[98]HELLO! BOOT0 is starting!
[101]BOOT0 commit : 27369ab
[104]set pll start
[106]periph0 has been enabled
[109]set pll end
[110][pmu]: bus read error
[113]board init ok
[114]ZQ value = 0x32***********
[117]get_pmu_exist() = -1
[120]ddr_efuse_type: 0x0
[123][AUTO DEBUG] single rank and full DQ!
[127]ddr_efuse_type: 0x0
[130][AUTO DEBUG] rank 0 row = 13
[133][AUTO DEBUG] rank 0 bank = 4
[136][AUTO DEBUG] rank 0 page size = 2 KB
[140]DRAM BOOT DRIVE INFO: V0.24
[143]DRAM CLK = 528 MHz
[145]DRAM Type = 2 (2:DDR2,3:DDR3)
[148]DRAMC read ODT off.
[151]DRAM ODT off.
[153]ddr_efuse_type: 0x0
[155]DRAM SIZE =64 M
[159]DRAM simple test OK.
[161]dram size =64
[163]card no is 0
[165]sdcard 0 line count 4
[167][mmc]: mmc driver ver 2021-04-2 16:45
[177][mmc]: Wrong media type 0x0
[180][mmc]: ***Try SD card 0***
[192][mmc]: HSSDR52/SDR25 4 bit
[195][mmc]: 50000000 Hz
[197][mmc]: 1876 MB
[199][mmc]: ***SD/MMC 0 init OK!!!***
[257]Loading boot-pkg Succeed(index=0).
[261]Entry_name = opensbi
[264]Entry_name = u-boot
[268]Entry_name = dtb
[270]mmc not para
[272]Jump to second Boot.
OpenSBI v0.6
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x40000400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000040000000-0x000000004001ffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,▒
U-Boot 2018.05-g0a88ac9-dirty (Aug 30 2021 - 18:24:19 +0800) Allwinner Technology
[00.355]DRAM: 64 MiB
[00.357]Relocation Offset is: 01ef0000
[00.362]secure enable bit: 0
[00.364]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.371]flash init start
[00.373]workmode = 0,storage type = 1
[00.376][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
[00.382][mmc]: get sdc_type fail and use default host:tm1.
[00.388][mmc]: can't find node "mmc0",will add new node
[00.393][mmc]: fdt err returned <no error>
[00.397][mmc]: Using default timing para
[00.400][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.421][mmc]: card_caps:0x3000000a
[00.424][mmc]: host_caps:0x3000003f
[00.429]sunxi flash init ok
[00.431]line:714 init_clocks
__clk_init: clk pll_periph0x2 already initialized
register fix_factor clk error
[00.441]drv_disp_init
request pwm success, pwm2:pwm2:0x2000c00.
[00.458]drv_disp_init finish
[00.461]boot_gui_init:start
[00.463]set disp.dev2_output_type fail. using defval=0
[00.655]boot_gui_init:finish
sunxi_partition_get_partno_byname: try part 1, ret = 0
sunxi_partition_get_partno_byname: try part 2, ret = 0
sunxi_partition_get_partno_byname: try part 3, ret = 0
sunxi_partition_get_partno_byname: try part 4, ret = 0
sunxi_partition_get_partno_byname: try part 5, ret = 0
sunxi_partition_get_partno_byname: try part 6, ret = 0
sunxi_partition_get_partno_byname: try part 7, ret = 0
sunxi_partition_get_partno_byname: try part 8, ret = 0
sunxi_partition_get_partno_byname: try part 9, ret = -1
partno erro : can't find partition bootloader
54 bytes read in 2 ms [01.067]LCD open finish
(26.4 KiB/s)
[01.070]bmp_name=bootlogo.bmp size 307254
307254 bytes read in 19 ms (15.4 MiB/s)
[01.112]Loading Environment from SUNXI_FLASH... OK
[01.136]out of usb burn from boot: not need burn key
root_partition is rootfs
set root to /dev/mmcblk0p5
[01.146]update part info
[01.149]update bootcmd
[01.153]change working_fdt 0x42aafda8 to 0x42a8fda8
[01.174]update dts
Android's image name: d1-nezha
No reserved memory region found in source FDT
[01.678]
[01.680][mmc]: MMC Device 2 not found
[01.684][mmc]: mmc 2 not find, so not exit
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #40 PREEMPT Sat Aug 28 01:37:30 UTC 2021
[ 0.000000] cma: Reserved 8 MiB at 0x0000000043800000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x0000000043ffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040200000-0x0000000043ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x0000000043ffffff]
[ 0.000000] On node 0 totalpages: 15872
[ 0.000000] DMA32 zone: 217 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 15872 pages, LIFO batch:3
[ 0.000000] elf_hwcap is 0x20112d
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 15655
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(08/30/2021-18:24:19) mbr_off
[ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000000] Sorting __ex_table...
[ 0.000000] Memory: 42216K/63488K available (6067K kernel code, 663K rwdata, 2093K rodata, 192K init, 254K bss, 13080K reserved, 8192K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
[ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000029] riscv_timer_clockevent depends on broadcast, but no broadcast function available
[ 0.000371] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.001010] Console: colour dummy device 80x25
[ 0.001056] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001075] pid_max: default: 32768 minimum: 301
[ 0.001291] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.001312] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.003350] ASID allocator initialised with 65536 entries
[ 0.003556] rcu: Hierarchical SRCU implementation.
[ 0.004298] devtmpfs: initialized
[ 0.022812] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
[ 0.023781] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.023817] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.024389] pinctrl core: initialized pinctrl subsystem
[ 0.025926] NET: Registered protocol family 16
[ 0.027969] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.028729] cpuidle: using governor menu
[ 0.075867] rtc_ccu: sunxi ccu init OK
[ 0.083712] clock: sunxi ccu init OK
[ 0.084890] clock: sunxi ccu init OK
[ 0.125048] iommu: Default domain type: Translated
[ 0.125252] sunxi iommu: irq = 4
[ 0.126569] SCSI subsystem initialized
[ 0.126961] usbcore: registered new interface driver usbfs
[ 0.127055] usbcore: registered new interface driver hub
[ 0.127198] usbcore: registered new device driver usb
[ 0.127417] mc: Linux media interface: v0.10
[ 0.127489] videodev: Linux video capture interface: v2.00
[ 0.128800] sunxi-msgbox-amp 3003000.msgbox: invalid resource
[ 0.129560] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130259] Bluetooth: Core ver 2.22
[ 0.130360] NET: Registered protocol family 31
[ 0.130373] Bluetooth: HCI device and connection manager initialized
[ 0.130400] Bluetooth: HCI socket layer initialized
[ 0.130418] Bluetooth: L2CAP socket layer initialized
[ 0.130461] Bluetooth: SCO socket layer initialized
[ 0.130942] pwm module init!
[ 0.132670] g2d 5410000.g2d: Adding to iommu group 0
[ 0.133234] G2D: rcq version initialized.major:250
[ 0.134042] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.135604] clocksource: Switched to clocksource riscv_clocksource
[ 0.149142] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.167834] thermal_sys: Registered thermal governor 'step_wise'
[ 0.167842] thermal_sys: Registered thermal governor 'user_space'
[ 0.168448] NET: Registered protocol family 2
[ 0.169367] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.169418] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.169442] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.169458] TCP: Hash tables configured (established 512 bind 512)
[ 0.169643] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.169690] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.169978] NET: Registered protocol family 1
[ 0.172838] Initialise system trusted keyrings
[ 0.173153] workingset: timestamp_bits=62 max_order=14 bucket_order=0
[ 0.181146] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.201370] Key type asymmetric registered
[ 0.201389] Asymmetric key parser 'x509' registered
[ 0.201417] io scheduler mq-deadline registered
[ 0.201426] io scheduler kyber registered
[ 0.201449] atomic64_test: passed
[ 0.202868] [DISP]disp_module_init
[ 0.203493] disp 5000000.disp: Adding to iommu group 0
[ 0.204178] [DISP] disp_init,line:2385:
[ 0.204186] smooth display screen:0 type:1 mode:4
[ 0.244375] display_fb_request,fb_id:0
[ 0.260591] disp_al_manager_apply ouput_type:1
[ 0.260777] [DISP] lcd_clk_config,line:731:
[ 0.260792] disp 0, clk: pll(816000000),clk(816000000),dclk(34000000) dsi_rate(34000000)
[ 0.260792] clk real:pll(816000000),clk(816000000),dclk(204000000) dsi_rate(150000000)
[ 0.261216] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.262259] [DISP]disp_module_init finish
[ 0.263326] sunxi_sid_init()506 - insmod ok
[ 0.263955] pwm-regulator: supplied by regulator-dummy
[ 0.272677] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.273174] uart uart0: get regulator failed
[ 0.273206] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.273564] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[ 0.273596] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 1.037526] printk: console [ttyS0] enabled
[ 1.043195] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.054801] uart uart1: get regulator failed
[ 1.059644] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.067795] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
[ 1.077950] misc dump reg init
[ 1.082320] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 1.089648] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
[ 1.097268] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 1.104584] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 1.112011] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 1.118594] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 1.125514] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 1.133301] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 1.141181] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 1.149387] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 1.157122] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 1.163850] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.171476] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.179918] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 1.187652] [ADDR_MGT] addr_mgt_probe: success.
