楼主 # 2022-07-29 17:10:58
xboot
已发帖子: 675
RV1103/RV1106 裸奔日记
RV1103 / RV1106开始裸奔了,要搞定裸奔必须研究透RK的引导机制,经过一整天的深入研究,在没有任何TRM手册的情况下,搞定了RV1106的SPI NAND FLASH引导启动。
下面是启动日记
DDR Version V1.07 20220523
f947
F
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=13 CS=1 Die BW=16 Size=128MB
924MHz
DDR bin out
       _                   _
 _  _ | |___ _____ _____ _| |_
\ \/ /|  _  |  _  |  _  |_   _|  (C) 2007-2022
 )  ( | |_| | |_| | |_| | | |____JIANJUN.JIANG__
/_/\_\|_____|_____|_____| |_____________________|
V3.0.0 (Jul 29 2022 - 16:59:22) - [x1106][X1106 Based On RV1106 SOC]
[    0.000020]Probe device 'blk-romdisk.0' with blk-romdisk
[    0.000800]Probe device 'usbphy480m' with clk-fixed
[    0.000810]Probe device 'xin24m' with clk-fixed
[    0.000820]Probe device 'xin32k' with clk-fixed
[    0.000830]Probe device 'link-uart0' with clk-link
[    0.000840]Probe device 'link-uart1' with clk-link
[    0.000850]Probe device 'link-uart2' with clk-link
[    0.000860]Probe device 'link-uart3' with clk-link
[    0.000870]Probe device 'link-uart4' with clk-link
[    0.000880]Probe device 'link-uart5' with clk-link
[    0.000890]Probe device 'uart-8250.0' with uar              &       S&LWobe device 'uart-8250.2' with uart-8250
[    0.000920]Probe device 'uart-8250.3' with uart-8250
[    0.000930]Probe device 'uart-8250.4' with uart-8250
[    0.000940]Probe device 'uart-8250.5' with uart-8250
[    0.000950]Probe device 'console-uart.0' with console-uart
[    0.001060]mount /private with 'ram' filesystem
xboot: /#
xboot: /#
楼主 #1 2022-07-29 17:13:52
xboot
已发帖子: 675
Re: RV1103/RV1106 裸奔日记
为了烧写裸奔镜像,这里对xrock工具进行了扩展,支持了RV1103/RV1106芯片
https://github.com/xboot/xrock
烧写指令:
sudo xrock maskrom rv1106_ddr_924MHz_v1.07.bin rv1106_usbplug_v1.03.bin --rc4-off;
sleep 3;
sudo xrock flash write 512 xbootpak.bin;
sudo xrock reset;
#2 2022-07-29 17:49:32
dykxjh
已发帖子: 153
xboot出品,必属精品!
#3 2022-07-29 19:13:35
unturned3
已发帖子: 263
没TRM都能搞出来,太厉害了 orz
最近编辑记录 unturned3 (2022-07-29 19:13:46)
#5 2022-07-29 20:04:38
jasonhu
已发帖子: 20
搞个二维码是什么意思?哈哈哈
#6 2022-07-29 20:38:06
九重天
已发帖子: 25
二维码居然给我扫出来了.
#7 2022-07-30 08:28:21
已发帖子: 1,212
用QQ扫了下,该二维码暂不支持识别。
#8 2022-07-30 21:46:34
mysteryli
已发帖子: 481
1106的板子用的哪款呢
#9 2022-07-31 20:45:14
Timaker
已发帖子: 62
板子拿到了,哪一家的?
楼主 #10 2022-08-01 15:11:42
xboot
已发帖子: 675
自己造的一个板子,没有寄存器手册,只能用各种资料来推测具体芯片内部细节了,搞定常规外设,基本没太大问题,先用官方的sdk来跑通所有功能先。
#11 2022-08-01 16:22:58
david
已发帖子: 357
1106这芯片贵么 某宝没见到有
#12 2022-08-01 21:01:25
Timaker
已发帖子: 62
大佬,出板子吗,我也想玩
楼主 #13 2022-08-02 09:53:58
xboot
已发帖子: 675
这个芯片比F133/D1S/T113便宜,有价格优势
#14 2022-08-02 12:25:15
tango_zhu
已发帖子: 115
xboot 说:
啥时候出开发板
#15 2022-08-02 15:24:05
Timaker
已发帖子: 62
xboot 说:
好像含税25左右,等大佬出板子
楼主 #16 2022-08-09 17:28:00
xboot
已发帖子: 675
先DUMP整个时种树,以便裸奔时参考。
# cat clk_summary
                                 enable  prepare  protect                                duty
   clock                          count    count    count        rate   accuracy phase  cycle
 xin24m                              18       18        0    24000000          0     0  50000
    pclk_vi_rtc_root                  2        2        0    24000000          0     0  50000
       pclk_vi_rtc_phy                1        1        0    24000000          0     0  50000
       pclk_vi_rtc_test               1        1        0    24000000          0     0  50000
    clk_tsadc_tsen                    1        1        0    12000000          0     0  50000
    clk_tsadc                         1        1        0     1000000          0     0  50000
    clk_user_otpc_s                   0        0        0    12000000          0     0  50000
    clk_sbpi_otpc_s                   0        0        0    24000000          0     0  50000
       clk_pmc_otp                    0        0        0    24000000          0     0  50000
    clk_user_otpc_ns                  0        0        0    12000000          0     0  50000
    clk_sbpi_otpc_ns                  0        0        0    24000000          0     0  50000
    clk_otpc_arb                      0        0        0    24000000          0     0  50000
    clk_macphy                        1        1        0    24000000          0     0  50000
    dbclk_gpio2                       0        0        0    24000000          0     0  50000
    clk_sdmmc_detn_flt                0        0        0    24000000          0     0  50000
    cclk_src_sdmmc                    1        1        0      800000          0     0  50000
       sdmmc_sample                   0        0        0      400000          0     0  50000
       sdmmc_drv                      0        0        0      400000          0    90  50000
    dbclk_gpio3                       0        0        0    24000000          0     0  50000
    dbclk_gpio1                       0        0        0    24000000          0     0  50000
    clk_uart_detn_flt                 0        0        0    24000000          0     0  50000
    tclk_pmu_wdt                      0        0        0    24000000          0     0  50000
    clk_refout                        0        0        0    24000000          0     0  50000
    clk_pvtm_pmu                      0        0        0    24000000          0     0  50000
    clk_pmu_mcu_rtc                   0        0        0    24000000          0     0  50000
    dbclk_pmu_gpio0                   0        0        0    24000000          0     0  50000
    clk_pmu                           1        1        0    24000000          0     0  50000
       clk_ddr_fail_safe              0        0        0    24000000          0     0  50000
    clk_rtc32k_frac                   0        0        0       32768          0     0  50000
       clk_rtc_32k                    0        0        0       32768          0     0  50000
    tclk_wdt_s                        0        0        0    24000000          0     0  50000
    tclk_wdt_ns                       0        0        0    24000000          0     0  50000
    clk_ref_usbphy                    2        2        0    24000000          0     0  50000
       clk_usbphy_480m                1        1        0   480000000          0     0  50000
    clk_ref_usbotg                    1        1        0    24000000          0     0  50000
    clk_saradc                        1        1        0     3000000          0     0  50000
    clk_capture_pwm2_peri             0        0        0    24000000          0     0  50000
    clk_capture_pwm1_peri             0        0        0    24000000          0     0  50000
    clk_timer_root                    2        2        0    24000000          0     0  50000
       clk_timer5                     1        1        0    24000000          0     0  50000
       clk_timer4                     0        0        0    24000000          0     0  50000
       clk_timer3                     0        0        0    24000000          0     0  50000
       clk_timer2                     0        0        0    24000000          0     0  50000
       clk_timer1                     0        0        0    24000000          0     0  50000
       clk_timer0                     0        0        0    24000000          0     0  50000
       clk_stimer1                    0        0        0    24000000          0     0  50000
       clk_stimer0                    0        0        0    24000000          0     0  50000
    clk_capture_pwm0_peri             0        0        0    24000000          0     0  50000
    dbclk_gpio4                       0        0        0    24000000          0     0  50000
    cclk_src_emmc                     0        0        0      400000          0     0  50000
       emmc_sample                    0        0        0      200000          0     0  50000
       emmc_drv                       0        0        0      200000          0   180  50000
    clk_timer_ddrmon                  0        0        0    24000000          0     0  50000
    clk_vicap_m1                      1        1        0    24000000          0     0  50000
       sclk_vicap_m1                  1        1        0    24000000          0     0  50000
