楼主 #1 2020-11-10 16:04:45
hanzixi_angel
已发帖子: 54
关于V3s display-engine/display_clocks /mixer0和tcon0 有关lcd时钟配置的一些问题
最近更换了一块高亮屏   其实参数都一样  但是运行起来屏幕出现抖动的现象  很明显   uboot中显示正常  一旦进入内核就会出现画面抖动;   换了其他的屏幕就正常   推测应该是参数不匹配的问题   然后修改设备树和驱动  使用sun8i-v3s-licheepi-zero-with-800x480-lcd.dts的设备树   启用了display-engine功能   但是测试发现仍然抖动  根据设备树找到了内核的屏幕参数   更改参数仍然抖动   最终没有办法用示波器测量时钟  发现屏幕的时钟变成了24M-25M  跟晶振频率基本一致    在uboot中的频率是33M  这就导致屏幕出现抖动   在驱动中修改屏幕的之中频率  时钟无法超过24M   推测就是设备树时钟的限制   但是参看设备树  找不到如何修改设备树时钟相关的参数    设备树文件内容如下
sun8i-v3s.tdsi
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/clock/sun8i-v3s-ccu.h>
#include <dt-bindings/reset/sun8i-v3s-ccu.h>
	#address-cells = <1>;
	#size-cells = <1>;
	interrupt-parent = <&gic>;
	chosen {
		#size-cells = <1>;
		ranges;
		simplefb_lcd: framebuffer@0 {
			compatible = "allwinner,simple-framebuffer",
				     "simple-framebuffer";
			allwinner,pipeline = "de0-lcd0";
			clocks = <&ccu CLK_BUS_TCON0>, <&display_clocks 0>,
				 <&display_clocks 6>, <&ccu CLK_TCON0>;
			status = "disabled";
	cpus {
		#size-cells = <0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0>;
			clocks = <&ccu CLK_CPU>;
	de: display-engine {
		compatible = "allwinner,sun8i-v3s-display-engine";
		allwinner,pipelines = <&mixer0>;
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: osc24M_clk {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: osc32k_clk {
			#clock-cells = <0>;
			clock-frequency = <32768>;
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		display_clocks: clock@1000000 {
			compatible = "allwinner,sun8i-v3s-de2-clk";
			reg = <0x01000000 0x100000>;
			clocks = <&ccu CLK_DE>,
				 <&ccu CLK_BUS_DE>;
			clock-names = "mod",
				      "bus";
			resets = <&ccu RST_BUS_DE>;
			#clock-cells = <1>;
			#reset-cells = <1>;
		mixer0: mixer@1100000 {
			compatible = "allwinner,sun8i-v3s-de2-mixer";
			reg = <0x01100000 0x100000>;
			clocks = <&display_clocks 0>,
				 <&display_clocks 6>;
			clock-names = "bus",
				      "mod";
			resets = <&display_clocks 0>;
			assigned-clocks = <&display_clocks 6>;
			assigned-clock-rates = <150000000>;
			ports {
				#size-cells = <0>;
				mixer0_out: port@1 {
					reg = <1>;
					mixer0_out_tcon0: endpoint {
						remote-endpoint = <&tcon0_in_mixer0>;
		syscon: syscon@1c00000 {
			compatible = "allwinner,sun8i-v3s-system-controller",
				"syscon";
			reg = <0x01c00000 0x1000>;
   			compatible = "allwinner,sun8i-v3s-system-controller", "allwinner,sun8i-h3-system-control", "syscon";
    		reg = <0x01c00000 0xd0>;
    		#size-cells = <1>;
    		ranges;
    		sram_c: sram@1d00000 {
        		compatible = "mmio-sram";
        		reg = <0x01d00000 0x80000>;
        		#size-cells = <1>;
        		ranges = <0 0x01d00000 0x80000>;
        		ve_sram: sram-section@0 {
            		compatible = "allwinner,sun8i-v3s-sram-c", "allwinner,sun4i-a10-sram-c1";
            		reg = <0x000000 0x80000>;
		cedarx: video-codec@1c0e000 {
    		compatible = "allwinner,sun8i-v3-cedar";
    		reg = <0x01c0e000 0x1000>;
    		clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_DRAM_VE>;
    		clock-names = "ahb", "mod", "ram";
    		resets = <&ccu RST_BUS_VE>;
    		interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>;
    		allwinner,sram = <&ve_sram 1>;
    		//status = "disabled";
		ion: ion {
    		compatible = "allwinner,sunxi-ion";
    		heap_cma@0{
        		compatible = "allwinner,cma";
        		heap-name  = "cma";
        		heap-id    = <0x4>;
        		heap-base  = <0x0>;
        		heap-size  = <0x0>;
        		heap-type  = "ion_cma";
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,sun8i-v3s-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
