2018-04-01上架版本:
核心板原理图: Lichee_nano.pdf
底板原理图: lpi-nano-dock.pdf
网盘资料(有可能会失效):https://pan.baidu.com/s/1smzuGS9
购买地址: 9.9元起 荔枝派Nano 跨界核心板 开发板 多系统 linux
F1C100s资料集合:
参考链接0: 买个全志arm9 F1C100s 方案的唱戏机回来拆一拆
参考链接1: F1C100s 手册
参考链接2: 看戏机(唱戏机)F1C100原理图
参考链接3: 侨德实业有限公司VS (全志C100电脑升级)流程示意图
参考链接4: 先科唱戏机(看戏机)F1C100s方案运行XBOOT大神的XBOOT系统步骤
参考链接5: F1C100s入坑记录
参考链接6: 编译、安装Windows版本sunxi-fel步骤
参考链接7: 感谢荔枝派群主泽畔友情赠送的nano f1c100s开发板、液晶屏、电容触摸屏.
正确姿势下载芒果派git hub上 f1c100s bsp代码
如果你的姿势是:
git clone https://github.com/mirkerson/c600.git
那么恭喜你, 你碰到的坑多大根本填不完。
How to install git-lfs on Ubuntu 16.04?
sudo apt-get install -y lib32z1 lib32ncurses5 lib32stdc++6
sudo apt-get install -y u-boot-tools make g++ gettext python unzip fakeroot
sudo apt-get install -y bison texinfo bc flex
sudo apt-get install -y software-properties-common
sudo curl -s https://packagecloud.io/install/repositories/github/git-lfs/script.deb.sh | sudo bash
sudo apt-get install git-lfs
git lfs install
所以直接用下面的命令即可:
git lfs install
git lfs clone https://github.com/mirkerson/c600.git离线
test -z "/opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/bin" || /bin/mkdir -p "/opt/c600/out/sunivw1p1/linux/common/sr/bin"
/bin/bash ./libtool --mode=install /usr/bin/install -c 'faked' '/opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/b
libtool: install: /usr/bin/install -c faked /opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/bin/faked
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-fakeroot-1.9.5'
make[2]: Leaving directory `/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-fakeroot-1.9.5'
make[1]: Leaving directory `/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-fakeroot-1.9.5'
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs
mkdir /opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs
cp package/makedevs/makedevs.c /opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs
cc -Wall -Werror -O2 /opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs/makedevs.c -o /opt/c600/out/sunivw1p1ildroot/build/host-makedevs/makedevs
/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs/makedevs.c: In function ‘main’:
/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs/makedevs.c:374:6: error: variable ‘ret’ set but not used [ut-set-variable]
int ret = EXIT_SUCCESS;
cc1: all warnings being treated as errors
make: *** [/opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs/makedevs] Error 1
make: Leaving directory `/opt/c600/buildroot'
ERROR: build buildroot Failed
一个编译错误。
文件 /opt/c600/out/sunivw1p1/linux/common/buildroot/build/host-makedevs/makedevs.c 最末
改为
return ret;
即可。
LD arch/arm/boot/compressed/vmlinux
OBJCOPY arch/arm/boot/zImage
Kernel: arch/arm/boot/zImage is ready
UIMAGE arch/arm/boot/uImage
"mkimage" command not found - U-Boot images will not be built
make[1]: *** [arch/arm/boot/uImage] Error 1
make: *** [uImage] Error 2
ERROR: build kernel Failed
root@localhost:/opt/c600# mkimage
-bash: mkimage: command not found
解决方法:
ubuntu12.04:
sudo apt-get install uboot-mkimage
ubuntu14.04:
sudo apt-get install u-boot-tools
In file included from drivers/soc/allwinner/pm-suniv/standby/standby_i.h:21:0,
from drivers/soc/allwinner/pm-suniv/standby/standby_clock.h:20,
from drivers/soc/allwinner/pm-suniv/standby/standby_clock.c:9:
include/linux/power/aw_pm.h:143:0: warning: "PLL_NUM" redefined
include/linux/power/aw_pm.h:92:0: note: this is the location of the previous definition
include/linux/power/aw_pm.h:153:0: warning: "BUS_NUM" redefined
include/linux/power/aw_pm.h:93:0: note: this is the location of the previous definition
rm -rf *.o drivers/soc/allwinner/pm-suniv/standby/./*.o
AS drivers/soc/allwinner/pm-suniv/standby.o
LD drivers/soc/allwinner/pm-suniv/built-in.o
LD drivers/soc/allwinner/built-in.o
LD drivers/soc/built-in.o
LD drivers/built-in.o
LINK vmlinux
LD vmlinux.o
MODPOST vmlinux.o
WARNING: modpost: Found 3 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
GEN .version
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
KSYM .tmp_kallsyms1.o
KSYM .tmp_kallsyms2.o
LD vmlinux
SORTEX vmlinux
SYSMAP System.map
OBJCOPY arch/arm/boot/Image
Kernel: arch/arm/boot/Image is ready
GZIP arch/arm/boot/compressed/piggy.gzip
AS arch/arm/boot/compressed/piggy.gzip.o
Building modules, stage 2.
MODPOST 3 modules
make: Nothing to be done for `modules'.
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CALL scripts/checksyscalls.sh
CC scripts/mod/devicetable-offsets.s
GEN scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTLD scripts/mod/modpost
CC drivers/soc/allwinner/pm-suniv/standby/main.o
from drivers/soc/allwinner/pm-suniv/standby/main.c:19:
AS drivers/soc/allwinner/pm-suniv/standby/suniv-standby.o
CC drivers/soc/allwinner/pm-suniv/standby/dram_sys.o
CC drivers/soc/allwinner/pm-suniv/standby/standby_clock.o
LINK vmlinux
LD vmlinux.o
MODPOST vmlinux.o
GEN .version
CC init/version.o
LD init/built-in.o
LD vmlinux
SORTEX vmlinux
SYSMAP System.map
Image Name: Linux-3.10.65
Created: Thu Apr 19 06:02:31 2018
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2167008 Bytes = 2116.22 kB = 2.07 MB
Load Address: 80008000
Entry Point: 80008000
Image arch/arm/boot/uImage is ready
‘arch/arm/boot/Image’ -> ‘output/bImage’
‘arch/arm/boot/uImage’ -> ‘output/uImage’
‘arch/arm/boot/zImage’ -> ‘output/zImage’
Copy modules to target ...
sunivw1p1 compile Kernel successful
INFO: build kernel OK.
INFO: build rootfs ...
make: Entering directory `/opt/c600/buildroot'
/bin/sed -i -e '/# GENERIC_SERIAL$/s~^.*#~ttyS1::respawn:/sbin/getty -n -l /bin/ash -L ttyS1 115200 vt100 #~' \
/opt/c600/out/sunivw1p1/linux/common/buildroot/target/etc/inittab
"3a:9d:33:28:d2:22"
192.168.3.122
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/include /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/lib/pkgconfig /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/aclocal
find /opt/c600/out/sunivw1p1/linux/common/buildroot/target/lib \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
find /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/lib \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/gdb
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/man /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/man
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/info /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/info
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/doc /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/doc
rm -rf /opt/c600/out/sunivw1p1/linux/common/buildroot/target/usr/share/gtk-doc
find /opt/c600/out/sunivw1p1/linux/common/buildroot/target -type f -perm +111 '!' -name 'libthread_db*.so*' | \
xargs /opt/c600/out/sunivw1p1/linux/common/buildroot/external-toolchain/bin/arm-none-linux-gnueabi-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
find /opt/c600/out/sunivw1p1/linux/common/buildroot/target/lib/modules -type f -name '*.ko' | \
xargs -r /opt/c600/out/sunivw1p1/linux/common/buildroot/external-toolchain/bin/arm-none-linux-gnueabi-strip --remove-section=.comment --remove-section=.note --strip-unneeded || true
mkdir -p /opt/c600/out/sunivw1p1/linux/common/buildroot/target/etc
# Mandatory configuration file and auxilliary cache directory
# for recent versions of ldconfig
touch /opt/c600/out/sunivw1p1/linux/common/buildroot/target/etc/ld.so.conf
mkdir -p /opt/c600/out/sunivw1p1/linux/common/buildroot/target/var/cache/ldconfig
if [ -x "/opt/c600/out/sunivw1p1/linux/common/buildroot/external-toolchain/bin/arm-none-linux-gnueabi-ldconfig" ]; \
then \
/opt/c600/out/sunivw1p1/linux/common/buildroot/external-toolchain/bin/arm-none-linux-gnueabi-ldconfig -r /opt/c600/out/sunivw1p1/linux/common/buildroot/target; \
else \
/sbin/ldconfig -r /opt/c600/out/sunivw1p1/linux/common/buildroot/target; \
fi
echo 2011.02-g6e1e8f9 > /opt/c600/out/sunivw1p1/linux/common/buildroot/target/etc/br-version
"target/suniv.sh" /opt/c600/out/sunivw1p1/linux/common/buildroot/target
mkdir: cannot create directory ‘/opt/c600/out/sunivw1p1/linux/common/buildroot/target/lib/firmware’: File exists
cp: cannot stat ‘/opt/c600/out/sunivw1p1/linux/common/buildroot/external-toolchain/arm-linux-gnueabi/libc/lib/arm-linux-gnueabi/*’: No such file or directory
>>> Generating root filesystem image rootfs.squashfs
rm -f /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
touch /opt/c600/out/sunivw1p1/linux/common/buildroot/build/.fakeroot.00000
cat /opt/c600/out/sunivw1p1/linux/common/buildroot/build/.fakeroot* > /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
echo "chown -R 0:0 /opt/c600/out/sunivw1p1/linux/common/buildroot/target" >> /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
echo "/opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/bin/makedevs -d target/generic/device_table.txt /opt/c600/out/sunivw1p1/linux/common/buildroot/target" >> /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
echo " /opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/bin/mksquashfs /opt/c600/out/sunivw1p1/linux/common/buildroot/target /opt/c600/out/sunivw1p1/linux/common/buildroot/images/rootfs.squashfs -noappend -comp xz && chmod 0644 /opt/c600/out/sunivw1p1/linux/common/buildroot/images/rootfs.squashfs" >> /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
chmod a+x /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
/opt/c600/out/sunivw1p1/linux/common/buildroot/host/usr/bin/fakeroot -- /opt/c600/out/sunivw1p1/linux/common/buildroot/build/_fakeroot.fs
rootdir=/opt/c600/out/sunivw1p1/linux/common/buildroot/target
table='target/generic/device_table.txt'
Warning: skip syncing
Parallel mksquashfs: Using 1 processor
Creating 4.0 filesystem on /opt/c600/out/sunivw1p1/linux/common/buildroot/images/rootfs.squashfs, block size 131072.
[============================================================================================================\] 113/113 100%
Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
compressed data, compressed metadata, compressed fragments, no xattrs
duplicates are removed
Filesystem size 2383.61 Kbytes (2.33 Mbytes)
37.09% of uncompressed filesystem size (6426.59 Kbytes)
Inode table size 3134 bytes (3.06 Kbytes)
16.84% of uncompressed inode table size (18613 bytes)
Directory table size 4780 bytes (4.67 Kbytes)
55.35% of uncompressed directory table size (8636 bytes)
Number of duplicate files found 2
Number of inodes 580
Number of files 83
Number of fragments 17
Number of symbolic links 269
Number of device nodes 185
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 43
Number of ids (unique uids + gids) 3
Number of uids 2
root (0)
unknown (1000)
Number of gids 3
root (0)
tty (5)
unknown (1000)
INFO: build rootfs OK.
INFO: ----------------------------------------
INFO: build lichee OK.
root@localhost:/opt/c600#编译成功,但是不知道生成的 img 在何处 .
-rw-r--r-- 1 root root 305770 Apr 19 04:55 ./linux-3.10/drivers/staging/ft1000/ft1000-pcmcia/ft1000.img
-rw-r--r-- 1 root root 280414 Apr 19 04:55 ./linux-3.10/drivers/staging/ft1000/ft1000-usb/ft3000.img
-rw-r--r-- 1 root root 7256064 Apr 19 06:02 ./linux-3.10/output/boot.img
-rw-r--r-- 1 root root 7256064 Apr 19 06:02 ./out/sunivw1p1/linux/common/boot.img
原来是还没有生成烧录的image文件, 汗!
在 @assert 大神指导下,执行 ./build.sh pack 搞定。
root@localhost:/opt/c600# ./build.sh pack
INFO: packing firmware ...
copying tools file
copying configs file
./out/aultls32.fex
./out/aultools.fex
./out/bootlogo.fex
./out/boot_package.cfg
./out/boot_package.fex
./out/boot_package_nor.cfg
./out/cardscript.fex
./out/cardtool.fex
./out/diskfs.fex
./out/env_burn.cfg
./out/env.cfg
./out/image.cfg
‘./out/image_linux.cfg’ -> ‘./out/image.cfg’
./out/recover_f.fex
./out/recover_k.fex
./out/split_xxxx.fex
./out/sunxi.fex
./out/sys_config.fex
./out/sys_partition_dragonboard.fex
./out/sys_partition_dump.fex
./out/sys_partition.fex
‘./out/sys_partition_linux.fex’ -> ‘./out/sys_partition.fex’
./out/sys_partition_nor.fex
./out/sys_partition_private.fex
./out/test_config.fex
./out/toc0.fex
./out/toc1.fex
./out/usbtool.fex
./out/usbtool_test.fex
copying boot resource
copying boot file
p=soc c=product state=0
p=soc c=platform state=0
p=soc c=target state=0
p=soc c=power_sply state=0
p=soc c=card_boot state=0
p=soc c=pm_para state=0
p=soc c=card0_boot_para state=0
p=soc c=card2_boot_para state=0
p=soc c=twi_para state=0
p=soc c=uart_para state=0
p=soc c=jtag_para state=0
p=soc c=dram state=0
p=soc c=twi0 state=0
p=soc c=twi1 state=0
p=soc c=twi2 state=0
p=soc c=uart0 state=0
p=soc c=uart1 state=0
p=soc c=spi0 state=0
p=soc c=rtp_para state=0
p=soc c=ctp_para state=0
p=soc c=tkey_para state=0
p=soc c=motor_para state=0
p=soc c=nand0 state=0
p=soc c=disp_init state=0
p=soc c=lcd0 state=0
p=soc c=pwm0_para state=0
p=soc c=pwm1_para state=0
p=soc c=vip0 state=0
p=soc c=tvout_para state=0
p=soc c=tvin_para state=0
p=soc c=di state=0
p=soc c=sdc0 state=0
p=soc c=sdc1 state=0
p=soc c=smc state=0
p=soc c=gsensor_para state=0
p=soc c=gps_para state=0
p=soc c=wifi_para state=0
p=soc c=gy_para state=0
p=soc c=ls_para state=0
p=soc c=compass_para state=0
p=soc c=bt_para state=0
p=soc c=audiospdif state=0
p=soc c=spdif_machine state=0
p=soc c=audiohdmi state=0
p=soc c=hdmi_machine state=0
p=soc c=pmu0 state=0
p=soc c=pmu0_regu state=0
p=soc c=dvfs_table state=0
p=soc c=Vdevice state=0
Conver script to dts ok.
./pack: line 439: busybox: command not found
./pack: line 440: busybox: command not found
./pack: line 436: 4466 Segmentation fault script sys_partition.fex > /dev/null
update_fdt: u-boot-spinor.fex will merage sunxi.fex, generate u-boot-spinor.fex
---0xd0, 0xd
update_fdt: num 216204 randto1k
update_fdt: num 40289 randto1k
file1_len = 35000, file2_len = c000
----------i1111-217088
dtb offset 35000,size c000
update_fdt:genrate /opt/c600/tools/pack/out/u-boot-spinor.fex ok
./pack: line 462: busybox: command not found
pack boot package
./pack: line 469: busybox: command not found
GetPrivateProfileSection read to end
content_count=1
pack boot package
./pack: line 501: busybox: command not found
content_count=1
packing for linux
normal
load file: boot0_spinor.fex ok
load file: boot_package_nor.fex ok
load file: sunxi_mbr.fex ok
load file: sys_partition.bin ok
load file: kernel.fex ok
this is not a partition key
merge_package ok
/opt/c600/tools/pack/pctools/linux/eDragonEx/
Begin Parse sys_partion.fex
Add partion boot-resource.fex BOOT-RESOURCE_FEX
Add partion very boot-resource.fex BOOT-RESOURCE_FEX
FilePath: boot-resource.fex
FileLength=483400Add partion env.fex ENV_FEX000000000
Add partion very env.fex ENV_FEX000000000
FilePath: env.fex
FileLength=20000Add partion boot.fex BOOT_FEX00000000
Add partion very boot.fex BOOT_FEX00000000
FilePath: boot.fex
FileLength=6eb800sys_config.fex Len: 0xab09
config.fex Len: 0x6900
split_xxxx.fex Len: 0x200
sys_partition.fex Len: 0xb49
sunxi.fex Len: 0x9d61
boot0_nand.fex Len: 0x8000
boot0_sdcard.fex Len: 0x8000
u-boot.fex Len: 0x64000
toc1.fex Len: 0x8
toc0.fex Len: 0x8
fes1.fex Len: 0x2740
boot_package.fex Len: 0x68000
full_img.fex Len: 0x2c0000
usbtool.fex Len: 0x23000
aultools.fex Len: 0x26ead
aultls32.fex Len: 0x238dd
cardtool.fex Len: 0x18e00
cardscript.fex Len: 0x779
sunxi_mbr.fex Len: 0x4000
dlinfo.fex Len: 0x4000
arisc.fex Len: 0x6
boot-resource.fex Len: 0x483400
Vboot-resource.fex Len: 0x4
env.fex Len: 0x20000
Venv.fex Len: 0x4
boot.fex Len: 0x6eb800
Vboot.fex Len: 0x4
BuildImg 0
Dragon execute image.cfg SUCCESS !
----------image is at----------
/opt/c600/tools/pack/sunivw1p1_linux_evb_uart0.img
pack finish离线
HELLO! BOOT0 is starting!
boot0 commit : 79d2fe0388f5367fe2f42cc3eb1db9113426c15d
boot0 version : 4.0
run key detect boot0
do_key_test
key pressed value=0x00000003
reg_val=0x00000000----------------------
dram size =32
Reg pull reg_val=0x00000000,read=0x00000010
Succeed in reading toc file head.
The size of toc is 00050000.
Entry_name = u-boot
Ready to disable icache.
Jump to secend Boot.
board/sunxi/common/board_common.c 510--nodeoffset = 623c
U-Boot 2014.07 (Mar 31 2018 - 15:55:09) Allwinner Technology
uboot commit : 79d2fe0388f5367fe2f42cc3eb1db9113426c15d
uboot:normal mode
[ 0.123]pmbus: ready
run key detect
no uart input
DRAM: 32 MiB
Relocation Offset is: 017b9000
In: serial
Out: serial
Err: serial
workmode = 0,storage type = 3
[ 0.154]spinor: 0
sunxi spinor is initing...int sunxi_dma_init---
sunxi_dma_install_int ok
OK
[ 0.156]sunxi flash init ok
[ 0.157]sunxi flash init ok
*(uint32_t *)(0x81ff0000)=-2002244950
sunxi secure storage is not supported
private partition is not exist
fail to find part named env
Using default environment
-total partitions:2-
-name- -start- -size-
boot : 4000 240000
UDISK : 244000 0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_nand
fix bootcmd=run setargs_nand boot_normal
key 0
cant find recovery value
cant find fastboot value
no misc partition is found
to be run cmd=run setargs_nand boot_normal
common/fdt_support.c 540--blob = 0x8096e120
emmc or nand path error: <no error>
common/board_r.c 305-initr_sunxi_base-END--
[ 0.194]inter uboot shell
Hit any key to stop autoboot: 3 2 1 0
read partition: boot or recovery
boota: bad boot image magic, maybe not a boot.img?
try to read partition(boot) all
[ 3.348]sunxi flash read :offset 4000, 2359296 bytes OK
boota - boota - boot android bootimg from memory
Usage:
boota <addr>
- boot application image stored in memory
'addr' should be the address of boot image which is kernel+ramdisk.img
sunxi#烧录我自己编译的 sunivw1p1_linux_evb_uart0.img 只能启动到 u-boot?
而 @assert 给我的img文件能正常启动到linux shell
而且我pack出来的img只有 @assert 给我的一半大小。
我编译的挂了:
boot0 version : 4.0
do_key_test
key pressed value=0x00000004
dram size =32
Entry_name = u-boot
board/sunxi/common/board_common.c 510--nodeoffset = 6244
uboot:normal mode
run key detect
no uart input
DRAM: 32 MiB
In: serial
Out: serial
Err: serial
[ 0.154]spinor: 0
OK
*(uint32_t *)(0x81ff0000)=-2012741624
[ 0.165]usb burn from boot
delay time 0
[ 0.231]usb prepare ok
[ 0.419]timer occur
[ 0.419]overtime
[ 0.453]do_burn_from_boot usb : no usb exist
-total partitions:8-
boot : 4000 240000
rootfs : 244000 800000
env : a44000 20000
bootlogo : a64000 10000
recoverk : a74000 180000
recoverf : bf4000 340000
private : f34000 10000
UDISK : f44000 0
base bootcmd=run setargs_mmc boot_normal
fix bootcmd=run setargs_mmc boot_normal
key 0
to be run cmd=run setargs_mmc boot_normal
[ 0.501]inter uboot shell
[ 0.652]sunxi flash read :offset 4000, 2359296 bytes OK
## Booting kernel from Legacy Image at 80007800 ...
Data Size: 2243928 Bytes = 2.1 MiB
Verifying Checksum ... OK
Loading Kernel Image ...