    clk_vicap_m0                      1        1        0    24000000          0     0  50000
       sclk_vicap_m0                  1        1        0    24000000          0     0  50000
    clk_uart5                         0        0        0    24000000          0     0  50000
       sclk_uart5                     0        0        0    24000000          0     0  50000
    clk_uart4                         0        0        0    24000000          0     0  50000
       sclk_uart4                     0        0        0    24000000          0     0  50000
    clk_uart3                         0        0        0    24000000          0     0  50000
       sclk_uart3                     0        0        0    24000000          0     0  50000
    clk_uart2                         1        1        0    24000000          0     0  50000
       sclk_uart2                     1        1        0    24000000          0     0  50000
    clk_uart1                         0        0        0    24000000          0     0  50000
       sclk_uart1                     0        0        0    24000000          0     0  50000
    clk_uart0                         0        0        0    24000000          0     0  50000
       sclk_uart0                     0        0        0    24000000          0     0  50000
    clk_ref_mipi1                     0        0        0    24000000          0     0  50000
       mclk_ref_mipi1                 0        0        0    24000000          0     0  50000
    clk_core_mcu_rtc                  1        1        0    24000000          0     0  50000
    clk_pvtm_core                     0        0        0    24000000          0     0  50000
    xin_osc0_half                     0        0        0    12000000          0     0  50000
       i2s0_8ch_mclkout               0        0        0    12000000          0     0  50000
    pll_gpll                          1        1        0  1188000000          0     0  50000
       gpll                          12       12        0  1188000000          0     0  50000
          clk_vicap_m1_src            0        0        0   594000000          0     0  50000
             clk_vicap_m1_frac        0        0        0    12000000          0     0  50000
          clk_vicap_m0_src            0        0        0   594000000          0     0  50000
             clk_vicap_m0_frac        0        0        0    12000000          0     0  50000
          clk_uart5_src               0        0        0   594000000          0     0  50000
             clk_uart5_frac           0        0        0    12000000          0     0  50000
          clk_uart4_src               0        0        0   594000000          0     0  50000
             clk_uart4_frac           0        0        0    12000000          0     0  50000
          clk_uart3_src               0        0        0   594000000          0     0  50000
             clk_uart3_frac           0        0        0    12000000          0     0  50000
          clk_uart2_src               0        0        0   594000000          0     0  50000
             clk_uart2_frac           0        0        0    12000000          0     0  50000
          clk_uart1_src               0        0        0   594000000          0     0  50000
             clk_uart1_frac           0        0        0    12000000          0     0  50000
          clk_uart0_src               0        0        0   594000000          0     0  50000
             clk_uart0_frac           0        0        0    12000000          0     0  50000
          clk_ref_mipi1_src           0        0        0   594000000          0     0  50000
             clk_ref_mipi1_frac       0        0        0    12000000          0     0  50000
          clk_ref_mipi0_src           1        1        0   594000000          0     0  50000
             clk_ref_mipi0_frac       1        1        0    27000000          0     0  50000
                clk_ref_mipi0         1        1        0    27000000          0     0  50000
                   mclk_ref_mipi0       1        1        0    27000000          0     0  50000
          clk_i2s0_8ch_rx_src         1        1        0   594000000          0     0  50000
             clk_i2s0_8ch_rx_frac       1        1        0     2048000          0     0  50000
                clk_i2s0_8ch_rx       1        1        0     2048000          0     0  50000
                   mclk_i2s0_8ch_rx       1        1        0     2048000          0     0  50000
          clk_i2s0_8ch_tx_src         1        1        0   594000000          0     0  50000
             clk_i2s0_8ch_tx_frac       1        1        0     2048000          0     0  50000
                clk_i2s0_8ch_tx       1        1        0     2048000          0     0  50000
                   mclk_i2s0_8ch_tx       2        2        0     2048000          0     0  50000
                      mclk_sai        0        0        0     2048000          0     0  50000
                      mclk_dsm        0        0        0     2048000          0     0  50000
                      mclk_acodec_tx       1        1        0     2048000          0     0  50000
          clk_450m_src                1        1        0   475200000          0     0  50000
          clk_400m_src                4        4        0   396000000          0     0  50000
             cclk_src_sdio            0        0        0   396000000          0     0  50000
                sdio_sample           0        0        0   198000000          0     0  50000
                sdio_drv              0        0        0   198000000          0   180  50000
             clk_core_rga2e           0        0        0   396000000          0     0  50000
             aclk_vo_root             1        1        0   396000000          0     0  50000
                aclk_rga2e            0        0        0   396000000          0     0  50000
             aclk_vepu_com_root       1        1        0   396000000          0     0  50000
             dclk_decom               0        0        0   396000000          0     0  50000
             aclk_peri_root           1        1        0   396000000          0     0  50000
                aclk_ive              0        0        0   396000000          0     0  50000
                aclk_decom            0        0        0   396000000          0     0  50000
          clk_339m_src                4        4        0   339428572          0     0  50000
             clk_core_isp3p2          1        1        0   339428572          0     0  50000
             dclk_vicap               1        1        0   339428572          0     0  50000
             aclk_vi_root             3        3        0   339428572          0     0  50000
                aclk_vicap            1        1        0   339428572          0     0  50000
                aclk_isp3p2           1        1        0   339428572          0     0  50000
          clk_300m_src                5        5        0   297000000          0     0  50000
             sclk_sfc                 0        0        0    74250000          0     0  50000
             aclk_vop_root            1        1        0   297000000          0     0  50000
                aclk_vop              1        1        0   297000000          0     0  50000
             aclk_mac_root            1        1        0   297000000          0     0  50000
                aclk_mac              1        1        0   297000000          0     0  50000
             aclk_vepu_root           2        2        0   297000000          0     0  50000
                aclk_vepu_pp          0        0        0   297000000          0     0  50000
                aclk_vepu             1        1        0   297000000          0     0  50000
             clk_pka_crypto           0        0        0   297000000          0     0  50000
             clk_core_crypto          0        0        0   297000000          0     0  50000
             aclk_bus_root            3        3        0   297000000          0     0  50000
