楼主 #1 2017-10-24 14:21:27
楼主 #2 2017-10-27 08:34:17
Re: 买个全志arm9 F1C100s 方案的唱戏机回来拆一拆
等了四天,刚刚收到的全志F1C100s唱戏机
楼主 #3 2017-10-27 08:47:42
继续
楼主 #4 2017-10-27 13:56:46
继续拆:
楼主 #5 2017-10-29 07:27:48
接串口线:
BOOT0 is starting
DBG: init jtag OK
init dram , base is 0x80000000
init dram , clk is 156
init dram , access_mode is 1
init dram , cs_num is 1
init dram , ddr8_remap is 0
init dram , sdr_ddr is 1
init dram , bwidth is 16
init dram , col_width is 10
init dram , row_width is 13
init dram , bank_size is 4
init dram , cas is 3
init dram , size is 0
dram init successed,size is 32
DBG: init heap OK, base address is 0x80000000, size is 0x00100000
DBG: load boot1 from spinor
DBG: init spinor OK
DBG: the size of BOOT1 is 71168
DBG: src_sum = 0x0x4dd22bba
DBG: sum = 0x0x4dd22bba
succeed in loading BOOT1
jump to BOOT1
DBG: boot1 starting!
DBG: init heap OK, base address is 0x80800000, size is 0x00100000
begin to init file system
DBG: init block device OK
DBG: init mini file system OK
DBG: mount c partition OK
0
jump to kernal
Mount Parts Thread running.....
\0partition [D] plug in..
\0Mount Parts Thread work now.....
\0.Start Shell from partion 'c'..................................................................................
\0Mount Parts Thread work end....
\0Execute startup script begin..............
\0Esh Error: \0OpenConfigFile y:\config\config.bin failed.
\01
\02
\03
\0.orange Installed and Openned!........................................................................................
\04
\0partition [E] plug in..
\05
\0.Desktop Installed and Openned!........................................................................................
\0...............Execute startup script end
\0Esh msg: \0shell main thread: Bye Bye!
\0pend event sem overtime!
\0*divider=7
\0b_interlace=0
\022212222 22222222 00222222
\0
以上是原版固件接上串口线后的打印输出
楼主 #6 2018-01-09 10:14:35
SEGGER J-Link Commander V4.96l ('?' for help)
Compiled Feb 25 2015 10:24:24
DLL version V4.96l, compiled Feb 25 2015 10:24:11
Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
Hardware: V8.00
S/N: 20121126
Feature(s): RDI,FlashDL,FlashBP,JFlash
VTarget = 2.982V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D152192: ICache: 32kB (425632), DCache: 16kB (412832)
Info: Cache type: Separate, Write-back, Format C (WT supported)
Found 1 JTAG device, Total IRLen = 4:
#0 Id: 0x07926F0F, IRLen: 04, IRPrint: 0x1, ARM926EJ-S Core
Found ARM with core Id 0x07926F0F (ARM9)
Target interface speed: 100 kHz
J-Link>
JLINK连接成功!
楼主 #7 2018-01-09 12:02:16
读写 SRAM, DRAM都正常。
楼主 #8 2018-01-09 19:39:04
下载EWARM-CD-8201-14188.exe
再到csdn下载了 IAR7.x破解文件.rar 破解工具,
根据 IAR for ARM介绍、下载、安装与注册终于把IAR破解了。
IAR 7.4下载链接:EWARM-CD-7401-8472.exe
楼主 #9 2018-01-09 20:10:56
f1c100s JLINK 单步调试OK
IAR7工程下载: F1C100s_IAR_V7_20180109.zip
#10 2018-01-10 14:42:49
shotstar
能用keil吗?驱动调试的怎么样了?
楼主 #11 2018-01-10 14:52:33
shotstar wrote:
能用keil吗?驱动调试的怎么样了?
keil 应该问题也不大。
#12 2018-01-17 10:57:47
kgp0213
已发帖子: 149
串口线和jlink的线接到板子哪里的?有标记吗?
