楼主 # 2024-12-30 20:39:36
memory
已发帖子: 725
45块买到的10.1寸保资LCD价签F1C200S (二)
参考链接:45块顺丰包邮买到的10.1寸保资LCD价签F1C200S 值不值
下载 xfdr0805大佬的 dws
电脑用adb把dws推送到价签:
adb push dws /usr/bin/
添加执行属性:
chmod +x /usr/bin/dws
修改: /etc/profile.d/bloziplayer.sh
改成这样,连接热点,同步ntp时间,开启时钟app:
    #bloziplayer
    wifi_connect_ap_test wifi 13800138000
    ntpd -p pool.ntp.org
    /usr/bin/dws &
调光方法在 #13 楼
R74 和 R75 短路上,就能用这个程序 backlight.bin.7z (二进制文件)调光了 0 - 255
使用方法 /usr/bin/backlight 135
看到一个好玩的:
天眼查: https://www.tianyancha.com/company/3149053673
企查查: https://www.qcc.com/firm/52365fe875af00802f4a62d1ef97c942.html
上海保资智能科技有限公司 法人代表被限高了,对外投资的公司都注销了。
楼主 #1 2024-12-30 20:40:17
memory
已发帖子: 725
Re: 45块买到的10.1寸保资LCD价签F1C200S (二)
楼主 #2 2024-12-30 20:40:21
memory
已发帖子: 725
楼主 #3 2024-12-30 20:40:25
memory
已发帖子: 725
串口日志:
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
[60]dram size =64
[62](GPIO_BASE_ADDR + 0x48): 0x00002222
[65](GPIO_BASE_ADDR + 0x5c): 0x00000055
[69](GPIO_BASE_ADDR + 0x64): 0x00000004
[72]CCMU_BASE_ADDR + 0x2c0 0x00104040
[76]CCMU_BASE_ADDR + 0x60 0x00104040
[79]SPIC0_BASE_ADDR+0x24: 0x00001004
[82]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 58
[87]block from 8 to 58
[568]Check is correct.
[579]Ready to disable icache.
[582]Jump to secend Boot.
U-Boot 2014.07 (Jul 29 2021 - 16:47:52) Allwinner Technology
uboot commit : dfc3875a5628fed71dd73c10becab31d46b6569c
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[0.631]pmbus:   ready
axp: get node[/soc/pmu0] error
axp_probe error
[0.637]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
key value = 4294967295, fel_key = [256,426]
DRAM:  64 MiB
Relocation Offset is: 03521000
int sunxi_dma_init---
irq enable
workmode = 0,storage type = 0
[0.714]NAND: NAND_UbootInit
[0.717]NAND_UbootInit start
[0.719]NB1: enter NAND_LogicInit
[0.724]nand0: get node offset error
[0.727]init nctri NAND PIORequest error!
[0.731]nand_physic_init, init nctri error
[0.735]nand_physic_init init_parameter error
[0.739]nand_physic_init error -1
[0.742]SpiNandHwInit: Start Nand Hardware initializing .....
[0.747]uboot: nand version: 3 6013 20180906 1300
irq enable
[0.767]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db891c
[0.774]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db893c
_change_spic_clk: 0x01c05024=0x1009
_change_spic_clk_v1: mclk=0xc8
_change_spic_clk: 0x01c05024=0x1004
_change_spic_clk: 0x01c05024=0x1001
_get_spic_clk_v1: sclk0=0x32
[0.828]not burn nand partition table!
[0.831]NB1: nftl num: 1
[0.833]init nftl: 0
[1.168]NB1: NAND_LogicInit ok, result = 0x0
[1.172]NAND_UbootInit end: 0x0
used mbr [0], count = 9
sunxi secure storage is not supported
[1.183]usb burn from boot
delay time 0
sunxi_dma_install_int ok
[1.249]usb prepare ok
usset address 0x1a
b sof ok
[1.493]usb probe ok
[1.494]usb setup ok
set address 0x33
try to update
start to recv by dma
recv done
usb update probe
usb command = 0
SUNXI_USB_SEND_DATA=32
usb update probe
usb command = 1
ready to boot normal
[12.029]exit usb burn from boot
next work 0
SUNXI_UPDATE_NEXT_ACTION_NULL
logo addr = 0x83f00000
sunxi_read_bootlogo: read bootlogo partition successful
do not find fastboot status flag
root_partition is rootfs
-total partitions:9-
bootlogo    : 400000        80000
env         : 480000        40000
boot        : 4c0000        600000
rootfs      : ac0000        f00000
rootfs_data : 19c0000       f00000
recovery    : 28c0000       800000
misc        : 30c0000       40000
private     : 3100000       40000
UDISK       : 3140000       0
set root to /dev/nandd
disable nand error: FDT_ERR_BADPATH
## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery exist
sunxi_bmp_logo_display
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   ARM OpenWrt Linux-3.10.65
   Data Size:    1618568 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   XIP Kernel Image ... OK
   reserving fdt memory region: addr=81000000 size=10000
   Using Device Tree in place at 81000000, end 8100eeff
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (jason@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #526 Tue Mar 1 04:28:42 UTC 2022
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[    0.000000] cma: CMA: reserved 32 MiB at 82000000
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat c0535004, node_mem_map c0565000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 16384 pages, LIFO batch:3
[    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/nandd init=/pseudo_init rdinit=/rdinit partitions=bootlogo@nanda:env@nandb:boot@nandc:rootfs@nandd:rootfs_data@nande:recovery@nandf:misc@nandg:private@nandh:UDISK@nandi cma=32M fb_base=0x83f00000 androidboot.serialno=0000000000000000000 boot_type=5
[    0.000000] Memory: 26468k/26468k available, 39068k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc0429fb4   (4232 kB)
[    0.000000]       .init : 0xc042a000 - 0xc0446fa0   ( 116 kB)
[    0.000000]       .data : 0xc0448000 - 0xc0535928   ( 951 kB)
[    0.000000]        .bss : 0xc0535928 - 0xc0564740   ( 188 kB)
[    0.000000] NR_IRQS:256
[    0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[    0.000000] pll_cpu-set_default_rate=552000000 success!
[    0.000000] pll_video-set_default_rate=297000000 success!
[    0.000000] pll_ddr-set_default_rate=312000000 success!
[    0.000644] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[    0.070005] pid_max: default: 32768 minimum: 301
[    0.070365] Mount-cache hash table entries: 512
[    0.071573] CPU: Testing write buffer coherency: ok
[    0.072314] Setting up static identity map for 0xc0395960 - 0xc03959b8
[    0.074659] devtmpfs: initialized
[    0.076697] pinctrl core: initialized pinctrl subsystem
[    0.083694] NET: Registered protocol family 16
[    0.086979] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.087481] dump_class_init,844, success
[    0.092210] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[    0.110634] bio: create slab <bio-0> at 0
[    0.111748] pwm module init!
[    0.113482] SCSI subsystem initialized
[    0.113800] usbcore: registered new interface driver usbfs
[    0.113951] usbcore: registered new interface driver hub
[    0.114310] usbcore: registered new device driver usb
[    0.120538] Advanced Linux Sound Architecture Driver Initialized.
[    0.122109] cfg80211: Calling CRDA to update world regulatory domain
[    0.123050] Switching to clocksource sun3i high-res couter
[    0.142508] get det_vbus is fail, 84
[    0.144244] NET: Registered protocol family 2
[    0.146239] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.146303] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.146336] TCP: Hash tables configured (established 512 bind 512)
[    0.146480] TCP: reno registered
[    0.146516] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.146563] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.147134] NET: Registered protocol family 1
[    0.162592] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.163279] msgmni has been set to 115
[    0.166434] io scheduler noop registered
[    0.166544] io scheduler cfq registered (default)
[    0.166561] [pm]aw_pm_init!