                aclk_usbotg           1        1        0   297000000          0     0  50000
                aclk_dmac             1        1        0   297000000          0     0  50000
                aclk_crypto           0        0        0   297000000          0     0  50000
          clk_200m_src                6        8        0   198000000          0     0  50000
             hclk_vo_root             2        2        0   198000000          0     0  50000
                hclk_vop              1        1        0   198000000          0     0  50000
                hclk_sdio             0        0        0   198000000          0     0  50000
                hclk_rga2e            0        0        0   198000000          0     0  50000
             clk_core_vepu_dvbm       0        0        0   198000000          0     0  50000
             clk_spi0                 0        0        0   198000000          0     0  50000
             hclk_vepu_root           2        2        0   198000000          0     0  50000
                hclk_vepu_pp          0        0        0   198000000          0     0  50000
                hclk_vepu             1        1        0   198000000          0     0  50000
             clk_i2c1                 0        1        0   198000000          0     0  50000
             hclk_pmu_root            1        1        0   198000000          0     0  50000
                hclk_pmu_sram         0        0        0   198000000          0     0  50000
                clk_pmu_mcu           0        0        0   198000000          0     0  50000
             clk_100m_pmu             1        1        0    99000000          0     0  50000
                pclk_pmu_root         3        4        0    99000000          0     0  50000
                   pclk_pmu_wdt       0        0        0    99000000          0     0  50000
                   pclk_pvtm_pmu       0        0        0    99000000          0     0  50000
                   pclk_pmu_mailbox       0        0        0    99000000          0     0  50000
                   pclk_i2c1          0        1        0    99000000          0     0  50000
                   pclk_pmu_gpio0       1        1        0    99000000          0     0  50000
                   pclk_pmu           1        1        0    99000000          0     0  50000
             clk_i2c4                 0        1        0   198000000          0     0  50000
             clk_i2c3                 0        0        0   198000000          0     0  50000
             clk_i2c2                 0        0        0   198000000          0     0  50000
             clk_i2c0                 0        0        0   198000000          0     0  50000
             hclk_peri_root           2        2        0   198000000          0     0  50000
                hclk_trng_s           0        0        0   198000000          0     0  50000
                hclk_trng_ns          0        0        0   198000000          0     0  50000
                hclk_sai              0        0        0   198000000          0     0  50000
                hclk_bootrom          0        0        0   198000000          0     0  50000
                hclk_sfc              0        0        0   198000000          0     0  50000
                hclk_ive              0        0        0   198000000          0     0  50000
                hclk_i2s0             1        1        0   198000000          0     0  50000
                hclk_emmc             0        0        0   198000000          0     0  50000
                hclk_crypto           0        0        0   198000000          0     0  50000
          clk_150m_src                5        5        0   148500000          0     0  50000
             pclk_vo_root             4        4        0   148500000          0     0  50000
                pclk_tsadc            1        1        0   148500000          0     0  50000
                pclk_otp_mask         0        0        0   148500000          0     0  50000
                pclk_otpc_s           0        0        0   148500000          0     0  50000
                pclk_otpc_ns          0        0        0   148500000          0     0  50000
                pclk_mac              2        2        0   148500000          0     0  50000
                pclk_gpio2            1        1        0   148500000          0     0  50000
             pclk_vi_root             4        4        0   148500000          0     0  50000
                pclk_mipicsiphy       1        1        0   148500000          0     0  50000
                pclk_gpio3            1        1        0   148500000          0     0  50000
                pclk_csihost1         0        0        0   148500000          0     0  50000
                pclk_csihost0         1        1        0   148500000          0     0  50000
             hclk_vi_root             4        4        0   148500000          0     0  50000
                hclk_vicap            1        1        0   148500000          0     0  50000
                hclk_sdmmc            1        1        0   148500000          0     0  50000
                hclk_isp3p2           1        1        0   148500000          0     0  50000
             hclk_npu_root            2        2        0   148500000          0     0  50000
                hclk_rknn             1        1        0   148500000          0     0  50000
          clk_core_mcu                1        1        0   297000000          0     0  50000
          hclk_cpu                    1        1        0   198000000          0     0  50000
    pll_cpll                          1        1        0  1000000000          0     0  50000
       cpll                           5        5        0  1000000000          0     0  50000
          dclk_vop_src                1        1        0    50000000          0     0  50000
             dclk_vop                 1        1        0    50000000          0     0  50000
          clk_500m_src                2        2        0   500000000          0     0  50000
             aclk_ddr_root            2        2        0   500000000          0     0  50000
                aclk_sys_shrm         1        1        0   500000000          0     0  50000
          clk_250m_src                1        1        0   250000000          0     0  50000
          clk_100m_src                7        7        0   100000000          0     0  50000
             pclk_vepu_root           2        2        0   100000000          0     0  50000
                pclk_gpio1            1        1        0   100000000          0     0  50000
                pclk_spi0             0        0        0   100000000          0     0  50000
             clk_pwm2_peri            0        0        0   100000000          0     0  50000
             clk_pwm1_peri            0        0        0   100000000          0     0  50000
             clk_pwm0_peri            2        2        0   100000000          0     0  50000
             pclk_peri_root           7        9        0   100000000          0     0  50000
                pclk_wdt_s            0        0        0   100000000          0     0  50000
                pclk_wdt_ns           0        0        0   100000000          0     0  50000
                pclk_usbphy           1        1        0   100000000          0     0  50000
                pclk_uart5            0        0        0   100000000          0     0  50000
                pclk_uart4            0        0        0   100000000          0     0  50000
                pclk_uart3            0        0        0   100000000          0     0  50000
                pclk_uart2            1        1        0   100000000          0     0  50000
                pclk_timer            1        1        0   100000000          0     0  50000
                pclk_stimer           0        0        0   100000000          0     0  50000
                pclk_spi1             0        0        0   100000000          0     0  50000
