开贴庆祝一下,自己制作的T113-I核心板一次成功点亮,自己焊接的T113-I,DDR和EMMC立创贴片
[89]BOOT0 commit : 09b36272
[92]set pll start
[94]fix vccio detect value:0xc0
[101]periph0 has been enabled
[104]set pll end
[105][pmu]: bus read error
[108]board init ok
[110]enable_jtag
[111]DRAM only have internal ZQ!!
[115]get_pmu_exist() = -1
[117]DRAM BOOT DRIVE INFO: V0.32
[120]DRAM CLK = 792 MHz
[123]DRAM Type = 3 (2:DDR2,3:DDR3)
[126]DRAMC ZQ value: 0x7b7bfb
[129]DRAM ODT value: 0x42.
[131]ddr_efuse_type: 0x0
[134]mark_id: 0x34
[136]DRAM SIZE =512 M
[138]PLL_DDR_CTRL_REG:0xf8004100
[142]DRAM_CLK_REG:0xc0000000
[144][TIMING DEBUG] MR2= 0x18
[152]DRAM simple test OK.
[154]rtc standby flag is 0x0, super standby flag is 0x0
[160]dram size =512
[162]card no is 2
[164]sdcard 2 line count 4
[167][mmc]: mmc driver ver 2021-05-21 14:47
[176][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[182][mmc]: ***Try MMC card 2***
[206][mmc]: RMCA OK!
[208][mmc]: mmc 2 bias 0
[211][mmc]: MMC 5.1
[213][mmc]: HSSDR52/SDR25 4 bit
[216][mmc]: 50000000 Hz
[218][mmc]: 7456 MB
[220][mmc]: ***SD/MMC 2 init OK!!!***
[317]Loading boot-pkg Succeed(index=0).
[321]Entry_name = u-boot
[328]Entry_name = optee
[332]Entry_name = dtb
[335]tunning data addr:0x430003e8
[338]Jump to second Boot.
M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
U-Boot 2018.05-g9444cec (Dec 25 2023 - 12:40:59 +0000) Allwinner Technology
[00.390]CPU: Allwinner Family
[00.393]Model: sun8iw20
I2C: ready
[00.413]DRAM: 512 MiB
[00.417]Relocation Offset is: 1cea2000
[00.446]secure enable bit: 0
E/TC:0 fdt_getprop_u32:343 prop trace_level not found
[00.459]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.465]gic: sec monitor mode
[00.468]flash init start
[00.470]workmode = 0,storage type = 2
[00.474][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
[00.480][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.505][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.512]sunxi flash init ok
[00.514]line:719 init_clocks
[00.517]drv_disp_init
[00.530]drv_disp_init finish
[00.532]boot_gui_init:start
[00.535]set disp.dev2_output_type fail. using defval=0
[00.692]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read in 1 ms (52.7 KiB/s)
[00.706]bmp_name=bootlogo.bmp size 1036854
1036854 bytes read in 23 ms (43 MiB/s)
[00.971]LT8912b chip ID: 0x0, 0x0
[02.262]LCD open finish
[02.264]Loading Environment from SUNXI_FLASH... OK
[02.291]update part info
[02.294]update bootcmd
[02.296]change working_fdt 0x5c861e70 to 0x5c841e70
[02.301][mmc]: no mmc-hs400-1_8v!
[02.304][mmc]: no mmc-hs200-1_8v!
[02.307][mmc]: get max-frequency ok 50000000 Hz
[02.329]update dts
phy_mode=rgmii, phy_interface=7
eth0
=====YTR==workmode=0==if_need_auto_force_burn=0, nRet=-1,auto_update_system
Hit <SPACE> key to stop autoboot in 1s
[02.783]no vendor_boot partition is found
Android's image name: sun8i_arm
[02.807]Starting kernel ...
