开这帖子,估计就是为了扒光这颗芯片的内裤。
先来点初步研究成果,这个芯片里面的RISCV核玄铁906只能算通房丫鬟,正室还是ARM,估计是双核cortex-a7,当然还带有一个hifi dsp,这个是第三方的不公开,也不值得研究。
这个芯片算异构系统,总共4个核,2个cortex-a7(可能是一个,但一定存在),一个riscv-64,一个dsp。
初步确认的马甲有,D1, T1033, R528-RV, ...
V, T, R, F系列都会有马甲,静候风暴吧,这是一个什么钱都能挣到的马甲,同志们,努力研究吧,会有惊喜的。
关于DSP,关注Tensilica 这家公司,应该会有答案
cat /proc/cpuinfo
processor       : 0
hart            : 0
isa             : rv64imafdcvu
mmu             : sv39RISCV核支持的扩展,以及mmu信息
正室是可以被关禁闭的。
=> md.l 0x02001504 1
02001504: 80000000                               ....
=> md.l 0x02001500 2
02001500: 00000300 80000000                      ........
=> mw.l 0x02001504 0x000016aa
02001504: 00000000                               ....
02001508: 00000000                               ....
02001504: 00000000                               ....离线
opensbi太恶心了,程序都不給跳转,一跳转就指令异常,直接干掉这个,影响我开发引导程序
修改boot0干掉opensbi,修改uboot,增加go指令,借助fastboot,顺利启动xboot
=> go 0x41000800
## Starting application at 0x41000800 ...
OOOO       _                   _
 _  _ | |___ _____ _____ _| |_
\ \/ /|  _  |  _  |  _  |_   _|  (C) 2007-2021
 )  ( | |_| | |_| | |_| | | |____JIANJUN.JIANG__
/_/\_\|_____|_____|_____| |_____________________|
V3.0.0 (May 23 2021 - 15:15:37) - [nezha][Nezha Based On Allwinner D1 SOC]
[    0.000000] Probe device 'blk-romdisk.0' with blk-romdisk
[    0.000010] Probe device 'xin24m' with clk-fixed
[    0.000020] Probe device 'xin10m' with clk-fixed
[    0.000030] Probe device 'xin32k' with clk-fixed
[    0.000040] Probe device 'uart0' with clk-link
[    0.000050] Probe device 'uart1' with clk-link
[    0.000060] Probe device 'uart2' with clk-link
[    0.000070] Probe device 'uart3' with clk-link
[    0.000080] Probe device 'uart4' with clk-link
[    0.000090] Probe device 'uart5' with clk-link
[    0.000100] Probe device 'uart-16550.0' with uart-16550
[    0.000110] Probe device 'uart-16550.1' with uart-16550
[    0.000120] Probe device 'uart-16550.2' with uart-16550
[    0.000130] Probe device 'uart-16550.3' with uart-16550
[    0.000140] Probe device 'uart-16550.4' with uart-16550
[    0.000150] Probe device 'uart-16550.5' with uart-16550
[    0.000160] Probe device 'console-uart.0' with console-uart
[    0.000170] mount /private with 'ram' filesystem
Press any key to stop auto boot:  0.000
 could not found 'launcher' command
xboot: /#
xboot: /#
xboot: /#
xboot: /# help
 cat       - show the contents of a file
 cd        - change the current working directory
 clear     - clear the terminal screen
 cp        - copy files and directories
 date      - print the system date and time
 dcp       - device copy for file or block or memory
 delay     - delay for a specified time
 echo      - echo the string to standard output
 env       - display environment variable
 event     - show all of input events
 fdt       - flattened device tree utility commands
 go        - start application at address
 help      - show online help about command
 kill      - kill the window task
 ls        - list directory contents
 md        - dump a memory region
 mkdir     - make directories
 mkfat16   - format fat16 filesystem on block device
 mkfat32   - format fat32 filesystem on block device
 mkz       - compress and encrypt and signature image
 mount     - mount a file system
 mv        - move (rename) files
 mw        - write values to memory region
 overview  - show overview application of xui
 ps        - report a snapshot of the current processes
 pwd       - print the current working directory
 reboot    - reboot the target system
 rm        - remove files or directories
 rx        - receive file using xmodem
 setting   - display the global setting
 sha1sum   - compute sha1 message digest
 sha256sum - compute sha256 message digest
 shutdown  - shutdown the target system
 sleep     - sleep the target system
 sx        - send file using xmodem
 sync      - synchronize cached writes to storage
 test      - debug command for programmer
 tree      - list contents of directories in a tree-like format
 umount    - unmount a file system
 version   - show xboot version information
 write     - write contents to a file
 xsync     - xsync server for file copying为了达成这一步,用了很多高级技巧,万事开头难。现在啥工具都缺。
搬个小板凳等楼主更新
HIFI DSP应该和其它家的差不多。不是3就是4了
#define SID_PRCTL               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x40)
#define SID_PRKEY               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x50)
#define SID_RDKEY               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x60)
#define SJTAG_AT0               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x80)
#define SJTAG_AT1               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x84)
#define SJTAG_S                 (IOMEM_ADDR(SUNXI_SID_BASE) + 0x88)
#define SID_EFUSE               (IOMEM_ADDR(SUNXI_SID_BASE) + 0x200)
#define SID_OP_LOCK  (0xAC)
#define EFUSE_CHIPID            (0x0)
#define EFUSE_ANTI_BRUSH		(0x10)
#define EFUSE_OEM_PROGRAM		(0x38)
#define ANTI_BRUSH_BIT_OFFSET			(31)
#define ANTI_BRUSH_MODE			(SID_EFUSE + EFUSE_ANTI_BRUSH)
/* write protect */
#define EFUSE_WRITE_PROTECT		(0x40)
/* read  protect */
#define EFUSE_READ_PROTECT		(0x44)
/* jtag security */
#define EFUSE_HUK					(0x50)
#define EFUSE_ROTPK					(0x70)
#define EFUSE_SSK					(0x90)
#define EFUSE_RSSK					(0xB0)
#define EFUSE_HDCP_HASH				(0xC0)
#define EFUSE_NV1					(0xD0)
#define EFUSE_NV2					(0xD4)
#define EFUSE_OEM_PROGRAM_SECURE	(0xE4)
#define SID_HUK_SIZE					(192)
#define SID_OEM_PROGRAM_SIZE			(64)
#define SID_SSK_SIZE					(256)
#define SID_RSSK_SIZE					(128)
#define SID_HDCP_HASH_SIZE				(128)
#define SID_OEM_PROGRAM_SECURE_SIZE		(224)
/*read protect*/
#define SCC_OEM_PROGRAM_DONTSHOW_FLAG			(4)
#define SCC_ROTPK_DONTSHOW_FLAG					(12)
#define SCC_SSK_DONTSHOW_FLAG					(13)
#define SCC_RSSK_DONTSHOW_FLAG					(14)
#define SCC_HDCP_HASH_DONTSHOW_FLAG				(15)
#define SCC_OEM_PROGRAM_SECURE_DONTSHOW_FLAG	(18)
/*write protect*/
#define SCC_OEM_PROGRAM_BURNED_FLAG				(4)
#define SCC_HUK_BURNED_FLAG						(9)
#define SCC_ROTPK_BURNED_FLAG					(12)
#define SCC_SSK_BURNED_FLAG						(13)
#define SCC_RSSK_BURNED_FLAG					(14)
#define SCC_HDCP_HASH_BURNED_FLAG				(15)
#define SCC_OEM_PROGRAM_SECURE_BURNED_FLAG		(18)
/*efuse power ctl*/
#define EFUSE_HV_SWITCH			(IOMEM_ADDR(SUNXI_RTC_BASE) + 0x204)整个秘密都在SID里,这是个比较有用的信息,现在xboot可以获取D1的唯一序列号。
xboot: /# cat sys/class/machine/nezha/uniqueid
92805000dc0048140141d5812c5a1b0b离线
请问楼主, #5 楼怎么进入uboot命令模式? 按什么按键?
需要修改uboot的bootdelay
实现reset驱动,gpio驱动,串口驱动,还有一堆工作要做,任重道远!
加一条,D1对应F系的F133。
芯片内包的东西比较多(设计时并非只针对RV推出的芯片),所以D1的价格会比较尴尬。
是的,无所不包,要什么有什么,算比较完美的芯片,当然晶圆面积也小不了哪里去,脚越多的,全志定价肯定越贵,虽然是同一个东西。在满足要求的同时,尽量选脚少的。
如果包DDR版本定价在4个美金左右,还是有杀伤力的。
但是这几个不是一个芯片,需要澄清一下,以免各位开发者选片的时候误导了,具体还请咨询实际的商务和代理。
我大概说一下:D1——RISC-V片子; T1033——A7片子;R528-RV合作伙伴预研的时候拿到的测试片,后面不会再有了
有些片子可能有共台的情况,但是不是一个片子啊,都是内部要生要死分几个项目做出来的(泪目~
@Kirin
马甲不马甲,我们也真没那么关心,比较关心的还是哪有卖更实惠的芯片,能让利消费者,产品拥有成本优势,能在市场上拥有竞争力。这才是选择的出发点。你科技进步了,成本得降,不然那算哪门子科技进步。
这芯片拿来做图像处理可以吗 看里面hifi数字处理器像是搞音频的
@Kirin
话不能这么绝对,活在经济规律中,大家都要养家糊口的
@Kirin
收到,细心听取大家的建议(respect!
前来膜拜大神
D1包了那么多东西,然而少了MIPI-CSI 和 H264编码,不然就齐活了
工欲善其事,必先利其器,先开发个fel工具,名叫xfel
xfel-v1.0.0 https://github.com/xboot/xfel
usage:
    xfel help                                   - Print this usage summary
    xfel version                                - Show brom version
    xfel hexdump <address> <length>             - Dumps memory region in hex
    xfel dump <address> <length>                - Binary memory dump to stdout
    xfel exec <address>                         - Call function address
    xfel read32 <address>                       - Read 32-bits value from device memory
    xfel write32 <address> <value>              - Write 32-bits value to device memory
    xfel read <address> <length> <file>         - Read memory to file
    xfel write <address> <file>                 - Write file to memory
    xfel reset                                  - Reset device using watchdog
    xfel sid                                    - Output 128-bits SID information
    xfel jtag                                   - Enable JTAG debug
    xfel ddr [type]                             - Initial DDR controller with optional type
    xfel spinor                                 - Detect spi nor flash
    xfel spinor read <address> <length> <file>  - Read spi nor flash to file
    xfel spinor write <address> <file>          - Write file to spi nor flash
    xfel spinand                                - Detect spi nand flash
    xfel spinand read <address> <length> <file> - Read spi nand flash to file
    xfel spinand write <address> <file>         - Write file to spi nand flash离线
xfel项目工程路径,理论上全志全系列芯片都可以支持,不管是arm32,arm64,riscv64,短期重点目标是riscv64的D1支持,设计时避免过多hack,增强适应性,最大的特色借用xfel工具可以直接初始化DDR。
感兴趣的,可以尝尝鲜,开发中...
@Kirin
那D1里到底有木有A7呢?
@Kirin
那D1里到底有木有A7呢?
存在,但是D1锁死,没得用arm的哦,你用不了
d1-brom.zip
利用xfel工具dump出来的D1 brom,感兴趣的可以逆向看看
一段代码来石锤正室的存在,cortex-a7,不要有任何怀疑。
	/* a7:Reparent CPU during PLL CPU rate changes */
	ccu_mux_notifier_register(pll_cpux_clk.common.hw.clk,
				  &sun8iw20_cpu_nb);
	/* riscv:Reparent CPU during PLL CPU rate changes */
				  &sun20iw1_cpu_nb);离线
root@TinaLinux:/sys/kernel/debug/clk# cat clk_summary
                                 enable  prepare  protect                                duty
   clock                          count    count    count        rate   accuracy phase  cycle
 ext-32k                              1        1        0       32768          0     0  50000
    ext32k-gate                       1        1        0       32768          0     0  50000
       osc32k                         1        1        0       32768          0     0  50000
          r-apb0-ir-rx                0        0        0       32768          0     0  50000
          rtc-32k-fanout              0        0        0       32768          0     0  50000
          rtc32k                      1        1        0       32768          0     0  50000
             rtc-1k                   1        1        0        1024          0     0  50000
 rc-16m                               0        0        0    16000000  300000000     0  50000
    iosc                              0        0        0    16000000  300000000     0  50000
       iosc-div32k                    0        0        0       32000  300000000     0  50000
 dcxo24M                              6        6        0    24000000          0     0  50000
    r-apb0                            0        0        0    24000000          0     0  50000
       r-apb0-cpucfg                  0        0        0    24000000          0     0  50000
       r-apb0-bus-ir-rx               0        0        0    24000000          0     0  50000
       r-ppu                          0        0        0    24000000          0     0  50000
       r-apb0-twd                     0        0        0    24000000          0     0  50000
       r-apb0-timer                   0        0        0    24000000          0     0  50000
    r-ahb                             2        2        0    24000000          0     0  50000
       r-ahb-rtc                      1        1        0    24000000          0     0  50000
       rtc-spi                        1        1        0    24000000          0     0  50000
    fanout-24m                        0        0        0    24000000          0     0  50000
    tpadc                             0        0        0    24000000          0     0  50000
    csi0-mclk                         0        0        0    24000000          0     0  50000
    ledc                              0        0        0    24000000          0     0  50000
    tvd                               0        0        0    24000000          0     0  50000
    hdmi-24m                          0        0        0    24000000          0     0  50000
    ir-tx                             0        0        0    24000000          0     0  50000
    spi1                              0        0        0    24000000          0     0  50000
    mmc2                              0        0        0    24000000          0     0  50000
    mmc0                              0        0        0      800000          0     0  50000
    avs                               0        0        0    24000000          0     0  50000
    apb1                              1        1        0    24000000          0     0  50000
       bus-i2s2                       0        0        0    24000000          0     0  50000
       bus-i2s1                       0        0        0    24000000          0     0  50000
       bus-i2s0                       0        0        0    24000000          0     0  50000
       bus-can1                       0        0        0    24000000          0     0  50000
       bus-can0                       0        0        0    24000000          0     0  50000
       bus-i2c3                       0        0        0    24000000          0     0  50000
       bus-i2c2                       0        0        0    24000000          0     0  50000
       bus-i2c1                       0        0        0    24000000          0     0  50000
       bus-i2c0                       0        0        0    24000000          0     0  50000
       bus-uart5                      0        0        0    24000000          0     0  50000
       bus-uart4                      0        0        0    24000000          0     0  50000
       bus-uart3                      0        0        0    24000000          0     0  50000
       bus-uart2                      0        0        0    24000000          0     0  50000
       bus-uart1                      0        0        0    24000000          0     0  50000
       bus-uart0                      1        1        0    24000000          0     0  50000
    cpux                              1        1        0    24000000          0     0  50000
       apb                            0        0        0     6000000          0     0  50000
       axi                            0        0        0    24000000          0     0  50000
    pll-audio1                        0        0        0  3072000000          0     0  50000
       pll-audio1-div5                0        0        0   614400000          0     0  50000
       pll-audio1-div2                0        0        0  1536000000          0     0  50000
    pll-audio0-4x                     0        0        0    49142857          0     0  50000
       i2s2-asrc                      0        0        0    49142857          0     0  50000
       pll-audio0                     0        0        0    12285714          0     0  50000
          audio-codec-adc             0        0        0    12285714          0     0  50000
          audio-codec-dac             0        0        0    12285714          0     0  50000
          dmic                        0        0        0    12285714          0     0  50000
          spdif-tx                    0        0        0    12285714          0     0  50000
          i2s2                        0        0        0    12285714          0     0  50000
          i2s1                        0        0        0    12285714          0     0  50000
          i2s0                        0        0        0    12285714          0     0  50000
       pll-audio0-2x                  0        0        0    24571428          0     0  50000
    pll-ve                            0        0        0   432000000          0     0  50000
    pll-video1                        0        0        0   297000000          0     0  50000
       pll-video1-4x                  0        0        0  1188000000          0     0  50000
          tcon-tv                     0        0        0  1188000000          0     0  50000
       pll-video1-2x                  0        0        0   594000000          0     0  50000
    pll-video0                        0        0        0   102000000          0     0  50000
       fanout-27m                     0        0        0   102000000          0     0  50000
       tve                            0        0        0   102000000          0     0  50000
       pll-video0-4x                  0        0        0   408000000          0     0  50000
          tcon-lcd0                   0        0        0   408000000          0     0  50000
       pll-video0-2x                  0        0        0   204000000          0     0  50000
          mipi-dsi                    0        0        0   204000000          0     0  50000
    pll-periph0-parent                1        1        0  2400000000          0     0  50000
       pll-periph0-800m               0        0        0   800000000          0     0  50000
       pll-periph0-2x                 3        3        0  1200000000          0     0  50000
          mmc1                        1        1        0   100000000          0     0  50000
          fanout-32k                  1        1        0       32768          0     0  50000
             fanout2-out-clk          0        0        0       32768          0     0  50000
             fanout1-out-clk          1        1        0       32768          0     0  50000
             fanout0-out-clk          0        0        0       32768          0     0  50000
          fanout-16m                  0        0        0    16000000          0     0  50000
          dsp                         0        0        0   600000000          0     0  50000
          csi-top                     0        0        0  1200000000          0     0  50000
          hdmi-cec-32k                0        0        0       32768          0     0  50000
             hdmi-cec                 0        0        0       32768          0     0  50000
          ce                          0        0        0   400000000          0     0  50000
          g2d                         0        0        0  1200000000          0     0  50000
          di                          0        0        0  1200000000          0     0  50000
          de0                         0        0        0   300000000          0     0  50000
          pll-periph0-div3            0        0        0   200000000          0     0  50000
          pll-periph0                 4        4        0   600000000          0     0  50000
             spi0                     1        1        0   100000000          0     0  50000
             fanout-25m               0        0        0    25000000          0     0  50000
             spdif-rx                 0        0        0   600000000          0     0  50000
             emac0-25m                0        0        0   600000000          0     0  50000
             apb0                     3        3        0   100000000          0     0  50000
                fanout-pclk           0        0        0   100000000          0     0  50000
                bus-tzma              0        0        0   100000000          0     0  50000
                bus-tpadc             0        0        0   100000000          0     0  50000
                bus-audio-codec       0        0        0   100000000          0     0  50000
                bus-dmic              0        0        0   100000000          0     0  50000
                bus-spdif             0        0        0   100000000          0     0  50000
                bus-ths               0        0        0   100000000          0     0  50000
                bus-gpadc             0        0        0   100000000          0     0  50000
                bus-ir-tx             0        0        0   100000000          0     0  50000
                bus-iommu             1        1        0   100000000          0     0  50000
                bus-pwm               1        1        0   100000000          0     0  50000
             psi-ahb                  6        6        0   200000000          0     0  50000
                bus-riscv-cfg         0        0        0   200000000          0     0  50000
                bus-dsp-cfg           0        0        0   200000000          0     0  50000
                bus-csi               0        0        0   200000000          0     0  50000
                bus-ledc              0        0        0   200000000          0     0  50000
                bus-tvd-top           0        0        0   200000000          0     0  50000
                bus-tvd               0        0        0   200000000          0     0  50000
                bus-tve-top           0        0        0   200000000          0     0  50000
                bus-tve               0        0        0   200000000          0     0  50000
                bus-tcon-tv           0        0        0   200000000          0     0  50000
                bus-tcon-lcd0         0        0        0   200000000          0     0  50000
                bus-mipi-dsi          0        0        0   200000000          0     0  50000
                bus-hdmi              0        0        0   200000000          0     0  50000
                bus-dpss-top0         0        0        0   200000000          0     0  50000
                bus-lradc             1        1        0   200000000          0     0  50000
                bus-otg               1        1        0   200000000          0     0  50000
                bus-ehci1             0        0        0   200000000          0     0  50000
                bus-ehci0             0        0        0   200000000          0     0  50000
                bus-ohci1             0        0        0   200000000          0     0  50000
                bus-ohci0             0        0        0   200000000          0     0  50000
                bus-emac0             0        0        0   200000000          0     0  50000
                bus-spi1              0        0        0   200000000          0     0  50000
                bus-spi0              1        1        0   200000000          0     0  50000
                bus-mmc2              0        0        0   200000000          0     0  50000
                bus-mmc1              1        1        0   200000000          0     0  50000
                bus-mmc0              0        0        0   200000000          0     0  50000
                bus-dram              1        1        0   200000000          0     0  50000
                bus-dbg               0        0        0   200000000          0     0  50000
                bus-hstimer           0        0        0   200000000          0     0  50000
                bus-spinlock          0        0        0   200000000          0     0  50000
                bus-msgbox2           0        0        0   200000000          0     0  50000
                bus-msgbox1           0        0        0   200000000          0     0  50000
                bus-msgbox0           0        0        0   200000000          0     0  50000
                bus-dma               1        1        0   200000000          0     0  50000
                bus-ve                0        0        0   200000000          0     0  50000
                bus-ce                0        0        0   200000000          0     0  50000
                bus-g2d               0        0        0   200000000          0     0  50000
                bus-di                0        0        0   200000000          0     0  50000
                bus-de0               0        0        0   200000000          0     0  50000
    pll-ddr0                          2        2        0  1584000000          0     0  50000
       dram-clk                       0        0        0  1584000000          0     0  50000
       mbus                           1        1        0   396000000          0     0  50000
          mbus-g2d                    0        0        0   396000000          0     0  50000
          mbus-csi                    0        0        0   396000000          0     0  50000
          mbus-tvin                   0        0        0   396000000          0     0  50000
          mbus-ce                     0        0        0   396000000          0     0  50000
          mbus-ve                     0        0        0   396000000          0     0  50000
          mbus-dma                    1        1        0   396000000          0     0  50000
    pll-cpux                          0        0        0  1008000000          0     0  50000
       riscv                          0        0        0  1008000000          0     0  50000
          riscv-axi                   0        0        0   504000000          0     0  50000
       pll-cpux-div                   0        0        0  1008000000          0     0  50000
    osc12M                            0        0        0    12000000          0     0  50000
       fanout-12m                     0        0        0    12000000          0     0  50000
       usb-ohci1                      0        0        0    12000000          0     0  50000
       usb-ohci0                      0        0        0    12000000          0     0  50000
    dcxo24M-div32k                    0        0        0       32768          0     0  50000先dump整个时种,发现D1芯片里的PLL特别多,根本不是规格书里说的8个pll,而是至少有10个
a7是d2, d3的吧
实现中断驱动,定时器驱动
D1内存带宽测试
xboot: /# wboxtest benchmark
[benchmark]-[memcmp]
 Bandwidth: 117.588MB/s
[benchmark]-[memcpy]
 Bandwidth: 1.200GB/s
[benchmark]-[memmove]
 Bandwidth: 189.810MB/s
[benchmark]-[memset]
 Bandwidth: 2.457GB/s离线
d1spl.zip
一个小型spl测试镜像,可以通过xfel工具上传到sram,然后执行,并在串口输出相关debug信息
xfel上传镜像到sram中并执行操作指令
sudo xfel write 0x20000 output/d1spl.bin;
sudo xfel exec 0x20000;执行上述指令后,串口输出如下信息:
OK
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X                  这是彻底裸奔的第一步,下一步就可以初始化DDR了。
执行上述指令时,需要将D1置于fel模式,可以按着fel按键开机,就可以自动进入fel模式,或者直接清空flash里面内容。
D1快被扒的裤衩都不剩了。。。
玄铁扩展了指令集,一些有用的信息
http://crva.ict.ac.cn/crvs2020/index/slides/2-8.pdf
-MCFLAGS                := -march=rv64imafdc -mabi=lp64d -mcmodel=medany
+MCFLAGS                := -march=rv64gcvxthead -mabi=lp64d -mcmodel=medany也不是非得用官方编译器,标准编译器也是可以正常工作的,只不过扩展指令就别指望能用上了。
已实现DDR初始化
DRAM only have internal ZQ!!
get_pmu_exist() = 4294967295
ddr_efuse_type: 0x0
[AUTO DEBUG] two rank and full DQ!
ddr_efuse_type: 0x0
[AUTO DEBUG] rank 0 row = 15
[AUTO DEBUG] rank 0 bank = 8
[AUTO DEBUG] rank 0 page size = 2 KB
[AUTO DEBUG] rank 1 row = 15
[AUTO DEBUG] rank 1 bank = 8
[AUTO DEBUG] rank 1 page size = 2 KB
rank1 config same as rank0
DRAM BOOT DRIVE INFO: %s
DRAM CLK = 792 MHz
DRAM Type = 3 (2:DDR2,3:DDR3)
DRAMC ZQ value: 0x7b7bfb
DRAM ODT value: 0x42.
ddr_efuse_type: 0x0
DRAM SIZE =1024 M
DRAM simple test OK.
ok 1024
OK
X
X
X
X离线
XFEL已支持D1芯片的DDR初始化
仅需执行如下指令即可初始化DDR,支持DDR3以及LPDDR3的初始化。
sudo xfel ddr ddr3xfel ddr ddr3	- Initial ddr controller with ddr3
xfel ddr lpddr3	- Initial ddr controller with lpddr3执行这条指令后,串口会输出如下信息:
ddr_efuse_type: 0x0
ddr_efuse_type: 0x0
DRAM CLK = 792 MHz
ddr_efuse_type: 0x0
DRAM SIZE =1024 M
DRAM simple test OK.有了xfel,裸奔已经没有任何难度了。
下面就看大家各显神通了。
到这里,xboot就可以直接运行在ram中,无需uboot支持了
执行如下指令:
sudo xfel ddr ddr3
sudo xfel write 0x40000000 output/xboot.bin
sudo xfel exec 0x40000000离线
去知乎开了个专栏,广而告之。
https://www.zhihu.com/column/c_1382754923101081600
cat /proc/cpuinfo processor : 0 hart : 0 isa : rv64imafdcv[b]u[/b] mmu : sv39RISCV核支持的扩展,以及mmu信息
请问这个 U 是代表什么意思?
u可能是玄铁自己的扩展吧,具体是什么就不得而知了。在玄铁工具链里可以添加xthead标志生成玄铁扩展的指令集。
+MCFLAGS                := -march=rv64gcvxthead -mabi=lp64d -mcmodel=medany离线
@xboot
请问xfel支持 spi nand/nor 读写了吗?
spi nor及 spi nand的支持正在开发,计划先支持spi nor flash的烧写,spi nand的后延,现在底层spi接口,已支持F1C100S,V3S, V831, H3这四个芯片,D1暂未实现,一切都会有的,需要时间。。。
XFEL工具,在理论上,全志全系列芯片都是可以支持的,因全志芯片太多,个人也不可能拥有所有芯片的开发板,这里也只能借助大家的力量,欢迎大家踊跃pull request,以支持更多的芯片。
这里说明一下,如何支持一款芯片,以A40I为例,首先,在chips目录下创建一个名为a40i的文件,里面主要是实现struct chip_t这个结构,这些回调函数可以直接return 0,这个代表某个具体的指令不支持而已,但读写sram等都是可以的,这个支持由fel协议来实现的,具体的芯片不需做任何适配。
#include <fel.h>
static int chip_reset(struct xfel_ctx_t * ctx)
static int chip_sid(struct xfel_ctx_t * ctx, uint32_t * sid)
static int chip_jtag(struct xfel_ctx_t * ctx)
static int chip_ddr(struct xfel_ctx_t * ctx, const char * type)
static int chip_spi_init(struct xfel_ctx_t * ctx)
static int chip_spi_exit(struct xfel_ctx_t * ctx)
static int chip_spi_select(struct xfel_ctx_t * ctx)
static int chip_spi_deselect(struct xfel_ctx_t * ctx)
static int chip_spi_xfer(struct xfel_ctx_t * ctx, void * txbuf, uint32_t txlen, void * rxbuf, uint32_t rxlen)
struct chip_t a40i = {
	.name = "A40I",
	.id = 0x00170100,
	.reset = chip_reset,
	.sid = chip_sid,
	.jtag = chip_jtag,
	.ddr = chip_ddr,
	.spi_init = chip_spi_init,
	.spi_exit = chip_spi_exit,
	.spi_select = chip_spi_select,
	.spi_deselect = chip_spi_deselect,
	.spi_xfer = chip_spi_xfer,
};添加了a40i这个文件后,别忘记将这个加入到支持的芯片列表里,加入时按名字排序即可
extern struct chip_t a40i;
extern struct chip_t d1;
extern struct chip_t f1c100s;
extern struct chip_t h3;
extern struct chip_t r329;
extern struct chip_t t507;
extern struct chip_t v3s;
extern struct chip_t v831;
static struct chip_t * chips[] = {
	&a40i,
	&d1,
	&f1c100s,
	&h3,
	&r329,
	&t507,
	&v3s,
	&v831,
};这样提交后,xfel就支持了一款全志的新芯片了,当然很多高阶功能都是赞未实现的,这个也无关仅要,慢慢完善就可以了。
这里有个最关键的ID信息,需要填准确,这个获取很容易,将你的板子上电并进入芯片的fel模式,然后执行如下指令
sudo xfel version此时终端会反馈一串芯片信息,其中的soc字段就是芯片的id,十六进制方式表达。
AWUSBFEX soc=0x00170100(A40I) 0x00000001 ver=0x0001 0x44 0x08 scratchpad=0x00007e00支持一个新芯片是不是很简单呢,如果你手上有xfel还未支持的芯片,不妨按这个流程操作下,并pull request,争取能将xfel变成全志芯片裸机开发的瑞士军刀。
重新架构xfel工具的spi接口,采用命令队列方式,现在写入速度正常了,由原先的1.7KB/S提升到80KB/S,基本达到实用的程度了。
100% [================================================]  1049 kB,   81.0 kB/s
100% [================================================]  1049 kB,  184.4 kB/s 上面是的V831 spi nor flash的写入速度,下面是读速度。
xfel现已支持D1芯片SPI NOR FLASH的读写
100% [================================================]  1049 kB,  108.8 kB/s
100% [================================================]  1049 kB,  383.4 kB/s 上面是SPI NOR FLASH写入速度,下面是读速度。
现在xfel已支持F1C100S,V3S, V831, H3,D1这5个芯片的nor flash烧写,linux版就直接下载源码,自己编译就行,windows版工具,可以直接下载晕哥的,https://whycan.com/viewtopic.php?pid=64570#p64570
对于全志全系列芯片支持,这个还得靠大家一起努力,欢迎pull request,看到哪里缺了,手上又有现成开发板就顺手支持下,添加芯片的支持参考上面的帖子。为了提升烧录速度,接口有些变化,但大同小异,照着抄,就行了。
sunxi-fel工具至少是无法同时支持V3S以及F1C100S这两个芯片,这一点xfel做到了,而且还能支持RISCV平台,所以全系列芯片的支持,是完全可能的。
最近编辑记录 xboot (2021-06-15 09:29:39)
现在XBOOT已实现D1芯片的SPI FLASH自举引导,因为采用了内嵌机器码方案,所以就完全可以摒弃玄铁的专用工具链,任何一个RISCV工具链,都是可以编译并正常运行的,(可能玄铁编出来的性能更强吧,未测试)其中DDR初始化因为官方仅释放出一个玄铁工具链反编译出来.S文件,而且这个DDR初始化代码无法做到位置无关,所以,还是用上了之前解决V831 DDR初始化的思路,直接构造闭源二进制运行环境。引导头的校验和运算,还沿用全志传统的计算方法,所以,mksunxi工具可以无需做任何修改,直接利用就行。
还有一个异常,关于自拷贝的,这个地方被RISCV编译器给坑了,一开始还以为自己哪里代码写出异常了,查了半天,最后是因为RISCV编译器在链接,链接脚本中的导出符号时,会采用相对指令,而sys_copyself函数运行时,一般情况都不是运行在链接地址,任何地址都需要能正确运行,也就是需要实现成位置无关的程序,但我要自拷贝的目的地址则必须绝对的,不能是相对的,不然就拷贝错了。
这个用C如何获取链接脚本的绝对地址,我现在还没有很好手段,所以先暂时硬编码了,补丁如下:
diff --git a/src/arch/riscv64/mach-d1/sys-copyself.c b/src/arch/riscv64/mach-d1/sys-copyself.c
index 79ec9e9973381d3d01c0d0ee85b24c91e23aff8e..88fd32274f970afe939463b3ccbc6f8d3845eb09 100644
--- a/src/arch/riscv64/mach-d1/sys-copyself.c
+++ b/src/arch/riscv64/mach-d1/sys-copyself.c
@@ -53,7 +53,7 @@ void sys_copyself(void)
 	if(d == BOOT_DEVICE_SPINOR)
-		mem = (void *)__image_start;
+		mem = (void *)0x40000000;
 		size = __image_end - __image_start;
 		sys_spinor_init();不知在RISCV平台用C来获取链接脚本的绝对位置,如果有发现其他方法,不妨回复下,用C来控制RISCV编译器感觉还是比较困难的。
最近编辑记录 xboot (2021-06-17 13:11:22)
@xboot
既然.c不能实现绝对地址编码,
那 .S 的 copyself 能不能实现呢?
汇编是可以的,start.S里就有获取绝对链接地址的方式,但是,是开辟了一个存储空间来存储链接地址的,想获取时,通过相对指令访问这片存储空间,然后获取里面的值,算间接获取,汇编的控制能力,肯定要比C强很多。
	/* Copyself to link address */
	la t0, _start
	la t1, _image_start
	LREG t1, (t1)
 * The location of section
	.align 3
_image_start:
	RVPTR __image_start
_image_end:
	RVPTR __image_end离线
那可以通过汇编把 __image_start 当参数传递给C函数实现曲线救国吗?
也可以将_image_start变成全局标识,然后C里面去访问这个地址,再获取里面的值,就是觉得这样干,太不优雅了,总觉得很怪异。RISCV C编译器搞得这么绝吗?没留任何一种获取绝对链接地址的方式?
喔,原来如此,感谢大佬解惑。
头大,下面这样一条简单的赋值语句,也可能会被编译成auipc这种指令,也就说,这个代码如果不在链接地址运行赋值,那么赋值出来的结果一定是不正确的。这个问题太严重了,必须要找到一种控制方式,不然,在RISCV平台,根本无法写出适应性强的代码。
	struct ddr3_param_t * p = (struct ddr3_param_t *)0x00030018;
/*	p->dram_clk = 792;
	p->dram_type = 3;
	p->dram_zq = 0x7b7bfb;
	p->dram_odt_en = 0x01;
	p->dram_para1 = 0x000010d2;
	p->dram_para2 = 0x0000;
	p->dram_mr0 = 0x1c70;
	p->dram_mr1 = 0x042;
	p->dram_mr2 = 0x18;
	p->dram_mr3 = 0x0;
	p->dram_tpr0 = 0x004A2195;
	p->dram_tpr1 = 0x02423190;
	p->dram_tpr2 = 0x0008B061;
	p->dram_tpr3 = 0xB4787896;
	p->dram_tpr4 = 0x0;
	p->dram_tpr5 = 0x48484848;
	p->dram_tpr6 = 0x00000048;
	p->dram_tpr7 = 0x1620121e;
	p->dram_tpr8 = 0x0;
	p->dram_tpr9 = 0x0;
	p->dram_tpr10 = 0x0;
	p->dram_tpr11 = 0x00870000;
	p->dram_tpr12 = 0x00000024;
	p->dram_tpr13 = 0x34050100;*/离线
上面的赋值语句,随便组合下,完全看编译器的心情,心情好了就li直接立即数解决,心情不好了就上auipc指令,完全不受控。这情况谁能用C写出位置无关的代码?
使用medlow代码模型,链接脚本里的地址就可以直接引用了
为什么RISC-V GCC (Linux)默认使用medlow代码模型
RISC-V现在有两个代码模型:medlow和medany。
medlow: 对全局数据的寻址使用lui/ld的指令组合,程序被限制在[-2GB,2GB]内的连续2GB虚拟地址空间范围。
medany: 对全局数据的寻址使用auipc/ld指令码组合,程序被限制在任意连续的2GB虚拟地址空间范围。
在这两种代码模型中,lui和auipc都是为了设置全局数据的[31:8]位的20位高址。 在medlow模型中,由于lui/ld的指令组合使用0x00000000为基址做32比特地址寻址,当局部出现的多个全局数据寻址,他们可共享同一个lui设定的高址。 在medany模型中,lui被替换为auipc,使用pc为基址。由于所有的全局寻址为基于pc的相对寻址,medany代码模型可以支持对任意地址空间的寻址,突破medlow的地址空间限制。 同时,medany可以支持加载时地址重定向,即地址无关代码(position independent code, PIC)的生成。
在Linux环境中,所有的程序都是运行在虚拟内存中,独占一个虚拟内存空间。当不需要加载时地址重定向的需求时(非动态加载库), 使用medlow的lui/ld组合,GCC能够生成性能较优的代码,因而Linux上的RISC-V GCC默认使用medlow代码模型。 在编译动态加载库时,则需要手动使用medany代码模型。
为什么medany生成的代码性能比medlow差一些呢? 由于pc不是一个常量,对局部的多个全局数据寻址共享同一个auipc设定的高址可能会造成错误。 所以auipc/ld的指令组合并不能很好地被GCC优化,会产生大量的auipc指令。 此外,现有GCC编译器在-O -mcmodel=medany -mexplicit-relocs的参数组合下甚至会生成错误的代码。 在没有必要时,应当使用medlow模型,如果需要生成可重定向代码,现在暂时不要使用-O -mcmodel=medany -mexplicit-relocs的参数组合。离线
为方便大家研究全志RISCV D1芯片,花了点时间编写了一个精简版的裸机程序,方便大家学习参考。
https://whycan.com/t_6683.html
这个A7存在是干什么的了,玄铁号称很厉害,跟A5X或7X比怎么样
A7是正宫,别忽略她就行,玄铁性能未测试,A72这种水平肯定达不到的,A53估计有可能
玄铁这么厉害的么,还以为是A7 A9的性能呢。那有点意思
贴一下D1 BROM相关逆向信息
代码段,数据段,地址
0x00000000 text
0x0000e3f0 data符号表
0x00000022 fel_entry
0x00000028 normal_entry
0x0000010e sram_clear_stack
0x00000126 prcm_enable_rtc_clocks
0x00000166 debug_state_init
0x000001b4 boot_jump
0x000001bc FUN_000001bc
0x0000020e FUN_0000020e
0x0000026a FUN_0000026a
0x000002c6 FUN_000002c6
0x0000034e FUN_0000034e
0x0000047e FUN_0000047e
0x00000536 FUN_00000536
0x0000056a FUN_0000056a
0x000005e6 FUN_000005e6
0x00000660 FUN_00000660
0x00000a68 FUN_00000a68
0x00000afa FUN_00000afa
0x00000bbe FUN_00000bbe
0x00000c4c FUN_00000c4c
0x00000cce sunxi_sha_calc
0x00000f2c FUN_00000f2c
0x0000124a FUN_0000124a
0x00001396 FUN_00001396
0x00001424 FUN_00001424
0x0000150a FUN_0000150a
0x00001598 FUN_00001598
0x0000161e FUN_0000161e
0x00001772 FUN_00001772
0x0000199e FUN_0000199e
0x00001c3e FUN_00001c3e
0x00001cb4 FUN_00001cb4
0x00001e12 FUN_00001e12
0x00001f22 FUN_00001f22
0x000020ae FUN_000020ae
0x00002124 FUN_00002124
0x00002152 FUN_00002152
0x000021a8 ALIGN
0x000021f0 FUN_000021f0
0x00002256 FUN_00002256
0x0000239e FUN_0000239e
0x00002464 FUN_00002464
0x0000256e FUN_0000256e
0x00002742 FUN_00002742
0x0000279e FUN_0000279e
0x00002840 FUN_00002840
0x000028e0 FUN_000028e0
0x00002952 boot_verify_image
0x00002b68 boot_from_sdc0
0x00002bbc boot_from_sdc2
0x00002c88 FUN_00002c88
0x00002cdc FUN_00002cdc
0x00002d42 try_boot_process
0x00002e16 sid_boot_process
0x00002f16 gpio_boot_process
0x0000306c normal_boot_process
0x000030de attempt_fast_boot
0x00003226 maybe_attempt_fast_boot
0x00003284 normal_boot
0x00003320 trap_vector
0x000033c2 FUN_000033c2
0x00003462 FUN_00003462
0x000034ca FUN_000034ca
0x00003514 FUN_00003514
0x000035c4 FUN_000035c4
0x00003824 FUN_00003824
0x00003b08 memset
0x00003b44 load_boot0_from_sd
0x00003eaa boot_from_sd
0x00003f82 boot_from_emmc
0x00004208 FUN_00004208
0x00004238 FUN_00004238
0x00004264 FUN_00004264
0x000043e2 FUN_000043e2
0x000044d8 FUN_000044d8
0x00004596 FUN_00004596
0x0000463e FUN_0000463e
0x000048dc FUN_000048dc
0x00004924 FUN_00004924
0x000049aa FUN_000049aa
0x00004be4 FUN_00004be4
0x00004d1e FUN_00004d1e
0x00005064 FUN_00005064
0x000057c0 FUN_000057c0
0x00005858 FUN_00005858
0x0000588e FUN_0000588e
0x0000593a FUN_0000593a
0x00005984 FUN_00005984
0x000059d0 FUN_000059d0
0x00005a22 FUN_00005a22
0x00005b68 FUN_00005b68
0x00005cc4 FUN_00005cc4
0x00005d2c FUN_00005d2c
0x00005dc4 FUN_00005dc4
0x00005e22 FUN_00005e22
0x0000602c FUN_0000602c
0x0000608e FUN_0000608e
0x000060bc FUN_000060bc
0x000065ee FUN_000065ee
0x00006680 FUN_00006680
0x00006778 sd_read_sectors
0x00006846 FUN_00006846
0x0000694e FUN_0000694e
0x00006a2e FUN_00006a2e
0x00006ab0 FUN_00006ab0
0x00006b48 FUN_00006b48
0x00006b74 FUN_00006b74
0x00006bc0 FUN_00006bc0
0x00006c0c FUN_00006c0c
0x00006cec FUN_00006cec
0x00006d34 FUN_00006d34
0x00006d7c FUN_00006d7c
0x00006e0c FUN_00006e0c
0x00006e44 FUN_00006e44
0x00006ea0 FUN_00006ea0
0x00006edc FUN_00006edc
0x00006fd0 FUN_00006fd0
0x00007078 FUN_00007078
0x000070de FUN_000070de
0x00007146 FUN_00007146
0x000071b6 FUN_000071b6
0x00007554 FUN_00007554
0x00007590 FUN_00007590
0x00007688 FUN_00007688
0x000076c2 FUN_000076c2
0x000078fc FUN_000078fc
0x00007916 FUN_00007916
0x00007ad4 FUN_00007ad4
0x00007d1c FUN_00007d1c
0x00007d66 sid_readl
0x00007d96 FUN_00007d96
0x00007dba sid_init_brom_config
0x00007e14 sid_get_boot_mode
0x00007e44 brom_config_bit_2
0x00007e74 brom_config_skip_cache_setup
0x00007ea4 brom_config_bit_4
0x00007ec6 brom_config_bit_5
0x00007ef8 brom_config_bit_7_switch
0x00007f4c brom_config_bit_6
0x00007f70 FUN_00007f70
0x00007f80 brom_config_bit_13
0x00007fa6 brom_config_lower_ce_freq
0x00007fcc brom_config_disable_fel
0x00007ff0 FUN_00007ff0
0x00008000 brom_config_bit_10
0x00008024 brom_config_bit_15
0x0000804a brom_config_bit_8
0x0000806e brom_config_bit_1
0x00008090 brom_config_bit_12
0x000080b6 sid_get_boot_device
0x00008244 debug_state_save
0x00008388 debug_select_word
0x00008428 rtc_brom_debug
0x00008612 boot0_check_magic
0x000086b6 FUN_000086b6
0x000088c8 FUN_000088c8
0x00008942 FUN_00008942
0x00008a52 FUN_00008a52
0x00008a9a ccu_enable_pll_lock
0x00008b66 ccu_disable_pll_lock_output
0x00008ba4 ccu_enable_pll_output
0x00008be0 ccu_enable_pll_ldo
0x00008c26 ccu_enable_pll_cpux
0x00008cee FUN_00008cee
0x00008dce FUN_00008dce
0x00008ea2 FUN_00008ea2
0x00008f32 FUN_00008f32
0x00008fd8 FUN_00008fd8
0x00009068 ccu_set_cpux_to_24_MHz
0x000090dc ccu_set_psi_to_24_MHz
0x00009152 ccu_set_apb_to_24_MHz
0x00009228 ccu_set_ce_to_hosc
0x000092c8 FUN_000092c8
0x0000931e FUN_0000931e
0x00009418 FUN_00009418
0x0000947c ccu_reset_mbus_dram
0x000094b4 ccu_set_ce_reset
0x00009516 ccu_set_ce_gating
0x0000956c ccu_set_ce_to_pll
0x00009668 ccu_set_ce_clocks
0x000096fa ccu_init_cpu_ce_clocks
0x0000977c set_audio_codec_gating_bias
0x00009816 set_bg_trim_voltage
0x00009860 sid_read_voltages_0x14
0x000098b2 sid_read_voltage_0x1c
0x000098de prcm_set_gpu_pwroff_gating
0x00009916 prcm_set_ldo_voltage_bias
0x0000996c rtc_enable_hosc_iosc
0x000099c0 ccu_init_bus_clocks
0x000099e6 ccu_init
0x00009a00 debug_syscon
0x00009a48 rtc_get_fast_boot_status
0x00009a6c FUN_00009a6c
0x00009ac6 gpio_enable_jtag_pf
0x00009b1e riscv_init_caches
0x00009b4a fel_boot
0x00009ba4 boot_finish
0x00009bda trap_handler
0x00009c3c FUN_00009c3c
0x00009d08 FUN_00009d08
0x00009d30 FUN_00009d30
0x00009d88 FUN_00009d88
0x00009e8a memcpy
0x00009eea memset
0x00009f3a FUN_00009f3a
0x00009f6c FUN_00009f6c
0x0000a066 memset
0x0000a0a2 FUN_0000a0a2
0x0000a108 strncmp
0x0000a17e rdtime
0x0000a184 udelay
0x0000a1ae udelay_x800
0x0000a1d8 FUN_0000a1d8
0x0000a1e6 FUN_0000a1e6
0x0000a1f4 FUN_0000a1f4
0x0000a244 FUN_0000a244
0x0000a278 FUN_0000a278
0x0000a2c2 FUN_0000a2c2
0x0000a352 FUN_0000a352
0x0000a3e2 FUN_0000a3e2
0x0000a44c FUN_0000a44c
0x0000a4ea FUN_0000a4ea
0x0000a548 FUN_0000a548
0x0000a56e FUN_0000a56e
0x0000a5ca FUN_0000a5ca
0x0000a652 FUN_0000a652
0x0000a6ee FUN_0000a6ee
0x0000a73c FUN_0000a73c
0x0000a78e FUN_0000a78e
0x0000a7f6 do_fel_write
0x0000a93a do_fel_read
0x0000a9fa FUN_0000a9fa
0x0000aa4e FUN_0000aa4e
0x0000aab6 FUN_0000aab6
0x0000ab08 FUN_0000ab08
0x0000ad66 FUN_0000ad66
0x0000addc FUN_0000addc
0x0000ae64 usb_irq_handler
0x0000ae80 FUN_0000ae80
0x0000aedc FUN_0000aedc
0x0000afa2 FUN_0000afa2
0x0000afd6 interrupt_handler
0x0000b026 FUN_0000b026
0x0000b058 FUN_0000b058
0x0000b07c disable_interrupts
0x0000b09a enable_interrupts
0x0000b0b8 clear_interrupts
0x0000b0cc FUN_0000b0cc
0x0000b0f0 FUN_0000b0f0
0x0000b10e FUN_0000b10e
0x0000b1ac FUN_0000b1ac
0x0000b212 FUN_0000b212
0x0000b278 FUN_0000b278
0x0000b2c6 FUN_0000b2c6
0x0000b316 FUN_0000b316
0x0000b346 FUN_0000b346
0x0000b394 FUN_0000b394
0x0000b3e4 FUN_0000b3e4
0x0000b414 FUN_0000b414
0x0000b524 FUN_0000b524
0x0000b580 FUN_0000b580
0x0000b5d6 FUN_0000b5d6
0x0000b62c FUN_0000b62c
0x0000b682 FUN_0000b682
0x0000b6be FUN_0000b6be
0x0000b70c FUN_0000b70c
0x0000b746 FUN_0000b746
0x0000b7ba FUN_0000b7ba
0x0000b83a FUN_0000b83a
0x0000b876 FUN_0000b876
0x0000b8c4 FUN_0000b8c4
0x0000b908 FUN_0000b908
0x0000ba36 FUN_0000ba36
0x0000ba8a FUN_0000ba8a
0x0000bb68 FUN_0000bb68
0x0000bb76 FUN_0000bb76
0x0000bbb0 FUN_0000bbb0
0x0000bbea FUN_0000bbea
0x0000bc24 FUN_0000bc24
0x0000bc6c FUN_0000bc6c
0x0000bcb4 FUN_0000bcb4
0x0000bcfc FUN_0000bcfc
0x0000bd28 FUN_0000bd28
0x0000bd68 FUN_0000bd68
0x0000be18 FUN_0000be18
0x0000bff4 FUN_0000bff4
0x0000c140 FUN_0000c140
0x0000c3a2 FUN_0000c3a2
0x0000c60c FUN_0000c60c
0x0000c640 FUN_0000c640
0x0000c66a FUN_0000c66a
0x0000c786 FUN_0000c786
0x0000c7ba FUN_0000c7ba
0x0000c884 FUN_0000c884
0x0000cbba FUN_0000cbba
0x0000ccd4 FUN_0000ccd4
0x0000cea6 FUN_0000cea6
0x0000d08e fel_irq_handler
0x0000d3c0 FUN_0000d3c0
0x0000d3e2 FUN_0000d3e2
0x0000d488 fel_main
0x0000d69e FUN_0000d69e
0x0000d712 FUN_0000d712
0x0000d796 FUN_0000d796
0x0000d83c FUN_0000d83c
0x0000da38 FUN_0000da38
0x0000dbc6 FUN_0000dbc6
0x0000dc6c FUN_0000dc6c
0x0000dd08 FUN_0000dd08
0x0000dd5e FUN_0000dd5e
0x0000dec0 FUN_0000dec0
0x0000df16 FUN_0000df16
0x0000e112 usb_bgr_disable
0x0000e152 usb_bgr_enable
0x0000e1ca usb_phy_disable
0x0000e208 usb_clk_phy_enable
0x0000e282 FUN_0000e282
0x0000e2f8 usb_init
0x0000e31a syscon_read_fel_button
0x0000e396 gpio_get_boot_device离线
sun20iw1p1/rvbrom/blob.elf:     文件格式 elf64-littleriscv
Disassembly of section .0x0000000000000000:
0000000000000000 <fel_entry-0x22>:
       0:  4281                 li t0,0
       2:  4301                 li t1,0
       4:  4381                 li t2,0
       6:  4e01                 li t3,0
       8:  4e81                 li t4,0
       a:  4f01                 li t5,0
       c:  4f81                 li t6,0
       e:  4401                 li s0,0
      10:  4481                 li s1,0
      12:  4181                 li gp,0
      14:  4201                 li tp,0
      16:  4101                 li sp,0
      18:  4501                 li a0,0
      1a:  4581                 li a1,0
      1c:  4601                 li a2,0
      1e:  a029                 j 28 <normal_entry>
      20:  a009                 j 22 <fel_entry>
0000000000000022 <fel_entry>:
      22:  05c00493           li s1,92
      26:  a82d                 j 60 <normal_entry+0x38>
0000000000000028 <normal_entry>:
      28:  0fe000ef           jal ra,126 <prcm_enable_rtc_clocks>
      2c:  13a000ef           jal ra,166 <debug_state_init>
      30:  a801                 j 40 <normal_entry+0x18>
      32:  070002b7           lui t0,0x7000
      36:  5e02829b           addiw t0,t0,1504
      3a:  0002e303           lwu t1,0(t0) # 7000000 <gpio_get_boot_device+0x6ff1c6a>
      3e:  8302                 jr t1
      40:  070002b7           lui t0,0x7000
      44:  5dc2829b           addiw t0,t0,1500
      48:  0003f337           lui t1,0x3f
      4c:  9413031b           addiw t1,t1,-1727
      50:  00e31313           slli t1,t1,0xe
      54:  92f30313           addi t1,t1,-1745 # 3e92f <gpio_get_boot_device+0x30599>
      58:  0002e383           lwu t2,0(t0) # 7000000 <gpio_get_boot_device+0x6ff1c6a>
      5c:  fc730be3           beq t1,t2,32 <normal_entry+0xa>
      60:  00400337           lui t1,0x400
      64:  7c032073           csrs mxstatus,t1
      68:  000703b7           lui t2,0x70
      6c:  0133839b           addiw t2,t2,19
      70:  7c23a073           csrs mcor,t2
      74:  4321                 li t1,8
      76:  30033073           csrc mstatus,t1
      7a:  30401073           csrw mie,zero
      7e:  00003297           auipc t0,0x3
      82:  2a228293           addi t0,t0,674 # 3320 <trap_vector>
      86:  30529073           csrw mtvec,t0
      8a:  02050337           lui t1,0x2050
      8e:  0b83031b           addiw t1,t1,184
      92:  00036383           lwu t2,0(t1) # 2050000 <gpio_get_boot_device+0x2041c6a>
      96:  16aa0e37           lui t3,0x16aa0
      9a:  01c32023           sw t3,0(t1)
      9e:  07000337           lui t1,0x7000
      a2:  5e43031b           addiw t1,t1,1508
      a6:  00036283           lwu t0,0(t1) # 7000000 <gpio_get_boot_device+0x6ff1c6a>
      aa:  000103b7           lui t2,0x10
      ae:  fff3839b           addiw t2,t2,-1
      b2:  0053fe33           and t3,t2,t0
      b6:  0000feb7           lui t4,0xf
      ba:  fe8e8e9b           addiw t4,t4,-24
      be:  05de0063           beq t3,t4,fe <normal_entry+0xd6>
      c2:  00045137           lui sp,0x45
      c6:  ffc1011b           addiw sp,sp,-4
      ca:  030002b7           lui t0,0x3000
      ce:  0082829b           addiw t0,t0,8
      d2:  0002e303           lwu t1,0(t0) # 3000000 <gpio_get_boot_device+0x2ff1c6a>
