楼主 #1 2017-09-07 16:29:19
admin
已发帖子: 20
发现一个轻量级UI, 移植到 STM32/STM8 不错 ----- µGUI/uGUI
楼主 #2 2017-09-07 16:29:38
admin
已发帖子: 20
Re: 发现一个轻量级UI, 移植到 STM32/STM8 不错 ----- µGUI/uGUI
Introduction
What is µGUI?
µGUI is a free and open source graphic library for embedded systems. It is platform-independent and can be easily ported to almost any microcontroller system. As long as the display is capable of showing graphics, µGUI is not restricted to a certain display technology. Therefore, display technologies such as LCD, TFT, E-Paper, LED or OLED are supported. The whole module consists of three files: ugui.c, ugui.h and ugui_config.h.
µGUI Features
  • µGUI supports any color, grayscale or monochrome display
  • µGUI supports any display resolution
  • µGUI supports multiple different displays
  • µGUI supports any touch screen technology (e.g. AR, PCAP)
  • µGUI supports windows and objects (e.g. button, textbox)
  • µGUI supports platform-specific hardware acceleration
  • 16 different fonts available
  • cyrillic fonts supported
  • TrueType font converter available (https://github.com/AriZuu)
  • integrated and free scalable system console
  • basic geometric functions (e.g. line, circle, frame etc.)
  • can be easily ported to almost any microcontroller system
  • no risky dynamic memory allocation required
µGUI Requirements
µGUI is platform-independent, so there is no need to use a certain embedded system. In order to use µGUI, only two requirements are necessary:
a C-function which is able to control pixels of the target display.
integer types for the target platform have to be adjusted in ugui_config.h.
楼主 #3 2017-09-07 16:33:54
admin
已发帖子: 20
那么小的µGUI, 居然还支持 TrueType Font (ttf字体)
#4 2018-03-23 14:36:44
chaoking
厉害了,感谢作者的无私奉献,正在移植中
#5 2018-03-23 14:42:16
已发帖子: 9,437
chaoking 说:
厉害了,感谢作者的无私奉献,正在移植中
成功了发个图片上来给坑友们围观一下哈
#6 2018-04-18 08:19:21
xinxiaoci
已发帖子: 71
chaoking 说:
厉害了,感谢作者的无私奉献,正在移植中
移植好了没有?
最近编辑记录 xinxiaoci (2018-04-18 08:20:23)
#7 2018-04-18 09:49:26
kgp0213
已发帖子: 149
移植好了没有?
#8 2018-04-18 09:54:05
已发帖子: 9,437
kgp0213 说:
移植好了没有?
UI移植都不会太难, 给他一块画布,然后告诉UI怎么画点,大神你很快就可以搞定的。
#9 2018-04-18 10:27:09
qwert1213131
已发帖子: 57
kgp0213 说:
移植好了没有?
只需要把画点函数提供给uGUI调用就可以,然后使用内部的API进行使用,
/*               uGUI              */
void pset(UG_U16 x, UG_U16 y, UG_COLOR c)
   LCD_WriteBuffer(x,y,c);
/* GUI structure */
UG_GUI gui;
函数中直接调用下面:
UG_Init(&gui,(void(*)(UG_S16,UG_S16,UG_COLOR))pset,128,128);
最近编辑记录 qwert1213131 (2018-04-18 10:31:14)
#10 2018-04-18 11:09:07
daydayup
已发帖子: 343
qwert1213131 说:
kgp0213 说:
移植好了没有?
/*               uGUI              */
/* GUI structure */
UG_GUI gui;
函数中直接调用下面:
厉害了老铁,学习!
#11 2018-04-18 11:44:45
qwert1213131
已发帖子: 57
daydayup 说:
qwert1213131 说:
kgp0213 说:
移植好了没有?
/*               uGUI              */
/* GUI structure */
UG_GUI gui;
函数中直接调用下面:
厉害了老铁,学习!
有硬件加速的选项,但是这ui的控件太少了,我还是去玩LittleVGL了
#12 2018-04-19 14:48:38
lcfmax
已发帖子: 329
这个挺不错的,有没有移植运行的效果图看看
#13 2018-04-19 17:15:44
qwert1213131
已发帖子: 57
lcfmax 说:
去油管可以看到很多的,
建议试试这个https://littlevgl.com/
#14 2018-04-19 17:33:01
已发帖子: 9,437
看看nuklear,一个头文件搞定一个gui,只有两万多行而已:
https://whycan.cn/t_764.html
#15 2018-04-20 09:01:23
qwert1213131
已发帖子: 57
nuklear不知道能不能用到普通的单片机里去
#16 2018-04-25 16:43:14
chaoking
交作业,移植不难
#17 2018-05-04 11:19:12
LAQ
已发帖子: 38
可以移植到ESP32里面不
#18 2018-05-04 11:30:26
cityf
已发帖子: 195
当然可以, ESP32 RAM那么多.