[ 1.194205] libphy: Fixed MDIO Bus: probed
[ 1.198939] CAN device driver interface
[ 1.204423] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator离线
[转载 aw-ol.com] 【极简操作】使用builroot 2021一键编译生成D1 nezha 系统镜像!
https://whycan.com/t_6753.html#p66259
[ 0.975011] loop: module loaded
[ 0.979567] libphy: Fixed MDIO Bus: probed
[ 0.984173] CAN device driver interface
[ 0.989450] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.000746] sunxi gmac driver's version: 1.0.0
[ 1.005871] gmac-power0: NULL
[ 1.009210] gmac-power1: NULL
[ 1.012514] gmac-power2: NULL
[ 1.016764] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.024072] sunxi-ehci: EHCI SUNXI driver感觉是 F133 板子没有 mac 芯片导致,你到 dts 里面屏蔽试一试呗。
感谢楼上的朋友,board.dts 屏蔽了 gmac,然后这样了:
[85]HELLO! BOOT0 is starting!
[88]BOOT0 commit : 27369ab
[91]set pll start
[93]periph0 has been enabled
[95]set pll end
[97][pmu]: bus read error
[99]board init ok
[101]ZQ value = 0x32***********
[104]get_pmu_exist() = -1
[107]ddr_efuse_type: 0x0
[109][AUTO DEBUG] single rank and full DQ!
[113]ddr_efuse_type: 0x0
[116][AUTO DEBUG] rank 0 row = 13
[119][AUTO DEBUG] rank 0 bank = 4
[123][AUTO DEBUG] rank 0 page size = 2 KB
[126]DRAM BOOT DRIVE INFO: V0.24
[129]DRAM CLK = 528 MHz
[132]DRAM Type = 2 (2:DDR2,3:DDR3)
[135]DRAMC read ODT off.
[137]DRAM ODT off.
[139]ddr_efuse_type: 0x0
[142]DRAM SIZE =64 M
[146]DRAM simple test OK.
[148]dram size =64
[150]card no is 0
[152]sdcard 0 line count 4
[154][mmc]: mmc driver ver 2021-04-2 16:45
[163][mmc]: Wrong media type 0x0
[166][mmc]: ***Try SD card 0***
[179][mmc]: HSSDR52/SDR25 4 bit
[182][mmc]: 50000000 Hz
[184][mmc]: 1876 MB
[186][mmc]: ***SD/MMC 0 init OK!!!***
[243]Loading boot-pkg Succeed(index=0).
[247]Entry_name = opensbi
[250]Entry_name = u-boot
[254]Entry_name = dtb
[256]mmc not para
[258]Jump to second Boot.
OpenSBI v0.6
|_|
Current Hart : 0
U-Boot 2018.05-g0a88ac9-dirty (Sep 02 2021 - 15:47:05 +0800) Allwinner Technology
[00.341]DRAM: 64 MiB
[00.343]Relocation Offset is: 01ef0000
[00.348]secure enable bit: 0
[00.350]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.357]flash init start
[00.359]workmode = 0,storage type = 1
[00.362][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
[00.368][mmc]: get sdc_type fail and use default host:tm1.
[00.374][mmc]: can't find node "mmc0",will add new node
[00.379][mmc]: fdt err returned <no error>
[00.383][mmc]: Using default timing para
[00.386][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.407][mmc]: card_caps:0x3000000a
[00.410][mmc]: host_caps:0x3000003f
[00.415]sunxi flash init ok
[00.417]line:714 init_clocks
[00.427]drv_disp_init
[00.444]drv_disp_init finish
[00.447]boot_gui_init:start
[00.450]set disp.dev2_output_type fail. using defval=0
[00.641]boot_gui_init:finish
54 bytes read [01.053]LCD open finish
in 3 ms (17.6 KiB/s)
[01.057]bmp_name=bootlogo.bmp size 307254
307254 bytes read in 20 ms (14.7 MiB/s)
[01.100]Loading Environment from SUNXI_FLASH... OK
[01.123]out of usb burn from boot: not need burn key
[01.133]update part info
[01.136]update bootcmd
[01.140]change working_fdt 0x42aafda8 to 0x42a8fda8
[01.161]update dts
[01.647]
[01.649][mmc]: MMC Device 2 not found
[01.653][mmc]: mmc 2 not find, so not exit
[ 0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #41 PREEMPT Thu Sep 2 07:48:48 UTC 2021
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(09/02/2021-15:47:05) mbr_off
[ 0.000374] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.001013] Console: colour dummy device 80x25
[ 0.001059] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001079] pid_max: default: 32768 minimum: 301
[ 0.001311] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.003374] ASID allocator initialised with 65536 entries
[ 0.003579] rcu: Hierarchical SRCU implementation.
[ 0.004322] devtmpfs: initialized
[ 0.022703] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
[ 0.023675] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.023711] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.024282] pinctrl core: initialized pinctrl subsystem
[ 0.025827] NET: Registered protocol family 16
[ 0.027875] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.028642] cpuidle: using governor menu
[ 0.074668] rtc_ccu: sunxi ccu init OK
[ 0.082594] clock: sunxi ccu init OK
[ 0.083772] clock: sunxi ccu init OK
[ 0.125148] iommu: Default domain type: Translated
[ 0.125349] sunxi iommu: irq = 4
[ 0.126654] SCSI subsystem initialized
[ 0.127057] usbcore: registered new interface driver usbfs
[ 0.127154] usbcore: registered new interface driver hub
[ 0.127277] usbcore: registered new device driver usb
[ 0.127483] mc: Linux media interface: v0.10
[ 0.127587] videodev: Linux video capture interface: v2.00
[ 0.128887] sunxi-msgbox-amp 3003000.msgbox: invalid resource
[ 0.129658] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130319] Bluetooth: Core ver 2.22
[ 0.130415] NET: Registered protocol family 31
[ 0.130428] Bluetooth: HCI device and connection manager initialized
[ 0.130455] Bluetooth: HCI socket layer initialized
[ 0.130609] Bluetooth: L2CAP socket layer initialized
[ 0.130665] Bluetooth: SCO socket layer initialized
[ 0.131002] pwm module init!
[ 0.132757] g2d 5410000.g2d: Adding to iommu group 0
[ 0.133340] G2D: rcq version initialized.major:250
[ 0.134145] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.135721] clocksource: Switched to clocksource riscv_clocksource
[ 0.149343] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.167933] thermal_sys: Registered thermal governor 'step_wise'
[ 0.167940] thermal_sys: Registered thermal governor 'user_space'
[ 0.168548] NET: Registered protocol family 2
[ 0.169461] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.169513] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.169535] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.169552] TCP: Hash tables configured (established 512 bind 512)
[ 0.169737] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.169785] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.170056] NET: Registered protocol family 1
[ 0.172913] Initialise system trusted keyrings
[ 0.173240] workingset: timestamp_bits=62 max_order=14 bucket_order=0
[ 0.181176] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.202194] Key type asymmetric registered
[ 0.202212] Asymmetric key parser 'x509' registered
[ 0.202240] io scheduler mq-deadline registered
[ 0.202250] io scheduler kyber registered
[ 0.202273] atomic64_test: passed
[ 0.203688] [DISP]disp_module_init
[ 0.204346] disp 5000000.disp: Adding to iommu group 0
[ 0.205006] [DISP] disp_init,line:2385:
[ 0.205012] smooth display screen:0 type:1 mode:4
[ 0.245011] display_fb_request,fb_id:0
[ 0.261161] disp_al_manager_apply ouput_type:1
[ 0.261348] [DISP] lcd_clk_config,line:731:
[ 0.261362] disp 0, clk: pll(816000000),clk(816000000),dclk(34000000) dsi_rate(34000000)
[ 0.261362] clk real:pll(816000000),clk(816000000),dclk(204000000) dsi_rate(150000000)
[ 0.261783] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.262849] [DISP]disp_module_init finish
[ 0.263879] sunxi_sid_init()506 - insmod ok
[ 0.264539] pwm-regulator: supplied by regulator-dummy
[ 0.273185] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.273685] uart uart0: get regulator failed
[ 0.273718] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.274118] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[ 0.274150] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 1.037858] printk: console [ttyS0] enabled
[ 1.043524] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.055126] uart uart1: get regulator failed
[ 1.059974] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.068114] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
[ 1.078191] misc dump reg init
[ 1.082606] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 1.089867] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
[ 1.097547] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 1.104840] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 1.112307] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 1.118855] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 1.125848] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 1.133584] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 1.141469] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 1.149674] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 1.157397] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 1.164163] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.171729] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.180198] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 1.187920] [ADDR_MGT] addr_mgt_probe: success.