[    0.166909] [pm]valid
[    0.166927] [pm]valid
[    0.167371] [DISP]disp_module_init
[    0.223210] pll_freq=297000000HZ, lcd_dclk_freq=62000000HZ, clk_div=4
[    0.223874] *******************************
[    0.223893] ***
[    0.223903] *** LCD Panel Parameter Check
[    0.223913] ***
[    0.223924] ***             by guozhenjie
[    0.223933] ***
[    0.223943] ********************************
[    0.223953] ***
[    0.223964] *** Interface:
[    0.223975] *** Parallel HV Panel
[    0.223986] *** Lcd Frm to RGB666
[    0.223995] ***
[    0.224004] *** Timing:
[    0.224016] *** lcd_x:      800
[    0.224027] *** lcd_y:      1280
[    0.224038] *** lcd_ht:     1220
[    0.224050] *** lcd_hbp:    70
[    0.224061] *** lcd_vt:     1315
[    0.224072] *** lcd_vbp:    22
[    0.224083] *** lcd_hspw:   20
[    0.224094] *** lcd_vspw:   6
[    0.224105] *** lcd_frame_frq:  38Hz
[    0.224115] ***
[    0.224127] *** WRN03: Recommend "lcd_dclk_frq = 96"
[    0.224137] ***
[    0.224147] *** LCD Panel Parameter Check End
[    0.224158] *******************************
[    0.224294] num_screens=1
[    0.224315] screen_id=0
[    0.224329] para->mclk[MOD_CLK_LCD1CH0]=0xc180c340
[    0.224342] para->mclk[MOD_CLK_LCD1CH1]=0xc180c440
[    0.224355] disp tv init
[    0.224370] tcon_clk=0xc180c340, tcon_clk_parent=0x0
[    0.224388] tcon_clk=0xc180c340, tcon_clk_parent=0xc1804400
[    0.224404] tve_clk=0xc180c440, tve_clk_parent=0xc1804400
[    0.224416] disp al tv init
[    0.227037] fetch script datadisp.screen2_output_type fail
[    0.227356] fetch script datadisp.screen2_output_mode fail
[    0.229872] fetch script datadisp.fb2_format fail
[    0.230181] fetch script datadisp.fb2_scaler_mode_enable fail
[    0.230483] fetch script datadisp.fb2_width fail
[    0.230788] fetch script datadisp.fb2_height fail
[    0.278368] [DISP]disp_module_init finish
[    0.291813] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[    0.291878] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
[    0.967198] console [ttyS1] enabled
[    0.972189] misc dump reg init
[    0.977547] [NAND]SPIC0_BASE_ADDR f1c05000
[    0.982786] Failed to get dragonboard_flag
[    0.987441] [NAND]nand init start
[    0.991133] SpiNandHwInit: Start Nand Hardware initializing Sep  6 2018 07:23:33.....
[    0.999871] kernel: nand version: 3 6013 20180906 1300
[    1.005617] print_level is no used
[    1.009396] request spi gpio  ok!
[    1.013070] request tx DMA
[    1.016120] request general tx dma channel ok!
[    1.021047] request rx DMA
[    1.024091] request general rx dma channel ok!
[    1.029018] NAND_ClkRequest
[    1.032160] NAND_ClkRequest: get pll6 rate 200000000HZ
[    1.037984] SPI nand ID: 12c212c2 12c212c2
[    1.042562] [SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffcfffff
[    1.050539] id_number_ctl is no used
[    1.054549] _UpdateExtAccessFreqPara: no para.
[    1.060160] PHY_Scan_DelayMode: right delay mode 0x0
[    1.066219] PHY_Scan_DelayMode: right delay mode 0x800
[    1.071971] _get_spic_clk_v1: sclk0=0x32
[    1.076405] PHY_Scan_DelayMode: right delay mode,clk 50 MHz, bit[13]=0,bit[11]=0
[    1.084648] physic_info_read start!!
[    1.088640] physic_info_get_offset start!!
[    1.097655] physic_info_get_one_copy start!!
[    1.103408] block 13 page 48
[    1.107089] block 13 page 49
[    1.110759] block 13 page 50
[    1.114498] block 13 page 51
[    1.118167] block 13 page 52
[    1.121843] block 13 page 53
[    1.125585] block 13 page 54
[    1.129261] block 13 page 55
[    1.132923] block 13 page 56
[    1.136676] block 13 page 57
[    1.140348] block 13 page 58
[    1.144083] block 13 page 59
[    1.147753] block 13 page 60
[    1.151424] block 13 page 61
[    1.155163] block 13 page 62
[    1.158832] block 13 page 63
[    1.163231] physic info copy is ok
[    1.167024]
[    1.167024]
[    1.170321] [SCAN_DBG] ==============Nand Architecture Parameter==============
[    1.178391] [SCAN_DBG]    Nand Chip ID:         0xffff12c2 0xffffffff
[    1.185575] [SCAN_DBG]    Nand Chip Count:      0x1
[    1.190982] [SCAN_DBG]    Nand Chip Connect:    0x1
[    1.196421] [SCAN_DBG]    Sector Count Of Page: 0x4
[    1.201829] [SCAN_DBG]    Page Count Of Block:  0x40
[    1.207362] [SCAN_DBG]    Block Count Of Die:   0x400
[    1.212961] [SCAN_DBG]    Plane Count Of Die:   0x2
[    1.218396] [SCAN_DBG]    Die Count Of Chip:    0x1
[    1.223832] [SCAN_DBG]    Bank Count Of Chip:   0x1
[    1.229240] [SCAN_DBG]    Optional Operation:   0x6d
[    1.234770] [SCAN_DBG]    Access Frequence:     0x32
[    1.240275] [SCAN_DBG] =======================================================
[    1.240275]
[    1.279859] secure storage updata ok!