[02.809][mmc]: mmc exit start
[02.829][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 5.4.61-gd2437b5 (tl@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Fri Jan 26 12:24:54 CST 2024
[ 0.000000] OF: fdt: Machine model: TLT113-EVM HDMI
[ 0.000000] cma: Reserved 16 MiB at 0x5f000000
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 130816 pages, LIFO batch:31
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s31296 r8192 d21952 u61440
[ 0.000000] pcpu-alloc: s31296 r8192 d21952 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129664
[ 0.000000] Kernel command line: clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p5 rootwait rw init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:userdata@mmcblk0p8:UDISK@mmcblk0p9 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-g9444cec(12/25/2023-12:40:59) disp_reserve=8294400,0x5c8cc000 androidboot.dramsize=512
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 472036K/523264K available (8192K kernel code, 460K rwdata, 2836K rodata, 1024K init, 330K bss, 34844K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x254/0x3e0 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000209] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000828] Console: colour dummy device 80x30
[ 0.000878] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000892] pid_max: default: 32768 minimum: 301
[ 0.001085] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001099] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.002058] CPU: Testing write buffer coherency: ok
[ 0.002466] /cpus/cpu@0 missing clock-frequency property
[ 0.002490] /cpus/cpu@1 missing clock-frequency property
[ 0.002502] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003171] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003319] rcu: Hierarchical SRCU implementation.
[ 0.003675] BOOTEVENT: 3.666374: ON
[ 0.003907] smp: Bringing up secondary CPUs ...
[ 0.005263] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005433] smp: Brought up 1 node, 2 CPUs
[ 0.005450] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.005457] CPU: All CPU(s) started in SVC mode.
[ 0.006058] devtmpfs: initialized
[ 0.020050] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.020684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020713] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.021616] pinctrl core: initialized pinctrl subsystem
[ 0.023219] NET: Registered protocol family 16
[ 0.025451] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.071395] rtc_ccu: sunxi ccu init OK
[ 0.073773] ccu: sunxi ccu init OK
[ 0.074304] r_ccu: sunxi ccu init OK
[ 0.128273] Deinterlace Module initialized.
[ 0.128584] iommu: Default domain type: Translated
[ 0.128819] sunxi iommu: irq = 24
[ 0.130074] SCSI subsystem initialized
[ 0.130932] usbcore: registered new interface driver usbfs
[ 0.131022] usbcore: registered new interface driver hub
[ 0.131153] usbcore: registered new device driver usb
[ 0.131343] mc: Linux media interface: v0.10
[ 0.131414] videodev: Linux video capture interface: v2.00
[ 0.133089] Advanced Linux Sound Architecture Driver Initialized.
[ 0.133858] Bluetooth: Core ver 2.22
[ 0.133950] NET: Registered protocol family 31
[ 0.133960] Bluetooth: HCI device and connection manager initialized
[ 0.133985] Bluetooth: HCI socket layer initialized
[ 0.133997] Bluetooth: L2CAP socket layer initialized
[ 0.134028] Bluetooth: SCO socket layer initialized
[ 0.134382] pwm module init!
[ 0.136246] g2d 5410000.g2d: Adding to iommu group 0
[ 0.136713] G2D: rcq version initialized.major:249
[ 0.137449] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.138468] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[ 0.138489] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[ 0.138504] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[ 0.138519] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[ 0.139699] clocksource: Switched to clocksource arch_sys_counter
[ 0.149597] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.165392] thermal_sys: Registered thermal governor 'step_wise'
[ 0.165399] thermal_sys: Registered thermal governor 'user_space'
[ 0.166022] NET: Registered protocol family 2
[ 0.166845] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.166897] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.166952] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.167015] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.167127] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.167171] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.167383] NET: Registered protocol family 1
[ 0.168152] RPC: Registered named UNIX socket transport module.
[ 0.168168] RPC: Registered udp transport module.
[ 0.168175] RPC: Registered tcp transport module.
