在u-boot-2019.10 调试 usb host 功能,能读浏览u盘目录
U-Boot 2019.10 (Feb 04 2020 - 17:43:43 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   mmc@01c0f000: 0
Loading Environment from FAT... Card did not respond to voltage select!
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
=> usb reset
resetting USB...
scanning bus usb@1c1a000 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
=> usb info
1: Hub,  USB Revision 2.0
 - u-boot EHCI Host Controller
 - Class: Hub
 - PacketSize: 64  Configurations: 1
 - Vendor: 0x0000  Product 0x0000 Version 1.0
   Configuration: 1
   - Interfaces: 1 Self Powered 0mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 1
     - Class Hub
     - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
2: Mass Storage,  USB Revision 2.10
 - Prolific Technology Inc. USB SD Card Reader      ABCDEF0123456789AB
 - Class: (from Interface) Mass Storage
 - Vendor: 0x067b  Product 0x2731 Version 1.0
   Configuration: 1
   - Interfaces: 1 Bus Powered 500mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 2
     - Class Mass Storage, Transp. SCSI, Bulk only
     - Endpoint 1 Out Bulk MaxPacket 512
     - Endpoint 2 In Bulk MaxPacket 512
1: Hub,  USB Revision 1.10
 -  U-Boot Root Hub
 - Class: Hub
 - PacketSize: 8  Configurations: 1
 - Vendor: 0x0000  Product 0x0000 Version 0.0
   Configuration: 1
     Interface: 0
     - Class Hub
     - Endpoint 1 In Interrupt MaxPacket 2 Interval 255ms
=> fatls usb 0
            System Volume Information/
       11   1.txt
            123/
1 file(s), 2 dir(s)
=> 离线
真是没想到u-boot 这么强大了.
牛叉啊, 直接克隆编译就可以在 荔枝派zero 跑吗?
f1c100s也可以不?
好
谢谢分享,晚上试用一吓
收藏,不错!
请教个问题。是不是需要接带额外供电的USB hub?
可以不用. 主板可以直接供电.
请问下大佬们,我用uboot 2019.10;为什么系统启动不了呢?(烧uboot之前都正常)
到 Starting kernel ...  后无反应。
打印信息如下:
U-Boot 2019.10 (Jan 17 2021 - 17:12:13 +0800) Allwinner Technology
DRAM:  64 MiB
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@01c28000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
290 bytes read in 2 ms (141.6 KiB/s)
2694144 bytes read in 140 ms (18.4 MiB/s)
32612 bytes read in 5 ms (6.2 MiB/s)
## Booting kernel from Legacy Image at 41000000 ...
   Image Name:   Linux-3.4.39
   Data Size:    2694080 Bytes = 2.6 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image
Using machid 0x1029 from environment
Starting kernel ...最近编辑记录 MTLINUX (2021-01-17 20:12:09)
@MTLINUX
应该是啥不匹配
感谢楼主分享, 把楼主的文件patch出来了:
diff --git a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
index 3d9168cbae..0e58454707 100644
--- a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
+++ b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
@@ -81,3 +81,11 @@
 	usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
+&ohci0 {
+	status = "okay";
+&ehci0 {
+	status = "okay";
diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi
index ebefc0fefe..a09bfdb8d2 100644
--- a/arch/arm/dts/sun8i-v3s.dtsi
+++ b/arch/arm/dts/sun8i-v3s.dtsi
@@ -177,9 +177,31 @@
 			resets = <&ccu RST_USB_PHY0>;
 			reset-names = "usb0_reset";
 			status = "disabled";
-			#phy-cells = <1>;
+			#phy-cells = <0>;
+		ehci0: usb@1c1a000 {
+			compatible = "allwinner,sun8i-h3-ehci", "generic-ehci";
+			reg = <0x01c1a000 0x100>;
+			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
+			clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
+			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
+			phys = <&usbphy 0>;
+			phy-names = "usb";
+			status = "disabled";
+		ohci0: usb@1c1a400 {
+			compatible = "allwinner,sun8i-h3-ohci", "generic-ohci";
+			reg = <0x01c1a400 0x100>;
+			interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
+					 <&ccu CLK_BUS_OHCI0>,
+					 <&ccu CLK_USB_OHCI0>;
 		ccu: clock@01c20000 {
 			compatible = "allwinner,sun8i-v3s-ccu";
 			reg = <0x01c20000 0x400>;
diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c
index 789ac72026..05336658db 100644
--- a/drivers/clk/sunxi/clk_v3s.c
+++ b/drivers/clk/sunxi/clk_v3s.c
@@ -18,6 +18,9 @@ static struct ccu_clk_gate v3s_gates[] = {
 	[CLK_BUS_MMC2]		= GATE(0x060, BIT(10)),
 	[CLK_BUS_SPI0]		= GATE(0x060, BIT(20)),
 	[CLK_BUS_OTG]		= GATE(0x060, BIT(24)),
+	[CLK_BUS_OHCI0]		= GATE(0X060, BIT(29)),
+	[CLK_BUS_EHCI0]     = GATE(0X060, BIT(26)),
 	[CLK_BUS_UART0]		= GATE(0x06c, BIT(16)),
 	[CLK_BUS_UART1]		= GATE(0x06c, BIT(17)),
@@ -26,6 +29,10 @@ static struct ccu_clk_gate v3s_gates[] = {
 	[CLK_SPI0]		= GATE(0x0a0, BIT(31)),
 	[CLK_USB_PHY0]          = GATE(0x0cc, BIT(8)),
+	[CLK_USB_OHCI0]      =GATE(0x0cc,BIT(16)),
+	[CLK_DRAM_EHCI]      =GATE(0X100, BIT(17)),
+	[CLK_DRAM_OHCI]      =GATE(0X100, BIT(18)),
 static struct ccu_reset v3s_resets[] = {
@@ -36,6 +43,9 @@ static struct ccu_reset v3s_resets[] = {
 	[RST_BUS_MMC2]		= RESET(0x2c0, BIT(10)),
 	[RST_BUS_SPI0]		= RESET(0x2c0, BIT(20)),
 	[RST_BUS_OTG]		= RESET(0x2c0, BIT(24)),
+	[RST_BUS_EHCI0]     = RESET(0X2C0, BIT(26)),
+	[RST_BUS_OHCI0]     = RESET(0X2C0, BIT(29)),
 	[RST_BUS_UART0]		= RESET(0x2d8, BIT(16)),
 	[RST_BUS_UART1]		= RESET(0x2d8, BIT(17)),
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c
index 5e8f87717f..3be3ceb6d3 100644
--- a/drivers/phy/allwinner/phy-sun4i-usb.c
+++ b/drivers/phy/allwinner/phy-sun4i-usb.c
@@ -290,9 +290,12 @@ static int sun4i_usb_phy_init(struct phy *phy)
 		if (usb_phy->id == 0)
 			sun4i_usb_phy_write(phy, PHY_RES45_CAL_EN,
 					    PHY_RES45_CAL_DATA,
 					    PHY_RES45_CAL_LEN);
+			sun4i_usb_phy0_reroute(data, false);
 		/* Adjust PHY's magnitude and rate */
 		sun4i_usb_phy_write(phy, PHY_TX_AMPLITUDE_TUNE,
@@ -306,7 +309,7 @@ static int sun4i_usb_phy_init(struct phy *phy)
 	sun4i_usb_phy_passby(phy, true);
-	sun4i_usb_phy0_reroute(data, true);
+	//sun4i_usb_phy0_reroute(data, true);
diff --git a/.config b/.config
new file mode 100644
index 0000000000..1507e133db
--- /dev/null
+++ b/.config
@@ -0,0 +1,1547 @@
+# Automatically generated file; DO NOT EDIT.
