楼主 #1 2018-09-03 10:46:29
楼主 #2 2018-09-03 10:47:23
Re: 买两片 W25M512JVFIQ 测试一下
$ sudo sunxi-fel -p spiflash-info
Manufacturer: Winbond (EFh), model: 71h, size: 33554432 bytes
sunxi-fel 不能识别成 512.
楼主 #3 2018-09-03 10:48:43
JFlashSPI.exe 搭配jlink v9 也仍然无法识别正确。
#4 2018-09-03 11:09:10
多少钱?
楼主 #5 2018-09-03 11:16:50
芯片手册: W25M512JV
看起来这个芯片就是玩 Die 堆叠了, 叠了两个 W25Q256, 用 0xC2 命令来选则 Die.
楼主 #6 2018-09-03 11:17:23
达克罗德 wrote:
多少钱?
19左右.
楼主 #7 2018-09-03 11:18:33
用各个版本的 JLINK 软件都没能烧写正常。
楼主 #8 2018-09-03 11:19:27
即使设置了 双 Die 模式也一样不能通过校验.
楼主 #9 2018-09-03 11:21:16
sunxi-fel 烧写正常。
楼主 #10 2018-09-03 16:37:00
V3s u-boot 修改
licheepi/u-boot/drivers/mtd/spi/spi_flash_ids.c
添加一行:
{"w25m512jv", INFO(0xef7119, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | SECT_4K) },
linux
licheepi/linux/drivers/mtd/devices/m25p80.c
添加
{"w25q80bl"}, {"w25q128"}, {"w25q256"}, {"w25m512jv"},
licheepi/linux/drivers/mtd/spi-nor/spi-nor.c
{ "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024, SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) },
改完之后重新编译烧录, 发现u-boot, Linux都可以启动,w25q256驱动不正常了:
[ 0.624277] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 0.624352] m25p80: probe of spi32766.0 failed with error -2
楼主 #11 2018-09-03 16:38:42
经过 @assert 大神指点, 把 spi 时钟频率从 50Mhz 调整到 16Mhz,
识别flash正常了.
licheepi/linux/arch/arm/boot/dts/sun8i-v3s-sya.dts
&spi0 {
status ="okay";
mx25l25635e:mx25l25635e@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-max-frequency = <16000000>;
#address-cells = <1>;
#size-cells = <1>;
楼主 #12 2018-09-03 18:36:36
JLINK 6.30i 也是个扯淡的软件, 读出来和写进去偏移了一个字节.
6.10d 可以写一个 u-boot 进去,校验也正常,但是写32M文件在 0xF0000 处校验失败。
楼主 #13 2018-09-03 18:39:00
找到一个 linux 下的 W25M512 的补丁
https://github.com/ya-mouse/openbmc-target/blob/master/aspeed/patches-3.18/0006-Add-various-MTD-SPI-chips.patch
From c7025568f83800de384c457557169e44740dc8f7 Mon Sep 17 00:00:00 2001
Date: Tue, 24 May 2016 19:36:35 +0300
Subject: [PATCH 06/14] Add various MTD SPI chips
Signed-off-by: Anton D. Kachalov <mouse@yandex-team.ru>
 drivers/mtd/spichips/Kconfig     |   94 ++++
 drivers/mtd/spichips/Makefile    |   18 +
 drivers/mtd/spichips/astspi.c    |  367 +++++++++++++
 drivers/mtd/spichips/atmel.c     |  133 +++++
 drivers/mtd/spichips/default.c   |  106 ++++
 drivers/mtd/spichips/generic.c   | 1052 ++++++++++++++++++++++++++++++++++++++
 drivers/mtd/spichips/intels33.c  |   96 ++++
 drivers/mtd/spichips/m25pxx.c    |  121 +++++
 drivers/mtd/spichips/macronix.c  |  208 ++++++++
 drivers/mtd/spichips/micron.c    |  104 ++++
 drivers/mtd/spichips/spansion.c  |  103 ++++
 drivers/mtd/spichips/spiaccess.c |  433 ++++++++++++++++
 drivers/mtd/spichips/spiflash.h  |  178 +++++++
 drivers/mtd/spichips/spimtd.c    |  241 +++++++++
 drivers/mtd/spichips/spireg.c    |  180 +++++++
 drivers/mtd/spichips/winbond.c   |   98 ++++
 16 files changed, 3532 insertions(+)
 create mode 100644 drivers/mtd/spichips/Kconfig
 create mode 100644 drivers/mtd/spichips/Makefile
 create mode 100644 drivers/mtd/spichips/astspi.c
 create mode 100644 drivers/mtd/spichips/atmel.c
 create mode 100644 drivers/mtd/spichips/default.c
 create mode 100644 drivers/mtd/spichips/generic.c
 create mode 100644 drivers/mtd/spichips/intels33.c
 create mode 100644 drivers/mtd/spichips/m25pxx.c
 create mode 100644 drivers/mtd/spichips/macronix.c
 create mode 100644 drivers/mtd/spichips/micron.c
 create mode 100644 drivers/mtd/spichips/spansion.c
 create mode 100644 drivers/mtd/spichips/spiaccess.c
 create mode 100644 drivers/mtd/spichips/spiflash.h
 create mode 100644 drivers/mtd/spichips/spimtd.c
 create mode 100644 drivers/mtd/spichips/spireg.c
 create mode 100644 drivers/mtd/spichips/winbond.c
diff --git a/drivers/mtd/spichips/Kconfig b/drivers/mtd/spichips/Kconfig
new file mode 100644
index 0000000..c5e5a4c
--- /dev/null
+++ b/drivers/mtd/spichips/Kconfig
@@ -0,0 +1,94 @@
+# drivers/mtd/chips/Kconfig
+# $Id: Kconfig,v 1.18 2005/11/07 11:14:22 gleixner Exp $
+menu "SPI Flash chip drivers"
+	depends on MTD!=n
+config MTD_SPI
+	bool "Enable MTD support on SPI devices"
+	depends on MTD
+	help
+	  Select this if you want to access SPI flash devices via MTD
+config MTD_SPI_SPANSION
+	bool "Spansion SPI devices Support"
+	depends on MTD_SPI
+	help
+	  Select this if you want to use Spansion SPI devices
+config MTD_SPI_MACRONIX
+	bool "Macronix SPI devices Support"
+	help
+	  Select this if you want to use Macronix SPI devices
+config MTD_SPI_INTEL_S33
+	bool "Intel S33 SPI devices Support"
+	help
+	  Select this if you want to use Intel S33 SPI devices
+config MTD_SPI_WINBOND
+	bool "Winbond SPI devices Support"
+	help
+	  Select this if you want to use Winbond SPI devices
+config MTD_SPI_AT
+	bool "Atmel SPI devices Support"
+	help
+	  Select this if you want to use Atmel SPI devices
+config MTD_SPI_ST
+	bool "ST Micro SPI devices Support"
+	help
+	  Select this if you want to use ST Microelectronics SPI devices
+config MTD_SPI_NUMONYX
+	bool "Numonyx SPI devices Support"
+	help
+	  Select this if you want to use Numonyx SPI devices
+config MTD_SPI_MICRON
+	help
+	  Select this if you want to use Micron SPI devices
+config MTD_SPI_DEFAULT
+	bool "Support for SPI Devices not supporting ReadID"
+	help
+	   Select this if the SPI device on your board does not SPI ReadID Command
+config DEFAULT_SPI_NAME
+	string "Default SPI Name"
+	depends on MTD_SPI && MTD_SPI_DEFAULT
+	default "default"
+	help
+	   Name of the SPI Device that does not support ReadID
+config DEFAULT_SPI_SIZE
+	int "Default SPI Size in Bytes"
+	default "65536"
+	help
+	   Chip Size of the SPI Device that does not support ReadID
+config DEFAULT_SPI_ERASE_SIZE
+	int "Default SPI Erase Block Size in Bytes"
+	default "65536"
+	help
+	   Erase Block Size of the SPI Device that does not support ReadID
+config MTD_AST_SPI
+	bool "AST SOC SPI Flash Controller"
+	help
+		If you are using SPI device on AST SOC, select Y
+endmenu
diff --git a/drivers/mtd/spichips/Makefile b/drivers/mtd/spichips/Makefile
index 0000000..b30a452
--- /dev/null
+++ b/drivers/mtd/spichips/Makefile
@@ -0,0 +1,18 @@
+# linux/drivers/spichips/Makefile
+obj-$(CONFIG_MTD_SPI)		+= spimtd.o spiaccess.o spireg.o generic.o
+obj-$(CONFIG_MTD_SPI_ST)   	+= m25pxx.o
+obj-$(CONFIG_MTD_SPI_SPANSION) += spansion.o
+obj-$(CONFIG_MTD_SPI_MACRONIX) += macronix.o
+obj-$(CONFIG_MTD_SPI_AT)   	+= atmel.o
+obj-$(CONFIG_MTD_SPI_INTEL_S33) += intels33.o
+obj-$(CONFIG_MTD_SPI_WINBOND) += winbond.o
+obj-$(CONFIG_MTD_SPI_MICRON) += micron.o
+obj-$(CONFIG_MTD_SPI_NUMONYX) += micron.o
+# The default driver  should be the last in the list of suppported devices
+obj-$(CONFIG_MTD_SPI_DEFAULT)   += default.o
+obj-$(CONFIG_MTD_AST_SPI)   += astspi.o
diff --git a/drivers/mtd/spichips/astspi.c b/drivers/mtd/spichips/astspi.c
index 0000000..a0dc9d4
--- /dev/null
+++ b/drivers/mtd/spichips/astspi.c
@@ -0,0 +1,367 @@
+ * (C) Copyright 2009
+ * American Megatrends Inc.
+ * SPI flash controller driver for the AST SoC
+ * See file CREDITS for list of people who contributed to this
+ * project.
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.	 See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#include "spiflash.h"
+#define AST_FMC_REG_BASE		AST_FMC_VA_BASE /* 0x1E620000 */
+#define AST_FMC_FLASH_CTRL_REG		0x00
+#define AST_FMC_CE0_CTRL_REG		0x10
+#define AST_FMC_CTRL_REG_SIZE           0x04
+#define AST_SPI_CMD_MASK		0x00FF0000 /* bit[23:16] */
+#define AST_SPI_CMD_SHIFT		16
+#define AST_SPI_CLOCK_MASK		0x00000F00 /* bit[11:8] */
+#define AST_SPI_CLOCK_SHIFT		8
+#define AST_SPI_DUMMY_MASK		0x000000C0 /* bit[7:6] */
+#define AST_SPI_DUMMY_0			0x00000000
+#define AST_SPI_DUMMY_1			0x00000040
+#define AST_SPI_DUMMY_2			0x00000080
+#define AST_SPI_DUMMY_3			0x000000C0
+#define AST_SPI_DATA_SINGLE		0x00000000
+#define AST_SPI_DATA_DUAL		0x00000008
+#define AST_SPI_DUAL_IO		0x00000002
+#define AST_SPI_FULL_DUAL_IO		0x00000003
+#define AST_SPI_DATA_MASK		7
+#define AST_SPI_DUAL_IO_SHIFT		28
+#define AST_SPI_CE_LOW			0x00000000
+#define AST_SPI_CE_HI			0x00000004
+#define AST_SPI_CMD_MODE_MASK		0x00000007 /* bit[2:0] */
+#define AST_SPI_CMD_MODE_NORMAL		0x00000000
+#define AST_SPI_CMD_MODE_FAST		0x00000001
+#define AST_SPI_CMD_MODE_WRITE		0x00000002
+#define AST_SPI_CMD_MODE_USER		0x00000003
+#define SPI_FAST_READ_CMD		0x0B
+#define SPI_DREAD_CMD		0x3B
+#define SPI_2READ_CMD		0xBB
+extern unsigned long ractrends_spiflash_flash_size[MAX_SPI_BANKS];
+static int *g_fast_read = 0;
+static void reset_flash(int bank)
+	uint32_t reg;
+	uint32_t ctrl_reg;
+        // bank = 0,CE0 (0x10) ; bank = 1,CE1 (0x14) ; bank = 2,CE2 (0x18)
+        ctrl_reg = AST_FMC_CE0_CTRL_REG + (bank * AST_FMC_CTRL_REG_SIZE);
+	reg = ioread32((void __iomem *)AST_FMC_REG_BASE + ctrl_reg);
+	if (*g_fast_read == 3)//2xI/O Read
+		reg &= ~(AST_SPI_CMD_MASK | AST_SPI_DUMMY_MASK | AST_SPI_CMD_MODE_MASK);
+		reg |= (SPI_2READ_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST | (AST_SPI_FULL_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 2)//Dual Read
+		reg |= (SPI_DREAD_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST | (AST_SPI_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 1)//Fast Read
+		reg |= (SPI_FAST_READ_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST;
+	else
+		reg &= (~AST_SPI_CMD_MODE_MASK);
+		reg |= (AST_SPI_CE_LOW | AST_SPI_CMD_MODE_NORMAL);
+	iowrite32(reg, (void __iomem *)AST_FMC_REG_BASE + ctrl_reg);
+static void reset_iomode (int bank)
+	uint32_t reg;
+	reg &= ~(AST_SPI_CMD_MASK | AST_SPI_DUMMY_MASK | (AST_SPI_DATA_MASK << AST_SPI_DUAL_IO_SHIFT));
+	if (*g_fast_read == 2)//Dual Read
+		reg |= (AST_SPI_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 3)//2xI/O Read
+		reg |= (AST_SPI_FULL_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	return;
+static void chip_select_active(int bank)
+	uint32_t reg;
+	reg &= (~(AST_SPI_CMD_MODE_MASK | (AST_SPI_DATA_MASK << AST_SPI_DUAL_IO_SHIFT)) );
+	reg |= (AST_SPI_CE_LOW | AST_SPI_CMD_MODE_USER);
+static void chip_select_deactive(int bank)
+	uint32_t reg;
+	reg |= (AST_SPI_CE_HI | AST_SPI_CMD_MODE_USER);
+static int astspiflash_transfer(int bank, unsigned char *cmd, int cmdlen, SPI_DIR dir, unsigned char *data, unsigned long datalen)
+	ulong base;
+	int i;
+	ulong offset = 0;
+	for(i = 0; i < bank; i++)
+		offset += ractrends_spiflash_flash_size[i];
+	base = AST_SPI_FLASH_VA_BASE + offset;
+	chip_select_active(bank);
+	if (cmd[0] == 0xBB)
+		*((volatile unsigned char *) base) = cmd[0];
+		reset_iomode(bank);
+		for (i = 1; i < cmdlen; i ++)
+			*((volatile unsigned char *) base) = cmd[i];
+	else if (cmd[0] == 0x3B)
+		for (i = 0; i < cmdlen; i ++)
+	else
+	/* issue command */
+	if (dir == SPI_WRITE) {
+		/* write data to flash */
+		for (i = 0; i < datalen; i ++) {
+			*((volatile unsigned char *) base) = data[i];
+	} else if (dir == SPI_READ) {
+		/* read data from flash */
+			data[i] = ((volatile unsigned char *) base)[i];
+	chip_select_deactive(bank);
+	reset_flash(bank);
+	return 0;
+static const unsigned char clock_selection_table[] = {
+	0x0F, /* 1 */
+	0x07, /* 2 */
+	0x0E, /* 3 */
+	0x06, /* 4 */
+	0x0D, /* 5 */
+	0x05, /* 6 */
+	0x0C, /* 7 */
+	0x04, /* 8 */
+	0x0B, /* 9 */
+	0x03, /* 10 */
+	0x0A, /* 11 */
+	0x02, /* 12 */
+	0x09, /* 13 */
+	0x01, /* 14 */
+	0x08, /* 15 */
+	0x00, /* 16 */
+static int astspiflash_configure_clock(int bank, unsigned int clock)
+	uint32_t reg;
+	uint32_t cpu_clock;
+	uint32_t clock_divisor;
+#if defined(CONFIG_SOC_AST2500) || defined(CONFIG_SOC_AST2530)
+	uint32_t cpu_ratio;
+	uint32_t axi_ratio;
+#endif
+	/* according to AST spec, clock of SPI controller can not exceed 50M Hz */
+	if (clock > (50 * 1000000))
+		clock = 50 * 1000000;
+	/* read CPU clock rate and CPU/AHB ratio from SCU */
+	reg = ioread32((void __iomem *)SCU_HW_STRAPPING_REG);
+	#if defined(CONFIG_SOC_AST2500) || defined(CONFIG_SOC_AST2530)
+	cpu_ratio = 2;
+	switch ((reg & 0x00000E00) >> 9) {
+	case 0x01:
+		axi_ratio = 2;
+		break;
+	case 0x02:
+		axi_ratio = 3;
+		break;
+	case 0x03:
+		axi_ratio = 4;
+		break;
+	case 0x04:
+		axi_ratio = 5;
+		break;
+	case 0x05:
+		axi_ratio = 6;
+		break;
+	case 0x06:
+		axi_ratio = 7;
+		break;
+	case 0x07:
+		axi_ratio = 8;
+		break;
+	default:
+		axi_ratio = 2;
+		break;
+	cpu_clock = 792 * 1000000;//Default H-PLL value
+	cpu_clock = cpu_clock / cpu_ratio / axi_ratio;
+	#else
+	switch ((reg & 0x00000300) >> 8) {
+	case 0x00:
+		cpu_clock = 384 * 1000000;
+		break;
+	case 0x01:
+		cpu_clock = 360 * 1000000;
+		break;
+	case 0x02:
+		cpu_clock = 336 * 1000000;
+		break;
+	case 0x03:
+		cpu_clock = 408 * 1000000;
+		break;
+	default:
+	switch ((reg & 0x00000C00) >> 10) {
+	case 0x01:
+		cpu_clock /= 2;
+		break;
+	case 0x02:
+		cpu_clock /= 4;
+		break;
+	case 0x03:
+		cpu_clock /= 3;
+		break;
+	#endif
+	clock_divisor = 1;
+	while ((cpu_clock / clock_divisor) > clock) {
+		clock_divisor ++;
+		if (clock_divisor == 16)
+			break;
+	reg &= ~AST_SPI_CLOCK_MASK;
+	reg |= (clock_selection_table[clock_divisor - 1] << AST_SPI_CLOCK_SHIFT);
+	return 0;
+struct spi_ctrl_driver astspi_driver = {
+	.name = "astspiflash",
+	.module = THIS_MODULE,
+	.max_read = (64 * 1024 * 1024), /* 32 MB */
+	#ifdef CONFIG_FLASH_OPERATION_MODE_MASK
+	.operation_mode_mask = CONFIG_FLASH_OPERATION_MODE_MASK,
+	#else
+	.operation_mode_mask = 0x00010003, //Default
+	#endif
+	.fast_read = 1,
+	.fast_write = 0,
+	.spi_transfer = astspiflash_transfer,
+	.spi_burst_read = astspiflash_transfer,
+	.spi_configure_clock = astspiflash_configure_clock,
+static int astspi_init(void)
+	sema_init(&astspi_driver.lock, 1);
+	register_spi_ctrl_driver(&astspi_driver);
+	g_fast_read = &astspi_driver.fast_read;
+	reset_flash(0);	// CE0
+	reset_flash(1);	// CE1
+	reset_flash(2);	// CE2
+	#if !defined(CONFIG_SOC_AST2500) && !defined(CONFIG_SOC_AST2530)
+	reset_flash(3);	// CE3
+	#endif
+	return 0;
+static void astspi_exit(void)
+	unregister_spi_ctrl_driver(&astspi_driver);
+module_init(astspi_init);
+module_exit(astspi_exit);
+MODULE_LICENSE("GPL");
+MODULE_AUTHOR("American Megatrends Inc");
+MODULE_DESCRIPTION("AST SOC SPI flash controller driver");
diff --git a/drivers/mtd/spichips/atmel.c b/drivers/mtd/spichips/atmel.c
index 0000000..a7cfddb
--- /dev/null
+++ b/drivers/mtd/spichips/atmel.c
@@ -0,0 +1,133 @@
+ * Copyright (C) 2007 American Megatrends Inc
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
+#ifdef __UBOOT__
+#include <common.h>
+#endif
+#ifdef	CFG_FLASH_SPI_DRIVER
+/* Name, ID1, ID2 , Size, Clock, Erase regions, address mode,{ Offset, Erase Size, Erase Block Count } */
+/* address mode:  0x00 -3 byte address
+			 	0x01 - 4 byte address
+			 	0x02 - Low byte: 3 byte address, High byte: 4 byte address*/
+static struct spi_flash_info atmel_data [] =
+	/* Atmel 26F 64K Sectors */
+	{ "Atmel at26f004"   , 0x1F, 0x0004, 0x00010001, 0x100000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	/* Atmel 25DF 64K Sectors */
+	{ "Atmel at25df041a" , 0x1F, 0x0144, 0x00010001, 0x100000 , 70 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	/* Atmel 26DF 64K Sectors */
+	{ "Atmel at26df081a" , 0x1F, 0x0145, 0x00010001, 0x100000 , 70 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "Atmel at26df161a" , 0x1F, 0x0146, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Atmel at26df161"  , 0x1F, 0x0046, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Atmel at26df321"  , 0x1F, 0x0047, 0x00010001, 0x400000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "Atmel at25df321"  , 0x1F, 0x0147, 0x00010001, 0x400000 , 85 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+static
+int
+atmel_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	unsigned char status;
+	retval =  spi_generic_probe(bank, ctrl_drv,chip_info,"atmel",atmel_data,ARRAY_SIZE(atmel_data));
+	if (retval == -1)
+		return retval;
+	if (spi_generic_read_status(bank,ctrl_drv,&status) < 0)
+		printk("atmel: Read SR Failed.Cannot Unprotect all sectors\n");
+		return retval;
+	/* If SRPL = 1 (Bit 7)and WP/ = 0 (Bit 4), then it is hardware locked */
+	if ((status & 0x80) && (!(status & 0x10)))
+		printk("atmel: Hardware Locked\n");
+		return retval;
+	/* Check if already unprotected */
+	if ((status & 0xC) == 0)
+		return retval;
+	/* if SRPL is set, we have to disable SRPL before unprotect */
+	if (status & 0x80)
+		if (spi_generic_write_status(bank,ctrl_drv,status& 0x7F) < 0)
+			printk("atmel: Clearing SRPL failed .Cannot Unprotect all sectors\n");
+			return retval;
+	/* Unprotect all sectors */
+	if (spi_generic_write_status(bank,ctrl_drv,0x0) < 0)
+		printk("atmel: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver atmel_driver =
+	.name 		= "atmel",
+	.probe	 	= atmel_probe,
+	.erase_sector 	= spi_generic_erase,
+	.read_bytes	= spi_generic_read,
+	.write_bytes	= spi_generic_write,
+	/* Atmel supports individual protect and unprotect of sectors */
+	/* if needed implement the functions and add here */
+int
+atmel_init(void)
+	sema_init(&atmel_driver.lock, 1);
+#ifdef __UBOOT__	/* MIPS */
+	atmel_driver.probe	 		= atmel_probe;
+	atmel_driver.erase_sector 	= spi_generic_erase;
+	atmel_driver.read_bytes		= spi_generic_read;
+	atmel_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&atmel_driver);
+	return 0;
+void
+atmel_exit(void)
+	unregister_spi_chip_driver(&atmel_driver);
+	return;
+module_init(atmel_init);
+module_exit(atmel_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Atmel flash chips");
+#endif
diff --git a/drivers/mtd/spichips/default.c b/drivers/mtd/spichips/default.c
index 0000000..93f31d7
--- /dev/null
+++ b/drivers/mtd/spichips/default.c
@@ -0,0 +1,106 @@
+#ifdef __UBOOT__
+#endif
+#ifndef CONFIG_DEFAULT_SPI_NAME
+#define CONFIG_DEFAULT_SPI_NAME "Unknown SPI Device"
+#endif
+#ifndef CONFIG_DEFAULT_SPI_SIZE
+#define CONFIG_DEFAULT_SPI_SIZE 0
+#endif
+#ifndef CONFIG_DEFAULT_SPI_CLOCK
+#define CONFIG_DEFAULT_SPI_CLOCK (25 * 1000000)
+#endif
+#ifndef CONFIG_DEFAULT_SPI_ERASE_SIZE
+#define CONFIG_DEFAULT_SPI_ERASE_SIZE	(64 *1024)
+#endif
+/* This driver is called at end when all probe failed. Some chips don't support read id
