荔枝派nano的SPI-Flash启动报错(新手入坑求助,4楼有启动的log)
荔枝派Nano公板
SPI_Flash编译烧录启动
交叉编译工具:gcc-linaro-7.5.0-2019.12-x86_64_arm-linux-gnueabi
u-boot: nano-lcd800480
Linux:linux-nano-4.14-exp
buildroot:buildroot-2018.11.2
开发环境:ubuntu18.04
TF卡启动是正常得
以下是编译配置以及烧录流程
一、U-boot
修改uboot以适配spi flash
在uboot源码目录下 进入 ./include/configs/,修改 suniv.h
#define CONFIG_BOOTCOMMAND   "sf probe 0 50000000; "                           \
                              "sf read 0x80C00000 0x100000 0x4000; "  \
                              "sf read 0x80008000 0x110000 0x400000; " \
                             "bootz 0x80008000 - 0x80C00000"
 #define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 rootwait " \
                  " mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) " \
                  " root=/dev/mtdblock3 rw rootfstype=jffs2 "Uboot的配置和修改我是参考晕哥的帖子https://whycan.com/t_1623.html
二、Linux
1、Linux配置
勾选 File systems ‣ Miscellaneous filesystems ‣ Journalling Flash File System v2 (JFFS2) support
勾选Device Driver --->  SPI Support ---> Allwinner A31 SPI controller
取消勾选Device Driver --->  SPI Support ---> Allwinner A10 SoCs SPI controller
勾选 Memory Technology Device (MTD) support  --->   Caching block device access to MTD devices
勾选 File systems  --->  Miscellaneous filesystems  --->   Journalling Flash File System v2 (JFFS2) support
取消勾选 Memory Technology Device (MTD) support  --->  SPI-NOR device support  --->    Use small 4096 B erase
2、修改源码下的 ./drivers/mtd/spi-nor.c
适配spi flash型号
   注释掉以下一行:
    //{ "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
    在这一行下面增加一项:
    { "xt25f128b", INFO(0x064018, 0, 64 * 1024, 256, SECT_4K) },3、修改dts以适配spi flash驱动
修改内核源码目录下的 arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
将原来的&spi0{...}替换为:
&spi0 {
    pinctrl-names = "default";
    pinctrl-0 = <&spi0_pins_a>;
    flash: w25q128@0 {
        #address-cells = <1>;
        #size-cells = <1>;
        compatible = "winbond,xt25f128b", "jedec,spi-nor";
        reg = <0>;
        partitions {
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x100000>;
                read-only;
            partition@100000 {
                label = "dtb";
                reg = <0x100000 0x10000>;
                read-only;
            partition@110000 {
                label = "kernel";
                reg = <0x110000 0x400000>;
                read-only;
            partition@510000 {
                label = "rootfs";
                reg = <0x510000 0xAF0000>;
};    dts修改参考荔枝派Nano全流程指南http://nano.lichee.pro/build_sys/build_flash.html#dts
三、Buildroot
下载Buildroot后解压,从零开始编译
配置 make menuconfig
Target options
  -- Target Architecture (ARM (little endian))
  -- Target Variant arm926t
Toolchain
  -- C library (musl) # 使用musl减小最终体积
System configuration
  -- Use syslinks to /usr .... # 启用/bin, /sbin, /lib的链接
  -- Enable root login # 启用root登录
  -- Run a getty after boot # 启用登录密码输入窗口
  -- remount root filesystem # 重新挂载根文件系统到可读写
  -- Install Timezone info # 安装时区信息。我的程序需要所以就打开了这个玩意
     -- timezone list (asia)
     -- default local time (Asia/Shanghai)
Target Packages
  -- mount/umount # 如果要用overlayfs,那就要用这个挂载最近编辑记录 L_max (2020-12-12 18:23:19)
没有启动运行脚本,他就进入命令行了
四、制作系统镜像
  将解压后的rootfs,suniv-f1c100s-licheepi-nano.dtb,zImage,u-boot-sunxi-with-spl.bin拷贝到一个文件
1、制作文件系统镜像
//板子自带的16M flashs
执行sudo mkfs.jffs2 -s 0x100 -e 0x10000 -p 0xAF0000 -d rootfs/ -o jffs2.img
会生成jffs2.img
注:
    -p 指的是rootfs占据的总空间:16M-1M-64K-4M=0xAF0000 或者 32M-1M-64K-4M=0x1AF0000
   -s 页大小0x100 256字节
   -e 块大小0x10000 64k
   jffs2.img是生成的文件系统镜像。2、编写制作镜像脚本:BuildMyImage.sh
#!/bin/sh
dd if=/dev/zero of=f1c100s_spiflash_16M.bin bs=1M count=16 &&\
