "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7", "lcdd10", "lcdd11", "lcdd12", "lcdd13", "lcdd14", "lcdd15", "lcdd19", "lcdd20", "lcdd21", "lcdd22", "lcdd23", "lcdclk", "lcdde";
pwm0_para@0 {
linux,phandle = <0x58>;
phandle = <0x58>;
allwinner,pins = "PH0";
allwinner,function = "pwm0_para";
allwinner,pname = "pwm_positive";
pwm1_para@0 {
linux,phandle = <0x59>;
phandle = <0x59>;
allwinner,pins = "PH1";
allwinner,function = "pwm1_para";
vip0@0 {
linux,phandle = <0x5a>;
phandle = <0x5a>;
allwinner,pins = "PE0", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13";
allwinner,function = "vip0";
allwinner,pname = "vip0_csi_pck", "vip0_csi_hsync", "vip0_csi_vsync", "vip0_csi_d0", "vip0_csi_d1", "vip0_csi_d2", "vip0_csi_d3", "vip0_csi_d4", "vip0_csi_d5", "vip0_csi_d6", "vip0_csi_d7", "vip_csi_sck", "vip_csi_sda";
vip0@1 {
linux,phandle = <0x5b>;
phandle = <0x5b>;
allwinner,pins = "PE1";
allwinner,pname = "vip0_csi_mck";
sdc0@0 {
linux,phandle = <0x5c>;
phandle = <0x5c>;
allwinner,function = "sdc0";
allwinner,pname = "sdc0_d1", "sdc0_d0", "sdc0_clk", "sdc0_cmd", "sdc0_d3", "sdc0_d2";
sdc1@0 {
linux,phandle = <0x5d>;
phandle = <0x5d>;
allwinner,function = "sdc1";
allwinner,pname = "sdc1_clk", "sdc1_cmd", "sdc1_d0";
Vdevice@0 {
linux,phandle = <0x5e>;
phandle = <0x5e>;
allwinner,pins = "PB1", "PB2";
allwinner,function = "Vdevice";
allwinner,pname = "Vdevice_0", "Vdevice_1";
dma-controller@01c02000 {
compatible = "allwinner,suniv-dma";
reg = <0x0 0x1c02000 0x0 0x1000>;
interrupts = <0x12>;
clocks = <0x5>;
#dma-cells = <0x2>;
linux,phandle = <0x22>;
phandle = <0x22>;
timer@1c20c00 {
compatible = "allwinner,sunxi-timer";
device_type = "timer";
reg = <0x0 0x1c20c00 0x0 0x90>;
interrupts = <0xd>;
timer-prescale = <0x10>;
ve@01c0e000 {
compatible = "allwinner,sunxi-cedar-ve";
reg = <0x0 0x1c0e000 0x0 0x1000 0x0 0x1c00000 0x0 0x3000 0x0 0x1c20000 0x0 0x800>;
interrupts = <0x22>;
clocks = <0x6 0x7>;
uart@01c25000 {
compatible = "allwinner,suniv-uart";
device_type = "uart0";
reg = <0x0 0x1c25000 0x0 0x400>;
interrupts = <0x1>;
clocks = <0x8>;
pinctrl-1 = <0xa>;
uart0_port = <0x0>;
uart0_type = <0x2>;
status = "disabled";
pinctrl-0 = <0x50>;
uart@01c25400 {
device_type = "uart1";
reg = <0x0 0x1c25400 0x0 0x400>;
interrupts = <0x2>;
clocks = <0xb>;
pinctrl-1 = <0xd>;
uart1_port = <0x1>;
uart1_type = <0x2>;
pinctrl-0 = <0x51>;
uart@01c25800 {
device_type = "uart2";
reg = <0x0 0x1c25800 0x0 0x400>;
interrupts = <0x3>;
clocks = <0xe>;
pinctrl-1 = <0x10>;
uart2_port = <0x2>;
uart2_type = <0x4>;
uart1_used = <0x1>;
uart1_port = <0x2>;
uart1_type = <0x2>;
pinctrl-0 = <0x52>;
cir {
compatible = "allwinner,s_cir";
reg = <0x0 0x1c22c00 0x0 0x400>;
interrupts = <0x6>;
clocks = <0x11 0x12>;
pinctrl-0 = <0x13>;
pinctrl-1 = <0x14>;
supply = "vcc-pl";
ir_power_key_code = <0x0>;
ir_addr_code = <0x0>;
twi@0x01c27000 {
#address-cells = <0x1>;
compatible = "allwinner,suniv-twi";
device_type = "twi0";
reg = <0x0 0x1c27000 0x0 0x400>;
interrupts = <0x7>;
clocks = <0x15>;
clock-frequency = <0x186a0>;
pinctrl-1 = <0x17>;
pinctrl-0 = <0x4d>;
rtc@0x51 {
compatible = "nxp,pcf8563";
i2c-max-frequency = <0x186a0>;
reg = <0x51>;
io_expand@0x20 {
compatible = "ti,pcf8574a";
reg = <0x20>;
sensor_ov5640@0x78 {
compatible = "allwinner,sensor_ov5640";
reg = <0x78>;
twi@0x01c27400 {
device_type = "twi1";
reg = <0x0 0x1c27400 0x0 0x400>;
interrupts = <0x8>;
clocks = <0x18>;
clock-frequency = <0x30d40>;
pinctrl-1 = <0x1a>;
pinctrl-0 = <0x4e>;
twi@0x01c27800 {
device_type = "twi2";
reg = <0x0 0x1c27800 0x0 0x400>;
interrupts = <0x9>;
clocks = <0x1b>;
pinctrl-1 = <0x1d>;
pinctrl-0 = <0x4f>;
spi@01c05000 {
compatible = "allwinner,sun8i-spi";
device_type = "spi0";
reg = <0x0 0x1c05000 0x0 0x1000>;
interrupts = <0xa>;
clocks = <0x4 0x1e>;
clock-frequency = <0x5f5e100>;
pinctrl-1 = <0x21>;
spi0_cs_number = <0x1>;
spi0_cs_bitmap = <0x1>;
dmas = <0x22 0x0 0x4 0x22 0x0 0x4>;
dma-names = "rx", "tx";
pinctrl-0 = <0x53 0x54>;
nor_flash@0 {
#size-cells = <0x1>;
compatible = "st,m25p64";
spi-max-frequency = <0x989680>;
reg = <0x0>;
spi@01c06000 {
device_type = "spi1";
reg = <0x0 0x1c06000 0x0 0x1000>;
interrupts = <0xb>;
clocks = <0x4 0x23>;
pinctrl-0 = <0x24 0x25>;
pinctrl-1 = <0x26>;
spi1_cs_number = <0x1>;
spi1_cs_bitmap = <0x1>;
sdmmc@01c0f000 {
compatible = "allwinner,sunivw1p1-sdmmc0";
device_type = "sdc0";
reg = <0x0 0x1c0f000 0x0 0x1000>;
interrupts = <0x17>;
clocks = <0x11 0x4 0x27 0x28 0x29>;
clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst";
pinctrl-1 = <0x2b>;
max-frequency = <0x2faf080>;
bus-width = <0x4>;
cap-sdio-irq;
keep-power-in-suspend;
ignore-pm-notify;
sdc0_detmode = <0x4>;
sdc0_buswidth = <0x4>;
pinctrl-0 = <0x5c>;
sdc0_det = <0x38 0x0 0x1 0x0 0x1 0x2 0xffffffff>;
sdc0_use_wp = <0x0>;
sdc0_wp;
sdc0_isio = <0x0>;
sdc0_regulator = "none";
sdmmc@01c10000 {
compatible = "allwinner,sunivw1p1-sdmmc1";
device_type = "sdc1";
reg = <0x0 0x1c10000 0x0 0x1000>;
interrupts = <0x18>;
clocks = <0x11 0x4 0x2c 0x2d 0x2e>;
pinctrl-1 = <0x30>;
bus-width = <0x1>;
cap-sdio-irq;
ignore-pm-notify;
sunxi-dly-52M-ddr4 = <0x1 0x0 0x0 0x0 0x2>;
sunxi-dly-104M = <0x1 0x0 0x0 0x0 0x1>;
sunxi-dly-208M = <0x1 0x0 0x0 0x0 0x1>;
sdc1_detmode = <0x4>;
sdc1_buswidth = <0x1>;
pinctrl-0 = <0x5d>;
sdc1_det;
sdc1_use_wp = <0x0>;
sdc1_wp;
sdc1_isio = <0x1>;
sdc1_regulator = "none";
disp@0x01e00000 {
compatible = "allwinner,suniv-disp";
reg = <0x0 0x1e00000 0x0 0x20000 0x0 0x1e60000 0x0 0x10000 0x0 0x1e70000 0x0 0x10000 0x0 0x1c0c000 0x0 0x1000>;
interrupts = <0x1e 0x1f 0x21 0x1d>;
clocks = <0x31 0x32 0x33 0x34>;
lcd0@01c0c000 {
compatible = "allwinner,sunxi-lcd0";
pinctrl-names = "active", "sleep";
device_type = "lcd0";
lcd_used = <0x0>;
lcd_driver_name = "default_lcd";
lcd_if = <0x0>;
lcd_x = <0x320>;
lcd_y = <0x1e0>;
lcd_width = <0x96>;
lcd_height = <0x5e>;
lcd_dclk_freq = <0x21>;
lcd_pwm_used = <0x0>;
lcd_pwm_ch = <0x0>;
lcd_pwm_freq = <0x2710>;
lcd_pwm_pol = <0x0>;
lcd_hbp = <0x2e>;
lcd_ht = <0x41f>;
lcd_hspw = <0x0>;
lcd_vbp = <0x17>;
lcd_vt = <0x20d>;
lcd_vspw = <0x0>;
lcd_hv_if = <0x0>;
lcd_hv_smode = <0x0>;
lcd_hv_s888_if = <0x0>;
lcd_hv_syuv_if = <0x0>;
lcd_hv_vspw = <0x0>;
lcd_hv_hspw = <0x0>;
lcd_lvds_if = <0x0>;
lcd_lvds_colordepth = <0x1>;
lcd_lvds_mode = <0x0>;
lcd_lvds_ch = <0x0>;
lcd_lvds_bitwidth = <0x0>;
lcd_lvds_io_cross = <0x0>;
lcd_cpu_if = <0x0>;
lcd_frm = <0x0>;