+# U-Boot 2020.04 Configuration
+CONFIG_CREATE_ARCH_SYMLINK=y
+# CONFIG_ARC is not set
+CONFIG_ARM=y
+# CONFIG_M68K is not set
+# CONFIG_MICROBLAZE is not set
+# CONFIG_MIPS is not set
+# CONFIG_NDS32 is not set
+# CONFIG_NIOS2 is not set
+# CONFIG_PPC is not set
+# CONFIG_RISCV is not set
+# CONFIG_SANDBOX is not set
+# CONFIG_SH is not set
+# CONFIG_X86 is not set
+# CONFIG_XTENSA is not set
+CONFIG_SYS_ARCH="arm"
+CONFIG_SYS_CPU="armv7"
+CONFIG_SYS_SOC="sunxi"
+CONFIG_SYS_BOARD="sunxi"
+CONFIG_SYS_CONFIG_NAME="sun8i"
+# CONFIG_SYS_ICACHE_OFF is not set
+# CONFIG_SPL_SYS_ICACHE_OFF is not set
+# CONFIG_SYS_DCACHE_OFF is not set
+# CONFIG_SPL_SYS_DCACHE_OFF is not set
+# ARM architecture
+# CONFIG_GIC_V3_ITS is not set
+CONFIG_HAS_VBAR=y
+CONFIG_HAS_THUMB2=y
+CONFIG_ARM_ASM_UNIFIED=y
+CONFIG_SYS_ARM_CACHE_CP15=y
+CONFIG_SYS_ARM_MMU=y
+# CONFIG_SYS_ARM_MPU is not set
+CONFIG_CPU_V7A=y
+CONFIG_SYS_ARM_ARCH=7
+CONFIG_SYS_CACHE_SHIFT_6=y
+CONFIG_SYS_CACHELINE_SIZE=64
+# CONFIG_ARCH_CPU_INIT is not set
+# CONFIG_SYS_ARCH_TIMER is not set
+# CONFIG_ARM_SMCCC is not set
+# CONFIG_SEMIHOSTING is not set
+CONFIG_SYS_THUMB_BUILD=y
+CONFIG_SPL_SYS_THUMB_BUILD=y
+# CONFIG_SYS_L2CACHE_OFF is not set
+# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
+CONFIG_USE_ARCH_MEMCPY=y
+CONFIG_SPL_USE_ARCH_MEMCPY=y
+CONFIG_USE_ARCH_MEMSET=y
+CONFIG_SPL_USE_ARCH_MEMSET=y
+# CONFIG_SET_STACK_SIZE is not set
+# CONFIG_ARCH_AT91 is not set
+# CONFIG_TARGET_EDB93XX is not set
+# CONFIG_TARGET_ASPENITE is not set
+# CONFIG_TARGET_GPLUGD is not set
+# CONFIG_ARCH_DAVINCI is not set
+# CONFIG_KIRKWOOD is not set
+# CONFIG_ARCH_MVEBU is not set
+# CONFIG_TARGET_APF27 is not set
+# CONFIG_ORION5X is not set
+# CONFIG_TARGET_SPEAR300 is not set
+# CONFIG_TARGET_SPEAR310 is not set
+# CONFIG_TARGET_SPEAR320 is not set
+# CONFIG_TARGET_SPEAR600 is not set
+# CONFIG_TARGET_STV0991 is not set
+# CONFIG_TARGET_X600 is not set
+# CONFIG_TARGET_FLEA3 is not set
+# CONFIG_TARGET_MX35PDK is not set
+# CONFIG_ARCH_BCM283X is not set
+# CONFIG_ARCH_BCM63158 is not set
+# CONFIG_ARCH_BCM68360 is not set
+# CONFIG_ARCH_BCM6858 is not set
+# CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
+# CONFIG_ARCH_BCMSTB is not set
+# CONFIG_TARGET_VEXPRESS_CA5X2 is not set
+# CONFIG_TARGET_VEXPRESS_CA9X4 is not set
+# CONFIG_TARGET_BCM23550_W1D is not set
+# CONFIG_TARGET_BCM28155_AP is not set
+# CONFIG_TARGET_BCMCYGNUS is not set
+# CONFIG_TARGET_BCMNSP is not set
+# CONFIG_TARGET_BCMNS2 is not set
+# CONFIG_ARCH_EXYNOS is not set
+# CONFIG_ARCH_S5PC1XX is not set
+# CONFIG_ARCH_HIGHBANK is not set
+# CONFIG_ARCH_INTEGRATOR is not set
+# CONFIG_ARCH_KEYSTONE is not set
+# CONFIG_ARCH_K3 is not set
+# CONFIG_ARCH_OMAP2PLUS is not set
+# CONFIG_ARCH_MESON is not set
+# CONFIG_ARCH_MEDIATEK is not set
+# CONFIG_ARCH_LPC32XX is not set
+# CONFIG_ARCH_IMX8 is not set
+# CONFIG_ARCH_IMX8M is not set
+# CONFIG_ARCH_IMXRT is not set
+# CONFIG_ARCH_MX23 is not set
+# CONFIG_ARCH_MX25 is not set
+# CONFIG_ARCH_MX28 is not set
+# CONFIG_ARCH_MX31 is not set
+# CONFIG_ARCH_MX7ULP is not set
+# CONFIG_ARCH_MX7 is not set
+# CONFIG_ARCH_MX6 is not set
+CONFIG_SPL_LDSCRIPT="arch/arm/cpu/armv7/sunxi/u-boot-spl.lds"
+# CONFIG_ARCH_MX5 is not set
+# CONFIG_ARCH_OWL is not set
+# CONFIG_ARCH_QEMU is not set
+# CONFIG_ARCH_RMOBILE is not set
+# CONFIG_TARGET_S32V234EVB is not set
+# CONFIG_ARCH_SNAPDRAGON is not set
+# CONFIG_ARCH_SOCFPGA is not set
+CONFIG_ARCH_SUNXI=y
+# CONFIG_ARCH_U8500 is not set
+# CONFIG_ARCH_VERSAL is not set
+# CONFIG_ARCH_VF610 is not set
+# CONFIG_ARCH_ZYNQ is not set
+# CONFIG_ARCH_ZYNQMP_R5 is not set
+# CONFIG_ARCH_ZYNQMP is not set
+# CONFIG_TEGRA is not set
+# CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
+# CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
+# CONFIG_TARGET_VEXPRESS64_JUNO is not set
+# CONFIG_TARGET_LS2080A_EMU is not set
+# CONFIG_TARGET_LS2080A_SIMU is not set
+# CONFIG_TARGET_LS1088AQDS is not set
+# CONFIG_TARGET_LS2080AQDS is not set
+# CONFIG_TARGET_LS2080ARDB is not set
+# CONFIG_TARGET_LS2081ARDB is not set
+# CONFIG_TARGET_LX2160ARDB is not set
+# CONFIG_TARGET_LX2160AQDS is not set
+# CONFIG_TARGET_HIKEY is not set
+# CONFIG_TARGET_HIKEY960 is not set
+# CONFIG_TARGET_POPLAR is not set
+# CONFIG_TARGET_LS1012AQDS is not set
+# CONFIG_TARGET_LS1012ARDB is not set
+# CONFIG_TARGET_LS1012A2G5RDB is not set
+# CONFIG_TARGET_LS1012AFRWY is not set
+# CONFIG_TARGET_LS1012AFRDM is not set
+# CONFIG_TARGET_LS1028AQDS is not set
+# CONFIG_TARGET_LS1028ARDB is not set
+# CONFIG_TARGET_LS1088ARDB is not set
+# CONFIG_TARGET_LS1021AQDS is not set
+# CONFIG_TARGET_LS1021ATWR is not set
+# CONFIG_TARGET_LS1021ATSN is not set
+# CONFIG_TARGET_LS1021AIOT is not set
+# CONFIG_TARGET_LS1043AQDS is not set
+# CONFIG_TARGET_LS1043ARDB is not set
+# CONFIG_TARGET_LS1046AQDS is not set
+# CONFIG_TARGET_LS1046ARDB is not set
+# CONFIG_TARGET_LS1046AFRWY is not set
+# CONFIG_TARGET_COLIBRI_PXA270 is not set
+# CONFIG_ARCH_UNIPHIER is not set
+# CONFIG_STM32 is not set
+# CONFIG_ARCH_STI is not set
+# CONFIG_ARCH_STM32MP is not set
+# CONFIG_ARCH_ROCKCHIP is not set
+# CONFIG_TARGET_THUNDERX_88XX is not set
+# CONFIG_ARCH_ASPEED is not set
+# CONFIG_TARGET_DURIAN is not set
+# CONFIG_TARGET_PRESIDIO_ASIC is not set
+CONFIG_SYS_TEXT_BASE=0x4a000000
+CONFIG_SPL_GPIO_SUPPORT=y
+CONFIG_SPL_LIBCOMMON_SUPPORT=y
+CONFIG_SPL_LIBGENERIC_SUPPORT=y
+CONFIG_SYS_MALLOC_F_LEN=0x400
+CONFIG_ENV_SIZE=0x20000
+CONFIG_DM_GPIO=y
+CONFIG_SPL_MMC_SUPPORT=y
+CONFIG_SPL_SERIAL_SUPPORT=y
+# CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
+CONFIG_SPL_STACK_R_ADDR=0x4fe00000
+CONFIG_SPL_SYS_MALLOC_F_LEN=0x400
+CONFIG_ERR_PTR_OFFSET=0x0
+CONFIG_NR_DRAM_BANKS=1
+CONFIG_SPL_SIZE_LIMIT=0
+CONFIG_SPL=y
+CONFIG_PRE_CON_BUF_ADDR=0x4f000000
+CONFIG_PRE_CON_BUF_SZ=4096
+CONFIG_BOOTSTAGE_STASH_ADDR=0
+CONFIG_IDENT_STRING=" Allwinner Technology"
+# CONFIG_SUN6I_P2WI is not set
+CONFIG_SUN6I_PRCM=y
+# CONFIG_AXP_PMIC_BUS is not set
+CONFIG_SUN8I_RSB=y
+CONFIG_SUNXI_SRAM_ADDRESS=0x0
+CONFIG_SUNXI_GEN_SUN6I=y
+CONFIG_SUNXI_DRAM_DW=y
+CONFIG_SUNXI_DRAM_DW_16BIT=y
+CONFIG_SUNXI_DRAM_MAX_SIZE=0x80000000
+# CONFIG_MACH_SUN4I is not set
+# CONFIG_MACH_SUN5I is not set
+# CONFIG_MACH_SUN6I is not set