OK
## Transferring control to Linux (at address 80008000)...
arch/arm/lib/bootm.c 72 Starting kernel ...
--r2 0x8096e120,images->ft_len= = 0 , working_fdt = 8096e120, bi_boot_params = 0 fake = 0正常的是这样的:
boot0 version : 4.0
do_key_test
key pressed value=0x00000002
dram size =32
Entry_name = u-boot
uboot:normal mode
run key detect
no uart input
DRAM: 32 MiB
In: serial
Out: serial
Err: serial
[ 0.154]spinor: 0
OK
*(uint32_t *)(0x81ff0000)=0
[ 0.164]usb burn from boot
delay time 0
[ 0.419]timer occur
[ 0.419]overtime
boot : 4000 240000
env : a44000 20000
UDISK : f44000 0
key 0
Data Size: 2167000 Bytes = 2.1 MiB
OK
[ 0.000000] Linux version 3.10.65 (lq@assert) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #6 Thu Apr 12 16:46:36 CST 2018
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sunivw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: ECC disabled, Data cache writethrough
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] free_area_init_node: node 0, pgdat c04420a0, node_mem_map c0457000
[ 0.000000] Normal zone: 64 pages used for memmap
[ 0.000000] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x01c25000 loglevel=8 initcall_debug=1 console=ttyS1 init=/init root=/dev/mtdblock2
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Memory: 32MB = 32MB total
[ 0.000000] Memory: 27840k/27840k available, 4928k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0xc0008000 - 0xc03f4fdc (4020 kB)
[ 0.000000] .init : 0xc03f5000 - 0xc0413b04 ( 123 kB)
[ 0.000000] .data : 0xc0414000 - 0xc0442780 ( 186 kB)
[ 0.000000] .bss : 0xc0442780 - 0xc0456228 ( 79 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=528000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.005331] Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
[ 0.075240] pid_max: default: 32768 minimum: 301
[ 0.080446] Mount-cache hash table entries: 512
[ 0.086443] CPU: Testing write buffer coherency: ok
[ 0.092225] Setting up static identity map for 0xc02d6f40 - 0xc02d6f98
[ 0.101717] devtmpfs: initialized
[ 0.107119] pinctrl core: initialized pinctrl subsystem
[ 0.112881] NET: Registered protocol family 16
[ 0.118581] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.126461] dump_class_init,821, success
[ 0.135618] sunivw1p1-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.152930] No ATAGs?
[ 0.162755] bio: create slab <bio-0> at 0
[ 0.169190] SCSI subsystem initialized
[ 0.173493] usbcore: registered new interface driver usbfs
[ 0.179294] usbcore: registered new interface driver hub
[ 0.185216] usbcore: registered new device driver usb
[ 0.191530] Advanced Linux Sound Architecture Driver Initialized.
[ 0.200152] cfg80211: Calling CRDA to update world regulatory domain
[ 0.207196] [pm]aw_pm_init!
[ 0.210476] [pm]aw_pm_valid!
[ 0.213589] Notice: sunivw1p1 just support normal standby.
[ 0.219255] [pm]aw_pm_valid!
[ 0.222268] Notice: sunivw1p1 just support normal standby.
[ 0.228311] Switching to clocksource suniv high-res couter
[ 0.268087] codec_config
[ 0.270878] (null).sta33x_pwrdn_gpio gpio=135,mul_sel=0,data:1
[ 0.277018] codec_config: sta33x_pwrdn_gpio gpio num=135
[ 0.282506] codec_request_gpio: test1
[ 0.286378] codec_request_gpio: request gpio=135
[ 0.291288] codec_request_gpio: L1167 Pin=1
[ 0.295718] codec_request_gpio: request gpio(135) ok
[ 0.314620] NET: Registered protocol family 2
[ 0.321750] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.328999] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.335628] TCP: Hash tables configured (established 512 bind 512)
[ 0.342145] TCP: reno registered
[ 0.345613] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.351654] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.358753] NET: Registered protocol family 1
[ 0.378502] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.385266] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.393104] msgmni has been set to 54
[ 0.400276] io scheduler noop registered
[ 0.404499] io scheduler deadline registered
[ 0.409039] io scheduler cfq registered (default)
[ 0.437504] sw_uart_request_gpio(753)
[ 0.441362] uart0: ttyS0 at MMIO 0x1c25000 (irq = 103) is a SUNXI
[ 0.449113] sw_uart_request_gpio(753)
[ 0.452967] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[ 0.459390] sw_console_setup()1175 - console setup baud 115200 parity n bits 8, flow n
[ 0.467684] console [ttyS1] enabled, bootconsole disabled
[ 0.480364] misc dump reg init
[ 0.487608] spi spi0: master is unqueued, this is deprecated
[ 0.495441] NorFlash ID: 0xc22019 - 0xc220
[ 0.500023] m25p80 spi0.0: found mx25l25635e, expected m25p64
[ 0.506639] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[ 0.526714] Creating 8 MTD partitions on "(null)":
[ 0.532057] 0x000000000000-0x000000080000 : "uboot"
[ 0.540152] 0x000000080000-0x0000002c0000 : "boot"
[ 0.548020] 0x0000002c0000-0x000000ac0000 : "rootfs"
[ 0.556173] 0x000000ac0000-0x000000ae0000 : "env"
[ 0.563897] 0x000000ae0000-0x000000af0000 : "bootlogo"
[ 0.572362] 0x000000af0000-0x000000c70000 : "recoverk"
[ 0.580788] 0x000000c70000-0x000000fb0000 : "recoverf"
[ 0.589019] 0x000000fb0000-0x000000fc0000 : "private"
[ 0.597611] usbcore: registered new interface driver usb-storage
[ 0.604938] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.612866] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.625197] hub 1-0:1.0: USB hub found
[ 0.629428] hub 1-0:1.0: 1 port detected
[ 0.635641] support report repeat key value.
[ 0.641166] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.649080] i2c /dev entries driver
[ 0.653092] IR NEC protocol handler initialized
[ 0.658695] pdev->dev.of_node name :cir
[ 0.663260] Registered IR keymap rc_map_sunxi
[ 0.670273] input: sunxi_ir_recv as /devices/soc.0/1c22c00.cir/rc/rc0/input1
[ 0.678781] rc0: sunxi_ir_recv as /devices/soc.0/1c22c00.cir/rc/rc0
[ 0.687891] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.30 2015-10-10 10:03) Compiled in Apr 12 2018 at 16:03:01
[ 0.701212] sunxi-mmc 1c0f000.sdmmc: Can't get vmmc regulator string
[ 0.708261] IR RX IRQ Serve
[ 0.711352] sunxi_ir_recv_irq !!
[ 0.714919] receive cnt :5
[ 0.718007] get frist pulse,add head 128 !!
[ 0.722632] pusle :1, dur: 16277079 ns
[ 0.726777] handle raw data.
[ 0.730096] sunxi-mmc 1c0f000.sdmmc: Can't get vqmmc regulator string
[ 0.737328] sunxi-mmc 1c0f000.sdmmc: Can't get vdmmc regulator string
[ 0.744534] sunxi-mmc 1c0f000.sdmmc: Failed getting OCR mask: 0
[ 0.751903] sunxi-mmc 1c0f000.sdmmc: *******************set host ocr**************************
[ 0.762007] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.784194] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.814375] sunxi-mmc 1c0f000.sdmmc: base:0xf1c0f000 irq:107
[ 0.820703] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.828442] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.835385] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.850983]
[ 0.850983] sunxi_daudio->tx_data_mode =0
[ 0.859948] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.871861] failed to get headphone-dect gpio from dts,headphone-dect:-2
[ 0.879978] no jack gpio or irq
[ 0.889031] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
[ 0.898168] sunxi-codec-machine sound.3: sun8iw10codec <-> 1c23c00.cpudai0-controller mapping ok
[ 0.908170] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.915881] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.923510] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.931204] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.938221] sunxi-codec-machine-i2s sound.5: ASoC: CODEC sta339.2-001c not registered
[ 0.947012] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.953807]
[ 0.953807] snd_soc_register_card failed -517
[ 0.960434] platform sound.5: Driver sunxi-codec-machine-i2s requests probe deferral
[ 0.969109] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.976818] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.984338] TCP: cubic registered
[ 0.988082] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.994941] Initializing XFRM netlink socket
[ 0.999740] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.011463] NET: Registered protocol family 17
[ 1.016760] VFP support v0.3: not present
[ 1.023844] sunxi-codec-machine-i2s sound.5: ASoC: CODEC sta339.2-001c not registered
[ 1.032663]
[ 1.032663] snd_soc_register_card failed -517
[ 1.039463] platform sound.5: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.048169] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 1, RTO !!
[ 1.054991] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.067523] input: gpio_keys.6 as /devices/soc.0/gpio_keys.6/input/input2
[ 1.076355] sunxi-codec-machine-i2s sound.5: ASoC: CODEC sta339.2-001c not registered
[ 1.085180]
[ 1.085180] snd_soc_register_card failed -517
[ 1.092077] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.100361] ALSA device list:
[ 1.103693] #0: audiocodec
[ 1.107198] platform sound.5: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.116590] async_waiting @ 1
[ 1.119938] async_continuing @ 1 after 3 usec
[ 1.138180] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 1.155716] devtmpfs: mounted
[ 1.159135] async_waiting @ 1
[ 1.162453] async_continuing @ 1 after 3 usec
[ 1.167878] Freeing unused kernel memory: 120K (c03f5000 - c0413000)
/etc/init.d/rcS: line 12: /usr/sbin/net.sh: not found
/ # 离线
解决方法:
1.
/bin/bash: 行 2: /lichee/out/sun8iw8p1/linux/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-gcc: 没有那个文件或目录在网上查了一下,大概说是我的系统是64位的,而这个程序是32位的,存在兼容问题,需要安装lsb-core,即命令sudo apt-get install lsb-core。
2.但是在这之后又有了新的问题:
./arm-linux-gnueabi-gcc: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory这个问题安装一下下面软件就好了。
apt-get install lib32z1 lib32ncurses5
apt-get install lib32stdc++6
有几个问题需要处理。
固件大小只有一半,不能正常启动kernel的原因可能是分区配置和产品配置的问题。
建议晕哥尝试:
1,在linux-3.10上层目录执行./build.sh config进行产品配置
2,在tools目录查找sys_partition.fex,使用nor的话,应该是sys_partition_nor.fex。
看看分区是否合理。
建议晕哥尝试:
看看分区是否合理。
那个问题后来解决了。
现在是用全志官方软件根本烧不进去,
换几台电脑都不行,
一开始能烧进去的 img 现在换了5台都不行。
现在改用开源的 sunxi-fel, 一点问题都没有。
自己处理烧写地址问题.
建议晕哥尝试:
看看分区是否合理。
请假一下你编译出来了且能正常运行么?用的nor flash 么? 多大的呢? 还有就是需要调整分区参数么?这个linux跑起来之后就只有个 shell 么 有没有简单的应用程序在跑呢?
晚些出教程,
用主线u-boot, bsp linux, jffs2 文件系统,
sunxi-fel 直接烧写 spi flash.
晕哥,有更新了没?
等教程...
晚些出教程,
晕哥我继续关注这教程 好久出一个撒? 那里面的硬解码有攻破么?
晚些出教程,
请教一下晕哥,我编译出来的sunivw1p1_linux_evb_uart0.img有30M,要在16M的spi flash里跑是不是还得在哪个地方配置一下重新编译?
晕哥 说:晚些出教程,
sunxi-fel 直接烧写 spi flash.请教一下晕哥,我编译出来的sunivw1p1_linux_evb_uart0.img有30M,要在16M的spi flash里跑是不是还得在哪个地方配置一下重新编译?
官方的 img就酱紫的,V3s的img也会大于30M, 烧进去是没有问题的,原理不知。
iki1120 说:固件大小只有一半,不能正常启动kernel的原因可能是分区配置和产品配置的问题。
建议晕哥尝试:
看看分区是否合理。那个问题后来解决了。
现在是用全志官方软件根本烧不进去,
换几台电脑都不行,
一开始能烧进去的 img 现在换了5台都不行。https://whycan.cn/files/members/3/165923gsascz2dhd2tadmv.png
自己处理烧写地址问题.
晕哥,请教一下,C600编译出来的是img镜像,如何使用sunxi-fel进行烧录呢?
本帖九楼那个软件烧录。
我使用PhoenixSuit这个软件烧录的时候,一直卡住,界面显示开始烧写固件,进度条却一点没有,最后就超时了,这个是什么原因呀?
https://whycan.cn/files/members/3/QQ20180419204822.png
烧是烧完了, 两组UART0串口都没反应.
我用 PhoenixSuit 燒 sunivw1p1_linux_evb_uart0.img 進去後,
情況也是一樣, UART0 串口都沒反應, 後來怎樣解決 ?
建议还是按 @assert 给出那个方法,用主线u-boot, 全志官方的linux 3.4.
https://whycan.cn/t_1008.html
源码包下载地址: http://oslife.top/f1c600.tar.bz2
本站临时下载地址: f1c600.tar.bz2
那即是這個裡面的 linux-3.10 ? 還是那裡可以找到呢 ? dts 檔都是用跟 kernel 的 ?
然後改名成 suniv-f1c100s-licheepi-nano.dtb , 給 uboot 引導時用 ?
我记错了,V3s才是linux3.4
f1c100s 可能是 linux3.10。
dtb文件是全志用一个命令(具体哪个命令不记得了)把 .fex 文本文件生成的。
用 fex 文件成生, 跟我用 dts 文件, 在 make kernel 時做這個有沒有分別 ?
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- dtbs -j4
编译出现很多错误,不知为什么
/usr/bin/gcc -I. -O2 -I/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/host/include -I/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/host/usr/include -MT freading.o -MD -MP -MF .deps/freading.Tpo -c -o freading.o freading.c
/usr/bin/gcc -I. -O2 -I/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/host/include -I/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/host/usr/include -MT gl_linkedhash_list.o -MD -MP -MF .deps/gl_linkedhash_list.Tpo -c -o gl_linkedhash_list.o gl_linkedhash_list.c
In file included from clean-temp.h:22:0,
from clean-temp.c:23:
./stdio.h:456:1: error: 'gets' undeclared here (not in a function)
_GL_WARN_ON_USE (gets, "gets is a security hole - use fgets instead");
In file included from freadahead.h:18:0,
from freadahead.c:20:
In file included from freading.h:18:0,
from freading.c:20:
Makefile:1279: recipe for target 'freading.o' failed
make[4]: *** [freading.o] Error 1
make[4]: *** Waiting for unfinished jobs....
Makefile:1279: recipe for target 'freadahead.o' failed
make[4]: *** [freadahead.o] Error 1
mv -f .deps/fd-safer-flag.Tpo .deps/fd-safer-flag.Po
mv -f .deps/dup-safer-flag.Tpo .deps/dup-safer-flag.Po
Makefile:1279: recipe for target 'clean-temp.o' failed
make[4]: *** [clean-temp.o] Error 1
mv -f .deps/gl_linkedhash_list.Tpo .deps/gl_linkedhash_list.Po
make[4]: Leaving directory '/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15/lib'
Makefile:1083: recipe for target 'all' failed
make[3]: *** [all] Error 2
make[3]: Leaving directory '/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15/lib'
Makefile:1023: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15'
Makefile:976: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15'
package/Makefile.package.in:289: recipe for target '/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15/.stamp_built' failed
make: *** [/root/linux_bsp/f1c600/out/sunivw1p1/linux/common/buildroot/build/host-m4-1.4.15/.stamp_built] Error 2
make: Leaving directory '/root/linux_bsp/f1c600/buildroot'
root@e46b861a6d2d:~/linux_bsp/f1c600#
是这个流程啊
我的ubuntu 是16.04
gcc 5.4.0
不知有没有关系
用 https://whycan.cn/t_1008.html
里面的源码包编译通过了
编译出现很多错误,不知为什么
from freading.c:20:
修改 lichee/out/sun8iw8p1/linux/common/buildroot/build/host-m4-1.4.15/lib/stdio.h
456 行改成这样:
#if HAVE_RAW_DECL_GETS
参考: https://blog.csdn.net/luckywang1103/article/details/43968079
二进制bin 打包
以16M 大小flash镜像打包脚本为例:
dd if=/dev/zero of=flashimg.bin bs=1M count=16 &&\
dd if=$YOUR_UBOOT_FILE of=flashimg.bin bs=1K conv=notrunc &&\
dd if=$YOUR_DTB_FILE of=flashimg.bin bs=1K seek=1024 conv=notrunc &&\
dd if=$YOUR_KERNEL_FILE of=flashimg.bin bs=1K seek=1088 conv=notrunc &&\
mkdir rootfs
tar -xzvf $YOUR_ROOTFS_FILE -C ./rootfs &&\
cp -r $YOUR_MOD_FILE rootfs/lib/modules/ &&\
# 为根文件系统制作jffs2镜像包
# --pad参数指定 jffs2大小
# 由此计算得到 0x1000000(16M)-0x10000(64K)-0x100000(1M)-0x400000(4M)=0xAF0000
mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o jffs2.img &&\
dd if=jffs2.img of=$YOUR_IMG_FILE bs=1K seek=5184 conv=notrunc &&\
以上脚本通过对一个生成的16M空bin文件填充 uboot、dtb、kernel、rootfs 生成 16M 镜像,如需修改,请注意各个文件的大小,修改成对应地址(注意对齐)。
怎么烧进FLASH 启动不了?
二进制bin 打包
以16M 大小flash镜像打包脚本为例:dd if=/dev/zero of=flashimg.bin bs=1M count=16 &&\
mkdir rootfs
# 为根文件系统制作jffs2镜像包
# --pad参数指定 jffs2大小
以上脚本通过对一个生成的16M空bin文件填充 uboot、dtb、kernel、rootfs 生成 16M 镜像,如需修改,请注意各个文件的大小,修改成对应地址(注意对齐)。怎么烧进FLASH 启动不了?
把你的串口终端 log 贴出来吧,
没有log没办法判断问题的.
串口终端就是没有输出
就是按照二进制bin 打包
mkdir rootfs
# 为根文件系统制作jffs2镜像包
# --pad参数指定 jffs2大小
dd if=jffs2.img of=$YOUR_IMG_FILE bs=1K seek=5184 conv=notrunc &&\生产启动文件,串口就没有输出
编译生成 dtb文件
生成的 dtb文件 在 dts同级目录下 没有找到生成 dtb的文件
dtb 文件在 arch/arm/boot/ 目录下面
也可以用这个命令找:
find . | grep XXX.dtb
find 是查找命令, 点号是当前目录, | 是管道输出, grep 是从查找字符串
比如 f1c100s bsp linux 的dtb 位置:
/opt/c600/linux-3.10/arch/arm/boot/dts/sunivw1p1-evb.dtb
RAM: 32 MiB
Trying to boot from MMC1
mmc_init: -95, time 22
Trying to boot from sunxi SPI
U-Boot 2018.01-05676-g0018878-dirty (Aug 02 2018 - 20:35:23 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
Hit any key to stop autoboot: 2 1 0
spi_flash@0:50000000: failed to activate chip-select 50000000
SF: error -2 reading JEDEC ID
Failed to initialize SPI flash at 0:50000000 (error -2)
No SPI flash selected. Please run `sf probe'
这是u-boot 启动信息,烧u-boot就可以看到串口有输出,SPIflash打包烧录串口一点信息就没有输出
在uboot源码目录下 进入 ./include/configs/
修改 suniv.h¶
#define CONFIG_BOOTCOMMAND "sf probe 0:50000000; " \
"sf read 0x80C00000 0x100000 0x4000; " \
"sf read 0x80008000 0x110000 0x400000; " \
"bootz 0x80008000 - 0x80C00000"
修改内核源码目录下的 ./arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins_a>;
flash: w25q128@0 {
#address-cells = <1>;
#size-cells = <1>;
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x000000 0x100000>;
read-only;
partition@100000 {
label = "dtb";
reg = <0x100000 0x10000>;
read-only;
partition@110000 {
label = "kernel";
reg = <0x110000 0x400000>;
read-only;
partition@510000 {
label = "rootfs";
reg = <0x510000 0xAF0000>;
};添加这个就这样了
w25q128
w25q128
你把spi 的时钟频率调低试一试.
