购买链接: https://s.click.taobao.com/s0JIBZw
参考链接0: 买个全志arm9 F1C100s 方案的唱戏机回来拆一拆
参考链接1: F1C100s 手册
参考链接2: 看戏机(唱戏机)F1C100原理图
参考链接3: 侨德实业有限公司VS (全志C100电脑升级)流程示意图
参考链接4: 先科唱戏机(看戏机)F1C100s方案运行XBOOT大神的XBOOT系统步骤
参考链接5: F1C100s入坑记录
参考链接A: 荔枝派Zero V3s开发板入坑记录
参考链接B: 【视频分享】制作荔枝派Zero开发板(全志V3s) TF/SD卡启动盘
下面是网友拆解图片:
接串口线:
BOOT0 is starting
DBG: init jtag OK
init dram , base is 0x80000000
init dram , clk is 156
init dram , access_mode is 1
init dram , cs_num is 1
init dram , ddr8_remap is 0
init dram , sdr_ddr is 1
init dram , bwidth is 16
init dram , col_width is 10
init dram , row_width is 13
init dram , bank_size is 4
init dram , cas is 3
init dram , size is 0
dram init successed,size is 32
DBG: init heap OK, base address is 0x80000000, size is 0x00100000
DBG: load boot1 from spinor
DBG: init spinor OK
DBG: the size of BOOT1 is 71168
DBG: src_sum = 0x0x4dd22bba
DBG: sum = 0x0x4dd22bba
succeed in loading BOOT1
jump to BOOT1
DBG: boot1 starting!
DBG: init heap OK, base address is 0x80800000, size is 0x00100000
begin to init file system
DBG: init block device OK
DBG: init mini file system OK
DBG: mount c partition OK
0
jump to kernal
Mount Parts Thread running.....
\0partition [D] plug in..
\0Mount Parts Thread work now.....
\0.Start Shell from partion 'c'..................................................................................
\0Mount Parts Thread work end....
\0Execute startup script begin..............
\0Esh Error: \0OpenConfigFile y:\config\config.bin failed.
\01
\02
\03
\0.orange Installed and Openned!........................................................................................
\04
\0partition [E] plug in..
\05
\0.Desktop Installed and Openned!........................................................................................
\0...............Execute startup script end
\0Esh msg: \0shell main thread: Bye Bye!
\0pend event sem overtime!
\0*divider=7
\0b_interlace=0
\022212222 22222222 00222222
\0
以上是原版固件接上串口线后的打印输出
SEGGER J-Link Commander V4.96l ('?' for help)
Compiled Feb 25 2015 10:24:24
DLL version V4.96l, compiled Feb 25 2015 10:24:11
Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
Hardware: V8.00
S/N: 20121126
Feature(s): RDI,FlashDL,FlashBP,JFlash
VTarget = 2.982V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D152192: ICache: 32kB (4*256*32), DCache: 16kB (4*128*32)
Info: Cache type: Separate, Write-back, Format C (WT supported)
Found 1 JTAG device, Total IRLen = 4:
#0 Id: 0x07926F0F, IRLen: 04, IRPrint: 0x1, ARM926EJ-S Core
Found ARM with core Id 0x07926F0F (ARM9)
Target interface speed: 100 kHz
J-Link>
JLINK连接成功!
下载EWARM-CD-8201-14188.exe
再到csdn下载了 IAR7.x破解文件.rar 破解工具,
根据 IAR for ARM介绍、下载、安装与注册终于把IAR破解了。
IAR 7.4下载链接:EWARM-CD-7401-8472.exe
能用keil吗?驱动调试的怎么样了?
串口线和jlink的线接到板子哪里的?有标记吗?
参考链接: http://linux-sunxi.org/MicroSD_Breakout
Mapping
Pin MicroSD JTAG Connection 14-pin ARM JTAG Header UART Connection 5-pin UART Header
1 Data2 TCK 9 nc nc
2 CD/Data3 nc nc RX 2
3 Cmd TDO 11 nc nc
4 VDD VTG 1,13 VDD 3
5 CLK nc nc TX 1
6 VSS GND 2,4,6,8,10,14 GND 4, 5
7 Data0 TDI 5 nc nc
8 Data1 TMS 7 nc nc
nc nc nTRST 3 nc nc
nc nc nRESET 12 nc nc
然后再谷歌找一张带引脚序号的TF卡封装图,对照标出UART和JTAG, 然后用杜邦线引出贴上标签纸。
晕哥,F1C100s的内存映射表也是靠猜的吗? 参考哪个芯片猜的?
