楼主 # 2024-02-21 21:41:43
上邪
已发帖子: 37
自制T113-I 核心板一次成功开机
开贴庆祝一下,自己制作的T113-I核心板一次成功点亮,自己焊接的T113-I,DDR和EMMC立创贴片
[89]BOOT0 commit : 09b36272
[92]set pll start
[94]fix vccio detect value:0xc0
[101]periph0 has been enabled
[104]set pll end
[105][pmu]: bus read error
[108]board init ok
[110]enable_jtag
[111]DRAM only have internal ZQ!!
[115]get_pmu_exist() = -1
[117]DRAM BOOT DRIVE INFO: V0.32
[120]DRAM CLK = 792 MHz
[123]DRAM Type = 3 (2:DDR2,3:DDR3)
[126]DRAMC ZQ value: 0x7b7bfb
[129]DRAM ODT value: 0x42.
[131]ddr_efuse_type: 0x0
[134]mark_id: 0x34
[136]DRAM SIZE =512 M
[138]PLL_DDR_CTRL_REG:0xf8004100
[142]DRAM_CLK_REG:0xc0000000
[144][TIMING DEBUG] MR2= 0x18
[152]DRAM simple test OK.
[154]rtc standby flag is 0x0, super standby flag is 0x0
[160]dram size =512
[162]card no is 2
[164]sdcard 2 line count 4
[167][mmc]: mmc driver ver 2021-05-21 14:47
[176][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[182][mmc]: ***Try MMC card 2***
[206][mmc]: RMCA OK!
[208][mmc]: mmc 2 bias 0
[211][mmc]: MMC 5.1
[213][mmc]: HSSDR52/SDR25 4 bit
[216][mmc]: 50000000 Hz
[218][mmc]: 7456 MB
[220][mmc]: ***SD/MMC 2 init OK!!!***
[317]Loading boot-pkg Succeed(index=0).
[321]Entry_name        = u-boot
[328]Entry_name        = optee
[332]Entry_name        = dtb
[335]tunning data addr:0x430003e8
[338]Jump to second Boot.
M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
U-Boot 2018.05-g9444cec (Dec 25 2023 - 12:40:59 +0000) Allwinner Technology
[00.390]CPU:   Allwinner Family
[00.393]Model: sun8iw20
I2C:   ready
[00.413]DRAM:  512 MiB
[00.417]Relocation Offset is: 1cea2000
[00.446]secure enable bit: 0
E/TC:0   fdt_getprop_u32:343 prop trace_level not found
[00.459]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.465]gic: sec monitor mode
[00.468]flash init start
[00.470]workmode = 0,storage type = 2
[00.474][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
[00.480][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.505][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.512]sunxi flash init ok
[00.514]line:719 init_clocks
[00.517]drv_disp_init
[00.530]drv_disp_init finish
[00.532]boot_gui_init:start
[00.535]set disp.dev2_output_type fail. using defval=0
[00.692]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read in 1 ms (52.7 KiB/s)
[00.706]bmp_name=bootlogo.bmp size 1036854
1036854 bytes read in 23 ms (43 MiB/s)
[00.971]LT8912b chip ID: 0x0, 0x0
[02.262]LCD open finish
[02.264]Loading Environment from SUNXI_FLASH... OK
[02.291]update part info
[02.294]update bootcmd
[02.296]change working_fdt 0x5c861e70 to 0x5c841e70
[02.301][mmc]: no mmc-hs400-1_8v!
[02.304][mmc]: no mmc-hs200-1_8v!
[02.307][mmc]: get max-frequency ok 50000000 Hz
[02.329]update dts
phy_mode=rgmii, phy_interface=7
eth0
=====YTR==workmode=0==if_need_auto_force_burn=0, nRet=-1,auto_update_system
Hit <SPACE> key to stop autoboot in  1s
[02.783]no vendor_boot partition is found
Android's image name: sun8i_arm
[02.807]Starting kernel ...