我把 0:50000000 改成 "sf probe 0; " uboot可以正常启动了,请问F1C100S全套开发指南吗?再请问我们开发应用程序放在哪里编译,可不可以给一些实例模仿一下。
Nano的设备树在源码的 linux ‣ arch ‣ arm ‣ boot ‣ dts ‣ suniv-f1c100s-licheepi-nano.dts
编译生成 dtb文件
但是我们找不到这个 dtb文件。
dd if=/dev/zero of=flashimg.bin bs=16M count=1
dd if=../ubootmainline/u-boot/u-boot-sunxi-with-spl.bin of=flashimg.bin bs=1K conv=notrunc
dd if=../zero41y/linux-zero-4.10.y/arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dtb of=flashimg.bin bs=1K seek=1024 conv=notrunc
dd if=../zero41y/linux-zero-4.10.y/arch/arm/boot/zImage of=flashimg.bin bs=1K seek=1088 conv=notrunc
dd if=../zero_imager/jffs2/jffs2.img of=flashimg.bin bs=1K seek=5184 conv=notrunc
按上面打包,为什么我打包出来的bin文件有105M多呢?
帮我看看Nano的设备树在源码的 linux ‣ arch ‣ arm ‣ boot ‣ dts目录下为啥没有DTB文件?
dd if=../zero_imager/jffs2/jffs2.img of=flashimg.bin bs=1K seek=5184 conv=notrunc按上面打包,为什么我打包出来的bin文件有105M多呢?
我刚刚试了一下,一切正常, 输入 16MB 的 flashimg.bin, 是不是你的 jffs2.img 文件有问题.
我的在这个目录下找不到,是不是我下载的LINUX有问题?
仔细看下49楼出错信息,
应该是你的flash型号没有支持,
如果是这样,
开启配置文件就可以了,
你的是什么flash?
nano支持nand flash吗?有哪些型号呢?在哪个文件可以查看呀
http://nano.lichee.pro/build_sys/kernel.html
按这个一步一步走就可以了,我刚刚就是在干净的环境编译的
我就是 按这个步骤来的
是的,没有
sun8i-r40-bananapi-m2-ultra.dts
sun8i-r40.dtsi
sun8i-reference-design-tablet.dtsi
sun8i-v3s.dtsi
sun8i-v3s-licheepi-zero-dock.dts
sun8i-v3s-licheepi-zero.dts
sun8i-v40-bananapi-m2-berry.dts
sun9i-a80-cubieboard4.dts
sun9i-a80.dtsi
sun9i-a80-optimus.dts
suniv.dtsi
suniv-f1c100s.dtsi
sunxi-common-regulators.dtsi
sunxi-h3-h5.dtsi
sunxi-itead-core-common.dtsi
sunxi-reference-design-tablet.dtsi
tango4-common.dtsi
tango4-smp8758.dtsi
tango4-vantage-1172.dts
tegra114-dalmore.dts
tegra114.dtsi
tegra114-roth.dts
tegra114-tn7.dts
解决方法:
1.
2.但是在这之后又有了新的问题:
apt-get install lib32stdc++6有几个问题需要处理。
我编译也遇到了这种情况:
[ 0.653]sunxi flash read :offset 4000, 2359296 bytes OK
Data Size: 2313480 Bytes = 2.2 MiB
OK
然后就一直不动了,
晕哥怎么解决的啊!
你是从git clone --depth=1 -b f1c100s-480272lcd-test https://github.com/Icenowy/linux.git
下载的吗
可不可以一个一个来烧录,怎么烧录?
看起来设备树文件(dtb)出问题?
晕哥你11楼遇到的问题和我这个问题一样啊,你下面说已经解决了,把解决方法说明一下啊。。。
mkdir rootfs
# 为根文件系统制作jffs2镜像包
# --pad参数指定 jffs2大小
@晕哥 cp -r $YOUR_MOD_FILE rootfs/lib/modules/ YOUR_MOD_FILE这个是什么文件? 做启动文件系统需要用这个吗?
需要修改 配置才能从 UART0 输出 log。
* 确保可以使用uboot中的bootargs
* 采用UART0作为调试口
可以从 UART0 输出 log 的.config。
修改 sunivw1p1-pinctrl.dtsi,uart0 的管脚配置采用 PE0,PE1:
uart0_pins_a: uart0@0 {
allwinner,pins = "PE1", "PE0";
allwinner,pname = "uart0_tx", "uart0_rx";
allwinner,function = "uart0";
allwinner,muxsel = <5>;
allwinner,drive = <1>;
allwinner,pull = <1>;
};需要调整其他用到 PE0,PE1 的配置。
请问是使用哪个命令编译内核的?是否使用build.sh+参数编译,麻烦告知下可以吗?谢谢
以下是2018-08-13 更新:
全志官方烧录软件: PhoenixSuit_CN_debug.msi
我编译的img: sunivw1p1_linux_evb_uart0.img.tar.gz串口线接 A0, A1
麻烦请告知下调试串口是接的哪2个?我烧录了这个固件,串口没有打印。
所以直接用下面的命令即可:
sudo apt-get install -y lib32z1 lib32ncurses5 lib32stdc++6 sudo apt-get install -y u-boot-tools make g++ gettext python unzip fakeroot sudo apt-get install -y bison texinfo bc flex sudo apt-get install -y software-properties-common sudo curl -s https://packagecloud.io/install/repositories/github/git-lfs/script.deb.sh | sudo bash sudo apt-get install git-lfs git lfs install git lfs clone https://github.com/mirkerson/c600.git
请问下晕哥,用这个官方的bsp kernel编译出来的固件,启动后屏幕有显示吗?/dev/目录下有没显示设备?我的貌似没有找到有fb或者disp设备之类的,可能是叫其他名字?
谢谢!
@qinxiongxu framebuffer 是有的.
你烧我3楼的固件试一试。
这个固件是800x480的吗,起来显示竖向的RGB颜色条,但是有花屏的方块在不断变化,闪烁。。。
一跑那个fb-test那个程序,内核会奔溃,包内存越界的错误。
我的是lichee nano配套的5寸800x480分辨率的,是我的屏跟你们不同?
我这边是怎么着都显示“尚未检测到设备接入电脑”。请问正确的操作应该是怎样的?
我就是把SPI Flash的CS叫接地,然后接上USB,Windows的设备管理器里面会有设备,PhoenixSuit虽然会跳出来界面,但是一直都是“尚未检测到设备接入电脑)
串口没有任何输出啊。
我这个操作流程正确吗?
会跟操作系统有关吗?我是win10.
接上串口线,可以看到log,会显示原因的
我记得当时也是在 5寸800x480 LCD 测试的.
晕哥3楼固件我测试了,用的海豚派配的液晶 看淘宝说明是480x272的,这个液晶显示正常。我自己配置的800*480的内核崩溃了。开完机后显示的是红绿蓝。cat urandom > fb0 这个正常。
开发指南不存在的,全志对资料很保守,经常有全志的员工要求删帖,站长鸭梨也很大。
这个是真的假的? 难道资料越开放,别人越会用到她家的芯片。不知道我这逻辑对不对。
800x480 没有问题: https://whycan.cn/t_1522.html
把奔溃 log 贴上来看下
谢谢链接。这是我有问题的,麻烦看看。
[BEGIN] 2019/6/17 16:20:54
boot0 version : 4.0
do_key_test
dram size =32
Entry_name = u-boot
board/sunxi/common/board_common.c 510--nodeoffset = 65a4
uboot:normal mode
run key detect
key pressed value=0x1
key pressed value=0x2
no uart input
DRAM: 32 MiB
In: serial
Out: serial
Err: serial
[ 0.155]spinor: 0
OK
[ 0.158]sunxi flash init ok
*(uint32_t *)(0x81ff0000)=176160992
[ 0.166]usb burn from boot
delay time 0
[ 0.233]usb prepare ok
usb sof ok
[ 0.280]usb probe ok
[ 0.280]usb setup ok
[ 0.284]exit usb burn from boot
next work 1
SUNXI_UPDATE_NEXT_ACTION_NULL
boot : 4000 240000
env : a44000 20000
UDISK : f44000 0
key 0
common/fdt_support.c 540--blob = 0x8096dfa0
[ 0.366]inter uboot shell
[ 0.517]sunxi flash read :offset 4000, 2359296 bytes OK
Data Size: 2311064 Bytes = 2.2 MiB
OK
--r2 0x8096dfa0,images->ft_len= = 0 , working_fdt = 8096dfa0, bi_boot_params = 0 fake = 0
[ 0.000000] Linux version 3.10.65 (du@du) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #86 Fri Jun 14 15:41:50 CST 2019
[ 0.000000] free_area_init_node: node 0, pgdat c0492e60, node_mem_map c04af000
[ 0.000000] Memory: 27480k/27480k available, 5288k reserved, 0K highmem
[ 0.000000] .text : 0xc0008000 - 0xc043bfdc (4304 kB)
[ 0.000000] .init : 0xc043c000 - 0xc045e454 ( 138 kB)
[ 0.000000] .data : 0xc0460000 - 0xc0493540 ( 206 kB)
[ 0.000000] .bss : 0xc0493540 - 0xc04ae608 ( 109 kB)
[ 0.005322] Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
[ 0.075239] pid_max: default: 32768 minimum: 301
[ 0.080439] Mount-cache hash table entries: 512
[ 0.092226] Setting up static identity map for 0xc030fdf8 - 0xc030fe50
[ 0.101720] devtmpfs: initialized
[ 0.107115] pinctrl core: initialized pinctrl subsystem
[ 0.112872] NET: Registered protocol family 16
[ 0.118586] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.126438] dump_class_init,821, success
[ 0.135589] sunivw1p1-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.153317] No ATAGs?
[ 0.163272] bio: create slab <bio-0> at 0
[ 0.169748] SCSI subsystem initialized
[ 0.174045] usbcore: registered new interface driver usbfs
[ 0.179839] usbcore: registered new interface driver hub
[ 0.185763] usbcore: registered new device driver usb
[ 0.192064] Advanced Linux Sound Architecture Driver Initialized.
[ 0.200711] cfg80211: Calling CRDA to update world regulatory domain
[ 0.207731] [pm]aw_pm_init!
[ 0.211008] [pm]aw_pm_valid!
[ 0.214117] Notice: sunivw1p1 just support normal standby.
[ 0.219782] [pm]aw_pm_valid!
[ 0.222831] Notice: sunivw1p1 just support normal standby.
[ 0.228854] Switching to clocksource suniv high-res couter
[ 0.267651] codec_config
[ 0.270442] (null).sta33x_pwrdn_gpio gpio=135,mul_sel=0,data:1
[ 0.276583] codec_config: sta33x_pwrdn_gpio gpio num=135
[ 0.282073] codec_request_gpio: test1
[ 0.285940] codec_request_gpio: request gpio=135
[ 0.290846] codec_request_gpio: L1167 Pin=1
[ 0.295278] codec_request_gpio: request gpio(135) ok
[ 0.315158] NET: Registered protocol family 2
[ 0.322027] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.329274] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.335902] TCP: Hash tables configured (established 512 bind 512)
[ 0.342429] TCP: reno registered
[ 0.345899] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.351942] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.359042] NET: Registered protocol family 1
[ 0.378791] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.385539] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.393390] msgmni has been set to 53
[ 0.399227] io scheduler noop registered
[ 0.403325] io scheduler deadline registered
[ 0.407957] io scheduler cfq registered (default)
[ 0.437467] sw_uart_request_gpio(753)
[ 0.441323] uart0: ttyS0 at MMIO 0x1c25000 (irq = 103) is a SUNXI
[ 0.448982] sw_uart_request_gpio(753)
[ 0.452836] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[ 0.459264] sw_console_setup()1175 - console setup baud 115200 parity n bits 8, flow n
[ 0.467565] console [ttyS1] enabled, bootconsole disabled
[ 0.480485] misc dump reg init
[ 0.487773] spi spi0: master is unqueued, this is deprecated
[ 0.495866] NorFlash ID: 0xef4018 - 0x0
[ 0.500191] m25p80 spi0.0: found w25q128, expected m25p64
[ 0.506304] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.526015] Creating 8 MTD partitions on "(null)":
[ 0.531359] 0x000000000000-0x000000080000 : "uboot"
[ 0.539411] 0x000000080000-0x0000002c0000 : "boot"
[ 0.547295] 0x0000002c0000-0x000000ac0000 : "rootfs"
[ 0.555402] 0x000000ac0000-0x000000ae0000 : "env"
[ 0.563118] 0x000000ae0000-0x000000af0000 : "bootlogo"
[ 0.571582] 0x000000af0000-0x000000c70000 : "recoverk"
[ 0.579952] 0x000000c70000-0x000000fb0000 : "recoverf"
[ 0.588122] 0x000000fb0000-0x000000fc0000 : "private"
[ 0.596516] PPP generic driver version 2.4.2
[ 0.601887] PPP BSD Compression module registered
[ 0.607225] PPP Deflate Compression module registered
[ 0.612840] PPP MPPE Compression module registered
[ 0.618208] NET: Registered protocol family 24
[ 0.623426] usbcore: registered new interface driver usb-storage
[ 0.630707] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.638751] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.650909] hub 1-0:1.0: USB hub found
[ 0.655289] hub 1-0:1.0: 1 port detected
[ 0.661379] support report repeat key value.
[ 0.667016] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.675016] i2c /dev entries driver
[ 0.679012] IR NEC protocol handler initialized
[ 0.684502] pdev->dev.of_node name :cir
[ 0.689156] Registered IR keymap rc_map_sunxi
[ 0.696173] input: sunxi_ir_recv as /devices/soc.0/1c22c00.cir/rc/rc0/input1
[ 0.704714] rc0: sunxi_ir_recv as /devices/soc.0/1c22c00.cir/rc/rc0
[ 0.712265] sunxi cedar version 0.1
[ 0.716552] [cedar]: install start!!!
[ 0.720776] cedar-ve the get irq is 102
[ 0.725264] cedar-ve the sram base addr is f1c00000, value is 7fffffff
[ 0.732500] IR RX IRQ Serve
[ 0.735589] sunxi_ir_recv_irq !!
[ 0.739156] receive cnt :5
[ 0.742245] get frist pulse,add head 128 !!
[ 0.746872] pusle :1, dur: 16277079 ns
[ 0.751017] handle raw data.
[ 0.754325] cedar-ve the sram for ve addr is f1c00004, value is 70000001
[ 0.762676] cedar-ve clk_bass_vir 0x18 is f1c20018, the value:93000800
[ 0.770133] cedar-ve clk_bass_vir 0x13c is f1c2013c, the value:80000000
[ 0.777622] cedar-ve clk_bass_vir 0x64 is f1c20064, the value:1
[ 0.784279] cedar-ve clk_bass_vir 0x2c4 is f1c202c4, the value:0
[ 0.791071] cedar-ve clk_bass_vir 0x100 is f1c20100, the value:1
[ 0.797856] [cedar]: install end!!!
[ 0.803429] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.30 2015-10-10 10:03) Compiled in Jun 11 2019 at 10:27:08
[ 0.816752] sunxi-mmc 1c0f000.sdmmc: Can't get vmmc regulator string
[ 0.823830] sunxi-mmc 1c0f000.sdmmc: Can't get vqmmc regulator string
[ 0.831053] sunxi-mmc 1c0f000.sdmmc: Can't get vdmmc regulator string
[ 0.838257] sunxi-mmc 1c0f000.sdmmc: Failed getting OCR mask: 0
[ 0.845541] sunxi-mmc 1c0f000.sdmmc: *******************set host ocr**************************
[ 0.855930] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.884730] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.914888] sunxi-mmc 1c0f000.sdmmc: base:0xf1c0f000 irq:107
[ 0.921231] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.928974] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.935937] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.951241]
[ 0.951241] sunxi_daudio->tx_data_mode =0
[ 0.960183] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.972139] failed to get headphone-dect gpio from dts,headphone-dect:-2
[ 0.980264] no jack gpio or irq
[ 0.989291] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
[ 0.998428] sunxi-codec-machine sound.4: sun8iw10codec <-> 1c23c00.cpudai0-controller mapping ok
[ 1.008442] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 1.016162] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 1.023743] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 1.031434] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 1.038664] sunxi-codec-machine-i2s sound.6: ASoC: CODEC sta339.2-001c not registered
[ 1.047485] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.054288]
[ 1.054288] snd_soc_register_card failed -517
[ 1.060918] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.069600] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.077325] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.084820] TCP: cubic registered
[ 1.088565] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.095424] Initializing XFRM netlink socket
[ 1.100226] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.111950] NET: Registered protocol family 17
[ 1.117274] VFP support v0.3: not present
[ 1.123311] [LCD] lcd_module_init
[ 1.128849] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 1, RTO !!