+   commands and user can provide the information here */
+static struct spi_flash_info default_data [] =
+	{ CONFIG_DEFAULT_SPI_NAME , 0xFF, 0x0FFFF, 0x00010001, CONFIG_DEFAULT_SPI_SIZE , CONFIG_DEFAULT_SPI_CLOCK, 1, 0x00,
+			{{ 0, CONFIG_DEFAULT_SPI_ERASE_SIZE, CONFIG_DEFAULT_SPI_SIZE/CONFIG_DEFAULT_SPI_ERASE_SIZE },} },
+static
+int
+default_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	memcpy(chip_info,&default_data[0],sizeof(struct spi_flash_info));
+		printk("%s: Unable to Unprotect all sectors\n",CONFIG_DEFAULT_SPI_NAME);
+	return 0;
+struct spi_chip_driver default_driver =
+	.name 		= "default",
+	.probe	 	= default_probe,
+int
+default_init(void)
+	sema_init(&default_driver.lock, 1);
+	default_driver.probe	 		= default_probe;
+	default_driver.erase_sector 	= spi_generic_erase;
+	default_driver.read_bytes		= spi_generic_read;
+	default_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&default_driver);
+	return 0;
+void
+default_exit(void)
+	unregister_spi_chip_driver(&default_driver);
+	return;
+module_init(default_init);
+module_exit(default_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Default flash chips");
+#endif
diff --git a/drivers/mtd/spichips/generic.c b/drivers/mtd/spichips/generic.c
index 0000000..50a70f6
--- /dev/null
+++ b/drivers/mtd/spichips/generic.c
@@ -0,0 +1,1052 @@
+ * Copyright (C) 2007-2013 American Megatrends Inc
+#ifdef __UBOOT__
+#endif
+/* Flash opcodes. */
+#define	OPCODE_WREN		0x06	/* Write enable */
+#define	OPCODE_WRDI		0x04	/* Write disable*/
+#define	OPCODE_RDID		0x9F	/* Read JEDEC ID */
+#define	OPCODE_RDSR		0x05	/* Read status register */
+#define OPCODE_WRSR		0x01	/* Write status register */
+#define	OPCODE_READ		0x03	/* Read data bytes */
+#define	OPCODE_FAST_READ	0x0B	/* Read Fast read */
+#define	OPCODE_DREAD	0x3B	/* Dual Read Mode */
+#define	OPCODE_2READ	0xBB	/* 2 x I/O Read Mode */
+#define	OPCODE_PP		0x02	/* Page program */
+#define	OPCODE_SE		0xD8	/* Sector erase */
+#define OPCODE_DP		0xB9	/* Deep Power Down */
+#define	OPCODE_RES		0xAB	/* Read Electronic Signature */
+/* Status Register bits. */
+#define	SR_WIP			0x01	/* Write in progress */
+#define	SR_WEL			0x02	/* Write enable latch */
+#define	SR_BP0			0x04	/* Block protect 0 */
+#define	SR_BP1			0x08	/* Block protect 1 */
+#define	SR_BP2			0x10	/* Block protect 2 */
+#define	SR_SRWD			0x80	/* SR write protect */
+#define PROGRAM_PAGE_SIZE	256	/* Max Program Size */
+#define ADDR_16MB 		0x1000000
+#define CMD_MX25XX_EN4B		0xb7	/* Enter 4-byte address mode */
+#define CMD_MX25XX_EX4B		0xe9	/* Exit 4-byte address mode */
+#define ADDRESS_3BYTE	0x00
+#define ADDRESS_4BYTE	0x01
+#define ADDRESS_LO3_HI4_BYTE 0x02
+#define ADDRESS_DIE_LO3_HI4_BYTE 0x06
+#define ADDR_32MB 		0x2000000
+#define CMD_WX25XX_CS		0xc2	/* Die select */
+extern unsigned long ractrends_spiflash_flash_id[MAX_SPI_BANKS];
+static int wait_till_ready(int bank,struct spi_ctrl_driver *ctrl_drv);
+static
+int inline
+spi_error(int retval)
+	printk("SPI Chip %s (%d) : Error (%d)\n",__FILE__,__LINE__,retval);
+	return retval;
+static int
+spi_generic_read_flag_status(int bank, struct spi_ctrl_driver *ctrl_drv,unsigned char *status)
+	int  retval;
+	u8 code = 0x70;
+	/* Issue Controller Transfer Routine */
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,status, 1);
+	if (retval < 0)
+		return spi_error(retval);
+	return 0;
+int
+spi_generic_read_status(int bank, struct spi_ctrl_driver *ctrl_drv,unsigned char *status)
+	int  retval;
+	u8 code = OPCODE_RDSR;
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_status(int bank,struct spi_ctrl_driver *ctrl_drv, unsigned char status)
+	int retval;
+	u8 code = OPCODE_WRSR;
+	/* Send write enable */
+	spi_generic_write_enable(bank,ctrl_drv);
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_WRITE,&status, 1);
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_enable(int bank,struct spi_ctrl_driver *ctrl_drv)
+	u8 code = OPCODE_WREN;
+	int retval;
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_NONE, NULL, 0);
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_disable(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = OPCODE_WRDI;
+	int retval;
+	if (retval < 0)
+	return 0;
+int spi_generic_select_die(int bank, u8 die_num, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	u8 command[2];
+	command[0] = CMD_WX25XX_CS;
+	command[1] = die_num;
+	/* Wait until finished previous command. */
+	if (wait_till_ready(bank,ctrl_drv))
+		return -1;
+	retval = ctrl_drv->spi_transfer(bank, command, 2, SPI_NONE, NULL, 0);
+	if (retval < 0)
+		printk ("Could not select die.\n");
+	return 0;
+int enter_4byte_addr_mode(int bank, struct spi_ctrl_driver *ctrl_drv)
+	//enable 32 MB Address mode
+	u8 code = CMD_MX25XX_EN4B;
+	int retval;
+	//printf("<ENTER> 4 BYTE\n");
+		return -1;
+	if ((ractrends_spiflash_flash_id[bank] == 0x002019BA) || (ractrends_spiflash_flash_id[bank] == 0x002020BA) || (ractrends_spiflash_flash_id[bank] == 0x002021BA))
+	retval = ctrl_drv->spi_transfer(bank, &code, 1, SPI_NONE, NULL, 0);
+	if ((ractrends_spiflash_flash_id[bank] == 0x002019BA) || (ractrends_spiflash_flash_id[bank] == 0x002021BA))
+		spi_generic_write_disable(bank,ctrl_drv);
+	if (retval < 0)
+		printk ("Could not Enter into 4-byte address mode\n");
+	return 0;
+int exit_4byte_addr_mode(int bank, struct spi_ctrl_driver *ctrl_drv)
+	//Disable 32 MB Address mode
+	u8 code = CMD_MX25XX_EX4B;
+	int retval;
+	//printf("<EXIT> 4 BYTE\n");
+		return -1;
+	if (retval < 0)
+		printk ("Could not Exit from 4-byte address mode\n");
+	return 0;
+int spi_generic_extended_address(int bank, SPI_DIR dir, u8 addr, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	if (dir == SPI_READ)
+		u8 code = 0xC8;
+		u8 reg_data;
+		ctrl_drv->spi_transfer(bank, &code, 1, SPI_READ, &reg_data, 1);
+		retval = (int) reg_data;
+	else if (dir == SPI_WRITE)
+		u8 command[2];
+		command[0] = 0xC5;
+		command[1] = addr;
+		spi_generic_write_enable(bank, ctrl_drv);
+		ctrl_drv->spi_transfer(bank, command, 2, SPI_NONE, NULL, 0);
+		spi_generic_write_disable(bank, ctrl_drv);
+		retval = command[1];
+	else // SPI_NONE
+		retval = 0;
+	return retval;
+// the function just for WINBOND W25Q256 only, always revise the extended address to the defalut
+int w25q256_force_extended_address(int bank, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	u8 code;
+	u8 reg_data;
+	u8 command[5];
+	code = 0xC8; // "Read Extended Address Register"
+	retval = ctrl_drv->spi_transfer(bank, &code, 1, SPI_READ, &reg_data, 1);
+	if (reg_data == 0x01)
+		command[0] = 0xC5; // "Write Extended Address Register" with the force address 0x00
+		command[1] = command[2] = command[3] = command[4] = 0x00;
+		retval = ctrl_drv->spi_transfer(bank, command, 5, SPI_NONE, NULL, 0);
+	return 0;
+/* Define max times to check status register before we give up. */
+#define	MAX_READY_WAIT_COUNT	4000000
+static int
+wait_till_ready(int bank,struct spi_ctrl_driver *ctrl_drv)
+	unsigned long  count;
+	unsigned char sr;
+	for (count = 0; count < MAX_READY_WAIT_COUNT; count++)
+		if (spi_generic_read_status(bank,ctrl_drv,&sr) < 0)
+			printk("Error reading SPI Status Register\n");
+			break;
+		else
+			if (!(sr & SR_WIP))
+				return 0;
+	printk("spi_generic: Waiting for Ready Failed\n");
+	return 1;
+static int
+require_read_flag_status(int bank,struct spi_ctrl_driver *ctrl_drv)
+	unsigned char sr;
+		if (spi_generic_read_flag_status(bank,ctrl_drv,&sr) < 0)
+			break;
+		else
+			if (sr & SR_SRWD)
+				return 0;
+	printk("spi_generic %s() : Waiting for Ready Failed\n", __func__);
+	return 1;
+int
+spi_generic_erase(struct map_info *map, unsigned long sect_addr)
+	struct spi_flash_private *priv=map->fldrv_priv;
+	int bank = map->map_priv_1;
+	struct spi_ctrl_driver *ctrl_drv = priv->ctrl_drv;
+	int retval;
+	unsigned char command[5];
+	int cmd_size;
+	u8 address32 = priv->address32;
+	//unsigned long flash_size = priv->size;
+	u8 had_switch_die = 0;
+    u8 pwr_up_mode = 0;
+	down(&priv->chip_drv->lock);
+		up(&priv->chip_drv->lock);
+		return -1;
+	if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) {
+		if(sect_addr>=ADDR_32MB){
+			spi_generic_select_die( bank, 1,ctrl_drv);
+			had_switch_die = 1;
+			sect_addr-=ADDR_32MB;
+    if (ractrends_spiflash_flash_id[bank] == 0x00EF1940)
+        u8 reg_data;
+        command[0] = 0x15; /* Read Status Register S23 ~ S16 */
+        cmd_size = 1;
+        retval = ctrl_drv->spi_transfer(bank,command, cmd_size ,SPI_READ, &reg_data, 1);
+        pwr_up_mode = (reg_data & 0x2)>>1; /* S17(ADP) field */
+	/* Logic for 4 byte address mode Enter */
+	if ( ((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE )||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+		retval = enter_4byte_addr_mode(bank, ctrl_drv);
+		if (retval < 0)
+			printk ("Unable to enter 4 byte address mode\n");
+			if(had_switch_die == 1)
+				spi_generic_select_die( bank, 0,ctrl_drv);
+	if (ractrends_spiflash_flash_id[bank]  == 0x00EF1940) w25q256_force_extended_address(bank, ctrl_drv);
+	if ((ractrends_spiflash_flash_id[bank]  == 0x002020BA) || (ractrends_spiflash_flash_id[bank]  == 0x002021BA) || (ractrends_spiflash_flash_id[bank]  == 0x00C21A20))
+		spi_generic_extended_address(bank, SPI_WRITE, (sect_addr & 0xFF000000) >> 24, ctrl_drv);
+	if ( (((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode)
+		/* Set up command buffer. */
+		command[0] = OPCODE_SE;
+		if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0xDC; // ERASE command in 4byte mode [spansion only]
+		if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0xDC; // ERASE command in 4byte mode
+		command[1] = sect_addr >> 24;
+		command[2] = sect_addr >> 16;
+		command[3] = sect_addr >> 8;
+		command[4] = sect_addr;
+		cmd_size = 5;
+	else {
+		command[1] = sect_addr >> 16;
+		command[2] = sect_addr >> 8;
+		command[3] = sect_addr;
+		cmd_size = 4;
+	spi_generic_write_enable(bank,ctrl_drv); /* Send write enable */
+	retval = ctrl_drv->spi_transfer(bank,command, cmd_size ,SPI_NONE, NULL, 0);
+	spi_generic_write_disable(bank,ctrl_drv); /* Send write disable */
+	if (ractrends_spiflash_flash_id[bank] == 0x002020BA || ractrends_spiflash_flash_id[bank] == 0x002021BA)
+		/* requires the read flag status with at latest one byte. */
+		if (require_read_flag_status(bank,ctrl_drv))
+			return -1;
+	if (retval < 0)
+		//if 4 byte mode exit
+		if ( ((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+			retval = exit_4byte_addr_mode(bank, ctrl_drv);
+			if (retval < 0)
+				printk ("Unable to exit 4 byte address mode\n");
+			spi_generic_extended_address(bank, SPI_WRITE, 0x00, ctrl_drv);
+		if (retval < 0)
+	return retval;
+int
+spi_generic_read(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buff)
+	int retval = 0;
+	size_t transfer;
+	unsigned char command[6];
+	int cmd_size;
+	int  (*readfn)(int bank,unsigned char *,int , SPI_DIR, unsigned char *, unsigned long); //unsigned long);
+	int end_addr = (addr+bytes-1);
+	/* Some time zero bytes length are sent */
+	if (bytes==0)
+		return 0;
+        u8 reg_data;
+        cmd_size = 1;
+		if (addr < ADDR_32MB && end_addr >= ADDR_32MB)
+			int ErrorCode;
+			transfer = (ADDR_32MB - addr);
+			ErrorCode = spi_generic_read(map, addr, transfer, buff);
+			if (ErrorCode != 0) return ErrorCode;
+			 //fix address
+			bytes-=transfer;
+			addr+=transfer;
+			buff+=transfer;
+			end_addr = (addr+bytes-1);
+			if (bytes==0) return 0;
+		return -1;
+	if (address32 == ADDRESS_DIE_LO3_HI4_BYTE){
+		if(addr >= ADDR_32MB){
+			addr-=ADDR_32MB;
+	if (ctrl_drv->spi_burst_read)
+		readfn = ctrl_drv->spi_burst_read;
+	else
+		readfn = ctrl_drv->spi_transfer;
+	transfer=bytes;
+	if ( (( end_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE )||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+		//printk ("Trying to enter 4 byte mode\n");
+		if (retval < 0)
+		spi_generic_extended_address(bank, SPI_WRITE, (addr & 0xFF000000) >> 24, ctrl_drv);
+	while (bytes)
+			transfer=bytes;
+		else
+			transfer=ctrl_drv->max_read;
+			if (transfer > bytes)
+				transfer = bytes;
+		if (!ctrl_drv->fast_read)
+			if ( ((( end_addr  >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode )
+				/* Set up command buffer. */	/* Normal Read */
+				command[0] = OPCODE_READ;
+				if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0x13; // READ command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x13; // READ command in 4byte mode
+				command[1] = addr >> 24;
+				command[2] = addr >> 16;
+				command[3] = addr >> 8;
+				command[4] = addr;
+				cmd_size = 5;
+			else {
+				command[1] = addr >> 16;
+				command[2] = addr >> 8;
+				command[3] = addr;
+				cmd_size = 4;
+			retval = (*readfn)(bank,command, cmd_size ,SPI_READ, buff, (unsigned long)transfer);
+		else if (ctrl_drv->fast_read == 1) // Need to check Fast Read in 4 byte address mode
+				/* Set up command buffer. */   /* Fast Read */
+				command[0] = OPCODE_FAST_READ;
+				if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0x0C; // FAST_READ command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x0C; // FAST_READ command in 4byte mode
+				command[5] = 0;			/* dummy data */
+				cmd_size = 6;
+			else
+				command[4] = 0;			/* dummy data */
+				cmd_size = 5;
+		else if (ctrl_drv->fast_read == 2) // Need to check Dual Read in 4 byte address mode
+				/* Set up command buffer. */   /* Dual Read */
+				command[0] = OPCODE_DREAD;
+				cmd_size = 6;
+			else
+				cmd_size = 5;
+		else if (ctrl_drv->fast_read == 3) // Need to check 2xI/O Read in 4 byte address mode
+				/* Set up command buffer. */   /* 2xI/O Read */
+				command[0] = OPCODE_2READ;
+				cmd_size = 6;
+			else
+				cmd_size = 5;
+		if (retval < 0)
+			//if 4 byte mode, exit
+			if ( (( end_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+				if (retval < 0)
+		bytes-=transfer;
+		addr+=transfer;
+		buff+=transfer;
+		//printk ("Trying to exit 4 byte mode\n");
+		if (retval < 0)
+	return 0;
+int
+spi_generic_write(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buff)
+	int retval;
+	size_t transfer;
+	int cmd_size = 0;
+	if (bytes==0)
+		return 0;
+        u8 reg_data;
+        cmd_size = 1;
+			int ErrorCode;
+			ErrorCode = spi_generic_write(map, addr, transfer, buff);
+			 //fix address
+			bytes-=transfer;
+			addr+=transfer;
+			buff+=transfer;
+			addr-=ADDR_32MB;
+		if (retval < 0)
+	while (bytes)
+			return -1;
+		transfer = PROGRAM_PAGE_SIZE;
+		if (bytes <  transfer)
+			transfer = bytes;
+		if (!ctrl_drv->fast_write)
+			if ( (((end_addr >= ADDR_16MB) && (address32 == ADDRESS_LO3_HI4_BYTE)) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode)
+				command[0] = OPCODE_PP;
+				if (ractrends_spiflash_flash_id[bank]  == 0x00011902) command[0] = 0x12; // PROGRAM command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x12; // PROGRAM command in 4byte mode
+				cmd_size = 5;
+			else {
+				cmd_size = 4;
+		retval = ctrl_drv->spi_transfer(bank,command,cmd_size ,SPI_WRITE,
+						(unsigned char *)buff, transfer);
+				return -1;
+		if (retval < 0)
+				if (retval < 0)
+		addr+=(transfer-retval);
+		buff+=(transfer-retval);
+		bytes-=(transfer-retval);
+		if (retval < 0)
+	return 0;
+extern int spi_verbose;
+int
+spi_generic_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info,
+			char *spi_name,struct spi_flash_info *spi_list, int spi_list_len)
+	int  retval;
+	u32 val;
+	int i;
+	u16 opread;
+	u16 opwrite;
+	u8 code = OPCODE_RDID;
+	//int address_mode = 0;
+	if (spi_verbose == 2)
+		printk("SPI: probing for %s devices ...\n",spi_name);
+	retval =spi_generic_write_enable(bank,ctrl_drv);
+	if (retval < 0)
+	 	return -1;
+	val = 0;
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,(unsigned char *)&val, 3);
+	val &= 0x00FFFFFF;
+	if (retval < 0)
+		spi_error(retval);
+		return -1;
+	/* Send write disable */
+	retval = spi_generic_write_disable(bank,ctrl_drv);
+	if (retval < 0)
+		return -1;
+	/* Match the ID against the table entries */
+	for (i = 0; i < spi_list_len; i++)
+		if ((spi_list[i].mfr_id == ((val)& 0xFF)) && (spi_list[i].dev_id == ((val >> 8)& 0xFFFF)))
+			/* Check Operation Mode */
+			//for Read Operation
+			opread = (spi_list[i].operationmode & 0xFFFF);
+			opread &= ctrl_drv->operation_mode_mask;
+			if (opread > 0x7)
+				ctrl_drv->fast_read = 3;
+			else if ((0x3 < opread) && (opread  <= 0x7))
+				ctrl_drv->fast_read = 2;
+			else if ((0x1 < opread) && (opread <= 0x3))
+				ctrl_drv->fast_read = 1;
+			else if (opread <= 0x1)
+				ctrl_drv->fast_read = 0;
+			//for Write Operation
+			opwrite = (spi_list[i].operationmode >> 16);
+			opwrite &= (ctrl_drv->operation_mode_mask >> 16);
+			if (opwrite <= 0x1)
+				ctrl_drv->fast_write = 0;
+		  break;
+	if (i == spi_list_len)
+//		if (spi_verbose == 2)
+//			printk("%s : Unrecognized ID (0x%x) got \n",spi_name,val);
+		return -1;
+	memcpy(chip_info,&spi_list[i],sizeof(struct spi_flash_info));
+	if (spi_verbose > 0)
+		printk(KERN_INFO"Found SPI Chip %s \n",spi_list[i].name);
+	return 0;
+EXPORT_SYMBOL(spi_generic_probe);
+EXPORT_SYMBOL(spi_generic_erase);
+EXPORT_SYMBOL(spi_generic_read);
+EXPORT_SYMBOL(spi_generic_write);
+EXPORT_SYMBOL(spi_generic_write_disable);
+EXPORT_SYMBOL(spi_generic_write_enable);
+EXPORT_SYMBOL(spi_generic_read_status);
+EXPORT_SYMBOL(spi_generic_write_status);
+MODULE_DESCRIPTION("MTD SPI driver for Generic SPI flash chips");
+#endif
diff --git a/drivers/mtd/spichips/intels33.c b/drivers/mtd/spichips/intels33.c
index 0000000..6900319
--- /dev/null
+++ b/drivers/mtd/spichips/intels33.c
@@ -0,0 +1,96 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info s33_data [] =
+	/* Intel S33  64 K Sectors */
+	{ "Intel S33 16Mb"  , 0x89, 0x1189, 0x00010001, 0x200000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Intel S33 32Mb"  , 0x89, 0x1289, 0x00010001, 0x400000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "Intel S33 64Mb"  , 0x89, 0x1389, 0x00010001, 0x800000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+static
+int
+s33_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"intel s33",