[02.809][mmc]: mmc exit start
[02.829][mmc]: mmc 2 exit ok
[    0.000000] Linux version 5.4.61-gd2437b5 (tl@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Fri Jan 26 12:24:54 CST 2024
[    0.000000] OF: fdt: Machine model: TLT113-EVM HDMI
[    0.000000] cma: Reserved 16 MiB at 0x5f000000
[    0.000000] On node 0 totalpages: 130816
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 130816 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s31296 r8192 d21952 u61440
[    0.000000] pcpu-alloc: s31296 r8192 d21952 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129664
[    0.000000] Kernel command line: clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p5 rootwait rw init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:userdata@mmcblk0p8:UDISK@mmcblk0p9 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-g9444cec(12/25/2023-12:40:59) disp_reserve=8294400,0x5c8cc000 androidboot.dramsize=512
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Memory: 472036K/523264K available (8192K kernel code, 460K rwdata, 2836K rodata, 1024K init, 330K bss, 34844K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] random: get_random_bytes called from start_kernel+0x254/0x3e0 with crng_init=0
[    0.000209] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000828] Console: colour dummy device 80x30
[    0.000878] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000892] pid_max: default: 32768 minimum: 301
[    0.001085] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001099] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002058] CPU: Testing write buffer coherency: ok
[    0.002466] /cpus/cpu@0 missing clock-frequency property
[    0.002490] /cpus/cpu@1 missing clock-frequency property
[    0.002502] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003171] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003319] rcu: Hierarchical SRCU implementation.
[    0.003675] BOOTEVENT:         3.666374: ON
[    0.003907] smp: Bringing up secondary CPUs ...
[    0.005263] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005433] smp: Brought up 1 node, 2 CPUs
[    0.005450] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.005457] CPU: All CPU(s) started in SVC mode.
[    0.006058] devtmpfs: initialized
[    0.020050] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.020684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.020713] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.021616] pinctrl core: initialized pinctrl subsystem
[    0.023219] NET: Registered protocol family 16
[    0.025451] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.071395] rtc_ccu: sunxi ccu init OK
[    0.073773] ccu: sunxi ccu init OK
[    0.074304] r_ccu: sunxi ccu init OK
[    0.128273] Deinterlace Module initialized.
[    0.128584] iommu: Default domain type: Translated
[    0.128819] sunxi iommu: irq = 24
[    0.130074] SCSI subsystem initialized
[    0.130932] usbcore: registered new interface driver usbfs
[    0.131022] usbcore: registered new interface driver hub
[    0.131153] usbcore: registered new device driver usb
[    0.131343] mc: Linux media interface: v0.10
[    0.131414] videodev: Linux video capture interface: v2.00
[    0.133089] Advanced Linux Sound Architecture Driver Initialized.
[    0.133858] Bluetooth: Core ver 2.22
[    0.133950] NET: Registered protocol family 31
[    0.133960] Bluetooth: HCI device and connection manager initialized
[    0.133985] Bluetooth: HCI socket layer initialized
[    0.133997] Bluetooth: L2CAP socket layer initialized
[    0.134028] Bluetooth: SCO socket layer initialized
[    0.134382] pwm module init!
[    0.136246] g2d 5410000.g2d: Adding to iommu group 0
[    0.136713] G2D: rcq version initialized.major:249
[    0.137449] input: sunxi-keyboard as /devices/virtual/input/input0
[    0.138468] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[    0.138489] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[    0.138504] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[    0.138519] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[    0.139699] clocksource: Switched to clocksource arch_sys_counter
[    0.149597] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[    0.165392] thermal_sys: Registered thermal governor 'step_wise'
[    0.165399] thermal_sys: Registered thermal governor 'user_space'
[    0.166022] NET: Registered protocol family 2
[    0.166845] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.166897] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.166952] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.167015] TCP: Hash tables configured (established 4096 bind 4096)
[    0.167127] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.167171] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.167383] NET: Registered protocol family 1
[    0.168152] RPC: Registered named UNIX socket transport module.
[    0.168168] RPC: Registered udp transport module.
[    0.168175] RPC: Registered tcp transport module.