[ 1.194491] libphy: Fixed MDIO Bus: probed
[ 1.199252] CAN device driver interface
[ 1.203920] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.211260] sunxi-ehci: EHCI SUNXI driver
[ 1.216496] get ehci1-controller wakeup-source is fail.
[ 1.222445] sunxi ehci1-controller don't init wakeup source
[ 1.228787] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0008fbf20, 0x:ffffffd004078000, irq_no:31
[ 1.242385] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 1.255043] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 1.262332] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.272306] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
[ 1.305772] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 1.314699] hub 1-0:1.0: USB hub found
[ 1.319081] hub 1-0:1.0: 1 port detected
[ 1.324437] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.331541] sunxi-ohci: OHCI SUNXI driver
[ 1.336717] get ohci1-controller wakeup-source is fail.
[ 1.342674] sunxi ohci1-controller don't init wakeup source
[ 1.349011] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0008fca60
[ 1.359501] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[ 1.372104] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 1.379391] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.389296] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
[ 1.470823] hub 2-0:1.0: USB hub found
[ 1.475075] hub 2-0:1.0: 1 port detected
[ 1.480869] usbcore: registered new interface driver uas
[ 1.487088] usbcore: registered new interface driver usb-storage
[ 1.493915] usbcore: registered new interface driver ums-alauda
[ 1.500728] usbcore: registered new interface driver ums-cypress
[ 1.507640] usbcore: registered new interface driver ums-datafab
[ 1.514438] usbcore: registered new interface driver ums_eneub6250
[ 1.521540] usbcore: registered new interface driver ums-freecom
[ 1.528384] usbcore: registered new interface driver ums-isd200
[ 1.535105] usbcore: registered new interface driver ums-jumpshot
[ 1.542041] usbcore: registered new interface driver ums-karma
[ 1.548765] usbcore: registered new interface driver ums-onetouch
[ 1.555661] usbcore: registered new interface driver ums-realtek
[ 1.562572] usbcore: registered new interface driver ums-sddr09
[ 1.569318] usbcore: registered new interface driver ums-sddr55
[ 1.576126] usbcore: registered new interface driver ums-usbat
[ 1.583938] sunxi_gpadc_init,1968, success
[ 1.589596] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 1.602045] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.607891] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
[ 1.616859] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.622743] i2c /dev entries driver
[ 1.626886] IR NEC protocol handler initialized
[ 1.632709] sunxi cedar version 1.1
[ 1.637085] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.643333] VE: install start!!!
[ 1.643333]
[ 1.648942] VE: cedar-ve the get irq is 6
[ 1.648942]
[ 1.655384] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[ 1.655384]
[ 1.667042] VE: install end!!!
[ 1.667042]
[ 1.673651] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.682944] Bluetooth: HCI UART driver ver 2.3
[ 1.687963] Bluetooth: HCI UART protocol H4 registered
[ 1.693725] Bluetooth: HCI UART protocol BCSP registered
[ 1.699685] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.707105] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.713490] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 1.720164] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 1.720164]
[ 1.728847] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 1.737987] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[ 1.748073] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.754249] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.760668] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.767108] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.773540] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 1.780079] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 1.786648] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 1.793155] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 1.800268] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 1.805808] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 1.812527] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.823746] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 1.843915] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.868460] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 1.874140] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.886077] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[ 1.896158] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 1.902371] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 1.908851] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 1.915343] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 1.921791] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 1.928375] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 1.934883] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 1.941493] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 1.948071] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.957703] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.968927] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 1.989096] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.013371] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.021064] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.028396] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 2.039386] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.046333] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.058239] sunxi_led_probe()1715 - start
[ 2.062790] sunxi_get_str_of_property()1560 - failed to get the string of propname led_regulator!
[ 2.072890] sunxi_register_led_classdev()1448 - led_classdev start
[ 2.081591] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.096819] sunxi_led_probe()1820 - finish
[ 2.102212] usbcore: registered new interface driver usbhid
[ 2.108617] usbhid: USB HID core driver
[ 2.113760] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.121373] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.128694] usbcore: registered new interface driver snd-usb-audio
[ 2.135618] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.143260] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.150080] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.163749] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 2.176561] sunxi-daudio 2034000.daudio: regulator missing or invalid
[ 2.185013] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.185013]
[ 2.202212] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.213648] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
[ 2.223441] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 2.233333] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.242759] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 2.254213] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
[ 2.266522] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
[ 2.274901] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
[ 2.283411] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
[ 2.292613] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
[ 2.304277] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
[ 2.316620] NET: Registered protocol family 10
[ 2.323096] Segment Routing with IPv6
[ 2.327583] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.335099] NET: Registered protocol family 17
[ 2.340297] can: controller area network core (rev 20170425 abi 9)
[ 2.347397] NET: Registered protocol family 29
[ 2.352401] can: raw protocol (rev 20170425)
[ 2.357216] can: broadcast manager protocol (rev 20170425 t)
[ 2.363543] can: netlink gateway (rev 20190810) max_hops=1
[ 2.370123] Bluetooth: RFCOMM TTY layer initialized
[ 2.375585] Bluetooth: RFCOMM socket layer initialized
[ 2.381519] Bluetooth: RFCOMM ver 1.11
[ 2.386913] Loading compiled-in X.509 certificates
[ 2.395163] HDMI 2.0 driver init start!
[ 2.399574] boot_hdmi=false
[ 2.402765] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 2.410033] HDMI2.0 module init end
[ 2.438387] twi twi2: twi2 supply twi not found, using dummy regulator
[ 2.454847] twi_stop()488 - [i2c2] i2c state(0x0) isn't idle(0xf8)
[ 2.461748] sunxi_i2c_core_process()1632 - [i2c2] STOP failed!
[ 2.468359] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0xff, dev addr: 0x38)
[ 2.477808] pcf857x: probe of 2-0038 failed with error -70
[ 2.483983] sunxi_i2c_probe()2262 - [i2c2] probe success
[ 2.494810] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
[ 2.505479] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
[ 2.516251] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
[ 2.527376] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
[ 2.539020] get ehci0-controller wakeup-source is fail.
[ 2.544972] sunxi ehci0-controller don't init wakeup source
[ 2.551313] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008fbb60, 0x:ffffffd004b72000, irq_no:2e
[ 2.564883] [sunxi-ehci0]: Not init ehci0
[ 2.569954] get ohci0-controller wakeup-source is fail.
[ 2.575993] sunxi ohci0-controller don't init wakeup source
[ 2.582253] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008fc6a0
[ 2.592737] [sunxi-ohci0]: Not init ohci0
[ 2.599841] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.611098] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.618846] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.628550] clk: Not disabling unused clocks
[ 2.633360] ALSA device list:
[ 2.636834] cfg80211: failed to load regulatory.db
[ 2.642278] #0: audiocodec
[ 2.645526] #1: snddmic
[ 2.648534] #2: sndhdmi
[ 2.651470] alloc_fd: slot 0 not NULL!
