下面是BSP内核目录
easyboard@V3S:~/corelinux/v3ssdk$ ls
app buildroot linux-3.4 patch rootfs 执行linux_docker_build.sh
app-bke build.sh linux_docker_build.sh prebuilt tools
运行linux_docker_build.sh一键编译
linux_docker_build.sh文件内容
TOP_DIR=`pwd`
echo "检查Docker......"
docker -v
if [ $? -eq 0 ]; then
echo "检查到Docker已安装!"
sudo apt-get install docker.io -y
fi
# 创建公用网络==bridge模式
#docker network create share_network
sudo
docker run -it -v $TOP_DIR:$TOP_DIR ld3003/v3s_env /bin/bash $TOP_DIR/build.sh $1
build.sh文件内容
#!/bin/bash
physicalNumber=0
coreNumber=0
logicalNumber=0
HTNumber=0
logicalNumber=$(grep "processor" /proc/cpuinfo|sort -u|wc -l)
physicalNumber=$(grep "physical id" /proc/cpuinfo|sort -u|wc -l)
coreNumber=$(grep "cpu cores" /proc/cpuinfo|uniq|awk -F':' '{print $2}'|xargs)
HTNumber=$((logicalNumber / (physicalNumber * coreNumber)))
echo "****** CPU Information ******"
echo "Logical CPU Number : ${logicalNumber}"
echo "Physical CPU Number : ${physicalNumber}"
echo "CPU Core Number : ${coreNumber}"
echo "HT Number : ${HTNumber}"
echo "*****************************"
if [ -L $0 ]
then
BASE_DIR=`dirname $(readlink $0)`
BASE_DIR=`dirname $0`
fi
basepath=$(cd $BASE_DIR; pwd)
echo $basepath
set -e
LD_LIBRARY_PATH=
TOP_DIR=$basepath
cd $TOP_DIR
PATH=$TOP_DIR/buildroot/out/host/bin/:$PATH
CROSS_COMPILE=$TOP_DIR/tools/external-toolchain/bin/arm-linux-gnueabi-
UBOOT_DIR=$TOP_DIR/u-boot-2011.09
KERNEL_DIR=$TOP_DIR/linux-3.4
BUILDROOT_DIR=$TOP_DIR/buildroot
BUILDROOT_OUT_DIR=$TOP_DIR/buildroot/out
ROOTFS_DIR=$TOP_DIR/rootfs
HOSTTOOLS_DIR=$TOP_DIR/tools/bin
PACKTOOLS_DIR=$TOP_DIR/tools/pack
ROOTFS_OVERRIDE_DIR=$TOP_DIR/prebuilt/rootfs-override
APP_DIR=$TOP_DIR/app
BR_CROSS_COMPILE=$BUILDROOT_OUT_DIR/host/usr/bin/arm-buildroot-linux-gnueabihf-
copy_file_list=(
$ROOTFS_OVERRIDE_DIR/etc/inittab:$ROOTFS_DIR/etc/inittab
$ROOTFS_OVERRIDE_DIR/etc/profile:$ROOTFS_DIR/etc/profile
$ROOTFS_OVERRIDE_DIR/etc/wpa_supplicant.conf:$ROOTFS_DIR/etc/wpa_supplicant.conf
$ROOTFS_OVERRIDE_DIR/etc/hostapd.conf:$ROOTFS_DIR/etc/hostapd.conf
$ROOTFS_OVERRIDE_DIR/etc/udhcpd.conf:$ROOTFS_DIR/etc/udhcpd.conf
$ROOTFS_OVERRIDE_DIR/etc/mdev.conf:$ROOTFS_DIR/etc/mdev.conf
$ROOTFS_OVERRIDE_DIR/etc/init.d/S50sshd:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90camera:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90wifiap:$ROOTFS_DIR/etc/init.d/_S90wifiap
$ROOTFS_OVERRIDE_DIR/etc/init.d/S90wifista:$ROOTFS_DIR/etc/init.d/_S90wifista
$ROOTFS_OVERRIDE_DIR/etc/init.d/S99appstart:$ROOTFS_DIR/etc/init.d/
$ROOTFS_OVERRIDE_DIR/etc/ssh/sshd_config:$ROOTFS_DIR/etc/ssh/
$ROOTFS_OVERRIDE_DIR/root/*.sh:$ROOTFS_DIR/root/
$ROOTFS_OVERRIDE_DIR/root/demo-h264enc:$ROOTFS_DIR/usr/bin/
$APP_DIR/demo-camera/demo-camera:$ROOTFS_DIR/usr/bin/