楼主 #13 2018-01-17 11:05:17
参考链接: http://linux-sunxi.org/MicroSD_Breakout
Mapping
Pin MicroSD JTAG Connection 14-pin ARM JTAG Header UART Connection 5-pin UART Header
1 Data2 TCK 9 nc nc
2 CD/Data3 nc nc RX 2
3 Cmd TDO 11 nc nc
4 VDD VTG 1,13 VDD 3
5 CLK nc nc TX 1
6 VSS GND 2,4,6,8,10,14 GND 4, 5
7 Data0 TDI 5 nc nc
8 Data1 TMS 7 nc nc
nc nc nTRST 3 nc nc
nc nc nRESET 12 nc nc
然后再谷歌找一张带引脚序号的TF卡封装图,对照标出UART和JTAG, 然后用杜邦线引出贴上标签纸。
#14 2018-01-17 15:35:34
kgp0213
已发帖子: 149
晕哥,F1C100s的内存映射表也是靠猜的吗? 参考哪个芯片猜的?
楼主 #15 2018-01-17 15:42:12
内部SRAM 地址是0开始, 不记得是多大了,可能24K,32K.
DRAM 地址是 0x80000000, 本帖5#楼 的调试信息输出有。
内存地址这个好猜测,从唱戏机固件就可以分析出来。
#16 2018-01-19 14:55:25
kgp0213
已发帖子: 149
晕哥,F1C100S的gpio 地址 及配置哪里能参考?
楼主 #17 2018-01-19 15:18:44
https://github.com/xboot/xboot/blob/master/src/arch/arm32/mach-f1c100s/driver/gpio-f1c100s.c
gpio_f1c100s_set_cfg
gpio_f1c100s_set_pull
gpio_f1c100s_set_drv
#18 2018-01-22 14:21:11
cheng880126
大神,请教一个小问题啊,从你的jlink接线图片,看起来。SD的第三脚(白色线,JTAG定义是TDO)貌似是对应到jlink的13脚(JTAG定义是VDD)上去了呀,而按照资料来看,这根白色线应该是接到11脚的呢,
现在我碰到的问题是,SD的第三脚接到jlink的11脚,jlink.exe无法读取到任何设备啊。。。是应该按照 你的接法去连接吗?
楼主 #19 2018-01-22 14:31:32
没错, 13p就是 TDO
#20 2018-01-22 16:51:36
kgp0213
已发帖子: 149
F1C100S的sram地址应该是0~0x7fff,32k。
#21 2018-01-22 22:59:46
kgp0213
已发帖子: 149
晕哥,修改lcd驱动参数在哪个目录下面呢? arch 下 f1c100s下的driver下面没找到
楼主 #22 2018-01-23 01:23:51
xboot目前应该还没有驱动lcd,
uboot和linux应该冰淇淋大神应该搞定了
#23 2018-01-23 08:41:46
goodgoodstudy
已发帖子: 61
kgp0213 wrote:
xboot带的演示效果那么的酷炫,居然不支持LCD?
xboot目前没有适配f1c100s的lcd而已,估计要不了几天就可以了。
楼主 #24 2018-02-01 20:37:38
楼主 #25 2018-03-25 17:45:32
这是挖坑网网友 @www220 买到的炬力方案唱戏机,
下面是 @www220 在Q群的聊天记录:
都是一个牌子,一批和一批芯片用的不一样,仅有的兴趣折腾没了,不玩了.
能找到外包装的话,记录一个型号,我买的KK-131不行
#26 2018-03-26 13:40:56
www220
已发帖子: 46
希望晕神,找到外包装,给一个能用的版本
楼主 #27 2018-04-23 17:39:39
这是xboot的设备树文件: sast-kk131.c
也是 kk-131型号,说明这家公司产品型号命名是比较混乱的。
#28 2018-04-23 23:40:25
www220
已发帖子: 46
及其混乱
#29 2018-08-21 09:23:50
mianhua
晕哥大神,能不能分离这个视频是如何做到20FPS这么高的?
楼主 #30 2018-08-21 09:27:24
这是 xboot 作者本人发在QQ群里面的演示视频,不知道如何实现的,你可以单独问下他.
#31 2018-08-21 12:17:22
为啥我自己编的xboot没改任何东西只能跑10fps左右?