[ 0.168181] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.172807] Initialise system trusted keyrings
[ 0.173085] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.188388] NFS: Registering the id_resolver key type
[ 0.188430] Key type id_resolver registered
[ 0.188439] Key type id_legacy registered
[ 0.188459] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.188469] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.188477] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.188809] fuse: init (API version 7.31)
[ 0.219548] NET: Registered protocol family 38
[ 0.219576] Key type asymmetric registered
[ 0.219585] Asymmetric key parser 'x509' registered
[ 0.219770] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.219787] io scheduler mq-deadline registered
[ 0.219795] io scheduler kyber registered
[ 0.219944] atomic64_test: passed
[ 0.221825] [DISP]disp_module_init
[ 0.222492] disp 5000000.disp: Adding to iommu group 0
[ 0.223148] [DISP] disp_init,line:2387:
[ 0.223153] smooth display screen:0 type:1 mode:4
[ 0.239976] [DISP] disp_init_hdmi,line:1047:
[ 0.239982] dont support hdmi
[ 0.240380] display_fb_request,fb_id:0
[ 0.263524] disp_al_manager_apply ouput_type:1
[ 0.264217] [DISP]disp_module_init finish
[ 0.265659] sunxi_sid_init()563 - insmod ok
[ 0.266174] pwm-regulator: supplied by regulator-dummy
[ 0.267603] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.269680] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 0.270351] uart uart0: get regulator failed
[ 0.270381] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.270709] uart0: ttyAS0 at MMIO 0x2500000 (irq = 33, base_baud = 1500000) is a SUNXI
[ 0.270740] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 0.297395] free logo buffer src_phy_addr=0x5c8cc000 fb_height=1080 src_stride=7680
[ 0.303527] Freeing logo buffer memory: 8100K
[ 0.307897] printk: console [ttyAS0] enabled
[ 1.243369] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 1.252507] uart uart1: get regulator failed
[ 1.257312] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.265375] uart1: ttyAS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[ 1.275111] uart uart2: get regulator failed
[ 1.279971] uart uart2: uart2 supply uart not found, using dummy regulator
[ 1.288041] uart2: ttyAS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
[ 1.297756] uart uart3: get regulator failed
[ 1.302618] uart uart3: uart3 supply uart not found, using dummy regulator
[ 1.310738] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
[ 1.320414] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 1.329459] uart uart4: get regulator failed
[ 1.334310] uart uart4: uart4 supply uart not found, using dummy regulator
[ 1.342407] uart4: ttyAS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
[ 1.352185] uart uart5: get regulator failed
[ 1.356996] uart uart5: uart5 supply uart not found, using dummy regulator
[ 1.365087] uart5: ttyAS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
[ 1.375273] misc dump reg init
[ 1.380902] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
[ 1.388199] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 1.396059] [ADDR_MGT] addr_mgt_probe: success.
[ 1.402760] libphy: Fixed MDIO Bus: probed
[ 1.407472] CAN device driver interface
[ 1.413136] sunxi-can can@0x0: can driver probe ok ...
[ 1.420006] sunxi-can can@0x1: can driver probe ok ...
[ 1.426806] sunxi gmac driver's version: 1.0.0
[ 1.432038] gmac-power0: NULL
[ 1.435368] gmac-power1: NULL
[ 1.438693] gmac-power2: NULL
[ 1.443279] Failed to alloc md5
[ 1.446815] eth0: Use random mac address
[ 1.451782] usbcore: registered new interface driver asix
[ 1.457930] usbcore: registered new interface driver ax88179_178a
[ 1.464883] usbcore: registered new interface driver cdc_ether
[ 1.471527] usbcore: registered new interface driver net1080
[ 1.477938] usbcore: registered new interface driver cdc_subset
[ 1.484665] usbcore: registered new interface driver zaurus
[ 1.491040] usbcore: registered new interface driver cdc_ncm
[ 1.497395] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.504741] sunxi-ehci: EHCI SUNXI driver
[ 1.509851] get ehci1-controller wakeup-source is fail.