+						s33_data,ARRAY_SIZE(s33_data));
+	if (retval == -1)
+		return retval;
+	/* UnProctect all sectors */
+ 	/* SRWD=0 (Bit 7)  BP0,BP1,BP2 = 0 (Bit 2,3,4) */
+		printk("intel s33: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver s33_driver =
+	.name 		= "intel s33",
+	.probe	 	= s33_probe,
+int
+s33_init(void)
+	sema_init(&s33_driver.lock, 1);
+	s33_driver.probe	 		= s33_probe;
+	s33_driver.erase_sector 	= spi_generic_erase;
+	s33_driver.read_bytes		= spi_generic_read;
+	s33_driver.write_bytes		= spi_generic_write;
+#endif
+	register_spi_chip_driver(&s33_driver);
+	return 0;
+void
+s33_exit(void)
+	unregister_spi_chip_driver(&s33_driver);
+	return;
+module_init(s33_init);
+module_exit(s33_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Intel S33 flash chips");
+#endif
diff --git a/drivers/mtd/spichips/m25pxx.c b/drivers/mtd/spichips/m25pxx.c
index 0000000..448fe06
--- /dev/null
+++ b/drivers/mtd/spichips/m25pxx.c
@@ -0,0 +1,121 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info m25pxx_data [] =
+	/* ST Micro 32K Sectors */
+	{ "ST Micro m25p05A" , 0x20, 0x1020, 0x00010001, 0x010000 , 50 * 1000000, 1, 0x00, {{ 0, 32  * 1024, 2   },} },
+	{ "ST Micro m25p10A" , 0x20, 0x1120, 0x00010001, 0x020000 , 50 * 1000000, 1, 0x00, {{ 0, 32  * 1024, 4   },} },
+	/* ST Micro 64 K Sectors */
+	{ "ST Micro m25p20"  , 0x20, 0x1220, 0x00010001, 0x040000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 4   },} },
+	{ "ST Micro m25p40"  , 0x20, 0x1320, 0x00010001, 0x080000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	{ "ST Micro m25p80"  , 0x20, 0x1420, 0x00010001, 0x100000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "ST Micro m25p16"  , 0x20, 0x1520, 0x00010001, 0x200000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "ST Micro m25p32"  , 0x20, 0x1620, 0x00010001, 0x400000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "ST Micro m25p64"  , 0x20, 0x1720, 0x00010001, 0x800000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "ST Micro m25px64"  , 0x20, 0x1771, 0x00010001, 0x800000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	/* ST Micro 256K Sectors */
+	{ "ST Micro m25p128" , 0x20, 0x1820, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 256 * 1024, 64  },} },
+	/* ST Micro 64 K Sectors, 25MHz speed */
+	{ "ST Micro m45p20"  , 0x20, 0x1240, 0x00010001, 0x040000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 4   },} },
+	{ "ST Micro m45p40"  , 0x20, 0x1340, 0x00010001, 0x080000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	{ "ST Micro m45p80"  , 0x20, 0x1440, 0x00010001, 0x100000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "ST Micro m45p16"  , 0x20, 0x1540, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "ST Micro m45p32"  , 0x20, 0x1640, 0x00010001, 0x400000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "ST Micro m45p64"  , 0x20, 0x1740, 0x00010001, 0x800000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+static
+int
+m25pxx_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"m25pxx",
+						m25pxx_data,ARRAY_SIZE(m25pxx_data));
+	if (retval == -1)
+		return retval;
+		printk("m25pxx: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver m25pxx_driver =
+	.name 		= "m25pxx",
+	.probe	 	= m25pxx_probe,
+int
+m25pxx_init(void)
+	sema_init(&m25pxx_driver.lock, 1);
+	m25pxx_driver.probe	 		= m25pxx_probe;
+	m25pxx_driver.erase_sector 	= spi_generic_erase;
+	m25pxx_driver.read_bytes	= spi_generic_read;
+	m25pxx_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&m25pxx_driver);
+	return 0;
+void
+m25pxx_exit(void)
+	unregister_spi_chip_driver(&m25pxx_driver);
+	return;
+module_init(m25pxx_init);
+module_exit(m25pxx_exit);
+MODULE_DESCRIPTION("MTD SPI driver for ST M25Pxx flash chips");
+#endif
diff --git a/drivers/mtd/spichips/macronix.c b/drivers/mtd/spichips/macronix.c
index 0000000..176d101
--- /dev/null
+++ b/drivers/mtd/spichips/macronix.c
@@ -0,0 +1,208 @@
+#ifdef __UBOOT__
+#endif
+#define CMD_MX25XX_RDSCUR		0x2B	/* Read security register */
+#define CMD_MX25XX_RDCR			0x15	/* Read configuration register */
+/* Security register */
+#define SCUR_BIT2			0x04
+/* Configuration register */
+#define CR_BIT5				0x20
+#define MX25L25x35E_MFR_ID 0xC2
+#define MX25L25x35E_DEV_ID 0x1920
+static struct spi_flash_info macronix_data [] =
+	/* Macronix 64 K Sectors */
+	{ "Macronix MX25L1605D" , 0xC2, 0x1520, 0x0001000B, 0x200000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32 },} },
+	{ "Macronix MX25L3205D" , 0xC2, 0x1620, 0x0001000B, 0x400000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64 },} },
+	{ "Macronix MX25L6405D" , 0xC2, 0x1720, 0x0001000B, 0x800000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Macronix MX25L12805D", 0xC2, 0x1820, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+   	{ "Macronix MX25L25635E", 0xC2, 0x1920, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+    	{ "Macronix MX25L25735E", 0xC2, 0x1920, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x01, {{ 0, 64  * 1024, 512 },} },
+    	{ "Macronix MX66L51235F", 0xC2, 0x1A20, 0x0001000F, 0x4000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 1024 },} },
+    	{ "EON EN25QH256",        0x1C, 0x1970, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+/* to dinstinguish between MX25L25635/MX25L25735 E and F type */
+static int read_security_register(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = CMD_MX25XX_RDSCUR;
+	int retval;
+	unsigned char scur_reg;
+	/* Issue Controller Transfer Routine*/
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,&scur_reg, 1);
+	if (retval < 0)
+		printk ("Could not read security register\n");
+		return -1;
+	/* 0x00 - 3 byte mode
+	   0x04 - 4 byte mode */
+	scur_reg &= SCUR_BIT2;
+	if(scur_reg == 0x04)
+		return ADDRESS_4BYTE;		// MX25L25735E
+	else
+		return ADDRESS_LO3_HI4_BYTE;	// MX25L25635E, MX25L25635F, MX25L25735F
+	return 0;
+/* to dinstinguish MX25L25635/MX25L25735 F type */
+static int read_configuration_register(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = CMD_MX25XX_RDCR;
+	int retval;
+	unsigned char conf_reg;
+	retval = ctrl_drv->spi_transfer(bank,&code,1,SPI_READ,&conf_reg,1);
+	if (retval < 0)
+		printk ("Could not read configuration register\n");
+		return -1;
+	if (conf_reg == 0xFF) conf_reg = 0x00; // invalid value (maybe unsupported the RDCR command)
+	   0x20 - 4 byte mode */
+	conf_reg &= CR_BIT5;
+	if(conf_reg == CR_BIT5)
+		return ADDRESS_4BYTE;		// MX25L25735F
+	else
+		return ADDRESS_LO3_HI4_BYTE;	// MX25L25635E or MX25L25635F
+	return 0;
+static
+int
+macronix_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	int address_mode = 0;
+	int i=0;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"macronix",
+						macronix_data,ARRAY_SIZE(macronix_data));
+	if (retval == -1)
+		return retval;
+	/* MX25L25635E, MX25L25735E, MX25L25635F, MX25L25735F - the same ID code */
+	if((chip_info->mfr_id == MX25L25x35E_MFR_ID) && (chip_info->dev_id == MX25L25x35E_DEV_ID))
+		address_mode = read_security_register(bank, ctrl_drv);
+		if (address_mode == ADDRESS_LO3_HI4_BYTE) address_mode = read_configuration_register(bank, ctrl_drv);
+		if (address_mode == -1)
+			return address_mode;
+		if(chip_info->address32 != address_mode)
+			memset(chip_info,0,sizeof(struct spi_flash_info));
+			for (i = 0; i < (ARRAY_SIZE(macronix_data)); i++)
+				if((macronix_data[i].mfr_id == MX25L25x35E_MFR_ID) && (macronix_data[i].dev_id == MX25L25x35E_DEV_ID))
+					if(macronix_data[i].address32 == address_mode)
+					   break;
+			memcpy(chip_info,&macronix_data[i],sizeof(struct spi_flash_info));
+		printk("macronix: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver macronix_driver =
+	.name 		= "macronix",
+	.probe	 	= macronix_probe,
+int
+macronix_init(void)
+	sema_init(&macronix_driver.lock, 1);
+	macronix_driver.probe	 		= macronix_probe;
+	macronix_driver.erase_sector 	= spi_generic_erase;
+	macronix_driver.read_bytes	= spi_generic_read;
+	macronix_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&macronix_driver);
+	return 0;
+void
+macronix_exit(void)
+	unregister_spi_chip_driver(&macronix_driver);
+	return;
+module_init(macronix_init);
+module_exit(macronix_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Macronix flash chips");
+#endif
diff --git a/drivers/mtd/spichips/micron.c b/drivers/mtd/spichips/micron.c
index 0000000..e9f44ab
--- /dev/null
+++ b/drivers/mtd/spichips/micron.c
@@ -0,0 +1,104 @@
+#ifdef __UBOOT__
+#endif
+/* Name, ID1, ID2 , Size, Clock, Erase regions, address mode, { Offset, Erase Size, Erase Block Count } */
+static struct spi_flash_info micron_data [] =
+	/* Micron 64 K Sectors */
+	{ "Micron/Numonyx N25Q00A"  , 0x20, 0x21BA, 0x00010001, 0x8000000  , 108 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 2048 },} },
+	{ "Micron/Numonyx N25Q512A"  , 0x20, 0x20BA, 0x00010001, 0x4000000 , 108 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 1024 },} },
+	{ "Micron/Numonyx N25Q256A"  , 0x20, 0x19BA, 0x00010001, 0x2000000 , 108 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+    { "Micron/Numonyx n25q128" , 0x20, 0x18BA, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+static
+int
+micron_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"micron",
+						micron_data,ARRAY_SIZE(micron_data));
+	if (retval == -1)
+		return retval;
+		printk("micron: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver micron_driver =
+	.name 		= "micron",
+	.probe	 	= micron_probe,
+int
+micron_init(void)
+	sema_init(&micron_driver.lock,1);
+	micron_driver.probe	 		= micron_probe;
+	micron_driver.erase_sector 	= spi_generic_erase;
+	micron_driver.read_bytes	= spi_generic_read;
+	micron_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&micron_driver);
+	return 0;
+void
+micron_exit(void)
+	unregister_spi_chip_driver(&micron_driver);
+	return;
+module_init(micron_init);
+module_exit(micron_exit);
+MODULE_DESCRIPTION("MTD SPI driver for micron flash chips");
+#endif
diff --git a/drivers/mtd/spichips/spansion.c b/drivers/mtd/spichips/spansion.c
index 0000000..33a7bca
--- /dev/null
+++ b/drivers/mtd/spichips/spansion.c
@@ -0,0 +1,103 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info spansion_data [] =
+	/* Spansion 64 K Sectors */
+	{ "Spansion S25FL064A"  , 0x01, 0x1602, 0x00010001, 0x800000  , 104 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Spansion S25FL128P"  , 0x01, 0x1820, 0x00010001, 0x1000000 , 104 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+	{ "Spansion S25FL256S"  , 0x01, 0x1902, 0x00010001, 0x2000000 , 104 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+static
+int
+spansion_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"spansion",
+						spansion_data,ARRAY_SIZE(spansion_data));
+	if (retval == -1)
+		return retval;
+		printk("spansion: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver spansion_driver =
+	.name 		= "spansion",
+	.probe	 	= spansion_probe,
+int
+spansion_init(void)
+	sema_init(&spansion_driver.lock, 1);
+	spansion_driver.probe	 		= spansion_probe;
+	spansion_driver.erase_sector 	= spi_generic_erase;
+	spansion_driver.read_bytes	= spi_generic_read;
+	spansion_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&spansion_driver);
+	return 0;
+void
+spansion_exit(void)
+	unregister_spi_chip_driver(&spansion_driver);
+	return;
+module_init(spansion_init);
+module_exit(spansion_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Spansion flash chips");
+#endif
diff --git a/drivers/mtd/spichips/spiaccess.c b/drivers/mtd/spichips/spiaccess.c
index 0000000..5412f72
--- /dev/null
+++ b/drivers/mtd/spichips/spiaccess.c
@@ -0,0 +1,433 @@
+int spi_verbose = 1;
+/*           Low level functions which finally talk to the chip driver              */
+static void inline
+chip_unlock_sector(struct map_info *map, unsigned long sect_addr,int unlock)
+	if (!priv->chip_drv->unlock_sector)
+		return;
+	(*priv->chip_drv->unlock_sector)(map,sect_addr,unlock);
+	return;
+static int inline
+chip_is_sector_locked(struct map_info *map, unsigned long sect_addr)
+	if (!priv->chip_drv->is_sector_locked)
+		return 0;
+	return (*priv->chip_drv->is_sector_locked)(map,sect_addr);
+static int inline
+chip_read_bytes(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buf)
+	if (!priv->chip_drv->read_bytes)
+		return -1;
+	return (*priv->chip_drv->read_bytes)(map,addr,bytes,buf);
+static int inline
+chip_write_bytes(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buf)
+	if (!priv->chip_drv->write_bytes)
+		return -1;
+	return (*priv->chip_drv->write_bytes)(map,addr,bytes,buf);
+static int inline
+chip_erase_sector(struct map_info *map, unsigned long sect_addr)
+	if (!priv->chip_drv->erase_sector)
+		return -1;
+	return (*priv->chip_drv->erase_sector)(map,sect_addr);
+void
+spi_flash_sync(struct mtd_info *mtd)
+	struct map_info *map = mtd->priv;
+	struct spi_flash_private *priv = map->fldrv_priv;
+	if (!priv->chip_drv->sync)
+		return;
+	(*priv->chip_drv->sync)(map);
+	return;
+int
+spi_flash_suspend(struct mtd_info *mtd)
+	if (!priv->chip_drv->suspend)
+		return -EINVAL;
+	return (*priv->chip_drv->suspend)(map);
+void
+spi_flash_resume(struct mtd_info *mtd)
+	if (!priv->chip_drv->resume)
+		return;
+	(*priv->chip_drv->resume)(map);
+	return;
+/*  Intermediate Functions which interfaces mtd functionss to chip driver fucntions */
+static int
+spi_flash_do_unlock(struct mtd_info *mtd, loff_t ofs, uint32_t len,
+			       int is_unlock)
+	struct map_info *map;
+	struct mtd_erase_region_info *merip;
+	int eraseoffset, erasesize, eraseblocks;
+	int i;
+	int retval = 0;
+	int lock_status;
+	map = mtd->priv;
+	/* Pass the whole chip through sector by sector and check for each
+	   sector if the sector and the given interval overlap */
+	for(i = 0; i < mtd->numeraseregions; i++)
+		merip = &mtd->eraseregions[i];
+		eraseoffset = merip->offset;
+		erasesize = merip->erasesize;
+		eraseblocks = merip->numblocks;
+		if (ofs > eraseoffset + erasesize)
+			continue;
+		while (eraseblocks > 0)
+			if (ofs < eraseoffset + erasesize && ofs + len > eraseoffset)
+				chip_unlock_sector(map, eraseoffset, is_unlock);
+				lock_status = chip_is_sector_locked(map, eraseoffset);
+				if (is_unlock && lock_status)
+					printk("Cannot unlock sector at address %x length %xx\n",
+					       eraseoffset, merip->erasesize);
+					retval = -1;
+				else if (!is_unlock && !lock_status)
+					printk("Cannot lock sector at address %x length %x\n",
+					retval = -1;
+			eraseoffset += erasesize;
+			eraseblocks --;
+	return retval;
+static int
+read_one_chip(struct map_info *map, struct flchip *chip,
+			       loff_t adr, size_t len, u_char *buf)
+	uint32_t	i;
+	size_t bytes;
+	chip->state = FL_READY;
+	bytes = SPI_READ_PAGE_SIZE;
+	i = 0;
+	while (len >= bytes)
+		if (0 != chip_read_bytes(map,adr,bytes,&buf [i]))
+			printk (KERN_ERR "spi_read failed in read_one_chip function\n");
+			return -1;
+		len -= bytes;
+		i   += bytes;
+		adr += bytes;
+	if (0 != len)
+		if (0 != chip_read_bytes(map, adr, len, &buf [i]))
+			return -1;
+	return 0;
+static int
+write_one_chip(struct map_info *map, struct flchip *chip,
+	                        loff_t addr, size_t len, const u_char * buf)
+	uint32_t page_size, page_offset;
+	uint32_t i;
+	chip->state = FL_WRITING;
+	/* what page do we start with? */
+	page_offset = addr % SPI_WRITE_PAGE_SIZE;
+	/* do all the bytes fit onto one page? */
+	if (page_offset + len <= SPI_WRITE_PAGE_SIZE)
+		if (0 != chip_write_bytes (map, addr, len, buf))
+			printk (KERN_ERR "spi writing in the spi_write_bytes function failed\n");
+			return -1;
+	else
+		/* the size of data remaining on the first page */
+		page_size = SPI_WRITE_PAGE_SIZE - page_offset;
+		if (0 != chip_write_bytes (map, addr, page_size, buf))
+			return -1;
+		/* write everything in PAGESIZE chunks */
+		for (i = page_size; i < len; i += page_size)
+			page_size = len - i;
+			if (page_size > SPI_WRITE_PAGE_SIZE)
+				page_size = SPI_WRITE_PAGE_SIZE;
+			if (0 != chip_write_bytes (map, (addr + i), page_size, (buf + i)))
+				return -1;
+	return 0;
+static  int
+erase_one_block(struct map_info *map, struct flchip *chip,ulong addr)
+	int	retval = 0;
+	chip->state = FL_ERASING;
+	retval = chip_erase_sector (map,addr);
+	return (retval);
+/*  		                       MTD Functions 					                */
+int
+spi_flash_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
+	return spi_flash_do_unlock(mtd, ofs, len, 1);
+int
+spi_flash_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
+	return spi_flash_do_unlock(mtd, ofs, len, 0);
+int
+spi_flash_read(struct mtd_info *mtd, loff_t from, size_t len,
+                                          size_t *retlen, u_char *buf)
+	struct spi_flash_private *private = map->fldrv_priv;
+	unsigned long ofs;
+	int ret = 0;
+	if ((from + len) > mtd->size)
+		printk(KERN_WARNING "%s: read request past end of device "
+		       "(0x%lx)\n", map->name, (unsigned long)from + len);
+		return -EINVAL;
+	ofs = from;
+	*retlen = 0;
+	ret = read_one_chip(map, &private->chips,ofs,len,buf);
+	if (0 == ret)
+		*retlen = len;
+	else
+		ret = -EINVAL;
+	return ret;
+int
+spi_flash_write(struct mtd_info *mtd, loff_t to , size_t len,
+                                       size_t *retlen, const u_char *buf)
+	if (to > mtd->size)
+		printk (KERN_ERR "write address > size of spi flash\n");
+		return -EINVAL;
+	if ((len + to) > mtd->size)
+		printk (KERN_ERR "write address + size > size of spi flash\n");
+		return -EINVAL;
+	*retlen = 0;
+	if (!len)
+		return 0;
+	if (0 == write_one_chip(map, &private->chips, to, len, buf))
+		*retlen = len;
+		return 0;
+	return -EINVAL;
+int
+spi_flash_erase(struct mtd_info *mtd, struct erase_info *instr)
+	unsigned long adr, len;
+	int ret = 0;
+	int i;
+	int first;
+	struct mtd_erase_region_info *regions = mtd->eraseregions;
+	if (instr->addr > mtd->size)
+		return -EINVAL;
+	if ((instr->len + instr->addr) > mtd->size)
+		return -EINVAL;
+	/* Check that both start and end of the requested erase are
+	 * aligned with the erasesize at the appropriate addresses.
