这个驱动分析起来像捉迷藏一样,本着顺藤摸瓜的思路,发现开了两个tasklet:
1 tasklet_init(&precvpriv->recv_tasklet, (void(*)(unsigned long))usb_recv_tasklet,(unsigned long)padapter);
2 tasklet_init(&pxmitpriv->xmit_tasklet,(void(*)(unsigned long))rtl8188eu_xmit_tasklet,(unsigned long)padapter);
在"ifconfig wlan0 up"开了一个命令线程:rtw_start_drv_threads(padapter).
究竟是如何发送数据的呢?发送任务函数原型是这个:
void rtl8188eu_xmit_tasklet(void *priv)
int ret = _FALSE;
_adapter *padapter = (_adapter *)priv;
struct xmit_priv *pxmitpriv = &padapter->xmitpriv;
while (1) {
if (RTW_CANNOT_TX(padapter)) {
RTW_INFO("xmit_tasklet => bDriverStopped or bSurpriseRemoved or bWritePortCancel\n");
break;
if (rtw_xmit_ac_blocked(padapter) == _TRUE)
break;
ret = rtl8188eu_xmitframe_complete(padapter, pxmitpriv, NULL);
if (ret == _FALSE)
break;
而发送数据的函数是包括这个:
s32 rtw_hal_xmit(_adapter *padapter, struct xmit_frame *pxmitframe)
return padapter->hal_func.hal_xmit(padapter, pxmitframe);
也就是这个:pHalFunc->hal_xmit = &rtl8188eu_hal_xmit;
s32 rtl8188eu_hal_xmit(_adapter *padapter, struct xmit_frame *pxmitframe)
{ //RTW_INFO("==> %s xmitframe 3 \n", __FUNCTION__);
return pre_xmitframe(padapter, pxmitframe);
还有一串.....
static s32 pre_xmitframe(_adapter *padapter, struct xmit_frame *pxmitframe)
_irqL irqL;
s32 res;
struct xmit_buf *pxmitbuf = NULL;
struct pkt_attrib *pattrib = &pxmitframe->attrib;
struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
_enter_critical_bh(&pxmitpriv->lock, &irqL);
/* RTW_INFO("==> %s\n",__FUNCTION__); */
if (rtw_txframes_sta_ac_pending(padapter, pattrib) > 0) {
/* RTW_INFO("enqueue AC(%d)\n",pattrib->priority); */
goto enqueue;
goto enqueue;
if (DEV_STA_LG_NUM(padapter->dvobj))
goto enqueue;
pxmitbuf = rtw_alloc_xmitbuf(pxmitpriv);
if (pxmitbuf == NULL)
goto enqueue;
_exit_critical_bh(&pxmitpriv->lock, &irqL);
pxmitframe->pxmitbuf = pxmitbuf;
pxmitframe->buf_addr = pxmitbuf->pbuf;
pxmitbuf->priv_data = pxmitframe;
if (xmitframe_direct(padapter, pxmitframe) != _SUCCESS) {
rtw_free_xmitbuf(pxmitpriv, pxmitbuf);
rtw_free_xmitframe(pxmitpriv, pxmitframe);
return _TRUE;
enqueue:
res = rtw_xmitframe_enqueue(padapter, pxmitframe);
if (res != _SUCCESS) {
pxmitpriv->tx_drop++;
return _TRUE;
return _FALSE;
static s32 xmitframe_direct(_adapter *padapter, struct xmit_frame *pxmitframe)
s32 res = _SUCCESS;
res = rtw_xmitframe_coalesce(padapter, pxmitframe->pkt, pxmitframe);
if (res == _SUCCESS)
rtw_dump_xframe(padapter, pxmitframe);//mark
RTW_INFO("==> %s xmitframe_coalsece failed\n", __FUNCTION__);
return res;
怎么就勾搭上了?