[ 2.656222] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[ 2.664900] Please append a correct "root=" boot option; here are the available partitions:
[ 2.674362] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.683590] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #41
[ 2.690088] Call Trace:
[ 2.692829] [<ffffffe0000323ce>] walk_stackframe+0x0/0xa0
[ 2.698850] [<ffffffe0000325b0>] show_stack+0x2a/0x34
[ 2.704494] [<ffffffe00060231c>] dump_stack+0x20/0x28
[ 2.710129] [<ffffffe000037376>] panic+0xee/0x2b6
[ 2.715376] [<ffffffe000000eda>] mount_block_root+0x1ee/0x28a
[ 2.721782] [<ffffffe000000ffc>] mount_root+0x86/0x90
[ 2.727414] [<ffffffe000001116>] prepare_namespace+0x110/0x152
[ 2.733916] [<ffffffe000000b78>] kernel_init_freeable+0x17e/0x19a
[ 2.740713] [<ffffffe000615c2a>] kernel_init+0x12/0xee
[ 2.746442] [<ffffffe000031018>] ret_from_exception+0x0/0xc
[ 2.752658] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---离线
屏蔽 /*cd-inverted;*/ 切换cd引脚逻辑
或者无需检测cd引脚:
/*cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
/*non-removable;*/
broken-cd;
&sdc0 {
bus-width = <4>;
/*non-removable;*/
/*broken-cd;*/
/*cd-inverted;*/
/*data3-detect;*/
/*card-pwr-gpios = <&pio PH 14 1 1 2 0xffffffff>;*/
cd-used-24M;
cap-sd-highspeed;
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
no-sdio;
no-mmc;
sunxi-power-save-mode;
/*sunxi-dis-signal-vol-sw;*/
max-frequency = <150000000>;
ctl-spec-caps = <0x8>;
/*vmmc-supply = <®_dcdc1>;*/
/*vqmmc33sw-supply = <®_dcdc1>;*/
/*vdmmc33sw-supply = <®_dcdc1>;*/
/*vqmmc18sw-supply = <®_eldo1>;*/
/*vdmmc18sw-supply = <®_eldo1>;*/
};这样,就能顺利启动了:
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /proc/interrupts
CPU0
1: 0 SiFive PLIC 77 sunxikbd
4: 0 SiFive PLIC 80 2010000.iommu
6: 0 SiFive PLIC 82 cedar_dev
8: 0 SiFive PLIC 160 7090000.rtc
18: 260 SiFive PLIC 18 uart0
26: 0 SiFive PLIC 102 3003000.msgbox
27: 2 SiFive PLIC 27 twi2
29: 0 SiFive PLIC 105 5410000.g2d
32: 101832 SiFive PLIC 108 dispaly
36: 0 SiFive PLIC 36 ledcirq
41: 1 SiFive PLIC 41 audio jack irq
49: 0 SiFive PLIC 49 ehci_hcd:usb1
50: 0 SiFive PLIC 50 ohci_hcd:usb2
56: 2057 SiFive PLIC 56 mmc0
57: 62 SiFive PLIC 57 mmc1
64: 0 SiFive PLIC 140 3003000.msgbox
66: 389 SiFive PLIC 66 3002000.dma-controller
70: 0 SiFive PLIC 144 3003000.msgbox
75: 0 SiFive PLIC 75 timer@2050000
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /proc/meminfo
MemTotal: 50600 kB
MemFree: 10944 kB
MemAvailable: 25120 kB
Buffers: 5188 kB
Cached: 8908 kB
SwapCached: 0 kB
Active: 12464 kB
Inactive: 4476 kB
Active(anon): 2860 kB
Inactive(anon): 28 kB
Active(file): 9604 kB
Inactive(file): 4448 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 2892 kB
Mapped: 3396 kB
Shmem: 44 kB
KReclaimable: 3708 kB
Slab: 14092 kB
SReclaimable: 3708 kB
SUnreclaim: 10384 kB
KernelStack: 944 kB
PageTables: 304 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 25300 kB
Committed_AS: 56192 kB
VmallocTotal: 67108863 kB
VmallocUsed: 2340 kB
VmallocChunk: 0 kB
Percpu: 32 kB
CmaTotal: 8192 kB
CmaFree: 5388 kB
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# top
Mem: 39616K used, 10984K free, 44K shrd, 5188K buff, 8912K cached
CPU: 0% usr 9% sys 0% nic 90% idle 0% io 0% irq 0% sirq
Load average: 1.09 1.03 0.85 1/59 758
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
758 120 root R 2620 5% 5% top
663 1 root S 1496 3% 5% /sbin/swupdate-progress -w
270 1 root S 217m 440% 0% /bin/adbd -D
704 1 root S 85548 169% 0% tt
644 1 root S 9820 19% 0% /usr/sbin/MtpDaemon -D
145 140 root S 5260 10% 0% /usr/bin/lvgl_demo
695 1 root S< 2708 5% 0% /usr/sbin/ntpd -n -N -S /usr/sbin/ntpd
120 1 root S 2684 5% 0% /bin/ash --login
140 1 root S 2620 5% 0% {S99lvgldemo} /bin/sh /etc/rc.common /
261 1 root S 2096 4% 0% /usr/sbin/dbus-daemon --system
1 0 root S 2092 4% 0% /sbin/procd
622 1 root S 1760 3% 0% /sbin/netifd
108 1 root S 1660 3% 0% /sbin/ubusd
121 1 root S 1624 3% 0% /sbin/askfirst /bin/ash --login
10 2 root IW 0 0% 0% [rcu_preempt]
63 2 root SW 0 0% 0% [cec thread]
13 2 root IW 0 0% 0% [kworker/0:1-eve]
62 2 root SW 0 0% 0% [hdmi proc]
750 2 root IW 0 0% 0% [kworker/0:2-eve]
58 2 root IW< 0 0% 0% [kworker/0:1H-kb]离线
最终修改两个文件即可:
device/config/chips/d1/configs/nezha/sys_config.fex
;sunxi platform application
; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串
; 描述gpio的形式:Port:端口+组内序号<功能分配><内部电阻状态><驱动能力><输出电平状态>
; version:版本1.00
; machine:板级文件名
[product]
version = "100"
machine = "nezha"
;debug_mode = 0-close printf, > 0-open printf
[platform]
debug_mode = 8
;storage_type = boot medium, 0-nand, 1-sd, 2-emmc, 3-nor, 4-emmc3, 5-spinand -1(defualt)auto scan
[target]
storage_type = 5
;card_ctrl -卡量产相关的控制器选择0 |
;card_high_speed -速度模式 0为低速,1为高速|
;card_line -4:4线卡,8:8线卡|
;sdc_d1 -sdc卡数据1线信号的GPIO配置 |
;sdc_d0 -sdc卡数据0线信号的GPIO配置 |
;sdc_clk -sdc卡时钟信号的GPIO配置 |
;sdc_cmd -sdc命令信号的GPIO配置|
;sdc_d3 -sdc卡数据3线信号的GPIO配置 |
;sdc_d2 -sdc卡数据2线信号的GPIO配置 |
[card0_boot_para]
card_ctrl = 0
card_high_speed = 1
card_line = 4
sdc_d1 = port:PF0<2><1><2><default>
sdc_d0 = port:PF1<2><1><2><default>
sdc_clk = port:PF2<2><1><2><default>
sdc_cmd = port:PF3<2><1><2><default>
sdc_d3 = port:PF4<2><1><2><default>
sdc_d2 = port:PF5<2><1><2><default>
bus-width = 4
cap-sd-highspeed =
cap-wait-while-busy =
no-sdio =
no-mmc =
sunxi-power-save-mode =
;card_ctrl -卡启动控制器选择2
;sdc_ds -ds信号的GPIO配置
;sdc_d4 -sdc卡数据4线信号的GPIO配置
;sdc_d5 -sdc卡数据5线信号的GPIO配置
;sdc_d6 -sdc卡数据6线信号的GPIO配置
;sdc_d7 -sdc卡数据7线信号的GPIO配置
;sdc_emmc_rst -emmc_rst信号的GPIO配置
;sdc_ex_dly_used -ex_dly_used信号
;sdc_io_1v8 -sdc_io_1v8高速emmc模式配置
[card2_boot_para]
card_ctrl = 2
card_high_speed = 1
card_line = 8
sdc_clk = port:PF25<2><1><3><default>
sdc_cmd = port:PF24<2><1><3><default>
sdc_d0 = port:PF16<2><1><3><default>
sdc_d1 = port:PF17<2><1><3><default>
sdc_d2 = port:PF18<2><1><3><default>
sdc_d3 = port:PF19<2><1><3><default>
sdc_d4 = port:PF20<2><1><3><default>
sdc_d5 = port:PF21<2><1><3><default>
sdc_d6 = port:PF22<2><1><3><default>
sdc_d7 = port:PF23<2><1><3><default>
sdc_emmc_rst = port:PF31<2><1><3><default>
sdc_ds = port:PF27<2><1><3><default>
;jtag_enable |JTAG使能 |
;jtag_ms |测试模式选择输入(TMS) 的GPIO配置|
;jtag_ck |测试时钟输入(CLK) 的GPIO配置 |
;jtag_do |测试数据输出(TDO) 的GPIO配置 |
;jtag_di |测试数据输出(TDI) 的GPIO配置 |
[jtag_para]
jtag_enable = 0
jtag_ms = port:PF0<4><default><default><default>
jtag_ck = port:PF5<4><default><default><default>
jtag_do = port:PF3<4><default><default><default>
jtag_di = port:PF1<4><default><default><default>
;dram select configuration
;select_mode : dram模式选择, 0:不进行自动识别
; 1:gpio识别模式(dram_para, dram_para1-15, 共16组有效)
; 2:gpadc识别模式(dram_para, dram_para1-7, 共8组有效)
; 3:1个IO+gpadc识别模式(dram_para, dram_para1-15, 共16组有效)。其中IO配置优先级按select_gpio0>select_gpio1>select_gpio2>select_gpio3
;gpadc_channel : 选择gpadc通道 有效值(0-3)
;select_gpio1-4 : 选择gpio pin
[dram_select_para]
select_mode = 0
gpadc_channel = 1
select_gpio0 = port:PB7<0><1><default><default>
select_gpio1 = port:PB4<0><1><default><default>
select_gpio2 = port:PH1<0><1><default><default>
select_gpio3 = port:PH0<0><1><default><default>
;sdram configuration
[dram_para]
dram_clk = 528
dram_type = 2
dram_zq = 0x07b7bf9
dram_odt_en = 0x00
dram_para1 = 0x000000d2
dram_para2 = 0x00000000
dram_mr0 = 0x00000E73
dram_mr1 = 0x02
dram_mr2 = 0x0
dram_mr3 = 0x0
dram_tpr0 = 0x00471992
dram_tpr1 = 0x0131A10C
dram_tpr2 = 0x00057041
dram_tpr3 = 0xB4787896
dram_tpr4 = 0x0
dram_tpr5 = 0x48484848
dram_tpr6 = 0x48
dram_tpr7 = 0x1621121e
dram_tpr8 = 0x0
dram_tpr9 = 0x0
dram_tpr10 = 0x00000000
dram_tpr11 = 0x00030010
dram_tpr12 = 0x00000035
dram_tpr13 = 0x34000000
[dram_para1]
dram_clk = 672
dram_type = 7
dram_dx_odt = 0x06060606
dram_dx_dri = 0x0c0c0c0c
dram_ca_dri = 0x1919
dram_para0 = 0x16171411
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr6 = 0x2fb48080
dram_tpr10 = 0x002f876b
dram_tpr11 = 0x10120c05