#19 2018-05-04 11:55:21
LAQ
已发帖子: 38
有例程可以提供下不
#20 2018-05-04 12:33:42
xinxiaoci
已发帖子: 71
chaoking 说:
我来检查作业,不错!100分!
#21 2018-05-04 14:07:34
已发帖子: 9,437
http://embeddedlightning.com/wp-content/uploads/2015/12/ssd1325.c
#include    "system.h"
#include    "ugui.h"
/* SOFTWARE SPI                                       */
#define OLED_PORT  GPIOB
#define OLED_SCK   GPIO_Pin_0
#define OLED_SDA   GPIO_Pin_1
#define OLED_DC    GPIO_Pin_2
#define OLED_RES   GPIO_Pin_3
#define OLED_CS    GPIO_Pin_4
void write_cmd(unsigned char b)
   unsigned char i;
   GPIO_WriteBit(OLED_PORT, OLED_CS, Bit_RESET);
   GPIO_WriteBit(OLED_PORT, OLED_DC, Bit_RESET);
   for (i=0x80; i; i>>=1)
      GPIO_WriteBit(OLED_PORT, OLED_SCK, Bit_RESET);
      GPIO_WriteBit(OLED_PORT, OLED_SDA, (b&i)?Bit_SET:Bit_RESET);
      GPIO_WriteBit(OLED_PORT, OLED_SCK, Bit_SET);
   GPIO_WriteBit(OLED_PORT, OLED_DC, Bit_SET);
   GPIO_WriteBit(OLED_PORT, OLED_CS, Bit_SET);
void write_data(unsigned char b)
   unsigned char i;
/* FRAMEBUFFER                                        */
unsigned char buff[128*32]; // 128x64 4BPP OLED
/* SSD1325 PSET-FUNCTION                              */
void ssd1325_pset ( UG_S16 x , UG_S16 y , UG_COLOR c )
   unsigned int n;
   unsigned char b;
   unsigned char col;
   col = c & 0x0F;
   n = (x >> 1) + 64 * y;
   b = buff[n];
   switch ( x%2 )
      case 0: b &= 0xF0; b |= col; break;
      case 1: b &= 0x0F; b |= col<<4; break;
   buff[n] = b;
/* SSD1325 INIT-FUNCTION                              */
void ssd1325_init( void )
   GPIO_WriteBit(OLED_PORT, OLED_RES, Bit_RESET);
   delay_ms(100);
   GPIO_WriteBit(OLED_PORT, OLED_RES, Bit_SET);
   delay_ms(100);
   write_cmd(0xAE|0x00);
   delay_ms(10);
   write_cmd(0xB3);         // Display Clock Divider/Osciallator Frequency
   write_cmd(0x91);         //   Default => 0x41
   delay_ms(10);
   write_cmd(0xA8);         // Set Multiplex Ratio
   write_cmd(0x3F);         //   Default => 0x5F
   delay_ms(10);
   write_cmd(0xA2);         // Set Display Offset
   write_cmd(0x4C);         //   Default => 0x00
   delay_ms(10);
   write_cmd(0xA1);         // Set Display Start Line
   write_cmd(0x00);         //   Default => 0x00
   delay_ms(10);
   write_cmd(0xAD);         // Set Master Configuration
   write_cmd(0x02|0x00);   //   Default => 0x03
   delay_ms(10);
   write_cmd(0xA0);         // Set Re-Map & Data Format
   write_cmd(0x50);         //   Default => 0x00
   delay_ms(10);
   write_cmd(0x84|0x02);   // Set Current Range
   delay_ms(10);
   write_cmd(0xB8);         // Set Gray Scale Table
   write_cmd(0x01);         //   Gray Scale Level 1
   write_cmd(0x11);         //   Gray Scale Level 3 & 2
   write_cmd(0x22);         //   Gray Scale Level 5 & 4
   write_cmd(0x32);         //   Gray Scale Level 7 & 6
   write_cmd(0x43);         //   Gray Scale Level 9 & 8
   write_cmd(0x54);         //   Gray Scale Level 11 & 10
   write_cmd(0x65);         //   Gray Scale Level 13 & 12
   write_cmd(0x76);         //   Gray Scale Level 15 & 14
   delay_ms(10);
   write_cmd(0x81);         // Set Contrast Value
   write_cmd(0x7F);         //   Default => 0x40
   delay_ms(10);
   write_cmd(0xB2);         // Set Frame Frequency (Row Period)
   write_cmd(0x46);         //   Default => 0x25 (37 Display Clocks)
   delay_ms(10);