dd if=u-boot/u-boot-sunxi-with-spl.bin of=f1c100s_spiflash_16M.bin bs=1K conv=notrunc &&\
dd if=linux/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb of=f1c100s_spiflash_16M.bin bs=1K see    k=1024 conv=notrunc &&\
dd if=linux/arch/arm/boot/zImage of=f1c100s_spiflash_16M.bin bs=1K seek=1088 conv=notrunc &&\
mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o rootfs.jffs2 &&\
dd if=rootfs.jffs2 of=f1c100s_spiflash_16M.bin bs=1k seek=5184 conv=notrunc &&\
sync注:
    ①生成一个空文件,大小是16MB
    ②将uboot添加到文件开头
    ③将dtb放到1M偏移处
    ④将kernel放到1M+64K偏移处
    ⑤将rootfs放到1M+64K+4M偏移处,偏移大小是seek,单位是KB。
执行脚本完毕后生成镜像文件f1c100s_spiflash_16M.bin
lrz@lrz-pc:~/licheepiNano/spi_flash_nano/myImagefile$ ./BuildMyImage.sh
记录了16+0 的读入
记录了16+0 的写出
16777216 bytes (17 MB, 16 MiB) copied, 0.0206363 s, 813 MB/s
记录了984+0 的读入
记录了984+0 的写出
1007616 bytes (1.0 MB, 984 KiB) copied, 0.000967329 s, 1.0 GB/s
记录了7+1 的读入
记录了7+1 的写出
7880 bytes (7.9 kB, 7.7 KiB) copied, 0.000119927 s, 65.7 MB/s
记录了3771+1 的读入
记录了3771+1 的写出
3862384 bytes (3.9 MB, 3.7 MiB) copied, 0.00349949 s, 1.1 GB/s
记录了19+1 的读入
记录了19+1 的写出
20252 bytes (20 kB, 20 KiB) copied, 0.000116751 s, 173 MB/s
lrz@lrz-pc:~/licheepiNano/spi_flash_nano/myImagefile$ ls
BuildMyImage.sh           jffs2.img  rootfs.jffs2                     u-boot-sunxi-with-spl.bin
f1c100s_spiflash_16M.bin  rootfs     suniv-f1c100s-licheepi-nano.dtb  zImage离线
五、烧录固件
我是在Ubuntu上用sunxi-fel工具烧录的,sunxi-fel工具安装参考荔枝派Nano全流程指南http://nano.lichee.pro/step_by_step/two_sunxi-tools.html
1、拔出TF卡,上电前, flash的CS和GND短接,不然ubuntu下检测不到Allwinner USB设备,这里我要被自己蠢哭了,CS管脚接错了,我之前接在排针上了,spi0的CS管脚是没有用排针引出来的,需要自己拿根杜邦线引出来,这里又被我们的硬件工程师给坑了,我是想把CS和GND接一个拨动开关,焊接的时候硬件工程师把Nano的GND看错了,一定要看清原理图啊!!!(荔枝派公版排针上的管脚和旁边没用排针引出来的管脚需要看仔细是否是接在一起)
未检测到Allwinner USB设备
sudo sunxi-fel spiflash-info
ERROR: Allwinner USB FEL device not found!2、进入fel就要断开SPI_CE与GND的链接,不然不能读取norflash芯片
No SPI flash detected.成功检测到Allwinner USB设备,查看版本信息,显示flash信息
sudo sunxi-fel version
Manufacturer: Unknown (0Bh), model: 40h, size: 16777216 bytes.3、执行烧录命令烧录,有进度条显示
(虽然进度条从0到100%了,但是不确定有没有烧录成功,请问下怎么样确定烧录成功了呢)
sudo sunxi-fel -p spiflash-write 0 f1c100s_spiflash_16M.bin
100% [================================================] 16777 kB,   79.4 kB/s 4、断电接上串口,上电启动失败,以下是启动log
U-Boot 2018.01-05679-g013ca457fd-dirty (Nov 20 2020 - 00:57:23 -0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected xt25f128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
mmc_init: -95, time 22
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
=> 5、后面重新烧录了一次,还是启动不了
U-Boot 2018.01 (Dec 11 2020 - 11:42:02 +0800) Allwinner Technology
DRAM:  32 MiB
SF: unrecognized JEDEC id bytes: 0b, 40, 18
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
No SPI flash selected. Please run `sf probe'
=> 打算重新再理一下,不知道哪里有问题。。。
没有启动运行脚本,他就进入命令行了
能稍微说的详细点嘛?不太明白要怎么解决,谢谢大佬。
raspberryman 说:没有启动运行脚本,他就进入命令行了
你的是什么flash型号,现在的log是没有把对应的flash型号添加到uboot配置。
直接用vi打开.config文件,找到WINBOND,把那几个flash型号都勾上试一试。
增加了U-boot对spi flash的识别
修改uboot源码下的:driver/mtd/spi_flash_ids.c
增加一行
{"xt25f128",       INFO(0x0b4018, 0x0,  64*1024,     256, SECT_4K)},U-boot启动OK,但是系统还是启动失败
U-Boot SPL 2018.01 (Dec 14 2020 - 12:03:43)
DRAM: 32 MiB
Trying to boot from MMC1
Trying to boot from sunxi SPI
U-Boot 2018.01 (Dec 14 2020 - 12:03:43 +0800) Allwinner Technology
DRAM:  32 MiB
SF: Detected xt25f128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
   Loading Device Tree to 80e01000, end 80e05ec7 ... OK
[    0.000000] Linux version 4.14.0-licheepi-nano (lrz@lrz-pc) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #7 Mon Dec 14 15:27:58 CST 2020