dram_tpr12 = 0x12121111
dram_tpr13 = 0x61
dram_tpr14 = 0x211e1e22
[dram_para2]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para3]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para4]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para5]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para6]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para7]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para8]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para9]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para10]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para11]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para12]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para13]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para14]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
[dram_para15]
dram_clk = 672
dram_type = 7
dram_para1 = 0x30eb
dram_para2 = 0x0000
dram_mr0 = 0x0
dram_mr1 = 0xc3
dram_mr2 = 0x6
dram_mr3 = 0x2
dram_mr4 = 0x0
dram_mr5 = 0x0
dram_mr6 = 0x0
dram_mr11 = 0x0
dram_mr12 = 0x0
dram_mr13 = 0x0
dram_mr14 = 0x0
dram_mr16 = 0x0
dram_mr17 = 0x0
dram_mr22 = 0x0
dram_tpr0 = 0x0
dram_tpr1 = 0x0
dram_tpr2 = 0x0
dram_tpr3 = 0x0
dram_tpr13 = 0x61
;twi configuration
;twi_used 0:关闭, 1:打开
;twi_port 0:twi0, 1:twi1, 2:twi2, 3:twi3, 4:twi4, 5:twi5, 6:r_twi0, 7:r_twi1
;twi_scl boot0 scl的GPIO配置
;twi_sda boot0 sda的GPIO配置
[twi_para]
twi_used = 0
twi_port = 2
twi_scl = port:PG14<3><1><default><default>
twi_sda = port:PG15<3><1><default><default>
;uart configuration
;uart_debug_port |Boot串口控制器编号 |
;uart_debug_tx |Boot串口发送的GPIO配置|
;uart_debug_rx |Boot串口接收的GPIO配置 |
[uart_para]
uart_debug_port = 0
uart_debug_tx = port:PE02<6><1><default><default>
uart_debug_rx = port:PE03<6><1><default><default>
;dram_region_mbytes :设置drm大小以bytes为单位
[secure]
dram_region_mbytes = 80
drm_region_mbytes = 0
drm_region_start_mbytes = 0device/config/chips/d1/configs/nezha/board.dts
* Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
* fpga support.
/dts-v1/;
#include "sun20iw1p1.dtsi"
compatible = "allwinner,d1", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
aliases {
dsp0 = &dsp0;
dsp0_gpio_int= &dsp0_gpio_int;
dsp0: dsp0 {
compatible = "allwinner,sun20iw1-dsp";
dsp0_gpio_int: dsp0_gpio_int {
compatible = "allwinner,sun20iw1-dsp-gpio-int";
pin-group = "PB", "PC", "PD", "PE";
status = "disabled";
reg_vdd_cpu: vdd-cpu {
compatible = "sunxi-pwm-regulator";
pwms = <&pwm 0 5000 0>;
regulator-name = "vdd_cpu";
regulator-min-microvolt = <810000>;
regulator-max-microvolt = <1160000>;
regulator-ramp-delay = <25>;
regulator-always-on;
regulator-boot-on;
reg_usb1_vbus: usb1-vbus {
regulator-name = "usb1-vbus";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-enable-ramp-delay = <1000>;
gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
enable-active-high;
&CPU0 {
cpu-supply = <®_vdd_cpu>;
&pio {
sdc0_pins_a: sdc0@0 {
allwinner,pins = "PF0", "PF1", "PF2",
"PF3", "PF4", "PF5";
allwinner,function = "sdc0";
allwinner,muxsel = <2>;
allwinner,drive = <3>;
allwinner,pull = <1>;
function = "sdc0";
drive-strength = <30>;
bias-pull-up;
power-source = <3300>;
sdc0_pins_b: sdc0@1 {
function = "sdc0";
bias-pull-up;
power-source = <1800>;
sdc0_pins_c: sdc0@2 {
function = "gpio_in";
/* TODO: add jtag pin */
sdc0_pins_d: sdc0@3 {
pins = "PF2", "PF4";
function = "uart0";
drive-strength = <10>;
bias-pull-up;
sdc0_pins_e: sdc0@4 {
pins = "PF0", "PF1", "PF3",
"PF5";
function = "jtag";
bias-pull-up;
sdc1_pins_a: sdc1@0 {
pins = "PG0", "PG1", "PG2",
"PG3", "PG4", "PG5";
function = "sdc1";
bias-pull-up;
sdc1_pins_b: sdc1@1 {
sdc2_pins_a: sdc2@0 {
allwinner,pins = "PC2", "PC3", "PC4",
"PC5", "PC6", "PC7";
allwinner,function = "sdc2";
allwinner,muxsel = <3>;
function = "sdc2";
bias-pull-up;
sdc2_pins_b: sdc2@1 {
wlan_pins_a:wlan@0 {
pins = "PG11";
function = "clk_fanout1";
uart0_pins_a: uart0_pins@0 { /* For nezha board */
pins = "PB8", "PB9";
function = "uart0";
bias-pull-up;
uart0_pins_b: uart0_pins@1 { /* For nezha board */
uart1_pins_a: uart1_pins@0 { /* For EVB1 board */
pins = "PG6", "PG7", "PG8", "PG9";
function = "uart1";
bias-pull-up;
uart1_pins_b: uart1_pins { /* For EVB1 board */
uart2_pins_a: uart2_pins@0 { /* For EVB1 board */
pins = "PC0", "PC1";
function = "uart2";
bias-pull-up;
uart2_pins_b: uart2_pins@1 { /* For EVB1 board */
uart3_pins_a: uart3_pins@0 { /* For EVB1 board */
pins = "PD10", "PD11";
function = "uart3";
muxsel = <5>;
bias-pull-up;
twi0_pins_a: twi0@0 {
pins = "PB10", "PB11"; /*sck sda*/
function = "twi0";
twi0_pins_b: twi0@1 {
twi1_pins_a: twi1@0 {
pins = "PB4", "PB5";
function = "twi1";
twi1_pins_b: twi1@1 {
twi2_pins_a: twi2@0 {
pins = "PB0", "PB1";
function = "twi2";
twi2_pins_b: twi2@1 {
twi3_pins_a: twi3@0 {
pins = "PB6", "PB7";
function = "twi3";
twi3_pins_b: twi3@1 {
gmac_pins_a: gmac@0 {
pins = "PE0", "PE1", "PE2", "PE3",
"PE4", "PE5", "PE6", "PE7",
"PE8", "PE9", "PE10", "PE11",
"PE12", "PE13", "PE14", "PE15";
function = "gmac0";
gmac_pins_b: gmac@1 {
dmic_pins_a: dmic@0 {
/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
pins = "PE17", "PB11", "PB10", "PD17";
function = "dmic";
drive-strength = <20>;
bias-disable;
dmic_pins_b: dmic@1 {
function = "io_disabled";
bias-disable;
daudio0_pins_a: daudio0@0 {
pins = "PE17", "PE16", "PE15", "PE14", "PE13";
function = "i2s0";
bias-disable;
daudio0_pins_b: daudio0_sleep@0 {
bias-disable;
daudio1_pins_a: daudio1@0 {
pins = "PG11", "PG12", "PG13", "PG14", "PG15";
function = "i2s1";
bias-disable;
daudio1_pins_b: daudio1_sleep@0 {
bias-disable;
daudio2_pins_a: daudio2@0 {
/* I2S_PIN: MCLK, BCLK, LRCK */
pins = "PB7", "PB5", "PB6";
function = "i2s2";
bias-disable;
daudio2_pins_b: daudio2@1 {
/* I2S_PIN: DOUT0 */
pins = "PB4";
function = "i2s2_dout";
bias-disable;
daudio2_pins_c: daudio2@2 {
/* I2S_PIN: DIN0 */
pins = "PB3";
function = "i2s2_din";
bias-disable;
daudio2_pins_d: daudio2_sleep@0 {
pins = "PB7", "PB5", "PB6", "PB4", "PB3";
bias-disable;
spdif_pins_a: spdif@0 {
/* SPDIF_PIN: SPDIF_OUT */
pins = "PB0";
function = "spdif";
bias-disable;
spdif_pins_b: spdif_sleep@0 {
pins = "PB0";
bias-disable;
spi0_pins_a: spi0@0 {
pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
function = "spi0";
muxsel = <2>;
spi0_pins_b: spi0@1 {
pins = "PC3", "PC7", "PC6";
function = "spi0";
muxsel = <2>;
bias-pull-up; /* only CS should be pulled up */
spi0_pins_c: spi0@2 {
pins = "PC2", "PC3", "PC4", "PC5","PC6", "PC7";
muxsel = <0>;
spi1_pins_a: spi1@0 {
pins = "PD11", "PD12", "PD13","PD14", "PD15"; /*clk mosi miso hold wp*/
function = "spi1";
spi1_pins_b: spi1@1 {
pins = "PD10";
function = "spi1";
bias-pull-up; // only CS should be pulled up
spi1_pins_c: spi1@2 {
pins = "PD10", "PD11", "PD12", "PD13","PD14", "PD15";
ledc_pins_a: ledc@0 {
pins = "PC0";
function = "ledc";
ledc_pins_b: ledc@1 {
pins = "PC0";
pwm0_pin_a: pwm0@0 {
pins = "PD16";
function = "pwm0";
bias-pull-up;
pwm0_pin_b: pwm0@1 {
pins = "PD16";
bias-disable;
pwm2_pin_a: pwm2@0 {
pins = "PD18";
function = "pwm2";
bias-pull-up;
pwm2_pin_b: pwm2@1 {
pins = "PD18";
pwm7_pin_a: pwm7@0 {
pins = "PD22";
function = "pwm7";
bias-pull-up;
pwm7_pin_b: pwm7@1 {
pins = "PD22";
s_cir0_pins_a: s_cir@0 {
pins = "PB12";
function = "ir";
bias-pull-up;
s_cir0_pins_b: s_cir@1 {
pins = "PB12";
ir1_pins_a: ir1@0 {
pins = "PB0";
function = "ir";
bias-pull-up;
ir1_pins_b: ir1@1 {
pins = "PB0";
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
pinctrl-1 = <&uart0_pins_b>;
&uart1 {
pinctrl-0 = <&uart1_pins_a>;
pinctrl-1 = <&uart1_pins_b>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
pinctrl-1 = <&uart2_pins_b>;
&uart3 {
/*compatible = "allwinner,sun20iw1-dsp-uart";*/
pinctrl-0 = <&uart3_pins_a>;
pinctrl-1 = <&uart3_pins_a>;
&soc {
card0_boot_para@2 {
* Avoid dtc compiling warnings.