[ 1.146134] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.164908] sunivw1p1-pinctrl 1c20800.pinctrl: pin PD7 already requested by 1c22000.daudio; cannot claim for lcd0.2
[ 1.176578] sunivw1p1-pinctrl 1c20800.pinctrl: pin-103 (lcd0.2) status -22
[ 1.184213] sunivw1p1-pinctrl 1c20800.pinctrl: could not request pin 103 on device 1c20800.pinctrl
[ 1.194192] platform lcd0.2: Error applying setting, reverse things back
[ 1.201680] [DISP WRN] file:drivers/video/sunxi/disp/OSAL/OSAL_Pin.c,line:144: pinctrl_select_state(active) for allwinner,sunxi-lcd0 fail
[ 1.215748] Disp_lcdc_pin_cfg: fail to set lcd0's pin to active state, ret=-22
[ 1.787284] BSP_disp_layer_set_para: fb_format=0x0, yuv_ch=0
[ 1.836973] sunxi-codec-machine-i2s sound.6: ASoC: CODEC sta339.2-001c not registered
[ 1.845792]
[ 1.845792] snd_soc_register_card failed -517
[ 1.852375] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.862242] input: gpio_keys.7 as /devices/soc.0/gpio_keys.7/input/input2
[ 1.871059] sunxi-codec-machine-i2s sound.6: ASoC: CODEC sta339.2-001c not registered
[ 1.879894]
[ 1.879894] snd_soc_register_card failed -517
[ 1.886824] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.893986] ALSA device list:
[ 1.897405] #0: audiocodec
[ 1.900842] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.910243] async_waiting @ 1
[ 1.913586] async_continuing @ 1 after 3 usec
[ 1.932185] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 1.950467] devtmpfs: mounted
[ 1.953904] async_waiting @ 1
[ 1.957322] async_continuing @ 1 after 2 usec
[ 1.962721] Freeing unused kernel memory: 136K (c043c000 - c045e000)
/ # fb-test
fb-test 1.1.0 (rosetta)
fb res 800x480 virtual 800x960, line_len 1600, bpp 16
[ 11.596785] Unable to handle kernel paging request at virtual address 07e00810
[ 11.604980] pgd = c1a84000
[ 11.608020] [07e00810] *pgd=00000000
[ 11.612012] Internal error: Oops: 5 [#1] ARM
[ 11.616735] Modules linked in:
[ 11.620131] CPU: 0 PID: 55 Comm: fb-test Not tainted 3.10.65 #86
[ 11.626784] task: c145f260 ti: c14e0000 task.ti: c14e0000
[ 11.632777] PC is at filemap_fault+0x30/0x39c
[ 11.637618] LR is at __do_fault+0xa8/0x448
[ 11.642157] pc : [<c0063d50>] lr : [<c007960c>] psr: 60000013
[ 11.642157] sp : c14e1d80 ip : c14e1dc8 fp : c14e1dc4
[ 11.654855] r10: c14feaa8 r9 : 000000a8 r8 : 00000000
[ 11.660636] r7 : c1c050ec r6 : 000000e6 r5 : c1a80820 r4 : c14feaa8
[ 11.667857] r3 : 07e007e0 r2 : 00000fff r1 : c14e1dd8 r0 : c14feaa8
[ 11.675081] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 11.682975] Control: 0005317f Table: 81a84000 DAC: 00000015
[ 11.689329]
[ 11.689329] PC: 0xc0063cd0:
[ 11.694055] 3cd0 0a000010 e1a00004 e1a01005 ebfff960 ea000009 e3120020 0a000005 ebfff892
[ 11.703143] 3cf0 e3500000 0a000006 e285003c ebff6409 ea000004 ebfff8ab ea000001 e1a06005
[ 11.712239] 3d10 ea000000 e3a06001 e1a00006 e89da8f0 e1a0c00d e92ddff0 e24cb004 e24dd01c
[ 11.721328] 3d30 e5905050 e59f2370 e5957084 e5916004 e5973000 e1a0a000 e50b1030 e50b3034
[ 11.730423] 3d50 e1c303d0 e3a03000 e0900002 e0a11003 e1a03620 e1833a01 e1560003 2a0000c7
[ 11.739517] 3d70 e1a00007 e1a01006 ebfff84f e2504000 e2859048 0a000017 e51b3030 e5938000
[ 11.748611] 3d90 e2188040 1a000044 e59a3028 e5950084 e3130801 1a000041 e5953058 e3530000
[ 11.757705] 3db0 12433001 15853058 e5948000 e1a08928 e2188001 0a000039 e58d6000 e5953054
[ 11.766801]
[ 11.766801] LR: 0xc007958c:
[ 11.771525] 958c e50b1040 0a00000e e5943028 e3130008 13a06000 1a00000b e1a00004 eb002b7d
[ 11.780616] 95ac e2501000 1a0000f2 e59f03d4 e59f23d4 e1a03001 ebffbb83 e2506000 1a000001
[ 11.789708] 95cc ea0000eb e51b6040 e51b2044 e50b503c e3c23eff e3c3300f e50b3034 e59b3004
[ 11.798799] 95ec e1a00004 e50b3038 e3a03000 e50b3030 e5943048 e24b103c e5933008 e12fff33
[ 11.807889] 960c e59f3384 e1a09000 e0003003 e3530000 1a0000d2 e3100c02 1a00000c e51b5030
[ 11.816982] 962c eb0a5698 e10f2000 e3823080 e121f003 e5953000 e3831001 e5851000 e121f002
[ 11.826077] 964c e3130001 0a000001 e1a00005 ebffa256 e51b3040 e51b5030 e3530000 051b8040
[ 11.835168] 966c 0a000036 e5948028 e2188008 1a00000a e1a00006 e1a01005 e51b2044 e1a03004
[ 11.844263]
[ 11.844263] SP: 0xc14e1d00:
[ 11.848986] 1d00 002284d0 c04ff4f0 c14e1d7c c14e1d18 c0068064 c0063d50 60000013 ffffffff
[ 11.858081] 1d20 c14e1d6c 00000000 c14e1dc4 c14e1d38 c000f538 c000a1a0 c14feaa8 c14e1dd8
[ 11.867175] 1d40 00000fff 07e007e0 c14feaa8 c1a80820 000000e6 c1c050ec 00000000 000000a8
[ 11.876260] 1d60 c14feaa8 c14e1dc4 c14e1dc8 c14e1d80 c007960c c0063d50 60000013 ffffffff
[ 11.885353] 1d80 80000093 c049acc0 00000000 c049acc0 07e007e0 c14e1dd8 009897a3 c14feaa8
[ 11.894444] 1da0 000000a8 00000000 c1a1e480 00000000 000000a8 c1a86db8 c14e1e14 c14e1dc8
[ 11.903530] 1dc0 c007960c c0063d30 c14e1fb0 ffffffff b6f23000 00000000 000000a8 000000e6
[ 11.912620] 1de0 b6f23000 00000000 c14e1e04 c14feaa8 c14fc48c 000000e6 c1a86db8 00000000
[ 11.921715]
[ 11.921715] IP: 0xc14e1d48:
[ 11.926438] 1d48 c14feaa8 c1a80820 000000e6 c1c050ec 00000000 000000a8 c14feaa8 c14e1dc4
[ 11.935529] 1d68 c14e1dc8 c14e1d80 c007960c c0063d50 60000013 ffffffff 80000093 c049acc0
[ 11.944625] 1d88 00000000 c049acc0 07e007e0 c14e1dd8 009897a3 c14feaa8 000000a8 00000000
[ 11.953711] 1da8 c1a1e480 00000000 000000a8 c1a86db8 c14e1e14 c14e1dc8 c007960c c0063d30
[ 11.962803] 1dc8 c14e1fb0 ffffffff b6f23000 00000000 000000a8 000000e6 b6f23000 00000000
[ 11.971895] 1de8 c14e1e04 c14feaa8 c14fc48c 000000e6 c1a86db8 00000000 000000a8 c1a1e480
[ 11.980986] 1e08 c14e1e64 c14e1e18 c007c4e8 c0079574 000000e6 000000a8 00000000 c1a1e480
[ 11.990073] 1e28 c14e1e84 c14e1e38 c007c808 c0017240 00000001 b6f23000 c1a84000 000005b7
[ 11.999168]
[ 11.999168] FP: 0xc14e1d44:
[ 12.003892] 1d44 07e007e0 c14feaa8 c1a80820 000000e6 c1c050ec 00000000 000000a8 c14feaa8
[ 12.012979] 1d64 c14e1dc4 c14e1dc8 c14e1d80 c007960c c0063d50 60000013 ffffffff 80000093
[ 12.022067] 1d84 c049acc0 00000000 c049acc0 07e007e0 c14e1dd8 009897a3 c14feaa8 000000a8
[ 12.031158] 1da4 00000000 c1a1e480 00000000 000000a8 c1a86db8 c14e1e14 c14e1dc8 c007960c
[ 12.040246] 1dc4 c0063d30 c14e1fb0 ffffffff b6f23000 00000000 000000a8 000000e6 b6f23000
[ 12.049334] 1de4 00000000 c14e1e04 c14feaa8 c14fc48c 000000e6 c1a86db8 00000000 000000a8
[ 12.058424] 1e04 c1a1e480 c14e1e64 c14e1e18 c007c4e8 c0079574 000000e6 000000a8 00000000
[ 12.067516] 1e24 c1a1e480 c14e1e84 c14e1e38 c007c808 c0017240 00000001 b6f23000 c1a84000
[ 12.076615]
[ 12.076615] R0: 0xc14fea28:
[ 12.081339] ea28 00000000 00000000 0000013a c1a19c68 c1a19c68 c1489940 c03144e0 00000139
[ 12.090427] ea48 c1a80820 00000000 b6f81000 b6f84000 c14febb0 c14fe948 c14feb10 c14febc0
[ 12.099521] ea68 c14fea08 00000000 c1a1e480 0000018b 00100077 00000000 00000000 00000000
[ 12.108616] ea88 00000000 c1a19be8 c1a19be8 c14897a0 00000000 000b6f81 00000000 00000000
[ 12.117708] eaa8 b6e3d000 b6f76000 c14feb00 c14fec60 c14fee29 00000000 c14fec70 b6cb4000
[ 12.126801] eac8 c1a1e480 0000018b 00000075 c14d5b85 00000000 c14fe39c 00000138 c14feae4
[ 12.135894] eae8 c14feae4 00000000 c03144e0 00000000 c1a80820 00000000 b6f76000 b6f7e000
[ 12.144985] eb08 c14fe9f8 c14feaa8 c14fec19 c14fea60 c14fee28 b6cb4000 c1a1e480 00000a8b
[ 12.154078]
[ 12.154078] R1: 0xc14e1d58:
[ 12.158802] 1d58 00000000 000000a8 c14feaa8 c14e1dc4 c14e1dc8 c14e1d80 c007960c c0063d50
[ 12.167892] 1d78 60000013 ffffffff 80000093 c049acc0 00000000 c049acc0 07e007e0 c14e1dd8
[ 12.176984] 1d98 009897a3 c14feaa8 000000a8 00000000 c1a1e480 00000000 000000a8 c1a86db8
[ 12.186076] 1db8 c14e1e14 c14e1dc8 c007960c c0063d30 c14e1fb0 ffffffff b6f23000 00000000
[ 12.195170] 1dd8 000000a8 000000e6 b6f23000 00000000 c14e1e04 c14feaa8 c14fc48c 000000e6
[ 12.204261] 1df8 c1a86db8 00000000 000000a8 c1a1e480 c14e1e64 c14e1e18 c007c4e8 c0079574
[ 12.213349] 1e18 000000e6 000000a8 00000000 c1a1e480 c14e1e84 c14e1e38 c007c808 c0017240
[ 12.222441] 1e38 00000001 b6f23000 c1a84000 000005b7 c1a86db8 c1a1e480 c14feaa8 000000a8
[ 12.231533]
[ 12.231533] R4: 0xc14fea28:
[ 12.236257] ea28 00000000 00000000 0000013a c1a19c68 c1a19c68 c1489940 c03144e0 00000139
[ 12.245347] ea48 c1a80820 00000000 b6f81000 b6f84000 c14febb0 c14fe948 c14feb10 c14febc0
[ 12.254434] ea68 c14fea08 00000000 c1a1e480 0000018b 00100077 00000000 00000000 00000000
[ 12.263520] ea88 00000000 c1a19be8 c1a19be8 c14897a0 00000000 000b6f81 00000000 00000000
[ 12.272609] eaa8 b6e3d000 b6f76000 c14feb00 c14fec60 c14fee29 00000000 c14fec70 b6cb4000
[ 12.281700] eac8 c1a1e480 0000018b 00000075 c14d5b85 00000000 c14fe39c 00000138 c14feae4
[ 12.290786] eae8 c14feae4 00000000 c03144e0 00000000 c1a80820 00000000 b6f76000 b6f7e000
[ 12.299877] eb08 c14fe9f8 c14feaa8 c14fec19 c14fea60 c14fee28 b6cb4000 c1a1e480 00000a8b
[ 12.308973]
[ 12.308973] R5: 0xc1a807a0:
[ 12.313698] 07a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.322786] 07c0 00000000 c14966c0 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.331874] 07e0 00000000 00000000 00000000 00000000 00000000 c1a807f4 c1a807f4 c1a807fc
[ 12.340964] 0800 c1a807fc 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.350054] 0820 c1a80f00 c1416864 c1820790 c1c00908 c1c05038 c0314fec 00000004 00000000
[ 12.359144] 0840 0000001d 00000000 00000200 00000000 00000000 00000000 00000000 00000000
[ 12.368225] 0860 00000000 c1496420 00000000 00000000 00000000 00000020 00000000 00000000
[ 12.377311] 0880 00000200 00000000 00000000 00000000 00000000 c1a80894 c1a80894 c1a8089c
[ 12.386406]
[ 12.386406] R7: 0xc1c0506c:
[ 12.391131] 506c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.400227] 508c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.409322] 50ac 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.418413] 50cc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.427503] 50ec 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.436600] 510c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.445697] 512c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.454783] 514c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 12.463877]
[ 12.463877] R10: 0xc14fea28:
[ 12.468698] ea28 00000000 00000000 0000013a c1a19c68 c1a19c68 c1489940 c03144e0 00000139
[ 12.477791] ea48 c1a80820 00000000 b6f81000 b6f84000 c14febb0 c14fe948 c14feb10 c14febc0
[ 12.486881] ea68 c14fea08 00000000 c1a1e480 0000018b 00100077 00000000 00000000 00000000
[ 12.495971] ea88 00000000 c1a19be8 c1a19be8 c14897a0 00000000 000b6f81 00000000 00000000
[ 12.505060] eaa8 b6e3d000 b6f76000 c14feb00 c14fec60 c14fee29 00000000 c14fec70 b6cb4000
[ 12.514154] eac8 c1a1e480 0000018b 00000075 c14d5b85 00000000 c14fe39c 00000138 c14feae4
[ 12.523245] eae8 c14feae4 00000000 c03144e0 00000000 c1a80820 00000000 b6f76000 b6f7e000
[ 12.532337] eb08 c14fe9f8 c14feaa8 c14fec19 c14fea60 c14fee28 b6cb4000 c1a1e480 00000a8b
[ 12.541441] Process fb-test (pid: 55, stack limit = 0xc14e01b8)
[ 12.547990] Stack: (0xc14e1d80 to 0xc14e2000)
[ 12.553252] 1d80: 80000093 c049acc0 00000000 c049acc0 07e007e0 c14e1dd8 009897a3 c14feaa8
[ 12.562527] 1da0: 000000a8 00000000 c1a1e480 00000000 000000a8 c1a86db8 c14e1e14 c14e1dc8
[ 12.571713] 1dc0: c007960c c0063d30 c14e1fb0 ffffffff b6f23000 00000000 000000a8 000000e6
[ 12.580871] 1de0: b6f23000 00000000 c14e1e04 c14feaa8 c14fc48c 000000e6 c1a86db8 00000000
[ 12.590007] 1e00: 000000a8 c1a1e480 c14e1e64 c14e1e18 c007c4e8 c0079574 000000e6 000000a8
[ 12.599135] 1e20: 00000000 c1a1e480 c14e1e84 c14e1e38 c007c808 c0017240 00000001 b6f23000
[ 12.608255] 1e40: c1a84000 000005b7 c1a86db8 c1a1e480 c14feaa8 000000a8 c14e1e9c c14e1e68
[ 12.617379] 1e60: c007c924 c007c280 c1a86db8 000000a8 c14fec60 b6f239ac c14e1fb0 c145f260
[ 12.626502] 1e80: 000000a8 c1a1e480 c14feaa8 80000005 c14e1edc c14e1ea0 c0016c18 c007c87c
[ 12.635627] 1ea0: c14e1ebc c14e1eb0 00000000 c1a1e4bc c14e1efc 80000005 c046af70 b6f239ac
[ 12.644767] 1ec0: c14e1fb0 b6fbde00 b6f96adc 00000000 c14e1f04 c14e1ee0 c0016e00 c0016b00
[ 12.653863] 1ee0: c0016ddc 00000005 c046af70 b6f239ac c14e1fb0 b6fbde00 c14e1fac c14e1f08
[ 12.662991] 1f00: c000a26c c0016dec c0023160 c0022f14 00000000 ffffffff 00000004 ffff8f59
[ 12.672117] 1f20: c005c860 60000093 00000000 ffffffff 00000000 01400000 c14e1f64 c14e1f48
[ 12.681237] 1f40: c005f3d0 c005f2b8 0000000d 00000000 ffffffff 000008bb c14e1f7c c14e1f68
[ 12.690377] 1f60: c00234ec c005f374 00000100 0000000d c14e1f94 c14e1f80 c0010854 c0023440
[ 12.699507] 1f80: c049fb80 c14e1fb0 c14e1fac 0000871c b6f239ac a0000010 ffffffff bee3bcd8
[ 12.708641] 1fa0: 00000000 c14e1fb0 c000f898 c000a240 b6f96cb0 b6f80e08 b6f80e18 fffffff8
[ 12.717777] 1fc0: 00000004 b6fbb658 00000001 bee3bcd8 b6fbde00 b6f96adc 00000000 bee3bd4c
[ 12.726913] 1fe0: 00000000 bee3bcc0 b6f867d0 b6f239ac a0000010 ffffffff 00000000 00000000
[ 12.736008] Backtrace:
[ 12.738801] [<c0063d20>] (filemap_fault+0x0/0x39c) from [<c007960c>] (__do_fault+0xa8/0x448)
[ 12.748249] [<c0079564>] (__do_fault+0x0/0x448) from [<c007c4e8>] (handle_pte_fault+0x278/0x5fc)
[ 12.758070] [<c007c270>] (handle_pte_fault+0x0/0x5fc) from [<c007c924>] (handle_mm_fault+0xb8/0xcc)
[ 12.768178] [<c007c86c>] (handle_mm_fault+0x0/0xcc) from [<c0016c18>] (do_page_fault+0x128/0x278)
[ 12.778082] [<c0016af0>] (do_page_fault+0x0/0x278) from [<c0016e00>] (do_translation_fault+0x24/0xbc)
[ 12.788377] [<c0016ddc>] (do_translation_fault+0x0/0xbc) from [<c000a26c>] (do_PrefetchAbort+0x3c/0xa0)
[ 12.798839] r8:b6fbde00 r7:c14e1fb0 r6:b6f239ac r5:c046af70 r4:00000005
r3:c0016ddc
[ 12.807649] [<c000a230>] (do_PrefetchAbort+0x0/0xa0) from [<c000f898>] (ret_from_exception+0x0/0x10)
[ 12.817818] Exception stack(0xc14e1fb0 to 0xc14e1ff8)
[ 12.823445] 1fa0: b6f96cb0 b6f80e08 b6f80e18 fffffff8
[ 12.832573] 1fc0: 00000004 b6fbb658 00000001 bee3bcd8 b6fbde00 b6f96adc 00000000 bee3bd4c
[ 12.841688] 1fe0: 00000000 bee3bcc0 b6f867d0 b6f239ac a0000010 ffffffff
[ 12.849056] r7:bee3bcd8 r6:ffffffff r5:a0000010 r4:b6f239ac
[ 12.855430] Code: e5973000 e1a0a000 e50b1030 e50b3034 (e1c303d0)
[ 12.862203] ---[ end trace fcf66e4c308589c9 ]---
[ 12.867803] Unable to handle kernel paging request at virtual address 07e007e0
[ 12.875987] pgd = c0004000
[ 12.879011] [07e007e0] *pgd=00000000
[ 12.883003] Internal error: Oops: 805 [#2] ARM
[ 12.887919] Modules linked in:
[ 12.891318] CPU: 0 PID: 55 Comm: fb-test Tainted: G D 3.10.65 #86
[ 12.899028] task: c145f260 ti: c14e0000 task.ti: c14e0000
[ 12.905027] PC is at __mutex_lock_slowpath+0x3c/0xb4
[ 12.910528] LR is at mutex_lock+0x3c/0x40
[ 12.914973] pc : [<c030e18c>] lr : [<c030e48c>] psr: 80000013
[ 12.914973] sp : c14e1a40 ip : c14e1a70 fp : c14e1a6c
[ 12.927672] r10: b6cc6000 r9 : c14feb00 r8 : c14fec60
[ 12.933456] r7 : c14feaa8 r6 : c145f260 r5 : c1c05110 r4 : c1c0510c
[ 12.940678] r3 : 07e007e0 r2 : c14e1a44 r1 : c1a0f898 r0 : c1c0510c
[ 12.947902] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 12.955796] Control: 0005317f Table: 81a84000 DAC: 00000015
[ 12.962150]
[ 12.962150] PC: 0xc030e10c:
[ 12.966875] e10c e1a03000 e3a02000 e1030092 e3500000 a89da800 e1032090 e1c20fc2 e89da800
[ 12.975968] e12c e1a0c00d e92dd800 e24cb004 e3a02001 e1003092 e3530000 089da800 ebffffe3
[ 12.985060] e14c e89da800 e1a0c00d e92dd870 e24cb004 e24dd014 e1a0200d e3c23d7f e3c3303f