[ 1.515838] sunxi ehci1-controller don't init wakeup source
[ 1.522114] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0eb8100, 0x:e0885000, irq_no:40
[ 1.534156] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 1.546714] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 1.558960] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 1.566248] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.576420] sunxi-ehci 4200000.ehci1-controller: irq 64, io mem 0x04200000
[ 1.609720] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 1.618599] hub 1-0:1.0: USB hub found
[ 1.622905] hub 1-0:1.0: 1 port detected
[ 1.628171] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.635184] sunxi-ohci: OHCI SUNXI driver
[ 1.640282] get ohci1-controller wakeup-source is fail.
[ 1.646282] sunxi ohci1-controller don't init wakeup source
[ 1.652568] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0eb8390
[ 1.662274] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[ 1.674862] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 1.687116] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 1.694405] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.704384] sunxi-ohci 4200400.ohci1-controller: irq 65, io mem 0x04200400
[ 1.784730] hub 2-0:1.0: USB hub found
[ 1.788994] hub 2-0:1.0: 1 port detected
[ 1.794596] usbcore: registered new interface driver uas
[ 1.800749] usbcore: registered new interface driver usb-storage
[ 1.807565] usbcore: registered new interface driver ums-alauda
[ 1.814304] usbcore: registered new interface driver ums-cypress
[ 1.821137] usbcore: registered new interface driver ums-datafab
[ 1.827953] usbcore: registered new interface driver ums_eneub6250
[ 1.834969] usbcore: registered new interface driver ums-freecom
[ 1.841797] usbcore: registered new interface driver ums-isd200
[ 1.848500] usbcore: registered new interface driver ums-jumpshot
[ 1.855428] usbcore: registered new interface driver ums-karma
[ 1.862064] usbcore: registered new interface driver ums-onetouch
[ 1.868982] usbcore: registered new interface driver ums-realtek
[ 1.875810] usbcore: registered new interface driver ums-sddr09
[ 1.882550] usbcore: registered new interface driver ums-sddr55
[ 1.889261] usbcore: registered new interface driver ums-usbat
[ 1.896028] usbcore: registered new interface driver option
[ 1.902533] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.911703] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.921299] sunxi_gpadc_init,2137, success
[ 1.926209] sunxi_key_init: get key count failed
[ 1.926224] sunxi_gpadc_setup: get channel scan data failed
[ 1.937989] input: sunxi-gpadc0 as /devices/virtual/input/input2
[ 1.945258] input: sunxi-gpadc1 as /devices/virtual/input/input3
[ 1.953531] i2c /dev entries driver
[ 1.957684] IR NEC protocol handler initialized
[ 1.962809] IR RC5(x/sz) protocol handler initialized
[ 1.970921] usbcore: registered new interface driver uvcvideo
[ 1.977375] USB Video Class driver (1.1.1)
[ 1.982016] gspca_main: v2.14.0 registered
[ 1.986611] sunxi cedar version 1.1
[ 1.990783] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.997058] VE: sunxi_cedar_probe power-domain init!!!
[ 2.002849] VE: install start!!!
[ 2.002849]
[ 2.008444] VE: cedar-ve the get irq is 45
[ 2.008444]
[ 2.014963] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 2.014963]
[ 2.024264] VE: install end!!!