[    1.284008] nand secure storage ok: 58,59
[    1.288481] start block:60
[    1.291488] [ND]boot start
[    1.294632] [ND]boot :0xc1940000
[    1.298213] [ND]boot->magic :0xaa55a5a5
[    1.302463] [ND]boot->len :0x8000
[    1.306172] [ND]boot->no_use_block :0x21
[    1.310522] [ND]boot->uboot_start_block :0x8
[    1.315288] [ND]boot->uboot_next_block :0x3a
[    1.320021] [ND]boot->logic_start_block :0x21
[    1.324882] [ND]mbr len :4096
[    1.328169] [ND]_PARTITION len :2560
[    1.332131] [ND]_NAND_STORAGE_INFO len :512
[    1.336806] [ND]_FACTORY_BLOCK len :2048
[    1.341235] [NE]partition_num: 0,size :0x36e00,cross_talk 0
[    1.347464] [NE]part mbr size: 0x2000 type: 0
[    1.352298] [NE]part bootlogo size: 0x400 type: 0
[    1.357549] [NE]part env size: 0x200 type: 0
[    1.362287] [NE]part boot size: 0x3000 type: 0
[    1.367245] [NE]part rootfs size: 0x7800 type: 0
[    1.372366] [NE]part rootfs_data size: 0x7800 type: 0
[    1.377998] [NE]part recovery size: 0x4000 type: 0
[    1.383339] [NE]part misc size: 0x200 type: 0
[    1.388170] [NE]part private size: 0x200 type: 0
[    1.393320] [NE]part UDISK size: 0x1e400 type: 0
[    1.398570] [ND]partition->size :224768
[    1.402821] [ND]partition->cross_talk :0
[    1.407206] [ND]partition->attribute :0
[    1.411459] [ND]partition->start.Chip_NO :0
[    1.416129] [ND]partition->start.Block_NO :33
[    1.420956] [ND]partition->end.Chip_NO :0
[    1.425433] [ND]partition->end.Block_NO :511
[    1.430167] [ND]partition->nand_disk[0].size :8192
[    1.435507] [ND]partition->nand_disk[0].type :0
[    1.440528] [ND]partition->nand_disk[1].size :1024
[    1.445869] [ND]partition->nand_disk[1].type :0
[    1.450893] [ND]partition->nand_disk[2].size :512
[    1.456137] [ND]partition->nand_disk[2].type :0
[    1.461160] [ND]partition->nand_disk[3].size :12288
[    1.466597] [ND]partition->nand_disk[3].type :0
[    1.471620] [ND]partition->nand_disk[4].size :30720
[    1.477054] [ND]partition->nand_disk[4].type :0
[    1.482077] [ND]partition->nand_disk[5].size :30720
[    1.487515] [ND]partition->nand_disk[5].type :0
[    1.492530] [ND]partition->nand_disk[6].size :16384
[    1.497966] [ND]partition->nand_disk[6].type :0
[    1.502988] [ND]partition->nand_disk[7].size :512
[    1.508232] [ND]partition->nand_disk[7].type :0
[    1.513283] [ND]partition->nand_disk[8].size :512
[    1.518497] [ND]partition->nand_disk[8].type :0
[    1.523549] [ND]partition->nand_disk[9].size :123904
[    1.529051] [ND]partition->nand_disk[9].type :0
[    1.534103] [ND]partition->nand_disk[10].size :-1
[    1.539317] [ND]partition->nand_disk[10].type :-1
[    1.544562] [ND]partition->nand_disk[11].size :-1
[    1.549777] [ND]partition->nand_disk[11].type :-1
[    1.555021] [ND]partition->nand_disk[12].size :-1
[    1.560235] [ND]partition->nand_disk[12].type :-1
[    1.565478] [ND]partition->nand_disk[13].size :-1
[    1.570694] [ND]partition->nand_disk[13].type :-1
[    1.575940] [ND]partition->nand_disk[14].size :-1
[    1.581154] [ND]partition->nand_disk[14].type :-1
[    1.586401] [ND]partition->nand_disk[15].size :-1
[    1.591615] [ND]partition->nand_disk[15].type :-1
[    1.596858] [ND]partition->nand_disk[16].size :-1
[    1.602073] [ND]partition->nand_disk[16].type :-1
[    1.607316] [ND]partition->nand_disk[17].size :-1
[    1.612531] [ND]partition->nand_disk[17].type :-1
[    1.617774] [ND]partition->nand_disk[18].size :-1
[    1.622989] [ND]partition->nand_disk[18].type :-1
[    1.628234] [ND]partition->nand_disk[19].size :-1
[    1.633478] [ND]partition->nand_disk[19].type :-1
[    1.638693] [ND]partition->nand_disk[20].size :-1
[    1.643934] [ND]partition->nand_disk[20].type :-1
[    1.649150] [ND]partition->nand_disk[21].size :-1
[    1.654394] [ND]partition->nand_disk[21].type :-1
[    1.659610] [ND]partition->nand_disk[22].size :-1
[    1.664857] [ND]partition->nand_disk[22].type :-1
[    1.670071] [ND]partition->nand_disk[23].size :-1
[    1.675313] [ND]partition->nand_disk[23].type :-1
[    1.680530] [ND]phy_partition->PartitionNO :0
[    1.685389] [ND]phy_partition->SectorNumsPerPage :8
[    1.690796] [ND]phy_partition->PageNumsPerBlk :64
[    1.696037] [ND]phy_partition->TotalBlkNum :479
[    1.701059] [ND]phy_partition->FullBitmapPerPage :8
[    1.706495] [ND]phy_partition->FreeBlock :0
[    1.711134] [ND]phy_partition->TotalSectors :224768
[    1.716570] [ND]phy_partition->StartBlock.Chip_NO :0
[    1.722071] [ND]phy_partition->StartBlock.Block_NO :33
[    1.727794] [ND]phy_partition->EndBlock.Chip_NO :0
[    1.733135] [ND]phy_partition->EndBlock.Block_NO :511
[    1.738734] [ND]phy_partition->next_phy_partition :0
[    1.744266] [ND]phy_partition->PartitionNO 0  FACTORY BAD BLOCK:
[    1.750923] [ND]phy_partition->PartitionNO 0  NEW BAD BLOCK:
[    1.757229] [ND]build 1 phy_partition !
[    1.761481] [ND]nand_info->type :0
[    1.765283] [ND]nand_info->SectorNumsPerPage :8
[    1.770305] [ND]nand_info->BytesUserData :16
[    1.775067] [ND]nand_info->PageNumsPerBlk :64
[    1.779896] [ND]nand_info->BlkPerChip :512
[    1.784465] [ND]nand_info->FirstBuild :0
[    1.788813] [ND]nand_info->FullBitmap :0
[    1.793192] [ND]nand_info->bad_block_addr.Chip_NO :0
[    1.798695] [ND]nand_info->bad_block_addr.Block_NO :0
[    1.804326] [ND]nand_info->mbr_block_addr.Chip_NO :0
[    1.809830] [ND]nand_info->mbr_block_addr.Block_NO :0
[    1.815460] [ND]nand_info->no_used_block_addr.Chip_NO :0
[    1.821348] [ND]nand_info->no_used_block_addr.Block_NO :33
[    1.827457] [ND]nand_info->new_bad_block_addr.Chip_NO :0
[    1.833374] [ND]nand_info->new_bad_block_addr.Block_NO :0
[    1.839357] [ND]nand_info->new_bad_page_addr :65535
[    1.844793] [ND]nand_info->partition_nums :1
[    1.849525] [ND]sizeof partition:2384
[    1.853613] [ND]nand_info->partition:0:
[    1.857865] [ND]size:0x36e00
[    1.861055] [ND]cross_talk:0x0
[    1.864470] [ND]attribute:0x0
[    1.867762] [ND]start: chip:0 block:33
[    1.871919] [ND]end  : chip:0 block:511
[    1.876202] [ND]boot :0xc1940000
[    1.879782] [ND]boot->magic :0xaa55a5a5
[    1.884063] [ND]boot->len :0x8000
[    1.887738] [ND]boot->no_use_block :0x21
[    1.892083] [ND]boot->uboot_start_block :0x8
[    1.896847] [ND]boot->uboot_next_block :0x3a
[    1.901579] [ND]boot->logic_start_block :0x21
[    1.906437] [ND]mbr len :4096
[    1.909726] [ND]_PARTITION len :2560
[    1.913716] [ND]_NAND_STORAGE_INFO len :512
[    1.918352] [ND]_FACTORY_BLOCK len :2048
[    1.923035] [ND]nand_partition0
[    1.926791] [ND]nftl start:479,40
[    1.930706] [ND]first
[    2.075702] [ND]before second 479 439.
[    2.540305] [NE]recover_phy_page_mapping no used page 9!!
[    2.546387] [ND]recover 174 9
[    2.549709] [ND]free block nums is 26 !
[    2.554017] [NE]not power on gc 26!
[    2.557886] [ND]nftl ok!