      d6:  4385                 li t2,1
      d8:  00736e33           or t3,t1,t2
      dc:  01c2a023           sw t3,0(t0)
      e0:  07f00513           li a0,127
      e4:  05c00293           li t0,92
      e8:  00549463           bne s1,t0,f0 <normal_entry+0xc8>
      ec:  25f0906f           j 9b4a <fel_boot>
      f0:  01e000ef           jal ra,10e <sram_clear_stack>
      f4:  06f00513           li a0,111
      f8:  18c030ef           jal ra,3284 <normal_boot>
      fc:  a001                 j fc <normal_entry+0xd4>
      fe:  070002b7           lui t0,0x7000
     102:  5e82829b           addiw t0,t0,1512
     106:  0002e303           lwu t1,0(t0) # 7000000 <gpio_get_boot_device+0x6ff1c6a>
     10a:  8302                 jr t1
     10c:  a001                 j 10c <normal_entry+0xe4>
000000000000010e <sram_clear_stack>:
     10e:  000482b7           lui t0,0x48
     112:  d002829b           addiw t0,t0,-768
     116:  00048337           lui t1,0x48
     11a:  0002a023           sw zero,0(t0) # 48000 <gpio_get_boot_device+0x39c6a>
     11e:  0291                 addi t0,t0,4
     120:  fe62cde3           blt t0,t1,11a <sram_clear_stack+0xc>
     124:  8082                 ret
0000000000000126 <prcm_enable_rtc_clocks>:
     126:  070102b7           lui t0,0x7010
     12a:  20c2829b           addiw t0,t0,524
     12e:  0002e303           lwu t1,0(t0) # 7010000 <gpio_get_boot_device+0x7001c6a>
     132:  63c1                 lui t2,0x10
     134:  0063ee33           or t3,t2,t1
     138:  01c2a023           sw t3,0(t0)
     13c:  0002e303           lwu t1,0(t0)
     140:  00136393           ori t2,t1,1
     144:  0072a023           sw t2,0(t0)
     148:  070902b7           lui t0,0x7090
     14c:  3102829b           addiw t0,t0,784
     150:  0002e303           lwu t1,0(t0) # 7090000 <gpio_get_boot_device+0x7081c6a>
     154:  0010039b           addiw t2,zero,1
     158:  01f39393           slli t2,t2,0x1f
     15c:  0063ee33           or t3,t2,t1
     160:  01c2a023           sw t3,0(t0)
     164:  8082                 ret
0000000000000166 <debug_state_init>:
     166:  070902b7           lui t0,0x7090
     16a:  3042829b           addiw t0,t0,772
     16e:  0002e303           lwu t1,0(t0) # 7090000 <gpio_get_boot_device+0x7081c6a>
     172:  63a1                 lui t2,0x8
     174:  00737e33           and t3,t1,t2
     178:  020e0163           beqz t3,19a <debug_state_init+0x34>
     17c:  00008e37           lui t3,0x8
     180:  001e0e1b           addiw t3,t3,1
     184:  010e1e13           slli t3,t3,0x10
     188:  7ff00513           li a0,2047
     18c:  00a37eb3           and t4,t1,a0
     190:  01de6f33           or t5,t3,t4
     194:  01e2a023           sw t5,0(t0)
     198:  8082                 ret
     19a:  00008e37           lui t3,0x8
     19e:  001e0e1b           addiw t3,t3,1
     1a2:  07ff0537           lui a0,0x7ff0
     1a6:  00a37eb3           and t4,t1,a0
     1aa:  01de6f33           or t5,t3,t4
     1ae:  01e2a023           sw t5,0(t0)
     1b2:  8082                 ret
00000000000001b4 <boot_jump>:
     1b4:  8502                 jr a0
     1b6:  a001                 j 1b6 <boot_jump+0x2>
     1b8:  a001                 j 1b8 <boot_jump+0x4>
00000000000001bc <FUN_000001bc>:
     1bc:  7179                 addi sp,sp,-48
     1be:  f422                 sd s0,40(sp)
     1c0:  1800                 addi s0,sp,48
     1c2:  87aa                 mv a5,a0
     1c4:  fcf40fa3           sb a5,-33(s0)
     1c8:  fe042623           sw zero,-20(s0)
     1cc:  030007b7           lui a5,0x3000
     1d0:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     1d4:  439c                 lw a5,0(a5)
     1d6:  fef42623           sw a5,-20(s0)
     1da:  fec42703           lw a4,-20(s0)
     1de:  77c1                 lui a5,0xffff0
     1e0:  8ff9                 and a5,a5,a4
     1e2:  fef42623           sw a5,-20(s0)
     1e6:  fdf44783           lbu a5,-33(s0)
     1ea:  0007871b           sext.w a4,a5
     1ee:  fec42783           lw a5,-20(s0)
     1f2:  8fd9                 or a5,a5,a4
     1f4:  fef42623           sw a5,-20(s0)
     1f8:  030007b7           lui a5,0x3000
     1fc:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     200:  fec42703           lw a4,-20(s0)
     204:  c398                 sw a4,0(a5)
     206:  0001                 nop
     208:  7422                 ld s0,40(sp)
     20a:  6145                 addi sp,sp,48
     20c:  8082                 ret
000000000000020e <FUN_0000020e>:
     20e:  7179                 addi sp,sp,-48
     210:  f422                 sd s0,40(sp)
     212:  1800                 addi s0,sp,48
     214:  87aa                 mv a5,a0
     216:  fcf40fa3           sb a5,-33(s0)
     21a:  fe042623           sw zero,-20(s0)
     21e:  030007b7           lui a5,0x3000
     222:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     226:  439c                 lw a5,0(a5)
     228:  fef42623           sw a5,-20(s0)
     22c:  fec42703           lw a4,-20(s0)
     230:  ff0007b7           lui a5,0xff000
     234:  8ff9                 and a5,a5,a4
     236:  fef42623           sw a5,-20(s0)
     23a:  fdf44783           lbu a5,-33(s0)
     23e:  2781                 sext.w a5,a5
     240:  0107979b           slliw a5,a5,0x10
     244:  2781                 sext.w a5,a5
     246:  0007871b           sext.w a4,a5
     24a:  fec42783           lw a5,-20(s0)
     24e:  8fd9                 or a5,a5,a4
     250:  fef42623           sw a5,-20(s0)
     254:  030007b7           lui a5,0x3000
     258:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     25c:  fec42703           lw a4,-20(s0)
     260:  c398                 sw a4,0(a5)
     262:  0001                 nop
     264:  7422                 ld s0,40(sp)
     266:  6145                 addi sp,sp,48
     268:  8082                 ret
000000000000026a <FUN_0000026a>:
     26a:  7179                 addi sp,sp,-48
     26c:  f422                 sd s0,40(sp)
     26e:  1800                 addi s0,sp,48
     270:  87aa                 mv a5,a0
     272:  fcf40fa3           sb a5,-33(s0)
     276:  fe042623           sw zero,-20(s0)
     27a:  030007b7           lui a5,0x3000
     27e:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     282:  439c                 lw a5,0(a5)
     284:  fef42623           sw a5,-20(s0)
     288:  fec42703           lw a4,-20(s0)
     28c:  800007b7           lui a5,0x80000
     290:  8ff9                 and a5,a5,a4
     292:  fef42623           sw a5,-20(s0)
     296:  fdf44783           lbu a5,-33(s0)
     29a:  2781                 sext.w a5,a5
     29c:  0187979b           slliw a5,a5,0x18
     2a0:  2781                 sext.w a5,a5
     2a2:  0007871b           sext.w a4,a5
     2a6:  fec42783           lw a5,-20(s0)
     2aa:  8fd9                 or a5,a5,a4
     2ac:  fef42623           sw a5,-20(s0)
     2b0:  030007b7           lui a5,0x3000
     2b4:  0d078793           addi a5,a5,208 # 30000d0 <gpio_get_boot_device+0x2ff1d3a
     2b8:  fec42703           lw a4,-20(s0)
     2bc:  c398                 sw a4,0(a5)
     2be:  0001                 nop
     2c0:  7422                 ld s0,40(sp)
     2c2:  6145                 addi sp,sp,48
     2c4:  8082                 ret
00000000000002c6 <FUN_000002c6>:
     2c6:  7179                 addi sp,sp,-48
     2c8:  f406                 sd ra,40(sp)
     2ca:  f022                 sd s0,32(sp)
     2cc:  1800                 addi s0,sp,48
     2ce:  fca43c23           sd a0,-40(s0)
     2d2:  fcb43823           sd a1,-48(s0)
     2d6:  fe043423           sd zero,-24(s0)
     2da:  03800613           li a2,56
     2de:  4581                 li a1,0
     2e0:  fd043503           ld a0,-48(s0)
     2e4:  583090ef           jal ra,a066 <memset>
     2e8:  fd843783           ld a5,-40(s0)
     2ec:  fef43423           sd a5,-24(s0)
     2f0:  fe843783           ld a5,-24(s0)
     2f4:  0087c703           lbu a4,8(a5)
     2f8:  0097c683           lbu a3,9(a5)
     2fc:  06a2                 slli a3,a3,0x8
     2fe:  8f55                 or a4,a4,a3
     300:  00a7c683           lbu a3,10(a5)
     304:  06c2                 slli a3,a3,0x10
     306:  8f55                 or a4,a4,a3
     308:  00b7c783           lbu a5,11(a5)
     30c:  07e2                 slli a5,a5,0x18
     30e:  8fd9                 or a5,a5,a4
     310:  2781                 sext.w a5,a5
     312:  873e                 mv a4,a5
     314:  8911a7b7           lui a5,0x8911a
     318:  80078793           addi a5,a5,-2048 # ffffffff89119800 <gpio_get_boot_devic
     31c:  00f70463           beq a4,a5,324 <FUN_000002c6+0x5e>
     320:  57fd                 li a5,-1
     322:  a00d                 j 344 <FUN_000002c6+0x7e>
     324:  fd043783           ld a5,-48(s0)
     328:  fd843703           ld a4,-40(s0)
     32c:  e398                 sd a4,0(a5)
     32e:  fd043783           ld a5,-48(s0)
     332:  07a1                 addi a5,a5,8
     334:  03000613           li a2,48
     338:  fd843583           ld a1,-40(s0)
     33c:  853e                 mv a0,a5
     33e:  3fd090ef           jal ra,9f3a <FUN_00009f3a>
     342:  4781                 li a5,0
     344:  853e                 mv a0,a5
     346:  70a2                 ld ra,40(sp)
     348:  7402                 ld s0,32(sp)
     34a:  6145                 addi sp,sp,48
     34c:  8082                 ret
000000000000034e <FUN_0000034e>:
     34e:  715d                 addi sp,sp,-80
     350:  e486                 sd ra,72(sp)
     352:  e0a2                 sd s0,64(sp)
     354:  0880                 addi s0,sp,80
     356:  fca43c23           sd a0,-40(s0)
     35a:  87ae                 mv a5,a1
     35c:  fcc43423           sd a2,-56(s0)
     360:  fcd43023           sd a3,-64(s0)
     364:  fae43c23           sd a4,-72(s0)
     368:  fcf42a23           sw a5,-44(s0)
     36c:  fe042623           sw zero,-20(s0)
     370:  fe043023           sd zero,-32(s0)
     374:  fc843783           ld a5,-56(s0)
     378:  0007b023           sd zero,0(a5)
     37c:  fc043783           ld a5,-64(s0)
     380:  0007a023           sw zero,0(a5)
     384:  fd843783           ld a5,-40(s0)
     388:  639c                 ld a5,0(a5)
     38a:  03078793           addi a5,a5,48
     38e:  fef43023           sd a5,-32(s0)
     392:  fe042623           sw zero,-20(s0)
     396:  a0f9                 j 464 <FUN_0000034e+0x116>
     398:  fec42783           lw a5,-20(s0)
     39c:  0796                 slli a5,a5,0x5
     39e:  fe043703           ld a4,-32(s0)
     3a2:  97ba                 add a5,a5,a4
     3a4:  0007c703           lbu a4,0(a5)
     3a8:  0017c683           lbu a3,1(a5)
     3ac:  06a2                 slli a3,a3,0x8
     3ae:  8f55                 or a4,a4,a3
     3b0:  0027c683           lbu a3,2(a5)
     3b4:  06c2                 slli a3,a3,0x10
     3b6:  8f55                 or a4,a4,a3
     3b8:  0037c783           lbu a5,3(a5)
     3bc:  07e2                 slli a5,a5,0x18
     3be:  8fd9                 or a5,a5,a4
     3c0:  0007871b           sext.w a4,a5
     3c4:  fd442783           lw a5,-44(s0)
     3c8:  2781                 sext.w a5,a5
     3ca:  08e79863           bne a5,a4,45a <FUN_0000034e+0x10c>
     3ce:  fd843783           ld a5,-40(s0)
     3d2:  6398                 ld a4,0(a5)
     3d4:  fec42783           lw a5,-20(s0)
     3d8:  0796                 slli a5,a5,0x5
     3da:  fe043683           ld a3,-32(s0)
     3de:  97b6                 add a5,a5,a3
     3e0:  0047c683           lbu a3,4(a5)
     3e4:  0057c603           lbu a2,5(a5)
     3e8:  0622                 slli a2,a2,0x8
     3ea:  8ed1                 or a3,a3,a2
     3ec:  0067c603           lbu a2,6(a5)
     3f0:  0642                 slli a2,a2,0x10
     3f2:  8ed1                 or a3,a3,a2
     3f4:  0077c783           lbu a5,7(a5)
     3f8:  07e2                 slli a5,a5,0x18
     3fa:  8fd5                 or a5,a5,a3
     3fc:  2781                 sext.w a5,a5
     3fe:  1782                 slli a5,a5,0x20
     400:  9381                 srli a5,a5,0x20
     402:  973e                 add a4,a4,a5
     404:  fc843783           ld a5,-56(s0)
     408:  e398                 sd a4,0(a5)
     40a:  fec42783           lw a5,-20(s0)
     40e:  0796                 slli a5,a5,0x5
     410:  fe043703           ld a4,-32(s0)
     414:  97ba                 add a5,a5,a4
     416:  0087c703           lbu a4,8(a5)
     41a:  0097c683           lbu a3,9(a5)
     41e:  06a2                 slli a3,a3,0x8
     420:  8f55                 or a4,a4,a3
     422:  00a7c683           lbu a3,10(a5)
     426:  06c2                 slli a3,a3,0x10
     428:  8f55                 or a4,a4,a3
     42a:  00b7c783           lbu a5,11(a5)
     42e:  07e2                 slli a5,a5,0x18
     430:  8fd9                 or a5,a5,a4
     432:  0007871b           sext.w a4,a5
     436:  fc043783           ld a5,-64(s0)
     43a:  c398                 sw a4,0(a5)
     43c:  fec42783           lw a5,-20(s0)
     440:  0796                 slli a5,a5,0x5
     442:  fe043703           ld a4,-32(s0)
     446:  97ba                 add a5,a5,a4
     448:  02000613           li a2,32
     44c:  85be                 mv a1,a5
     44e:  fb843503           ld a0,-72(s0)
     452:  2e9090ef           jal ra,9f3a <FUN_00009f3a>
     456:  4781                 li a5,0
     458:  a831                 j 474 <FUN_0000034e+0x126>
     45a:  fec42783           lw a5,-20(s0)
     45e:  2785                 addiw a5,a5,1
     460:  fef42623           sw a5,-20(s0)
     464:  fd843783           ld a5,-40(s0)
     468:  5398                 lw a4,32(a5)
     46a:  fec42783           lw a5,-20(s0)
     46e:  f2e7e5e3           bltu a5,a4,398 <FUN_0000034e+0x4a>
     472:  57fd                 li a5,-1
     474:  853e                 mv a0,a5
     476:  60a6                 ld ra,72(sp)
     478:  6406                 ld s0,64(sp)
     47a:  6161                 addi sp,sp,80
     47c:  8082                 ret
000000000000047e <FUN_0000047e>:
     47e:  7139                 addi sp,sp,-64
     480:  fc06                 sd ra,56(sp)
     482:  f822                 sd s0,48(sp)
     484:  0080                 addi s0,sp,64
     486:  fca43423           sd a0,-56(s0)
     48a:  fcb43023           sd a1,-64(s0)
     48e:  fe043423           sd zero,-24(s0)
     492:  fe043023           sd zero,-32(s0)
     496:  fc042e23           sw zero,-36(s0)
     49a:  fc843783           ld a5,-56(s0)
     49e:  6398                 ld a4,0(a5)
     4a0:  fc043783           ld a5,-64(s0)
     4a4:  0047c683           lbu a3,4(a5)
     4a8:  0057c603           lbu a2,5(a5)
     4ac:  0622                 slli a2,a2,0x8
     4ae:  8ed1                 or a3,a3,a2
     4b0:  0067c603           lbu a2,6(a5)
     4b4:  0642                 slli a2,a2,0x10
     4b6:  8ed1                 or a3,a3,a2
     4b8:  0077c783           lbu a5,7(a5)
     4bc:  07e2                 slli a5,a5,0x18
     4be:  8fd5                 or a5,a5,a3
     4c0:  2781                 sext.w a5,a5
     4c2:  1782                 slli a5,a5,0x20
     4c4:  9381                 srli a5,a5,0x20
     4c6:  97ba                 add a5,a5,a4
     4c8:  fef43423           sd a5,-24(s0)
     4cc:  fc043783           ld a5,-64(s0)
     4d0:  0147c703           lbu a4,20(a5)
     4d4:  0157c683           lbu a3,21(a5)
     4d8:  06a2                 slli a3,a3,0x8
     4da:  8f55                 or a4,a4,a3
     4dc:  0167c683           lbu a3,22(a5)
     4e0:  06c2                 slli a3,a3,0x10
     4e2:  8f55                 or a4,a4,a3
     4e4:  0177c783           lbu a5,23(a5)
     4e8:  07e2                 slli a5,a5,0x18
     4ea:  8fd9                 or a5,a5,a4
     4ec:  2781                 sext.w a5,a5
     4ee:  1782                 slli a5,a5,0x20
     4f0:  9381                 srli a5,a5,0x20
     4f2:  fef43023           sd a5,-32(s0)
     4f6:  fc043783           ld a5,-64(s0)
     4fa:  0087c703           lbu a4,8(a5)
     4fe:  0097c683           lbu a3,9(a5)
     502:  06a2                 slli a3,a3,0x8
     504:  8f55                 or a4,a4,a3
     506:  00a7c683           lbu a3,10(a5)
     50a:  06c2                 slli a3,a3,0x10
     50c:  8f55                 or a4,a4,a3
     50e:  00b7c783           lbu a5,11(a5)
     512:  07e2                 slli a5,a5,0x18
     514:  8fd9                 or a5,a5,a4
     516:  fcf42e23           sw a5,-36(s0)
     51a:  fdc42783           lw a5,-36(s0)
     51e:  863e                 mv a2,a5
     520:  fe843583           ld a1,-24(s0)
     524:  fe043503           ld a0,-32(s0)
     528:  245090ef           jal ra,9f6c <FUN_00009f6c>
     52c:  0001                 nop
     52e:  70e2                 ld ra,56(sp)
     530:  7442                 ld s0,48(sp)
     532:  6121                 addi sp,sp,64
     534:  8082                 ret
0000000000000536 <FUN_00000536>:
     536:  1101                 addi sp,sp,-32
     538:  ec22                 sd s0,24(sp)
     53a:  1000                 addi s0,sp,32
     53c:  fea43423           sd a0,-24(s0)
     540:  fe843783           ld a5,-24(s0)
     544:  0147c703           lbu a4,20(a5)
     548:  0157c683           lbu a3,21(a5)
     54c:  06a2                 slli a3,a3,0x8
     54e:  8f55                 or a4,a4,a3
     550:  0167c683           lbu a3,22(a5)
     554:  06c2                 slli a3,a3,0x10
     556:  8f55                 or a4,a4,a3
     558:  0177c783           lbu a5,23(a5)
     55c:  07e2                 slli a5,a5,0x18
     55e:  8fd9                 or a5,a5,a4
     560:  2781                 sext.w a5,a5
     562:  853e                 mv a0,a5
     564:  6462                 ld s0,24(sp)
     566:  6105                 addi sp,sp,32
     568:  8082                 ret
000000000000056a <FUN_0000056a>:
     56a:  1101                 addi sp,sp,-32
     56c:  ec22                 sd s0,24(sp)
     56e:  1000                 addi s0,sp,32
     570:  fe042623           sw zero,-20(s0)
     574:  020017b7           lui a5,0x2001
     578:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
     57c:  439c                 lw a5,0(a5)
     57e:  fef42423           sw a5,-24(s0)
     582:  fe842703           lw a4,-24(s0)
     586:  77c1                 lui a5,0xffff0
     588:  17fd                 addi a5,a5,-1
     58a:  8ff9                 and a5,a5,a4
     58c:  fef42423           sw a5,-24(s0)
     590:  020017b7           lui a5,0x2001
     594:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
     598:  fe842703           lw a4,-24(s0)
     59c:  c398                 sw a4,0(a5)
     59e:  06400793           li a5,100
     5a2:  fef42623           sw a5,-20(s0)
     5a6:  0001                 nop
     5a8:  fec42783           lw a5,-20(s0)
     5ac:  fff7871b           addiw a4,a5,-1
     5b0:  fee42623           sw a4,-20(s0)
     5b4:  fbf5                 bnez a5,5a8 <FUN_0000056a+0x3e>
     5b6:  020017b7           lui a5,0x2001
     5ba:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
     5be:  439c                 lw a5,0(a5)
     5c0:  fef42423           sw a5,-24(s0)
     5c4:  fe842703           lw a4,-24(s0)
     5c8:  67c1                 lui a5,0x10
     5ca:  8fd9                 or a5,a5,a4
     5cc:  fef42423           sw a5,-24(s0)
     5d0:  020017b7           lui a5,0x2001
     5d4:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
     5d8:  fe842703           lw a4,-24(s0)
     5dc:  c398                 sw a4,0(a5)
     5de:  0001                 nop
     5e0:  6462                 ld s0,24(sp)
     5e2:  6105                 addi sp,sp,32
     5e4:  8082                 ret
00000000000005e6 <FUN_000005e6>:
     5e6:  7179                 addi sp,sp,-48
     5e8:  f422                 sd s0,40(sp)
     5ea:  1800                 addi s0,sp,48
     5ec:  87aa                 mv a5,a0
     5ee:  fcf42e23           sw a5,-36(s0)
     5f2:  fdc42783           lw a5,-36(s0)
     5f6:  0187979b           slliw a5,a5,0x18
     5fa:  fef42623           sw a5,-20(s0)
     5fe:  fdc42783           lw a5,-36(s0)
     602:  0087979b           slliw a5,a5,0x8
     606:  2781                 sext.w a5,a5
     608:  873e                 mv a4,a5
     60a:  00ff07b7           lui a5,0xff0
     60e:  8ff9                 and a5,a5,a4
     610:  fef42423           sw a5,-24(s0)
     614:  fdc42783           lw a5,-36(s0)
     618:  0087d79b           srliw a5,a5,0x8
     61c:  2781                 sext.w a5,a5
     61e:  873e                 mv a4,a5
     620:  67c1                 lui a5,0x10
     622:  f0078793           addi a5,a5,-256 # ff00 <gpio_get_boot_device+0x1b6a>
     626:  8ff9                 and a5,a5,a4
     628:  fef42223           sw a5,-28(s0)
     62c:  fdc42783           lw a5,-36(s0)
     630:  0187d79b           srliw a5,a5,0x18
     634:  fef42023           sw a5,-32(s0)
     638:  fec42703           lw a4,-20(s0)
     63c:  fe842783           lw a5,-24(s0)
     640:  8fd9                 or a5,a5,a4
     642:  0007871b           sext.w a4,a5
     646:  fe442783           lw a5,-28(s0)
     64a:  8fd9                 or a5,a5,a4
     64c:  0007871b           sext.w a4,a5
     650:  fe042783           lw a5,-32(s0)
     654:  8fd9                 or a5,a5,a4
     656:  2781                 sext.w a5,a5
     658:  853e                 mv a0,a5
     65a:  7422                 ld s0,40(sp)
     65c:  6145                 addi sp,sp,48
     65e:  8082                 ret
0000000000000660 <FUN_00000660>:
     660:  7119                 addi sp,sp,-128
     662:  fc86                 sd ra,120(sp)
     664:  f8a2                 sd s0,112(sp)
     666:  0100                 addi s0,sp,128
     668:  87aa                 mv a5,a0
     66a:  f8b43023           sd a1,-128(s0)
     66e:  f8f42623           sw a5,-116(s0)
     672:  f8c42783           lw a5,-116(s0)
     676:  0067d79b           srliw a5,a5,0x6
     67a:  fef42223           sw a5,-28(s0)
     67e:  f8c42783           lw a5,-116(s0)
     682:  03f7f793           andi a5,a5,63
     686:  fef42023           sw a5,-32(s0)
     68a:  f9840793           addi a5,s0,-104
     68e:  fcf43c23           sd a5,-40(s0)
     692:  fe042783           lw a5,-32(s0)
     696:  2781                 sext.w a5,a5
     698:  efe1                 bnez a5,770 <FUN_00000660+0x110>
     69a:  fe042623           sw zero,-20(s0)
     69e:  a831                 j 6ba <FUN_00000660+0x5a>
     6a0:  fec46783           lwu a5,-20(s0)
     6a4:  078a                 slli a5,a5,0x2
     6a6:  ff040713           addi a4,s0,-16
     6aa:  97ba                 add a5,a5,a4
     6ac:  fa07a423           sw zero,-88(a5)
     6b0:  fec42783           lw a5,-20(s0)
     6b4:  2785                 addiw a5,a5,1
     6b6:  fef42623           sw a5,-20(s0)
     6ba:  fec42783           lw a5,-20(s0)
     6be:  0007871b           sext.w a4,a5
     6c2:  47bd                 li a5,15
     6c4:  fce7fee3           bgeu a5,a4,6a0 <FUN_00000660+0x40>
     6c8:  08000793           li a5,128
     6cc:  f8f42c23           sw a5,-104(s0)
     6d0:  f8c42783           lw a5,-116(s0)
     6d4:  01d7d79b           srliw a5,a5,0x1d
     6d8:  2781                 sext.w a5,a5
     6da:  fcf42823           sw a5,-48(s0)
     6de:  f8c42783           lw a5,-116(s0)
     6e2:  0037979b           slliw a5,a5,0x3
     6e6:  2781                 sext.w a5,a5
     6e8:  fcf42a23           sw a5,-44(s0)
     6ec:  fd042783           lw a5,-48(s0)
     6f0:  853e                 mv a0,a5
     6f2:  ef5ff0ef           jal ra,5e6 <FUN_000005e6>
     6f6:  87aa                 mv a5,a0
     6f8:  2781                 sext.w a5,a5
     6fa:  fcf42823           sw a5,-48(s0)
     6fe:  fd442783           lw a5,-44(s0)
     702:  853e                 mv a0,a5
     704:  ee3ff0ef           jal ra,5e6 <FUN_000005e6>
     708:  87aa                 mv a5,a0
     70a:  2781                 sext.w a5,a5
     70c:  fcf42a23           sw a5,-44(s0)
     710:  fe042623           sw zero,-20(s0)
     714:  a82d                 j 74e <FUN_00000660+0xee>
     716:  fec46783           lwu a5,-20(s0)
     71a:  fd843703           ld a4,-40(s0)
     71e:  973e                 add a4,a4,a5
     720:  fe442783           lw a5,-28(s0)
     724:  0067979b           slliw a5,a5,0x6
     728:  2781                 sext.w a5,a5
     72a:  fec42683           lw a3,-20(s0)
     72e:  9fb5                 addw a5,a5,a3
     730:  2781                 sext.w a5,a5
     732:  1782                 slli a5,a5,0x20
     734:  9381                 srli a5,a5,0x20
     736:  f8043683           ld a3,-128(s0)
     73a:  97b6                 add a5,a5,a3
     73c:  00074703           lbu a4,0(a4)
     740:  00e78023           sb a4,0(a5)
     744:  fec42783           lw a5,-20(s0)
     748:  2785                 addiw a5,a5,1
     74a:  fef42623           sw a5,-20(s0)
     74e:  fec42783           lw a5,-20(s0)
     752:  0007871b           sext.w a4,a5
     756:  03f00793           li a5,63
     75a:  fae7fee3           bgeu a5,a4,716 <FUN_00000660+0xb6>
     75e:  fe442783           lw a5,-28(s0)
     762:  2785                 addiw a5,a5,1
     764:  2781                 sext.w a5,a5
     766:  0067979b           slliw a5,a5,0x6
     76a:  fef42423           sw a5,-24(s0)
     76e:  a4f5                 j a5a <FUN_00000660+0x3fa>
     770:  fe042783           lw a5,-32(s0)
     774:  0007871b           sext.w a4,a5
     778:  03700793           li a5,55
     77c:  12e7e963           bltu a5,a4,8ae <FUN_00000660+0x24e>
     780:  fe042623           sw zero,-20(s0)
     784:  a831                 j 7a0 <FUN_00000660+0x140>
     786:  fec46783           lwu a5,-20(s0)
     78a:  078a                 slli a5,a5,0x2
     78c:  ff040713           addi a4,s0,-16
     790:  97ba                 add a5,a5,a4
     792:  fa07a423           sw zero,-88(a5)
     796:  fec42783           lw a5,-20(s0)
     79a:  2785                 addiw a5,a5,1
     79c:  fef42623           sw a5,-20(s0)
     7a0:  fec42783           lw a5,-20(s0)
     7a4:  0007871b           sext.w a4,a5
     7a8:  47bd                 li a5,15
     7aa:  fce7fee3           bgeu a5,a4,786 <FUN_00000660+0x126>
     7ae:  fe042623           sw zero,-20(s0)
     7b2:  a82d                 j 7ec <FUN_00000660+0x18c>
     7b4:  fe442783           lw a5,-28(s0)
     7b8:  0067979b           slliw a5,a5,0x6
     7bc:  2781                 sext.w a5,a5
     7be:  fec42703           lw a4,-20(s0)
     7c2:  9fb9                 addw a5,a5,a4
     7c4:  2781                 sext.w a5,a5
     7c6:  1782                 slli a5,a5,0x20
     7c8:  9381                 srli a5,a5,0x20
     7ca:  f8043703           ld a4,-128(s0)
     7ce:  973e                 add a4,a4,a5
     7d0:  fec46783           lwu a5,-20(s0)
     7d4:  fd843683           ld a3,-40(s0)
     7d8:  97b6                 add a5,a5,a3
     7da:  00074703           lbu a4,0(a4)
     7de:  00e78023           sb a4,0(a5)
     7e2:  fec42783           lw a5,-20(s0)
     7e6:  2785                 addiw a5,a5,1
     7e8:  fef42623           sw a5,-20(s0)
     7ec:  fec42703           lw a4,-20(s0)
     7f0:  fe042783           lw a5,-32(s0)
     7f4:  2701                 sext.w a4,a4
     7f6:  2781                 sext.w a5,a5
     7f8:  faf76ee3           bltu a4,a5,7b4 <FUN_00000660+0x154>
     7fc:  fe046783           lwu a5,-32(s0)
     800:  fd843703           ld a4,-40(s0)
     804:  97ba                 add a5,a5,a4
     806:  f8000713           li a4,-128
     80a:  00e78023           sb a4,0(a5)
     80e:  f8c42783           lw a5,-116(s0)
     812:  01d7d79b           srliw a5,a5,0x1d
     816:  2781                 sext.w a5,a5
     818:  fcf42823           sw a5,-48(s0)
     81c:  f8c42783           lw a5,-116(s0)
     820:  0037979b           slliw a5,a5,0x3
     824:  2781                 sext.w a5,a5
     826:  fcf42a23           sw a5,-44(s0)
     82a:  fd042783           lw a5,-48(s0)
     82e:  853e                 mv a0,a5
     830:  db7ff0ef           jal ra,5e6 <FUN_000005e6>
     834:  87aa                 mv a5,a0
     836:  2781                 sext.w a5,a5
     838:  fcf42823           sw a5,-48(s0)
     83c:  fd442783           lw a5,-44(s0)
     840:  853e                 mv a0,a5
     842:  da5ff0ef           jal ra,5e6 <FUN_000005e6>
     846:  87aa                 mv a5,a0
     848:  2781                 sext.w a5,a5
     84a:  fcf42a23           sw a5,-44(s0)
     84e:  fe042623           sw zero,-20(s0)
     852:  a82d                 j 88c <FUN_00000660+0x22c>
     854:  fec46783           lwu a5,-20(s0)
     858:  fd843703           ld a4,-40(s0)
     85c:  973e                 add a4,a4,a5
     85e:  fe442783           lw a5,-28(s0)
     862:  0067979b           slliw a5,a5,0x6
     866:  2781                 sext.w a5,a5
     868:  fec42683           lw a3,-20(s0)
     86c:  9fb5                 addw a5,a5,a3
     86e:  2781                 sext.w a5,a5
     870:  1782                 slli a5,a5,0x20
     872:  9381                 srli a5,a5,0x20
     874:  f8043683           ld a3,-128(s0)
     878:  97b6                 add a5,a5,a3
     87a:  00074703           lbu a4,0(a4)
     87e:  00e78023           sb a4,0(a5)
     882:  fec42783           lw a5,-20(s0)
     886:  2785                 addiw a5,a5,1
     888:  fef42623           sw a5,-20(s0)
     88c:  fec42783           lw a5,-20(s0)
     890:  0007871b           sext.w a4,a5
     894:  03f00793           li a5,63
     898:  fae7fee3           bgeu a5,a4,854 <FUN_00000660+0x1f4>
     89c:  fe442783           lw a5,-28(s0)
     8a0:  2785                 addiw a5,a5,1
     8a2:  2781                 sext.w a5,a5
     8a4:  0067979b           slliw a5,a5,0x6
     8a8:  fef42423           sw a5,-24(s0)
     8ac:  a27d                 j a5a <FUN_00000660+0x3fa>
     8ae:  fe042623           sw zero,-20(s0)
     8b2:  a831                 j 8ce <FUN_00000660+0x26e>
     8b4:  fec46783           lwu a5,-20(s0)
     8b8:  078a                 slli a5,a5,0x2
     8ba:  ff040713           addi a4,s0,-16
     8be:  97ba                 add a5,a5,a4
     8c0:  fa07a423           sw zero,-88(a5)
     8c4:  fec42783           lw a5,-20(s0)
     8c8:  2785                 addiw a5,a5,1
     8ca:  fef42623           sw a5,-20(s0)
     8ce:  fec42783           lw a5,-20(s0)
     8d2:  0007871b           sext.w a4,a5
     8d6:  47bd                 li a5,15
     8d8:  fce7fee3           bgeu a5,a4,8b4 <FUN_00000660+0x254>
     8dc:  fe042623           sw zero,-20(s0)
     8e0:  a82d                 j 91a <FUN_00000660+0x2ba>
     8e2:  fe442783           lw a5,-28(s0)
     8e6:  0067979b           slliw a5,a5,0x6
     8ea:  2781                 sext.w a5,a5
     8ec:  fec42703           lw a4,-20(s0)
     8f0:  9fb9                 addw a5,a5,a4
     8f2:  2781                 sext.w a5,a5
     8f4:  1782                 slli a5,a5,0x20
     8f6:  9381                 srli a5,a5,0x20
     8f8:  f8043703           ld a4,-128(s0)
     8fc:  973e                 add a4,a4,a5
     8fe:  fec46783           lwu a5,-20(s0)
     902:  fd843683           ld a3,-40(s0)
     906:  97b6                 add a5,a5,a3
     908:  00074703           lbu a4,0(a4)
     90c:  00e78023           sb a4,0(a5)
     910:  fec42783           lw a5,-20(s0)
     914:  2785                 addiw a5,a5,1
     916:  fef42623           sw a5,-20(s0)
     91a:  fec42703           lw a4,-20(s0)
     91e:  fe042783           lw a5,-32(s0)
     922:  2701                 sext.w a4,a4
     924:  2781                 sext.w a5,a5
     926:  faf76ee3           bltu a4,a5,8e2 <FUN_00000660+0x282>
     92a:  fe046783           lwu a5,-32(s0)
     92e:  fd843703           ld a4,-40(s0)
     932:  97ba                 add a5,a5,a4
     934:  f8000713           li a4,-128
     938:  00e78023           sb a4,0(a5)
     93c:  fe042623           sw zero,-20(s0)
     940:  a82d                 j 97a <FUN_00000660+0x31a>
     942:  fec46783           lwu a5,-20(s0)
     946:  fd843703           ld a4,-40(s0)
     94a:  973e                 add a4,a4,a5
     94c:  fe442783           lw a5,-28(s0)
     950:  0067979b           slliw a5,a5,0x6
     954:  2781                 sext.w a5,a5
     956:  fec42683           lw a3,-20(s0)
     95a:  9fb5                 addw a5,a5,a3
     95c:  2781                 sext.w a5,a5
     95e:  1782                 slli a5,a5,0x20
     960:  9381                 srli a5,a5,0x20
     962:  f8043683           ld a3,-128(s0)
     966:  97b6                 add a5,a5,a3
     968:  00074703           lbu a4,0(a4)
     96c:  00e78023           sb a4,0(a5)
     970:  fec42783           lw a5,-20(s0)
     974:  2785                 addiw a5,a5,1
     976:  fef42623           sw a5,-20(s0)
     97a:  fec42783           lw a5,-20(s0)
     97e:  0007871b           sext.w a4,a5
     982:  03f00793           li a5,63
     986:  fae7fee3           bgeu a5,a4,942 <FUN_00000660+0x2e2>
     98a:  fe042623           sw zero,-20(s0)
     98e:  a831                 j 9aa <FUN_00000660+0x34a>
     990:  fec46783           lwu a5,-20(s0)
     994:  078a                 slli a5,a5,0x2
     996:  ff040713           addi a4,s0,-16
     99a:  97ba                 add a5,a5,a4
     99c:  fa07a423           sw zero,-88(a5)
     9a0:  fec42783           lw a5,-20(s0)
     9a4:  2785                 addiw a5,a5,1
     9a6:  fef42623           sw a5,-20(s0)
     9aa:  fec42783           lw a5,-20(s0)
     9ae:  0007871b           sext.w a4,a5
     9b2:  47bd                 li a5,15
     9b4:  fce7fee3           bgeu a5,a4,990 <FUN_00000660+0x330>
     9b8:  f8c42783           lw a5,-116(s0)
     9bc:  01d7d79b           srliw a5,a5,0x1d
     9c0:  2781                 sext.w a5,a5
     9c2:  fcf42823           sw a5,-48(s0)
     9c6:  f8c42783           lw a5,-116(s0)
     9ca:  0037979b           slliw a5,a5,0x3
     9ce:  2781                 sext.w a5,a5
     9d0:  fcf42a23           sw a5,-44(s0)
     9d4:  fd042783           lw a5,-48(s0)
     9d8:  853e                 mv a0,a5
     9da:  c0dff0ef           jal ra,5e6 <FUN_000005e6>
     9de:  87aa                 mv a5,a0
     9e0:  2781                 sext.w a5,a5
     9e2:  fcf42823           sw a5,-48(s0)
     9e6:  fd442783           lw a5,-44(s0)
     9ea:  853e                 mv a0,a5
     9ec:  bfbff0ef           jal ra,5e6 <FUN_000005e6>
     9f0:  87aa                 mv a5,a0
     9f2:  2781                 sext.w a5,a5
     9f4:  fcf42a23           sw a5,-44(s0)
     9f8:  fe042623           sw zero,-20(s0)
     9fc:  a83d                 j a3a <FUN_00000660+0x3da>
     9fe:  fec46783           lwu a5,-20(s0)
     a02:  fd843703           ld a4,-40(s0)
     a06:  973e                 add a4,a4,a5
     a08:  fe442783           lw a5,-28(s0)
     a0c:  2785                 addiw a5,a5,1
     a0e:  2781                 sext.w a5,a5
     a10:  0067979b           slliw a5,a5,0x6
     a14:  2781                 sext.w a5,a5
     a16:  fec42683           lw a3,-20(s0)
     a1a:  9fb5                 addw a5,a5,a3
     a1c:  2781                 sext.w a5,a5
     a1e:  1782                 slli a5,a5,0x20
     a20:  9381                 srli a5,a5,0x20
     a22:  f8043683           ld a3,-128(s0)
     a26:  97b6                 add a5,a5,a3
     a28:  00074703           lbu a4,0(a4)
     a2c:  00e78023           sb a4,0(a5)
     a30:  fec42783           lw a5,-20(s0)
     a34:  2785                 addiw a5,a5,1
     a36:  fef42623           sw a5,-20(s0)
     a3a:  fec42783           lw a5,-20(s0)
     a3e:  0007871b           sext.w a4,a5
     a42:  03f00793           li a5,63
     a46:  fae7fce3           bgeu a5,a4,9fe <FUN_00000660+0x39e>
     a4a:  fe442783           lw a5,-28(s0)
     a4e:  2789                 addiw a5,a5,2
     a50:  2781                 sext.w a5,a5
     a52:  0067979b           slliw a5,a5,0x6
     a56:  fef42423           sw a5,-24(s0)
     a5a:  fe842783           lw a5,-24(s0)
     a5e:  853e                 mv a0,a5
     a60:  70e6                 ld ra,120(sp)
     a62:  7446                 ld s0,112(sp)
     a64:  6109                 addi sp,sp,128
     a66:  8082                 ret
0000000000000a68 <FUN_00000a68>:
     a68:  7139                 addi sp,sp,-64
     a6a:  fc22                 sd s0,56(sp)
     a6c:  0080                 addi s0,sp,64
     a6e:  87aa                 mv a5,a0
     a70:  fcb43823           sd a1,-48(s0)
     a74:  8732                 mv a4,a2
     a76:  fcd43423           sd a3,-56(s0)
     a7a:  fcf42e23           sw a5,-36(s0)
     a7e:  87ba                 mv a5,a4
     a80:  fcf42c23           sw a5,-40(s0)
     a84:  fe042623           sw zero,-20(s0)
     a88:  fe042623           sw zero,-20(s0)
     a8c:  a8a1                 j ae4 <FUN_00000a68+0x7c>
     a8e:  fec42703           lw a4,-20(s0)
     a92:  fd842783           lw a5,-40(s0)
     a96:  2781                 sext.w a5,a5
     a98:  02f77a63           bgeu a4,a5,acc <FUN_00000a68+0x64>
     a9c:  fec42783           lw a5,-20(s0)
     aa0:  fd842703           lw a4,-40(s0)
     aa4:  40f707bb           subw a5,a4,a5
     aa8:  2781                 sext.w a5,a5
     aaa:  37fd                 addiw a5,a5,-1
     aac:  2781                 sext.w a5,a5
     aae:  1782                 slli a5,a5,0x20
     ab0:  9381                 srli a5,a5,0x20
     ab2:  fd043703           ld a4,-48(s0)
     ab6:  973e                 add a4,a4,a5
     ab8:  fec42783           lw a5,-20(s0)
     abc:  fc843683           ld a3,-56(s0)
     ac0:  97b6                 add a5,a5,a3
     ac2:  00074703           lbu a4,0(a4)
     ac6:  00e78023           sb a4,0(a5)
     aca:  a801                 j ada <FUN_00000a68+0x72>
     acc:  fec42783           lw a5,-20(s0)
     ad0:  fc843703           ld a4,-56(s0)
     ad4:  97ba                 add a5,a5,a4
     ad6:  00078023           sb zero,0(a5)
     ada:  fec42783           lw a5,-20(s0)
     ade:  2785                 addiw a5,a5,1
     ae0:  fef42623           sw a5,-20(s0)
     ae4:  fec42703           lw a4,-20(s0)
     ae8:  fdc42783           lw a5,-36(s0)
     aec:  2781                 sext.w a5,a5
     aee:  faf760e3           bltu a4,a5,a8e <FUN_00000a68+0x26>
     af2:  0001                 nop
     af4:  7462                 ld s0,56(sp)
     af6:  6121                 addi sp,sp,64
     af8:  8082                 ret
0000000000000afa <FUN_00000afa>:
     afa:  7179                 addi sp,sp,-48
     afc:  f422                 sd s0,40(sp)
     afe:  1800                 addi s0,sp,48
     b00:  87aa                 mv a5,a0
     b02:  8736                 mv a4,a3
     b04:  fcf42e23           sw a5,-36(s0)
     b08:  87ae                 mv a5,a1
     b0a:  fcf42c23           sw a5,-40(s0)
     b0e:  87b2                 mv a5,a2
     b10:  fcf42a23           sw a5,-44(s0)
     b14:  87ba                 mv a5,a4
     b16:  fcf42823           sw a5,-48(s0)
     b1a:  fdc42783           lw a5,-36(s0)
     b1e:  0007871b           sext.w a4,a5
     b22:  20000793           li a5,512
     b26:  00f71563           bne a4,a5,b30 <FUN_00000afa+0x36>
     b2a:  fe042623           sw zero,-20(s0)
     b2e:  a095                 j b92 <FUN_00000afa+0x98>
     b30:  fdc42783           lw a5,-36(s0)
     b34:  0007871b           sext.w a4,a5
     b38:  40000793           li a5,1024
     b3c:  00f71763           bne a4,a5,b4a <FUN_00000afa+0x50>
     b40:  100007b7           lui a5,0x10000
     b44:  fef42623           sw a5,-20(s0)
     b48:  a0a9                 j b92 <FUN_00000afa+0x98>
     b4a:  fdc42783           lw a5,-36(s0)
     b4e:  8007879b           addiw a5,a5,-2048
     b52:  2781                 sext.w a5,a5
     b54:  e791                 bnez a5,b60 <FUN_00000afa+0x66>
     b56:  200007b7           lui a5,0x20000
     b5a:  fef42623           sw a5,-20(s0)
     b5e:  a815                 j b92 <FUN_00000afa+0x98>
     b60:  fdc42783           lw a5,-36(s0)
     b64:  0007871b           sext.w a4,a5
     b68:  6785                 lui a5,0x1
     b6a:  c0078793           addi a5,a5,-1024 # c00 <FUN_00000bbe+0x42>
     b6e:  00f71763           bne a4,a5,b7c <FUN_00000afa+0x82>
     b72:  300007b7           lui a5,0x30000
     b76:  fef42623           sw a5,-20(s0)
     b7a:  a821                 j b92 <FUN_00000afa+0x98>
     b7c:  fdc42783           lw a5,-36(s0)
     b80:  0007871b           sext.w a4,a5
     b84:  6785                 lui a5,0x1
     b86:  00f71663           bne a4,a5,b92 <FUN_00000afa+0x98>
     b8a:  400007b7           lui a5,0x40000
     b8e:  fef42623           sw a5,-20(s0)
     b92:  fd842783           lw a5,-40(s0)
     b96:  0107979b           slliw a5,a5,0x10
     b9a:  2781                 sext.w a5,a5
     b9c:  873e                 mv a4,a5
     b9e:  000707b7           lui a5,0x70
     ba2:  8ff9                 and a5,a5,a4
     ba4:  0007871b           sext.w a4,a5
     ba8:  fec42783           lw a5,-20(s0)
     bac:  8fd9                 or a5,a5,a4
     bae:  fef42623           sw a5,-20(s0)
     bb2:  fec42783           lw a5,-20(s0)
     bb6:  853e                 mv a0,a5
     bb8:  7422                 ld s0,40(sp)
     bba:  6145                 addi sp,sp,48
     bbc:  8082                 ret
0000000000000bbe <FUN_00000bbe>:
     bbe:  7179                 addi sp,sp,-48
     bc0:  f422                 sd s0,40(sp)
     bc2:  1800                 addi s0,sp,48
     bc4:  87aa                 mv a5,a0
     bc6:  fcf42e23           sw a5,-36(s0)
     bca:  030417b7           lui a5,0x3041
     bce:  80878793           addi a5,a5,-2040 # 3040808 <gpio_get_boot_device+0x30324
     bd2:  439c                 lw a5,0(a5)
     bd4:  2781                 sext.w a5,a5
     bd6:  8bbd                 andi a5,a5,15
     bd8:  fef42423           sw a5,-24(s0)
     bdc:  fdc42783           lw a5,-36(s0)
     be0:  4705                 li a4,1
     be2:  00f717bb           sllw a5,a4,a5
     be6:  2781                 sext.w a5,a5
     be8:  0007871b           sext.w a4,a5
     bec:  fe842783           lw a5,-24(s0)
     bf0:  8ff9                 and a5,a5,a4
     bf2:  fef42423           sw a5,-24(s0)
     bf6:  fe842783           lw a5,-24(s0)
     bfa:  2781                 sext.w a5,a5
     bfc:  c7a1                 beqz a5,c44 <FUN_00000bbe+0x86>
     bfe:  0001                 nop
     c00:  030417b7           lui a5,0x3041
     c04:  80c78793           addi a5,a5,-2036 # 304080c <gpio_get_boot_device+0x30324
     c08:  439c                 lw a5,0(a5)
     c0a:  0007869b           sext.w a3,a5
     c0e:  fdc42783           lw a5,-36(s0)
     c12:  4705                 li a4,1
     c14:  00f717bb           sllw a5,a4,a5
     c18:  2781                 sext.w a5,a5
     c1a:  2781                 sext.w a5,a5
     c1c:  8736                 mv a4,a3
     c1e:  8ff9                 and a5,a5,a4
     c20:  2781                 sext.w a5,a5
     c22:  dff9                 beqz a5,c00 <FUN_00000bbe+0x42>
     c24:  fe042623           sw zero,-20(s0)
     c28:  a031                 j c34 <FUN_00000bbe+0x76>
     c2a:  fec42783           lw a5,-20(s0)
     c2e:  2785                 addiw a5,a5,1
     c30:  fef42623           sw a5,-20(s0)
     c34:  fec42783           lw a5,-20(s0)
     c38:  0007871b           sext.w a4,a5
     c3c:  3e700793           li a5,999
     c40:  fee7f5e3           bgeu a5,a4,c2a <FUN_00000bbe+0x6c>
     c44:  0001                 nop
     c46:  7422                 ld s0,40(sp)
     c48:  6145                 addi sp,sp,48
     c4a:  8082                 ret
0000000000000c4c <FUN_00000c4c>:
     c4c:  7179                 addi sp,sp,-48
     c4e:  f422                 sd s0,40(sp)
     c50:  1800                 addi s0,sp,48
     c52:  87aa                 mv a5,a0
     c54:  fcf42e23           sw a5,-36(s0)
     c58:  030417b7           lui a5,0x3041
     c5c:  80c78793           addi a5,a5,-2036 # 304080c <gpio_get_boot_device+0x30324
     c60:  439c                 lw a5,0(a5)
     c62:  fef42623           sw a5,-20(s0)
     c66:  fdc42783           lw a5,-36(s0)
     c6a:  4705                 li a4,1
     c6c:  00f717bb           sllw a5,a4,a5
     c70:  2781                 sext.w a5,a5
     c72:  0007871b           sext.w a4,a5
     c76:  fec42783           lw a5,-20(s0)
     c7a:  8ff9                 and a5,a5,a4
     c7c:  0007869b           sext.w a3,a5
     c80:  fdc42783           lw a5,-36(s0)
     c84:  4705                 li a4,1
     c86:  00f717bb           sllw a5,a4,a5
     c8a:  2781                 sext.w a5,a5
     c8c:  2781                 sext.w a5,a5
     c8e:  8736                 mv a4,a3
     c90:  02f71463           bne a4,a5,cb8 <FUN_00000c4c+0x6c>
     c94:  fec42783           lw a5,-20(s0)
     c98:  9bc1                 andi a5,a5,-16
     c9a:  fef42623           sw a5,-20(s0)
     c9e:  fdc42783           lw a5,-36(s0)