[ 12.994154] e16c e593600c e1a04000 e5903008 e24b2028 e2805004 e50b3024 e5802008 e50b5028
[ 13.003247] e18c e5832000 e5903000 e50b6020 e3530000 ba000003 e3e02000 e1003092 e3530001
[ 13.012340] e1ac 0a00000a e5943000 e3530000 ba000003 e3e02000 e1043092 e3530001 0a000003
[ 13.021434] e1cc e3a03002 e5863000 eb000522 eafffff4 e51b3024 e51b2028 e5823004 e5832000
[ 13.030528] e1ec e5943004 e1530005 03a03000 05843000 e24bd018 e89da870 e1a0c00d e92dd870
[ 13.039624]
[ 13.039624] LR: 0xc030e40c:
[ 13.044348] e40c e89da818 e1a0c00d e92dd818 e24cb004 e1a04000 eb00031b e3a00000 e1043090
[ 13.053431] e42c e3530001 089da818 e3e02000 e1043092 e3530001 089da818 e1a00004 ebffffa8
[ 13.062521] e44c e89da818 e1a0c00d e92dd818 e24cb004 e1a04000 eb00030b e3a02000 e1043092
[ 13.071610] e46c e3530001 089da818 e3e02000 e1043092 e3530001 089da818 e1a00004 ebffff30
[ 13.080704] e48c e89da818 e1a0c00d e92dd9f0 e24cb004 e24dd00c e1a0200d e3c23d7f e3c3303f
[ 13.089800] e4ac e1a08001 e593100c e1a06000 ebf4b5f2 e1a0300d e3c37d7f e3c7703f e597300c
[ 13.098898] e4cc e3a02001 e5832000 e1c641d8 e1c621d0 e0522004 e0c33005 e58d2000 e1a03005
[ 13.107986] e4ec e1a00006 e1a02004 e58d8004 ebf4b83f e5963028 e3530000 05863030 e5963030
[ 13.117077]
[ 13.117077] SP: 0xc14e19c0:
[ 13.121801] 19c0 c14e19e4 c14e19d0 c04ff4fc 00000000 c0492e60 c030e18c 80000013 ffffffff
[ 13.130893] 19e0 c14e1a2c c14fec60 c14e1a6c c14e19f8 c000f538 c000a1a0 c1c0510c c1a0f898
[ 13.139989] 1a00 c14e1a44 07e007e0 c1c0510c c1c05110 c145f260 c14feaa8 c14fec60 c14feb00
[ 13.149086] 1a20 b6cc6000 c14e1a6c c14e1a70 c14e1a40 c030e48c c030e18c 80000013 ffffffff
[ 13.158181] 1a40 c049d9f8 c1c05110 07e007e0 c1a19cc0 c1a0f8a4 c1c0510c c1c050ec c1a80820
[ 13.167274] 1a60 c14e1a84 c14e1a70 c030e48c c030e160 b703d000 c1c0510c c14e1aa4 c14e1a88
[ 13.176367] 1a80 c007edb8 c030e460 c14feaa8 00002000 c14e1ae0 00000000 c14e1adc c14e1aa8
[ 13.185457] 1aa0 c0079e94 c007ed9c b6cc6000 c14e1ab8 c007b974 c1a1e480 c14fee70 00000000
[ 13.194553]
[ 13.194553] IP: 0xc14e19f0:
[ 13.199278] 19f0 c000f538 c000a1a0 c1c0510c c1a0f898 c14e1a44 07e007e0 c1c0510c c1c05110
[ 13.208372] 1a10 c145f260 c14feaa8 c14fec60 c14feb00 b6cc6000 c14e1a6c c14e1a70 c14e1a40
[ 13.217467] 1a30 c030e48c c030e18c 80000013 ffffffff c049d9f8 c1c05110 07e007e0 c1a19cc0
[ 13.226561] 1a50 c1a0f8a4 c1c0510c c1c050ec c1a80820 c14e1a84 c14e1a70 c030e48c c030e160
[ 13.235651] 1a70 b703d000 c1c0510c c14e1aa4 c14e1a88 c007edb8 c030e460 c14feaa8 00002000
[ 13.244742] 1a90 c14e1ae0 00000000 c14e1adc c14e1aa8 c0079e94 c007ed9c b6cc6000 c14e1ab8
[ 13.253830] 1ab0 c007b974 c1a1e480 c14fee70 00000000 c1a1e4bc 00000000 00000015 00000001
[ 13.262918] 1ad0 c14e1b44 c14e1ae0 c00802a0 c0079e50 c1a1e480 00000001 00000000 00000000
[ 13.272009]
[ 13.272009] FP: 0xc14e19ec:
[ 13.276732] 19ec c14e19f8 c000f538 c000a1a0 c1c0510c c1a0f898 c14e1a44 07e007e0 c1c0510c
[ 13.285824] 1a0c c1c05110 c145f260 c14feaa8 c14fec60 c14feb00 b6cc6000 c14e1a6c c14e1a70
[ 13.294919] 1a2c c14e1a40 c030e48c c030e18c 80000013 ffffffff c049d9f8 c1c05110 07e007e0
[ 13.304011] 1a4c c1a19cc0 c1a0f8a4 c1c0510c c1c050ec c1a80820 c14e1a84 c14e1a70 c030e48c
[ 13.313105] 1a6c c030e160 b703d000 c1c0510c c14e1aa4 c14e1a88 c007edb8 c030e460 c14feaa8
[ 13.322198] 1a8c 00002000 c14e1ae0 00000000 c14e1adc c14e1aa8 c0079e94 c007ed9c b6cc6000
[ 13.331292] 1aac c14e1ab8 c007b974 c1a1e480 c14fee70 00000000 c1a1e4bc 00000000 00000015
[ 13.340382] 1acc 00000001 c14e1b44 c14e1ae0 c00802a0 c0079e50 c1a1e480 00000001 00000000
[ 13.349477]
[ 13.349477] R0: 0xc1c0508c:
[ 13.354201] 508c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.363290] 50ac 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.372385] 50cc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.381480] 50ec 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.390576] 510c ffffffff 07e007e0 c14e1a44 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.399664] 512c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.408756] 514c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.417849] 516c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.426945]
[ 13.426945] R1: 0xc1a0f818:
[ 13.431668] f818 00000001 09896620 00000000 0000000c 00000000 00000000 00000001 c1a0f834
[ 13.440755] f838 c1a0f834 00000000 00000000 00000000 c1a0f848 c1a0f848 c1a0f850 c1a0f850
[ 13.449843] f858 c1a0f710 c1a0f9a0 c140aa98 00000000 00000000 00000000 00000001 00000000
[ 13.458934] f878 00000000 c0315058 00000000 c1a0f7d0 00000000 00000020 00000000 00000000
[ 13.468030] f898 00000000 c1a0f89c c1a0f89c 00000001 c1a0f8a8 c1a0f8a8 00000000 00000000
[ 13.477118] f8b8 c0315318 000200da c04680c8 c1a0f8c4 c1a0f8c4 00000000 c18710ec c18710ec
[ 13.486210] f8d8 c18710c0 00000001 00000000 00000000 c04a9758 00000000 c1a0f8f8 00000000
[ 13.495299] f8f8 00200000 00000000 00000000 c1a0f904 c1a0f904 c1a0f90c c1a0f90c 00000000
[ 13.504391]
[ 13.504391] R2: 0xc14e19c4:
[ 13.509116] 19c4 c14e19d0 c04ff4fc 00000000 c0492e60 c030e18c 80000013 ffffffff c14e1a2c
[ 13.518209] 19e4 c14fec60 c14e1a6c c14e19f8 c000f538 c000a1a0 c1c0510c c1a0f898 c14e1a44
[ 13.527301] 1a04 07e007e0 c1c0510c c1c05110 c145f260 c14feaa8 c14fec60 c14feb00 b6cc6000
[ 13.536393] 1a24 c14e1a6c c14e1a70 c14e1a40 c030e48c c030e18c 80000013 ffffffff c049d9f8
[ 13.545485] 1a44 c1c05110 07e007e0 c1a19cc0 c1a0f8a4 c1c0510c c1c050ec c1a80820 c14e1a84
[ 13.554579] 1a64 c14e1a70 c030e48c c030e160 b703d000 c1c0510c c14e1aa4 c14e1a88 c007edb8
[ 13.563672] 1a84 c030e460 c14feaa8 00002000 c14e1ae0 00000000 c14e1adc c14e1aa8 c0079e94
[ 13.572765] 1aa4 c007ed9c b6cc6000 c14e1ab8 c007b974 c1a1e480 c14fee70 00000000 c1a1e4bc
[ 13.581858]
[ 13.581858] R4: 0xc1c0508c:
[ 13.586584] 508c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.595677] 50ac 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.604776] 50cc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.613873] 50ec 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.622962] 510c ffffffff 07e007e0 c14e1a44 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.632053] 512c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.641142] 514c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.650238] 516c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.659339]
[ 13.659339] R5: 0xc1c05090:
[ 13.664064] 5090 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.673158] 50b0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.682253] 50d0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.691344] 50f0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 ffffffff
[ 13.700437] 5110 07e007e0 c14e1a44 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.709531] 5130 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.718630] 5150 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.727729] 5170 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 13.736820]
[ 13.736820] R6: 0xc145f1e0:
[ 13.741543] f1e0 00000000 00000000 00000000 00000000 00000001 00000002 c145f1f8 c145f1f8
[ 13.750635] f200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 13.759723] f220 00000000 00000000 c145f228 c145f228 00000000 00000000 00000000 00000000
[ 13.768806] f240 00000000 00000000 00000000 00000020 00000000 0000c350 0000c350 00000000
[ 13.777896] f260 00000000 c14e0000 00000002 00400104 00000000 00000001 00000078 00000078
[ 13.786985] f280 00000078 00000000 c0313e9c 00000000 00000400 00400000 c145e818 00000000
[ 13.796074] f2a0 00000000 c145f2a4 c145f2a4 00000001 ff764b59 00000002 20b78a09 00000000
[ 13.805165] f2c0 a92a946c 00000000 2035efa6 00000000 00000000 00000000 c145f2d8 c145f2d8
[ 13.814257]
[ 13.814257] R7: 0xc14fea28:
[ 13.818983] ea28 00000000 00000000 0000013a c1a19c68 c1a19c68 c1489940 c03144e0 00000139
[ 13.828080] ea48 c1a80820 00000000 b6f81000 b6f84000 c14febb0 c14fe948 c14feb10 c14febc0
[ 13.837176] ea68 c14fea08 00000000 c1a1e480 0000018b 00100077 00000000 00000000 00000000
[ 13.846269] ea88 00000000 c1a19be8 c1a19be8 c14897a0 00000000 000b6f81 00000000 00000000
[ 13.855358] eaa8 b6e3d000 b6f76000 c14feb00 c14fec60 c14fee29 00000000 c14fec70 b6cb4000
[ 13.864447] eac8 c1a1e480 0000018b 00000075 c14d5b85 00000000 c14fe39c 00000138 c14feae4
[ 13.873537] eae8 c14feae4 00000000 c03144e0 00000000 c1a80820 00000000 b6f76000 b6f7e000
[ 13.882627] eb08 c14fe9f8 c14feaa8 c14fec19 c14fea60 c14fee28 b6cb4000 c1a1e480 00000a8b
[ 13.891722]
[ 13.891722] R8: 0xc14febe0:
[ 13.896450] ebe0 00000000 00000000 0000000a c14febec c14febec 00000000 c03144e0 00000000
[ 13.905540] ec00 c1a80f00 00000000 b6f8f000 b6f96000 c14feb58 c14febb0 c14fecc8 c14fedd0
[ 13.914636] ec20 c14feb10 b6cb4000 c1a1e480 00000a8b 00000070 c14feb84 00000000 00000000
[ 13.923724] ec40 00000011 c14fec44 c14fec44 00000000 c03144e0 0000000b c1a80f00 00000000
[ 13.932815] ec60 b6cc6000 b6e3d000 c14feaa8 c14fee18 c14feab8 00000000 00000000 b6cb4000
[ 13.941908] ec80 c1a1e480 00000107 040444ff 00000001 00000000 00000000 00000176 c14fec9c
[ 13.950992] eca0 c14fec9c 00000000 00000000 00000000 c1a80dc0 00000000 b6fbb000 b6fbc000
[ 13.960084] ecc0 c14fed10 c14fe9a0 00000001 c14fed78 c14fec18 b6cb4000 c1a1e480 0000018b
[ 13.969177]
[ 13.969177] R9: 0xc14fea80:
[ 13.973903] ea80 00000000 00000000 00000000 c1a19be8 c1a19be8 c14897a0 00000000 000b6f81
[ 13.983000] eaa0 00000000 00000000 b6e3d000 b6f76000 c14feb00 c14fec60 c14fee29 00000000
[ 13.992092] eac0 c14fec70 b6cb4000 c1a1e480 0000018b 00000075 c14d5b85 00000000 c14fe39c
[ 14.001182] eae0 00000138 c14feae4 c14feae4 00000000 c03144e0 00000000 c1a80820 00000000
[ 14.010274] eb00 b6f76000 b6f7e000 c14fe9f8 c14feaa8 c14fec19 c14fea60 c14fee28 b6cb4000
[ 14.019363] eb20 c1a1e480 00000a8b 00000070 c14fe44d c14fea24 c14d5c34 00000140 c14feb3c
[ 14.028451] eb40 c14feb3c 00000000 c03144e0 00000139 c1a80820 00000000 b6f96000 b6f97000
[ 14.037541] eb60 c14fedc0 c14fec08 c14fedd1 00000000 00000000 00000000 c1a1e480 0000018b
[ 14.046641] Process fb-test (pid: 55, stack limit = 0xc14e01b8)
[ 14.053190] Stack: (0xc14e1a40 to 0xc14e2000)
[ 14.060160] Unable to handle kernel paging request at virtual address 07e007e8
[ 14.068325] pgd = c14b0000
[ 14.071349] [07e007e8] *pgd=00000000
[ 14.075398] Internal error: Oops: 5 [#3] ARM
[ 14.080126] Modules linked in:
[ 14.083529] CPU: 0 PID: 50 Comm: syslogd Tainted: G D 3.10.65 #86
[ 14.091243] task: c145ea80 ti: c14b4000 task.ti: c14b4000
[ 14.097245] PC is at __inode_permission+0x30/0x60
[ 14.102457] LR is at inode_permission+0x54/0x58
[ 14.107478] pc : [<c009a8a8>] lr : [<c009a92c>] psr: 60000013
[ 14.107478] sp : c14b5e18 ip : c14b5e28 fp : c14b5e24
[ 14.120185] r10: 00000041 r9 : c14b4000 r8 : c14b5f60
[ 14.125970] r7 : 00000000 r6 : c14a3011 r5 : 00000076 r4 : c14b5ee0
[ 14.133195] r3 : 07e007e0 r2 : 07e007e0 r1 : 00000081 r0 : c1c03038
[ 14.140421] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 14.148318] Control: 0005317f Table: 814b0000 DAC: 00000015
[ 14.154673]
[ 14.154673] PC: 0xc009a828:
[ 14.159398] a828 e5846004 ea000005 e3e0500b ea000000 e3e05023 e1a00004 ebffffb2 e1a04005
[ 14.168496] a848 e1a00004 e89da9f8 c0468254 c049d99c 000080d0 e1a0c00d e92dd800 e24cb004
[ 14.177588] a868 e3a01000 e1a02001 ebffffb9 e89da800 e1a0c00d e92dd800 e24cb004 e3110002
[ 14.186681] a888 0a000002 e590300c e3130008 1a00000d e1d030b2 e3130001 1a000008 e5903018
[ 14.195770] a8a8 e5933008 e3530000 0a000001 e12fff33 e89da800 e1d030b2 e3833001 e1c030b2
[ 14.204857] a8c8 ebfffdde e89da800 e3e0000c e89da800 e1a0c00d e92dd800 e24cb004 e3110002
[ 14.213949] a8e8 e590201c 0a00000d e5922034 e1d030b0 e3120001 0a000009 e2033a0f e3530902
[ 14.223040] a908 13530901 0a000003 e3530a0a 03e0001d 1a000002 e89da800 e3e0001d e89da800
[ 14.232134]
[ 14.232134] LR: 0xc009a8ac:
[ 14.236858] a8ac e3530000 0a000001 e12fff33 e89da800 e1d030b2 e3833001 e1c030b2 ebfffdde
[ 14.245948] a8cc e89da800 e3e0000c e89da800 e1a0c00d e92dd800 e24cb004 e3110002 e590201c
[ 14.255042] a8ec 0a00000d e5922034 e1d030b0 e3120001 0a000009 e2033a0f e3530902 13530901
[ 14.264131] a90c 0a000003 e3530a0a 03e0001d 1a000002 e89da800 e3e0001d e89da800 ebffffd2
[ 14.273223] a92c e89da800 e1a0c00d e92dddf0 e24cb004 e24dd028 e1a04001 e1a06000 e4d05001
[ 14.282314] a94c e355002f 0afffffb e3550000 0a0001b6 e5943024 e3130040 0a00000b e5940020
[ 14.291406] a96c e3a01081 ebffffd8 e370000a e1a08000 11a05000 1a000008 e1a00004 e3a01000
[ 14.300494] a98c ebfffa7b e3500000 1a0001a4 e5940020 e3a01001 ebffffcc e1a05000 e3550000
[ 14.309583]
[ 14.309583] SP: 0xc14b5d98:
[ 14.314305] 5d98 c14b5dbc c14b5da8 c026bef4 c0268920 00000000 c009a8a8 60000013 ffffffff
[ 14.323396] 5db8 c14b5e04 c14b5f60 c14b5e24 c14b5dd0 c000f538 c000a1a0 c1c03038 00000081
[ 14.332487] 5dd8 07e007e0 07e007e0 c14b5ee0 00000076 c14a3011 00000000 c14b5f60 c14b4000
[ 14.341578] 5df8 00000041 c14b5e24 c14b5e28 c14b5e18 c009a92c c009a8a8 60000013 ffffffff
[ 14.350663] 5e18 c14b5e34 c14b5e28 c009a92c c009a888 c14b5e84 c14b5e38 c009a974 c009a8e8
[ 14.359748] 5e38 c14b5e64 c14b5e48 c008e974 c008e9a8 c14b5e84 c14b5e58 c009b23c c003f974
[ 14.368838] 5e58 c14b5e84 c14b5e68 c14b5ee0 c1a80d20 c14a3000 00000000 c14b5f60 00000041
[ 14.377925] 5e78 c14b5ed4 c14b5e88 c009d870 c009a940 c14b5ea4 c14b5ec0 c1a801e0 000000ff
[ 14.387015]
[ 14.387015] IP: 0xc14b5da8:
[ 14.391739] 5da8 00000000 c009a8a8 60000013 ffffffff c14b5e04 c14b5f60 c14b5e24 c14b5dd0
[ 14.400825] 5dc8 c000f538 c000a1a0 c1c03038 00000081 07e007e0 07e007e0 c14b5ee0 00000076
[ 14.409913] 5de8 c14a3011 00000000 c14b5f60 c14b4000 00000041 c14b5e24 c14b5e28 c14b5e18
[ 14.419001] 5e08 c009a92c c009a8a8 60000013 ffffffff c14b5e34 c14b5e28 c009a92c c009a888
[ 14.428090] 5e28 c14b5e84 c14b5e38 c009a974 c009a8e8 c14b5e64 c14b5e48 c008e974 c008e9a8
[ 14.437180] 5e48 c14b5e84 c14b5e58 c009b23c c003f974 c14b5e84 c14b5e68 c14b5ee0 c1a80d20
[ 14.446274] 5e68 c14a3000 00000000 c14b5f60 00000041 c14b5ed4 c14b5e88 c009d870 c009a940
[ 14.455365] 5e88 c14b5ea4 c14b5ec0 c1a801e0 000000ff c1820f00 c14b5f78 00000000 00000000
[ 14.464459]
[ 14.464459] FP: 0xc14b5da4:
[ 14.469181] 5da4 c0268920 00000000 c009a8a8 60000013 ffffffff c14b5e04 c14b5f60 c14b5e24
[ 14.478267] 5dc4 c14b5dd0 c000f538 c000a1a0 c1c03038 00000081 07e007e0 07e007e0 c14b5ee0
[ 14.487361] 5de4 00000076 c14a3011 00000000 c14b5f60 c14b4000 00000041 c14b5e24 c14b5e28
[ 14.496451] 5e04 c14b5e18 c009a92c c009a8a8 60000013 ffffffff c14b5e34 c14b5e28 c009a92c
[ 14.505541] 5e24 c009a888 c14b5e84 c14b5e38 c009a974 c009a8e8 c14b5e64 c14b5e48 c008e974
[ 14.514625] 5e44 c008e9a8 c14b5e84 c14b5e58 c009b23c c003f974 c14b5e84 c14b5e68 c14b5ee0
[ 14.523718] 5e64 c1a80d20 c14a3000 00000000 c14b5f60 00000041 c14b5ed4 c14b5e88 c009d870
[ 14.532813] 5e84 c009a940 c14b5ea4 c14b5ec0 c1a801e0 000000ff c1820f00 c14b5f78 00000000
[ 14.541902]
[ 14.541902] R0: 0xc1c02fb8:
[ 14.546627] 2fb8 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.555715] 2fd8 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.564803] 2ff8 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.573894] 3018 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.582991] 3038 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.592074] 3058 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.601159] 3078 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.610246] 3098 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 14.619333]