lcd_io_phase = <0x0>;
lcd_gamma_en = <0x0>;
lcd_bright_curve_en = <0x0>;
lcd_cmap_en = <0x0>;
deu_mode = <0x0>;
lcdgamma4iep = <0x16>;
lcd_io_cfg0 = <0x4000000>;
smart_color = <0x5a>;
lcd_bl_en_used = <0x1>;
lcd_bl_en = <0x38 0x4 0xc 0x1 0x0 0xffffffff 0x1>;
lcd_power = <0x38 0x0 0x0 0x1 0x0 0xffffffff 0x1>;
pinctrl-0 = <0x57>;
csi_res@0x01cb0000 {
compatible = "allwinner,sunxi-csi";
reg = <0x0 0x1cb0000 0x0 0x1000>;
clocks = <0x35 0x3 0x11>;
clocks-index = <0x0 0x1 0x2>;
vfe@0 {
device_type = "csi0";
compatible = "allwinner,sunxi-vfe";
interrupts = <0x20>;
pinctrl-0 = <0x36>;
pinctrl-1 = <0x37>;
csi_sel = <0x0>;
csi0_sensor_list = <0x0>;
csi0_mck = <0x38 0x4 0xb 0x2 0x0 0x1 0x0>;
status = "disable";
dev@1 {
csi0_dev0_mname = "ov5640";
csi0_dev0_twi_addr = <0x78>;
csi0_dev0_pos = "rear";
csi0_dev0_isp_used = <0x0>;
csi0_dev0_fmt = <0x0>;
csi0_dev0_stby_mode = <0x0>;
csi0_dev0_vflip = <0x0>;
csi0_dev0_hflip = <0x0>;
csi0_dev0_iovdd = <0x0>;
csi0_dev0_iovdd_vol = <0x0>;
csi0_dev0_avdd = <0x0>;
csi0_dev0_avdd_vol = <0x0>;
csi0_dev0_dvdd = <0x0>;
csi0_dev0_dvdd_vol = <0x0>;
csi0_dev0_afvdd = <0x0>;
csi0_dev0_afvdd_vol = <0x0>;
csi0_dev0_power_en;
csi0_dev0_flash_en;
csi0_dev0_flash_mode;
csi0_dev0_af_pwdn;
csi0_dev0_act_used = <0x0>;
csi0_dev0_act_name = <0x0>;
csi0_dev0_act_slave = <0x0>;
status = "disable";
usbc0@0 {
device_type = "usbc0";
compatible = "allwinner,sun50i-otg-manager";
usb_port_type = <0x1>;
usb_detect_type = <0x1>;
usb_det_vbus_gpio = <0x38 0x0 0x2 0x0 0x1 0x1 0x1>;
usb_host_init_state = <0x0>;
usb_regulator_io = "nocare";
usb_wakeup_suspend = <0x0>;
usb_luns = <0x3>;
usb_serial_unique = <0x0>;
usb_serial_number = "20080411";
rndis_wceis = <0x1>;
udc-controller@0x01c13000 {
compatible = "allwinner,sun50i-udc";
reg = <0x0 0x1c13000 0x0 0x1000 0x0 0x1c00000 0x0 0x100>;
interrupts = <0x1a>;
clocks = <0x39 0x3a>;
otghci0-controller@0x01c13000 {
compatible = "allwinner,sunxi-otghci";
hci_ctrl_no = <0x0>;
daudio@0x01c22000 {
compatible = "allwinner,sunxi-daudio";
reg = <0x0 0x1c22000 0x0 0x3c>;
clocks = <0x2 0x3b>;
pinctrl-0 = <0x3c 0x3d>;
pinctrl-1 = <0x3e>;
word_select_size = <0x20>;
pcm_sync_period = <0x10>;
pcm_lsb_first = <0x0>;
slot_width_select = <0x8>;
pcm_sync_type = <0x0>;
pcm_start_slot = <0x4>;
tx_data_mode = <0x0>;
rx_data_mode = <0x0>;
tdm_config = <0x1>;
tdm_num = <0x0>;
dmas = <0x22 0x0 0xe 0x22 0x0 0xe>;
dma-names = "rx-tx", "rx-tx";
linux,phandle = <0x46>;
phandle = <0x46>;
spdif-controller@0x01c21400 {
compatible = "allwinner,sunxi-spdif";
reg = <0x0 0x1c21400 0x0 0x38>;
clocks = <0x2 0x3f>;
pinctrl-0 = <0x40>;
pinctrl-1 = <0x41>;
dmas = <0x22 0x0 0x1 0x22 0x0 0x1>;
linux,phandle = <0x45>;
phandle = <0x45>;
codec@0x01c23c00 {
compatible = "allwinner,sunxi-internal-codec";
reg = <0x0 0x1c23c00 0x0 0x9c>;
clocks = <0x2 0x42>;
headphonevol = <0x3b>;
spkervol = <0x1b>;
maingain = <0x4>;
hp_dirused = <0x0>;
pa_sleep_time = <0x15e>;
linux,phandle = <0x44>;
phandle = <0x44>;
cpudai0-controller@0x01c23c00 {
compatible = "allwinner,sunxi-internal-cpudai";
clocks = <0x42>;
dmas = <0x22 0x0 0xc 0x22 0x0 0xc>;
linux,phandle = <0x43>;
phandle = <0x43>;
sound@0 {
compatible = "allwinner,sunxi-codec-machine";
sunxi,cpudai-controller = <0x43>;
sunxi,audio-codec = <0x44>;
hp_detect_case = <0x0>;
sound@1 {
compatible = "allwinner,sunxi-spdif-machine";
sunxi,spdif-controller = <0x45>;
sound@2 {
device_type = "sndi2scodec_conf";
compatible = "allwinner,sunxi-codec-machine-i2s";
sunxi,cpudai-controller-i2s = <0x46>;
sta33x_pwrdn_gpio = <0x38 0x4 0x7 0x0 0x1 0x1 0x1>;
sta33x_reset_gpio = <0x38 0x4 0x8 0x0 0x1 0x1 0x1>;
wifi {
device_type = "wifi_conf";
interrupts = <0x26>;
power_en;
reset_pin = <0x38 0x3 0x10 0x0 0x1 0x1 0x1>;
irq_pin = <0x38 0x3 0xd 0x0 0x6 0x1 0x1>;
power {
device_type = "power_ctrl";
usb_drvbus_down = <0x38 0x3 0xb 0x0 0x1 0x1 0x1>;
power_on = <0x38 0x3 0xf 0x0 0x1 0x1 0x1>;
gpio_keys {
compatible = "gpio-keys";
autorepeat;
button@21 {
label = "GPIO Key Power";
linux,code = <0x6c>;
gpios = <0x38 0x3 0xe 0x0 0x6 0x1 0x1>;
keyboard {
compatible = "allwinner,keyboard_2000mv";
reg = <0x0 0x1c23400 0x0 0x400>;
interrupts = <0x16>;
key_cnt = <0x6>;
key1 = <0xf8 0x73>;
key2 = <0x193 0x72>;
key3 = <0x24d 0x8b>;
key4 = <0x307 0x1c>;
key5 = <0x3c1 0x66>;
key6 = <0x4b9 0x67>;
wirelesskey@0 {
compatible = "allwinner,wireless-key";
gpio-key = <0x38 0x4 0x3 0x0 0x6 0x1 0x1>;
debounce = <0x0>;
product {
device_type = "product";
version = "100";
machine = "evb";
platform {
device_type = "platform";
eraseflag = <0x0>;
target {
device_type = "target";
boot_clock = <0x198>;
storage_type = <0x3>;
burn_key = <0x1>;
power_sply {
device_type = "power_sply";
dcdc1_vol = <0xbb8>;
dcdc2_vol = <0x4b0>;
dcdc3_vol = <0x4b0>;
dcdc4_vol = <0x4b0>;
dcdc5_vol = <0x5dc>;
aldo2_vol = <0x708>;
aldo3_vol = <0xbb8>;
card_boot {
device_type = "card_boot";
logical_start = <0xa000>;
sprite_gpio0;
pm_para {
device_type = "pm_para";
standby_mode = <0x1>;
card0_boot_para {
device_type = "card0_boot_para";
card_ctrl = <0x0>;
card_high_speed = <0x1>;
card_line = <0x4>;
pinctrl-0 = <0x47>;
card2_boot_para {
device_type = "card2_boot_para";
card_ctrl = <0x2>;
card_line = <0x8>;
pinctrl-0 = <0x48>;
twi_para {
device_type = "twi_para";
twi_port = <0x0>;
pinctrl-0 = <0x49>;
uart_para {
device_type = "uart_para";
uart_debug_port = <0x2>;
pinctrl-0 = <0x4a>;
force_uart_para {
device_type = "force_uart_para";
force_uart__port = <0x2>;
pinctrl-0 = <0x4b>;
jtag_para {
device_type = "jtag_para";
jtag_enable = <0x0>;
pinctrl-0 = <0x4c>;
dram {
device_type = "dram";
dram_clk = <0x1e0>;
dram_type = <0x3>;
dram_zq = <0x77bb>;
dram_odt_en = <0x1>;
dram_para1 = <0x4319f4>;
dram_para2 = <0x5>;
dram_mr0 = <0x620>;
dram_mr1 = <0x0>;
dram_mr2 = <0x8>;
dram_mr3 = <0x0>;
dram_tpr0 = <0x6141b10>;
dram_tpr1 = <0x40416>;
dram_tpr2 = <0x3030306>;
dram_tpr3 = <0x2006>;
dram_tpr4 = <0x5040405>;
dram_tpr5 = <0x5050302>;
dram_tpr6 = <0x90006644>;
dram_tpr7 = <0x42c21590>;
dram_tpr8 = <0xd05612c0>;
dram_tpr9 = <0x83def>;
dram_tpr10 = <0x18082356>;
dram_tpr11 = <0x32034156>;
dram_tpr12 = <0x0>;
dram_tpr13 = <0x0>;
rtp_para {
device_type = "rtp_para";
rtp_used = <0x0>;
rtp_screen_size = <0x5>;
rtp_regidity_level = <0x5>;
rtp_press_threshold_enable = <0x0>;
rtp_press_threshold = <0x1f40>;
rtp_sensitive_level = <0xf>;
rtp_exchange_x_y_flag = <0x0>;
ctp_para {