                pclk_saradc           1        1        0   100000000          0     0  50000
                pclk_pwm2_peri        0        0        0   100000000          0     0  50000
                pclk_pwm1_peri        0        0        0   100000000          0     0  50000
                pclk_uart1            0        0        0   100000000          0     0  50000
                pclk_uart0            0        0        0   100000000          0     0  50000
                pclk_pwm0_peri        0        2        0   100000000          0     0  50000
                pclk_dft2apb          0        0        0   100000000          0     0  50000
                pclk_i2c4             0        1        0   100000000          0     0  50000
                pclk_i2c3             0        0        0   100000000          0     0  50000
                pclk_i2c2             0        0        0   100000000          0     0  50000
                pclk_i2c0             0        0        0   100000000          0     0  50000
                pclk_gpio4            1        1        0   100000000          0     0  50000
                pclk_dsm              0        0        0   100000000          0     0  50000
                pclk_decom            0        0        0   100000000          0     0  50000
                pclk_acodec           1        1        0   100000000          0     0  50000
             pclk_npu_root            1        1        0   100000000          0     0  50000
             pclk_ddr_root            2        2        0   100000000          0     0  50000
                pclk_dfictrl          1        1        0   100000000          0     0  50000
                pclk_ddrc             0        0        0   100000000          0     0  50000
                pclk_ddrmon           0        0        0   100000000          0     0  50000
                pclk_ddr_hwlp         0        0        0   100000000          0     0  50000
                pclk_ddrphy           0        0        0   100000000          0     0  50000
             pclk_top_root            1        1        0   100000000          0     0  50000
          clk_50m_src                 2        2        0    50000000          0     0  50000
             clk_gmac0_50m_o          2        2        0    50000000          0     0  50000
                clk_gmac0_tx_50m_o       1        1        0    50000000          0     0  50000
                clk_gmac0_ref_50m       1        1        0    50000000          0     0  50000
             clk_spi1                 0        0        0    50000000          0     0  50000
    pll_dpll                          1        1        0   924000000          0     0  50000
          clk_core_ddrc_src           2        2        0   462000000          0     0  50000
             clk_core_ddrc            1        1        0   462000000          0     0  50000
             aclk_ddrc                1        1        0   462000000          0     0  50000
             clk_ddr_phy              0        0        0   462000000          0     0  50000
             clk_ddrmon               0        0        0   462000000          0     0  50000
             clk_dfictrl              0        0        0   462000000          0     0  50000
    pll_apll                          1        1        0  1608000000          0     0  50000
          armclk                      1        1        0  1608000000          0     0  50000
             pclk_dbg                 2        2        0   201000000          0     0  50000
                pclk_cpu_root         2        2        0   201000000          0     0  50000
                   pclk_mailbox       1        1        0   201000000          0     0  50000
 clk_pvtpll_1                         1        1        0   420000000          0     0  50000
    aclk_npu_root                     2        2        0   420000000          0     0  50000
       aclk_rknn                      1        1        0   420000000          0     0  50000
 clk_pvtpll_0                         1        1        0   410000000          0     0  50000
    clk_core_vepu                     1        1        0   410000000          0     0  50000
 clk_utmi_usbotg                      1        1        0           0          0     0  50000
 sclk_in_spi0                         0        0        0           0          0     0  50000
 pclk_vicap_vepu                      1        1        0           0          0     0  50000
 clk_rxbyteclkhs_1                    0        0        0           0          0     0  50000
 clk_rxbyteclkhs_0                    1        1        0           0          0     0  50000
 pclk_vicap                           1        1        0           0          0     0  50000
 i1clk_vicap                          1        1        0           0          0     0  50000
 i0clk_vicap                          1        1        0           0          0     0  50000
 isp0clk_vicap                        2        2        0           0          0     0  50000
 rx1pclk_vicap                        1        1        0           0          0     0  50000
 rx0pclk_vicap                        1        1        0           0          0     0  50000
楼主 #17 2022-08-09 20:01:28
xboot
已发帖子: 675
搞定linux系统所有功能,跑个lvgl8先。
楼主 #18 2022-08-10 15:56:21
xboot
已发帖子: 675
上传个LVGL触摸的操作视频,1024X600的分辨率
#19 2022-08-10 21:21:51
Timaker
已发帖子: 62
大佬tql
楼主 #20 2022-08-11 18:10:12
xboot
已发帖子: 675
RV1103 / RV1106 裸奔已支持SPI NOR FLASH以及SPI NAND FLASH引导
SPI NOR FLASH烧录指令 (offset = 0x00020000, sector = 256)
sudo xrock maskrom rv1106_ddr_924MHz_v1.09.bin rv1106_usbplug_v1.03.bin --rc4-off;
sleep 3;
sudo xrock flash write 256 xbootpak.bin;
sudo xrock reset;
SPI NAND FLASH烧录指令 (offset = 0x00040000, sector = 512)
sleep 3;
sudo xrock reset;
楼主 #21 2022-08-11 18:18:58
xboot
已发帖子: 675
当然,除了使用XROCK工具进行烧写之外,还可以利用《瑞芯微工具套件 1.8》进行烧写裸机程序。
两种烧写方法原理是一样的,如果是windows平台,注意下,两者的驱动是不一样的。
spi nor flash 烧写
spi nand flash 烧写
楼主 #22 2022-08-11 18:33:24
xboot
已发帖子: 675
虽然,未进行EMMC引导测试,但根据分析,如果需要用EMMC介质进行裸奔,烧写指令会是如下方式:
EMMC烧录指令 (offset = 0x00080000, sector = 1024)
sleep 3;
sudo xrock flash write 1024 xbootpak.bin;
sudo xrock reset;
楼主 #23 2022-08-11 18:42:07
xboot
已发帖子: 675
EMMC引导肯定是可以支持的,只不过现在因为硬件限制,无法进行测试,那么疑问来了。
RV1103/RV1106是否能支持SD NAND引导呢,至少这种玩意有一定的性价比,特别是容量有要求时,优势会比较明显。
SPI NAND 最大容量是4Gbit
SD NAND 最大容量是8Gbit
EMMC这玩意最小得4GB
楼主 #24 2022-08-12 16:37:33
xboot
已发帖子: 675
对于RV1106支持SD NAND有个比较棘手的问题,RK默认EMMC启动使用200MHZ的时钟,而SD NAND基本不够格,从这一点来说RV1106是无法使用SD NAND做引导介质的
但是否可以修改EMMC时钟频率,这个就不敢肯定了
烧录不行,引导启动肯定也是不行的
楼主 #25 2022-08-18 09:14:48
xboot
已发帖子: 675
继续RV1106的裸奔,在编写看门狗驱动,发现时间到了后,并不能复位芯片,有一个机关,必须在启动时执行如下代码
	 * Release the watchdog
	write32(0xff000000 + 0x0004, 0x2000200);
	write32(0xff3b0000 + 0x0c10, 0x400040);
现在没TRM手册,也搞不清是啥意思,先能用就行,顺便来个sys_cpu_init函数吧,start.S里调用下,免得后面还有一堆未知的依赖。
void sys_cpu_init(void)
	 * Set all devices to Non-secure
	write32(0xff070000 + 0x0020, 0xffff0000);
	write32(0xff070000 + 0x0024, 0xffff0000);
	write32(0xff070000 + 0x0028, 0xffff0000);
	write32(0xff070000 + 0x002c, 0xffff0000);
	write32(0xff070000 + 0x0030, 0xffff0000);
	write32(0xff070000 + 0x00bc, 0x000f0000);
	write32(0xff076000 + 0x0020, 0xffff0000);
	write32(0xff076000 + 0x0024, 0xffff0000);
	write32(0xff076000 + 0x0028, 0xffff0000);
	write32(0xff076000 + 0x002c, 0xffff0000);
	write32(0xff076000 + 0x0030, 0xffff0000);
	write32(0xff076000 + 0x0040, 0x00030002);
	write32(0xff080000, 0x20000000);
	 * Set the emmc and fspi to access secure area
	write32(0xff900000 + 0x4c, 0x00000000);
	write32(0xff910000 + 0x44, 0xff00ffff);
	 * Set fspi clk 6mA
	write32(0xff568000 + 0x0030, 0x0f000700);
	 * Set the USB2 PHY in suspend mode and turn off the
	 * USB2 PHY FS/LS differential receiver to save power
	write32(0xff000000 + 0x0050, 0x01ff01d1);
	write32(0xff3e0000 + 0x0100, 0x00000000);
	 * When venc/npu use pvtpll, reboot will fail, because
	 * pvtpll is reset before venc/npu reset, so venc/npu
	 * is not completely reset, system will block when access
	 * NoC in SPL.