     ca2:  4705                 li a4,1
     ca4:  00f717bb           sllw a5,a4,a5
     ca8:  2781                 sext.w a5,a5
     caa:  0007871b           sext.w a4,a5
     cae:  fec42783           lw a5,-20(s0)
     cb2:  8fd9                 or a5,a5,a4
     cb4:  fef42623           sw a5,-20(s0)
     cb8:  030417b7           lui a5,0x3041
     cbc:  80c78793           addi a5,a5,-2036 # 304080c <gpio_get_boot_device+0x30324
     cc0:  fec42703           lw a4,-20(s0)
     cc4:  c398                 sw a4,0(a5)
     cc6:  0001                 nop
     cc8:  7422                 ld s0,40(sp)
     cca:  6145                 addi sp,sp,48
     ccc:  8082                 ret
0000000000000cce <sunxi_sha_calc>:
     cce:  7149                 addi sp,sp,-368
     cd0:  f686                 sd ra,360(sp)
     cd2:  f2a2                 sd s0,352(sp)
     cd4:  1a80                 addi s0,sp,368
     cd6:  87aa                 mv a5,a0
     cd8:  eab43023           sd a1,-352(s0)
     cdc:  e8d43c23           sd a3,-360(s0)
     ce0:  eaf42623           sw a5,-340(s0)
     ce4:  87b2                 mv a5,a2
     ce6:  eaf42423           sw a5,-344(s0)
     cea:  87ba                 mv a5,a4
     cec:  e8f42a23           sw a5,-364(s0)
     cf0:  fc042e23           sw zero,-36(s0)
     cf4:  fc042c23           sw zero,-40(s0)
     cf8:  fe042623           sw zero,-20(s0)
     cfc:  fe042423           sw zero,-24(s0)
     d00:  fc043823           sd zero,-48(s0)
     d04:  fc043423           sd zero,-56(s0)
     d08:  fe043023           sd zero,-32(s0)
     d0c:  85fff0ef           jal ra,56a <FUN_0000056a>
     d10:  eb040793           addi a5,s0,-336
     d14:  0b000613           li a2,176
     d18:  4581                 li a1,0
     d1a:  853e                 mv a0,a5
     d1c:  34a090ef           jal ra,a066 <memset>
     d20:  f6040793           addi a5,s0,-160
     d24:  04000613           li a2,64
     d28:  4581                 li a1,0
     d2a:  853e                 mv a0,a5
     d2c:  33a090ef           jal ra,a066 <memset>
     d30:  fa040793           addi a5,s0,-96
     d34:  02800613           li a2,40
     d38:  4581                 li a1,0
     d3a:  853e                 mv a0,a5
     d3c:  32a090ef           jal ra,a066 <memset>
     d40:  fa040793           addi a5,s0,-96
     d44:  07fd                 addi a5,a5,31
     d46:  9b81                 andi a5,a5,-32
     d48:  fcf43823           sd a5,-48(s0)
     d4c:  f6040793           addi a5,s0,-160
     d50:  07fd                 addi a5,a5,31
     d52:  9b81                 andi a5,a5,-32
     d54:  fcf43423           sd a5,-56(s0)
     d58:  ea043783           ld a5,-352(s0)
     d5c:  8bfd                 andi a5,a5,31
     d5e:  c399                 beqz a5,d64 <sunxi_sha_calc+0x96>
     d60:  57fd                 li a5,-1
     d62:  a2c1                 j f22 <sunxi_sha_calc+0x254>
     d64:  eac42783           lw a5,-340(s0)
     d68:  0007871b           sext.w a4,a5
     d6c:  4785                 li a5,1
     d6e:  00f71a63           bne a4,a5,d82 <sunxi_sha_calc+0xb4>
     d72:  47cd                 li a5,19
     d74:  fef43023           sd a5,-32(s0)
     d78:  02000793           li a5,32
     d7c:  fef42623           sw a5,-20(s0)
     d80:  a831                 j d9c <sunxi_sha_calc+0xce>
     d82:  eac42783           lw a5,-340(s0)
     d86:  2781                 sext.w a5,a5
     d88:  eb81                 bnez a5,d98 <sunxi_sha_calc+0xca>
     d8a:  47c5                 li a5,17
     d8c:  fef43023           sd a5,-32(s0)
     d90:  47d1                 li a5,20
     d92:  fef42623           sw a5,-20(s0)
     d96:  a019                 j d9c <sunxi_sha_calc+0xce>
     d98:  57fd                 li a5,-1
     d9a:  a261                 j f22 <sunxi_sha_calc+0x254>
     d9c:  ea842783           lw a5,-344(s0)
     da0:  ea043583           ld a1,-352(s0)
     da4:  853e                 mv a0,a5
     da6:  8bbff0ef           jal ra,660 <FUN_00000660>
     daa:  87aa                 mv a5,a0
     dac:  fcf42e23           sw a5,-36(s0)
     db0:  fdc42783           lw a5,-36(s0)
     db4:  0027d79b           srliw a5,a5,0x2
     db8:  fcf42c23           sw a5,-40(s0)
     dbc:  ea042823           sw zero,-336(s0)
     dc0:  fe043783           ld a5,-32(s0)
     dc4:  2781                 sext.w a5,a5
     dc6:  873e                 mv a4,a5
     dc8:  800007b7           lui a5,0x80000
     dcc:  8fd9                 or a5,a5,a4
     dce:  2781                 sext.w a5,a5
     dd0:  eaf42a23           sw a5,-332(s0)
     dd4:  eb442783           lw a5,-332(s0)
     dd8:  873e                 mv a4,a5
     dda:  080007b7           lui a5,0x8000
     dde:  8fd9                 or a5,a5,a4
     de0:  2781                 sext.w a5,a5
     de2:  eaf42a23           sw a5,-332(s0)
     de6:  ea042c23           sw zero,-328(s0)
     dea:  ea042e23           sw zero,-324(s0)
     dee:  ec042023           sw zero,-320(s0)
     df2:  fd043783           ld a5,-48(s0)
     df6:  2781                 sext.w a5,a5
     df8:  ecf42223           sw a5,-316(s0)
     dfc:  ec042423           sw zero,-312(s0)
     e00:  fd842783           lw a5,-40(s0)
     e04:  ecf42623           sw a5,-308(s0)
     e08:  ea043783           ld a5,-352(s0)
     e0c:  2781                 sext.w a5,a5
     e0e:  ecf42823           sw a5,-304(s0)
     e12:  fd842783           lw a5,-40(s0)
     e16:  ecf42a23           sw a5,-300(s0)
     e1a:  4785                 li a5,1
     e1c:  fef42423           sw a5,-24(s0)
     e20:  a839                 j e3e <sunxi_sha_calc+0x170>
     e22:  fe842783           lw a5,-24(s0)
     e26:  0791                 addi a5,a5,4
     e28:  078e                 slli a5,a5,0x3
     e2a:  ff040713           addi a4,s0,-16
     e2e:  97ba                 add a5,a5,a4
     e30:  ec07a223           sw zero,-316(a5) # 7fffec4 <gpio_get_boot_device+0x7ff1b
     e34:  fe842783           lw a5,-24(s0)
     e38:  2785                 addiw a5,a5,1
     e3a:  fef42423           sw a5,-24(s0)
     e3e:  fe842783           lw a5,-24(s0)
     e42:  0007871b           sext.w a4,a5
     e46:  479d                 li a5,7
     e48:  fce7dde3           bge a5,a4,e22 <sunxi_sha_calc+0x154>
     e4c:  fc843783           ld a5,-56(s0)
     e50:  2781                 sext.w a5,a5
     e52:  f0f42823           sw a5,-240(s0)
     e56:  fec42783           lw a5,-20(s0)
     e5a:  0027d79b           srliw a5,a5,0x2
     e5e:  2781                 sext.w a5,a5
     e60:  f0f42a23           sw a5,-236(s0)
     e64:  4785                 li a5,1
     e66:  fef42423           sw a5,-24(s0)
     e6a:  a839                 j e88 <sunxi_sha_calc+0x1ba>
     e6c:  fe842783           lw a5,-24(s0)
     e70:  07b1                 addi a5,a5,12
     e72:  078e                 slli a5,a5,0x3
     e74:  ff040713           addi a4,s0,-16
     e78:  97ba                 add a5,a5,a4
     e7a:  ec07a223           sw zero,-316(a5)
     e7e:  fe842783           lw a5,-24(s0)
     e82:  2785                 addiw a5,a5,1
     e84:  fef42423           sw a5,-24(s0)
     e88:  fe842783           lw a5,-24(s0)
     e8c:  0007871b           sext.w a4,a5
     e90:  479d                 li a5,7
     e92:  fce7dde3           bge a5,a4,e6c <sunxi_sha_calc+0x19e>
     e96:  f4042823           sw zero,-176(s0)
     e9a:  eb040713           addi a4,s0,-336
     e9e:  030417b7           lui a5,0x3041
     ea2:  80078793           addi a5,a5,-2048 # 3040800 <gpio_get_boot_device+0x30324
     ea6:  2701                 sext.w a4,a4
     ea8:  c398                 sw a4,0(a5)
     eaa:  eb042783           lw a5,-336(s0)
     eae:  4705                 li a4,1
     eb0:  00f717bb           sllw a5,a4,a5
     eb4:  0007871b           sext.w a4,a5
     eb8:  030417b7           lui a5,0x3041
     ebc:  80878793           addi a5,a5,-2040 # 3040808 <gpio_get_boot_device+0x30324
     ec0:  2701                 sext.w a4,a4
     ec2:  c398                 sw a4,0(a5)
     ec4:  030417b7           lui a5,0x3041
     ec8:  81078793           addi a5,a5,-2032 # 3040810 <gpio_get_boot_device+0x30324
     ecc:  4705                 li a4,1
     ece:  c398                 sw a4,0(a5)
     ed0:  eb042783           lw a5,-336(s0)
     ed4:  853e                 mv a0,a5
     ed6:  ce9ff0ef           jal ra,bbe <FUN_00000bbe>
     eda:  fe042423           sw zero,-24(s0)
     ede:  a02d                 j f08 <sunxi_sha_calc+0x23a>
     ee0:  fe842703           lw a4,-24(s0)
     ee4:  fc843783           ld a5,-56(s0)
     ee8:  97ba                 add a5,a5,a4
     eea:  86be                 mv a3,a5
     eec:  fe842783           lw a5,-24(s0)
     ef0:  e9843703           ld a4,-360(s0)
     ef4:  97ba                 add a5,a5,a4
     ef6:  0006c703           lbu a4,0(a3)
     efa:  00e78023           sb a4,0(a5)
     efe:  fe842783           lw a5,-24(s0)
     f02:  2785                 addiw a5,a5,1
     f04:  fef42423           sw a5,-24(s0)
     f08:  fe842703           lw a4,-24(s0)
     f0c:  fec42783           lw a5,-20(s0)
     f10:  2781                 sext.w a5,a5
     f12:  fcf767e3           bltu a4,a5,ee0 <sunxi_sha_calc+0x212>
     f16:  eb042783           lw a5,-336(s0)
     f1a:  853e                 mv a0,a5
     f1c:  d31ff0ef           jal ra,c4c <FUN_00000c4c>
     f20:  4781                 li a5,0
     f22:  853e                 mv a0,a5
     f24:  70b6                 ld ra,360(sp)
     f26:  7416                 ld s0,352(sp)
     f28:  6175                 addi sp,sp,368
     f2a:  8082                 ret
0000000000000f2c <FUN_00000f2c>:
     f2c:  86010113           addi sp,sp,-1952 # 44860 <gpio_get_boot_device+0x364ca>
     f30:  78113c23           sd ra,1944(sp)
     f34:  78813823           sd s0,1936(sp)
     f38:  7a010413           addi s0,sp,1952
     f3c:  88b43023           sd a1,-1920(s0)
     f40:  86d43c23           sd a3,-1928(s0)
     f44:  86ba                 mv a3,a4
     f46:  86f43423           sd a5,-1944(s0)
     f4a:  8742                 mv a4,a6
     f4c:  87143023           sd a7,-1952(s0)
     f50:  87aa                 mv a5,a0
     f52:  88f42623           sw a5,-1908(s0)
     f56:  87b2                 mv a5,a2
     f58:  88f42423           sw a5,-1912(s0)
     f5c:  87b6                 mv a5,a3
     f5e:  86f42a23           sw a5,-1932(s0)
     f62:  87ba                 mv a5,a4
     f64:  86f42823           sw a5,-1936(s0)
     f68:  88c42783           lw a5,-1908(s0)
     f6c:  0037d79b           srliw a5,a5,0x3
     f70:  fef42423           sw a5,-24(s0)
     f74:  88c42783           lw a5,-1908(s0)
     f78:  0057d79b           srliw a5,a5,0x5
     f7c:  fef42223           sw a5,-28(s0)
     f80:  fe042623           sw zero,-20(s0)
     f84:  e2040793           addi a5,s0,-480
     f88:  fcf43c23           sd a5,-40(s0)
     f8c:  c8040793           addi a5,s0,-896
     f90:  fcf43823           sd a5,-48(s0)
     f94:  ae040793           addi a5,s0,-1312
     f98:  fcf43423           sd a5,-56(s0)
     f9c:  94040793           addi a5,s0,-1728
     fa0:  fcf43023           sd a5,-64(s0)
     fa4:  dc6ff0ef           jal ra,56a <FUN_0000056a>
     fa8:  89040793           addi a5,s0,-1904
     fac:  0b000613           li a2,176
     fb0:  4581                 li a1,0
     fb2:  853e                 mv a0,a5
     fb4:  0b2090ef           jal ra,a066 <memset>
     fb8:  fd843783           ld a5,-40(s0)
     fbc:  1a000613           li a2,416
     fc0:  4581                 li a1,0
     fc2:  853e                 mv a0,a5
     fc4:  0a2090ef           jal ra,a066 <memset>
     fc8:  fd043783           ld a5,-48(s0)
     fcc:  1a000613           li a2,416
     fd0:  4581                 li a1,0
     fd2:  853e                 mv a0,a5
     fd4:  092090ef           jal ra,a066 <memset>
     fd8:  fc843783           ld a5,-56(s0)
     fdc:  1a000613           li a2,416
     fe0:  4581                 li a1,0
     fe2:  853e                 mv a0,a5
     fe4:  082090ef           jal ra,a066 <memset>
     fe8:  fc043783           ld a5,-64(s0)
     fec:  1a000613           li a2,416
     ff0:  4581                 li a1,0
     ff2:  853e                 mv a0,a5
     ff4:  072090ef           jal ra,a066 <memset>
     ff8:  fd843783           ld a5,-40(s0)
     ffc:  07fd                 addi a5,a5,31
     ffe:  9b81                 andi a5,a5,-32
    1000:  fcf43c23           sd a5,-40(s0)
    1004:  fd043783           ld a5,-48(s0)
    1008:  07fd                 addi a5,a5,31
    100a:  9b81                 andi a5,a5,-32
    100c:  fcf43823           sd a5,-48(s0)
    1010:  fc843783           ld a5,-56(s0)
    1014:  07fd                 addi a5,a5,31
    1016:  9b81                 andi a5,a5,-32
    1018:  fcf43423           sd a5,-56(s0)
    101c:  fc043783           ld a5,-64(s0)
    1020:  07fd                 addi a5,a5,31
    1022:  9b81                 andi a5,a5,-32
    1024:  fcf43023           sd a5,-64(s0)
    1028:  88c42783           lw a5,-1908(s0)
    102c:  0007871b           sext.w a4,a5
    1030:  20000793           li a5,512
    1034:  02f70b63           beq a4,a5,106a <FUN_00000f2c+0x13e>
    1038:  88c42783           lw a5,-1908(s0)
    103c:  0007871b           sext.w a4,a5
    1040:  40000793           li a5,1024
    1044:  02f70363           beq a4,a5,106a <FUN_00000f2c+0x13e>
    1048:  88c42783           lw a5,-1908(s0)
    104c:  8007879b           addiw a5,a5,-2048
    1050:  2781                 sext.w a5,a5
    1052:  cf81                 beqz a5,106a <FUN_00000f2c+0x13e>
    1054:  88c42783           lw a5,-1908(s0)
    1058:  0007871b           sext.w a4,a5
    105c:  6785                 lui a5,0x1
    105e:  c0078793           addi a5,a5,-1024 # c00 <FUN_00000bbe+0x42>
    1062:  00f70463           beq a4,a5,106a <FUN_00000f2c+0x13e>
    1066:  57fd                 li a5,-1
    1068:  aac9                 j 123a <FUN_00000f2c+0x30e>
    106a:  fd043683           ld a3,-48(s0)
    106e:  87442703           lw a4,-1932(s0)
    1072:  fe842783           lw a5,-24(s0)
    1076:  863a                 mv a2,a4
    1078:  87843583           ld a1,-1928(s0)
    107c:  853e                 mv a0,a5
    107e:  9ebff0ef           jal ra,a68 <FUN_00000a68>
    1082:  fd843683           ld a3,-40(s0)
    1086:  88842703           lw a4,-1912(s0)
    108a:  fe842783           lw a5,-24(s0)
    108e:  863a                 mv a2,a4
    1090:  88043583           ld a1,-1920(s0)
    1094:  853e                 mv a0,a5
    1096:  9d3ff0ef           jal ra,a68 <FUN_00000a68>
    109a:  fc043683           ld a3,-64(s0)
    109e:  fe842703           lw a4,-24(s0)
    10a2:  fe842783           lw a5,-24(s0)
    10a6:  863a                 mv a2,a4
    10a8:  86043583           ld a1,-1952(s0)
    10ac:  853e                 mv a0,a5
    10ae:  9bbff0ef           jal ra,a68 <FUN_00000a68>
    10b2:  88042823           sw zero,-1904(s0)
    10b6:  800007b7           lui a5,0x80000
    10ba:  0207879b           addiw a5,a5,32
    10be:  88f42a23           sw a5,-1900(s0)
    10c2:  89442783           lw a5,-1900(s0)
    10c6:  873e                 mv a4,a5
    10c8:  080007b7           lui a5,0x8000
    10cc:  8fd9                 or a5,a5,a4
    10ce:  2781                 sext.w a5,a5
    10d0:  88f42a23           sw a5,-1900(s0)
    10d4:  88042c23           sw zero,-1896(s0)
    10d8:  88c42783           lw a5,-1908(s0)
    10dc:  4681                 li a3,0
    10de:  0a000613           li a2,160
    10e2:  4581                 li a1,0
    10e4:  853e                 mv a0,a5
    10e6:  a15ff0ef           jal ra,afa <FUN_00000afa>
    10ea:  87aa                 mv a5,a0
    10ec:  2781                 sext.w a5,a5
    10ee:  88f42e23           sw a5,-1892(s0)
    10f2:  fd843783           ld a5,-40(s0)
    10f6:  2781                 sext.w a5,a5
    10f8:  8af42023           sw a5,-1888(s0)
    10fc:  fc043783           ld a5,-64(s0)
    1100:  2781                 sext.w a5,a5
    1102:  8af42223           sw a5,-1884(s0)
    1106:  8a042423           sw zero,-1880(s0)
    110a:  fe442783           lw a5,-28(s0)
    110e:  8af42623           sw a5,-1876(s0)
    1112:  fd043783           ld a5,-48(s0)
    1116:  2781                 sext.w a5,a5
    1118:  8af42823           sw a5,-1872(s0)
    111c:  fe442783           lw a5,-28(s0)
    1120:  8af42a23           sw a5,-1868(s0)
    1124:  4785                 li a5,1
    1126:  fef42623           sw a5,-20(s0)
    112a:  a839                 j 1148 <FUN_00000f2c+0x21c>
    112c:  fec42783           lw a5,-20(s0)
    1130:  0791                 addi a5,a5,4
    1132:  078e                 slli a5,a5,0x3
    1134:  ff040713           addi a4,s0,-16
    1138:  97ba                 add a5,a5,a4
    113a:  8a07a223           sw zero,-1884(a5) # 7fff8a4 <gpio_get_boot_device+0x7ff1
    113e:  fec42783           lw a5,-20(s0)
    1142:  2785                 addiw a5,a5,1
    1144:  fef42623           sw a5,-20(s0)
    1148:  fec42783           lw a5,-20(s0)
    114c:  0007871b           sext.w a4,a5
    1150:  479d                 li a5,7
    1152:  fce7dde3           bge a5,a4,112c <FUN_00000f2c+0x200>
    1156:  fc843783           ld a5,-56(s0)
    115a:  2781                 sext.w a5,a5
    115c:  8ef42823           sw a5,-1808(s0)
    1160:  fe442783           lw a5,-28(s0)
    1164:  8ef42a23           sw a5,-1804(s0)
    1168:  4785                 li a5,1
    116a:  fef42623           sw a5,-20(s0)
    116e:  a839                 j 118c <FUN_00000f2c+0x260>
    1170:  fec42783           lw a5,-20(s0)
    1174:  07b1                 addi a5,a5,12
    1176:  078e                 slli a5,a5,0x3
    1178:  ff040713           addi a4,s0,-16
    117c:  97ba                 add a5,a5,a4
    117e:  8a07a223           sw zero,-1884(a5)
    1182:  fec42783           lw a5,-20(s0)
    1186:  2785                 addiw a5,a5,1
    1188:  fef42623           sw a5,-20(s0)
    118c:  fec42783           lw a5,-20(s0)
    1190:  0007871b           sext.w a4,a5
    1194:  479d                 li a5,7
    1196:  fce7dde3           bge a5,a4,1170 <FUN_00000f2c+0x244>
    119a:  92042823           sw zero,-1744(s0)
    119e:  89040713           addi a4,s0,-1904
    11a2:  030417b7           lui a5,0x3041
    11a6:  80078793           addi a5,a5,-2048 # 3040800 <gpio_get_boot_device+0x30324
    11aa:  2701                 sext.w a4,a4
    11ac:  c398                 sw a4,0(a5)
    11ae:  89042783           lw a5,-1904(s0)
    11b2:  4705                 li a4,1
    11b4:  00f717bb           sllw a5,a4,a5
    11b8:  0007871b           sext.w a4,a5
    11bc:  030417b7           lui a5,0x3041
    11c0:  80878793           addi a5,a5,-2040 # 3040808 <gpio_get_boot_device+0x30324
    11c4:  2701                 sext.w a4,a4
    11c6:  c398                 sw a4,0(a5)
    11c8:  030417b7           lui a5,0x3041
    11cc:  81078793           addi a5,a5,-2032 # 3040810 <gpio_get_boot_device+0x30324
    11d0:  4705                 li a4,1
    11d2:  c398                 sw a4,0(a5)
    11d4:  89042783           lw a5,-1904(s0)
    11d8:  853e                 mv a0,a5
    11da:  9e5ff0ef           jal ra,bbe <FUN_00000bbe>
    11de:  fe042623           sw zero,-20(s0)
    11e2:  a83d                 j 1220 <FUN_00000f2c+0x2f4>
    11e4:  fec42783           lw a5,-20(s0)
    11e8:  87042703           lw a4,-1936(s0)
    11ec:  40f707bb           subw a5,a4,a5
    11f0:  2781                 sext.w a5,a5
    11f2:  37fd                 addiw a5,a5,-1
    11f4:  2781                 sext.w a5,a5
    11f6:  02079713           slli a4,a5,0x20
    11fa:  9301                 srli a4,a4,0x20
    11fc:  fc843783           ld a5,-56(s0)
    1200:  97ba                 add a5,a5,a4
    1202:  86be                 mv a3,a5
    1204:  fec42783           lw a5,-20(s0)
    1208:  86843703           ld a4,-1944(s0)
    120c:  97ba                 add a5,a5,a4
    120e:  0006c703           lbu a4,0(a3)
    1212:  00e78023           sb a4,0(a5)
    1216:  fec42783           lw a5,-20(s0)
    121a:  2785                 addiw a5,a5,1
    121c:  fef42623           sw a5,-20(s0)
    1220:  fec42703           lw a4,-20(s0)
    1224:  87042783           lw a5,-1936(s0)
    1228:  2781                 sext.w a5,a5
    122a:  faf76de3           bltu a4,a5,11e4 <FUN_00000f2c+0x2b8>
    122e:  89042783           lw a5,-1904(s0)
    1232:  853e                 mv a0,a5
    1234:  a19ff0ef           jal ra,c4c <FUN_00000c4c>
    1238:  4781                 li a5,0
    123a:  853e                 mv a0,a5
    123c:  79813083           ld ra,1944(sp)
    1240:  79013403           ld s0,1936(sp)
    1244:  7a010113           addi sp,sp,1952
    1248:  8082                 ret
000000000000124a <FUN_0000124a>:
    124a:  7169                 addi sp,sp,-304
    124c:  f606                 sd ra,296(sp)
    124e:  f222                 sd s0,288(sp)
    1250:  1a00                 addi s0,sp,304
    1252:  eca43c23           sd a0,-296(s0)
    1256:  fe043023           sd zero,-32(s0)
    125a:  fc042e23           sw zero,-36(s0)
    125e:  ee840793           addi a5,s0,-280
    1262:  07fd                 addi a5,a5,31
    1264:  9b81                 andi a5,a5,-32
    1266:  fef43023           sd a5,-32(s0)
    126a:  47a1                 li a5,8
    126c:  fcf42e23           sw a5,-36(s0)
    1270:  f2840793           addi a5,s0,-216
    1274:  0b000613           li a2,176
    1278:  4581                 li a1,0
    127a:  853e                 mv a0,a5
    127c:  5eb080ef           jal ra,a066 <memset>
    1280:  ee840793           addi a5,s0,-280
    1284:  04000613           li a2,64
    1288:  4581                 li a1,0
    128a:  853e                 mv a0,a5
    128c:  5db080ef           jal ra,a066 <memset>
    1290:  f2042423           sw zero,-216(s0)
    1294:  800007b7           lui a5,0x80000
    1298:  0307879b           addiw a5,a5,48
    129c:  f2f42623           sw a5,-212(s0)
    12a0:  fdc42783           lw a5,-36(s0)
    12a4:  f4f42223           sw a5,-188(s0)
    12a8:  f4042423           sw zero,-184(s0)
    12ac:  f4042623           sw zero,-180(s0)
    12b0:  4785                 li a5,1
    12b2:  fef42623           sw a5,-20(s0)
    12b6:  a839                 j 12d4 <FUN_0000124a+0x8a>
    12b8:  fec42783           lw a5,-20(s0)
    12bc:  0791                 addi a5,a5,4
    12be:  078e                 slli a5,a5,0x3
    12c0:  ff040713           addi a4,s0,-16
    12c4:  97ba                 add a5,a5,a4
    12c6:  f207ae23           sw zero,-196(a5) # ffffffff7fffff3c <gpio_get_boot_devic
    12ca:  fec42783           lw a5,-20(s0)
    12ce:  2785                 addiw a5,a5,1
    12d0:  fef42623           sw a5,-20(s0)
    12d4:  fec42783           lw a5,-20(s0)
    12d8:  0007871b           sext.w a4,a5
    12dc:  479d                 li a5,7
    12de:  fce7dde3           bge a5,a4,12b8 <FUN_0000124a+0x6e>
    12e2:  fe043783           ld a5,-32(s0)
    12e6:  2781                 sext.w a5,a5
    12e8:  f8f42423           sw a5,-120(s0)
    12ec:  fdc42783           lw a5,-36(s0)
    12f0:  f8f42623           sw a5,-116(s0)
    12f4:  4785                 li a5,1
    12f6:  fef42623           sw a5,-20(s0)
    12fa:  a839                 j 1318 <FUN_0000124a+0xce>
    12fc:  fec42783           lw a5,-20(s0)
    1300:  07b1                 addi a5,a5,12
    1302:  078e                 slli a5,a5,0x3
    1304:  ff040713           addi a4,s0,-16
    1308:  97ba                 add a5,a5,a4
    130a:  f207ae23           sw zero,-196(a5)
    130e:  fec42783           lw a5,-20(s0)
    1312:  2785                 addiw a5,a5,1
    1314:  fef42623           sw a5,-20(s0)
    1318:  fec42783           lw a5,-20(s0)
    131c:  0007871b           sext.w a4,a5
    1320:  479d                 li a5,7
    1322:  fce7dde3           bge a5,a4,12fc <FUN_0000124a+0xb2>
    1326:  fc042423           sw zero,-56(s0)
    132a:  a40ff0ef           jal ra,56a <FUN_0000056a>
    132e:  f2840713           addi a4,s0,-216
    1332:  030417b7           lui a5,0x3041
    1336:  80078793           addi a5,a5,-2048 # 3040800 <gpio_get_boot_device+0x30324
    133a:  2701                 sext.w a4,a4
    133c:  c398                 sw a4,0(a5)
    133e:  f2842783           lw a5,-216(s0)
    1342:  4705                 li a4,1
    1344:  00f717bb           sllw a5,a4,a5
    1348:  0007871b           sext.w a4,a5
    134c:  030417b7           lui a5,0x3041
    1350:  80878793           addi a5,a5,-2040 # 3040808 <gpio_get_boot_device+0x30324
    1354:  2701                 sext.w a4,a4
    1356:  c398                 sw a4,0(a5)
    1358:  030417b7           lui a5,0x3041
    135c:  81078793           addi a5,a5,-2032 # 3040810 <gpio_get_boot_device+0x30324
    1360:  4705                 li a4,1
    1362:  c398                 sw a4,0(a5)
    1364:  f2842783           lw a5,-216(s0)
    1368:  853e                 mv a0,a5
    136a:  855ff0ef           jal ra,bbe <FUN_00000bbe>
    136e:  f2842783           lw a5,-216(s0)
    1372:  853e                 mv a0,a5
    1374:  8d9ff0ef           jal ra,c4c <FUN_00000c4c>
    1378:  fe043783           ld a5,-32(s0)
    137c:  02000613           li a2,32
    1380:  85be                 mv a1,a5
    1382:  ed843503           ld a0,-296(s0)
    1386:  3e7080ef           jal ra,9f6c <FUN_00009f6c>
    138a:  4781                 li a5,0
    138c:  853e                 mv a0,a5
    138e:  70b2                 ld ra,296(sp)
    1390:  7412                 ld s0,288(sp)
    1392:  6155                 addi sp,sp,304
    1394:  8082                 ret
0000000000001396 <FUN_00001396>:
    1396:  7139                 addi sp,sp,-64
    1398:  fc06                 sd ra,56(sp)
    139a:  f822                 sd s0,48(sp)
    139c:  f426                 sd s1,40(sp)
    139e:  0080                 addi s0,sp,64
    13a0:  fca43423           sd a0,-56(s0)
    13a4:  87ae                 mv a5,a1
    13a6:  fcf42223           sw a5,-60(s0)
    13aa:  fc042e23           sw zero,-36(s0)
    13ae:  fc042c23           sw zero,-40(s0)
    13b2:  fc442783           lw a5,-60(s0)
    13b6:  863e                 mv a2,a5
    13b8:  4581                 li a1,0
    13ba:  fc843503           ld a0,-56(s0)
    13be:  4a9080ef           jal ra,a066 <memset>
    13c2:  fc042c23           sw zero,-40(s0)
    13c6:  fc042e23           sw zero,-36(s0)
    13ca:  a83d                 j 1408 <FUN_00001396+0x72>
    13cc:  fdc42783           lw a5,-36(s0)
    13d0:  0707879b           addiw a5,a5,112
    13d4:  2781                 sext.w a5,a5
    13d6:  0007869b           sext.w a3,a5
    13da:  fd846783           lwu a5,-40(s0)
    13de:  078a                 slli a5,a5,0x2
    13e0:  fc843703           ld a4,-56(s0)
    13e4:  00f704b3           add s1,a4,a5
    13e8:  8536                 mv a0,a3
    13ea:  17d060ef           jal ra,7d66 <sid_readl>
    13ee:  87aa                 mv a5,a0
    13f0:  2781                 sext.w a5,a5
    13f2:  c09c                 sw a5,0(s1)
    13f4:  fdc42783           lw a5,-36(s0)
    13f8:  2791                 addiw a5,a5,4
    13fa:  fcf42e23           sw a5,-36(s0)
    13fe:  fd842783           lw a5,-40(s0)
    1402:  2785                 addiw a5,a5,1
    1404:  fcf42c23           sw a5,-40(s0)
    1408:  fdc42703           lw a4,-36(s0)
    140c:  fc442783           lw a5,-60(s0)
    1410:  2781                 sext.w a5,a5
    1412:  faf76de3           bltu a4,a5,13cc <FUN_00001396+0x36>
    1416:  4781                 li a5,0
    1418:  853e                 mv a0,a5
    141a:  70e2                 ld ra,56(sp)
    141c:  7442                 ld s0,48(sp)
    141e:  74a2                 ld s1,40(sp)
    1420:  6121                 addi sp,sp,64
    1422:  8082                 ret
0000000000001424 <FUN_00001424>:
    1424:  7179                 addi sp,sp,-48
    1426:  f422                 sd s0,40(sp)
    1428:  1800                 addi s0,sp,48
    142a:  87aa                 mv a5,a0
    142c:  fcf42e23           sw a5,-36(s0)
    1430:  fe042623           sw zero,-20(s0)
    1434:  fe042423           sw zero,-24(s0)
    1438:  0001                 nop
    143a:  030067b7           lui a5,0x3006
    143e:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    1442:  439c                 lw a5,0(a5)
    1444:  2781                 sext.w a5,a5
    1446:  8ba1                 andi a5,a5,8
    1448:  2781                 sext.w a5,a5
    144a:  fbe5                 bnez a5,143a <FUN_00001424+0x16>
    144c:  030067b7           lui a5,0x3006
    1450:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    1454:  439c                 lw a5,0(a5)
    1456:  fef42623           sw a5,-20(s0)
    145a:  fec42703           lw a4,-20(s0)
    145e:  fe0107b7           lui a5,0xfe010
    1462:  17f1                 addi a5,a5,-4
    1464:  8ff9                 and a5,a5,a4
    1466:  fef42623           sw a5,-20(s0)
    146a:  fdc42783           lw a5,-36(s0)
    146e:  0107979b           slliw a5,a5,0x10
    1472:  0007871b           sext.w a4,a5
    1476:  fec42783           lw a5,-20(s0)
    147a:  8fd9                 or a5,a5,a4
    147c:  fef42623           sw a5,-20(s0)
    1480:  030067b7           lui a5,0x3006
    1484:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    1488:  fec42703           lw a4,-20(s0)
    148c:  c398                 sw a4,0(a5)
    148e:  fec42703           lw a4,-20(s0)
    1492:  77c1                 lui a5,0xffff0
    1494:  0fc78793           addi a5,a5,252 # ffffffffffff00fc <gpio_get_boot_device+
    1498:  8ff9                 and a5,a5,a4
    149a:  fef42623           sw a5,-20(s0)
    149e:  fec42703           lw a4,-20(s0)
    14a2:  67ad                 lui a5,0xb
    14a4:  c0278793           addi a5,a5,-1022 # ac02 <FUN_0000ab08+0xfa>
    14a8:  8fd9                 or a5,a5,a4
    14aa:  fef42623           sw a5,-20(s0)
    14ae:  030067b7           lui a5,0x3006
    14b2:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    14b6:  fec42703           lw a4,-20(s0)
    14ba:  c398                 sw a4,0(a5)
    14bc:  0001                 nop
    14be:  030067b7           lui a5,0x3006
    14c2:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    14c6:  439c                 lw a5,0(a5)
    14c8:  2781                 sext.w a5,a5
    14ca:  8b89                 andi a5,a5,2
    14cc:  2781                 sext.w a5,a5
    14ce:  fbe5                 bnez a5,14be <FUN_00001424+0x9a>
    14d0:  fec42703           lw a4,-20(s0)
    14d4:  fe0007b7           lui a5,0xfe000
    14d8:  0fc78793           addi a5,a5,252 # fffffffffe0000fc <gpio_get_boot_device+
    14dc:  8ff9                 and a5,a5,a4
    14de:  fef42623           sw a5,-20(s0)
    14e2:  030067b7           lui a5,0x3006
    14e6:  04078793           addi a5,a5,64 # 3006040 <gpio_get_boot_device+0x2ff7caa>
    14ea:  fec42703           lw a4,-20(s0)
    14ee:  c398                 sw a4,0(a5)
    14f0:  030067b7           lui a5,0x3006
    14f4:  06078793           addi a5,a5,96 # 3006060 <gpio_get_boot_device+0x2ff7cca>
    14f8:  439c                 lw a5,0(a5)
    14fa:  fef42423           sw a5,-24(s0)
    14fe:  fe842783           lw a5,-24(s0)
    1502:  853e                 mv a0,a5
    1504:  7422                 ld s0,40(sp)
    1506:  6145                 addi sp,sp,48
    1508:  8082                 ret
000000000000150a <FUN_0000150a>:
    150a:  7139                 addi sp,sp,-64
    150c:  fc06                 sd ra,56(sp)
    150e:  f822                 sd s0,48(sp)
    1510:  f426                 sd s1,40(sp)
    1512:  0080                 addi s0,sp,64
    1514:  fca43423           sd a0,-56(s0)
    1518:  87ae                 mv a5,a1
    151a:  fcf42223           sw a5,-60(s0)
    151e:  fc042e23           sw zero,-36(s0)
    1522:  fc042c23           sw zero,-40(s0)
    1526:  fc442783           lw a5,-60(s0)
    152a:  863e                 mv a2,a5
    152c:  4581                 li a1,0
    152e:  fc843503           ld a0,-56(s0)
    1532:  335080ef           jal ra,a066 <memset>
    1536:  fc042c23           sw zero,-40(s0)
    153a:  fc042e23           sw zero,-36(s0)
    153e:  a83d                 j 157c <FUN_0000150a+0x72>
    1540:  fdc42783           lw a5,-36(s0)
    1544:  0707879b           addiw a5,a5,112
    1548:  2781                 sext.w a5,a5
    154a:  0007869b           sext.w a3,a5
    154e:  fd846783           lwu a5,-40(s0)
    1552:  078a                 slli a5,a5,0x2
    1554:  fc843703           ld a4,-56(s0)
    1558:  00f704b3           add s1,a4,a5
    155c:  8536                 mv a0,a3
    155e:  ec7ff0ef           jal ra,1424 <FUN_00001424>
    1562:  87aa                 mv a5,a0
    1564:  2781                 sext.w a5,a5
    1566:  c09c                 sw a5,0(s1)
    1568:  fdc42783           lw a5,-36(s0)
    156c:  2791                 addiw a5,a5,4
    156e:  fcf42e23           sw a5,-36(s0)
    1572:  fd842783           lw a5,-40(s0)
    1576:  2785                 addiw a5,a5,1
    1578:  fcf42c23           sw a5,-40(s0)
    157c:  fdc42703           lw a4,-36(s0)
    1580:  fc442783           lw a5,-60(s0)
    1584:  2781                 sext.w a5,a5
    1586:  faf76de3           bltu a4,a5,1540 <FUN_0000150a+0x36>
    158a:  4781                 li a5,0
    158c:  853e                 mv a0,a5
    158e:  70e2                 ld ra,56(sp)
    1590:  7442                 ld s0,48(sp)
    1592:  74a2                 ld s1,40(sp)
    1594:  6121                 addi sp,sp,64
    1596:  8082                 ret
0000000000001598 <FUN_00001598>:
    1598:  7139                 addi sp,sp,-64
    159a:  fc22                 sd s0,56(sp)
    159c:  0080                 addi s0,sp,64
    159e:  fca43c23           sd a0,-40(s0)
    15a2:  87ae                 mv a5,a1
    15a4:  fcc43423           sd a2,-56(s0)
    15a8:  fcf42a23           sw a5,-44(s0)
    15ac:  fe042623           sw zero,-20(s0)
    15b0:  fd843783           ld a5,-40(s0)
    15b4:  0007c783           lbu a5,0(a5)
    15b8:  873e                 mv a4,a5
    15ba:  03000793           li a5,48
    15be:  04f71b63           bne a4,a5,1614 <FUN_00001598+0x7c>
    15c2:  fd843783           ld a5,-40(s0)
    15c6:  0785                 addi a5,a5,1
    15c8:  0007c783           lbu a5,0(a5)
    15cc:  fef42623           sw a5,-20(s0)
    15d0:  fec42783           lw a5,-20(s0)
    15d4:  2789                 addiw a5,a5,2
    15d6:  fef42623           sw a5,-20(s0)
    15da:  fec42783           lw a5,-20(s0)
    15de:  0007871b           sext.w a4,a5
    15e2:  07f00793           li a5,127
    15e6:  00e7ea63           bltu a5,a4,15fa <FUN_00001598+0x62>
    15ea:  fec42703           lw a4,-20(s0)
    15ee:  fd442783           lw a5,-44(s0)
    15f2:  2701                 sext.w a4,a4
    15f4:  2781                 sext.w a5,a5
    15f6:  00f76463           bltu a4,a5,15fe <FUN_00001598+0x66>
    15fa:  57fd                 li a5,-1
    15fc:  a829                 j 1616 <FUN_00001598+0x7e>
    15fe:  fec46783           lwu a5,-20(s0)
    1602:  fd843703           ld a4,-40(s0)
    1606:  973e                 add a4,a4,a5
    1608:  fc843783           ld a5,-56(s0)
    160c:  e398                 sd a4,0(a5)
    160e:  fec42783           lw a5,-20(s0)
    1612:  a011                 j 1616 <FUN_00001598+0x7e>
    1614:  57fd                 li a5,-1
    1616:  853e                 mv a0,a5
    1618:  7462                 ld s0,56(sp)
    161a:  6121                 addi sp,sp,64
    161c:  8082                 ret
000000000000161e <FUN_0000161e>:
    161e:  7179                 addi sp,sp,-48
    1620:  f406                 sd ra,40(sp)
    1622:  f022                 sd s0,32(sp)
    1624:  1800                 addi s0,sp,48
    1626:  87aa                 mv a5,a0
    1628:  feb43023           sd a1,-32(s0)
    162c:  8732                 mv a4,a2
    162e:  fcd43c23           sd a3,-40(s0)
    1632:  fef42623           sw a5,-20(s0)
    1636:  87ba                 mv a5,a4
    1638:  fef42423           sw a5,-24(s0)
    163c:  fe842783           lw a5,-24(s0)
    1640:  863e                 mv a2,a5
    1642:  4581                 li a1,0
    1644:  fe043503           ld a0,-32(s0)
    1648:  0a3080ef           jal ra,9eea <memset>
    164c:  fec42783           lw a5,-20(s0)
    1650:  0007871b           sext.w a4,a5
    1654:  07f00793           li a5,127
    1658:  00e7ef63           bltu a5,a4,1676 <FUN_0000161e+0x58>
    165c:  fec42783           lw a5,-20(s0)
    1660:  0ff7f713           andi a4,a5,255
    1664:  fe043783           ld a5,-32(s0)
    1668:  00e78023           sb a4,0(a5)
    166c:  fd843783           ld a5,-40(s0)
    1670:  4705                 li a4,1
    1672:  c398                 sw a4,0(a5)
    1674:  a8d5                 j 1768 <FUN_0000161e+0x14a>
    1676:  fec42783           lw a5,-20(s0)
    167a:  0007871b           sext.w a4,a5
    167e:  0ff00793           li a5,255
    1682:  02e7e663           bltu a5,a4,16ae <FUN_0000161e+0x90>
    1686:  fe043783           ld a5,-32(s0)
    168a:  f8100713           li a4,-127
    168e:  00e78023           sb a4,0(a5)
    1692:  fe043783           ld a5,-32(s0)
    1696:  0785                 addi a5,a5,1
    1698:  fec42703           lw a4,-20(s0)
    169c:  0ff77713           andi a4,a4,255
    16a0:  00e78023           sb a4,0(a5)
    16a4:  fd843783           ld a5,-40(s0)
    16a8:  4709                 li a4,2
    16aa:  c398                 sw a4,0(a5)
    16ac:  a875                 j 1768 <FUN_0000161e+0x14a>
    16ae:  fec42783           lw a5,-20(s0)
    16b2:  0007871b           sext.w a4,a5
    16b6:  67c1                 lui a5,0x10
    16b8:  04f77363           bgeu a4,a5,16fe <FUN_0000161e+0xe0>
    16bc:  fe043783           ld a5,-32(s0)
    16c0:  f8200713           li a4,-126
    16c4:  00e78023           sb a4,0(a5) # 10000 <gpio_get_boot_device+0x1c6a>
    16c8:  fec42783           lw a5,-20(s0)
    16cc:  0087d79b           srliw a5,a5,0x8
    16d0:  0007871b           sext.w a4,a5
    16d4:  fe043783           ld a5,-32(s0)
    16d8:  0785                 addi a5,a5,1
    16da:  0ff77713           andi a4,a4,255
    16de:  00e78023           sb a4,0(a5)
    16e2:  fe043783           ld a5,-32(s0)
    16e6:  0789                 addi a5,a5,2
    16e8:  fec42703           lw a4,-20(s0)
    16ec:  0ff77713           andi a4,a4,255
    16f0:  00e78023           sb a4,0(a5)
    16f4:  fd843783           ld a5,-40(s0)
    16f8:  470d                 li a4,3
    16fa:  c398                 sw a4,0(a5)
    16fc:  a0b5                 j 1768 <FUN_0000161e+0x14a>
    16fe:  fec42783           lw a5,-20(s0)
    1702:  0007871b           sext.w a4,a5
    1706:  010007b7           lui a5,0x1000
    170a:  04f77f63           bgeu a4,a5,1768 <FUN_0000161e+0x14a>
    170e:  fe043783           ld a5,-32(s0)
    1712:  f8300713           li a4,-125
    1716:  00e78023           sb a4,0(a5) # 1000000 <gpio_get_boot_device+0xff1c6a>
    171a:  fec42783           lw a5,-20(s0)
    171e:  0107d79b           srliw a5,a5,0x10
    1722:  0007871b           sext.w a4,a5
    1726:  fe043783           ld a5,-32(s0)
    172a:  0785                 addi a5,a5,1
    172c:  0ff77713           andi a4,a4,255
    1730:  00e78023           sb a4,0(a5)
    1734:  fec42783           lw a5,-20(s0)
    1738:  0087d79b           srliw a5,a5,0x8
    173c:  0007871b           sext.w a4,a5
    1740:  fe043783           ld a5,-32(s0)
    1744:  0789                 addi a5,a5,2
    1746:  0ff77713           andi a4,a4,255
    174a:  00e78023           sb a4,0(a5)
    174e:  fe043783           ld a5,-32(s0)
    1752:  078d                 addi a5,a5,3
    1754:  fec42703           lw a4,-20(s0)
    1758:  0ff77713           andi a4,a4,255
    175c:  00e78023           sb a4,0(a5)
    1760:  fd843783           ld a5,-40(s0)
    1764:  4711                 li a4,4
    1766:  c398                 sw a4,0(a5)
    1768:  0001                 nop
    176a:  70a2                 ld ra,40(sp)
    176c:  7402                 ld s0,32(sp)
    176e:  6145                 addi sp,sp,48
    1770:  8082                 ret
0000000000001772 <FUN_00001772>:
    1772:  711d                 addi sp,sp,-96
    1774:  ec86                 sd ra,88(sp)
    1776:  e8a2                 sd s0,80(sp)
    1778:  1080                 addi s0,sp,96
    177a:  fca43423           sd a0,-56(s0)
    177e:  fcb43023           sd a1,-64(s0)
    1782:  fac43c23           sd a2,-72(s0)
    1786:  fad43823           sd a3,-80(s0)
    178a:  87ba                 mv a5,a4
    178c:  faf42623           sw a5,-84(s0)
    1790:  fc843783           ld a5,-56(s0)
    1794:  fef43423           sd a5,-24(s0)
    1798:  fe042223           sw zero,-28(s0)
    179c:  fe042023           sw zero,-32(s0)
    17a0:  fc042e23           sw zero,-36(s0)
    17a4:  fc043783           ld a5,-64(s0)
    17a8:  cb89                 beqz a5,17ba <FUN_00001772+0x48>
    17aa:  fac42783           lw a5,-84(s0)
    17ae:  863e                 mv a2,a5
    17b0:  4581                 li a1,0
    17b2:  fc043503           ld a0,-64(s0)
    17b6:  0b1080ef           jal ra,a066 <memset>
    17ba:  fe843783           ld a5,-24(s0)
    17be:  0785                 addi a5,a5,1
    17c0:  0007c783           lbu a5,0(a5)
    17c4:  0187979b           slliw a5,a5,0x18
    17c8:  4187d79b           sraiw a5,a5,0x18
    17cc:  0607cc63           bltz a5,1844 <FUN_00001772+0xd2>
    17d0:  fe843783           ld a5,-24(s0)
    17d4:  0785                 addi a5,a5,1
    17d6:  0007c783           lbu a5,0(a5)
    17da:  fef42223           sw a5,-28(s0)
    17de:  fe442783           lw a5,-28(s0)
    17e2:  2789                 addiw a5,a5,2
    17e4:  0007871b           sext.w a4,a5
    17e8:  fb043783           ld a5,-80(s0)
    17ec:  c398                 sw a4,0(a5)
    17ee:  fe442783           lw a5,-28(s0)
    17f2:  8b85                 andi a5,a5,1
    17f4:  0ff7f793           andi a5,a5,255
    17f8:  cf99                 beqz a5,1816 <FUN_00001772+0xa4>
    17fa:  fe843783           ld a5,-24(s0)
    17fe:  0789                 addi a5,a5,2
    1800:  0007c783           lbu a5,0(a5)
    1804:  eb89                 bnez a5,1816 <FUN_00001772+0xa4>
    1806:  4785                 li a5,1
    1808:  fef42023           sw a5,-32(s0)
    180c:  fe442783           lw a5,-28(s0)
    1810:  37fd                 addiw a5,a5,-1
    1812:  fef42223           sw a5,-28(s0)
    1816:  fb843783           ld a5,-72(s0)
    181a:  fe442703           lw a4,-28(s0)
    181e:  c398                 sw a4,0(a5)
    1820:  fe843783           ld a5,-24(s0)
    1824:  0789                 addi a5,a5,2
    1826:  fef43423           sd a5,-24(s0)
    182a:  fe042783           lw a5,-32(s0)
    182e:  2781                 sext.w a5,a5
    1830:  c791                 beqz a5,183c <FUN_00001772+0xca>
    1832:  fe843783           ld a5,-24(s0)
    1836:  0785                 addi a5,a5,1
    1838:  fef43423           sd a5,-24(s0)
    183c:  4785                 li a5,1
    183e:  fcf42e23           sw a5,-36(s0)
    1842:  aa39                 j 1960 <FUN_00001772+0x1ee>
    1844:  fe843783           ld a5,-24(s0)
    1848:  0785                 addi a5,a5,1
    184a:  0007c783           lbu a5,0(a5)
    184e:  873e                 mv a4,a5
    1850:  08100793           li a5,129
    1854:  06f71c63           bne a4,a5,18cc <FUN_00001772+0x15a>
    1858:  fe843783           ld a5,-24(s0)
    185c:  0789                 addi a5,a5,2
    185e:  0007c783           lbu a5,0(a5)
    1862:  fef42223           sw a5,-28(s0)
    1866:  fe442783           lw a5,-28(s0)
    186a:  278d                 addiw a5,a5,3
    186c:  0007871b           sext.w a4,a5
    1870:  fb043783           ld a5,-80(s0)
    1874:  c398                 sw a4,0(a5)
    1876:  fe442783           lw a5,-28(s0)
    187a:  8b85                 andi a5,a5,1
    187c:  0ff7f793           andi a5,a5,255
    1880:  cf99                 beqz a5,189e <FUN_00001772+0x12c>
    1882:  fe843783           ld a5,-24(s0)
    1886:  078d                 addi a5,a5,3
    1888:  0007c783           lbu a5,0(a5)
    188c:  eb89                 bnez a5,189e <FUN_00001772+0x12c>
    188e:  4785                 li a5,1
    1890:  fef42023           sw a5,-32(s0)
    1894:  fe442783           lw a5,-28(s0)
    1898:  37fd                 addiw a5,a5,-1
    189a:  fef42223           sw a5,-28(s0)
    189e:  fb843783           ld a5,-72(s0)
    18a2:  fe442703           lw a4,-28(s0)
    18a6:  c398                 sw a4,0(a5)
    18a8:  fe843783           ld a5,-24(s0)
    18ac:  078d                 addi a5,a5,3
    18ae:  fef43423           sd a5,-24(s0)
    18b2:  fe042783           lw a5,-32(s0)
    18b6:  2781                 sext.w a5,a5
    18b8:  c791                 beqz a5,18c4 <FUN_00001772+0x152>