+	i = 0;
+        /* Skip all erase regions which are ended before the start of
+           the requested erase. Actually, to save on the calculations,
+           we skip to the first erase region which starts after the
+           start of the requested erase, and then go back one.
+        while ((i < mtd->numeraseregions) &&
+	       (instr->addr >= regions[i].offset))
+               i++;
+        i--;
+	/* OK, now i is pointing at the erase region in which this
+	 * erase request starts. Check the start of the requested
+	 * erase range is aligned with the erase size which is in
+	 * effect here.
+	if (instr->addr & (regions[i].erasesize-1))
+		return -EINVAL;
+	/* Remember the erase region we start on. */
+	first = i;
+	/* Next, check that the end of the requested erase is aligned
+	 * with the erase region at that address.
+	       ((instr->addr + instr->len) >= regions[i].offset))
+                i++;
+	/* As before, drop back one to point at the region in which
+	 * the address actually falls.
+	i--;
+	if ((instr->addr + instr->len) & (regions[i].erasesize-1))
+                return -EINVAL;
+	adr = instr->addr;
+	len = instr->len;
+	i = first;
+	while (len)
+		ret = erase_one_block(map, &private->chips, adr);
+		if (ret)
+			return ret;
+		adr += regions[i].erasesize;
+		len -= regions[i].erasesize;
+	instr->state = MTD_ERASE_DONE;
+	mtd_erase_callback(instr);
+	return 0;
diff --git a/drivers/mtd/spichips/spiflash.h b/drivers/mtd/spichips/spiflash.h
index 0000000..2ec2eb4
--- /dev/null
+++ b/drivers/mtd/spichips/spiflash.h
@@ -0,0 +1,178 @@
+#ifndef __LINUX_SPI_H__
+#define __LINUX_SPI_H__
+#include <linux/kernel.h>
+#include <linux/module.h>
+#include <linux/types.h>
+#include <linux/sched.h>
+#include <linux/errno.h>
+#include <linux/init.h>
+#include <linux/slab.h>
+#include <linux/list.h>
+#include <linux/string.h>
+#include <linux/spinlock.h>
+#include <linux/device.h>
+#include <linux/interrupt.h>
+#include <linux/mtd/mtd.h>
+#include <linux/mtd/map.h>
+#include <linux/mtd/partitions.h>
+#include <linux/mtd/flashchip.h>
+#include <linux/dma-mapping.h>
+#include <linux/wait.h>
+#include <linux/delay.h>
+#include <asm/delay.h>
+#include <linux/semaphore.h>
+#define CFG_FLASH_SPI_DRIVER 1   /* Need for compile the modules */
+ The folllowing should match exactly with its uboot counterpart spiflash.h
+#define DEVICE_TYPE_X8	(8 / 8)
+#define DEVICE_TYPE_X16	(16 / 8)
+#define DEVICE_TYPE_X32	(32 / 8)
+#define SPI_READ_PAGE_SIZE (4*1024)			/* 4K page size */
+#define SPI_WRITE_PAGE_SIZE  256
+#define MAX_ERASE_REGIONS    4
+struct spi_flash_info
+	const char *name;
+	const __u8  mfr_id;
+	const __u16 dev_id;
+	const __u32 operationmode;
+	const uint64_t size;
+	const unsigned int max_clock;
+	const int numeraseregions;
+	const __u8 address32;
+	const struct mtd_erase_region_info regions[MAX_ERASE_REGIONS];
+typedef enum spidir
+	SPI_NONE = 0,
+	SPI_READ = 1,
+	SPI_WRITE = 2
+} SPI_DIR;
+	struct module *module;
+	struct semaphore lock;
+	char *name;
+	struct list_head list;
+	/* Supports operation mode */
+	int operation_mode_mask;
+	/* Supports fast read at higher frequency */
+	int  fast_read;
+	/* Supports fast write at higher frequency */
+	int  fast_write;
+	/* Max datasize to be used to read type functions in spi_transfer*/
+	int  max_read;
+	/* spi_transfer can be used for all type of spi access */
+	int  (*spi_transfer)(int bank,unsigned char *cmd,int cmdlen, SPI_DIR dir,
+				unsigned char *data, unsigned long datalen);
+	/* spi_burst_read is not NULL, if the ctrl supports read large data continuosly */
+	int  (*spi_burst_read)(int bank,unsigned char *cmd,int cmdlen, SPI_DIR dir,
+	int (*spi_configure_clock)(int bank, unsigned int clock);
+#ifdef __UBOOT__
+	int  (*spi_init)(void);
+#endif
+	char *name;
+	int (*probe)(int bank,struct spi_ctrl_driver *ctlr_drv, struct spi_flash_info *chip_info);
+	void (*unlock_sector)   (struct map_info *map, unsigned long sect_addr,int unlock);
+	int  (*is_sector_locked)(struct map_info *map, unsigned long sect_addr);
+	int  (*erase_sector)	(struct map_info *map, unsigned long sect_addr);
+	int  (*read_bytes)      (struct map_info *map, loff_t addr, size_t bytes, unsigned char *buf);
+	int  (*write_bytes)     (struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buf);
+	void (*sync)		(struct map_info *map);
+	int  (*suspend)		(struct map_info *map);
+	void (*resume)		(struct map_info *map);
+struct spi_flash_private
+	int device_type;
+	int interleave;
+	int numchips;
+	unsigned long chipshift;
+	__u8 address32;
+	struct flchip chips;
+	struct spi_chip_driver *chip_drv;
+	struct spi_ctrl_driver *ctrl_drv;
+/* SPI Core Functions to register,access chip and controller drivers */
+struct spi_chip_driver *get_spi_chip_driver_by_index (int index);
+struct spi_chip_driver *get_spi_chip_driver_by_name (const char *name);
+struct spi_ctrl_driver *get_spi_ctrl_driver_by_index (int index);
+struct spi_ctrl_driver *get_spi_ctrl_driver_by_name (const char *name);
+void register_spi_chip_driver(struct spi_chip_driver *drv);
+void unregister_spi_chip_driver(struct spi_chip_driver *drv);
+void register_spi_ctrl_driver(struct spi_ctrl_driver *drv);
+void unregister_spi_ctrl_driver(struct spi_ctrl_driver *drv);
+/* Functions registered to MTD  for accessing the chips */
+int  spi_flash_read(struct mtd_info *, loff_t, size_t, size_t *, u_char *);
+int  spi_flash_write(struct mtd_info *, loff_t, size_t, size_t *,const u_char *);
+int  spi_flash_erase(struct mtd_info *, struct erase_info *);
+void spi_flash_sync(struct mtd_info *);
+int  spi_flash_suspend(struct mtd_info *);
+void spi_flash_resume(struct mtd_info *);
+int  spi_flash_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len);
+int  spi_flash_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len);
+/* Generic spi funtions which can be used by any spi device (if uses generic algo) */
+int spi_generic_write_enable(int bank,struct spi_ctrl_driver *ctrl_drv);
+int spi_generic_read_enable(int bank,struct spi_ctrl_driver *ctrl_drv);
+int spi_generic_read_status(int bank,struct spi_ctrl_driver *ctrl_drv,unsigned char *status);
+int spi_generic_write_status(int bank,struct spi_ctrl_driver *ctrl_drv, unsigned char status);
+int spi_generic_erase(struct map_info *map, unsigned long sect_addr);
+int spi_generic_read(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buff);
+int spi_generic_write(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buff);
+int spi_generic_probe(int bank, struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info,
+			char *spi_name,struct spi_flash_info *spi_list, int spi_list_len);
+#ifdef CONFIG_SPX_FEATURE_GLOBAL_BKUP_FLASH_BANKS
+#define MAX_SPI_BANKS	(CONFIG_SPX_FEATURE_GLOBAL_FLASH_BANKS + CONFIG_SPX_FEATURE_GLOBAL_BKUP_FLASH_BANKS)
+#else
+#define MAX_SPI_BANKS	CONFIG_SPX_FEATURE_GLOBAL_FLASH_BANKS
+#endif
+#endif
diff --git a/drivers/mtd/spichips/spimtd.c b/drivers/mtd/spichips/spimtd.c
index 0000000..3c3a3c0
--- /dev/null
+++ b/drivers/mtd/spichips/spimtd.c
@@ -0,0 +1,241 @@
+static struct mtd_info * spi_flash_probe(struct map_info *map);
+static void spi_flash_destroy(struct mtd_info *mtd);
+static struct mtd_chip_driver spi_flash_chipdrv =
+	.probe = spi_flash_probe,
+	.destroy = spi_flash_destroy,
+	.name = "spi_probe",
+unsigned long ractrends_spiflash_flash_id[MAX_SPI_BANKS];
+unsigned long ractrends_spiflash_flash_size[MAX_SPI_BANKS];
+/*                               Probe Function       			                */
+static
+int
+probe_spi_chips(struct map_info *map,struct spi_flash_private *private,
+							struct spi_flash_info *spi_info)
+	int req = 0;
+	int ctrl,chip;
+	int gotindex;
+	gotindex=0;
+	/* For Every Controller driver */
+	ctrl = 0;
+	ctrl_drv = get_spi_ctrl_driver_by_index(ctrl);
+	while (ctrl_drv != NULL)
+		/* For Every Chip driver */
+		chip = 0;
+		chip_drv = get_spi_chip_driver_by_index(chip);
+		while (chip_drv != NULL)
+			/* Probe for the chip on the controller */
+			if (chip_drv->probe(bank,ctrl_drv,spi_info) == 0)
+				/* If success, check if it is the requested index */
+				if (req == gotindex)
+					private->chip_drv = chip_drv;
+					private->ctrl_drv = ctrl_drv;
+					return 0;
+				gotindex++;
+			/* Try Next chip */
+			chip++;
+		/* Try next controller */
+		ctrl++;
+	return -1;
+static int configure_spi_clock(struct spi_ctrl_driver *ctrl_drv, int bank, unsigned int clock)
+	if (ctrl_drv->spi_configure_clock == NULL)
+		return 0;
+	return ctrl_drv->spi_configure_clock(bank, clock);
+/*                               Interfaces to MTD Module                               */
+spi_flash_probe(struct map_info *map)
+	struct mtd_info *mtd;
+	struct spi_flash_private *private;
+	struct spi_flash_info spi_info;
+	int j,i;
+	private = kmalloc(sizeof(*private) + sizeof(struct flchip) , GFP_KERNEL);
+	if (!private)
+		       "%s: kmalloc failed for private structure\n", map->name);
+		return NULL;
+	memset(private,0,sizeof(*private) + (sizeof(struct flchip)));
+	mtd = (struct mtd_info*)kmalloc(sizeof(*mtd), GFP_KERNEL);
+	if (!mtd)
+		       "%s: kmalloc failed for info structure\n", map->name);
+		return NULL;
+	memset(mtd, 0, sizeof(*mtd));
+	mtd->priv = map;
+	memset(&spi_info, 0, sizeof(spi_info));
+	if (probe_spi_chips(map,private,&spi_info) == -1)
+		       "%s: No spi compatible flash device found\n",
+		       map->name);
+		map->fldrv_priv = NULL;
+		kfree(mtd);
+		kfree(private);
+		return NULL;
+	/* Fill flash ID and size in public array */
+	ractrends_spiflash_flash_id[map->map_priv_1] = ((spi_info.mfr_id << 16) | spi_info.dev_id);
+	ractrends_spiflash_flash_size[map->map_priv_1] = spi_info.size;
+	configure_spi_clock(private->ctrl_drv, map->map_priv_1, spi_info.max_clock);
+	chips.start = 0;
+	chips.state = FL_READY;
+	/* Fill in the mtd  structures */
+	mtd->size = spi_info.size;
+	mtd->numeraseregions = spi_info.numeraseregions;
+	/* Allocate memory for erase regions */
+	mtd->eraseregions = kmalloc(sizeof(struct mtd_erase_region_info) *
+				    mtd->numeraseregions, GFP_KERNEL);
+	if (!mtd->eraseregions)
+		printk(KERN_WARNING "%s: Failed to allocate "
+		       "memory for MTD erase region info\n", map->name);
+		kfree(mtd);
+		kfree(private);
+		return NULL;
+	/* Fill in the mtd erase structures */
+	for (j = 0; j < spi_info.numeraseregions; j++)
+		mtd->eraseregions[j].offset = spi_info.regions[j].offset;
+		mtd->eraseregions[j].erasesize = spi_info.regions[j].erasesize;
+		mtd->eraseregions[j].numblocks = spi_info.regions[j].numblocks;
+		if (mtd->erasesize <  mtd->eraseregions[j].erasesize)
+			mtd->erasesize = mtd->eraseregions[j].erasesize;
+	/* Fill in the remaining mtd structure */
+	mtd->type = MTD_NORFLASH;
+	mtd->flags = MTD_CAP_NORFLASH;
+	mtd->name = map->name;
+	mtd->_erase = spi_flash_erase;
+	mtd->_read = spi_flash_read;
+	mtd->_write = spi_flash_write;
+	mtd->_sync = spi_flash_sync;
+	mtd->_suspend = spi_flash_suspend;
+	mtd->_resume = spi_flash_resume;
+	mtd->_lock = spi_flash_lock;
+	mtd->_unlock = spi_flash_unlock;
+	mtd->writesize = 1;
+	/* Fill in the private structure */
+	private->numchips = 1;
+	private->device_type = DEVICE_TYPE_X8;
+	private->interleave = 1;
+	private->address32 = spi_info.address32;
+	memcpy(&private->chips, &chips,sizeof(struct flchip) * private->numchips);
+	for (i = 0; i < private->numchips; i++)
+		init_waitqueue_head(&private->chips.wq);
+		mutex_init(&private->chips.mutex);
+	/* Fill in the map structure */
+	map->fldrv_priv = private;
+	map->bankwidth = 1;
+	map->fldrv = &spi_flash_chipdrv;
+	__module_get(THIS_MODULE);
+	return mtd;
+static void
+spi_flash_destroy(struct mtd_info *mtd)
+	kfree(private);
+int __init
+spi_flash_init(void)
+	register_mtd_chip_driver(&spi_flash_chipdrv);
+	return 0;
+void __exit
+spi_flash_exit(void)
+	unregister_mtd_chip_driver(&spi_flash_chipdrv);
+module_init(spi_flash_init);
+module_exit(spi_flash_exit);
+MODULE_DESCRIPTION("Core SPI with MTD Interface");
diff --git a/drivers/mtd/spichips/spireg.c b/drivers/mtd/spichips/spireg.c
new file mode 100644
index 0000000..09aaa51
--- /dev/null
+++ b/drivers/mtd/spichips/spireg.c
@@ -0,0 +1,180 @@
+#ifdef __UBOOT__
+#endif
+DEFINE_SPINLOCK(spi_chip_drvs_lock);
+LIST_HEAD(spi_chip_drvs_list);
+DEFINE_SPINLOCK(spi_ctrl_drvs_lock);
+LIST_HEAD(spi_ctrl_drvs_list);
+void
+register_spi_chip_driver(struct spi_chip_driver *drv)
+	spin_lock(&spi_chip_drvs_lock);
+	list_add(&drv->list, &spi_chip_drvs_list);
+	spin_unlock(&spi_chip_drvs_lock);
+void
+unregister_spi_chip_driver(struct spi_chip_driver *drv)
+	list_del(&drv->list);
+void
+register_spi_ctrl_driver(struct spi_ctrl_driver *drv)
+	spin_lock(&spi_ctrl_drvs_lock);
+	list_add(&drv->list, &spi_ctrl_drvs_list);
+	spin_unlock(&spi_ctrl_drvs_lock);
+void
+unregister_spi_ctrl_driver(struct spi_ctrl_driver *drv)
+get_spi_chip_driver_by_name (const char *name)
+	struct list_head *pos;
+	struct spi_chip_driver *ret = NULL, *this;
+	list_for_each(pos, &spi_chip_drvs_list) {
+		this = list_entry(pos, typeof(*this), list);
+		if (!strcmp(this->name, name)) {
+			ret = this;
+			break;
+	if (ret && !try_module_get(ret->module))
+		ret = NULL;
+	return ret;
+get_spi_chip_driver_by_index (int index)
+	int got;
+	got=0;
+		if (index == got) {
+			ret = this;
+			break;
+		got++;
+		ret = NULL;
+	return ret;
+get_spi_ctrl_driver_by_name (const char *name)
+	struct spi_ctrl_driver *ret = NULL, *this;
+	list_for_each(pos, &spi_ctrl_drvs_list) {
+			ret = this;
+			break;
+		ret = NULL;
+	return ret;
+get_spi_ctrl_driver_by_index (int index)
+	int got;
+	got=0;
+			ret = this;
+			break;
+		got++;
+		ret = NULL;
+	return ret;
+EXPORT_SYMBOL(get_spi_chip_driver_by_name);
+EXPORT_SYMBOL(get_spi_chip_driver_by_index);
+EXPORT_SYMBOL(get_spi_ctrl_driver_by_name);
+EXPORT_SYMBOL(get_spi_ctrl_driver_by_index);
+EXPORT_SYMBOL(register_spi_ctrl_driver);
+EXPORT_SYMBOL(unregister_spi_ctrl_driver);
+EXPORT_SYMBOL(register_spi_chip_driver);
+EXPORT_SYMBOL(unregister_spi_chip_driver);
+MODULE_DESCRIPTION("Core routines for (un)registering  spi chip and controller drivers");
+#endif
diff --git a/drivers/mtd/spichips/winbond.c b/drivers/mtd/spichips/winbond.c
index 0000000..03b203c
--- /dev/null
+++ b/drivers/mtd/spichips/winbond.c
@@ -0,0 +1,98 @@
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+#ifdef __UBOOT__
+#endif
+#include "spiflash.h"
+static struct spi_flash_info winbond_data [] =
+	/* Winbond 64 K Sectors */
+	{ "Winbond W25X64" , 0xEF, 0x1730, 0x00010007, 0x800000 , 75  * 1000000,  1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q32" , 0xEF, 0x1640, 0x0001000F, 0x400000 , 75  * 1000000 , 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q64" , 0xEF, 0x1740, 0x0001000F, 0x800000 , 80  * 1000000,  1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q128", 0xEF, 0x1840, 0x0001000F, 0x1000000, 104 * 1000000,  1, 0x00, {{ 0, 64  * 1024, 256 },} },
+	{ "Winbond W25Q256", 0xEF, 0x1940, 0x0001000F, 0x2000000, 104 * 1000000,  1, 0x02, {{ 0, 64  * 1024, 512 },} },
+	{ "Winbond W25M512", 0xEF, 0x1971, 0x0001000f, 0x4000000, 104 * 1000000,  2, 0x06, {{ 0, 64  * 1024, 512 },{ 0x2000000, 64  * 1024, 512 },} },
+static
+int
+winbond_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"winbond",
+						winbond_data,ARRAY_SIZE(winbond_data));
+	if (retval == -1)
+		return retval;
+		printk("winbond: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver winbond_driver =
+	.name 		= "winbond",
+	.probe	 	= winbond_probe,
+int
+winbond_init(void)
+	sema_init(&winbond_driver.lock, 1);
+	winbond_driver.probe	 		= winbond_probe;
+	winbond_driver.erase_sector 	= spi_generic_erase;
+	winbond_driver.read_bytes	= spi_generic_read;
+	winbond_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&winbond_driver);
+	return 0;
+void
+winbond_exit(void)
+	unregister_spi_chip_driver(&winbond_driver);
+	return;
+module_init(winbond_init);
+module_exit(winbond_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Winbond flash chips");
+#endif
1.9.1
楼主 #14 2018-09-04 08:47:49
Re: 买两片 W25M512JVFIQ 测试一下
发现最新的 JLink_Windows_V634e.exe 也是一毛一样问题, 偏移了一个字节。
楼主 #15 2018-09-04 15:16:32
楼主 #16 2018-09-04 16:00:46
u-boot执行正常 说明: BROM 把 u-boot 读出来没问题
linux执行正常 说明: u-boot 读 flash也没问题
我现在用 flashcp 把 u-boot-sunxi-with-spl.bin 写入 /dev/mtd0,
出现校验错误:
flash_eraseall /dev/mtd0
Erasing 4 Kibyte @ f0000 - 100% complete.
flashcp -v u-boot-sunxi-with-spl.bin /dev/mtd0
Erasing block: 107/107 (100%)
Writing kb: 426/426 (100%)
Verifying kb: 0/426 (0%) flashcp: verification mismatch at 0x0
然后我把 /dev/mtd0 dump 出来
dd if=/dev/mtd0 of=5.bin
使用 beyond compare 比较, 完全一致, 说明一个问题:
spi flash 的读驱动有问题,写驱动问题不大, 而且是与JLINK读一毛一样的问题。
继续跟踪.
楼主 #17 2018-09-04 18:19:44
终于可以当32M用了
{ "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 512, SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ | SPI_NOR_4B_OPCODES) },
特别感谢这位网友: https://whycan.cn/t_1108.html
明天继续搞64M 切换 DIE.
现在问题来了, 难道 JLINK 的 JFLashSPI.exe 读程序有 4B 地址的bug ?
楼主 #18 2018-09-05 14:59:35
为了简化问题,把第二个die 单独划分到一个 mtd 分区, 使用 flash_eraseall 格式化分区,
mount jffs2 文件系统,读写文件均正常了.
下一步要把后面的die(32M) 合并到前面来.
楼主 #19 2018-09-06 08:40:03
同时操作多个文件会挂,感觉那个切换die整个函数要加锁.
楼主 #20 2018-09-06 08:43:20
https://github.com/ya-mouse/openbmc-target/blob/master/aspeed/patches-3.18/0006-Add-various-MTD-SPI-chips.patch
看了一下别人切换die, 都要加锁。
#21 2019-02-11 10:32:19
jimmy
已发帖子: 316
https://github.com/u-boot/u-boot/blob/master/cmd/mtdparts.c
u-boot 如同 Linux一样,也支持 mtd 分区, 估计是通过partition(分区首地址) + offset(偏移) 方式访问flash地址.