	write32(0xff3b0000 + 0x1008, 0xffff0018);
	write32(0xff3b0000 + 0x1000, 0x00030003);
	write32(0xff3b0000 + 0x1038, 0xffff0018);
	write32(0xff3b0000 + 0x1030, 0x00030003);
	sdelay(20);
	 * Limits npu max transport packets to 4 for route to scheduler,
	 * give much more chance for other controllers to access memory.
	write32(0xff140080 + 0x0008, 0x4);
	 * Improve VENC QOS PRIORITY
	write32(0xff150000 + 0x0008, 0x303);
最近编辑记录 xboot (2022-08-18 09:15:24)
楼主 #26 2022-08-18 09:18:08
xboot
已发帖子: 675
在没有TRM手册情况下,只能参考官方SDK,一点点来编写各种驱动了,算慢慢翻译吧,CLOCK,RESET,GPIO,IRQ,TIMER,这些都得慢慢翻译过来
楼主 #27 2022-08-18 09:23:27
xboot
已发帖子: 675
RV1106应该带了6个timer,但翻遍SDK,没能找到TIMER的基地址,有个0xff660000这个地址,貌似是基地址,但查看IP版本号又对不上,额,如果不能用TIMER,只能去用cortex-a7自带的timer实现tickless驱动了。
楼主 #29 2022-08-18 11:38:23
xboot
已发帖子: 675
已实现timer的中断支持,还算利用cortex-a7的timer了,核心代码如下:
#define armv7_read_cntpctl()		({ u32_t val; __asm__ __volatile__("mrc p15, 0, %0, c14, c2, 1" : "=r" (val)); val; })
#define armv7_write_cntpctl(val)	__asm__ __volatile__("mcr p15, 0, %0, c14, c2, 1\nisb sy\n" : : "r" (val));
static inline void armv7_timer_start(void)
	u32_t ctrl = armv7_read_cntpctl();
	if(!(ctrl & (1 << 0)))
		ctrl |= (1 << 0);
		armv7_write_cntpctl(ctrl);
static inline void armv7_timer_stop(void)
	if((ctrl & (1 << 0)))
		ctrl &= ~(1 << 0);
static inline void armv7_timer_interrupt_enable(void)
	if(ctrl & (1 << 1))
		ctrl &= ~(1 << 1);
static inline void armv7_timer_interrupt_disable(void)
	if(!(ctrl & (1 << 1)))
		ctrl |= (1 << 1);
static inline u64_t armv7_timer_frequecy(void)
	u32_t v;
	__asm__ __volatile__("mrc p15, 0, %0, c14, c0, 0" : "=r" (v));
	return (v != 0) ? (u64_t)v : 1000000;
static inline u64_t armv7_timer_read(void)
	u32_t l, h;
	__asm__ __volatile__("mrrc p15, 0, %0, %1, c14" : "=r" (l), "=r" (h));
	return ((u64_t)h << 32) | l;
static inline void armv7_timer_compare(uint64_t interval)
	u64_t last = armv7_timer_read() + interval;
	__asm__ __volatile__("mcrr p15, 2, %Q0, %R0, c14" : : "r" (last));
PPI里面timer中断有4个
#define RV1106_IRQ_HYPERVISOR_TIMER			(26)
#define RV1106_IRQ_VIRTUAL_TIMER			(27)
#define RV1106_IRQ_SECURE_PHYSICAL_TIMER	(29)
#define RV1106_IRQ_NONSECURE_PHYSICAL_TIMER	(30)
现在需要申请29号中断才可以触发,仅申请30号中断,无法触发,从这一点来看,现在代码运行在加密模式?
引导过程大概如下:
BOOTROM -> DDR.BIN -> XBOOT
BOOTROM 和 DDR.BIN,前在运行在加密模式的可能性比较低,后者很有可能。现在还没有对当前CPU运行模式摸个底。
楼主 #30 2022-08-18 11:44:26
xboot
已发帖子: 675
关于timer的运行模式,看linux内核,有些平台4个中断全部一起注册,额,这是增强适应性吧。
timer {
                compatible = "arm,armv7-timer";
                interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
                             <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
                             <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
                             <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
                clock-frequency = <24000000>;
PPI 中断号从16开始,对应就是上面的26,27,29,30,四个中断号
楼主 #31 2022-08-18 11:59:29
xboot
已发帖子: 675
RV1106内部自带的6个timer不可见,其还带了两个加密模式的stimer,严重怀疑当前CPU工作在加密模式,导致其不可见,当然加密模式的stimer,现在不知道其基地址,所以也无从确认起。
关于搜寻timer基地址,本来是想通过 TIMER_REVISION_6CH = 0x11970006 或 TIMER_REVISION_2CH = 0x11970002 这两个关键信息,写了个程序来遍历的,但访问某些地址空间,触发访问异常,无法继续搜寻,所以,这个思路就没有继续了。
理论上是可以对异常进行处理后,再继续搜寻的。这个问题先放弃了,采用CORTEX-A7内部自带的,也更通用点,实现功能就行,不纠结了。
楼主 #32 2022-08-18 16:05:12
xboot
已发帖子: 675
RESET驱动,GIC400中断驱动,TICKLESS驱动,GPIO驱动已经编写完了,基本是依据linux里的RV1106相关代码翻译而成。
现在也编写好了GPIO 中断驱动,但发现还是未能触发中断,普通的输入,输出等操作都是OK的。不知哪里还有坑,先放一放。
楼主 #33 2022-08-18 19:01:21
xboot
已发帖子: 675
编写SARADC驱动,测试通过,其寄存器跟RK3588一致。
https://github.com/xboot/xboot/blob/master/src/arch/arm32/mach-rv1106/driver/adc-rv1106.c
楼主 #34 2022-08-18 19:09:11
xboot
已发帖子: 675
基于ADC驱动,添加ADC按键驱动,添加如下设备树即可。
	"key-adc@0": {
		"adc-name": "adc-rv1106.0",
		"adc-channel": 0,
		"poll-interval-ms": 100,
		"keys": [
			{ "min-voltage": 0, "max-voltage": 100000, "key-code": 11 }
xboot: /# event
[key-adc.0]: [KeyDown] [11]
[key-adc.0]: [KeyUp] [11]
楼主 #35 2022-08-19 10:48:17
xboot
已发帖子: 675
实现RV1106的RTC驱动
 * driver/rtc-rv1106.c
 * Copyright(c) 2007-2022 Jianjun Jiang <8192542@qq.com>
 * Official site: http://xboot.org
 * Mobile phone: +86-18665388956
 * QQ: 8192542
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
#include <xboot.h>
#include <clk/clk.h>
#include <rtc/rtc.h>
enum {
	RTC_SET_SECONDS		= 0x00,
	RTC_SET_MINUTES		= 0x04,
	RTC_SET_HOURS		= 0x08,
	RTC_SET_DAYS		= 0x0c,
	RTC_SET_MONTHS		= 0x10,
	RTC_SET_YEARL		= 0x14,
	RTC_SET_YEARH		= 0x18,
	RTC_SET_WEEKS		= 0x1c,
	RTC_ALARM_SECONDS	= 0x20,
	RTC_ALARM_MINUTES	= 0x24,
	RTC_ALARM_HOURS		= 0x28,
	RTC_ALARM_DAYS		= 0x2c,
	RTC_ALARM_MONTHS	= 0x30,
	RTC_ALARM_YEARL		= 0x34,
	RTC_ALARM_YEARH		= 0x38,
	RTC_CTRL			= 0x3C,
	RTC_STATUS0			= 0x40,
	RTC_STATUS1			= 0x44,
	RTC_INT0_EN			= 0x48,
	RTC_INT1_EN			= 0x4c,
	RTC_MSEC_CTRL		= 0x50,
	RTC_MSEC_CNT		= 0x54,
	RTC_COMP_H			= 0x58,
	RTC_COMP_D			= 0x5c,