    18ba:  fe843783           ld a5,-24(s0)
    18be:  0785                 addi a5,a5,1
    18c0:  fef43423           sd a5,-24(s0)
    18c4:  4789                 li a5,2
    18c6:  fcf42e23           sw a5,-36(s0)
    18ca:  a859                 j 1960 <FUN_00001772+0x1ee>
    18cc:  fe843783           ld a5,-24(s0)
    18d0:  0785                 addi a5,a5,1
    18d2:  0007c783           lbu a5,0(a5)
    18d6:  873e                 mv a4,a5
    18d8:  08200793           li a5,130
    18dc:  08f71263           bne a4,a5,1960 <FUN_00001772+0x1ee>
    18e0:  fe843783           ld a5,-24(s0)
    18e4:  0789                 addi a5,a5,2
    18e6:  0007c783           lbu a5,0(a5)
    18ea:  2781                 sext.w a5,a5
    18ec:  0087979b           slliw a5,a5,0x8
    18f0:  0007871b           sext.w a4,a5
    18f4:  fe843783           ld a5,-24(s0)
    18f8:  078d                 addi a5,a5,3
    18fa:  0007c783           lbu a5,0(a5)
    18fe:  2781                 sext.w a5,a5
    1900:  8fd9                 or a5,a5,a4
    1902:  2781                 sext.w a5,a5
    1904:  fef42223           sw a5,-28(s0)
    1908:  fe442783           lw a5,-28(s0)
    190c:  2791                 addiw a5,a5,4
    190e:  0007871b           sext.w a4,a5
    1912:  fb043783           ld a5,-80(s0)
    1916:  c398                 sw a4,0(a5)
    1918:  fe442783           lw a5,-28(s0)
    191c:  8b85                 andi a5,a5,1
    191e:  0ff7f793           andi a5,a5,255
    1922:  cb89                 beqz a5,1934 <FUN_00001772+0x1c2>
    1924:  4785                 li a5,1
    1926:  fef42023           sw a5,-32(s0)
    192a:  fe442783           lw a5,-28(s0)
    192e:  37fd                 addiw a5,a5,-1
    1930:  fef42223           sw a5,-28(s0)
    1934:  fb843783           ld a5,-72(s0)
    1938:  fe442703           lw a4,-28(s0)
    193c:  c398                 sw a4,0(a5)
    193e:  fe843783           ld a5,-24(s0)
    1942:  0791                 addi a5,a5,4
    1944:  fef43423           sd a5,-24(s0)
    1948:  fe042783           lw a5,-32(s0)
    194c:  2781                 sext.w a5,a5
    194e:  c791                 beqz a5,195a <FUN_00001772+0x1e8>
    1950:  fe843783           ld a5,-24(s0)
    1954:  0785                 addi a5,a5,1
    1956:  fef43423           sd a5,-24(s0)
    195a:  478d                 li a5,3
    195c:  fcf42e23           sw a5,-36(s0)
    1960:  fc043783           ld a5,-64(s0)
    1964:  c795                 beqz a5,1990 <FUN_00001772+0x21e>
    1966:  fe442703           lw a4,-28(s0)
    196a:  fac42783           lw a5,-84(s0)
    196e:  2701                 sext.w a4,a4
    1970:  2781                 sext.w a5,a5
    1972:  00e7f663           bgeu a5,a4,197e <FUN_00001772+0x20c>
    1976:  fac42783           lw a5,-84(s0)
    197a:  fef42223           sw a5,-28(s0)
    197e:  fe442783           lw a5,-28(s0)
    1982:  863e                 mv a2,a5
    1984:  fe843583           ld a1,-24(s0)
    1988:  fc043503           ld a0,-64(s0)
    198c:  5ae080ef           jal ra,9f3a <FUN_00009f3a>
    1990:  fdc42783           lw a5,-36(s0)
    1994:  853e                 mv a0,a5
    1996:  60e6                 ld ra,88(sp)
    1998:  6446                 ld s0,80(sp)
    199a:  6125                 addi sp,sp,96
    199c:  8082                 ret
000000000000199e <FUN_0000199e>:
    199e:  715d                 addi sp,sp,-80
    19a0:  e486                 sd ra,72(sp)
    19a2:  e0a2                 sd s0,64(sp)
    19a4:  0880                 addi s0,sp,80
    19a6:  fca43423           sd a0,-56(s0)
    19aa:  87ae                 mv a5,a1
    19ac:  fac43c23           sd a2,-72(s0)
    19b0:  fcf42223           sw a5,-60(s0)
    19b4:  fc843783           ld a5,-56(s0)
    19b8:  fef43423           sd a5,-24(s0)
    19bc:  fc843783           ld a5,-56(s0)
    19c0:  fef43023           sd a5,-32(s0)
    19c4:  fc042e23           sw zero,-36(s0)
    19c8:  fc042c23           sw zero,-40(s0)
    19cc:  fe843783           ld a5,-24(s0)
    19d0:  0785                 addi a5,a5,1
    19d2:  fef43423           sd a5,-24(s0)
    19d6:  fe843783           ld a5,-24(s0)
    19da:  0785                 addi a5,a5,1
    19dc:  fef43423           sd a5,-24(s0)
    19e0:  fb843783           ld a5,-72(s0)
    19e4:  fdc40693           addi a3,s0,-36
    19e8:  fd840613           addi a2,s0,-40
    19ec:  4711                 li a4,4
    19ee:  85be                 mv a1,a5
    19f0:  fe843503           ld a0,-24(s0)
    19f4:  d7fff0ef           jal ra,1772 <FUN_00001772>
    19f8:  fdc42783           lw a5,-36(s0)
    19fc:  1782                 slli a5,a5,0x20
    19fe:  9381                 srli a5,a5,0x20
    1a00:  fe843703           ld a4,-24(s0)
    1a04:  97ba                 add a5,a5,a4
    1a06:  fef43423           sd a5,-24(s0)
    1a0a:  fb843783           ld a5,-72(s0)
    1a0e:  0791                 addi a5,a5,4
    1a10:  fdc40693           addi a3,s0,-36
    1a14:  fd840613           addi a2,s0,-40
    1a18:  4711                 li a4,4
    1a1a:  85be                 mv a1,a5
    1a1c:  fe843503           ld a0,-24(s0)
    1a20:  d53ff0ef           jal ra,1772 <FUN_00001772>
    1a24:  fdc42783           lw a5,-36(s0)
    1a28:  1782                 slli a5,a5,0x20
    1a2a:  9381                 srli a5,a5,0x20
    1a2c:  fe843703           ld a4,-24(s0)
    1a30:  97ba                 add a5,a5,a4
    1a32:  fef43423           sd a5,-24(s0)
    1a36:  fe843783           ld a5,-24(s0)
    1a3a:  0017c703           lbu a4,1(a5)
    1a3e:  fb843783           ld a5,-72(s0)
    1a42:  00e78e23           sb a4,28(a5)
    1a46:  fb843783           ld a5,-72(s0)
    1a4a:  00878713           addi a4,a5,8
    1a4e:  fe843783           ld a5,-24(s0)
    1a52:  00178693           addi a3,a5,1
    1a56:  fb843783           ld a5,-72(s0)
    1a5a:  01c7c783           lbu a5,28(a5)
    1a5e:  2781                 sext.w a5,a5
    1a60:  863e                 mv a2,a5
    1a62:  85b6                 mv a1,a3
    1a64:  853a                 mv a0,a4
    1a66:  4d4080ef           jal ra,9f3a <FUN_00009f3a>
    1a6a:  fe843783           ld a5,-24(s0)
    1a6e:  0785                 addi a5,a5,1
    1a70:  0007c783           lbu a5,0(a5)
    1a74:  873e                 mv a4,a5
    1a76:  fe843783           ld a5,-24(s0)
    1a7a:  97ba                 add a5,a5,a4
    1a7c:  fef43423           sd a5,-24(s0)
    1a80:  fe843783           ld a5,-24(s0)
    1a84:  0789                 addi a5,a5,2
    1a86:  fef43423           sd a5,-24(s0)
    1a8a:  fe843783           ld a5,-24(s0)
    1a8e:  fef43023           sd a5,-32(s0)
    1a92:  fc042e23           sw zero,-36(s0)
    1a96:  fe043683           ld a3,-32(s0)
    1a9a:  fdc42783           lw a5,-36(s0)
    1a9e:  fc442703           lw a4,-60(s0)
    1aa2:  40f707bb           subw a5,a4,a5
    1aa6:  2781                 sext.w a5,a5
    1aa8:  fe040713           addi a4,s0,-32
    1aac:  863a                 mv a2,a4
    1aae:  85be                 mv a1,a5
    1ab0:  8536                 mv a0,a3
    1ab2:  ae7ff0ef           jal ra,1598 <FUN_00001598>
    1ab6:  87aa                 mv a5,a0
    1ab8:  0007871b           sext.w a4,a5
    1abc:  fdc42783           lw a5,-36(s0)
    1ac0:  9fb9                 addw a5,a5,a4
    1ac2:  2781                 sext.w a5,a5
    1ac4:  fcf42e23           sw a5,-36(s0)
    1ac8:  fe043683           ld a3,-32(s0)
    1acc:  fdc42783           lw a5,-36(s0)
    1ad0:  fc442703           lw a4,-60(s0)
    1ad4:  40f707bb           subw a5,a4,a5
    1ad8:  2781                 sext.w a5,a5
    1ada:  fe040713           addi a4,s0,-32
    1ade:  863a                 mv a2,a4
    1ae0:  85be                 mv a1,a5
    1ae2:  8536                 mv a0,a3
    1ae4:  ab5ff0ef           jal ra,1598 <FUN_00001598>
    1ae8:  87aa                 mv a5,a0
    1aea:  0007871b           sext.w a4,a5
    1aee:  fdc42783           lw a5,-36(s0)
    1af2:  9fb9                 addw a5,a5,a4
    1af4:  2781                 sext.w a5,a5
    1af6:  fcf42e23           sw a5,-36(s0)
    1afa:  fe043683           ld a3,-32(s0)
    1afe:  fdc42783           lw a5,-36(s0)
    1b02:  fc442703           lw a4,-60(s0)
    1b06:  40f707bb           subw a5,a4,a5
    1b0a:  2781                 sext.w a5,a5
    1b0c:  fe040713           addi a4,s0,-32
    1b10:  863a                 mv a2,a4
    1b12:  85be                 mv a1,a5
    1b14:  8536                 mv a0,a3
    1b16:  a83ff0ef           jal ra,1598 <FUN_00001598>
    1b1a:  87aa                 mv a5,a0
    1b1c:  0007871b           sext.w a4,a5
    1b20:  fdc42783           lw a5,-36(s0)
    1b24:  9fb9                 addw a5,a5,a4
    1b26:  2781                 sext.w a5,a5
    1b28:  fcf42e23           sw a5,-36(s0)
    1b2c:  fe043783           ld a5,-32(s0)
    1b30:  fef43423           sd a5,-24(s0)
    1b34:  fe843783           ld a5,-24(s0)
    1b38:  0791                 addi a5,a5,4
    1b3a:  fef43423           sd a5,-24(s0)
    1b3e:  fb843783           ld a5,-72(s0)
    1b42:  01d78713           addi a4,a5,29
    1b46:  fe843783           ld a5,-24(s0)
    1b4a:  00278693           addi a3,a5,2
    1b4e:  fe843783           ld a5,-24(s0)
    1b52:  0785                 addi a5,a5,1
    1b54:  0007c783           lbu a5,0(a5)
    1b58:  2781                 sext.w a5,a5
    1b5a:  863e                 mv a2,a5
    1b5c:  85b6                 mv a1,a3
    1b5e:  853a                 mv a0,a4
    1b60:  3da080ef           jal ra,9f3a <FUN_00009f3a>
    1b64:  fe843783           ld a5,-24(s0)
    1b68:  0785                 addi a5,a5,1
    1b6a:  0007c783           lbu a5,0(a5)
    1b6e:  873e                 mv a4,a5
    1b70:  fe843783           ld a5,-24(s0)
    1b74:  97ba                 add a5,a5,a4
    1b76:  fef43423           sd a5,-24(s0)
    1b7a:  fe843783           ld a5,-24(s0)
    1b7e:  0789                 addi a5,a5,2
    1b80:  fef43423           sd a5,-24(s0)
    1b84:  fd840693           addi a3,s0,-40
    1b88:  fd840793           addi a5,s0,-40
    1b8c:  4701                 li a4,0
    1b8e:  863e                 mv a2,a5
    1b90:  4581                 li a1,0
    1b92:  fe843503           ld a0,-24(s0)
    1b96:  bddff0ef           jal ra,1772 <FUN_00001772>
    1b9a:  87aa                 mv a5,a0
    1b9c:  2781                 sext.w a5,a5
    1b9e:  fcf42e23           sw a5,-36(s0)
    1ba2:  fdc42783           lw a5,-36(s0)
    1ba6:  1782                 slli a5,a5,0x20
    1ba8:  9381                 srli a5,a5,0x20
    1baa:  fe843703           ld a4,-24(s0)
    1bae:  97ba                 add a5,a5,a4
    1bb0:  fef43423           sd a5,-24(s0)
    1bb4:  fe843783           ld a5,-24(s0)
    1bb8:  0785                 addi a5,a5,1
    1bba:  fef43423           sd a5,-24(s0)
    1bbe:  fb843783           ld a5,-72(s0)
    1bc2:  02d78593           addi a1,a5,45
    1bc6:  fb843783           ld a5,-72(s0)
    1bca:  1c078793           addi a5,a5,448
    1bce:  fdc40693           addi a3,s0,-36
    1bd2:  19000713           li a4,400
    1bd6:  863e                 mv a2,a5
    1bd8:  fe843503           ld a0,-24(s0)
    1bdc:  b97ff0ef           jal ra,1772 <FUN_00001772>
    1be0:  fdc42783           lw a5,-36(s0)
    1be4:  1782                 slli a5,a5,0x20
    1be6:  9381                 srli a5,a5,0x20
    1be8:  fe843703           ld a4,-24(s0)
    1bec:  97ba                 add a5,a5,a4
    1bee:  fef43423           sd a5,-24(s0)
    1bf2:  fb843783           ld a5,-72(s0)
    1bf6:  1c478593           addi a1,a5,452
    1bfa:  fb843783           ld a5,-72(s0)
    1bfe:  35478793           addi a5,a5,852
    1c02:  fdc40693           addi a3,s0,-36
    1c06:  19000713           li a4,400
    1c0a:  863e                 mv a2,a5
    1c0c:  fe843503           ld a0,-24(s0)
    1c10:  b63ff0ef           jal ra,1772 <FUN_00001772>
    1c14:  fdc42783           lw a5,-36(s0)
    1c18:  1782                 slli a5,a5,0x20
    1c1a:  9381                 srli a5,a5,0x20
    1c1c:  fe843703           ld a4,-24(s0)
    1c20:  97ba                 add a5,a5,a4
    1c22:  fef43423           sd a5,-24(s0)
    1c26:  fe843703           ld a4,-24(s0)
    1c2a:  fc843783           ld a5,-56(s0)
    1c2e:  40f707b3           sub a5,a4,a5
    1c32:  2781                 sext.w a5,a5
    1c34:  853e                 mv a0,a5
    1c36:  60a6                 ld ra,72(sp)
    1c38:  6406                 ld s0,64(sp)
    1c3a:  6161                 addi sp,sp,80
    1c3c:  8082                 ret
0000000000001c3e <FUN_00001c3e>:
    1c3e:  7139                 addi sp,sp,-64
    1c40:  fc06                 sd ra,56(sp)
    1c42:  f822                 sd s0,48(sp)
    1c44:  0080                 addi s0,sp,64
    1c46:  fca43c23           sd a0,-40(s0)
    1c4a:  87ae                 mv a5,a1
    1c4c:  fcc43423           sd a2,-56(s0)
    1c50:  fcf42a23           sw a5,-44(s0)
    1c54:  fd843783           ld a5,-40(s0)
    1c58:  fef43423           sd a5,-24(s0)
    1c5c:  fe843783           ld a5,-24(s0)
    1c60:  0789                 addi a5,a5,2
    1c62:  fef43423           sd a5,-24(s0)
    1c66:  fe843783           ld a5,-24(s0)
    1c6a:  0789                 addi a5,a5,2
    1c6c:  fef43423           sd a5,-24(s0)
    1c70:  fe843783           ld a5,-24(s0)
    1c74:  0789                 addi a5,a5,2
    1c76:  fef43423           sd a5,-24(s0)
    1c7a:  fc843783           ld a5,-56(s0)
    1c7e:  35878793           addi a5,a5,856
    1c82:  02000613           li a2,32
    1c86:  fe843583           ld a1,-24(s0)
    1c8a:  853e                 mv a0,a5
    1c8c:  2ae080ef           jal ra,9f3a <FUN_00009f3a>
    1c90:  fe843783           ld a5,-24(s0)
    1c94:  02078793           addi a5,a5,32
    1c98:  fef43423           sd a5,-24(s0)
    1c9c:  fe843703           ld a4,-24(s0)
    1ca0:  fd843783           ld a5,-40(s0)
    1ca4:  40f707b3           sub a5,a4,a5
    1ca8:  2781                 sext.w a5,a5
    1caa:  853e                 mv a0,a5
    1cac:  70e2                 ld ra,56(sp)
    1cae:  7442                 ld s0,48(sp)
    1cb0:  6121                 addi sp,sp,64
    1cb2:  8082                 ret
0000000000001cb4 <FUN_00001cb4>:
    1cb4:  711d                 addi sp,sp,-96
    1cb6:  ec86                 sd ra,88(sp)
    1cb8:  e8a2                 sd s0,80(sp)
    1cba:  1080                 addi s0,sp,96
    1cbc:  faa43c23           sd a0,-72(s0)
    1cc0:  87ae                 mv a5,a1
    1cc2:  fac43423           sd a2,-88(s0)
    1cc6:  faf42a23           sw a5,-76(s0)
    1cca:  fb843783           ld a5,-72(s0)
    1cce:  fef43023           sd a5,-32(s0)
    1cd2:  fc042e23           sw zero,-36(s0)
    1cd6:  fc042c23           sw zero,-40(s0)
    1cda:  fe042623           sw zero,-20(s0)
    1cde:  fc042a23           sw zero,-44(s0)
    1ce2:  fc840793           addi a5,s0,-56
    1ce6:  4621                 li a2,8
    1ce8:  4581                 li a1,0
    1cea:  853e                 mv a0,a5
    1cec:  37a080ef           jal ra,a066 <memset>
    1cf0:  fe043783           ld a5,-32(s0)
    1cf4:  0007c783           lbu a5,0(a5)
    1cf8:  873e                 mv a4,a5
    1cfa:  0a300793           li a5,163
    1cfe:  00f70463           beq a4,a5,1d06 <FUN_00001cb4+0x52>
    1d02:  57fd                 li a5,-1
    1d04:  a211                 j 1e08 <FUN_00001cb4+0x154>
    1d06:  fe043783           ld a5,-32(s0)
    1d0a:  0785                 addi a5,a5,1
    1d0c:  0007c783           lbu a5,0(a5)
    1d10:  fcf42e23           sw a5,-36(s0)
    1d14:  fe043783           ld a5,-32(s0)
    1d18:  0789                 addi a5,a5,2
    1d1a:  fef43023           sd a5,-32(s0)
    1d1e:  fe043783           ld a5,-32(s0)
    1d22:  0007c783           lbu a5,0(a5)
    1d26:  873e                 mv a4,a5
    1d28:  03000793           li a5,48
    1d2c:  00f70463           beq a4,a5,1d34 <FUN_00001cb4+0x80>
    1d30:  57fd                 li a5,-1
    1d32:  a8d9                 j 1e08 <FUN_00001cb4+0x154>
    1d34:  fe043783           ld a5,-32(s0)
    1d38:  0785                 addi a5,a5,1
    1d3a:  0007c783           lbu a5,0(a5)
    1d3e:  fcf42c23           sw a5,-40(s0)
    1d42:  fe043783           ld a5,-32(s0)
    1d46:  0789                 addi a5,a5,2
    1d48:  fef43023           sd a5,-32(s0)
    1d4c:  fe043783           ld a5,-32(s0)
    1d50:  0007c783           lbu a5,0(a5)
    1d54:  873e                 mv a4,a5
    1d56:  4789                 li a5,2
    1d58:  00f70463           beq a4,a5,1d60 <FUN_00001cb4+0xac>
    1d5c:  57fd                 li a5,-1
    1d5e:  a06d                 j 1e08 <FUN_00001cb4+0x154>
    1d60:  fe043783           ld a5,-32(s0)
    1d64:  0789                 addi a5,a5,2
    1d66:  fef43023           sd a5,-32(s0)
    1d6a:  fa843783           ld a5,-88(s0)
    1d6e:  35878793           addi a5,a5,856
    1d72:  02000613           li a2,32
    1d76:  fe043583           ld a1,-32(s0)
    1d7a:  853e                 mv a0,a5
    1d7c:  1be080ef           jal ra,9f3a <FUN_00009f3a>
    1d80:  fe043783           ld a5,-32(s0)
    1d84:  02078793           addi a5,a5,32
    1d88:  fef43023           sd a5,-32(s0)
    1d8c:  fe043783           ld a5,-32(s0)
    1d90:  0007c783           lbu a5,0(a5)
    1d94:  873e                 mv a4,a5
    1d96:  03000793           li a5,48
    1d9a:  00f70463           beq a4,a5,1da2 <FUN_00001cb4+0xee>
    1d9e:  57fd                 li a5,-1
    1da0:  a0a5                 j 1e08 <FUN_00001cb4+0x154>
    1da2:  fe043783           ld a5,-32(s0)
    1da6:  0785                 addi a5,a5,1
    1da8:  0007c783           lbu a5,0(a5)
    1dac:  fef42623           sw a5,-20(s0)
    1db0:  fec42783           lw a5,-20(s0)
    1db4:  37f9                 addiw a5,a5,-2
    1db6:  fef42623           sw a5,-20(s0)
    1dba:  fe043783           ld a5,-32(s0)
    1dbe:  0789                 addi a5,a5,2
    1dc0:  fef43023           sd a5,-32(s0)
    1dc4:  fec42703           lw a4,-20(s0)
    1dc8:  fc840793           addi a5,s0,-56
    1dcc:  863a                 mv a2,a4
    1dce:  fe043583           ld a1,-32(s0)
    1dd2:  853e                 mv a0,a5
    1dd4:  166080ef           jal ra,9f3a <FUN_00009f3a>
    1dd8:  fc842783           lw a5,-56(s0)
    1ddc:  873e                 mv a4,a5
    1dde:  4785                 li a5,1
    1de0:  00f71963           bne a4,a5,1df2 <FUN_00001cb4+0x13e>
    1de4:  fcc42703           lw a4,-52(s0)
    1de8:  fa843783           ld a5,-88(s0)
    1dec:  3ce7ac23           sw a4,984(a5)
    1df0:  a029                 j 1dfa <FUN_00001cb4+0x146>
    1df2:  fa843783           ld a5,-88(s0)
    1df6:  3c07ac23           sw zero,984(a5)
    1dfa:  fe043703           ld a4,-32(s0)
    1dfe:  fb843783           ld a5,-72(s0)
    1e02:  40f707b3           sub a5,a4,a5
    1e06:  2781                 sext.w a5,a5
    1e08:  853e                 mv a0,a5
    1e0a:  60e6                 ld ra,88(sp)
    1e0c:  6446                 ld s0,80(sp)
    1e0e:  6125                 addi sp,sp,96
    1e10:  8082                 ret
0000000000001e12 <FUN_00001e12>:
    1e12:  7139                 addi sp,sp,-64
    1e14:  fc06                 sd ra,56(sp)
    1e16:  f822                 sd s0,48(sp)
    1e18:  0080                 addi s0,sp,64
    1e1a:  fca43c23           sd a0,-40(s0)
    1e1e:  87ae                 mv a5,a1
    1e20:  fcc43423           sd a2,-56(s0)
    1e24:  fcf42a23           sw a5,-44(s0)
    1e28:  fd843783           ld a5,-40(s0)
    1e2c:  fef43423           sd a5,-24(s0)
    1e30:  fe042223           sw zero,-28(s0)
    1e34:  fe042023           sw zero,-32(s0)
    1e38:  fe040693           addi a3,s0,-32
    1e3c:  fe040793           addi a5,s0,-32
    1e40:  4701                 li a4,0
    1e42:  863e                 mv a2,a5
    1e44:  4581                 li a1,0
    1e46:  fe843503           ld a0,-24(s0)
    1e4a:  929ff0ef           jal ra,1772 <FUN_00001772>
    1e4e:  87aa                 mv a5,a0
    1e50:  2781                 sext.w a5,a5
    1e52:  fef42223           sw a5,-28(s0)
    1e56:  fe442783           lw a5,-28(s0)
    1e5a:  1782                 slli a5,a5,0x20
    1e5c:  9381                 srli a5,a5,0x20
    1e5e:  fe843703           ld a4,-24(s0)
    1e62:  97ba                 add a5,a5,a4
    1e64:  fef43423           sd a5,-24(s0)
    1e68:  fe843783           ld a5,-24(s0)
    1e6c:  0785                 addi a5,a5,1
    1e6e:  fef43423           sd a5,-24(s0)
    1e72:  fe843783           ld a5,-24(s0)
    1e76:  0007c783           lbu a5,0(a5)
    1e7a:  873e                 mv a4,a5
    1e7c:  03000793           li a5,48
    1e80:  00f70463           beq a4,a5,1e88 <FUN_00001e12+0x76>
    1e84:  57fd                 li a5,-1
    1e86:  a849                 j 1f18 <FUN_00001e12+0x106>
    1e88:  fc843783           ld a5,-56(s0)
    1e8c:  3dc78713           addi a4,a5,988
    1e90:  fe843783           ld a5,-24(s0)
    1e94:  00278693           addi a3,a5,2
    1e98:  fe843783           ld a5,-24(s0)
    1e9c:  0785                 addi a5,a5,1
    1e9e:  0007c783           lbu a5,0(a5)
    1ea2:  2781                 sext.w a5,a5
    1ea4:  863e                 mv a2,a5
    1ea6:  85b6                 mv a1,a3
    1ea8:  853a                 mv a0,a4
    1eaa:  090080ef           jal ra,9f3a <FUN_00009f3a>
    1eae:  fe843783           ld a5,-24(s0)
    1eb2:  0785                 addi a5,a5,1
    1eb4:  0007c783           lbu a5,0(a5)
    1eb8:  873e                 mv a4,a5
    1eba:  fe843783           ld a5,-24(s0)
    1ebe:  97ba                 add a5,a5,a4
    1ec0:  fef43423           sd a5,-24(s0)
    1ec4:  fe843783           ld a5,-24(s0)
    1ec8:  0789                 addi a5,a5,2
    1eca:  fef43423           sd a5,-24(s0)
    1ece:  fe843783           ld a5,-24(s0)
    1ed2:  0007c783           lbu a5,0(a5)
    1ed6:  873e                 mv a4,a5
    1ed8:  478d                 li a5,3
    1eda:  00f70463           beq a4,a5,1ee2 <FUN_00001e12+0xd0>
    1ede:  57fd                 li a5,-1
    1ee0:  a825                 j 1f18 <FUN_00001e12+0x106>
    1ee2:  fc843783           ld a5,-56(s0)
    1ee6:  3ec78593           addi a1,a5,1004
    1eea:  fc843783           ld a5,-56(s0)
    1eee:  57c78793           addi a5,a5,1404
    1ef2:  fe440693           addi a3,s0,-28
    1ef6:  19000713           li a4,400
    1efa:  863e                 mv a2,a5
    1efc:  fe843503           ld a0,-24(s0)
    1f00:  873ff0ef           jal ra,1772 <FUN_00001772>
    1f04:  fe442783           lw a5,-28(s0)
    1f08:  1782                 slli a5,a5,0x20
    1f0a:  9381                 srli a5,a5,0x20
    1f0c:  fe843703           ld a4,-24(s0)
    1f10:  97ba                 add a5,a5,a4
    1f12:  fef43423           sd a5,-24(s0)
    1f16:  4781                 li a5,0
    1f18:  853e                 mv a0,a5
    1f1a:  70e2                 ld ra,56(sp)
    1f1c:  7442                 ld s0,48(sp)
    1f1e:  6121                 addi sp,sp,64
    1f20:  8082                 ret
0000000000001f22 <FUN_00001f22>:
    1f22:  7119                 addi sp,sp,-128
    1f24:  fc86                 sd ra,120(sp)
    1f26:  f8a2                 sd s0,112(sp)
    1f28:  0100                 addi s0,sp,128
    1f2a:  f8a43c23           sd a0,-104(s0)
    1f2e:  f8b43823           sd a1,-112(s0)
    1f32:  87b2                 mv a5,a2
    1f34:  f8f42623           sw a5,-116(s0)
    1f38:  fe042623           sw zero,-20(s0)
    1f3c:  fe043023           sd zero,-32(s0)
    1f40:  fc042e23           sw zero,-36(s0)
    1f44:  fc043823           sd zero,-48(s0)
    1f48:  fc042623           sw zero,-52(s0)
    1f4c:  fc043023           sd zero,-64(s0)
    1f50:  fa042e23           sw zero,-68(s0)
    1f54:  f9043783           ld a5,-112(s0)
    1f58:  faf43823           sd a5,-80(s0)
    1f5c:  fa042623           sw zero,-84(s0)
    1f60:  fb043783           ld a5,-80(s0)
    1f64:  0789                 addi a5,a5,2
    1f66:  0007c783           lbu a5,0(a5)
    1f6a:  2781                 sext.w a5,a5
    1f6c:  0087979b           slliw a5,a5,0x8
    1f70:  0007871b           sext.w a4,a5
    1f74:  fb043783           ld a5,-80(s0)
    1f78:  078d                 addi a5,a5,3
    1f7a:  0007c783           lbu a5,0(a5)
    1f7e:  2781                 sext.w a5,a5
    1f80:  8fd9                 or a5,a5,a4
    1f82:  2781                 sext.w a5,a5
    1f84:  fef42623           sw a5,-20(s0)
    1f88:  fb043783           ld a5,-80(s0)
    1f8c:  0791                 addi a5,a5,4
    1f8e:  faf43823           sd a5,-80(s0)
    1f92:  fb043783           ld a5,-80(s0)
    1f96:  0789                 addi a5,a5,2
    1f98:  0007c783           lbu a5,0(a5)
    1f9c:  2781                 sext.w a5,a5
    1f9e:  0087979b           slliw a5,a5,0x8
    1fa2:  0007871b           sext.w a4,a5
    1fa6:  fb043783           ld a5,-80(s0)
    1faa:  078d                 addi a5,a5,3
    1fac:  0007c783           lbu a5,0(a5)
    1fb0:  2781                 sext.w a5,a5
    1fb2:  8fd9                 or a5,a5,a4
    1fb4:  2781                 sext.w a5,a5
    1fb6:  fcf42e23           sw a5,-36(s0)
    1fba:  fb043783           ld a5,-80(s0)
    1fbe:  0007871b           sext.w a4,a5
    1fc2:  f9843783           ld a5,-104(s0)
    1fc6:  58e7a023           sw a4,1408(a5)
    1fca:  f9843783           ld a5,-104(s0)
    1fce:  fdc42703           lw a4,-36(s0)
    1fd2:  58e7a223           sw a4,1412(a5)
    1fd6:  fb043783           ld a5,-80(s0)
    1fda:  0791                 addi a5,a5,4
    1fdc:  faf43823           sd a5,-80(s0)
    1fe0:  fb043783           ld a5,-80(s0)
    1fe4:  fef43023           sd a5,-32(s0)
    1fe8:  fdc46783           lwu a5,-36(s0)
    1fec:  fb043703           ld a4,-80(s0)
    1ff0:  97ba                 add a5,a5,a4
    1ff2:  faf43823           sd a5,-80(s0)
    1ff6:  fb043783           ld a5,-80(s0)
    1ffa:  0007c783           lbu a5,0(a5)
    1ffe:  873e                 mv a4,a5
    2000:  478d                 li a5,3
    2002:  00f70463           beq a4,a5,200a <FUN_00001f22+0xe8>
    2006:  57fd                 li a5,-1
    2008:  a871                 j 20a4 <FUN_00001f22+0x182>
    200a:  fec42703           lw a4,-20(s0)
    200e:  fdc42783           lw a5,-36(s0)
    2012:  40f707bb           subw a5,a4,a5
    2016:  2781                 sext.w a5,a5
    2018:  37f1                 addiw a5,a5,-4
    201a:  faf42e23           sw a5,-68(s0)
    201e:  fb043783           ld a5,-80(s0)
    2022:  fcf43023           sd a5,-64(s0)
    2026:  fdc42783           lw a5,-36(s0)
    202a:  f9843603           ld a2,-104(s0)
    202e:  85be                 mv a1,a5
    2030:  fe043503           ld a0,-32(s0)
    2034:  96bff0ef           jal ra,199e <FUN_0000199e>
    2038:  87aa                 mv a5,a0
    203a:  faf42623           sw a5,-84(s0)
    203e:  fac42783           lw a5,-84(s0)
    2042:  fe043703           ld a4,-32(s0)
    2046:  97ba                 add a5,a5,a4
    2048:  fcf43823           sd a5,-48(s0)
    204c:  fac42783           lw a5,-84(s0)
    2050:  fdc42703           lw a4,-36(s0)
    2054:  40f707bb           subw a5,a4,a5
    2058:  fcf42623           sw a5,-52(s0)
    205c:  7a5050ef           jal ra,8000 <brom_config_bit_10>
    2060:  87aa                 mv a5,a0
    2062:  873e                 mv a4,a5
    2064:  4785                 li a5,1
    2066:  00f71c63           bne a4,a5,207e <FUN_00001f22+0x15c>
    206a:  fcc42783           lw a5,-52(s0)
    206e:  f9843603           ld a2,-104(s0)
    2072:  85be                 mv a1,a5
    2074:  fd043503           ld a0,-48(s0)
    2078:  bc7ff0ef           jal ra,1c3e <FUN_00001c3e>
    207c:  a811                 j 2090 <FUN_00001f22+0x16e>
    207e:  fcc42783           lw a5,-52(s0)
    2082:  f9843603           ld a2,-104(s0)
    2086:  85be                 mv a1,a5
    2088:  fd043503           ld a0,-48(s0)
    208c:  c29ff0ef           jal ra,1cb4 <FUN_00001cb4>
    2090:  fbc42783           lw a5,-68(s0)
    2094:  f9843603           ld a2,-104(s0)
    2098:  85be                 mv a1,a5
    209a:  fc043503           ld a0,-64(s0)
    209e:  d75ff0ef           jal ra,1e12 <FUN_00001e12>
    20a2:  4781                 li a5,0
    20a4:  853e                 mv a0,a5
    20a6:  70e6                 ld ra,120(sp)
    20a8:  7446                 ld s0,112(sp)
    20aa:  6109                 addi sp,sp,128
    20ac:  8082                 ret
00000000000020ae <FUN_000020ae>:
    20ae:  7139                 addi sp,sp,-64
    20b0:  fc06                 sd ra,56(sp)
    20b2:  f822                 sd s0,48(sp)
    20b4:  0080                 addi s0,sp,64
    20b6:  fca43c23           sd a0,-40(s0)
    20ba:  87ae                 mv a5,a1
    20bc:  fcc43423           sd a2,-56(s0)
    20c0:  fcf42a23           sw a5,-44(s0)
    20c4:  fe042623           sw zero,-20(s0)
    20c8:  5a000613           li a2,1440
    20cc:  4581                 li a1,0
    20ce:  fc843503           ld a0,-56(s0)
    20d2:  795070ef           jal ra,a066 <memset>
    20d6:  fc843783           ld a5,-56(s0)
    20da:  fd843703           ld a4,-40(s0)
    20de:  e798                 sd a4,8(a5)
    20e0:  fc843783           ld a5,-56(s0)
    20e4:  fd442703           lw a4,-44(s0)
    20e8:  cb98                 sw a4,16(a5)
    20ea:  fc843783           ld a5,-56(s0)
    20ee:  01478713           addi a4,a5,20
    20f2:  fc843783           ld a5,-56(s0)
    20f6:  6794                 ld a3,8(a5)
    20f8:  fc843783           ld a5,-56(s0)
    20fc:  4b9c                 lw a5,16(a5)
    20fe:  863e                 mv a2,a5
    2100:  85b6                 mv a1,a3
    2102:  853a                 mv a0,a4
    2104:  e1fff0ef           jal ra,1f22 <FUN_00001f22>
    2108:  87aa                 mv a5,a0
    210a:  fef42623           sw a5,-20(s0)
    210e:  fc843783           ld a5,-56(s0)
    2112:  4705                 li a4,1
    2114:  c398                 sw a4,0(a5)
    2116:  fec42783           lw a5,-20(s0)
    211a:  853e                 mv a0,a5
    211c:  70e2                 ld ra,56(sp)
    211e:  7442                 ld s0,48(sp)
    2120:  6121                 addi sp,sp,64
    2122:  8082                 ret
0000000000002124 <FUN_00002124>:
    2124:  1101                 addi sp,sp,-32
    2126:  ec06                 sd ra,24(sp)
    2128:  e822                 sd s0,16(sp)
    212a:  1000                 addi s0,sp,32
    212c:  fea43423           sd a0,-24(s0)
    2130:  fe843783           ld a5,-24(s0)
    2134:  0007a023           sw zero,0(a5)
    2138:  5a000613           li a2,1440
    213c:  4581                 li a1,0
    213e:  fe843503           ld a0,-24(s0)
    2142:  725070ef           jal ra,a066 <memset>
    2146:  4781                 li a5,0
    2148:  853e                 mv a0,a5
    214a:  60e2                 ld ra,24(sp)
    214c:  6442                 ld s0,16(sp)
    214e:  6105                 addi sp,sp,32
    2150:  8082                 ret
0000000000002152 <FUN_00002152>:
    2152:  7139                 addi sp,sp,-64
    2154:  fc06                 sd ra,56(sp)
    2156:  f822                 sd s0,48(sp)
    2158:  0080                 addi s0,sp,64
    215a:  fca43c23           sd a0,-40(s0)
    215e:  fcb43823           sd a1,-48(s0)
    2162:  87b2                 mv a5,a2
    2164:  fcf42623           sw a5,-52(s0)
    2168:  08000793           li a5,128
    216c:  fef42623           sw a5,-20(s0)
    2170:  fcc42703           lw a4,-52(s0)
    2174:  fec42783           lw a5,-20(s0)
    2178:  2701                 sext.w a4,a4
    217a:  2781                 sext.w a5,a5
    217c:  00f77463           bgeu a4,a5,2184 <FUN_00002152+0x32>
    2180:  57fd                 li a5,-1
    2182:  a831                 j 219e <FUN_00002152+0x4c>
    2184:  fd843783           ld a5,-40(s0)
    2188:  36c78793           addi a5,a5,876
    218c:  fec42703           lw a4,-20(s0)
    2190:  863a                 mv a2,a4
    2192:  85be                 mv a1,a5
    2194:  fd043503           ld a0,-48(s0)
    2198:  5a3070ef           jal ra,9f3a <FUN_00009f3a>
    219c:  4781                 li a5,0
    219e:  853e                 mv a0,a5
    21a0:  70e2                 ld ra,56(sp)
    21a2:  7442                 ld s0,48(sp)
    21a4:  6121                 addi sp,sp,64
    21a6:  8082                 ret
00000000000021a8 <ALIGN>:
    21a8:  7179                 addi sp,sp,-48
    21aa:  f422                 sd s0,40(sp)
    21ac:  1800                 addi s0,sp,48
    21ae:  fca43c23           sd a0,-40(s0)
    21b2:  87ae                 mv a5,a1
    21b4:  fcf42a23           sw a5,-44(s0)
    21b8:  fe043423           sd zero,-24(s0)
    21bc:  fd442783           lw a5,-44(s0)
    21c0:  37fd                 addiw a5,a5,-1
    21c2:  2781                 sext.w a5,a5
    21c4:  02079713           slli a4,a5,0x20
    21c8:  9301                 srli a4,a4,0x20
    21ca:  fd843783           ld a5,-40(s0)
    21ce:  973e                 add a4,a4,a5
    21d0:  fd442783           lw a5,-44(s0)
    21d4:  40f007bb           negw a5,a5
    21d8:  2781                 sext.w a5,a5
    21da:  1782                 slli a5,a5,0x20
    21dc:  9381                 srli a5,a5,0x20
    21de:  8ff9                 and a5,a5,a4
    21e0:  fef43423           sd a5,-24(s0)
    21e4:  fe843783           ld a5,-24(s0)
    21e8:  853e                 mv a0,a5
    21ea:  7422                 ld s0,40(sp)
    21ec:  6145                 addi sp,sp,48
    21ee:  8082                 ret
00000000000021f0 <FUN_000021f0>:
    21f0:  7179                 addi sp,sp,-48
    21f2:  f422                 sd s0,40(sp)
    21f4:  1800                 addi s0,sp,48
    21f6:  fca43c23           sd a0,-40(s0)
    21fa:  87ae                 mv a5,a1
    21fc:  fcf42a23           sw a5,-44(s0)
    2200:  fe042623           sw zero,-20(s0)
    2204:  fd843783           ld a5,-40(s0)
    2208:  439c                 lw a5,0(a5)
    220a:  fef42423           sw a5,-24(s0)
    220e:  4785                 li a5,1
    2210:  fef42623           sw a5,-20(s0)
    2214:  a02d                 j 223e <FUN_000021f0+0x4e>
    2216:  fec42783           lw a5,-20(s0)
    221a:  078a                 slli a5,a5,0x2
    221c:  fd843703           ld a4,-40(s0)
    2220:  97ba                 add a5,a5,a4
    2222:  4398                 lw a4,0(a5)
    2224:  fe842783           lw a5,-24(s0)
    2228:  2781                 sext.w a5,a5
    222a:  00e79863           bne a5,a4,223a <FUN_000021f0+0x4a>
    222e:  fec42783           lw a5,-20(s0)
    2232:  2785                 addiw a5,a5,1
    2234:  fef42623           sw a5,-20(s0)
    2238:  a019                 j 223e <FUN_000021f0+0x4e>
    223a:  4785                 li a5,1
    223c:  a809                 j 224e <FUN_000021f0+0x5e>
    223e:  fec42703           lw a4,-20(s0)
    2242:  fd442783           lw a5,-44(s0)
    2246:  2781                 sext.w a5,a5
    2248:  fcf767e3           bltu a4,a5,2216 <FUN_000021f0+0x26>
    224c:  4781                 li a5,0
    224e:  853e                 mv a0,a5
    2250:  7422                 ld s0,40(sp)
    2252:  6145                 addi sp,sp,48
    2254:  8082                 ret
0000000000002256 <FUN_00002256>:
    2256:  c7010113           addi sp,sp,-912
    225a:  38113423           sd ra,904(sp)
    225e:  38813023           sd s0,896(sp)
    2262:  0f00                 addi s0,sp,912
    2264:  c8a43423           sd a0,-888(s0)
    2268:  c8b43023           sd a1,-896(s0)
    226c:  87b2                 mv a5,a2
    226e:  8736                 mv a4,a3
    2270:  c6f42e23           sw a5,-900(s0)
    2274:  87ba                 mv a5,a4
    2276:  c6f42c23           sw a5,-904(s0)
    227a:  fe042623           sw zero,-20(s0)
    227e:  fe043023           sd zero,-32(s0)
    2282:  c8843783           ld a5,-888(s0)
    2286:  1d47a783           lw a5,468(a5)
    228a:  fcf42e23           sw a5,-36(s0)
    228e:  fc042c23           sw zero,-40(s0)
    2292:  c7c42783           lw a5,-900(s0)
    2296:  0007871b           sext.w a4,a5
    229a:  47fd                 li a5,31
    229c:  00e7f563           bgeu a5,a4,22a6 <FUN_00002256+0x50>
    22a0:  c8043783           ld a5,-896(s0)
    22a4:  e399                 bnez a5,22aa <FUN_00002256+0x54>
    22a6:  57fd                 li a5,-1
    22a8:  a0dd                 j 238e <FUN_00002256+0x138>
    22aa:  c9840793           addi a5,s0,-872
    22ae:  02000593           li a1,32
    22b2:  853e                 mv a0,a5
    22b4:  ef5ff0ef           jal ra,21a8 <ALIGN>
    22b8:  87aa                 mv a5,a0
    22ba:  fef43023           sd a5,-32(s0)
    22be:  c8843783           ld a5,-888(s0)
    22c2:  04178713           addi a4,a5,65
    22c6:  c8843783           ld a5,-888(s0)
    22ca:  1d47a783           lw a5,468(a5)
    22ce:  863e                 mv a2,a5
    22d0:  85ba                 mv a1,a4
    22d2:  fe043503           ld a0,-32(s0)
    22d6:  465070ef           jal ra,9f3a <FUN_00009f3a>
    22da:  fdc46703           lwu a4,-36(s0)
    22de:  fe043783           ld a5,-32(s0)
    22e2:  97ba                 add a5,a5,a4
    22e4:  86be                 mv a3,a5
    22e6:  c8843783           ld a5,-888(s0)
    22ea:  1d878713           addi a4,a5,472
    22ee:  c8843783           ld a5,-888(s0)
    22f2:  3687a783           lw a5,872(a5)
    22f6:  863e                 mv a2,a5
    22f8:  85ba                 mv a1,a4
    22fa:  8536                 mv a0,a3
    22fc:  43f070ef           jal ra,9f3a <FUN_00009f3a>
    2300:  c8843783           ld a5,-888(s0)
    2304:  3687a783           lw a5,872(a5)
    2308:  fdc42703           lw a4,-36(s0)
    230c:  9fb9                 addw a5,a5,a4
    230e:  2781                 sext.w a5,a5
    2310:  fcf42c23           sw a5,-40(s0)
    2314:  fdc42783           lw a5,-36(s0)
    2318:  0017979b           slliw a5,a5,0x1
    231c:  0007871b           sext.w a4,a5
    2320:  fd842783           lw a5,-40(s0)
    2324:  00f77463           bgeu a4,a5,232c <FUN_00002256+0xd6>
    2328:  57fd                 li a5,-1
    232a:  a095                 j 238e <FUN_00002256+0x138>
    232c:  fd842703           lw a4,-40(s0)
    2330:  fe043783           ld a5,-32(s0)
    2334:  97ba                 add a5,a5,a4
    2336:  86be                 mv a3,a5
    2338:  fdc42783           lw a5,-36(s0)
    233c:  0017979b           slliw a5,a5,0x1
    2340:  0007871b           sext.w a4,a5
    2344:  fd842783           lw a5,-40(s0)
    2348:  40f707bb           subw a5,a4,a5
    234c:  2781                 sext.w a5,a5
    234e:  863e                 mv a2,a5
    2350:  09100593           li a1,145
    2354:  8536                 mv a0,a3
    2356:  511070ef           jal ra,a066 <memset>
    235a:  fdc42783           lw a5,-36(s0)
    235e:  0017979b           slliw a5,a5,0x1
    2362:  2781                 sext.w a5,a5
    2364:  c7c42703           lw a4,-900(s0)
    2368:  c8043683           ld a3,-896(s0)
    236c:  863e                 mv a2,a5
    236e:  fe043583           ld a1,-32(s0)
    2372:  4505                 li a0,1
    2374:  95bfe0ef           jal ra,cce <sunxi_sha_calc>
    2378:  87aa                 mv a5,a0
    237a:  fef42623           sw a5,-20(s0)
    237e:  fec42783           lw a5,-20(s0)
    2382:  2781                 sext.w a5,a5
    2384:  0007d463           bgez a5,238c <FUN_00002256+0x136>
    2388:  57fd                 li a5,-1
    238a:  a011                 j 238e <FUN_00002256+0x138>
    238c:  4781                 li a5,0
    238e:  853e                 mv a0,a5
    2390:  38813083           ld ra,904(sp)
    2394:  38013403           ld s0,896(sp)
    2398:  39010113           addi sp,sp,912
    239c:  8082                 ret
000000000000239e <FUN_0000239e>:
    239e:  711d                 addi sp,sp,-96
    23a0:  ec86                 sd ra,88(sp)
    23a2:  e8a2                 sd s0,80(sp)
    23a4:  1080                 addi s0,sp,96
    23a6:  faa43423           sd a0,-88(s0)
    23aa:  87ae                 mv a5,a1
    23ac:  faf42223           sw a5,-92(s0)
    23b0:  fbc40793           addi a5,s0,-68
    23b4:  fef43423           sd a5,-24(s0)
    23b8:  fc040793           addi a5,s0,-64
    23bc:  853e                 mv a0,a5
    23be:  e8dfe0ef           jal ra,124a <FUN_0000124a>
    23c2:  fc044783           lbu a5,-64(s0)
    23c6:  873e                 mv a4,a5
    23c8:  47f5                 li a5,29
    23ca:  02f777bb           remuw a5,a4,a5
    23ce:  0ff7f793           andi a5,a5,255
    23d2:  873e                 mv a4,a5
    23d4:  fc040793           addi a5,s0,-64
    23d8:  97ba                 add a5,a5,a4
    23da:  fef43023           sd a5,-32(s0)
    23de:  fe043783           ld a5,-32(s0)
    23e2:  0007c703           lbu a4,0(a5)
    23e6:  fe843783           ld a5,-24(s0)
    23ea:  00e78023           sb a4,0(a5)
    23ee:  fe843783           ld a5,-24(s0)
    23f2:  0785                 addi a5,a5,1
    23f4:  fe043703           ld a4,-32(s0)
    23f8:  00174703           lbu a4,1(a4)
    23fc:  00e78023           sb a4,0(a5)
    2400:  fe843783           ld a5,-24(s0)
    2404:  0789                 addi a5,a5,2
    2406:  fe043703           ld a4,-32(s0)
    240a:  00274703           lbu a4,2(a4)
    240e:  00e78023           sb a4,0(a5)
    2412:  fe843783           ld a5,-24(s0)
    2416:  078d                 addi a5,a5,3
    2418:  fe043703           ld a4,-32(s0)
    241c:  00374703           lbu a4,3(a4)
    2420:  00e78023           sb a4,0(a5)
    2424:  fbc42783           lw a5,-68(s0)
    2428:  873e                 mv a4,a5
    242a:  3e800793           li a5,1000
    242e:  02f777bb           remuw a5,a4,a5
    2432:  2781                 sext.w a5,a5
    2434:  3e87879b           addiw a5,a5,1000
    2438:  2781                 sext.w a5,a5
    243a:  faf42e23           sw a5,-68(s0)
    243e:  fbc42783           lw a5,-68(s0)
    2442:  1782                 slli a5,a5,0x20
    2444:  9381                 srli a5,a5,0x20
    2446:  853e                 mv a0,a5
    2448:  53d070ef           jal ra,a184 <udelay>
    244c:  fa442783           lw a5,-92(s0)
    2450:  85be                 mv a1,a5
    2452:  fa843503           ld a0,-88(s0)
    2456:  8b4ff0ef           jal ra,150a <FUN_0000150a>
    245a:  0001                 nop
    245c:  60e6                 ld ra,88(sp)
    245e:  6446                 ld s0,80(sp)
    2460:  6125                 addi sp,sp,96
    2462:  8082                 ret
0000000000002464 <FUN_00002464>:
    2464:  7159                 addi sp,sp,-112
    2466:  f486                 sd ra,104(sp)
    2468:  f0a2                 sd s0,96(sp)
    246a:  1880                 addi s0,sp,112
    246c:  f8a43c23           sd a0,-104(s0)
    2470:  02000793           li a5,32
    2474:  fef42423           sw a5,-24(s0)
    2478:  fe842783           lw a5,-24(s0)
    247c:  0027d79b           srliw a5,a5,0x2
    2480:  fef42223           sw a5,-28(s0)
    2484:  fe042623           sw zero,-20(s0)
    2488:  fc040793           addi a5,s0,-64
    248c:  02000613           li a2,32
    2490:  4581                 li a1,0
    2492:  853e                 mv a0,a5
    2494:  3d3070ef           jal ra,a066 <memset>
    2498:  fc040793           addi a5,s0,-64
    249c:  02000593           li a1,32
    24a0:  853e                 mv a0,a5
    24a2:  ef5fe0ef           jal ra,1396 <FUN_00001396>
    24a6:  fe442703           lw a4,-28(s0)
    24aa:  fc040793           addi a5,s0,-64
    24ae:  85ba                 mv a1,a4
    24b0:  853e                 mv a0,a5
    24b2:  d3fff0ef           jal ra,21f0 <FUN_000021f0>
    24b6:  87aa                 mv a5,a0
    24b8:  fef42623           sw a5,-20(s0)
    24bc:  fec42783           lw a5,-20(s0)
    24c0:  2781                 sext.w a5,a5
    24c2:  eba9                 bnez a5,2514 <FUN_00002464+0xb0>
    24c4:  3cd050ef           jal ra,8090 <brom_config_bit_12>
    24c8:  87aa                 mv a5,a0
    24ca:  cf85                 beqz a5,2502 <FUN_00002464+0x9e>
    24cc:  fc040793           addi a5,s0,-64
    24d0:  02000613           li a2,32
    24d4:  4581                 li a1,0
    24d6:  853e                 mv a0,a5
    24d8:  38f070ef           jal ra,a066 <memset>
    24dc:  fe442703           lw a4,-28(s0)
    24e0:  fc040793           addi a5,s0,-64
    24e4:  85ba                 mv a1,a4
    24e6:  853e                 mv a0,a5
    24e8:  eb7ff0ef           jal ra,239e <FUN_0000239e>
    24ec:  fe442703           lw a4,-28(s0)
    24f0:  fc040793           addi a5,s0,-64
    24f4:  85ba                 mv a1,a4
    24f6:  853e                 mv a0,a5
    24f8:  cf9ff0ef           jal ra,21f0 <FUN_000021f0>
    24fc:  87aa                 mv a5,a0