勾搭
#ifdef CONFIG_USB_TX_AGGREGATION
#define IDEA_CONDITION 1 /* check all packets before enqueue */
s32 rtl8188eu_xmitframe_complete(_adapter *padapter, struct xmit_priv *pxmitpriv, struct xmit_buf *pxmitbuf)
HAL_DATA_TYPE *pHalData = GET_HAL_DATA(padapter);
struct xmit_frame *pxmitframe = NULL;
struct xmit_frame *pfirstframe = NULL;
/* aggregate variable */
struct hw_xmit *phwxmit;
struct sta_info *psta = NULL;
struct tx_servq *ptxservq = NULL;
_irqL irqL;
_list *xmitframe_plist = NULL, *xmitframe_phead = NULL;
u32 pbuf; /* next pkt address */
u32 pbuf_tail; /* last pkt tail */
u32 len; /* packet length, except TXDESC_SIZE and PKT_OFFSET */
u32 bulkSize = pHalData->UsbBulkOutSize;
u8 descCount;
u32 bulkPtr;
/* dump frame variable */
u32 ff_hwaddr;
_list *sta_plist, *sta_phead;
u8 single_sta_in_queue = _FALSE;
#ifndef IDEA_CONDITION
int res = _SUCCESS;
/* check xmitbuffer is ok */
if (pxmitbuf == NULL) {
/* RTW_INFO("%s #1, connot alloc xmitbuf!!!!\n",__FUNCTION__); */
return _FALSE;
/* RTW_INFO("%s =====================================\n",__FUNCTION__); */
/* 3 1. pick up first frame */
do {
pxmitframe = rtw_dequeue_xframe(pxmitpriv, pxmitpriv->hwxmits, pxmitpriv->hwxmit_entry);
if (pxmitframe == NULL) {
/* no more xmit frame, release xmit buffer */
/* RTW_INFO("no more xmit frame ,return\n"); */
return _FALSE;
if (pxmitframe->frame_tag != DATA_FRAMETAG) {
/* rtw_free_xmitframe(pxmitpriv, pxmitframe); */
continue;
/* TID 0~15 */
if ((pxmitframe->attrib.priority < 0) ||
(pxmitframe->attrib.priority > 15)) {
continue;
/* RTW_INFO("==> pxmitframe->attrib.priority:%d\n",pxmitframe->attrib.priority); */
pxmitframe->agg_num = 1; /* alloc xmitframe should assign to 1. */
#ifdef CONFIG_TX_EARLY_MODE
pxmitframe->pkt_offset = (PACKET_OFFSET_SZ / 8) + 1; /* 2; */ /* first frame of aggregation, reserve one offset for EM info ,another for usb bulk-out block check */
#else
pxmitframe->pkt_offset = (PACKET_OFFSET_SZ / 8); /* 1; */ /* first frame of aggregation, reserve offset */
if (rtw_xmitframe_coalesce(padapter, pxmitframe->pkt, pxmitframe) == _FALSE) {
RTW_INFO("%s coalesce 1st xmitframe failed\n", __FUNCTION__);
continue;
/* always return ndis_packet after rtw_xmitframe_coalesce */
rtw_os_xmit_complete(padapter, pxmitframe);
break;
} while (1);
/* 3 2. aggregate same priority and same DA(AP or STA) frames */
pfirstframe = pxmitframe;
len = rtw_wlan_pkt_size(pfirstframe) + TXDESC_SIZE + (pfirstframe->pkt_offset * PACKET_OFFSET_SZ);
pbuf_tail = len;
pbuf = _RND8(pbuf_tail);
/* check pkt amount in one bulk */
descCount = 0;
bulkPtr = bulkSize;
if (pbuf < bulkPtr) {
descCount++;
if (descCount == pHalData->UsbTxAggDescNum)
goto agg_end;
} else {
descCount = 0;
bulkPtr = ((pbuf / bulkSize) + 1) * bulkSize; /* round to next bulkSize */