* @TODO: Developer should modify this to the actual value
reg = <0x0 0x2 0x0 0x0>;
device_type = "card0_boot_para";
card_ctrl = <0x0>;
card_high_speed = <0x1>;
card_line = <0x4>;
pinctrl-0 = <&sdc0_pins_a>;
card2_boot_para@3 {
reg = <0x0 0x3 0x0 0x0>;
device_type = "card2_boot_para";
card_ctrl = <0x2>;
card_line = <0x4>;
pinctrl-0 = <&sdc2_pins_a>;
/*pinctrl-0 = <&sdc0_pins_a>;*/
/*sdc_ex_dly_used = <0x2>;*/
sdc_io_1v8 = <0x1>;
/*sdc_type = "tm4";*/
sdc_tm4_hs200_max_freq = <150>;
sdc_tm4_hs400_max_freq = <100>;
sdc_ex_dly_used = <2>;
/*sdc_tm4_win_th = <8>;*/
/*sdc_dis_host_caps = <0x180>;*/
rfkill: rfkill@0 {
compatible = "allwinner,sunxi-rfkill";
chip_en;
power_en;
wlan: wlan@0 {
compatible = "allwinner,sunxi-wlan";
pinctrl-0 = <&wlan_pins_a>;
pinctrl-names = "default";
clock-names = "32k-fanout1";
clocks = <&ccu CLK_FANOUT1_OUT>;
wlan_busnum = <0x1>;
wlan_regon = <&pio PG 12 GPIO_ACTIVE_HIGH>;
wlan_hostwake = <&pio PG 10 GPIO_ACTIVE_HIGH>;
/*wlan_power = "VCC-3V3";*/
/*wlan_power_vol = <3300000>;*/
/*interrupt-parent = <&pio>;
interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
wakeup-source;
bt: bt@0 {
compatible = "allwinner,sunxi-bt";
/*bt_power_num = <0x01>;*/
/*bt_power = "axp803-dldo1";*/
/*bt_io_regulator = "axp803-dldo1";*/
/*bt_io_vol = <3300000>;*/
/*bt_power_vol = <330000>;*/
bt_rst_n = <&pio PG 18 GPIO_ACTIVE_LOW>;
btlpm: btlpm@0 {
compatible = "allwinner,sunxi-btlpm";
uart_index = <0x1>;
bt_wake = <&pio PG 16 GPIO_ACTIVE_HIGH>;
bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
addr_mgt: addr_mgt@0 {
compatible = "allwinner,sunxi-addr_mgt";
type_addr_wifi = <0x0>;
type_addr_bt = <0x0>;
type_addr_eth = <0x0>;
&sdc2 {
non-removable;
bus-width = <4>;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
no-sdio;
no-sd;
ctl-spec-caps = <0x308>;
cap-mmc-highspeed;
mmc-bootpart-noacc;
/*emmc io vol 3.3v*/
/*vqmmc-supply = <®_aldo1>;*/
/*emmc io vol 1.8v*/
/*vqmmc-supply = <®_eldo1>;*/
&sdc0 {
bus-width = <4>;
/*non-removable;*/
/*broken-cd;*/
/*cd-inverted*/;
/*data3-detect;*/
cd-used-24M;
cap-sd-highspeed;
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
no-sdio;
no-mmc;
&sdc1 {
bus-width = <4>;
no-mmc;
no-sd;
cap-sd-highspeed;
/*sd-uhs-sdr12*/
/*sd-uhs-sdr25;*/
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
/*sunxi-power-save-mode;*/
cap-sdio-irq;
keep-power-in-suspend;
ignore-pm-notify;
tvd configuration
used (create device, 0: do not create device, 1: create device)
agc_auto_enable (0: agc manual mode,agc_manual_value is valid; 1: agc auto mode)
agc_manual_value (agc manual value, default value is 64)
cagc_enable (cagc 0: disable, 1: enable)
fliter_used (3d fliter 0: disable, 1: enable)
support two PMU power (tvd_power0, tvd_power1)
support two GPIO power (tvd_gpio0, tvd_gpio1)
NOTICE: If tvd need pmu power or gpio power,params need be configured under [tvd]
tvd_sw (the switch of all tvd driver.)
tvd_interface (0: cvbs, 1: ypbpr,)
tvd_format (0:TVD_PL_YUV420 , 1: MB_YUV420, 2: TVD_PL_YUV422)
tvd_system (0:ntsc, 1:pal)
tvd_row (total row number in multi channel mode 1-2)
tvd_column (total column number in multi channel mode 1-2)
tvd_channelx_en (0:disable, 1~4:position in multi channel mode,In single channel
mode,mean enable)
tvd_row*tvd_column is the total tvd channel number to be used in multichannel mode
| 1 | 2 |
| 3 | 4 |
&tvd {
tvd_sw = <1>;
tvd_interface = <0>;
tvd_format = <0>;
tvd_system = <1>;
tvd_row = <1>;
tvd_column = <1>;
tvd_channel0_en = <1>;
tvd_channel1_en = <0>;
tvd_channel2_en = <0>;
tvd_channel3_en = <0>;
/*tvd_gpio0 = <&pio PD 22 GPIO_ACTIVE_HIGH>;*/
/*tvd_gpio1 = <&pio PD 23 GPIO_ACTIVE_HIGH>;*/
/*tvd_gpio2 = <&pio PD 24 GPIO_ACTIVE_HIGH>;*/
/* dc1sw-supply = <®_dc1sw>;*/
/* eldo3-supply = <®_eldo3>;*/
/*tvd_power0 = "dc1sw"*/
/*tvd_power1 = "eldo3"*/
&tvd0 {
used = <1>;
agc_auto_enable = <1>;
agc_manual_value = <64>;
cagc_enable = <1>;
fliter_used = <1>;
/* Audio Driver modules */
&sunxi_rpaf_dsp0 {
/* if audiocodec is used, sdc0 and uart0 should be closed to enable PA. */
&codec {
/* MIC and headphone gain setting */
mic1gain = <0x13>;
mic2gain = <0x13>;
mic3gain = <0x13>;
/* ADC/DAC DRC/HPF func enabled */
/* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */
adcdrc_cfg = <0x0>;
adchpf_cfg = <0x1>;
dacdrc_cfg = <0x0>;
dachpf_cfg = <0x0>;
/* Volume about */
digital_vol = <0x00>;
lineout_vol = <0x1a>;
headphonegain = <0x03>;
/* Pa enabled about */
pa_level = <0x01>;
pa_pwr_level = <0x01>;
pa_msleep_time = <0x78>;
/* gpio-spk = <&pio PF 2 GPIO_ACTIVE_HIGH>; */
/* gpio-spk-pwr = <&pio PF 4 GPIO_ACTIVE_HIGH>; */
/* regulator about */
/* avcc-supply = <®_aldo1>; */
/* hpvcc-supply = <®_eldo1>; */
&sndcodec {
hp_detect_case = <0x01>;
jack_enable = <0x01>;
&dummy_cpudai {
/* CMA config about */
playback_cma = <128>;
capture_cma = <256>;
&dmic {
pinctrl-names = "default","sleep";
pinctrl-0 = <&dmic_pins_a>;
pinctrl-1 = <&dmic_pins_b>;
&sounddmic {
&dmic_codec {
* pcm_lrck_period 16/32/64/128/256
* (set 0x20 for HDMI audio out)
* slot_width_select 16bits/20bits/24bits/32bits
* frametype 0 --> short frame = 1 clock width;
* 1 --> long frame = 2 clock width;
* tdm_config 0 --> pcm
* 1 --> i2s
* (set 0x01 for HDMI audio out)
* mclk_div 0 --> not output
* 1/2/4/6/8/12/16/24/32/48/64/96/128/176/192
* (set mclk as external codec clk source, freq is pll_audio/mclk_div)
* pinctrl_used 0 --> I2S/PCM use for internal (e.g. HDMI)
* 1 --> I2S/PCM use for external audio
* daudio_type: 0 --> external audio type
* 1 --> HDMI audio type
&daudio0 {
mclk_div = <0x01>;
frametype = <0x00>;
tdm_config = <0x01>;
sign_extend = <0x00>;
msb_lsb_first = <0x00>;
pcm_lrck_period = <0x80>;
slot_width_select = <0x20>;
pinctrl-0 = <&daudio0_pins_a>;
pinctrl-1 = <&daudio0_pins_b>;
pinctrl_used = <0x0>;
* simple-audio-card,name name of sound card, e.g.