[    0.168181] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.172807] Initialise system trusted keyrings
[    0.173085] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.188388] NFS: Registering the id_resolver key type
[    0.188430] Key type id_resolver registered
[    0.188439] Key type id_legacy registered
[    0.188459] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.188469] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.188477] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.188809] fuse: init (API version 7.31)
[    0.219548] NET: Registered protocol family 38
[    0.219576] Key type asymmetric registered
[    0.219585] Asymmetric key parser 'x509' registered
[    0.219770] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.219787] io scheduler mq-deadline registered
[    0.219795] io scheduler kyber registered
[    0.219944] atomic64_test: passed
[    0.221825] [DISP]disp_module_init
[    0.222492] disp 5000000.disp: Adding to iommu group 0
[    0.223148] [DISP] disp_init,line:2387:
[    0.223153] smooth display screen:0 type:1 mode:4
[    0.239976] [DISP] disp_init_hdmi,line:1047:
[    0.239982] dont support hdmi
[    0.240380] display_fb_request,fb_id:0
[    0.263524] disp_al_manager_apply ouput_type:1
[    0.264217] [DISP]disp_module_init finish
[    0.265659] sunxi_sid_init()563 - insmod ok
[    0.266174] pwm-regulator: supplied by regulator-dummy
[    0.267603] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.269680] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[    0.270351] uart uart0: get regulator failed
[    0.270381] uart uart0: uart0 supply uart not found, using dummy regulator
[    0.270709] uart0: ttyAS0 at MMIO 0x2500000 (irq = 33, base_baud = 1500000) is a SUNXI
[    0.270740] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[    0.297395] free logo buffer src_phy_addr=0x5c8cc000  fb_height=1080  src_stride=7680
[    0.303527] Freeing logo buffer memory: 8100K
[    0.307897] printk: console [ttyAS0] enabled
[    1.243369] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[    1.252507] uart uart1: get regulator failed
[    1.257312] uart uart1: uart1 supply uart not found, using dummy regulator
[    1.265375] uart1: ttyAS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[    1.275111] uart uart2: get regulator failed
[    1.279971] uart uart2: uart2 supply uart not found, using dummy regulator
[    1.288041] uart2: ttyAS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
[    1.297756] uart uart3: get regulator failed
[    1.302618] uart uart3: uart3 supply uart not found, using dummy regulator
[    1.310738] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
[    1.320414] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[    1.329459] uart uart4: get regulator failed
[    1.334310] uart uart4: uart4 supply uart not found, using dummy regulator
[    1.342407] uart4: ttyAS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
[    1.352185] uart uart5: get regulator failed
[    1.356996] uart uart5: uart5 supply uart not found, using dummy regulator
[    1.365087] uart5: ttyAS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
[    1.375273] misc dump reg init
[    1.380902] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
[    1.388199] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[    1.396059] [ADDR_MGT] addr_mgt_probe: success.
[    1.402760] libphy: Fixed MDIO Bus: probed
[    1.407472] CAN device driver interface
[    1.413136] sunxi-can can@0x0: can driver probe ok ...
[    1.420006] sunxi-can can@0x1: can driver probe ok ...
[    1.426806] sunxi gmac driver's version: 1.0.0
[    1.432038] gmac-power0: NULL
[    1.435368] gmac-power1: NULL
[    1.438693] gmac-power2: NULL
[    1.443279] Failed to alloc md5
[    1.446815] eth0: Use random mac address
[    1.451782] usbcore: registered new interface driver asix
[    1.457930] usbcore: registered new interface driver ax88179_178a
[    1.464883] usbcore: registered new interface driver cdc_ether
[    1.471527] usbcore: registered new interface driver net1080
[    1.477938] usbcore: registered new interface driver cdc_subset
[    1.484665] usbcore: registered new interface driver zaurus
[    1.491040] usbcore: registered new interface driver cdc_ncm
[    1.497395] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.504741] sunxi-ehci: EHCI SUNXI driver
[    1.509851] get ehci1-controller wakeup-source is fail.
[    1.515838] sunxi ehci1-controller don't init wakeup source
[    1.522114] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0eb8100, 0x:e0885000, irq_no:40
[    1.534156] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.546714] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[    1.558960] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.566248] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.576420] sunxi-ehci 4200000.ehci1-controller: irq 64, io mem 0x04200000
[    1.609720] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.618599] hub 1-0:1.0: USB hub found
[    1.622905] hub 1-0:1.0: 1 port detected
[    1.628171] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.635184] sunxi-ohci: OHCI SUNXI driver
[    1.640282] get ohci1-controller wakeup-source is fail.