[    0.000000] Memory: 22668K/32768K available (6144K kernel code, 213K rwdata, 1416K rodata, 1024K init, 254K bss, 10100K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a35600   ( 214 kB)
[    0.000000]        .bss : 0xc0a3aa84 - 0xc0a7a45c   ( 255 kB)
[    0.000046] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000114] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000646] Console: colour dummy device 80x30
[    0.000737] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070238] pid_max: default: 32768 minimum: 301
[    0.070575] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070624] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072066] CPU: Testing write buffer coherency: ok
[    0.073755] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076247] devtmpfs: initialized
[    0.082836] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.082899] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083164] pinctrl core: initialized pinctrl subsystem
[    0.085218] NET: Registered protocol family 16
[    0.086718] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.088548] cpuidle: using governor menu
[    0.113642] SCSI subsystem initialized
[    0.114011] usbcore: registered new interface driver usbfs
[    0.114164] usbcore: registered new interface driver hub
[    0.114371] usbcore: registered new device driver usb
[    0.114774] pps_core: LinuxPPS API ver. 1 registered
[    0.114800] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.114858] PTP clock support registered
[    0.115376] Advanced Linux Sound Architecture Driver Initialized.
[    0.118372] clocksource: Switched to clocksource timer
[    0.145645] NET: Registered protocol family 2
[    0.147052] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.147129] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.147180] TCP: Hash tables configured (established 1024 bind 1024)
[    0.147457] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.147516] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.147950] NET: Registered protocol family 1
[    0.149095] RPC: Registered named UNIX socket transport module.
[    0.149135] RPC: Registered udp transport module.
[    0.149151] RPC: Registered tcp transport module.
[    0.149167] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.150268] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.152070] Initialise system trusted keyrings
[    0.152644] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.169635] NFS: Registering the id_resolver key type
[    0.169723] Key type id_resolver registered
[    0.169742] Key type id_legacy registered
[    0.169860] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.183712] Key type asymmetric registered
[    0.183752] Asymmetric key parser 'x509' registered
[    0.183960] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.183990] io scheduler noop registered
[    0.184009] io scheduler deadline registered
[    0.184762] io scheduler cfq registered (default)
[    0.184797] io scheduler mq-deadline registered
[    0.184814] io scheduler kyber registered
[    0.185847] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.195803] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.370736] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.377552] console [ttyS0] disabled
[    0.397807] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[    0.875711] console [ttyS0] enabled
[    0.914694] brd: module loaded
[    0.937038] loop: module loaded
[    0.941049] SCSI Media Changer driver v0.25
[    0.945854] slram: not enough parameters.
