从网上找了一份esp8089-spi的驱动,但是编译失败了。
源码位置在这。
https://github.com/notabucketofspam/ESP8089-SPI/blob/master/README.md
文中说,可以使用ESP8266或者ESP8089都是可以的。只不过ESP8266需要把SPI flash拆掉。
咱们先编译一下驱动吧。
我改了Makefile的KBUILD,指向F1C200S linux-5.2源码目录。
使用make ARCH=arm CROSS_COMPILE=arm-linux-命令进行编译,得来如下结果:
这是什么原因?
还有他居然说这个内核不支持无线?什么鬼
以下由 @哇酷小二 2020-05-09 添加:
不方便git clone的朋友本站下载: ESP8089-SPI_20200509.7z
最近也在研究linux驱动,发现驱动编写真不是人干的,涉及到的东西太多了,编译出错了,安装驱动出错了,根本就无从下手,想要彻底搞明白,还得从linux源码看起。
$ grep ieee80211_rx_napi -r .
./net/mac80211/rx.c:void ieee80211_rx_napi(struct ieee80211_hw *hw, struct ieee80211_sta *pubsta,
./net/mac80211/rx.c:EXPORT_SYMBOL(ieee80211_rx_napi);
./include/net/mac80211.h: * ieee80211_rx_napi - receive frame from NAPI context
要使能 网络驱动里面的 80211
./include/net/mac80211.h: * ieee80211_rx_napi - receive frame from NAPI context要使能 网络驱动里面的 80211
多谢指点,今天试一下。
进度在此更新
dika@dika-pc:~/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master$ make ARCH=arm CROSS_COMPILE=arm-linux-
*** WARNING: This kernel lacks wireless extensions.
Wireless drivers will not work properly.
make -C /home/dika/DVPM_linux-5.2/linux-nano-5.2-tf M=/home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master
make[1]: Entering directory '/home/dika/DVPM_linux-5.2/linux-nano-5.2-tf'
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_debug.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/sdio_sif_esp.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_io.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_file.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_main.o
In file included from ./include/linux/mm_types.h:12:0,
from ./include/linux/mmzone.h:21,
from ./include/linux/gfp.h:6,
from ./include/linux/slab.h:15,
from ./include/linux/crypto.h:19,
from ./include/crypto/hash.h:11,
from ./include/linux/uio.h:10,
from ./include/linux/socket.h:8,
from ./include/linux/compat.h:15,
from ./include/linux/ethtool.h:17,
from ./include/linux/netdevice.h:37,
from /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_main.c:17:
/home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_main.c: In function ‘esp_pub_init_all’:
./include/linux/completion.h:54:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
struct completion work = COMPLETION_INITIALIZER(work)
./include/linux/completion.h:74:43: note: in expansion of macro ‘DECLARE_COMPLETION’
# define DECLARE_COMPLETION_ONSTACK(work) DECLARE_COMPLETION(work)
/home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_main.c:81:2: note: in expansion of macro ‘DECLARE_COMPLETION_ONSTACK’
DECLARE_COMPLETION_ONSTACK(complete);
In file included from /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_main.c:221:0:
/home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/eagle_fw1.h: In function ‘esp_download_fw’:
/home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/eagle_fw1.h:8:1: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
static u8 eagle_fw1[] =
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_sip.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_ext.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_ctrl.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_mac80211.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_utils.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp_pm.o
CC [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/testmode.o
LD [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp8089-spi.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp8089-spi.mod.o
LD [M] /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/esp8089-spi.ko
make[1]: Leaving directory '/home/dika/DVPM_linux-5.2/linux-nano-5.2-tf'
这是编译时的信息
首先对
进行分析。
查看esp8089-spi的Makefile,发现这么一句话,
config_check:
@if [ -z "$(CONFIG_WIRELESS_EXT)$(CONFIG_NET_RADIO)" ]; then \
echo; echo; \
echo "*** WARNING: This kernel lacks wireless extensions."; \
echo "Wireless drivers will not work properly."; \
echo; echo; \
fi
那么我们就去搜一下。
在内核目录使用make ARCH=arm CROSS_COMPILE=arm-linux- menuconfig
然后按下/键,进行搜索CONFIG_WIRELESS_EXT,
找到
Symbol: WIRELESS_EXT [=n ]
│ Type : bool
│ Defined at net/wireless/Kconfig:2
│ Depends on: NET [=y] && WIRELESS [=y]
然后我就去kernel/net/wireless/Kconfig中找WIRELESS_EXT
config WIRELESS_EXT
bool
更改为
config WIRELESS_EXT
def_bool y
就OK了,再次编译
MODPOST 1 modules
没有刚才的提示信息了
先参考这个帖子进行一些配置看看 https://whycan.cn/t_3754.html。
先把SPI搞定可以用再说接wifi
接到spi flash那组引脚,
dts写到 spi 节点下面就可以了.
我将dtsi修改如下:
在pio分组下
spi0_pc_pins: spi0-pc-pins {
pins = "PC0","PC1","PC2","PC3";
function = "spi0";
在soc分组下(我是从4.15内核设备树中复制过来的)
spi0: spi@1c05000 {
"allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <10>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
status = "disabled";
#address-cells = <1>;
#size-cells = <0>;
我将dts修改如下
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pc_pins>;
然后我将编译出来的esp8089-spi.ko放到了板子的文件系统/opt中。
执行modprobe esp8089-spi.ko
# modprobe esp8089-spi.ko
我手动mkdir创建了/lib目录的modules文件夹
再次modprobe esp8089-spi.ko
modprobe: can't change directory to '5.2.0-licheepi-nano': No such file or directory
我手动mkdir创建了/lib/modules/目录的5.2.0-licheepi-nano文件夹
modprobe: can't open 'modules.dep': No such file or directory
这个modules.dep是什么鬼???去查查
从这个博客中看https://blog.csdn.net/qq_39101111/article/details/78773362
好像是缺东西,depmod,这个指令我的文件系统没有,那么我就再编译一遍buildroot,添加上这个指令。
同时要记得,手动将esp8089-spi.ko放到/lib/modules/5.2.0-licheepi-nano目录中。
我先去编译buildroot了,
这段时候可以去看个电视
据说回复才有积分,我来支持大师
做一下标记
# cd /lib/modules/5.2.0-licheepi-nano/
# ls
esp8089-spi.ko
# depmod
# ls
esp8089-spi.ko modules.alias modules.dep modules.symbols
[ 59.630001] esp8089_spi: loading out-of-tree module taints kernel.
[ 59.682075] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 60.305428] esp8089_spi: FAILED to find master
[ 60.328536] esp8089_spi: FAILED to create slave
[ 60.351455] Unable to handle kernel NULL pointer dereference at virtual address 000001a8
[ 60.396146] pgd = (ptrval)
[ 60.417170] [000001a8] *pgd=83254831, *pte=00000000, *ppte=00000000
[ 60.460005] Internal error: Oops: 17 [#1] ARM
[ 60.482718] Modules linked in: esp8089_spi(O+)
[ 60.505401] CPU: 0 PID: 122 Comm: modprobe Tainted: G O 5.2.0-lic heepi-nano #7
[ 60.550047] Hardware name: Allwinner suniv Family
[ 60.572839] PC is at spi_setup+0x4/0x164
[ 60.594988] LR is at sif_platform_new_device+0x38/0x88 [esp8089_spi]
[ 60.636851] pc : [<c0423420>] lr : [<bf00023c>] psr: 60000013
[ 60.678439] sp : c3217d7c ip : 00000000 fp : bf00f490
[ 60.701620] r10: 00000003 r9 : bf03b9e0 r8 : 00000000
[ 60.724673] r7 : bf03bba4 r6 : 00000000 r5 : bf00f400 r4 : bf03bba0
[ 60.766000] r3 : 1ea5b1d7 r2 : 1ea5b1d7 r1 : 60000093 r0 : 00000000
[ 60.807214] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 60.849221] Control: 0005317f Table: 83220000 DAC: 00000051
[ 60.889929] Process modprobe (pid: 122, stack limit = 0x(ptrval))
[ 60.931219] Stack: (0xc3217d7c to 0xc3218000)
[ 60.953276] 7d60: bf03bba0
[ 60.996208] 7d80: bf00f400 bf00023c bf03bba0 bf00f000 00000000 bf0410a0 00000000 c0a3bf00
[ 61.039109] 7da0: c0a03028 ffffe000 bf041000 00000000 bf03b9e0 00000024 c0a03028 c0102cc0
[ 61.082670] 7dc0: c0a03028 00000000 c0a76050 c0700c80 c08318f0 00000000 c3fdee00 c0a36640
[ 61.126169] 7de0: c3217df8 c3fdee04 c3fdee44 1ea5b1d7 bf03ba28 20000013 c3fdf020 00080000
[ 61.170070] 7e00: 00000001 0080007f bf03b9e0 1ea5b1d7 bf03b9e0 00000001 c32cc320 00000001
[ 61.213941] 7e20: c3bfcba4 00000024 c0a03028 c016f088 00000001 c016e1bc c3217f38 00000001
[ 61.257947] 7e40: c3bfcb80 c016e1c4 bf03b9ec 00007fff bf03b9e0 c016ba84 00000041 bf03ba28
[ 61.302507] 7e60: 000d05f0 bf03bad4 bf047844 bf03b9e0 c4a50708 bf03bb78 bf042000 c0701b8c
[ 61.347315] 7e80: 00000000 00000000 ffffe000 00000000 bf000000 00000000 00000000 00000000
[ 61.392105] 7ea0: 00000000 00000000 00000000 00000000 6e72656b 00006c65 00000000 00000000
[ 61.436708] 7ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 61.481700] 7ee0: 00000000 00000000 00000000 1ea5b1d7 7fffffff c0a03028 00000000 00000003
[ 61.526818] 7f00: 000d05f0 c0101208 c3216000 00000000 000cfc80 c016e980 7fffffff 00000000
[ 61.572258] 7f20: 00000003 00000000 00000000 c4a0c000 00044758 00000000 c4a19bba c4a46660
[ 61.617726] 7f40: c4a0c000 00044758 c4a501e0 c4a50080 c4a4a55c 0003c000 0003de40 00006604
[ 61.663561] 7f60: 0003f098 00000000 00000000 00000000 000065f4 00000020 00000021 00000017
[ 61.709573] 7f80: 00000000 00000011 00000000 1ea5b1d7 000d05a8 000d05f0 000d05a8 000d05f0
[ 61.755883] 7fa0: 0000017b c0101000 000d05f0 000d05a8 00000003 000d05f0 00000000 000d0690
[ 61.802241] 7fc0: 000d05f0 000d05a8 000d05f0 0000017b 000d0690 000d0690 00000000 000cfc80
[ 61.848786] 7fe0: bec1db28 bec1db18 000263ec b6f008a0 60000010 00000003 00000000 00000000
[ 61.895790] [<c0423420>] (spi_setup) from [<00000000>] (0x0)
[ 61.940327] Code: ebff0d15 eafffff9 c080caa4 e92d4030 (e59031a8)
[ 61.985796] ---[ end trace b39325ed7e1d8da4 ]---
Segmentation fault
SPI 没通的感觉
esp8266是串口的吧,速度肯定很慢,还使用usb或者sdio的好。
看的这眼花啊,感觉驱动这东西真的太深了。完全没法玩。
先把/dev/spixxx搞出来再说,应该是要研究一下设备树,对设备树不太懂
驱动spi网卡, 不用搞出 /dev/spi0.0
除非你想应用层往 spi 设备写数据.
速度怎么样? melis上好像大家用的不多,有没有人扩展到melis上的。
我先去编译buildroot了,
这段时候可以去看个电视
depmod加进去就可以了吗?编译好的驱动可以分享吗?
esp8089-spi.ko
# cp esp8089-spi.ko /lib/modules/5.2.0-licheepi-nano/
[ 33.725660] esp8089_spi: loading out-of-tree module taints kernel.
[ 33.777373] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 34.401079] esp8089_spi: FAILED to find master
[ 34.424137] esp8089_spi: FAILED to create slave
[ 34.446956] esp8089_spi: I will go dead ##这句是我自己加的,打印出来了。
[ 34.468930] Unable to handle kernel NULL pointer dereference at virtual addre ss 000001a8
[ 34.513349] pgd = (ptrval)
[ 34.534138] [000001a8] *pgd=83216831, *pte=00000000, *ppte=00000000
[ 34.576547] Internal error: Oops: 17 [#1] ARM
[ 34.598981] Modules linked in: esp8089_spi(O+)
[ 34.621376] CPU: 0 PID: 119 Comm: modprobe Tainted: G
struct spi_device* sif_platform_new_device(void) {
master = spi_busnum_to_master(esp_board_spi_devices[0].bus_num);
if(!master)
printk("esp8089_spi: FAILED to find master\n");
spi = spi_new_device( master, esp_board_spi_devices );
if(!spi)
printk("esp8089_spi: FAILED to create slave\n");
printk("esp8089_spi: I will go dead\n");
if(spi_setup(spi))
printk("esp8089_spi: FAILED to setup slave\n");
return spi;
这个用esp8266是真香 量大 便宜 1MB/s速度很快了 一般的应用都可以了
从串口信息来看,是这段代码出了问题,我们一个个分析
if(!master)
if(!spi)
if(spi_setup(spi))
printk("esp8089_spi: I am OK\n");
return spi;
首先看
其中,esp_board_spi_devices[]为前面定义的结构体
static struct spi_board_info esp_board_spi_devices[] = {
.modalias = "ESP8089_0",
.max_speed_hz = MAX_SPEED_HZ,
.bus_num = 1,
.chip_select = 0,
.mode = 0,
bus_num就是1
spi_busnum_to_master(1)研究一下
每个master都对应一个bus num。
注册spi slave设备,由dts解析得到,dts会指定spi slave 挂载在哪个bus num下,由bus num就可以得到对应的spi master 了
将bus_num改为0之后,就是如下
[ 11.554796] esp8089_spi: loading out-of-tree module taints kernel.
[ 11.606600] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 12.230317] esp8089_spi: esp_spi_dummy_probe enter
[ 12.254156] sun6i-spi 1c05000.spi: chipselect 0 already in use
[ 12.296718] esp8089_spi: FAILED to create slave
[ 12.319904] esp8089_spi: I will go dead
[ 12.342262] Unable to handle kernel NULL pointer dereference at virtual addre ss 000001a8
[ 12.387280] pgd = (ptrval)
woc,,牛逼!!!
[ 12.181054] esp8089_spi: loading out-of-tree module taints kernel.
[ 12.233128] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 12.857475] esp8089_spi: esp_spi_dummy_probe enter
[ 12.881136] esp8089_spi: I will go dead
[ 12.903368] esp8089_spi: I am OK
[ 12.924720] esp8089_spi: register board OK
[ 12.946892] esp8089_spi: sem_timeout = 0
[ 13.182012] esp8089_spi: ESP8089 power up OK
[ 13.204773] esp8089_spi: esp_spi_probe ENTER
[ 13.226888] esp8089_spi: esp_setup_spi
[ 13.248167] esp8089_spi: sif_spi_protocol_init
[ 13.269955] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 13.313000] esp8089_spi: fail_count = 0
[ 13.437998] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 13.579642] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 13.622443] esp8089_spi: fail_count = 1
[ 13.746389] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 13.888106] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 13.931011] esp8089_spi: fail_count = 2
[ 14.055044] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 14.196744] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 14.239826] esp8089_spi: fail_count = 3
[ 14.364670] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 14.506752] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 14.550011] esp8089_spi: fail_count = 4
[ 14.675678] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 14.817810] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c,
完整版打印日志如下
[ 14.160787] esp8089_spi: loading out-of-tree module taints kernel.
[ 14.212248] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 14.836264] esp8089_spi: esp_spi_dummy_probe enter
[ 14.859719] esp8089_spi: I will go dead
[ 14.881817] esp8089_spi: I am OK
[ 14.903073] esp8089_spi: register board OK
[ 14.925106] esp8089_spi: sem_timeout = 0
[ 15.161968] esp8089_spi: ESP8089 power up OK
[ 15.184532] esp8089_spi: esp_spi_probe ENTER
[ 15.206471] esp8089_spi: esp_setup_spi
[ 15.227518] esp8089_spi: sif_spi_protocol_init
[ 15.249056] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 15.291547] esp8089_spi: fail_count = 0
[ 15.416100] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 15.557168] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 15.599577] esp8089_spi: fail_count = 1
[ 15.723559] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 15.864807] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 15.907158] esp8089_spi: fail_count = 2
[ 16.030840] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 16.172182] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.214934] esp8089_spi: fail_count = 3
[ 16.339190] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 16.480864] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.523665] esp8089_spi: fail_count = 4
[ 16.648389] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 16.790452] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.833929] esp8089_spi: fail_count = 5
[ 16.958406] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 17.100829] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.144925] esp8089_spi: fail_count = 6
[ 17.270024] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 17.412897] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.457390] esp8089_spi: fail_count = 7
[ 17.582389] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 17.725779] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.770330] esp8089_spi: fail_count = 8
[ 17.895073] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 18.038762] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 18.084524] esp8089_spi: fail_count = 9
[ 18.210388] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 18.356068] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 18.403822] esp8089_spi: fail_count = 10
[ 18.530763] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 18.677695] esp8089_spi: first error exit
[ 18.701399] esp8089_spi: esp_spi_probe EXIT
[ 18.725104] eagle: probe of spi0.0 failed with error -110
[ 18.750141] esp8089_spi: sem_timeout = 0
[ 18.773383] esp8089_spi: esp_spi_init err 0
F1C100S的spi操作与树莓派相同吗? 这个移植的关键是把spi通信搞通吧
mark 一下,多一种接口方案增加接口灵活性。
现在有/dev/spi0.0节点呢,spi应该可以用了。
现在不知道esp8266与板子连接的spi是哪几个脚。
因为github上那个人用的不是8266的spi脚
这个是不是需要通过spi把8266的固件传过去后,8266才可以正常工作?我看这个代码里好像没有8266的固件。
这一步考虑没?
里面是RK的IO操作
spi_stub.c
* Copyright (c) 2013 Espressif System.