[    1.646282] sunxi ohci1-controller don't init wakeup source
[    1.652568] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0eb8390
[    1.662274] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.674862] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[    1.687116] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.694405] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.704384] sunxi-ohci 4200400.ohci1-controller: irq 65, io mem 0x04200400
[    1.784730] hub 2-0:1.0: USB hub found
[    1.788994] hub 2-0:1.0: 1 port detected
[    1.794596] usbcore: registered new interface driver uas
[    1.800749] usbcore: registered new interface driver usb-storage
[    1.807565] usbcore: registered new interface driver ums-alauda
[    1.814304] usbcore: registered new interface driver ums-cypress
[    1.821137] usbcore: registered new interface driver ums-datafab
[    1.827953] usbcore: registered new interface driver ums_eneub6250
[    1.834969] usbcore: registered new interface driver ums-freecom
[    1.841797] usbcore: registered new interface driver ums-isd200
[    1.848500] usbcore: registered new interface driver ums-jumpshot
[    1.855428] usbcore: registered new interface driver ums-karma
[    1.862064] usbcore: registered new interface driver ums-onetouch
[    1.868982] usbcore: registered new interface driver ums-realtek
[    1.875810] usbcore: registered new interface driver ums-sddr09
[    1.882550] usbcore: registered new interface driver ums-sddr55
[    1.889261] usbcore: registered new interface driver ums-usbat
[    1.896028] usbcore: registered new interface driver option
[    1.902533] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.911703] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[    1.921299] sunxi_gpadc_init,2137, success
[    1.926209] sunxi_key_init: get key count failed
[    1.926224] sunxi_gpadc_setup: get channel scan data failed
[    1.937989] input: sunxi-gpadc0 as /devices/virtual/input/input2
[    1.945258] input: sunxi-gpadc1 as /devices/virtual/input/input3
[    1.953531] i2c /dev entries driver
[    1.957684] IR NEC protocol handler initialized
[    1.962809] IR RC5(x/sz) protocol handler initialized
[    1.970921] usbcore: registered new interface driver uvcvideo
[    1.977375] USB Video Class driver (1.1.1)
[    1.982016] gspca_main: v2.14.0 registered
[    1.986611] sunxi cedar version 1.1
[    1.990783] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.997058] VE: sunxi_cedar_probe power-domain init!!!
[    2.002849] VE: install start!!!
[    2.002849]
[    2.008444] VE: cedar-ve the get irq is 45
[    2.008444]
[    2.014963] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[    2.014963]
[    2.024264] VE: install end!!!
[    2.024264]
[    2.029344] VE: sunxi_cedar_probe
[    2.034632] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.043901] Bluetooth: HCI UART driver ver 2.3
[    2.048888] Bluetooth: HCI UART protocol H4 registered
[    2.056729] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[    2.065720] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[    2.075718] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
[    2.082148] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[    2.088499] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[    2.094992] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[    2.101469] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[    2.108012] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[    2.114575] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[    2.121131] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[    2.127697] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    2.137304] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.161050] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.185315] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[    2.192497] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.201489] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[    2.214202] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    2.215236] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.220471] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    2.233401] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.238391] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    2.256484] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    2.262955] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    2.269515] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    2.276095] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    2.282663] random: fast init done
[    2.282677] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.282754] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.286497] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    2.311025] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.316856] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    2.333745] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.344986] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    2.353550] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.365185] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.377839] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[    2.383969] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.395264] ledtrig-cpu: registered to indicate activity on CPUs
[    2.402439] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.412269] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.412401] usbcore: registered new interface driver usbhid
[    2.422164] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.428382] usbhid: USB HID core driver
[    2.438128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    2.442512] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.453787] rpmsg_tty_init: Sunxi rpmsg tty driver will init
[    2.470481] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.470682] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
[    2.488593] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
[    2.493799] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[    2.493799]
[    2.517844] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:2, dachpf:3
[    2.517883] mmc0: new high speed MMC card at address 0001
[    2.529343] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[    2.536438] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[    2.544608] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[    2.548938] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[    2.558437] [SNDCODEC][sunxi_card_init][583]:card init finished
[    2.574079] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[    2.584687]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    2.585919] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
[    2.602211] [SNDCODEC][sunxi_card_dev_probe][800]:jack_enable missing, use default enable jack
[    2.611960] [SNDCODEC][sunxi_card_dev_probe][810]:hp_detect_case missing, use default hp_detect_low
[    2.622284] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[    2.631403] NET: Registered protocol family 10
[    2.637652] Segment Routing with IPv6
[    2.642099] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.649805] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[    2.651021] NET: Registered protocol family 17
[    2.662191] NET: Registered protocol family 15
[    2.667177] can: controller area network core (rev 20170425 abi 9)
[    2.674243] NET: Registered protocol family 29
[    2.679234] can: raw protocol (rev 20170425)
[    2.684049] can: broadcast manager protocol (rev 20170425 t)
[    2.690427] can: netlink gateway (rev 20190810) max_hops=1
[    2.697106] Bluetooth: RFCOMM TTY layer initialized
[    2.702651] Bluetooth: RFCOMM socket layer initialized
[    2.708442] Bluetooth: RFCOMM ver 1.11
[    2.713240] Key type dns_resolver registered
[    2.718616] Registering SWP/SWPB emulation handler
[    2.724462] Loading compiled-in X.509 certificates
[    2.732217] tv_probe()1527 - of_property_read_string tv_power failed!