#22 2019-02-11 10:50:57
john78
已发帖子: 223
32M的MX25L2564
在U-BOOT中没有搞定
=> sf probe 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
=> sf update 0x41010000 0x16200000 0x100
Offset exceeds device limit
sf - SPI flash sub-system
Usage:
sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus
and chip select
sf read addr offset|partition len - read `len' bytes starting at
`offset' or from start of mtd
partition'to memory at addr'
sf write addr offset|partition len - write `len' bytes from memory
at addr' to flash at offset'
or to start of mtd `partition'
sf erase offset|partition [+]len - erase len' bytes from offset'
or from start of mtd `partition'
+len' round up len' to block size
sf update addr offset|partition len - erase and write `len' bytes from memory
sf protect lock/unlock sector len - protect/unprotect 'len' bytes starting
at address 'sector'
#23 2019-02-11 11:18:54
jimmy
已发帖子: 316
32M flash 操作比 16M及其以下的 flash 多一个步骤,
可以通过两种方式:
  1. 开启4B地址模式, 这样可以访问 16M 后面的地址空间
  2. 写 EAR 寄存器, 也可以访问后面 16M 空间
理论上来说新 u-boot 应该早就实现了.
#24 2019-02-13 20:22:37
isuman
關注一下flash 準備入坑
最近编辑记录 isuman (2019-02-13 20:22:58)
楼主 #25 2019-02-14 22:49:07
john78 wrote:
32M的MX25L2564
在U-BOOT中没有搞定
=> sf probe 0
Usage:
and chip select
at address 'sector'
CONFIG_SPI_FLASH_BAR 这个宏开起来试一试
#26 2019-02-14 22:58:04
john78
已发帖子: 223
应该是sf update 的问题。
用sf erase,sf write 可以了
#27 2019-02-15 08:38:59
jimmy
已发帖子: 316
john78 wrote:
应该是sf update 的问题。
sf erase,sf write 这两个功能本来就正常,
而 sf update 有问题?
#28 2019-05-13 17:51:01
发现主线上面并没有 W25M512 的补丁, 代码里面并没有适配这个芯片。
哪怕 最新的 linux 5.1 也没有关于 die 切换的代码
https://github.com/torvalds/linux/blob/v5.1/include/linux/mtd/spi-nor.h
https://github.com/torvalds/linux/blob/v5.1/drivers/mtd/spi-nor/spi-nor.c
不知道这个能不能用上:
From c7025568f83800de384c457557169e44740dc8f7 Mon Sep 17 00:00:00 2001
Date: Tue, 24 May 2016 19:36:35 +0300
Subject: [PATCH 06/14] Add various MTD SPI chips
Signed-off-by: Anton D. Kachalov <mouse@yandex-team.ru>
 drivers/mtd/spichips/Kconfig     |   94 ++++
 drivers/mtd/spichips/Makefile    |   18 +
 drivers/mtd/spichips/astspi.c    |  367 +++++++++++++
 drivers/mtd/spichips/atmel.c     |  133 +++++
 drivers/mtd/spichips/default.c   |  106 ++++
 drivers/mtd/spichips/generic.c   | 1052 ++++++++++++++++++++++++++++++++++++++
 drivers/mtd/spichips/intels33.c  |   96 ++++
 drivers/mtd/spichips/m25pxx.c    |  121 +++++
 drivers/mtd/spichips/macronix.c  |  208 ++++++++
 drivers/mtd/spichips/micron.c    |  104 ++++
 drivers/mtd/spichips/spansion.c  |  103 ++++
 drivers/mtd/spichips/spiaccess.c |  433 ++++++++++++++++
 drivers/mtd/spichips/spiflash.h  |  178 +++++++
 drivers/mtd/spichips/spimtd.c    |  241 +++++++++
 drivers/mtd/spichips/spireg.c    |  180 +++++++
 drivers/mtd/spichips/winbond.c   |   98 ++++
 16 files changed, 3532 insertions(+)
 create mode 100644 drivers/mtd/spichips/Kconfig
 create mode 100644 drivers/mtd/spichips/Makefile
 create mode 100644 drivers/mtd/spichips/astspi.c
 create mode 100644 drivers/mtd/spichips/atmel.c
 create mode 100644 drivers/mtd/spichips/default.c
 create mode 100644 drivers/mtd/spichips/generic.c
 create mode 100644 drivers/mtd/spichips/intels33.c
 create mode 100644 drivers/mtd/spichips/m25pxx.c
 create mode 100644 drivers/mtd/spichips/macronix.c
 create mode 100644 drivers/mtd/spichips/micron.c
 create mode 100644 drivers/mtd/spichips/spansion.c
 create mode 100644 drivers/mtd/spichips/spiaccess.c
 create mode 100644 drivers/mtd/spichips/spiflash.h
 create mode 100644 drivers/mtd/spichips/spimtd.c
 create mode 100644 drivers/mtd/spichips/spireg.c
 create mode 100644 drivers/mtd/spichips/winbond.c
diff --git a/drivers/mtd/spichips/Kconfig b/drivers/mtd/spichips/Kconfig
index 0000000..c5e5a4c
--- /dev/null
+++ b/drivers/mtd/spichips/Kconfig
@@ -0,0 +1,94 @@
+# drivers/mtd/chips/Kconfig
+# $Id: Kconfig,v 1.18 2005/11/07 11:14:22 gleixner Exp $
+menu "SPI Flash chip drivers"
+	depends on MTD!=n
+config MTD_SPI
+	bool "Enable MTD support on SPI devices"
+	depends on MTD
+	help
+	  Select this if you want to access SPI flash devices via MTD
+config MTD_SPI_SPANSION
+	bool "Spansion SPI devices Support"
+	depends on MTD_SPI
+	help
+	  Select this if you want to use Spansion SPI devices
+config MTD_SPI_MACRONIX
+	bool "Macronix SPI devices Support"
+	help
+	  Select this if you want to use Macronix SPI devices
+config MTD_SPI_INTEL_S33
+	bool "Intel S33 SPI devices Support"
+	help
+	  Select this if you want to use Intel S33 SPI devices
+config MTD_SPI_WINBOND
+	bool "Winbond SPI devices Support"
+	help
+	  Select this if you want to use Winbond SPI devices
+config MTD_SPI_AT
+	bool "Atmel SPI devices Support"
+	help
+	  Select this if you want to use Atmel SPI devices
+config MTD_SPI_ST
+	bool "ST Micro SPI devices Support"
+	help
+	  Select this if you want to use ST Microelectronics SPI devices
+config MTD_SPI_NUMONYX
+	bool "Numonyx SPI devices Support"
+	help
+	  Select this if you want to use Numonyx SPI devices
+config MTD_SPI_MICRON
+	help
+	  Select this if you want to use Micron SPI devices
+config MTD_SPI_DEFAULT
+	bool "Support for SPI Devices not supporting ReadID"
+	help
+	   Select this if the SPI device on your board does not SPI ReadID Command
+config DEFAULT_SPI_NAME
+	string "Default SPI Name"
+	depends on MTD_SPI && MTD_SPI_DEFAULT
+	default "default"
+	help
+	   Name of the SPI Device that does not support ReadID
+config DEFAULT_SPI_SIZE
+	int "Default SPI Size in Bytes"
+	default "65536"
+	help
+	   Chip Size of the SPI Device that does not support ReadID
+config DEFAULT_SPI_ERASE_SIZE
+	int "Default SPI Erase Block Size in Bytes"
+	default "65536"
+	help
+	   Erase Block Size of the SPI Device that does not support ReadID
+config MTD_AST_SPI
+	bool "AST SOC SPI Flash Controller"
+	help
+		If you are using SPI device on AST SOC, select Y
+endmenu
diff --git a/drivers/mtd/spichips/Makefile b/drivers/mtd/spichips/Makefile
index 0000000..b30a452
--- /dev/null
+++ b/drivers/mtd/spichips/Makefile
@@ -0,0 +1,18 @@
+# linux/drivers/spichips/Makefile
+obj-$(CONFIG_MTD_SPI)		+= spimtd.o spiaccess.o spireg.o generic.o
+obj-$(CONFIG_MTD_SPI_ST)   	+= m25pxx.o
+obj-$(CONFIG_MTD_SPI_SPANSION) += spansion.o
+obj-$(CONFIG_MTD_SPI_MACRONIX) += macronix.o
+obj-$(CONFIG_MTD_SPI_AT)   	+= atmel.o
+obj-$(CONFIG_MTD_SPI_INTEL_S33) += intels33.o
+obj-$(CONFIG_MTD_SPI_WINBOND) += winbond.o
+obj-$(CONFIG_MTD_SPI_MICRON) += micron.o
+obj-$(CONFIG_MTD_SPI_NUMONYX) += micron.o
+# The default driver  should be the last in the list of suppported devices
+obj-$(CONFIG_MTD_SPI_DEFAULT)   += default.o
+obj-$(CONFIG_MTD_AST_SPI)   += astspi.o
diff --git a/drivers/mtd/spichips/astspi.c b/drivers/mtd/spichips/astspi.c
index 0000000..a0dc9d4
--- /dev/null
+++ b/drivers/mtd/spichips/astspi.c
@@ -0,0 +1,367 @@
+ * (C) Copyright 2009
+ * American Megatrends Inc.
+ * SPI flash controller driver for the AST SoC
+ * See file CREDITS for list of people who contributed to this
+ * project.
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#define AST_FMC_REG_BASE		AST_FMC_VA_BASE /* 0x1E620000 */
+#define AST_FMC_FLASH_CTRL_REG		0x00
+#define AST_FMC_CE0_CTRL_REG		0x10
+#define AST_FMC_CTRL_REG_SIZE           0x04
+#define AST_SPI_CMD_MASK		0x00FF0000 /* bit[23:16] */
+#define AST_SPI_CMD_SHIFT		16
+#define AST_SPI_CLOCK_MASK		0x00000F00 /* bit[11:8] */
+#define AST_SPI_CLOCK_SHIFT		8
+#define AST_SPI_DUMMY_MASK		0x000000C0 /* bit[7:6] */
+#define AST_SPI_DUMMY_0			0x00000000
+#define AST_SPI_DUMMY_1			0x00000040
+#define AST_SPI_DUMMY_2			0x00000080
+#define AST_SPI_DUMMY_3			0x000000C0
+#define AST_SPI_DATA_SINGLE		0x00000000
+#define AST_SPI_DATA_DUAL		0x00000008
+#define AST_SPI_DUAL_IO		0x00000002
+#define AST_SPI_FULL_DUAL_IO		0x00000003
+#define AST_SPI_DATA_MASK		7
+#define AST_SPI_DUAL_IO_SHIFT		28
+#define AST_SPI_CE_LOW			0x00000000
+#define AST_SPI_CE_HI			0x00000004
+#define AST_SPI_CMD_MODE_MASK		0x00000007 /* bit[2:0] */
+#define AST_SPI_CMD_MODE_NORMAL		0x00000000
+#define AST_SPI_CMD_MODE_FAST		0x00000001
+#define AST_SPI_CMD_MODE_WRITE		0x00000002
+#define AST_SPI_CMD_MODE_USER		0x00000003
+#define SPI_FAST_READ_CMD		0x0B
+#define SPI_DREAD_CMD		0x3B
+#define SPI_2READ_CMD		0xBB
+extern unsigned long ractrends_spiflash_flash_size[MAX_SPI_BANKS];
+static int *g_fast_read = 0;
+static void reset_flash(int bank)
+	uint32_t reg;
+	uint32_t ctrl_reg;
+        // bank = 0,CE0 (0x10) ; bank = 1,CE1 (0x14) ; bank = 2,CE2 (0x18)
+        ctrl_reg = AST_FMC_CE0_CTRL_REG + (bank * AST_FMC_CTRL_REG_SIZE);
+	reg = ioread32((void __iomem *)AST_FMC_REG_BASE + ctrl_reg);
+	if (*g_fast_read == 3)//2xI/O Read
+		reg &= ~(AST_SPI_CMD_MASK | AST_SPI_DUMMY_MASK | AST_SPI_CMD_MODE_MASK);
+		reg |= (SPI_2READ_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST | (AST_SPI_FULL_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 2)//Dual Read
+		reg |= (SPI_DREAD_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST | (AST_SPI_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 1)//Fast Read
+		reg |= (SPI_FAST_READ_CMD << AST_SPI_CMD_SHIFT) | AST_SPI_DUMMY_1 | AST_SPI_CE_LOW | AST_SPI_CMD_MODE_FAST;
+	else
+		reg &= (~AST_SPI_CMD_MODE_MASK);
+		reg |= (AST_SPI_CE_LOW | AST_SPI_CMD_MODE_NORMAL);
+	iowrite32(reg, (void __iomem *)AST_FMC_REG_BASE + ctrl_reg);
+static void reset_iomode (int bank)
+	uint32_t reg;
+	reg &= ~(AST_SPI_CMD_MASK | AST_SPI_DUMMY_MASK | (AST_SPI_DATA_MASK << AST_SPI_DUAL_IO_SHIFT));
+	if (*g_fast_read == 2)//Dual Read
+		reg |= (AST_SPI_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	else if (*g_fast_read == 3)//2xI/O Read
+		reg |= (AST_SPI_FULL_DUAL_IO << AST_SPI_DUAL_IO_SHIFT);
+	return;
+static void chip_select_active(int bank)
+	uint32_t reg;
+	reg &= (~(AST_SPI_CMD_MODE_MASK | (AST_SPI_DATA_MASK << AST_SPI_DUAL_IO_SHIFT)) );
+	reg |= (AST_SPI_CE_LOW | AST_SPI_CMD_MODE_USER);
+static void chip_select_deactive(int bank)
+	uint32_t reg;
+	reg |= (AST_SPI_CE_HI | AST_SPI_CMD_MODE_USER);
+static int astspiflash_transfer(int bank, unsigned char *cmd, int cmdlen, SPI_DIR dir, unsigned char *data, unsigned long datalen)
+	ulong base;
+	int i;
+	ulong offset = 0;
+	for(i = 0; i < bank; i++)
+		offset += ractrends_spiflash_flash_size[i];
+	base = AST_SPI_FLASH_VA_BASE + offset;
+	chip_select_active(bank);
+	if (cmd[0] == 0xBB)
+		*((volatile unsigned char *) base) = cmd[0];
+		reset_iomode(bank);
+		for (i = 1; i < cmdlen; i ++)
+			*((volatile unsigned char *) base) = cmd[i];
+	else if (cmd[0] == 0x3B)
+		for (i = 0; i < cmdlen; i ++)
+	else
+	/* issue command */
+	if (dir == SPI_WRITE) {
+		/* write data to flash */
+		for (i = 0; i < datalen; i ++) {
+			*((volatile unsigned char *) base) = data[i];
+	} else if (dir == SPI_READ) {
+		/* read data from flash */
+			data[i] = ((volatile unsigned char *) base)[i];
+	chip_select_deactive(bank);
+	reset_flash(bank);
+	return 0;
+static const unsigned char clock_selection_table[] = {
+	0x0F, /* 1 */
+	0x07, /* 2 */
+	0x0E, /* 3 */
+	0x06, /* 4 */
+	0x0D, /* 5 */
+	0x05, /* 6 */
+	0x0C, /* 7 */
+	0x04, /* 8 */
+	0x0B, /* 9 */
+	0x03, /* 10 */
+	0x0A, /* 11 */
+	0x02, /* 12 */
+	0x09, /* 13 */
+	0x01, /* 14 */
+	0x08, /* 15 */
+	0x00, /* 16 */
+static int astspiflash_configure_clock(int bank, unsigned int clock)
+	uint32_t reg;
+	uint32_t cpu_clock;
+	uint32_t clock_divisor;
+#if defined(CONFIG_SOC_AST2500) || defined(CONFIG_SOC_AST2530)
+	uint32_t cpu_ratio;
+	uint32_t axi_ratio;
+#endif
+	/* according to AST spec, clock of SPI controller can not exceed 50M Hz */
+	if (clock > (50 * 1000000))
+		clock = 50 * 1000000;
+	/* read CPU clock rate and CPU/AHB ratio from SCU */
+	reg = ioread32((void __iomem *)SCU_HW_STRAPPING_REG);
+	#if defined(CONFIG_SOC_AST2500) || defined(CONFIG_SOC_AST2530)
+	cpu_ratio = 2;
+	switch ((reg & 0x00000E00) >> 9) {
+	case 0x01:
+		axi_ratio = 2;
+		break;
+	case 0x02:
+		axi_ratio = 3;
+		break;
+	case 0x03:
+		axi_ratio = 4;
+		break;
+	case 0x04:
+		axi_ratio = 5;
+		break;
+	case 0x05:
+		axi_ratio = 6;
+		break;
+	case 0x06:
+		axi_ratio = 7;
+		break;
+	case 0x07:
+		axi_ratio = 8;
+		break;
+	default:
+		axi_ratio = 2;
+		break;
+	cpu_clock = 792 * 1000000;//Default H-PLL value
+	cpu_clock = cpu_clock / cpu_ratio / axi_ratio;
+	#else
+	switch ((reg & 0x00000300) >> 8) {
+	case 0x00:
+		cpu_clock = 384 * 1000000;
+		break;
+	case 0x01:
+		cpu_clock = 360 * 1000000;
+		break;
+	case 0x02:
+		cpu_clock = 336 * 1000000;
+		break;
+	case 0x03:
+		cpu_clock = 408 * 1000000;
+		break;
+	default:
+	switch ((reg & 0x00000C00) >> 10) {
+	case 0x01:
+		cpu_clock /= 2;
+		break;
+	case 0x02:
+		cpu_clock /= 4;
+		break;
+	case 0x03:
+		cpu_clock /= 3;
+		break;
+	#endif
+	clock_divisor = 1;
+	while ((cpu_clock / clock_divisor) > clock) {
+		clock_divisor ++;
+		if (clock_divisor == 16)
+			break;
+	reg &= ~AST_SPI_CLOCK_MASK;
+	reg |= (clock_selection_table[clock_divisor - 1] << AST_SPI_CLOCK_SHIFT);
+	return 0;
+struct spi_ctrl_driver astspi_driver = {
+	.name = "astspiflash",
+	.module = THIS_MODULE,
+	.max_read = (64 * 1024 * 1024), /* 32 MB */
+	#ifdef CONFIG_FLASH_OPERATION_MODE_MASK
+	.operation_mode_mask = CONFIG_FLASH_OPERATION_MODE_MASK,
+	#else
+	.operation_mode_mask = 0x00010003, //Default
+	#endif
+	.fast_read = 1,
+	.fast_write = 0,
+	.spi_transfer = astspiflash_transfer,
+	.spi_burst_read = astspiflash_transfer,
+	.spi_configure_clock = astspiflash_configure_clock,
+static int astspi_init(void)
+	sema_init(&astspi_driver.lock, 1);
+	register_spi_ctrl_driver(&astspi_driver);
+	g_fast_read = &astspi_driver.fast_read;
+	reset_flash(0);	// CE0
+	reset_flash(1);	// CE1
+	reset_flash(2);	// CE2
+	#if !defined(CONFIG_SOC_AST2500) && !defined(CONFIG_SOC_AST2530)
+	reset_flash(3);	// CE3
+	#endif
+	return 0;
+static void astspi_exit(void)
+	unregister_spi_ctrl_driver(&astspi_driver);
+module_init(astspi_init);
+module_exit(astspi_exit);
+MODULE_LICENSE("GPL");
+MODULE_AUTHOR("American Megatrends Inc");
+MODULE_DESCRIPTION("AST SOC SPI flash controller driver");
diff --git a/drivers/mtd/spichips/atmel.c b/drivers/mtd/spichips/atmel.c
index 0000000..a7cfddb
--- /dev/null
+++ b/drivers/mtd/spichips/atmel.c
@@ -0,0 +1,133 @@
+ * Copyright (C) 2007 American Megatrends Inc
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
+#ifdef __UBOOT__
+#include <common.h>
+#endif
+#ifdef	CFG_FLASH_SPI_DRIVER
+/* Name, ID1, ID2 , Size, Clock, Erase regions, address mode,{ Offset, Erase Size, Erase Block Count } */
+/* address mode:  0x00 -3 byte address
+			 	0x01 - 4 byte address
+			 	0x02 - Low byte: 3 byte address, High byte: 4 byte address*/
+static struct spi_flash_info atmel_data [] =
+	/* Atmel 26F 64K Sectors */
+	{ "Atmel at26f004"   , 0x1F, 0x0004, 0x00010001, 0x100000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	/* Atmel 25DF 64K Sectors */
+	{ "Atmel at25df041a" , 0x1F, 0x0144, 0x00010001, 0x100000 , 70 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	/* Atmel 26DF 64K Sectors */
+	{ "Atmel at26df081a" , 0x1F, 0x0145, 0x00010001, 0x100000 , 70 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "Atmel at26df161a" , 0x1F, 0x0146, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Atmel at26df161"  , 0x1F, 0x0046, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Atmel at26df321"  , 0x1F, 0x0047, 0x00010001, 0x400000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "Atmel at25df321"  , 0x1F, 0x0147, 0x00010001, 0x400000 , 85 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+static
+int
+atmel_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	unsigned char status;
+	retval =  spi_generic_probe(bank, ctrl_drv,chip_info,"atmel",atmel_data,ARRAY_SIZE(atmel_data));
+	if (retval == -1)
+		return retval;
+	if (spi_generic_read_status(bank,ctrl_drv,&status) < 0)
+		printk("atmel: Read SR Failed.Cannot Unprotect all sectors\n");
+		return retval;
+	/* If SRPL = 1 (Bit 7)and WP/ = 0 (Bit 4), then it is hardware locked */
+	if ((status & 0x80) && (!(status & 0x10)))
+		printk("atmel: Hardware Locked\n");
+		return retval;
+	/* Check if already unprotected */
+	if ((status & 0xC) == 0)
+		return retval;
+	/* if SRPL is set, we have to disable SRPL before unprotect */
+	if (status & 0x80)
+		if (spi_generic_write_status(bank,ctrl_drv,status& 0x7F) < 0)
+			printk("atmel: Clearing SRPL failed .Cannot Unprotect all sectors\n");
+			return retval;
+	/* Unprotect all sectors */
+	if (spi_generic_write_status(bank,ctrl_drv,0x0) < 0)
+		printk("atmel: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver atmel_driver =
+	.name 		= "atmel",
+	.probe	 	= atmel_probe,
+	.erase_sector 	= spi_generic_erase,
+	.read_bytes	= spi_generic_read,
+	.write_bytes	= spi_generic_write,
+	/* Atmel supports individual protect and unprotect of sectors */
+	/* if needed implement the functions and add here */
+int
+atmel_init(void)
+	sema_init(&atmel_driver.lock, 1);
+#ifdef __UBOOT__	/* MIPS */
+	atmel_driver.probe	 		= atmel_probe;
+	atmel_driver.erase_sector 	= spi_generic_erase;
+	atmel_driver.read_bytes		= spi_generic_read;
+	atmel_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&atmel_driver);
+	return 0;
+void
+atmel_exit(void)
+	unregister_spi_chip_driver(&atmel_driver);
+	return;
+module_init(atmel_init);
+module_exit(atmel_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Atmel flash chips");
+#endif
diff --git a/drivers/mtd/spichips/default.c b/drivers/mtd/spichips/default.c
index 0000000..93f31d7
--- /dev/null
+++ b/drivers/mtd/spichips/default.c
@@ -0,0 +1,106 @@
+#ifdef __UBOOT__
+#endif
+#ifndef CONFIG_DEFAULT_SPI_NAME
+#define CONFIG_DEFAULT_SPI_NAME "Unknown SPI Device"
+#endif
+#ifndef CONFIG_DEFAULT_SPI_SIZE
+#define CONFIG_DEFAULT_SPI_SIZE 0
+#endif
+#ifndef CONFIG_DEFAULT_SPI_CLOCK
+#define CONFIG_DEFAULT_SPI_CLOCK (25 * 1000000)
+#endif
+#ifndef CONFIG_DEFAULT_SPI_ERASE_SIZE
+#define CONFIG_DEFAULT_SPI_ERASE_SIZE	(64 *1024)
+#endif
+/* This driver is called at end when all probe failed. Some chips don't support read id
+   commands and user can provide the information here */
+static struct spi_flash_info default_data [] =
+	{ CONFIG_DEFAULT_SPI_NAME , 0xFF, 0x0FFFF, 0x00010001, CONFIG_DEFAULT_SPI_SIZE , CONFIG_DEFAULT_SPI_CLOCK, 1, 0x00,
