楼主 # 2022-01-21 15:21:58
缥缈九哥
已发帖子: 93
基于荔枝派nano的镜像烧录方法--缥缈九哥测试
购买的板子是:
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.70052e8d1HwnxK&id=584657396198 Sipeed lichee Nano 荔枝派 跨界开发板 多系统 Linux F1c100s (焊接的SPIFLASH是新天下的XT25F128B)
烧录方法是本论坛的:sunxi-tools-win32support_f1c100s 里面的sunxi-fel.exe
登陆方法是:USB-TTL转换线直接接到 PE1 PE0 +5V GND 脚。PC登陆用的是SecureCRT 8.5 串口终端模式115200 8N1 无流控
镜像来源于:https://www.codenong.com/cs106854611/ (别的镜像不支持这个SPIFLASH,但是测试中文件系统莫名崩溃)
文件系统来源于:
https://whycan.com/t_2689.html 和 https://whycan.com/t_2688.html
烧录方法命令是:
(注意用本坛的zadig-2.3.exe安装WCID驱动,插USB线前短路SPIFLASH的1,2脚进入USB烧录模式,用sunxi-fel.exe命令行烧录)
D:\bin\sunxi-tools-win32support_f1c100s>sunxi-fel.exe -p spiflash-write 0 u-boot-sunxi-with-spl.bin
100% [================================================]   418 kB,   89.9 kB/s
D:\bin\sunxi-tools-win32support_f1c100s>sunxi-fel.exe -p spiflash-write 0x100000 suniv-f1c100s-licheepi-nano.dtb
100% [================================================]     8 kB,   32.5 kB/s
D:\bin\sunxi-tools-win32support_f1c100s>sunxi-fel.exe -p spiflash-write 0x110000 zImage
100% [================================================]  3656 kB,   96.3 kB/s
D:\bin\sunxi-tools-win32support_f1c100s>sunxi-fel.exe -p spiflash-write 0x510000  jffs2.bin
100% [================================================] 11469 kB,  101.6 kB/s
UBOOT启动命令行与参数是:
setenv bootcmd 'sf probe 0 50000000;sf read 0x80c00000 0x100000 0x4000;sf read 0x80008000 0x110000 0x400000;bootz 0x80008000 - 0x80c00000'
setenv bbotargs 'console=ttyS0,115200 root=/dev/mtdblock3 rootfstype=jffs2 mtdparts=spi0.0:1M(uboot),64K(dtb),4M(kernel),-(rootfs)'
saveenv
run bootcmd
两个不同的文件系统登陆命令是:
其中两个文件系统 :
jffs2.bin的登陆
opendeck login: root
Password: whycan.cn
rootfs.jffs2的登陆
Password: opendeck
文件:sunxi-tools-win32support_f1c100-缥缈九哥测试整理.rar。
最近编辑记录 缥缈九哥 (2022-01-21 15:49:53)
