楼主 #1 2020-10-16 13:48:46
f1c100_
已发帖子: 32
f1c100s调用cedar 实现硬编码jpeg h.264
还是这个解码库
https://github.com/EmperG/lindenis-v536-package
jpeg硬解码研究了好久没搞起来,想跑一下.264解码但是cedarx编译不起来,提示没有cdxlist.i也不知道咋搞,希望有大神能研究下跑起来
使用主线5.2,按照这个教程成功安装了cedar,dev出现了cedar和ion设备,下面的cedarx也装一下,这样就不用拷so库了
https://github.com/aodzip/cedar/
编译链要用这个:
https://pan.baidu.com/s/1-WXlwxLoQNzKGDdIJ5JDpw
buildroot里的cedarc要改一下
主要看lindenis-v536-package里面的
tina_multimedia和tina_multimedia_demo两个文件夹,
先编译tina_multimedia/cedarc,按照里面的readme说明编译,平台选arm-none-linux-gnueabi,注意编译的时候统一编译链,configure和make都带上CC=/...你的编译链路径
jpeg和.264硬编码的demo在/tina_multimedia_demo/encodertest/src,修改makefile文件如下:
Target = demo
SourceIncludePath := -I/work/tina_multimedia/libcedarx/libcore/base/include -I/work/tina_multimedia/libcedarc/include -L/work/libcedarc/lib -L/work/tina_multimedia/libcedarc/library/arm-none-linux-gnueabi
CompileFlags = $(CFLAGS) $(SourceIncludePath)
LoadFlags +=  -lvencoder -lMemAdapter -lpthread -ldl -lm
CC=/work/arm-2014.05/bin/arm-none-linux-gnueabi-gcc
LDFLAGS= -Wl,-rpath-link /work/tina_multimedia/libcedarc/library/arm-none-linux-gnueabi -Wl,-rpath-link /work/tina_multimedia/libcedarc/base/.libs
$(Target): encodertest.c
    $(CC) -o $@ $^ $(CompileFlags) $(LDFLAGS) $(LoadFlags)
路径名字对应改就行,其中/work/libcedarc/lib路径是编译tina_multimedia时的输出安装路径
然后make就生成程序了,直接拷到板子就能运行(前面buildroot已经安装了库所以不用拷)
测试程序,支持jpg和.264编码,前面的1表示编码成jpg,后面的1表示1帧
./demo 1 YUV420 800 480 800 480 1 ./123.yuv /root
debug  : cedarc <VeSetSpeed:1559>: *** set ve freq to 300 Mhz ***
debug  : cedarc <VeInitialize:1198>: ve init ok
debug  : ionAlloc <__GetIonMemOpsS:985>:*** get __GetIonMemOpsS ***
debug  : ionAlloc <ion_alloc_open:134>:begin ion_alloc_open
debug  : ionAlloc <ion_alloc_open:175>:** phy offset = 40000000
debug  : cedarc <VeRelease:1253>: ve release ok
debug  : cedarc <VideoEncInit:195>: (f:VideoEncInit, l:195)
debug  : cedarc <VideoEncInit:210>: (f:VideoEncInit, l:210)
debug  : cedarc <BitStreamCreate:102>: BitStreamCreate OK
 encode frame 0 use time is 5263us...
 the average encode time is 5263us...
 output file is saved:/root
编码结果,5ms一帧,还是挺快的。
这里提供个YUV420文件供测试:
https://whycan.com/files/members/5219/yuv.rar
到此f1c200/100 的硬编码基本论证了,就剩解码了
继续研究lindenis-v536-package这个库ING......
#2 2020-10-16 23:50:25
已发帖子: 649
Re: f1c100s调用cedar 实现硬编码jpeg h.264
解码我确定是可以的(裸机)。感谢楼主分享的编码经验
楼主 #3 2020-10-17 01:12:17
f1c100_
已发帖子: 32
微凉VeiLiang 说:
对,官方tina,裸机代码都可以,但是tina linux我们这些diy的拿不到啊:(主线linux能跑就方便多了
最近编辑记录 f1c100_ (2020-10-17 01:13:24)
#4 2020-10-19 19:15:40
dgtg
已发帖子: 271
支持一下大神!