晕哥,F1C100S的gpio 地址 及配置哪里能参考?
大神,请教一个小问题啊,从你的jlink接线图片,看起来。SD的第三脚(白色线,JTAG定义是TDO)貌似是对应到jlink的13脚(JTAG定义是VDD)上去了呀,而按照资料来看,这根白色线应该是接到11脚的呢,
现在我碰到的问题是,SD的第三脚接到jlink的11脚,jlink.exe无法读取到任何设备啊。。。是应该按照 你的接法去连接吗?
F1C100S的sram地址应该是0~0x7fff,32k。
晕哥,修改lcd驱动参数在哪个目录下面呢? arch 下 f1c100s下的driver下面没找到
xboot带的演示效果那么的酷炫,居然不支持LCD?
xboot目前没有适配f1c100s的lcd而已,估计要不了几天就可以了。
希望晕神,找到外包装,给一个能用的版本
及其混乱
晕哥大神,能不能分离这个视频是如何做到20FPS这么高的?
为啥我自己编的xboot没改任何东西只能跑10fps左右?
晕啊,买了拆了还能退么?
晕哥,发现坑越来越深哦,从网上查唱戏机方案,貌似除了炬力的,还有瑞芯微的。。。
agnd 说:晕啊,买了拆了还能退么?
据说热风枪 吹保修标签可以完整撕下 (逃
可以在tf卡位置怼一下jlink看一下芯片么![]()
最近编辑记录 Jin劲 (2018-08-24 14:34:38)
晕哥 说:agnd 说:晕啊,买了拆了还能退么?
http://linux-sunxi.org/images/thumb/0/05/JTAG_MicroSD_UART-front.jpeg/180px-JTAG_MicroSD_UART-front.jpeg
优秀!
还有这种操作。
RK2806也是ARM926EJ_s,外加一个DSP组成的双核,小心以假乱真啊
Jin劲 说:晕哥 说:据说热风枪 吹保修标签可以完整撕下 (逃
http://linux-sunxi.org/images/thumb/0/05/JTAG_MicroSD_UART-front.jpeg/180px-JTAG_MicroSD_UART-front.jpegRK2806也是ARM926EJ_s,外加一个DSP组成的双核,小心以假乱真啊
不怕,看Core Id
哇 异构多核
我想买一款F1C200S的产品拆解一下,求产品链接。
F1C800芯片怎么样?感觉功能比这个增强很多。
800好像支持LVDS
siwen 说:F1C800芯片怎么样?感觉功能比这个增强很多。
800好像支持LVDS
C800和100S、200S一样是ARM926EJS的内核,工艺有提升,跑MELIS3.0系统,CPU量产稳定可以跑1G左右,
外加支持MIPI、LVDS屏,支持解大部分1080P视频,可以说基本是全格式的
微凉VeiLiang 说:siwen 说:F1C800芯片怎么样?感觉功能比这个增强很多。
800好像支持LVDS
你有支持吗?带不带集成内存?价位多少?
800好像支持LVDS
网站的简介,说支持wifi b/g/n/ac,难道内置WiFi?
九霄云外 说:微凉VeiLiang 说:800好像支持LVDS
外加支持MIPI、LVDS屏,支持解大部分1080P视频,可以说基本是全格式的你有支持吗?带不带集成内存?价位多少?
C800带64MB的DDR2, 有支持,我就是干这个的
外加支持MIPI、LVDS屏,支持解大部分1080P视频,可以说基本是全格式的网站的简介,说支持wifi b/g/n/ac,难道内置WiFi?
没有WIFI,如果简介有说支持,那就是写错了,复制粘贴的那种错错
ippen 说:九霄云外 说:C800和100S、200S一样是ARM926EJS的内核,工艺有提升,跑MELIS3.0系统,CPU量产稳定可以跑1G左右,
老兄,你不会就是全志代理吧?我需要拿一些200s片子
达克罗德 说:九霄云外 说:C800和100S、200S一样是ARM926EJS的内核,工艺有提升,跑MELIS3.0系统,CPU量产稳定可以跑1G左右,
什么价位方便透露下吗?我的QQ15194966
九霄云外 说:ippen 说:网站的简介,说支持wifi b/g/n/ac,难道内置WiFi?