/* dequeue same priority packet from station tx queue */
/* psta = pfirstframe->attrib.psta; */
psta = rtw_get_stainfo(&padapter->stapriv, pfirstframe->attrib.ra);
if (pfirstframe->attrib.psta != psta)
RTW_INFO("%s, pattrib->psta(%p) != psta(%p)\n", __func__, pfirstframe->attrib.psta, psta);
if (psta == NULL)
RTW_INFO("rtw_xmit_classifier: psta == NULL\n");
if (!(psta->state & _FW_LINKED))
RTW_INFO("%s, psta->state(0x%x) != _FW_LINKED\n", __func__, psta->state);
switch (pfirstframe->attrib.priority) {
case 1:
case 2:
ptxservq = &(psta->sta_xmitpriv.bk_q);
phwxmit = pxmitpriv->hwxmits + 3;
break;
case 4:
case 5:
ptxservq = &(psta->sta_xmitpriv.vi_q);
phwxmit = pxmitpriv->hwxmits + 1;
break;
case 6:
case 7:
ptxservq = &(psta->sta_xmitpriv.vo_q);
phwxmit = pxmitpriv->hwxmits;
break;
case 0:
case 3:
default:
ptxservq = &(psta->sta_xmitpriv.be_q);
phwxmit = pxmitpriv->hwxmits + 2;
break;
/* RTW_INFO("==> pkt_no=%d,pkt_len=%d,len=%d,RND8_LEN=%d,pkt_offset=0x%02x\n", */
/* pxmitframe->agg_num,pxmitframe->attrib.last_txcmdsz,len,pbuf,pxmitframe->pkt_offset ); */
sta_phead = get_list_head(phwxmit->sta_queue);
sta_plist = get_next(sta_phead);
single_sta_in_queue = rtw_end_of_queue_search(sta_phead, get_next(sta_plist));
xmitframe_phead = get_list_head(&ptxservq->sta_pending);
xmitframe_plist = get_next(xmitframe_phead);
while (rtw_end_of_queue_search(xmitframe_phead, xmitframe_plist) == _FALSE) {
pxmitframe = LIST_CONTAINOR(xmitframe_plist, struct xmit_frame, list);
xmitframe_plist = get_next(xmitframe_plist);
if (_FAIL == rtw_hal_busagg_qsel_check(padapter, pfirstframe->attrib.qsel, pxmitframe->attrib.qsel))
break;
pxmitframe->agg_num = 0; /* not first frame of aggregation */
pxmitframe->pkt_offset = 1;/* not first frame of aggregation,reserve offset for EM Info */
#else
pxmitframe->pkt_offset = 0; /* not first frame of aggregation, no need to reserve offset */
len = rtw_wlan_pkt_size(pxmitframe) + TXDESC_SIZE + (pxmitframe->pkt_offset * PACKET_OFFSET_SZ);
if (_RND8(pbuf + len) > MAX_XMITBUF_SZ) {
/* RTW_INFO("%s....len> MAX_XMITBUF_SZ\n",__FUNCTION__); */
break;
rtw_list_delete(&pxmitframe->list);
ptxservq->qcnt--;
phwxmit->accnt--;
/* suppose only data frames would be in queue */
continue;
/* TID 0~15 */
continue;
/* pxmitframe->pxmitbuf = pxmitbuf; */
pxmitframe->buf_addr = pxmitbuf->pbuf + pbuf;
RTW_INFO("%s coalesce failed\n", __FUNCTION__);
continue;
/* (len - TXDESC_SIZE) == pxmitframe->attrib.last_txcmdsz */
update_txdesc(pxmitframe, pxmitframe->buf_addr, pxmitframe->attrib.last_txcmdsz, _TRUE);
/* don't need xmitframe any more */
/* handle pointer and stop condition */
pbuf_tail = pbuf + len;
pfirstframe->agg_num++;
pxmitpriv->agg_pkt[pfirstframe->agg_num - 1].offset = _RND8(len);
pxmitpriv->agg_pkt[pfirstframe->agg_num - 1].pkt_len = pxmitframe->attrib.last_txcmdsz;