[    0.953030] m25p80 spi0.0: xt25f128 (16384 Kbytes)
[    0.959004] 4 ofpart partitions found on MTD device spi0.0
[    0.964506] Creating 4 MTD partitions on "spi0.0":
[    0.969418] 0x000000000000-0x000000100000 : "u-boot"
[    0.975520] 0x000000100000-0x000000110000 : "dtb"
[    0.981434] 0x000000110000-0x000000510000 : "kernel"
[    0.987373] 0x000000510000-0x000001000000 : "rootfs"
[    0.994043] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.000700] ehci-platform: EHCI generic platform driver
[    1.006196] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.012493] ohci-platform: OHCI generic platform driver
[    1.018165] usbcore: registered new interface driver usb-storage
[    1.025142] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.034182] i2c /dev entries driver
[    1.098504] sunxi-mmc 1c0f000.mmc: base:0xc2936000 irq:18
[    1.105970] usbcore: registered new interface driver usbhid
[    1.111670] usbhid: USB HID core driver
[    1.133418] NET: Registered protocol family 17
[    1.138105] Key type dns_resolver registered
[    1.144807] Loading compiled-in X.509 certificates
[    1.159482] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.171155] ------------[ cut here ]------------
[    1.175849] WARNING: CPU: 0 PID: 3 at drivers/usb/musb/sunxi.c:411 sunxi_musb_ep_offset+0x3c/0x54
[    1.184820] sunxi_musb_ep_offset called with non 0 offset
[    1.190267] Modules linked in:
[    1.193345] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 4.14.0-licheepi-nano #7
[    1.200676] Hardware name: Allwinner suniv Family
[    1.205418] Workqueue: events deferred_probe_work_func
[    1.210689] [<c010e5e0>] (unwind_backtrace) from [<c010b730>] (show_stack+0x10/0x14)
[    1.218513] [<c010b730>] (show_stack) from [<c0116674>] (__warn+0xd4/0xfc)
[    1.225394] [<c0116674>] (__warn) from [<c01166d4>] (warn_slowpath_fmt+0x38/0x48)
[    1.232939] [<c01166d4>] (warn_slowpath_fmt) from [<c0492350>] (sunxi_musb_ep_offset+0x3c/0x54)
[    1.241707] [<c0492350>] (sunxi_musb_ep_offset) from [<c0485e30>] (ep_config_from_hw+0xc4/0x158)
[    1.250547] [<c0485e30>] (ep_config_from_hw) from [<c0487aa4>] (musb_probe+0x8d8/0xbe8)
[    1.258604] [<c0487aa4>] (musb_probe) from [<c03f5200>] (platform_drv_probe+0x50/0xac)
[    1.266521] [<c03f5200>] (platform_drv_probe) from [<c03f3a14>] (driver_probe_device+0x234/0x2f0)
[    1.275450] [<c03f3a14>] (driver_probe_device) from [<c03f202c>] (bus_for_each_drv+0x48/0x94)
[    1.284023] [<c03f202c>] (bus_for_each_drv) from [<c03f36fc>] (__device_attach+0xac/0x114)
[    1.292337] [<c03f36fc>] (__device_attach) from [<c03f2d04>] (bus_probe_device+0x84/0x8c)
[    1.300565] [<c03f2d04>] (bus_probe_device) from [<c03f1184>] (device_add+0x370/0x58c)
[    1.308530] [<c03f1184>] (device_add) from [<c03f5014>] (platform_device_add+0x100/0x218)
[    1.316709] [<c03f5014>] (platform_device_add) from [<c03f59ec>] (platform_device_register_full+0xec/0x100)
[    1.326497] [<c03f59ec>] (platform_device_register_full) from [<c0491fac>] (sunxi_musb_probe+0x244/0x408)
[    1.336105] [<c0491fac>] (sunxi_musb_probe) from [<c03f5200>] (platform_drv_probe+0x50/0xac)
[    1.344584] [<c03f5200>] (platform_drv_probe) from [<c03f3a14>] (driver_probe_device+0x234/0x2f0)
[    1.353502] [<c03f3a14>] (driver_probe_device) from [<c03f202c>] (bus_for_each_drv+0x48/0x94)
[    1.362072] [<c03f202c>] (bus_for_each_drv) from [<c03f36fc>] (__device_attach+0xac/0x114)
[    1.370385] [<c03f36fc>] (__device_attach) from [<c03f2d04>] (bus_probe_device+0x84/0x8c)