* sdio stub code for allwinner
#include <asm/io.h>
#include <mach/irqs.h>
#include <mach/io.h>
#include <mach/iomux.h>
#include <mach/pmu.h>
#include <linux/gpio.h>
#include <asm/gpio.h>
#include <asm/mach/irq.h>
#include "linux/spi/spi.h"//#include "../drivers/spi/rk29_spim.h"
#include "esp_sif.h"
//#define SPI_FREQ (20000000) // 1. 22.5Mhz 2. 45Mhz
#define SPI_FREQ (30000000) // 1. 22.5Mhz 2. 45Mhz
//Below are for spi HZ 22.5M
#if (SPI_FREQ == 30000000)
#define CMD_RESP_SIZE (10) //(50) //Common respon wait time
#define DATA_RESP_SIZE_W (142+45) // (1024*13)// (1024*16) //(398+400) // (1024*10) //Only for Write bytes function, data write response. max:(361+109)
#define DATA_RESP_SIZE_R (231+75) // (340+102) //(231+75)//(340+102) //Only for Read bytes function, data write response max:(340+102)
#define BLOCK_W_DATA_RESP_SIZE_EACH (10) //For each data write resp size, in block write
#define BLOCK_W_DATA_RESP_SIZE_FINAL (152) // (142+52) //For final data write resp size, in block write ,max: 119
#define BLOCK_R_DATA_RESP_SIZE_1ST (265) // (231+75) //For each data read resp size, in block read ,max: 134
#define BLOCK_R_DATA_RESP_SIZE_EACH (10) // (20) //For each data read resp size, in block read
#elif(SPI_FREQ == 20000000)
#define CMD_RESP_SIZE (10) //Common respon wait time
#define DATA_RESP_SIZE_W (103+40) //Only for Write bytes function, data write response. max: 103
#define DATA_RESP_SIZE_R (118+40) //Only for Read bytes function, data write response max: 118
//w: oxFF : 218 clock. oxFE : 214 clock.
#define BLOCK_W_DATA_RESP_SIZE_EACH (20) //For each data write resp size, in block write
#define BLOCK_W_DATA_RESP_SIZE_FINAL (112+40) //For final data write resp size, in block write ,max :112
#define BLOCK_R_DATA_RESP_SIZE_1ST (123+40) //For each data read resp size, in block read ,max: 123
#define BLOCK_R_DATA_RESP_SIZE_EACH (20) //For each data read resp size, in block read
//0xE5 ~0xFF 30us totoal
struct spi_device_id esp_spi_id[] = {
{"esp_spi_0", 0},
{"esp_spi_1", 1},
#ifdef REGISTER_SPI_BOARD_INFO
.modalias = "esp_spi_0",
.bus_num = 0, //0 or 1
.max_speed_hz = 18*1000*1000,
.chip_select = 0,
.mode = SPI_MODE_3,
void sif_platform_register_board_info(void) {
spi_register_board_info(esp_board_spi_devices, ARRAY_SIZE(esp_board_spi_devices));
#endif /*REGISTER_SPI_BOARD_INFO*/
#define RK30_GPIO0_BASE RK2928_GPIO0_BASE
#define GPIO_NO RK30_PIN0_PA0
#define GPIO_BASE_ADDR ((unsigned char __iomem *) RK30_GPIO0_BASE)
#define GPIO_INT_MASK_OFFSET GPIO_INTEN
#define GPIO_INT_STAT_OFFSET GPIO_PORTS_EOI
int sif_platform_get_irq_no(void)
return gpio_to_irq(GPIO_NO);
int sif_platform_is_irq_occur(void)
return 1;
void sif_platform_irq_clear(void)
void sif_platform_irq_mask(int mask)
if (mask)
disable_irq_nosync(sif_platform_get_irq_no());
enable_irq(sif_platform_get_irq_no());
int sif_platform_irq_init(void)
int ret;
printk(KERN_ERR "%s enter\n", __func__);
if ( (ret = gpio_request(GPIO_NO, "esp_spi_int")) != 0) {
printk(KERN_ERR "request gpio error\n");
return ret;
gpio_direction_input(GPIO_NO);
sif_platform_irq_clear();
sif_platform_irq_mask(1);
udelay(1);
void sif_platform_irq_deinit(void)
gpio_free(GPIO_NO);
void sif_platform_reset_target(void)
gpio_direction_output(RK30_PIN1_PB3, GPIO_LOW);
mdelay(200);
gpio_direction_output(RK30_PIN1_PB3, GPIO_HIGH);
mdelay(200);
void sif_platform_target_poweroff(void)
void sif_platform_target_poweron(void)
mdelay(200);
mdelay(200);
mdelay(200);
void sif_platform_target_speed(int high_speed)
#ifdef ESP_ACK_INTERRUPT
void sif_platform_ack_interrupt(struct esp_pub *epub)
#endif //ESP_ACK_INTERRUPT
module_init(esp_spi_init);
module_exit(esp_spi_exit);
里面应该是树莓派的IO操作
spi_stub.c
#define MHz (1000000)
/* https://www.signal.com.tr/pdf/cat/8n-esp8266_spi_reference_en_v1.0.pdf */
#define SPI_FREQ (10000000)
//#define SPI_FREQ (30000000) // 1. 22.5Mhz 2. 45Mhz
#elif (SPI_FREQ == 10000000)
#define CMD_RESP_SIZE 10
#define DATA_RESP_SIZE_W 99
#define DATA_RESP_SIZE_R 10
#define BLOCK_W_DATA_RESP_SIZE_EACH 30
#define BLOCK_W_DATA_RESP_SIZE_FINAL 152
#define BLOCK_R_DATA_RESP_SIZE_1ST 61
#define BLOCK_R_DATA_RESP_SIZE_EACH 30
#else /* Per 1*MHz */
#define CMD_RESP_SIZE (0*(SPI_FREQ/1000000)+10)
#define DATA_RESP_SIZE_W (4.4*(SPI_FREQ/1000000)+55)
#define DATA_RESP_SIZE_R (14.8*(SPI_FREQ/1000000)-138)
#define BLOCK_W_DATA_RESP_SIZE_EACH (-1*(SPI_FREQ/1000000)+40)
#define BLOCK_W_DATA_RESP_SIZE_FINAL (0*(SPI_FREQ/1000000)+152)
#define BLOCK_R_DATA_RESP_SIZE_1ST (10.2*(SPI_FREQ/1000000)-41)
#define BLOCK_R_DATA_RESP_SIZE_EACH (-1*(SPI_FREQ/1000000)+40)
x per 10*MHz
CMD_RESP_SIZE 0x+10
DATA_RESP_SIZE_W 44x+55
DATA_RESP_SIZE_R 148x-138
BLOCK_W_DATA_RESP_SIZE_EACH -10x+40
BLOCK_W_DATA_RESP_SIZE_FINAL 0x+152
BLOCK_R_DATA_RESP_SIZE_1ST 102x-41
BLOCK_R_DATA_RESP_SIZE_EACH -10x+40
#include "linux/interrupt.h"
#include <linux/init.h>
#include <linux/delay.h>
#include <linux/module.h>
#include <linux/moduleparam.h>
/* *** *** Board info *** *** */
{"ESP8089_0", 0},
{"ESP8089_1", 1},
{"ESP8089_2", 2},
MODULE_DEVICE_TABLE(spi, esp_spi_id);
static int esp_cs0_pin = 16;
module_param(esp_cs0_pin, int, 0);
MODULE_PARM_DESC(esp_cs0_pin, "SPI chip select zero");
#define MAX_SPEED_HZ (20*MHz)
static struct spi_master *master;
static struct spi_device *spi;
.bus_num = 0,
.chip_select = 0,
.mode = 0,
//spi_register_board_info(esp_board_spi_devices, ARRAY_SIZE(esp_board_spi_devices));
if(!master)
if(!spi)
if(spi_setup(spi))
return spi;
/* *** *** Interrupt *** *** */
static int esp_interrupt = 26;
module_param(esp_interrupt, int, 0);
MODULE_PARM_DESC(esp_interrupt, "Interrupt pin");
int sif_platform_irq_init(void) {
int ret;
printk(KERN_ERR "esp8089_spi: %s enter\n", __func__);
if ( (ret = gpio_request(esp_interrupt, "esp_interrupt")) != 0) {
printk(KERN_ERR "esp8089_spi: request gpio error\n");
return ret;
gpio_direction_input(esp_interrupt);
udelay(1);
void sif_platform_irq_deinit(void) {
gpio_free(esp_interrupt);
int sif_platform_get_irq_no(void) {
return gpio_to_irq(esp_interrupt);
int sif_platform_is_irq_occur(void) {
return 1;
void sif_platform_irq_clear(void) {
void sif_platform_irq_mask(int mask) {
if (mask)
void sif_platform_target_speed(int high_speed) {
void sif_platform_ack_interrupt(struct esp_pub *epub) {
/* *** *** Platform power *** *** */
HSPI:
GPIO12 HMISO
GPIO13 HMOSI
GPIO14 HSCLK
GPIO15 HCS
SPI:
GPIO6 SCLK
GPIO7 MISO
GPIO8 MOSI
GPIO11 CS
SDIO:
GPIO6 SDCLK
GPIO7 SDD0
GPIO8 SDD1
GPIO9 SDD2
GPIO10 SDD3
GPIO11 SDCMD
static int esp_reset_gpio = 13;
module_param(esp_reset_gpio, int, 0);
MODULE_PARM_DESC(esp_reset_gpio, "ESP8089 CHIP_EN GPIO number");
void sif_platform_reset_target(void) {
gpio_request(esp_reset_gpio, "esp_reset_gpio");
gpio_direction_output(esp_reset_gpio, 0);
mdelay(200);
gpio_direction_output(esp_reset_gpio, 1);
mdelay(200);
gpio_free(esp_reset_gpio);
void sif_platform_target_poweroff(void) {
void sif_platform_target_poweron(void) {
mdelay(200);
mdelay(200);
mdelay(200);
//module_init(esp_spi_init);
late_initcall(esp_spi_init);
SPI 1MHz
# insmod esp8089-spi.ko
[ 17.952847] esp8089_spi: loading out-of-tree module taints kernel.
[ 18.004636] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 18.028754] esp8089_spi: poweron
[ 18.650540] esp8089_spi: esp_spi_dummy_probe enter
[ 18.674024] esp8089_spi: I will go dead
[ 18.696104] esp8089_spi: I am OK
[ 18.717387] esp8089_spi: register board OK
[ 18.739441] esp8089_spi: sem_timeout = 0
[ 18.971992] esp8089_spi: ESP8089 power up OK
[ 18.994566] esp8089_spi: esp_spi_probe ENTER
[ 19.016477] esp8089_spi: esp_setup_spi
[ 19.037504] esp8089_spi: sif_spi_protocol_init
[ 19.059051] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 19.101610] esp8089_spi: fail_count = 0
[ 19.226331] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 19.367306] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 19.409756] esp8089_spi: fail_count = 1
[ 19.533739] rx:[0x7e],[0x13],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.674991] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 19.717502] esp8089_spi: fail_count = 2
[ 19.841174] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.982489] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.025333] esp8089_spi: fail_count = 3
[ 20.149896] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.291597] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.334566] esp8089_spi: fail_count = 4
[ 20.458476] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.600450] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.644036] esp8089_spi: fail_count = 5
[ 20.768435] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.910754] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.954281] esp8089_spi: fail_count = 6
[ 21.078735] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.221554] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 21.266070] esp8089_spi: fail_count = 7
[ 21.391336] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.534522] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 21.579003] esp8089_spi: fail_count = 8
[ 21.704930] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.848840] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 21.894883] esp8089_spi: fail_count = 9
[ 22.021035] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 22.166974] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 22.215061] esp8089_spi: fail_count = 10
[ 22.342137] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 22.489415] esp8089_spi: first error exit
[ 22.513264] esp8089_spi: esp_spi_probe EXIT
[ 22.537086] eagle: probe of spi0.0 failed with error -110
[ 22.562279] esp8089_spi: sem_timeout = 0
[ 22.585622] esp8089_spi: esp_spi_init err 0
SPI 15MHz
[ 14.900929] esp8089_spi: loading out-of-tree module taints kernel.
[ 14.952975] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 14.977090] esp8089_spi: poweron
[ 15.598862] esp8089_spi: esp_spi_dummy_probe enter
[ 15.622305] esp8089_spi: I will go dead
[ 15.644433] esp8089_spi: I am OK
[ 15.665721] esp8089_spi: register board OK
[ 15.687822] esp8089_spi: sem_timeout = 0
[ 15.921987] esp8089_spi: ESP8089 power up OK
[ 15.944590] esp8089_spi: esp_spi_probe ENTER
[ 15.966546] esp8089_spi: esp_setup_spi
[ 15.987586] esp8089_spi: sif_spi_protocol_init
[ 16.009206] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.051926] esp8089_spi: fail_count = 0
[ 16.176664] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 16.317848] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.360380] esp8089_spi: fail_count = 1
[ 16.484384] rx:[0x7e],[0x13],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 16.625686] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.668282] esp8089_spi: fail_count = 2
[ 16.792084] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 16.933510] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 16.976461] esp8089_spi: fail_count = 3
[ 17.100712] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 17.242400] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.285400] esp8089_spi: fail_count = 4
[ 17.409749] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 17.551823] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.595541] esp8089_spi: fail_count = 5
[ 17.719894] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 17.862428] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 17.906287] esp8089_spi: fail_count = 6
[ 18.030713] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 18.173591] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 18.218119] esp8089_spi: fail_count = 7
[ 18.343120] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 18.486304] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 18.530786] esp8089_spi: fail_count = 8
[ 18.655660] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 18.799412] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 18.845437] esp8089_spi: fail_count = 9
[ 18.971166] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.117060] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 19.165190] esp8089_spi: fail_count = 10
[ 19.292546] rx:[0xff],[0xfe],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.439672] esp8089_spi: first error exit
[ 19.463473] esp8089_spi: esp_spi_probe EXIT
[ 19.487289] eagle: probe of spi0.0 failed with error -110
[ 19.512469] esp8089_spi: sem_timeout = 0
[ 19.535793] esp8089_spi: esp_spi_init err 0
目前卡住的位置,还没有达到把固件上传到wifi模块那一步
static int esp_spi_probe(struct spi_device *spi)
int err;
struct esp_pub *epub;
struct esp_spi_ctrl *sctrl;
printk("esp8089_spi: %s ENTER\n", __func__);
//esp_dbg(ESP_DBG_ERROR, "esp8089_spi: %s enter\n", __func__);
err = esp_setup_spi(spi);
if (err) {
esp_dbg(ESP_DBG_ERROR, "esp8089_spi: %s setup_spi error[%d]\n", __func__, err);
if(sif_sdio_state == ESP_SDIO_STATE_FIRST_INIT)
goto _err_spi;
goto _err_second_init;
//esp_dbg(ESP_DBG_ERROR, "esp8089_spi: %s init_protocol\n", __func__);
err = sif_spi_protocol_init(spi);//在这卡住了 @@@@@@@
if(err) {
goto _err_spi;
if(sif_sdio_state == ESP_SDIO_STATE_FIRST_INIT){
sctrl = kzalloc(sizeof(struct esp_spi_ctrl), GFP_KERNEL);
if (sctrl == NULL) {
err = -ENOMEM;
goto _err_spi;
/* temp buffer reserved for un-dma-able request */
sctrl->dma_buffer = kzalloc(ESP_DMA_IBUFSZ, GFP_KERNEL);
什么鬼??