	RTC_COMP_M			= 0x60,
	RTC_ANALOG_CTRL		= 0x64,
	RTC_ANALOG_TEST		= 0x68,
	RTC_LDO_CTRL		= 0x6c,
	RTC_XO_TRIM0		= 0x70,
	RTC_XO_TRIM1		= 0x74,
	RTC_VPTAT_TRIM		= 0x78,
	RTC_ANALOG_EN		= 0x7c,
	RTC_CLK32K_TEST		= 0x80,
	RTC_TEST_ST			= 0x84,
	RTC_TEST_LEN		= 0x88,
	RTC_CNT_0			= 0x8c,
	RTC_CNT_1			= 0x90,
	RTC_CNT_2			= 0x94,
	RTC_CNT_3			= 0x98,
struct rtc_rv1106_pdata_t {
	virtual_addr_t virt;
	char * clk;
static void rtc_update_bits(virtual_addr_t virt, u32_t offset, u32_t mask, u32_t set)
	u32_t val;
	val = read32(virt + offset);
	write32(virt + offset, (val & ~mask) | set | 0xc4522900);
static bool_t rtc_rv1106_settime(struct rtc_t * rtc, struct rtc_time_t * time)
	struct rtc_rv1106_pdata_t * pdat = (struct rtc_rv1106_pdata_t *)rtc->priv;
	u32_t rtc_data[8];
	u32_t status;
	int yearh, yearl;
	int i;
	rtc_data[0] = bin2bcd(time->second) | 0xc4522900;
	rtc_data[1] = bin2bcd(time->minute) | 0xc4522900;
	rtc_data[2] = bin2bcd(time->hour) | 0xc4522900;
	rtc_data[3] = bin2bcd(time->day) | 0xc4522900;
	rtc_data[4] = bin2bcd(time->month) | 0xc4522900;
	if(time->year > 199)
		yearh = (time->year - 100) / 100;
		yearl = time->year - 100 - yearh * 100;
		yearh = 0;
	rtc_data[5] = bin2bcd(yearl) | 0xc4522900;
	rtc_data[6] = bin2bcd(yearh) | 0xc4522900;
	rtc_data[7] = bin2bcd(time->week) | 0xc4522900;
	rtc_update_bits(pdat->virt, RTC_CTRL, (1 << 0), 0);
	do {
		status = read32(pdat->virt + RTC_STATUS1);
		udelay(1);
	} while(status & (1 << 0));
	for(i = 0; i < 8; i++)
		write32(pdat->virt + RTC_SET_SECONDS + (i << 2), rtc_data[i]);
	rtc_update_bits(pdat->virt, RTC_CTRL, (1 << 7) | (1 << 0), (1 << 7) | (1 << 0));
	do {
		udelay(1);
	} while(!(status & (1 << 0)));
	return TRUE;
static bool_t rtc_rv1106_gettime(struct rtc_t * rtc, struct rtc_time_t * time)
	u32_t rtc_data[8];
	int i;
		rtc_data[i] = read32(pdat->virt + RTC_SET_SECONDS + (i << 2));
	time->second = bcd2bin(rtc_data[0] & 0x7f);
	time->minute = bcd2bin(rtc_data[1] & 0x7f);
	time->hour = bcd2bin(rtc_data[2] & 0x3f);
	time->day = bcd2bin(rtc_data[3] & 0x3f);
	time->month = bcd2bin(rtc_data[4] & 0x1f);
	time->year = (bcd2bin(rtc_data[6] & 0xff)) * 100 + (bcd2bin(rtc_data[5] & 0xff)) + 100;
	time->week = bcd2bin(rtc_data[7] & 0x07);
	return TRUE;
static struct device_t * rtc_rv1106_probe(struct driver_t * drv, struct dtnode_t * n)
	struct rtc_rv1106_pdata_t * pdat;
	struct rtc_t * rtc;
	struct device_t * dev;
	virtual_addr_t virt = phys_to_virt(dt_read_address(n));
	char * clk = dt_read_string(n, "clock-name", NULL);
	if(!search_clk(clk))
		return NULL;
	pdat = malloc(sizeof(struct rtc_rv1106_pdata_t));
	if(!pdat)
		return NULL;
	rtc = malloc(sizeof(struct rtc_t));
	if(!rtc)
		free(pdat);
		return NULL;
	pdat->virt = virt;
	pdat->clk = strdup(clk);
	rtc->name = alloc_device_name(dt_read_name(n), -1);
	rtc->settime = rtc_rv1106_settime;
	rtc->gettime = rtc_rv1106_gettime;
	rtc->priv = pdat;
	clk_enable(pdat->clk);
	write32(phys_to_virt(0xff000000) + 0x50000, ((1 << 6) << 16) | (1 << 6));
	rtc_update_bits(pdat->virt, RTC_VPTAT_TRIM, (1 << 4), (4 << 1));
	rtc_update_bits(pdat->virt, RTC_ANALOG_EN, (1 << 1), 0x00);
	rtc_update_bits(pdat->virt, RTC_LDO_CTRL, (1 << 0), (1 << 0));
	rtc_update_bits(pdat->virt, RTC_ANALOG_EN, (1 << 5), (1 << 5));
	rtc_update_bits(pdat->virt, RTC_CTRL, (1 << 0) | (1 << 7), (1 << 0) | (1 << 7));
	if(!(dev = register_rtc(rtc, drv)))
		clk_disable(pdat->clk);
		free(pdat->clk);
		free_device_name(rtc->name);
		free(rtc->priv);
		free(rtc);
		return NULL;
	return dev;
static void rtc_rv1106_remove(struct device_t * dev)
	struct rtc_t * rtc = (struct rtc_t *)dev->priv;
	if(rtc)
		unregister_rtc(rtc);
		free(pdat->clk);
		free(rtc->priv);
		free(rtc);
static void rtc_rv1106_suspend(struct device_t * dev)
static void rtc_rv1106_resume(struct device_t * dev)
static struct driver_t rtc_rv1106 = {
	.name		= "rtc-rv1106",
	.probe		= rtc_rv1106_probe,
	.remove		= rtc_rv1106_remove,
	.suspend	= rtc_rv1106_suspend,
	.resume		= rtc_rv1106_resume,
static __init void rtc_rv1106_driver_init(void)
	register_driver(&rtc_rv1106);
static __exit void rtc_rv1106_driver_exit(void)
	unregister_driver(&rtc_rv1106);
driver_initcall(rtc_rv1106_driver_init);
driver_exitcall(rtc_rv1106_driver_exit);
最近编辑记录 xboot (2022-08-19 10:48:55)
楼主 #36 2022-08-19 10:54:48
xboot
已发帖子: 675
现在已添加了不少裸机驱动,启动log如下:
DDR Version V1.09 20220630
f947
F
DDRConf2
924MHz
DDR bin out
       _                   _
V3.0.0 (Aug 19 2022 - 10:43:57) - [x1106][X1106 Based On RV1106 SOC]
[    0.000800]Probe device 'xin24m' with clk-fixed
[    0.000810]Probe device 'xin32k' with clk-fixed
[    0.000820]Probe device 'clk_rtc_32k' with clk-link
[    0.000830]Probe device 'apll' with clk-rv1106-pll
[    0.000840]Probe device 'cpll' with clk-rv1106-pll
[    0.000850]Probe device 'dpll' with clk-rv1106-pll