+# CONFIG_MACH_SUN7I is not set
+# CONFIG_MACH_SUN8I_A23 is not set
+# CONFIG_MACH_SUN8I_A33 is not set
+# CONFIG_MACH_SUN8I_A83T is not set
+# CONFIG_MACH_SUN8I_H3 is not set
+# CONFIG_MACH_SUN8I_R40 is not set
+CONFIG_MACH_SUN8I_V3S=y
+# CONFIG_MACH_SUN8I_S3 is not set
+# CONFIG_MACH_SUN9I is not set
+# CONFIG_MACH_SUN50I is not set
+# CONFIG_MACH_SUN50I_H5 is not set
+# CONFIG_MACH_SUN50I_H6 is not set
+CONFIG_MACH_SUN8I=y
+# CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER is not set
+CONFIG_SUNXI_DRAM_DDR2=y
+# CONFIG_SUNXI_DRAM_LPDDR3_STOCK is not set
+CONFIG_SUNXI_DRAM_DDR2_V3S=y
+CONFIG_DRAM_CLK=312
+CONFIG_DRAM_ZQ=14779
+# CONFIG_DRAM_ODT_EN is not set
+CONFIG_SYS_CLK_FREQ=1008000000
+# CONFIG_UART0_PORT_F is not set
+# CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set
+CONFIG_MACPWR=""
+CONFIG_MMC0_CD_PIN=""
+CONFIG_MMC1_CD_PIN=""
+CONFIG_MMC2_CD_PIN=""
+CONFIG_MMC3_CD_PIN=""
+CONFIG_MMC1_PINS=""
+CONFIG_MMC2_PINS=""
+CONFIG_MMC3_PINS=""
+CONFIG_MMC_SUNXI_SLOT_EXTRA=2
+CONFIG_INITIAL_USB_SCAN_DELAY=0
+CONFIG_USB0_VBUS_PIN=""
+CONFIG_USB0_VBUS_DET=""
+CONFIG_USB0_ID_DET="PF6"
+CONFIG_USB1_VBUS_PIN=""
+CONFIG_USB2_VBUS_PIN=""
+CONFIG_USB3_VBUS_PIN=""
+# CONFIG_I2C0_ENABLE is not set
+# CONFIG_I2C1_ENABLE is not set
+# CONFIG_I2C2_ENABLE is not set
+# CONFIG_R_I2C_ENABLE is not set
+# CONFIG_AXP_GPIO is not set
+CONFIG_VIDEO_LCD_DCLK_PHASE=1
+CONFIG_SUNXI_DE2=y
+CONFIG_VIDEO_DE2=y
+CONFIG_SATAPWR=""
+CONFIG_GMAC_TX_DELAY=0
+# CONFIG_SPL_FS_FAT is not set
+# CONFIG_SPL_LIBDISK_SUPPORT is not set
+# CONFIG_SPL_SPI_SUPPORT is not set
+CONFIG_CPU_V7_HAS_NONSEC=y
+CONFIG_CPU_V7_HAS_VIRT=y
+CONFIG_ARCH_SUPPORT_PSCI=y
+CONFIG_ARMV7_NONSEC=y
+# CONFIG_ARMV7_BOOT_SEC_DEFAULT is not set
+CONFIG_ARMV7_VIRT=y
+CONFIG_ARMV7_PSCI=y
+CONFIG_ARMV7_PSCI_NR_CPUS=4
+CONFIG_ARMV7_LPAE=y
+CONFIG_CSF_SIZE=0x2060
+# CONFIG_CMD_DEKBLOB is not set
+# CONFIG_CMD_HDMIDETECT is not set
+CONFIG_IMX_DCD_ADDR=0x00910000
+# ARM debug
+# CONFIG_DEBUG_LL is not set
+CONFIG_SMBIOS_PRODUCT_NAME="sunxi"
+# CONFIG_DEBUG_UART is not set
+# CONFIG_AHCI is not set
+CONFIG_SPL_TEXT_BASE=0x00060
+# General setup
+CONFIG_LOCALVERSION=""
+CONFIG_LOCALVERSION_AUTO=y
+CONFIG_CC_OPTIMIZE_FOR_SIZE=y
+CONFIG_DISTRO_DEFAULTS=y
+CONFIG_ENV_VARS_UBOOT_CONFIG=y
+# CONFIG_SYS_BOOT_GET_CMDLINE is not set
+# CONFIG_SYS_BOOT_GET_KBD is not set
+CONFIG_SYS_MALLOC_F=y
+CONFIG_EXPERT=y
+CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
+# CONFIG_TOOLS_DEBUG is not set
+# CONFIG_PHYS_64BIT is not set
+CONFIG_SPL_IMAGE="spl/u-boot-spl.bin"
+CONFIG_BUILD_TARGET=""
+# CONFIG_SYS_CUSTOM_LDSCRIPT is not set
+CONFIG_PLATFORM_ELFENTRY="_start"
+# Boot images
+CONFIG_ANDROID_BOOT_IMAGE=y
+CONFIG_FIT=y
+CONFIG_FIT_EXTERNAL_OFFSET=0x0
+CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
+# CONFIG_FIT_SIGNATURE is not set
+# CONFIG_FIT_CIPHER is not set
+# CONFIG_FIT_VERBOSE is not set
+# CONFIG_FIT_BEST_MATCH is not set
+# CONFIG_SPL_FIT is not set
+# CONFIG_SPL_LOAD_FIT is not set
+# CONFIG_SPL_LOAD_FIT_FULL is not set
+CONFIG_LEGACY_IMAGE_FORMAT=y
+CONFIG_OF_BOARD_SETUP=y
+# CONFIG_OF_SYSTEM_SETUP is not set
+# CONFIG_OF_STDOUT_VIA_ALIAS is not set
+CONFIG_SYS_EXTRA_OPTIONS=""
+CONFIG_HAVE_SYS_TEXT_BASE=y
+CONFIG_ARCH_FIXUP_FDT_MEMORY=y
+# API
+# CONFIG_API is not set
+# Boot timing
+# CONFIG_BOOTSTAGE is not set
+CONFIG_BOOTSTAGE_RECORD_COUNT=30
+CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5
+CONFIG_TPL_BOOTSTAGE_RECORD_COUNT=5
+CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
+# CONFIG_SHOW_BOOT_PROGRESS is not set
+# Boot media
+# CONFIG_NAND_BOOT is not set
+# CONFIG_ONENAND_BOOT is not set
+# CONFIG_QSPI_BOOT is not set
+# CONFIG_SATA_BOOT is not set
+# CONFIG_SD_BOOT is not set
+# CONFIG_SPI_BOOT is not set
+CONFIG_BOOTDELAY=0
+# CONFIG_USE_BOOTARGS is not set
+CONFIG_USE_BOOTCOMMAND=y
+CONFIG_BOOTCOMMAND="ums 0 mmc 0:0"
+CONFIG_USE_PREBOOT=y
+CONFIG_PREBOOT=""
+# Console
+CONFIG_MENU=y
+# CONFIG_CONSOLE_RECORD is not set
+# CONFIG_DISABLE_CONSOLE is not set
+CONFIG_LOGLEVEL=4
+CONFIG_SPL_LOGLEVEL=4
+CONFIG_TPL_LOGLEVEL=4
+# CONFIG_SILENT_CONSOLE is not set
+CONFIG_PRE_CONSOLE_BUFFER=y
+CONFIG_CONSOLE_MUX=y
+CONFIG_SYS_CONSOLE_IS_IN_ENV=y
+# CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
+# CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
+# CONFIG_SYS_CONSOLE_INFO_QUIET is not set
+CONFIG_SYS_STDIO_DEREGISTER=y
+# Logging
+# CONFIG_LOG is not set
+CONFIG_LOG_DEFAULT_LEVEL=6
+CONFIG_SUPPORT_RAW_INITRD=y
+CONFIG_DEFAULT_FDT_FILE=""
+CONFIG_MISC_INIT_R=y
+# CONFIG_VERSION_VARIABLE is not set
+# CONFIG_BOARD_LATE_INIT is not set
+CONFIG_DISPLAY_CPUINFO=y
+CONFIG_DISPLAY_BOARDINFO=y
+# CONFIG_DISPLAY_BOARDINFO_LATE is not set
+# CONFIG_BOUNCE_BUFFER is not set
+# CONFIG_BOARD_TYPES is not set
+# Start-up hooks
+# CONFIG_ARCH_EARLY_INIT_R is not set
+# CONFIG_ARCH_MISC_INIT is not set
+# CONFIG_BOARD_EARLY_INIT_F is not set
+# CONFIG_BOARD_EARLY_INIT_R is not set
+# CONFIG_LAST_STAGE_INIT is not set
+# Security support
+CONFIG_HASH=y
+# Update support
+# CONFIG_UPDATE_TFTP is not set
+# CONFIG_ANDROID_AB is not set
+# Blob list
+# CONFIG_BLOBLIST is not set
+# SPL / TPL
+CONFIG_SUPPORT_SPL=y
+CONFIG_SPL_FRAMEWORK=y
+# CONFIG_SPL_FRAMEWORK_BOARD_INIT_F is not set
+CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa
+# CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set
+# PowerPC and LayerScape SPL Boot options
+# CONFIG_SPL_BOARD_INIT is not set
+# CONFIG_SPL_BOOTROM_SUPPORT is not set
+CONFIG_SPL_RAW_IMAGE_SUPPORT=y
+CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
+# CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK is not set
+CONFIG_SPL_SYS_MALLOC_SIMPLE=y
+CONFIG_SPL_STACK_R=y
+CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
+# CONFIG_SPL_SEPARATE_BSS is not set
+CONFIG_SPL_BANNER_PRINT=y
+# CONFIG_SPL_EARLY_BSS is not set
+# CONFIG_SPL_DISPLAY_PRINT is not set
+CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
+CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x50
+CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET=0x0
+# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
+CONFIG_SPL_CRC32_SUPPORT=y
+# CONFIG_SPL_CACHE_SUPPORT is not set
+# CONFIG_SPL_CPU_SUPPORT is not set
+# CONFIG_SPL_CRYPTO_SUPPORT is not set