[ 21.298456] esp8089_spi: esp_pub_init_all
[ 21.324239] esp8089_spi: downloadesp_download_fw
[ 21.457072] random: crng init done
[ 21.871575] esp8089_spi: sif_platform_irq_init enter
[ 21.898407] esp8089_spi: sif sif_enable_irq failed
[ 32.481935] resetting event timeout
[ 32.506446] esp8089_spi: esp_init_all failed: -110
[ 32.532108] esp8089_spi: first error exit
[ 32.556646] esp8089_spi: esp_spi_probe EXIT
[ 32.581431] esp8089_spi: sem_timeout = 0
[ 32.605472] esp8089_spi: esp_spi_init err 0
woc,是不是起来了呀,CS脚工作起来了好像一直在运行,,
首先对比一下/dev目录的东西,挂载前和挂载后,
挂载前的/dev
# ls
adsp ptyv8 ttyda
audio ptyv9 ttydb
console ptyva ttydc
cpu_dma_latency ptyvb ttydd
dri ptyvc ttyde
dsp ptyvd ttydf
fb0 ptyve ttye0
full ptyvf ttye1
gpiochip0 ptyw0 ttye2
kmsg ptyw1 ttye3
log ptyw2 ttye4
mem ptyw3 ttye5
memory_bandwidth ptyw4 ttye6
mixer ptyw5 ttye7
mmcblk0 ptyw6 ttye8
mmcblk0p1 ptyw7 ttye9
mmcblk0p2 ptyw8 ttyea
network_latency ptyw9 ttyeb
network_throughput ptywa ttyec
null ptywb ttyed
ptmx ptywc ttyee
pts ptywd ttyef
ptya0 ptywe ttyp0
ptya1 ptywf ttyp1
ptya2 ptyx0 ttyp2
ptya3 ptyx1 ttyp3
ptya4 ptyx2 ttyp4
ptya5 ptyx3 ttyp5
ptya6 ptyx4 ttyp6
ptya7 ptyx5 ttyp7
ptya8 ptyx6 ttyp8
ptya9 ptyx7 ttyp9
ptyaa ptyx8 ttypa
ptyab ptyx9 ttypb
ptyac ptyxa ttypc
ptyad ptyxb ttypd
ptyae ptyxc ttype
ptyaf ptyxd ttypf
ptyb0 ptyxe ttyq0
ptyb1 ptyxf ttyq1
ptyb2 ptyy0 ttyq2
ptyb3 ptyy1 ttyq3
ptyb4 ptyy2 ttyq4
ptyb5 ptyy3 ttyq5
ptyb6 ptyy4 ttyq6
ptyb7 ptyy5 ttyq7
ptyb8 ptyy6 ttyq8
ptyb9 ptyy7 ttyq9
ptyba ptyy8 ttyqa
ptybb ptyy9 ttyqb
ptybc ptyya ttyqc
ptybd ptyyb ttyqd
ptybe ptyyc ttyqe
ptybf ptyyd ttyqf
ptyc0 ptyye ttyr0
ptyc1 ptyyf ttyr1
ptyc2 ptyz0 ttyr2
ptyc3 ptyz1 ttyr3
ptyc4 ptyz2 ttyr4
ptyc5 ptyz3 ttyr5
ptyc6 ptyz4 ttyr6
ptyc7 ptyz5 ttyr7
ptyc8 ptyz6 ttyr8
ptyc9 ptyz7 ttyr9
ptyca ptyz8 ttyra
ptycb ptyz9 ttyrb
ptycc ptyza ttyrc
ptycd ptyzb ttyrd
ptyce ptyzc ttyre
ptycf ptyzd ttyrf
ptyd0 ptyze ttys0
ptyd1 ptyzf ttys1
ptyd2 random ttys2
ptyd3 shm ttys3
ptyd4 snd ttys4
ptyd5 tty ttys5
ptyd6 tty0 ttys6
ptyd7 tty1 ttys7
ptyd8 tty10 ttys8
ptyd9 tty11 ttys9
ptyda tty12 ttysa
ptydb tty13 ttysb
ptydc tty14 ttysc
ptydd tty15 ttysd
ptyde tty16 ttyse
ptydf tty17 ttysf
ptye0 tty18 ttyt0
ptye1 tty19 ttyt1
ptye2 tty2 ttyt2
ptye3 tty20 ttyt3
ptye4 tty21 ttyt4
ptye5 tty22 ttyt5
ptye6 tty23 ttyt6
ptye7 tty24 ttyt7
ptye8 tty25 ttyt8
ptye9 tty26 ttyt9
ptyea tty27 ttyta
ptyeb tty28 ttytb
ptyec tty29 ttytc
ptyed tty3 ttytd
ptyee tty30 ttyte
ptyef tty31 ttytf
ptyp0 tty32 ttyu0
ptyp1 tty33 ttyu1
ptyp2 tty34 ttyu2
ptyp3 tty35 ttyu3
ptyp4 tty36 ttyu4
ptyp5 tty37 ttyu5
ptyp6 tty38 ttyu6
ptyp7 tty39 ttyu7
ptyp8 tty4 ttyu8
ptyp9 tty40 ttyu9
ptypa tty41 ttyua
ptypb tty42 ttyub
ptypc tty43 ttyuc
ptypd tty44 ttyud
ptype tty45 ttyue
ptypf tty46 ttyuf
ptyq0 tty47 ttyv0
ptyq1 tty48 ttyv1
ptyq2 tty49 ttyv2
ptyq3 tty5 ttyv3
ptyq4 tty50 ttyv4
ptyq5 tty51 ttyv5
ptyq6 tty52 ttyv6
ptyq7 tty53 ttyv7
ptyq8 tty54 ttyv8
ptyq9 tty55 ttyv9
ptyqa tty56 ttyva
ptyqb tty57 ttyvb
ptyqc tty58 ttyvc
ptyqd tty59 ttyvd
ptyqe tty6 ttyve
ptyqf tty60 ttyvf
ptyr0 tty61 ttyw0
ptyr1 tty62 ttyw1
ptyr2 tty63 ttyw2
ptyr3 tty7 ttyw3
ptyr4 tty8 ttyw4
ptyr5 tty9 ttyw5
ptyr6 ttyS0 ttyw6
ptyr7 ttyS1 ttyw7
ptyr8 ttyS2 ttyw8
ptyr9 ttyS3 ttyw9
ptyra ttyS4 ttywa
ptyrb ttyS5 ttywb
ptyrc ttyS6 ttywc
ptyrd ttyS7 ttywd
ptyre ttya0 ttywe
ptyrf ttya1 ttywf
ptys0 ttya2 ttyx0
ptys1 ttya3 ttyx1
ptys2 ttya4 ttyx2
ptys3 ttya5 ttyx3
ptys4 ttya6 ttyx4
ptys5 ttya7 ttyx5
ptys6 ttya8 ttyx6
ptys7 ttya9 ttyx7
ptys8 ttyaa ttyx8
ptys9 ttyab ttyx9
ptysa ttyac ttyxa
ptysb ttyad ttyxb
ptysc ttyae ttyxc
ptysd ttyaf ttyxd
ptyse ttyb0 ttyxe
ptysf ttyb1 ttyxf
ptyt0 ttyb2 ttyy0
ptyt1 ttyb3 ttyy1
ptyt2 ttyb4 ttyy2
ptyt3 ttyb5 ttyy3
ptyt4 ttyb6 ttyy4
ptyt5 ttyb7 ttyy5
ptyt6 ttyb8 ttyy6
ptyt7 ttyb9 ttyy7
ptyt8 ttyba ttyy8
ptyt9 ttybb ttyy9
ptyta ttybc ttyya
ptytb ttybd ttyyb
ptytc ttybe ttyyc
ptytd ttybf ttyyd
ptyte ttyc0 ttyye
ptytf ttyc1 ttyyf
ptyu0 ttyc2 ttyz0
ptyu1 ttyc3 ttyz1
ptyu2 ttyc4 ttyz2
ptyu3 ttyc5 ttyz3
ptyu4 ttyc6 ttyz4
ptyu5 ttyc7 ttyz5
ptyu6 ttyc8 ttyz6
ptyu7 ttyc9 ttyz7
ptyu8 ttyca ttyz8
ptyu9 ttycb ttyz9
ptyua ttycc ttyza
ptyub ttycd ttyzb
ptyuc ttyce ttyzc
ptyud ttycf ttyzd
ptyue ttyd0 ttyze
ptyuf ttyd1 ttyzf
ptyv0 ttyd2 urandom
ptyv1 ttyd3 vcs
ptyv2 ttyd4 vcs1
ptyv3 ttyd5 vcsa
ptyv4 ttyd6 vcsa1
ptyv5 ttyd7 vcsu
ptyv6 ttyd8 vcsu1
ptyv7 ttyd9 zero
挂载后的/dev
# ls /dev/
adsp ptyv8 ttyda
audio ptyv9 ttydb
console ptyva ttydc
dri ptyvc ttyde
dsp ptyvd ttydf
fb0 ptyve ttye0
full ptyvf ttye1
kmsg ptyw1 ttye3
log ptyw2 ttye4
mem ptyw3 ttye5
mixer ptyw5 ttye7
mmcblk0 ptyw6 ttye8
null ptywb ttyed
ptmx ptywc ttyee
pts ptywd ttyef
ptya0 ptywe ttyp0
ptya1 ptywf ttyp1
ptya2 ptyx0 ttyp2
ptya3 ptyx1 ttyp3
ptya4 ptyx2 ttyp4
ptya5 ptyx3 ttyp5
ptya6 ptyx4 ttyp6
ptya7 ptyx5 ttyp7
ptya8 ptyx6 ttyp8
ptya9 ptyx7 ttyp9
ptyaa ptyx8 ttypa
ptyab ptyx9 ttypb
ptyac ptyxa ttypc
ptyad ptyxb ttypd
ptyae ptyxc ttype
ptyaf ptyxd ttypf
ptyb0 ptyxe ttyq0
ptyb1 ptyxf ttyq1
ptyb2 ptyy0 ttyq2
ptyb3 ptyy1 ttyq3
ptyb4 ptyy2 ttyq4
ptyb5 ptyy3 ttyq5
ptyb6 ptyy4 ttyq6
ptyb7 ptyy5 ttyq7
ptyb8 ptyy6 ttyq8
ptyb9 ptyy7 ttyq9
ptyba ptyy8 ttyqa
ptybb ptyy9 ttyqb
ptybc ptyya ttyqc
ptybd ptyyb ttyqd
ptybe ptyyc ttyqe
ptybf ptyyd ttyqf
ptyc0 ptyye ttyr0
ptyc1 ptyyf ttyr1
ptyc2 ptyz0 ttyr2
ptyc3 ptyz1 ttyr3
ptyc4 ptyz2 ttyr4
ptyc5 ptyz3 ttyr5
ptyc6 ptyz4 ttyr6
ptyc7 ptyz5 ttyr7
ptyc8 ptyz6 ttyr8
ptyc9 ptyz7 ttyr9
ptyca ptyz8 ttyra
ptycb ptyz9 ttyrb
ptycc ptyza ttyrc
ptycd ptyzb ttyrd
ptyce ptyzc ttyre
ptycf ptyzd ttyrf
ptyd0 ptyze ttys0
ptyd1 ptyzf ttys1
ptyd2 random ttys2
ptyd3 shm ttys3
ptyd4 snd ttys4
ptyd5 tty ttys5
ptyd6 tty0 ttys6
ptyd7 tty1 ttys7
ptyd8 tty10 ttys8
ptyd9 tty11 ttys9
ptyda tty12 ttysa
ptydb tty13 ttysb
ptydc tty14 ttysc
ptydd tty15 ttysd
ptyde tty16 ttyse
ptydf tty17 ttysf
ptye0 tty18 ttyt0
ptye1 tty19 ttyt1
ptye2 tty2 ttyt2
ptye3 tty20 ttyt3
ptye4 tty21 ttyt4
ptye5 tty22 ttyt5
ptye6 tty23 ttyt6
ptye7 tty24 ttyt7
ptye8 tty25 ttyt8
ptye9 tty26 ttyt9
ptyea tty27 ttyta
ptyeb tty28 ttytb
ptyec tty29 ttytc
ptyed tty3 ttytd
ptyee tty30 ttyte
ptyef tty31 ttytf
ptyp0 tty32 ttyu0
ptyp1 tty33 ttyu1
ptyp2 tty34 ttyu2
ptyp3 tty35 ttyu3
ptyp4 tty36 ttyu4
ptyp5 tty37 ttyu5
ptyp6 tty38 ttyu6
ptyp7 tty39 ttyu7
ptyp8 tty4 ttyu8
ptyp9 tty40 ttyu9
ptypa tty41 ttyua
ptypb tty42 ttyub
ptypc tty43 ttyuc
ptypd tty44 ttyud
ptype tty45 ttyue
ptypf tty46 ttyuf
ptyq0 tty47 ttyv0
ptyq1 tty48 ttyv1
ptyq2 tty49 ttyv2
ptyq3 tty5 ttyv3
ptyq4 tty50 ttyv4
ptyq5 tty51 ttyv5
ptyq6 tty52 ttyv6
ptyq7 tty53 ttyv7
ptyq8 tty54 ttyv8
ptyq9 tty55 ttyv9
ptyqa tty56 ttyva
ptyqb tty57 ttyvb
ptyqc tty58 ttyvc
ptyqd tty59 ttyvd
ptyqe tty6 ttyve
ptyqf tty60 ttyvf
ptyr0 tty61 ttyw0
ptyr1 tty62 ttyw1
ptyr2 tty63 ttyw2
ptyr3 tty7 ttyw3
ptyr4 tty8 ttyw4
ptyr5 tty9 ttyw5
ptyr6 ttyS0 ttyw6
ptyr7 ttyS1 ttyw7
ptyr8 ttyS2 ttyw8
ptyr9 ttyS3 ttyw9
ptyra ttyS4 ttywa
ptyrb ttyS5 ttywb
ptyrc ttyS6 ttywc
ptyrd ttyS7 ttywd
ptyre ttya0 ttywe
ptyrf ttya1 ttywf
ptys0 ttya2 ttyx0
ptys1 ttya3 ttyx1
ptys2 ttya4 ttyx2
ptys3 ttya5 ttyx3
ptys4 ttya6 ttyx4
ptys5 ttya7 ttyx5
ptys6 ttya8 ttyx6
ptys7 ttya9 ttyx7
ptys8 ttyaa ttyx8
ptys9 ttyab ttyx9
ptysa ttyac ttyxa
ptysb ttyad ttyxb
ptysc ttyae ttyxc
ptysd ttyaf ttyxd
ptyse ttyb0 ttyxe
ptysf ttyb1 ttyxf
ptyt0 ttyb2 ttyy0
ptyt1 ttyb3 ttyy1
ptyt2 ttyb4 ttyy2
ptyt3 ttyb5 ttyy3
ptyt4 ttyb6 ttyy4
ptyt5 ttyb7 ttyy5
ptyt6 ttyb8 ttyy6
ptyt7 ttyb9 ttyy7
ptyt8 ttyba ttyy8
ptyt9 ttybb ttyy9
ptyta ttybc ttyya
ptytb ttybd ttyyb
ptytc ttybe ttyyc
ptytd ttybf ttyyd
ptyte ttyc0 ttyye
ptytf ttyc1 ttyyf
ptyu0 ttyc2 ttyz0
ptyu1 ttyc3 ttyz1
ptyu2 ttyc4 ttyz2
ptyu3 ttyc5 ttyz3
ptyu4 ttyc6 ttyz4
ptyu5 ttyc7 ttyz5
ptyu6 ttyc8 ttyz6
ptyu7 ttyc9 ttyz7
ptyu8 ttyca ttyz8
ptyu9 ttycb ttyz9
ptyua ttycc ttyza
ptyub ttycd ttyzb
ptyuc ttyce ttyzc
ptyud ttycf ttyzd
ptyue ttyd0 ttyze
ptyuf ttyd1 ttyzf
ptyv0 ttyd2 urandom
ptyv1 ttyd3 vcs
ptyv2 ttyd4 vcs1
ptyv3 ttyd5 vcsa
ptyv4 ttyd6 vcsa1
ptyv5 ttyd7 vcsu
ptyv6 ttyd8 vcsu1
ptyv7 ttyd9 zero
挂载完整打印信息如下:
[ 95.688812] esp8089_spi: loading out-of-tree module taints kernel.
[ 95.741441] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 95.765422] esp8089_spi: poweron
[ 96.387139] esp8089_spi: esp_spi_dummy_probe enter
[ 96.410540] esp8089_spi: I will go dead
[ 96.432614] esp8089_spi: I am OK
[ 96.453823] esp8089_spi: register board OK
[ 96.475790] esp8089_spi: sem_timeout = 0
[ 96.712043] esp8089_spi: ESP8089 power up OK
[ 96.734478] esp8089_spi: esp_spi_probe ENTER
[ 96.756241] esp8089_spi: esp_setup_spi
[ 96.777099] esp8089_spi: sif_spi_protocol_init
[ 96.798455] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 96.840698] esp8089_spi: fail_count = 0
[ 96.965062] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 97.105917] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 97.148312] esp8089_spi: fail_count = 1
[ 97.273686] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 97.414738] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 97.456957] esp8089_spi: fail_count = 2
[ 97.580939] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 98.221376] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 98.266542] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 98.807767] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 98.853626] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 99.395096] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 99.441481] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 99.983821] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 100.030828] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 100.574038] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 100.620951] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 101.164762] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 101.213307] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 101.757707] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 101.805890] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 102.350613] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 102.400344] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 102.946778] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 102.997877] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 103.546238] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 103.599613] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 104.149105] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 104.202882] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 104.752619] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 104.806487] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 105.356591] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 105.410714] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 105.961113] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 106.015706] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 106.566018] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 106.620083] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 106.671116] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 106.725178] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 106.776159] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 106.830105] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 107.885182] esp8089_spi: esp_pub_init_all
[ 107.910962] esp8089_spi: downloadesp_download_fw
[ 107.948002] random: crng init done
[ 108.457730] esp8089_spi: sif_platform_irq_init enter
[ 108.682929] esp_host:bdf5087c3deb
[ 108.682929] esp_target: e826c2b3c9fd 57 18202
[ 108.682929]
[ 108.754269] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[ 108.807356] esp8089_spi: first normal exit
[ 108.832108] esp8089_spi: esp_spi_probe EXIT
[ 108.856864] esp8089_spi: sem_timeout = 0
[ 108.880921] esp8089_spi: esp_spi_remove
[ 109.022172] esp8089_spi: esp_spi_probe ENTER
[ 109.046057] esp8089_spi: esp_setup_spi
[ 109.069029] esp8089_spi: sif_spi_protocol_init
[ 109.092510] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 109.138970] esp8089_spi: fail_count = 0
[ 109.265424] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 109.410344] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 109.456558] esp8089_spi: fail_count = 1
[ 109.582142] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 109.726810] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 109.772626] esp8089_spi: fail_count = 2
[ 109.897947] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 110.541520] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 110.589422] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 111.133165] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 111.180911] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 111.724615] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 111.772396] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 112.316162] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 112.363925] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 112.907706] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 112.955502] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 113.499256] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 113.546952] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 114.091379] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 114.140416] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 114.685987] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 114.735674] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 115.282003] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 115.333521] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 115.881856] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 115.934723] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 116.484208] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 116.537977] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 117.087691] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 117.141635] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 117.691596] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 117.745683] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 118.296061] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 118.350494] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 118.900869] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 118.955132] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 119.006037] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 119.060398] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 119.111387] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 119.165337] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 120.219675] esp8089_spi: esp_pub_init_all
[ 120.245395] esp8089_spi: downloadesp_download_fw
[ 120.878445] esp8089_spi: sif_platform_irq_init enter
[ 120.935677] esp8089_spi: esp_spi_probe EXIT
[ 120.961321] esp8089_spi: esp_spi_init err 0
[ 120.992229] esp_host:bdf5087c3deb
[ 120.992229] esp_target: e826c2b3c9fd 57 18202
[ 120.992229]
请问,这是跑起来了吗?
# ifconfig wlan0 up
[ 569.902089] esp_op_add_interface STA
# ifconfig
lo Link encap:Local Loopback
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr AC:D0:74:70:73:35
UP BROADCAST MULTICAST MTU:1500 Metric:1
楼主真有耐心,不错赞一个
拾柴来了
iw只能连接无密码的WIFI,现在的wifi协议不支持
# iw wlan0 connect huawei3
# [ 723.742594] wlan0: authenticate with e0:a3:ac:1d:7d:5b
[ 723.768122] wlan0: send auth to e0:a3:ac:1d:7d:5b (try 1/3)
[ 723.823034] wlan0: authenticated
[ 723.852631] wlan0: associate with e0:a3:ac:1d:7d:5b (try 1/3)
[ 723.908738] wlan0: RX AssocResp from e0:a3:ac:1d:7d:5b (capab=0x401 status=0 aid=1)
[ 723.955519] wlan0: associated
[ 723.979399] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
连上了我手机的热点
# while [ 1 ]; do
> data;wget ftp://192.168.43.1:3721/Downloads/DKTool_0229.rar -O /dev/null ;data
> done;
厉害厉害,持续关注,我一直用ESP8266做开发,还没有大佬这钻研精神
#cd /lib/modules/5.2.0-licheepi-nano/
#modprobe esp8089-spi.ko
#ifconfig wlan0 up
#iw wlan0 connect huawei3
#ifconfig wlan0 192.168.43.45
# while [ 1 ]; do
> data;wget ftp://192.168.43.1:3721/Downloads/DKTool_0229.rar -O /dev/null ;data;
> done;
迪卡再把微信配网搞定, 配合F1C100s, 做些不在乎功耗的物联网产品竞争力还是蛮强的。
这个驱动稳定性如何?我记得前面的帖子里面的驱动三下五除二就挂了,基本没有找到稳定的。
创建一个方便用的文件系统,免得缺什么都要去重新buildroot,太麻烦了。
就用debian吧,
debian分很多版本
9 stretch
8 jessie
7 wheezy
6 squeeze
5 lenny
4 etch
sudo apt-get install debootstrap
debootstrap --foreign --verbose --arch=armel jessie rootfs http://ftp2.cn.debian.org/debian
root密码必须在设定rootfs的时候弄,不然空密码很可能进不去;现在已经有Debian10Buster了,为啥不用最新的呢
支持一下大佬!不能支持wpa密码的WiFi吗?
1. 可以用iperf测试这个网卡的收发数据的性能。
2. esp8266的 GPIO15/MTDO 必需是拉高的状态吗?
请问,想用这个spi接8266,一定要把flash焊掉吗?我这边用的nodemcu, 拆壳比较费劲!!
迪神NB
我尝试在openwrt跑跑看,不知道能不能长期用,还有就是8266在这种工作模式下的休眠和唤醒会不会有问题
迪神,我搞到这里了,接下去怎么搞,要搞中断口或者EN口吗?
root@OpenWrt:~# insmod esp8089-spi.ko
[ 19.267713] esp8089_spi: loading out-of-tree module taints kernel.