[ 2.024264]
[ 2.029344] VE: sunxi_cedar_probe
[ 2.034632] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.043901] Bluetooth: HCI UART driver ver 2.3
[ 2.048888] Bluetooth: HCI UART protocol H4 registered
[ 2.056729] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 2.065720] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 2.075718] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
[ 2.082148] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[ 2.088499] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[ 2.094992] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[ 2.101469] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[ 2.108012] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[ 2.114575] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[ 2.121131] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[ 2.127697] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 2.137304] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.161050] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.185315] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[ 2.192497] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.201489] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[ 2.214202] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 2.215236] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.220471] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 2.233401] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.238391] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 2.256484] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 2.262955] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 2.269515] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 2.276095] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 2.282663] random: fast init done
[ 2.282677] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.282754] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.286497] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 2.311025] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.316856] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 2.333745] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.344986] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.353550] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.365185] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.377839] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 2.383969] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.395264] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.402439] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 2.412269] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 2.412401] usbcore: registered new interface driver usbhid
[ 2.422164] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 2.428382] usbhid: USB HID core driver
[ 2.438128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 2.442512] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.453787] rpmsg_tty_init: Sunxi rpmsg tty driver will init
[ 2.470481] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.470682] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
[ 2.488593] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
[ 2.493799] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.493799]
[ 2.517844] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:2, dachpf:3
[ 2.517883] mmc0: new high speed MMC card at address 0001
[ 2.529343] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 2.536438] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.544608] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 2.548938] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 2.558437] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.574079] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 2.584687] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 2.585919] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
[ 2.602211] [SNDCODEC][sunxi_card_dev_probe][800]:jack_enable missing, use default enable jack
[ 2.611960] [SNDCODEC][sunxi_card_dev_probe][810]:hp_detect_case missing, use default hp_detect_low
[ 2.622284] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.631403] NET: Registered protocol family 10
[ 2.637652] Segment Routing with IPv6
[ 2.642099] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.649805] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 2.651021] NET: Registered protocol family 17
[ 2.662191] NET: Registered protocol family 15
[ 2.667177] can: controller area network core (rev 20170425 abi 9)
[ 2.674243] NET: Registered protocol family 29
[ 2.679234] can: raw protocol (rev 20170425)
[ 2.684049] can: broadcast manager protocol (rev 20170425 t)
[ 2.690427] can: netlink gateway (rev 20190810) max_hops=1
[ 2.697106] Bluetooth: RFCOMM TTY layer initialized
[ 2.702651] Bluetooth: RFCOMM socket layer initialized
[ 2.708442] Bluetooth: RFCOMM ver 1.11
[ 2.713240] Key type dns_resolver registered
[ 2.718616] Registering SWP/SWPB emulation handler
[ 2.724462] Loading compiled-in X.509 certificates
[ 2.732217] tv_probe()1527 - of_property_read_string tv_power failed!
[ 2.739881] get_key_map_info()179 - Failed to find "tvou" in dts.
[ 2.746816] tv probe finished!
[ 2.769769] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[ 2.780333] sunxi-i2c sunxi-i2c2: drv-mode: Timeout when sending 9th SCL clk
[ 2.788277] sunxi-i2c sunxi-i2c2: drv-mode: xfer failed (dev addr:0x68)
[ 2.795870] rtc-ds1307: probe of 2-0068 failed with error -22
[ 2.802389] sunxi-i2c sunxi-i2c2: probe success
[ 2.807999] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 2.815719] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 2.824299] sunxi-thermal 2009400.ths: sun8iw20 chip id: 13312
[ 2.830904] sunxi-thermal 2009400.ths: sun8iw20 t1: 3000
[ 2.836989] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 2.852309] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 2.891362] get ehci0-controller wakeup-source is fail.
[ 2.897337] sunxi ehci0-controller don't init wakeup source
[ 2.903715] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0eb7be0, 0x:e2677000, irq_no:3e
[ 2.915730] [sunxi-ehci0]: Not init ehci0
[ 2.920688] get ohci0-controller wakeup-source is fail.