#32 2018-08-24 13:21:33
agnd
FluxBB bbcode 晕哥,我晕!
楼主 #33 2018-08-24 13:43:50
只能买回来拆开看下,
形势不对退货。
或者可以买荔枝派nano板子,
价格也非常合适。
#34 2018-08-24 13:55:39
agnd
晕啊,买了拆了还能退么?
#35 2018-08-24 14:17:23
agnd
晕哥,发现坑越来越深哦,从网上查唱戏机方案,貌似除了炬力的,还有瑞芯微的。。。
楼主 #36 2018-08-24 14:21:31
agnd wrote:
晕啊,买了拆了还能退么?
据说热风枪 吹保修标签可以完整撕下 (逃
#37 2018-08-24 14:32:27
Jin劲
已发帖子: 217
agnd wrote:
晕啊,买了拆了还能退么?
可以在tf卡位置怼一下jlink看一下芯片么
最近编辑记录 Jin劲 (2018-08-24 14:34:38)
楼主 #38 2018-08-24 14:51:53
是的。
全志虽然资料不怎么开放,但是社区对他很眷顾。
楼主 #39 2018-08-24 14:52:38
Jin劲 wrote:
agnd wrote:
晕啊,买了拆了还能退么?
http://linux-sunxi.org/images/thumb/0/05/JTAG_MicroSD_UART-front.jpeg/180px-JTAG_MicroSD_UART-front.jpeg
优秀!
还有这种操作。
#40 2018-08-24 15:05:11
agnd
Jin劲 wrote:
agnd wrote:
晕啊,买了拆了还能退么?
RK2806也是ARM926EJ_s,外加一个DSP组成的双核,小心以假乱真啊
楼主 #41 2018-08-24 15:07:39
不怕,看Core Id
#42 2018-08-24 15:59:09
Jin劲
已发帖子: 217
哇 异构多核
楼主 #43 2018-08-24 18:31:27
查看芯片id
https://whycan.cn/t_1544.html
#44 2019-01-17 17:12:45
siwen
我想买一款F1C200S的产品拆解一下,求产品链接。
#45 2019-01-26 11:57:20
siwen
F1C800芯片怎么样?感觉功能比这个增强很多。
#46 2019-01-26 13:39:58
已发帖子: 649
800好像支持LVDS
楼主 #47 2019-01-26 13:41:45
https://whycan.cn/t_2088.html
widora 正在打算做这个开发板.
#48 2019-02-23 16:25:48
九霄云外
已发帖子: 100
微凉VeiLiang wrote:
800好像支持LVDS
C800和100S、200S一样是ARM926EJS的内核,工艺有提升,跑MELIS3.0系统,CPU量产稳定可以跑1G左右,
外加支持MIPI、LVDS屏,支持解大部分1080P视频,可以说基本是全格式的
#49 2019-02-23 19:23:51
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
你有支持吗?带不带集成内存?价位多少?
#50 2019-02-24 00:43:32
ippen
已发帖子: 345
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
网站的简介,说支持wifi b/g/n/ac,难道内置WiFi?
#51 2019-02-25 09:54:36
九霄云外
已发帖子: 100
达克罗德 wrote:
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
你有支持吗?带不带集成内存?价位多少?
C800带64MB的DDR2, 有支持,我就是干这个的
#52 2019-02-25 09:56:11
九霄云外
已发帖子: 100
ippen wrote:
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
没有WIFI,如果简介有说支持,那就是写错了,复制粘贴的那种错错
#53 2019-02-25 11:26:26
老兄,你不会就是全志代理吧?我需要拿一些200s片子
#54 2019-02-25 12:04:25
九霄云外 wrote:
你有支持吗?带不带集成内存?价位多少?
什么价位方便透露下吗?我的QQ15194966
#55 2019-02-25 13:10:12
九霄云外
已发帖子: 100
可以找我拿,我们还可以提供技术支持,加我QQ:610943940
最近编辑记录 九霄云外 (2019-02-25 13:12:42)
#56 2019-02-25 14:12:05
山无棱
已发帖子: 116
赞赞赞,市场上就确实你这种既懂技术,又懂市场的老板。
#57 2019-02-26 00:05:14
elecompu
这论坛太让人感觉舒服了,亲切!