				 <&ccu CLK_TCON0>;
				      "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			#clock-cells = <0>;
			resets = <&ccu RST_BUS_TCON0>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					reg = <0>;
					tcon0_in_mixer0: endpoint {
						remote-endpoint = <&mixer0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		dma: dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x01c02000 0x1000>;
			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_DMA>;
			resets = <&ccu RST_BUS_DMA>;
			#dma-cells = <1>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-names = "default";
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		mmc1: mmc@1c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-0 = <&mmc1_pins>;
			#size-cells = <0>;
		mmc2: mmc@1c11000 {
			reg = <0x01c11000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC2>,
				 <&ccu CLK_MMC2>,
				 <&ccu CLK_MMC2_OUTPUT>,
				 <&ccu CLK_MMC2_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC2>;
			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		usb_otg: usb@1c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x01c19000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@1c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x01c19400 0x2c>,
			      <0x01c1a800 0x4>;
			reg-names = "phy_ctrl",
				    "pmu0";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		ehci0: usb@01c1a000 {
			compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
			reg = <0x01c1a000 0x100>;
			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
		ohci0: usb@01c1a400 {
			compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
			reg = <0x01c1a400 0x100>;
			interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>,
				 <&ccu CLK_USB_OHCI0>;
		ccu: clock@1c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
		rtc: rtc@1c20400 {
			compatible = "allwinner,sun6i-a31-rtc";
			reg = <0x01c20400 0x54>;
			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
		pio: pinctrl@1c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x01c20800 0x400>;
			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
			gpio-controller;
			#gpio-cells = <3>;
			interrupt-controller;
			#interrupt-cells = <3>;
			emac_rgmii_pins: emac-rgmii-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4",
				       "PD5", "PD7", "PD8", "PD9", "PD10",
				       "PD12", "PD13", "PD15", "PD16", "PD17";
				function = "emac";
				drive-strength = <40>;
			i2c0_pins: i2c0-pins {
				pins = "PB6", "PB7";
				function = "i2c0";
			pwm0_pins: pwm0 {
				pins = "PB4";
				function = "pwm0";
			uart0_pb_pins: uart0-pb-pins {
				pins = "PB8", "PB9";
				function = "uart0";
			lcd_rgb666_pins_a: lcd-rgb666-pe {
				pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5",
				       "PE6", "PE7", "PE8", "PE9", "PE10", "PE11",
				       "PE12", "PE13", "PE14", "PE15", "PE16", "PE17",
				       "PE18", "PE19", "PE23", "PE24";
				function = "lcd";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3",
				       "PF4", "PF5";
				function = "mmc0";
				drive-strength = <30>;
				bias-pull-up;
			mmc1_pins: mmc1-pins {
				pins = "PG0", "PG1", "PG2", "PG3",
				       "PG4", "PG5";
				function = "mmc1";
				bias-pull-up;
			spi0_pins: spi0-pins {
				function = "spi0";
		timer@1c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x01c20c00 0xa0>;
			interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&osc24M>;
		wdt0: watchdog@1c20ca0 {
			reg = <0x01c20ca0 0x20>;
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
		pwm: pwm@1c21400 {
			compatible = "allwinner,sun8i-v3s-pwm",
				     "allwinner,sun7i-a20-pwm";
			reg = <0x01c21400 0x400>;