+# CONFIG_SPL_HASH_SUPPORT is not set
+# CONFIG_SPL_DMA is not set
+# CONFIG_SPL_DM_GPIO is not set
+# CONFIG_SPL_ENV_SUPPORT is not set
+# CONFIG_SPL_FS_EXT4 is not set
+# CONFIG_SPL_FAT_WRITE is not set
+# CONFIG_SPL_FPGA_SUPPORT is not set
+# CONFIG_SPL_I2C_SUPPORT is not set
+# CONFIG_SPL_DM_MAILBOX is not set
+# CONFIG_SPL_FORCE_MMC_BOOT is not set
+# CONFIG_SPL_MMC_TINY is not set
+# CONFIG_SPL_MMC_WRITE is not set
+# CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
+# CONFIG_SPL_MTD_SUPPORT is not set
+# CONFIG_SPL_MUSB_NEW_SUPPORT is not set
+# CONFIG_SPL_NAND_SUPPORT is not set
+# CONFIG_SPL_UBI is not set
+# CONFIG_SPL_NET_SUPPORT is not set
+# CONFIG_SPL_NO_CPU_SUPPORT is not set
+# CONFIG_SPL_NOR_SUPPORT is not set
+# CONFIG_SPL_XIP_SUPPORT is not set
+# CONFIG_SPL_ONENAND_SUPPORT is not set
+# CONFIG_SPL_OS_BOOT is not set
+CONFIG_SPL_PAYLOAD="u-boot.bin"
+# CONFIG_SPL_PCI is not set
+# CONFIG_SPL_PCH_SUPPORT is not set
+# CONFIG_SPL_POST_MEM_SUPPORT is not set
+# CONFIG_SPL_DM_RESET is not set
+CONFIG_SPL_POWER_SUPPORT=y
+# CONFIG_SPL_POWER_DOMAIN is not set
+# CONFIG_SPL_RAM_SUPPORT is not set
+# CONFIG_SPL_REMOTEPROC is not set
+# CONFIG_SPL_RTC_SUPPORT is not set
+# CONFIG_SPL_SATA_SUPPORT is not set
+# CONFIG_SPL_THERMAL is not set
+# CONFIG_SPL_USB_HOST_SUPPORT is not set
+# CONFIG_SPL_USB_GADGET is not set
+# CONFIG_SPL_WATCHDOG_SUPPORT is not set
+# CONFIG_SPL_YMODEM_SUPPORT is not set
+# CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set
+# CONFIG_SPL_OPTEE is not set
+# Command line interface
+CONFIG_CMDLINE=y
+CONFIG_HUSH_PARSER=y
+CONFIG_CMDLINE_EDITING=y
+CONFIG_AUTO_COMPLETE=y
+CONFIG_SYS_LONGHELP=y
+CONFIG_SYS_PROMPT="=> "
+CONFIG_SYS_XTRACE="y"
+# Autoboot options
+CONFIG_AUTOBOOT=y
+# CONFIG_AUTOBOOT_KEYED is not set
+# CONFIG_AUTOBOOT_USE_MENUKEY is not set
+# CONFIG_AUTOBOOT_MENU_SHOW is not set
+# Commands
+# Info commands
+CONFIG_CMD_BDI=y
+# CONFIG_CMD_CONFIG is not set
+CONFIG_CMD_CONSOLE=y
+# CONFIG_CMD_CPU is not set
+# CONFIG_CMD_LICENSE is not set
+# CONFIG_CMD_PMC is not set
+# Boot commands
+CONFIG_CMD_BOOTD=y
+CONFIG_CMD_BOOTM=y
+CONFIG_BOOTM_EFI=y
+CONFIG_CMD_BOOTZ=y
+CONFIG_BOOTM_LINUX=y
+CONFIG_BOOTM_NETBSD=y
+# CONFIG_BOOTM_OPENRTOS is not set
+# CONFIG_BOOTM_OSE is not set
+CONFIG_BOOTM_PLAN9=y
+CONFIG_BOOTM_RTEMS=y
+CONFIG_BOOTM_VXWORKS=y
+CONFIG_CMD_BOOTEFI=y
+CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
+# CONFIG_CMD_BOOTEFI_HELLO is not set
+# CONFIG_CMD_BOOTEFI_SELFTEST is not set
+CONFIG_CMD_BOOTMENU=y
+# CONFIG_CMD_ADTIMG is not set
+# CONFIG_CMD_ABOOTIMG is not set
+CONFIG_CMD_ELF=y
+CONFIG_CMD_FDT=y
+CONFIG_CMD_GO=y
+CONFIG_CMD_RUN=y
+CONFIG_CMD_IMI=y
+# CONFIG_CMD_IMLS is not set
+CONFIG_CMD_XIMG=y
+# CONFIG_CMD_SPL is not set
+# CONFIG_CMD_FITUPD is not set
+# CONFIG_CMD_THOR_DOWNLOAD is not set
+# CONFIG_CMD_ZBOOT is not set
+# Environment commands
+# CONFIG_CMD_ASKENV is not set
+CONFIG_CMD_EXPORTENV=y
+CONFIG_CMD_IMPORTENV=y
+CONFIG_CMD_EDITENV=y
+# CONFIG_CMD_GREPENV is not set
+CONFIG_CMD_SAVEENV=y
+# CONFIG_CMD_ERASEENV is not set
+CONFIG_CMD_ENV_EXISTS=y
+# CONFIG_CMD_ENV_CALLBACK is not set
+# CONFIG_CMD_ENV_FLAGS is not set
+# CONFIG_CMD_NVEDIT_EFI is not set
+# CONFIG_CMD_NVEDIT_INFO is not set
+# Memory commands
+# CONFIG_CMD_BINOP is not set
+CONFIG_CMD_CRC32=y
+# CONFIG_CRC32_VERIFY is not set
+# CONFIG_CMD_EEPROM is not set
+# CONFIG_LOOPW is not set
+# CONFIG_CMD_MD5SUM is not set
+CONFIG_CMD_MEMINFO=y
+CONFIG_CMD_MEMORY=y
+# CONFIG_CMD_MX_CYCLIC is not set
+CONFIG_CMD_RANDOM=y
+# CONFIG_CMD_MEMTEST is not set
+# CONFIG_CMD_SHA1SUM is not set
+# CONFIG_CMD_STRINGS is not set
+# Compression commands
+# CONFIG_CMD_LZMADEC is not set
+# CONFIG_CMD_UNZIP is not set
+# CONFIG_CMD_ZIP is not set
+# Device access commands
+# CONFIG_CMD_ARMFLASH is not set
+# CONFIG_CMD_ADC is not set
+# CONFIG_CMD_BCB is not set
+# CONFIG_CMD_BIND is not set
+# CONFIG_CMD_CLK is not set
+# CONFIG_CMD_DEMO is not set
+# CONFIG_CMD_DFU is not set
+CONFIG_CMD_DM=y
+CONFIG_CMD_FASTBOOT=y
+# CONFIG_CMD_FPGAD is not set
+# CONFIG_CMD_FUSE is not set
+CONFIG_CMD_GPIO=y
+CONFIG_CMD_GPT=y
+CONFIG_RANDOM_UUID=y
+# CONFIG_CMD_GPT_RENAME is not set
+# CONFIG_CMD_IDE is not set
+# CONFIG_CMD_IO is not set
+# CONFIG_CMD_IOTRACE is not set
+# CONFIG_CMD_I2C is not set
+CONFIG_CMD_LOADB=y
+CONFIG_CMD_LOADS=y
+CONFIG_CMD_MMC=y
+# CONFIG_CMD_MMC_RPMB is not set
+# CONFIG_CMD_MMC_SWRITE is not set
+# CONFIG_CMD_OSD is not set
+CONFIG_CMD_PART=y
+# CONFIG_CMD_PCI is not set
+# CONFIG_CMD_PINMUX is not set
+# CONFIG_CMD_POWEROFF is not set
+# CONFIG_CMD_READ is not set
+# CONFIG_CMD_SATA is not set
+# CONFIG_CMD_SAVES is not set
+# CONFIG_CMD_SCSI is not set
+# CONFIG_CMD_SDRAM is not set
+# CONFIG_CMD_TSI148 is not set
+# CONFIG_CMD_UNIVERSE is not set
+CONFIG_CMD_USB=y
+# CONFIG_CMD_USB_SDP is not set
+CONFIG_CMD_USB_MASS_STORAGE=y
+# Shell scripting commands
+CONFIG_CMD_ECHO=y
+CONFIG_CMD_ITEST=y
+CONFIG_CMD_SOURCE=y
+CONFIG_CMD_SETEXPR=y
+# Android support commands
+CONFIG_CMD_NET=y
+CONFIG_CMD_BOOTP=y
+CONFIG_CMD_DHCP=y
+CONFIG_BOOTP_BOOTPATH=y
+CONFIG_BOOTP_DNS=y
+# CONFIG_BOOTP_DNS2 is not set
+CONFIG_BOOTP_GATEWAY=y
+CONFIG_BOOTP_HOSTNAME=y
+# CONFIG_BOOTP_PREFER_SERVERIP is not set
+CONFIG_BOOTP_SUBNETMASK=y
+# CONFIG_BOOTP_NTPSERVER is not set
+# CONFIG_CMD_PCAP is not set
+CONFIG_BOOTP_PXE=y
+CONFIG_BOOTP_PXE_CLIENTARCH=0x15
+CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
+CONFIG_CMD_TFTPBOOT=y
+# CONFIG_CMD_TFTPPUT is not set
+# CONFIG_CMD_TFTPSRV is not set
+CONFIG_NET_TFTP_VARS=y
+# CONFIG_CMD_RARP is not set
+CONFIG_CMD_NFS=y
+CONFIG_CMD_MII=y
+CONFIG_CMD_MDIO=y
+CONFIG_CMD_PING=y
+# CONFIG_CMD_CDP is not set
+# CONFIG_CMD_SNTP is not set
+# CONFIG_CMD_DNS is not set
+# CONFIG_CMD_LINK_LOCAL is not set
+# CONFIG_CMD_ETHSW is not set
+CONFIG_CMD_PXE=y
+# CONFIG_CMD_WOL is not set
+# Misc commands
+CONFIG_CMD_BMP=y
+# CONFIG_CMD_BSP is not set
+# CONFIG_CMD_BKOPS_ENABLE is not set
+CONFIG_CMD_BLOCK_CACHE=y
+# CONFIG_CMD_CACHE is not set
+# CONFIG_CMD_CONITRACE is not set
+# CONFIG_CMD_CLS is not set
+# CONFIG_CMD_EFIDEBUG is not set
+# CONFIG_CMD_EXCEPTION is not set
+# CONFIG_CMD_DATE is not set
+# CONFIG_CMD_TIME is not set
+# CONFIG_CMD_GETTIME is not set