[ 2.926662] sunxi ohci0-controller don't init wakeup source
[ 2.932942] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0eb7e70
[ 2.942611] [sunxi-ohci0]: Not init ohci0
[ 2.949474] get det_vbus is fail, -84
[ 2.955097] sun8iw20-pinctrl pio: pin PE2 already requested by pio:130; cannot claim for 5801000.csi
[ 2.965528] sun8iw20-pinctrl pio: pin-130 (5801000.csi) status -22
[ 2.972562] sun8iw20-pinctrl pio: could not request pin 130 (PE2) from group PE2 on device pio
[ 2.982345] vin_csi 5801000.csi: Error applying setting, reverse things back
[ 2.990350] vin_csi: probe of 5801000.csi failed with error -22
[ 3.002215] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
[ 3.010040] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
[ 3.018075] sun8iw20-pinctrl pio: missing pins property in node csi_mclk0
[ 3.025794] sunxi-vin-media: probe of 5800800.vind failed with error -22
[ 3.034707] OF: fdt: not creating '/sys/firmware/fdt': CRC check failed
[ 3.042229] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.053435] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.061012] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.069782] clk: Not disabling unused clocks
[ 3.070727] cfg80211: failed to load regulatory.db
[ 3.075474] ALSA device list:
[ 3.084267] #0: audiocodec
[ 3.087504] alloc_fd: slot 0 not NULL!
[ 3.133096] EXT4-fs (mmcblk0p5): recovery complete
[ 3.139298] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.148526] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 3.156980] Freeing unused kernel memory: 1024K
[ 3.179905] Kernel init done
[ 3.183132] Run /init as init process
[ 3.371448] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Populating /dev using udev: [ 3.592067] udevd[1252]: starting version 3.2.7
[ 3.610658] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.619379] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.626826] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.641461] udevd[1252]: specified group 'kvm' unknown
[ 3.667798] udevd[1253]: starting eudev-3.2.7
done
Mounting cgroupfs hierarchy: OK
Starting system message bus: [ 4.710703] urandom_read: 3 callbacks suppressed
[ 4.710714] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[ 4.724070] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
[ 4.751835] random: dbus-daemon: uninitialized urandom read (12 bytes read)
done
Starting rpcbind: OK
Starting network: [ 5.122562] libphy: 4500000.eth: probed
[ 5.126880] sunxi-gmac 4500000.eth eth0: No PHY found!
RTNETLINK answers: Invalid argument
Waiting for interface eth1 to appear.[ 7.049718]
[ 7.049718] insmod_device_driver
[ 7.049718]
[ 7.056958] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
....... timeout!
run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1
FAIL
Starting ntpd: OK
Starting mosquitto: OK
[ 22.069751] random: crng init done
[ 22.073576] random: 1 urandom warning(s) missed due to ratelimiting
Starting sshd: OK
Starting telnetd: OK
Starting dockerd: OK
Starting NFS statd: OK
Starting NFS services: OK
Starting NFS daemon: OK
Starting NFS mountd: OK
Starting vsftpd: OK
mount: /run/media/mmcblk0rpmb: /dev/mmcblk0rpmb is not a block device.
mount: /run/media/mmcblk0p7: wrong fs type, bad option, bad superblock on /dev/mmcblk0p7, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p3: wrong fs type, bad option, bad superblock on /dev/mmcblk0p3, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p9: wrong fs type, bad option, bad superblock on /dev/mmcblk0p9, missing codepage or helper program, or other error.
[ 23.426659] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
mount: /run/media/mmcblk0p6: wrong fs type, bad option, bad superblock on /dev/mmcblk0p6, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p4: wrong fs type, bad option, bad superblock on /dev/mmcblk0p4, missing codepage or helper program, or other error.
mount: /run/media/mmcblk0p2: wrong fs type, bad option, bad superblock on /dev/mmcblk0p2, missing codepage or helper program, or other error.