+			{{ 0, CONFIG_DEFAULT_SPI_ERASE_SIZE, CONFIG_DEFAULT_SPI_SIZE/CONFIG_DEFAULT_SPI_ERASE_SIZE },} },
+static
+int
+default_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	memcpy(chip_info,&default_data[0],sizeof(struct spi_flash_info));
+		printk("%s: Unable to Unprotect all sectors\n",CONFIG_DEFAULT_SPI_NAME);
+	return 0;
+struct spi_chip_driver default_driver =
+	.name 		= "default",
+	.probe	 	= default_probe,
+int
+default_init(void)
+	sema_init(&default_driver.lock, 1);
+	default_driver.probe	 		= default_probe;
+	default_driver.erase_sector 	= spi_generic_erase;
+	default_driver.read_bytes		= spi_generic_read;
+	default_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&default_driver);
+	return 0;
+void
+default_exit(void)
+	unregister_spi_chip_driver(&default_driver);
+	return;
+module_init(default_init);
+module_exit(default_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Default flash chips");
+#endif
diff --git a/drivers/mtd/spichips/generic.c b/drivers/mtd/spichips/generic.c
index 0000000..50a70f6
--- /dev/null
+++ b/drivers/mtd/spichips/generic.c
@@ -0,0 +1,1052 @@
+ * Copyright (C) 2007-2013 American Megatrends Inc
+#ifdef __UBOOT__
+#endif
+/* Flash opcodes. */
+#define	OPCODE_WREN		0x06	/* Write enable */
+#define	OPCODE_WRDI		0x04	/* Write disable*/
+#define	OPCODE_RDID		0x9F	/* Read JEDEC ID */
+#define	OPCODE_RDSR		0x05	/* Read status register */
+#define OPCODE_WRSR		0x01	/* Write status register */
+#define	OPCODE_READ		0x03	/* Read data bytes */
+#define	OPCODE_FAST_READ	0x0B	/* Read Fast read */
+#define	OPCODE_DREAD	0x3B	/* Dual Read Mode */
+#define	OPCODE_2READ	0xBB	/* 2 x I/O Read Mode */
+#define	OPCODE_PP		0x02	/* Page program */
+#define	OPCODE_SE		0xD8	/* Sector erase */
+#define OPCODE_DP		0xB9	/* Deep Power Down */
+#define	OPCODE_RES		0xAB	/* Read Electronic Signature */
+/* Status Register bits. */
+#define	SR_WIP			0x01	/* Write in progress */
+#define	SR_WEL			0x02	/* Write enable latch */
+#define	SR_BP0			0x04	/* Block protect 0 */
+#define	SR_BP1			0x08	/* Block protect 1 */
+#define	SR_BP2			0x10	/* Block protect 2 */
+#define	SR_SRWD			0x80	/* SR write protect */
+#define PROGRAM_PAGE_SIZE	256	/* Max Program Size */
+#define ADDR_16MB 		0x1000000
+#define CMD_MX25XX_EN4B		0xb7	/* Enter 4-byte address mode */
+#define CMD_MX25XX_EX4B		0xe9	/* Exit 4-byte address mode */
+#define ADDRESS_3BYTE	0x00
+#define ADDRESS_4BYTE	0x01
+#define ADDRESS_LO3_HI4_BYTE 0x02
+#define ADDRESS_DIE_LO3_HI4_BYTE 0x06
+#define ADDR_32MB 		0x2000000
+#define CMD_WX25XX_CS		0xc2	/* Die select */
+extern unsigned long ractrends_spiflash_flash_id[MAX_SPI_BANKS];
+static int wait_till_ready(int bank,struct spi_ctrl_driver *ctrl_drv);
+static
+int inline
+spi_error(int retval)
+	printk("SPI Chip %s (%d) : Error (%d)\n",__FILE__,__LINE__,retval);
+	return retval;
+static int
+spi_generic_read_flag_status(int bank, struct spi_ctrl_driver *ctrl_drv,unsigned char *status)
+	int  retval;
+	u8 code = 0x70;
+	/* Issue Controller Transfer Routine */
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,status, 1);
+	if (retval < 0)
+		return spi_error(retval);
+	return 0;
+int
+spi_generic_read_status(int bank, struct spi_ctrl_driver *ctrl_drv,unsigned char *status)
+	int  retval;
+	u8 code = OPCODE_RDSR;
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_status(int bank,struct spi_ctrl_driver *ctrl_drv, unsigned char status)
+	int retval;
+	u8 code = OPCODE_WRSR;
+	/* Send write enable */
+	spi_generic_write_enable(bank,ctrl_drv);
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_WRITE,&status, 1);
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_enable(int bank,struct spi_ctrl_driver *ctrl_drv)
+	u8 code = OPCODE_WREN;
+	int retval;
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_NONE, NULL, 0);
+	if (retval < 0)
+	return 0;
+int
+spi_generic_write_disable(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = OPCODE_WRDI;
+	int retval;
+	if (retval < 0)
+	return 0;
+int spi_generic_select_die(int bank, u8 die_num, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	u8 command[2];
+	command[0] = CMD_WX25XX_CS;
+	command[1] = die_num;
+	/* Wait until finished previous command. */
+	if (wait_till_ready(bank,ctrl_drv))
+		return -1;
+	retval = ctrl_drv->spi_transfer(bank, command, 2, SPI_NONE, NULL, 0);
+	if (retval < 0)
+		printk ("Could not select die.\n");
+	return 0;
+int enter_4byte_addr_mode(int bank, struct spi_ctrl_driver *ctrl_drv)
+	//enable 32 MB Address mode
+	u8 code = CMD_MX25XX_EN4B;
+	int retval;
+	//printf("<ENTER> 4 BYTE\n");
+		return -1;
+	if ((ractrends_spiflash_flash_id[bank] == 0x002019BA) || (ractrends_spiflash_flash_id[bank] == 0x002020BA) || (ractrends_spiflash_flash_id[bank] == 0x002021BA))
+	retval = ctrl_drv->spi_transfer(bank, &code, 1, SPI_NONE, NULL, 0);
+	if ((ractrends_spiflash_flash_id[bank] == 0x002019BA) || (ractrends_spiflash_flash_id[bank] == 0x002021BA))
+		spi_generic_write_disable(bank,ctrl_drv);
+	if (retval < 0)
+		printk ("Could not Enter into 4-byte address mode\n");
+	return 0;
+int exit_4byte_addr_mode(int bank, struct spi_ctrl_driver *ctrl_drv)
+	//Disable 32 MB Address mode
+	u8 code = CMD_MX25XX_EX4B;
+	int retval;
+	//printf("<EXIT> 4 BYTE\n");
+		return -1;
+	if (retval < 0)
+		printk ("Could not Exit from 4-byte address mode\n");
+	return 0;
+int spi_generic_extended_address(int bank, SPI_DIR dir, u8 addr, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	if (dir == SPI_READ)
+		u8 code = 0xC8;
+		u8 reg_data;
+		ctrl_drv->spi_transfer(bank, &code, 1, SPI_READ, &reg_data, 1);
+		retval = (int) reg_data;
+	else if (dir == SPI_WRITE)
+		u8 command[2];
+		command[0] = 0xC5;
+		command[1] = addr;
+		spi_generic_write_enable(bank, ctrl_drv);
+		ctrl_drv->spi_transfer(bank, command, 2, SPI_NONE, NULL, 0);
+		spi_generic_write_disable(bank, ctrl_drv);
+		retval = command[1];
+	else // SPI_NONE
+		retval = 0;
+	return retval;
+// the function just for WINBOND W25Q256 only, always revise the extended address to the defalut
+int w25q256_force_extended_address(int bank, struct spi_ctrl_driver *ctrl_drv)
+	int retval;
+	u8 code;
+	u8 reg_data;
+	u8 command[5];
+	code = 0xC8; // "Read Extended Address Register"
+	retval = ctrl_drv->spi_transfer(bank, &code, 1, SPI_READ, &reg_data, 1);
+	if (reg_data == 0x01)
+		command[0] = 0xC5; // "Write Extended Address Register" with the force address 0x00
+		command[1] = command[2] = command[3] = command[4] = 0x00;
+		retval = ctrl_drv->spi_transfer(bank, command, 5, SPI_NONE, NULL, 0);
+	return 0;
+/* Define max times to check status register before we give up. */
+#define	MAX_READY_WAIT_COUNT	4000000
+static int
+wait_till_ready(int bank,struct spi_ctrl_driver *ctrl_drv)
+	unsigned long  count;
+	unsigned char sr;
+	for (count = 0; count < MAX_READY_WAIT_COUNT; count++)
+		if (spi_generic_read_status(bank,ctrl_drv,&sr) < 0)
+			printk("Error reading SPI Status Register\n");
+			break;
+		else
+			if (!(sr & SR_WIP))
+				return 0;
+	printk("spi_generic: Waiting for Ready Failed\n");
+	return 1;
+static int
+require_read_flag_status(int bank,struct spi_ctrl_driver *ctrl_drv)
+	unsigned char sr;
+		if (spi_generic_read_flag_status(bank,ctrl_drv,&sr) < 0)
+			break;
+		else
+			if (sr & SR_SRWD)
+				return 0;
+	printk("spi_generic %s() : Waiting for Ready Failed\n", __func__);
+	return 1;
+int
+spi_generic_erase(struct map_info *map, unsigned long sect_addr)
+	struct spi_flash_private *priv=map->fldrv_priv;
+	int bank = map->map_priv_1;
+	struct spi_ctrl_driver *ctrl_drv = priv->ctrl_drv;
+	int retval;
+	unsigned char command[5];
+	int cmd_size;
+	u8 address32 = priv->address32;
+	//unsigned long flash_size = priv->size;
+	u8 had_switch_die = 0;
+    u8 pwr_up_mode = 0;
+	down(&priv->chip_drv->lock);
+		up(&priv->chip_drv->lock);
+		return -1;
+	if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) {
+		if(sect_addr>=ADDR_32MB){
+			spi_generic_select_die( bank, 1,ctrl_drv);
+			had_switch_die = 1;
+			sect_addr-=ADDR_32MB;
+    if (ractrends_spiflash_flash_id[bank] == 0x00EF1940)
+        u8 reg_data;
+        command[0] = 0x15; /* Read Status Register S23 ~ S16 */
+        cmd_size = 1;
+        retval = ctrl_drv->spi_transfer(bank,command, cmd_size ,SPI_READ, &reg_data, 1);
+        pwr_up_mode = (reg_data & 0x2)>>1; /* S17(ADP) field */
+	/* Logic for 4 byte address mode Enter */
+	if ( ((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE )||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+		retval = enter_4byte_addr_mode(bank, ctrl_drv);
+		if (retval < 0)
+			printk ("Unable to enter 4 byte address mode\n");
+			if(had_switch_die == 1)
+				spi_generic_select_die( bank, 0,ctrl_drv);
+	if (ractrends_spiflash_flash_id[bank]  == 0x00EF1940) w25q256_force_extended_address(bank, ctrl_drv);
+	if ((ractrends_spiflash_flash_id[bank]  == 0x002020BA) || (ractrends_spiflash_flash_id[bank]  == 0x002021BA) || (ractrends_spiflash_flash_id[bank]  == 0x00C21A20))
+		spi_generic_extended_address(bank, SPI_WRITE, (sect_addr & 0xFF000000) >> 24, ctrl_drv);
+	if ( (((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode)
+		/* Set up command buffer. */
+		command[0] = OPCODE_SE;
+		if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0xDC; // ERASE command in 4byte mode [spansion only]
+		if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0xDC; // ERASE command in 4byte mode
+		command[1] = sect_addr >> 24;
+		command[2] = sect_addr >> 16;
+		command[3] = sect_addr >> 8;
+		command[4] = sect_addr;
+		cmd_size = 5;
+	else {
+		command[1] = sect_addr >> 16;
+		command[2] = sect_addr >> 8;
+		command[3] = sect_addr;
+		cmd_size = 4;
+	spi_generic_write_enable(bank,ctrl_drv); /* Send write enable */
+	retval = ctrl_drv->spi_transfer(bank,command, cmd_size ,SPI_NONE, NULL, 0);
+	spi_generic_write_disable(bank,ctrl_drv); /* Send write disable */
+	if (ractrends_spiflash_flash_id[bank] == 0x002020BA || ractrends_spiflash_flash_id[bank] == 0x002021BA)
+		/* requires the read flag status with at latest one byte. */
+		if (require_read_flag_status(bank,ctrl_drv))
+			return -1;
+	if (retval < 0)
+		//if 4 byte mode exit
+		if ( ((sect_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+			retval = exit_4byte_addr_mode(bank, ctrl_drv);
+			if (retval < 0)
+				printk ("Unable to exit 4 byte address mode\n");
+			spi_generic_extended_address(bank, SPI_WRITE, 0x00, ctrl_drv);
+		if (retval < 0)
+	return retval;
+int
+spi_generic_read(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buff)
+	int retval = 0;
+	size_t transfer;
+	unsigned char command[6];
+	int cmd_size;
+	int  (*readfn)(int bank,unsigned char *,int , SPI_DIR, unsigned char *, unsigned long); //unsigned long);
+	int end_addr = (addr+bytes-1);
+	/* Some time zero bytes length are sent */
+	if (bytes==0)
+		return 0;
+        u8 reg_data;
+        cmd_size = 1;
+		if (addr < ADDR_32MB && end_addr >= ADDR_32MB)
+			int ErrorCode;
+			transfer = (ADDR_32MB - addr);
+			ErrorCode = spi_generic_read(map, addr, transfer, buff);
+			if (ErrorCode != 0) return ErrorCode;
+			 //fix address
+			bytes-=transfer;
+			addr+=transfer;
+			buff+=transfer;
+			end_addr = (addr+bytes-1);
+			if (bytes==0) return 0;
+		return -1;
+	if (address32 == ADDRESS_DIE_LO3_HI4_BYTE){
+		if(addr >= ADDR_32MB){
+			addr-=ADDR_32MB;
+	if (ctrl_drv->spi_burst_read)
+		readfn = ctrl_drv->spi_burst_read;
+	else
+		readfn = ctrl_drv->spi_transfer;
+	transfer=bytes;
+	if ( (( end_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE )||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+		//printk ("Trying to enter 4 byte mode\n");
+		if (retval < 0)
+		spi_generic_extended_address(bank, SPI_WRITE, (addr & 0xFF000000) >> 24, ctrl_drv);
+	while (bytes)
+			transfer=bytes;
+		else
+			transfer=ctrl_drv->max_read;
+			if (transfer > bytes)
+				transfer = bytes;
+		if (!ctrl_drv->fast_read)
+			if ( ((( end_addr  >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode )
+				/* Set up command buffer. */	/* Normal Read */
+				command[0] = OPCODE_READ;
+				if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0x13; // READ command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x13; // READ command in 4byte mode
+				command[1] = addr >> 24;
+				command[2] = addr >> 16;
+				command[3] = addr >> 8;
+				command[4] = addr;
+				cmd_size = 5;
+			else {
+				command[1] = addr >> 16;
+				command[2] = addr >> 8;
+				command[3] = addr;
+				cmd_size = 4;
+			retval = (*readfn)(bank,command, cmd_size ,SPI_READ, buff, (unsigned long)transfer);
+		else if (ctrl_drv->fast_read == 1) // Need to check Fast Read in 4 byte address mode
+				/* Set up command buffer. */   /* Fast Read */
+				command[0] = OPCODE_FAST_READ;
+				if (ractrends_spiflash_flash_id[bank] == 0x00011902) command[0] = 0x0C; // FAST_READ command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x0C; // FAST_READ command in 4byte mode
+				command[5] = 0;			/* dummy data */
+				cmd_size = 6;
+			else
+				command[4] = 0;			/* dummy data */
+				cmd_size = 5;
+		else if (ctrl_drv->fast_read == 2) // Need to check Dual Read in 4 byte address mode
+				/* Set up command buffer. */   /* Dual Read */
+				command[0] = OPCODE_DREAD;
+				cmd_size = 6;
+			else
+				cmd_size = 5;
+		else if (ctrl_drv->fast_read == 3) // Need to check 2xI/O Read in 4 byte address mode
+				/* Set up command buffer. */   /* 2xI/O Read */
+				command[0] = OPCODE_2READ;
+				cmd_size = 6;
+			else
+				cmd_size = 5;
+		if (retval < 0)
+			//if 4 byte mode, exit
+			if ( (( end_addr >= ADDR_16MB) && ((address32 == ADDRESS_LO3_HI4_BYTE)||(address32 == ADDRESS_DIE_LO3_HI4_BYTE))) || pwr_up_mode)
+				if (retval < 0)
+		bytes-=transfer;
+		addr+=transfer;
+		buff+=transfer;
+		//printk ("Trying to exit 4 byte mode\n");
+		if (retval < 0)
+	return 0;
+int
+spi_generic_write(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buff)
+	int retval;
+	size_t transfer;
+	int cmd_size = 0;
+	if (bytes==0)
+		return 0;
+        u8 reg_data;
+        cmd_size = 1;
+			int ErrorCode;
+			ErrorCode = spi_generic_write(map, addr, transfer, buff);
+			 //fix address
+			bytes-=transfer;
+			addr+=transfer;
+			buff+=transfer;
+			addr-=ADDR_32MB;
+		if (retval < 0)
+	while (bytes)
+			return -1;
+		transfer = PROGRAM_PAGE_SIZE;
+		if (bytes <  transfer)
+			transfer = bytes;
+		if (!ctrl_drv->fast_write)
+			if ( (((end_addr >= ADDR_16MB) && (address32 == ADDRESS_LO3_HI4_BYTE)) || (address32 == ADDRESS_4BYTE)) || pwr_up_mode)
+				command[0] = OPCODE_PP;
+				if (ractrends_spiflash_flash_id[bank]  == 0x00011902) command[0] = 0x12; // PROGRAM command in 4byte mode [spansion only]
+				if (address32 == ADDRESS_DIE_LO3_HI4_BYTE) command[0] = 0x12; // PROGRAM command in 4byte mode
+				cmd_size = 5;
+			else {
+				cmd_size = 4;
+		retval = ctrl_drv->spi_transfer(bank,command,cmd_size ,SPI_WRITE,
+						(unsigned char *)buff, transfer);
+				return -1;
+		if (retval < 0)
+				if (retval < 0)
+		addr+=(transfer-retval);
+		buff+=(transfer-retval);
+		bytes-=(transfer-retval);
+		if (retval < 0)
+	return 0;
+extern int spi_verbose;
+int
+spi_generic_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info,
+	int  retval;
+	u32 val;
+	int i;
+	u16 opread;
+	u16 opwrite;
+	u8 code = OPCODE_RDID;
+	//int address_mode = 0;
+	if (spi_verbose == 2)
+		printk("SPI: probing for %s devices ...\n",spi_name);
+	retval =spi_generic_write_enable(bank,ctrl_drv);
+	if (retval < 0)
+	 	return -1;
+	val = 0;
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,(unsigned char *)&val, 3);
+	val &= 0x00FFFFFF;
+	if (retval < 0)
+		spi_error(retval);
+		return -1;
+	/* Send write disable */
+	retval = spi_generic_write_disable(bank,ctrl_drv);
+	if (retval < 0)
+		return -1;
+	/* Match the ID against the table entries */
+	for (i = 0; i < spi_list_len; i++)
+		if ((spi_list[i].mfr_id == ((val)& 0xFF)) && (spi_list[i].dev_id == ((val >> 8)& 0xFFFF)))
+			/* Check Operation Mode */
+			//for Read Operation
+			opread = (spi_list[i].operationmode & 0xFFFF);
+			opread &= ctrl_drv->operation_mode_mask;
+			if (opread > 0x7)
+				ctrl_drv->fast_read = 3;
+			else if ((0x3 < opread) && (opread  <= 0x7))
+				ctrl_drv->fast_read = 2;
+			else if ((0x1 < opread) && (opread <= 0x3))
+				ctrl_drv->fast_read = 1;
+			else if (opread <= 0x1)
+				ctrl_drv->fast_read = 0;
+			//for Write Operation
+			opwrite = (spi_list[i].operationmode >> 16);
+			opwrite &= (ctrl_drv->operation_mode_mask >> 16);
+			if (opwrite <= 0x1)
+				ctrl_drv->fast_write = 0;
+		  break;
+	if (i == spi_list_len)
+//		if (spi_verbose == 2)
+//			printk("%s : Unrecognized ID (0x%x) got \n",spi_name,val);
+		return -1;
+	memcpy(chip_info,&spi_list[i],sizeof(struct spi_flash_info));
+	if (spi_verbose > 0)
+		printk(KERN_INFO"Found SPI Chip %s \n",spi_list[i].name);
+	return 0;
+EXPORT_SYMBOL(spi_generic_probe);
+EXPORT_SYMBOL(spi_generic_erase);
+EXPORT_SYMBOL(spi_generic_read);
+EXPORT_SYMBOL(spi_generic_write);
+EXPORT_SYMBOL(spi_generic_write_disable);
+EXPORT_SYMBOL(spi_generic_write_enable);
+EXPORT_SYMBOL(spi_generic_read_status);
+EXPORT_SYMBOL(spi_generic_write_status);
+MODULE_DESCRIPTION("MTD SPI driver for Generic SPI flash chips");
+#endif
diff --git a/drivers/mtd/spichips/intels33.c b/drivers/mtd/spichips/intels33.c
index 0000000..6900319
--- /dev/null
+++ b/drivers/mtd/spichips/intels33.c
@@ -0,0 +1,96 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info s33_data [] =
+	/* Intel S33  64 K Sectors */
+	{ "Intel S33 16Mb"  , 0x89, 0x1189, 0x00010001, 0x200000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "Intel S33 32Mb"  , 0x89, 0x1289, 0x00010001, 0x400000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "Intel S33 64Mb"  , 0x89, 0x1389, 0x00010001, 0x800000 , 68 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+static
+int
+s33_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"intel s33",
+						s33_data,ARRAY_SIZE(s33_data));
+	if (retval == -1)
+		return retval;
+	/* UnProctect all sectors */