[    2.560774] [ND]max_erase_times = 65000
[    2.567581]  nanda: unknown partition table
[    2.575037]  nandb: unknown partition table
[    2.582189]  nandc: unknown partition table
[    2.589486]  nandd: unknown partition table
[    2.596735]  nande: unknown partition table
[    2.603983]  nandf: unknown partition table
[    2.611152]  nandg: unknown partition table
[    2.618433]  nandh:
[    2.623411]  nandi: unknown partition table
[    2.628937] [NAND]nand init end
[    2.633040] sunxi-wlan wlan: wlan_busnum (0)
[    2.637921] sunxi-wlan wlan: wlan_power_num (0)
[    2.642965] sunxi-wlan wlan: Missing wlan_io_regulator.
[    2.648817] sunxi-wlan wlan: io_regulator_name ((null))
[    2.654697] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
[    2.662580] sunxi-wlan wlan: wlan_regon gpio=130  mul-sel=1  pull=3  drv_level=1  data=0
[    2.671720] sunxi-wlan wlan: wlan_hostwake gpio=131  mul-sel=6  pull=-1  drv_level=-1  data=1
[    2.681295] sunxi-wlan wlan: Missing clocks.
[    2.686098] sunxi-wlan wlan: clk_name ((null))
[    2.691065] sunxi-wlan wlan: clk not config
[    2.696159] lradc_battery_probe:lradc_battery_probe ++++++
[    2.702258] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
[    2.709234] key base: f1c23400
[    2.712760] irq num: 116 !
[    2.715834] battery_data_hw_init:battery_data_hw_init ++++++
[    2.722171] lradc_battery_probe:lradc_battery_probe ------
[    2.730298] spi spi1: master is unqueued, this is deprecated
[    3.297565] ssd2828 spi1.0: ssd2828_probe
[    3.302308] ssd2828 spi1.0: reg_value = 0x2828
[    3.307329] ssd2828 spi1.0: ssd2828_init START
[    3.665985] ssd2828 spi1.0: ssd2828_init SUCCESS!
[    3.671566] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.679454] usbcore: registered new interface driver usb-storage
[    3.686312] usbcore: registered new interface driver ums-alauda
[    3.692963] usbcore: registered new interface driver ums-cypress
[    3.699783] usbcore: registered new interface driver ums-datafab
[    3.706599] usbcore: registered new interface driver ums_eneub6250
[    3.713601] usbcore: registered new interface driver ums-freecom
[    3.720345] usbcore: registered new interface driver ums-isd200
[    3.727100] usbcore: registered new interface driver ums-jumpshot
[    3.734021] usbcore: registered new interface driver ums-karma
[    3.740582] usbcore: registered new interface driver ums-onetouch
[    3.747541] usbcore: registered new interface driver ums-realtek
[    3.754363] usbcore: registered new interface driver ums-sddr09
[    3.761015] usbcore: registered new interface driver ums-sddr55
[    3.767737] usbcore: registered new interface driver ums-usbat
[    3.775222] /soc/usbc0@0: could not find phandle
[    3.780369] get regulator_io is no nocare
[    3.785073] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[    3.793019] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[    3.804897] hub 1-0:1.0: USB hub found
[    3.809118] hub 1-0:1.0: 1 port detected
[    3.814078] wrn: hcd is not enable, need not stop hcd
[    3.820457] sunxi_keyboard_startup: keyboard has no clk.
[    3.827066] input: sunxi-keyboard as /devices/virtual/input/input0
[    3.835084] rtc-pcf8563 0-0051: chip found, driver version 0.4.3
[    3.841988] twi_start()387 - [i2c0] START can't sendout!
[    3.848204] twi_start()387 - [i2c0] START can't sendout!
[    3.854368] twi_start()387 - [i2c0] START can't sendout!
[    3.860365] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[    3.867807] rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0
[    3.875467] sunxi cedar version 0.1
[    3.879598] VE: install start!!!
[    3.879598]
[    3.885089] cedar_ve: cedar-ve the get irq is 103
[    3.890929] VE: install end!!!
[    3.890929]
[    3.897577] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=1)
[    3.907846] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v0.91 2018-5-29 14:19) Compiled in Feb 25 2021 at 05:49:58
[    3.920487] sunxi-mmc sdc0: Can't get vmmc regulator string
[    3.926804] sunxi-mmc sdc0: Can't get vqmmc regulator string
[    3.933146] sunxi-mmc sdc0: Can't get vdmmc regulator string
[    3.939431] sunxi-mmc sdc0: Failed getting OCR mask: 0
[    3.946494] sunxi-mmc sdc0: ***set host ocr***
[    3.951864] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    3.973213] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.003365] sunxi-mmc sdc0: base:0xf1c0f000 irq:108
[    4.008826] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
[    4.015736] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
[    4.021831] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.033199] usbcore: registered new interface driver usbhid
[    4.039390] usbhid: USB HID core driver
[    4.046368] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.060136] failed to get gpio-spk and gpio_num
[    4.067500] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
[    4.075578] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
[    4.083562] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
[    4.091290] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
[    4.099073] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker
[    4.109350] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !!
[    4.118887] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[    4.127911] sunxi-codec-machine sound.2:  sun3iw1codec <-> 1c23c00.cpudai0-controller mapping ok
[    4.137887] sunxi-codec-machine sound.2: ASoC: no sink widget found for MainMic Bias
[    4.146581] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[    4.152428] sunxi-codec-machine sound.2: ASoC: Failed to add route External MainMic -> direct -> MainMic Bias
[    4.163501] sunxi-codec-machine sound.2: ASoC: no source widget found for MainMic Bias
[    4.172295] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bias -> direct -> MIC1P
[    4.182275] sunxi-codec-machine sound.2: ASoC: no source widget found for MainMic Bias
[    4.191110] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bias -> direct -> MIC1N
[    4.201953] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[    4.209659] ipip: IPv4 over IPv4 tunneling driver
[    4.216255] gre: GRE over IPv4 demultiplexor driver
[    4.221689] ip_gre: GRE over IPv4 tunneling driver
[    4.229286] TCP: cubic registered
[    4.232984] Initializing XFRM netlink socket
[    4.237897] NET: Registered protocol family 17
[    4.242908] NET: Registered protocol family 15
[    4.248456] VFP support v0.3: not present
[    4.253868] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[    4.260178] [LCD]lcd_module_init
[    4.263914] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[    4.270730] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[    4.278207] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[    4.285337] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[    4.291343] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    4.302910] enhance_en=1
[    4.305875] matrixresult:(0x0, 0x3c4, 0x0, 0x0)
[    4.310955] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[    4.317139] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[    4.323290] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[    4.329447] pll_freq=297000000HZ, lcd_dclk_freq=62000000HZ, clk_div=4
[    4.336682] clk_div=4
[    4.339249]
[    4.339249] insmod_device_driver
[    4.339249]
[    4.347906] [LCD]open, step 0 finish
[    4.352226] device_chose finished 77!
[    4.356438] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !!
[    4.362362] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    4.383167] [LCD]open, step 1 finish
[    4.443167] [LCD]open, step 2 finish
[    4.563263] [LCD]open, step 3 finish
[    4.573653] [LCD]lcd_module_init finish
[    4.578518] usb_serial_number:20080411
[    4.583431] file system registered
[    4.590174] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    4.598022] android_usb gadget: Number of LUNs=3
[    4.603226]  lun0: LUN: removable file: (no medium)
[    4.608644]  lun1: LUN: removable file: (no medium)
[    4.614102]  lun2: LUN: removable file: (no medium)
[    4.620461] android_usb gadget: android_usb ready
[    4.626071] twi_start()387 - [i2c0] START can't sendout!
[    4.632197] twi_start()387 - [i2c0] START can't sendout!
[    4.638411] twi_start()387 - [i2c0] START can't sendout!
[    4.644479] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[    4.651152] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    4.659077] ALSA device list:
[    4.662437]   #0: audiocodec
[    4.674472] VFS: Mounted root (squashfs filesystem) readonly on device 93:48.