[    1.378621] [<c03f2d04>] (bus_probe_device) from [<c03f3140>] (deferred_probe_work_func+0x48/0x140)
[    1.387686] [<c03f3140>] (deferred_probe_work_func) from [<c0129ab8>] (process_one_work+0x1d8/0x3ec)
[    1.396871] [<c0129ab8>] (process_one_work) from [<c0129f68>] (worker_thread+0x29c/0x5b8)
[    1.405101] [<c0129f68>] (worker_thread) from [<c012f010>] (kthread+0x120/0x138)
[    1.412558] [<c012f010>] (kthread) from [<c0107e48>] (ret_from_fork+0x14/0x2c)
[    1.419808] ---[ end trace cb1dc811f8b9347d ]---
[    1.424439] musb-sunxi 1c13000.usb: Error unknown readb offset 128
[    1.430760] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -22
[    1.438615] musb-hdrc: probe of musb-hdrc.1.auto failed with error -22
[    1.446661] ALSA device list:
[    1.449772]   #0: Loopback 1
[    1.454065] Waiting for root device /dev/mtdblock3...
[  208.188492] random: crng init done已有配置
勾选Device Driver --->Block devices  ---> Loopback device support离线
MTD BLOCK 选项没有勾?
MTD BLOCK 选项没有勾?
勾选了
 Device Drivers --->  Memory Technology Device (MTD) support
回车进入Memory Technology Device (MTD) support  --->
看着好像MTD有关的选项都给勾选上了
 <M>   MTD tests support (DANGEROUS)
 <M>   Command line partition table parsing
 <M>   Caching block device access to MTD devices
<*>   Swap on MTD device support
改用TF卡启动,看下有没有生成 /dev/mtdblockX 分区。
TF卡正常启动,在dev下没有/mtdblockX
ls: /dev/mtdblockX: No such file or directory
uuid 说:改用TF卡启动,看下有没有生成 /dev/mtdblockX 分区。
那检查 驱动配置和设备树吧,一定要生成 mtdblock设备才行
参考大佬LinjieGuo的帖子https://whycan.com/t_3138.html,查看其 menuconfig 配置,发现配置都是有的,还是不清楚自己配置的为啥有问题,可能还是哪里配置错了,忘记把自己的.config贴出来了(内核配置还得自己再配一次)
直接copy大佬的的内核配置文件.config到自己的内核源码中,不修改其它的,重新编译烧录,启动成功了
(大神的linux内核源码链接: https://pan.baidu.com/s/1YpbDNFXn_2QdTh8YIcF_jg 提取码:bc35)
U-Boot SPL 2018.01 (Dec 14 2020 - 17:45:04)
DRAM: 32 MiB
U-Boot 2018.01 (Dec 14 2020 - 17:45:04 +0800) Allwinner Technology
DRAM:  32 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
[    0.000000] Linux version 4.14.0-licheepi-nano (lrz@lrz-pc) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #13 Tue Dec 15 09:17:24 CST 2020
[    0.000000]       .data : 0xc0a00000 - 0xc0a356c0   ( 214 kB)
[    0.000000]        .bss : 0xc0a3ab44 - 0xc0a7a4bc   ( 255 kB)
[    0.000110] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000644] Console: colour dummy device 80x30
[    0.000735] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070231] pid_max: default: 32768 minimum: 301
[    0.070569] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070616] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072052] CPU: Testing write buffer coherency: ok
[    0.073708] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076181] devtmpfs: initialized
[    0.082786] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.082852] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083113] pinctrl core: initialized pinctrl subsystem
[    0.085120] NET: Registered protocol family 16
[    0.086621] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.088499] cpuidle: using governor menu
[    0.113256] SCSI subsystem initialized
[    0.113621] usbcore: registered new interface driver usbfs
[    0.113771] usbcore: registered new interface driver hub
[    0.113970] usbcore: registered new device driver usb
[    0.114380] pps_core: LinuxPPS API ver. 1 registered
[    0.114407] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.114464] PTP clock support registered
[    0.114967] Advanced Linux Sound Architecture Driver Initialized.