+CONFIG_CMD_MISC=y
+# CONFIG_MP is not set
+# CONFIG_CMD_TIMER is not set
+CONFIG_CMD_SYSBOOT=y
+# CONFIG_CMD_QFW is not set
+# CONFIG_CMD_TERMINAL is not set
+# CONFIG_CMD_UUID is not set
+# TI specific command line interface
+# CONFIG_CMD_DDR3 is not set
+# Power commands
+# CONFIG_CMD_REGULATOR is not set
+# Security commands
+# CONFIG_CMD_AES is not set
+# CONFIG_CMD_BLOB is not set
+# CONFIG_CMD_HASH is not set
+# Firmware commands
+# Filesystem commands
+# CONFIG_CMD_BTRFS is not set
+CONFIG_CMD_EXT2=y
+CONFIG_CMD_EXT4=y
+# CONFIG_CMD_EXT4_WRITE is not set
+CONFIG_CMD_FAT=y
+CONFIG_CMD_FS_GENERIC=y
+# CONFIG_CMD_FS_UUID is not set
+# CONFIG_CMD_JFFS2 is not set
+# CONFIG_CMD_REISER is not set
+# CONFIG_CMD_ZFS is not set
+# Debug commands
+# CONFIG_CMD_BEDBUG is not set
+# CONFIG_CMD_DIAG is not set
+# CONFIG_CMD_LOG is not set
+# CONFIG_CMD_TRACE is not set
+# CONFIG_CMD_UBI is not set
+# Partition Types
+CONFIG_PARTITIONS=y
+# CONFIG_MAC_PARTITION is not set
+# CONFIG_SPL_MAC_PARTITION is not set
+CONFIG_DOS_PARTITION=y
+# CONFIG_SPL_DOS_PARTITION is not set
+CONFIG_ISO_PARTITION=y
+# CONFIG_SPL_ISO_PARTITION is not set
+# CONFIG_AMIGA_PARTITION is not set
+# CONFIG_SPL_AMIGA_PARTITION is not set
+CONFIG_EFI_PARTITION=y
+CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=56
+CONFIG_EFI_PARTITION_ENTRIES_OFF=0
+# CONFIG_SPL_EFI_PARTITION is not set
+CONFIG_PARTITION_UUIDS=y
+# CONFIG_SPL_PARTITION_UUIDS is not set
+# CONFIG_PARTITION_TYPE_GUID is not set
+CONFIG_SUPPORT_OF_CONTROL=y
+CONFIG_DTC=y
+CONFIG_PYLIBFDT=y
+CONFIG_DTOC=y
+CONFIG_BINMAN=y
+# Device Tree Control
+CONFIG_OF_CONTROL=y
+# CONFIG_OF_BOARD_FIXUP is not set
+# CONFIG_SPL_OF_CONTROL is not set
+# CONFIG_OF_LIVE is not set
+CONFIG_OF_SEPARATE=y
+# CONFIG_OF_EMBED is not set
+# CONFIG_OF_BOARD is not set
+# CONFIG_OF_PRIOR_STAGE is not set
+CONFIG_DEFAULT_DEVICE_TREE="sun8i-s3-generic"
+# CONFIG_MULTI_DTB_FIT is not set
+# CONFIG_OF_DTB_PROPS_REMOVE is not set
+CONFIG_MKIMAGE_DTC_PATH="dtc"
+# Environment
+CONFIG_ENV_SUPPORT=y
+# CONFIG_ENV_IS_NOWHERE is not set
+# CONFIG_ENV_IS_IN_EEPROM is not set
+CONFIG_ENV_IS_IN_FAT=y
+# CONFIG_ENV_IS_IN_EXT4 is not set
+# CONFIG_ENV_IS_IN_FLASH is not set
+# CONFIG_ENV_IS_IN_MMC is not set
+# CONFIG_ENV_IS_IN_NAND is not set
+# CONFIG_ENV_IS_IN_NVRAM is not set
+# CONFIG_ENV_IS_IN_ONENAND is not set
+# CONFIG_ENV_IS_IN_REMOTE is not set
+CONFIG_ENV_FAT_INTERFACE="mmc"
+CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto"
+CONFIG_ENV_FAT_FILE="uboot.env"
+CONFIG_SYS_RELOC_GD_ENV_ADDR=y
+# CONFIG_USE_DEFAULT_ENV_FILE is not set
+# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set
+CONFIG_NET=y
+CONFIG_NET_RANDOM_ETHADDR=y
+# CONFIG_NETCONSOLE is not set
+# CONFIG_IP_DEFRAG is not set
+CONFIG_TFTP_BLOCKSIZE=1468
+# Device Drivers
+# Generic Driver Options
+CONFIG_DM=y
+# CONFIG_SPL_DM is not set
+CONFIG_DM_WARN=y
+# CONFIG_DM_DEBUG is not set
+CONFIG_DM_DEVICE_REMOVE=y
+CONFIG_DM_STDIO=y
+CONFIG_DM_SEQ_ALIAS=y
+# CONFIG_REGMAP is not set
+# CONFIG_DEVRES is not set
+CONFIG_SIMPLE_BUS=y
+CONFIG_OF_TRANSLATE=y
+# CONFIG_TRANSLATION_OFFSET is not set
+CONFIG_DM_DEV_READ_INLINE=y
+# CONFIG_ACPIGEN is not set
+# CONFIG_ADC is not set
+# CONFIG_ADC_EXYNOS is not set
+# CONFIG_ADC_SANDBOX is not set
+# CONFIG_SARADC_MESON is not set
+# CONFIG_SARADC_ROCKCHIP is not set
+# CONFIG_SATA is not set
+# CONFIG_SCSI_AHCI is not set
+# SATA/SCSI device support
+# CONFIG_DWC_AHSATA is not set
+# CONFIG_FSL_SATA is not set
+# CONFIG_MVSATA_IDE is not set
+# CONFIG_SATA_MV is not set
+# CONFIG_SATA_SIL is not set
+# CONFIG_SATA_SIL3114 is not set
+# CONFIG_AXI is not set
+CONFIG_BLK=y
+CONFIG_HAVE_BLOCK_DEVICE=y
+CONFIG_BLOCK_CACHE=y
+# CONFIG_IDE is not set
+# CONFIG_BOOTCOUNT_LIMIT is not set
+# Cache Controller drivers
+# CONFIG_CACHE is not set
+# CONFIG_L2X0_CACHE is not set
+# CONFIG_NCORE_CACHE is not set
+# Clock
+CONFIG_CLK=y
+# CONFIG_SPL_CLK_CCF is not set
+# CONFIG_CLK_CCF is not set
+# CONFIG_CLK_HSDK is not set
+# CONFIG_CLK_CDCE9XX is not set
+# CONFIG_CLK_AT91 is not set
+CONFIG_CLK_SUNXI=y
+# CONFIG_CLK_SUN4I_A10 is not set
+# CONFIG_CLK_SUN5I_A10S is not set
+# CONFIG_CLK_SUN6I_A31 is not set
+# CONFIG_CLK_SUN8I_A23 is not set
+# CONFIG_CLK_SUN8I_A83T is not set
+# CONFIG_CLK_SUN8I_R40 is not set
+CONFIG_CLK_SUN8I_V3S=y
+# CONFIG_CLK_SUN9I_A80 is not set
+# CONFIG_CLK_SUN8I_H3 is not set
+# CONFIG_CLK_SUN50I_H6 is not set
+# CONFIG_CLK_SUN50I_A64 is not set
+# CONFIG_CLK_SIFIVE is not set
+# CONFIG_ICS8N3QV01 is not set
+# CONFIG_CLK_MPC83XX is not set
+# CONFIG_CPU is not set
+# Hardware crypto devices
+# CONFIG_FSL_CAAM is not set
+# CONFIG_SYS_FSL_SEC_BE is not set
+# CONFIG_SYS_FSL_SEC_LE is not set
+# Demo for driver model
+# CONFIG_DM_DEMO is not set
+# CONFIG_BOARD is not set
+# DFU support
+# DMA Support
+# CONFIG_DMA is not set
+# CONFIG_TI_EDMA3 is not set
+# Fastboot support
+CONFIG_FASTBOOT=y
+CONFIG_USB_FUNCTION_FASTBOOT=y
+# CONFIG_UDP_FUNCTION_FASTBOOT is not set
+CONFIG_FASTBOOT_BUF_ADDR=0x42000000
+CONFIG_FASTBOOT_BUF_SIZE=0x2000000
+CONFIG_FASTBOOT_USB_DEV=0
+CONFIG_FASTBOOT_FLASH=y
+CONFIG_FASTBOOT_FLASH_MMC=y
+CONFIG_FASTBOOT_FLASH_MMC_DEV=1
+CONFIG_FASTBOOT_GPT_NAME="gpt"
+CONFIG_FASTBOOT_MBR_NAME="mbr"
+CONFIG_FASTBOOT_CMD_OEM_FORMAT=y
+# CONFIG_FIRMWARE is not set
+# CONFIG_ZYNQMP_FIRMWARE is not set
+# FPGA support
+# CONFIG_FPGA_ALTERA is not set
+# CONFIG_FPGA_SOCFPGA is not set
+# CONFIG_FPGA_XILINX is not set
+# GPIO Support
+# CONFIG_GPIO_HOG is not set
+# CONFIG_ALTERA_PIO is not set
+# CONFIG_DWAPB_GPIO is not set
+# CONFIG_AT91_GPIO is not set
+# CONFIG_ATMEL_PIO4 is not set
+# CONFIG_DA8XX_GPIO is not set
+# CONFIG_INTEL_BROADWELL_GPIO is not set
+# CONFIG_INTEL_GPIO is not set
+# CONFIG_INTEL_ICH6_GPIO is not set
+# CONFIG_IMX_RGPIO2P is not set
+# CONFIG_HSDK_CREG_GPIO is not set
+# CONFIG_LPC32XX_GPIO is not set
+# CONFIG_MSM_GPIO is not set
+# CONFIG_MXC_GPIO is not set
+# CONFIG_MXS_GPIO is not set
+# CONFIG_CMD_PCA953X is not set
+# CONFIG_ROCKCHIP_GPIO is not set
+CONFIG_SUNXI_GPIO=y
+# CONFIG_XILINX_GPIO is not set
+# CONFIG_CMD_TCA642X is not set
+# CONFIG_TEGRA_GPIO is not set
+# CONFIG_TEGRA186_GPIO is not set
+# CONFIG_VYBRID_GPIO is not set
+# CONFIG_SIFIVE_GPIO is not set