[    4.687626] devtmpfs: mounted
[    4.692677] Freeing unused kernel memory: 112K (c042a000 - c0446000)
mount: mounting none on /dev failed: Resource busy
mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
[    5.839100] EXT4-fs (nande): mounted filesystem with ordered data mode. Opts: (null)
-- run rc.preboot --
-- blozi init --
------- start blozi init -------
-- end --
copy SN.txt to /usr/product_id success!
-- end --
[    6.468897] EXT4-fs (nandi): mounted filesystem with ordered data mode. Opts: (null)
[    7.266067] sunxi-wlan wlan: bus_index: 0
[    7.285768] ======== XRADIO WIFI OPEN ========
[    7.290799] [XRADIO] Driver Label:XR_V02.15.40  Jun  5 2021 08:58:58
[    7.309166] [XRADIO] Allocated hw_priv @ c1916fa0
[    7.315736] product_sn to macaddr:18:54:c9:43:85:17
[    7.443309] [XRADIO] Detect SDIO card 0
[    7.458668] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    7.483267] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    7.513968] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    7.528300] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    7.541967] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[    7.563773] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[    7.575507] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[    7.587711] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[    7.600914] mmc0: new high speed SDIO card at address 0001
[    7.621799] [SBUS] XRadio Device:sdio clk=50000000
[    7.650901] [XRADIO] XRADIO_HW_REV 1.0 detected.
[    7.820985] [XRADIO] Bootloader complete
[    7.920769] [XRADIO] Firmware completed.
[    7.943271] [WSM] Firmware Label:XR_C01.08.52.11 Jan 24 2017 10:15:58
[    7.950680] [XRADIO] Firmware Startup Done.
[    8.005530] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
-- run rc.final --
insmod F1C200s-board
-- bloziplayer init --
video_dir exist
-- upgrade app --
[    8.306227] android_usb: already disabled
 _____  _              __     _
|_   _||_| ___  _ _   |  |   |_| ___  _ _  _ _
  | |   _ |   ||   |  |  |__ | ||   || | ||_'_|
  | |  | || | || _ |  |_____||_||_|_||___||_,_|
  |_|  |_||_|_||_|_|  Tina is Based on OpenWrt!
 ---------------------------[    8.384843] adb_open
----------------[    8.387948] adb_bind_config
 Tina Linux (Neptune, 5C1C9C53)
[    8.402496] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0
-- wpa supplicant init --
[    8.647847] android_work: sent uevent USB_STATE=CONNECTED
[    8.894630] android_work: sent uevent USB_STATE=DISCONNECTED
[    8.922558] android_usb gadget: high-speed config #1: android
[    8.930220] android_work: sent uevent USB_STATE=CONNECTED
[    8.939412] android_work: sent uevent USB_STATE=CONFIGURED
starting...
start success
root@TinaLinux:/# [   13.990739] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[   13.999983] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[   14.009196] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[   14.018333] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[   14.027527] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[   43.152253] [NE]gc_one ok!
root@TinaLinux:/#
root@TinaLinux:/#
修改mac地址:
没有efuse???:
root@TinaLinux:/#
root@TinaLinux:/# cat /sys/class/sunxi_info/key_info
[ 1514.128823] sunxi_efuse_readn()621 - Invalid parameter. name: c054b320, read_buf: c4901000, size: 256
00000000
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /sys/class/sunxi_info/sys_info
sunxi_platform    : Sun3iw1p1
sunxi_secure      : normal
sunxi_serial      : 00000000000000000000000000000000
sunxi_chiptype    : 00000000
sunxi_batchno     : 0x0
root@TinaLinux:/#
楼主 #4 2024-12-30 20:40:30
memory
已发帖子: 725
楼主 #5 2024-12-30 21:06:49
memory
已发帖子: 725
ps 命令:
root@TinaLinux:/# ps
  PID USER       VSZ STAT COMMAND
    1 root      1164 S    /sbin/init
    2 root         0 SW   [kthreadd]
    3 root         0 SW   [ksoftirqd/0]
    4 root         0 SW   [kworker/0:0]
    5 root         0 SW<  [kworker/0:0H]
    6 root         0 SW   [kworker/u2:0]
    7 root         0 SW<  [khelper]
    8 root         0 SW   [kdevtmpfs]
    9 root         0 SW   [kworker/0:1]
   10 root         0 SW<  [writeback]
   11 root         0 SW<  [bioset]
   12 root         0 SW<  [crypto]
   13 root         0 SW<  [kblockd]
   14 root         0 SW   [khubd]
   15 root         0 SW   [kworker/u2:1]
   26 root         0 SW<  [cfg80211]
   28 root         0 SW   [khungtaskd]
   29 root         0 SW   [kswapd0]
   30 root         0 SW   [fsnotify_mark]
   41 root         0 SW   [nand]
   42 root         0 SW   [nftld]
   43 root         0 SW   [nand_rcd]
   44 root         0 SW<  [spi1]
   47 root         0 SW<  [uether]
   48 root         0 SW   [irq/108-sunxi-m]
   49 root         0 SW   [system]
   50 root         0 SW   [kworker/u2:2]
   51 root         0 SW<  [deferwq]
   52 root         0 SW<  [f_mtp]
   53 root         0 SW   [file-storage]
   78 root         0 SW   [jbd2/nande-8]
   79 root         0 SW<  [ext4-dio-unwrit]
  103 root      1164 S    /sbin/syslogd -n -m 0
  104 root      1164 S    /sbin/klogd -n
  108 root         0 SW   [jbd2/nandi-8]
  109 root         0 SW<  [ext4-dio-unwrit]
  120 root         0 SW   [xradio_etf]
  122 root         0 SW<  [xradio_wq]
  123 root         0 SW<  [xradio_spare_wq]
  131 root         0 SW   [xradio_bh]
  133 root         0 SW<  [kworker/0:1H]
  152 root      1172 S    -/bin/sh
  153 root      1108 S    /bin/adbd -D
  155 root      1500 S    wpa_supplicant -iwlan0 -Dnl80211 -c/etc/wifi/wpa_sup
  172 root     19416 S    bloziplayer
  177 root      1168 S    -/bin/sh
  434 root      1164 S    sleep 5
  435 root      1164 R    ps
root@TinaLinux:/#
killall bloziplayer
之后必然重启,可能因为主程序喂狗中断了
楼主 #6 2024-12-30 21:28:07
memory
已发帖子: 725
坑
楼主 #7 2024-12-30 21:49:20
memory
已发帖子: 725
请问如何用命令行调整背光亮度?
https://bbs.aw-ol.com/topic/906/share/2
用这个测试调节背光,并没有卵用。
#8 2024-12-31 08:41:40
lanlanzhilian
已发帖子: 171
背光电阻根本就没焊吧
楼主 #9 2024-12-31 08:42:40
memory
已发帖子: 725
lanlanzhilian wrote:
背光电阻根本就没焊吧
请问在哪个位置呢?
#10 2024-12-31 12:18:21
lanlanzhilian
已发帖子: 171
背光电路那边好多电阻都没焊,自己量一下看看
#11 2024-12-31 14:20:57
yishuizi
memory wrote:
请问如何用命令行调整背光亮度?
用这个测试调节背光,并没有卵用。
我也使用了大神的dws,效果不错,就是亮度目前不能调。晚上太亮了
楼主 #12 2024-12-31 14:52:46
memory
已发帖子: 725
开机自动检测,不知道如何实现的。
楼主 #13 2024-12-31 15:22:44
memory
已发帖子: 725
yishuizi wrote:
memory wrote:
请问如何用命令行调整背光亮度?