#58 2019-02-26 15:09:17
jlau
已发帖子: 217
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
CPU上到1GHz?
#59 2019-02-28 10:06:55
九霄云外
已发帖子: 100
jlau wrote:
九霄云外 wrote:
微凉VeiLiang wrote:
800好像支持LVDS
CPU上到1GHz?
C800可以的,其它不行
最近编辑记录 九霄云外 (2019-02-28 10:07:21)
#60 2019-03-05 13:50:01
blmfnewlife2016
用料不少。晕哥,请问有没有游客建议开一个学习的版块,好跟着Debugdump一起学习些东西。
楼主 #61 2019-03-05 13:55:05
想学习哪些东西呢?
#62 2019-04-09 13:41:40
北冥雪
已发帖子: 43
/files/members/3/QQ20180109200945.png
我把这个工程下载下来了,为什么使用的是S3C2440A(926T),不应该使用的是926的内核么
楼主 #63 2019-04-09 13:46:01
因为内核接近,指令集兼容,所以这样也不会出错,最好还是按你上面的选择。
#64 2019-04-27 00:09:31
dven
所在地: 中国广州
已发帖子: 43
RK28xx/29xx现在应该已经不多见了,同屏器用的RK3026/3036印象中很少用在唱戏机上
F1C系列看起来是五六年前安卓MP4方案的改版?
http://tech.sina.com.cn/digi/2011-05-26/09221765762.shtml
最近编辑记录 dven (2019-04-27 00:15:22)
#65 2019-08-06 15:21:01
sea18c
也想买一个唱戏机来学习
楼主 #66 2019-08-06 15:40:25
sea18c wrote:
也想买一个唱戏机来学习
很难确定某唱戏机用 F1C100s 方案, 不太建议买唱戏机。
可以买荔枝派nano 开发板, 或者迪卡芒果的F1C200s板子。
#67 2019-08-06 18:23:10
ippen
已发帖子: 345
有唱戏机主板卖,可以挑f1c100s芯片的
#68 2019-08-12 15:06:12
sea18c
我买了唱戏机,就是晕哥说那个98包邮那款,是用F1C100s方案的。且是主板改小尺寸了,以后就要跟晕哥混了
#69 2019-08-22 11:54:53
sea18c
折腾了20天,终于摸到门边了,用 https://whycan.cn/t_2689.html 的 suniv_f1c100s_w25q128_usb_lcd_ok_20190722.7z 能看到显示屏有显示 但分辨率不对,还有就是终端好像输出错误,串口是用UART0 PE0 PE1脚,即是收音机芯片的那两个数据管脚。
楼主 #70 2019-08-22 17:03:21
看起来很不错,↖(^ω^)↗
#71 2019-09-25 09:12:57
明月心惜
已发帖子: 24
老哥们 唱戏机的屏幕背光用的是哪个引脚,用nano的固件改成480*272的分辨率,nano点唱戏机的屏,是可以显示的。现在换回唱戏机主板点唱戏机,屏幕不亮,不知道背光是哪个脚?4.3寸唱戏机,跟晕哥这个是一样的。
#72 2019-09-25 09:31:31
我思故我在
已发帖子: 244
找到背光芯片, 顺藤摸瓜找到背光芯片的控制引脚, 这时有两个选择:
  1. 用万用表量出与 f1c100s 连接的引脚.
  2. 直接飞线上拉或者下拉引脚控制引脚。
#73 2019-09-25 12:02:22
cris8259
已发帖子: 283
新人入坑,之前弄的stm32,没搞过linux,有带入坑的吗?红包支持
楼主 #74 2019-09-25 12:48:48
欢迎欢迎,热烈欢迎,遇到问题可以先翻下前面的帖子,不懂的可以发帖。
#75 2019-09-25 14:31:40
cris8259
已发帖子: 283
完全小白,问得会有点低能。晕哥能QQ求教吗
楼主 #76 2019-09-25 14:34:49
QQ只聊天,不聊技术。有问题直接发帖/跟帖,再低能的问题也竭尽所能解答,不过也可能会把你带坑里面去。
#77 2019-09-25 14:37:57
cris8259
已发帖子: 283
哈哈,请多赐教
#78 2019-09-25 21:53:03
明月心惜
已发帖子: 24
背光芯片找到了,没找到资料,万用表也没量出引脚,
夏新唱戏机,4.3寸,rgb 40PIN。没人玩吗?