+# CONFIG_DM_74X164 is not set
+# CONFIG_DM_PCA953X is not set
+# CONFIG_SPL_DM_PCA953X is not set
+# CONFIG_MPC8XXX_GPIO is not set
+# Hardware Spinlock Support
+# CONFIG_DM_HWSPINLOCK is not set
+# I2C support
+# CONFIG_DM_I2C is not set
+# CONFIG_SYS_I2C_DW is not set
+# CONFIG_SYS_I2C_IMX_LPI2C is not set
+# CONFIG_SYS_I2C_MXC is not set
+CONFIG_INPUT=y
+CONFIG_DM_KEYBOARD=y
+# CONFIG_CROS_EC_KEYB is not set
+# CONFIG_I8042_KEYB is not set
+# CONFIG_TEGRA_KEYBOARD is not set
+# CONFIG_TWL4030_INPUT is not set
+# LED Support
+# CONFIG_LED is not set
+# CONFIG_LED_STATUS is not set
+# Mailbox Controller Support
+# CONFIG_DM_MAILBOX is not set
+# Memory Controller drivers
+# Multifunction device drivers
+# CONFIG_MISC is not set
+# CONFIG_CROS_EC is not set
+# CONFIG_SPL_CROS_EC is not set
+# CONFIG_DS4510 is not set
+# CONFIG_FSL_SEC_MON is not set
+# CONFIG_NUVOTON_NCT6102D is not set
+# CONFIG_PWRSEQ is not set
+# CONFIG_PCA9551_LED is not set
+# CONFIG_TWL4030_LED is not set
+# CONFIG_WINBOND_W83627 is not set
+# CONFIG_FS_LOADER is not set
+# MMC Host controller Support
+CONFIG_MMC=y
+CONFIG_MMC_WRITE=y
+# CONFIG_MMC_BROKEN_CD is not set
+CONFIG_DM_MMC=y
+# CONFIG_ARM_PL180_MMCI is not set
+CONFIG_MMC_QUIRKS=y
+CONFIG_MMC_HW_PARTITIONING=y
+# CONFIG_SUPPORT_EMMC_RPMB is not set
+# CONFIG_SUPPORT_EMMC_BOOT is not set
+# CONFIG_MMC_IO_VOLTAGE is not set
+# CONFIG_SPL_MMC_IO_VOLTAGE is not set
+# CONFIG_MMC_HS400_ES_SUPPORT is not set
+# CONFIG_SPL_MMC_HS400_ES_SUPPORT is not set
+# CONFIG_MMC_HS400_SUPPORT is not set
+# CONFIG_SPL_MMC_HS400_SUPPORT is not set
+# CONFIG_MMC_HS200_SUPPORT is not set
+# CONFIG_SPL_MMC_HS200_SUPPORT is not set
+CONFIG_MMC_VERBOSE=y
+# CONFIG_MMC_TRACE is not set
+# CONFIG_MMC_DW is not set
+# CONFIG_MMC_MXC is not set
+# CONFIG_MMC_PCI is not set
+# CONFIG_MMC_OMAP_HS is not set
+# CONFIG_MMC_SDHCI is not set
+CONFIG_MMC_SUNXI=y
+# CONFIG_STM32_SDMMC2 is not set
+# CONFIG_FTSDC010 is not set
+# CONFIG_FSL_ESDHC is not set
+# CONFIG_FSL_ESDHC_IMX is not set
+# MTD Support
+# CONFIG_MTD is not set
+# CONFIG_DM_MTD is not set
+# CONFIG_MTD_NOR_FLASH is not set
+# CONFIG_FLASH_CFI_DRIVER is not set
+# CONFIG_MTD_RAW_NAND is not set
+# SPI Flash Support
+# CONFIG_SPI_FLASH is not set
+# UBI support
+# CONFIG_UBI_SILENCE_MSG is not set
+# CONFIG_MTD_UBI is not set
+# CONFIG_BITBANGMII is not set
+# CONFIG_MV88E6352_SWITCH is not set
+CONFIG_PHYLIB=y
+CONFIG_PHY_ADDR_ENABLE=y
+CONFIG_PHY_ADDR=1
+# CONFIG_B53_SWITCH is not set
+# CONFIG_MV88E61XX_SWITCH is not set
+# CONFIG_PHYLIB_10G is not set
+# CONFIG_PHY_AQUANTIA is not set
+# CONFIG_PHY_ATHEROS is not set
+# CONFIG_PHY_BROADCOM is not set
+# CONFIG_PHY_CORTINA is not set
+# CONFIG_PHY_DAVICOM is not set
+# CONFIG_PHY_ET1011C is not set
+# CONFIG_PHY_LXT is not set
+# CONFIG_PHY_MARVELL is not set
+# CONFIG_PHY_MESON_GXL is not set
+# CONFIG_PHY_MICREL is not set
+# CONFIG_PHY_MSCC is not set
+# CONFIG_PHY_NATSEMI is not set
+# CONFIG_PHY_REALTEK is not set
+# CONFIG_PHY_SMSC is not set
+# CONFIG_PHY_TERANETICS is not set
+# CONFIG_PHY_TI is not set
+# CONFIG_PHY_VITESSE is not set
+# CONFIG_PHY_XILINX is not set
+# CONFIG_PHY_XILINX_GMII2RGMII is not set
+# CONFIG_PHY_FIXED is not set
+# CONFIG_PHY_NCSI is not set
+# CONFIG_FSL_PFE is not set
+CONFIG_DM_ETH=y
+# CONFIG_DM_MDIO is not set
+CONFIG_NETDEVICES=y
+CONFIG_PHY_GIGE=y
+# CONFIG_ALTERA_TSE is not set
+# CONFIG_BCM_SF2_ETH is not set
+# CONFIG_BCMGENET is not set
+# CONFIG_DWC_ETH_QOS is not set
+# CONFIG_E1000 is not set
+# CONFIG_ETH_DESIGNWARE is not set
+# CONFIG_ETHOC is not set
+# CONFIG_FMAN_ENET is not set
+# CONFIG_FTMAC100 is not set
+# CONFIG_FTGMAC100 is not set
+# CONFIG_MCFFEC is not set
+# CONFIG_FSLDMAFEC is not set
+# CONFIG_MACB is not set
+# CONFIG_RGMII is not set
+# CONFIG_MII is not set
+# CONFIG_RTL8139 is not set
+# CONFIG_RTL8169 is not set
+# CONFIG_SMC911X is not set
+# CONFIG_SUN7I_GMAC is not set
+# CONFIG_SUN4I_EMAC is not set
+CONFIG_SUN8I_EMAC=y
+# CONFIG_SH_ETHER is not set
+# CONFIG_DRIVER_TI_CPSW is not set
+# CONFIG_DRIVER_TI_EMAC is not set
+# CONFIG_DRIVER_TI_KEYSTONE_NET is not set
+# CONFIG_SYS_DPAA_QBMAN is not set
+# CONFIG_TSEC_ENET is not set
+# CONFIG_MEDIATEK_ETH is not set
+# CONFIG_HIGMACV300_ETH is not set
+# CONFIG_PCI is not set
+# PCI Endpoint
+# CONFIG_PCI_ENDPOINT is not set
+# CONFIG_X86_PCH7 is not set
+# CONFIG_X86_PCH9 is not set
+# PHY Subsystem
+CONFIG_PHY=y
+# CONFIG_SPL_PHY is not set
+# CONFIG_NOP_PHY is not set
+# CONFIG_MSM8916_USB_PHY is not set
+CONFIG_PHY_SUN4I_USB=y
+# CONFIG_MVEBU_COMPHY_SUPPORT is not set
+# Pin controllers
+# CONFIG_PINCTRL is not set
+# Power
+# CONFIG_ACPI_PMC is not set
+# CONFIG_SPL_ACPI_PMC is not set
+# CONFIG_TPL_ACPI_PMC is not set
+# Power Domain Support
+# CONFIG_POWER_DOMAIN is not set
+# CONFIG_DM_PMIC is not set
+# CONFIG_PMIC_AS3722 is not set
+# CONFIG_POWER_MC34VR500 is not set
+CONFIG_DM_REGULATOR=y
+# CONFIG_SPL_DM_REGULATOR is not set
+CONFIG_REGULATOR_PWM=y
+# CONFIG_SPL_REGULATOR_PWM is not set
+# CONFIG_DM_REGULATOR_FIXED is not set
+# CONFIG_DM_REGULATOR_GPIO is not set
+# CONFIG_DM_REGULATOR_PBIAS is not set
+# CONFIG_DM_REGULATOR_TPS62360 is not set
+CONFIG_SUNXI_NO_PMIC=y
+# CONFIG_POWER_MT6323 is not set
+CONFIG_DM_PWM=y
+# CONFIG_PWM_EXYNOS is not set
+# CONFIG_PWM_IMX is not set
+# CONFIG_PWM_ROCKCHIP is not set
+# CONFIG_PWM_SANDBOX is not set
+# CONFIG_PWM_TEGRA is not set
+CONFIG_PWM_SUNXI=y
+# CONFIG_U_QE is not set
+# CONFIG_RAM is not set
+# Remote Processor drivers
+# Reset Controller Support
+CONFIG_DM_RESET=y
+CONFIG_RESET_SUNXI=y
+# CONFIG_RESET_HISILICON is not set
+# CONFIG_DM_RNG is not set
+# Real Time Clock
+# CONFIG_DM_RTC is not set
+# CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set
+# CONFIG_RTC_RX8025 is not set
+# CONFIG_RTC_PL031 is not set
+# CONFIG_RTC_S35392A is not set
+# CONFIG_RTC_MC146818 is not set
+# CONFIG_RTC_M41T62 is not set
+# CONFIG_SCSI is not set
+# CONFIG_DM_SCSI is not set
+# Serial drivers
+CONFIG_BAUDRATE=115200
+CONFIG_REQUIRE_SERIAL_CONSOLE=y
+CONFIG_SPECIFY_CONSOLE_INDEX=y
+CONFIG_SERIAL_PRESENT=y
+CONFIG_SPL_SERIAL_PRESENT=y
+CONFIG_CONS_INDEX=1
+CONFIG_DM_SERIAL=y
+# CONFIG_SERIAL_RX_BUFFER is not set
+# CONFIG_SERIAL_SEARCH_ALL is not set