[ 14.619333] R4: 0xc14b5e60:
[ 14.624056] 5e60 c14b5ee0 c1a80d20 c14a3000 00000000 c14b5f60 00000041 c14b5ed4 c14b5e88
[ 14.633139] 5e80 c009d870 c009a940 c14b5ea4 c14b5ec0 c1a801e0 000000ff c1820f00 c14b5f78
[ 14.642229] 5ea0 00000000 00000000 c14b5f44 c14b5f60 00000001 ffffff9c c14a3000 c000faa8
[ 14.651316] 5ec0 c14b4000 00000000 c14b5f54 c14b5ed8 c009dec4 c009d7f4 00000041 00000000
[ 14.660402] 5ee0 c1820790 c1c00088 c14b5f1c c14b5ef8 00000000 c19fecc0 c1820790 c1c00088
[ 14.669486] 5f00 c1c03038 00001051 00000002 00000001 00000000 c00a7940 00020d41 00020d41
[ 14.678569] 5f20 ffffff9c c14a3000 00000001 c000faa8 c14b4000 00000000 00000004 ffffff9c
[ 14.687658] 5f40 c14a3000 00000001 c14b5f94 c14b5f58 c0090b20 c009dea0 c14b4000 00000000
[ 14.696746]
[ 14.696746] R6: 0xc14a2f91:
[ 14.701468] 2f90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.710552] 2fb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.719643] 2fd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.728733] 2ff0 00000000 00000000 00000000 00000000 c14a3010 000a1be4 8020041a 80300400
[ 14.737820] 3010 7261762f 676f6c2f 73656d2f 65676173 2b730073 00312e6f 312e6f73 2e6f7300
[ 14.746905] 3030 2e6f0031 2e6f0031 00000031 6f00322e 0000322e 8110041a 8120041a 8130041a
[ 14.755993] 3050 8140041a 8150041a 8160041a 8170041a 8180041a 8190041a 81a0041a 81b0041a
[ 14.765080] 3070 81c0041a 81d0041a 81e0041a 81f0041a 00000000 00000000 00000000 00000000
[ 14.774162] 3090 00000000 00000000 00000000 00000000 81831811 81831c11 8140b811 8140bc11
[ 14.783256]
[ 14.783256] R8: 0xc14b5ee0:
[ 14.787980] 5ee0 c1820790 c1c00088 c14b5f1c c14b5ef8 00000000 c19fecc0 c1820790 c1c00088
[ 14.797072] 5f00 c1c03038 00001051 00000002 00000001 00000000 c00a7940 00020d41 00020d41
[ 14.806155] 5f20 ffffff9c c14a3000 00000001 c000faa8 c14b4000 00000000 00000004 ffffff9c
[ 14.815242] 5f40 c14a3000 00000001 c14b5f94 c14b5f58 c0090b20 c009dea0 c14b4000 00000000
[ 14.824336] 5f60 00020d41 c14b81b6 0000002a 00000300 000a1be4 016c0008 0000000c 00000005
[ 14.833421] 5f80 c000faa8 00000000 c14b5fa4 c14b5f98 c0090bd8 c0090a44 00000000 c14b5fa8
[ 14.842507] 5fa0 c000f920 c0090bbc 000a1be4 016c0008 000a1be4 00020d41 000001b6 00000000
[ 14.851594] 5fc0 000a1be4 016c0008 0000000c 00000005 000b3800 00000000 00000085 bea25cac
[ 14.860684]
[ 14.860684] R9: 0xc14b3f80:
[ 14.865408] 3f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.874498] 3fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.883579] 3fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.892664] 3fe0 00000000 00000000 00000000 00000000 00000000 00000000 81ffd831 81ffdc31
[ 14.901754] 4000 00000002 00000001 00000000 c145ea80 c046b6ac 00000000 00000017 c1a1e780
[ 14.910844] 4020 c1a1e300 c145ea80 c145e7e0 c145ebe0 00000000 00000000 c14b5d1c c14b5cf8
[ 14.919933] 4040 c030efe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.929017] 4060 b6fbf4c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 14.938116] Process syslogd (pid: 50, stack limit = 0xc14b41b8)
[ 14.944669] Stack: (0xc14b5e18 to 0xc14b6000)
[ 14.951213] 1a40: c049d9f8 c1c05110 07e007e0 c1a19cc0 c1a0f8a4 c1c0510c c1c050ec c1a80820
[ 14.960442] 1a60: c14e1a84 c14e1a70 c030e48c c030e160 b703d000 c1c0510c c14e1aa4 c14e1a88
[ 14.969593] 1a80: c007edb8 c030e460 c14feaa8 00002000 c14e1ae0 00000000 c14e1adc c14e1aa8
[ 14.978732] 1aa0: c0079e94 c007ed9c b6cc6000 c14e1ab8 c007b974 c1a1e480 c14fee70 00000000
[ 14.987860] 1ac0: c1a1e4bc 00000000 00000015 00000001 c14e1b44 c14e1ae0 c00802a0 c0079e50
[ 14.996987] 1ae0: c1a1e480 00000001 00000000 00000000 ffffffff c14e1b00 c0040a4c 00000065
[ 15.006142] 1b00: 00000400 c1a83000 c14e1b24 c14e1b18 c030f0cc c1a1e4bc c145f260 c14e4000
[ 15.015288] 1b20: c14e1b3c c14e1b30 c003cd38 c1a1e480 00000000 00000000 c14e1b5c c14e1b48
[ 15.024368] 1b40: c001a808 c00801cc c145f260 c1a1e480 c14e1b7c c14e1b60 c00212d8 c001a7d0
[ 15.033499] 1b60: c14e1b7c c14e1b70 c001ca18 c14e1bc2 c14e1bf4 c14e1b80 c0013a08 c0020fcc
[ 15.042628] 1b80: c14e01b8 0000000b 60000013 00000008 65010000 33373935 20303030 30613165
[ 15.051758] 1ba0: 30303061 30356520 33303162 35652030 30336230 28203433 33633165 30643330
[ 15.061086] 1bc0: c0002029 c030dab8 c03e3113 07e00810 00000005 c1a1e480 c14e1d38 00000000
[ 15.070332] 1be0: 00010000 00000005 c14e1c1c c14e1bf8 c0016ad0 c00136d4 c14e1d38 07e00810
[ 15.079506] 1c00: c14e1d38 c145f260 00000028 c1a1e480 c14e1c5c c14e1c20 c0016d50 c0016a74
[ 15.088663] 1c20: 00000000 c1ff666c 00000000 c1a1e4bc 00000001 00000005 00000005 07e00810
[ 15.097795] 1c40: c046af20 c14e1d38 000000a8 c14feaa8 c14e1c84 c14e1c60 c0016e00 c0016b00
[ 15.106922] 1c60: c0016ddc 00000005 00000005 07e00810 c046af20 c14e1d38 c14e1d34 c14e1c88
[ 15.116047] 1c80: c000a1c8 c0016dec 00000000 00000001 c14e1cd4 c14e1ca0 c005a30c c005bc70
[ 15.125176] 1ca0: c14e1cc4 c14e1cb0 c0040af4 c04718f4 00000000 ffffffff c14e1cdc c14e1cc8
[ 15.134257] 1cc0: c005c860 c005c448 00000000 c04718f4 00000000 01400000 c14e1d04 c14e1ce8
[ 15.143381] 1ce0: c005f3d0 c005f2b8 c04ff4fc 00000000 c0492e60 00000001 c04ff4fc 00000000
[ 15.152518] 1d00: 002284d0 c04ff4f0 c14e1d7c c14e1d18 c0068064 c0063d50 60000013 ffffffff
[ 15.161659] 1d20: c14e1d6c 00000000 c14e1dc4 c14e1d38 c000f538 c000a1a0 c14feaa8 c14e1dd8
[ 15.170789] 1d40: 00000fff 07e007e0 c14feaa8 c1a80820 000000e6 c1c050ec 00000000 000000a8
[ 15.179915] 1d60: c14feaa8 c14e1dc4 c14e1dc8 c14e1d80 c007960c c0063d50 60000013 ffffffff
[ 15.189037] 1d80: 80000093 c049acc0 00000000 c049acc0 07e007e0 c14e1dd8 009897a3 c14feaa8
[ 15.198160] 1da0: 000000a8 00000000 c1a1e480 00000000 000000a8 c1a86db8 c14e1e14 c14e1dc8
[ 15.207289] 1dc0: c007960c c0063d30 c14e1fb0 ffffffff b6f23000 00000000 000000a8 000000e6
[ 15.216410] 1de0: b6f23000 00000000 c14e1e04 c14feaa8 c14fc48c 000000e6 c1a86db8 00000000
[ 15.225561] 1e00: 000000a8 c1a1e480 c14e1e64 c14e1e18 c007c4e8 c0079574 000000e6 000000a8
[ 15.234707] 1e20: 00000000 c1a1e480 c14e1e84 c14e1e38 c007c808 c0017240 00000001 b6f23000
[ 15.243806] 1e40: c1a84000 000005b7 c1a86db8 c1a1e480 c14feaa8 000000a8 c14e1e9c c14e1e68
[ 15.252931] 1e60: c007c924 c007c280 c1a86db8 000000a8 c14fec60 b6f239ac c14e1fb0 c145f260
[ 15.262055] 1e80: 000000a8 c1a1e480 c14feaa8 80000005 c14e1edc c14e1ea0 c0016c18 c007c87c
[ 15.271178] 1ea0: c14e1ebc c14e1eb0 00000000 c1a1e4bc c14e1efc 80000005 c046af70 b6f239ac
[ 15.280333] 5e00: c14b5e34 c14b5e28
[ 15.289601] 1ec0: c14e1fb0 b6fbde00 b6f96adc 00000000 c14e1f04 c14e1ee0 c0016e00 c0016b00
[ 15.298789] 5e20: c009a92c c009a888 c14b5e84 c14b5e38 c009a974 c009a8e8 c14b5e64 c14b5e48
[ 15.307954] 1ee0: c0016ddc 00000005 c046af70 b6f239ac c14e1fb0 b6fbde00 c14e1fac c14e1f08
[ 15.317109] 5e40: c008e974 c008e9a8 c14b5e84 c14b5e58 c009b23c c003f974 c14b5e84 c14b5e68
[ 15.326241] 1f00: c000a26c c0016dec c0023160 c0022f14 00000000 ffffffff 00000004 ffff8f59
[ 15.335370] 5e60: c14b5ee0 c1a80d20 c14a3000 00000000 c14b5f60 00000041 c14b5ed4 c14b5e88
[ 15.344451] 5e80: c009d870 c009a940 c14b5ea4 c14b5ec0 c1a801e0 000000ff c1820f00 c14b5f78
[ 15.353579] 1f20: c005c860 60000093 00000000 ffffffff 00000000 01400000 c14e1f64 c14e1f48
[ 15.362703] 1f40: c005f3d0 c005f2b8 0000000d 00000000 ffffffff 000008bb c14e1f7c c14e1f68
[ 15.371838] 5ea0: 00000000 00000000 c14b5f44 c14b5f60 00000001 ffffff9c c14a3000 c000faa8
[ 15.380975] 1f60: c00234ec c005f374 00000100 0000000d c14e1f94 c14e1f80 c0010854 c0023440
[ 15.390115] 5ec0: c14b4000 00000000 c14b5f54 c14b5ed8 c009dec4 c009d7f4 00000041 00000000
[ 15.399246] 1f80: c049fb80 c14e1fb0 c14e1fac 0000871c b6f239ac a0000010 ffffffff bee3bcd8
[ 15.408380] 5ee0: c1820790 c1c00088 c14b5f1c c14b5ef8 00000000 c19fecc0 c1820790 c1c00088
[ 15.417504] 1fa0: 00000000 c14e1fb0 c000f898 c000a240 b6f96cb0 b6f80e08 b6f80e18 fffffff8
[ 15.426634] 5f00: c1c03038 00001051 00000002 00000001 00000000 c00a7940 00020d41 00020d41
[ 15.435756] 1fc0: 00000004 b6fbb658 00000001 bee3bcd8 b6fbde00 b6f96adc 00000000 bee3bd4c
[ 15.444890] 5f20: ffffff9c c14a3000 00000001 c000faa8 c14b4000 00000000 00000004 ffffff9c
[ 15.453970] 5f40: c14a3000 00000001 c14b5f94 c14b5f58 c0090b20 c009dea0 c14b4000 00000000
[ 15.463100] 1fe0: 00000000 bee3bcc0 b6f867d0 b6f239ac a0000010 ffffffff 00000000 00000000
[ 15.472198] Backtrace:
[ 15.475024] [<c030e150>] (__mutex_lock_slowpath+0x0/0xb4) from [<c030e48c>] (mutex_lock+0x3c/0x40)
[ 15.485005] r6:c1a80820 r5:c1c050ec r4:c1c0510c
[ 15.490208] [<c030e450>] (mutex_lock+0x0/0x40) from [<c007edb8>] (unlink_file_vma+0x2c/0x48)
[ 15.499614] r4:c1c0510c r3:b703d000
[ 15.503643] [<c007ed8c>] (unlink_file_vma+0x0/0x48) from [<c0079e94>] (free_pgtables+0x54/0xb0)
[ 15.513332] r7:00000000 r6:c14e1ae0 r5:00002000 r4:c14feaa8
[ 15.519735] [<c0079e40>] (free_pgtables+0x0/0xb0) from [<c00802a0>] (exit_mmap+0xe4/0x208)
[ 15.528994] [<c00801bc>] (exit_mmap+0x0/0x208) from [<c001a808>] (mmput+0x48/0xd0)
[ 15.537441] r6:00000000 r5:00000000 r4:c1a1e480
[ 15.542637] [<c001a7c0>] (mmput+0x0/0xd0) from [<c00212d8>] (do_exit+0x31c/0x7e0)
[ 15.550975] r5:c1a1e480 r4:c145f260
[ 15.555030] [<c0020fbc>] (do_exit+0x0/0x7e0) from [<c0013a08>] (die+0x344/0x394)
[ 15.563224] r7:c14e1bc2
[ 15.566115] [<c00136c4>] (die+0x0/0x394) from [<c0016ad0>] (__do_kernel_fault+0x6c/0x8c)
[ 15.575147] [<c0016a64>] (__do_kernel_fault+0x0/0x8c) from [<c0016d50>] (do_page_fault+0x260/0x278)
[ 15.585208] r8:c1a1e480 r7:00000028 r6:c145f260 r5:c14e1d38 r4:07e00810
r3:c14e1d38
[ 15.593971] [<c0016af0>] (do_page_fault+0x0/0x278) from [<c0016e00>] (do_translation_fault+0x24/0xbc)
[ 15.604273] [<c0016ddc>] (do_translation_fault+0x0/0xbc) from [<c000a1c8>] (do_DataAbort+0x38/0xa0)
[ 15.614348] r8:c14e1d38 r7:c046af20 r6:07e00810 r5:00000005 r4:00000005
r3:c0016ddc
[ 15.623162] [<c000a190>] (do_DataAbort+0x0/0xa0) from [<c000f538>] (__dabt_svc+0x38/0x60)
[ 15.632273] Exception stack(0xc14e1d38 to 0xc14e1d80)
[ 15.637957] 5f60: 00020d41 c14b81b6 0000002a 00000300 000a1be4 016c0008 0000000c 00000005
[ 15.647091] 5f80: c000faa8 00000000 c14b5fa4 c14b5f98 c0090bd8 c0090a44 00000000 c14b5fa8
[ 15.656213] 5fa0: c000f920 c0090bbc 000a1be4 016c0008 000a1be4 00020d41 000001b6 00000000
[ 15.665337] 5fc0: 000a1be4 016c0008 0000000c 00000005 000b3800 00000000 00000085 bea25cac
[ 15.674420] 5fe0: 000b33fc bea25bf8 00041594 b6f1d4b4 60000010 000a1be4 00000000 00000000
[ 15.683515] Backtrace:
[ 15.686330] [<c009a878>] (__inode_permission+0x0/0x60) from [<c009a92c>] (inode_permission+0x54/0x58)
[ 15.696609] [<c009a8d8>] (inode_permission+0x0/0x58) from [<c009a974>] (link_path_walk+0x44/0x764)
[ 15.706601] [<c009a930>] (link_path_walk+0x0/0x764) from [<c009d870>] (path_openat.clone.52+0x8c/0x3fc)
[ 15.717078] [<c009d7e4>] (path_openat.clone.52+0x0/0x3fc) from [<c009dec4>] (do_filp_open+0x34/0x80)
[ 15.727282] [<c009de90>] (do_filp_open+0x0/0x80) from [<c0090b20>] (do_sys_open+0xec/0x178)
[ 15.736578] r7:00000001 r6:c14a3000 r5:ffffff9c r4:00000004
[ 15.742930] [<c0090a34>] (do_sys_open+0x0/0x178) from [<c0090bd8>] (SyS_open+0x2c/0x30)
[ 15.751894] [<c0090bac>] (SyS_open+0x0/0x30) from [<c000f920>] (ret_fast_syscall+0x0/0x2c)
[ 15.761131] Code: e1d030b2 e3130001 1a000008 e5903018 (e5933008)
[ 15.767950] ---[ end trace fcf66e4c308589ca ]---
[ 15.773358] Unable to handle kernel paging request at virtual address 07e007e0
[ 15.781522] pgd = c0004000
[ 15.784594] [07e007e0] *pgd=00000000
[ 15.788589] Internal error: Oops: 805 [#4] ARM
[ 15.793509] Modules linked in:
[ 15.796909] CPU: 0 PID: 50 Comm: syslogd Tainted: G D 3.10.65 #86
[ 15.804621] task: c145ea80 ti: c14b4000 task.ti: c14b4000
[ 15.810626] PC is at __mutex_lock_slowpath+0x3c/0xb4
[ 15.816129] LR is at mutex_lock+0x3c/0x40
[ 15.820573] pc : [<c030e18c>] lr : [<c030e48c>] psr: 80000013
[ 15.820573] sp : c14b5ad8 ip : c14b5b08 fp : c14b5b04
[ 15.833278] r10: 00008000 r9 : 00000015 r8 : c145be18
[ 15.839061] r7 : c145be18 r6 : c145ea80 r5 : c1c03690 r4 : c1c0368c
[ 15.846285] r3 : 07e007e0 r2 : c14b5adc r1 : c145be18 r0 : c1c0368c
[ 15.853512] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 15.861409] Control: 0005317f Table: 814b0000 DAC: 00000015
[ 15.867765]
[ 15.867765] PC: 0xc030e10c:
[ 15.872489] e10c e1a03000 e3a02000 e1030092 e3500000 a89da800 e1032090 e1c20fc2 e89da800
[ 15.881578] e12c e1a0c00d e92dd800 e24cb004 e3a02001 e1003092 e3530000 089da800 ebffffe3
[ 15.890670] e14c e89da800 e1a0c00d e92dd870 e24cb004 e24dd014 e1a0200d e3c23d7f e3c3303f
[ 15.899759] e16c e593600c e1a04000 e5903008 e24b2028 e2805004 e50b3024 e5802008 e50b5028
[ 15.908850] e18c e5832000 e5903000 e50b6020 e3530000 ba000003 e3e02000 e1003092 e3530001
[ 15.917937] e1ac 0a00000a e5943000 e3530000 ba000003 e3e02000 e1043092 e3530001 0a000003
[ 15.927023] e1cc e3a03002 e5863000 eb000522 eafffff4 e51b3024 e51b2028 e5823004 e5832000
[ 15.936113] e1ec e5943004 e1530005 03a03000 05843000 e24bd018 e89da870 e1a0c00d e92dd870
[ 15.945210]
[ 15.945210] LR: 0xc030e40c:
[ 15.949932] e40c e89da818 e1a0c00d e92dd818 e24cb004 e1a04000 eb00031b e3a00000 e1043090
[ 15.959024] e42c e3530001 089da818 e3e02000 e1043092 e3530001 089da818 e1a00004 ebffffa8
[ 15.968113] e44c e89da818 e1a0c00d e92dd818 e24cb004 e1a04000 eb00030b e3a02000 e1043092
[ 15.977203] e46c e3530001 089da818 e3e02000 e1043092 e3530001 089da818 e1a00004 ebffff30
[ 15.986294] e48c e89da818 e1a0c00d e92dd9f0 e24cb004 e24dd00c e1a0200d e3c23d7f e3c3303f
[ 15.995383] e4ac e1a08001 e593100c e1a06000 ebf4b5f2 e1a0300d e3c37d7f e3c7703f e597300c
[ 16.004465] e4cc e3a02001 e5832000 e1c641d8 e1c621d0 e0522004 e0c33005 e58d2000 e1a03005
[ 16.013553] e4ec e1a00006 e1a02004 e58d8004 ebf4b83f e5963028 e3530000 05863030 e5963030
[ 16.022648]
[ 16.022648] SP: 0xc14b5a58:
[ 16.027370] 5a58 00000000 00000001 c04ff4fc 00000000 c0492e60 c030e18c 80000013 ffffffff
[ 16.036460] 5a78 c14b5ac4 c145be18 c14b5b04 c14b5a90 c000f538 c000a1a0 c1c0368c c145be18
[ 16.045558] 5a98 c14b5adc 07e007e0 c1c0368c c1c03690 c145ea80 c145be18 c145be18 00000015
[ 16.054652] 5ab8 00008000 c14b5b04 c14b5b08 c14b5ad8 c030e48c c030e18c 80000013 ffffffff
[ 16.063736] 5ad8 bea25000 c1c03690 07e007e0 c14b5af0 c007b140 c1c0368c c1c0366c c14c51e0
[ 16.072832] 5af8 c14b5b1c c14b5b08 c030e48c c030e160 00000000 c1c0368c c14b5b3c c14b5b20
[ 16.081924] 5b18 c007edb8 c030e460 c145bdc0 00002000 c14b5b78 00000000 c14b5b74 c14b5b40
[ 16.091010] 5b38 c0079e7c c007ed9c c14b5b74 c14b5b50 c007b974 c1a1e300 c145be18 00000000
[ 16.100094]
[ 16.100094] IP: 0xc14b5a88:
[ 16.104818] 5a88 c000f538 c000a1a0 c1c0368c c145be18 c14b5adc 07e007e0 c1c0368c c1c03690
[ 16.113909] 5aa8 c145ea80 c145be18 c145be18 00000015 00008000 c14b5b04 c14b5b08 c14b5ad8
[ 16.123000] 5ac8 c030e48c c030e18c 80000013 ffffffff bea25000 c1c03690 07e007e0 c14b5af0
[ 16.132094] 5ae8 c007b140 c1c0368c c1c0366c c14c51e0 c14b5b1c c14b5b08 c030e48c c030e160
[ 16.141182] 5b08 00000000 c1c0368c c14b5b3c c14b5b20 c007edb8 c030e460 c145bdc0 00002000
[ 16.150272] 5b28 c14b5b78 00000000 c14b5b74 c14b5b40 c0079e7c c007ed9c c14b5b74 c14b5b50
[ 16.159364] 5b48 c007b974 c1a1e300 c145be18 00000000 c1a1e33c 00000000 00000015 00000001
[ 16.168459] 5b68 c14b5bdc c14b5b78 c00802a0 c0079e50 c1a1e300 00000001 00000000 00000000