device_type = "ctp_para";
ctp_used = <0x0>;
ctp_twi_id = <0x1>;
ctp_twi_addr = <0x5d>;
ctp_screen_max_x = <0x500>;
ctp_screen_max_y = <0x320>;
ctp_revert_x_flag = <0x1>;
ctp_revert_y_flag = <0x1>;
ctp_exchange_x_y_flag = <0x1>;
ctp_int_port = <0x38 0x0 0x3 0x6 0xffffffff 0xffffffff 0xffffffff>;
ctp_wakeup = <0x38 0x0 0x2 0x1 0xffffffff 0xffffffff 0x1>;
tkey_para {
device_type = "tkey_para";
tkey_used = <0x0>;
tkey_twi_id;
tkey_twi_addr;
tkey_int;
motor_para {
device_type = "motor_para";
motor_used = <0x0>;
nand0 {
device_type = "nand0";
nand0_support_2ch = <0x0>;
pinctrl-0 = <0x55 0x56>;
nand0_regulator1 = "vcc-nand";
nand0_regulator2 = "none";
nand0_cache_level = <0x55aaaa55>;
nand0_flush_cache_num = <0x55aaaa55>;
nand0_capacity_level = <0x55aaaa55>;
nand0_id_number_ctl = <0x55aaaa55>;
nand0_print_level = <0x55aaaa55>;
nand0_p0 = <0x55aaaa55>;
nand0_p1 = <0x55aaaa55>;
nand0_p2 = <0x55aaaa55>;
nand0_p3 = <0x55aaaa55>;
disp_init {
device_type = "disp_init";
disp_init_enable = <0x0>;
disp_mode = <0x0>;
screen0_output_type = <0x1>;
screen0_output_mode = <0x4>;
screen1_output_type = <0x1>;
screen1_output_mode = <0x4>;
fb0_framebuffer_num = <0x2>;
fb0_pixel_sequence = <0x0>;
fb0_scaler_mode_enable = <0x0>;
fb0_format = <0x5>;
fb0_width = <0x320>;
fb0_height = <0x1e0>;
fb1_framebuffer_num = <0x0>;
fb1_pixel_sequence = <0x0>;
fb1_scaler_mode_enable = <0x0>;
fb1_format = <0x0>;
fb1_width = <0x0>;
fb1_height = <0x0>;
lcd0_backlight = <0x32>;
lcd1_backlight = <0x32>;
lcd0_bright = <0x32>;
lcd0_contrast = <0x32>;
lcd0_saturation = <0x39>;
lcd0_hue = <0x32>;
lcd1_bright = <0x32>;
lcd1_contrast = <0x32>;
lcd1_saturation = <0x39>;
lcd1_hue = <0x32>;
pwm0_para {
device_type = "pwm0_para";
pwm_used = <0x0>;
pinctrl-0 = <0x58>;
pwm1_para {
device_type = "pwm1_para";
pwm_used = <0x0>;
pinctrl-0 = <0x59>;
vip0 {
device_type = "vip0";
pinctrl-0 = <0x5a 0x5b>;
vip0_mname = "ov5640";
vip0_twi_addr = <0x78>;
vip0_isp_used = <0x1>;
vip0_fmt = <0x0>;
vip0_stby_mode = <0x0>;
vip0_vflip = <0x0>;
vip0_hflip = <0x0>;
vip0_iovdd = "axp22_eldo3";
vip0_iovdd_vol = <0x2ab980>;
vip0_avdd = "axp22_dldo4";
vip0_avdd_vol = <0x2ab980>;
vip0_dvdd = "axp22_eldo2";
vip0_dvdd_vol = <0x16e360>;
vip0_afvdd;
vip0_afvdd_vol = <0x2ab980>;
vip0_power_en;
vip0_reset = <0x38 0x4 0x10 0x1 0x0 0x1 0x0>;
vip0_pwdn = <0x38 0x4 0x11 0x1 0x0 0x1 0x0>;
vip0_flash_en;
vip0_flash_mode;
vip0_af_pwdn;
tvout_para {
device_type = "tvout_para";
tvout_used;
tvout_channel_num;
tv_en;
tvin_para {
device_type = "tvin_para";
tvin_used;
tvin_channel_num;
di {
device_type = "di";
smc {
device_type = "smc";
smc_used;
smc_rst;
smc_vppen;
smc_vppp;
smc_det;
smc_vccen;
smc_sck;
smc_sda;
gsensor_para {
device_type = "gsensor_para";
gsensor_used = <0x0>;
gsensor_twi_id = <0x2>;
gsensor_twi_addr = <0x18>;
gsensor_int1 = <0x38 0x0 0x9 0x6 0x1 0xffffffff 0xffffffff>;
gsensor_int2;
gps_para {
device_type = "gps_para";
wifi_para {
device_type = "wifi_para";
wifi_used = <0x0>;
wifi_sdc_id = <0x1>;
wifi_usbc_id = <0x1>;
wifi_usbc_type = <0x1>;
wifi_mod_sel = <0x3>;
wifi_power = "axp22_aldo1";
gy_para {
device_type = "gy_para";
gy_used = <0x0>;
gy_twi_id = <0x2>;
gy_twi_addr = <0x6a>;
gy_int1 = <0x38 0x0 0xa 0x6 0x1 0xffffffff 0xffffffff>;
gy_int2;
ls_para {
device_type = "ls_para";
ls_used = <0x0>;
ls_twi_id = <0x2>;
ls_twi_addr = <0x23>;
ls_int = <0x38 0x0 0xc 0x6 0x1 0xffffffff 0xffffffff>;
compass_para {
device_type = "compass_para";
compass_used = <0x0>;
compass_twi_id = <0x2>;
compass_twi_addr = <0xd>;
compass_int = <0x38 0x0 0xb 0x6 0x1 0xffffffff 0xffffffff>;
bt_para {
device_type = "bt_para";
bt_used;
bt_uart_id;
bt_wakeup;
bt_gpio;
bt_rst;
audiospdif {
device_type = "audiospdif";
spdif_machine {
device_type = "spdif_machine";
audiohdmi {
device_type = "audiohdmi";
hdmi_machine {
device_type = "hdmi_machine";
pmu0 {
device_type = "pmu0";
pmu_id = <0x6>;
pmu_twi_addr = <0x34>;
pmu_twi_id = <0x1>;
pmu_irq_id = <0x0>;
pmu_chg_ic_temp = <0x0>;
pmu_battery_rdc = <0x64>;
pmu_battery_cap = <0x0>;
pmu_runtime_chgcur = <0x1c2>;
pmu_suspend_chgcur = <0x5dc>;
pmu_shutdown_chgcur = <0x5dc>;
pmu_init_chgvol = <0x1068>;
pmu_ac_vol = <0xfa0>;
pmu_ac_cur = <0x0>;
pmu_usbpc_vol = <0x1130>;
pmu_usbpc_cur = <0x1f4>;
pmu_battery_warning_level1 = <0xf>;
pmu_battery_warning_level2 = <0x0>;
pmu_chgled_func = <0x0>;
pmu_chgled_type = <0x0>;
pmu_bat_para1 = <0x0>;
pmu_bat_para2 = <0x0>;
pmu_bat_para3 = <0x0>;
pmu_bat_para4 = <0x0>;
pmu_bat_para5 = <0x0>;
pmu_bat_para6 = <0x0>;
pmu_bat_para7 = <0x0>;
pmu_bat_para8 = <0x0>;
pmu_bat_para9 = <0x5>;
pmu_bat_para10 = <0x8>;
pmu_bat_para11 = <0x9>;
pmu_bat_para12 = <0xa>;
pmu_bat_para13 = <0xd>;
pmu_bat_para14 = <0x10>;
pmu_bat_para15 = <0x14>;
pmu_bat_para16 = <0x21>;
pmu_bat_para17 = <0x29>;
pmu_bat_para18 = <0x2e>;
pmu_bat_para19 = <0x32>;
pmu_bat_para20 = <0x35>;
pmu_bat_para21 = <0x39>;
pmu_bat_para22 = <0x3d>;
pmu_bat_para23 = <0x43>;
pmu_bat_para24 = <0x49>;
pmu_bat_para25 = <0x4e>;
pmu_bat_para26 = <0x54>;
pmu_bat_para27 = <0x58>;
pmu_bat_para28 = <0x5c>;
pmu_bat_para29 = <0x5d>;
pmu_bat_para30 = <0x5e>;
pmu_bat_para31 = <0x5f>;
pmu_bat_para32 = <0x64>;
pmu_bat_temp_enable = <0x0>;
pmu_bat_charge_ltf = <0x8d5>;
pmu_bat_charge_htf = <0x184>;
pmu_bat_shutdown_ltf = <0xc80>;
pmu_bat_shutdown_htf = <0xed>;
pmu_bat_temp_para1 = <0x1d2a>;
pmu_bat_temp_para2 = <0x1180>;
pmu_bat_temp_para3 = <0xdbe>;
pmu_bat_temp_para4 = <0xae2>;
pmu_bat_temp_para5 = <0x8af>;
pmu_bat_temp_para6 = <0x6fc>;
pmu_bat_temp_para7 = <0x5a8>;
pmu_bat_temp_para8 = <0x3c9>;
pmu_bat_temp_para9 = <0x298>;
pmu_bat_temp_para10 = <0x1d2>;
pmu_bat_temp_para11 = <0x189>;
pmu_bat_temp_para12 = <0x14d>;
pmu_bat_temp_para13 = <0x11b>;
pmu_bat_temp_para14 = <0xf2>;
pmu_bat_temp_para15 = <0xb3>;
pmu_bat_temp_para16 = <0x86>;
pmu_powkey_off_time = <0x1770>;
pmu_powkey_off_func = <0x0>;
pmu_powkey_off_en = <0x1>;
pmu_powkey_long_time = <0x5dc>;
pmu_powkey_on_time = <0x3e8>;
pmu0_regu {
device_type = "pmu0_regu";
regulator_count = <0x17>;
regulator1 = "axp28_rtc";
regulator2 = "axp28_aldo1";
regulator3 = "axp28_aldo2";
regulator4 = "axp28_aldo3";
regulator5 = "axp28_dldo1";
regulator6 = "axp28_dldo2";
regulator7 = "axp28_dldo3";
regulator8 = "axp28_dldo4";
regulator9 = "axp28_eldo1";
regulator0 = "axp28_eldo2";
regulator11 = "axp28_eldo3";
regulator12 = "axp28_fldo1";
regulator13 = "axp28_fldo2";
