楼主 #1 2019-11-14 09:45:09
所在地: 芒果派
已发帖子: 779
凌阳突然出来一款QFP封装神芯SP7021(四核A7+ARM9+8051)
不知道发到哪个版块,先放电子综合了,丢给站长处理(逃
新闻来自这里: https://www.cnx-software.com/2019/11/13 … lopment%29
芯片手册: https://sunplus-tibbo.atlassian.net/wiki/spaces/doc/pages/374669411/SP7021+Datasheet
框图:
特性:
Key features:
CPU
Quad-core Cortex-A7 CPU @ 1.0 GHz with 512KB L2 cache
Arm A926 real-time core @ 202 MHz
8051 core for I/Os. 500uA @ 32KHz for the entire IC
System Memory – 128MB or 512MB DDR3 DRAM
Storage I/F – eMMC flash interface, SPI NOR / NAND flash interface, SD card interface
Video Input/Output
HDMI Tx 1.4
Parallel LCD
MIPI LCD camera interface
Audio – TDM, PDM, I2S input & output
Connectivity – Dual Ethernet MAC controllers with built-in Ethernet switch
USB – 2x USB 2.0 HS/OTG interfaces
Other I/Os & Peripherals
8x 8-bit 5V-tolerant IO ports, plus one high-current port.
Up to 64x GPIO’s
Up to 4x PWM
4x UART, 4x SPI, 4x I2C
4x Timers
Special interface to connect to FPGA
Flexible Peripheral Multiplexing (PinMux)
Security – Secure Boot, Crypto Engine (RSA/AES/MD5/SHA3)
Debug – SWD/JTAG and console UART
Power Management
Embedded DC-DC convert:
Single 3.3V power supply
3.3V to 0.90V for CA7
3.3V to 1.5V for DDR3
3.3V to 1.2V for peripherals
Package – 20x20mm LQFP176-EP package
Temperature range – Industrial: -40°C ~ +85°C
最近编辑记录 mango (2019-11-14 09:47:47)
楼主 #2 2019-11-14 09:47:26
所在地: 芒果派
已发帖子: 779
Re: 凌阳突然出来一款QFP封装神芯SP7021(四核A7+ARM9+8051)
#3 2019-11-14 09:54:04
感觉凌阳基本没有存在感,不过这个芯片确实挺有诚意的, 不知道会不会下大力气推广。
发这个板块也没问题
楼主 #4 2019-11-14 09:54:11
所在地: 芒果派
已发帖子: 779
看到的几个突出特性:
1、所有IO可链接到A7,ARM9和8051上(All IO and peripherals are accessible by Cortex-A7/ARM926/8051)
2、内置DC-DC(Embedded DC-DC for computation unit, DDR3, and the core power)
3、温度范围 -40°C to 125°C
4、内置128MB/512MB RAM
5、两个USB OTG口
6、双百兆网RMII,需要外部接PHY
7、HDMI到720P
8、FPGA BUS?FBIO
9、20mmX20mm LQFP176-EP package
#5 2019-11-14 10:09:20
已发帖子: 844
好奇葩,有a7了为什么还要集成一个arm9,感觉a7+8051比较合适
#6 2019-11-14 10:13:16
jimmy
已发帖子: 316
widora 准备出这个开发板吗?有点小期待
楼主 #7 2019-11-14 10:13:38
所在地: 芒果派
已发帖子: 779
看来不止有我看不懂这路数,有点堆料的意思。
真是实时控制的话,外置一颗STM32不好吗?
楼主 #8 2019-11-14 10:16:25
所在地: 芒果派
已发帖子: 779
jimmy 说:
没这个打算,哈哈
#9 2019-11-14 10:21:01
ippen
已发帖子: 345
这个开发起来有点坑,要写三个程序,8051,arm9,a7
#10 2019-11-14 10:21:39
ippen
已发帖子: 345
外围接口看起来不错
#11 2019-11-14 10:29:17
dbskcnc
已发帖子: 67
价格,价格,如果性价比好的话还有的可能,这么强大的U可能应用场合还是有限
#12 2019-11-14 10:34:47
已发帖子: 1,135
Wiki下面有个评论:
what is the reason to add only low resolution 320x240?
Is possible to run 800x480 RGB888 ?
这也是我想问的
#13 2019-11-14 10:35:52
已发帖子: 1,135
mango 说:
没这个打算,哈哈
你们R11什么时候开卖?
楼主 #14 2019-11-14 10:38:40
所在地: 芒果派
已发帖子: 779
你们R11什么时候开卖?
我争取12月份多生产一批出来。当前小量200套是已经被全定,连我自己的都没有。
#15 2019-11-14 10:59:41
想不到台产芯片越来越没有存在感的今天,还有如此神芯,要是价格好,稳定性不错,可以试一试。
#16 2019-11-14 11:03:48
价格20美元,,也就是134块钱..
要说1GHz 4核A7 + 200MHz ARM9 + 8051+512MB DDR3 + 3路DCDC
价格也差不多了...
这个芯片做成板子也就是150块钱...如果真加这么多东西在一块板子上,也差不多130的样子。
#17 2019-11-14 11:08:20
这个芯片会不会热炸,啊哈啊啊哈啊哈哈啊哈哈哈哈
楼主 #18 2019-11-14 11:16:10
所在地: 芒果派
已发帖子: 779
迪卡 说:
价格20美元,,也就是134块钱..
价格也差不多了...
价格确定?这么贵?都赶上3399了!
#19 2019-11-14 18:23:25
sinovoip
所在地: shenzhen
#20 2019-11-21 15:38:08
sy373466062
已发帖子: 130
看了一遍  没有ADC。
#21 2019-11-23 09:51:59
knight_hu
这个神片和开发板在哪里能买到呀?有兴趣
#22 2019-11-23 10:33:48
异乡是故乡
已发帖子: 74
knight_hu 说:
这个神片和开发板在哪里能买到呀?有兴趣
这个开发板就是香蕉派的吧?
#23 2020-07-23 13:57:53
lcmwork
哇,这个芯片的功能很强大呐.就是不知道价格成本如何?
#24 2020-07-24 09:19:53
一世安
这个芯片的功能很强大.就是价格可能不便宜..
#25 2020-07-24 15:03:35
飞觞醉月
这芯片集成的东西真不少,就是感觉ARM9没啥存在的必要
#26 2020-07-25 11:07:43
qdk0901
20美元的价格就有点夸张了,2美元还差不多
楼主 #27 2020-07-25 11:19:09
所在地: 芒果派
已发帖子: 779
这其实是个很奇葩的芯片。
LQFP176这种封装的SMT会非常头疼,大封装QFP的良率不如BGA好控制。
另外,芯片没什么特点,感觉就是东拼西凑,想满足所有场合,但又似乎是干啥都不专业。
价格嘛,5美元以内还差不多。
#28 2020-07-25 21:51:18
MyCuphead
如果是工业级,做控制用,我觉得arm9换成一个M4会不会更好一些?