用这个测试调节背光,并没有卵用。
楼主 #14 2024-12-31 15:50:01
memory
已发帖子: 725
从公司垃圾堆翻出来的T113-i 1200x1920板子,直接可以驱动价签屏。
#15 2024-12-31 17:53:42
xfdr0805
已发帖子: 350
@memory
我说当时怎么测试亮度始终没变化,原来是电阻没焊,直接最高亮度了,看来必须得拆了
#16 2024-12-31 18:05:49
xfdr0805
已发帖子: 350
yishuizi wrote:
memory wrote:
请问如何用命令行调整背光亮度?
用这个测试调节背光,并没有卵用。
这个晚上确实太亮了,跟个灯泡一样。
这个外壳卡的真是结实,当时没拆开,就没继续拆了
准备再拆一下,要是拆开的话,我抽空把自动调整亮度的加上,顺便焊个温湿度传感器上去,手里正好有几个AHT20,SHT30
楼主 #17 2025-01-01 11:35:26
memory
已发帖子: 725
memory wrote:
/files/members/7106/QQ20241231-145202.png
开机自动检测,不知道如何实现的。
sys_config.fex
burn_key=1
参考:45块顺丰包邮买到的10.1寸保资LCD价签F1C200S 值不值
#18 2025-01-02 09:12:06
li6848
已发帖子: 29
@memory
直接把/etc/init.d/rc.final里面的bloziplayer相关的启动脚本给注释关了或者删了。
把/etc/profile.d/里面的脚本也给删了。
再给/etc/init.d/rc.final里加
#联网
wpa_supplicant -iwlan0 -Dnl80211 -c /etc/wpa_supplicant.conf & udhcpc -iwlan0 &
#启动自己应用
/usr/bin/player &
wpa_supplicant.conf文件内容如下
network={
ssid="SSID" # SSID
psk="xxxxxxx" # 密码
启动后就很干净了。第一个贴里发过了。怎么这又开了2.3贴炒冷饭。。。同一个贴里一起讨论交流不好吗。
#19 2025-01-02 09:26:35
jordonwu
已发帖子: 66
这个有人成功自己编译固件点屏了吗?
#20 2025-01-02 09:38:51
xfdr0805
已发帖子: 350
jordonwu wrote:
这个有人成功自己编译固件点屏了吗?
没用过全志tina Linux, 不过主线编译应该没问题,坛里资料挻全了。
还是想上rtt 不过问题是sdio wifi xr819不好驱
#21 2025-01-02 10:08:37
li6848
已发帖子: 29
jordonwu wrote:
这个有人成功自己编译固件点屏了吗?
论坛里面F1C200S编译。ssd2828使用spi1来初始化。
SPI初始化数据:
https://whycan.com/t_11396.html#p101059
裸机代码
https://whycan.com/t_11396.html#p101140
不过论坛里的编译环境教程比较老了。我没成功。不过有交叉编译工具和dts,直接改DTS再编译就好用了。点屏代码链接里有佬抓了初始化代码。
#22 2025-01-07 20:54:55
litedoufu
想把它当成电子相册,用电脑直接将照片推送过去,这样是不是要求简单些吖
#23 2025-01-12 22:24:06
li6848
已发帖子: 29
为了更便于使用,adb并不是每个人都有呀。用HTML传参数。传照片,更方便家人用呀。要不然还要让家人带回来,我给他推。
#26 2025-03-15 18:17:09
夜黑风高雪花飞舞3
45可以整个平板电脑玩了,这个没有捡到便宜啊!
楼主 #29 2025-04-30 20:52:37
memory
已发帖子: 725
/etc/blozi/network.conf
[server]
ip = 192.168.200.2
port = 8189
[wifi]
set = 0
ssid = blozi-lcd-
password = blozi567lcd
这个联网要怎么才能玩呢?
楼主 #30 2025-04-30 21:09:38
memory
已发帖子: 725
[server]
ip = 192.168.200.2
port = 8189
[wifi]
set = 0
ssid = blozi-lcd-
这个联网要怎么才能玩呢?
基站ssid和password套出来了:
root@TinaLinux:/# bloziplayer
WARNING: awplayer <log_set_level:30>: Set log level to 7
warning: cedarc <VDecoderRegister:127>: register codec: '115:h264' success.
warning: cedarc <VDecoderRegister:127>: register codec: '101:mjpeg' success.
warning: cedarc <VDecoderRegister:127>: register codec: '102:mpeg2' success.
warning: cedarc <VDecoderRegister:127>: register codec: '103:mpeg2' success.
warning: cedarc <VDecoderRegister:127>: register codec: '105:mpeg4dx' success.
warning: cedarc <VDecoderRegister:127>: register codec: '106:mpeg4dx' success.
warning: cedarc <VDecoderRegister:127>: register codec: '107:mpeg4dx' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10e:mpeg4dx' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10f:mpeg4dx' success.
warning: cedarc <VDecoderRegister:127>: register codec: '104:mpeg4H263' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10b:mpeg4H263' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10d:mpeg4H263' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10a:mpeg4Normal' success.
warning: cedarc <VDecoderRegister:127>: register codec: '10c:mpeg4Normal' success.
warning: cedarc <VDecoderRegister:127>: register codec: '108:mpeg4Normal' success.
warning: cedarc <VDecoderRegister:127>: register codec: '109:mpeg4Normal' success.
bloziplayer Version: 1.2.0
product_sn = 5000003737, len = 10
sn = 5000003737, g_product_sn = 5000003737
g_http_server_url:http://192.168.200.2:8189
/dev/urandom = 286908823
-------------------rand_num: 286908823 ----------------
-------------------wifi on start delay 3 S----------------
tr: write error: Broken pipe
head: standard output: Broken pipe
dd: writing '/dev/fb0': No space left on device
16001+0 records in
16000+0 records out
http_get(1) json data array size = 2
------------------video--------------------
http_get(1) json video time = 0
http_get(1) json video data area left=0, top=0, weith=800, height=480
http_get(1) json video data files num = 1
http_get(1) json video file[0].name=cmedia1654149294544.mp4
http_get(1) json video file[0].md5=93060ff49b09e6d971b4f17ce3395292
------------------img[0]--------------------
http_get(1) json img[0] time = 0
http_get(1) json img[0] data area left=0, top=480, weith=800, height=800
http_get(1) json img[0] file num = 1
http_get(1) json img[0] file[0].name=167975_926h884195844_s5000003737_1005396016.jpg
http_get(1) json img[0] file[0].md5=7b881fddce123f5732b422853de09db0
-------------video_player_read_conf ret=0-----------
video player read conf sucess!
player not init.
opt_alpha = 0, x_size = 800, y_size = 800, file=/mnt/UDISK/bloziplayer/167975_926h884195844_s5000003737_1005396016.jpg
display img[0]: /mnt/UDISK/bloziplayer/167975_926h884195844_s5000003737_1005396016.jpg 0 480
player_conf.video.num = 1
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : tina3.5
branch: tina-dev
date  : Mon Jul 15 19:04:59 2019 +0800
Change-Id: I5f6c8a88d7b387a312b7744797a0d5f8ab07ee7a
debug  : cedarc <VeSetSpeed:1559>: *** set ve freq to 300 Mhz ***
debug  : cedarc <VeInitialize:1198>: ve init ok
debug  : cedarc <VeRelease:1253>: ve release ok
debug  : cedarc <VideoEngineCreate:388>: *** pEngine->nIcVeVersion = 1663, decIpVersion = 0
debug  : cedarc <VeGetChipId:1385>: 00000000
debug  : cedarc <CreateSpecificDecoder:1209>: Create decoder '115:h264'
debug  : cedarc <VideoEngineCreate:481>: **************eCtlAfcbMode = 0
setDataSource end
TPLAYER_NOTIFY_PREPARED,has prepared.
prepare
prepared ok
debug  : cedarc <H264ProcessExtraData2:579>: H264ProcessNaluUnit, bNeedFindSPS = 0, bNeedFindPPS = 0
opt_alpha = 1, x_size = 24, y_size = 24, file=/etc/img/wifi0.png
debug  : cedarc <H264DecodePictureScanType:2688>: here3:hCtx->bProgressice=1
wifimanager Version: 18.10.31
wpa_supplicant :process exist
connect to wpa_supplicant ok!
do cmd STATUS
event_label:354508771
--->WMG_EVENT: WSE_STARTUP_AUTO_CONNECT
--->WMG_STATE: DISCONNECTED
event_label 0x15215fe3
Disconnected,the reason:WSE_STARTUP_AUTO_CONNECT
aw wifi on success!