regulator14 = "axp28_dcdc1";
regulator15 = "axp28_dcdc2";
regulator16 = "axp28_dcdc3";
regulator17 = "axp28_dcdc4";
regulator18 = "axp28_dcdc5";
regulator19 = "axp28_dcdc6";
regulator20 = "axp28_dcdc7";
regulator21 = "axp28_gpio0ldo";
regulator22 = "axp28_gpio1ldo";
dvfs_table {
device_type = "dvfs_table";
max_freq = <0x47868c00>;
min_freq = <0x1c9c3800>;
LV_count = <0x8>;
LV1_freq = <0x5b8d8000>;
LV1_volt = <0x5dc>;
LV2_freq = <0x501bd000>;
LV2_volt = <0x5b4>;
LV3_freq = <0x47868c00>;
LV3_volt = <0x528>;
LV4_freq = <0x3c14dc00>;
LV4_volt = <0x4b0>;
LV5_freq = <0x30a32c00>;
LV5_volt = <0x44c>;
LV6_freq = <0x269fb200>;
LV6_volt = <0x410>;
LV7_freq = <0x0>;
LV7_volt = <0x410>;
LV8_freq = <0x0>;
LV8_volt = <0x410>;
Vdevice {
device_type = "Vdevice";
pinctrl-0 = <0x5e>;
aliases {
serial0 = "/soc/uart@01c25000";
serial1 = "/soc/uart@01c25400";
serial2 = "/soc/uart@01c25800";
twi0 = "/soc/twi@0x01c27000";
twi1 = "/soc/twi@0x01c27400";
twi2 = "/soc/twi@0x01c27800";
spi0 = "/soc/spi@01c05000";
spi1 = "/soc/spi@01c06000";
mmc0 = "/soc/sdmmc@01c0f000";
mmc1 = "/soc/sdmmc@01c10000";
global_timer0 = "/soc/timer@1c20c00";
csi_res0 = "/soc/csi_res@0x01cb0000";
vfe0 = "/soc/vfe@0";
disp = "/soc/disp@0x01e00000";
lcd0 = "/soc/lcd0@01c0c000";
chosen {
bootargs = "earlyprintk=sunxi-uart,0x01c25000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init";
linux,initrd-start = <0x0 0x0>;
linux,initrd-end = <0x0 0x0>;
cpus {
cpu@0 {
device_type = "cpu";
compatible = "arm,arm926ejs";
reg = <0x0>;
sram_ctrl {
device_type = "sram_ctrl";
compatible = "allwinner,sram_ctrl";
reg = <0x0 0x1c00000 0x0 0x100>;
ion {
compatible = "allwinner,sunxi-ion";
system {
type = <0x0>;
system_contig {
type = <0x1>;
carveout {
type = <0x2>;
base = <0x81c00000>;
size = <0x400000>;
cma {
type = <0x4>;
memory@80000000 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x2000000>;
interrupt-controller@01c20400 {
compatible = "allwinner,suniv-intc";
#interrupt-cells = <0x1>;
#address-cells = <0x0>;
device_type = "intc";
reg = <0x0 0x1c20400 0x0 0x400>;
linux,phandle = <0x1>;
phandle = <0x1>;
watchdog@01c20ca0 {
compatible = "allwinner,sun8i-wdt";
reg = <0x0 0x1c20ca0 0x0 0x18>;
最近编辑记录 Sam (2022-03-17 17:28:55)
修改了BSP linux-3.10/arch/arm/include/debug/sunxi.S 33行
#elif defined(CONFIG_DEBUG_SUNXI_UART2)
#ifdef CONFIG_ARCH_SUNIVW1
#define SUNXI_UART_DEBUG_PHYS_BASE 0x01c25800
#define SUNXI_UART_DEBUG_VIRT_BASE 0xf1c25800
#else
#define SUNXI_UART_DEBUG_PHYS_BASE 0x01c28800
#define SUNXI_UART_DEBUG_VIRT_BASE 0xf1c28800
直接修改 .config文件
# CONFIG_DEBUG_SUNXI_UART0 is not set
# CONFIG_DEBUG_SUNXI_UART1 is not set
CONFIG_DEBUG_SUNXI_UART2=y
bsp 根目录下 编译
./build.sh
编译后.config 自动重新回到以前的状态
CONFIG_DEBUG_SUNXI_UART0=y
求解???
@Sam UBOOT 下的dts 文件
/dts-v1/;
#include "suniv-f1c100s.dtsi"
"allwinner,suniv";
aliases {
serial2 = &uart2;
spi0 = &spi0;
chosen {
stdout-path = "serial2:115200n8";
&otg_sram {
&spi0 {
pinctrl-0 = <&spi0_pins_a>;
flash@0 {
#address-cells = <1>;
#size-cells = <1>;
reg = <0>;
&uart2 {
pinctrl-0 = <&uart2_pins_e>;
&usb_otg {
dr_mode = "otg";
&usbphy {
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
#size-cells = <1>;
ranges;
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
fake100M: clk-100M {
#clock-cells = <0>;
clock-frequency = <100000000>;
clock-output-names = "fake-100M";
cpus {
#address-cells = <0>;
#size-cells = <0>;
cpu {
soc {
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,sun4i-a10-sram-controller";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
reg = <0x0000 0x1000>;
spi0: spi@1c05000 {
"allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <10>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
#size-cells = <0>;
ccu: clock@1c20000 {
compatible = "allwinner,suniv-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-ic";
reg = <0x01c20400 0x400>;
#interrupt-cells = <1>;
gpio-controller;
#gpio-cells = <3>;
function = "spi0";
uart2_pins_e: uart-pins-pe {
function = "uart2";
timer@1c20c00 {
compatible = "allwinner,sun4i-a10-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
wdt: watchdog@1c20ca0 {
reg = <0x01c20ca0 0x20>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
usb_otg: usb@1c13000 {
reg = <0x01c13000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <26>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c13400 {
reg = <0x01c13400 0x10>;
reg-names = "phy_ctrl";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
.config 文件
# U-Boot 2018.01 Configuration
CONFIG_CREATE_ARCH_SYMLINK=y
# CONFIG_ARC is not set
CONFIG_ARM=y
# CONFIG_M68K is not set
# CONFIG_MICROBLAZE is not set
# CONFIG_MIPS is not set
# CONFIG_NDS32 is not set
# CONFIG_NIOS2 is not set
# CONFIG_PPC is not set
# CONFIG_SANDBOX is not set
# CONFIG_SH is not set
# CONFIG_X86 is not set
# CONFIG_XTENSA is not set
CONFIG_SYS_ARCH="arm"
CONFIG_SYS_CPU="arm926ejs"
CONFIG_SYS_SOC="sunxi"
CONFIG_SYS_BOARD="sunxi"
CONFIG_SYS_CONFIG_NAME="suniv"
# ARM architecture
CONFIG_ARM_ASM_UNIFIED=y
CONFIG_CPU_ARM926EJS=y
CONFIG_SYS_ARM_ARCH=5
CONFIG_SYS_CACHE_SHIFT_5=y
CONFIG_SYS_CACHELINE_SIZE=32
# CONFIG_SEMIHOSTING is not set
CONFIG_SYS_THUMB_BUILD=y
CONFIG_SPL_SYS_THUMB_BUILD=y
# CONFIG_SYS_L2CACHE_OFF is not set
# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
# CONFIG_ARM_CORTEX_CPU_IS_UP is not set
CONFIG_USE_ARCH_MEMCPY=y
CONFIG_SPL_USE_ARCH_MEMCPY=y
CONFIG_USE_ARCH_MEMSET=y
CONFIG_SPL_USE_ARCH_MEMSET=y
# CONFIG_ARM64_SUPPORT_AARCH32 is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_TARGET_EDB93XX is not set
# CONFIG_TARGET_ASPENITE is not set
# CONFIG_TARGET_GPLUGD is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_KIRKWOOD is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_TARGET_DEVKIT3250 is not set
# CONFIG_TARGET_WORK_92105 is not set
# CONFIG_TARGET_APF27 is not set
# CONFIG_TARGET_APX4DEVKIT is not set
# CONFIG_TARGET_XFI3 is not set
# CONFIG_TARGET_M28EVK is not set
# CONFIG_TARGET_MX23EVK is not set
# CONFIG_TARGET_MX28EVK is not set
# CONFIG_TARGET_MX23_OLINUXINO is not set
# CONFIG_TARGET_BG0900 is not set
# CONFIG_TARGET_SANSA_FUZE_PLUS is not set
# CONFIG_TARGET_SC_SPS_1 is not set
# CONFIG_ORION5X is not set
# CONFIG_TARGET_SPEAR300 is not set
# CONFIG_TARGET_SPEAR310 is not set
# CONFIG_TARGET_SPEAR320 is not set
# CONFIG_TARGET_SPEAR600 is not set
# CONFIG_TARGET_STV0991 is not set
# CONFIG_TARGET_X600 is not set