			clocks = <&osc24M>;
			#pwm-cells = <3>;
		lradc: lradc@1c22800 {
			compatible = "allwinner,sun4i-a10-lradc-keys";
			reg = <0x01c22800 0x400>;
			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
		codec: codec@01c22c00 {
			#sound-dai-cells = <0>;
			compatible = "allwinner,sun8i-v3s-codec";
			reg = <0x01c22c00 0x400>;
			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>;
			clock-names = "apb", "codec";
			resets = <&ccu RST_BUS_CODEC>;
			dmas = <&dma 15>, <&dma 15>;
			dma-names = "rx", "tx";
			allwinner,codec-analog-controls = <&codec_analog>;
		codec_analog: codec-analog@01c23000 {
			compatible = "allwinner,sun8i-v3s-codec-analog";
			reg = <0x01c23000 0x4>;
		uart0: serial@1c28000 {
			reg = <0x01c28000 0x400>;
			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@1c28400 {
			reg = <0x01c28400 0x400>;
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@1c28800 {
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		i2c0: i2c@1c2ac00 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x01c2ac00 0x400>;
			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C0>;
			resets = <&ccu RST_BUS_I2C0>;
			pinctrl-0 = <&i2c0_pins>;
			#size-cells = <0>;
		i2c1: i2c@1c2b000 {
			reg = <0x01c2b000 0x400>;
			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C1>;
			resets = <&ccu RST_BUS_I2C1>;
			#size-cells = <0>;
		emac: ethernet@1c30000 {
			compatible = "allwinner,sun8i-h3-emac";
			syscon = <&syscon>;
			reg = <0x01c30000 0x10000>;
			interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "macirq";
			resets = <&ccu RST_BUS_EMAC>;
			reset-names = "stmmaceth";
			clocks = <&ccu CLK_BUS_EMAC>;
			clock-names = "stmmaceth";
			mdio: mdio {
				#size-cells = <0>;
				compatible = "snps,dwmac-mdio";
			mdio-mux {
				compatible = "allwinner,sun8i-h3-mdio-mux";
				#size-cells = <0>;
				mdio-parent-bus = <&mdio>;
				/* Only one MDIO is usable at the time */
				internal_mdio: mdio@1 {
					compatible = "allwinner,sun8i-h3-mdio-internal";
					reg = <1>;
					#size-cells = <0>;
					int_mii_phy: ethernet-phy@1 {
						compatible = "ethernet-phy-ieee802.3-c22";
						reg = <1>;
						clocks = <&ccu CLK_BUS_EPHY>;
						resets = <&ccu RST_BUS_EPHY>;
				external_mdio: mdio@2 {
					reg = <2>;
					#size-cells = <0>;
		spi0: spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x01c68000 0x1000>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <&spi0_pins>;
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		gic: interrupt-controller@1c81000 {
			compatible = "arm,gic-400";
			reg = <0x01c81000 0x1000>,
			      <0x01c82000 0x1000>,
			      <0x01c84000 0x2000>,
			      <0x01c86000 0x2000>;
			interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
sun8i-v3s-licheepi-zero-with-lcd.tdsi
 * Copyright (C) 2018 Icenowy Zheng <icenowy@aosc.io>
 * SPDX-License-Identifier: (GPL-2.0+ OR X11)
#include "sun8i-v3s-licheepi-zero.dts"
	backlight: backlight {
		compatible = "pwm-backlight";
		pwms = <&pwm 0 1000000 0>;
		brightness-levels = <0 30 40 50 60 70 100>;
		default-brightness-level = <6>;
	panel: panel {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			backlight = <&backlight>;
			#size-cells = <0>;
			panel_input: endpoint@0 {
				reg = <0>;
&de {
&pwm {
	pinctrl-0 = <&pwm0_pins>;
&tcon0 {
	pinctrl-0 = <&lcd_rgb666_pins_a>;
&tcon0_out {
	tcon0_out_lcd: endpoint@0 {
		reg = <0>;
 #include "sun8i-v3s-licheepi-zero-with-lcd.dtsi"
 &panel {
	compatible = "urt,umsh-8596md-t", "simple-panel";
本人是新手  关于时钟配置不是很精通  希望各位大牛不吝赐教
#2 2020-11-10 16:09:13
所在地: 你猜
已发帖子: 3,379
Re: 关于V3s display-engine/display_clocks /mixer0和tcon0 有关lcd时钟配置的一些问题
用 sun8i-v3s-licheepi-zero.dts 这个dts呢?