+# CONFIG_ALTERA_JTAG_UART is not set
+# CONFIG_ALTERA_UART is not set
+# CONFIG_ARC_SERIAL is not set
+# CONFIG_ATMEL_USART is not set
+# CONFIG_BCM6345_SERIAL is not set
+# CONFIG_COREBOOT_SERIAL is not set
+# CONFIG_CORTINA_UART is not set
+# CONFIG_FSL_LINFLEXUART is not set
+# CONFIG_FSL_LPUART is not set
+# CONFIG_MVEBU_A3700_UART is not set
+# CONFIG_MCFUART is not set
+# CONFIG_NULLDEV_SERIAL is not set
+CONFIG_SYS_NS16550=y
+# CONFIG_NS16550_DYNAMIC is not set
+# CONFIG_PL01X_SERIAL is not set
+# CONFIG_MSM_SERIAL is not set
+# CONFIG_OMAP_SERIAL is not set
+# CONFIG_PXA_SERIAL is not set
+# CONFIG_SIFIVE_SERIAL is not set
+# CONFIG_MTK_SERIAL is not set
+# CONFIG_SMEM is not set
+# Sound support
+# CONFIG_SOUND is not set
+# SOC (System On Chip) specific Drivers
+# CONFIG_SOC_TI is not set
+# CONFIG_SPI is not set
+# SPMI support
+# CONFIG_SPMI is not set
+# System reset device drivers
+# CONFIG_SYSRESET is not set
+# CONFIG_SYSRESET_SYSCON is not set
+# CONFIG_SYSRESET_WATCHDOG is not set
+# CONFIG_SYSRESET_MPC83XX is not set
+# CONFIG_TEE is not set
+# CONFIG_OPTEE is not set
+# CONFIG_DM_THERMAL is not set
+# Timer Support
+# CONFIG_TIMER is not set
+# TPM support
+CONFIG_USB=y
+CONFIG_DM_USB=y
+# CONFIG_DM_USB_GADGET is not set
+# USB Host Controller Drivers
+CONFIG_USB_HOST=y
+# CONFIG_USB_XHCI_HCD is not set
+CONFIG_USB_EHCI_HCD=y
+# CONFIG_USB_EHCI_MSM is not set
+# CONFIG_USB_EHCI_PCI is not set
+CONFIG_USB_EHCI_GENERIC=y
+# CONFIG_USB_EHCI_FSL is not set
+CONFIG_USB_OHCI_HCD=y
+# CONFIG_USB_OHCI_PCI is not set
+CONFIG_USB_OHCI_GENERIC=y
+# CONFIG_USB_OHCI_DA8XX is not set
+# CONFIG_USB_UHCI_HCD is not set
+# CONFIG_USB_DWC2 is not set
+# CONFIG_USB_R8A66597_HCD is not set
+# CONFIG_USB_CDNS3 is not set
+# CONFIG_USB_DWC3 is not set
+# Legacy MUSB Support
+# CONFIG_USB_MUSB_HCD is not set
+# CONFIG_USB_MUSB_UDC is not set
+# MUSB Controller Driver
+# CONFIG_USB_MUSB_HOST is not set
+CONFIG_USB_MUSB_GADGET=y
+# CONFIG_USB_MUSB_DA8XX is not set
+# CONFIG_USB_MUSB_TI is not set
+# CONFIG_USB_MUSB_AM35X is not set
+# CONFIG_USB_MUSB_DSPS is not set
+CONFIG_USB_MUSB_SUNXI=y
+CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT=y
+CONFIG_USB_MUSB_PIO_ONLY=y
+# USB Phy
+# CONFIG_TWL4030_USB is not set
+# CONFIG_OMAP_USB_PHY is not set
+# CONFIG_ROCKCHIP_USB2_PHY is not set
+# ULPI drivers
+# USB peripherals
+CONFIG_USB_STORAGE=y
+CONFIG_USB_KEYBOARD=y
+CONFIG_USB_KEYBOARD_FN_KEYS=y
+# CONFIG_SYS_USB_EVENT_POLL is not set
+CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
+# CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP is not set
+CONFIG_USB_GADGET=y
+CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology"
+CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a
+CONFIG_USB_GADGET_PRODUCT_NUM=0x1010
+# CONFIG_USB_GADGET_ATMEL_USBA is not set
+# CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
+# CONFIG_USB_GADGET_DWC2_OTG is not set
+# CONFIG_CI_UDC is not set
+CONFIG_USB_GADGET_VBUS_DRAW=250
+CONFIG_USB_GADGET_DUALSPEED=y
+CONFIG_USB_GADGET_DOWNLOAD=y
+CONFIG_USB_FUNCTION_MASS_STORAGE=y
+# CONFIG_USB_FUNCTION_ROCKUSB is not set
+# CONFIG_USB_FUNCTION_SDP is not set
+# CONFIG_USB_FUNCTION_THOR is not set
+CONFIG_USB_ETHER=y
+# CONFIG_USB_ETH_CDC is not set
+CONFIG_USB_ETH_RNDIS=y
+CONFIG_USBNET_DEVADDR="de:ad:be:ef:00:01"
+CONFIG_USBNET_HOST_ADDR="de:ad:be:ef:00:00"
+# CONFIG_USB_HOST_ETHER is not set
+# UFS Host Controller Support
+# CONFIG_TI_J721E_UFS is not set
+# Graphics support
+CONFIG_DM_VIDEO=y
+CONFIG_BACKLIGHT_PWM=y
+# CONFIG_BACKLIGHT_GPIO is not set
+CONFIG_VIDEO_BPP8=y
+CONFIG_VIDEO_BPP16=y
+CONFIG_VIDEO_BPP32=y
+CONFIG_VIDEO_ANSI=y
+# CONFIG_VIDEO_MIPI_DSI is not set
+CONFIG_CONSOLE_NORMAL=y
+# CONFIG_CONSOLE_ROTATION is not set
+# CONFIG_CONSOLE_TRUETYPE is not set
+CONFIG_SYS_WHITE_ON_BLACK=y
+# CONFIG_NO_FB_CLEAR is not set
+# TrueType Fonts
+# CONFIG_VIDCONSOLE_AS_LCD is not set
+# CONFIG_VIDEO_VESA is not set
+# CONFIG_VIDEO_LCD_ANX9804 is not set
+# CONFIG_VIDEO_LCD_ORISETECH_OTM8009A is not set
+# CONFIG_VIDEO_LCD_RAYDIUM_RM68200 is not set
+# CONFIG_VIDEO_LCD_SSD2828 is not set
+# CONFIG_VIDEO_MESON is not set
+# CONFIG_VIDEO_MVEBU is not set
+CONFIG_I2C_EDID=y
+CONFIG_DISPLAY=y
+# CONFIG_NXP_TDA19988 is not set
+# CONFIG_ATMEL_HLCD is not set
+# CONFIG_AM335X_LCD is not set
+# CONFIG_LOGICORE_DP_TX is not set
+# CONFIG_VIDEO_FSL_DCU_FB is not set
+# CONFIG_VIDEO_ROCKCHIP is not set
+# CONFIG_VIDEO_ARM_MALIDP is not set
+# CONFIG_VIDEO_STM32 is not set
+# CONFIG_VIDEO_TEGRA20 is not set
+# CONFIG_VIDEO_TEGRA124 is not set
+# CONFIG_VIDEO_BRIDGE is not set
+CONFIG_CONSOLE_SCROLL_LINES=1
+# CONFIG_LCD is not set
+CONFIG_VIDEO_SIMPLE=y
+CONFIG_VIDEO_DT_SIMPLEFB=y
+# CONFIG_OSD is not set
+# VirtIO Drivers
+# CONFIG_VIRTIO_MMIO is not set
+# 1-Wire support
+# CONFIG_W1 is not set
+# 1-wire EEPROM support
+# CONFIG_W1_EEPROM is not set
+# Watchdog Timer Support
+# CONFIG_WATCHDOG is not set
+CONFIG_WATCHDOG_TIMEOUT_MSECS=60000
+# CONFIG_WATCHDOG_RESET_DISABLE is not set
+# CONFIG_IMX_WATCHDOG is not set
+# CONFIG_ULP_WATCHDOG is not set
+# CONFIG_DESIGNWARE_WATCHDOG is not set
+# CONFIG_WDT is not set
+# CONFIG_PHYS_TO_BUS is not set
+# File systems
+# CONFIG_FS_BTRFS is not set
+# CONFIG_FS_CBFS is not set
+# CONFIG_SPL_FS_CBFS is not set
+CONFIG_FS_EXT4=y
+# CONFIG_EXT4_WRITE is not set
+CONFIG_FS_FAT=y
+CONFIG_FAT_WRITE=y
+CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
+# CONFIG_FS_JFFS2 is not set
+# CONFIG_UBIFS_SILENCE_MSG is not set
+# CONFIG_FS_CRAMFS is not set
+# CONFIG_YAFFS2 is not set
+# Library routines
+# CONFIG_BCH is not set
+CONFIG_BINMAN_FDT=y
+# CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
+# CONFIG_DYNAMIC_CRC_TABLE is not set
+CONFIG_HAVE_PRIVATE_LIBGCC=y
+CONFIG_LIB_UUID=y
+CONFIG_PRINTF=y
+CONFIG_SPL_PRINTF=y
+CONFIG_SPRINTF=y
+CONFIG_SPL_SPRINTF=y
+CONFIG_STRTO=y
+CONFIG_SPL_STRTO=y
+CONFIG_IMAGE_SPARSE=y
+CONFIG_IMAGE_SPARSE_FILLBUF_SIZE=0x80000
+CONFIG_USE_PRIVATE_LIBGCC=y
+CONFIG_SYS_HZ=1000
+CONFIG_SPL_USE_TINY_PRINTF=y
+# CONFIG_PANIC_HANG is not set
+CONFIG_REGEX=y
+CONFIG_LIB_RAND=y
+# CONFIG_LIB_HW_RAND is not set
+# CONFIG_SPL_TINY_MEMSET is not set
+# CONFIG_TPL_TINY_MEMSET is not set
+# CONFIG_BITREVERSE is not set
+# CONFIG_TRACE is not set