[    2.739881] get_key_map_info()179 - Failed to find "tvou" in dts.
[    2.746816] tv probe finished!
[    2.769769] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[    2.780333] sunxi-i2c sunxi-i2c2: drv-mode: Timeout when sending 9th SCL clk
[    2.788277] sunxi-i2c sunxi-i2c2: drv-mode: xfer failed (dev addr:0x68)
[    2.795870] rtc-ds1307: probe of 2-0068 failed with error -22
[    2.802389] sunxi-i2c sunxi-i2c2: probe success
[    2.807999] deinterlace 5400000.deinterlace: Adding to iommu group 0
[    2.815719] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[    2.824299] sunxi-thermal 2009400.ths: sun8iw20 chip id: 13312
[    2.830904] sunxi-thermal 2009400.ths: sun8iw20 t1: 3000
[    2.836989] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[    2.852309] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[    2.891362] get ehci0-controller wakeup-source is fail.
[    2.897337] sunxi ehci0-controller don't init wakeup source
[    2.903715] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0eb7be0, 0x:e2677000, irq_no:3e
[    2.915730] [sunxi-ehci0]: Not init ehci0
[    2.920688] get ohci0-controller wakeup-source is fail.
[    2.926662] sunxi ohci0-controller don't init wakeup source
[    2.932942] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0eb7e70
[    2.942611] [sunxi-ohci0]: Not init ohci0
[    2.949474] get det_vbus is fail, -84
[    2.955097] sun8iw20-pinctrl pio: pin PE2 already requested by pio:130; cannot claim for 5801000.csi
[    2.965528] sun8iw20-pinctrl pio: pin-130 (5801000.csi) status -22
[    2.972562] sun8iw20-pinctrl pio: could not request pin 130 (PE2) from group PE2  on device pio
[    2.982345] vin_csi 5801000.csi: Error applying setting, reverse things back
[    2.990350] vin_csi: probe of 5801000.csi failed with error -22
[    3.002215] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
[    3.010040] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
[    3.018075] sun8iw20-pinctrl pio: missing pins property in node csi_mclk0
[    3.025794] sunxi-vin-media: probe of 5800800.vind failed with error -22
[    3.034707] OF: fdt: not creating '/sys/firmware/fdt': CRC check failed
[    3.042229] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.053435] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.061012] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.069782] clk: Not disabling unused clocks
[    3.070727] cfg80211: failed to load regulatory.db
[    3.075474] ALSA device list:
[    3.084267]   #0: audiocodec
[    3.087504] alloc_fd: slot 0 not NULL!
[    3.133096] EXT4-fs (mmcblk0p5): recovery complete
[    3.139298] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[    3.148526] VFS: Mounted root (ext4 filesystem) on device 179:5.
[    3.156980] Freeing unused kernel memory: 1024K
[    3.179905] Kernel init done
[    3.183132] Run /init as init process
[    3.371448] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Populating /dev using udev: [    3.592067] udevd[1252]: starting version 3.2.7
[    3.610658] random: udevd: uninitialized urandom read (16 bytes read)
[    3.619379] random: udevd: uninitialized urandom read (16 bytes read)
[    3.626826] random: udevd: uninitialized urandom read (16 bytes read)
[    3.641461] udevd[1252]: specified group 'kvm' unknown
[    3.667798] udevd[1253]: starting eudev-3.2.7
done
Mounting cgroupfs hierarchy: OK
Starting system message bus: [    4.710703] urandom_read: 3 callbacks suppressed
[    4.710714] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[    4.724070] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
[    4.751835] random: dbus-daemon: uninitialized urandom read (12 bytes read)
done
Starting rpcbind: OK
Starting network: [    5.122562] libphy: 4500000.eth: probed
[    5.126880] sunxi-gmac 4500000.eth eth0: No PHY found!