    24fe:  fef42623           sw a5,-20(s0)
    2502:  fec42783           lw a5,-20(s0)
    2506:  2781                 sext.w a5,a5
    2508:  e791                 bnez a5,2514 <FUN_00002464+0xb0>
    250a:  4525                 li a0,9
    250c:  cb1fd0ef           jal ra,1bc <FUN_000001bc>
    2510:  4789                 li a5,2
    2512:  a889                 j 2564 <FUN_00002464+0x100>
    2514:  fe842703           lw a4,-24(s0)
    2518:  fa040793           addi a5,s0,-96
    251c:  4681                 li a3,0
    251e:  863a                 mv a2,a4
    2520:  85be                 mv a1,a5
    2522:  f9843503           ld a0,-104(s0)
    2526:  d31ff0ef           jal ra,2256 <FUN_00002256>
    252a:  fe842683           lw a3,-24(s0)
    252e:  fc040713           addi a4,s0,-64
    2532:  fa040793           addi a5,s0,-96
    2536:  8636                 mv a2,a3
    2538:  85ba                 mv a1,a4
    253a:  853e                 mv a0,a5
    253c:  367070ef           jal ra,a0a2 <FUN_0000a0a2>
    2540:  87aa                 mv a5,a0
    2542:  fef42623           sw a5,-20(s0)
    2546:  fec42783           lw a5,-20(s0)
    254a:  2781                 sext.w a5,a5
    254c:  c781                 beqz a5,2554 <FUN_00002464+0xf0>
    254e:  4529                 li a0,10
    2550:  c6dfd0ef           jal ra,1bc <FUN_000001bc>
    2554:  fec42783           lw a5,-20(s0)
    2558:  2781                 sext.w a5,a5
    255a:  0017b793           seqz a5,a5
    255e:  0ff7f793           andi a5,a5,255
    2562:  2781                 sext.w a5,a5
    2564:  853e                 mv a0,a5
    2566:  70a6                 ld ra,104(sp)
    2568:  7406                 ld s0,96(sp)
    256a:  6165                 addi sp,sp,112
    256c:  8082                 ret
000000000000256e <FUN_0000256e>:
    256e:  81010113           addi sp,sp,-2032
    2572:  7e113423           sd ra,2024(sp)
    2576:  7e813023           sd s0,2016(sp)
    257a:  7f010413           addi s0,sp,2032
    257e:  b6010113           addi sp,sp,-1184
    2582:  77fd                 lui a5,0xfffff
    2584:  ff040713           addi a4,s0,-16
    2588:  97ba                 add a5,a5,a4
    258a:  38a7b423           sd a0,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    258e:  fe043423           sd zero,-24(s0)
    2592:  02000793           li a5,32
    2596:  fef42223           sw a5,-28(s0)
    259a:  fe042023           sw zero,-32(s0)
    259e:  77fd                 lui a5,0xfffff
    25a0:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    25a4:  ff040713           addi a4,s0,-16
    25a8:  973e                 add a4,a4,a5
    25aa:  6785                 lui a5,0x1
    25ac:  c2078613           addi a2,a5,-992 # c20 <FUN_00000bbe+0x62>
    25b0:  4581                 li a1,0
    25b2:  853a                 mv a0,a4
    25b4:  2b3070ef           jal ra,a066 <memset>
    25b8:  77fd                 lui a5,0xfffff
    25ba:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    25be:  ff040713           addi a4,s0,-16
    25c2:  97ba                 add a5,a5,a4
    25c4:  02000613           li a2,32
    25c8:  4581                 li a1,0
    25ca:  853e                 mv a0,a5
    25cc:  29b070ef           jal ra,a066 <memset>
    25d0:  77fd                 lui a5,0xfffff
    25d2:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    25d6:  ff040713           addi a4,s0,-16
    25da:  97ba                 add a5,a5,a4
    25dc:  02000613           li a2,32
    25e0:  4581                 li a1,0
    25e2:  853e                 mv a0,a5
    25e4:  283070ef           jal ra,a066 <memset>
    25e8:  77fd                 lui a5,0xfffff
    25ea:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    25ee:  ff040713           addi a4,s0,-16
    25f2:  97ba                 add a5,a5,a4
    25f4:  02000593           li a1,32
    25f8:  853e                 mv a0,a5
    25fa:  bafff0ef           jal ra,21a8 <ALIGN>
    25fe:  87aa                 mv a5,a0
    2600:  fef43423           sd a5,-24(s0)
    2604:  77fd                 lui a5,0xfffff
    2606:  ff040713           addi a4,s0,-16
    260a:  97ba                 add a5,a5,a4
    260c:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    2610:  5987a783           lw a5,1432(a5)
    2614:  873e                 mv a4,a5
    2616:  6785                 lui a5,0x1
    2618:  c0078793           addi a5,a5,-1024 # c00 <FUN_00000bbe+0x42>
    261c:  00f71463           bne a4,a5,2624 <FUN_0000256e+0xb6>
    2620:  4781                 li a5,0
    2622:  a231                 j 272e <FUN_0000256e+0x1c0>
    2624:  77fd                 lui a5,0xfffff
    2626:  ff040713           addi a4,s0,-16
    262a:  97ba                 add a5,a5,a4
    262c:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    2630:  5947a783           lw a5,1428(a5)
    2634:  1782                 slli a5,a5,0x20
    2636:  9381                 srli a5,a5,0x20
    2638:  873e                 mv a4,a5
    263a:  77fd                 lui a5,0xfffff
    263c:  ff040693           addi a3,s0,-16
    2640:  97b6                 add a5,a5,a3
    2642:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    2646:  5987a783           lw a5,1432(a5)
    264a:  863e                 mv a2,a5
    264c:  85ba                 mv a1,a4
    264e:  fe843503           ld a0,-24(s0)
    2652:  0e9070ef           jal ra,9f3a <FUN_00009f3a>
    2656:  77fd                 lui a5,0xfffff
    2658:  ff040713           addi a4,s0,-16
    265c:  97ba                 add a5,a5,a4
    265e:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    2662:  5987a603           lw a2,1432(a5)
    2666:  77fd                 lui a5,0xfffff
    2668:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    266c:  ff040713           addi a4,s0,-16
    2670:  97ba                 add a5,a5,a4
    2672:  02000713           li a4,32
    2676:  86be                 mv a3,a5
    2678:  fe843583           ld a1,-24(s0)
    267c:  4505                 li a0,1
    267e:  e50fe0ef           jal ra,cce <sunxi_sha_calc>
    2682:  77fd                 lui a5,0xfffff
    2684:  ff040713           addi a4,s0,-16
    2688:  97ba                 add a5,a5,a4
    268a:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    268e:  1d878593           addi a1,a5,472
    2692:  77fd                 lui a5,0xfffff
    2694:  ff040713           addi a4,s0,-16
    2698:  97ba                 add a5,a5,a4
    269a:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    269e:  3687a603           lw a2,872(a5)
    26a2:  77fd                 lui a5,0xfffff
    26a4:  ff040713           addi a4,s0,-16
    26a8:  97ba                 add a5,a5,a4
    26aa:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    26ae:  40078693           addi a3,a5,1024
    26b2:  77fd                 lui a5,0xfffff
    26b4:  ff040713           addi a4,s0,-16
    26b8:  97ba                 add a5,a5,a4
    26ba:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    26be:  5907a703           lw a4,1424(a5)
    26c2:  77fd                 lui a5,0xfffff
    26c4:  ff040513           addi a0,s0,-16
    26c8:  97aa                 add a5,a5,a0
    26ca:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    26ce:  04178813           addi a6,a5,65
    26d2:  fe442503           lw a0,-28(s0)
    26d6:  77fd                 lui a5,0xfffff
    26d8:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    26dc:  ff040893           addi a7,s0,-16
    26e0:  97c6                 add a5,a5,a7
    26e2:  88c2                 mv a7,a6
    26e4:  882a                 mv a6,a0
    26e6:  6505                 lui a0,0x1
    26e8:  80050513           addi a0,a0,-2048 # 800 <FUN_00000660+0x1a0>
    26ec:  841fe0ef           jal ra,f2c <FUN_00000f2c>
    26f0:  77fd                 lui a5,0xfffff
    26f2:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    26f6:  ff040713           addi a4,s0,-16
    26fa:  973e                 add a4,a4,a5
    26fc:  77fd                 lui a5,0xfffff
    26fe:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    2702:  ff040693           addi a3,s0,-16
    2706:  97b6                 add a5,a5,a3
    2708:  02000613           li a2,32
    270c:  85ba                 mv a1,a4
    270e:  853e                 mv a0,a5
    2710:  193070ef           jal ra,a0a2 <FUN_0000a0a2>
    2714:  87aa                 mv a5,a0
    2716:  fef42023           sw a5,-32(s0)
    271a:  fe042783           lw a5,-32(s0)
    271e:  2781                 sext.w a5,a5
    2720:  c791                 beqz a5,272c <FUN_0000256e+0x1be>
    2722:  4545                 li a0,17
    2724:  a99fd0ef           jal ra,1bc <FUN_000001bc>
    2728:  4781                 li a5,0
    272a:  a011                 j 272e <FUN_0000256e+0x1c0>
    272c:  4785                 li a5,1
    272e:  853e                 mv a0,a5
    2730:  4a010113           addi sp,sp,1184
    2734:  7e813083           ld ra,2024(sp)
    2738:  7e013403           ld s0,2016(sp)
    273c:  7f010113           addi sp,sp,2032
    2740:  8082                 ret
0000000000002742 <FUN_00002742>:
    2742:  7179                 addi sp,sp,-48
    2744:  f406                 sd ra,40(sp)
    2746:  f022                 sd s0,32(sp)
    2748:  1800                 addi s0,sp,48
    274a:  fca43c23           sd a0,-40(s0)
    274e:  fe042623           sw zero,-20(s0)
    2752:  fe042423           sw zero,-24(s0)
    2756:  fd843503           ld a0,-40(s0)
    275a:  d0bff0ef           jal ra,2464 <FUN_00002464>
    275e:  87aa                 mv a5,a0
    2760:  fef42623           sw a5,-20(s0)
    2764:  fec42783           lw a5,-20(s0)
    2768:  2781                 sext.w a5,a5
    276a:  e399                 bnez a5,2770 <FUN_00002742+0x2e>
    276c:  4781                 li a5,0
    276e:  a01d                 j 2794 <FUN_00002742+0x52>
    2770:  fd843503           ld a0,-40(s0)
    2774:  dfbff0ef           jal ra,256e <FUN_0000256e>
    2778:  87aa                 mv a5,a0
    277a:  fef42423           sw a5,-24(s0)
    277e:  fec42783           lw a5,-20(s0)
    2782:  2781                 sext.w a5,a5
    2784:  c799                 beqz a5,2792 <FUN_00002742+0x50>
    2786:  fe842783           lw a5,-24(s0)
    278a:  2781                 sext.w a5,a5
    278c:  c399                 beqz a5,2792 <FUN_00002742+0x50>
    278e:  4785                 li a5,1
    2790:  a011                 j 2794 <FUN_00002742+0x52>
    2792:  4781                 li a5,0
    2794:  853e                 mv a0,a5
    2796:  70a2                 ld ra,40(sp)
    2798:  7402                 ld s0,32(sp)
    279a:  6145                 addi sp,sp,48
    279c:  8082                 ret
000000000000279e <FUN_0000279e>:
    279e:  714d                 addi sp,sp,-336
    27a0:  e686                 sd ra,328(sp)
    27a2:  e2a2                 sd s0,320(sp)
    27a4:  0a80                 addi s0,sp,336
    27a6:  eca43423           sd a0,-312(s0)
    27aa:  ecb43023           sd a1,-320(s0)
    27ae:  87b2                 mv a5,a2
    27b0:  eaf42e23           sw a5,-324(s0)
    27b4:  fe042623           sw zero,-20(s0)
    27b8:  ec043783           ld a5,-320(s0)
    27bc:  8bfd                 andi a5,a5,31
    27be:  c399                 beqz a5,27c4 <FUN_0000279e+0x26>
    27c0:  57fd                 li a5,-1
    27c2:  a895                 j 2836 <FUN_0000279e+0x98>
    27c4:  f6040793           addi a5,s0,-160
    27c8:  08800613           li a2,136
    27cc:  4581                 li a1,0
    27ce:  853e                 mv a0,a5
    27d0:  097070ef           jal ra,a066 <memset>
    27d4:  ed840793           addi a5,s0,-296
    27d8:  08800613           li a2,136
    27dc:  4581                 li a1,0
    27de:  853e                 mv a0,a5
    27e0:  087070ef           jal ra,a066 <memset>
    27e4:  f6040793           addi a5,s0,-160
    27e8:  08000613           li a2,128
    27ec:  85be                 mv a1,a5
    27ee:  ec843503           ld a0,-312(s0)
    27f2:  961ff0ef           jal ra,2152 <FUN_00002152>
    27f6:  ed840693           addi a3,s0,-296
    27fa:  ebc42783           lw a5,-324(s0)
    27fe:  08800713           li a4,136
    2802:  863e                 mv a2,a5
    2804:  ec043583           ld a1,-320(s0)
    2808:  4505                 li a0,1
    280a:  cc4fe0ef           jal ra,cce <sunxi_sha_calc>
    280e:  ed840713           addi a4,s0,-296
    2812:  f6040793           addi a5,s0,-160
    2816:  02000613           li a2,32
    281a:  85ba                 mv a1,a4
    281c:  853e                 mv a0,a5
    281e:  085070ef           jal ra,a0a2 <FUN_0000a0a2>
    2822:  87aa                 mv a5,a0
    2824:  fef42623           sw a5,-20(s0)
    2828:  fec42783           lw a5,-20(s0)
    282c:  2781                 sext.w a5,a5
    282e:  e399                 bnez a5,2834 <FUN_0000279e+0x96>
    2830:  4785                 li a5,1
    2832:  a011                 j 2836 <FUN_0000279e+0x98>
    2834:  4781                 li a5,0
    2836:  853e                 mv a0,a5
    2838:  60b6                 ld ra,328(sp)
    283a:  6416                 ld s0,320(sp)
    283c:  6171                 addi sp,sp,336
    283e:  8082                 ret
0000000000002840 <FUN_00002840>:
    2840:  1101                 addi sp,sp,-32
    2842:  ec06                 sd ra,24(sp)
    2844:  e822                 sd s0,16(sp)
    2846:  1000                 addi s0,sp,32
    2848:  fe042223           sw zero,-28(s0)
    284c:  4785                 li a5,1
    284e:  fef42023           sw a5,-32(s0)
    2852:  fe042783           lw a5,-32(s0)
    2856:  fef42623           sw a5,-20(s0)
    285a:  a885                 j 28ca <FUN_00002840+0x8a>
    285c:  fec42783           lw a5,-20(s0)
    2860:  0337879b           addiw a5,a5,51
    2864:  2781                 sext.w a5,a5
    2866:  0027979b           slliw a5,a5,0x2
    286a:  2781                 sext.w a5,a5
    286c:  853e                 mv a0,a5
    286e:  4f8050ef           jal ra,7d66 <sid_readl>
    2872:  87aa                 mv a5,a0
    2874:  fef42423           sw a5,-24(s0)
    2878:  fe842783           lw a5,-24(s0)
    287c:  2781                 sext.w a5,a5
    287e:  c3a9                 beqz a5,28c0 <FUN_00002840+0x80>
    2880:  a821                 j 2898 <FUN_00002840+0x58>
    2882:  fe442783           lw a5,-28(s0)
    2886:  2785                 addiw a5,a5,1
    2888:  fef42223           sw a5,-28(s0)
    288c:  fe842783           lw a5,-24(s0)
    2890:  0017d79b           srliw a5,a5,0x1
    2894:  fef42423           sw a5,-24(s0)
    2898:  fe842783           lw a5,-24(s0)
    289c:  2781                 sext.w a5,a5
    289e:  f3f5                 bnez a5,2882 <FUN_00002840+0x42>
    28a0:  fec42703           lw a4,-20(s0)
    28a4:  080007b7           lui a5,0x8000
    28a8:  37fd                 addiw a5,a5,-1
    28aa:  9fb9                 addw a5,a5,a4
    28ac:  2781                 sext.w a5,a5
    28ae:  0057979b           slliw a5,a5,0x5
    28b2:  2781                 sext.w a5,a5
    28b4:  fe442703           lw a4,-28(s0)
    28b8:  9fb9                 addw a5,a5,a4
    28ba:  fef42423           sw a5,-24(s0)
    28be:  a811                 j 28d2 <FUN_00002840+0x92>
    28c0:  fec42783           lw a5,-20(s0)
    28c4:  37fd                 addiw a5,a5,-1
    28c6:  fef42623           sw a5,-20(s0)
    28ca:  fec42783           lw a5,-20(s0)
    28ce:  2781                 sext.w a5,a5
    28d0:  f7d1                 bnez a5,285c <FUN_00002840+0x1c>
    28d2:  fe842783           lw a5,-24(s0)
    28d6:  853e                 mv a0,a5
    28d8:  60e2                 ld ra,24(sp)
    28da:  6442                 ld s0,16(sp)
    28dc:  6105                 addi sp,sp,32
    28de:  8082                 ret
00000000000028e0 <FUN_000028e0>:
    28e0:  7179                 addi sp,sp,-48
    28e2:  f406                 sd ra,40(sp)
    28e4:  f022                 sd s0,32(sp)
    28e6:  1800                 addi s0,sp,48
    28e8:  fca43c23           sd a0,-40(s0)
    28ec:  fe042623           sw zero,-20(s0)
    28f0:  fe042423           sw zero,-24(s0)
    28f4:  fd843783           ld a5,-40(s0)
    28f8:  e399                 bnez a5,28fe <FUN_000028e0+0x1e>
    28fa:  57fd                 li a5,-1
    28fc:  a0b1                 j 2948 <FUN_000028e0+0x68>
    28fe:  fd843783           ld a5,-40(s0)
    2902:  3ec7a783           lw a5,1004(a5) # 80003ec <gpio_get_boot_device+0x7ff2056
    2906:  fef42423           sw a5,-24(s0)
    290a:  fe842783           lw a5,-24(s0)
    290e:  0007871b           sext.w a4,a5
    2912:  47fd                 li a5,31
    2914:  00e7f763           bgeu a5,a4,2922 <FUN_000028e0+0x42>
    2918:  4549                 li a0,18
    291a:  8a3fd0ef           jal ra,1bc <FUN_000001bc>
    291e:  57fd                 li a5,-1
    2920:  a025                 j 2948 <FUN_000028e0+0x68>
    2922:  f1fff0ef           jal ra,2840 <FUN_00002840>
    2926:  87aa                 mv a5,a0
    2928:  fef42623           sw a5,-20(s0)
    292c:  fe842703           lw a4,-24(s0)
    2930:  fec42783           lw a5,-20(s0)
    2934:  2701                 sext.w a4,a4
    2936:  2781                 sext.w a5,a5
    2938:  00f76463           bltu a4,a5,2940 <FUN_000028e0+0x60>
    293c:  4781                 li a5,0
    293e:  a029                 j 2948 <FUN_000028e0+0x68>
    2940:  454d                 li a0,19
    2942:  87bfd0ef           jal ra,1bc <FUN_000001bc>
    2946:  57fd                 li a5,-1
    2948:  853e                 mv a0,a5
    294a:  70a2                 ld ra,40(sp)
    294c:  7402                 ld s0,32(sp)
    294e:  6145                 addi sp,sp,48
    2950:  8082                 ret
0000000000002952 <boot_verify_image>:
    2952:  9d010113           addi sp,sp,-1584
    2956:  62113423           sd ra,1576(sp)
    295a:  62813023           sd s0,1568(sp)
    295e:  63010413           addi s0,sp,1584
    2962:  9ca43c23           sd a0,-1576(s0)
    2966:  87ae                 mv a5,a1
    2968:  9cf42a23           sw a5,-1580(s0)
    296c:  fe042623           sw zero,-20(s0)
    2970:  fa043423           sd zero,-88(s0)
    2974:  fa042223           sw zero,-92(s0)
    2978:  fe042423           sw zero,-24(s0)
    297c:  4521                 li a0,8
    297e:  8edfd0ef           jal ra,26a <FUN_0000026a>
    2982:  4505                 li a0,1
    2984:  88bfd0ef           jal ra,20e <FUN_0000020e>
    2988:  fb040793           addi a5,s0,-80
    298c:  03800613           li a2,56
    2990:  4581                 li a1,0
    2992:  853e                 mv a0,a5
    2994:  6d2070ef           jal ra,a066 <memset>
    2998:  a0040793           addi a5,s0,-1536
    299c:  5a000613           li a2,1440
    29a0:  4581                 li a1,0
    29a2:  853e                 mv a0,a5
    29a4:  6c2070ef           jal ra,a066 <memset>
    29a8:  9e040793           addi a5,s0,-1568
    29ac:  02000613           li a2,32
    29b0:  4581                 li a1,0
    29b2:  853e                 mv a0,a5
    29b4:  6b2070ef           jal ra,a066 <memset>
    29b8:  4509                 li a0,2
    29ba:  855fd0ef           jal ra,20e <FUN_0000020e>
    29be:  fb040793           addi a5,s0,-80
    29c2:  85be                 mv a1,a5
    29c4:  9d843503           ld a0,-1576(s0)
    29c8:  8fffd0ef           jal ra,2c6 <FUN_000002c6>
    29cc:  87aa                 mv a5,a0
    29ce:  fef42623           sw a5,-20(s0)
    29d2:  fec42783           lw a5,-20(s0)
    29d6:  2781                 sext.w a5,a5
    29d8:  0007d663           bgez a5,29e4 <boot_verify_image+0x92>
    29dc:  4505                 li a0,1
    29de:  fdefd0ef           jal ra,1bc <FUN_000001bc>
    29e2:  aa95                 j 2b56 <boot_verify_image+0x204>
    29e4:  4515                 li a0,5
    29e6:  829fd0ef           jal ra,20e <FUN_0000020e>
    29ea:  9e040713           addi a4,s0,-1568
    29ee:  fa440693           addi a3,s0,-92
    29f2:  fa840793           addi a5,s0,-88
    29f6:  fb040513           addi a0,s0,-80
    29fa:  863e                 mv a2,a5
    29fc:  67c1                 lui a5,0x10
    29fe:  10178593           addi a1,a5,257 # 10101 <gpio_get_boot_device+0x1d6b>
    2a02:  94dfd0ef           jal ra,34e <FUN_0000034e>
    2a06:  87aa                 mv a5,a0
    2a08:  fef42623           sw a5,-20(s0)
    2a0c:  fec42783           lw a5,-20(s0)
    2a10:  2781                 sext.w a5,a5
    2a12:  0007d663           bgez a5,2a1e <boot_verify_image+0xcc>
    2a16:  450d                 li a0,3
    2a18:  fa4fd0ef           jal ra,1bc <FUN_000001bc>
    2a1c:  aa2d                 j 2b56 <boot_verify_image+0x204>
    2a1e:  4519                 li a0,6
    2a20:  feefd0ef           jal ra,20e <FUN_0000020e>
    2a24:  fa843783           ld a5,-88(s0)
    2a28:  fa442703           lw a4,-92(s0)
    2a2c:  a0040693           addi a3,s0,-1536
    2a30:  8636                 mv a2,a3
    2a32:  85ba                 mv a1,a4
    2a34:  853e                 mv a0,a5
    2a36:  e78ff0ef           jal ra,20ae <FUN_000020ae>
    2a3a:  87aa                 mv a5,a0
    2a3c:  fef42623           sw a5,-20(s0)
    2a40:  fec42783           lw a5,-20(s0)
    2a44:  2781                 sext.w a5,a5
    2a46:  0007d663           bgez a5,2a52 <boot_verify_image+0x100>
    2a4a:  4511                 li a0,4
    2a4c:  f70fd0ef           jal ra,1bc <FUN_000001bc>
    2a50:  a219                 j 2b56 <boot_verify_image+0x204>
    2a52:  451d                 li a0,7
    2a54:  fbafd0ef           jal ra,20e <FUN_0000020e>
    2a58:  a0040793           addi a5,s0,-1536
    2a5c:  853e                 mv a0,a5
    2a5e:  ce5ff0ef           jal ra,2742 <FUN_00002742>
    2a62:  87aa                 mv a5,a0
    2a64:  fef42623           sw a5,-20(s0)
    2a68:  fec42783           lw a5,-20(s0)
    2a6c:  2781                 sext.w a5,a5
    2a6e:  0ef05163           blez a5,2b50 <boot_verify_image+0x1fe>
    2a72:  4521                 li a0,8
    2a74:  f9afd0ef           jal ra,20e <FUN_0000020e>
    2a78:  588050ef           jal ra,8000 <brom_config_bit_10>
    2a7c:  87aa                 mv a5,a0
    2a7e:  873e                 mv a4,a5
    2a80:  4785                 li a5,1
    2a82:  00f70f63           beq a4,a5,2aa0 <boot_verify_image+0x14e>
    2a86:  a0040793           addi a5,s0,-1536
    2a8a:  853e                 mv a0,a5
    2a8c:  e55ff0ef           jal ra,28e0 <FUN_000028e0>
    2a90:  87aa                 mv a5,a0
    2a92:  fef42623           sw a5,-20(s0)
    2a96:  fec42783           lw a5,-20(s0)
    2a9a:  2781                 sext.w a5,a5
    2a9c:  0a07cc63           bltz a5,2b54 <boot_verify_image+0x202>
    2aa0:  451d                 li a0,7
    2aa2:  f6cfd0ef           jal ra,20e <FUN_0000020e>
    2aa6:  9e040713           addi a4,s0,-1568
    2aaa:  fa440693           addi a3,s0,-92
    2aae:  fa840793           addi a5,s0,-88
    2ab2:  fb040513           addi a0,s0,-80
    2ab6:  863e                 mv a2,a5
    2ab8:  67c1                 lui a5,0x10
    2aba:  20278593           addi a1,a5,514 # 10202 <gpio_get_boot_device+0x1e6c>
    2abe:  891fd0ef           jal ra,34e <FUN_0000034e>
    2ac2:  87aa                 mv a5,a0
    2ac4:  fef42623           sw a5,-20(s0)
    2ac8:  fec42783           lw a5,-20(s0)
    2acc:  2781                 sext.w a5,a5
    2ace:  0007d663           bgez a5,2ada <boot_verify_image+0x188>
    2ad2:  4515                 li a0,5
    2ad4:  ee8fd0ef           jal ra,1bc <FUN_000001bc>
    2ad8:  a8bd                 j 2b56 <boot_verify_image+0x204>
    2ada:  4529                 li a0,10
    2adc:  f32fd0ef           jal ra,20e <FUN_0000020e>
    2ae0:  fa843703           ld a4,-88(s0)
    2ae4:  fa442683           lw a3,-92(s0)
    2ae8:  a0040793           addi a5,s0,-1536
    2aec:  8636                 mv a2,a3
    2aee:  85ba                 mv a1,a4
    2af0:  853e                 mv a0,a5
    2af2:  cadff0ef           jal ra,279e <FUN_0000279e>
    2af6:  87aa                 mv a5,a0
    2af8:  fef42623           sw a5,-20(s0)
    2afc:  fec42783           lw a5,-20(s0)
    2b00:  2781                 sext.w a5,a5
    2b02:  00f04663           bgtz a5,2b0e <boot_verify_image+0x1bc>
    2b06:  4551                 li a0,20
    2b08:  eb4fd0ef           jal ra,1bc <FUN_000001bc>
    2b0c:  a0a9                 j 2b56 <boot_verify_image+0x204>
    2b0e:  9e040713           addi a4,s0,-1568
    2b12:  fb040793           addi a5,s0,-80
    2b16:  85ba                 mv a1,a4
    2b18:  853e                 mv a0,a5
    2b1a:  965fd0ef           jal ra,47e <FUN_0000047e>
    2b1e:  452d                 li a0,11
    2b20:  eeefd0ef           jal ra,20e <FUN_0000020e>
    2b24:  9e040793           addi a5,s0,-1568
    2b28:  853e                 mv a0,a5
    2b2a:  a0dfd0ef           jal ra,536 <FUN_00000536>
    2b2e:  87aa                 mv a5,a0
    2b30:  fef42423           sw a5,-24(s0)
    2b34:  9d442783           lw a5,-1580(s0)
    2b38:  2781                 sext.w a5,a5
    2b3a:  cb89                 beqz a5,2b4c <boot_verify_image+0x1fa>
    2b3c:  fe842783           lw a5,-24(s0)
    2b40:  0fc00593           li a1,252
    2b44:  853e                 mv a0,a5
    2b46:  05e070ef           jal ra,9ba4 <boot_finish>
    2b4a:  a031                 j 2b56 <boot_verify_image+0x204>
    2b4c:  4785                 li a5,1
    2b4e:  a029                 j 2b58 <boot_verify_image+0x206>
    2b50:  0001                 nop
    2b52:  a011                 j 2b56 <boot_verify_image+0x204>
    2b54:  0001                 nop
    2b56:  4781                 li a5,0
    2b58:  853e                 mv a0,a5
    2b5a:  62813083           ld ra,1576(sp)
    2b5e:  62013403           ld s0,1568(sp)
    2b62:  63010113           addi sp,sp,1584
    2b66:  8082                 ret
0000000000002b68 <boot_from_sdc0>:
    2b68:  1101                 addi sp,sp,-32
    2b6a:  ec06                 sd ra,24(sp)
    2b6c:  e822                 sd s0,16(sp)
    2b6e:  1000                 addi s0,sp,32
    2b70:  fe042623           sw zero,-20(s0)
    2b74:  4b0050ef           jal ra,8024 <brom_config_bit_15>
    2b78:  87aa                 mv a5,a0
    2b7a:  e78d                 bnez a5,2ba4 <boot_from_sdc0+0x3c>
    2b7c:  4581                 li a1,0
    2b7e:  4505                 li a0,1
    2b80:  681060ef           jal ra,9a00 <debug_syscon>
    2b84:  4585                 li a1,1
    2b86:  4501                 li a0,0
    2b88:  6bc050ef           jal ra,8244 <debug_state_save>
    2b8c:  4501                 li a0,0
    2b8e:  31c010ef           jal ra,3eaa <boot_from_sd>
    2b92:  87aa                 mv a5,a0
    2b94:  fef42623           sw a5,-20(s0)
    2b98:  fec42783           lw a5,-20(s0)
    2b9c:  2781                 sext.w a5,a5
    2b9e:  eb89                 bnez a5,2bb0 <boot_from_sdc0+0x48>
    2ba0:  4781                 li a5,0
    2ba2:  a801                 j 2bb2 <boot_from_sdc0+0x4a>
    2ba4:  4581                 li a1,0
    2ba6:  4535                 li a0,13
    2ba8:  69c050ef           jal ra,8244 <debug_state_save>
    2bac:  71b060ef           jal ra,9ac6 <gpio_enable_jtag_pf>
    2bb0:  57fd                 li a5,-1
    2bb2:  853e                 mv a0,a5
    2bb4:  60e2                 ld ra,24(sp)
    2bb6:  6442                 ld s0,16(sp)
    2bb8:  6105                 addi sp,sp,32
    2bba:  8082                 ret
0000000000002bbc <boot_from_sdc2>:
    2bbc:  7179                 addi sp,sp,-48
    2bbe:  f406                 sd ra,40(sp)
    2bc0:  f022                 sd s0,32(sp)
    2bc2:  1800                 addi s0,sp,48
    2bc4:  87aa                 mv a5,a0
    2bc6:  fcf42e23           sw a5,-36(s0)
    2bca:  fe042623           sw zero,-20(s0)
    2bce:  fdc42783           lw a5,-36(s0)
    2bd2:  0007871b           sext.w a4,a5
    2bd6:  4789                 li a5,2
    2bd8:  04f71a63           bne a4,a5,2c2c <boot_from_sdc2+0x70>
    2bdc:  4581                 li a1,0
    2bde:  4509                 li a0,2
    2be0:  621060ef           jal ra,9a00 <debug_syscon>
    2be4:  4589                 li a1,2
    2be6:  4501                 li a0,0
    2be8:  65c050ef           jal ra,8244 <debug_state_save>
    2bec:  4509                 li a0,2
    2bee:  2bc010ef           jal ra,3eaa <boot_from_sd>
    2bf2:  87aa                 mv a5,a0
    2bf4:  fef42623           sw a5,-20(s0)
    2bf8:  fec42783           lw a5,-20(s0)
    2bfc:  2781                 sext.w a5,a5
    2bfe:  e399                 bnez a5,2c04 <boot_from_sdc2+0x48>
    2c00:  4781                 li a5,0
    2c02:  a8b5                 j 2c7e <boot_from_sdc2+0xc2>
    2c04:  4581                 li a1,0
    2c06:  450d                 li a0,3
    2c08:  5f9060ef           jal ra,9a00 <debug_syscon>
    2c0c:  458d                 li a1,3
    2c0e:  4501                 li a0,0
    2c10:  634050ef           jal ra,8244 <debug_state_save>
    2c14:  4509                 li a0,2
    2c16:  36c010ef           jal ra,3f82 <boot_from_emmc>
    2c1a:  87aa                 mv a5,a0
    2c1c:  fef42623           sw a5,-20(s0)
    2c20:  fec42783           lw a5,-20(s0)
    2c24:  2781                 sext.w a5,a5
    2c26:  ebb9                 bnez a5,2c7c <boot_from_sdc2+0xc0>
    2c28:  4781                 li a5,0
    2c2a:  a891                 j 2c7e <boot_from_sdc2+0xc2>
    2c2c:  4581                 li a1,0
    2c2e:  450d                 li a0,3
    2c30:  5d1060ef           jal ra,9a00 <debug_syscon>
    2c34:  458d                 li a1,3
    2c36:  4501                 li a0,0
    2c38:  60c050ef           jal ra,8244 <debug_state_save>
    2c3c:  4509                 li a0,2
    2c3e:  344010ef           jal ra,3f82 <boot_from_emmc>
    2c42:  87aa                 mv a5,a0
    2c44:  fef42623           sw a5,-20(s0)
    2c48:  fec42783           lw a5,-20(s0)
    2c4c:  2781                 sext.w a5,a5
    2c4e:  e399                 bnez a5,2c54 <boot_from_sdc2+0x98>
    2c50:  4781                 li a5,0
    2c52:  a035                 j 2c7e <boot_from_sdc2+0xc2>
    2c54:  4581                 li a1,0
    2c56:  4509                 li a0,2
    2c58:  5a9060ef           jal ra,9a00 <debug_syscon>
    2c5c:  4589                 li a1,2
    2c5e:  4501                 li a0,0
    2c60:  5e4050ef           jal ra,8244 <debug_state_save>
    2c64:  4509                 li a0,2
    2c66:  244010ef           jal ra,3eaa <boot_from_sd>
    2c6a:  87aa                 mv a5,a0
    2c6c:  fef42623           sw a5,-20(s0)
    2c70:  fec42783           lw a5,-20(s0)
    2c74:  2781                 sext.w a5,a5
    2c76:  e399                 bnez a5,2c7c <boot_from_sdc2+0xc0>
    2c78:  4781                 li a5,0
    2c7a:  a011                 j 2c7e <boot_from_sdc2+0xc2>
    2c7c:  57fd                 li a5,-1
    2c7e:  853e                 mv a0,a5
    2c80:  70a2                 ld ra,40(sp)
    2c82:  7402                 ld s0,32(sp)
    2c84:  6145                 addi sp,sp,48
    2c86:  8082                 ret
0000000000002c88 <FUN_00002c88>:
    2c88:  7179                 addi sp,sp,-48
    2c8a:  f406                 sd ra,40(sp)
    2c8c:  f022                 sd s0,32(sp)
    2c8e:  1800                 addi s0,sp,48
    2c90:  87aa                 mv a5,a0
    2c92:  fcf42e23           sw a5,-36(s0)
    2c96:  fe042623           sw zero,-20(s0)
    2c9a:  fdc42783           lw a5,-36(s0)
    2c9e:  0007871b           sext.w a4,a5
    2ca2:  478d                 li a5,3
    2ca4:  02f71663           bne a4,a5,2cd0 <FUN_00002c88+0x48>
    2ca8:  4581                 li a1,0
    2caa:  4515                 li a0,5
    2cac:  555060ef           jal ra,9a00 <debug_syscon>
    2cb0:  4595                 li a1,5
    2cb2:  4501                 li a0,0
    2cb4:  590050ef           jal ra,8244 <debug_state_save>
    2cb8:  4501                 li a0,0
    2cba:  062050ef           jal ra,7d1c <FUN_00007d1c>
    2cbe:  87aa                 mv a5,a0
    2cc0:  fef42623           sw a5,-20(s0)
    2cc4:  fec42783           lw a5,-20(s0)
    2cc8:  2781                 sext.w a5,a5
    2cca:  e399                 bnez a5,2cd0 <FUN_00002c88+0x48>
    2ccc:  4781                 li a5,0
    2cce:  a011                 j 2cd2 <FUN_00002c88+0x4a>
    2cd0:  57fd                 li a5,-1
    2cd2:  853e                 mv a0,a5
    2cd4:  70a2                 ld ra,40(sp)
    2cd6:  7402                 ld s0,32(sp)
    2cd8:  6145                 addi sp,sp,48
    2cda:  8082                 ret
0000000000002cdc <FUN_00002cdc>:
    2cdc:  7179                 addi sp,sp,-48
    2cde:  f406                 sd ra,40(sp)
    2ce0:  f022                 sd s0,32(sp)
    2ce2:  1800                 addi s0,sp,48
    2ce4:  87aa                 mv a5,a0
    2ce6:  872e                 mv a4,a1
    2ce8:  fcf42e23           sw a5,-36(s0)
    2cec:  87ba                 mv a5,a4
    2cee:  fcf42c23           sw a5,-40(s0)
    2cf2:  fe042623           sw zero,-20(s0)
    2cf6:  fdc42783           lw a5,-36(s0)
    2cfa:  0007871b           sext.w a4,a5
    2cfe:  4791                 li a5,4
    2d00:  02f71b63           bne a4,a5,2d36 <FUN_00002cdc+0x5a>
    2d04:  4581                 li a1,0
    2d06:  4519                 li a0,6
    2d08:  4f9060ef           jal ra,9a00 <debug_syscon>
    2d0c:  4599                 li a1,6
    2d0e:  4501                 li a0,0
    2d10:  534050ef           jal ra,8244 <debug_state_save>
    2d14:  fd842703           lw a4,-40(s0)
    2d18:  fdc42783           lw a5,-36(s0)
    2d1c:  85ba                 mv a1,a4
    2d1e:  853e                 mv a0,a5
    2d20:  7f4000ef           jal ra,3514 <FUN_00003514>
    2d24:  87aa                 mv a5,a0
    2d26:  fef42623           sw a5,-20(s0)
    2d2a:  fec42783           lw a5,-20(s0)
    2d2e:  2781                 sext.w a5,a5
    2d30:  e399                 bnez a5,2d36 <FUN_00002cdc+0x5a>
    2d32:  4781                 li a5,0
    2d34:  a011                 j 2d38 <FUN_00002cdc+0x5c>
    2d36:  57fd                 li a5,-1
    2d38:  853e                 mv a0,a5
    2d3a:  70a2                 ld ra,40(sp)
    2d3c:  7402                 ld s0,32(sp)
    2d3e:  6145                 addi sp,sp,48
    2d40:  8082                 ret
0000000000002d42 <try_boot_process>:
    2d42:  7179                 addi sp,sp,-48
    2d44:  f406                 sd ra,40(sp)
    2d46:  f022                 sd s0,32(sp)
    2d48:  1800                 addi s0,sp,48
    2d4a:  87aa                 mv a5,a0
    2d4c:  fcf42e23           sw a5,-36(s0)
    2d50:  fe042623           sw zero,-20(s0)
    2d54:  4581                 li a1,0
    2d56:  451d                 li a0,7
    2d58:  4ec050ef           jal ra,8244 <debug_state_save>
    2d5c:  fdc42783           lw a5,-36(s0)
    2d60:  0007871b           sext.w a4,a5
    2d64:  478d                 li a5,3
    2d66:  00f70c63           beq a4,a5,2d7e <try_boot_process+0x3c>
    2d6a:  450d                 li a0,3
    2d6c:  f1dff0ef           jal ra,2c88 <FUN_00002c88>
    2d70:  87aa                 mv a5,a0
    2d72:  fef42623           sw a5,-20(s0)
    2d76:  fec42783           lw a5,-20(s0)
    2d7a:  2781                 sext.w a5,a5
    2d7c:  cfb9                 beqz a5,2dda <try_boot_process+0x98>
    2d7e:  fdc42783           lw a5,-36(s0)
    2d82:  0007871b           sext.w a4,a5
    2d86:  4791                 li a5,4
    2d88:  02f70063           beq a4,a5,2da8 <try_boot_process+0x66>
    2d8c:  00eff7b7           lui a5,0xeff
    2d90:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    2d94:  4511                 li a0,4
    2d96:  f47ff0ef           jal ra,2cdc <FUN_00002cdc>
    2d9a:  87aa                 mv a5,a0
    2d9c:  fef42623           sw a5,-20(s0)
    2da0:  fec42783           lw a5,-20(s0)
    2da4:  2781                 sext.w a5,a5
    2da6:  cf85                 beqz a5,2dde <try_boot_process+0x9c>
    2da8:  fdc42783           lw a5,-36(s0)
    2dac:  0007871b           sext.w a4,a5
    2db0:  4789                 li a5,2
    2db2:  04f70963           beq a4,a5,2e04 <try_boot_process+0xc2>
    2db6:  fdc42783           lw a5,-36(s0)
    2dba:  0007871b           sext.w a4,a5
    2dbe:  4795                 li a5,5
    2dc0:  04f70263           beq a4,a5,2e04 <try_boot_process+0xc2>
    2dc4:  4509                 li a0,2
    2dc6:  df7ff0ef           jal ra,2bbc <boot_from_sdc2>
    2dca:  87aa                 mv a5,a0
    2dcc:  fef42623           sw a5,-20(s0)
    2dd0:  fec42783           lw a5,-20(s0)
    2dd4:  2781                 sext.w a5,a5
    2dd6:  e79d                 bnez a5,2e04 <try_boot_process+0xc2>
    2dd8:  a021                 j 2de0 <try_boot_process+0x9e>
    2dda:  0001                 nop
    2ddc:  a011                 j 2de0 <try_boot_process+0x9e>
    2dde:  0001                 nop
    2de0:  000487b7           lui a5,0x48
    2de4:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    2de8:  c799                 beqz a5,2df6 <try_boot_process+0xb4>
    2dea:  4585                 li a1,1
    2dec:  00020537           lui a0,0x20
    2df0:  b63ff0ef           jal ra,2952 <boot_verify_image>
    2df4:  a809                 j 2e06 <try_boot_process+0xc4>
    2df6:  0fc00593           li a1,252
    2dfa:  00020537           lui a0,0x20
    2dfe:  5a7060ef           jal ra,9ba4 <boot_finish>
    2e02:  a011                 j 2e06 <try_boot_process+0xc4>
    2e04:  0001                 nop
    2e06:  4501                 li a0,0
    2e08:  543060ef           jal ra,9b4a <fel_boot>
    2e0c:  0001                 nop
    2e0e:  70a2                 ld ra,40(sp)
    2e10:  7402                 ld s0,32(sp)
    2e12:  6145                 addi sp,sp,48
    2e14:  8082                 ret
0000000000002e16 <sid_boot_process>:
    2e16:  7179                 addi sp,sp,-48
    2e18:  f406                 sd ra,40(sp)
    2e1a:  f022                 sd s0,32(sp)
    2e1c:  1800                 addi s0,sp,48
    2e1e:  87aa                 mv a5,a0
    2e20:  fcf42e23           sw a5,-36(s0)
    2e24:  fe042623           sw zero,-20(s0)
    2e28:  4581                 li a1,0
    2e2a:  4519                 li a0,6
    2e2c:  418050ef           jal ra,8244 <debug_state_save>
    2e30:  d39ff0ef           jal ra,2b68 <boot_from_sdc0>
    2e34:  87aa                 mv a5,a0
    2e36:  fef42623           sw a5,-20(s0)
    2e3a:  fec42783           lw a5,-20(s0)
    2e3e:  2781                 sext.w a5,a5
    2e40:  cfd9                 beqz a5,2ede <sid_boot_process+0xc8>
    2e42:  fdc42783           lw a5,-36(s0)
    2e46:  0007871b           sext.w a4,a5
    2e4a:  4799                 li a5,6
    2e4c:  08e7e163           bltu a5,a4,2ece <sid_boot_process+0xb8>
    2e50:  fdc46783           lwu a5,-36(s0)
    2e54:  00279713           slli a4,a5,0x2
    2e58:  67b9                 lui a5,0xe
    2e5a:  3f078793           addi a5,a5,1008 # e3f0 <gpio_get_boot_device+0x5a>
    2e5e:  97ba                 add a5,a5,a4
    2e60:  439c                 lw a5,0(a5)
    2e62:  8782                 jr a5
    2e64:  0ff00513           li a0,255
    2e68:  edbff0ef           jal ra,2d42 <try_boot_process>
    2e6c:  a885                 j 2edc <sid_boot_process+0xc6>
    2e6e:  4515                 li a0,5
    2e70:  d4dff0ef           jal ra,2bbc <boot_from_sdc2>
    2e74:  87aa                 mv a5,a0
    2e76:  fef42623           sw a5,-20(s0)
    2e7a:  fec42783           lw a5,-20(s0)
    2e7e:  2781                 sext.w a5,a5
    2e80:  eba9                 bnez a5,2ed2 <sid_boot_process+0xbc>
    2e82:  a08d                 j 2ee4 <sid_boot_process+0xce>
    2e84:  4509                 li a0,2
    2e86:  d37ff0ef           jal ra,2bbc <boot_from_sdc2>
    2e8a:  87aa                 mv a5,a0
    2e8c:  fef42623           sw a5,-20(s0)
    2e90:  fec42783           lw a5,-20(s0)
    2e94:  2781                 sext.w a5,a5
    2e96:  e3a1                 bnez a5,2ed6 <sid_boot_process+0xc0>
    2e98:  a0b1                 j 2ee4 <sid_boot_process+0xce>
    2e9a:  450d                 li a0,3
    2e9c:  dedff0ef           jal ra,2c88 <FUN_00002c88>
    2ea0:  87aa                 mv a5,a0
    2ea2:  fef42623           sw a5,-20(s0)
    2ea6:  fec42783           lw a5,-20(s0)
    2eaa:  2781                 sext.w a5,a5
    2eac:  e79d                 bnez a5,2eda <sid_boot_process+0xc4>
    2eae:  a81d                 j 2ee4 <sid_boot_process+0xce>
    2eb0:  00eff7b7           lui a5,0xeff
    2eb4:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    2eb8:  4511                 li a0,4
    2eba:  e23ff0ef           jal ra,2cdc <FUN_00002cdc>
    2ebe:  87aa                 mv a5,a0
    2ec0:  fef42623           sw a5,-20(s0)
    2ec4:  fec42783           lw a5,-20(s0)
    2ec8:  2781                 sext.w a5,a5
    2eca:  cf81                 beqz a5,2ee2 <sid_boot_process+0xcc>
    2ecc:  a801                 j 2edc <sid_boot_process+0xc6>
    2ece:  0001                 nop
    2ed0:  a81d                 j 2f06 <sid_boot_process+0xf0>
    2ed2:  0001                 nop
    2ed4:  a80d                 j 2f06 <sid_boot_process+0xf0>
    2ed6:  0001                 nop
    2ed8:  a03d                 j 2f06 <sid_boot_process+0xf0>
    2eda:  0001                 nop
    2edc:  a02d                 j 2f06 <sid_boot_process+0xf0>
    2ede:  0001                 nop
    2ee0:  a011                 j 2ee4 <sid_boot_process+0xce>
    2ee2:  0001                 nop
    2ee4:  000487b7           lui a5,0x48
    2ee8:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    2eec:  c799                 beqz a5,2efa <sid_boot_process+0xe4>
    2eee:  4585                 li a1,1
    2ef0:  00020537           lui a0,0x20
    2ef4:  a5fff0ef           jal ra,2952 <boot_verify_image>
    2ef8:  a039                 j 2f06 <sid_boot_process+0xf0>
    2efa:  0fc00593           li a1,252
    2efe:  00020537           lui a0,0x20
    2f02:  4a3060ef           jal ra,9ba4 <boot_finish>
    2f06:  4501                 li a0,0
    2f08:  443060ef           jal ra,9b4a <fel_boot>
    2f0c:  0001                 nop
    2f0e:  70a2                 ld ra,40(sp)
    2f10:  7402                 ld s0,32(sp)
    2f12:  6145                 addi sp,sp,48
    2f14:  8082                 ret
0000000000002f16 <gpio_boot_process>:
    2f16:  7179                 addi sp,sp,-48
    2f18:  f406                 sd ra,40(sp)
    2f1a:  f022                 sd s0,32(sp)
    2f1c:  1800                 addi s0,sp,48
    2f1e:  87aa                 mv a5,a0
    2f20:  fcf42e23           sw a5,-36(s0)
    2f24:  fe042423           sw zero,-24(s0)
    2f28:  fe042623           sw zero,-20(s0)
    2f2c:  4581                 li a1,0
    2f2e:  4515                 li a0,5
    2f30:  314050ef           jal ra,8244 <debug_state_save>
    2f34:  fdc42783           lw a5,-36(s0)
    2f38:  2781                 sext.w a5,a5
    2f3a:  cb99                 beqz a5,2f50 <gpio_boot_process+0x3a>
    2f3c:  c2dff0ef           jal ra,2b68 <boot_from_sdc0>
    2f40:  87aa                 mv a5,a0
    2f42:  fef42423           sw a5,-24(s0)
    2f46:  fe842783           lw a5,-24(s0)
    2f4a:  2781                 sext.w a5,a5
    2f4c:  e781                 bnez a5,2f54 <gpio_boot_process+0x3e>
    2f4e:  a0f5                 j 303a <gpio_boot_process+0x124>
    2f50:  377060ef           jal ra,9ac6 <gpio_enable_jtag_pf>
    2f54:  fdc42783           lw a5,-36(s0)
    2f58:  0007871b           sext.w a4,a5
    2f5c:  4785                 li a5,1
    2f5e:  06f70e63           beq a4,a5,2fda <gpio_boot_process+0xc4>
    2f62:  fdc42783           lw a5,-36(s0)
    2f66:  2781                 sext.w a5,a5
    2f68:  cf8d                 beqz a5,2fa2 <gpio_boot_process+0x8c>
    2f6a:  fdc42783           lw a5,-36(s0)
    2f6e:  0007871b           sext.w a4,a5
    2f72:  4789                 li a5,2
    2f74:  08f70163           beq a4,a5,2ff6 <gpio_boot_process+0xe0>
    2f78:  fdc42783           lw a5,-36(s0)
    2f7c:  0007871b           sext.w a4,a5
    2f80:  478d                 li a5,3
    2f82:  08f71c63           bne a4,a5,301a <gpio_boot_process+0x104>
    2f86:  4509                 li a0,2
    2f88:  c35ff0ef           jal ra,2bbc <boot_from_sdc2>
    2f8c:  87aa                 mv a5,a0
    2f8e:  fef42423           sw a5,-24(s0)
    2f92:  fe842783           lw a5,-24(s0)
    2f96:  2781                 sext.w a5,a5
    2f98:  cbc1                 beqz a5,3028 <gpio_boot_process+0x112>
    2f9a:  4789                 li a5,2
    2f9c:  fef42623           sw a5,-20(s0)
    2fa0:  a8b5                 j 301c <gpio_boot_process+0x106>
    2fa2:  450d                 li a0,3
    2fa4:  ce5ff0ef           jal ra,2c88 <FUN_00002c88>