[ 24.039033] EXT4-fs (mmcblk0p8): recovery complete
[ 24.044485] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
add /dev/input/event1 to Qt Application.
find qt5 installed done
Welcome to Allwinner KunoOS Platform
来个实物图片
底部照片来一个
这个手工焊的话难度会比较大的,没技术都焊不好
哈哈,是有点,我也是第一次焊接bga,焊接过后我还把芯片拿起来看了一下,然后又放上去。我以为焊接挂了,没想到能正常开机
手工焊接BGA难度不小,手上都有点功夫才行。
是的,是的
@上邪
T113为啥不在LC一起贴呢
这个用的免费打样做的,T113-I没法免费贴片(免费的贴片是经济模式,T113-I立创系统提示要标准模式才能贴);所以只能自己买回来手动焊接了
请教下,全志的官方开发包SDK之类的资料一般是联系他们的代理吗?现在的开发板好多都做成核心板,资料也不给全。
以前在全志开发者在线,注册帐号后,就可以下在t113的sdk。后来发现不能下载了,估计要申请。
买个开发板就有了
您好,原理图能不能开源呢,或者给个PDF的
我也是参考官方的原理图,你可以搜一下:
T113-i Hardware硬件类文档.7z
手册:
T113-i brief-V1.1.pdf
T113-i_Datasheet_V1.4.pdf
T113-i_User_Manual_V1.4.pdf
参考链接:全志A20 / A64 / A133 / D1 / T113-I/V83x /V85x Tina / Android 文档合集/集合,很全!
牛,开源吗?
使用几层板
使用几层板
盘中孔,6层以上了。
4层板可以吗,6层太贵了
楼主,你好,T113-i的I2S怎么设置的,我们使用的是ADC芯片型号是PCM1865;
使用几层板
6层
4层板可以吗,6层太贵了
可以的,不过有难度
我没使用
牛,开源吗?
暂时不准备开源,不过有官方的原理图,对照着画
你好,请问一下ddr的等长规则是怎么设置的?我看全志给的模板地址线长度差距达到了900mil,PCB并没有做等长处理,如果这样都能用的话说明芯片内部做了延时匹配,那自己画PCB的话也得按照这个画一模一样的长度?还是说按照标准ddr3的等长规则设计?
@epoko
我数据等长100mil,地址是200mil
有没有一个完整的资料包?
电源也是全志的套片么?
安心man 说:您好,原理图能不能开源呢,或者给个PDF的
我也是参考官方的原理图,你可以搜一下:
Dear Shang Xie your projects was wonderfull, can you say me that GERBER file or PCB file was include in this informations or not?
All dear colleagues, I'd like to create a board with T113-i. I need information such as Gerber or PCB reference files for guidance. Could you please assist me? Thank you.
核间资源分配有介绍吗?
阻容0402的吗
自己焊接的T113-I。牛啊。
自己焊接的T113-I。牛啊。
Did you design a cutomized borad with T113-i ?
thanks.
电源也是全志的套片么?
不是,用的dc-dc
阻容0402的吗
是的
@Ali64
包含了一部分,可以参考一下楼上官方原理图
### Compile
$ source build/envsetup.sh
$ lunch
``` sh
You're building on Linux
Lunch menu... pick a combo:
1. d1_mq_pro-tina
2. d1_nezha_min-tina
3. d1_nezha-tina
4. f133_evb1-tina
5. f133_mq_r-tina
6. t113_evb1-tina
7. t113_mq_r-tina
请问这个SDK,哪个是T113-I,有哪个大佬知道吗?
有全志T113I芯片的DDR参考电路吗
有全志T113I芯片的DDR参考电路吗
单片DDR怎么设计?
这个自己做我感觉不一定能成功的。。。
我也想做一个类似的全志H3的板子,楼主有什么经验可以讲下吗?之前没布过这么复杂的
请问板子大小是多少?
单片DDR怎么设计?
demo板是2片DDR,原理图设计时直接去掉一片就行,CS1的那片不用
有全志T113I芯片的DDR参考电路吗
vigour1000 说:使用几层板
盘中孔,6层以上了。
好奇如何看出这个板子用了盘中孔工艺?
https://www.jlc.com/portal/q7i38630.html
搜了下,看到嘉立创的盘中孔、过孔盖油、过孔塞油这三者的图片,能感觉出区别了。
不过0.2mm的过孔,估计过孔塞油和盘中孔看不出区别吧?猜测。
最近编辑记录 Gentlepig (昨天 09:02:03)