# CONFIG_TARGET_IMX31_PHYCORE is not set
# CONFIG_TARGET_IMX31_PHYCORE_EET is not set
# CONFIG_TARGET_MX31ADS is not set
# CONFIG_TARGET_MX31PDK is not set
# CONFIG_TARGET_WOODBURN is not set
# CONFIG_TARGET_WOODBURN_SD is not set
# CONFIG_TARGET_FLEA3 is not set
# CONFIG_TARGET_MX35PDK is not set
# CONFIG_ARCH_BCM283X is not set
# CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
# CONFIG_TARGET_VEXPRESS_CA5X2 is not set
# CONFIG_TARGET_VEXPRESS_CA9X4 is not set
# CONFIG_TARGET_BCM23550_W1D is not set
# CONFIG_TARGET_BCM28155_AP is not set
# CONFIG_TARGET_BCMCYGNUS is not set
# CONFIG_TARGET_BCMNSP is not set
# CONFIG_TARGET_BCMNS2 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_S5PC1XX is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_OMAP2PLUS is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MX25 is not set
# CONFIG_ARCH_MX7ULP is not set
# CONFIG_ARCH_MX7 is not set
# CONFIG_ARCH_MX6 is not set
CONFIG_SPL_LDSCRIPT="arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds"
# CONFIG_ARCH_MX5 is not set
# CONFIG_ARCH_QEMU is not set
# CONFIG_ARCH_RMOBILE is not set
# CONFIG_TARGET_S32V234EVB is not set
# CONFIG_ARCH_SNAPDRAGON is not set
# CONFIG_ARCH_SOCFPGA is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_TARGET_TS4600 is not set
# CONFIG_ARCH_VF610 is not set
# CONFIG_ARCH_ZYNQ is not set
# CONFIG_ARCH_ZYNQMP is not set
# CONFIG_TEGRA is not set
# CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM is not set
# CONFIG_TARGET_VEXPRESS64_JUNO is not set
# CONFIG_TARGET_LS2080A_EMU is not set
# CONFIG_TARGET_LS2080A_SIMU is not set
# CONFIG_TARGET_LS1088AQDS is not set
# CONFIG_TARGET_LS2080AQDS is not set
# CONFIG_TARGET_LS2080ARDB is not set
# CONFIG_TARGET_LS2081ARDB is not set
# CONFIG_TARGET_HIKEY is not set
# CONFIG_TARGET_POPLAR is not set
# CONFIG_TARGET_LS1012AQDS is not set
# CONFIG_TARGET_LS1012ARDB is not set
# CONFIG_TARGET_LS1012AFRDM is not set
# CONFIG_TARGET_LS1088ARDB is not set
# CONFIG_TARGET_LS1021AQDS is not set
# CONFIG_TARGET_LS1021ATWR is not set
# CONFIG_TARGET_LS1021AIOT is not set
# CONFIG_TARGET_LS1043AQDS is not set
# CONFIG_TARGET_LS1043ARDB is not set
# CONFIG_TARGET_LS1046AQDS is not set
# CONFIG_TARGET_LS1046ARDB is not set
# CONFIG_TARGET_H2200 is not set
# CONFIG_TARGET_ZIPITZ2 is not set
# CONFIG_TARGET_COLIBRI_PXA270 is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_STM32 is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_TARGET_THUNDERX_88XX is not set
# CONFIG_ARCH_ASPEED is not set
CONFIG_SPL_GPIO_SUPPORT=y
CONFIG_SPL_LIBCOMMON_SUPPORT=y
CONFIG_SPL_LIBGENERIC_SUPPORT=y
CONFIG_SYS_MALLOC_F_LEN=0x400
CONFIG_CONS_INDEX=2
CONFIG_SPL_MMC_SUPPORT=y
CONFIG_SPL_SERIAL_SUPPORT=y
# CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
CONFIG_ENV_SIZE=0x8000
CONFIG_ENV_OFFSET=0xf8000
CONFIG_SPL_LIBDISK_SUPPORT=y
# CONFIG_SPL_NAND_SUPPORT is not set
# CONFIG_SPL_SPI_FLASH_SUPPORT is not set
# CONFIG_SPL_SPI_SUPPORT is not set
# CONFIG_SPL_WATCHDOG_SUPPORT is not set
CONFIG_IDENT_STRING=" Allwinner Technology"
# CONFIG_SUNXI_HIGH_SRAM is not set
CONFIG_SUNXI_GEN_SUN6I=y
CONFIG_MACH_SUNIV=y
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
# CONFIG_MACH_SUN8I_A23 is not set
# CONFIG_MACH_SUN8I_A33 is not set
# CONFIG_MACH_SUN8I_A83T is not set
# CONFIG_MACH_SUN8I_H3 is not set
# CONFIG_MACH_SUN8I_R40 is not set
# CONFIG_MACH_SUN8I_V3S is not set
# CONFIG_MACH_SUN9I is not set
# CONFIG_MACH_SUN50I is not set
# CONFIG_MACH_SUN50I_H5 is not set
# CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER is not set
CONFIG_DRAM_CLK=156
CONFIG_DRAM_ZQ=0
# CONFIG_DRAM_ODT_EN is not set
CONFIG_SYS_CLK_FREQ=408000000
# CONFIG_UART0_PORT_F is not set
# CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set
CONFIG_MACPWR=""
CONFIG_MMC0_CD_PIN=""
CONFIG_MMC1_CD_PIN=""
CONFIG_MMC2_CD_PIN=""
CONFIG_MMC3_CD_PIN=""
CONFIG_MMC1_PINS=""
CONFIG_MMC2_PINS=""
CONFIG_MMC3_PINS=""
CONFIG_MMC_SUNXI_SLOT_EXTRA=-1
CONFIG_INITIAL_USB_SCAN_DELAY=0
CONFIG_USB0_VBUS_PIN=""
CONFIG_USB0_VBUS_DET=""
CONFIG_USB0_ID_DET=""
CONFIG_USB1_VBUS_PIN=""
CONFIG_USB2_VBUS_PIN=""
CONFIG_USB3_VBUS_PIN=""
# CONFIG_I2C0_ENABLE is not set
# CONFIG_I2C1_ENABLE is not set
# CONFIG_I2C2_ENABLE is not set
# CONFIG_R_I2C_ENABLE is not set
# CONFIG_AXP_GPIO is not set
# CONFIG_VIDEO_SUNXI is not set
# CONFIG_SUNXI_DE2 is not set
CONFIG_SATAPWR=""
CONFIG_GMAC_TX_DELAY=0
CONFIG_SPL_STACK_R_ADDR=0x81e00000
# CONFIG_SPL_FAT_SUPPORT is not set
# CONFIG_CMD_DEKBLOB is not set
# CONFIG_CMD_HDMIDETECT is not set
# ARM debug
# CONFIG_DEBUG_LL is not set
CONFIG_DEFAULT_DEVICE_TREE="suniv-f1c100s-licheepi-nano"
CONFIG_SMBIOS_PRODUCT_NAME="sunxi"
# CONFIG_DEBUG_UART is not set
# CONFIG_AHCI is not set
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_DISTRO_DEFAULTS=y
CONFIG_SYS_MALLOC_F=y
CONFIG_SPL_SYS_MALLOC_F_LEN=0x400
CONFIG_TPL_SYS_MALLOC_F_LEN=0x400
CONFIG_EXPERT=y
CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
# CONFIG_TOOLS_DEBUG is not set
# CONFIG_PHYS_64BIT is not set
# Boot images
# CONFIG_ANDROID_BOOT_IMAGE is not set
# CONFIG_FIT is not set
CONFIG_OF_BOARD_SETUP=y
# CONFIG_OF_SYSTEM_SETUP is not set
# CONFIG_OF_STDOUT_VIA_ALIAS is not set
CONFIG_SYS_EXTRA_OPTIONS=""
CONFIG_ARCH_FIXUP_FDT_MEMORY=y
# API
# CONFIG_API is not set
# Boot timing
# CONFIG_BOOTSTAGE is not set
CONFIG_BOOTSTAGE_RECORD_COUNT=30
CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5
CONFIG_BOOTSTAGE_STASH_ADDR=0
CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
# Boot media
# CONFIG_NAND_BOOT is not set
# CONFIG_ONENAND_BOOT is not set
# CONFIG_QSPI_BOOT is not set
# CONFIG_SATA_BOOT is not set
# CONFIG_SD_BOOT is not set
# CONFIG_SPI_BOOT is not set
CONFIG_BOOTDELAY=2
CONFIG_USE_BOOTARGS=y
CONFIG_BOOTARGS="console=ttyS2,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2"
CONFIG_USE_BOOTCOMMAND=y
CONFIG_BOOTCOMMAND="sf probe 0 50000000; sf read 0x80C00000 0x100000 0x4000; sf read 0x80008000 0x110000 0x400000; bootz 0x80008000 - 0x80C00000"
# Console
CONFIG_MENU=y
# CONFIG_CONSOLE_RECORD is not set
CONFIG_LOGLEVEL=4
CONFIG_SPL_LOGLEVEL=4
# CONFIG_SILENT_CONSOLE is not set
CONFIG_PRE_CONSOLE_BUFFER=y
CONFIG_PRE_CON_BUF_SZ=4096
CONFIG_PRE_CON_BUF_ADDR=0x4f000000
# CONFIG_CONSOLE_MUX is not set
# CONFIG_SYS_CONSOLE_IS_IN_ENV is not set
# CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
# CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
# CONFIG_SYS_CONSOLE_INFO_QUIET is not set
CONFIG_SYS_STDIO_DEREGISTER=y