    2fa8:  87aa                 mv a5,a0
    2faa:  fef42423           sw a5,-24(s0)
    2fae:  fe842783           lw a5,-24(s0)
    2fb2:  2781                 sext.w a5,a5
    2fb4:  cfa5                 beqz a5,302c <gpio_boot_process+0x116>
    2fb6:  00eff7b7           lui a5,0xeff
    2fba:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    2fbe:  4511                 li a0,4
    2fc0:  d1dff0ef           jal ra,2cdc <FUN_00002cdc>
    2fc4:  87aa                 mv a5,a0
    2fc6:  fef42423           sw a5,-24(s0)
    2fca:  fe842783           lw a5,-24(s0)
    2fce:  2781                 sext.w a5,a5
    2fd0:  c3a5                 beqz a5,3030 <gpio_boot_process+0x11a>
    2fd2:  478d                 li a5,3
    2fd4:  fef42623           sw a5,-20(s0)
    2fd8:  a091                 j 301c <gpio_boot_process+0x106>
    2fda:  450d                 li a0,3
    2fdc:  cadff0ef           jal ra,2c88 <FUN_00002c88>
    2fe0:  87aa                 mv a5,a0
    2fe2:  fef42423           sw a5,-24(s0)
    2fe6:  fe842783           lw a5,-24(s0)
    2fea:  2781                 sext.w a5,a5
    2fec:  c7a1                 beqz a5,3034 <gpio_boot_process+0x11e>
    2fee:  478d                 li a5,3
    2ff0:  fef42623           sw a5,-20(s0)
    2ff4:  a025                 j 301c <gpio_boot_process+0x106>
    2ff6:  00eff7b7           lui a5,0xeff
    2ffa:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    2ffe:  4511                 li a0,4
    3000:  cddff0ef           jal ra,2cdc <FUN_00002cdc>
    3004:  87aa                 mv a5,a0
    3006:  fef42423           sw a5,-24(s0)
    300a:  fe842783           lw a5,-24(s0)
    300e:  2781                 sext.w a5,a5
    3010:  c785                 beqz a5,3038 <gpio_boot_process+0x122>
    3012:  4791                 li a5,4
    3014:  fef42623           sw a5,-20(s0)
    3018:  a011                 j 301c <gpio_boot_process+0x106>
    301a:  0001                 nop
    301c:  fec42783           lw a5,-20(s0)
    3020:  853e                 mv a0,a5
    3022:  d21ff0ef           jal ra,2d42 <try_boot_process>
    3026:  a81d                 j 305c <gpio_boot_process+0x146>
    3028:  0001                 nop
    302a:  a801                 j 303a <gpio_boot_process+0x124>
    302c:  0001                 nop
    302e:  a031                 j 303a <gpio_boot_process+0x124>
    3030:  0001                 nop
    3032:  a021                 j 303a <gpio_boot_process+0x124>
    3034:  0001                 nop
    3036:  a011                 j 303a <gpio_boot_process+0x124>
    3038:  0001                 nop
    303a:  000487b7           lui a5,0x48
    303e:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3042:  c799                 beqz a5,3050 <gpio_boot_process+0x13a>
    3044:  4585                 li a1,1
    3046:  00020537           lui a0,0x20
    304a:  909ff0ef           jal ra,2952 <boot_verify_image>
    304e:  a039                 j 305c <gpio_boot_process+0x146>
    3050:  0fc00593           li a1,252
    3054:  00020537           lui a0,0x20
    3058:  34d060ef           jal ra,9ba4 <boot_finish>
    305c:  4501                 li a0,0
    305e:  2ed060ef           jal ra,9b4a <fel_boot>
    3062:  0001                 nop
    3064:  70a2                 ld ra,40(sp)
    3066:  7402                 ld s0,32(sp)
    3068:  6145                 addi sp,sp,48
    306a:  8082                 ret
000000000000306c <normal_boot_process>:
    306c:  1101                 addi sp,sp,-32
    306e:  ec06                 sd ra,24(sp)
    3070:  e822                 sd s0,16(sp)
    3072:  1000                 addi s0,sp,32
    3074:  fe042623           sw zero,-20(s0)
    3078:  fe042423           sw zero,-24(s0)
    307c:  599040ef           jal ra,7e14 <sid_get_boot_mode>
    3080:  87aa                 mv a5,a0
    3082:  fef42423           sw a5,-24(s0)
    3086:  fe842783           lw a5,-24(s0)
    308a:  2781                 sext.w a5,a5
    308c:  cb89                 beqz a5,309e <normal_boot_process+0x32>
    308e:  fe842783           lw a5,-24(s0)
    3092:  0007871b           sext.w a4,a5
    3096:  4785                 li a5,1
    3098:  00f70e63           beq a4,a5,30b4 <normal_boot_process+0x48>
    309c:  a03d                 j 30ca <normal_boot_process+0x5e>
    309e:  2f80b0ef           jal ra,e396 <gpio_get_boot_device>
    30a2:  87aa                 mv a5,a0
    30a4:  fef42623           sw a5,-20(s0)
    30a8:  fec42783           lw a5,-20(s0)
    30ac:  853e                 mv a0,a5
    30ae:  e69ff0ef           jal ra,2f16 <gpio_boot_process>
    30b2:  a00d                 j 30d4 <normal_boot_process+0x68>
    30b4:  002050ef           jal ra,80b6 <sid_get_boot_device>
    30b8:  87aa                 mv a5,a0
    30ba:  fef42623           sw a5,-20(s0)
    30be:  fec42783           lw a5,-20(s0)
    30c2:  853e                 mv a0,a5
    30c4:  d53ff0ef           jal ra,2e16 <sid_boot_process>
    30c8:  a031                 j 30d4 <normal_boot_process+0x68>
    30ca:  0ff00513           li a0,255
    30ce:  c75ff0ef           jal ra,2d42 <try_boot_process>
    30d2:  0001                 nop
    30d4:  0001                 nop
    30d6:  60e2                 ld ra,24(sp)
    30d8:  6442                 ld s0,16(sp)
    30da:  6105                 addi sp,sp,32
    30dc:  8082                 ret
00000000000030de <attempt_fast_boot>:
    30de:  7179                 addi sp,sp,-48
    30e0:  f406                 sd ra,40(sp)
    30e2:  f022                 sd s0,32(sp)
    30e4:  1800                 addi s0,sp,48
    30e6:  87aa                 mv a5,a0
    30e8:  872e                 mv a4,a1
    30ea:  fcf42e23           sw a5,-36(s0)
    30ee:  87ba                 mv a5,a4
    30f0:  fcf42c23           sw a5,-40(s0)
    30f4:  fe042423           sw zero,-24(s0)
    30f8:  fe042623           sw zero,-20(s0)
    30fc:  4581                 li a1,0
    30fe:  4511                 li a0,4
    3100:  144050ef           jal ra,8244 <debug_state_save>
    3104:  a65ff0ef           jal ra,2b68 <boot_from_sdc0>
    3108:  87aa                 mv a5,a0
    310a:  fef42423           sw a5,-24(s0)
    310e:  fe842783           lw a5,-24(s0)
    3112:  2781                 sext.w a5,a5
    3114:  c7f9                 beqz a5,31e2 <attempt_fast_boot+0x104>
    3116:  fdc42783           lw a5,-36(s0)
    311a:  0007871b           sext.w a4,a5
    311e:  478d                 li a5,3
    3120:  06f70b63           beq a4,a5,3196 <attempt_fast_boot+0xb8>
    3124:  fdc42783           lw a5,-36(s0)
    3128:  0007871b           sext.w a4,a5
    312c:  478d                 li a5,3
    312e:  00e7ea63           bltu a5,a4,3142 <attempt_fast_boot+0x64>
    3132:  fdc42783           lw a5,-36(s0)
    3136:  0007871b           sext.w a4,a5
    313a:  4789                 li a5,2
    313c:  02f70f63           beq a4,a5,317a <attempt_fast_boot+0x9c>
    3140:  a851                 j 31d4 <attempt_fast_boot+0xf6>
    3142:  fdc42783           lw a5,-36(s0)
    3146:  0007871b           sext.w a4,a5
    314a:  4791                 li a5,4
    314c:  06f70363           beq a4,a5,31b2 <attempt_fast_boot+0xd4>
    3150:  fdc42783           lw a5,-36(s0)
    3154:  0007871b           sext.w a4,a5
    3158:  4795                 li a5,5
    315a:  06f71d63           bne a4,a5,31d4 <attempt_fast_boot+0xf6>
    315e:  4515                 li a0,5
    3160:  a5dff0ef           jal ra,2bbc <boot_from_sdc2>
    3164:  87aa                 mv a5,a0
    3166:  fef42423           sw a5,-24(s0)
    316a:  fe842783           lw a5,-24(s0)
    316e:  2781                 sext.w a5,a5
    3170:  cbbd                 beqz a5,31e6 <attempt_fast_boot+0x108>
    3172:  4795                 li a5,5
    3174:  fef42623           sw a5,-20(s0)
    3178:  a8b9                 j 31d6 <attempt_fast_boot+0xf8>
    317a:  4509                 li a0,2
    317c:  a41ff0ef           jal ra,2bbc <boot_from_sdc2>
    3180:  87aa                 mv a5,a0
    3182:  fef42423           sw a5,-24(s0)
    3186:  fe842783           lw a5,-24(s0)
    318a:  2781                 sext.w a5,a5
    318c:  cfb9                 beqz a5,31ea <attempt_fast_boot+0x10c>
    318e:  4789                 li a5,2
    3190:  fef42623           sw a5,-20(s0)
    3194:  a089                 j 31d6 <attempt_fast_boot+0xf8>
    3196:  450d                 li a0,3
    3198:  af1ff0ef           jal ra,2c88 <FUN_00002c88>
    319c:  87aa                 mv a5,a0
    319e:  fef42423           sw a5,-24(s0)
    31a2:  fe842783           lw a5,-24(s0)
    31a6:  2781                 sext.w a5,a5
    31a8:  c3b9                 beqz a5,31ee <attempt_fast_boot+0x110>
    31aa:  478d                 li a5,3
    31ac:  fef42623           sw a5,-20(s0)
    31b0:  a01d                 j 31d6 <attempt_fast_boot+0xf8>
    31b2:  fd842783           lw a5,-40(s0)
    31b6:  85be                 mv a1,a5
    31b8:  4511                 li a0,4
    31ba:  b23ff0ef           jal ra,2cdc <FUN_00002cdc>
    31be:  87aa                 mv a5,a0
    31c0:  fef42423           sw a5,-24(s0)
    31c4:  fe842783           lw a5,-24(s0)
    31c8:  2781                 sext.w a5,a5
    31ca:  c785                 beqz a5,31f2 <attempt_fast_boot+0x114>
    31cc:  4791                 li a5,4
    31ce:  fef42623           sw a5,-20(s0)
    31d2:  a011                 j 31d6 <attempt_fast_boot+0xf8>
    31d4:  0001                 nop
    31d6:  fec42783           lw a5,-20(s0)
    31da:  853e                 mv a0,a5
    31dc:  b67ff0ef           jal ra,2d42 <try_boot_process>
    31e0:  a81d                 j 3216 <attempt_fast_boot+0x138>
    31e2:  0001                 nop
    31e4:  a801                 j 31f4 <attempt_fast_boot+0x116>
    31e6:  0001                 nop
    31e8:  a031                 j 31f4 <attempt_fast_boot+0x116>
    31ea:  0001                 nop
    31ec:  a021                 j 31f4 <attempt_fast_boot+0x116>
    31ee:  0001                 nop
    31f0:  a011                 j 31f4 <attempt_fast_boot+0x116>
    31f2:  0001                 nop
    31f4:  000487b7           lui a5,0x48
    31f8:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    31fc:  c799                 beqz a5,320a <attempt_fast_boot+0x12c>
    31fe:  4585                 li a1,1
    3200:  00020537           lui a0,0x20
    3204:  f4eff0ef           jal ra,2952 <boot_verify_image>
    3208:  a039                 j 3216 <attempt_fast_boot+0x138>
    320a:  0fc00593           li a1,252
    320e:  00020537           lui a0,0x20
    3212:  193060ef           jal ra,9ba4 <boot_finish>
    3216:  4501                 li a0,0
    3218:  133060ef           jal ra,9b4a <fel_boot>
    321c:  0001                 nop
    321e:  70a2                 ld ra,40(sp)
    3220:  7402                 ld s0,32(sp)
    3222:  6145                 addi sp,sp,48
    3224:  8082                 ret
0000000000003226 <maybe_attempt_fast_boot>:
    3226:  1101                 addi sp,sp,-32
    3228:  ec06                 sd ra,24(sp)
    322a:  e822                 sd s0,16(sp)
    322c:  1000                 addi s0,sp,32
    322e:  fe042623           sw zero,-20(s0)
    3232:  fe042423           sw zero,-24(s0)
    3236:  fe042223           sw zero,-28(s0)
    323a:  00f060ef           jal ra,9a48 <rtc_get_fast_boot_status>
    323e:  87aa                 mv a5,a0
    3240:  fef42623           sw a5,-20(s0)
    3244:  fec42783           lw a5,-20(s0)
    3248:  2781                 sext.w a5,a5
    324a:  c79d                 beqz a5,3278 <maybe_attempt_fast_boot+0x52>
    324c:  fec42783           lw a5,-20(s0)
    3250:  01c7d79b           srliw a5,a5,0x1c
    3254:  fef42423           sw a5,-24(s0)
    3258:  fec42703           lw a4,-20(s0)
    325c:  100007b7           lui a5,0x10000
    3260:  17fd                 addi a5,a5,-1
    3262:  8ff9                 and a5,a5,a4
    3264:  fef42223           sw a5,-28(s0)
    3268:  fe442703           lw a4,-28(s0)
    326c:  fe842783           lw a5,-24(s0)
    3270:  85ba                 mv a1,a4
    3272:  853e                 mv a0,a5
    3274:  e6bff0ef           jal ra,30de <attempt_fast_boot>
    3278:  57fd                 li a5,-1
    327a:  853e                 mv a0,a5
    327c:  60e2                 ld ra,24(sp)
    327e:  6442                 ld s0,16(sp)
    3280:  6105                 addi sp,sp,32
    3282:  8082                 ret
0000000000003284 <normal_boot>:
    3284:  7179                 addi sp,sp,-48
    3286:  f406                 sd ra,40(sp)
    3288:  f022                 sd s0,32(sp)
    328a:  1800                 addi s0,sp,48
    328c:  87aa                 mv a5,a0
    328e:  fcf42e23           sw a5,-36(s0)
    3292:  329040ef           jal ra,7dba <sid_init_brom_config>
    3296:  089060ef           jal ra,9b1e <riscv_init_caches>
    329a:  fdc42783           lw a5,-36(s0)
    329e:  2781                 sext.w a5,a5
    32a0:  cf99                 beqz a5,32be <normal_boot+0x3a>
    32a2:  0780b0ef           jal ra,e31a <syscon_read_fel_button>
    32a6:  87aa                 mv a5,a0
    32a8:  fef42623           sw a5,-20(s0)
    32ac:  fec42783           lw a5,-20(s0)
    32b0:  2781                 sext.w a5,a5
    32b2:  c791                 beqz a5,32be <normal_boot+0x3a>
    32b4:  4581                 li a1,0
    32b6:  4509                 li a0,2
    32b8:  78d040ef           jal ra,8244 <debug_state_save>
    32bc:  a825                 j 32f4 <normal_boot+0x70>
    32be:  4581                 li a1,0
    32c0:  450d                 li a0,3
    32c2:  783040ef           jal ra,8244 <debug_state_save>
    32c6:  720060ef           jal ra,99e6 <ccu_init>
    32ca:  4581                 li a1,0
    32cc:  4541                 li a0,16
    32ce:  732060ef           jal ra,9a00 <debug_syscon>
    32d2:  4581                 li a1,0
    32d4:  4545                 li a0,17
    32d6:  72a060ef           jal ra,9a00 <debug_syscon>
    32da:  f4dff0ef           jal ra,3226 <maybe_attempt_fast_boot>
    32de:  87aa                 mv a5,a0
    32e0:  fef42623           sw a5,-20(s0)
    32e4:  fec42783           lw a5,-20(s0)
    32e8:  2781                 sext.w a5,a5
    32ea:  c781                 beqz a5,32f2 <normal_boot+0x6e>
    32ec:  d81ff0ef           jal ra,306c <normal_boot_process>
    32f0:  a011                 j 32f4 <normal_boot+0x70>
    32f2:  0001                 nop
    32f4:  07f00513           li a0,127
    32f8:  053060ef           jal ra,9b4a <fel_boot>
    32fc:  0001                 nop
    32fe:  70a2                 ld ra,40(sp)
    3300:  7402                 ld s0,32(sp)
    3302:  6145                 addi sp,sp,48
    3304:  8082                 ret
0000000000003320 <trap_vector>:
    3320:  7119                 addi sp,sp,-128
    3322:  c206                 sw ra,4(sp)
    3324:  c40a                 sw sp,8(sp)
    3326:  c60e                 sw gp,12(sp)
    3328:  c812                 sw tp,16(sp)
    332a:  ca16                 sw t0,20(sp)
    332c:  cc1a                 sw t1,24(sp)
    332e:  ce1e                 sw t2,28(sp)
    3330:  d022                 sw s0,32(sp)
    3332:  d226                 sw s1,36(sp)
    3334:  d42a                 sw a0,40(sp)
    3336:  d62e                 sw a1,44(sp)
    3338:  d832                 sw a2,48(sp)
    333a:  da36                 sw a3,52(sp)
    333c:  dc3a                 sw a4,56(sp)
    333e:  de3e                 sw a5,60(sp)
    3340:  c0c2                 sw a6,64(sp)
    3342:  c2c6                 sw a7,68(sp)
    3344:  c4ca                 sw s2,72(sp)
    3346:  c6ce                 sw s3,76(sp)
    3348:  c8d2                 sw s4,80(sp)
    334a:  cad6                 sw s5,84(sp)
    334c:  ccda                 sw s6,88(sp)
    334e:  cede                 sw s7,92(sp)
    3350:  d0e2                 sw s8,96(sp)
    3352:  d2e6                 sw s9,100(sp)
    3354:  d4ea                 sw s10,104(sp)
    3356:  d6ee                 sw s11,108(sp)
    3358:  d8f2                 sw t3,112(sp)
    335a:  daf6                 sw t4,116(sp)
    335c:  dcfa                 sw t5,120(sp)
    335e:  defe                 sw t6,124(sp)
    3360:  34202573           csrr a0,mcause
    3364:  341025f3           csrr a1,mepc
    3368:  34302673           csrr a2,mtval
    336c:  868a                 mv a3,sp
    336e:  06d060ef           jal ra,9bda <trap_handler>
    3372:  4092                 lw ra,4(sp)
    3374:  41b2                 lw gp,12(sp)
    3376:  4242                 lw tp,16(sp)
    3378:  42d2                 lw t0,20(sp)
    337a:  4362                 lw t1,24(sp)
    337c:  43f2                 lw t2,28(sp)
    337e:  5402                 lw s0,32(sp)
    3380:  5492                 lw s1,36(sp)
    3382:  5522                 lw a0,40(sp)
    3384:  55b2                 lw a1,44(sp)
    3386:  5642                 lw a2,48(sp)
    3388:  56d2                 lw a3,52(sp)
    338a:  5762                 lw a4,56(sp)
    338c:  57f2                 lw a5,60(sp)
    338e:  4806                 lw a6,64(sp)
    3390:  4896                 lw a7,68(sp)
    3392:  4926                 lw s2,72(sp)
    3394:  49b6                 lw s3,76(sp)
    3396:  4a46                 lw s4,80(sp)
    3398:  4ad6                 lw s5,84(sp)
    339a:  4b66                 lw s6,88(sp)
    339c:  4bf6                 lw s7,92(sp)
    339e:  5c06                 lw s8,96(sp)
    33a0:  5c96                 lw s9,100(sp)
    33a2:  5d26                 lw s10,104(sp)
    33a4:  5db6                 lw s11,108(sp)
    33a6:  5e46                 lw t3,112(sp)
    33a8:  5ed6                 lw t4,116(sp)
    33aa:  5f66                 lw t5,120(sp)
    33ac:  5ff6                 lw t6,124(sp)
    33ae:  4122                 lw sp,8(sp)
    33b0:  6109                 addi sp,sp,128
    33b2:  30200073           mret
00000000000033c2 <FUN_000033c2>:
    33c2:  1101                 addi sp,sp,-32
    33c4:  ec06                 sd ra,24(sp)
    33c6:  e822                 sd s0,16(sp)
    33c8:  1000                 addi s0,sp,32
    33ca:  fea43423           sd a0,-24(s0)
    33ce:  87ae                 mv a5,a1
    33d0:  8732                 mv a4,a2
    33d2:  fef42223           sw a5,-28(s0)
    33d6:  87ba                 mv a5,a4
    33d8:  fef42023           sw a5,-32(s0)
    33dc:  fe042783           lw a5,-32(s0)
    33e0:  2781                 sext.w a5,a5
    33e2:  eb95                 bnez a5,3416 <FUN_000033c2+0x54>
    33e4:  fe442783           lw a5,-28(s0)
    33e8:  0007871b           sext.w a4,a5
    33ec:  4785                 li a5,1
    33ee:  02e7e263           bltu a5,a4,3412 <FUN_000033c2+0x50>
    33f2:  fe446783           lwu a5,-28(s0)
    33f6:  00479713           slli a4,a5,0x4
    33fa:  67b9                 lui a5,0xe
    33fc:  41078793           addi a5,a5,1040 # e410 <gpio_get_boot_device+0x7a>
    3400:  97ba                 add a5,a5,a4
    3402:  4641                 li a2,16
    3404:  85be                 mv a1,a5
    3406:  fe843503           ld a0,-24(s0)
    340a:  281060ef           jal ra,9e8a <memcpy>
    340e:  4781                 li a5,0
    3410:  a0a1                 j 3458 <FUN_000033c2+0x96>
    3412:  57fd                 li a5,-1
    3414:  a091                 j 3458 <FUN_000033c2+0x96>
    3416:  fe042783           lw a5,-32(s0)
    341a:  0007871b           sext.w a4,a5
    341e:  4785                 li a5,1
    3420:  02f71b63           bne a4,a5,3456 <FUN_000033c2+0x94>
    3424:  fe442783           lw a5,-28(s0)
    3428:  0007871b           sext.w a4,a5
    342c:  4799                 li a5,6
    342e:  02e7e263           bltu a5,a4,3452 <FUN_000033c2+0x90>
    3432:  fe446783           lwu a5,-28(s0)
    3436:  00479713           slli a4,a5,0x4
    343a:  67b9                 lui a5,0xe
    343c:  43078793           addi a5,a5,1072 # e430 <gpio_get_boot_device+0x9a>
    3440:  97ba                 add a5,a5,a4
    3442:  4641                 li a2,16
    3444:  85be                 mv a1,a5
    3446:  fe843503           ld a0,-24(s0)
    344a:  241060ef           jal ra,9e8a <memcpy>
    344e:  4781                 li a5,0
    3450:  a021                 j 3458 <FUN_000033c2+0x96>
    3452:  57fd                 li a5,-1
    3454:  a011                 j 3458 <FUN_000033c2+0x96>
    3456:  57fd                 li a5,-1
    3458:  853e                 mv a0,a5
    345a:  60e2                 ld ra,24(sp)
    345c:  6442                 ld s0,16(sp)
    345e:  6105                 addi sp,sp,32
    3460:  8082                 ret
0000000000003462 <FUN_00003462>:
    3462:  7179                 addi sp,sp,-48
    3464:  f406                 sd ra,40(sp)
    3466:  f022                 sd s0,32(sp)
    3468:  1800                 addi s0,sp,48
    346a:  87aa                 mv a5,a0
    346c:  86ae                 mv a3,a1
    346e:  8732                 mv a4,a2
    3470:  fcf42e23           sw a5,-36(s0)
    3474:  87b6                 mv a5,a3
    3476:  fcf42c23           sw a5,-40(s0)
    347a:  87ba                 mv a5,a4
    347c:  fcf42a23           sw a5,-44(s0)
    3480:  fd842783           lw a5,-40(s0)
    3484:  0187979b           slliw a5,a5,0x18
    3488:  2781                 sext.w a5,a5
    348a:  873e                 mv a4,a5
    348c:  0f0007b7           lui a5,0xf000
    3490:  8ff9                 and a5,a5,a4
    3492:  0007871b           sext.w a4,a5
    3496:  fd442783           lw a5,-44(s0)
    349a:  0107979b           slliw a5,a5,0x10
    349e:  2781                 sext.w a5,a5
    34a0:  86be                 mv a3,a5
    34a2:  00ff07b7           lui a5,0xff0
    34a6:  8ff5                 and a5,a5,a3
    34a8:  2781                 sext.w a5,a5
    34aa:  8fd9                 or a5,a5,a4
    34ac:  fef42623           sw a5,-20(s0)
    34b0:  fec42703           lw a4,-20(s0)
    34b4:  fdc42783           lw a5,-36(s0)
    34b8:  85ba                 mv a1,a4
    34ba:  853e                 mv a0,a5
    34bc:  5b0060ef           jal ra,9a6c <FUN_00009a6c>
    34c0:  0001                 nop
    34c2:  70a2                 ld ra,40(sp)
    34c4:  7402                 ld s0,32(sp)
    34c6:  6145                 addi sp,sp,48
    34c8:  8082                 ret
00000000000034ca <FUN_000034ca>:
    34ca:  7179                 addi sp,sp,-48
    34cc:  f422                 sd s0,40(sp)
    34ce:  1800                 addi s0,sp,48
    34d0:  87aa                 mv a5,a0
    34d2:  feb43023           sd a1,-32(s0)
    34d6:  fcc43c23           sd a2,-40(s0)
    34da:  fef42623           sw a5,-20(s0)
    34de:  fec42783           lw a5,-20(s0)
    34e2:  0187d79b           srliw a5,a5,0x18
    34e6:  2781                 sext.w a5,a5
    34e8:  8bbd                 andi a5,a5,15
    34ea:  0007871b           sext.w a4,a5
    34ee:  fe043783           ld a5,-32(s0)
    34f2:  c398                 sw a4,0(a5)
    34f4:  fec42783           lw a5,-20(s0)
    34f8:  0107d79b           srliw a5,a5,0x10
    34fc:  2781                 sext.w a5,a5
    34fe:  0ff7f793           andi a5,a5,255
    3502:  0007871b           sext.w a4,a5
    3506:  fd843783           ld a5,-40(s0)
    350a:  c398                 sw a4,0(a5)
    350c:  0001                 nop
    350e:  7422                 ld s0,40(sp)
    3510:  6145                 addi sp,sp,48
    3512:  8082                 ret
0000000000003514 <FUN_00003514>:
    3514:  7179                 addi sp,sp,-48
    3516:  f406                 sd ra,40(sp)
    3518:  f022                 sd s0,32(sp)
    351a:  1800                 addi s0,sp,48
    351c:  87aa                 mv a5,a0
    351e:  872e                 mv a4,a1
    3520:  fcf42e23           sw a5,-36(s0)
    3524:  87ba                 mv a5,a4
    3526:  fcf42c23           sw a5,-40(s0)
    352a:  fe042623           sw zero,-20(s0)
    352e:  fe042423           sw zero,-24(s0)
    3532:  070907b7           lui a5,0x7090
    3536:  32078513           addi a0,a5,800 # 7090320 <gpio_get_boot_device+0x7081f8a
    353a:  64f040ef           jal ra,8388 <debug_select_word>
    353e:  fd842783           lw a5,-40(s0)
    3542:  0007871b           sext.w a4,a5
    3546:  00eff7b7           lui a5,0xeff
    354a:  80078793           addi a5,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    354e:  04f70563           beq a4,a5,3598 <FUN_00003514+0x84>
    3552:  fe840693           addi a3,s0,-24
    3556:  fec40713           addi a4,s0,-20
    355a:  fd842783           lw a5,-40(s0)
    355e:  8636                 mv a2,a3
    3560:  85ba                 mv a1,a4
    3562:  853e                 mv a0,a5
    3564:  f67ff0ef           jal ra,34ca <FUN_000034ca>
    3568:  fec42783           lw a5,-20(s0)
    356c:  fe842703           lw a4,-24(s0)
    3570:  85ba                 mv a1,a4
    3572:  853e                 mv a0,a5
    3574:  050000ef           jal ra,35c4 <FUN_000035c4>
    3578:  87aa                 mv a5,a0
    357a:  e399                 bnez a5,3580 <FUN_00003514+0x6c>
    357c:  4781                 li a5,0
    357e:  a835                 j 35ba <FUN_00003514+0xa6>
    3580:  fec42783           lw a5,-20(s0)
    3584:  fe842703           lw a4,-24(s0)
    3588:  85ba                 mv a1,a4
    358a:  853e                 mv a0,a5
    358c:  298000ef           jal ra,3824 <FUN_00003824>
    3590:  87aa                 mv a5,a0
    3592:  e399                 bnez a5,3598 <FUN_00003514+0x84>
    3594:  4781                 li a5,0
    3596:  a015                 j 35ba <FUN_00003514+0xa6>
    3598:  4581                 li a1,0
    359a:  4501                 li a0,0
    359c:  028000ef           jal ra,35c4 <FUN_000035c4>
    35a0:  87aa                 mv a5,a0
    35a2:  e399                 bnez a5,35a8 <FUN_00003514+0x94>
    35a4:  4781                 li a5,0
    35a6:  a811                 j 35ba <FUN_00003514+0xa6>
    35a8:  4581                 li a1,0
    35aa:  4505                 li a0,1
    35ac:  278000ef           jal ra,3824 <FUN_00003824>
    35b0:  87aa                 mv a5,a0
    35b2:  e399                 bnez a5,35b8 <FUN_00003514+0xa4>
    35b4:  4781                 li a5,0
    35b6:  a011                 j 35ba <FUN_00003514+0xa6>
    35b8:  57fd                 li a5,-1
    35ba:  853e                 mv a0,a5
    35bc:  70a2                 ld ra,40(sp)
    35be:  7402                 ld s0,32(sp)
    35c0:  6145                 addi sp,sp,48
    35c2:  8082                 ret
00000000000035c4 <FUN_000035c4>:
    35c4:  7159                 addi sp,sp,-112
    35c6:  f486                 sd ra,104(sp)
    35c8:  f0a2                 sd s0,96(sp)
    35ca:  1880                 addi s0,sp,112
    35cc:  87aa                 mv a5,a0
    35ce:  872e                 mv a4,a1
    35d0:  f8f42e23           sw a5,-100(s0)
    35d4:  87ba                 mv a5,a4
    35d6:  f8f42c23           sw a5,-104(s0)
    35da:  fc043c23           sd zero,-40(s0)
    35de:  fc043823           sd zero,-48(s0)
    35e2:  4501                 li a0,0
    35e4:  0f9030ef           jal ra,6edc <FUN_00006edc>
    35e8:  0a0040ef           jal ra,7688 <FUN_00007688>
    35ec:  f9842783           lw a5,-104(s0)
    35f0:  fef42623           sw a5,-20(s0)
    35f4:  a421                 j 37fc <FUN_000035c4+0x238>
    35f6:  f9c42683           lw a3,-100(s0)
    35fa:  fec42703           lw a4,-20(s0)
    35fe:  fa840793           addi a5,s0,-88
    3602:  8636                 mv a2,a3
    3604:  85ba                 mv a1,a4
    3606:  853e                 mv a0,a5
    3608:  dbbff0ef           jal ra,33c2 <FUN_000033c2>
    360c:  87aa                 mv a5,a0
    360e:  fcf42623           sw a5,-52(s0)
    3612:  fcc42783           lw a5,-52(s0)
    3616:  0007871b           sext.w a4,a5
    361a:  57fd                 li a5,-1
    361c:  1cf70a63           beq a4,a5,37f0 <FUN_000035c4+0x22c>
    3620:  fa842783           lw a5,-88(s0)
    3624:  fcf42423           sw a5,-56(s0)
    3628:  fac42783           lw a5,-84(s0)
    362c:  fcf42223           sw a5,-60(s0)
    3630:  fb442783           lw a5,-76(s0)
    3634:  fcf42023           sw a5,-64(s0)
    3638:  fb042783           lw a5,-80(s0)
    363c:  faf42e23           sw a5,-68(s0)
    3640:  fc842683           lw a3,-56(s0)
    3644:  fc442703           lw a4,-60(s0)
    3648:  fbc42783           lw a5,-68(s0)
    364c:  fc042603           lw a2,-64(s0)
    3650:  8832                 mv a6,a2
    3652:  4605                 li a2,1
    3654:  000205b7           lui a1,0x20
    3658:  4501                 li a0,0
    365a:  068040ef           jal ra,76c2 <FUN_000076c2>
    365e:  87aa                 mv a5,a0
    3660:  873e                 mv a4,a5
    3662:  4789                 li a5,2
    3664:  00f71963           bne a4,a5,3676 <FUN_000035c4+0xb2>
    3668:  0f000613           li a2,240
    366c:  4581                 li a1,0
    366e:  4511                 li a0,4
    3670:  5b9040ef           jal ra,8428 <rtc_brom_debug>
    3674:  aabd                 j 37f2 <FUN_000035c4+0x22e>
    3676:  000487b7           lui a5,0x48
    367a:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    367e:  cba1                 beqz a5,36ce <FUN_000035c4+0x10a>
    3680:  67b9                 lui a5,0xe
    3682:  4a078593           addi a1,a5,1184 # e4a0 <gpio_get_boot_device+0x10a>
    3686:  00020537           lui a0,0x20
    368a:  789040ef           jal ra,8612 <boot0_check_magic>
    368e:  87aa                 mv a5,a0
    3690:  cb81                 beqz a5,36a0 <FUN_000035c4+0xdc>
    3692:  0f100613           li a2,241
    3696:  4581                 li a1,0
    3698:  4511                 li a0,4
    369a:  58f040ef           jal ra,8428 <rtc_brom_debug>
    369e:  aa91                 j 37f2 <FUN_000035c4+0x22e>
    36a0:  000207b7           lui a5,0x20
    36a4:  fcf43c23           sd a5,-40(s0)
    36a8:  fd843783           ld a5,-40(s0)
    36ac:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    36b0:  01d7c683           lbu a3,29(a5)
    36b4:  06a2                 slli a3,a3,0x8
    36b6:  8f55                 or a4,a4,a3
    36b8:  01e7c683           lbu a3,30(a5)
    36bc:  06c2                 slli a3,a3,0x10
    36be:  8f55                 or a4,a4,a3
    36c0:  01f7c783           lbu a5,31(a5)
    36c4:  07e2                 slli a5,a5,0x18
    36c6:  8fd9                 or a5,a5,a4
    36c8:  fef42423           sw a5,-24(s0)
    36cc:  a815                 j 3700 <FUN_000035c4+0x13c>
    36ce:  67b9                 lui a5,0xe
    36d0:  4b078593           addi a1,a5,1200 # e4b0 <gpio_get_boot_device+0x11a>
    36d4:  00020537           lui a0,0x20
    36d8:  73b040ef           jal ra,8612 <boot0_check_magic>
    36dc:  87aa                 mv a5,a0
    36de:  cb81                 beqz a5,36ee <FUN_000035c4+0x12a>
    36e0:  0f100613           li a2,241
    36e4:  4581                 li a1,0
    36e6:  4511                 li a0,4
    36e8:  541040ef           jal ra,8428 <rtc_brom_debug>
    36ec:  a219                 j 37f2 <FUN_000035c4+0x22e>
    36ee:  000207b7           lui a5,0x20
    36f2:  fcf43823           sd a5,-48(s0)
    36f6:  fd043783           ld a5,-48(s0)
    36fa:  4b9c                 lw a5,16(a5)
    36fc:  fef42423           sw a5,-24(s0)
    3700:  fe842783           lw a5,-24(s0)
    3704:  3ff7f793           andi a5,a5,1023
    3708:  2781                 sext.w a5,a5
    370a:  cb81                 beqz a5,371a <FUN_000035c4+0x156>
    370c:  0f200613           li a2,242
    3710:  4581                 li a1,0
    3712:  4511                 li a0,4
    3714:  515040ef           jal ra,8428 <rtc_brom_debug>
    3718:  a8e9                 j 37f2 <FUN_000035c4+0x22e>
    371a:  fc442783           lw a5,-60(s0)
    371e:  fe842703           lw a4,-24(s0)
    3722:  02f777bb           remuw a5,a4,a5
    3726:  2781                 sext.w a5,a5
    3728:  cf81                 beqz a5,3740 <FUN_000035c4+0x17c>
    372a:  fc442783           lw a5,-60(s0)
    372e:  fe842703           lw a4,-24(s0)
    3732:  02f757bb           divuw a5,a4,a5
    3736:  2781                 sext.w a5,a5
    3738:  2785                 addiw a5,a5,1
    373a:  fef42223           sw a5,-28(s0)
    373e:  a809                 j 3750 <FUN_000035c4+0x18c>
    3740:  fc442783           lw a5,-60(s0)
    3744:  fe842703           lw a4,-24(s0)
    3748:  02f757bb           divuw a5,a4,a5
    374c:  fef42223           sw a5,-28(s0)
    3750:  fc842683           lw a3,-56(s0)
    3754:  fc442703           lw a4,-60(s0)
    3758:  fbc42783           lw a5,-68(s0)
    375c:  fc042583           lw a1,-64(s0)
    3760:  fe442603           lw a2,-28(s0)
    3764:  882e                 mv a6,a1
    3766:  000205b7           lui a1,0x20
    376a:  4501                 li a0,0
    376c:  757030ef           jal ra,76c2 <FUN_000076c2>
    3770:  87aa                 mv a5,a0
    3772:  873e                 mv a4,a5
    3774:  4789                 li a5,2
    3776:  00f71963           bne a4,a5,3788 <FUN_000035c4+0x1c4>
    377a:  0f300613           li a2,243
    377e:  4581                 li a1,0
    3780:  4511                 li a0,4
    3782:  4a7040ef           jal ra,8428 <rtc_brom_debug>
    3786:  a0b5                 j 37f2 <FUN_000035c4+0x22e>
    3788:  fe842783           lw a5,-24(s0)
    378c:  85be                 mv a1,a5
    378e:  00020537           lui a0,0x20
    3792:  725040ef           jal ra,86b6 <FUN_000086b6>
    3796:  87aa                 mv a5,a0
    3798:  e7a9                 bnez a5,37e2 <FUN_000035c4+0x21e>
    379a:  000487b7           lui a5,0x48
    379e:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    37a2:  c799                 beqz a5,37b0 <FUN_000035c4+0x1ec>
    37a4:  fd843783           ld a5,-40(s0)
    37a8:  4711                 li a4,4
    37aa:  02e78023           sb a4,32(a5)
    37ae:  a031                 j 37ba <FUN_000035c4+0x1f6>
    37b0:  fd043783           ld a5,-48(s0)
    37b4:  4711                 li a4,4
    37b6:  02e78423           sb a4,40(a5)
    37ba:  fec42703           lw a4,-20(s0)
    37be:  f9c42783           lw a5,-100(s0)
    37c2:  863a                 mv a2,a4
    37c4:  85be                 mv a1,a5
    37c6:  4511                 li a0,4
    37c8:  c9bff0ef           jal ra,3462 <FUN_00003462>
    37cc:  6785                 lui a5,0x1
    37ce:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    37d2:  4581                 li a1,0
    37d4:  4511                 li a0,4
    37d6:  453040ef           jal ra,8428 <rtc_brom_debug>
    37da:  7f6030ef           jal ra,6fd0 <FUN_00006fd0>
    37de:  4781                 li a5,0
    37e0:  a82d                 j 381a <FUN_000035c4+0x256>
    37e2:  0f400613           li a2,244
    37e6:  4581                 li a1,0
    37e8:  4511                 li a0,4
    37ea:  43f040ef           jal ra,8428 <rtc_brom_debug>
    37ee:  a011                 j 37f2 <FUN_000035c4+0x22e>
    37f0:  0001                 nop
    37f2:  fec42783           lw a5,-20(s0)
    37f6:  2785                 addiw a5,a5,1
    37f8:  fef42623           sw a5,-20(s0)
    37fc:  f9c42783           lw a5,-100(s0)
    3800:  2781                 sext.w a5,a5
    3802:  c399                 beqz a5,3808 <FUN_000035c4+0x244>
    3804:  479d                 li a5,7
    3806:  a011                 j 380a <FUN_000035c4+0x246>
    3808:  4789                 li a5,2
    380a:  fec42703           lw a4,-20(s0)
    380e:  2701                 sext.w a4,a4
    3810:  def763e3           bltu a4,a5,35f6 <FUN_000035c4+0x32>
    3814:  7bc030ef           jal ra,6fd0 <FUN_00006fd0>
    3818:  57fd                 li a5,-1
    381a:  853e                 mv a0,a5
    381c:  70a6                 ld ra,104(sp)
    381e:  7406                 ld s0,96(sp)
    3820:  6165                 addi sp,sp,112
    3822:  8082                 ret
0000000000003824 <FUN_00003824>:
    3824:  7159                 addi sp,sp,-112
    3826:  f486                 sd ra,104(sp)
    3828:  f0a2                 sd s0,96(sp)
    382a:  1880                 addi s0,sp,112
    382c:  87aa                 mv a5,a0
    382e:  872e                 mv a4,a1
    3830:  f8f42e23           sw a5,-100(s0)
    3834:  87ba                 mv a5,a4
    3836:  f8f42c23           sw a5,-104(s0)
    383a:  fe042423           sw zero,-24(s0)
    383e:  fc043823           sd zero,-48(s0)
    3842:  fc043423           sd zero,-56(s0)
    3846:  4501                 li a0,0
    3848:  694030ef           jal ra,6edc <FUN_00006edc>
    384c:  63d030ef           jal ra,7688 <FUN_00007688>
    3850:  f9842783           lw a5,-104(s0)
    3854:  fef42623           sw a5,-20(s0)
    3858:  a461                 j 3ae0 <FUN_00003824+0x2bc>
    385a:  fe042423           sw zero,-24(s0)
    385e:  04000793           li a5,64
    3862:  fcf42e23           sw a5,-36(s0)
    3866:  a485                 j 3ac6 <FUN_00003824+0x2a2>
    3868:  fe842783           lw a5,-24(s0)
    386c:  2785                 addiw a5,a5,1
    386e:  fef42423           sw a5,-24(s0)
    3872:  f9c42683           lw a3,-100(s0)
    3876:  fec42703           lw a4,-20(s0)
    387a:  fa040793           addi a5,s0,-96
    387e:  8636                 mv a2,a3
    3880:  85ba                 mv a1,a4
    3882:  853e                 mv a0,a5
    3884:  b3fff0ef           jal ra,33c2 <FUN_000033c2>
    3888:  87aa                 mv a5,a0
    388a:  fcf42223           sw a5,-60(s0)
    388e:  fc442783           lw a5,-60(s0)
    3892:  0007871b           sext.w a4,a5
    3896:  57fd                 li a5,-1
    3898:  22f70063           beq a4,a5,3ab8 <FUN_00003824+0x294>
    389c:  fa042783           lw a5,-96(s0)
    38a0:  fcf42023           sw a5,-64(s0)
    38a4:  fa442783           lw a5,-92(s0)
    38a8:  faf42e23           sw a5,-68(s0)
    38ac:  fac42783           lw a5,-84(s0)
    38b0:  faf42c23           sw a5,-72(s0)
    38b4:  fa842783           lw a5,-88(s0)
    38b8:  faf42a23           sw a5,-76(s0)
    38bc:  fc042683           lw a3,-64(s0)
    38c0:  fbc42703           lw a4,-68(s0)
    38c4:  fb442783           lw a5,-76(s0)
    38c8:  fb842603           lw a2,-72(s0)
    38cc:  fdc42503           lw a0,-36(s0)
    38d0:  8832                 mv a6,a2
    38d2:  4605                 li a2,1
    38d4:  000205b7           lui a1,0x20
    38d8:  5eb030ef           jal ra,76c2 <FUN_000076c2>
    38dc:  87aa                 mv a5,a0
    38de:  873e                 mv a4,a5
    38e0:  4789                 li a5,2
    38e2:  00f71b63           bne a4,a5,38f8 <FUN_00003824+0xd4>
    38e6:  fe842783           lw a5,-24(s0)
    38ea:  0f000613           li a2,240
    38ee:  85be                 mv a1,a5
    38f0:  4511                 li a0,4
    38f2:  337040ef           jal ra,8428 <rtc_brom_debug>
    38f6:  a2d1                 j 3aba <FUN_00003824+0x296>
    38f8:  000487b7           lui a5,0x48
    38fc:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3900:  cbb1                 beqz a5,3954 <FUN_00003824+0x130>
    3902:  67b9                 lui a5,0xe
    3904:  4a078593           addi a1,a5,1184 # e4a0 <gpio_get_boot_device+0x10a>
    3908:  00020537           lui a0,0x20
    390c:  507040ef           jal ra,8612 <boot0_check_magic>
    3910:  87aa                 mv a5,a0
    3912:  cb91                 beqz a5,3926 <FUN_00003824+0x102>
    3914:  fe842783           lw a5,-24(s0)
    3918:  0f100613           li a2,241
    391c:  85be                 mv a1,a5
    391e:  4511                 li a0,4
    3920:  309040ef           jal ra,8428 <rtc_brom_debug>
    3924:  aa59                 j 3aba <FUN_00003824+0x296>
    3926:  000207b7           lui a5,0x20
    392a:  fcf43823           sd a5,-48(s0)
    392e:  fd043783           ld a5,-48(s0)
    3932:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    3936:  01d7c683           lbu a3,29(a5)
    393a:  06a2                 slli a3,a3,0x8
    393c:  8f55                 or a4,a4,a3
    393e:  01e7c683           lbu a3,30(a5)
    3942:  06c2                 slli a3,a3,0x10
    3944:  8f55                 or a4,a4,a3
    3946:  01f7c783           lbu a5,31(a5)
    394a:  07e2                 slli a5,a5,0x18
    394c:  8fd9                 or a5,a5,a4
    394e:  fef42223           sw a5,-28(s0)
    3952:  a825                 j 398a <FUN_00003824+0x166>
    3954:  67b9                 lui a5,0xe
    3956:  4b078593           addi a1,a5,1200 # e4b0 <gpio_get_boot_device+0x11a>
    395a:  00020537           lui a0,0x20
    395e:  4b5040ef           jal ra,8612 <boot0_check_magic>
    3962:  87aa                 mv a5,a0
    3964:  cb91                 beqz a5,3978 <FUN_00003824+0x154>
    3966:  fe842783           lw a5,-24(s0)
    396a:  0f100613           li a2,241
    396e:  85be                 mv a1,a5
    3970:  4511                 li a0,4
    3972:  2b7040ef           jal ra,8428 <rtc_brom_debug>
    3976:  a291                 j 3aba <FUN_00003824+0x296>
    3978:  000207b7           lui a5,0x20
    397c:  fcf43423           sd a5,-56(s0)
    3980:  fc843783           ld a5,-56(s0)
    3984:  4b9c                 lw a5,16(a5)
    3986:  fef42223           sw a5,-28(s0)
    398a:  fe442783           lw a5,-28(s0)
    398e:  3ff7f793           andi a5,a5,1023
    3992:  2781                 sext.w a5,a5
    3994:  cb91                 beqz a5,39a8 <FUN_00003824+0x184>
    3996:  fe842783           lw a5,-24(s0)
    399a:  0f200613           li a2,242
    399e:  85be                 mv a1,a5
    39a0:  4511                 li a0,4
    39a2:  287040ef           jal ra,8428 <rtc_brom_debug>
    39a6:  aa11                 j 3aba <FUN_00003824+0x296>
    39a8:  fbc42783           lw a5,-68(s0)
    39ac:  fe442703           lw a4,-28(s0)
    39b0:  02f777bb           remuw a5,a4,a5
    39b4:  2781                 sext.w a5,a5
    39b6:  cf81                 beqz a5,39ce <FUN_00003824+0x1aa>
    39b8:  fbc42783           lw a5,-68(s0)
    39bc:  fe442703           lw a4,-28(s0)
    39c0:  02f757bb           divuw a5,a4,a5
    39c4:  2781                 sext.w a5,a5
    39c6:  2785                 addiw a5,a5,1
    39c8:  fef42023           sw a5,-32(s0)
    39cc:  a809                 j 39de <FUN_00003824+0x1ba>
    39ce:  fbc42783           lw a5,-68(s0)
    39d2:  fe442703           lw a4,-28(s0)
    39d6:  02f757bb           divuw a5,a4,a5
    39da:  fef42023           sw a5,-32(s0)
    39de:  fc042683           lw a3,-64(s0)
    39e2:  fbc42703           lw a4,-68(s0)
    39e6:  fb442783           lw a5,-76(s0)
    39ea:  fb842583           lw a1,-72(s0)
    39ee:  fe042603           lw a2,-32(s0)
    39f2:  fdc42503           lw a0,-36(s0)
    39f6:  882e                 mv a6,a1
    39f8:  000205b7           lui a1,0x20
    39fc:  4c7030ef           jal ra,76c2 <FUN_000076c2>
    3a00:  87aa                 mv a5,a0
    3a02:  873e                 mv a4,a5
    3a04:  4789                 li a5,2
    3a06:  00f71b63           bne a4,a5,3a1c <FUN_00003824+0x1f8>
    3a0a:  fe842783           lw a5,-24(s0)
    3a0e:  0f300613           li a2,243
    3a12:  85be                 mv a1,a5
    3a14:  4511                 li a0,4
    3a16:  213040ef           jal ra,8428 <rtc_brom_debug>
    3a1a:  a045                 j 3aba <FUN_00003824+0x296>
    3a1c:  fe442783           lw a5,-28(s0)
    3a20:  85be                 mv a1,a5
    3a22:  00020537           lui a0,0x20
    3a26:  491040ef           jal ra,86b6 <FUN_000086b6>
    3a2a:  87aa                 mv a5,a0
    3a2c:  efad                 bnez a5,3aa6 <FUN_00003824+0x282>
    3a2e:  000487b7           lui a5,0x48
    3a32:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3a36:  c395                 beqz a5,3a5a <FUN_00003824+0x236>
    3a38:  fe842783           lw a5,-24(s0)
    3a3c:  0ff7f793           andi a5,a5,255
    3a40:  0047979b           slliw a5,a5,0x4
    3a44:  0ff7f793           andi a5,a5,255
    3a48:  0047e793           ori a5,a5,4
    3a4c:  0ff7f713           andi a4,a5,255
    3a50:  fd043783           ld a5,-48(s0)
    3a54:  02e78023           sb a4,32(a5)
    3a58:  a00d                 j 3a7a <FUN_00003824+0x256>
    3a5a:  fe842783           lw a5,-24(s0)
    3a5e:  0ff7f793           andi a5,a5,255
    3a62:  0047979b           slliw a5,a5,0x4
    3a66:  0ff7f793           andi a5,a5,255
    3a6a:  0047e793           ori a5,a5,4
    3a6e:  0ff7f713           andi a4,a5,255
    3a72:  fc843783           ld a5,-56(s0)
    3a76:  02e78423           sb a4,40(a5)
    3a7a:  fec42703           lw a4,-20(s0)
    3a7e:  f9c42783           lw a5,-100(s0)
    3a82:  863a                 mv a2,a4
    3a84:  85be                 mv a1,a5
    3a86:  4511                 li a0,4
    3a88:  9dbff0ef           jal ra,3462 <FUN_00003462>
    3a8c:  fe842703           lw a4,-24(s0)
    3a90:  6785                 lui a5,0x1