[ 19.276448] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 19.882064] esp8089_spi: esp_spi_dummy_probe enter
[ 19.886991] esp8089_spi: register board OK
[ 19.891086] esp8089_spi: sem_timeout = 0
[ 20.105470] esp8089_spi: ESP8089 power up OK
[ 20.110065] esp8089_spi: esp_spi_probe ENTER
[ 20.114338] esp8089_spi: esp_setup_spi
[ 20.118173] esp8089_spi: sif_spi_protocol_init
[ 20.122617] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 20.129245] esp8089_spi: fail_count = 0
[ 20.234938] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 20.342720] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 20.349337] esp8089_spi: fail_count = 1
[ 20.454818] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 20.562585] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 20.569200] esp8089_spi: fail_count = 2
[ 20.674696] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 20.782472] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 20.789088] esp8089_spi: fail_count = 3
[ 20.894560] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 21.002336] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 21.008951] esp8089_spi: fail_count = 4
[ 21.114433] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 21.222210] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 21.228827] esp8089_spi: fail_count = 5
[ 21.334298] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 21.442086] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 21.448703] esp8089_spi: fail_count = 6
[ 21.556023] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 21.663783] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 21.670398] esp8089_spi: fail_count = 7
[ 21.775866] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 21.883617] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 21.890231] esp8089_spi: fail_count = 8
[ 21.995690] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 22.103444] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 22.110060] esp8089_spi: fail_count = 9
[ 22.215553] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 22.323312] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 22.329926] esp8089_spi: fail_count = 10
[ 22.437331] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 22.545097] esp8089_spi: first error exit
[ 22.549127] esp8089_spi: esp_spi_probe EXIT
[ 22.553342] eagle: probe of spi0.0 failed with error -110
[ 22.558887] esp8089_spi: sem_timeout = 0
[ 22.562811] esp8089_spi: esp_spi_init err 0
root@OpenWrt:~#
我看到加载驱动的时候可以指定参数,比如说中断口
我的板子是荔枝zero,想用PB5作为中断口,但是他对应的参数是int型的
root@OpenWrt:~# insmod esp8089-spi.ko esp_interrupt=PB5
[ 25.373115] esp8089_spi: loading out-of-tree module taints kernel.
[ 25.381419] esp8089_spi: `PB5' invalid for parameter `esp_interrupt'
那你算一下PB5是多少呀
A是0
B是32
32+5
感谢迪大大的回复,原来还可以这样算的,我基础知识太差了
之前直接接排针容易掉,找了个nodemcu的板子给焊上去了,但是rx输出还是一样的,一直是00
root@OpenWrt:~# insmod esp8089-spi.ko esp_reset_gpio=36 esp_interrupt=37
[ 35.284414] esp8089_spi: loading out-of-tree module taints kernel.
[ 35.293242] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 35.898977] esp8089_spi: esp_spi_dummy_probe enter
[ 35.903832] esp8089_spi: register board OK
[ 35.907996] esp8089_spi: sem_timeout = 0
[ 36.125445] esp8089_spi: ESP8089 power up OK
[ 36.130047] esp8089_spi: esp_spi_probe ENTER
[ 36.134346] esp8089_spi: esp_setup_spi
[ 36.138168] esp8089_spi: sif_spi_protocol_init
[ 36.142609] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 36.149234] esp8089_spi: fail_count = 0
[ 36.255791] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 36.363546] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 36.370163] esp8089_spi: fail_count = 1
[ 36.475697] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 36.583461] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 36.590079] esp8089_spi: fail_count = 2
[ 36.697425] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 36.805183] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 36.811798] esp8089_spi: fail_count = 3
[ 36.917287] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 37.025043] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 37.031662] esp8089_spi: fail_count = 4
[ 37.137145] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 37.244897] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 37.251512] esp8089_spi: fail_count = 5
[ 37.356994] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 37.464749] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 37.471366] esp8089_spi: fail_count = 6
[ 37.577472] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 37.685211] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 37.691827] esp8089_spi: fail_count = 7
[ 37.797296] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 37.905036] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 37.911651] esp8089_spi: fail_count = 8
[ 38.017126] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 38.124866] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 38.131481] esp8089_spi: fail_count = 9
[ 38.236956] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 38.344697] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 38.351312] esp8089_spi: fail_count = 10
[ 38.456870] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 38.564619] esp8089_spi: first error exit
[ 38.568638] esp8089_spi: esp_spi_probe EXIT
[ 38.572852] eagle: probe of spi0.0 failed with error -110
[ 38.578399] esp8089_spi: sem_timeout = 0
[ 38.582322] esp8089_spi: esp_spi_init err 0
最近编辑记录 ma6254 (2020-05-08 16:54:02)
请教迪卡大佬, 为什么ESP8089 和 ESP8266 都可以通过SPI接主控芯片?
他们是不是同一个DIE?有什么区别呢?
楼主大佬有没有 dts 参考一下呢?
楼主大佬有没有 dts 参考一下呢?
感觉不需要,
按readme, 应该这样执行命令或许就可以了:
modprobe esp8089-spi esp_reset_gpio=13 esp_cs0_pin=16 esp_interrupt=26
有进展,起码有数据了,改了spi设备树的interrupts,感觉哪里还没配置好,板子是荔枝zero
root@OpenWrt:~# uname -a
Linux OpenWrt 4.14.14-licheepi-zero+ #3 SMP Fri May 8 21:46:55 CST 2020 armv7l GNU/Linux
root@OpenWrt:~# insmod esp8089-spi.ko esp_reset_gpio=33 esp_interrupt=32
[ 41.873059] esp8089_spi: loading out-of-tree module taints kernel.
[ 41.881785] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 42.487522] esp8089_spi: esp_spi_dummy_probe enter
[ 42.492375] esp8089_spi: register board OK
[ 42.496540] esp8089_spi: sem_timeout = 0
[ 42.714973] esp8089_spi: ESP8089 power up OK
[ 42.719538] esp8089_spi: esp_spi_probe ENTER
[ 42.723810] esp8089_spi: esp_setup_spi
[ 42.727645] esp8089_spi: sif_spi_protocol_init
[ 42.732088] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 42.738716] esp8089_spi: fail_count = 0
[ 42.844994] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 42.853177] eagle spi0.0: SPI transfer failed: -110
[ 42.858111] spi_master spi0: failed to transfer one message from queue
[ 42.864634] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 43.074977] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 43.083239] eagle spi0.0: SPI transfer failed: -110
[ 43.088162] spi_master spi0: failed to transfer one message from queue
[ 43.094685] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 43.102355] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 43.210101] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 43.216712] esp8089_spi: fail_count = 1
[ 43.324968] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 43.333144] eagle spi0.0: SPI transfer failed: -110
[ 43.338055] spi_master spi0: failed to transfer one message from queue
[ 43.344575] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 43.554974] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 43.563239] eagle spi0.0: SPI transfer failed: -110
[ 43.568164] spi_master spi0: failed to transfer one message from queue
[ 43.574684] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 43.582350] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 43.690095] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 43.696708] esp8089_spi: fail_count = 2
[ 43.804981] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 43.813171] eagle spi0.0: SPI transfer failed: -110
[ 43.818106] spi_master spi0: failed to transfer one message from queue
[ 43.824630] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 44.034994] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 44.043258] eagle spi0.0: SPI transfer failed: -110
[ 44.048179] spi_master spi0: failed to transfer one message from queue
[ 44.054698] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 44.062377] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 44.170128] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 44.176743] esp8089_spi: fail_count = 3
[ 44.284972] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 44.293146] eagle spi0.0: SPI transfer failed: -110
[ 44.298061] spi_master spi0: failed to transfer one message from queue
[ 44.304580] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 44.514977] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 44.523239] eagle spi0.0: SPI transfer failed: -110
[ 44.528157] spi_master spi0: failed to transfer one message from queue
[ 44.534676] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 44.542341] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 44.650086] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 44.656700] esp8089_spi: fail_count = 4
[ 44.764974] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 44.773151] eagle spi0.0: SPI transfer failed: -110
[ 44.778069] spi_master spi0: failed to transfer one message from queue
[ 44.784589] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 44.994972] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 45.003235] eagle spi0.0: SPI transfer failed: -110
[ 45.008152] spi_master spi0: failed to transfer one message from queue
[ 45.014673] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 45.022336] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 45.130081] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 45.136698] esp8089_spi: fail_count = 5
[ 45.244965] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 45.253140] eagle spi0.0: SPI transfer failed: -110
[ 45.258051] spi_master spi0: failed to transfer one message from queue
[ 45.264570] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 45.475002] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 45.483259] eagle spi0.0: SPI transfer failed: -110
[ 45.488171] spi_master spi0: failed to transfer one message from queue
[ 45.494691] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 45.502358] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 45.610110] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 45.616722] esp8089_spi: fail_count = 6
[ 45.724980] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 45.733156] eagle spi0.0: SPI transfer failed: -110
[ 45.738080] spi_master spi0: failed to transfer one message from queue
[ 45.744601] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 45.955006] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 45.963266] eagle spi0.0: SPI transfer failed: -110
[ 45.968179] spi_master spi0: failed to transfer one message from queue
[ 45.974699] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 45.982365] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 46.090110] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 46.096726] esp8089_spi: fail_count = 7
[ 46.205025] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 46.213210] eagle spi0.0: SPI transfer failed: -110
[ 46.218159] spi_master spi0: failed to transfer one message from queue
[ 46.224681] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 46.434985] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 46.443251] eagle spi0.0: SPI transfer failed: -110
[ 46.448179] spi_master spi0: failed to transfer one message from queue
[ 46.454700] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 46.462369] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 46.570113] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 46.576726] esp8089_spi: fail_count = 8
[ 46.684971] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 46.693149] eagle spi0.0: SPI transfer failed: -110
[ 46.698069] spi_master spi0: failed to transfer one message from queue
[ 46.704590] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 46.914970] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 46.923236] eagle spi0.0: SPI transfer failed: -110
[ 46.928156] spi_master spi0: failed to transfer one message from queue
[ 46.934677] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 46.942346] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 47.050092] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 47.056706] esp8089_spi: fail_count = 9
[ 47.164964] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 47.173139] eagle spi0.0: SPI transfer failed: -110
[ 47.178049] spi_master spi0: failed to transfer one message from queue
[ 47.184567] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 47.394978] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 47.403233] eagle spi0.0: SPI transfer failed: -110
[ 47.408148] spi_master spi0: failed to transfer one message from queue
[ 47.414669] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 47.422336] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 47.530080] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559
[ 47.536693] esp8089_spi: fail_count = 10
[ 47.644974] spi_master spi0: spi0.0: timeout transferring 6 bytes@100000Hz for 110(100)ms
[ 47.653147] eagle spi0.0: SPI transfer failed: -110
[ 47.658057] spi_master spi0: failed to transfer one message from queue
[ 47.664578] esp8089_spi: sif_spi_write_raw_proto: failed, error: -110
[ 47.874976] spi_master spi0: spi0.0: timeout transferring 10 bytes@100000Hz for 110(100)ms
[ 47.883240] eagle spi0.0: SPI transfer failed: -110
[ 47.888155] spi_master spi0: failed to transfer one message from queue
[ 47.894675] esp8089_spi: spierr sif_spi_write_async_read_proto: failed, error: -110
[ 47.902341] rx:[0x00],[0xbf],[0xc0],[0xab],[0x03],[0xbf],[0x0b],[0x00],[0x00],[0x00]
[ 48.010096] esp8089_spi: first error exit
[ 48.014102] esp8089_spi: esp_spi_probe EXIT
[ 48.018330] eagle: probe of spi0.0 failed with error -110
[ 48.023868] esp8089_spi: sem_timeout = 0
[ 48.027830] esp8089_spi: esp_spi_init err 0
root@OpenWrt:~#
spi0: spi@1c68000 {
compatible = "allwinner,sun8i-h3-spi";
reg = <0x01c68000 0x1000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins>;
status = "disabled";
#address-cells = <1>;
#size-cells = <0>;
最近编辑记录 ma6254 (2020-05-09 16:38:00)
逻辑分析仪抓了下
哥们,哪里的板子?
我也想弄一个;
淘宝买的,给个链接
自己做的,能否共享pcb;谢谢
root@OpenWrt:~# insmod esp8089-spi.ko esp_reset_gpio=36 esp_interrupt=37 [ 35.284414] esp8089_spi: loading out-of-tree module taints kernel. [ 35.293242] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb [ 35.898977] esp8089_spi: esp_spi_dummy_probe enter [ 35.903832] esp8089_spi: register board OK [ 35.907996] esp8089_spi: sem_timeout = 0 [ 36.125445] esp8089_spi: ESP8089 power up OK [ 36.130047] esp8089_spi: esp_spi_probe ENTER [ 36.134346] esp8089_spi: esp_setup_spi [ 36.138168] esp8089_spi: sif_spi_protocol_init [ 36.142609] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 36.149234] esp8089_spi: fail_count = 0 [ 36.255791] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 36.363546] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 36.370163] esp8089_spi: fail_count = 1 [ 36.475697] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 36.583461] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 36.590079] esp8089_spi: fail_count = 2 [ 36.697425] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 36.805183] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 36.811798] esp8089_spi: fail_count = 3 [ 36.917287] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 37.025043] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 37.031662] esp8089_spi: fail_count = 4 [ 37.137145] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 37.244897] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 37.251512] esp8089_spi: fail_count = 5 [ 37.356994] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 37.464749] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 37.471366] esp8089_spi: fail_count = 6 [ 37.577472] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 37.685211] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 37.691827] esp8089_spi: fail_count = 7 [ 37.797296] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 37.905036] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 37.911651] esp8089_spi: fail_count = 8 [ 38.017126] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 38.124866] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 38.131481] esp8089_spi: fail_count = 9 [ 38.236956] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 38.344697] esp8089_spi: /home/mjc/test/ESP8089-SPI/spi_sif_esp.c, 1559 [ 38.351312] esp8089_spi: fail_count = 10 [ 38.456870] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 38.564619] esp8089_spi: first error exit [ 38.568638] esp8089_spi: esp_spi_probe EXIT [ 38.572852] eagle: probe of spi0.0 failed with error -110 [ 38.578399] esp8089_spi: sem_timeout = 0 [ 38.582322] esp8089_spi: esp_spi_init err 0
https://whycan.cn/files/members/2303/_20200508164806.png
https://whycan.cn/files/members/2303/_20200508164625.jpg
https://whycan.cn/files/members/2303/_20200508164620.jpg
https://whycan.cn/files/members/2303/_20200508164634.jpg
板子不错,这样焊比较整洁
[ 26.600400] Adding 905212k swap on /var/swap. Priority:-2 extents:4 across:1167356k SSFS
[ 66.371975] esp8089_spi: loading out-of-tree module taints kernel.
[ 66.396631] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 67.015290] esp8089_spi: esp_spi_dummy_probe enter
[ 67.015484] esp8089_spi: register board OK
[ 67.015497] esp8089_spi: sem_timeout = 0
[ 67.226446] esp8089_spi: ESP8089 power up OK
[ 67.226881] esp8089_spi: esp_spi_probe ENTER
[ 67.226892] esp8089_spi: esp_setup_spi
[ 67.226920] esp8089_spi: sif_spi_protocol_init
[ 67.226933] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 67.226940] esp8089_spi: fail_count = 0
[ 67.352574] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 67.453473] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 67.453485] esp8089_spi: fail_count = 1
[ 67.561299] rx:[0x3f],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 67.662171] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 67.662184] esp8089_spi: fail_count = 2
[ 67.770685] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 68.375609] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1578
[ 68.380606] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 68.884734] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1591
[ 68.888699] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 69.392803] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1603
[ 69.397658] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 69.901795] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1617
[ 69.907142] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.411257] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1630
[ 70.415723] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.919875] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1643
[ 70.931100] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.435197] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 71.439793] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.943983] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 71.950147] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.454206] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 72.458791] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.963012] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 72.968017] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.472106] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 73.476040] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.980207] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 73.984614] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 74.488777] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 74.493607] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 74.997712] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 75.002035] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.506140] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1668
[ 75.509766] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.509787] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1681
[ 75.509929] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.509941] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1694
[ 75.510079] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 76.530982] esp8089_spi: esp_pub_init_all
[ 76.531125] esp8089_spi: esp_download_fw
[ 77.025219] esp8089_spi: sif_platform_irq_init enter
[ 77.244191] esp_host:bdf5087c3deb
[ 77.244321] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[ 77.245832] esp8089_spi: first normal exit
[ 77.245848] esp8089_spi: esp_spi_probe EXIT
[ 77.246132] esp8089_spi: sem_timeout = 0
[ 77.246206] esp8089_spi: esp_spi_remove
[ 77.376590] esp8089_spi: esp_spi_probe ENTER
[ 77.376606] esp8089_spi: esp_setup_spi
[ 77.376614] esp8089_spi: sif_spi_protocol_init
[ 77.376628] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 77.376634] esp8089_spi: fail_count = 0
[ 77.485191] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 77.586224] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 77.586238] esp8089_spi: fail_count = 1
[ 77.693635] rx:[0x3f],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 77.794564] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559
[ 77.794577] esp8089_spi: fail_count = 2
[ 77.901298] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 78.506161] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1578
[ 78.510096] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 79.014201] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1591
[ 79.019392] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 79.523503] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1603
[ 79.528183] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 80.032309] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1617
[ 80.036776] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 80.540880] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1630
[ 80.545516] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 81.049727] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1643
[ 81.061853] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 81.565989] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 81.570411] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 82.074605] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 82.079556] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 82.583775] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 82.589059] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 83.093204] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 83.145532] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 83.649765] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 83.654466] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 84.158628] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 84.163003] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 84.667139] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 84.671465] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 85.175548] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655
[ 85.180071] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 85.684170] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1668
[ 85.689675] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 85.689695] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1681
[ 85.689837] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 85.689851] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1694
[ 85.689987] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 86.710515] esp8089_spi: esp_pub_init_all
[ 86.710532] esp8089_spi: esp_download_fw
[ 87.314819] esp8089_spi: sif_platform_irq_init enter
[ 87.363840] esp_host:bdf5087c3deb
[ 87.588031] esp8089_spi: esp_spi_probe EXIT
[ 87.588344] esp8089_spi: esp_spi_init err 0
[ 88.913171] esp_op_add_interface STA
[ 88.915054] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 90.110801] wlan0: authenticate with 20:dc:e6:fd:c9:77
[ 90.111152] wlan0: send auth to 20:dc:e6:fd:c9:77 (try 1/3)
[ 90.122334] wlan0: authenticated
[ 90.126579] wlan0: associate with 20:dc:e6:fd:c9:77 (try 1/3)
[ 90.137107] wlan0: RX AssocResp from 20:dc:e6:fd:c9:77 (capab=0x431 status=0 aid=2)
[ 90.137311] wlan0: associated
[ 90.571333] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
成功把8266当成wifi网卡,之前的出现以下错误是en脚没有使能。直接接到3.3V后,可以下载固件,并正常加载ko.