RTNETLINK answers: Invalid argument
Waiting for interface eth1 to appear.[    7.049718]
[    7.049718] insmod_device_driver
[    7.049718]
[    7.056958] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
....... timeout!
run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1
FAIL
Starting ntpd: OK
Starting mosquitto: OK
[   22.069751] random: crng init done
[   22.073576] random: 1 urandom warning(s) missed due to ratelimiting
Starting sshd: OK
Starting telnetd: OK
Starting dockerd: OK
Starting NFS statd: OK
Starting NFS services: OK
Starting NFS daemon: OK
Starting NFS mountd: OK
Starting vsftpd: OK
mount: /run/media/mmcblk0rpmb: /dev/mmcblk0rpmb is not a block device.
mount: /run/media/mmcblk0p7: wrong fs type, bad option, bad superblock on /dev/mmcblk0p7, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p3: wrong fs type, bad option, bad superblock on /dev/mmcblk0p3, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p9: wrong fs type, bad option, bad superblock on /dev/mmcblk0p9, missing codepage or helper program, or other error.
[   23.426659] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
mount: /run/media/mmcblk0p6: wrong fs type, bad option, bad superblock on /dev/mmcblk0p6, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p4: wrong fs type, bad option, bad superblock on /dev/mmcblk0p4, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p2: wrong fs type, bad option, bad superblock on /dev/mmcblk0p2, missing codepage or helper program, or other error.
[   24.039033] EXT4-fs (mmcblk0p8): recovery complete
[   24.044485] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
add /dev/input/event1 to Qt Application.
find qt5 installed done
Welcome to Allwinner KunoOS Platform
楼主 #1 2024-02-21 21:56:48
上邪
已发帖子: 37
Re: 自制T113-I 核心板一次成功开机
来个实物图片
楼主 #2 2024-02-21 22:00:38
上邪
已发帖子: 37
底部照片来一个
#3 2024-02-21 23:26:11
winsinzhao
这个手工焊的话难度会比较大的,没技术都焊不好
楼主 #4 2024-02-22 09:03:25
上邪
已发帖子: 37
winsinzhao 说:
哈哈,是有点,我也是第一次焊接bga,焊接过后我还把芯片拿起来看了一下,然后又放上去。我以为焊接挂了,没想到能正常开机
#5 2024-02-22 09:35:48
mysky
手工焊接BGA难度不小,手上都有点功夫才行。
楼主 #6 2024-02-22 10:21:02
上邪
已发帖子: 37
mysky 说:
是的,是的
#7 2024-02-22 13:36:24
mysteryli
已发帖子: 487
@上邪
T113为啥不在LC一起贴呢
楼主 #8 2024-02-22 13:50:22
上邪
已发帖子: 37
mysteryli 说:
@上邪
T113为啥不在LC一起贴呢
这个用的免费打样做的,T113-I没法免费贴片(免费的贴片是经济模式,T113-I立创系统提示要标准模式才能贴);所以只能自己买回来手动焊接了
#9 2024-02-23 17:11:55
zt_ustb
请教下,全志的官方开发包SDK之类的资料一般是联系他们的代理吗?现在的开发板好多都做成核心板,资料也不给全。
#10 2024-02-23 17:31:26
已发帖子: 1,379
以前在全志开发者在线,注册帐号后,就可以下在t113的sdk。后来发现不能下载了,估计要申请。
楼主 #11 2024-02-27 14:02:18
上邪
已发帖子: 37
zt_ustb 说:
买个开发板就有了
#12 2024-02-29 13:25:25
安心man
您好,原理图能不能开源呢,或者给个PDF的
楼主 #13 2024-03-01 10:08:09
上邪
已发帖子: 37
安心man 说:
我也是参考官方的原理图,你可以搜一下:
T113-i Hardware硬件类文档.7z
手册:
T113-i brief-V1.1.pdf
T113-i_Datasheet_V1.4.pdf
T113-i_User_Manual_V1.4.pdf
参考链接:全志A20 / A64 / A133 / D1 / T113-I/V83x /V85x Tina / Android 文档合集/集合,很全!
#14 2024-03-10 20:37:53
vigour1000
已发帖子: 101
牛,开源吗?