if (MAX_TX_AGG_PACKET_NUMBER == pfirstframe->agg_num)
break;
descCount++;
break;
} else {
descCount = 0;
} /* end while( aggregate same priority and same DA(AP or STA) frames) */
if (_rtw_queue_empty(&ptxservq->sta_pending) == _TRUE)
rtw_list_delete(&ptxservq->tx_pending);
else if (single_sta_in_queue == _FALSE) {
/* Re-arrange the order of stations in this ac queue to balance the service for these stations */
rtw_list_insert_tail(&ptxservq->tx_pending, get_list_head(phwxmit->sta_queue));
agg_end:
#ifdef CONFIG_80211N_HT
if ((pfirstframe->attrib.ether_type != 0x0806) &&
(pfirstframe->attrib.ether_type != 0x888e) &&
(pfirstframe->attrib.ether_type != 0x88b4) &&
(pfirstframe->attrib.dhcp_pkt != 1))
rtw_issue_addbareq_cmd(padapter, pfirstframe);
#endif /* CONFIG_80211N_HT */
#ifndef CONFIG_USE_USB_BUFFER_ALLOC_TX
/* 3 3. update first frame txdesc */
if ((PACKET_OFFSET_SZ != 0) && ((pbuf_tail % bulkSize) == 0)) {
/* remove pkt_offset */
pbuf_tail -= PACKET_OFFSET_SZ;
pfirstframe->buf_addr += PACKET_OFFSET_SZ;
pfirstframe->pkt_offset--;
/* RTW_INFO("$$$$$ buf size equal to USB block size $$$$$$\n"); */
#endif /* CONFIG_USE_USB_BUFFER_ALLOC_TX */
update_txdesc(pfirstframe, pfirstframe->buf_addr, pfirstframe->attrib.last_txcmdsz, _TRUE);
/* prepare EM info for first frame, agg_num value start from 1 */
pxmitpriv->agg_pkt[0].offset = _RND8(pfirstframe->attrib.last_txcmdsz + TXDESC_SIZE + (pfirstframe->pkt_offset * PACKET_OFFSET_SZ));
pxmitpriv->agg_pkt[0].pkt_len = pfirstframe->attrib.last_txcmdsz;/* get from rtw_xmitframe_coalesce */
UpdateEarlyModeInfo8188E(pxmitpriv, pxmitbuf);
/* 3 4. write xmit buffer to USB FIFO */
ff_hwaddr = rtw_get_ff_hwaddr(pfirstframe);
/* RTW_INFO("%s ===================================== write port,buf_size(%d)\n",__FUNCTION__,pbuf_tail); */
/* xmit address == ((xmit_frame*)pxmitbuf->priv_data)->buf_addr */
#ifdef CONFIG_XMIT_THREAD_MODE
pxmitbuf->len = pbuf_tail;
pxmitbuf->ff_hwaddr = ff_hwaddr;
if (pfirstframe->attrib.qsel == QSLT_BEACON)
/* download rsvd page*/
rtw_write_port(padapter, ff_hwaddr, pbuf_tail, (u8 *)pxmitbuf);
enqueue_pending_xmitbuf(pxmitpriv, pxmitbuf);
#else
/* 3 5. update statisitc */
pbuf_tail -= (pfirstframe->agg_num * TXDESC_SIZE);
pbuf_tail -= (pfirstframe->pkt_offset * PACKET_OFFSET_SZ);
rtw_count_tx_stats(padapter, pfirstframe, pbuf_tail);
rtw_free_xmitframe(pxmitpriv, pfirstframe);
return _TRUE;
#else
struct hw_xmit *phwxmits;
sint hwentry;
int res = _SUCCESS, xcnt = 0;
phwxmits = pxmitpriv->hwxmits;
hwentry = pxmitpriv->hwxmit_entry;
if (!pxmitbuf)
return _FALSE;
do {
pxmitframe = rtw_dequeue_xframe(pxmitpriv, phwxmits, hwentry);
if (pxmitframe) {
if ((pxmitframe->frame_tag & 0x0f) == DATA_FRAMETAG) {
if (pxmitframe->attrib.priority <= 15) /* TID0~15 */