[ 72.081984] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 72.182922] esp8089_spi: first error exit
[ 72.182938] esp8089_spi: esp_spi_probe EXIT
[ 72.187142] eagle: probe of spi0.0 failed with error -110
[ 72.187353] esp8089_spi: sem_timeout = 0
[ 72.187367] esp8089_spi: esp_spi_init err 0
[ 177.692206] esp8089_spi: esp_spi_exit
可喜可贺,我也调通了
生成了一个大的空文件来测试速度
PC:
sudo dd if=/dev/zero of=./zero.bin bs=1G seek=100 count=0
python3 -m http.server
板子里:
root@OpenWrt:~# curl -o /dev/null "http://192.168.43.234:8000/a.zip"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
26 286M 26 76.5M 0 0 972k 0 0:05:01 0:01:20 0:03:41 967k^C
root@OpenWrt:~# curl -o /dev/null "http://192.168.43.234:8000/zero.bin"
0 10.0G 0 7451k 0 0 964k 0 3:01:06 0:00:07 3:00:59 978k^C
你后来都很顺利吗?我一直都有一个问题,就是开启中断后就提示超时,看了一下代码应该是等待中断超时,可是我明明设置了中断,而且我这时如果把中断脚接到地就可以成功下一步,而且后面还可以搜到AP(或者我CS脚拉到地也可以)
[ 59.382190] esp8089_spi: sif_platform_irq_init enter
[ 69.602131] resetting event timeout
[ 69.605657] esp8089_spi: esp_init_all failed: -110
[ 69.610435] esp8089_spi: first error exit
[ 69.614611] esp8089_spi: esp_spi_probe EXIT
[ 69.619080] esp8089_spi: sem_timeout = 0
[ 69.623112] esp8089_spi: esp_spi_init err 0
[ 26.600400] Adding 905212k swap on /var/swap. Priority:-2 extents:4 across:1167356k SSFS [ 66.371975] esp8089_spi: loading out-of-tree module taints kernel. [ 66.396631] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb [ 67.015290] esp8089_spi: esp_spi_dummy_probe enter [ 67.015484] esp8089_spi: register board OK [ 67.015497] esp8089_spi: sem_timeout = 0 [ 67.226446] esp8089_spi: ESP8089 power up OK [ 67.226881] esp8089_spi: esp_spi_probe ENTER [ 67.226892] esp8089_spi: esp_setup_spi [ 67.226920] esp8089_spi: sif_spi_protocol_init [ 67.226933] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 67.226940] esp8089_spi: fail_count = 0 [ 67.352574] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 67.453473] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 67.453485] esp8089_spi: fail_count = 1 [ 67.561299] rx:[0x3f],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 67.662171] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 67.662184] esp8089_spi: fail_count = 2 [ 67.770685] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 68.375609] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1578 [ 68.380606] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff] [ 68.884734] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1591 [ 68.888699] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff] [ 69.392803] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1603 [ 69.397658] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 69.901795] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1617 [ 69.907142] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 70.411257] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1630 [ 70.415723] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 70.919875] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1643 [ 70.931100] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 71.435197] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 71.439793] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 71.943983] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 71.950147] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 72.454206] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 72.458791] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 72.963012] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 72.968017] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 73.472106] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 73.476040] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 73.980207] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 73.984614] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 74.488777] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 74.493607] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 74.997712] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 75.002035] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 75.506140] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1668 [ 75.509766] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 75.509787] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1681 [ 75.509929] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 75.509941] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1694 [ 75.510079] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 76.530982] esp8089_spi: esp_pub_init_all [ 76.531125] esp8089_spi: esp_download_fw [ 77.025219] esp8089_spi: sif_platform_irq_init enter [ 77.244191] esp_host:bdf5087c3deb esp_target: e826c2b3c9fd 57 18202 [ 77.244321] esp_readwrite_file: file /system/lib/modules/test_results filp_open error [ 77.245832] esp8089_spi: first normal exit [ 77.245848] esp8089_spi: esp_spi_probe EXIT [ 77.246132] esp8089_spi: sem_timeout = 0 [ 77.246206] esp8089_spi: esp_spi_remove [ 77.376590] esp8089_spi: esp_spi_probe ENTER [ 77.376606] esp8089_spi: esp_setup_spi [ 77.376614] esp8089_spi: sif_spi_protocol_init [ 77.376628] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 77.376634] esp8089_spi: fail_count = 0 [ 77.485191] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 77.586224] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 77.586238] esp8089_spi: fail_count = 1 [ 77.693635] rx:[0x3f],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 77.794564] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1559 [ 77.794577] esp8089_spi: fail_count = 2 [ 77.901298] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 78.506161] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1578 [ 78.510096] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff] [ 79.014201] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1591 [ 79.019392] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff] [ 79.523503] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1603 [ 79.528183] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 80.032309] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1617 [ 80.036776] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 80.540880] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1630 [ 80.545516] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 81.049727] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1643 [ 81.061853] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 81.565989] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 81.570411] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 82.074605] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 82.079556] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 82.583775] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 82.589059] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 83.093204] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 83.145532] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 83.649765] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 83.654466] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 84.158628] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 84.163003] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 84.667139] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 84.671465] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 85.175548] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1655 [ 85.180071] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 85.684170] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1668 [ 85.689675] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 85.689695] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1681 [ 85.689837] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 85.689851] esp8089_spi: /data/raspberry/8266/ESP8089-SPI/spi_sif_esp.c, 1694 [ 85.689987] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] [ 86.710515] esp8089_spi: esp_pub_init_all [ 86.710532] esp8089_spi: esp_download_fw [ 87.314819] esp8089_spi: sif_platform_irq_init enter [ 87.363840] esp_host:bdf5087c3deb esp_target: e826c2b3c9fd 57 18202 [ 87.588031] esp8089_spi: esp_spi_probe EXIT [ 87.588344] esp8089_spi: esp_spi_init err 0 [ 88.913171] esp_op_add_interface STA [ 88.915054] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 90.110801] wlan0: authenticate with 20:dc:e6:fd:c9:77 [ 90.111152] wlan0: send auth to 20:dc:e6:fd:c9:77 (try 1/3) [ 90.122334] wlan0: authenticated [ 90.126579] wlan0: associate with 20:dc:e6:fd:c9:77 (try 1/3) [ 90.137107] wlan0: RX AssocResp from 20:dc:e6:fd:c9:77 (capab=0x431 status=0 aid=2) [ 90.137311] wlan0: associated [ 90.571333] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 72.081984] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 72.182922] esp8089_spi: first error exit [ 72.182938] esp8089_spi: esp_spi_probe EXIT [ 72.187142] eagle: probe of spi0.0 failed with error -110 [ 72.187353] esp8089_spi: sem_timeout = 0 [ 72.187367] esp8089_spi: esp_spi_init err 0 [ 177.692206] esp8089_spi: esp_spi_exit
我试了一下,去掉中断不可以呢。
把这部分屏蔽不行呢。在esp_main.c
gl_bootup_cplx = &complete;
epub->wait_reset = 0;
sif_enable_irq(epub);
if(epub->sdio_state == ESP_SDIO_STATE_SECOND_INIT || sif_get_ate_config() == 1){
ret = sip_poll_bootup_event(epub->sip);
} else {
ret = sip_poll_resetting_event(epub->sip);
if (ret == 0) {
sif_lock_bus(epub);
sif_interrupt_target(epub, 7);
sif_unlock_bus(epub);
gl_bootup_cplx = NULL;
if (sif_get_ate_config() == 1)
ret = -EOPNOTSUPP;
没有注释的
iroot@dika-pc:~# insmod esp8089-spi.ko
[ 65.213159] esp8089_spi: loading out-of-tree module taints kernel.
[ 65.228569] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 65.234474] esp8089_spi: poweron
[ 65.838454] esp8089_spi: esp_spi_dummy_probe enter
[ 65.844056] esp8089_spi: I will go dead
[ 65.848284] esp8089_spi: I am OK
[ 65.851806] esp8089_spi: register board OK
[ 65.856390] esp8089_spi: sem_timeout = 0
[ 66.072035] esp8089_spi: ESP8089 power up OK
[ 66.077361] esp8089_spi: esp_spi_probe ENTER
[ 66.082243] esp8089_spi: esp_setup_spi
[ 66.086392] esp8089_spi: sif_spi_protocol_init
[ 66.091242] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 66.101061] esp8089_spi: fail_count = 0
[ 66.231834] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 66.340450] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 66.350274] esp8089_spi: fail_count = 1
[ 66.463608] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 66.572247] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 66.582060] esp8089_spi: fail_count = 2
[ 66.694617] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 67.302569] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 67.317987] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 67.826062] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 67.841357] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 68.349446] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 68.365341] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 68.873472] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 68.888651] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 69.396793] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 69.425463] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 69.933547] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 69.967208] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.511327] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 70.563405] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.108057] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 71.160695] rx:[0xff],[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.707169] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 71.763010] rx:[0xff],[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.311245] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 72.368811] rx:[0xff],[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.918426] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 72.976042] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.525712] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 73.583312] rx:[0xff],[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 74.133500] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 74.191117] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 74.741480] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 74.799126] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.349603] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 75.407202] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.458201] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 75.515852] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.566801] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 75.624272] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 76.680657] esp8089_spi: esp_pub_init_all
[ 76.706385] esp8089_spi: downloadesp_download_fw
[ 76.857114] random: crng init done
[ 76.881730] random: 7 urandom warning(s) missed due to ratelimiting
[ 80.223072] esp8089_spi: sif_platform_irq_init enter
[ 80.527507] esp_host:bdf5087c3deb
[ 80.527507] esp_target: e826c2b3c9fd 57 18202
[ 80.527507]
[ 80.598417] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[ 80.654330] esp8089_spi: first normal exit
[ 80.678966] esp8089_spi: esp_spi_probe EXIT
[ 80.703763] esp8089_spi: sem_timeout = 0
[ 80.727807] esp8089_spi: esp_spi_remove
[ 80.922225] esp8089_spi: esp_spi_probe ENTER
[ 80.946062] esp8089_spi: esp_setup_spi
[ 80.968991] esp8089_spi: sif_spi_protocol_init
[ 80.992377] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 81.038581] esp8089_spi: fail_count = 0
[ 81.172482] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 81.317245] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 81.363166] esp8089_spi: fail_count = 1
[ 81.493955] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 81.638384] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 81.683966] esp8089_spi: fail_count = 2
[ 81.814245] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 82.457645] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 82.508701] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 83.052275] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 83.103360] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 83.646886] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 83.697736] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 84.241324] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 84.292412] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 84.835998] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 84.896748] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 85.440487] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 85.493332] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 86.038020] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 86.091099] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 86.636770] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 86.690563] rx:[0xff],[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 87.236891] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 87.291195] rx:[0xff],[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 87.839591] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 87.896524] rx:[0xff],[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 88.445959] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 88.503078] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 89.052786] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 89.110293] rx:[0xff],[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 89.660406] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 89.718079] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 90.268586] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 90.326790] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 90.877317] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 90.935472] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 90.986449] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 91.044053] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 91.094952] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 91.153159] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 92.209866] esp8089_spi: esp_pub_init_all
[ 92.235656] esp8089_spi: downloadesp_download_fw
[ 95.764156] esp8089_spi: sif_platform_irq_init enter
[ 95.824475] esp8089_spi: esp_spi_probe EXIT
[ 95.850211] esp8089_spi: esp_spi_init err 0
[ 95.892594] esp_host:bdf5087c3deb
[ 95.892594] esp_target: e826c2b3c9fd 57 18202
[ 95.892594]
注释的
[ 54.669147] esp8089_spi: loading out-of-tree module taints kernel.
[ 54.684727] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 54.690480] esp8089_spi: poweron
[ 55.294695] esp8089_spi: esp_spi_dummy_probe enter
[ 55.300136] esp8089_spi: I will go dead
[ 55.304497] esp8089_spi: I am OK
[ 55.308054] esp8089_spi: register board OK
[ 55.312607] esp8089_spi: sem_timeout = 0
[ 55.531980] esp8089_spi: ESP8089 power up OK
[ 55.537324] esp8089_spi: esp_spi_probe ENTER
[ 55.542201] esp8089_spi: esp_setup_spi
[ 55.546358] esp8089_spi: sif_spi_protocol_init
[ 55.551210] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 55.561021] esp8089_spi: fail_count = 0
[ 55.692091] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 55.800619] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 55.810433] esp8089_spi: fail_count = 1
[ 55.922643] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 56.031229] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 56.041045] esp8089_spi: fail_count = 2
[ 56.153565] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 56.761553] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 56.778179] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 57.286414] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 57.303044] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 57.811272] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 57.828048] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 58.336241] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 58.351534] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 58.859752] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 58.888941] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 59.397107] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 59.430476] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 59.974777] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 60.026648] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 60.571363] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 60.624304] rx:[0xff],[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 61.170744] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 61.225841] rx:[0xff],[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 61.774241] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 61.831059] rx:[0xff],[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 62.380644] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 62.438487] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 62.988421] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 63.047642] rx:[0xff],[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 63.597803] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 63.655841] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 64.206337] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 64.264346] rx:[0xff],[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 64.814901] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 64.873001] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 64.923916] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 64.981589] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 65.032581] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 65.089883] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 66.146896] esp8089_spi: esp_pub_init_all
[ 66.172604] esp8089_spi: downloadesp_download_fw
[ 66.337374] random: crng init done
[ 69.540394] esp8089_spi: first normal exit
[ 69.565672] esp8089_spi: esp_spi_probe EXIT
[ 69.591165] esp8089_spi: sem_timeout = 0
[ 69.615827] esp8089_spi: esp_spi_remove
[ 69.752243] esp8089_spi: esp_spi_probe ENTER
[ 69.776637] esp8089_spi: esp_setup_spi
[ 69.800169] esp8089_spi: sif_spi_protocol_init
[ 69.824209] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 69.871830] esp8089_spi: fail_count = 0
[ 70.006603] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.152729] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 70.199998] esp8089_spi: fail_count = 1
[ 70.331260] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.476976] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 70.523961] esp8089_spi: fail_count = 2
[ 70.655079] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.800530] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 70.847144] esp8089_spi: fail_count = 3
[ 70.978064] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.123087] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 71.169345] esp8089_spi: fail_count = 4
[ 71.299906] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.444655] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 71.490520] esp8089_spi: fail_count = 5
[ 71.621241] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.765606] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 71.811168] esp8089_spi: fail_count = 6
[ 71.941996] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.086032] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 72.131192] esp8089_spi: fail_count = 7
[ 72.261107] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.404730] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 72.449561] esp8089_spi: fail_count = 8
[ 72.579921] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.723926] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 72.769761] esp8089_spi: fail_count = 9
[ 72.910199] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.056031] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 73.104049] esp8089_spi: fail_count = 10
[ 73.236265] rx:[0xff],[0xff],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.383368] esp8089_spi: esp_spi_remove
[ 73.407044] esp8089_spi: esp_spi_remove no sctrl
[ 73.431183] eagle: probe of spi0.0 failed with error -110
[ 73.456373] esp8089_spi: esp_spi_init err 0
root@dika-pc:~#
迪神牛X,特来膜拜下,改后的文件发一份上来?
我用spi1接8266-12f 数据线时钟线都有数据了 可是出现了以下错误 不知道什么原因 插个眼
esp8089_spi: spierr byte read cmd resp 0x00 no recv
每次启动都要下载一次固件吗?可不可以跳过这部分
这个下载了没反应是怎么回事
此文必须标记
不错,正要调试ESP8089
卡在挺靠前的位置了
root@pop-os:/lib/modules/5.2.0-licheepi-nano+# ls
esp8089-spi.ko modules.builtin modules.dep.bin modules.softdep
modules.alias modules.builtin.bin modules.devname modules.symbols
modules.alias.bin modules.dep modules.order modules.symbols.bin
root@pop-os:/lib/modules/5.2.0-licheepi-nano+# modprobe esp8089-spi.ko
modprobe: FATAL: Module esp8089-spi.ko not found in directory /lib/modules/5.2.0-licheepi-nano+
这。。。什么鬼?我已经把.ko拷过去了啊?
各位大佬有没有什么思路?
解决了
原来要这样。。。
最近编辑记录 DoZh (2020-06-19 03:01:01)
我也出现了这个错误提示,多次重启之后加载ESP8089模块会报EXT4 xxxxx的错误,因为我的rootfs分区是EXT4的,于是改为EXT3之后就OK了,顺利出现WLAN0~~~,不知道你这个跟我一样不
... esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1681 rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] esp8089_spi: /home/dika/DVPM_linux-5.2/spiwifi1/ESP8089-SPI-master/spi_sif_esp.c, 1694 rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] esp8089_spi: spierr byte read cmd resp 0x00 no recv esp8089_spi: spierr byte read cmd resp 0x00 no recv ... esp8089_spi: spierr byte read cmd resp 0x00 no recv
感谢分享,先mark了,闲了调试看看。。。。。
有没有 esp8089 的原理图?
没辙了,怎么调试ESP8089/8266都没反应.
有没有哪位大佬能够指点一二?
用的是f1c100s的PA0-PA3做SPI1,ESP8089和8266都试过,换了几块板子了,感觉芯片都没有响应。。。
终端输出:
root@pop-os:~# insmod /lib/modules/5.2.0-licheepi-nano+/esp8089-spi.ko esp_reset_gpio=130 esp_cs0_pin=0 esp_interrupt=131
[ 100.487205] esp8089_spi: loading out-of-tree module taints kernel.
[ 100.502255] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 101.107979] esp8089_spi: esp_spi_dummy_probe enter
[ 101.113372] esp8089_spi: register board OK
[ 101.117707] esp8089_spi: sem_timeout = 0
[ 101.339049] esp8089_spi: ESP8089 power up OK
[ 101.344184] esp8089_spi: esp_spi_probe ENTER
[ 101.348713] esp8089_spi: esp_setup_spi
[ 101.352844] esp8089_spi: sif_spi_protocol_init
[ 101.357535] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 101.366256] esp8089_spi: fail_count = 0
[ 101.484912] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 101.593085] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 101.601821] esp8089_spi: fail_count = 1
[ 101.711623] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 101.819797] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 101.828460] esp8089_spi: fail_count = 2
[ 101.938086] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 102.046329] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 102.055057] esp8089_spi: fail_count = 3
[ 102.170503] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 102.290458] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 102.311082] esp8089_spi: fail_count = 4
[ 102.427085] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 102.546976] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 102.567478] esp8089_spi: fail_count = 5
[ 102.683231] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 102.803629] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 102.825123] esp8089_spi: fail_count = 6
[ 102.941701] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 103.063014] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 103.084966] esp8089_spi: fail_count = 7
[ 103.201628] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 103.322898] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 103.344858] esp8089_spi: fail_count = 8
[ 103.461802] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 103.583043] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 103.604976] esp8089_spi: fail_count = 9
[ 103.721343] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 103.842613] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559
[ 103.864570] esp8089_spi: fail_count = 10
[ 103.981306] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00]
[ 104.102631] esp8089_spi: first error exit
[ 104.113547] esp8089_spi: esp_spi_probe EXIT
[ 104.124558] eagle: probe of spi1.0 failed with error -110
[ 104.137024] esp8089_spi: sem_timeout = 0
[ 104.147740] esp8089_spi: esp_spi_init err 0
root@pop-os:~#
原理图:
逻辑分析仪吐出来的时序图:
ESP8266串口0输出的启动信息:
ets Jan 8 2013,rst cause:1, boot mode:(6,2)
ets Jan 8 2013,rst cause:1, boot mode:(6,6)
waiting for host
waiting for host
有没有哪位大佬能够指点一二?