#15 2024-03-10 20:38:42
vigour1000
已发帖子: 101
使用几层板
#18 2024-04-11 17:03:10
as86455011
已发帖子: 33
vigour1000 说:
使用几层板
盘中孔,6层以上了。
#19 2024-04-12 22:50:25
lyg116
4层板可以吗,6层太贵了
#20 2024-05-04 17:14:45
wapgrid2000
楼主,你好,T113-i的I2S怎么设置的,我们使用的是ADC芯片型号是PCM1865;
楼主 #22 2024-05-07 22:13:23
上邪
已发帖子: 37
vigour1000 说:
使用几层板
6层
楼主 #23 2024-05-07 22:13:55
上邪
已发帖子: 37
lyg116 说:
4层板可以吗,6层太贵了
可以的,不过有难度
楼主 #24 2024-05-07 22:14:14
上邪
已发帖子: 37
wapgrid2000 说:
我没使用
楼主 #25 2024-05-07 22:15:46
上邪
已发帖子: 37
vigour1000 说:
牛,开源吗?
暂时不准备开源,不过有官方的原理图,对照着画
#26 2024-05-08 09:45:52
epoko
你好,请问一下ddr的等长规则是怎么设置的?我看全志给的模板地址线长度差距达到了900mil,PCB并没有做等长处理,如果这样都能用的话说明芯片内部做了延时匹配,那自己画PCB的话也得按照这个画一模一样的长度?还是说按照标准ddr3的等长规则设计?
楼主 #27 2024-05-17 15:34:46
上邪
已发帖子: 37
@epoko
我数据等长100mil,地址是200mil
#28 2024-05-24 23:39:42
anguodeng
有没有一个完整的资料包?
#29 2024-08-07 20:44:38
sniper33
已发帖子: 19
电源也是全志的套片么?
#31 2024-08-10 21:18:31
Ali64
上邪 说:
安心man 说:
我也是参考官方的原理图,你可以搜一下:
Dear Shang Xie your projects was wonderfull, can you say me that GERBER file or PCB file was include in this informations or not?
#32 2024-08-10 21:23:41
Ali64
All dear colleagues, I'd like to create a board with T113-i. I need information such as Gerber or PCB reference files for guidance. Could you please assist me? Thank you.
#33 2024-08-11 09:46:08
sokou
已发帖子: 53
核间资源分配有介绍吗?
#34 2024-08-11 11:58:08
xuqm
已发帖子: 23
阻容0402的吗
#36 2024-08-18 08:20:23
老渔翁
自己焊接的T113-I。牛啊。
#37 2024-08-20 14:42:39
Ali64
老渔翁 说:
自己焊接的T113-I。牛啊。
Did you design a cutomized borad with T113-i ?
#38 2024-08-21 20:25:55
Ali64
This is the AllwinnerD1-H Open hardware and software link.
https://github.com/DongshanPI
Enjoy.
#39 2024-09-02 23:00:07
susu
Ali64 说:
Enjoy.
thanks.
楼主 #40 2024-09-18 14:34:03
上邪
已发帖子: 37
sniper33 说:
电源也是全志的套片么?
不是,用的dc-dc
楼主 #41 2024-09-18 14:34:48
上邪
已发帖子: 37
xuqm 说:
阻容0402的吗
是的
楼主 #42 2024-09-18 14:38:56
上邪
已发帖子: 37
@Ali64
包含了一部分,可以参考一下楼上官方原理图
#43 2024-10-10 17:37:11
plin
### Compile
  $ source build/envsetup.sh
  $ lunch
``` sh
  You're building on Linux
Lunch menu... pick a combo:
     1. d1_mq_pro-tina
     2. d1_nezha_min-tina
     3. d1_nezha-tina
     4. f133_evb1-tina
     5. f133_mq_r-tina
     6. t113_evb1-tina
     7. t113_mq_r-tina
请问这个SDK,哪个是T113-I,有哪个大佬知道吗?
#44 2024-10-17 15:05:00
freedombye
有全志T113I芯片的DDR参考电路吗
#45 2024-10-17 15:49:34
memory
已发帖子: 487
freedombye 说:
有全志T113I芯片的DDR参考电路吗
#48 2024-11-03 16:25:37
rdghx
单片DDR怎么设计?
#50 2024-11-24 09:35:39
zhenfanhei
已发帖子: 301
强,试试dram_clk             = 936  看看能稳定跑不
#51 2024-11-29 15:43:37
gp88sss
这个自己做我感觉不一定能成功的。。。
#53 2024-12-09 09:05:02
zyz_432
我也想做一个类似的全志H3的板子,楼主有什么经验可以讲下吗?之前没布过这么复杂的