[    0.000860]Probe device 'gpll' with clk-rv1106-pll
[    0.000870]Probe device 'clk_pvtm_core' with clk-rv1106-gate
[    0.000880]Probe device 'clk_core_mcu_rtc' with clk-rv1106-gate
[    0.000890]Probe device 'clk_timer_root' with clk-rv1106-gate
[    0.000900]Probe device 'hclk_cpu' with clk-rv1106-comp
[    0.000910]Probe device 'clk_core_mcu' with clk-rv1106-comp
[    0.000920]Probe device 'clk_50m_src' with clk-rv1106-comp
[    0.000930]Probe device 'clk_100m_src' with clk-rv1106-comp
[    0.000940]Probe device 'clk_150m_src' with clk-rv1106-comp
[    0.000950]Probe device 'clk_200m_src' with clk-rv1106-comp
[    0.000960]Probe device 'clk_250m_src' with clk-rv1106-comp
[    0.000970]Probe device 'clk_300m_src' with clk-rv1106-comp
[    0.000980]Probe device 'clk_339m_src' with clk-rv1106-comp
[    0.000990]Probe device 'clk_400m_src' with clk-rv1106-comp
[    0.001000]Probe device 'clk_450m_src' with clk-rv1106-comp
[    0.001010]Probe device 'clk_500m_src' with clk-rv1106-comp
[    0.001020]Probe device 'pclk_top_root' with clk-rv1106-comp
[    0.001030]Probe device 'pclk_peri_root' with clk-rv1106-comp
[    0.001040]Probe device 'clk_100m_pmu' with clk-rv1106-divider
[    0.001050]Probe device 'pclk_pmu_root' with clk-rv1106-comp
[    0.001060]Probe device 'pclk_vi_rtc_root' with clk-rv1106-comp
[    0.001070]Probe device 'pclk_vi_rtc_phy' with clk-rv1106-gate
[    0.001080]Probe device 'pclk_vi_rtc_test' with clk-rv1106-gate
[    0.001090]Probe device 'pclk_i2c0' with clk-rv1106-gate
[    0.001100]Probe device 'clk_i2c0' with clk-rv1106-comp
[    0.001110]Probe device 'pclk_i2c1' with clk-rv1106-gate
[    0.001120]Probe device 'clk_i2c1' with clk-rv1106-comp
[    0.001130]Probe device 'pclk_i2c2' with clk-rv1106-gate
[    0.001140]Probe device 'clk_i2c2' with clk-rv1106-comp
[    0.001150]Probe device 'pclk_i2c3' with clk-rv1106-gate
[    0.001160]Probe device 'clk_i2c3' with clk-rv1106-comp
[    0.001170]Probe device 'pclk_i2c4' with clk-rv1106-gate
[    0.001180]Probe device 'clk_i2c4' with clk-rv1106-comp
[    0.001190]Probe device 'pclk_timer' with clk-rv1106-gate
[    0.001200]Probe device 'clk_timer0' with clk-rv1106-gate
[    0.001210]Probe device 'clk_timer1' with clk-rv1106-gate
[    0.001220]Probe device 'clk_timer2' with clk-rv1106-gate
[    0.001230]Probe device 'clk_timer3' with clk-rv1106-gate
[    0.001240]Probe device 'clk_timer4' with clk-rv1106-gate
[    0.001250]Probe device 'clk_timer5' with clk-rv1106-gate
[    0.001260]Probe device 'pclk_stimer' with clk-rv1106-gate
[    0.001270]Probe device 'clk_stimer0' with clk-rv1106-gate
[    0.001280]Probe device 'clk_stimer1' with clk-rv1106-gate
[    0.001290]Probe device 'pclk_saradc' with clk-rv1106-gate
[    0.001300]Probe device 'clk_saradc' with clk-rv1106-comp
[    0.001310]Probe device 'clk_uart0_src' with clk-rv1106-comp
[    0.001320]Probe device 'gate-clk_uart0_src' with clk-rv1106-gate
[    0.001330]Probe device 'clk_uart0_frac' with clk-rv1106-factor
[    0.001340]Probe device 'clk_uart0' with clk-rv1106-mux
[    0.001350]Probe device 'link-uart0' with clk-link
[    0.001360]Probe device 'link-uart1' with clk-link
[    0.001370]Probe device 'link-uart2' with clk-link
[    0.001380]Probe device 'link-uart3' with clk-link
[    0.001390]Probe device 'link-uart4' with clk-link
[    0.001400]Probe device 'link-uart5' with clk-link
[    0.001410]Probe device 'link-wdt' with clk-link
[    0.001420]Probe device 'reset-rv1106.0' with reset-rv1106
[    0.001430]Probe device 'reset-rv1106.1' with reset-rv1106
[    0.001440]Probe device 'reset-rv1106.2' with reset-rv1106
[    0.001450]Probe device 'reset-rv1106.3' with reset-rv1106
[    0.001460]Probe device 'reset-rv1106.4' with reset-rv1106
[    0.001470]Probe device 'reset-rv1106.5' with reset-rv1106
[    0.001480]Probe device 'reset-rv1106.6' with reset-rv1106
[    0.001490]Probe device 'reset-rv1106.7' with reset-rv1106
[    0.001500]Probe device 'reset-rv1106.8' with reset-rv1106
[    0.001510]Probe device 'reset-rv1106.9' with reset-rv1106
[    0.001520]Probe device 'reset-rv1106.10' with reset-rv1106
[    0.001530]Probe device 'reset-rv1106.11' with reset-rv1106
[    0.001540]Probe device 'reset-rv1106.12' with reset-rv1106
[    0.001550]Probe device 'reset-rv1106.13' with reset-rv1106
[    0.001560]Probe device 'reset-rv1106.14' with reset-rv1106
[    0.001570]Probe device 'reset-rv1106.15' with reset-rv1106
[    0.001580]Probe device 'reset-rv1106.16' with reset-rv1106
[    0.001590]Probe device 'reset-rv1106.17' with reset-rv1106
[    0.001600]Probe device 'reset-rv1106.18' with reset-rv1106
[    0.001610]Probe device 'reset-rv1106.19' with reset-rv1106
[    0.001620]Probe device 'reset-rv1106.20' with reset-rv1106
[    0.001630]Probe device 'reset-rv1106.21' with reset-rv1106