* "snddaudio0" --> use for external audio
* "sndhdmi" --> use for HDMI audio
* sound-dai "snd-soc-dummy" --> use for I2S
* "hdmiaudio" --> use for HDMI audio
* "ac108" --> use for external audio of ac108
&sounddaudio0 {
/* simple-audio-card,format = "i2s"; */
/* simple-audio-card,frame-master = <&daudio0_master>; */
/* simple-audio-card,bitclock-master = <&daudio0_master>; */
/* simple-audio-card,bitclock-inversion; */
/* simple-audio-card,frame-inversion; */
daudio0_master: simple-audio-card,codec {
/* sound-dai = <&ac108>; */
&daudio1 {
mclk_div = <0x01>;
frametype = <0x00>;
pinctrl-0 = <&daudio1_pins_a>;
pinctrl-1 = <&daudio1_pins_b>;
&sounddaudio1 {
daudio1_master: simple-audio-card,codec {
&daudio2 {
mclk_div = <0x00>;
frametype = <0x00>;
tx_data_mode = <0x00>;
rx_data_mode = <0x00>;
pcm_lrck_period = <0x20>;
asrc_function_en = <0x00>;
/*pinctrl-0 = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
/*pinctrl-1 = <&daudio2_pins_d>;*/
/* HDMI audio, no need pin */
pinctrl-0;
pinctrl-1;
daudio_type = <0x1>;
/* if HDMI audio is used, daudio2 should be enable. */
&hdmiaudio {
&sounddaudio2 {
simple-audio-card,name = "sndhdmi";
daudio2_master: simple-audio-card,codec {
sound-dai = <&hdmiaudio>;
&spdif {
pinctrl-0 = <&spdif_pins_a>;
pinctrl-1 = <&spdif_pins_b>;
&soundspdif {
*usb_port_type: usb mode. 0-device, 1-host, 2-otg.
*usb_detect_type: usb hotplug detect mode. 0-none, 1-vbus/id detect, 2-id/dpdm detect.
*usb_detect_mode: 0-thread scan, 1-id gpio interrupt.
*usb_id_gpio: gpio for id detect.
*usb_det_vbus_gpio: gpio for id detect. gpio or "axp_ctrl";
*usb_wakeup_suspend:0-SUPER_STANDBY, 1-USB_STANDBY.
&usbc0 {
device_type = "usbc0";
usb_port_type = <0x2>;
usb_detect_type = <0x1>;
usb_detect_mode = <0>;
usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
enable-active-high;
usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
usb_wakeup_suspend = <0>;
usb_serial_unique = <0>;
usb_serial_number = "20080411";
rndis_wceis = <1>;
&ehci0 {
drvvbus-supply = <®_usb1_vbus>;
&ohci0 {
&usbc1 {
device_type = "usbc1";
usb_regulator_io = "nocare";
&ehci1 {
&ohci1 {
&twi0 {
clock-frequency = <400000>;
pinctrl-0 = <&twi0_pins_a>;
pinctrl-1 = <&twi0_pins_b>;
eeprom@50 {
compatible = "atmel,24c16";
reg = <0x50>;
&twi1 {
pinctrl-0 = <&twi1_pins_a>;
pinctrl-1 = <&twi1_pins_b>;
&twi2 {
pinctrl-0 = <&twi2_pins_a>;
pinctrl-1 = <&twi2_pins_b>;
dmas = <&dma 45>, <&dma 45>;
dma-names = "tx", "rx";
/* pcf8574-usage:
* only use gpio0~7, 0 means PP0.
* pin set:
* gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>;
* interrupt set:
* interrupt-parent = <&pcf8574>;
* interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
pcf8574: gpio@38 {
compatible = "nxp,pcf8574";
reg = <0x38>;
gpio_base = <2020>;
gpio-controller;
#gpio-cells = <2>;
interrupt-controller;
#interrupt-cells = <2>;
interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>;
ctp@14 {
compatible = "allwinner,goodix";
device_type = "ctp";
reg = <0x14>;
ctp_name = "gt9xxnew_ts";
ctp_twi_id = <0x2>;
ctp_twi_addr = <0x14>;
ctp_screen_max_x = <0x320>;
ctp_screen_max_y = <0x500>;
ctp_revert_x_flag = <0x0>;
ctp_revert_y_flag = <0x0>;
ctp_exchange_x_y_flag = <0x0>;
ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
&twi3 {
pinctrl-0 = <&twi3_pins_a>;
pinctrl-1 = <&twi3_pins_b>;
&gmac0 {
phy-mode = "rgmii";
use_ephy25m = <1>;
pinctrl-0 = <&gmac_pins_a>;
pinctrl-1 = <&gmac_pins_b>;
phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
tx-delay = <3>; /*2~4*/
rx-delay = <0>;
status = "disable";
&spi0 {
clock-frequency = <100000000>;
pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
pinctrl-1 = <&spi0_pins_c>;
/*spi-supply = <®_dcdc1>;*/
spi_slave_mode = <0>;
spi0_cs_number = <1>;
spi0_cs_bitmap = <1>;
spi-nand@0 {
compatible = "spi-nand";
spi-max-frequency=<0x5F5E100>;
reg = <0x0>;
spi-rx-bus-width=<0x04>;
spi-tx-bus-width=<0x04>;
status="disabled";
&spi1 {
pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
pinctrl-1 = <&spi1_pins_c>;
spi_board1@0 {
device_type = "spi_board1";
compatible = "rohm,dh2228fv";
spi-max-frequency = <0x5f5e100>;
reg = <0x0>;
spi-rx-bus-width = <0x4>;
spi-tx-bus-width = <0x4>;
&ledc {
pinctrl-0 = <&ledc_pins_a>;
pinctrl-1 = <&ledc_pins_b>;
led_count = <12>;
output_mode = "GRB";
reset_ns = <84>;
t1h_ns = <800>;
t1l_ns = <320>;
t0h_ns = <300>;
t0l_ns = <800>;
wait_time0_ns = <84>;
wait_time1_ns = <84>;
wait_data_time_ns = <600000>;
&keyboard0 {
key0 = <210 0x160>;
wakeup-source;
disp init configuration
disp_mode (0:screen0<screen0,fb0>)
screenx_output_type (0:none; 1:lcd; 2:tv; 3:hdmi;5:vdpo)
screenx_output_mode (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50)
(5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60)
screenx_output_format (for hdmi, 0:RGB 1:yuv444 2:yuv422 3:yuv420)
screenx_output_bits (for hdmi, 0:8bit 1:10bit 2:12bit 2:16bit)
screenx_output_eotf (for hdmi, 0:reserve 4:SDR 16:HDR10 18:HLG)
screenx_output_cs (for hdmi, 0:undefined 257:BT709 260:BT601 263:BT2020)
screenx_output_dvi_hdmi (for hdmi, 0:undefined 1:dvi mode 2:hdmi mode)
screen0_output_range (for hdmi, 0:default 1:full 2:limited)
screen0_output_scan (for hdmi, 0:no data 1:overscan 2:underscan)
screen0_output_aspect_ratio (for hdmi, 8-same as original picture 9-4:3 10-16:9 11-14:9)
fbx format (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444)
fbx pixel sequence (0:ARGB 1:BGRA 2:ABGR 3:RGBA)
fb0_scaler_mode_enable(scaler mode enable, used FE)
fbx_width,fbx_height (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0)
lcdx_backlight (lcd init backlight,the range:[0,256],default:197
lcdx_yy (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50)
lcd0_contrast (LCD contrast, 0~100)
lcd0_saturation (LCD saturation, 0~100)
lcd0_hue (LCD hue, 0~100)
framebuffer software rotation setting:
disp_rotation_used: (0:disable; 1:enable,you must set fbX_width to lcd_y,
set fbX_height to lcd_x)
degreeX: (X:screen index; 0:0 degree; 1:90 degree; 3:270 degree)
degreeX_Y: (X:screen index; Y:layer index 0~15; 0:0 degree; 1:90 degree; 3:270 degree)
devX_output_type : config output type in bootGUI framework in UBOOT-2018.