可以找我拿,我们还可以提供技术支持,加我QQ:610943940
最近编辑记录 九霄云外 (2019-02-25 13:12:42)
赞赞赞,市场上就确实你这种既懂技术,又懂市场的老板。
这论坛太让人感觉舒服了,亲切!
800好像支持LVDS
CPU上到1GHz?
外加支持MIPI、LVDS屏,支持解大部分1080P视频,可以说基本是全格式的CPU上到1GHz?
C800可以的,其它不行
最近编辑记录 九霄云外 (2019-02-28 10:07:21)
用料不少。晕哥,请问有没有游客建议开一个学习的版块,好跟着Debugdump一起学习些东西。
https://whycan.cn/files/members/3/QQ20180109200945.png
f1c100s JLINK 单步调试OK
IAR7工程下载: F1C100s_IAR_V7_20180109.zip
我把这个工程下载下来了,为什么使用的是S3C2440A(926T),不应该使用的是926的内核么
RK28xx/29xx现在应该已经不多见了,同屏器用的RK3026/3036印象中很少用在唱戏机上
F1C系列看起来是五六年前安卓MP4方案的改版?
http://tech.sina.com.cn/digi/2011-05-26/09221765762.shtml
最近编辑记录 dven (2019-04-27 00:15:22)
也想买一个唱戏机来学习
有唱戏机主板卖,可以挑f1c100s芯片的
我买了唱戏机,就是晕哥说那个98包邮那款,是用F1C100s方案的。且是主板改小尺寸了,以后就要跟晕哥混了
折腾了20天,终于摸到门边了,用 https://whycan.cn/t_2689.html 的 suniv_f1c100s_w25q128_usb_lcd_ok_20190722.7z 能看到显示屏有显示 但分辨率不对,还有就是终端好像输出错误,串口是用UART0 PE0 PE1脚,即是收音机芯片的那两个数据管脚。
老哥们 唱戏机的屏幕背光用的是哪个引脚,用nano的固件改成480*272的分辨率,nano点唱戏机的屏,是可以显示的。现在换回唱戏机主板点唱戏机,屏幕不亮,不知道背光是哪个脚?4.3寸唱戏机,跟晕哥这个是一样的。
找到背光芯片, 顺藤摸瓜找到背光芯片的控制引脚, 这时有两个选择:
1. 用万用表量出与 f1c100s 连接的引脚.
2. 直接飞线上拉或者下拉引脚控制引脚。
新人入坑,之前弄的stm32,没搞过linux,有带入坑的吗?红包支持
完全小白,问得会有点低能。晕哥能QQ求教吗
cris8259 说:完全小白,问得会有点低能。晕哥能QQ求教吗
QQ只聊天,不聊技术。有问题直接发帖/跟帖,再低能的问题也竭尽所能解答,不过也可能会把你带坑里面去。
哈哈,请多赐教
背光芯片找到了,没找到资料,万用表也没量出引脚,
夏新唱戏机,4.3寸,rgb 40PIN。没人玩吗?
@明月心惜 最近买的吗?求购买链接
背光芯片就那么几个, 看下是什么封装的, 帮你猜一下
最近编辑记录 firstman (2019-09-25 21:57:46)
@明月心惜 最近买的吗?求购买链接
【夏新M-185 4.3寸看戏机老人唱戏机听戏收音机老年高清视频播放器】 https://m.tb.cn/h.eNYNskN?sm=04b88c 点击链接,再选择浏览器咑閞;或椱ァ製这段描述$p6sWYnIdSuC$后到?◇綯℡寳?
18年11月买的,现在还在卖。40PIN最近那个sot-23-6就是驱动,丝印BIBHF6,引脚找到了,PE12,但是使能逻辑可能和nano(低电平)不一样,所以点不亮,我再试试。
MT9284?
好帖,谢谢楼主无私奉献,初学者的福音
好帖,谢谢楼主无私奉献,初学者的福音
是的。
全志虽然资料不怎么开放,但是社区对他很眷顾。
脸红吗,脸痛吗?就像馋女人的身子一样,不过是性价比高而已
真香定律?