[ 16.177547]
[ 16.177547] FP: 0xc14b5a84:
[ 16.182270] 5a84 c14b5a90 c000f538 c000a1a0 c1c0368c c145be18 c14b5adc 07e007e0 c1c0368c
[ 16.191365] 5aa4 c1c03690 c145ea80 c145be18 c145be18 00000015 00008000 c14b5b04 c14b5b08
[ 16.200452] 5ac4 c14b5ad8 c030e48c c030e18c 80000013 ffffffff bea25000 c1c03690 07e007e0
[ 16.209538] 5ae4 c14b5af0 c007b140 c1c0368c c1c0366c c14c51e0 c14b5b1c c14b5b08 c030e48c
[ 16.218625] 5b04 c030e160 00000000 c1c0368c c14b5b3c c14b5b20 c007edb8 c030e460 c145bdc0
[ 16.227721] 5b24 00002000 c14b5b78 00000000 c14b5b74 c14b5b40 c0079e7c c007ed9c c14b5b74
[ 16.236805] 5b44 c14b5b50 c007b974 c1a1e300 c145be18 00000000 c1a1e33c 00000000 00000015
[ 16.245895] 5b64 00000001 c14b5bdc c14b5b78 c00802a0 c0079e50 c1a1e300 00000001 00000000
[ 16.254987]
[ 16.254987] R0: 0xc1c0360c:
[ 16.259711] 360c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.268803] 362c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.277896] 364c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.286991] 366c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.296081] 368c ffffffff 07e007e0 c14b5adc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.305173] 36ac 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.314265] 36cc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.323356] 36ec 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.332454]
[ 16.332454] R1: 0xc145bd98:
[ 16.337177] bd98 00000000 00000000 00000000 c14a8828 c14a8828 c1489580 00000000 000000b4
[ 16.346269] bdb8 00000000 00000000 000b3000 000b4000 c145bd68 c145be18 c145bb10 c145bd78
[ 16.355357] bdd8 c145be28 0160a000 c1a1e300 0000018b 00100877 c145b0dd c14d58c4 c14a9b84
[ 16.364445] bdf8 000000a3 c14a8728 c14a8728 c14894a0 c03144e0 000000a3 c14c51e0 00000000
[ 16.373531] be18 00008000 000ab000 c145bdc0 00000000 c145bdd1 00000000 00000000 00008000
[ 16.382616] be38 c1a1e300 0000018b 00000875 c145b0dd c14d586c c14a95ac 000000a2 c145be54
[ 16.391708] be58 c145be54 00000000 c03144e0 00000000 c14c51e0 00000000 bea66000 bea88000
[ 16.400796] be78 00000000 c14d5160 c14a9699 00000000 c14d5170 07b42000 c1a1e780 0000038b
[ 16.409888]
[ 16.409888] R2: 0xc14b5a5c:
[ 16.414612] 5a5c 00000001 c04ff4fc 00000000 c0492e60 c030e18c 80000013 ffffffff c14b5ac4
[ 16.423703] 5a7c c145be18 c14b5b04 c14b5a90 c000f538 c000a1a0 c1c0368c c145be18 c14b5adc
[ 16.432791] 5a9c 07e007e0 c1c0368c c1c03690 c145ea80 c145be18 c145be18 00000015 00008000
[ 16.441877] 5abc c14b5b04 c14b5b08 c14b5ad8 c030e48c c030e18c 80000013 ffffffff bea25000
[ 16.450960] 5adc c1c03690 07e007e0 c14b5af0 c007b140 c1c0368c c1c0366c c14c51e0 c14b5b1c
[ 16.460054] 5afc c14b5b08 c030e48c c030e160 00000000 c1c0368c c14b5b3c c14b5b20 c007edb8
[ 16.469142] 5b1c c030e460 c145bdc0 00002000 c14b5b78 00000000 c14b5b74 c14b5b40 c0079e7c
[ 16.478232] 5b3c c007ed9c c14b5b74 c14b5b50 c007b974 c1a1e300 c145be18 00000000 c1a1e33c
[ 16.487321]
[ 16.487321] R4: 0xc1c0360c:
[ 16.492045] 360c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.501141] 362c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.510237] 364c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.519326] 366c 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.528416] 368c ffffffff 07e007e0 c14b5adc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.537505] 36ac 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.546593] 36cc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.555680] 36ec 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.564776]
[ 16.564776] R5: 0xc1c03610:
[ 16.569500] 3610 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.578594] 3630 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.587683] 3650 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.596774] 3670 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 ffffffff
[ 16.605862] 3690 07e007e0 c14b5adc 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.614956] 36b0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.624041] 36d0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.633134] 36f0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0 07e007e0
[ 16.642223]
[ 16.642223] R6: 0xc145ea00:
[ 16.646947] ea00 00000000 00000000 00000000 00000000 00000001 00000002 c145ea18 c145ea18
[ 16.656037] ea20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 16.665119] ea40 00000000 00000000 c145ea48 c145ea48 00000000 00000000 00000000 00000000
[ 16.674198] ea60 00000000 00000000 00000000 00000020 00000000 0000c350 0000c350 00000000
[ 16.683284] ea80 00000000 c14b4000 00000002 00400104 00000000 00000001 00000078 00000078
[ 16.692368] eaa0 00000078 00000000 c0313e9c 00000000 00000400 00400000 c145f298 00000000
[ 16.701458] eac0 00000000 c145eac4 c145eac4 00000001 acd511bf 00000003 4802d6a8 00000000
[ 16.710544] eae0 11eeade6 00000001 4753ce3a 00000000 00000000 00000000 c145eaf8 c145eaf8
[ 16.719636]
[ 16.719636] R7: 0xc145bd98:
[ 16.724360] bd98 00000000 00000000 00000000 c14a8828 c14a8828 c1489580 00000000 000000b4
[ 16.733446] bdb8 00000000 00000000 000b3000 000b4000 c145bd68 c145be18 c145bb10 c145bd78
[ 16.742533] bdd8 c145be28 0160a000 c1a1e300 0000018b 00100877 c145b0dd c14d58c4 c14a9b84
[ 16.751622] bdf8 000000a3 c14a8728 c14a8728 c14894a0 c03144e0 000000a3 c14c51e0 00000000
[ 16.760712] be18 00008000 000ab000 c145bdc0 00000000 c145bdd1 00000000 00000000 00008000
[ 16.769804] be38 c1a1e300 0000018b 00000875 c145b0dd c14d586c c14a95ac 000000a2 c145be54
[ 16.778897] be58 c145be54 00000000 c03144e0 00000000 c14c51e0 00000000 bea66000 bea88000
[ 16.787984] be78 00000000 c14d5160 c14a9699 00000000 c14d5170 07b42000 c1a1e780 0000038b
[ 16.797075]
[ 16.797075] R8: 0xc145bd98:
[ 16.801799] bd98 00000000 00000000 00000000 c14a8828 c14a8828 c1489580 00000000 000000b4
[ 16.810886] bdb8 00000000 00000000 000b3000 000b4000 c145bd68 c145be18 c145bb10 c145bd78
[ 16.819976] bdd8 c145be28 0160a000 c1a1e300 0000018b 00100877 c145b0dd c14d58c4 c14a9b84
[ 16.829066] bdf8 000000a3 c14a8728 c14a8728 c14894a0 c03144e0 000000a3 c14c51e0 00000000
[ 16.838159] be18 00008000 000ab000 c145bdc0 00000000 c145bdd1 00000000 00000000 00008000
[ 16.847246] be38 c1a1e300 0000018b 00000875 c145b0dd c14d586c c14a95ac 000000a2 c145be54
[ 16.856338] be58 c145be54 00000000 c03144e0 00000000 c14c51e0 00000000 bea66000 bea88000
[ 16.865422] be78 00000000 c14d5160 c14a9699 00000000 c14d5170 07b42000 c1a1e780 0000038b
[ 16.874522] Process syslogd (pid: 50, stack limit = 0xc14b41b8)
[ 16.881074] Stack: (0xc14b5ad8 to 0xc14b6000)
[ 16.886285] 1d20: c14feaa8 c14e1dd8
[ 16.895524] 1d40: 00000fff 07e007e0 c14feaa8 c1a80820 000000e6 c1c050ec 00000000 000000a8
[ 16.904673] 1d60: c14feaa8 c14e1dc4 c14e1dc8 c14e1d80 c007960c c0063d50 60000013 ffffffff
[ 16.913739] r8:00000000 r7:c14e1d6c r6:ffffffff r5:60000013 r4:c0063d50
[ 16.921336] [<c0063d20>] (filemap_fault+0x0/0x39c) from [<c007960c>] (__do_fault+0xa8/0x448)
[ 16.930808] [<c0079564>] (__do_fault+0x0/0x448) from [<c007c4e8>] (handle_pte_fault+0x278/0x5fc)
[ 16.940652] [<c007c270>] (handle_pte_fault+0x0/0x5fc) from [<c007c924>] (handle_mm_fault+0xb8/0xcc)
[ 16.950763] [<c007c86c>] (handle_mm_fault+0x0/0xcc) from [<c0016c18>] (do_page_fault+0x128/0x278)
[ 16.960670] [<c0016af0>] (do_page_fault+0x0/0x278) from [<c0016e00>] (do_translation_fault+0x24/0xbc)
[ 16.970950] [<c0016ddc>] (do_translation_fault+0x0/0xbc) from [<c000a26c>] (do_PrefetchAbort+0x3c/0xa0)
[ 16.981399] r8:b6fbde00 r7:c14e1fb0 r6:b6f239ac r5:c046af70 r4:00000005
r3:c0016ddc
[ 16.990206] [<c000a230>] (do_PrefetchAbort+0x0/0xa0) from [<c000f898>] (ret_from_exception+0x0/0x10)
[ 17.000389] Exception stack(0xc14e1fb0 to 0xc14e1ff8)
[ 17.006066] 1fa0: b6f96cb0 b6f80e08 b6f80e18 fffffff8
[ 17.015200] 1fc0: 00000004 b6fbb658 00000001 bee3bcd8 b6fbde00 b6f96adc 00000000 bee3bd4c
[ 17.024273] 1fe0: 00000000 bee3bcc0 b6f867d0 b6f239ac a0000010 ffffffff
[ 17.031642] r7:bee3bcd8 r6:ffffffff r5:a0000010 r4:b6f239ac
[ 17.038023] Code: e2805004 e50b3024 e5802008 e50b5028 (e5832000)
[ 17.044848] ---[ end trace fcf66e4c308589cb ]---
[ 17.049976] Fixing recursive fault but reboot is needed!
[ 17.055942] 5ac0: bea25000 c1c03690
[ 17.065072] 5ae0: 07e007e0 c14b5af0 c007b140 c1c0368c c1c0366c c14c51e0 c14b5b1c c14b5b08
[ 17.074161] 5b00: c030e48c c030e160 00000000 c1c0368c c14b5b3c c14b5b20 c007edb8 c030e460
[ 17.083287] 5b20: c145bdc0 00002000 c14b5b78 00000000 c14b5b74 c14b5b40 c0079e7c c007ed9c
[ 17.092402] 5b40: c14b5b74 c14b5b50 c007b974 c1a1e300 c145be18 00000000 c1a1e33c 00000000
[ 17.101518] 5b60: 00000015 00000001 c14b5bdc c14b5b78 c00802a0 c0079e50 c1a1e300 00000001
[ 17.110633] 5b80: 00000000 00000000 ffffffff c14b5b98 c0040a4c 00000090 00000400 c149e000
[ 17.119741] 5ba0: c14b5bbc c14b5bb0 c030f0cc c1a1e33c c145ea80 c1907980 c14b5bd4 c14b5bc8
[ 17.128849] 5bc0: c003cd38 c1a1e300 00000000 00000000 c14b5bf4 c14b5be0 c001a808 c00801cc
[ 17.137960] 5be0: c145ea80 c1a1e300 c14b5c14 c14b5bf8 c00212d8 c001a7d0 c14b5c14 c14b5c08
[ 17.147078] 5c00: c001ca18 c14b5c5a c14b5c8c c14b5c18 c0013a08 c0020fcc c14b41b8 0000000b
[ 17.156203] 5c20: 60000013 00000008 65010000 33306431 20326230 33313365 31303030 30613120
[ 17.165319] 5c40: 30303030 35652038 30333039 28203831 33393565 38303033 c0002029 c030dab8
[ 17.174395] 5c60: c03e3113 07e007e8 00000005 c1a1e300 c14b5dd0 00000000 00010000 00000005
[ 17.183509] 5c80: c14b5cb4 c14b5c90 c0016ad0 c00136d4 c14b5dd0 07e007e8 c14b5dd0 c145ea80
[ 17.192623] 5ca0: 00000028 c1a1e300 c14b5cf4 c14b5cb8 c0016d50 c0016a74 c14b5cdc c14b5cc8
[ 17.201734] 5cc0: 00000000 c1a1e33c 00000000 00000005 00000005 07e007e8 c046af20 c14b5dd0
[ 17.210843] 5ce0: c14b4000 00000041 c14b5d1c c14b5cf8 c0016e00 c0016b00 c0016ddc 00000005
[ 17.219960] 5d00: 00000005 07e007e8 c046af20 c14b5dd0 c14b5dcc c14b5d20 c000a1c8 c0016dec
[ 17.229087] 5d20: 00000000 c14e2180 c14b5dec c14b5e70 c14b5d4c c14b5d40 c0267e84 c008e1ec
[ 17.238213] 5d40: c14b5d64 c14b5d50 c02687bc c0267e2c c14e2180 c14b5dec c14b5d7c c14b5d68
[ 17.247328] 5d60: c04686ec c14e2180 c14b5dec c14b5e70 c14b5d94 c14b5d80 c02688cc c008e308
[ 17.256443] 5d80: 00000001 c1905000 c14b5da4 c14b5d98 c026895c c0268828 c14b5dbc c14b5da8
[ 17.265553] 5da0: c026bef4 c0268920 00000000 c009a8a8 60000013 ffffffff c14b5e04 c14b5f60
[ 17.274661] 5dc0: c14b5e24 c14b5dd0 c000f538 c000a1a0 c1c03038 00000081 07e007e0 07e007e0
[ 17.283737] 5de0: c14b5ee0 00000076 c14a3011 00000000 c14b5f60 c14b4000 00000041 c14b5e24
[ 17.292852] 5e00: c14b5e28 c14b5e18 c009a92c c009a8a8 60000013 ffffffff c14b5e34 c14b5e28
[ 17.301975] 5e20: c009a92c c009a888 c14b5e84 c14b5e38 c009a974 c009a8e8 c14b5e64 c14b5e48
[ 17.311097] 5e40: c008e974 c008e9a8 c14b5e84 c14b5e58 c009b23c c003f974 c14b5e84 c14b5e68
[ 17.320224] 5e60: c14b5ee0 c1a80d20 c14a3000 00000000 c14b5f60 00000041 c14b5ed4 c14b5e88
[ 17.329340] 5e80: c009d870 c009a940 c14b5ea4 c14b5ec0 c1a801e0 000000ff c1820f00 c14b5f78
[ 17.338454] 5ea0: 00000000 00000000 c14b5f44 c14b5f60 00000001 ffffff9c c14a3000 c000faa8
[ 17.347566] 5ec0: c14b4000 00000000 c14b5f54 c14b5ed8 c009dec4 c009d7f4 00000041 00000000
[ 17.356678] 5ee0: c1820790 c1c00088 c14b5f1c c14b5ef8 00000000 c19fecc0 c1820790 c1c00088
[ 17.365793] 5f00: c1c03038 00001051 00000002 00000001 00000000 c00a7940 00020d41 00020d41
[ 17.374915] 5f20: ffffff9c c14a3000 00000001 c000faa8 c14b4000 00000000 00000004 ffffff9c
[ 17.384002] 5f40: c14a3000 00000001 c14b5f94 c14b5f58 c0090b20 c009dea0 c14b4000 00000000
[ 17.393112] 5f60: 00020d41 c14b81b6 0000002a 00000300 000a1be4 016c0008 0000000c 00000005
[ 17.402222] 5f80: c000faa8 00000000 c14b5fa4 c14b5f98 c0090bd8 c0090a44 00000000 c14b5fa8
[ 17.411332] 5fa0: c000f920 c0090bbc 000a1be4 016c0008 000a1be4 00020d41 000001b6 00000000
[ 17.420442] 5fc0: 000a1be4 016c0008 0000000c 00000005 000b3800 00000000 00000085 bea25cac
[ 17.429549] 5fe0: 000b33fc bea25bf8 00041594 b6f1d4b4 60000010 000a1be4 00000000 00000000
[ 17.438639] Backtrace:
[ 17.441424] [<c030e150>] (__mutex_lock_slowpath+0x0/0xb4) from [<c030e48c>] (mutex_lock+0x3c/0x40)
[ 17.451407] r6:c14c51e0 r5:c1c0366c r4:c1c0368c
[ 17.456647] [<c030e450>] (mutex_lock+0x0/0x40) from [<c007edb8>] (unlink_file_vma+0x2c/0x48)
[ 17.466038] r4:c1c0368c r3:00000000
[ 17.470067] [<c007ed8c>] (unlink_file_vma+0x0/0x48) from [<c0079e7c>] (free_pgtables+0x3c/0xb0)
[ 17.479740] r7:00000000 r6:c14b5b78 r5:00002000 r4:c145bdc0
[ 17.486132] [<c0079e40>] (free_pgtables+0x0/0xb0) from [<c00802a0>] (exit_mmap+0xe4/0x208)
[ 17.495358] [<c00801bc>] (exit_mmap+0x0/0x208) from [<c001a808>] (mmput+0x48/0xd0)
[ 17.503743] r6:00000000 r5:00000000 r4:c1a1e300
[ 17.508974] [<c001a7c0>] (mmput+0x0/0xd0) from [<c00212d8>] (do_exit+0x31c/0x7e0)
[ 17.517315] r5:c1a1e300 r4:c145ea80
[ 17.521331] [<c0020fbc>] (do_exit+0x0/0x7e0) from [<c0013a08>] (die+0x344/0x394)
[ 17.529569] r7:c14b5c5a
[ 17.532409] [<c00136c4>] (die+0x0/0x394) from [<c0016ad0>] (__do_kernel_fault+0x6c/0x8c)
[ 17.541428] [<c0016a64>] (__do_kernel_fault+0x0/0x8c) from [<c0016d50>] (do_page_fault+0x260/0x278)
[ 17.551482] r8:c1a1e300 r7:00000028 r6:c145ea80 r5:c14b5dd0 r4:07e007e8
r3:c14b5dd0
[ 17.560283] [<c0016af0>] (do_page_fault+0x0/0x278) from [<c0016e00>] (do_translation_fault+0x24/0xbc)
[ 17.570567] [<c0016ddc>] (do_translation_fault+0x0/0xbc) from [<c000a1c8>] (do_DataAbort+0x38/0xa0)
[ 17.580616] r8:c14b5dd0 r7:c046af20 r6:07e007e8 r5:00000005 r4:00000005
r3:c0016ddc
[ 17.589438] [<c000a190>] (do_DataAbort+0x0/0xa0) from [<c000f538>] (__dabt_svc+0x38/0x60)
[ 17.598554] Exception stack(0xc14b5dd0 to 0xc14b5e18)
[ 17.604189] 5dc0: c1c03038 00000081 07e007e0 07e007e0
[ 17.613310] 5de0: c14b5ee0 00000076 c14a3011 00000000 c14b5f60 c14b4000 00000041 c14b5e24
[ 17.622425] 5e00: c14b5e28 c14b5e18 c009a92c c009a8a8 60000013 ffffffff
[ 17.629790] r8:c14b5f60 r7:c14b5e04 r6:ffffffff r5:60000013 r4:c009a8a8
[ 17.637352] [<c009a878>] (__inode_permission+0x0/0x60) from [<c009a92c>] (inode_permission+0x54/0x58)
[ 17.647626] [<c009a8d8>] (inode_permission+0x0/0x58) from [<c009a974>] (link_path_walk+0x44/0x764)
[ 17.657615] [<c009a930>] (link_path_walk+0x0/0x764) from [<c009d870>] (path_openat.clone.52+0x8c/0x3fc)
[ 17.668091] [<c009d7e4>] (path_openat.clone.52+0x0/0x3fc) from [<c009dec4>] (do_filp_open+0x34/0x80)
[ 17.678288] [<c009de90>] (do_filp_open+0x0/0x80) from [<c0090b20>] (do_sys_open+0xec/0x178)
[ 17.687572] r7:00000001 r6:c14a3000 r5:ffffff9c r4:00000004
[ 17.693915] [<c0090a34>] (do_sys_open+0x0/0x178) from [<c0090bd8>] (SyS_open+0x2c/0x30)
[ 17.702857] [<c0090bac>] (SyS_open+0x0/0x30) from [<c000f920>] (ret_fast_syscall+0x0/0x2c)
[ 17.712067] Code: e2805004 e50b3024 e5802008 e50b5028 (e5832000)
[ 17.718871] ---[ end trace fcf66e4c308589cc ]---
[ 17.723989] Fixing recursive fault but reboot is needed!离线
楼主你好,请问如何运行官方SDK中的示例程序
编译已经成功,系统可以跑起来
折腾不动了。。。
在uboot源码目录下 进入 ./include/configs/
修改 suniv.h¶
#define CONFIG_BOOTCOMMAND "sf probe 0:50000000; " \
"sf read 0x80C00000 0x100000 0x4000; " \
"sf read 0x80008000 0x110000 0x400000; " \
"bootz 0x80008000 - 0x80C00000"
suniv.h这样改会报错:
Failed to initialize SPI flash at 0:50000000 (error -2)
把sf probe 0:50000000 改为 sf probe 0 时:
不会报错了,但SPI读取速度超慢,sf read 0x80008000 0x110000 0x400000这条命令读完要5分钟!!!