终端输出:
root@pop-os:~# insmod /lib/modules/5.2.0-licheepi-nano+/esp8089-spi.ko esp_reset_gpio=130 esp_cs0_pin=0 esp_interrupt=131 [ 100.487205] esp8089_spi: loading out-of-tree module taints kernel. [ 100.502255] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb [ 101.107979] esp8089_spi: esp_spi_dummy_probe enter [ 101.113372] esp8089_spi: register board OK [ 101.117707] esp8089_spi: sem_timeout = 0 [ 101.339049] esp8089_spi: ESP8089 power up OK [ 101.344184] esp8089_spi: esp_spi_probe ENTER [ 101.348713] esp8089_spi: esp_setup_spi [ 101.352844] esp8089_spi: sif_spi_protocol_init [ 101.357535] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 101.366256] esp8089_spi: fail_count = 0 [ 101.484912] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 101.593085] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 101.601821] esp8089_spi: fail_count = 1 [ 101.711623] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 101.819797] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 101.828460] esp8089_spi: fail_count = 2 [ 101.938086] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 102.046329] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 102.055057] esp8089_spi: fail_count = 3 [ 102.170503] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 102.290458] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 102.311082] esp8089_spi: fail_count = 4 [ 102.427085] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 102.546976] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 102.567478] esp8089_spi: fail_count = 5 [ 102.683231] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 102.803629] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 102.825123] esp8089_spi: fail_count = 6 [ 102.941701] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 103.063014] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 103.084966] esp8089_spi: fail_count = 7 [ 103.201628] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 103.322898] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 103.344858] esp8089_spi: fail_count = 8 [ 103.461802] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 103.583043] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 103.604976] esp8089_spi: fail_count = 9 [ 103.721343] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 103.842613] esp8089_spi: /home/dozh/embedded_linux/f1c200s/ESP8089-SPI/spi_sif_esp.c, 1559 [ 103.864570] esp8089_spi: fail_count = 10 [ 103.981306] rx:[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00],[0x00] [ 104.102631] esp8089_spi: first error exit [ 104.113547] esp8089_spi: esp_spi_probe EXIT [ 104.124558] eagle: probe of spi1.0 failed with error -110 [ 104.137024] esp8089_spi: sem_timeout = 0 [ 104.147740] esp8089_spi: esp_spi_init err 0 root@pop-os:~#
原理图:
https://whycan.cn/files/members/2701/Snipaste_2020-07-28_22-35-28.png逻辑分析仪吐出来的时序图:
https://whycan.cn/files/members/2701/Snipaste_2020-07-28_22-42-07.png
https://whycan.cn/files/members/2701/Snipaste_2020-07-28_22-48-52.pngESP8266串口0输出的启动信息:
ets Jan 8 2013,rst cause:1, boot mode:(6,2) ets Jan 8 2013,rst cause:1, boot mode:(6,6) waiting for host ets Jan 8 2013,rst cause:1, boot mode:(6,6) waiting for host
感觉还是芯片工作不正常或者没焊接好,CHIP_EN脚看看是不是高电平
我的几乎都是这样,可能几十次之中会有一个能够接受到数据的
root@lign-G3-3579:~# insmod esp8089-spi.ko esp_reset_gpio=100 esp_interrupt=101
[ 40.118584] esp8089_spi: loading out-of-tree module taints kernel.
[ 40.141832] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 40.747336] esp8089_spi: esp_spi_dummy_probe enter
[ 40.752689] esp8089_spi: register board OK
[ 40.757011] esp8089_spi: sem_timeout = 0
[ 40.978375] esp8089_spi: ESP8089 power up OK
[ 40.983429] esp8089_spi: esp_spi_probe ENTER
[ 40.987947] esp8089_spi: esp_setup_spi
[ 41.029403] esp8089_spi: sif_spi_protocol_init
[ 41.034135] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 41.042747] esp8089_spi: fail_count = 0
[ 41.179144] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 41.287232] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 41.295755] esp8089_spi: fail_count = 1
[ 41.408015] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 41.516195] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 41.524725] esp8089_spi: fail_count = 2
[ 41.636543] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 41.744690] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 41.753208] esp8089_spi: fail_count = 3
[ 41.866619] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 41.974690] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 41.994558] esp8089_spi: fail_count = 4
[ 42.115036] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 42.234544] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 42.254508] esp8089_spi: fail_count = 5
[ 42.383613] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 42.503734] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 42.524648] esp8089_spi: fail_count = 6
[ 42.649902] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 42.770822] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 42.792176] esp8089_spi: fail_count = 7
[ 42.913071] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 43.033852] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 43.055174] esp8089_spi: fail_count = 8
[ 43.173997] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 43.294812] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 43.316164] esp8089_spi: fail_count = 9
[ 43.513360] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 43.634279] esp8089_spi: /home/lign/work/lichee/linux_sd/ESP8089-SPI/spi_sif_esp.c, 1559
[ 43.655658] esp8089_spi: fail_count = 10
[ 43.775698] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 43.896530] esp8089_spi: first error exit
[ 43.907218] esp8089_spi: esp_spi_probe EXIT
[ 43.918009] eagle: probe of spi1.0 failed with error -110
[ 43.930260] esp8089_spi: sem_timeout = 0
[ 43.940746] esp8089_spi: esp_spi_init err 0
我也是,你的问题解决了吗
有没有哪位大佬能够指点一二?
终端输出:
原理图:
谢谢指点,
我也感觉是芯片没焊好,甚至怀疑是板子不对,然后重焊、重画了板子甚至拿了一块esp12f飞线,结果一样。。。。。
我再查查吧。。。。
root@pop-os:~#
还没呢,情况和你一样,芯片无响应。
我也是,你的问题解决了吗
root@pop-os:~#
谢谢大佬提醒,我再调一下spi接口驱动模式试试
请大家看第60楼,我已经给了提示,这里要注意
试了下,每次大概会在重试到70次左右的时候,开始输出0xff 0xfe 0x03 ... , 但预期的应该是0xff 0xff 0x01,感觉正好有一个一位的位移。。。。
设备树里的spi mode0和 mode3都试过,一样。。比较懵。。。
用MCU简单验证了一下,每次都正常输出0xff 0xff 0x01, 看逻辑分析仪想到可能是f1c200s的SCK在CS脚拉低之前有一个脉冲,找了下可能可以这样解决:
https://linux-sunxi.org/SPIdev#LOW_on_SCK_line_on_transfer_start_when_using_SPI-Mode3
有时间试一下
有时间试一下
改了驱动代码,这个问题解决了,进下载固件的部分了,开始报下面的错误:
[ 201.832613] esp8089_spi: spierr byte read cmd resp 0x00 no recv
[ 201.865102] esp8089_spi: spierr byte read cmd resp 0x00 no recv
[ 201.897660] esp8089_spi: spierr byte read cmd resp 0x00 no recv
[ 201.930467] esp8089_spi: spierr byte read cmd resp 0x00 no recv
怀疑是中断的问题,继续调吧
DoZh 说:用MCU简单验证了一下,每次都正常输出0xff 0xff 0x01, 看逻辑分析仪想到可能是f1c200s的SCK在CS脚拉低之前有一个脉冲,找了下可能可以这样解决:
有时间试一下
[ 201.832613] esp8089_spi: spierr byte read cmd resp 0x00 no recv [ 201.865102] esp8089_spi: spierr byte read cmd resp 0x00 no recv [ 201.897660] esp8089_spi: spierr byte read cmd resp 0x00 no recv [ 201.930467] esp8089_spi: spierr byte read cmd resp 0x00 no recv
怀疑是中断的问题,继续调吧
从ESP8089换成8266,问题直接消失了。。。。
现在看起来网络是通了,但是中断脚是接地的,不然驱动初始化的时候还是会报另一个错。
这种情况下CPU一直在响应中断,终端都卡的要死。。。
还是要继续想办法,比如能不能屏蔽初始化时的中断超时检测。
自己跑一会内存居然还出错了。。。。
[ 963.708463] kworker/u2:4: page allocation failure: order:0, mode:0xa20(GFP_ATOMIC), nodemask=(null)
[ 963.729931] CPU: 0 PID: 105 Comm: kworker/u2:4 Tainted: G O 5.2.0-licheepi-nano+ #45
先这样改吧,屏蔽掉初始化时的中断检测,改完就算是调通了
--- a/esp_sip.c
+++ b/esp_sip.c
@@ -46,6 +46,7 @@
#include "esp_ext.h"
#endif /* USE_EXT_GPIO */
+extern struct task_struct *sif_irq_thread;
@@ -2206,7 +2207,11 @@ sip_poll_bootup_event(struct esp_sip *sip)
esp_dbg(ESP_DBG_TRACE, "******time remain****** = [%d]\n", ret);
if (ret <= 0) {
esp_dbg(ESP_DBG_ERROR, "bootup event timeout\n");
- return -ETIMEDOUT;
+ //return -ETIMEDOUT;
+ sip->epub->wait_reset = 0;
+ wake_up_process(sif_irq_thread);
+ esp_dbg(ESP_DBG_ERROR, "for unknow reason,we may not be informed the boot/rst complete event, assume it completed and continue here\n");
+ msleep(50);
if(sif_get_ate_config() == 0){
@@ -2240,7 +2245,11 @@ sip_poll_resetting_event(struct esp_sip *sip)
if (ret <= 0) {
esp_dbg(ESP_DBG_ERROR, "resetting event timeout\n");
+ msleep(50);
最近编辑记录 DoZh (2020-09-07 18:26:00)
前几天画板子前调了一天搞不定,反复看这个帖子,看来看来看去都像考试题。不会
第二天没有办法之下请出神器:树莓派。
按照原来帖子,树莓派的接法,很快跑通,然后再调板子。一共花了一天半。
要点:
- 按照rockchip的文档对确定好电路,按照github原贴对一遍。https://wenku.baidu.com/view/e93f719184254b35eefd3474.html
- cs 接地(如rockchip设计)
- 下载外网文件700K/s,同时用 PC 测试 9M/s
- 芯片好烫(我是拆了一共nodemcu飞线来用)
- 树莓派真是居家良药
下面是我的改动 git diff
diff --git i/.gitignore w/.gitignore
index c6127b3..b88f0e7 100644
--- i/.gitignore
+++ w/.gitignore
@@ -50,3 +50,5 @@ modules.order
Module.symvers
Mkfile.old
dkms.conf
+.cache.mk
diff --git i/Makefile w/Makefile
index c25d8fa..693ae60 100755
--- i/Makefile
+++ w/Makefile
@@ -9,7 +9,8 @@ KVERS_ARCH ?= $(shell arch)
# KBUILD is the path to the Linux kernel build tree. It is usually the
# same as the kernel source tree, except when the kernel was compiled in
# a separate directory.
-KBUILD ?= $(shell readlink -f /lib/modules/$(KVERS_UNAME)/build)
+# KBUILD ?= /work/f1c100s/f1c100s-linux #$(shell readlink -f /lib/modules/$(KVERS_UNAME)/build)
+KBUILD ?= /work/f1c100s/f1c100s-linux
ifeq (,$(KBUILD))
$(error Kernel build tree not found - please set KBUILD to configured kernel)
diff --git i/spi_stub.c w/spi_stub.c
index d4ffd96..26b075e 100755
--- i/spi_stub.c
+++ w/spi_stub.c
@@ -3,9 +3,9 @@
/* https://www.signal.com.tr/pdf/cat/8n-esp8266_spi_reference_en_v1.0.pdf */
-#define SPI_FREQ (10000000)
+//#define SPI_FREQ (10000000)
//#define SPI_FREQ (20000000) // 1. 22.5Mhz 2. 45Mhz
-//#define SPI_FREQ (30000000) // 1. 22.5Mhz 2. 45Mhz
+#define SPI_FREQ (30000000) // 1. 22.5Mhz 2. 45Mhz
//Below are for spi HZ 22.5M
#if (SPI_FREQ == 30000000)
@@ -109,9 +109,9 @@ static struct spi_board_info esp_board_spi_devices[] = {
.modalias = "ESP8089_0",
.max_speed_hz = MAX_SPEED_HZ,
- .bus_num = 1,
- .chip_select = 0,
- .mode = 0,
+ .bus_num = 0,
+ .chip_select = 1,
+ .mode = SPI_MODE_3,
不是说v3s有大神搞定了ESP8089WiFi驱动?sdio的,USB?阉割版,m4驱动常规USBWiFi然后配置写死搞出个普及版?
最近编辑记录 whyabc666 (2021-01-03 13:44:13)
ma6254 说:迪神NB
我尝试在openwrt跑跑看,不知道能不能长期用,还有就是8266在这种工作模式下的休眠和唤醒会不会有问题休眠??老子不让他休眠
请问怎么让ESP8089不进入休眠,我刚把它驱动起来,就回了消息20(SIP_EVT_SLEEP)
[W/SDIO] vdd=0,bit=23,power_mode=0
clock 0Hz busmode 1 powermode 1 cs 0 Vdd 23 width 0
clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 23 width 0
clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 23 width 0
[E/MMC] mmc err=0x00000100,risr_reg=0x00000000,risr=0x00000104
[E/MMC] [err]:0x00000100, RTO
[E/MMC] mmc cmd 8 err
clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 14 width 0
clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 14 width 0
[D/SDIO] function 0, CIS tuple code 1, length 3
CISTPL_MANFID[0] 0x6666 0x1111[D/SDIO] function 0, CIS tuple code 21, length 2
[D/SDIO] function 0, CIS tuple code 1a, length 5
[D/SDIO] function 0, CIS tuple code 1b, length 8
clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 14 width 0
clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 14 width 2
CISTPL_MANFID[1] 0x6666 0x1111[D/SDIO] function 1, CIS tuple code 21, length 2
[D/SDIO] function 1, CIS tuple code 80, length 1
[D/SDIO] function 1, CIS tuple code 81, length 1
[D/SDIO] function 1, CIS tuple code 82, length 1
sdio_function_num=1,manufacturer=6666,product=1111esp8089 manufacturer=6666,product=1111sdio_function[1]->product=0x1111[I/esp] esp_sif_sdio_probe >> enter
SDIO: enabling function func[1]=800cebb0 with func[0]=800ceaec
SDIO: enabled function successfull
[I/esp] esp_sif_sdio_probe >> power_on err 0
[D/esp]
SLC data 0x12102500, ID 0x00000600
[E/esp] esp_msg_level=0x00000007[I/esp] esp_sif_sdio_init_all offset=0x10,addr=0x40100000,len=0xc130
[I/esp] esp_sif_sdio_init_all offset=0xc148,addr=0x3ffe8000,len=0xf4
[I/esp] esp_sif_sdio_init_all offset=0xc244,addr=0x3ffe8100,len=0x920
SDIO: enabling IRQ for function 1
[I/esp] sending bootup
[I/esp] sip_alloc_skbuf ptr=800cf294,len=16,sip_type=0,sip_cmd=5
[I/esp] sip_cmd=5,seq=222
[I/esp] sip_free_skbuff ptr=800cf294,len=16,ref=1
[I/e[I/esp] sif_dsr enter 0
[D/esp] sif_dsr real_intr_cnt 1[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2bc8 first_sz=12 ref=1
[I/esp] sip_rx first_skb only
[I/esp] esp_sip_rx_pkt_process Hcredits 0x0000c068, realCredits 104
[D/esp] sip_update_tx_credits:before add, credits is 0
[I/esp] sip_update_tx_credits:after add 104, credits is 104
[I/esp] esp_sip_rx_pkt_process first_pkt_len 12, whole pkt len 12
[I/esp] seq 0
[I/esp] sip_parse_events evtid=0
[I/esp] sip_alloc_skbuf ptr=800d2de4,len=140,sip_type=0,sip_cmd=7
[I/esp] sip_cmd=7,seq=0
[I/esp] sip_free_skbuff ptr=800d2de4,len=140,ref=1
[I/esp] sip_free_skbuff ptr=800d2bc8,len=12,ref=1
[I/esp] sif_dsr enter 1
[D/esp] sif_dsr bogus_intr_cnt 1
sgussent bootup
[I/esp] polling resetting event...
[I/esp] sif_dsr enter 2
[D/esp] sif_dsr real_intr_cnt 2[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2bc8 first_sz=256 ref=1
[I/esp] esp_sip_rx_pkt_process Hcredits 0x00100001, realCredits 1
[D/esp] sip_update_tx_credits:before add, credits is 103
[I/esp] sip_update_tx_credits:after add 1, credits is 104
[I/esp] esp_sip_rx_pkt_process first_pkt_len 256, whole pkt len 256
[I/esp] seq 1
[I/esp] sip_parse_events evtid=8
[I/esp] esp_target: e826c2b3c9fd 57 18202
[I/esp] sip_free_skbuff ptr=800d2bc8,len=256,ref=1
[I/esp] sif_dsr enter 3
[D/esp] sif_dsr real_intr_cnt 3[I/esp] sip_rx enter
[I/esp] esp_sip_rx_pkt_process Hcredits 0x0000c000, realCredits 0
[I/esp] seq 2
[I/esp] sip_parse_events evtid=16
[I/esp] sif_dsr enter 4
[D/esp] sif_dsr bogus_intr_cnt 2
[I/esp] sif_dsr enter 5
[D/esp] sif_dsr bogus_intr_cnt 3
[I/esp] target resetting 0
[I/esp] esp_sif_sdio_probe return 0
[I/esp] first normal exit
SDIO: disabling IRQ for function 1
[E/MMC] mmc err=0x00000100,risr_reg=0x00000010,risr=0x00000114
[E/MMC] mmc cmd 52 err
[E/esp] sif_disable_irq release irq failed
[W/SDIO] vdd=14,bit=23,power_mode=2
clock 50000000Hz busmode 1 powermode 2 cs 0 Vdd 23 width 0
SDIO: enabling function func[1]=800cebcc with func[0]=800ceaec
[D/esp]
[I/esp] esp_sif_sdio_init_all offset=0x10,addr=0x40100000,len=0xfcc8
[I/esp] esp_sif_sdio_init_all offset=0xfce0,addr=0x3ffe8000,len=0x3de
[I/esp] esp_sif_sdio_init_all offset=0x100c6,addr=0x3ffe83e0,len=0x4b4
[I/esp] sip_alloc_skbuf ptr=800d2bf4,len=16,sip_type=0,sip_cmd=5
[I/esp] sip_cmd=5,seq=286
[I/esp] sip_free_skbuff ptr=800d2bf4,len=16,ref=1
[I/esp] sent bootup
[I/esp] polling bootup event...