(0:none; 1:lcd; 2:tv; 4:hdmi;)
devX_output_mode : config output resolution(see include/video/sunxi_display2.h) of bootGUI framework in UBOOT-2018
devX_screen_id : config display index of bootGUI framework in UBOOT-2018
devX_do_hpd : whether do hpd detectation or not in UBOOT-2018
chn_cfg_mode : Hardware DE channel allocation config. 0:single display with 6
channel, 1:dual display with 4 channel in main display and 2 channel in second
display, 2:dual display with 3 channel in main display and 3 channel in second
in display.
&disp {
disp_init_enable = <1>;
disp_mode = <0>;
screen0_output_type = <1>;
screen0_output_mode = <4>;
screen1_output_type = <3>;
screen1_output_mode = <10>;
screen1_output_format = <0>;
screen1_output_bits = <0>;
screen1_output_eotf = <4>;
screen1_output_cs = <257>;
screen1_output_dvi_hdmi = <2>;
screen1_output_range = <2>;
screen1_output_scan = <0>;
screen1_output_aspect_ratio = <8>;
dev0_output_type = <1>;
dev0_output_mode = <4>;
dev0_screen_id = <0>;
dev0_do_hpd = <0>;
dev1_output_type = <4>;
dev1_output_mode = <10>;
dev1_screen_id = <1>;
dev1_do_hpd = <1>;
def_output_dev = <0>;
hdmi_mode_check = <1>;
fb0_format = <0>;
fb0_width = <0>;
fb0_height = <0>;
fb1_format = <0>;
fb1_width = <0>;
fb1_height = <0>;
chn_cfg_mode = <1>;
disp_para_zone = <1>;
/*VCC-LCD*/
/*VCC-DSI*/
/*VCC-PD*/
/* dcdc1-supply = <®_dcdc1>;*/
;lcd0 configuration
;lcd_if: 0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_hv_if 0:Parallel RGB; 8:Serial RGB; 10:Dummy RGB; 11: RGB Dummy;12:CCIR656
;lcd_hv_clk_phase 0:0 degree;1:90 degree;2:180 degree;3:270 degree
;lcd_hv_sync_polarity 0:vs low,hs low; 1:vs high,hslow; 2:vs low,hs high; 3:vs high,hs high
;lcd_hv_syuv_seq 0:YUYV; 1:YVYU; 2:UYVY; 3:VYUY
;lcd_cpu_if 0:18bit/1 cycle parallel(RGB666); 4:16bit/1cycle parallel (RGB565)
; 6:18bit/3 cycle parallel(RGB666); 7:16bit/2cycle parallel (RGB565)
;lcd_cpu_te 0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_dsi_if 0:video mode; 1: Command mode; 2:video burst mode
;lcd_dsi_te 0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_x: lcd horizontal resolution
;lcd_y: lcd vertical resolution
;lcd_width: width of lcd in mm
;lcd_height: height of lcd in mm
;lcd_dclk_freq: in MHZ unit
;lcd_pwm_freq: in HZ unit
;lcd_pwm_pol: lcd backlight PWM polarity
;lcd_pwm_max_limit lcd backlight PWM max limit(<=255)
;lcd_hbp: hsync back porch(pixel) + hsync plus width(pixel);
;lcd_ht: hsync total cycle(pixel)
;lcd_vbp: vsync back porch(line) + vysnc plus width(line)
;lcd_vt: vysnc total cycle(line)
;lcd_hspw: hsync plus width(pixel)
;lcd_vspw: vysnc plus width(pixel)
;lcd_lvds_if: 0:single link; 1:dual link
;lcd_lvds_colordepth: 0:8bit; 1:6bit
;lcd_lvds_mode: 0:NS mode; 1:JEIDA mode
;lcd_frm: 0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase: 0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
; 8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en lcd gamma correction enable
;lcd_bright_curve_en lcd bright curve correction enable
;lcd_cmap_en lcd color map function enable
;deu_mode 0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep: Smart Backlight parameter, lcd gamma vale * 10;
; decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color 90:normal lcd screen 65:retina lcd screen(9.7inch)
;Pin setting for special function ie.LVDS, RGB data or vsync
; name(donot care) = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for gpio:
; lcd_gpio_X = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for backlight enable pin
; lcd_bl_en = port:PD12<pin function><pull up or pull down><drive ability><output level>
;fsync setting, pulse to csi
;lcd_fsync_en (0:disable fsync,1:enable)
;lcd_fsync_act_time (active time of fsync, unit:pixel)
;lcd_fsync_dis_time (disactive time of fsync, unit:pixel)
;lcd_fsync_pol (0:positive;1:negative)
;gpio config: <&pio for cpu or &r_pio for cpus, port, port num, pio function,
pull up or pull down(default 0), driver level(default 1), data>
;For dual link lvds: use lvds2link_pins_a and lvds2link_pins_b instead
;For rgb24: use rgb24_pins_a and rgb24_pins_b instead
;For lvds1: use lvds1_pins_a and lvds1_pins_b instead
;For lvds0: use lvds0_pins_a and lvds0_pins_b instead
&lcd0 {
lcd_used = <1>;
lcd_driver_name = "tft08006";
lcd_backlight = <100>;
lcd_if = <4>;
lcd_x = <800>;
lcd_y = <1280>;
lcd_width = <52>;
lcd_height = <52>;
lcd_dclk_freq = <70>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <2>;
lcd_pwm_freq = <1000>;
lcd_pwm_pol = <0>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <32>;
lcd_ht = <868>;
lcd_hspw = <4>;
lcd_vbp = <12>;
lcd_vt = <1311>;
lcd_vspw = <4>;
lcd_dsi_if = <0>;
lcd_dsi_lane = <4>;
lcd_lvds_if = <0>;
lcd_lvds_colordepth = <0>;
lcd_lvds_mode = <0>;
lcd_frm = <0>;
lcd_hv_clk_phase = <0>;
lcd_hv_sync_polarity= <0>;
lcd_io_phase = <0x0000>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
lcd_fsync_en = <0>;
lcd_fsync_act_time = <1000>;
lcd_fsync_dis_time = <1000>;
lcd_fsync_pol = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
lcd_gpio_0 = <&pio PG 13 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&dsi4lane_pins_a>;
pinctrl-1 = <&dsi4lane_pins_b>;
&hdmi {
hdmi_used = <1>;
hdmi_power_cnt = <0>;
hdmi_cts_compatibility = <1>;
hdmi_hdcp_enable = <1>;
hdmi_hdcp22_enable = <0>;
hdmi_cec_support = <1>;
hdmi_cec_super_standby = <0>;
ddc_en_io_ctrl = <0>;
power_io_ctrl = <0>;
&pwm0 {
pinctrl-names = "active", "sleep";
pinctrl-0 = <&pwm0_pin_a>;
pinctrl-1 = <&pwm0_pin_b>;
&pwm2 {
pinctrl-0 = <&pwm2_pin_a>;
pinctrl-1 = <&pwm2_pin_b>;
&pwm7 {
pinctrl-0 = <&pwm7_pin_a>;
pinctrl-1 = <&pwm7_pin_b>;
&rtp {
allwinner,tp-sensitive-adjust = <0xf>;
allwinner,filter-type = <0x1>;
allwinner,ts-attached;
&gpadc {
channel_num = <2>;
channel_select = <3>;
channel_data_select = <3>;
channel_compare_select = <3>;
channel_cld_select = <3>;
channel_chd_select = <3>;
channel0_compare_lowdata = <1700000>;
channel0_compare_higdata = <1200000>;
channel1_compare_lowdata = <460000>;
channel1_compare_higdata = <1200000>;
&s_cir0 {
pinctrl-0 = <&s_cir0_pins_a>;
pinctrl-1 = <&s_cir0_pins_b>;
&ir1 {
pinctrl-0 = <&ir1_pins_a>;
pinctrl-1 = <&ir1_pins_b>;
};用烧卡工具烧到TF卡启动:
固件下载: tina_d1-nezha_uart0_f133_nolcd.7z
LCD 还没有测试。