# Logging
CONFIG_LOG=y
# CONFIG_SPL_LOG is not set
CONFIG_LOG_MAX_LEVEL=5
CONFIG_LOG_CONSOLE=y
# CONFIG_LOG_TEST is not set
CONFIG_DEFAULT_FDT_FILE=""
# CONFIG_VERSION_VARIABLE is not set
CONFIG_DISPLAY_CPUINFO=y
CONFIG_DISPLAY_BOARDINFO=y
# Start-up hooks
# CONFIG_ARCH_EARLY_INIT_R is not set
# CONFIG_ARCH_MISC_INIT is not set
# CONFIG_BOARD_EARLY_INIT_F is not set
# Security support
# SPL / TPL
CONFIG_SUPPORT_SPL=y
CONFIG_SPL=y
# CONFIG_SPL_BOARD_INIT is not set
# CONFIG_SPL_BOOTROM_SUPPORT is not set
CONFIG_SPL_RAW_IMAGE_SUPPORT=y
CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
CONFIG_SPL_SYS_MALLOC_SIMPLE=y
# CONFIG_TPL_SYS_MALLOC_SIMPLE is not set
CONFIG_SPL_STACK_R=y
CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
# CONFIG_SPL_SEPARATE_BSS is not set
# CONFIG_SPL_DISPLAY_PRINT is not set
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x50
# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
# CONFIG_SPL_CPU_SUPPORT is not set
# CONFIG_SPL_CRYPTO_SUPPORT is not set
# CONFIG_SPL_HASH_SUPPORT is not set
# CONFIG_SPL_DMA_SUPPORT is not set
# CONFIG_SPL_ENV_SUPPORT is not set
# CONFIG_SPL_EXT_SUPPORT is not set
# CONFIG_SPL_FPGA_SUPPORT is not set
# CONFIG_SPL_I2C_SUPPORT is not set
# CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
# CONFIG_SPL_MTD_SUPPORT is not set
# CONFIG_SPL_MUSB_NEW_SUPPORT is not set
# CONFIG_SPL_NET_SUPPORT is not set
# CONFIG_SPL_NO_CPU_SUPPORT is not set
# CONFIG_SPL_NOR_SUPPORT is not set
# CONFIG_SPL_XIP_SUPPORT is not set
# CONFIG_SPL_ONENAND_SUPPORT is not set
# CONFIG_SPL_OS_BOOT is not set
# CONFIG_SPL_PCI_SUPPORT is not set
# CONFIG_SPL_PCH_SUPPORT is not set
# CONFIG_SPL_POST_MEM_SUPPORT is not set
CONFIG_SPL_POWER_SUPPORT=y
# CONFIG_SPL_RAM_SUPPORT is not set
# CONFIG_SPL_RTC_SUPPORT is not set
# CONFIG_SPL_SATA_SUPPORT is not set
# CONFIG_SPL_THERMAL is not set
# CONFIG_SPL_USB_HOST_SUPPORT is not set
# CONFIG_SPL_USB_GADGET_SUPPORT is not set
# CONFIG_SPL_YMODEM_SUPPORT is not set
# Command line interface
CONFIG_CMDLINE=y
CONFIG_HUSH_PARSER=y
CONFIG_SYS_PROMPT="=> "
# Autoboot options
CONFIG_AUTOBOOT=y
# CONFIG_AUTOBOOT_KEYED is not set
# FASTBOOT
# CONFIG_FASTBOOT is not set
# Commands
# Info commands
CONFIG_CMD_BDI=y
# CONFIG_CMD_CONFIG is not set
CONFIG_CMD_CONSOLE=y
# CONFIG_CMD_CPU is not set
# CONFIG_CMD_LICENSE is not set
# Boot commands
CONFIG_CMD_BOOTD=y
CONFIG_CMD_BOOTM=y
CONFIG_CMD_BOOTZ=y
CONFIG_CMD_BOOTEFI=y
CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
# CONFIG_CMD_BOOTEFI_HELLO is not set
# CONFIG_CMD_BOOTEFI_SELFTEST is not set
# CONFIG_CMD_BOOTMENU is not set
CONFIG_CMD_ELF=y
CONFIG_CMD_FDT=y
CONFIG_CMD_GO=y
CONFIG_CMD_RUN=y
CONFIG_CMD_IMI=y
# CONFIG_CMD_IMLS is not set
CONFIG_CMD_XIMG=y
# CONFIG_CMD_POWEROFF is not set
# CONFIG_CMD_SPL is not set
# CONFIG_CMD_THOR_DOWNLOAD is not set
# CONFIG_CMD_ZBOOT is not set
# Environment commands
# CONFIG_CMD_ASKENV is not set
CONFIG_CMD_EXPORTENV=y
CONFIG_CMD_IMPORTENV=y
CONFIG_CMD_EDITENV=y
# CONFIG_CMD_GREPENV is not set
CONFIG_CMD_SAVEENV=y
CONFIG_CMD_ENV_EXISTS=y
# CONFIG_CMD_ENV_CALLBACK is not set
# CONFIG_CMD_ENV_FLAGS is not set
# Memory commands
# CONFIG_CMD_CRC32 is not set
# CONFIG_CMD_EEPROM is not set
# CONFIG_LOOPW is not set
# CONFIG_CMD_MD5SUM is not set
# CONFIG_CMD_MEMINFO is not set
CONFIG_CMD_MEMORY=y
# CONFIG_CMD_MEMTEST is not set
# CONFIG_CMD_MX_CYCLIC is not set
# CONFIG_CMD_SHA1SUM is not set
# CONFIG_CMD_STRINGS is not set
# Compression commands
# CONFIG_CMD_LZMADEC is not set
# CONFIG_CMD_UNZIP is not set
# CONFIG_CMD_ZIP is not set
# Device access commands
# CONFIG_CMD_ARMFLASH is not set
# CONFIG_CMD_CLK is not set
# CONFIG_CMD_DEMO is not set
# CONFIG_CMD_DFU is not set
CONFIG_CMD_DM=y
# CONFIG_CMD_FDC is not set
# CONFIG_CMD_FLASH is not set
# CONFIG_CMD_FPGA is not set
# CONFIG_CMD_FPGAD is not set
# CONFIG_CMD_FUSE is not set
CONFIG_CMD_GPIO=y
CONFIG_CMD_GPT=y
CONFIG_RANDOM_UUID=y
# CONFIG_CMD_GPT_RENAME is not set
# CONFIG_CMD_IDE is not set
# CONFIG_CMD_IO is not set
# CONFIG_CMD_IOTRACE is not set
# CONFIG_CMD_I2C is not set
CONFIG_CMD_LOADB=y
CONFIG_CMD_LOADS=y
CONFIG_CMD_MMC=y
# CONFIG_CMD_NAND is not set
# CONFIG_CMD_MMC_SPI is not set
# CONFIG_CMD_ONENAND is not set
CONFIG_CMD_PART=y
# CONFIG_CMD_PCI is not set
# CONFIG_CMD_PCMCIA is not set
# CONFIG_CMD_READ is not set
# CONFIG_CMD_SATA is not set
# CONFIG_CMD_SAVES is not set
# CONFIG_CMD_SDRAM is not set
CONFIG_CMD_SF=y
# CONFIG_CMD_SF_TEST is not set
CONFIG_CMD_SPI=y
# CONFIG_CMD_TSI148 is not set
# CONFIG_CMD_UNIVERSE is not set
CONFIG_CMD_USB=y
# CONFIG_CMD_USB_SDP is not set
# CONFIG_CMD_USB_MASS_STORAGE is not set
# Shell scripting commands
CONFIG_CMD_ECHO=y
CONFIG_CMD_ITEST=y
CONFIG_CMD_SOURCE=y
CONFIG_CMD_SETEXPR=y
# Network commands
CONFIG_CMD_NET=y
# CONFIG_CMD_TFTPPUT is not set
# CONFIG_CMD_TFTPSRV is not set
# CONFIG_CMD_RARP is not set
CONFIG_CMD_DHCP=y
CONFIG_CMD_PXE=y
CONFIG_CMD_NFS=y
CONFIG_CMD_MII=y
CONFIG_CMD_PING=y
# CONFIG_CMD_CDP is not set
# CONFIG_CMD_SNTP is not set
# CONFIG_CMD_DNS is not set
# CONFIG_CMD_LINK_LOCAL is not set
# CONFIG_CMD_ETHSW is not set
# Misc commands
# CONFIG_CMD_BSP is not set
# CONFIG_CMD_BKOPS_ENABLE is not set
# CONFIG_CMD_CACHE is not set
# CONFIG_CMD_DISPLAY is not set
# CONFIG_CMD_LED is not set
# CONFIG_CMD_DATE is not set
# CONFIG_CMD_TIME is not set
# CONFIG_CMD_GETTIME is not set
# CONFIG_CMD_MISC is not set
# CONFIG_CMD_TIMER is not set
# CONFIG_CMD_QFW is not set
# CONFIG_CMD_TERMINAL is not set
# CONFIG_CMD_UUID is not set
# Power commands
# Security commands
# CONFIG_CMD_AES is not set
# CONFIG_CMD_BLOB is not set
# CONFIG_CMD_HASH is not set
# Firmware commands
# Filesystem commands
# CONFIG_CMD_BTRFS is not set
CONFIG_CMD_EXT2=y
CONFIG_CMD_EXT4=y
# CONFIG_CMD_EXT4_WRITE is not set
CONFIG_CMD_FAT=y
CONFIG_CMD_FS_GENERIC=y
# CONFIG_CMD_FS_UUID is not set
# CONFIG_CMD_JFFS2 is not set
# CONFIG_CMD_MTDPARTS is not set
# CONFIG_CMD_REISER is not set
# CONFIG_CMD_SCSI is not set
# CONFIG_CMD_ZFS is not set
# Debug commands
# CONFIG_CMD_BEDBUG is not set
# CONFIG_CMD_DIAG is not set
# CONFIG_CMD_KGDB is not set
# CONFIG_CMD_LOG is not set
# CONFIG_CMD_TRACE is not set
# CONFIG_CMD_UBI is not set
# Partition Types
CONFIG_PARTITIONS=y