    3a92:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    3a96:  85ba                 mv a1,a4
    3a98:  4511                 li a0,4
    3a9a:  18f040ef           jal ra,8428 <rtc_brom_debug>
    3a9e:  532030ef           jal ra,6fd0 <FUN_00006fd0>
    3aa2:  4781                 li a5,0
    3aa4:  a8a9                 j 3afe <FUN_00003824+0x2da>
    3aa6:  fe842783           lw a5,-24(s0)
    3aaa:  0f400613           li a2,244
    3aae:  85be                 mv a1,a5
    3ab0:  4511                 li a0,4
    3ab2:  177040ef           jal ra,8428 <rtc_brom_debug>
    3ab6:  a011                 j 3aba <FUN_00003824+0x296>
    3ab8:  0001                 nop
    3aba:  fdc42783           lw a5,-36(s0)
    3abe:  0407879b           addiw a5,a5,64
    3ac2:  fcf42e23           sw a5,-36(s0)
    3ac6:  fdc42783           lw a5,-36(s0)
    3aca:  0007871b           sext.w a4,a5
    3ace:  1ff00793           li a5,511
    3ad2:  d8e7fbe3           bgeu a5,a4,3868 <FUN_00003824+0x44>
    3ad6:  fec42783           lw a5,-20(s0)
    3ada:  2785                 addiw a5,a5,1
    3adc:  fef42623           sw a5,-20(s0)
    3ae0:  f9c42783           lw a5,-100(s0)
    3ae4:  2781                 sext.w a5,a5
    3ae6:  c399                 beqz a5,3aec <FUN_00003824+0x2c8>
    3ae8:  479d                 li a5,7
    3aea:  a011                 j 3aee <FUN_00003824+0x2ca>
    3aec:  4789                 li a5,2
    3aee:  fec42703           lw a4,-20(s0)
    3af2:  2701                 sext.w a4,a4
    3af4:  d6f763e3           bltu a4,a5,385a <FUN_00003824+0x36>
    3af8:  4d8030ef           jal ra,6fd0 <FUN_00006fd0>
    3afc:  57fd                 li a5,-1
    3afe:  853e                 mv a0,a5
    3b00:  70a6                 ld ra,104(sp)
    3b02:  7406                 ld s0,96(sp)
    3b04:  6165                 addi sp,sp,112
    3b06:  8082                 ret
0000000000003b08 <memset>:
    3b08:  1101                 addi sp,sp,-32
    3b0a:  ec06                 sd ra,24(sp)
    3b0c:  e822                 sd s0,16(sp)
    3b0e:  1000                 addi s0,sp,32
    3b10:  fea43423           sd a0,-24(s0)
    3b14:  87ae                 mv a5,a1
    3b16:  8732                 mv a4,a2
    3b18:  fef42223           sw a5,-28(s0)
    3b1c:  87ba                 mv a5,a4
    3b1e:  fef42023           sw a5,-32(s0)
    3b22:  fe442783           lw a5,-28(s0)
    3b26:  0ff7f793           andi a5,a5,255
    3b2a:  fe042703           lw a4,-32(s0)
    3b2e:  863a                 mv a2,a4
    3b30:  85be                 mv a1,a5
    3b32:  fe843503           ld a0,-24(s0)
    3b36:  3b4060ef           jal ra,9eea <memset>
    3b3a:  0001                 nop
    3b3c:  60e2                 ld ra,24(sp)
    3b3e:  6442                 ld s0,16(sp)
    3b40:  6105                 addi sp,sp,32
    3b42:  8082                 ret
0000000000003b44 <load_boot0_from_sd>:
    3b44:  7139                 addi sp,sp,-64
    3b46:  fc06                 sd ra,56(sp)
    3b48:  f822                 sd s0,48(sp)
    3b4a:  0080                 addi s0,sp,64
    3b4c:  87aa                 mv a5,a0
    3b4e:  872e                 mv a4,a1
    3b50:  fcc43023           sd a2,-64(s0)
    3b54:  fcf42623           sw a5,-52(s0)
    3b58:  87ba                 mv a5,a4
    3b5a:  fcf42423           sw a5,-56(s0)
    3b5e:  57fd                 li a5,-1
    3b60:  fef42623           sw a5,-20(s0)
    3b64:  fe042423           sw zero,-24(s0)
    3b68:  fe043023           sd zero,-32(s0)
    3b6c:  fc043c23           sd zero,-40(s0)
    3b70:  fc042a23           sw zero,-44(s0)
    3b74:  fc842783           lw a5,-56(s0)
    3b78:  2781                 sext.w a5,a5
    3b7a:  ef89                 bnez a5,3b94 <load_boot0_from_sd+0x50>
    3b7c:  00eff7b7           lui a5,0xeff
    3b80:  80078613           addi a2,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3b84:  4581                 li a1,0
    3b86:  4501                 li a0,0
    3b88:  0a1040ef           jal ra,8428 <rtc_brom_debug>
    3b8c:  47c1                 li a5,16
    3b8e:  fcf42a23           sw a5,-44(s0)
    3b92:  a81d                 j 3bc8 <load_boot0_from_sd+0x84>
    3b94:  fc842783           lw a5,-56(s0)
    3b98:  0007871b           sext.w a4,a5
    3b9c:  4785                 li a5,1
    3b9e:  00f71f63           bne a4,a5,3bbc <load_boot0_from_sd+0x78>
    3ba2:  00eff7b7           lui a5,0xeff
    3ba6:  80078613           addi a2,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3baa:  4585                 li a1,1
    3bac:  4501                 li a0,0
    3bae:  07b040ef           jal ra,8428 <rtc_brom_debug>
    3bb2:  10000793           li a5,256
    3bb6:  fcf42a23           sw a5,-44(s0)
    3bba:  a039                 j 3bc8 <load_boot0_from_sd+0x84>
    3bbc:  57fd                 li a5,-1
    3bbe:  fef42623           sw a5,-20(s0)
    3bc2:  fec42783           lw a5,-20(s0)
    3bc6:  ace9                 j 3ea0 <load_boot0_from_sd+0x35c>
    3bc8:  fd442783           lw a5,-44(s0)
    3bcc:  000206b7           lui a3,0x20
    3bd0:  4605                 li a2,1
    3bd2:  85be                 mv a1,a5
    3bd4:  fc043503           ld a0,-64(s0)
    3bd8:  3a1020ef           jal ra,6778 <sd_read_sectors>
    3bdc:  87aa                 mv a5,a0
    3bde:  2781                 sext.w a5,a5
    3be0:  873e                 mv a4,a5
    3be2:  4785                 li a5,1
    3be4:  04f70963           beq a4,a5,3c36 <load_boot0_from_sd+0xf2>
    3be8:  005b97b7           lui a5,0x5b9
    3bec:  d8078593           addi a1,a5,-640 # 5b8d80 <gpio_get_boot_device+0x5aa9ea>
    3bf0:  fc043503           ld a0,-64(s0)
    3bf4:  438020ef           jal ra,602c <FUN_0000602c>
    3bf8:  fd442783           lw a5,-44(s0)
    3bfc:  000206b7           lui a3,0x20
    3c00:  4605                 li a2,1
    3c02:  85be                 mv a1,a5
    3c04:  fc043503           ld a0,-64(s0)
    3c08:  371020ef           jal ra,6778 <sd_read_sectors>
    3c0c:  87aa                 mv a5,a0
    3c0e:  2781                 sext.w a5,a5
    3c10:  873e                 mv a4,a5
    3c12:  4785                 li a5,1
    3c14:  02f70163           beq a4,a5,3c36 <load_boot0_from_sd+0xf2>
    3c18:  0f000613           li a2,240
    3c1c:  00eff7b7           lui a5,0xeff
    3c20:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3c24:  4501                 li a0,0
    3c26:  003040ef           jal ra,8428 <rtc_brom_debug>
    3c2a:  57fd                 li a5,-1
    3c2c:  fef42623           sw a5,-20(s0)
    3c30:  fec42783           lw a5,-20(s0)
    3c34:  a4b5                 j 3ea0 <load_boot0_from_sd+0x35c>
    3c36:  000487b7           lui a5,0x48
    3c3a:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3c3e:  c3a5                 beqz a5,3c9e <load_boot0_from_sd+0x15a>
    3c40:  67b9                 lui a5,0xe
    3c42:  4c078593           addi a1,a5,1216 # e4c0 <gpio_get_boot_device+0x12a>
    3c46:  00020537           lui a0,0x20
    3c4a:  1c9040ef           jal ra,8612 <boot0_check_magic>
    3c4e:  87aa                 mv a5,a0
    3c50:  c385                 beqz a5,3c70 <load_boot0_from_sd+0x12c>
    3c52:  0f100613           li a2,241
    3c56:  00eff7b7           lui a5,0xeff
    3c5a:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3c5e:  4501                 li a0,0
    3c60:  7c8040ef           jal ra,8428 <rtc_brom_debug>
    3c64:  57fd                 li a5,-1
    3c66:  fef42623           sw a5,-20(s0)
    3c6a:  fec42783           lw a5,-20(s0)
    3c6e:  ac0d                 j 3ea0 <load_boot0_from_sd+0x35c>
    3c70:  000207b7           lui a5,0x20
    3c74:  fcf43c23           sd a5,-40(s0)
    3c78:  fd843783           ld a5,-40(s0)
    3c7c:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    3c80:  01d7c683           lbu a3,29(a5)
    3c84:  06a2                 slli a3,a3,0x8
    3c86:  8f55                 or a4,a4,a3
    3c88:  01e7c683           lbu a3,30(a5)
    3c8c:  06c2                 slli a3,a3,0x10
    3c8e:  8f55                 or a4,a4,a3
    3c90:  01f7c783           lbu a5,31(a5)
    3c94:  07e2                 slli a5,a5,0x18
    3c96:  8fd9                 or a5,a5,a4
    3c98:  fef42423           sw a5,-24(s0)
    3c9c:  a091                 j 3ce0 <load_boot0_from_sd+0x19c>
    3c9e:  67b9                 lui a5,0xe
    3ca0:  4d078593           addi a1,a5,1232 # e4d0 <gpio_get_boot_device+0x13a>
    3ca4:  00020537           lui a0,0x20
    3ca8:  16b040ef           jal ra,8612 <boot0_check_magic>
    3cac:  87aa                 mv a5,a0
    3cae:  c385                 beqz a5,3cce <load_boot0_from_sd+0x18a>
    3cb0:  0f100613           li a2,241
    3cb4:  00eff7b7           lui a5,0xeff
    3cb8:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3cbc:  4501                 li a0,0
    3cbe:  76a040ef           jal ra,8428 <rtc_brom_debug>
    3cc2:  57fd                 li a5,-1
    3cc4:  fef42623           sw a5,-20(s0)
    3cc8:  fec42783           lw a5,-20(s0)
    3ccc:  aad1                 j 3ea0 <load_boot0_from_sd+0x35c>
    3cce:  000207b7           lui a5,0x20
    3cd2:  fef43023           sd a5,-32(s0)
    3cd6:  fe043783           ld a5,-32(s0)
    3cda:  4b9c                 lw a5,16(a5)
    3cdc:  fef42423           sw a5,-24(s0)
    3ce0:  fe842783           lw a5,-24(s0)
    3ce4:  1ff7f793           andi a5,a5,511
    3ce8:  2781                 sext.w a5,a5
    3cea:  c385                 beqz a5,3d0a <load_boot0_from_sd+0x1c6>
    3cec:  0f200613           li a2,242
    3cf0:  00eff7b7           lui a5,0xeff
    3cf4:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3cf8:  4501                 li a0,0
    3cfa:  72e040ef           jal ra,8428 <rtc_brom_debug>
    3cfe:  57fd                 li a5,-1
    3d00:  fef42623           sw a5,-20(s0)
    3d04:  fec42783           lw a5,-20(s0)
    3d08:  aa61                 j 3ea0 <load_boot0_from_sd+0x35c>
    3d0a:  fe842783           lw a5,-24(s0)
    3d0e:  0097d79b           srliw a5,a5,0x9
    3d12:  0007871b           sext.w a4,a5
    3d16:  fd442783           lw a5,-44(s0)
    3d1a:  000206b7           lui a3,0x20
    3d1e:  863a                 mv a2,a4
    3d20:  85be                 mv a1,a5
    3d22:  fc043503           ld a0,-64(s0)
    3d26:  253020ef           jal ra,6778 <sd_read_sectors>
    3d2a:  87aa                 mv a5,a0
    3d2c:  0007871b           sext.w a4,a5
    3d30:  fe842783           lw a5,-24(s0)
    3d34:  0097d79b           srliw a5,a5,0x9
    3d38:  2781                 sext.w a5,a5
    3d3a:  06f70363           beq a4,a5,3da0 <load_boot0_from_sd+0x25c>
    3d3e:  005b97b7           lui a5,0x5b9
    3d42:  d8078593           addi a1,a5,-640 # 5b8d80 <gpio_get_boot_device+0x5aa9ea>
    3d46:  fc043503           ld a0,-64(s0)
    3d4a:  2e2020ef           jal ra,602c <FUN_0000602c>
    3d4e:  fe842783           lw a5,-24(s0)
    3d52:  0097d79b           srliw a5,a5,0x9
    3d56:  0007871b           sext.w a4,a5
    3d5a:  fd442783           lw a5,-44(s0)
    3d5e:  000206b7           lui a3,0x20
    3d62:  863a                 mv a2,a4
    3d64:  85be                 mv a1,a5
    3d66:  fc043503           ld a0,-64(s0)
    3d6a:  20f020ef           jal ra,6778 <sd_read_sectors>
    3d6e:  87aa                 mv a5,a0
    3d70:  0007871b           sext.w a4,a5
    3d74:  fe842783           lw a5,-24(s0)
    3d78:  0097d79b           srliw a5,a5,0x9
    3d7c:  2781                 sext.w a5,a5
    3d7e:  02f70163           beq a4,a5,3da0 <load_boot0_from_sd+0x25c>
    3d82:  0f300613           li a2,243
    3d86:  00eff7b7           lui a5,0xeff
    3d8a:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3d8e:  4501                 li a0,0
    3d90:  698040ef           jal ra,8428 <rtc_brom_debug>
    3d94:  57fd                 li a5,-1
    3d96:  fef42623           sw a5,-20(s0)
    3d9a:  fec42783           lw a5,-20(s0)
    3d9e:  a209                 j 3ea0 <load_boot0_from_sd+0x35c>
    3da0:  fe842783           lw a5,-24(s0)
    3da4:  85be                 mv a1,a5
    3da6:  00020537           lui a0,0x20
    3daa:  10d040ef           jal ra,86b6 <FUN_000086b6>
    3dae:  87aa                 mv a5,a0
    3db0:  ebf1                 bnez a5,3e84 <load_boot0_from_sd+0x340>
    3db2:  fcc42783           lw a5,-52(s0)
    3db6:  2781                 sext.w a5,a5
    3db8:  e385                 bnez a5,3dd8 <load_boot0_from_sd+0x294>
    3dba:  000487b7           lui a5,0x48
    3dbe:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3dc2:  c791                 beqz a5,3dce <load_boot0_from_sd+0x28a>
    3dc4:  fd843783           ld a5,-40(s0)
    3dc8:  02078023           sb zero,32(a5)
    3dcc:  a82d                 j 3e06 <load_boot0_from_sd+0x2c2>
    3dce:  fe043783           ld a5,-32(s0)
    3dd2:  02078423           sb zero,40(a5)
    3dd6:  a805                 j 3e06 <load_boot0_from_sd+0x2c2>
    3dd8:  fcc42783           lw a5,-52(s0)
    3ddc:  0007871b           sext.w a4,a5
    3de0:  4789                 li a5,2
    3de2:  02f71263           bne a4,a5,3e06 <load_boot0_from_sd+0x2c2>
    3de6:  000487b7           lui a5,0x48
    3dea:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3dee:  c799                 beqz a5,3dfc <load_boot0_from_sd+0x2b8>
    3df0:  fd843783           ld a5,-40(s0)
    3df4:  4709                 li a4,2
    3df6:  02e78023           sb a4,32(a5)
    3dfa:  a031                 j 3e06 <load_boot0_from_sd+0x2c2>
    3dfc:  fe043783           ld a5,-32(s0)
    3e00:  4709                 li a4,2
    3e02:  02e78423           sb a4,40(a5)
    3e06:  000487b7           lui a5,0x48
    3e0a:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    3e0e:  c78d                 beqz a5,3e38 <load_boot0_from_sd+0x2f4>
    3e10:  fd843783           ld a5,-40(s0)
    3e14:  0207c703           lbu a4,32(a5)
    3e18:  fc842783           lw a5,-56(s0)
    3e1c:  0ff7f793           andi a5,a5,255
    3e20:  0047979b           slliw a5,a5,0x4
    3e24:  0ff7f793           andi a5,a5,255
    3e28:  8fd9                 or a5,a5,a4
    3e2a:  0ff7f713           andi a4,a5,255
    3e2e:  fd843783           ld a5,-40(s0)
    3e32:  02e78023           sb a4,32(a5)
    3e36:  a025                 j 3e5e <load_boot0_from_sd+0x31a>
    3e38:  fe043783           ld a5,-32(s0)
    3e3c:  0287c703           lbu a4,40(a5)
    3e40:  fc842783           lw a5,-56(s0)
    3e44:  0ff7f793           andi a5,a5,255
    3e48:  0047979b           slliw a5,a5,0x4
    3e4c:  0ff7f793           andi a5,a5,255
    3e50:  8fd9                 or a5,a5,a4
    3e52:  0ff7f713           andi a4,a5,255
    3e56:  fe043783           ld a5,-32(s0)
    3e5a:  02e78423           sb a4,40(a5)
    3e5e:  fcc42783           lw a5,-52(s0)
    3e62:  4581                 li a1,0
    3e64:  853e                 mv a0,a5
    3e66:  407050ef           jal ra,9a6c <FUN_00009a6c>
    3e6a:  6785                 lui a5,0x1
    3e6c:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    3e70:  00eff7b7           lui a5,0xeff
    3e74:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3e78:  4501                 li a0,0
    3e7a:  5ae040ef           jal ra,8428 <rtc_brom_debug>
    3e7e:  fe042623           sw zero,-20(s0)
    3e82:  a829                 j 3e9c <load_boot0_from_sd+0x358>
    3e84:  0f400613           li a2,244
    3e88:  00eff7b7           lui a5,0xeff
    3e8c:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3e90:  4501                 li a0,0
    3e92:  596040ef           jal ra,8428 <rtc_brom_debug>
    3e96:  57fd                 li a5,-1
    3e98:  fef42623           sw a5,-20(s0)
    3e9c:  fec42783           lw a5,-20(s0)
    3ea0:  853e                 mv a0,a5
    3ea2:  70e2                 ld ra,56(sp)
    3ea4:  7442                 ld s0,48(sp)
    3ea6:  6121                 addi sp,sp,64
    3ea8:  8082                 ret
0000000000003eaa <boot_from_sd>:
    3eaa:  7171                 addi sp,sp,-176
    3eac:  f506                 sd ra,168(sp)
    3eae:  f122                 sd s0,160(sp)
    3eb0:  1900                 addi s0,sp,176
    3eb2:  87aa                 mv a5,a0
    3eb4:  f4f42e23           sw a5,-164(s0)
    3eb8:  57fd                 li a5,-1
    3eba:  fef42623           sw a5,-20(s0)
    3ebe:  070907b7           lui a5,0x7090
    3ec2:  31478513           addi a0,a5,788 # 7090314 <gpio_get_boot_device+0x7081f7e
    3ec6:  4c2040ef           jal ra,8388 <debug_select_word>
    3eca:  f9040793           addi a5,s0,-112
    3ece:  05800613           li a2,88
    3ed2:  4581                 li a1,0
    3ed4:  853e                 mv a0,a5
    3ed6:  c33ff0ef           jal ra,3b08 <memset>
    3eda:  f6840793           addi a5,s0,-152
    3ede:  02800613           li a2,40
    3ee2:  4581                 li a1,0
    3ee4:  853e                 mv a0,a5
    3ee6:  c23ff0ef           jal ra,3b08 <memset>
    3eea:  f6840793           addi a5,s0,-152
    3eee:  f8f43823           sd a5,-112(s0)
    3ef2:  f9040713           addi a4,s0,-112
    3ef6:  f5c42783           lw a5,-164(s0)
    3efa:  85ba                 mv a1,a4
    3efc:  853e                 mv a0,a5
    3efe:  331020ef           jal ra,6a2e <FUN_00006a2e>
    3f02:  87aa                 mv a5,a0
    3f04:  fef42623           sw a5,-20(s0)
    3f08:  fec42783           lw a5,-20(s0)
    3f0c:  2781                 sext.w a5,a5
    3f0e:  cf89                 beqz a5,3f28 <boot_from_sd+0x7e>
    3f10:  4605                 li a2,1
    3f12:  00eff7b7           lui a5,0xeff
    3f16:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3f1a:  4501                 li a0,0
    3f1c:  50c040ef           jal ra,8428 <rtc_brom_debug>
    3f20:  57fd                 li a5,-1
    3f22:  fef42623           sw a5,-20(s0)
    3f26:  a83d                 j 3f64 <boot_from_sd+0xba>
    3f28:  f9040713           addi a4,s0,-112
    3f2c:  f5c42783           lw a5,-164(s0)
    3f30:  863a                 mv a2,a4
    3f32:  4581                 li a1,0
    3f34:  853e                 mv a0,a5
    3f36:  c0fff0ef           jal ra,3b44 <load_boot0_from_sd>
    3f3a:  87aa                 mv a5,a0
    3f3c:  fef42623           sw a5,-20(s0)
    3f40:  fec42783           lw a5,-20(s0)
    3f44:  2781                 sext.w a5,a5
    3f46:  cf91                 beqz a5,3f62 <boot_from_sd+0xb8>
    3f48:  f9040713           addi a4,s0,-112
    3f4c:  f5c42783           lw a5,-164(s0)
    3f50:  863a                 mv a2,a4
    3f52:  4585                 li a1,1
    3f54:  853e                 mv a0,a5
    3f56:  befff0ef           jal ra,3b44 <load_boot0_from_sd>
    3f5a:  87aa                 mv a5,a0
    3f5c:  fef42623           sw a5,-20(s0)
    3f60:  a011                 j 3f64 <boot_from_sd+0xba>
    3f62:  0001                 nop
    3f64:  f9040713           addi a4,s0,-112
    3f68:  f5c42783           lw a5,-164(s0)
    3f6c:  85ba                 mv a1,a4
    3f6e:  853e                 mv a0,a5
    3f70:  3d9020ef           jal ra,6b48 <FUN_00006b48>
    3f74:  fec42783           lw a5,-20(s0)
    3f78:  853e                 mv a0,a5
    3f7a:  70aa                 ld ra,168(sp)
    3f7c:  740a                 ld s0,160(sp)
    3f7e:  614d                 addi sp,sp,176
    3f80:  8082                 ret
0000000000003f82 <boot_from_emmc>:
    3f82:  7131                 addi sp,sp,-192
    3f84:  fd06                 sd ra,184(sp)
    3f86:  f922                 sd s0,176(sp)
    3f88:  0180                 addi s0,sp,192
    3f8a:  87aa                 mv a5,a0
    3f8c:  f4f42623           sw a5,-180(s0)
    3f90:  57fd                 li a5,-1
    3f92:  fef42623           sw a5,-20(s0)
    3f96:  fc043c23           sd zero,-40(s0)
    3f9a:  070907b7           lui a5,0x7090
    3f9e:  31878513           addi a0,a5,792 # 7090318 <gpio_get_boot_device+0x7081f82
    3fa2:  3e6040ef           jal ra,8388 <debug_select_word>
    3fa6:  f8040793           addi a5,s0,-128
    3faa:  05800613           li a2,88
    3fae:  4581                 li a1,0
    3fb0:  853e                 mv a0,a5
    3fb2:  b57ff0ef           jal ra,3b08 <memset>
    3fb6:  f5840793           addi a5,s0,-168
    3fba:  02800613           li a2,40
    3fbe:  4581                 li a1,0
    3fc0:  853e                 mv a0,a5
    3fc2:  b47ff0ef           jal ra,3b08 <memset>
    3fc6:  f5840793           addi a5,s0,-168
    3fca:  f8f43023           sd a5,-128(s0)
    3fce:  f8040713           addi a4,s0,-128
    3fd2:  f4c42783           lw a5,-180(s0)
    3fd6:  85ba                 mv a1,a4
    3fd8:  853e                 mv a0,a5
    3fda:  2d7020ef           jal ra,6ab0 <FUN_00006ab0>
    3fde:  87aa                 mv a5,a0
    3fe0:  cf89                 beqz a5,3ffa <boot_from_emmc+0x78>
    3fe2:  4605                 li a2,1
    3fe4:  00eff7b7           lui a5,0xeff
    3fe8:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    3fec:  4515                 li a0,5
    3fee:  43a040ef           jal ra,8428 <rtc_brom_debug>
    3ff2:  57fd                 li a5,-1
    3ff4:  fef42623           sw a5,-20(s0)
    3ff8:  aacd                 j 41ea <boot_from_emmc+0x268>
    3ffa:  f8040793           addi a5,s0,-128
    3ffe:  000206b7           lui a3,0x20
    4002:  4605                 li a2,1
    4004:  4581                 li a1,0
    4006:  853e                 mv a0,a5
    4008:  03f020ef           jal ra,6846 <FUN_00006846>
    400c:  87aa                 mv a5,a0
    400e:  2781                 sext.w a5,a5
    4010:  873e                 mv a4,a5
    4012:  4785                 li a5,1
    4014:  00f70f63           beq a4,a5,4032 <boot_from_emmc+0xb0>
    4018:  0f000613           li a2,240
    401c:  00eff7b7           lui a5,0xeff
    4020:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    4024:  4515                 li a0,5
    4026:  402040ef           jal ra,8428 <rtc_brom_debug>
    402a:  57fd                 li a5,-1
    402c:  fef42623           sw a5,-20(s0)
    4030:  aa6d                 j 41ea <boot_from_emmc+0x268>
    4032:  000487b7           lui a5,0x48
    4036:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    403a:  c3a5                 beqz a5,409a <boot_from_emmc+0x118>
    403c:  67b9                 lui a5,0xe
    403e:  4c078593           addi a1,a5,1216 # e4c0 <gpio_get_boot_device+0x12a>
    4042:  00020537           lui a0,0x20
    4046:  5cc040ef           jal ra,8612 <boot0_check_magic>
    404a:  87aa                 mv a5,a0
    404c:  c385                 beqz a5,406c <boot_from_emmc+0xea>
    404e:  0f100613           li a2,241
    4052:  00eff7b7           lui a5,0xeff
    4056:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    405a:  4515                 li a0,5
    405c:  3cc040ef           jal ra,8428 <rtc_brom_debug>
    4060:  57fd                 li a5,-1
    4062:  fef42623           sw a5,-20(s0)
    4066:  fec42783           lw a5,-20(s0)
    406a:  aa51                 j 41fe <boot_from_emmc+0x27c>
    406c:  000207b7           lui a5,0x20
    4070:  fcf43c23           sd a5,-40(s0)
    4074:  fd843783           ld a5,-40(s0)
    4078:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    407c:  01d7c683           lbu a3,29(a5)
    4080:  06a2                 slli a3,a3,0x8
    4082:  8f55                 or a4,a4,a3
    4084:  01e7c683           lbu a3,30(a5)
    4088:  06c2                 slli a3,a3,0x10
    408a:  8f55                 or a4,a4,a3
    408c:  01f7c783           lbu a5,31(a5)
    4090:  07e2                 slli a5,a5,0x18
    4092:  8fd9                 or a5,a5,a4
    4094:  fef42423           sw a5,-24(s0)
    4098:  a081                 j 40d8 <boot_from_emmc+0x156>
    409a:  67b9                 lui a5,0xe
    409c:  4d078593           addi a1,a5,1232 # e4d0 <gpio_get_boot_device+0x13a>
    40a0:  00020537           lui a0,0x20
    40a4:  56e040ef           jal ra,8612 <boot0_check_magic>
    40a8:  87aa                 mv a5,a0
    40aa:  cf91                 beqz a5,40c6 <boot_from_emmc+0x144>
    40ac:  0f100613           li a2,241
    40b0:  00eff7b7           lui a5,0xeff
    40b4:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    40b8:  4515                 li a0,5
    40ba:  36e040ef           jal ra,8428 <rtc_brom_debug>
    40be:  57fd                 li a5,-1
    40c0:  fef42623           sw a5,-20(s0)
    40c4:  a21d                 j 41ea <boot_from_emmc+0x268>
    40c6:  000207b7           lui a5,0x20
    40ca:  fef43023           sd a5,-32(s0)
    40ce:  fe043783           ld a5,-32(s0)
    40d2:  4b9c                 lw a5,16(a5)
    40d4:  fef42423           sw a5,-24(s0)
    40d8:  fe842783           lw a5,-24(s0)
    40dc:  1ff7f793           andi a5,a5,511
    40e0:  2781                 sext.w a5,a5
    40e2:  cf91                 beqz a5,40fe <boot_from_emmc+0x17c>
    40e4:  0f200613           li a2,242
    40e8:  00eff7b7           lui a5,0xeff
    40ec:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    40f0:  4515                 li a0,5
    40f2:  336040ef           jal ra,8428 <rtc_brom_debug>
    40f6:  57fd                 li a5,-1
    40f8:  fef42623           sw a5,-20(s0)
    40fc:  a0fd                 j 41ea <boot_from_emmc+0x268>
    40fe:  fe842783           lw a5,-24(s0)
    4102:  0097d79b           srliw a5,a5,0x9
    4106:  0007871b           sext.w a4,a5
    410a:  f8040793           addi a5,s0,-128
    410e:  000206b7           lui a3,0x20
    4112:  863a                 mv a2,a4
    4114:  4581                 li a1,0
    4116:  853e                 mv a0,a5
    4118:  72e020ef           jal ra,6846 <FUN_00006846>
    411c:  87aa                 mv a5,a0
    411e:  0007871b           sext.w a4,a5
    4122:  fe842783           lw a5,-24(s0)
    4126:  0097d79b           srliw a5,a5,0x9
    412a:  2781                 sext.w a5,a5
    412c:  00f70f63           beq a4,a5,414a <boot_from_emmc+0x1c8>
    4130:  0f300613           li a2,243
    4134:  00eff7b7           lui a5,0xeff
    4138:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    413c:  4515                 li a0,5
    413e:  2ea040ef           jal ra,8428 <rtc_brom_debug>
    4142:  57fd                 li a5,-1
    4144:  fef42623           sw a5,-20(s0)
    4148:  a04d                 j 41ea <boot_from_emmc+0x268>
    414a:  fe842783           lw a5,-24(s0)
    414e:  85be                 mv a1,a5
    4150:  00020537           lui a0,0x20
    4154:  562040ef           jal ra,86b6 <FUN_000086b6>
    4158:  87aa                 mv a5,a0
    415a:  efa5                 bnez a5,41d2 <boot_from_emmc+0x250>
    415c:  f4c42783           lw a5,-180(s0)
    4160:  2781                 sext.w a5,a5
    4162:  e385                 bnez a5,4182 <boot_from_emmc+0x200>
    4164:  000487b7           lui a5,0x48
    4168:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    416c:  c791                 beqz a5,4178 <boot_from_emmc+0x1f6>
    416e:  fd843783           ld a5,-40(s0)
    4172:  02078023           sb zero,32(a5)
    4176:  a82d                 j 41b0 <boot_from_emmc+0x22e>
    4178:  fe043783           ld a5,-32(s0)
    417c:  02078423           sb zero,40(a5)
    4180:  a805                 j 41b0 <boot_from_emmc+0x22e>
    4182:  f4c42783           lw a5,-180(s0)
    4186:  0007871b           sext.w a4,a5
    418a:  4789                 li a5,2
    418c:  02f71263           bne a4,a5,41b0 <boot_from_emmc+0x22e>
    4190:  000487b7           lui a5,0x48
    4194:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    4198:  c799                 beqz a5,41a6 <boot_from_emmc+0x224>
    419a:  fd843783           ld a5,-40(s0)
    419e:  4709                 li a4,2
    41a0:  02e78023           sb a4,32(a5)
    41a4:  a031                 j 41b0 <boot_from_emmc+0x22e>
    41a6:  fe043783           ld a5,-32(s0)
    41aa:  4709                 li a4,2
    41ac:  02e78423           sb a4,40(a5)
    41b0:  4581                 li a1,0
    41b2:  4515                 li a0,5
    41b4:  0b9050ef           jal ra,9a6c <FUN_00009a6c>
    41b8:  6785                 lui a5,0x1
    41ba:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    41be:  00eff7b7           lui a5,0xeff
    41c2:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    41c6:  4515                 li a0,5
    41c8:  260040ef           jal ra,8428 <rtc_brom_debug>
    41cc:  fe042623           sw zero,-20(s0)
    41d0:  a829                 j 41ea <boot_from_emmc+0x268>
    41d2:  0f400613           li a2,244
    41d6:  00eff7b7           lui a5,0xeff
    41da:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    41de:  4515                 li a0,5
    41e0:  248040ef           jal ra,8428 <rtc_brom_debug>
    41e4:  57fd                 li a5,-1
    41e6:  fef42623           sw a5,-20(s0)
    41ea:  f8040713           addi a4,s0,-128
    41ee:  f4c42783           lw a5,-180(s0)
    41f2:  85ba                 mv a1,a4
    41f4:  853e                 mv a0,a5
    41f6:  153020ef           jal ra,6b48 <FUN_00006b48>
    41fa:  fec42783           lw a5,-20(s0)
    41fe:  853e                 mv a0,a5
    4200:  70ea                 ld ra,184(sp)
    4202:  744a                 ld s0,176(sp)
    4204:  6129                 addi sp,sp,192
    4206:  8082                 ret
0000000000004208 <FUN_00004208>:
    4208:  7179                 addi sp,sp,-48
    420a:  f422                 sd s0,40(sp)
    420c:  1800                 addi s0,sp,48
    420e:  fca43c23           sd a0,-40(s0)
    4212:  fe042623           sw zero,-20(s0)
    4216:  fd843783           ld a5,-40(s0)
    421a:  0007ac23           sw zero,24(a5)
    421e:  fd843783           ld a5,-40(s0)
    4222:  016e3737           lui a4,0x16e3
    4226:  6007071b           addiw a4,a4,1536
    422a:  cbd8                 sw a4,20(a5)
    422c:  fec42783           lw a5,-20(s0)
    4230:  853e                 mv a0,a5
    4232:  7422                 ld s0,40(sp)
    4234:  6145                 addi sp,sp,48
    4236:  8082                 ret
0000000000004238 <FUN_00004238>:
    4238:  7179                 addi sp,sp,-48
    423a:  f422                 sd s0,40(sp)
    423c:  1800                 addi s0,sp,48
    423e:  fca43c23           sd a0,-40(s0)
    4242:  fcb43823           sd a1,-48(s0)
    4246:  fd043703           ld a4,-48(s0)
    424a:  6799                 lui a5,0x6
    424c:  dc078793           addi a5,a5,-576 # 5dc0 <FUN_00005d2c+0x94>
    4250:  02f707b3           mul a5,a4,a5
    4254:  fef43423           sd a5,-24(s0)
    4258:  fe843783           ld a5,-24(s0)
    425c:  853e                 mv a0,a5
    425e:  7422                 ld s0,40(sp)
    4260:  6145                 addi sp,sp,48
    4262:  8082                 ret
0000000000004264 <FUN_00004264>:
    4264:  1101                 addi sp,sp,-32
    4266:  ec06                 sd ra,24(sp)
    4268:  e822                 sd s0,16(sp)
    426a:  1000                 addi s0,sp,32
    426c:  87aa                 mv a5,a0
    426e:  feb43023           sd a1,-32(s0)
    4272:  fef42623           sw a5,-20(s0)
    4276:  fec42783           lw a5,-20(s0)
    427a:  0007871b           sext.w a4,a5
    427e:  4789                 li a5,2
    4280:  0af71663           bne a4,a5,432c <FUN_00004264+0xc8>
    4284:  020007b7           lui a5,0x2000
    4288:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    428c:  6715                 lui a4,0x5
    428e:  5607071b           addiw a4,a4,1376
    4292:  c398                 sw a4,0(a5)
    4294:  020007b7           lui a5,0x2000
    4298:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    429c:  33333737           lui a4,0x33333
    42a0:  3ff7071b           addiw a4,a4,1023
    42a4:  c398                 sw a4,0(a5)
    42a6:  020027b7           lui a5,0x2002
    42aa:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    42ae:  439c                 lw a5,0(a5)
    42b0:  0007871b           sext.w a4,a5
    42b4:  020027b7           lui a5,0x2002
    42b8:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    42bc:  86ba                 mv a3,a4
    42be:  00040737           lui a4,0x40
    42c2:  8f55                 or a4,a4,a3
    42c4:  2701                 sext.w a4,a4
    42c6:  c398                 sw a4,0(a5)
    42c8:  020027b7           lui a5,0x2002
    42cc:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    42d0:  439c                 lw a5,0(a5)
    42d2:  0007871b           sext.w a4,a5
    42d6:  020027b7           lui a5,0x2002
    42da:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    42de:  00476713           ori a4,a4,4
    42e2:  2701                 sext.w a4,a4
    42e4:  c398                 sw a4,0(a5)
    42e6:  020027b7           lui a5,0x2002
    42ea:  83878793           addi a5,a5,-1992 # 2001838 <gpio_get_boot_device+0x1ff34
    42ee:  80000737           lui a4,0x80000
    42f2:  c398                 sw a4,0(a5)
    42f4:  fe043783           ld a5,-32(s0)
    42f8:  04022737           lui a4,0x4022
    42fc:  e398                 sd a4,0(a5)
    42fe:  fe043783           ld a5,-32(s0)
    4302:  639c                 ld a5,0(a5)
    4304:  2781                 sext.w a5,a5
    4306:  2007879b           addiw a5,a5,512
    430a:  0007871b           sext.w a4,a5
    430e:  fe043783           ld a5,-32(s0)
    4312:  cfd8                 sw a4,28(a5)
    4314:  fe043783           ld a5,-32(s0)
    4318:  02002737           lui a4,0x2002
    431c:  8387071b           addiw a4,a4,-1992
    4320:  cb98                 sw a4,16(a5)
    4322:  fe043503           ld a0,-32(s0)
    4326:  ee3ff0ef           jal ra,4208 <FUN_00004208>
    432a:  a055                 j 43ce <FUN_00004264+0x16a>
    432c:  020007b7           lui a5,0x2000
    4330:  11478793           addi a5,a5,276 # 2000114 <gpio_get_boot_device+0x1ff1d7e
    4334:  56500713           li a4,1381
    4338:  c398                 sw a4,0(a5)
    433a:  020007b7           lui a5,0x2000
    433e:  0f078793           addi a5,a5,240 # 20000f0 <gpio_get_boot_device+0x1ff1d5a
    4342:  00222737           lui a4,0x222
    4346:  2227071b           addiw a4,a4,546
    434a:  c398                 sw a4,0(a5)
    434c:  020027b7           lui a5,0x2002
    4350:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    4354:  439c                 lw a5,0(a5)
    4356:  0007871b           sext.w a4,a5
    435a:  020027b7           lui a5,0x2002
    435e:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    4362:  86ba                 mv a3,a4
    4364:  6741                 lui a4,0x10
    4366:  8f55                 or a4,a4,a3
    4368:  2701                 sext.w a4,a4
    436a:  c398                 sw a4,0(a5)
    436c:  020027b7           lui a5,0x2002
    4370:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    4374:  439c                 lw a5,0(a5)
    4376:  0007871b           sext.w a4,a5
    437a:  020027b7           lui a5,0x2002
    437e:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    4382:  00176713           ori a4,a4,1
    4386:  2701                 sext.w a4,a4
    4388:  c398                 sw a4,0(a5)
    438a:  020027b7           lui a5,0x2002
    438e:  83078793           addi a5,a5,-2000 # 2001830 <gpio_get_boot_device+0x1ff34
    4392:  80000737           lui a4,0x80000
    4396:  c398                 sw a4,0(a5)
    4398:  fe043783           ld a5,-32(s0)
    439c:  04020737           lui a4,0x4020
    43a0:  e398                 sd a4,0(a5)
    43a2:  fe043783           ld a5,-32(s0)
    43a6:  639c                 ld a5,0(a5)
    43a8:  2781                 sext.w a5,a5
    43aa:  2007879b           addiw a5,a5,512
    43ae:  0007871b           sext.w a4,a5
    43b2:  fe043783           ld a5,-32(s0)
    43b6:  cfd8                 sw a4,28(a5)
    43b8:  fe043783           ld a5,-32(s0)
    43bc:  02002737           lui a4,0x2002
    43c0:  8307071b           addiw a4,a4,-2000
    43c4:  cb98                 sw a4,16(a5)
    43c6:  fe043503           ld a0,-32(s0)
    43ca:  e3fff0ef           jal ra,4208 <FUN_00004208>
    43ce:  fe043783           ld a5,-32(s0)
    43d2:  00045737           lui a4,0x45
    43d6:  e798                 sd a4,8(a5)
    43d8:  0001                 nop
    43da:  60e2                 ld ra,24(sp)
    43dc:  6442                 ld s0,16(sp)
    43de:  6105                 addi sp,sp,32
    43e0:  8082                 ret
00000000000043e2 <FUN_000043e2>:
    43e2:  1101                 addi sp,sp,-32
    43e4:  ec22                 sd s0,24(sp)
    43e6:  1000                 addi s0,sp,32
    43e8:  87aa                 mv a5,a0
    43ea:  feb43023           sd a1,-32(s0)
    43ee:  fef42623           sw a5,-20(s0)
    43f2:  fec42783           lw a5,-20(s0)
    43f6:  0007871b           sext.w a4,a5
    43fa:  4789                 li a5,2
    43fc:  06f71663           bne a4,a5,4468 <FUN_000043e2+0x86>
    4400:  020007b7           lui a5,0x2000
    4404:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    4408:  577d                 li a4,-1
    440a:  c398                 sw a4,0(a5)
    440c:  020007b7           lui a5,0x2000
    4410:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    4414:  54000713           li a4,1344
    4418:  c398                 sw a4,0(a5)
    441a:  020027b7           lui a5,0x2002
    441e:  83878793           addi a5,a5,-1992 # 2001838 <gpio_get_boot_device+0x1ff34
    4422:  0007a023           sw zero,0(a5)
    4426:  020027b7           lui a5,0x2002
    442a:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    442e:  439c                 lw a5,0(a5)
    4430:  0007871b           sext.w a4,a5
    4434:  020027b7           lui a5,0x2002
    4438:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    443c:  9b6d                 andi a4,a4,-5
    443e:  2701                 sext.w a4,a4
    4440:  c398                 sw a4,0(a5)
    4442:  020027b7           lui a5,0x2002
    4446:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    444a:  439c                 lw a5,0(a5)
    444c:  0007871b           sext.w a4,a5
    4450:  020027b7           lui a5,0x2002
    4454:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    4458:  86ba                 mv a3,a4
    445a:  fffc0737           lui a4,0xfffc0
    445e:  177d                 addi a4,a4,-1
    4460:  8f75                 and a4,a4,a3
    4462:  2701                 sext.w a4,a4
    4464:  c398                 sw a4,0(a5)
    4466:  a0ad                 j 44d0 <FUN_000043e2+0xee>
    4468:  020007b7           lui a5,0x2000
    446c:  0f078793           addi a5,a5,240 # 20000f0 <gpio_get_boot_device+0x1ff1d5a
    4470:  0f4f5737           lui a4,0xf4f5
    4474:  f447071b           addiw a4,a4,-188
    4478:  c398                 sw a4,0(a5)
    447a:  020007b7           lui a5,0x2000
    447e:  11478793           addi a5,a5,276 # 2000114 <gpio_get_boot_device+0x1ff1d7e
    4482:  0007a023           sw zero,0(a5)
    4486:  020027b7           lui a5,0x2002
    448a:  83078793           addi a5,a5,-2000 # 2001830 <gpio_get_boot_device+0x1ff34
    448e:  0007a023           sw zero,0(a5)
    4492:  020027b7           lui a5,0x2002
    4496:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    449a:  439c                 lw a5,0(a5)
    449c:  0007871b           sext.w a4,a5
    44a0:  020027b7           lui a5,0x2002
    44a4:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    44a8:  9b79                 andi a4,a4,-2
    44aa:  2701                 sext.w a4,a4
    44ac:  c398                 sw a4,0(a5)
    44ae:  020027b7           lui a5,0x2002
    44b2:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    44b6:  439c                 lw a5,0(a5)
    44b8:  0007871b           sext.w a4,a5
    44bc:  020027b7           lui a5,0x2002
    44c0:  84c78793           addi a5,a5,-1972 # 200184c <gpio_get_boot_device+0x1ff34
    44c4:  86ba                 mv a3,a4
    44c6:  7741                 lui a4,0xffff0
    44c8:  177d                 addi a4,a4,-1
    44ca:  8f75                 and a4,a4,a3
    44cc:  2701                 sext.w a4,a4
    44ce:  c398                 sw a4,0(a5)
    44d0:  0001                 nop
    44d2:  6462                 ld s0,24(sp)
    44d4:  6105                 addi sp,sp,32
    44d6:  8082                 ret
00000000000044d8 <FUN_000044d8>:
    44d8:  715d                 addi sp,sp,-80
    44da:  e486                 sd ra,72(sp)
    44dc:  e0a2                 sd s0,64(sp)
    44de:  fc26                 sd s1,56(sp)
    44e0:  0880                 addi s0,sp,80
    44e2:  faa43c23           sd a0,-72(s0)
    44e6:  fb843783           ld a5,-72(s0)
    44ea:  639c                 ld a5,0(a5)
    44ec:  fcf43823           sd a5,-48(s0)
    44f0:  fd043783           ld a5,-48(s0)
    44f4:  639c                 ld a5,0(a5)
    44f6:  fcf43423           sd a5,-56(s0)
    44fa:  fc042e23           sw zero,-36(s0)
    44fe:  fc843783           ld a5,-56(s0)
    4502:  43dc                 lw a5,4(a5)
    4504:  2781                 sext.w a5,a5
    4506:  873e                 mv a4,a5
    4508:  800007b7           lui a5,0x80000
    450c:  8fd9                 or a5,a5,a4
    450e:  0007871b           sext.w a4,a5
    4512:  fc843783           ld a5,-56(s0)
    4516:  c3d8                 sw a4,4(a5)
    4518:  802027b7           lui a5,0x80202
    451c:  fcf42223           sw a5,-60(s0)
    4520:  fc843783           ld a5,-56(s0)
    4524:  fc442703           lw a4,-60(s0)
    4528:  cf98                 sw a4,24(a5)
    452a:  fc843783           ld a5,-56(s0)
    452e:  01878493           addi s1,a5,24 # ffffffff80202018 <gpio_get_boot_device+0
    4532:  4589                 li a1,2
    4534:  fd043503           ld a0,-48(s0)
    4538:  d01ff0ef           jal ra,4238 <FUN_00004238>
    453c:  87aa                 mv a5,a0
    453e:  863e                 mv a2,a5
    4540:  800005b7           lui a1,0x80000
    4544:  8526                 mv a0,s1
    4546:  401020ef           jal ra,7146 <FUN_00007146>
    454a:  87aa                 mv a5,a0
    454c:  fcf42e23           sw a5,-36(s0)
    4550:  fdc42783           lw a5,-36(s0)
    4554:  2781                 sext.w a5,a5
    4556:  c789                 beqz a5,4560 <FUN_000044d8+0x88>
    4558:  57fd                 li a5,-1
    455a:  fcf42e23           sw a5,-36(s0)
    455e:  a029                 j 4568 <FUN_000044d8+0x90>
    4560:  fc843783           ld a5,-56(s0)
    4564:  577d                 li a4,-1
    4566:  df98                 sw a4,56(a5)
    4568:  fc843783           ld a5,-56(s0)
    456c:  43dc                 lw a5,4(a5)
    456e:  2781                 sext.w a5,a5
    4570:  873e                 mv a4,a5
    4572:  800007b7           lui a5,0x80000
    4576:  fff7c793           not a5,a5
    457a:  8ff9                 and a5,a5,a4
    457c:  0007871b           sext.w a4,a5
    4580:  fc843783           ld a5,-56(s0)
    4584:  c3d8                 sw a4,4(a5)
    4586:  fdc42783           lw a5,-36(s0)
    458a:  853e                 mv a0,a5
    458c:  60a6                 ld ra,72(sp)
    458e:  6406                 ld s0,64(sp)
    4590:  74e2                 ld s1,56(sp)
    4592:  6161                 addi sp,sp,80
    4594:  8082                 ret
0000000000004596 <FUN_00004596>:
    4596:  715d                 addi sp,sp,-80
    4598:  e486                 sd ra,72(sp)
    459a:  e0a2                 sd s0,64(sp)
    459c:  0880                 addi s0,sp,80
    459e:  faa43c23           sd a0,-72(s0)
    45a2:  fb843783           ld a5,-72(s0)
    45a6:  639c                 ld a5,0(a5)
    45a8:  fef43423           sd a5,-24(s0)
    45ac:  fe843783           ld a5,-24(s0)
    45b0:  639c                 ld a5,0(a5)
    45b2:  fef43023           sd a5,-32(s0)
    45b6:  fc042e23           sw zero,-36(s0)
    45ba:  fc042c23           sw zero,-40(s0)
    45be:  fc043823           sd zero,-48(s0)
    45c2:  fc043423           sd zero,-56(s0)
    45c6:  fc043023           sd zero,-64(s0)
    45ca:  3b5050ef           jal ra,a17e <rdtime>
    45ce:  fca43823           sd a0,-48(s0)
    45d2:  67c1                 lui a5,0x10
    45d4:  17fd                 addi a5,a5,-1
    45d6:  fcf43023           sd a5,-64(s0)
    45da:  3a5050ef           jal ra,a17e <rdtime>
    45de:  872a                 mv a4,a0
    45e0:  fd043783           ld a5,-48(s0)
    45e4:  40f707b3           sub a5,a4,a5
    45e8:  fcf43423           sd a5,-56(s0)
    45ec:  fe043783           ld a5,-32(s0)
    45f0:  439c                 lw a5,0(a5)
    45f2:  fcf42c23           sw a5,-40(s0)
    45f6:  fd842783           lw a5,-40(s0)
    45fa:  8b9d                 andi a5,a5,7
    45fc:  2781                 sext.w a5,a5
    45fe:  e399                 bnez a5,4604 <FUN_00004596+0x6e>
    4600:  4781                 li a5,0
    4602:  a80d                 j 4634 <FUN_00004596+0x9e>
    4604:  fc843703           ld a4,-56(s0)