你上面的dts可能用drm驱动的,而不是simplefb
楼主 #3 2020-11-10 16:37:25
hanzixi_angel
已发帖子: 54
使用simplefb也一样  时钟被降低到25M   我测试发现屏蔽sun8i-v3s.dtsi中de相关的配置就可以了   不会被降低时钟了    去掉了display_clocks /mixer0和tcon0的配置   但是如果使用de改如何配置时钟呢?
楼主 #4 2020-11-11 09:48:59
hanzixi_angel
已发帖子: 54
				      "mod";
			//assigned-clock-rates = <150000000>;
              assigned-clock-rates = <200000000>;
			ports {
				#size-cells = <0>;
					reg = <1>;
经过查看设备树以及对比测试发现   lcd的时钟被降到25Mhz   发现正好是mixer0中时钟频率150M的6分频   然后将assigned-clock-rates的150M改为200M之后解决   测量发现时钟正好是33.3M   正好符合7寸屏的时钟需求   大家如果使用de驱动液晶屏的话如果出现屏幕抖动的问题可以参考下
最近编辑记录 hanzixi_angel (2020-11-11 09:49:20)
#5 2020-11-11 09:52:41
孤星泪
已发帖子: 235
楼主研究精神可嘉
楼主 #6 2020-11-11 10:13:19
hanzixi_angel
已发帖子: 54
孤星泪 说:
楼主研究精神可嘉
踩坑嘛   没有办法   smile
#7 2020-11-19 00:40:21
wupaul2001
已发帖子: 264
不用搞了,直接换新的内核,虽然我知道是那里问题,根本问题不在设备树
#8 2020-11-19 07:25:33
raspberryman
已发帖子: 503
wupaul2001 说:
请教用哪个版本? Linux5.9?
楼主 #9 2020-11-19 19:08:52
hanzixi_angel
已发帖子: 54
wupaul2001 说:
根本问题在哪   能指点一二吗   使用哪个内核?
#10 2020-11-24 18:10:39
wupaul2001
已发帖子: 264
我使用5,2的内核
#11 2020-11-24 18:13:15
wupaul2001
已发帖子: 264
不想换内核的话。修改/drivers/gpu/drm/sun4i/sun4i_tcon.c
-tcon->dclk_min_div = 6;
+tcon->dclk_min_div = 1;
楼主 #12 2020-11-25 15:20:20
hanzixi_angel
已发帖子: 54
wupaul2001 说:
我使用5,2的内核
我使用的也是5.2的内核   您是从那个地址clone的?
楼主 #13 2020-11-25 15:20:50
hanzixi_angel
已发帖子: 54
wupaul2001 说:
这个就是分频设置了吧
#14 2020-11-27 15:20:07
wupaul2001
已发帖子: 264
hanzixi_angel 说:
wupaul2001 说:
我使用5,2的内核
主线clone的
#15 2020-11-27 15:20:51
wupaul2001
已发帖子: 264
hanzixi_angel 说:
wupaul2001 说:
这个就是分频设置了吧
解决最小分频限制
#16 2020-12-17 17:17:43
b7376811
已发帖子: 27
mark 一下
#17 2022-09-06 02:41:11
iamseer
已发帖子: 69
我也遇到了类似问题,帧率想要60.却只有40.
检查的手册发现24M主时钟通过PLL_VIDEO_CTRL_REG配置到PLL_VIDEO频率,再通过TCON_CLK_REG降低到指定屏幕PCLK频率。PLL参数内核会自动设置,但是PLL_VIDEO频率需要指定。
不知道是不是我打的补丁冲突原因,assigned-clock-rates = <200000000>;不起作用。修改 sun8i_mixer.c 里对应板子的 .mod_rate 可行。