# CONFIG_MAC_PARTITION is not set
# CONFIG_SPL_MAC_PARTITION is not set
CONFIG_DOS_PARTITION=y
CONFIG_SPL_DOS_PARTITION=y
CONFIG_ISO_PARTITION=y
CONFIG_SPL_ISO_PARTITION=y
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_SPL_AMIGA_PARTITION is not set
CONFIG_EFI_PARTITION=y
CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=56
CONFIG_EFI_PARTITION_ENTRIES_OFF=0
CONFIG_SPL_EFI_PARTITION=y
CONFIG_PARTITION_UUIDS=y
CONFIG_SPL_PARTITION_UUIDS=y
# CONFIG_PARTITION_TYPE_GUID is not set
CONFIG_SUPPORT_OF_CONTROL=y
CONFIG_DTC=y
CONFIG_PYLIBFDT=y
CONFIG_DTOC=y
CONFIG_BINMAN=y
# Device Tree Control
CONFIG_OF_CONTROL=y
# CONFIG_OF_BOARD_FIXUP is not set
# CONFIG_SPL_OF_CONTROL is not set
# CONFIG_OF_LIVE is not set
CONFIG_OF_SEPARATE=y
# CONFIG_OF_EMBED is not set
# CONFIG_OF_BOARD is not set
# CONFIG_MULTI_DTB_FIT is not set
CONFIG_MKIMAGE_DTC_PATH="dtc"
# Environment
# CONFIG_ENV_IS_NOWHERE is not set
# CONFIG_ENV_IS_IN_EEPROM is not set
# CONFIG_ENV_IS_IN_FAT is not set
# CONFIG_ENV_IS_IN_FLASH is not set
# CONFIG_ENV_IS_IN_MMC is not set
# CONFIG_ENV_IS_IN_NAND is not set
# CONFIG_ENV_IS_IN_NVRAM is not set
# CONFIG_ENV_IS_IN_ONENAND is not set
# CONFIG_ENV_IS_IN_REMOTE is not set
CONFIG_ENV_IS_IN_SPI_FLASH=y
# CONFIG_ENV_IS_IN_UBI is not set
CONFIG_NET=y
# CONFIG_NET_RANDOM_ETHADDR is not set
# CONFIG_NETCONSOLE is not set
CONFIG_NET_TFTP_VARS=y
CONFIG_BOOTP_PXE_CLIENTARCH=0x15
CONFIG_BOOTP_VCI_STRING="U-Boot.arm"
# Device Drivers
# Generic Driver Options
CONFIG_DM=y
# CONFIG_SPL_DM is not set
CONFIG_DM_WARN=y
# CONFIG_DM_DEBUG is not set
CONFIG_DM_DEVICE_REMOVE=y
CONFIG_DM_STDIO=y
CONFIG_DM_SEQ_ALIAS=y
# CONFIG_SPL_DM_SEQ_ALIAS is not set
# CONFIG_REGMAP is not set
# CONFIG_DEVRES is not set
CONFIG_SIMPLE_BUS=y
CONFIG_OF_TRANSLATE=y
CONFIG_DM_DEV_READ_INLINE=y
# CONFIG_ADC is not set
# CONFIG_ADC_EXYNOS is not set
# CONFIG_ADC_SANDBOX is not set
# CONFIG_SARADC_ROCKCHIP is not set
# CONFIG_SATA is not set
# CONFIG_SCSI_AHCI is not set
# SATA/SCSI device support
# CONFIG_DWC_AHSATA is not set
# CONFIG_FSL_SATA is not set
# CONFIG_MVSATA_IDE is not set
# CONFIG_SATA_MV is not set
# CONFIG_SATA_SIL is not set
# CONFIG_SATA_SIL3114 is not set
# CONFIG_BLK is not set
# CONFIG_BLOCK_CACHE is not set
# CONFIG_IDE is not set
# Boot count support
# CONFIG_BOOTCOUNT is not set
# Clock
# CONFIG_CLK is not set
# CONFIG_CPU is not set
# Hardware crypto devices
# CONFIG_FSL_CAAM is not set
# CONFIG_SYS_FSL_SEC_BE is not set
# CONFIG_SYS_FSL_SEC_LE is not set
# Demo for driver model
# CONFIG_DM_DEMO is not set
# DFU support
# DMA Support
# CONFIG_DMA is not set
# CONFIG_TI_EDMA3 is not set
# FPGA support
# CONFIG_FPGA_ALTERA is not set
# CONFIG_FPGA_SOCFPGA is not set
# CONFIG_FPGA_XILINX is not set
# GPIO Support
CONFIG_DM_GPIO=y
# CONFIG_ALTERA_PIO is not set
# CONFIG_DWAPB_GPIO is not set
# CONFIG_AT91_GPIO is not set
# CONFIG_ATMEL_PIO4 is not set
# CONFIG_INTEL_BROADWELL_GPIO is not set
# CONFIG_INTEL_ICH6_GPIO is not set
# CONFIG_IMX_RGPIO2P is not set
# CONFIG_HSDK_CREG_GPIO is not set
# CONFIG_LPC32XX_GPIO is not set
# CONFIG_MSM_GPIO is not set
# CONFIG_CMD_PCA953X is not set
# CONFIG_ROCKCHIP_GPIO is not set
# CONFIG_CMD_TCA642X is not set
# CONFIG_TEGRA_GPIO is not set
# CONFIG_TEGRA186_GPIO is not set
# CONFIG_VYBRID_GPIO is not set
# CONFIG_DM_74X164 is not set
# CONFIG_DM_PCA953X is not set
# CONFIG_MPC85XX_GPIO is not set
# I2C support
# CONFIG_DM_I2C is not set
# CONFIG_DM_I2C_COMPAT is not set
# CONFIG_SYS_I2C_DW is not set
# CONFIG_SYS_I2C_IMX_LPI2C is not set
CONFIG_DM_KEYBOARD=y
# CONFIG_CROS_EC_KEYB is not set
# CONFIG_I8042_KEYB is not set
# LED Support
# CONFIG_LED is not set
# CONFIG_LED_STATUS is not set
# Mailbox Controller Support
# CONFIG_DM_MAILBOX is not set
# Memory Controller drivers
# Multifunction device drivers
# CONFIG_MISC is not set
# CONFIG_CROS_EC is not set
# CONFIG_DS4510 is not set
# CONFIG_FSL_SEC_MON is not set
# CONFIG_MXC_OCOTP is not set
# CONFIG_NUVOTON_NCT6102D is not set
# CONFIG_PWRSEQ is not set
# CONFIG_PCA9551_LED is not set
# CONFIG_WINBOND_W83627 is not set
# MMC Host controller Support
CONFIG_MMC=y
# CONFIG_DM_MMC is not set
# CONFIG_SPL_MMC_TINY is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_MXC is not set
# CONFIG_MMC_MXS is not set
# CONFIG_MMC_PCI is not set
# CONFIG_MMC_OMAP_HS is not set
# CONFIG_MMC_SDHCI is not set
CONFIG_MMC_SUNXI=y
# CONFIG_FTSDC010 is not set
# MTD Support
# CONFIG_MTD is not set
# CONFIG_MTD_NOR_FLASH is not set
# CONFIG_NAND is not set
# SPI Flash Support
CONFIG_DM_SPI_FLASH=y
CONFIG_SPI_FLASH=y
CONFIG_SPI_FLASH_BAR=y
# CONFIG_SF_DUAL_FLASH is not set
# CONFIG_SPI_FLASH_ATMEL is not set
# CONFIG_SPI_FLASH_EON is not set
CONFIG_SPI_FLASH_GIGADEVICE=y
CONFIG_SPI_FLASH_MACRONIX=y
# CONFIG_SPI_FLASH_SPANSION is not set
# CONFIG_SPI_FLASH_STMICRO is not set
# CONFIG_SPI_FLASH_SST is not set
CONFIG_SPI_FLASH_WINBOND=y
CONFIG_SPI_FLASH_USE_4K_SECTORS=y
# CONFIG_SPI_FLASH_DATAFLASH is not set
# CONFIG_SPI_FLASH_MTD is not set
CONFIG_SPL_SPI_SUNXI=y
# UBI support
# CONFIG_MTD_UBI is not set
# CONFIG_BITBANGMII is not set
# CONFIG_MV88E6352_SWITCH is not set
# CONFIG_PHYLIB is not set
CONFIG_DM_ETH=y
CONFIG_NETDEVICES=y
# CONFIG_PHY_GIGE is not set
# CONFIG_ALTERA_TSE is not set
# CONFIG_BCM_SF2_ETH is not set
# CONFIG_DWC_ETH_QOS is not set
# CONFIG_E1000 is not set
# CONFIG_ETH_DESIGNWARE is not set
# CONFIG_ETHOC is not set
# CONFIG_FTMAC100 is not set
# CONFIG_MACB is not set
# CONFIG_RGMII is not set
# CONFIG_RTL8139 is not set
# CONFIG_RTL8169 is not set
# CONFIG_SMC911X is not set
# CONFIG_SUN7I_GMAC is not set
# CONFIG_SUN4I_EMAC is not set
# CONFIG_SUN8I_EMAC is not set
# CONFIG_PCI is not set
# PHY Subsystem
# CONFIG_PHY is not set
# CONFIG_SPL_PHY is not set
# CONFIG_MVEBU_COMPHY_SUPPORT is not set
# Pin controllers
# CONFIG_PINCTRL is not set
# Power
# Power Domain Support
# CONFIG_POWER_DOMAIN is not set
# CONFIG_DM_PMIC is not set
# CONFIG_PMIC_AS3722 is not set
# CONFIG_POWER_MC34VR500 is not set
# CONFIG_DM_REGULATOR is not set
CONFIG_SUNXI_NO_PMIC=y
# CONFIG_DM_PWM is not set
# CONFIG_PWM_SANDBOX is not set
# CONFIG_RAM is not set
# Remote Processor drivers
# Reset Controller Support
# CONFIG_DM_RESET is not set
# Real Time Clock
# CONFIG_DM_RTC is not set
# CONFIG_RTC_S35392A is not set
# CONFIG_SCSI is not set
# Serial drivers
CONFIG_BAUDRATE=115200