#79 2019-09-25 21:56:01
firstman
已发帖子: 279
@明月心惜 最近买的吗?求购买链接
背光芯片就那么几个, 看下是什么封装的, 帮你猜一下
最近编辑记录 firstman (2019-09-25 21:57:46)
#80 2019-09-25 22:39:14
明月心惜
已发帖子: 24
firstman wrote:
@明月心惜 最近买的吗?求购买链接
【夏新M-185 4.3寸看戏机老人唱戏机听戏收音机老年高清视频播放器】 https://m.tb.cn/h.eNYNskN?sm=04b88c 点击链接,再选择浏览器咑閞;或椱ァ製这段描述$p6sWYnIdSuC$后到?◇綯℡寳?
18年11月买的,现在还在卖。40PIN最近那个sot-23-6就是驱动,丝印BIBHF6,引脚找到了,PE12,但是使能逻辑可能和nano(低电平)不一样,所以点不亮,我再试试。
#81 2019-09-26 00:08:51
cris8259
已发帖子: 283
MT9284?
#82 2019-11-26 12:33:34
jxmlegend
已发帖子: 49
好帖,谢谢楼主无私奉献,初学者的福音
#83 2020-03-18 20:30:47
吕氏春秋
已发帖子: 36
好帖,谢谢楼主无私奉献,初学者的福音
#84 2020-03-19 15:23:58
molin2050
已发帖子: 31
是的。
脸红吗,脸痛吗?就像馋女人的身子一样,不过是性价比高而已
#85 2020-03-19 16:24:54
真香定律?
#86 2020-04-17 14:41:43
sonni
已发帖子: 0
谢谢楼主无私奉献,初学者的福音
#87 2020-04-17 15:55:20
LIUlingo
好帖,谢谢楼主无私奉献,初学者的福音
#88 2020-04-17 15:55:35
LIUlingo
好帖,谢谢楼主无私奉献,初学者的福音
#89 2020-04-17 21:46:07
liuchangyin
已发帖子: 204
哈哈,以前买海思的开发板就是直接去买dvr成品
#90 2020-04-18 14:07:37
Andylyu
奢侈啊!!!没钱买
#91 2020-05-09 07:17:13
我思故我在
已发帖子: 244
楼主图文并茂赞赞赞,现在还能买到全志方案唱戏机吗?
#92 2020-05-13 16:04:31
居工
满满的黑科技,无解
#93 2020-05-13 17:28:45
cccsk
你好,有F1C100s裸机开发的例程吗
#94 2020-05-14 21:13:43
piyush
所在地: India
已发帖子: 23
Thanks for link, But it looks it's broken.
Can you please provide valid link.
感谢您的链接,但它似乎坏了。
您能提供有效的链接吗?
One more question I am not able to create a new post.
when I click on Topics: New then it search for post with new, So how to create a new post ?
最近编辑记录 piyush (2020-05-14 21:20:32)
#95 2020-05-14 21:45:36
已发帖子: 3,410
感谢您的链接,但它似乎坏了。
您能提供有效的链接吗?
请问你需要哪个文件?
#96 2020-05-14 22:05:34
piyush
所在地: India
已发帖子: 23
哇酷小二 wrote:
请问你需要哪个文件?
Thanks For reply smile.
#97 2020-05-14 22:33:29
已发帖子: 3,410
EWARM-CD-8201-14188.exe: https://pan.baidu.com/s/1jI7Kb8E?fid=984632783629706
EWARM-CD-7401-8472.exe: http://netstorage.iar.com/SuppDB/Protected/PRODUPD/009952/EWARM-CD-7401-8472.exe
#98 2020-05-14 23:02:04
piyush
所在地: India
已发帖子: 23
Thank you very much for the link.