/*RTW_INFO("==> pxmitframe->attrib.priority:%d\n",pxmitframe->attrib.priority); */
rtw_os_xmit_complete(padapter, pxmitframe);/* always return ndis_packet after rtw_xmitframe_coalesce */
if (res == _SUCCESS){
RTW_INFO("==> %s xmitframe 1 \n", __FUNCTION__);
else {
xcnt++;
} else {
return _FALSE;
break;
} while (0/*xcnt < (NR_XMITFRAME >> 3)*/);
return _TRUE;
勾搭
/* for non-agg data frame or management frame */
static s32 rtw_dump_xframe(_adapter *padapter, struct xmit_frame *pxmitframe)
s32 ret = _SUCCESS;
s32 inner_ret = _SUCCESS;
int t, sz, w_sz, pull = 0;
u8 *mem_addr;
u32 ff_hwaddr;
struct xmit_buf *pxmitbuf = pxmitframe->pxmitbuf;
struct security_priv *psecuritypriv = &padapter->securitypriv;
if ((pxmitframe->frame_tag == DATA_FRAMETAG) &&
(pxmitframe->attrib.ether_type != 0x0806) &&
(pxmitframe->attrib.ether_type != 0x888e) &&
(pxmitframe->attrib.ether_type != 0x88b4) &&
(pxmitframe->attrib.dhcp_pkt != 1))
rtw_issue_addbareq_cmd(padapter, pxmitframe);
mem_addr = pxmitframe->buf_addr;
for (t = 0; t < pattrib->nr_frags; t++) {
if (inner_ret != _SUCCESS && ret == _SUCCESS)
ret = _FAIL;
if (t != (pattrib->nr_frags - 1)) {
sz = pxmitpriv->frag_len;
sz = sz - 4 - (psecuritypriv->sw_encrypt ? 0 : pattrib->icv_len);
} else /* no frag */
sz = pattrib->last_txcmdsz;
pull = update_txdesc(pxmitframe, mem_addr, sz, _FALSE);
if (pull) {
mem_addr += PACKET_OFFSET_SZ; /* pull txdesc head */
/* pxmitbuf->pbuf = mem_addr; */
pxmitframe->buf_addr = mem_addr;
w_sz = sz + TXDESC_SIZE;
} else
w_sz = sz + TXDESC_SIZE + PACKET_OFFSET_SZ;
#ifdef CONFIG_IOL_IOREG_CFG_DBG
rtw_IOL_cmd_buf_dump(padapter, w_sz, pxmitframe->buf_addr);
ff_hwaddr = rtw_get_ff_hwaddr(pxmitframe);
pxmitbuf->len = w_sz;
if (pxmitframe->attrib.qsel == QSLT_BEACON)
rtw_write_port(padapter, ff_hwaddr, w_sz, (u8 *)pxmitbuf);
#else
RTW_INFO("%s: rtw_write_port size =%d\n", __func__,w_sz);
inner_ret = rtw_write_port(padapter, ff_hwaddr, w_sz, (unsigned char *)pxmitbuf);
rtw_count_tx_stats(padapter, pxmitframe, sz);
RTW_INFO("rtw_write_port, w_sz=%d, sz=%d, txdesc_sz=%d, tid=%d\n", w_sz, sz, w_sz-sz, pattrib->priority);
mem_addr += w_sz;
mem_addr = (u8 *)RND4(((SIZE_PTR)(mem_addr)));
if (ret != _SUCCESS)
rtw_sctx_done_err(&pxmitbuf->sctx, RTW_SCTX_DONE_UNKNOWN);
return ret;
最近编辑记录 whyabc666 (2021-02-28 15:07:05)
这个dia画图软件不好用,工具栏没和图表合在一起,粘帖函数切换麻烦.
最近编辑记录 whyabc666 (2021-02-28 02:23:57)
终于进入工作状态了,加油!
我刚好相反,越穷的时候睡的越香,因为没其他想法了
老是会有很多疑问.usb聚合发送是什么新技术?802.3数据转到802.11?监听模式加radiotap是在802.11数据包上?radiotap有没有加到fcs?(从recbuf2recframe看接收状态有记录数据是否丢包,怎么知道recbuf数据出错没有,不是取出数据做CRC和接收到的CRC比较吗?这个函数在哪里?)驱动层的crc校验是哪些函数?
最近编辑记录 whyabc666 (2021-03-01 13:10:34)
从ifconfig wlan0 up 到 _netdev_open 是怎么个流程?
插入驱动的log来看,怎么感觉从module_init(rtw_drv_entry),函数rtw_drv_entry中的usb_register明明在
''rtw_ndev_notifier_register();rtw_inetaddr_notifier_register();''
后面,怎么log却是这样?
RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
RTW: rtw_wiphy_alloc(phy0)
RTW: rtw_wdev_alloc(padapter=c3ea3000)
RTW: rtw_wiphy_register(phy0)
RTW: Register RTW cfg80211 vendor cmd(0x67) interface
RTW: rtw_reg_notifier: NL80211_REGDOM_SET_BY_CORE
RTW: rtw_ndev_init(wlan0) if1 mac_addr=cc:79:cf:94:06:fa
RTW: rtw_ndev_notifier_call(wlan0) state:16
RTW: cfg80211_rtw_get_txpower
RTW: rtw_ndev_notifier_call(wlan0) state:5
usbcore: registered new interface driver 8188eu
RTW: module init ret=0
usb注册主要执行usb探测probe吧, 就是这个".usbdrv.probe = rtw_drv_init, "
static int rtw_drv_init(struct usb_interface *pusb_intf, const struct usb_device_id *pdid)
_adapter *padapter = NULL;
int status = _FAIL;
struct dvobj_priv *dvobj;
#ifdef CONFIG_CONCURRENT_MODE
int i;
/* RTW_INFO("+rtw_drv_init\n"); */
/* step 0. */
process_spec_devid(pdid);
/* Initialize dvobj_priv */
dvobj = usb_dvobj_init(pusb_intf, pdid);
if (dvobj == NULL) {
goto exit;
padapter = rtw_usb_primary_adapter_init(dvobj, pusb_intf);
if (padapter == NULL) {
RTW_INFO("rtw_usb_primary_adapter_init Failed!\n");
goto free_dvobj;
if (usb_reprobe_switch_usb_mode(padapter) == _TRUE)
goto free_if_prim;
if (padapter->registrypriv.virtual_iface_num > (CONFIG_IFACE_NUMBER - 1))
padapter->registrypriv.virtual_iface_num = (CONFIG_IFACE_NUMBER - 1);
for (i = 0; i < padapter->registrypriv.virtual_iface_num; i++) {
if (rtw_drv_add_vir_if(padapter, usb_set_intf_ops) == NULL) {
RTW_INFO("rtw_drv_add_iface failed! (%d)\n", i);
goto free_if_vir;
#ifdef CONFIG_GLOBAL_UI_PID
if (ui_pid[1] != 0) {
RTW_INFO("ui_pid[1]:%d\n", ui_pid[1]);
rtw_signal_process(ui_pid[1], SIGUSR2);
/* dev_alloc_name && register_netdev */
if (rtw_os_ndevs_init(dvobj) != _SUCCESS)
goto free_if_vir;
#ifdef CONFIG_HOSTAPD_MLME
hostapd_mode_init(padapter);
#ifdef CONFIG_PLATFORM_RTD2880B
RTW_INFO("wlan link up\n");
rtd2885_wlan_netlink_sendMsg("linkup", "8712");
status = _SUCCESS;
#if 0 /* not used now */
os_ndevs_deinit:
if (status != _SUCCESS)
rtw_os_ndevs_deinit(dvobj);
free_if_vir:
if (status != _SUCCESS) {
rtw_drv_stop_vir_ifaces(dvobj);
rtw_drv_free_vir_ifaces(dvobj);
free_if_prim:
if (status != _SUCCESS && padapter)
rtw_usb_primary_adapter_deinit(padapter);
free_dvobj:
usb_dvobj_deinit(pusb_intf);
exit:
return status == _SUCCESS ? 0 : -ENODEV;
既然没注意到这个:
* rtw_os_ndevs_init - Allocate and register OS layer net devices and relating structures for @dvobj
* @dvobj: the dvobj on which this function applies
* Returns:
* _SUCCESS or _FAIL
int rtw_os_ndevs_init(struct dvobj_priv *dvobj)
int ret = _FAIL;
if (rtw_os_ndevs_alloc(dvobj) != _SUCCESS)
goto exit;
if (rtw_os_ndevs_register(dvobj) != _SUCCESS)
goto os_ndevs_free;
ret = _SUCCESS;
os_ndevs_free:
rtw_os_ndevs_free(dvobj);
exit:
return ret;
解除疑惑.
最近编辑记录 whyabc666 (2021-02-28 15:38:19)
老是会有很多疑问.usb聚合发送是什么新技术?802.3数据转到802.11?监听模式加radiotap是在802.11数据包上?radiotap有没有加到fcs?(从recvbuf2recvframe看接收状态有记录数据是否丢包,怎么知道recvbuf数据出错没有,不是取出数据做CRC和接收到的CRC比较吗?这个函数在哪里?)驱动层的crc校验是哪些函数?