The network has been disconnected
do cmd LIST_NETWORKS
do cmd SAVE_CONFIG
do cmd SCAN
read event 5
do cmd SCAN_RESULTS
ret of get_scan_results is 0
bssid / frequency / signal level / flags / ssid
c8:bf:4c:d5:43:88       2417    -22     [WPA2-PSK+FT/PSK-CCMP][WPS][ESS]        whycan
96:5f:f5:86:51:21       2467    -41     [WPA2-PSK-CCMP][ESS]    bloziwifi
fa:f7:b9:9f:64:2c       2437    -50     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
f8:f7:b9:af:54:1c       2462    -56     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
fa:f7:b9:9f:86:d4       2412    -61     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
68:77:da:f7:e0:10       2452    -78     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      zhangwei
8c:74:a0:81:cf:30       2462    -82     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      CMCC-5jwS
d8:68:52:84:40:ed       2462    -79     [ESS]   aWiFi
d8:6d:17:ae:a5:94       2412    -74     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Nader
4e:10:d5:7d:5d:9d       2437    -84     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]
f6:84:8d:ed:7d:b9       2412    -81     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]
f4:84:8d:fd:7d:b9       2412    -82     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      1302room
d8:68:52:84:40:ec       2462    -81     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Z
fc:ab:90:d7:32:31       2437    -85     [WPA2-PSK-CCMP][ESS]    \x00\x00\x00\x00\x00\x00\x00\x00
d8:6d:17:ae:a5:95       2412    -77     [ESS]   aWiFi
d8:6d:17:d2:20:8d       2432    -82     [ESS]   aWiFi
d8:6d:17:d2:20:8c       2432    -82     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Nader
b2:fd:77:84:3a:50       2412    -79     [ESS]   RHX-8W4m#123456
Wifi get_scan_results: Success!
not find ssid blozi-lcd-1
not find ssid blozi-lcd-2
not find ssid blozi-lcd-3
not find ssid blozi-lcd-4
not find ssid blozi-lcd-5
not find ssid blozi-lcd-6
not find ssid blozi-lcd-7
not find ssid blozi-lcd-8
not find ssid blozi-lcd-9
not find ssid blozi-lcd-10
wifi_connect_state_check = 0
do cmd SCAN
read event 5
do cmd SCAN_RESULTS
8c:74:a0:81:cf:30       2462    -80     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      CMCC-5jwS
d8:6d:17:ae:a5:94       2412    -75     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Nader
d8:68:52:84:40:ec       2462    -80     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Z
fc:ab:90:d7:32:31       2437    -84     [WPA2-PSK-CCMP][ESS]    \x00\x00\x00\x00\x00\x00\x00\x00
d8:6d:17:ae:a5:95       2412    -76     [ESS]   aWiFi
fc:7c:02:61:eb:7b       2412    -83     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]    @PHICOMM_79
do cmd SCAN
read event 5
do cmd SCAN_RESULTS
c8:bf:4c:d5:43:88       2417    -23     [WPA2-PSK+FT/PSK-CCMP][WPS][ESS]        whycan
ec:31:4a:2f:e1:b7       2437    -83     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      \xe5\x9c\xa3\xe5\x8b\xa4\xe6\x95\x99\xe8\x82\xb2\xe5\xa4\xa7\xe5\x8e\x85
fc:ab:90:d7:32:2d       2437    -83     [WPA2-PSK-CCMP][ESS]    \x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00
ssid: blozi-lcd-1
ssid: blozi-lcd-2
ssid: blozi-lcd-10
password: blozi567lcd
楼主 #31 2025-04-30 21:19:16
memory
已发帖子: 725
运行 bloziplayer 日志:
product_sn = AA:BB:CC:DD:EE:FF
, len = 18
, g_product_sn = 5000003676
/dev/urandom = 572566787
-------------------rand_num: 572566787 ----------------
-------------------wifi on start delay 16 S----------------
16001+0 records in
16000+0 records out
http_get(1) json data array size = 3
http_get(1) json img[0] data area left=0, top=480, weith=800, height=400
http_get(1) json img[0] file[0].name=168942_818h1521068339_s5000003676_23382587.jpg
http_get(1) json img[0] file[0].md5=b064d460f95d4eace82e5f70c3e23abf
------------------img[1]--------------------
http_get(1) json img[1] time = 0
http_get(1) json img[1] data area left=0, top=880, weith=800, height=400
http_get(1) json img[1] file num = 1
http_get(1) json img[1] file[0].name=168531_818h1521068339_s5000003676_1526018229.jpg
http_get(1) json img[1] file[0].md5=ee2984e2ae69b2e077fba9c514598941
player not init.
opt_alpha = 0, x_size = 800, y_size = 400, file=/mnt/UDISK/bloziplayer/168942_818h1521068339_s5000003676_23382587.jpg
display img[0]: /mnt/UDISK/bloziplayer/168942_818h1521068339_s5000003676_23382587.jpg 0 480
opt_alpha = 0, x_size = 800, y_size = 400, file=/mnt/UDISK/bloziplayer/168531_818h1521068339_s5000003676_1526018229.jpg
display img[1]: /mnt/UDISK/bloziplayer/168531_818h1521068339_s5000003676_1526018229.jpg 0 880
tag   : tina3.5
branch: tina-dev
debug  : cedarc <VeSetSpeed:1559[  106.171619] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
>: *** set ve fr[  106.181229] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
eq to 300 Mhz **[  106.191082] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
debug  : ceda[  106.200899] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
rc <VeInitialize[  106.210812] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
:1198>: ve init ok
setDataSource end
prepare
prepared ok
[  115.275018] twi_start()387 - [i2c0] START can't sendout!
[  115.281320] twi_start()387 - [i2c0] START can't sendout!
[  115.287513] twi_start()387 - [i2c0] START can't sendout!
[  115.293541] rtc-pcf8563 0-0051: pcf8563_set_datetime: err=-121 addr=02, data=19
[  115.309776] twi_start()387 - [i2c0] START can't sendout!
[  115.315973] twi_start()387 - [i2c0] START can't sendout!
[  115.322232] twi_start()387 - [i2c0] START can't sendout!
[  115.328320] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[  115.346879] twi_start()387 - [i2c0] START can't sendout!
[  115.353090] twi_start()387 - [i2c0] START can't sendout!
[  115.359292] twi_start()387 - [i2c0] START can't sendout!
[  115.365359] rtc-pcf8563 0-0051: pcf8563_set_datetime: err=-121 addr=02, data=20
[  115.389389] twi_start()387 - [i2c0] START can't sendout!