   write_cmd(0xB1);         // Phase 1 & 2 Period Adjustment
   write_cmd(0x22);         //   Default => 0x53 (5 Display Clocks [Phase 2] / 3 Display Clocks [Phase 1])
   delay_ms(10);
   write_cmd(0xBC);         // Set Pre-Charge Voltage Level
   write_cmd(0x10);         //   Default => 0x10 (Connect to VCOMH)
   delay_ms(10);
   write_cmd(0xB4);         // Set Pre-Charge Compensation Level
   write_cmd(0x07);         //   Default => 0x00 (No Compensation)
   write_cmd(0xB0);       // Set Pre-Charge Compensation Enable
   write_cmd(0x08|0x20);   //   Default => 0x08
   delay_ms(10);
   write_cmd(0xBE);         // Set Output Level High Voltage for COM Signal
   write_cmd(0x02);         //   Default => 0x1D (0.81*VREF)
   delay_ms(10);
   write_cmd(0xBF);         // Set Segment Low Voltage Level
   write_cmd(0x02|0x0C);   //   Default => 0x0E
   delay_ms(10);
   write_cmd(0xA4|0x00);   // Set Display Mode
   delay_ms(10);
   write_cmd(0xAE|0x01);   // Set Display On/Off
   delay_ms(10);
/* SSD1325 UPDATE-FUNCTION                            */
void ssd1325_update( void )
   unsigned int i;
   unsigned char* p;
   p = &buff[0];
   write_cmd(0x15);      // Set Column Address
   write_cmd(0);         //   Default => 0x00
   write_cmd(0x3F);      //   Default => 0x3F (Total Columns Devided by 2)
   write_cmd(0x75);      // Set Row Address
   write_cmd(0x3F);      //   Default => 0x4F
   for(i=0;i<128*32;i++)
      write_data(*p++);
UG_GUI   gui;
int main(void)
   /* OLED init */
   ssd1325_init();
   /* 碌GUI init */
   UG_Init(&gui,ssd1325_pset,128,64);
   UG_FillScreen( C_BLACK );
   UG_DrawFrame( 0, 0, 127, 63, C_WHITE );
   ssd1325_update();
   while(1)
这里有一个移植demo, poring 到esp32 问题不大。
http://embeddedlightning.com/forums/topic/pset-function-examples/
#22 2018-06-19 18:43:49
19697805
已发帖子: 77
谢谢分享
#23 2018-07-31 22:33:16
abc3240660
已发帖子: 100
看起来还不错啊
#24 2018-11-07 17:50:04
已发帖子: 9,437
用模拟器试了一下,挺不错。
#25 2018-11-07 21:21:18
已发帖子: 9,437
终于搞定 窗口 ugui 显示了.
#26 2018-11-07 21:28:22
已发帖子: 9,437
一个开源小型GUI移植到STM32F103上: http://bbs.21ic.com/blog-1849938-170836.html
默认支持3种 2D 硬件加速:
/* Supported drivers */
#define NUMBER_OF_DRIVERS                             3
#define DRIVER_DRAW_LINE                              0
#define DRIVER_FILL_FRAME                             1
#define DRIVER_FILL_AREA                              2
#27 2018-11-07 22:00:48
已发帖子: 9,437
通过函数 void UG_TouchUpdate( UG_S16 xp, UG_S16 yp, UG_U8 state ); 支持触摸屏, 但是不支持物理按键.
如果想用物理按键,要改代码了。
#28 2018-11-07 22:11:25
已发帖子: 9,437
https://github.com/AndresNavas/PSoC5_uGUI_Sample
https://github.com/AndresNavas/PSoC5_uGUI_Sample/blob/master/TFT_SSD1963/TFT_test.cydsn/main.c
Sample and Test project of uGUI library v.0.31 for a PSoC5-LP Kit using a SSD1963 Solomon LCD controller and XPT2046 Touch Controller.
Developed for CY8CKIT-050 PSoC5-LP Kit with a CY8C5868AXI-LP035 device using PSoC Creator 4.2
Folder with LCD Datasheets.
Folder with Picture and Video sample.
Folder with PSoC Creator Project (Inside Folder with Drivers and uGUI Library)
#29 2018-11-08 12:02:13
已发帖子: 9,437
试了一下汉字。
#30 2018-11-09 12:00:27
已发帖子: 9,437
https://embeddedlightning.com/ugui/
我的待办事项列表中包含以下功能:
演示不同平台的文件
鼠标支持
触摸屏支持
窗口支持
对象
多层支持
支持硬件加速
Alpha通道支持
抗锯齿
中心字符串功能
目前还不支持鼠标, 只支持触摸屏(绝对坐标)
#31 2018-11-09 14:45:42
已发帖子: 9,437
SDL模拟器运行.