But EWARM-CD-8201-14188.exe is still broken.
Will I need this crack file IAR7.x破解文件.rar ?
Actually I design a new F1C100S Hardware & I have to debug it.
For now I can get SPI Flash Clock pin signal but no rs232 message and no signale on SDClock.
I have not designed pad for SPI Flash as I want to use SD Card, So need to debug board.
非常感谢您提供的链接。
但是EWARM-CD-8201-14188.exe仍然损坏。
我需要这个破解文件IAR7.x crack file.rar吗?
实际上,我设计了一种新的F1C100S硬件,并且必须对其进行调试。
现在,我可以获得SPI Flash Clock引脚信号,但没有rs232消息,并且在SDClock上没有信号。
我还没有为SPI Flash设计焊盘,因为我想使用SD卡,因此需要调试电路板。
#99 2020-05-14 23:26:01
已发帖子: 3,410
#100 2020-05-15 10:55:31
hndawn
19年我也买了个F1C100s方案的唱戏机,当时55包邮,刚才去TB看了一下,已经下架,遗憾!!!哪个兄弟有购买链接发一个啊
#101 2020-05-15 15:08:54
piyush
所在地: India
已发帖子: 23
哇酷小二 wrote:
建议用MDK吧: https://whycan.cn/t_1527.html
Thankyour very much,
This is exactly what I need.
非常感谢你,
这正是我所需要的。
#102 2020-05-16 16:29:53
tianyekpsexzxg
之前也买过唱戏机,感觉这东西之前挺好卖的,不过现在手机流行,把唱戏机干下去了。不过全志的这颗芯片太有优势了
#103 2020-05-17 10:41:17
郝好小小
好帖,谢谢楼主无私奉献,初学者的福音
#104 2020-06-27 16:49:33
zkzhang
/files/members/1082/IMG_20190925_214430.jpeg
唱戏机的背光控制 一般是PWM 因为要控制背光的亮度 C100S PWM 只有两个 PE6 PE12 分辨对应的是 PIN 37 PIN43
#105 2020-06-30 17:16:01
qsszbsc
感谢分享,不知道现在买还是不是这个方案的了
#106 2020-07-19 23:29:56
xiaoerge
下了个单,隔了一天多没有发货,又取消了
#107 2020-07-20 11:04:06
qjb129
牛人啊,谢谢分享
#108 2020-07-20 11:16:56
piyush
所在地: India
已发帖子: 23
感谢分享
任何建议如何用音频/声音构建Linux
#109 2020-07-31 16:14:47
yuanxinfei
谢谢分享
解析的真的很好,正在研究他的原理图
#110 2020-08-03 17:44:15
Forrester
谢谢分享
解析的真的很好,正在研究他的原理图
#111 2020-08-04 09:27:04
DVR
感谢楼主分享,我这边正好学习要全志的芯片
#112 2020-08-11 10:57:23
打盹的消防车
哈哈哈,先科的,总能想到飞科。。。。。。
#113 2020-08-11 15:52:41
240011814
好帖,谢谢楼主无私奉献,初学者的福音
#114 2020-08-18 13:36:27
hongyancl
已发帖子: 19
好帖,谢谢楼主无私奉献
#115 2020-11-15 16:59:22
rick lou
所在地: 中国北京海淀
麻烦介绍一下按键的识别方式和引脚。
#116 2020-11-19 11:23:32
myxiaonia
已发帖子: 83
Jin劲 wrote:
agnd wrote:
晕啊,买了拆了还能退么?
哪里可以搞到这个tf转接板
#117 2020-11-19 11:45:20
raspberryman
已发帖子: 505
哪里可以搞到这个tf转接板
设计一片 SD NAND + JTAG(全志soc) 转接板
http://whycan.com/t_2025.html
#118 2022-05-12 12:10:07
luowuping597
准备入坑了。是不是太晚了?
#121 2023-08-08 16:21:00
bidezhi7777
已发帖子: 23
跟着玩一下,有现在成的板子!!!
#122 2025-03-23 20:32:01
GSL1337
@raspberryman
能不能转nor flash的呢