CONFIG_REQUIRE_SERIAL_CONSOLE=y
CONFIG_SERIAL_PRESENT=y
CONFIG_SPL_SERIAL_PRESENT=y
CONFIG_DM_SERIAL=y
# CONFIG_SERIAL_RX_BUFFER is not set
# CONFIG_SPL_DM_SERIAL is not set
# CONFIG_TPL_DM_SERIAL is not set
# CONFIG_DEBUG_UART_SKIP_INIT is not set
# CONFIG_ALTERA_JTAG_UART is not set
# CONFIG_ALTERA_UART is not set
# CONFIG_ATMEL_USART is not set
# CONFIG_FSL_LPUART is not set
# CONFIG_MVEBU_A3700_UART is not set
# CONFIG_NULLDEV_SERIAL is not set
CONFIG_SYS_NS16550=y
# CONFIG_MSM_SERIAL is not set
# CONFIG_PXA_SERIAL is not set
# Sound support
# CONFIG_SOUND is not set
# SPI Support
CONFIG_DM_SPI=y
# CONFIG_ALTERA_SPI is not set
# CONFIG_CADENCE_QSPI is not set
# CONFIG_DESIGNWARE_SPI is not set
# CONFIG_EXYNOS_SPI is not set
# CONFIG_FSL_DSPI is not set
# CONFIG_ICH_SPI is not set
# CONFIG_MVEBU_A3700_SPI is not set
# CONFIG_ROCKCHIP_SPI is not set
CONFIG_SUN6I_SPI=y
# CONFIG_TEGRA114_SPI is not set
# CONFIG_TEGRA20_SFLASH is not set
# CONFIG_TEGRA20_SLINK is not set
# CONFIG_TEGRA210_QSPI is not set
# CONFIG_XILINX_SPI is not set
# CONFIG_SOFT_SPI is not set
# CONFIG_FSL_ESPI is not set
# CONFIG_FSL_QSPI is not set
# CONFIG_ATCSPI200_SPI is not set
# CONFIG_TI_QSPI is not set
# CONFIG_OMAP3_SPI is not set
# SPMI support
# CONFIG_SPMI is not set
# System reset device drivers
# CONFIG_SYSRESET is not set
# CONFIG_SYSRESET_SYSCON is not set
# CONFIG_SYSRESET_WATCHDOG is not set
# CONFIG_DM_THERMAL is not set
# Timer Support
# CONFIG_TIMER is not set
# TPM support
CONFIG_USB=y
CONFIG_DM_USB=y
# USB Host Controller Drivers
# CONFIG_USB_XHCI_HCD is not set
# CONFIG_USB_EHCI_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_DWC3 is not set
# MUSB Controller Driver
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
# CONFIG_USB_MUSB_TI is not set
# ULPI drivers
# USB peripherals
CONFIG_USB_STORAGE=y
CONFIG_USB_KEYBOARD=y
CONFIG_SYS_USB_EVENT_POLL=y
# CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE is not set
# CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP is not set
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology"
CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a
CONFIG_USB_GADGET_PRODUCT_NUM=0x1010
# CONFIG_USB_GADGET_ATMEL_USBA is not set
# CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
# CONFIG_USB_GADGET_DWC2_OTG is not set
# CONFIG_CI_UDC is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
# CONFIG_USB_GADGET_DOWNLOAD is not set
# CONFIG_USB_ETHER is not set
# CONFIG_USB_HOST_ETHER is not set
# Graphics support
# CONFIG_DM_VIDEO is not set
# CONFIG_SYS_WHITE_ON_BLACK is not set
# CONFIG_NO_FB_CLEAR is not set
# TrueType Fonts
# CONFIG_VIDEO_VESA is not set
# CONFIG_VIDEO_LCD_ANX9804 is not set
# CONFIG_VIDEO_LCD_SSD2828 is not set
# CONFIG_VIDEO_MVEBU is not set
# CONFIG_DISPLAY is not set
# CONFIG_VIDEO_TEGRA20 is not set
# CONFIG_VIDEO_BRIDGE is not set
# CONFIG_VIDEO is not set
# CONFIG_LCD is not set
# CONFIG_VIDEO_SIMPLE is not set
# CONFIG_VIDEO_DT_SIMPLEFB is not set
# Watchdog Timer Support
# CONFIG_BCM2835_WDT is not set
# CONFIG_ULP_WATCHDOG is not set
# CONFIG_WDT is not set
# CONFIG_PHYS_TO_BUS is not set
# File systems
# CONFIG_FS_BTRFS is not set
# CONFIG_FS_CBFS is not set
CONFIG_FS_FAT=y
CONFIG_FAT_WRITE=y
CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
# CONFIG_FS_JFFS2 is not set
# CONFIG_FS_CRAMFS is not set
# CONFIG_YAFFS2 is not set
# Library routines
# CONFIG_BCH is not set
# CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
CONFIG_HAVE_PRIVATE_LIBGCC=y
CONFIG_USE_PRIVATE_LIBGCC=y
CONFIG_SYS_HZ=1000
CONFIG_USE_TINY_PRINTF=y
# CONFIG_PANIC_HANG is not set
# CONFIG_REGEX is not set
# CONFIG_LIB_RAND is not set
# CONFIG_SPL_TINY_MEMSET is not set
# CONFIG_TPL_TINY_MEMSET is not set
# CONFIG_BITREVERSE is not set
# CONFIG_CMD_DHRYSTONE is not set
# Security support
# CONFIG_AES is not set
# CONFIG_RSA is not set
# CONFIG_TPM is not set
# Hashing Support
# CONFIG_SHA1 is not set
# CONFIG_SHA256 is not set
# CONFIG_SHA_HW_ACCEL is not set
# Compression Support
# CONFIG_LZ4 is not set
# CONFIG_LZMA is not set
# CONFIG_LZO is not set
# CONFIG_SPL_LZO is not set
# CONFIG_SPL_GZIP is not set
# CONFIG_ERRNO_STR is not set
CONFIG_OF_LIBFDT=y
CONFIG_OF_LIBFDT_OVERLAY=y
# CONFIG_SPL_OF_LIBFDT is not set
# CONFIG_FDT_FIXUP_PARTITIONS is not set
# System tables
CONFIG_GENERATE_SMBIOS_TABLE=y
CONFIG_SMBIOS_MANUFACTURER=""
CONFIG_EFI_LOADER=y
# CONFIG_UNIT_TEST is not set
board.c 中已经添加了
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
sunxi_gpio_set_cfgpin(SUNXI_GPE(7), SUNIV_GPE_UART2);
sunxi_gpio_set_cfgpin(SUNXI_GPE(8), SUNIV_GPE_UART2);
sunxi_gpio_set_pull(SUNXI_GPE(7), SUNXI_GPIO_PULL_UP);
suniv.h 中添加了
#define CONFIG_SUNXI_USB_PHYS 1
#define CONFIG_CONS_INDEX 2
gpio.h 中添加了
#define SUNIV_GPE_UART2 3
sunxi-common.h 中添加了
#define OF_STDOUT_PATH "/soc/serial@01c25800:115200"
该改的都改了 还是不行
tina sdk不能直接修改 .config 文件,
需要修改 target/ 目录下面一个linux内核配置文件。
多谢大神
直接用UBOOT里的DTS文件,串口2 还是不工作,帮忙分析下,还有哪里没改到位 :)
@哇酷小二
BSP_C200S_Linux_V0.1.tar
uboot 版本
@哇酷小二
https://whycan.com/files/members/2591/微信截图_20220318144844.png
uboot 版本
https://whycan.com/files/members/2591/uboot.png
本来想用BSP中的一整套,但是我看坑网里说不支持修改debug 串口,我自己试了以下修改sys_config.fex,修改后没办法直接烧录镜像,单独重新编译UBOOT后还是不行,所以退而求其次,想用荔枝派的uboot来引导BSP中的内核,结果调试串口还是不打印
板子已经试过了,用RT-Thread打印、显示都是正常的;
各种折腾。。。。之前移植了鸿蒙也是半途而废了
@哇酷小二
刚才改了以下C200S_Linux_V0.1\out\sunivw1p1\linux\common\buildroot\.config
真是牵一发而动全身,编译时一下子蹦出来好多需要配置的
重新配置竟然没找到 arm926ejs
楼主的补丁确认好用,使用的是串口1,pa2和pa3引脚,荔枝派的u-boot
git clone https://github.com/Lichee-Pi/u-boot.git
git checkout nano-v2018.01
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- licheepi_nano_defconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j12
sunxi-fel uboot ./u-boot-sunxi-with-spl.bin
然后就可以看到log输出了。
U-Boot SPL 2018.01-05679-g013ca457fd-dirty (Mar 03 2024 - 13:11:13)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2018.01-05679-g013ca457fd-dirty (Mar 03 2024 - 13:11:13 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
mmc_init: -95, time 23
*** Warning - MMC init failed, using default environment
In: serial@1c25400
Out: serial@1c25400
Err: serial@1c25400
Net: No ethernet found.
No controllers found
mmc_init: -95, time 24
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
使用主线u-boot检查上面的配置后发现已经配置好了,在设备树里面改使用的串口即可,但是串口1还是无法输出log