+ 	/* SRWD=0 (Bit 7)  BP0,BP1,BP2 = 0 (Bit 2,3,4) */
+		printk("intel s33: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver s33_driver =
+	.name 		= "intel s33",
+	.probe	 	= s33_probe,
+int
+s33_init(void)
+	sema_init(&s33_driver.lock, 1);
+	s33_driver.probe	 		= s33_probe;
+	s33_driver.erase_sector 	= spi_generic_erase;
+	s33_driver.read_bytes		= spi_generic_read;
+	s33_driver.write_bytes		= spi_generic_write;
+#endif
+	register_spi_chip_driver(&s33_driver);
+	return 0;
+void
+s33_exit(void)
+	unregister_spi_chip_driver(&s33_driver);
+	return;
+module_init(s33_init);
+module_exit(s33_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Intel S33 flash chips");
+#endif
diff --git a/drivers/mtd/spichips/m25pxx.c b/drivers/mtd/spichips/m25pxx.c
index 0000000..448fe06
--- /dev/null
+++ b/drivers/mtd/spichips/m25pxx.c
@@ -0,0 +1,121 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info m25pxx_data [] =
+	/* ST Micro 32K Sectors */
+	{ "ST Micro m25p05A" , 0x20, 0x1020, 0x00010001, 0x010000 , 50 * 1000000, 1, 0x00, {{ 0, 32  * 1024, 2   },} },
+	{ "ST Micro m25p10A" , 0x20, 0x1120, 0x00010001, 0x020000 , 50 * 1000000, 1, 0x00, {{ 0, 32  * 1024, 4   },} },
+	/* ST Micro 64 K Sectors */
+	{ "ST Micro m25p20"  , 0x20, 0x1220, 0x00010001, 0x040000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 4   },} },
+	{ "ST Micro m25p40"  , 0x20, 0x1320, 0x00010001, 0x080000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	{ "ST Micro m25p80"  , 0x20, 0x1420, 0x00010001, 0x100000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "ST Micro m25p16"  , 0x20, 0x1520, 0x00010001, 0x200000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "ST Micro m25p32"  , 0x20, 0x1620, 0x00010001, 0x400000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "ST Micro m25p64"  , 0x20, 0x1720, 0x00010001, 0x800000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "ST Micro m25px64"  , 0x20, 0x1771, 0x00010001, 0x800000 , 75 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	/* ST Micro 256K Sectors */
+	{ "ST Micro m25p128" , 0x20, 0x1820, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 256 * 1024, 64  },} },
+	/* ST Micro 64 K Sectors, 25MHz speed */
+	{ "ST Micro m45p20"  , 0x20, 0x1240, 0x00010001, 0x040000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 4   },} },
+	{ "ST Micro m45p40"  , 0x20, 0x1340, 0x00010001, 0x080000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 8   },} },
+	{ "ST Micro m45p80"  , 0x20, 0x1440, 0x00010001, 0x100000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 16  },} },
+	{ "ST Micro m45p16"  , 0x20, 0x1540, 0x00010001, 0x200000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32  },} },
+	{ "ST Micro m45p32"  , 0x20, 0x1640, 0x00010001, 0x400000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64  },} },
+	{ "ST Micro m45p64"  , 0x20, 0x1740, 0x00010001, 0x800000 , 25 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+static
+int
+m25pxx_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"m25pxx",
+						m25pxx_data,ARRAY_SIZE(m25pxx_data));
+	if (retval == -1)
+		return retval;
+		printk("m25pxx: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver m25pxx_driver =
+	.name 		= "m25pxx",
+	.probe	 	= m25pxx_probe,
+int
+m25pxx_init(void)
+	sema_init(&m25pxx_driver.lock, 1);
+	m25pxx_driver.probe	 		= m25pxx_probe;
+	m25pxx_driver.erase_sector 	= spi_generic_erase;
+	m25pxx_driver.read_bytes	= spi_generic_read;
+	m25pxx_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&m25pxx_driver);
+	return 0;
+void
+m25pxx_exit(void)
+	unregister_spi_chip_driver(&m25pxx_driver);
+	return;
+module_init(m25pxx_init);
+module_exit(m25pxx_exit);
+MODULE_DESCRIPTION("MTD SPI driver for ST M25Pxx flash chips");
+#endif
diff --git a/drivers/mtd/spichips/macronix.c b/drivers/mtd/spichips/macronix.c
index 0000000..176d101
--- /dev/null
+++ b/drivers/mtd/spichips/macronix.c
@@ -0,0 +1,208 @@
+#ifdef __UBOOT__
+#endif
+#define CMD_MX25XX_RDSCUR		0x2B	/* Read security register */
+#define CMD_MX25XX_RDCR			0x15	/* Read configuration register */
+/* Security register */
+#define SCUR_BIT2			0x04
+/* Configuration register */
+#define CR_BIT5				0x20
+#define MX25L25x35E_MFR_ID 0xC2
+#define MX25L25x35E_DEV_ID 0x1920
+static struct spi_flash_info macronix_data [] =
+	/* Macronix 64 K Sectors */
+	{ "Macronix MX25L1605D" , 0xC2, 0x1520, 0x0001000B, 0x200000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 32 },} },
+	{ "Macronix MX25L3205D" , 0xC2, 0x1620, 0x0001000B, 0x400000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 64 },} },
+	{ "Macronix MX25L6405D" , 0xC2, 0x1720, 0x0001000B, 0x800000 , 66 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Macronix MX25L12805D", 0xC2, 0x1820, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+   	{ "Macronix MX25L25635E", 0xC2, 0x1920, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+    	{ "Macronix MX25L25735E", 0xC2, 0x1920, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x01, {{ 0, 64  * 1024, 512 },} },
+    	{ "Macronix MX66L51235F", 0xC2, 0x1A20, 0x0001000F, 0x4000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 1024 },} },
+    	{ "EON EN25QH256",        0x1C, 0x1970, 0x0001000F, 0x2000000, 50 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+/* to dinstinguish between MX25L25635/MX25L25735 E and F type */
+static int read_security_register(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = CMD_MX25XX_RDSCUR;
+	int retval;
+	unsigned char scur_reg;
+	/* Issue Controller Transfer Routine*/
+	retval = ctrl_drv->spi_transfer(bank,&code, 1,SPI_READ,&scur_reg, 1);
+	if (retval < 0)
+		printk ("Could not read security register\n");
+		return -1;
+	/* 0x00 - 3 byte mode
+	   0x04 - 4 byte mode */
+	scur_reg &= SCUR_BIT2;
+	if(scur_reg == 0x04)
+		return ADDRESS_4BYTE;		// MX25L25735E
+	else
+		return ADDRESS_LO3_HI4_BYTE;	// MX25L25635E, MX25L25635F, MX25L25735F
+	return 0;
+/* to dinstinguish MX25L25635/MX25L25735 F type */
+static int read_configuration_register(int bank, struct spi_ctrl_driver *ctrl_drv)
+	u8 code = CMD_MX25XX_RDCR;
+	int retval;
+	unsigned char conf_reg;
+	retval = ctrl_drv->spi_transfer(bank,&code,1,SPI_READ,&conf_reg,1);
+	if (retval < 0)
+		printk ("Could not read configuration register\n");
+		return -1;
+	if (conf_reg == 0xFF) conf_reg = 0x00; // invalid value (maybe unsupported the RDCR command)
+	   0x20 - 4 byte mode */
+	conf_reg &= CR_BIT5;
+	if(conf_reg == CR_BIT5)
+		return ADDRESS_4BYTE;		// MX25L25735F
+	else
+		return ADDRESS_LO3_HI4_BYTE;	// MX25L25635E or MX25L25635F
+	return 0;
+static
+int
+macronix_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	int address_mode = 0;
+	int i=0;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"macronix",
+						macronix_data,ARRAY_SIZE(macronix_data));
+	if (retval == -1)
+		return retval;
+	/* MX25L25635E, MX25L25735E, MX25L25635F, MX25L25735F - the same ID code */
+	if((chip_info->mfr_id == MX25L25x35E_MFR_ID) && (chip_info->dev_id == MX25L25x35E_DEV_ID))
+		address_mode = read_security_register(bank, ctrl_drv);
+		if (address_mode == ADDRESS_LO3_HI4_BYTE) address_mode = read_configuration_register(bank, ctrl_drv);
+		if (address_mode == -1)
+			return address_mode;
+		if(chip_info->address32 != address_mode)
+			memset(chip_info,0,sizeof(struct spi_flash_info));
+			for (i = 0; i < (ARRAY_SIZE(macronix_data)); i++)
+				if((macronix_data[i].mfr_id == MX25L25x35E_MFR_ID) && (macronix_data[i].dev_id == MX25L25x35E_DEV_ID))
+					if(macronix_data[i].address32 == address_mode)
+					   break;
+			memcpy(chip_info,&macronix_data[i],sizeof(struct spi_flash_info));
+		printk("macronix: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver macronix_driver =
+	.name 		= "macronix",
+	.probe	 	= macronix_probe,
+int
+macronix_init(void)
+	sema_init(&macronix_driver.lock, 1);
+	macronix_driver.probe	 		= macronix_probe;
+	macronix_driver.erase_sector 	= spi_generic_erase;
+	macronix_driver.read_bytes	= spi_generic_read;
+	macronix_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&macronix_driver);
+	return 0;
+void
+macronix_exit(void)
+	unregister_spi_chip_driver(&macronix_driver);
+	return;
+module_init(macronix_init);
+module_exit(macronix_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Macronix flash chips");
+#endif
diff --git a/drivers/mtd/spichips/micron.c b/drivers/mtd/spichips/micron.c
index 0000000..e9f44ab
--- /dev/null
+++ b/drivers/mtd/spichips/micron.c
@@ -0,0 +1,104 @@
+#ifdef __UBOOT__
+#endif
+/* Name, ID1, ID2 , Size, Clock, Erase regions, address mode, { Offset, Erase Size, Erase Block Count } */
+static struct spi_flash_info micron_data [] =
+	/* Micron 64 K Sectors */
+	{ "Micron/Numonyx N25Q00A"  , 0x20, 0x21BA, 0x00010001, 0x8000000  , 108 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 2048 },} },
+	{ "Micron/Numonyx N25Q512A"  , 0x20, 0x20BA, 0x00010001, 0x4000000 , 108 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 1024 },} },
+	{ "Micron/Numonyx N25Q256A"  , 0x20, 0x19BA, 0x00010001, 0x2000000 , 108 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+    { "Micron/Numonyx n25q128" , 0x20, 0x18BA, 0x00010001, 0x1000000, 50 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+static
+int
+micron_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"micron",
+						micron_data,ARRAY_SIZE(micron_data));
+	if (retval == -1)
+		return retval;
+		printk("micron: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver micron_driver =
+	.name 		= "micron",
+	.probe	 	= micron_probe,
+int
+micron_init(void)
+	sema_init(&micron_driver.lock,1);
+	micron_driver.probe	 		= micron_probe;
+	micron_driver.erase_sector 	= spi_generic_erase;
+	micron_driver.read_bytes	= spi_generic_read;
+	micron_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&micron_driver);
+	return 0;
+void
+micron_exit(void)
+	unregister_spi_chip_driver(&micron_driver);
+	return;
+module_init(micron_init);
+module_exit(micron_exit);
+MODULE_DESCRIPTION("MTD SPI driver for micron flash chips");
+#endif
diff --git a/drivers/mtd/spichips/spansion.c b/drivers/mtd/spichips/spansion.c
index 0000000..33a7bca
--- /dev/null
+++ b/drivers/mtd/spichips/spansion.c
@@ -0,0 +1,103 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info spansion_data [] =
+	/* Spansion 64 K Sectors */
+	{ "Spansion S25FL064A"  , 0x01, 0x1602, 0x00010001, 0x800000  , 104 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Spansion S25FL128P"  , 0x01, 0x1820, 0x00010001, 0x1000000 , 104 * 1000000, 1, 0x00, {{ 0, 64  * 1024, 256 },} },
+	{ "Spansion S25FL256S"  , 0x01, 0x1902, 0x00010001, 0x2000000 , 104 * 1000000, 1, 0x02, {{ 0, 64  * 1024, 512 },} },
+static
+int
+spansion_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"spansion",
+						spansion_data,ARRAY_SIZE(spansion_data));
+	if (retval == -1)
+		return retval;
+		printk("spansion: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver spansion_driver =
+	.name 		= "spansion",
+	.probe	 	= spansion_probe,
+int
+spansion_init(void)
+	sema_init(&spansion_driver.lock, 1);
+	spansion_driver.probe	 		= spansion_probe;
+	spansion_driver.erase_sector 	= spi_generic_erase;
+	spansion_driver.read_bytes	= spi_generic_read;
+	spansion_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&spansion_driver);
+	return 0;
+void
+spansion_exit(void)
+	unregister_spi_chip_driver(&spansion_driver);
+	return;
+module_init(spansion_init);
+module_exit(spansion_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Spansion flash chips");
+#endif
diff --git a/drivers/mtd/spichips/spiaccess.c b/drivers/mtd/spichips/spiaccess.c
index 0000000..5412f72
--- /dev/null
+++ b/drivers/mtd/spichips/spiaccess.c
@@ -0,0 +1,433 @@
+int spi_verbose = 1;
+/*           Low level functions which finally talk to the chip driver              */
+static void inline
+chip_unlock_sector(struct map_info *map, unsigned long sect_addr,int unlock)
+	if (!priv->chip_drv->unlock_sector)
+		return;
+	(*priv->chip_drv->unlock_sector)(map,sect_addr,unlock);
+	return;
+static int inline
+chip_is_sector_locked(struct map_info *map, unsigned long sect_addr)
+	if (!priv->chip_drv->is_sector_locked)
+		return 0;
+	return (*priv->chip_drv->is_sector_locked)(map,sect_addr);
+static int inline
+chip_read_bytes(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buf)
+	if (!priv->chip_drv->read_bytes)
+		return -1;
+	return (*priv->chip_drv->read_bytes)(map,addr,bytes,buf);
+static int inline
+chip_write_bytes(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buf)
+	if (!priv->chip_drv->write_bytes)
+		return -1;
+	return (*priv->chip_drv->write_bytes)(map,addr,bytes,buf);
+static int inline
+chip_erase_sector(struct map_info *map, unsigned long sect_addr)
+	if (!priv->chip_drv->erase_sector)
+		return -1;
+	return (*priv->chip_drv->erase_sector)(map,sect_addr);
+void
+spi_flash_sync(struct mtd_info *mtd)
+	struct map_info *map = mtd->priv;
+	struct spi_flash_private *priv = map->fldrv_priv;
+	if (!priv->chip_drv->sync)
+		return;
+	(*priv->chip_drv->sync)(map);
+	return;
+int
+spi_flash_suspend(struct mtd_info *mtd)
+	if (!priv->chip_drv->suspend)
+		return -EINVAL;
+	return (*priv->chip_drv->suspend)(map);
+void
+spi_flash_resume(struct mtd_info *mtd)
+	if (!priv->chip_drv->resume)
+		return;
+	(*priv->chip_drv->resume)(map);
+	return;
+/*  Intermediate Functions which interfaces mtd functionss to chip driver fucntions */
+static int
+spi_flash_do_unlock(struct mtd_info *mtd, loff_t ofs, uint32_t len,
+			       int is_unlock)
+	struct map_info *map;
+	struct mtd_erase_region_info *merip;
+	int eraseoffset, erasesize, eraseblocks;
+	int i;
+	int retval = 0;
+	int lock_status;
+	map = mtd->priv;
+	/* Pass the whole chip through sector by sector and check for each
+	   sector if the sector and the given interval overlap */
+	for(i = 0; i < mtd->numeraseregions; i++)
+		merip = &mtd->eraseregions[i];
+		eraseoffset = merip->offset;
+		erasesize = merip->erasesize;
+		eraseblocks = merip->numblocks;
+		if (ofs > eraseoffset + erasesize)
+			continue;
+		while (eraseblocks > 0)
+			if (ofs < eraseoffset + erasesize && ofs + len > eraseoffset)
+				chip_unlock_sector(map, eraseoffset, is_unlock);
+				lock_status = chip_is_sector_locked(map, eraseoffset);
+				if (is_unlock && lock_status)
+					printk("Cannot unlock sector at address %x length %xx\n",
+					       eraseoffset, merip->erasesize);
+					retval = -1;
+				else if (!is_unlock && !lock_status)
+					printk("Cannot lock sector at address %x length %x\n",
+					retval = -1;
+			eraseoffset += erasesize;
+			eraseblocks --;
+	return retval;
+static int
+read_one_chip(struct map_info *map, struct flchip *chip,
+			       loff_t adr, size_t len, u_char *buf)
+	uint32_t	i;
+	size_t bytes;
+	chip->state = FL_READY;
+	bytes = SPI_READ_PAGE_SIZE;
+	i = 0;
+	while (len >= bytes)
+		if (0 != chip_read_bytes(map,adr,bytes,&buf [i]))
+			printk (KERN_ERR "spi_read failed in read_one_chip function\n");
+			return -1;
+		len -= bytes;
+		i   += bytes;
+		adr += bytes;
+	if (0 != len)
+		if (0 != chip_read_bytes(map, adr, len, &buf [i]))
+			return -1;
+	return 0;
+static int
+write_one_chip(struct map_info *map, struct flchip *chip,
+	                        loff_t addr, size_t len, const u_char * buf)
+	uint32_t page_size, page_offset;
+	uint32_t i;
+	chip->state = FL_WRITING;
+	/* what page do we start with? */
+	page_offset = addr % SPI_WRITE_PAGE_SIZE;
+	/* do all the bytes fit onto one page? */
+	if (page_offset + len <= SPI_WRITE_PAGE_SIZE)
+		if (0 != chip_write_bytes (map, addr, len, buf))
+			printk (KERN_ERR "spi writing in the spi_write_bytes function failed\n");
+			return -1;
+	else
+		/* the size of data remaining on the first page */
+		page_size = SPI_WRITE_PAGE_SIZE - page_offset;
+		if (0 != chip_write_bytes (map, addr, page_size, buf))
+			return -1;
+		/* write everything in PAGESIZE chunks */
+		for (i = page_size; i < len; i += page_size)
+			page_size = len - i;
+			if (page_size > SPI_WRITE_PAGE_SIZE)
+				page_size = SPI_WRITE_PAGE_SIZE;
+			if (0 != chip_write_bytes (map, (addr + i), page_size, (buf + i)))
+				return -1;
+	return 0;
+static  int
+erase_one_block(struct map_info *map, struct flchip *chip,ulong addr)
+	int	retval = 0;
+	chip->state = FL_ERASING;
+	retval = chip_erase_sector (map,addr);
+	return (retval);
+/*  		                       MTD Functions 					                */
+int
+spi_flash_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
+	return spi_flash_do_unlock(mtd, ofs, len, 1);
+int
+spi_flash_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
+	return spi_flash_do_unlock(mtd, ofs, len, 0);
+int
+spi_flash_read(struct mtd_info *mtd, loff_t from, size_t len,
+                                          size_t *retlen, u_char *buf)
+	struct spi_flash_private *private = map->fldrv_priv;
+	unsigned long ofs;
+	int ret = 0;
+	if ((from + len) > mtd->size)
+		printk(KERN_WARNING "%s: read request past end of device "
+		       "(0x%lx)\n", map->name, (unsigned long)from + len);
+		return -EINVAL;
+	ofs = from;
+	*retlen = 0;
+	ret = read_one_chip(map, &private->chips,ofs,len,buf);
+	if (0 == ret)
+		*retlen = len;
+	else
+		ret = -EINVAL;
+	return ret;
+int
+spi_flash_write(struct mtd_info *mtd, loff_t to , size_t len,
+                                       size_t *retlen, const u_char *buf)
+	if (to > mtd->size)
+		printk (KERN_ERR "write address > size of spi flash\n");
+		return -EINVAL;
+	if ((len + to) > mtd->size)
+		printk (KERN_ERR "write address + size > size of spi flash\n");
+		return -EINVAL;
+	*retlen = 0;
+	if (!len)
+		return 0;
+	if (0 == write_one_chip(map, &private->chips, to, len, buf))
+		*retlen = len;
+		return 0;
+	return -EINVAL;
+int
+spi_flash_erase(struct mtd_info *mtd, struct erase_info *instr)
+	unsigned long adr, len;
+	int ret = 0;
+	int i;
+	int first;
+	struct mtd_erase_region_info *regions = mtd->eraseregions;
+	if (instr->addr > mtd->size)
+		return -EINVAL;
+	if ((instr->len + instr->addr) > mtd->size)
+		return -EINVAL;
+	/* Check that both start and end of the requested erase are
+	 * aligned with the erasesize at the appropriate addresses.