[    0.117936] clocksource: Switched to clocksource timer
[    0.144637] NET: Registered protocol family 2
[    0.146008] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.146082] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.146133] TCP: Hash tables configured (established 1024 bind 1024)
[    0.146390] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.146462] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.146898] NET: Registered protocol family 1
[    0.147894] RPC: Registered named UNIX socket transport module.
[    0.148059] RPC: Registered udp transport module.
[    0.148084] RPC: Registered tcp transport module.
[    0.148100] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.149219] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.151027] Initialise system trusted keyrings
[    0.151619] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.168513] NFS: Registering the id_resolver key type
[    0.168597] Key type id_resolver registered
[    0.168620] Key type id_legacy registered
[    0.168738] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.182539] Key type asymmetric registered
[    0.182581] Asymmetric key parser 'x509' registered
[    0.182795] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.182828] io scheduler noop registered
[    0.182846] io scheduler deadline registered
[    0.183607] io scheduler cfq registered (default)
[    0.183643] io scheduler mq-deadline registered
[    0.183660] io scheduler kyber registered
[    0.184697] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.194909] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.365358] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.372334] console [ttyS0] disabled
[    0.392590] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[    0.870567] console [ttyS0] enabled
[    0.909978] brd: module loaded
[    0.932442] loop: module loaded
[    0.936317] SCSI Media Changer driver v0.25
[    0.944259] m25p80 spi0.0: xt25f128 (16384 Kbytes)
[    0.950213] 4 ofpart partitions found on MTD device spi0.0
[    0.955715] Creating 4 MTD partitions on "spi0.0":
[    0.960634] 0x000000000000-0x000000100000 : "u-boot"
[    0.969622] rfd_ftl: no RFD magic found in 'u-boot'
[    0.976702] ftl_cs: FTL header not found.
[    0.982440] 0x000000100000-0x000000110000 : "dtb"
[    0.988590] ftl_cs: FTL header not found.
[    0.994191] 0x000000110000-0x000000510000 : "kernel"
[    1.010586] rfd_ftl: no RFD magic found in 'kernel'
[    1.017691] ftl_cs: FTL header not found.
[    1.023407] 0x000000510000-0x000001000000 : "rootfs"
[    1.056553] rfd_ftl: no RFD magic found in 'rootfs'
[    1.063764] ftl_cs: FTL header not found.
[    1.070068] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.076604] ehci-platform: EHCI generic platform driver
[    1.082212] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.088522] ohci-platform: OHCI generic platform driver
[    1.094116] usbcore: registered new interface driver usb-storage
[    1.101109] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.110153] i2c /dev entries driver
[    1.168063] sunxi-mmc 1c0f000.mmc: base:0xc2959000 irq:18
[    1.175505] usbcore: registered new interface driver usbhid
[    1.181204] usbhid: USB HID core driver
[    1.202825] NET: Registered protocol family 17
[    1.207495] Key type dns_resolver registered
[    1.214177] Loading compiled-in X.509 certificates
[    1.228953] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.240722] ------------[ cut here ]------------
[    1.245419] WARNING: CPU: 0 PID: 3 at drivers/usb/musb/sunxi.c:411 sunxi_musb_ep_offset+0x3c/0x54
[    1.254391] sunxi_musb_ep_offset called with non 0 offset