有个接收状态结构体 struct recv_stat *prxstat; 属于sk_buff ,( _pkt *pskb;typedef struct sk_buff _pkt;) 这个sk_buff的*data就是,
(#ifdef CONFIG_USE_USB_BUFFER_ALLOC_RX
pskb = NULL;
transfer_len = (s32)((struct recv_buf *)ptr)->transfer_len;
pbuf = ((struct recv_buf *)ptr)->pbuf;
#else
pskb = (_pkt *)ptr;
transfer_len = (s32)pskb->len;
pbuf = pskb->data;
prxstat = (struct recv_stat *)pbuf;
pkt_cnt = (le32_to_cpu(prxstat->rxdw2) >> 16) & 0xff;)
crc_err,icr_err是从何而来?从struct rx_pkt_attrib *pattrib = NULL,(pattrib = &precvframe->u.hdr.attrib)
但是和struct recv_stat *prxstat有什么关系?
从函数rtl8188e_query_rx_desc_status分析,struct recv_stat report换成了PRXREPORT prxreport,(prxreport = (PRXREPORT)&report).
什么意思呢?结构体数据成员可否相同?反正这个function把接收状态变成了包属性.
最近编辑记录 whyabc666 (2021-03-02 23:09:34)
whyabc666 说:老是会有很多疑问.usb聚合发送是什么新技术?802.3数据转到802.11?监听模式加radiotap是在802.11数据包上?radiotap有没有加到fcs?(从recvbuf2recvframe看接收状态有记录数据是否丢包,怎么知道recvbuf数据出错没有,不是取出数据做CRC和接收到的CRC比较吗?这个函数在哪里?)驱动层的crc校验是哪些函数?
pskb = NULL;
#else
pskb = (_pkt *)ptr;
pbuf = pskb->data;
pkt_cnt = (le32_to_cpu(prxstat->rxdw2) >> 16) & 0xff;)crc_err,icr_err是从何而来?从struct rx_pkt_attrib *pattrib = NULL,(pattrib = &precvframe->u.hdr.attrib)
从usb读到的precvbuf数据如何变换成sk_buff *pskb?
一颗赛挺,应垂死听!rtl8188eus驱动在监听模式下通过监听接口注入数据既然没反应?代码这里是干嘛去了哦?
int rtw_xmit_entry(_pkt *pkt, _nic_hdl pnetdev)
_adapter *padapter = (_adapter *)rtw_netdev_priv(pnetdev);
struct mlme_priv *pmlmepriv = &(padapter->mlmepriv);
int ret = 0;
if (pkt) {
if (check_fwstate(pmlmepriv, WIFI_MONITOR_STATE) == _TRUE) {
#if (LINUX_VERSION_CODE >= KERNEL_VERSION(2, 6, 24))//mark
rtw_monitor_xmit_entry((struct sk_buff *)pkt, pnetdev);
else {
rtw_mstat_update(MSTAT_TYPE_SKB, MSTAT_ALLOC_SUCCESS, pkt->truesize);
ret = _rtw_xmit_entry(pkt, pnetdev);
return ret;
监听模式的数据应该走的这条路线啊
rtw_monitor_xmit_entry->dump_mgntframe->rtw_hal_mgnt_xmit->hal_func.mgnt_xmit(pHalFunc->mgnt_xmit = &rtl8188eu_mgnt_xmit)
s32 rtl8188eu_mgnt_xmit(_adapter *padapter, struct xmit_frame *pmgntframe)
RTW_INFO("==> %s xmitframe 2\n", __FUNCTION__);
return rtw_dump_xframe(padapter, pmgntframe);
既然没有log出来?
最近编辑记录 whyabc666 (2021-03-06 00:37:28)
搞驱动是喝原厂的剩汤?一万一月都没有?
pskb = NULL;
#else
pskb = (_pkt *)ptr;
pbuf = pskb->data;
继续深挖,从USB端口读到的接收的数据为啥就带接收状态各种标志?是USB网卡固件加上去的吗?
白嫖一篇牛逼的技术分析帖。慢慢消化。