[I/esp] sif_dsr enter 6
[D/esp] sif_dsr real_intr_cnt 4[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2c20 first_sz=12 ref=1
[I/esp] seq 0
[I/esp] sip_alloc_skbuf ptr=800d2e3c,len=140,sip_type=0,sip_cmd=7
[I/esp] sip_free_skbuff ptr=800d2e3c,len=140,ref=1
[I/esp] sip_free_skbuff ptr=800d2c20,len=12,ref=1
[I/esp] sif_dsr enter 7
[D/esp] sif_dsr bogus_intr_cnt 4
[I/esp] sif_dsr enter 8
[D/esp] sif_dsr real_intr_cnt 5[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2c20 first_sz=28 ref=1
[I/esp] esp_sip_rx_pkt_process Hcredits 0x0001c001, realCredits 1
[I/esp] esp_sip_rx_pkt_process first_pkt_len 28, whole pkt len 28
[I/esp] seq 1
[I/esp] sip_post_init tx_blksz 260 rx_blksz 524 mac ac:d0:74:d3:f8:c6
[I/esp] sip_free_skbuff ptr=800d2c20,len=28,ref=1
[I/esp] sif_dsr enter 9
[D/esp] sif_dsr real_intr_cnt 6[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2c20 first_sz=256 ref=1
[I/esp] esp_sip_rx_pkt_process Hcredits 0x00100000, realCredits 0
[I/esp] seq 2
[I/esp] sip_free_skbuff ptr=800d2c20,len=256,ref=1
[I/esp] sif_dsr enter 10
[D/esp] sif_dsr bogus_intr_cnt 5
[I/esp] sif_dsr enter 11
[D/esp] sif_dsr bogus_intr_cnt 6
[I/esp] target booted up
[I/esp] second normal exit
[I/esp] sif_dsr enter 12
[D/esp] sif_dsr real_intr_cnt 7[I/esp] sip_rx enter
[I/esp] sip_rx rx_buf=800d2bf4 first_sz=12 ref=1
[I/esp] s
[I/esp] seq 3
[I/esp] sip_parse_events evtid=20 //ESP进入休眠?
[I/esp] sip_free_skbuff ptr=800d2bf4,len=12,ref=1
[I/esp] sif_dsr enter 13
[D/esp] sif_dsr bogus_intr_cnt 7
我也来了,今天开搞
f1c100s怎么和8266接线对应呢?
停在距离大神喊牛逼的位置无所适从
[ 80.631193] esp8089_spi: loading out-of-tree module taints kernel.
[ 80.645144] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 81.249796] sun6i-spi 1c05000.spi: chipselect 0 already in use
[ 81.255804] esp8089_spi: FAILED to create slave
[ 81.260399] 8<--- cut here ---
[ 81.263558] Unable to handle kernel NULL pointer dereference at virtual address 000001b8
[ 81.271743] pgd = (ptrval)
[ 81.274482] [000001b8] *pgd=80ca3831, *pte=00000000, *ppte=00000000
[ 81.280794] Internal error: Oops: 17 [#1] ARM
[ 81.285167] Modules linked in: esp8089_spi(O+)
[ 81.289658] CPU: 0 PID: 122 Comm: insmod Tainted: G W O 5.7.1 #7
大佬们给看看呗
[ 81.255804] esp8089_spi: FAILED to create slaveSPI-CS 已经被flash使用了吧?
没有flash
设备树配置如下:
dtsi
pio节点下面
spi0_pins: spi0-pins {
function = "spi0";
soc节点下面
spi0:spi@1c05000 {
compatible = "allwinner,suniv-spi", "allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <0xa>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
status = "disabled";
#address-cells = <1>;
#size-cells = <0>;
dts
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins>;
spidev@0x00 {
compatible = "spidev";
spi-max-frequency = <100000000>;
reg = <0>;
刚好把spi0.0让出来
spi-cs都接地了
问题正好停在在36~37之间的位置
最近编辑记录 twzy (2021-07-07 09:42:32)
请问如何修改Makefile的KBUILD,指向F1C200S linux-5.2源码目录?
MODNAME = esp8089-spi
# By default, we try to compile the modules for the currently running
# kernel. But it's the first approximation, as we will re-read the
# version from the kernel sources.
KVERS_UNAME ?= $(shell uname -r)
@542396750@qq.com
得把flash拆了吧,这条不能没有
RST PE3 131
EN PE4
IRQ PE5 32*4+5=133
CS PC1 32*2+1=65
# cd /lib/modules/5.4.77/
# insmod esp8089-spi.ko esp_reset_gpio=131 esp_cs0_pin=65 esp_interrupt=133
[ 18.120825] esp8089_spi: loading out-of-tree module taints kernel.
[ 18.139153] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 18.744422] esp8089_spi: esp_spi_dummy_probe enter
[ 18.749446] esp8089_spi: register board OK
[ 18.753547] esp8089_spi: sem_timeout = 0
[ 18.977012] esp8089_spi: ESP8089 power up OK
[ 18.981721] esp8089_spi: esp_spi_probe ENTER
[ 18.986158] esp8089_spi: esp_setup_spi
[ 18.989941] esp8089_spi: sif_spi_protocol_init
[ 18.994379] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 19.001762] esp8089_spi: fail_count = 0
[ 19.111812] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.219538] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 19.226879] esp8089_spi: fail_count = 1
[ 19.338297] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.446178] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 19.453478] esp8089_spi: fail_count = 2
[ 19.564533] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.672268] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 19.679606] esp8089_spi: fail_count = 3
[ 19.791680] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 19.899419] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 19.906761] esp8089_spi: fail_count = 4
[ 20.019025] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.126777] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 20.134073] esp8089_spi: fail_count = 5
[ 20.245284] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.353022] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 20.360360] esp8089_spi: fail_count = 6
[ 20.474072] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.581866] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 20.589210] esp8089_spi: fail_count = 7
[ 20.701654] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.809694] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 20.817038] esp8089_spi: fail_count = 8
[ 20.927312] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.035576] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 21.042875] esp8089_spi: fail_count = 9
[ 21.153863] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.262108] esp8089_spi: /home/obm/123/ESP8089-SPI_20200509/spi_sif_esp.c, 1559
[ 21.269450] esp8089_spi: fail_count = 10
[ 21.379834] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.488100] esp8089_spi: first error exit
[ 21.492122] esp8089_spi: esp_spi_probe EXIT
[ 21.496415] eagle: probe of spi0.0 failed with error -110
[ 21.501954] esp8089_spi: sem_timeout = 0
[ 21.505958] esp8089_spi: esp_spi_init err 0
卡在这一步,大佬求搭救
twzy 说:得把flash拆了吧,这条不能没有
ESP8266这种用法,是不是固件由驱动下载进去,然后8266仅仅作为一个网卡,本身没有实现任何协议栈,具体的协议栈还是由linux提供的,这种方式,如果想裸奔使用,欠缺哪些东西。看这带宽眼谗,比起串口好太多了。
ESP_12F的INT中断脚是IO5吗?
twzy 说:ESP_12F的INT中断脚是IO5吗?
好了,被模块上的丝印坑了,找到esp8266ex规格书,对应引脚重新接上好了
遇到一个和奇怪的问题,开发板接受数据正常,通过ssh进行访问操作都正常 ,但是只要大量发送数据,比如作为Web服务器被访问,wifi就挂了
root@SnailCard:~# dmesg |grep wlan0
[ 241.525691] wlan0: authenticate with 78:44:fd:7e:02:88
[ 241.531292] wlan0: send auth to 78:44:fd:7e:02:88 (try 1/3)
[ 241.742250] wlan0: send auth to 78:44:fd:7e:02:88 (try 2/3)
[ 241.755538] wlan0: authenticated
[ 241.772270] wlan0: associate with 78:44:fd:7e:02:88 (try 1/3)
[ 241.982257] wlan0: associate with 78:44:fd:7e:02:88 (try 2/3)
[ 241.998657] wlan0: RX AssocResp from 78:44:fd:7e:02:88 (capab=0x1411 status=0 aid=1)
[ 242.009522] wlan0: associated
[ 242.014791] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 78:44:fd:7e:02:88
[ 572.506851] wlan0: authenticate with 78:44:fd:7e:02:88 #在这里开始作为Web服务器被访问
[ 572.514157] wlan0: send auth to 78:44:fd:7e:02:88 (try 1/3)
[ 572.725587] wlan0: send auth to 78:44:fd:7e:02:88 (try 2/3)
[ 572.935684] wlan0: send auth to 78:44:fd:7e:02:88 (try 3/3)
[ 573.145784] wlan0: authentication with 78:44:fd:7e:02:88 timed out
调了好几天,毫无头绪,目前怀疑两点:
1 模块坏了
2 使用的144楼的方案,屏蔽了初始化时的中断检测
每次insmode 再rmood,再次insmod就失败
twzy 说:@542396750@qq.com
.bus_num = 0, //根据实际情况填写 .chip_select = 1, //根据实际情况填写 .mode = SPI_MODE_3
我调试过程中,关键卡在这个模式方面,前面我提了
esp8086 SDIO 接口,如果使用 spi 接 口,要怎么设定的
哦,直接按这个 接口连接, 那 ic 不用设定 用SDIO 还是 SPI 通信吧
看着楼主的更贴,感觉肝在疼
esp32-hosted 这个怎么看呀
貌似用esp8266很容易就断开连接,有什么好的解决方法吗
大佬,esp8266 哪些脚要连到f1c200s阿? GPIO15 0 2 需要连接吗?
@迪卡
大佬 怎么改SPI 的频率
你这个方向错了
@542396750@qq.com
大佬 我也卡在这里 解决了么
你这个方向错了
大佬 哪里错了 请指点
我用8266做家电和物联网,没想到还能这样用,做四轴时有改造8266做成SPI高速网络模块做数据回传,速度稳定1.5M没问题
老哥,请教下,我从https://github.com/notabucketofspam/ESP8089-SPI/
下载了这从这个地址下载了这个驱动程序,在程序中好像没有使能spi接口啊,这些宏都没有打开是什么情况,是在编译的时候打开的吗
我现在想要使用f1的spi1来驱动这个该怎么修改啊
[img]图片https://whycan.com/files/members/7831/2022-05-13 22-23-37屏幕截图.png[/img]
跟帖,后面遇到初始化时中断无响应,把CS接地就行了
拆了好多,总算成功了,开始ping测试1000多毫秒延时,板子CS引脚下拉到GND就快了
CS未下拉至GND
CS下拉到GND
一直卡在这个部分,这个要怎么解决呢?
root@hellolinux:~# insmod esp8089-spi.ko
[ 109.163676] esp8089_spi: loading out-of-tree module taints kernel.
[ 109.177688] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 109.783281] esp8089_spi: esp_spi_dummy_probe enter
[ 109.788243] esp8089_spi: register board OK
[ 109.792342] esp8089_spi: sem_timeout = 0
[ 110.013138] esp8089_spi: ESP8089 power up OK
[ 110.017965] esp8089_spi: esp_spi_probe ENTER
[ 110.022244] esp8089_spi: esp_setup_spi
[ 110.026182] esp8089_spi: sif_spi_protocol_init
[ 110.030632] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 110.038333] esp8089_spi: fail_count = 0
[ 110.167328] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 110.275072] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 110.282712] esp8089_spi: fail_count = 1
[ 110.394538] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 110.502237] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 110.509915] esp8089_spi: fail_count = 2
[ 110.621057] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 110.728824] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 110.736503] esp8089_spi: fail_count = 3
[ 110.849851] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 110.957586] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 110.965259] esp8089_spi: fail_count = 4
[ 111.078778] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 111.186505] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 111.194184] esp8089_spi: fail_count = 5
[ 111.307702] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 111.415453] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 111.423132] esp8089_spi: fail_count = 6
[ 111.536572] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 111.644299] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 111.651941] esp8089_spi: fail_count = 7
[ 111.763225] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 111.870912] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 111.878591] esp8089_spi: fail_count = 8
[ 111.991711] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 112.099452] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 112.107132] esp8089_spi: fail_count = 9
[ 112.220564] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 112.328320] esp8089_spi: /home/persai/Downloads/new/ESP8089-SPI/spi_sif_esp.c , 1559
[ 112.335999] esp8089_spi: fail_count = 10
[ 112.449538] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff] ,[0xff]
[ 112.557301] esp8089_spi: first error exit
[ 112.561318] esp8089_spi: esp_spi_probe EXIT
[ 112.565601] eagle: probe of spi0.0 failed with error -110
[ 112.571221] esp8089_spi: sem_timeout = 0
[ 112.575247] esp8089_spi: esp_spi_init err 0
root@hellolinux:~#
@你在卖萌吗
板子啥都不接也会出现这个
检查硬件 检查SPI模式3
@你在卖萌吗
CS 接地
@你在卖萌吗
板子啥都不接也会出现这个
检查硬件 检查SPI模式3
好的,我检查一下,我使用群友编译出来驱动的是能用的,我的SPI配置是
.bus_num = 0,
.chip_select = 0,
.mode = SPI_MODE_3,
不知道对不对
@你在卖萌吗
CS 接地
我有试过了,示波器显示的情况是MOSI没输出,应该是驱动配置有点问题
@twzy
我的也是ssh正常,只要下载或者上传大文件,一段时间就挂了,不知怎么解决
@资本家大善人
我使用 v3s + esp8089 连接到 wifi。 10 分钟后,连接断开。
# ping www.baidu.com
PING www.baidu.com (14.215.177.38): 56 data bytes
64 bytes from 14.215.177.38: seq=0 ttl=56 time=10.405 ms
[ 252.489515] esp_sdio_remove enter
[ 252.494046] sif_disable_irq release irq failed
[ 252.498511] ------------[ cut here ]------------
[ 252.503258] WARNING: CPU: 0 PID: 5 at kernel/workqueue.c:3031 __flush_work+0x184/0x1ac
[ 252.511186] Modules linked in: esp8089
[ 252.514944] CPU: 0 PID: 5 Comm: kworker/0:0 Not tainted 5.2.0-licheepi-zero #3
[ 252.522154] Hardware name: Allwinner sun8i Family
[ 252.526864] Workqueue: events_freezable mmc_rescan
[ 252.531678] [<c010ec34>] (unwind_backtrace) from [<c010b6cc>] (show_stack+0x10/0x14)
[ 252.539419] [<c010b6cc>] (show_stack) from [<c0715720>] (dump_stack+0x94/0xa8)
[ 252.546641] [<c0715720>] (dump_stack) from [<c011d984>] (__warn+0xfc/0x114)
[ 252.553598] [<c011d984>] (__warn) from [<c011dab0>] (warn_slowpath_null+0x40/0x48)
[ 252.561161] [<c011dab0>] (warn_slowpath_null) from [<c0133eec>] (__flush_work+0x184/0x1ac)
[ 252.569421] [<c0133eec>] (__flush_work) from [<c0136fc8>] (__cancel_work_timer+0x110/0x1ec)
[ 252.577800] [<c0136fc8>] (__cancel_work_timer) from [<bf004168>] (sip_detach+0xe8/0x1bc [esp8089])
[ 252.586778] [<bf004168>] (sip_detach [esp8089]) from [<bf000fe0>] (esp_sdio_remove+0x60/0x1ac [esp8089])
[ 252.596265] [<bf000fe0>] (esp_sdio_remove [esp8089]) from [<c0539780>] (sdio_bus_remove+0x30/0xf8)
[ 252.605225] [<c0539780>] (sdio_bus_remove) from [<c04330b4>] (device_release_driver_internal+0xdc/0x1a0)
[ 252.614701] [<c04330b4>] (device_release_driver_internal) from [<c0431bec>] (bus_remove_device+0xcc/0xf8)
[ 252.624260] [<c0431bec>] (bus_remove_device) from [<c042e2a0>] (device_del+0x13c/0x324)
[ 252.632250] [<c042e2a0>] (device_del) from [<c0539c08>] (sdio_remove_func+0x1c/0x28)
[ 252.639987] [<c0539c08>] (sdio_remove_func) from [<c0537a34>] (mmc_sdio_remove+0x40/0x70)
[ 252.648159] [<c0537a34>] (mmc_sdio_remove) from [<c0537c44>] (mmc_sdio_detect+0x6c/0xf8)
[ 252.656242] [<c0537c44>] (mmc_sdio_detect) from [<c052fe30>] (mmc_rescan+0x1bc/0x38c)
[ 252.664066] [<c052fe30>] (mmc_rescan) from [<c0135e64>] (process_one_work+0x150/0x358)
[ 252.671976] [<c0135e64>] (process_one_work) from [<c0136098>] (worker_thread+0x2c/0x518)
[ 252.680062] [<c0136098>] (worker_thread) from [<c013b854>] (kthread+0x120/0x150)
[ 252.687453] [<c013b854>] (kthread) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 252.694663] Exception stack(0xc3845fb0 to 0xc3845ff8)
[ 252.699701] 5fa0: 00000000 00000000 00000000 00000000
[ 252.707868] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 252.716034] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 252.722767] ---[ end trace c2da1efaf38c4f3d ]---
[ 252.727432] wlan0: deauthenticating from c8:e7:d8:34:27:84 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 252.831695] mmc1: card 0001 removed
[ 252.887836] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 252.908732] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 252.923924] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 252.939568] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 252.949438] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 252.962697] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 252.971128] mmc1: new high speed SDIO card at address 0001
[ 252.990913] 8<--- cut here ---
[ 252.993997] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[ 253.002247] pgd = 6ae702fa
[ 253.004956] [00000004] *pgd=00000000
[ 253.008538] Internal error: Oops: 17 [#1] SMP ARM
[ 253.013235] Modules linked in: esp8089
[ 253.016989] CPU: 0 PID: 5 Comm: kworker/0:0 Tainted: G W 5.2.0-licheepi-zero #3
[ 253.025584] Hardware name: Allwinner sun8i Family
[ 253.030297] Workqueue: events_freezable mmc_rescan
[ 253.035123] PC is at esp_sdio_probe+0x48/0x3e4 [esp8089]
[ 253.040432] LR is at sdio_bus_probe+0xfc/0x114
[ 253.044868] pc : [<bf001174>] lr : [<c0539944>] psr: 20060013
[ 253.051124] sp : c3845d98 ip : 29aaaaab fp : c0b04c48
[ 253.056340] r10: 0000000e r9 : bf00a188 r8 : bf00a188
[ 253.061557] r7 : c32bf400 r6 : bf00d080 r5 : bf039784 r4 : 00000000
[ 253.068073] r3 : c32bf408 r2 : 00000003 r1 : 00000000 r0 : c32bf400
[ 253.074592] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 253.081716] Control: 10c5387d Table: 432b406a DAC: 00000051
[ 253.087455] Process kworker/0:0 (pid: 5, stack limit = 0xb741b1b1)
[ 253.093626] Stack: (0xc3845d98 to 0xc3846000)
[ 253.097979] 5d80: bf00d0e8 0000000e
[ 253.106147] 5da0: c0b04c48 c32bf408 00000000 c32bf400 bf00d0e8 bf00a188 bf00d0e8 c0539944
[ 253.114315] 5dc0: c0b838c8 c32bf408 00000000 c0b838cc 00000001 c04329b4 c32bf408 bf00d0e8
[ 253.122482] 5de0: c0432e1c c0b04c48 00000001 00000000 00000001 c0432c34 c0b41240 00000000
[ 253.130650] 5e00: 00000000 c0b87250 bf00d0e8 c3845e64 c32bf408 00000000 c3845e64 c0432e1c
[ 253.138818] 5e20: c0b04c48 00000001 00000000 00000001 c0b04c48 c0430cc8 00000001 c39a0c6c
[ 253.146986] 5e40: c31dd2b8 3e4fcf47 c32bf408 c32bf408 c0b04c48 c32bf44c c3300008 c0432764
[ 253.155153] 5e60: 00000cc0 c32bf408 00000001 3e4fcf47 c32bf408 c32bf408 c0b3b860 c3300008
[ 253.163321] 5e80: 00000000 c0431b18 c32bf408 00000000 c0b04c48 c042f5cc c32bf400 c3b91000
[ 253.171489] 5ea0: 00000001 c052f164 c3300004 3e4fcf47 c3845ec8 c32bf400 c32bf408 c3300004
[ 253.179657] 5ec0: c3b91000 c3300398 c3300000 c0539bd8 00000000 00000001 c3300004 c0538f40
[ 253.187824] 5ee0: 00000000 c3845ef7 00000000 00000000 00000000 00000000 10ffff00 3e4fcf47
[ 253.195992] 5f00: ffffff92 c3b9128c 00061a80 c3b91000 c086bfc0 c086bfcc c3b91290 00000000
[ 253.204160] 5f20: c3dee880 c052ff78 c380d680 c3b9128c c3dee880 c3df1c00 00000000 c0135e64
[ 253.212328] 5f40: c3dee898 c0b03d00 c380d680 c3dee880 c380d694 c3dee898 c0b03d00 c3844000
[ 253.220496] 5f60: 00000008 c0136098 00000000 c3816980 c38168c0 00000000 c380d680 c013606c
[ 253.228663] 5f80: c381699c c3833eac 00000000 c013b854 c38168c0 c013b734 00000000 00000000
[ 253.236830] 5fa0: 00000000 00000000 00000000 c01010e8 00000000 00000000 00000000 00000000
[ 253.244997] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 253.253164] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 253.261360] [<bf001174>] (esp_sdio_probe [esp8089]) from [<c0539944>] (sdio_bus_probe+0xfc/0x114)
[ 253.270233] [<c0539944>] (sdio_bus_probe) from [<c04329b4>] (really_probe+0x1dc/0x2e0)
[ 253.278147] [<c04329b4>] (really_probe) from [<c0432c34>] (driver_probe_device+0x60/0x1a0)
[ 253.286406] [<c0432c34>] (driver_probe_device) from [<c0430cc8>] (bus_for_each_drv+0x74/0xb8)
[ 253.294925] [<c0430cc8>] (bus_for_each_drv) from [<c0432764>] (__device_attach+0xd0/0x13c)
[ 253.303181] [<c0432764>] (__device_attach) from [<c0431b18>] (bus_probe_device+0x84/0x8c)
[ 253.311352] [<c0431b18>] (bus_probe_device) from [<c042f5cc>] (device_add+0x444/0x5e4)
[ 253.319263] [<c042f5cc>] (device_add) from [<c0539bd8>] (sdio_add_func+0x5c/0x70)
[ 253.326741] [<c0539bd8>] (sdio_add_func) from [<c0538f40>] (mmc_attach_sdio+0x270/0x370)
[ 253.334825] [<c0538f40>] (mmc_attach_sdio) from [<c052ff78>] (mmc_rescan+0x304/0x38c)
[ 253.342652] [<c052ff78>] (mmc_rescan) from [<c0135e64>] (process_one_work+0x150/0x358)
[ 253.350566] [<c0135e64>] (process_one_work) from [<c0136098>] (worker_thread+0x2c/0x518)
[ 253.358653] [<c0136098>] (worker_thread) from [<c013b854>] (kthread+0x120/0x150)
[ 253.366044] [<c013b854>] (kthread) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 253.373255] Exception stack(0xc3845fb0 to 0xc3845ff8)
[ 253.378299] 5fa0: 00000000 00000000 00000000 00000000
[ 253.386466] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 253.394632] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 253.401243] Code: e5954018 e3a01000 e5851018 e2873008 (e5948004)
[ 253.407446] ---[ end trace c2da1efaf38c4f3e ]---
ping: sendto: Network is unreachable
终于出现网卡驱动了,记录这开心时刻
root@bai-Aspire-E1-421:~# insmod /opt/esp8089-spi.ko
[ 42.995608] esp8089_spi: loading out-of-tree module taints kernel.