[    1.259831] Modules linked in:
[    1.262909] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 4.14.0-licheepi-nano #13
[    1.270326] Hardware name: Allwinner suniv Family
[    1.275072] Workqueue: events deferred_probe_work_func
[    1.280340] [<c010e5e0>] (unwind_backtrace) from [<c010b730>] (show_stack+0x10/0x14)
[    1.288155] [<c010b730>] (show_stack) from [<c0116674>] (__warn+0xd4/0xfc)
[    1.295034] [<c0116674>] (__warn) from [<c01166d4>] (warn_slowpath_fmt+0x38/0x48)
[    1.302582] [<c01166d4>] (warn_slowpath_fmt) from [<c04949b0>] (sunxi_musb_ep_offset+0x3c/0x54)
[    1.311359] [<c04949b0>] (sunxi_musb_ep_offset) from [<c0488490>] (ep_config_from_hw+0xc4/0x158)
[    1.320201] [<c0488490>] (ep_config_from_hw) from [<c048a104>] (musb_probe+0x8d8/0xbe8)
[    1.328257] [<c048a104>] (musb_probe) from [<c03f5200>] (platform_drv_probe+0x50/0xac)
[    1.336179] [<c03f5200>] (platform_drv_probe) from [<c03f3a14>] (driver_probe_device+0x234/0x2f0)
[    1.345109] [<c03f3a14>] (driver_probe_device) from [<c03f202c>] (bus_for_each_drv+0x48/0x94)
[    1.353683] [<c03f202c>] (bus_for_each_drv) from [<c03f36fc>] (__device_attach+0xac/0x114)
[    1.362001] [<c03f36fc>] (__device_attach) from [<c03f2d04>] (bus_probe_device+0x84/0x8c)
[    1.370230] [<c03f2d04>] (bus_probe_device) from [<c03f1184>] (device_add+0x370/0x58c)
[    1.378197] [<c03f1184>] (device_add) from [<c03f5014>] (platform_device_add+0x100/0x218)
[    1.386377] [<c03f5014>] (platform_device_add) from [<c03f59ec>] (platform_device_register_full+0xec/0x100)
[    1.396167] [<c03f59ec>] (platform_device_register_full) from [<c049460c>] (sunxi_musb_probe+0x244/0x408)
[    1.405778] [<c049460c>] (sunxi_musb_probe) from [<c03f5200>] (platform_drv_probe+0x50/0xac)
[    1.414257] [<c03f5200>] (platform_drv_probe) from [<c03f3a14>] (driver_probe_device+0x234/0x2f0)
[    1.423177] [<c03f3a14>] (driver_probe_device) from [<c03f202c>] (bus_for_each_drv+0x48/0x94)
[    1.431747] [<c03f202c>] (bus_for_each_drv) from [<c03f36fc>] (__device_attach+0xac/0x114)
[    1.440058] [<c03f36fc>] (__device_attach) from [<c03f2d04>] (bus_probe_device+0x84/0x8c)
[    1.448287] [<c03f2d04>] (bus_probe_device) from [<c03f3140>] (deferred_probe_work_func+0x48/0x140)
[    1.457354] [<c03f3140>] (deferred_probe_work_func) from [<c0129ab8>] (process_one_work+0x1d8/0x3ec)
[    1.466537] [<c0129ab8>] (process_one_work) from [<c0129f68>] (worker_thread+0x29c/0x5b8)
[    1.474763] [<c0129f68>] (worker_thread) from [<c012f010>] (kthread+0x120/0x138)
[    1.482212] [<c012f010>] (kthread) from [<c0107e48>] (ret_from_fork+0x14/0x2c)
[    1.489464] ---[ end trace 00d7ca0cbfb5e356 ]---
[    1.494096] musb-sunxi 1c13000.usb: Error unknown readb offset 128
[    1.500418] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -22
[    1.508270] musb-hdrc: probe of musb-hdrc.1.auto failed with error -22
[    1.516238] ALSA device list:
[    1.519357]   #0: Loopback 1
[    1.598535] random: crng init done
[    5.128784] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    5.137217] devtmpfs: mounted
[    5.144716] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting network: OK
Welcome to CBD
LicheePiNano login: root
Password: 离线
L_max 说:uuid 说:改用TF卡启动,看下有没有生成 /dev/mtdblockX 分区。
spi_flash启动OK了,但是在串口终端进入dev下还是没有mtdblock设备
raspberryman 说:L_max 说:TF卡正常启动,在dev下没有/mtdblockX
用对比软件对比,linux用meld,diffuse, windows用beyond compare
L_max 说:raspberryman 说:那检查 驱动配置和设备树吧,一定要生成 mtdblock设备才行
dev下有mtdblock设备了,谢谢
raspberryman 说:L_max 说:spi_flash启动OK了,但是在串口终端进入dev下还是没有mtdblock设备
dev下有mtdblock设备了,谢谢
什么问题?
L_max 说:raspberryman 说:用对比软件对比,linux用meld,diffuse, windows用beyond compare
dev下有mtdblock设备了,谢谢
什么问题?
重启下就好了