[    0.001640]Probe device 'reset-rv1106.22' with reset-rv1106
[    0.001650]Probe device 'reset-rv1106.23' with reset-rv1106
[    0.001660]Probe device 'reset-rv1106.24' with reset-rv1106
[    0.001670]Probe device 'reset-rv1106.25' with reset-rv1106
[    0.001680]Probe device 'reset-rv1106.26' with reset-rv1106
[    0.001690]Probe device 'irq-gic400.0' with irq-gic400
[    0.001700]Probe device 'irq-rv1106-gpio.0' with irq-rv1106-gpio
[    0.001710]Probe device 'irq-rv1106-gpio.1' with irq-rv1106-gpio
[    0.001720]Probe device 'irq-rv1106-gpio.2' with irq-rv1106-gpio
[    0.001730]Probe device 'irq-rv1106-gpio.3' with irq-rv1106-gpio
[    0.001740]Probe device 'irq-rv1106-gpio.4' with irq-rv1106-gpio
[    0.001750]Probe device 'gpio-rv1106.0' with gpio-rv1106
[    0.001760]Probe device 'gpio-rv1106.1' with gpio-rv1106
[    0.001770]Probe device 'gpio-rv1106.2' with gpio-rv1106
[    0.001780]Probe device 'gpio-rv1106.3' with gpio-rv1106
[    0.001790]Probe device 'gpio-rv1106.4' with gpio-rv1106
[    0.001840]Probe device 'adc-rv1106.0' with adc-rv1106
[    0.001850]Probe device 'ce-armv7-timer.0' with ce-armv7-timer
[    0.000026]Probe device 'cs-armv7-timer.0' with cs-armv7-timer
[    0.005833]Probe device 'uart-8250.0' with uarn              &       SS&S%"٥:ѵr:ѡѵj                         &       SSS%"٥:ѵr:ѡѵj            &   SS0
[    0.024936]Probe device 'uart-8250.5' with uart-8250
[    0.029878]Probe device 'i2c-rv1106.0' with i2c-rv1106
[    0.034987]Probe device 'i2c-rv1106.1' with i2c-rv1106
[    0.040098]Probe device 'i2c-rv1106.2' with i2c-rv1106
[    0.045215]Probe device 'i2c-rv1106.3' with i2c-rv1106
[    0.050331]Probe device 'i2c-rv1106.4' with i2c-rv1106
[    0.055455]Probe device 'rtc-rv1106.0' with rtc-rv1106
[    0.060545]Probe device 'wdg-rv1106.0' with wdg-rv1106
[    0.065660]Probe device 'key-adc.0' with key-adc
[    0.070257]Probe device 'led-gpio.0' with led-gpio
[    0.075014]Probe device 'led-gpio.1' with led-gpio
[    0.079784]Probe device 'led-gpio.2' with led-gpio
[    0.084554]Probe device 'ledtrigger-heartbeat.0' with ledtrigger-heartbeat
[    0.091395]Probe device 'ledtrigger-heartbeat.1' with ledtrigger-heartbeat
[    0.098242]Probe device 'ledtrigger-heartbeat.2' with ledtrigger-heartbeat
[    0.105088]Probe device 'console-uart.0' with console-uart
[    0.111138]mount /private with 'ram' filesystem
xboot: /#
xboot: /#
xboot: /#
xboot: /#
xboot: /#
#37 2022-08-25 12:11:09
czg516@sina.com
请问哪里可以购买到开发板及芯片呢
#39 2022-08-31 15:11:36
ifun888
想问下大佬,有移植过Uboot到rv1106吗?如何在uboot中显示logo呢?
#40 2022-08-31 16:43:06
可爱的小盆友们
已发帖子: 37
板子在哪里呢?干巴巴看着大佬装逼!
#41 2022-09-01 08:21:09
musich
好nb啊
楼主 #43 2022-09-21 20:10:44
xboot
已发帖子: 675
补充一个准确的说明文件,上面的偏移有些错误
# Rockchip RV1106
## Compile source code and generate the target files at the output directory
```shell
make clean
make CROSS_COMPILE=/path/to/arm-none-linux-gnueabihf- PLATFORM=arm32-rv1106
## Enter maskrom mode and using xrock for burning spi nor flash (offset = 0x00010000, sector = 128)
```shell
sudo xrock maskrom rv1106_ddr_924MHz_v1.09.bin rv1106_usbplug_v1.06.bin --rc4-off;
sleep 3;
sudo xrock flash write 128 xbootpak.bin;
sudo xrock reset;
## Enter maskrom mode and using xrock for burning spi nand flash (offset = 0x00040000, sector = 512)
```shell
sleep 3;
sudo xrock reset;
## Enter maskrom mode and using xrock for burning emmc (offset = 0x00008000, sector = 64)
```shell
sleep 3;
sudo xrock flash write 64 xbootpak.bin;
sudo xrock reset;
## Download xrock source code
```shell
git clone https://github.com/xboot/xrock.git
## Make and install xrock
```shell
make
sudo make install
#44 2022-09-23 15:13:08
lignin
已发帖子: 99
眼巴巴的看着rv1106,想玩,貌似功能蛮不错的,要是价格也美丽就好了
#45 2022-09-23 18:39:55
Timaker
已发帖子: 62
买不到板子,没得玩,难受呀
#46 2022-11-17 19:18:52
abs4567abcd
这种邮票孔的核心板特别难拆
#49 2023-03-18 11:46:01
hanshuizhizi
这个芯片的ISP调通了吗?
#50 2023-05-17 15:12:13
q994billy1
请问rv1126怎么设置从spi nor flash启动
#51 2023-05-18 19:04:52
qdk0901
hanshuizhizi 说:
这个芯片的ISP调通了吗?
在xboot上搞isp、编解码这些,难度估计是地狱级
#52 2023-07-03 09:38:05
david.y
淘宝这款,便宜而且对接了两款sensor
https://item.taobao.com/item.htm?ft=t&id=696377468895
czg516@sina.com 说:
请问哪里可以购买到开发板及芯片呢
#53 2023-07-26 14:06:47
suzhouclark
Timaker 说:
xboot 说:
好像含税25左右,等大佬出板子
芯片能否给个购买链接?
最近编辑记录 suzhouclark (2023-07-26 14:07:28)
#54 2023-07-26 17:33:53
已发帖子: 1,212
Timaker 说:
xboot 说:
好像含税25左右,等大佬出板子
现在淘宝上搜到的是40。
#56 2023-09-04 16:02:20
yuqingli
楼主有没有兴趣研究下 国科微的 GK7205V200 这个才不到 200 也是A7 + 64MB 更具有性价比。并且淘宝能买到元件
#57 2023-09-16 09:47:00
fxman
理论上RV1103是不是可以直接用,最近在搞这个0.0
#58 2023-10-11 21:56:15
again
fxman 说:
有没相关资料可以分享下呢?
#60 2023-10-15 14:39:50
已发帖子: 595
yuqingli 说:
这个是不是可以通用以前海思的sdk
#61 2023-11-13 16:23:08
哈利路亚
大佬,到b站上搞个教学视频吧,小白看不懂
#62 2023-11-17 11:01:35
网络孤客
已发帖子: 20
微雪有RV1103板,要近40元
#63 2023-11-17 15:56:52
fubaojun2006
没有手册玩裸机,强无敌~
那这芯片没有手册 ,还能不能好好用了