[  115.395566] twi_start()387 - [i2c0] START can't sendout!
[  115.401882] twi_start()387 - [i2c0] START can't sendout!
[  115.408044] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
do cmd STATUS
Wifi already connect to whycan
event_label:249285976
--->WMG_STATE: NETWORK_CONNECTED
event_label 0xedbcd58
Successful network connection(whycan)
aw wifi on success!
do cmd DISCONNECT
[  121.199999] [TXRX_WRN] drop=1440, fctl=0x00d0.
[  121.289493] wlan0: deauthenticating from c8:bf:4c:d5:43:88 by local choice (reason=3)
[  121.300733] [WSM_WRN] Issue unjoin command(TX).
[  121.330649] cfg80211: Calling CRDA for country: CN
Network disconnected!
event_label:249285977
--->WMG_EVENT: WSE_AUTO_DISCONNECTED
event_label 0xedbcd59
Disconnected,the reason:WSE_AUTO_DISCONNECTED
do cmd REMOVE_NETWORK 0
do cmd SAVE_CONFIG
clear data 2
do cmd SCAN
[  124.082107] [BH_WRN] miss interrupt!
read event 5
do cmd SCAN_RESULTS
c8:bf:4c:d5:43:88       2417    -26     [WPA2-PSK+FT/PSK-CCMP][WPS][ESS]        whycan
fe:ba:6d:1a:ee:48       2472    -37     [WPA2-PSK-CCMP][ESS]    blozi-lcd-1
fa:f7:b9:9f:64:2c       2437    -56     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
fa:f7:b9:9f:86:d4       2412    -60     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
f8:f7:b9:af:54:1c       2462    -52     [WPA2-PSK-CCMP][WPS][ESS]       ChinaNet-SZZH
08:40:f3:21:52:f1       2417    -80     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      Tenda_ksK6J9
98:1e:89:3e:f0:a1       2437    -82     [WPA2-PSK-CCMP][WPS][ESS]       \xe6\x94\xb6\xe9\x93\xb6\xe7\xb3\xbb\xe7\xbb\x9f
ec:31:4a:2f:e1:b7       2437    -82     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      \xe5\x9c\xa3\xe5\x8b\xa4\xe6\x95\x99\xe8\x82\xb2\xe5\xa4\xa7\xe5\x8e\x85
98:1e:89:46:d4:b1       2437    -83     [WPA2-PSK-CCMP][WPS][ESS]       \xe6\x94\xb6\xe9\x93\xb6\xe7\xb3\xbb\xe7\xbb\x9f
d8:6d:17:d2:20:8d       2432    -77     [ESS]   aWiFi
b2:fd:77:84:3a:50       2412    -81     [ESS]   RHX-8W4m#123456
48:2f:d7:d1:f8:a8       2412    -80     [WPA2-PSK-CCMP][WPS][ESS]       DTB1602
fc:7c:02:61:eb:7b       2412    -82     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]    @PHICOMM_79
68:77:da:f7:e0:10       2452    -83     [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]      zhangwei
50:d2:f5:7d:46:cb       2457    -83     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       Xiaomi_46CA
d8:6d:17:ae:a5:95       2412    -65     [ESS]   aWiFi
find ssid blozi-lcd-1 in line 2  ssid= blozi-lcd-1, rssi= -37
wifi_info[0]: ssid = blozi-lcd-1, psk= blozi567lcd, rssi = -37
Wifi connect wifi_info[0]:blozi-lcd-1
event_label:249285979
--->WMG_EVENT: WSE_ACTIVE_CONNECT
--->WMG_STATE: CONNECTING
event_label 0xedbcd5b
Connecting to the network(blozi-lcd-1)......
do cmd ADD_NETWORK
do cmd SET_NETWORK 0 ssid "blozi-lcd-1"
do cmd SET_NETWORK 0 key_mgmt WPA-PSK
do cmd SET_NETWORK 0 psk "blozi567lcd"
do cmd SET_NETWORK 0 scan_ssid 1
do cmd GET_NETWORK 0 priority
do cmd SET_NETWORK 0 priority 1
[  124.644984] [STA_WRN] Freq 2472 (wsm ch: 13) prev: 2.
net id connecting 0
start reading WPA EVENT!
[  124.654484] wlan0: authenticate with fe:ba:6d:1a:ee:48 (try 1)
[  124.804891] wlan0: authenticated
[  124.814415] wlan0: associate with fe:ba:6d:1a:ee:48 (try 1)
[  124.852000] wlan0: RX AssocResp from fe:ba:6d:1a:ee:48 (capab=0x411 status=0 aid=1)
[  124.860657] wlan0: associated
[  124.880790] [AP_WRN] [STA] ASSOC HTCAP 11N 58
read event 1
reading WPA EVENT is over!
do cmd SAVE_CONFIG
wifi connected in inner!
do cmd ENABLE_NETWORK 0
do cmd SAVE_CONFIG
--->WMG_STATE: CONNECTED
Connected to the AP(blozi-lcd-1)
--->WMG_EVENT: WSE_ACTIVE_OBTAINED_IP
--->WMG_STATE: OBTAINING_IP
Getting ip address(blozi-lcd-1)......
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 192.168.243.210
[  125.612291] [TXRX_WRN] drop=1440, fctl=0x00d0.
udhcpc: lease of 192.168.243.210 obtained, lease time 3599
vflag= 4
Successful network connection(blozi-lcd-1)
connected Successful  !!!!
Wifi connect ap : Success! ssid = blozi-lcd-1, psk= blozi567lcd, rssi = -37
do cmd STATUS
do cmd SIGNAL_POLL
get_connection_info: ip= 192.168.243.210 mac_addr= 34:e9:8b:e1:06:43 rssi=-30db
opt_alpha = 1, x_size = 24, y_size = 24, file=/etc/img/wifi4.png
http_get(1) url=http://192.168.200.2:8189/alive?ver=1.2.0&scrn=10.1c800x1280v&sn=AA:BB:CC:DD:EE:FF
&model=bz-lcd-101-b&rssi=-30
[HTTPC][ERR]Send Header failed,849
[HTTPC][ERR]HTTP Send Request failed..
 http get error, ret=8
[  148.300999] twi_start()387 - [i2c0] START can't sendout!
[  148.307206] twi_start()387 - [i2c0] START can't sendout!
[  148.313451] twi_start()387 - [i2c0] START can't sendout!
[  148.319530] rtc-pcf8563 0-0051: pcf8563_set_datetime: err=-121 addr=02, data=52
[  148.334995] twi_start()387 - [i2c0] START can't sendout!
[  148.341467] twi_start()387 - [i2c0] START can't sendout!
[  148.347636] twi_start()387 - [i2c0] START can't sendout!
[  148.353750] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
楼主 #32 2025-05-06 13:39:17
memory
已发帖子: 725
刚刚入手五块
#33 2025-05-06 14:11:11
已发帖子: 857
可以跑lvgl了吗
#37 2026-02-05 14:09:27
aaaccc2000
这个还有最新完的方法吗?刚买了一个带贴膜的,显示效果很好
#38 2026-02-13 16:54:05
aaaccc2000
调光方法
R74 和 R75 短路上,就能用这个程序 backlight.bin.7z 学习了
#39 2026-02-13 16:54:53
aaaccc2000
@memory目前有新进展不?老哥
#40 2026-07-28 12:04:52
dykxjh
已发帖子: 194
为什么我的屏幕四个角发红?买到垃圾屏幕了吗?
#41 2026-07-28 17:28:18
hameyou
已发帖子: 271
dykxjh 说:
/files/members/3493/20260728120252_60_2.jpg
估计老化了,我的也是上电后四角发亮