V3s linux 4.13 运行.
汉字参考这个帖子: https://whycan.cn/t_982.html
#32 2018-11-09 17:04:31
已发帖子: 9,437
触摸屏驱动加进去了.
#33 2019-11-15 08:25:34
我思故我在
已发帖子: 244
ugui 这个好, 看了一下代码确实简洁,资源占用少, 用在单片机不错。
#34 2019-11-16 21:48:35
KeyMove
挺好用的,呈现的效果也不错
#35 2019-11-23 23:59:00
LinjieGuo
已发帖子: 591
好东西
#36 2019-12-21 20:55:44
WangLY_Snot
已发帖子: 19
晕哥,可否给出源代码,本人想想学习。。。。。。
#37 2019-12-21 21:26:53
已发帖子: 9,437
WangLY_Snot 说:
随便挑一个作为标准发个帖子就行: https://whycan.cn/t_3019.html
#38 2019-12-23 15:58:48
szchen2006
已发帖子: 216
学习了,顶!
#39 2020-02-16 20:08:17
citroen988
控件很少!
#40 2020-04-05 21:37:20
liuchangyin
已发帖子: 204
适合资源不太充裕的单片机
#41 2020-04-18 00:45:56
gmfzk2008
作者真是劳模,呵呵,谢谢分享。。
#42 2020-04-18 00:48:56
gmfzk2008
奇怪,我这里GIT上不去。。
#43 2020-04-18 14:07:55
村民
已发帖子: 43
用了,资源消耗少,功能也少。如果不做复杂的UI还是不错的
#44 2020-04-27 11:50:08
路人甲
已发帖子: 202
这个GUI果然够简,对于不复杂的系统值得一试。
#45 2020-04-28 13:34:08
9990
好帖好帖, mark学习
#46 2020-04-28 13:47:03
9990
有没有好用的字模提取工具
#47 2020-05-12 21:16:17
Paul
能不能在OS下跑?
#48 2020-07-03 11:22:31
wangjun110
好用吗
#49 2020-07-05 00:46:16
a_Cylinder
这个东西不错,值得仔细研究一下.
另外支持汉字的话全字库肯定不可取,太大了,字模提取软件用起来也不太方便,是否有什么程序可以直接将操作系统中的对应字库信息提取出来的?
#50 2020-07-15 18:03:21
ccheng-ppppp
超小资源消耗 不错 mark下
#51 2022-01-19 17:49:17
wojiaoguogai
这个会不会有版权问题
#54 2022-07-06 18:17:25
Marco
所在地: liu7312@sina.com
速度比较慢
#55 2022-07-07 20:15:18
dykxjh
已发帖子: 189
qwert1213131 说:
我觉得不能。
#56 2022-12-29 14:30:36
Zona
已发帖子: 35
dykxjh 说:
qwert1213131 说:
我觉得不能。
看了代码感觉应该是能的,问题貌似在内存管理上。具体没有深入。
言归正传,这个ugui有个0x333的 fork加强,增强了很多。
废话不多说,5,4,3,2,1,上链接! https://github.com/0x3333/UGUI
https://github.com/0x3333/UGUI/raw/master/.github/simulator-rgb888-x2.jpg?raw=true
#57 2023-04-11 16:52:40
marshallemon
这个GUI编译,运行对MCU的要求是什么?
#58 2023-05-24 15:18:03
krainwb
移植成功了吗
#59 2023-09-03 22:04:09
little_player
最近也在搞类似的,速度快吗?
#60 2023-09-05 16:53:46
Iven
已发帖子: 61
现在比较牛的是scgui和ldgui
#61 2023-09-06 09:03:30
已发帖子: 1,409
Iven 说:
现在比较牛的是scgui和ldgui
scgui搜到了:
http://saicheng.myds.me:30080/sc696a/SCGUI
ldgui没搜到...
#62 2023-09-06 10:18:40
zhangyizheng
与LVGL轻量级 GUI对比,哪个好一些?
#63 2023-09-06 11:00:57
已发帖子: 1,409
lvgl所需资源更多吧。
#64 2023-09-06 19:15:15
Iven
已发帖子: 61
#65 2024-03-26 15:13:21
banzhangzzw
这个gui只适合玩玩,组件太少,还不如uGFX
#66 2025-09-06 17:55:20
成成
有运行成功的吗
#67 2025-10-16 17:04:38
CCC_play
感谢楼主提供的思路,这样在tft屏幕上能做出更好的UI了。