把sf probe 0:50000000 改为 sf probe 0 50000000时:
不会报错了,SPI读取速度也正常了,可以启动linux了。
对, 这个是官方文档的坑, 一直都没有填
dd if=/dev/zero of=flashimg.bin bs=1M count=16 &&\
dd if=$YOUR_UBOOT_FILE of=flashimg.bin bs=1K conv=notrunc &&\
dd if=$YOUR_DTB_FILE of=flashimg.bin bs=1K seek=1024 conv=notrunc &&\
dd if=$YOUR_KERNEL_FILE of=flashimg.bin bs=1K seek=1088 conv=notrunc &&\
mkdir rootfs
tar -xzvf $YOUR_ROOTFS_FILE -C ./rootfs &&\
cp -r $YOUR_MOD_FILE rootfs/lib/modules/ &&\
# 为根文件系统制作jffs2镜像包
# --pad参数指定 jffs2大小
# 由此计算得到 0x1000000(16M)-0x10000(64K)-0x100000(1M)-0x400000(4M)=0xAF0000
mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o jffs2.img &&\
dd if=jffs2.img of=$YOUR_IMG_FILE bs=1K seek=5184 conv=notrunc &&\@晕哥 cp -r $YOUR_MOD_FILE rootfs/lib/modules/ YOUR_MOD_FILE这个是什么文件? 做启动文件系统需要用这个吗?
同问 这个是什么文件啊
同问 这个是什么文件啊
@晕哥
$YOUR_MOD_FILE 即目录下所有的 .ko 文件, 上面这个命令不好, 用 make modules_install 命令更好:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- INSTALL_MOD_PATH=/media/whycan/c3e8d3c2 make modules_install
假设/media/whycan/c3e8d3c2是你的文件系统目录.
这个目录指的是下载的根文件系统目录吗?
会报错make: *** 没有规则可制作目标“modules_install”。 停止。
运行的目录是Linux源码所在的目录。
如果当前目录不是 Linux源码目录,可以用 -C 参数指定就行:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- INSTALL_MOD_PATH=/media/whycan/c3e8d3c2 make -C /opt/linux modules_install
想请教下,bsp linux中,对应buildroot和linux kernel的menuconfig 配置 应该怎么配置呢?直接去buildroot文件夹里面和kernel里面 make menuconfig吗?好像不大对
感觉我和晕哥用的是一个buildroot,晕哥有没有编译buildroot的时候遇到过这种情况,就是,不论你的.config配置是什么,最后一定会编译,mpfr,mpc,还有各种automake,autoconf,lzo,然后我就连环出错了,之前瞎搞弄好了,然后删掉之前的重新打包又开始这样
我知道是什么问题了。。。因为我勾选了其他的文件系统,然后其他文件系统自动链接了其他的配置
所以到底我应该从哪里找到f1c100s的bsp 楼上各位大佬..跪求帮助.
他可能后来删了:
git clone https://github.com/qq516333132/c600.git
这个是荔枝派很早以前分享的文件: f1c600.tar.bz2
md5: d7ba43ff533948d6cd0455cf6f742a10
crc32: 1fc536dd
那个问题后来解决了。
现在是用全志官方软件根本烧不进去,
换几台电脑都不行,
一开始能烧进去的 img 现在换了5台都不行。https://whycan.cn/files/members/3/165923gsascz2dhd2tadmv.png
现在改用开源的 sunxi-fel, 一点问题都没有。
自己处理烧写地址问题.
你好,我现在出现一样的问题,请问 能否指点一下怎么处理?
盼复,谢谢。
接上串口,u-boot有错误信息输出的。
只提示fes1 init end就没有别的log了……
用 https://whycan.cn/t_1008.html
里面的源码包编译通过了
这个源码包你还有不? 原帖的链接失效了。
I have compiled, but the lcd is not working
480*272
here is serial log, sys_config.fex, sunivw1p1-pinctrl.dtsi and sunivw1p1smp_defconfig
https://whycan.cn/files/members/2525/serial_log.txt
https://whycan.cn/files/members/2525/sunivw1p1_dtsi.txt
https://whycan.cn/files/members/2525/sunivw1p1-pinctrl_dtsi.txt
https://whycan.cn/files/members/2525/sys_config_fex.txt
please check it i am confused ...
最近编辑记录 Biftor (2019-12-14 18:09:28)
改 sys_config.fex 的这部分:
lcd_x = 800
lcd_y = 480改为:
lcd_x = 480
lcd_y = 272
I did it,
but same result no lcd
also i did clean build too .
https://whycan.cn/files/members/2525/sys_config_fex_20191214-1828.txt
最近编辑记录 Biftor (2019-12-14 18:28:43)
lcd_used = 1
lcd_used = 0
still no lcd (it is only back light white)
./build clean
./build
./build pack
https://whycan.cn/files/members/2525/sys_config_fex_20191214-1840.txt
最近编辑记录 Biftor (2019-12-14 18:42:20)
参考@晕哥另外一个帖子: https://whycan.cn/t_1522.html
I have tried that too, i got same result .
the lcd is working when i follow
nano.lichee.pro .
but that Kernel linux not support video/audio hardware driver.
with
https://github.com/Icenowy/linux/tree/f1c100s-480272lcd-test
or kernel 4.14.0
https://github.com/steward-fu/lichee-nano/releases/download/v1.0/kernel.tar.gz
lcd is ok.
but with c600 from original repository (https://github.com/mirkerson/c600.git) or this repository https://bitbucket.org/qq516333132/c600.git
the LCD not working .
thanks
ok i will try this one too.
I tried it but failed.
git lfs clone https://github.com/qq516333132/c600.git
first i didn't touch just build
./build.sh config
./build.sh
./build.sh pack
no LCD .
i did
lcd_x = 480
lcd_y = 272no LCD.
lcd_used = 0no LCD.
and finally applied them
no LCD.
what should i do???
@Biftor 不可能啊, 我的都可以, https://whycan.cn/t_1522.html#p8133
要不你先烧上面的固件试一试, 需要 spi nor flash
tell me exactly which spi flash or nor flash i have to buy?
i have winbond 25064fvsig that is 8mb .
不太记得了, 可能是 MX25L128, 但是你最好买 MX25L256, 比较保险.
unfortunately this one is not available here.
i have to order it from China.
i found it
W25Q256JVEIQ
is it okay?
应该可以, 不完全确定.
as what you said, I bought W25Q256JVEIQ and soldered.
I tried this https://whycan.cn/t_1008.html#p4839
sunxi-fel.exe -p spiflash-write 0 file.binIt is working lcd is working and showing the
U-Boot SPL 2018.01-05676-g0018878-dirty (Apr 19 2018 - 20:06:23)
DRAM: 32 MiB
Trying to boot from sunxi SPI
U-Boot 2018.01-05676-g0018878-dirty (Apr 19 2018 - 20:06:23 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected w25q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
device 0 offset 0x100000, size 0x250000
SF: 2424832 bytes @ 0x100000 Read: OK
device 0 offset 0x350000, size 0x7000
SF: 28672 bytes @ 0x350000 Read: OK
reserving fdt memory region: addr=81000000 size=10000
Loading Device Tree to 80e5e000, end 80e679f0 ... OK
Read dt_phys 80e5e000
Read devtree c0e5e000
Read dt_root 0xc0489028d00dfeed
[ 0.000000] Linux version 3.10.65 (lq@assert) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #583 Thu Apr 26 15:02:26 CST 2018
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000]
[ 0.000000] Read dt_phys 80e5e000
[ 0.000000] Read devtree c0e5e000
[ 0.000000]
[ 0.000000] Read dt_root 0xc0489028d00dfeed
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sunivw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: ECC disabled, Data cache writethrough
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: earlyprintk panic=5 rootwait root=31:03 rw rootfstype=jffs2 init=/linuxrc console=ttyS0,115200
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Memory: 32MB = 32MB total
[ 0.000000] Memory: 27656k/27656k available, 5112k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0xc0008000 - 0xc041efdc (4188 kB)
[ 0.000000] .init : 0xc041f000 - 0xc043e0b4 ( 125 kB)
[ 0.000000] .data : 0xc0440000 - 0xc0471e60 ( 200 kB)
[ 0.000000] .bss : 0xc0471e60 - 0xc048ce48 ( 108 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=528000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.005448] Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
[ 0.075313] pid_max: default: 32768 minimum: 301
[ 0.080529] Mount-cache hash table entries: 512
[ 0.087329] CPU: Testing write buffer coherency: ok
[ 0.093430] Setting up static identity map for 0xc02f97f8 - 0xc02f9850
[ 0.104674] devtmpfs: initialized
[ 0.111472] pinctrl core: initialized pinctrl subsystem
[ 0.117401] NET: Registered protocol family 16
[ 0.124291] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.132278] dump_class_init,821, success
[ 0.144827] sunivw1p1-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.168921] No ATAGs?
[ 0.184077] bio: create slab <bio-0> at 0
[ 0.191868] SCSI subsystem initialized
[ 0.196419] usbcore: registered new interface driver usbfs
[ 0.202316] usbcore: registered new interface driver hub
[ 0.208382] usbcore: registered new device driver usb
[ 0.215103] Advanced Linux Sound Architecture Driver Initialized.
[ 0.225403] cfg80211: Calling CRDA to update world regulatory domain
[ 0.232528] [pm]aw_pm_init!
[ 0.235730] [pm]aw_pm_valid!
[ 0.238706] Notice: sunivw1p1 just support normal standby.
[ 0.244369] [pm]aw_pm_valid!
[ 0.247351] Notice: sunivw1p1 just support normal standby.
[ 0.253575] Switching to clocksource suniv high-res couter
[ 0.311709] codec_config
[ 0.314522] (null).sta33x_pwrdn_gpio gpio=135,mul_sel=0,data:1
[ 0.320626] codec_config: sta33x_pwrdn_gpio gpio num=135
[ 0.326042] codec_request_gpio: test1
[ 0.329857] codec_request_gpio: request gpio=135
[ 0.334769] codec_request_gpio: L1167 Pin=1
[ 0.339093] codec_request_gpio: request gpio(135) ok
[ 0.360061] NET: Registered protocol family 2
[ 0.368748] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.375979] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.382564] TCP: Hash tables configured (established 512 bind 512)
[ 0.389294] TCP: reno registered
[ 0.392678] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.398676] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.406018] NET: Registered protocol family 1
[ 0.434271] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.441255] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.450114] msgmni has been set to 54
[ 0.458841] io scheduler noop registered
[ 0.463066] io scheduler deadline registered
[ 0.467563] io scheduler cfq registered (default)
[ 0.510190] sw_uart_request_gpio(753)
[ 0.514027] uart0: ttyS0 at MMIO 0x1c25000 (irq = 103) is a SUNXI
[ 0.520414] sw_console_setup()1175 - console setup baud 115200 parity n bits 8, flow n
[ 0.528464] console [ttyS0] enabled, bootconsole disabled
[ 0.541870] sw_uart_request_gpio(753)
[ 0.546012] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[ 0.554693] misc dump reg init
[ 0.564142] spi spi0: master is unqueued, this is deprecated
[ 0.572740] NorFlash ID: 0xef4019 - 0x0
[ 0.577087] m25p80 spi0.0: found w25q256, expected m25p64
[ 0.583473] m25p80 spi0.0: w25q256 (32768 Kbytes)
[ 0.602633] partitions_register()897 - Invalid partitions count: -1
[ 0.609733] partition_register: enter
[ 0.614881] Creating 4 MTD partitions on "(null)":
[ 0.620392] 0x000000000000-0x000000080000 : "spl+uboot"
[ 0.630359] 0x000000080000-0x0000002e0000 : "kernel"
[ 0.639853] 0x0000002e0000-0x0000002f0000 : "script"
[ 0.649175] 0x000000400000-0x000001000000 : "rootfs"
[ 0.659712] usbcore: registered new interface driver usb-storage
[ 0.667133] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.675269] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.688715] hub 1-0:1.0: USB hub found
[ 0.693186] hub 1-0:1.0: 1 port detected
[ 0.700286] support report repeat key value.
[ 0.706120] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.714762] i2c /dev entries driver
[ 0.721297] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.30 2015-10-10 10:03) Compiled in Apr 23 2018 at 21:07:18
[ 0.734653] sunxi-mmc 1c0f000.sdmmc: Can't get vmmc regulator string
[ 0.741837] sunxi-mmc 1c0f000.sdmmc: Can't get vqmmc regulator string
[ 0.749032] sunxi-mmc 1c0f000.sdmmc: Can't get vdmmc regulator string
[ 0.756292] sunxi-mmc 1c0f000.sdmmc: Failed getting OCR mask: 0
[ 0.763849] sunxi-mmc 1c0f000.sdmmc: *******************set host ocr**************************
[ 0.774305] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.799378] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.829663] sunxi-mmc 1c0f000.sdmmc: base:0xf1c0f000 irq:110
[ 0.836036] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.843903] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 0.850975] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.867653] sunxi-codec-machine-i2s sound.6: ASoC: CPU DAI (null) not registered
[ 0.876045]
[ 0.876045] snd_soc_register_card failed -517
[ 0.883896] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 0.893788] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.907644] TCP: cubic registered
[ 0.911535] Initializing XFRM netlink socket
[ 0.917599] NET: Registered protocol family 17
[ 0.922685] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
[ 0.930186] VFP support v0.3:
[ 0.933508] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.940523] not present
[ 0.944249] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.952063] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.959758] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 0.966516] [LCD] lcd_module_init
[ 0.971355] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.978433] $s-$dxlssc100
[ 0.981563] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 0.988398] $s-$dxlssc100
[ 0.991415] $s-$dxlssc100
[ 0.995636] of_property_read_u32_array lcd0.lcd_bl_en_used fail
[ 1.002333] [DISP WRN] file:drivers/video/sunxi/disp/de_bsp/de/disp_lcd.c,line:499: lcd0.lcd_bl_en_used
[ 1.023169] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.030875] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 1.037698] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.050357] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 1, RTO !!
[ 1.057123] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.089261] $s-$dxlssc100
[ 1.670152] BSP_disp_layer_set_para: fb_format=0x0, yuv_ch=0
[ 1.683514] $s-$dxlssc100
[ 1.687250] sunxi-codec-machine-i2s sound.6: ASoC: CPU DAI (null) not registered
[ 1.695602]
[ 1.695602] snd_soc_register_card failed -517
[ 1.702246] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 1.712255] input: gpio_keys.7 as /devices/soc.0/gpio_keys.7/input/input1
[ 1.721131] sunxi-codec-machine-i2s sound.6: ASoC: CPU DAI (null) not registered
[ 1.729496]
[ 1.729496] snd_soc_register_card failed -517
[ 1.736409] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.743680] ALSA device list:
[ 1.746987] No soundcards found.
[ 1.751093] platform sound.6: Driver sunxi-codec-machine-i2s requests probe deferral
[ 7.031519] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 7.056422] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 7.065690] devtmpfs: mounted
[ 7.069984] Freeing unused kernel memory: 124K (c041f000 - c043e000)
start kernel end
Please press Enter to activate this console.
>>>00:00 #demox
The framebuffer device was opened successfully.
480x272, 32bpp
The framebuffer device was mapped to memory successfully.but as you see above there is no sound card.
[ 1.746987] No soundcards found.after that I tried this image you put here
https://whycan.cn/t_1522.html#p8073
sunxi-fel.exe -p spiflash-write 0 file.imgand i get this in loop in serial
DRAM: 32 MiB
DRAM: 32 MiB
Trying to boot from sunxi SPIwhat is your suggestion now?
thanks
最近编辑记录 Biftor (2019-12-16 16:39:27)
那个 img 文件是全志sdk打包的,不能用sunxi-fel烧录,要用全志官方的烧录软件烧录。
Do you mean PhoenixSuit ?
if yes then
I have tried
but it doesn't working
Just installed it from here https://whycan.cn/t_1522.html#p8073
short circuit pin 4 with GND
plug usb automatically started,
but it didn't get progress after 1 min it gives error
接上串口,看输出什么?
nothing
it doesn't work.
it boot old bin file i burnt to it.
just stuck on here for a min and then error
有几组串口都要试一下,或者打开 sys_comfig.fex 确认一下到底用哪组串口。
the problem is not Serial port or serial tools.
the problem is burn the img to device .
对,是这个问题,但是串口会显示更多错误信息。
Finally the PhoenixSuit worked and i have flashed this https://whycan.cn/t_1522.html#p8073 image, that you said
and again there is no lcd with this image too :-(
here is my flashing and boot log
https://whycan.cn/files/members/2525/serial_log_flash_startup.txt
also there is no sound driver with this image
[ 1.672162] ALSA device list:
[ 1.675575] No soundcards found.as what i said above in post number #135
https://whycan.cn/t_1014.html#p29941
that bin file,LCD worked well
最近编辑记录 Biftor (2019-12-17 14:20:42)
有没有 /dev/fb0 设备节点?
那试一试:
cat /dev/urandom > /dev/fb0
有没有 /dev/fb0 设备节点?
那试一试:
it shows nothing after while error
/ # cat /dev/urandom > /dev/fb0
cat: write error: No space left on deviceI have no idea why this one is working (i mentioned above this in this bin file, LCD working well)
is there anybody has its sources?
最近编辑记录 Biftor (2019-12-18 18:38:28)
他可能后来删了:
git clone https://github.com/qq516333132/c600.git这个是荔枝派很早以前分享的文件: f1c600.tar.bz2
crc32: 1fc536dd
is there any way to get this f1c600.tar.bz2 file?
the link is dead
想把调试串口,从 PE0 PE1 改为PA2 PA3 不知道怎么改
编译那个, linux 4 版本正常运行,
想编译这个, linux 3的版本,
提示如下错误,不知道怎么解决 ubuntu 版本是 18 64位的
Makefile:241: recipe for target 'autoconf.info' failed
make[3]: *** [autoconf.info] Error 1
make[3]: Leaving directory '/root/Documents/C600_Linux/out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65/doc'
Makefile:338: recipe for target 'install-recursive' failed
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory '/root/Documents/C600_Linux/out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65'
Makefile:653: recipe for target 'install' failed
make[1]: *** [install] Error 2
make[1]: Leaving directory '/root/Documents/C600_Linux/out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65'
package/Makefile.package.in:296: recipe for target '/root/Documents/C600_Linux/out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65/.stamp_host_installed' failed
make: *** [/root/Documents/C600_Linux/out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65/.stamp_host_installed] Error 2
make: Leaving directory '/root/Documents/C600_Linux/buildroot'
ERROR: build buildroot Failed
root@ubuntu:~/Documents/C600_Linux# apt-get install-recursive
E: Invalid operation install-recursive
root@ubuntu:~/Documents/C600_Linux# apt-get install recursive
Reading package lists... Done
Building dependency tree
Reading state information... Done
想编译这个, linux 3的版本,
我遇到的也是这个问题,是啥原因。
终于编译完成了
out/sunivw1p1/linux/common/buildroot/build/host-autoconf-2.65/doc/autoconf.texi
这个文件按照网上的回答,前面加减号不管用,直接把后面的@c删除就好了,又一个坑
最近编辑记录 bubailong (2020-05-02 14:42:11)
那个问题后来解决了。
现在是用全志官方软件根本烧不进去,
换几台电脑都不行,
自己处理烧写地址问题.
晕哥,你这个问题怎么解决的
beign to init dram
init dram ok dram_size = 64
--fas 1 run end---
U-Boot 2014.07 (Apr 07 2017 - 14:56:57) Allwinner Technology
uboot commit : b536a600941a03733bbba08d480dc3fbd57047bf
串口1只输出了这么多
接调试串口看输出信息.
sunivw1p1_linux_evb_uart0.img
我这编译生成的, 文件,有 30M, 烧不进 FLASH吧? FLASH只有 16M
晕哥我继续关注这教程 好久出一个撒? 那里面的硬解码有攻破么?
你搞掂好,硬件解码没有了?
懇求一个 f1c100s licheepi linux bsp lcd(800x480) 64M w25q128 SPI-NAND引导 有.config 的 u-boot 源码 (qt app)
beign to init dram
--fas 1 run end---U-Boot 2014.07 (Apr 07 2017 - 14:56:57) Allwinner Technology
串口1只输出了这么多
您好,镜像最终烧录进去了么?我也遇到了同样的问题。用串口0烧录没问题,但是修改了以下sys_confug.fex文件中的串口
然后烧录就成了这样,我用的是串口2
他可能后来删了:
crc32: 1fc536dd
为什么我用这个bsp里面编译好的sunivw1p1_linux_evb_uart0.img,自己也编译了一遍 ,烧录上去串口没有任何输出,好奇怪,板子确定是好的,用主线上的uboot正常