#$APP_DIR/demo-qt/digitalclock:$ROOTFS_DIR/root/
#$PREBUILT_DIR/libs/*:$ROOTFS_DIR/lib/
function copy_patch()
echo "ADD PATCH"
function copy_file_to_rootfs()
for line in ${copy_file_list[@]} ; do
srcfile=`echo $line | awk -F: '{print $1}'`
dstfile=`echo $line | awk -F: '{print $2}'`
cp -drf $srcfile $dstfile
done
function build_uboot()
cd $UBOOT_DIR
make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} sun8iw8p1_spinand_emmc && \
make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} fes && \
make -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} boot0
[ $? -ne 0 ] && echo "build u-boot Failed"
function clean_uboot()
cd $UBOOT_DIR
make CROSS_COMPILE=${CROSS_COMPILE} distclean
function build_kernel()
apt-get update
apt-get install kmod -y
cd $KERNEL_DIR
make ARCH=arm -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} && \
make ARCH=arm -j${logicalNumber} CROSS_COMPILE=${CROSS_COMPILE} uImage modules && \
make ARCH=arm CROSS_COMPILE=${CROSS_COMPILE} INSTALL_MOD_PATH=${ROOTFS_DIR} modules_install
[ $? -ne 0 ] && echo "build kernel Failed"
cp -v ./arch/arm/boot/uImage ../tools/pack/chips/sun8iw8p1/boot-resource/boot-resource/
function clean_kernel()
cd $KERNEL_DIR
make ARCH=arm -j4 CROSS_COMPILE=${CROSS_COMPILE} distclean
function build_buildroot()
echo "Build buildroot"
cd $BUILDROOT_DIR
mkdir -p $BUILDROOT_OUT_DIR
#cp $BUILDROOT_OUT_DIR/.config configs/mangopi_defconfig
#cp configs/mangopi_defconfig $BUILDROOT_OUT_DIR/.config
make O=$BUILDROOT_OUT_DIR oldconfig
mkdir -p $ROOTFS_DIR
rm -r $ROOTFS_DIR
tar xvf $BUILDROOT_OUT_DIR/images/rootfs.tar.bz2 -C $ROOTFS_DIR
function clean_buildroot()
cd $BUILDROOT_DIR
make O=$BUILDROOT_OUT_DIR clean
rm -r $TOP_DIR/rootfs
function pack()
copy_file_to_rootfs
$HOSTTOOLS_DIR/make_ext4fs -s -l 200M /tmp/rootfs-ext4.img $ROOTFS_DIR
cd $PACKTOOLS_DIR
./pack -c sun8iw8p1 -p camdroid -b tiger-spinand-standard -e spinand
function build_library()
cd $APP_DIR/ncnn/
mkdir build
cd build
cmake -DCMAKE_TOOLCHAIN_FILE=../toolchains/arm-buildroot-gnueabihf.toolchain.cmake ..
cd $APP_DIR/libfacedetection/
mkdir build
cd build
cmake ../
function build_demos()
cd $APP_DIR/
bash buildapp.sh
cp -v $APP_DIR/sdcard/ $TOP_DIR/rootfs/root/bin/ -rf
function clean_demos()
cd $TOP_DIR
source env-qt
cd $APP_DIR/demo-camera/
make clean
cd $APP_DIR/demo-qt
./run_qmake.sh
make clean
if [ $# -eq 0 ] ; then
copy_patch
build_buildroot
#build_uboot
build_kernel
#build_library
build_demos
pack
case $1 in
clean)
clean_uboot
clean_kernel
clean_buildroot
clean_demos
uboot)
build_uboot
kernel)
build_kernel
buildroot)
build_buildroot
lib)
build_library
app)
build_demos
pack)
pack
esac
fi
因为要用mplayer重新配置了buildroot但没效果,是不是上面的编译和buildroot没关系啊!请大神帮忙看看怎么办。
确实没用,配置文件感觉没对上吧