+# CONFIG_CMD_DHRYSTONE is not set
+# Security support
+# CONFIG_AES is not set
+# CONFIG_RSA is not set
+# CONFIG_ASYMMETRIC_KEY_TYPE is not set
+# CONFIG_TPM is not set
+# Android Verified Boot
+# CONFIG_LIBAVB is not set
+# Hashing Support
+CONFIG_SHA1=y
+CONFIG_SHA256=y
+# CONFIG_SHA_HW_ACCEL is not set
+CONFIG_MD5=y
+# Compression Support
+# CONFIG_LZ4 is not set
+# CONFIG_LZMA is not set
+# CONFIG_LZO is not set
+CONFIG_GZIP=y
+CONFIG_ZLIB=y
+# CONFIG_ZSTD is not set
+# CONFIG_SPL_LZ4 is not set
+# CONFIG_SPL_LZO is not set
+# CONFIG_SPL_GZIP is not set
+# CONFIG_SPL_ZSTD is not set
+# CONFIG_ERRNO_STR is not set
+# CONFIG_HEXDUMP is not set
+CONFIG_OF_LIBFDT=y
+CONFIG_OF_LIBFDT_ASSUME_MASK=0
+CONFIG_OF_LIBFDT_OVERLAY=y
+# CONFIG_SPL_OF_LIBFDT is not set
+CONFIG_SPL_OF_LIBFDT_ASSUME_MASK=0xff
+# CONFIG_TPL_OF_LIBFDT is not set
+CONFIG_TPL_OF_LIBFDT_ASSUME_MASK=0xff
+# System tables
+CONFIG_GENERATE_SMBIOS_TABLE=y
+CONFIG_SMBIOS_MANUFACTURER=""
+CONFIG_EFI_LOADER=y
+CONFIG_EFI_DEVICE_PATH_TO_TEXT=y
+CONFIG_EFI_LOADER_HII=y
+CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2=y
+CONFIG_EFI_UNICODE_CAPITALIZATION=y
+# CONFIG_EFI_UNICODE_COLLATION_PROTOCOL is not set
+CONFIG_EFI_PLATFORM_LANG_CODES="en-US"
+CONFIG_EFI_GRUB_ARM32_WORKAROUND=y
+# CONFIG_EFI_LOAD_FILE2_INITRD is not set
+# CONFIG_EFI_SECURE_BOOT is not set
+# CONFIG_TEST_FDTDEC is not set
+CONFIG_LIB_ELF=y
+# CONFIG_UNIT_TEST is not set
diff --git a/v3s_config b/v3s_config
index 0000000000..67ba20b871
--- /dev/null
+++ b/v3s_config
@@ -0,0 +1,1374 @@
+# U-Boot 2019.10 Configuration
+CONFIG_ARM=y
+# ARM architecture
+CONFIG_HAS_VBAR=y
+CONFIG_CPU_V7A=y
+# CONFIG_TARGET_WOODBURN is not set
+# CONFIG_TARGET_WOODBURN_SD is not set
+# CONFIG_TARGET_H2200 is not set
+CONFIG_SYS_TEXT_BASE=0x42e00000
+CONFIG_ENV_OFFSET=0x88000
+CONFIG_SPL=y
+CONFIG_SUN8I_RSB=y
+CONFIG_DRAM_CLK=360
+CONFIG_MACPWR=""
+CONFIG_MMC_SUNXI_SLOT_EXTRA=-1
+CONFIG_USB0_ID_DET=""
+CONFIG_SATAPWR=""
+# CONFIG_SPL_SPI_FLASH_SUPPORT is not set
+# ARM debug
+# General setup
+CONFIG_EXPERT=y
+# Boot images
+# CONFIG_ANDROID_BOOT_IMAGE is not set
+CONFIG_FIT=y
+# API
+# Boot timing
+# Boot media
+CONFIG_BOOTDELAY=2
+CONFIG_BOOTCOMMAND="run distro_bootcmd"
+CONFIG_PREBOOT=""
+# Console
+CONFIG_MENU=y
+CONFIG_LOGLEVEL=4
+# CONFIG_CONSOLE_MUX is not set
+# CONFIG_SYS_CONSOLE_IS_IN_ENV is not set
+# Logging
+# Start-up hooks
+# Security support
+CONFIG_HASH=y
+# Update support
+# Blob list
+# SPL / TPL
+# CONFIG_SPL_DMA_SUPPORT is not set
+CONFIG_CMDLINE=y
+# Autoboot options
+CONFIG_AUTOBOOT=y
+# Commands
+# Info commands
+CONFIG_CMD_BDI=y
+# Boot commands
+CONFIG_CMD_BOOTD=y
+CONFIG_CMD_BOOTM=y
+CONFIG_CMD_BOOTZ=y
+# CONFIG_CMD_BOOTMENU is not set
+# CONFIG_CMD_DTIMG is not set
+CONFIG_CMD_ELF=y
+CONFIG_CMD_FDT=y
+CONFIG_CMD_GO=y
+CONFIG_CMD_RUN=y
+CONFIG_CMD_IMI=y
+CONFIG_CMD_XIMG=y
+CONFIG_CMD_NVEDIT_EFI=y
+# Memory commands
+CONFIG_CMD_CRC32=y
+# CONFIG_CMD_MEMINFO is not set
+# CONFIG_MX_CYCLIC is not set
+CONFIG_CMD_DM=y
+# CONFIG_CMD_FDC is not set
+# CONFIG_CMD_FLASH is not set
+CONFIG_CMD_GPIO=y
+CONFIG_CMD_GPT=y
+CONFIG_CMD_LOADB=y
+CONFIG_CMD_LOADS=y
+CONFIG_CMD_MMC=y
+# CONFIG_CMD_MTD is not set
+# CONFIG_CMD_NAND is not set
+# CONFIG_CMD_ONENAND is not set
+CONFIG_CMD_PART=y
+CONFIG_CMD_USB=y
+# CONFIG_CMD_USB_MASS_STORAGE is not set
+CONFIG_CMD_ECHO=y
+CONFIG_CMD_ITEST=y
+CONFIG_CMD_NET=y
+CONFIG_CMD_BOOTP=y
+CONFIG_CMD_DHCP=y
+CONFIG_BOOTP_DNS=y
+CONFIG_BOOTP_PXE=y
+CONFIG_CMD_NFS=y
+CONFIG_CMD_MII=y
+CONFIG_CMD_PING=y
+CONFIG_CMD_PXE=y
+# Misc commands
+CONFIG_CMD_MISC=y
+# Power commands
+CONFIG_CMD_EXT2=y
+CONFIG_CMD_EXT4=y
+CONFIG_CMD_FAT=y
+# CONFIG_CMD_MTDPARTS is not set
+# Debug commands
+# Partition Types
+CONFIG_DTC=y
+CONFIG_PYLIBFDT=y
+CONFIG_DTOC=y
+CONFIG_BINMAN=y
+CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero"
+# Environment
+# CONFIG_ENV_IS_IN_UBI is not set
+CONFIG_ENV_FAT_DEVICE_AND_PART="0:auto"
+CONFIG_NET=y
+# CONFIG_NET_RANDOM_ETHADDR is not set
+CONFIG_TFTP_BLOCKSIZE=512
+# Device Drivers
+CONFIG_DM=y
+CONFIG_DM_WARN=y
+CONFIG_DM_STDIO=y
+CONFIG_BLK=y
+# Clock
+CONFIG_CLK=y
+CONFIG_CLK_SUNXI=y
+# DFU support
+# DMA Support
+# Fastboot support
+# CONFIG_USB_FUNCTION_FASTBOOT is not set
+# FPGA support
+# GPIO Support
+CONFIG_DM_GPIO=y
+# I2C support
+CONFIG_INPUT=y
+# LED Support
+CONFIG_MMC=y
+CONFIG_MMC_WRITE=y
+CONFIG_DM_MMC=y
+CONFIG_MMC_SUNXI=y
+# MTD Support
+# CONFIG_MTD_DEVICE is not set
+# CONFIG_NAND is not set
+# UBI support
+# CONFIG_PHYLIB is not set
+CONFIG_DM_ETH=y
+# CONFIG_NETDEVICES is not set
+# PCI Endpoint
+# PHY Subsystem
+CONFIG_PHY=y
+# CONFIG_MT76X8_USB_PHY is not set
+# Pin controllers
+# Power
+# CONFIG_DM_REGULATOR is not set
+# CONFIG_DM_PWM is not set
+CONFIG_DM_RESET=y
+# Real Time Clock
+# Serial drivers
+CONFIG_DM_SERIAL=y
+# CONFIG_TPL_DM_SERIAL is not set
+# Sound support
+# SPMI support
+# CONFIG_SYSRESET_MCP83XX is not set
+# Timer Support
+# TPM support
+CONFIG_USB=y
+CONFIG_DM_USB=y
+CONFIG_USB_HOST=y
+# CONFIG_USB_MUSB_GADGET is not set
+# CONFIG_USB_MUSB_PIO_ONLY is not set
+# USB Phy
+# ULPI drivers
+# USB peripherals
+# CONFIG_USB_GADGET_DOWNLOAD is not set
+# CONFIG_USB_ETHER is not set
+# Graphics support
+# CONFIG_DM_VIDEO is not set
+# TrueType Fonts
+# CONFIG_I2C_EDID is not set
+# CONFIG_DISPLAY is not set
+# CONFIG_VIDEO is not set
+# CONFIG_VIDEO_SIMPLE is not set
+# CONFIG_VIDEO_DT_SIMPLEFB is not set
+# VirtIO Drivers
+# 1-Wire support
+# File systems
+CONFIG_FS_EXT4=y
+CONFIG_FS_FAT=y
+CONFIG_FAT_WRITE=y
+# Library routines
+CONFIG_LIB_UUID=y
+CONFIG_PRINTF=y
+CONFIG_SPRINTF=y
+CONFIG_STRTO=y
+CONFIG_SPL_STRTO=y
+CONFIG_SYS_HZ=1000
+CONFIG_USE_TINY_PRINTF=y
+CONFIG_REGEX=y
+CONFIG_LIB_RAND=y
+# Security support
+# Hashing Support
+CONFIG_SHA1=y
+CONFIG_SHA256=y
+CONFIG_MD5=y
+CONFIG_GZIP=y
+CONFIG_ZLIB=y
+CONFIG_HEXDUMP=y
+CONFIG_OF_LIBFDT=y
+# System tables
+# CONFIG_UNIT_TEST is not set运行这个命令打补丁:
git clone https://github.com/u-boot/u-boot.git
cd u-boot
git reset --hard v2019.10
patch -p1 < v3s_uboot_otg.patch离线
能编译通过,并启动系统,但启动时tft没显示(企鹅图标没有),请问下如何修改能看到小企鹅啊,有了小企鹅才能修改开机LOGO吧 。 谢谢!
可以ums不,想通过USB直接通过etcher下载固件
板子上USB不是OTG,没有ID pin,是否可以支持呢?
可以,设备树里改成host
&usb_otg {
	dr_mode = "host";
};最近编辑记录 walke (2024-05-06 17:31:05)