谢谢分享!
一直想搞这个C100,但是却一直抽不出时间...看到楼主编解码的帖子...心又痒痒了
#5 2020-10-20 11:08:41
iki1120
f1c200/100 支持H264硬编码??规格书上没写啊
#6 2020-11-03 06:13:55
TivonLiu
已发帖子: 53
支持一下,留下记录,后面好找
#7 2020-11-05 17:33:52
b7376811
已发帖子: 27
好东西
#10 2021-06-20 23:56:02
unturned3
已发帖子: 272
iki1120 说:
对啊,我也想问问这个
f1c100、200s 不是只支持 jpeg 硬编码吗?什么时候支持 h.264 硬编码了(还是我文档没读懂?)
#11 2021-08-16 20:34:37
hoel
已发帖子: 96
mp4 可以达到哪个帧率?
#12 2021-08-16 20:39:52
hoel
已发帖子: 96
f1c100_ 说:
微凉VeiLiang 说:
你知道如何在裸机中进行h264解码吗?
#13 2021-11-10 09:21:15
luoguojian6
MemAdapter这个只有64位的库,编译不过去,32位的库在哪里可以找到?
#14 2022-02-17 21:52:11
X3
已发帖子: 85
make[4]: Entering directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx'
Making install in libcore
make[5]: Entering directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx/libcore'
Making install in base
make[6]: Entering directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx/libcore/base'
  CC       libcdx_base_la-AwPool.lo
In file included from ./AwPool.c:13:0:
./include/CdxList.h:153:21: fatal error: CdxList.i: No such file or directory
 #include <CdxList.i>
compilation terminated.
Makefile:551: recipe for target 'libcdx_base_la-AwPool.lo' failed
make[6]: *** [libcdx_base_la-AwPool.lo] Error 1
make[6]: Leaving directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx/libcore/base'
Makefile:353: recipe for target 'install-recursive' failed
make[5]: *** [install-recursive] Error 1
make[5]: Leaving directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx/libcore'
Makefile:398: recipe for target 'install-recursive' failed
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/libcedarx'
Makefile:724: recipe for target '/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/.built' failed
make[3]: *** [/opt/a133/tina/out/mr813-a3/compile_dir/target/libcedarx/.built] Error 2
make[3]: Leaving directory '/opt/a133/tina/package/allwinner/tina_multimedia'
package/Makefile:192: recipe for target 'package/allwinner/tina_multimedia/compile' failed
make[2]: *** [package/allwinner/tina_multimedia/compile] Error 2
make[2]: Leaving directory '/opt/a133/tina'
package/Makefile:189: recipe for target '/opt/a133/tina/out/mr813-a3/staging_dir/target/stamp/.package_compile' failed
make[1]: *** [/opt/a133/tina/out/mr813-a3/staging_dir/target/stamp/.package_compile] Error 2
make[1]: Leaving directory '/opt/a133/tina'
/opt/a133/tina/build/toplevel.mk:304: recipe for target 'world' failed
make: *** [world] Error 2
#### make failed to build some targets (22 seconds) ####
这个错误 。。。
#15 2022-02-17 22:05:10
X3
已发帖子: 85
故意删掉一个文件?
#16 2022-02-17 23:30:16
X3
已发帖子: 85
cp /opt/D1/tina_d1_open/package/allwinner/tina_multimedia/libcedarx/libcore/base/include/CdxList.i package/allwinner/tina_multimedia/libcedarx/libcore/base/include/
去D1 SDK 里面借一个用用。
#18 2023-06-12 17:05:28
rocklee
X3 说:
去D1 SDK 里面借一个用用。
这个能用吗?全志的bsp都会报这个错。。。。
#19 2023-07-19 12:01:49
hameyou
已发帖子: 241
不错,可以玩玩视频录制了