谢谢楼主无私奉献,初学者的福音
好帖,谢谢楼主无私奉献,初学者的福音
好帖,谢谢楼主无私奉献,初学者的福音
哈哈,以前买海思的开发板就是直接去买dvr成品
奢侈啊!!!没钱买
楼主图文并茂赞赞赞,现在还能买到全志方案唱戏机吗?
满满的黑科技,无解
你好,有F1C100s裸机开发的例程吗
根据 IAR for ARM介绍、下载、安装与注册终于把IAR破解了。IAR 7.4下载链接:EWARM-CD-7401-8472.exe
Thanks for link, But it looks it's broken.
Can you please provide valid link.
感谢您的链接,但它似乎坏了。
您能提供有效的链接吗?
One more question I am not able to create a new post.
when I click on Topics: New then it search for post with new, So how to create a new post ?
最近编辑记录 piyush (2020-05-14 21:20:32)
Can you please provide valid link.感谢您的链接,但它似乎坏了。
您能提供有效的链接吗?One more question I am not able to create a new post.
请问你需要哪个文件?
请问你需要哪个文件?
Thanks For reply
Thanks For reply
EWARM-CD-8201-14188.exe: https://pan.baidu.com/s/1jI7Kb8E?fid=984632783629706
EWARM-CD-7401-8472.exe: http://netstorage.iar.com/SuppDB/Protected/PRODUPD/009952/EWARM-CD-7401-8472.exe
Thank you very much for the link.
But EWARM-CD-8201-14188.exe is still broken.
Will I need this crack file IAR7.x破解文件.rar ?
Actually I design a new F1C100S Hardware & I have to debug it.
For now I can get SPI Flash Clock pin signal but no rs232 message and no signale on SDClock.
I have not designed pad for SPI Flash as I want to use SD Card, So need to debug board.
非常感谢您提供的链接。
但是EWARM-CD-8201-14188.exe仍然损坏。
我需要这个破解文件IAR7.x crack file.rar吗?
实际上,我设计了一种新的F1C100S硬件,并且必须对其进行调试。
现在,我可以获得SPI Flash Clock引脚信号,但没有rs232消息,并且在SDClock上没有信号。
我还没有为SPI Flash设计焊盘,因为我想使用SD卡,因此需要调试电路板。
19年我也买了个F1C100s方案的唱戏机,当时55包邮,刚才去TB看了一下,已经下架,遗憾!!!哪个兄弟有购买链接发一个啊
建议用MDK吧: https://whycan.cn/t_1527.html
Thankyour very much,
This is exactly what I need.
非常感谢你,
这正是我所需要的。
之前也买过唱戏机,感觉这东西之前挺好卖的,不过现在手机流行,把唱戏机干下去了。不过全志的这颗芯片太有优势了
好帖,谢谢楼主无私奉献,初学者的福音
https://whycan.cn/files/members/1082/IMG_20190925_214430.jpeg
唱戏机的背光控制 一般是PWM 因为要控制背光的亮度 C100S PWM 只有两个 PE6 PE12 分辨对应的是 PIN 37 PIN43
感谢分享,不知道现在买还是不是这个方案的了
下了个单,隔了一天多没有发货,又取消了
牛人啊,谢谢分享
感谢分享
任何建议如何用音频/声音构建Linux
谢谢分享
解析的真的很好,正在研究他的原理图
谢谢分享
解析的真的很好,正在研究他的原理图
感谢楼主分享,我这边正好学习要全志的芯片
哈哈哈,先科的,总能想到飞科。。。。。。
好帖,谢谢楼主无私奉献,初学者的福音
好帖,谢谢楼主无私奉献
麻烦介绍一下按键的识别方式和引脚。
哪里可以搞到这个tf转接板
http://linux-sunxi.org/images/thumb/0/05/JTAG_MicroSD_UART-front.jpeg/180px-JTAG_MicroSD_UART-front.jpeg哪里可以搞到这个tf转接板
设计一片 SD NAND + JTAG(全志soc) 转接板
http://whycan.com/t_2025.html
准备入坑了。是不是太晚了?
跟着玩一下,有现在成的板子!!!
@raspberryman
能不能转nor flash的呢