[ 43.029092] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 43.833820] esp8089_spi: esp_spi_dummy_probe enter
[ 43.838886] esp8089_spi: register board OK
[ 43.842986] esp8089_spi: sem_timeout = 0
[ 44.893907] esp8089_spi: ESP8089 power up OK
[ 44.898692] esp8089_spi: esp_spi_probe ENTER
[ 44.902975] esp8089_spi: esp_setup_spi
[ 44.964295] esp8089_spi: sif_spi_protocol_init
[ 44.968771] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 44.976475] esp8089_spi: fail_count = 0
[ 45.204078] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 45.311780] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 45.319370] esp8089_spi: fail_count = 1
[ 45.644075] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 45.751763] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 45.759357] esp8089_spi: fail_count = 2
[ 46.084070] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 46.690709] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c8
[ 47.314252] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff]
[ 47.821078] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c1
[ 48.454236] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff]
[ 48.961099] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c3
[ 49.484234] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 49.991063] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c7
[ 50.524240] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 51.031090] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c0
[ 51.554233] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 52.061055] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c3
[ 52.584240] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 53.091090] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 53.624230] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 54.131111] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 54.664240] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 55.171085] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 55.694245] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 56.201107] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 56.724232] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 57.231083] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 57.764232] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 58.271093] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 58.794233] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 59.301120] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 59.824234] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 60.331055] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 60.864231] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 61.371116] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c8
[ 61.914236] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 61.921991] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c1
[ 61.944355] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 61.952111] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c4
[ 61.974350] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 63.996780] esp8089_spi: esp_pub_init_all
[ 64.000850] esp8089_spi: esp_download_fw
[ 64.029468] random: crng init done
[ 64.899351] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[ 64.899379] esp8089_spi: sif_platform_irq_init enter
[ 64.909597] yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
[ 65.205813] esp_host:bdf5087c3deb
[ 65.205813] esp_target: e826c2b3c9fd 57 18202
[ 65.205813]
[ 65.220416] esp_readwrite_file: file /system/lib/modules/test_results filp_or
[ 65.274543] esp8089_spi: first normal exit
[ 65.278726] esp8089_spi: esp_spi_probe EXIT
[ 65.283259] esp8089_spi: sem_timeout = 0
[ 65.287398] esp8089_spi: esp_spi_remove
[ 65.426840] esp8089_spi: esp_spi_probe ENTER
[ 65.431139] esp8089_spi: esp_setup_spi
[ 65.435041] esp8089_spi: sif_spi_protocol_init
[ 65.439490] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 65.447099] esp8089_spi: fail_count = 0
[ 65.714066] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 65.821777] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 65.829374] esp8089_spi: fail_count = 1
[ 66.154070] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 66.261776] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c9
[ 66.269372] esp8089_spi: fail_count = 2
[ 66.594069] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 67.200737] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c8
[ 67.824233] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff]
[ 68.331123] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c1
[ 68.934237] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff]
[ 69.441105] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c3
[ 69.984236] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 70.491122] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c7
[ 71.014240] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 71.521082] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c0
[ 72.044231] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 72.551064] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c3
[ 73.074232] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 73.581106] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 74.114230] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 74.621052] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 75.140385] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 75.647242] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 76.174243] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 76.681080] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 77.224234] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 77.731090] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 78.254234] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 78.761075] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 79.284239] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 79.791082] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 80.324233] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 80.831074] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c5
[ 81.354229] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 81.861037] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c8
[ 82.384233] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 82.392048] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c1
[ 82.424270] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 82.432024] esp8089_spi: /home/bai/software/ESP8089-SPI-master/spi_sif_esp.c4
[ 82.454377] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 84.476548] esp8089_spi: esp_pub_init_all
[ 84.480583] esp8089_spi: esp_download_fw
[ 85.597536] xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[ 85.597563] esp8089_spi: sif_platform_irq_init enter
[ 85.607778] yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
[ 85.725871] ------------[ cut here ]------------
[ 85.735762] WARNING: CPU: 0 PID: 194 at kernel/irq/manage.c:524 enable_irq+00
[ 85.743483] Unbalanced enable for IRQ 65
[ 85.747396] Modules linked in: esp8089_spi(O+)
[ 85.751859] CPU: 0 PID: 194 Comm: kspiirqd/eagle Tainted: G O 46
[ 85.760872] Hardware name: Allwinner suniv Family
[ 85.765623] [<c010e544>] (unwind_backtrace) from [<c010b52c>] (show_stack+0x)
[ 85.773370] [<c010b52c>] (show_stack) from [<c0116918>] (__warn+0xc0/0xf0)
[ 85.780241] [<c0116918>] (__warn) from [<c01165ac>] (warn_slowpath_fmt+0x38/)
[ 85.787723] [<c01165ac>] (warn_slowpath_fmt) from [<c0148498>] (enable_irq+0)
[ 85.795813] [<c0148498>] (enable_irq) from [<bf000230>] (spi_irq_thread+0x48)
[ 85.804822] [<bf000230>] (spi_irq_thread [esp8089_spi]) from [<c012ece8>] (k)
[ 85.813448] [<c012ece8>] (kthread) from [<c0107e88>] (ret_from_fork+0x14/0x2)
[ 85.820655] ---[ end trace cced0687c4545830 ]---
[ 85.938008] esp8089_spi: esp_spi_probe EXIT
[ 85.942528] esp8089_spi: esp_spi_init err 0
[ 85.954343] esp_host:bdf5087c3deb
[ 85.954343] esp_target: e826c2b3c9fd 57 18202
[ 85.954343]
root@bai-Aspire-E1-421:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defau0
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default ql0
link/ether 18:fe:34:61:d0:57 brd ff:ff:ff:ff:ff:ff
@744219909
稳定性测试了吗
@744219909
稳定性测试了吗
没有,刚连上外网。现在在弄apt源配置。明天上班的时候再测试
最近编辑记录 744219909 (2022-08-23 17:41:02)
[ 27.188993] esp8089_spi: loading out-of-tree module taints kernel.
[ 27.207159] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 27.816544] esp8089_spi: esp_spi_dummy_probe enter
[ 27.825723] esp8089_spi: register board OK
[ 27.833917] esp8089_spi: sem_timeout = 0
[ 28.054724] esp8089_spi: ESP8089 power up OK
[ 28.063741] esp8089_spi: esp_spi_probe ENTER
[ 28.072424] esp8089_spi: esp_setup_spi
[ 28.080505] esp8089_spi: sif_spi_protocol_init
[ 28.089243] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 28.103132] esp8089_spi: fail_count = 0
[ 28.223750] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.337868] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 28.351740] esp8089_spi: fail_count = 1
[ 28.474338] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.588375] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 28.602186] esp8089_spi: fail_count = 2
[ 28.723686] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 29.336633] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 29.366553] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 29.879656] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 29.902138] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 30.415227] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 30.440394] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 30.953453] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 30.975877] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 31.488935] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 31.514586] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 32.027718] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 32.052173] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 32.565209] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 32.590464] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 33.103573] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 33.139303] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 33.652363] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 33.677319] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 34.190377] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 34.214739] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 34.727719] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 34.752307] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 35.265381] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 35.289065] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 35.802078] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 35.826945] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.339974] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 36.362567] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.875605] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 36.899451] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.913430] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 36.939312] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.953330] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 36.979086] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 38.036730] esp8089_spi: esp_pub_init_all
[ 38.045015] esp8089_spi: esp_download_fw
[ 38.621052] esp8089_spi: sif_platform_irq_init enter
[ 49.125337] resetting event timeout
[ 49.131110] esp8089_spi: esp_init_all failed: -110
[ 49.140078] esp8089_spi: first error exit
[ 49.148204] esp8089_spi: esp_spi_probe EXIT
[ 49.156738] esp8089_spi: sem_timeout = 0
[ 49.164852] esp8089_spi: esp_spi_init err 0
我前面都有数据就是后面resetting的时候失败了。。。。苦恼中
@黑蛋
你看一下你的复位脚弄对了没,我记得insmod的时候,8266的led指示灯会闪烁一下
芯片是esp8089 我用的是spi0,中断PD19(115),reset是PD21(117)cs是pc1(65)不知道是不是硬件问题,电压表不在身边。。。
.bus_num = 0,
.chip_select = 0,
.mode = SPI_MODE_3,
static int esp_cs0_pin = 65;
static int esp_interrupt = 115;
static int esp_reset_gpio = 117;
最近编辑记录 黑蛋 (2022-08-30 14:50:24)
我直接把cs接地了,这是可以了吗
[ 19.051605] esp8089_spi: loading out-of-tree module taints kernel.
[ 19.069799] esp8089_spi: EAGLE DRIVER VER bdf5087c3deb
[ 19.079361] <<<<<<<<sif_platform_target_poweron>>>>>>>>>>>>
[ 19.688136] <<<<<<<<sif_platform_target_poweron>>>>>>>>>>>>
[ 19.698782] esp8089_spi: esp_spi_dummy_probe enter
[ 19.708012] esp8089_spi: register board OK
[ 19.716408] esp8089_spi: sem_timeout = 0
[ 19.934722] esp8089_spi: ESP8089 power up OK
[ 19.943672] esp8089_spi: esp_spi_probe ENTER
[ 19.952300] esp8089_spi: esp_setup_spi
[ 19.960340] esp8089_spi: sif_spi_protocol_init
[ 19.969043] esp8089_spi: /home/linux/ɡ面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 19.982912] esp8089_spi: fail_count = 0
[ 20.104520] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.218558] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.232368] esp8089_spi: fail_count = 1
[ 20.353133] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 20.467114] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 20.480930] esp8089_spi: fail_count = 2
[ 20.604499] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 21.217433] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 21.243607] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 21.756712] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 21.781739] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 22.294814] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 22.318766] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 22.831868] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 22.854277] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 23.367382] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 23.390235] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 23.903285] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 23.926986] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 24.440038] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 24.466933] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 24.980000] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 25.006169] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 25.519192] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 25.542059] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 26.055144] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 26.078940] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 26.591957] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 26.616834] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 27.129877] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 27.152055] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 27.665081] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 27.689109] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.202196] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 28.226268] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.739264] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 28.762023] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.776012] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 28.800574] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 28.814551] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 28.838091] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 29.888796] esp8089_spi: esp_pub_init_all
[ 29.897096] esp8089_spi: esp_download_fw
[ 30.452949] esp8089_spi: sif_platform_irq_init enter
[ 30.462246] <<<<<<<<<<sif_platform_irq_init>>>>>>>>>>>>>
[ 30.471765] <<<<<<<<<<sif_platform_irq_init>>>>>>>>>>>>>
[ 30.688197] esp_host:bdf5087c3deb
[ 30.688197] esp_target: e826c2b3c9fd 57 18202
[ 30.688197]
[ 30.706851] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[ 30.722019] esp8089_spi: first normal exit
[ 30.730214] esp8089_spi: esp_spi_probe EXIT
[ 30.738652] esp8089_spi: sem_timeout = 0
[ 30.746705] esp8089_spi: esp_spi_remove
[ 30.884875] esp8089_spi: esp_spi_probe ENTER
[ 30.893160] esp8089_spi: esp_setup_spi
[ 30.900951] esp8089_spi: sif_spi_protocol_init
[ 30.909436] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 30.922935] esp8089_spi: fail_count = 0
[ 31.043092] rx:[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 31.156859] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 31.170497] esp8089_spi: fail_count = 1
[ 31.294416] rx:[0xff],[0x09],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 31.408430] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1559
[ 31.422228] esp8089_spi: fail_count = 2
[ 31.544004] rx:[0xff],[0xff],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 32.156939] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1578
[ 32.183120] rx:[0xff],[0xff],[0x01],[0x10],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 32.696237] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1591
[ 32.720009] rx:[0xff],[0xff],[0x00],[0x90],[0xff],[0xff],[0x00],[0xff],[0xff],[0xff]
[ 33.233082] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1603
[ 33.256068] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 33.769136] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1617
[ 33.798041] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 34.311085] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1630
[ 34.336269] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 34.849278] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1643
[ 34.871853] rx:[0xff],[0x00],[0x03],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 35.384918] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 35.408739] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 35.921814] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 35.946565] rx:[0xff],[0x00],[0x25],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.459598] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 36.482479] rx:[0xff],[0x00],[0x10],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 36.995567] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 37.018291] rx:[0xff],[0x00],[0x12],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 37.531328] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 37.556284] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 38.069304] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 38.091523] rx:[0xff],[0x00],[0x06],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 38.604536] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 38.628505] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 39.141610] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1655
[ 39.170509] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 39.683582] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1668
[ 39.707509] rx:[0xff],[0x00],[0x00],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 39.721477] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1681
[ 39.744861] rx:[0xff],[0x00],[0x02],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 39.758847] esp8089_spi: /home/linux/桌面/ESP8089-SPI-master/spi_sif_esp.c, 1694
[ 39.783486] rx:[0xff],[0x00],[0x01],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff],[0xff]
[ 40.834921] esp8089_spi: esp_pub_init_all
[ 40.843080] esp8089_spi: esp_download_fw
[ 41.510166] esp8089_spi: sif_platform_irq_init enter
[ 41.519470] <<<<<<<<<<sif_platform_irq_init>>>>>>>>>>>>>
[ 41.528988] <<<<<<<<<<sif_platform_irq_init>>>>>>>>>>>>>
[ 41.580848] esp8089_spi: esp_spi_probe EXIT
[ 41.589537] esp8089_spi: esp_spi_init err 0
[ 41.611632] esp_host:bdf5087c3deb
[ 41.611632] esp_target: e826c2b3c9fd 57 18202
[ 41.611632]
# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1000
2: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
link/ether 18:fe:34:00:00:00 brd ff:ff:ff:ff:ff:ff
@黑蛋
可以了