+	i = 0;
+        /* Skip all erase regions which are ended before the start of
+           the requested erase. Actually, to save on the calculations,
+           we skip to the first erase region which starts after the
+           start of the requested erase, and then go back one.
+        while ((i < mtd->numeraseregions) &&
+	       (instr->addr >= regions[i].offset))
+               i++;
+        i--;
+	/* OK, now i is pointing at the erase region in which this
+	 * erase request starts. Check the start of the requested
+	 * erase range is aligned with the erase size which is in
+	 * effect here.
+	if (instr->addr & (regions[i].erasesize-1))
+		return -EINVAL;
+	/* Remember the erase region we start on. */
+	first = i;
+	/* Next, check that the end of the requested erase is aligned
+	 * with the erase region at that address.
+	       ((instr->addr + instr->len) >= regions[i].offset))
+                i++;
+	/* As before, drop back one to point at the region in which
+	 * the address actually falls.
+	i--;
+	if ((instr->addr + instr->len) & (regions[i].erasesize-1))
+                return -EINVAL;
+	adr = instr->addr;
+	len = instr->len;
+	i = first;
+	while (len)
+		ret = erase_one_block(map, &private->chips, adr);
+		if (ret)
+			return ret;
+		adr += regions[i].erasesize;
+		len -= regions[i].erasesize;
+	instr->state = MTD_ERASE_DONE;
+	mtd_erase_callback(instr);
+	return 0;
diff --git a/drivers/mtd/spichips/spiflash.h b/drivers/mtd/spichips/spiflash.h
new file mode 100644
index 0000000..2ec2eb4
--- /dev/null
+++ b/drivers/mtd/spichips/spiflash.h
@@ -0,0 +1,178 @@
+#ifndef __LINUX_SPI_H__
+#define __LINUX_SPI_H__
+#include <linux/kernel.h>
+#include <linux/module.h>
+#include <linux/types.h>
+#include <linux/sched.h>
+#include <linux/errno.h>
+#include <linux/init.h>
+#include <linux/slab.h>
+#include <linux/list.h>
+#include <linux/string.h>
+#include <linux/spinlock.h>
+#include <linux/device.h>
+#include <linux/interrupt.h>
+#include <linux/mtd/mtd.h>
+#include <linux/mtd/map.h>
+#include <linux/mtd/partitions.h>
+#include <linux/mtd/flashchip.h>
+#include <linux/dma-mapping.h>
+#include <linux/wait.h>
+#include <linux/delay.h>
+#include <asm/delay.h>
+#include <linux/semaphore.h>
+#define CFG_FLASH_SPI_DRIVER 1   /* Need for compile the modules */
+ The folllowing should match exactly with its uboot counterpart spiflash.h
+#define DEVICE_TYPE_X8	(8 / 8)
+#define DEVICE_TYPE_X16	(16 / 8)
+#define DEVICE_TYPE_X32	(32 / 8)
+#define SPI_READ_PAGE_SIZE (4*1024)			/* 4K page size */
+#define SPI_WRITE_PAGE_SIZE  256
+#define MAX_ERASE_REGIONS    4
+struct spi_flash_info
+	const char *name;
+	const __u8  mfr_id;
+	const __u16 dev_id;
+	const __u32 operationmode;
+	const uint64_t size;
+	const unsigned int max_clock;
+	const int numeraseregions;
+	const __u8 address32;
+	const struct mtd_erase_region_info regions[MAX_ERASE_REGIONS];
+typedef enum spidir
+	SPI_NONE = 0,
+	SPI_READ = 1,
+	SPI_WRITE = 2
+} SPI_DIR;
+	struct module *module;
+	struct semaphore lock;
+	char *name;
+	struct list_head list;
+	/* Supports operation mode */
+	int operation_mode_mask;
+	/* Supports fast read at higher frequency */
+	int  fast_read;
+	/* Supports fast write at higher frequency */
+	int  fast_write;
+	/* Max datasize to be used to read type functions in spi_transfer*/
+	int  max_read;
+	/* spi_transfer can be used for all type of spi access */
+	int  (*spi_transfer)(int bank,unsigned char *cmd,int cmdlen, SPI_DIR dir,
+				unsigned char *data, unsigned long datalen);
+	/* spi_burst_read is not NULL, if the ctrl supports read large data continuosly */
+	int  (*spi_burst_read)(int bank,unsigned char *cmd,int cmdlen, SPI_DIR dir,
+	int (*spi_configure_clock)(int bank, unsigned int clock);
+#ifdef __UBOOT__
+	int  (*spi_init)(void);
+#endif
+	char *name;
+	int (*probe)(int bank,struct spi_ctrl_driver *ctlr_drv, struct spi_flash_info *chip_info);
+	void (*unlock_sector)   (struct map_info *map, unsigned long sect_addr,int unlock);
+	int  (*is_sector_locked)(struct map_info *map, unsigned long sect_addr);
+	int  (*erase_sector)	(struct map_info *map, unsigned long sect_addr);
+	int  (*read_bytes)      (struct map_info *map, loff_t addr, size_t bytes, unsigned char *buf);
+	int  (*write_bytes)     (struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buf);
+	void (*sync)		(struct map_info *map);
+	int  (*suspend)		(struct map_info *map);
+	void (*resume)		(struct map_info *map);
+struct spi_flash_private
+	int device_type;
+	int interleave;
+	int numchips;
+	unsigned long chipshift;
+	__u8 address32;
+	struct flchip chips;
+	struct spi_chip_driver *chip_drv;
+	struct spi_ctrl_driver *ctrl_drv;
+/* SPI Core Functions to register,access chip and controller drivers */
+struct spi_chip_driver *get_spi_chip_driver_by_index (int index);
+struct spi_chip_driver *get_spi_chip_driver_by_name (const char *name);
+struct spi_ctrl_driver *get_spi_ctrl_driver_by_index (int index);
+struct spi_ctrl_driver *get_spi_ctrl_driver_by_name (const char *name);
+void register_spi_chip_driver(struct spi_chip_driver *drv);
+void unregister_spi_chip_driver(struct spi_chip_driver *drv);
+void register_spi_ctrl_driver(struct spi_ctrl_driver *drv);
+void unregister_spi_ctrl_driver(struct spi_ctrl_driver *drv);
+/* Functions registered to MTD  for accessing the chips */
+int  spi_flash_read(struct mtd_info *, loff_t, size_t, size_t *, u_char *);
+int  spi_flash_write(struct mtd_info *, loff_t, size_t, size_t *,const u_char *);
+int  spi_flash_erase(struct mtd_info *, struct erase_info *);
+void spi_flash_sync(struct mtd_info *);
+int  spi_flash_suspend(struct mtd_info *);
+void spi_flash_resume(struct mtd_info *);
+int  spi_flash_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len);
+int  spi_flash_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len);
+/* Generic spi funtions which can be used by any spi device (if uses generic algo) */
+int spi_generic_write_enable(int bank,struct spi_ctrl_driver *ctrl_drv);
+int spi_generic_read_enable(int bank,struct spi_ctrl_driver *ctrl_drv);
+int spi_generic_read_status(int bank,struct spi_ctrl_driver *ctrl_drv,unsigned char *status);
+int spi_generic_write_status(int bank,struct spi_ctrl_driver *ctrl_drv, unsigned char status);
+int spi_generic_erase(struct map_info *map, unsigned long sect_addr);
+int spi_generic_read(struct map_info *map, loff_t addr, size_t bytes, unsigned char *buff);
+int spi_generic_write(struct map_info *map, loff_t addr, size_t bytes, const unsigned char *buff);
+int spi_generic_probe(int bank, struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info,
+			char *spi_name,struct spi_flash_info *spi_list, int spi_list_len);
+#ifdef CONFIG_SPX_FEATURE_GLOBAL_BKUP_FLASH_BANKS
+#define MAX_SPI_BANKS	(CONFIG_SPX_FEATURE_GLOBAL_FLASH_BANKS + CONFIG_SPX_FEATURE_GLOBAL_BKUP_FLASH_BANKS)
+#else
+#define MAX_SPI_BANKS	CONFIG_SPX_FEATURE_GLOBAL_FLASH_BANKS
+#endif
+#endif
diff --git a/drivers/mtd/spichips/spimtd.c b/drivers/mtd/spichips/spimtd.c
index 0000000..3c3a3c0
--- /dev/null
+++ b/drivers/mtd/spichips/spimtd.c
@@ -0,0 +1,241 @@
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+#include "spiflash.h"
+static struct mtd_info * spi_flash_probe(struct map_info *map);
+static void spi_flash_destroy(struct mtd_info *mtd);
+static struct mtd_chip_driver spi_flash_chipdrv =
+	.probe = spi_flash_probe,
+	.destroy = spi_flash_destroy,
+	.name = "spi_probe",
+unsigned long ractrends_spiflash_flash_id[MAX_SPI_BANKS];
+unsigned long ractrends_spiflash_flash_size[MAX_SPI_BANKS];
+/*                               Probe Function       			                */
+static
+int
+probe_spi_chips(struct map_info *map,struct spi_flash_private *private,
+							struct spi_flash_info *spi_info)
+	int req = 0;
+	int ctrl,chip;
+	int gotindex;
+	gotindex=0;
+	/* For Every Controller driver */
+	ctrl = 0;
+	ctrl_drv = get_spi_ctrl_driver_by_index(ctrl);
+	while (ctrl_drv != NULL)
+		/* For Every Chip driver */
+		chip = 0;
+		chip_drv = get_spi_chip_driver_by_index(chip);
+		while (chip_drv != NULL)
+			/* Probe for the chip on the controller */
+			if (chip_drv->probe(bank,ctrl_drv,spi_info) == 0)
+				/* If success, check if it is the requested index */
+				if (req == gotindex)
+					private->chip_drv = chip_drv;
+					private->ctrl_drv = ctrl_drv;
+					return 0;
+				gotindex++;
+			/* Try Next chip */
+			chip++;
+		/* Try next controller */
+		ctrl++;
+	return -1;
+static int configure_spi_clock(struct spi_ctrl_driver *ctrl_drv, int bank, unsigned int clock)
+	if (ctrl_drv->spi_configure_clock == NULL)
+		return 0;
+	return ctrl_drv->spi_configure_clock(bank, clock);
+/*                               Interfaces to MTD Module                               */
+spi_flash_probe(struct map_info *map)
+	struct mtd_info *mtd;
+	struct spi_flash_private *private;
+	struct spi_flash_info spi_info;
+	int j,i;
+	private = kmalloc(sizeof(*private) + sizeof(struct flchip) , GFP_KERNEL);
+	if (!private)
+		       "%s: kmalloc failed for private structure\n", map->name);
+		return NULL;
+	memset(private,0,sizeof(*private) + (sizeof(struct flchip)));
+	mtd = (struct mtd_info*)kmalloc(sizeof(*mtd), GFP_KERNEL);
+	if (!mtd)
+		       "%s: kmalloc failed for info structure\n", map->name);
+		return NULL;
+	memset(mtd, 0, sizeof(*mtd));
+	mtd->priv = map;
+	memset(&spi_info, 0, sizeof(spi_info));
+	if (probe_spi_chips(map,private,&spi_info) == -1)
+		       "%s: No spi compatible flash device found\n",
+		       map->name);
+		map->fldrv_priv = NULL;
+		kfree(mtd);
+		kfree(private);
+		return NULL;
+	/* Fill flash ID and size in public array */
+	ractrends_spiflash_flash_id[map->map_priv_1] = ((spi_info.mfr_id << 16) | spi_info.dev_id);
+	ractrends_spiflash_flash_size[map->map_priv_1] = spi_info.size;
+	configure_spi_clock(private->ctrl_drv, map->map_priv_1, spi_info.max_clock);
+	chips.start = 0;
+	chips.state = FL_READY;
+	/* Fill in the mtd  structures */
+	mtd->size = spi_info.size;
+	mtd->numeraseregions = spi_info.numeraseregions;
+	/* Allocate memory for erase regions */
+	mtd->eraseregions = kmalloc(sizeof(struct mtd_erase_region_info) *
+				    mtd->numeraseregions, GFP_KERNEL);
+	if (!mtd->eraseregions)
+		printk(KERN_WARNING "%s: Failed to allocate "
+		       "memory for MTD erase region info\n", map->name);
+		kfree(mtd);
+		kfree(private);
+		return NULL;
+	/* Fill in the mtd erase structures */
+	for (j = 0; j < spi_info.numeraseregions; j++)
+		mtd->eraseregions[j].offset = spi_info.regions[j].offset;
+		mtd->eraseregions[j].erasesize = spi_info.regions[j].erasesize;
+		mtd->eraseregions[j].numblocks = spi_info.regions[j].numblocks;
+		if (mtd->erasesize <  mtd->eraseregions[j].erasesize)
+			mtd->erasesize = mtd->eraseregions[j].erasesize;
+	/* Fill in the remaining mtd structure */
+	mtd->type = MTD_NORFLASH;
+	mtd->flags = MTD_CAP_NORFLASH;
+	mtd->name = map->name;
+	mtd->_erase = spi_flash_erase;
+	mtd->_read = spi_flash_read;
+	mtd->_write = spi_flash_write;
+	mtd->_sync = spi_flash_sync;
+	mtd->_suspend = spi_flash_suspend;
+	mtd->_resume = spi_flash_resume;
+	mtd->_lock = spi_flash_lock;
+	mtd->_unlock = spi_flash_unlock;
+	mtd->writesize = 1;
+	/* Fill in the private structure */
+	private->numchips = 1;
+	private->device_type = DEVICE_TYPE_X8;
+	private->interleave = 1;
+	private->address32 = spi_info.address32;
+	memcpy(&private->chips, &chips,sizeof(struct flchip) * private->numchips);
+	for (i = 0; i < private->numchips; i++)
+		init_waitqueue_head(&private->chips.wq);
+		mutex_init(&private->chips.mutex);
+	/* Fill in the map structure */
+	map->fldrv_priv = private;
+	map->bankwidth = 1;
+	map->fldrv = &spi_flash_chipdrv;
+	__module_get(THIS_MODULE);
+	return mtd;
+static void
+spi_flash_destroy(struct mtd_info *mtd)
+	kfree(private);
+int __init
+spi_flash_init(void)
+	register_mtd_chip_driver(&spi_flash_chipdrv);
+	return 0;
+void __exit
+spi_flash_exit(void)
+	unregister_mtd_chip_driver(&spi_flash_chipdrv);
+module_init(spi_flash_init);
+module_exit(spi_flash_exit);
+MODULE_DESCRIPTION("Core SPI with MTD Interface");
diff --git a/drivers/mtd/spichips/spireg.c b/drivers/mtd/spichips/spireg.c
index 0000000..09aaa51
--- /dev/null
+++ b/drivers/mtd/spichips/spireg.c
@@ -0,0 +1,180 @@
+#ifdef __UBOOT__
+#endif
+DEFINE_SPINLOCK(spi_chip_drvs_lock);
+LIST_HEAD(spi_chip_drvs_list);
+DEFINE_SPINLOCK(spi_ctrl_drvs_lock);
+LIST_HEAD(spi_ctrl_drvs_list);
+void
+register_spi_chip_driver(struct spi_chip_driver *drv)
+	spin_lock(&spi_chip_drvs_lock);
+	list_add(&drv->list, &spi_chip_drvs_list);
+	spin_unlock(&spi_chip_drvs_lock);
+void
+unregister_spi_chip_driver(struct spi_chip_driver *drv)
+	list_del(&drv->list);
+void
+register_spi_ctrl_driver(struct spi_ctrl_driver *drv)
+	spin_lock(&spi_ctrl_drvs_lock);
+	list_add(&drv->list, &spi_ctrl_drvs_list);
+	spin_unlock(&spi_ctrl_drvs_lock);
+void
+unregister_spi_ctrl_driver(struct spi_ctrl_driver *drv)
+get_spi_chip_driver_by_name (const char *name)
+	struct list_head *pos;
+	struct spi_chip_driver *ret = NULL, *this;
+	list_for_each(pos, &spi_chip_drvs_list) {
+		this = list_entry(pos, typeof(*this), list);
+		if (!strcmp(this->name, name)) {
+			ret = this;
+			break;
+	if (ret && !try_module_get(ret->module))
+		ret = NULL;
+	return ret;
+get_spi_chip_driver_by_index (int index)
+	int got;
+	got=0;
+		if (index == got) {
+			ret = this;
+			break;
+		got++;
+		ret = NULL;
+	return ret;
+get_spi_ctrl_driver_by_name (const char *name)
+	struct spi_ctrl_driver *ret = NULL, *this;
+	list_for_each(pos, &spi_ctrl_drvs_list) {
+			ret = this;
+			break;
+		ret = NULL;
+	return ret;
+get_spi_ctrl_driver_by_index (int index)
+	int got;
+	got=0;
+			ret = this;
+			break;
+		got++;
+		ret = NULL;
+	return ret;
+EXPORT_SYMBOL(get_spi_chip_driver_by_name);
+EXPORT_SYMBOL(get_spi_chip_driver_by_index);
+EXPORT_SYMBOL(get_spi_ctrl_driver_by_name);
+EXPORT_SYMBOL(get_spi_ctrl_driver_by_index);
+EXPORT_SYMBOL(register_spi_ctrl_driver);
+EXPORT_SYMBOL(unregister_spi_ctrl_driver);
+EXPORT_SYMBOL(register_spi_chip_driver);
+EXPORT_SYMBOL(unregister_spi_chip_driver);
+MODULE_DESCRIPTION("Core routines for (un)registering  spi chip and controller drivers");
+#endif
diff --git a/drivers/mtd/spichips/winbond.c b/drivers/mtd/spichips/winbond.c
index 0000000..03b203c
--- /dev/null
+++ b/drivers/mtd/spichips/winbond.c
@@ -0,0 +1,98 @@
+#ifdef __UBOOT__
+#endif
+static struct spi_flash_info winbond_data [] =
+	/* Winbond 64 K Sectors */
+	{ "Winbond W25X64" , 0xEF, 0x1730, 0x00010007, 0x800000 , 75  * 1000000,  1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q32" , 0xEF, 0x1640, 0x0001000F, 0x400000 , 75  * 1000000 , 1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q64" , 0xEF, 0x1740, 0x0001000F, 0x800000 , 80  * 1000000,  1, 0x00, {{ 0, 64  * 1024, 128 },} },
+	{ "Winbond W25Q128", 0xEF, 0x1840, 0x0001000F, 0x1000000, 104 * 1000000,  1, 0x00, {{ 0, 64  * 1024, 256 },} },
+	{ "Winbond W25Q256", 0xEF, 0x1940, 0x0001000F, 0x2000000, 104 * 1000000,  1, 0x02, {{ 0, 64  * 1024, 512 },} },
+	{ "Winbond W25M512", 0xEF, 0x1971, 0x0001000f, 0x4000000, 104 * 1000000,  2, 0x06, {{ 0, 64  * 1024, 512 },{ 0x2000000, 64  * 1024, 512 },} },
+static
+int
+winbond_probe(int bank,struct spi_ctrl_driver *ctrl_drv, struct spi_flash_info *chip_info)
+	int retval;
+	retval = spi_generic_probe(bank,ctrl_drv,chip_info,"winbond",
+						winbond_data,ARRAY_SIZE(winbond_data));
+	if (retval == -1)
+		return retval;
+		printk("winbond: Unable to Unprotect all sectors\n");
+	return retval;
+struct spi_chip_driver winbond_driver =
+	.name 		= "winbond",
+	.probe	 	= winbond_probe,
+int
+winbond_init(void)
+	sema_init(&winbond_driver.lock, 1);
+	winbond_driver.probe	 		= winbond_probe;
+	winbond_driver.erase_sector 	= spi_generic_erase;
+	winbond_driver.read_bytes	= spi_generic_read;
+	winbond_driver.write_bytes	= spi_generic_write;
+#endif
+	register_spi_chip_driver(&winbond_driver);
+	return 0;
+void
+winbond_exit(void)
+	unregister_spi_chip_driver(&winbond_driver);
+	return;
+module_init(winbond_init);
+module_exit(winbond_exit);
+MODULE_DESCRIPTION("MTD SPI driver for Winbond flash chips");
+#endif
1.9.1
#29 2019-05-14 08:51:07
wu150
已发帖子: 57
Re: 买两片 W25M512JVFIQ 测试一下
太折腾吧花那么多时间
#30 2019-05-14 08:59:22
wu150 wrote:
太折腾吧花那么多时间
没办法, 客户指定要用这种 spi nor flash, 32M字节的又小了, 只能硬着头皮上 64M的。
#31 2019-07-21 22:50:24
路人乙
已发帖子: 57
不知道打上这个补丁如何: https://github.com/betaflight/betaflight/pull/5722/files
不知道为什么最新的 Linux mtd代码都没有加上 w25m512 的驱动
#32 2022-12-16 18:21:48
ami7777
请问大家 mx66l51235f 这款64M的flash 我在uboot和kernel里面看到都是支持的 应该是没有双die的问题吧 v3s可以用这款nor-flash么?