    4608:  fc043783           ld a5,-64(s0)
    460c:  fcf767e3           bltu a4,a5,45da <FUN_00004596+0x44>
    4610:  fc843703           ld a4,-56(s0)
    4614:  fc043783           ld a5,-64(s0)
    4618:  00f76d63           bltu a4,a5,4632 <FUN_00004596+0x9c>
    461c:  fd842783           lw a5,-40(s0)
    4620:  8b9d                 andi a5,a5,7
    4622:  2781                 sext.w a5,a5
    4624:  c799                 beqz a5,4632 <FUN_00004596+0x9c>
    4626:  57e5                 li a5,-7
    4628:  fcf42e23           sw a5,-36(s0)
    462c:  fdc42783           lw a5,-36(s0)
    4630:  a011                 j 4634 <FUN_00004596+0x9e>
    4632:  4781                 li a5,0
    4634:  853e                 mv a0,a5
    4636:  60a6                 ld ra,72(sp)
    4638:  6406                 ld s0,64(sp)
    463a:  6161                 addi sp,sp,80
    463c:  8082                 ret
000000000000463e <FUN_0000463e>:
    463e:  7139                 addi sp,sp,-64
    4640:  fc06                 sd ra,56(sp)
    4642:  f822                 sd s0,48(sp)
    4644:  0080                 addi s0,sp,64
    4646:  fca43423           sd a0,-56(s0)
    464a:  87ae                 mv a5,a1
    464c:  fcf42223           sw a5,-60(s0)
    4650:  fc843783           ld a5,-56(s0)
    4654:  639c                 ld a5,0(a5)
    4656:  fef43023           sd a5,-32(s0)
    465a:  fe043783           ld a5,-32(s0)
    465e:  639c                 ld a5,0(a5)
    4660:  fcf43c23           sd a5,-40(s0)
    4664:  fc042a23           sw zero,-44(s0)
    4668:  47c1                 li a5,16
    466a:  fef42623           sw a5,-20(s0)
    466e:  fc042a23           sw zero,-44(s0)
    4672:  fd843783           ld a5,-40(s0)
    4676:  fd442703           lw a4,-44(s0)
    467a:  c3d8                 sw a4,4(a5)
    467c:  fc843503           ld a0,-56(s0)
    4680:  e59ff0ef           jal ra,44d8 <FUN_000044d8>
    4684:  87aa                 mv a5,a0
    4686:  c399                 beqz a5,468c <FUN_0000463e+0x4e>
    4688:  57fd                 li a5,-1
    468a:  a4a1                 j 48d2 <FUN_0000463e+0x294>
    468c:  fe043783           ld a5,-32(s0)
    4690:  4b9c                 lw a5,16(a5)
    4692:  1782                 slli a5,a5,0x20
    4694:  9381                 srli a5,a5,0x20
    4696:  0007a023           sw zero,0(a5) # 10000 <gpio_get_boot_device+0x1c6a>
    469a:  47c1                 li a5,16
    469c:  fef42623           sw a5,-20(s0)
    46a0:  0001                 nop
    46a2:  fec42783           lw a5,-20(s0)
    46a6:  fff7871b           addiw a4,a5,-1
    46aa:  fee42623           sw a4,-20(s0)
    46ae:  fbf5                 bnez a5,46a2 <FUN_0000463e+0x64>
    46b0:  fc442783           lw a5,-60(s0)
    46b4:  0007871b           sext.w a4,a5
    46b8:  000627b7           lui a5,0x62
    46bc:  a8078793           addi a5,a5,-1408 # 61a80 <gpio_get_boot_device+0x536ea>
    46c0:  08e7e763           bltu a5,a4,474e <FUN_0000463e+0x110>
    46c4:  fe043783           ld a5,-32(s0)
    46c8:  4f9c                 lw a5,24(a5)
    46ca:  86be                 mv a3,a5
    46cc:  4705                 li a4,1
    46ce:  02e68763           beq a3,a4,46fc <FUN_0000463e+0xbe>
    46d2:  873e                 mv a4,a5
    46d4:  cb11                 beqz a4,46e8 <FUN_0000463e+0xaa>
    46d6:  86be                 mv a3,a5
    46d8:  4709                 li a4,2
    46da:  02e68b63           beq a3,a4,4710 <FUN_0000463e+0xd2>
    46de:  873e                 mv a4,a5
    46e0:  478d                 li a5,3
    46e2:  04f70163           beq a4,a5,4724 <FUN_0000463e+0xe6>
    46e6:  a889                 j 4738 <FUN_0000463e+0xfa>
    46e8:  fe043783           ld a5,-32(s0)
    46ec:  4b9c                 lw a5,16(a5)
    46ee:  1782                 slli a5,a5,0x20
    46f0:  9381                 srli a5,a5,0x20
    46f2:  873e                 mv a4,a5
    46f4:  10e00793           li a5,270
    46f8:  c31c                 sw a5,0(a4)
    46fa:  a295                 j 485e <FUN_0000463e+0x220>
    46fc:  fe043783           ld a5,-32(s0)
    4700:  4b9c                 lw a5,16(a5)
    4702:  1782                 slli a5,a5,0x20
    4704:  9381                 srli a5,a5,0x20
    4706:  873e                 mv a4,a5
    4708:  10b00793           li a5,267
    470c:  c31c                 sw a5,0(a4)
    470e:  aa81                 j 485e <FUN_0000463e+0x220>
    4710:  fe043783           ld a5,-32(s0)
    4714:  4b9c                 lw a5,16(a5)
    4716:  1782                 slli a5,a5,0x20
    4718:  9381                 srli a5,a5,0x20
    471a:  873e                 mv a4,a5
    471c:  20b00793           li a5,523
    4720:  c31c                 sw a5,0(a4)
    4722:  aa35                 j 485e <FUN_0000463e+0x220>
    4724:  fe043783           ld a5,-32(s0)
    4728:  4b9c                 lw a5,16(a5)
    472a:  1782                 slli a5,a5,0x20
    472c:  9381                 srli a5,a5,0x20
    472e:  873e                 mv a4,a5
    4730:  10e00793           li a5,270
    4734:  c31c                 sw a5,0(a4)
    4736:  a225                 j 485e <FUN_0000463e+0x220>
    4738:  fe043783           ld a5,-32(s0)
    473c:  4b9c                 lw a5,16(a5)
    473e:  1782                 slli a5,a5,0x20
    4740:  9381                 srli a5,a5,0x20
    4742:  873e                 mv a4,a5
    4744:  10e00793           li a5,270
    4748:  c31c                 sw a5,0(a4)
    474a:  0001                 nop
    474c:  aa09                 j 485e <FUN_0000463e+0x220>
    474e:  fc442783           lw a5,-60(s0)
    4752:  0007871b           sext.w a4,a5
    4756:  005b97b7           lui a5,0x5b9
    475a:  d8078793           addi a5,a5,-640 # 5b8d80 <gpio_get_boot_device+0x5aa9ea>
    475e:  08e7e563           bltu a5,a4,47e8 <FUN_0000463e+0x1aa>
    4762:  fe043783           ld a5,-32(s0)
    4766:  4f9c                 lw a5,24(a5)
    4768:  86be                 mv a3,a5
    476a:  4705                 li a4,1
    476c:  02e68763           beq a3,a4,479a <FUN_0000463e+0x15c>
    4770:  873e                 mv a4,a5
    4772:  cb11                 beqz a4,4786 <FUN_0000463e+0x148>
    4774:  86be                 mv a3,a5
    4776:  4709                 li a4,2
    4778:  02e68a63           beq a3,a4,47ac <FUN_0000463e+0x16e>
    477c:  873e                 mv a4,a5
    477e:  478d                 li a5,3
    4780:  02f70f63           beq a4,a5,47be <FUN_0000463e+0x180>
    4784:  a0b9                 j 47d2 <FUN_0000463e+0x194>
    4786:  fe043783           ld a5,-32(s0)
    478a:  4b9c                 lw a5,16(a5)
    478c:  1782                 slli a5,a5,0x20
    478e:  9381                 srli a5,a5,0x20
    4790:  873e                 mv a4,a5
    4792:  10000793           li a5,256
    4796:  c31c                 sw a5,0(a4)
    4798:  a0d9                 j 485e <FUN_0000463e+0x220>
    479a:  fe043783           ld a5,-32(s0)
    479e:  4b9c                 lw a5,16(a5)
    47a0:  1782                 slli a5,a5,0x20
    47a2:  9381                 srli a5,a5,0x20
    47a4:  873e                 mv a4,a5
    47a6:  4785                 li a5,1
    47a8:  c31c                 sw a5,0(a4)
    47aa:  a855                 j 485e <FUN_0000463e+0x220>
    47ac:  fe043783           ld a5,-32(s0)
    47b0:  4b9c                 lw a5,16(a5)
    47b2:  1782                 slli a5,a5,0x20
    47b4:  9381                 srli a5,a5,0x20
    47b6:  873e                 mv a4,a5
    47b8:  4789                 li a5,2
    47ba:  c31c                 sw a5,0(a4)
    47bc:  a04d                 j 485e <FUN_0000463e+0x220>
    47be:  fe043783           ld a5,-32(s0)
    47c2:  4b9c                 lw a5,16(a5)
    47c4:  1782                 slli a5,a5,0x20
    47c6:  9381                 srli a5,a5,0x20
    47c8:  873e                 mv a4,a5
    47ca:  10000793           li a5,256
    47ce:  c31c                 sw a5,0(a4)
    47d0:  a079                 j 485e <FUN_0000463e+0x220>
    47d2:  fe043783           ld a5,-32(s0)
    47d6:  4b9c                 lw a5,16(a5)
    47d8:  1782                 slli a5,a5,0x20
    47da:  9381                 srli a5,a5,0x20
    47dc:  873e                 mv a4,a5
    47de:  10000793           li a5,256
    47e2:  c31c                 sw a5,0(a4)
    47e4:  0001                 nop
    47e6:  a8a5                 j 485e <FUN_0000463e+0x220>
    47e8:  fe043783           ld a5,-32(s0)
    47ec:  4f9c                 lw a5,24(a5)
    47ee:  86be                 mv a3,a5
    47f0:  4705                 li a4,1
    47f2:  02e68563           beq a3,a4,481c <FUN_0000463e+0x1de>
    47f6:  873e                 mv a4,a5
    47f8:  cb11                 beqz a4,480c <FUN_0000463e+0x1ce>
    47fa:  86be                 mv a3,a5
    47fc:  4709                 li a4,2
    47fe:  02e68763           beq a3,a4,482c <FUN_0000463e+0x1ee>
    4802:  873e                 mv a4,a5
    4804:  478d                 li a5,3
    4806:  02f70c63           beq a4,a5,483e <FUN_0000463e+0x200>
    480a:  a091                 j 484e <FUN_0000463e+0x210>
    480c:  fe043783           ld a5,-32(s0)
    4810:  4b9c                 lw a5,16(a5)
    4812:  1782                 slli a5,a5,0x20
    4814:  9381                 srli a5,a5,0x20
    4816:  0007a023           sw zero,0(a5)
    481a:  a091                 j 485e <FUN_0000463e+0x220>
    481c:  fe043783           ld a5,-32(s0)
    4820:  4b9c                 lw a5,16(a5)
    4822:  1782                 slli a5,a5,0x20
    4824:  9381                 srli a5,a5,0x20
    4826:  0007a023           sw zero,0(a5)
    482a:  a815                 j 485e <FUN_0000463e+0x220>
    482c:  fe043783           ld a5,-32(s0)
    4830:  4b9c                 lw a5,16(a5)
    4832:  1782                 slli a5,a5,0x20
    4834:  9381                 srli a5,a5,0x20
    4836:  873e                 mv a4,a5
    4838:  4785                 li a5,1
    483a:  c31c                 sw a5,0(a4)
    483c:  a00d                 j 485e <FUN_0000463e+0x220>
    483e:  fe043783           ld a5,-32(s0)
    4842:  4b9c                 lw a5,16(a5)
    4844:  1782                 slli a5,a5,0x20
    4846:  9381                 srli a5,a5,0x20
    4848:  0007a023           sw zero,0(a5)
    484c:  a809                 j 485e <FUN_0000463e+0x220>
    484e:  fe043783           ld a5,-32(s0)
    4852:  4b9c                 lw a5,16(a5)
    4854:  1782                 slli a5,a5,0x20
    4856:  9381                 srli a5,a5,0x20
    4858:  0007a023           sw zero,0(a5)
    485c:  0001                 nop
    485e:  47c1                 li a5,16
    4860:  fef42623           sw a5,-20(s0)
    4864:  0001                 nop
    4866:  fec42783           lw a5,-20(s0)
    486a:  fff7871b           addiw a4,a5,-1
    486e:  fee42623           sw a4,-20(s0)
    4872:  fbf5                 bnez a5,4866 <FUN_0000463e+0x228>
    4874:  fe043783           ld a5,-32(s0)
    4878:  4b9c                 lw a5,16(a5)
    487a:  1782                 slli a5,a5,0x20
    487c:  9381                 srli a5,a5,0x20
    487e:  439c                 lw a5,0(a5)
    4880:  0007869b           sext.w a3,a5
    4884:  fe043783           ld a5,-32(s0)
    4888:  4b9c                 lw a5,16(a5)
    488a:  1782                 slli a5,a5,0x20
    488c:  9381                 srli a5,a5,0x20
    488e:  873e                 mv a4,a5
    4890:  800007b7           lui a5,0x80000
    4894:  8fd5                 or a5,a5,a3
    4896:  2781                 sext.w a5,a5
    4898:  c31c                 sw a5,0(a4)
    489a:  47c1                 li a5,16
    489c:  fef42623           sw a5,-20(s0)
    48a0:  0001                 nop
    48a2:  fec42783           lw a5,-20(s0)
    48a6:  fff7871b           addiw a4,a5,-1
    48aa:  fee42623           sw a4,-20(s0)
    48ae:  fbf5                 bnez a5,48a2 <FUN_0000463e+0x264>
    48b0:  67c1                 lui a5,0x10
    48b2:  fcf42a23           sw a5,-44(s0)
    48b6:  fd843783           ld a5,-40(s0)
    48ba:  fd442703           lw a4,-44(s0)
    48be:  c3d8                 sw a4,4(a5)
    48c0:  fc843503           ld a0,-56(s0)
    48c4:  c15ff0ef           jal ra,44d8 <FUN_000044d8>
    48c8:  87aa                 mv a5,a0
    48ca:  c399                 beqz a5,48d0 <FUN_0000463e+0x292>
    48cc:  57fd                 li a5,-1
    48ce:  a011                 j 48d2 <FUN_0000463e+0x294>
    48d0:  4781                 li a5,0
    48d2:  853e                 mv a0,a5
    48d4:  70e2                 ld ra,56(sp)
    48d6:  7442                 ld s0,48(sp)
    48d8:  6121                 addi sp,sp,64
    48da:  8082                 ret
00000000000048dc <FUN_000048dc>:
    48dc:  7179                 addi sp,sp,-48
    48de:  f406                 sd ra,40(sp)
    48e0:  f022                 sd s0,32(sp)
    48e2:  1800                 addi s0,sp,48
    48e4:  fca43c23           sd a0,-40(s0)
    48e8:  fd843783           ld a5,-40(s0)
    48ec:  639c                 ld a5,0(a5)
    48ee:  fef43423           sd a5,-24(s0)
    48f2:  fe843783           ld a5,-24(s0)
    48f6:  639c                 ld a5,0(a5)
    48f8:  fef43023           sd a5,-32(s0)
    48fc:  fe043783           ld a5,-32(s0)
    4900:  0607ac23           sw zero,120(a5) # 10078 <gpio_get_boot_device+0x1ce2>
    4904:  4579                 li a0,30
    4906:  07f050ef           jal ra,a184 <udelay>
    490a:  fe043783           ld a5,-32(s0)
    490e:  4705                 li a4,1
    4910:  dfb8                 sw a4,120(a5)
    4912:  12c00513           li a0,300
    4916:  06f050ef           jal ra,a184 <udelay>
    491a:  0001                 nop
    491c:  70a2                 ld ra,40(sp)
    491e:  7402                 ld s0,32(sp)
    4920:  6145                 addi sp,sp,48
    4922:  8082                 ret
0000000000004924 <FUN_00004924>:
    4924:  7179                 addi sp,sp,-48
    4926:  f406                 sd ra,40(sp)
    4928:  f022                 sd s0,32(sp)
    492a:  1800                 addi s0,sp,48
    492c:  fca43c23           sd a0,-40(s0)
    4930:  fd843783           ld a5,-40(s0)
    4934:  639c                 ld a5,0(a5)
    4936:  fef43423           sd a5,-24(s0)
    493a:  fe843783           ld a5,-24(s0)
    493e:  639c                 ld a5,0(a5)
    4940:  fef43023           sd a5,-32(s0)
    4944:  fd843783           ld a5,-40(s0)
    4948:  539c                 lw a5,32(a5)
    494a:  c385                 beqz a5,496a <FUN_00004924+0x46>
    494c:  fd843783           ld a5,-40(s0)
    4950:  539c                 lw a5,32(a5)
    4952:  85be                 mv a1,a5
    4954:  fd843503           ld a0,-40(s0)
    4958:  ce7ff0ef           jal ra,463e <FUN_0000463e>
    495c:  87aa                 mv a5,a0
    495e:  c791                 beqz a5,496a <FUN_00004924+0x46>
    4960:  fe843783           ld a5,-24(s0)
    4964:  4705                 li a4,1
    4966:  d398                 sw a4,32(a5)
    4968:  a82d                 j 49a2 <FUN_00004924+0x7e>
    496a:  fd843783           ld a5,-40(s0)
    496e:  4fdc                 lw a5,28(a5)
    4970:  873e                 mv a4,a5
    4972:  4791                 li a5,4
    4974:  00f71763           bne a4,a5,4982 <FUN_00004924+0x5e>
    4978:  fe043783           ld a5,-32(s0)
    497c:  4705                 li a4,1
    497e:  c7d8                 sw a4,12(a5)
    4980:  a00d                 j 49a2 <FUN_00004924+0x7e>
    4982:  fd843783           ld a5,-40(s0)
    4986:  4fdc                 lw a5,28(a5)
    4988:  873e                 mv a4,a5
    498a:  47a1                 li a5,8
    498c:  00f71763           bne a4,a5,499a <FUN_00004924+0x76>
    4990:  fe043783           ld a5,-32(s0)
    4994:  4709                 li a4,2
    4996:  c7d8                 sw a4,12(a5)
    4998:  a029                 j 49a2 <FUN_00004924+0x7e>
    499a:  fe043783           ld a5,-32(s0)
    499e:  0007a623           sw zero,12(a5)
    49a2:  70a2                 ld ra,40(sp)
    49a4:  7402                 ld s0,32(sp)
    49a6:  6145                 addi sp,sp,48
    49a8:  8082                 ret
00000000000049aa <FUN_000049aa>:
    49aa:  7139                 addi sp,sp,-64
    49ac:  fc06                 sd ra,56(sp)
    49ae:  f822                 sd s0,48(sp)
    49b0:  0080                 addi s0,sp,64
    49b2:  fca43423           sd a0,-56(s0)
    49b6:  fc843783           ld a5,-56(s0)
    49ba:  639c                 ld a5,0(a5)
    49bc:  fef43423           sd a5,-24(s0)
    49c0:  fe843783           ld a5,-24(s0)
    49c4:  639c                 ld a5,0(a5)
    49c6:  fef43023           sd a5,-32(s0)
    49ca:  fc042e23           sw zero,-36(s0)
    49ce:  fe043783           ld a5,-32(s0)
    49d2:  471d                 li a4,7
    49d4:  c398                 sw a4,0(a5)
    49d6:  fc843503           ld a0,-56(s0)
    49da:  bbdff0ef           jal ra,4596 <FUN_00004596>
    49de:  87aa                 mv a5,a0
    49e0:  fcf42c23           sw a5,-40(s0)
    49e4:  fd842783           lw a5,-40(s0)
    49e8:  2781                 sext.w a5,a5
    49ea:  c781                 beqz a5,49f2 <FUN_000049aa+0x48>
    49ec:  fd842783           lw a5,-40(s0)
    49f0:  a2ed                 j 4bda <FUN_000049aa+0x230>
    49f2:  fe043783           ld a5,-32(s0)
    49f6:  00070737           lui a4,0x70
    49fa:  0f87071b           addiw a4,a4,248
    49fe:  c3b8                 sw a4,64(a5)
    4a00:  fe043783           ld a5,-32(s0)
    4a04:  0207a823           sw zero,48(a5)
    4a08:  fe043783           ld a5,-32(s0)
    4a0c:  577d                 li a4,-1
    4a0e:  df98                 sw a4,56(a5)
    4a10:  fe043783           ld a5,-32(s0)
    4a14:  3ff00713           li a4,1023
    4a18:  08e7a423           sw a4,136(a5)
    4a1c:  fe043783           ld a5,-32(s0)
    4a20:  6705                 lui a4,0x1
    4a22:  deb7071b           addiw a4,a4,-533
    4a26:  cbb8                 sw a4,80(a5)
    4a28:  fe043783           ld a5,-32(s0)
    4a2c:  577d                 li a4,-1
    4a2e:  c798                 sw a4,8(a5)
    4a30:  fe043783           ld a5,-32(s0)
    4a34:  02000737           lui a4,0x2000
    4a38:  2705                 addiw a4,a4,1
    4a3a:  10e7a023           sw a4,256(a5)
    4a3e:  fc843783           ld a5,-56(s0)
    4a42:  4bbc                 lw a5,80(a5)
    4a44:  efd1                 bnez a5,4ae0 <FUN_000049aa+0x136>
    4a46:  fe043783           ld a5,-32(s0)
    4a4a:  4ffc                 lw a5,92(a5)
    4a4c:  fcf42e23           sw a5,-36(s0)
    4a50:  fdc42703           lw a4,-36(s0)
    4a54:  800007b7           lui a5,0x80000
    4a58:  8fd9                 or a5,a5,a4
    4a5a:  fcf42e23           sw a5,-36(s0)
    4a5e:  fe043783           ld a5,-32(s0)
    4a62:  fdc42703           lw a4,-36(s0)
    4a66:  cff8                 sw a4,92(a5)
    4a68:  fe043783           ld a5,-32(s0)
    4a6c:  1407a783           lw a5,320(a5) # ffffffff80000140 <gpio_get_boot_device+0
    4a70:  fcf42e23           sw a5,-36(s0)
    4a74:  fdc42703           lw a4,-36(s0)
    4a78:  000307b7           lui a5,0x30
    4a7c:  8fd9                 or a5,a5,a4
    4a7e:  fcf42e23           sw a5,-36(s0)
    4a82:  fe843783           ld a5,-24(s0)
    4a86:  4b9c                 lw a5,16(a5)
    4a88:  1782                 slli a5,a5,0x20
    4a8a:  9381                 srli a5,a5,0x20
    4a8c:  439c                 lw a5,0(a5)
    4a8e:  0007869b           sext.w a3,a5
    4a92:  fe843783           ld a5,-24(s0)
    4a96:  4b9c                 lw a5,16(a5)
    4a98:  1782                 slli a5,a5,0x20
    4a9a:  9381                 srli a5,a5,0x20
    4a9c:  873e                 mv a4,a5
    4a9e:  800007b7           lui a5,0x80000
    4aa2:  fff7c793           not a5,a5
    4aa6:  8ff5                 and a5,a5,a3
    4aa8:  2781                 sext.w a5,a5
    4aaa:  c31c                 sw a5,0(a4)
    4aac:  fe043783           ld a5,-32(s0)
    4ab0:  fdc42703           lw a4,-36(s0)
    4ab4:  14e7a023           sw a4,320(a5) # ffffffff80000140 <gpio_get_boot_device+0
    4ab8:  fe843783           ld a5,-24(s0)
    4abc:  4b9c                 lw a5,16(a5)
    4abe:  1782                 slli a5,a5,0x20
    4ac0:  9381                 srli a5,a5,0x20
    4ac2:  439c                 lw a5,0(a5)
    4ac4:  0007869b           sext.w a3,a5
    4ac8:  fe843783           ld a5,-24(s0)
    4acc:  4b9c                 lw a5,16(a5)
    4ace:  1782                 slli a5,a5,0x20
    4ad0:  9381                 srli a5,a5,0x20
    4ad2:  873e                 mv a4,a5
    4ad4:  800007b7           lui a5,0x80000
    4ad8:  8fd5                 or a5,a5,a3
    4ada:  2781                 sext.w a5,a5
    4adc:  c31c                 sw a5,0(a4)
    4ade:  a8ed                 j 4bd8 <FUN_000049aa+0x22e>
    4ae0:  3e6030ef           jal ra,7ec6 <brom_config_bit_5>
    4ae4:  87aa                 mv a5,a0
    4ae6:  cfa9                 beqz a5,4b40 <FUN_000049aa+0x196>
    4ae8:  fe043783           ld a5,-32(s0)
    4aec:  4ffc                 lw a5,92(a5)
    4aee:  fcf42e23           sw a5,-36(s0)
    4af2:  fdc42703           lw a4,-36(s0)
    4af6:  800007b7           lui a5,0x80000
    4afa:  fff7c793           not a5,a5
    4afe:  8ff9                 and a5,a5,a4
    4b00:  fcf42e23           sw a5,-36(s0)
    4b04:  fe043783           ld a5,-32(s0)
    4b08:  fdc42703           lw a4,-36(s0)
    4b0c:  cff8                 sw a4,92(a5)
    4b0e:  fe043783           ld a5,-32(s0)
    4b12:  1447a783           lw a5,324(a5) # ffffffff80000144 <gpio_get_boot_device+0
    4b16:  fcf42e23           sw a5,-36(s0)
    4b1a:  fdc42783           lw a5,-36(s0)
    4b1e:  fc07f793           andi a5,a5,-64
    4b22:  fcf42e23           sw a5,-36(s0)
    4b26:  fdc42783           lw a5,-36(s0)
    4b2a:  0807e793           ori a5,a5,128
    4b2e:  fcf42e23           sw a5,-36(s0)
    4b32:  fe043783           ld a5,-32(s0)
    4b36:  fdc42703           lw a4,-36(s0)
    4b3a:  14e7a223           sw a4,324(a5)
    4b3e:  a015                 j 4b62 <FUN_000049aa+0x1b8>
    4b40:  fe043783           ld a5,-32(s0)
    4b44:  4ffc                 lw a5,92(a5)
    4b46:  fcf42e23           sw a5,-36(s0)
    4b4a:  fdc42703           lw a4,-36(s0)
    4b4e:  820007b7           lui a5,0x82000
    4b52:  8fd9                 or a5,a5,a4
    4b54:  fcf42e23           sw a5,-36(s0)
    4b58:  fe043783           ld a5,-32(s0)
    4b5c:  fdc42703           lw a4,-36(s0)
    4b60:  cff8                 sw a4,92(a5)
    4b62:  fe043783           ld a5,-32(s0)
    4b66:  1407a783           lw a5,320(a5) # ffffffff82000140 <gpio_get_boot_device+0
    4b6a:  fcf42e23           sw a5,-36(s0)
    4b6e:  fdc42703           lw a4,-36(s0)
    4b72:  000307b7           lui a5,0x30
    4b76:  8fd9                 or a5,a5,a4
    4b78:  fcf42e23           sw a5,-36(s0)
    4b7c:  fe843783           ld a5,-24(s0)
    4b80:  4b9c                 lw a5,16(a5)
    4b82:  1782                 slli a5,a5,0x20
    4b84:  9381                 srli a5,a5,0x20
    4b86:  439c                 lw a5,0(a5)
    4b88:  0007869b           sext.w a3,a5
    4b8c:  fe843783           ld a5,-24(s0)
    4b90:  4b9c                 lw a5,16(a5)
    4b92:  1782                 slli a5,a5,0x20
    4b94:  9381                 srli a5,a5,0x20
    4b96:  873e                 mv a4,a5
    4b98:  800007b7           lui a5,0x80000
    4b9c:  fff7c793           not a5,a5
    4ba0:  8ff5                 and a5,a5,a3
    4ba2:  2781                 sext.w a5,a5
    4ba4:  c31c                 sw a5,0(a4)
    4ba6:  fe043783           ld a5,-32(s0)
    4baa:  fdc42703           lw a4,-36(s0)
    4bae:  14e7a023           sw a4,320(a5) # ffffffff80000140 <gpio_get_boot_device+0
    4bb2:  fe843783           ld a5,-24(s0)
    4bb6:  4b9c                 lw a5,16(a5)
    4bb8:  1782                 slli a5,a5,0x20
    4bba:  9381                 srli a5,a5,0x20
    4bbc:  439c                 lw a5,0(a5)
    4bbe:  0007869b           sext.w a3,a5
    4bc2:  fe843783           ld a5,-24(s0)
    4bc6:  4b9c                 lw a5,16(a5)
    4bc8:  1782                 slli a5,a5,0x20
    4bca:  9381                 srli a5,a5,0x20
    4bcc:  873e                 mv a4,a5
    4bce:  800007b7           lui a5,0x80000
    4bd2:  8fd5                 or a5,a5,a3
    4bd4:  2781                 sext.w a5,a5
    4bd6:  c31c                 sw a5,0(a4)
    4bd8:  4781                 li a5,0
    4bda:  853e                 mv a0,a5
    4bdc:  70e2                 ld ra,56(sp)
    4bde:  7442                 ld s0,48(sp)
    4be0:  6121                 addi sp,sp,64
    4be2:  8082                 ret
0000000000004be4 <FUN_00004be4>:
    4be4:  711d                 addi sp,sp,-96
    4be6:  ec86                 sd ra,88(sp)
    4be8:  e8a2                 sd s0,80(sp)
    4bea:  1080                 addi s0,sp,96
    4bec:  faa43423           sd a0,-88(s0)
    4bf0:  fab43023           sd a1,-96(s0)
    4bf4:  fa843783           ld a5,-88(s0)
    4bf8:  639c                 ld a5,0(a5)
    4bfa:  fcf43823           sd a5,-48(s0)
    4bfe:  fd043783           ld a5,-48(s0)
    4c02:  639c                 ld a5,0(a5)
    4c04:  fcf43423           sd a5,-56(s0)
    4c08:  fe042623           sw zero,-20(s0)
    4c0c:  fa043783           ld a5,-96(s0)
    4c10:  4b98                 lw a4,16(a5)
    4c12:  fa043783           ld a5,-96(s0)
    4c16:  47dc                 lw a5,12(a5)
    4c18:  02f707bb           mulw a5,a4,a5
    4c1c:  fcf42223           sw a5,-60(s0)
    4c20:  fe042423           sw zero,-24(s0)
    4c24:  fe043023           sd zero,-32(s0)
    4c28:  fa043c23           sd zero,-72(s0)
    4c2c:  3e800593           li a1,1000
    4c30:  fd043503           ld a0,-48(s0)
    4c34:  e04ff0ef           jal ra,4238 <FUN_00004238>
    4c38:  fca43c23           sd a0,-40(s0)
    4c3c:  542050ef           jal ra,a17e <rdtime>
    4c40:  fea43023           sd a0,-32(s0)
    4c44:  fa043783           ld a5,-96(s0)
    4c48:  479c                 lw a5,8(a5)
    4c4a:  8b85                 andi a5,a5,1
    4c4c:  2781                 sext.w a5,a5
    4c4e:  c3f1                 beqz a5,4d12 <FUN_00004be4+0x12e>
    4c50:  fa043783           ld a5,-96(s0)
    4c54:  639c                 ld a5,0(a5)
    4c56:  faf43823           sd a5,-80(s0)
    4c5a:  fe042623           sw zero,-20(s0)
    4c5e:  a879                 j 4cfc <FUN_00004be4+0x118>
    4c60:  fc843783           ld a5,-56(s0)
    4c64:  5fdc                 lw a5,60(a5)
    4c66:  2781                 sext.w a5,a5
    4c68:  8b91                 andi a5,a5,4
    4c6a:  2781                 sext.w a5,a5
    4c6c:  e7bd                 bnez a5,4cda <FUN_00004be4+0xf6>
    4c6e:  fc843783           ld a5,-56(s0)
    4c72:  5fdc                 lw a5,60(a5)
    4c74:  2781                 sext.w a5,a5
    4c76:  0117d79b           srliw a5,a5,0x11
    4c7a:  2781                 sext.w a5,a5
    4c7c:  1ff7f793           andi a5,a5,511
    4c80:  fef42423           sw a5,-24(s0)
    4c84:  a035                 j 4cb0 <FUN_00004be4+0xcc>
    4c86:  fd043783           ld a5,-48(s0)
    4c8a:  4fdc                 lw a5,28(a5)
    4c8c:  1782                 slli a5,a5,0x20
    4c8e:  9381                 srli a5,a5,0x20
    4c90:  86be                 mv a3,a5
    4c92:  fec42783           lw a5,-20(s0)
    4c96:  0017871b           addiw a4,a5,1
    4c9a:  fee42623           sw a4,-20(s0)
    4c9e:  1782                 slli a5,a5,0x20
    4ca0:  9381                 srli a5,a5,0x20
    4ca2:  078a                 slli a5,a5,0x2
    4ca4:  fb043703           ld a4,-80(s0)
    4ca8:  97ba                 add a5,a5,a4
    4caa:  4298                 lw a4,0(a3)
    4cac:  2701                 sext.w a4,a4
    4cae:  c398                 sw a4,0(a5)
    4cb0:  fe842783           lw a5,-24(s0)
    4cb4:  fff7871b           addiw a4,a5,-1
    4cb8:  fee42423           sw a4,-24(s0)
    4cbc:  f7e9                 bnez a5,4c86 <FUN_00004be4+0xa2>
    4cbe:  3e800593           li a1,1000
    4cc2:  fd043503           ld a0,-48(s0)
    4cc6:  d72ff0ef           jal ra,4238 <FUN_00004238>
    4cca:  fca43c23           sd a0,-40(s0)
    4cce:  fa043c23           sd zero,-72(s0)
    4cd2:  4ac050ef           jal ra,a17e <rdtime>
    4cd6:  fea43023           sd a0,-32(s0)
    4cda:  4a4050ef           jal ra,a17e <rdtime>
    4cde:  872a                 mv a4,a0
    4ce0:  fe043783           ld a5,-32(s0)
    4ce4:  40f707b3           sub a5,a4,a5
    4ce8:  faf43c23           sd a5,-72(s0)
    4cec:  fb843703           ld a4,-72(s0)
    4cf0:  fd843783           ld a5,-40(s0)
    4cf4:  00f76463           bltu a4,a5,4cfc <FUN_00004be4+0x118>
    4cf8:  57fd                 li a5,-1
    4cfa:  a829                 j 4d14 <FUN_00004be4+0x130>
    4cfc:  fc442783           lw a5,-60(s0)
    4d00:  0027d79b           srliw a5,a5,0x2
    4d04:  0007871b           sext.w a4,a5
    4d08:  fec42783           lw a5,-20(s0)
    4d0c:  2781                 sext.w a5,a5
    4d0e:  f4e7e9e3           bltu a5,a4,4c60 <FUN_00004be4+0x7c>
    4d12:  4781                 li a5,0
    4d14:  853e                 mv a0,a5
    4d16:  60e6                 ld ra,88(sp)
    4d18:  6446                 ld s0,80(sp)
    4d1a:  6125                 addi sp,sp,96
    4d1c:  8082                 ret
0000000000004d1e <FUN_00004d1e>:
    4d1e:  7119                 addi sp,sp,-128
    4d20:  fc86                 sd ra,120(sp)
    4d22:  f8a2                 sd s0,112(sp)
    4d24:  f4a6                 sd s1,104(sp)
    4d26:  0100                 addi s0,sp,128
    4d28:  f8a43423           sd a0,-120(s0)
    4d2c:  f8b43023           sd a1,-128(s0)
    4d30:  f8843783           ld a5,-120(s0)
    4d34:  639c                 ld a5,0(a5)
    4d36:  fcf43023           sd a5,-64(s0)
    4d3a:  fc043783           ld a5,-64(s0)
    4d3e:  639c                 ld a5,0(a5)
    4d40:  faf43c23           sd a5,-72(s0)
    4d44:  fc043783           ld a5,-64(s0)
    4d48:  679c                 ld a5,8(a5)
    4d4a:  faf43823           sd a5,-80(s0)
    4d4e:  f8043783           ld a5,-128(s0)
    4d52:  4b98                 lw a4,16(a5)
    4d54:  f8043783           ld a5,-128(s0)
    4d58:  47dc                 lw a5,12(a5)
    4d5a:  02f707bb           mulw a5,a4,a5
    4d5e:  faf42623           sw a5,-84(s0)
    4d62:  010007b7           lui a5,0x1000
    4d66:  37fd                 addiw a5,a5,-1
    4d68:  faf42423           sw a5,-88(s0)
    4d6c:  fc042c23           sw zero,-40(s0)
    4d70:  fc042a23           sw zero,-44(s0)
    4d74:  fc042823           sw zero,-48(s0)
    4d78:  fc042623           sw zero,-52(s0)
    4d7c:  fa042223           sw zero,-92(s0)
    4d80:  f8043783           ld a5,-128(s0)
    4d84:  479c                 lw a5,8(a5)
    4d86:  8b85                 andi a5,a5,1
    4d88:  2781                 sext.w a5,a5
    4d8a:  c789                 beqz a5,4d94 <FUN_00004d1e+0x76>
    4d8c:  f8043783           ld a5,-128(s0)
    4d90:  639c                 ld a5,0(a5)
    4d92:  a021                 j 4d9a <FUN_00004d1e+0x7c>
    4d94:  f8043783           ld a5,-128(s0)
    4d98:  639c                 ld a5,0(a5)
    4d9a:  f8f43c23           sd a5,-104(s0)
    4d9e:  fac42783           lw a5,-84(s0)
    4da2:  00b7d79b           srliw a5,a5,0xb
    4da6:  fcf42a23           sw a5,-44(s0)
    4daa:  fac42783           lw a5,-84(s0)
    4dae:  7ff7f793           andi a5,a5,2047
    4db2:  fcf42823           sw a5,-48(s0)
    4db6:  fd042783           lw a5,-48(s0)
    4dba:  2781                 sext.w a5,a5
    4dbc:  c799                 beqz a5,4dca <FUN_00004d1e+0xac>
    4dbe:  fd442783           lw a5,-44(s0)
    4dc2:  2785                 addiw a5,a5,1
    4dc4:  fcf42a23           sw a5,-44(s0)
    4dc8:  a031                 j 4dd4 <FUN_00004d1e+0xb6>
    4dca:  6785                 lui a5,0x1
    4dcc:  8007879b           addiw a5,a5,-2048
    4dd0:  fcf42823           sw a5,-48(s0)
    4dd4:  fc042623           sw zero,-52(s0)
    4dd8:  a279                 j 4f66 <FUN_00004d1e+0x248>
    4dda:  fd846783           lwu a5,-40(s0)
    4dde:  0792                 slli a5,a5,0x4
    4de0:  fb043703           ld a4,-80(s0)
    4de4:  97ba                 add a5,a5,a4
    4de6:  4641                 li a2,16
    4de8:  4581                 li a1,0
    4dea:  853e                 mv a0,a5
    4dec:  0fe050ef           jal ra,9eea <memset>
    4df0:  fd846783           lwu a5,-40(s0)
    4df4:  0792                 slli a5,a5,0x4
    4df6:  fb043703           ld a4,-80(s0)
    4dfa:  97ba                 add a5,a5,a4
    4dfc:  4398                 lw a4,0(a5)
    4dfe:  01076713           ori a4,a4,16
    4e02:  c398                 sw a4,0(a5)
    4e04:  fd846783           lwu a5,-40(s0)
    4e08:  0792                 slli a5,a5,0x4
    4e0a:  fb043703           ld a4,-80(s0)
    4e0e:  97ba                 add a5,a5,a4
    4e10:  4394                 lw a3,0(a5)
    4e12:  80000737           lui a4,0x80000
    4e16:  8f55                 or a4,a4,a3
    4e18:  c398                 sw a4,0(a5)
    4e1a:  fd846783           lwu a5,-40(s0)
    4e1e:  0792                 slli a5,a5,0x4
    4e20:  fb043703           ld a4,-80(s0)
    4e24:  97ba                 add a5,a5,a4
    4e26:  4398                 lw a4,0(a5)
    4e28:  00276713           ori a4,a4,2
    4e2c:  c398                 sw a4,0(a5)
    4e2e:  fd442783           lw a5,-44(s0)
    4e32:  0007871b           sext.w a4,a5
    4e36:  4785                 li a5,1
    4e38:  02e7f863           bgeu a5,a4,4e68 <FUN_00004d1e+0x14a>
    4e3c:  fd442783           lw a5,-44(s0)
    4e40:  37fd                 addiw a5,a5,-1
    4e42:  0007871b           sext.w a4,a5
    4e46:  fcc42783           lw a5,-52(s0)
    4e4a:  2781                 sext.w a5,a5
    4e4c:  00e78e63           beq a5,a4,4e68 <FUN_00004d1e+0x14a>
    4e50:  fd846783           lwu a5,-40(s0)
    4e54:  0792                 slli a5,a5,0x4
    4e56:  fb043703           ld a4,-80(s0)
    4e5a:  97ba                 add a5,a5,a4
    4e5c:  6705                 lui a4,0x1
    4e5e:  8007071b           addiw a4,a4,-2048
    4e62:  00e79223           sh a4,4(a5) # 1004 <FUN_00000f2c+0xd8>
    4e66:  a829                 j 4e80 <FUN_00004d1e+0x162>
    4e68:  fd846783           lwu a5,-40(s0)
    4e6c:  0792                 slli a5,a5,0x4
    4e6e:  fb043703           ld a4,-80(s0)
    4e72:  97ba                 add a5,a5,a4
    4e74:  fd042703           lw a4,-48(s0)
    4e78:  1742                 slli a4,a4,0x30
    4e7a:  9341                 srli a4,a4,0x30
    4e7c:  00e79223           sh a4,4(a5)
    4e80:  fcc42783           lw a5,-52(s0)
    4e84:  00b7979b           slliw a5,a5,0xb
    4e88:  2781                 sext.w a5,a5
    4e8a:  02079713           slli a4,a5,0x20
    4e8e:  9301                 srli a4,a4,0x20
    4e90:  f9843783           ld a5,-104(s0)
    4e94:  97ba                 add a5,a5,a4
    4e96:  0027d693           srli a3,a5,0x2
    4e9a:  fd846783           lwu a5,-40(s0)
    4e9e:  0792                 slli a5,a5,0x4
    4ea0:  fb043703           ld a4,-80(s0)
    4ea4:  97ba                 add a5,a5,a4
    4ea6:  0006871b           sext.w a4,a3
    4eaa:  c798                 sw a4,8(a5)
    4eac:  fcc42783           lw a5,-52(s0)
    4eb0:  2781                 sext.w a5,a5
    4eb2:  eb99                 bnez a5,4ec8 <FUN_00004d1e+0x1aa>
    4eb4:  fd846783           lwu a5,-40(s0)
    4eb8:  0792                 slli a5,a5,0x4
    4eba:  fb043703           ld a4,-80(s0)
    4ebe:  97ba                 add a5,a5,a4
    4ec0:  4398                 lw a4,0(a5)
    4ec2:  00876713           ori a4,a4,8
    4ec6:  c398                 sw a4,0(a5)
    4ec8:  fd442783           lw a5,-44(s0)
    4ecc:  37fd                 addiw a5,a5,-1
    4ece:  0007871b           sext.w a4,a5
    4ed2:  fcc42783           lw a5,-52(s0)
    4ed6:  2781                 sext.w a5,a5
    4ed8:  04e79863           bne a5,a4,4f28 <FUN_00004d1e+0x20a>
    4edc:  fd846783           lwu a5,-40(s0)
    4ee0:  0792                 slli a5,a5,0x4
    4ee2:  fb043703           ld a4,-80(s0)
    4ee6:  97ba                 add a5,a5,a4
    4ee8:  4398                 lw a4,0(a5)
    4eea:  9b75                 andi a4,a4,-3
    4eec:  c398                 sw a4,0(a5)
    4eee:  fd846783           lwu a5,-40(s0)
    4ef2:  0792                 slli a5,a5,0x4
    4ef4:  fb043703           ld a4,-80(s0)
    4ef8:  97ba                 add a5,a5,a4
    4efa:  4398                 lw a4,0(a5)
    4efc:  00476713           ori a4,a4,4
    4f00:  c398                 sw a4,0(a5)
    4f02:  fd846783           lwu a5,-40(s0)
    4f06:  0792                 slli a5,a5,0x4
    4f08:  fb043703           ld a4,-80(s0)
    4f0c:  97ba                 add a5,a5,a4
    4f0e:  4398                 lw a4,0(a5)
    4f10:  02076713           ori a4,a4,32
    4f14:  c398                 sw a4,0(a5)
    4f16:  fd846783           lwu a5,-40(s0)
    4f1a:  0792                 slli a5,a5,0x4
    4f1c:  fb043703           ld a4,-80(s0)
    4f20:  97ba                 add a5,a5,a4
    4f22:  0007a623           sw zero,12(a5)
    4f26:  a035                 j 4f52 <FUN_00004d1e+0x234>
    4f28:  fd842783           lw a5,-40(s0)
    4f2c:  2785                 addiw a5,a5,1
    4f2e:  2781                 sext.w a5,a5
    4f30:  1782                 slli a5,a5,0x20
    4f32:  9381                 srli a5,a5,0x20
    4f34:  0792                 slli a5,a5,0x4
    4f36:  fb043703           ld a4,-80(s0)
    4f3a:  97ba                 add a5,a5,a4
    4f3c:  0027d693           srli a3,a5,0x2
    4f40:  fd846783           lwu a5,-40(s0)
    4f44:  0792                 slli a5,a5,0x4
    4f46:  fb043703           ld a4,-80(s0)
    4f4a:  97ba                 add a5,a5,a4
    4f4c:  0006871b           sext.w a4,a3
    4f50:  c7d8                 sw a4,12(a5)
    4f52:  fcc42783           lw a5,-52(s0)
    4f56:  2785                 addiw a5,a5,1
    4f58:  fcf42623           sw a5,-52(s0)
    4f5c:  fd842783           lw a5,-40(s0)
    4f60:  2785                 addiw a5,a5,1
    4f62:  fcf42c23           sw a5,-40(s0)
    4f66:  fcc42703           lw a4,-52(s0)
    4f6a:  fd442783           lw a5,-44(s0)
    4f6e:  2701                 sext.w a4,a4
    4f70:  2781                 sext.w a5,a5
    4f72:  e6f764e3           bltu a4,a5,4dda <FUN_00004d1e+0xbc>
    4f76:  fb843783           ld a5,-72(s0)
    4f7a:  439c                 lw a5,0(a5)
    4f7c:  fcf42e23           sw a5,-36(s0)
    4f80:  fdc42783           lw a5,-36(s0)
    4f84:  0247e793           ori a5,a5,36
    4f88:  0007871b           sext.w a4,a5
    4f8c:  fb843783           ld a5,-72(s0)
    4f90:  c398                 sw a4,0(a5)
    4f92:  f8843503           ld a0,-120(s0)
    4f96:  e00ff0ef           jal ra,4596 <FUN_00004596>
    4f9a:  87aa                 mv a5,a0
    4f9c:  f8f42a23           sw a5,-108(s0)
    4fa0:  f9442783           lw a5,-108(s0)
    4fa4:  2781                 sext.w a5,a5
    4fa6:  c781                 beqz a5,4fae <FUN_00004d1e+0x290>
    4fa8:  f9442783           lw a5,-108(s0)
    4fac:  a075                 j 5058 <FUN_00004d1e+0x33a>
    4fae:  fb843783           ld a5,-72(s0)
    4fb2:  4705                 li a4,1
    4fb4:  08e7a023           sw a4,128(a5)
    4fb8:  fb843783           ld a5,-72(s0)
    4fbc:  08078493           addi s1,a5,128
    4fc0:  4589                 li a1,2
    4fc2:  fc043503           ld a0,-64(s0)
    4fc6:  a72ff0ef           jal ra,4238 <FUN_00004238>
    4fca:  87aa                 mv a5,a0
    4fcc:  863e                 mv a2,a5
    4fce:  4585                 li a1,1
    4fd0:  8526                 mv a0,s1
    4fd2:  174020ef           jal ra,7146 <FUN_00007146>
    4fd6:  87aa                 mv a5,a0
    4fd8:  faf42223           sw a5,-92(s0)
    4fdc:  fa442783           lw a5,-92(s0)
    4fe0:  2781                 sext.w a5,a5
    4fe2:  c399                 beqz a5,4fe8 <FUN_00004d1e+0x2ca>
    4fe4:  57e5                 li a5,-7
    4fe6:  a88d                 j 5058 <FUN_00004d1e+0x33a>
    4fe8:  fb843783           ld a5,-72(s0)
    4fec:  08200713           li a4,130
    4ff0:  08e7a023           sw a4,128(a5)
    4ff4:  fb843783           ld a5,-72(s0)
    4ff8:  08c7a783           lw a5,140(a5)
    4ffc:  2781                 sext.w a5,a5
    4ffe:  9bf1                 andi a5,a5,-4
    5000:  fcf42e23           sw a5,-36(s0)
    5004:  f8043783           ld a5,-128(s0)
    5008:  479c                 lw a5,8(a5)
    500a:  8b89                 andi a5,a5,2
    500c:  2781                 sext.w a5,a5
    500e:  cb81                 beqz a5,501e <FUN_00004d1e+0x300>
    5010:  fdc42783           lw a5,-36(s0)
    5014:  0017e793           ori a5,a5,1
    5018:  fcf42e23           sw a5,-36(s0)
    501c:  a039                 j 502a <FUN_00004d1e+0x30c>
    501e:  fdc42783           lw a5,-36(s0)
    5022:  0027e793           ori a5,a5,2
    5026:  fcf42e23           sw a5,-36(s0)
    502a:  fb843783           ld a5,-72(s0)
    502e:  fdc42703           lw a4,-36(s0)
    5032:  08e7a623           sw a4,140(a5)
    5036:  fb043783           ld a5,-80(s0)
    503a:  8389                 srli a5,a5,0x2
    503c:  0007871b           sext.w a4,a5
    5040:  fb843783           ld a5,-72(s0)
    5044:  08e7a223           sw a4,132(a5)
    5048:  fb843783           ld a5,-72(s0)
    504c:  20070737           lui a4,0x20070
    5050:  0f87071b           addiw a4,a4,248
    5054:  c3b8                 sw a4,64(a5)
    5056:  4781                 li a5,0
    5058:  853e                 mv a0,a5
    505a:  70e6                 ld ra,120(sp)
    505c:  7446                 ld s0,112(sp)
    505e:  74a6                 ld s1,104(sp)
    5060:  6109                 addi sp,sp,128
    5062:  8082                 ret
0000000000005064 <FUN_00005064>:
    5064:  7119                 addi sp,sp,-128
    5066:  fc86                 sd ra,120(sp)
    5068:  f8a2                 sd s0,112(sp)
    506a:  0100                 addi s0,sp,128
    506c:  f8a43c23           sd a0,-104(s0)
    5070:  f8b43823           sd a1,-112(s0)
    5074:  f8c43423           sd a2,-120(s0)
    5078:  f9843783           ld a5,-104(s0)
    507c:  639c                 ld a5,0(a5)
    507e:  fcf43c23           sd a5,-40(s0)
    5082:  fd843783           ld a5,-40(s0)
    5086:  639c                 ld a5,0(a5)
    5088:  fcf43823           sd a5,-48(s0)
    508c:  800007b7           lui a5,0x80000
    5090:  fef42623           sw a5,-20(s0)
    5094:  fe042423           sw zero,-24(s0)
    5098:  fc042623           sw zero,-52(s0)
    509c:  fe042223           sw zero,-28(s0)
    50a0:  fc042423           sw zero,-56(s0)
    50a4:  fe042023           sw zero,-32(s0)
    50a8:  fc043023           sd zero,-64(s0)
    50ac:  fa043c23           sd zero,-72(s0)
    50b0:  fa043823           sd zero,-80(s0)
    50b4:  591020ef           jal ra,7e44 <brom_config_bit_2>
    50b8:  87aa                 mv a5,a0
    50ba:  c781                 beqz a5,50c2 <FUN_00005064+0x5e>
    50bc:  fe042023           sw zero,-32(s0)
    50c0:  a021                 j 50c8 <FUN_00005064+0x64>
    50c2:  4785                 li a5,1
    50c4:  fef42023           sw a5,-32(s0)
    50c8:  fd843783           ld a5,-40(s0)
    50cc:  539c                 lw a5,32(a5)
    50ce:  c399                 beqz a5,50d4 <FUN_00005064+0x70>
    50d0:  57fd                 li a5,-1
    50d2:  a5d5                 j 57b6 <FUN_00005064+0x752>
    50d4:  f9043783           ld a5,-112(s0)
    50d8:  439c                 lw a5,0(a5)
    50da:  e799                 bnez a5,50e8 <FUN_00005064+0x84>
    50dc:  fec42703           lw a4,-20(s0)
    50e0:  67a1                 lui a5,0x8
    50e2:  8fd9                 or a5,a5,a4
    50e4:  fef42623           sw a5,-20(s0)
    50e8:  f9043783           ld a5,-112(s0)
    50ec:  43dc                 lw a5,4(a5)
    50ee:  8b85                 andi a5,a5,1
    50f0:  2781                 sext.w a5,a5
    50f2:  c799                 beqz a5,5100 <FUN_00005064+0x9c>
    50f4:  fec42783           lw a5,-20(s0)
    50f8:  0407e793           ori a5,a5,64
    50fc:  fef42623           sw a5,-20(s0)
    5100:  f9043783           ld a5,-112(s0)
    5104:  43dc                 lw a5,4(a5)
    5106:  8b89                 andi a5,a5,2
    5108:  2781                 sext.w a5,a5
    510a:  c799                 beqz a5,5118 <FUN_00005064+0xb4>
    510c:  fec42783           lw a5,-20(s0)
    5110:  0807e793           ori a5,a5,128
    5114:  fef42623           sw a5,-20(s0)
    5118:  f9043783           ld a5,-112(s0)
    511c:  43dc                 lw a5,4(a5)
    511e:  8b91                 andi a5,a5,4
    5120:  2781                 sext.w a5,a5
    5122:  c799                 beqz a5,5130 <FUN_00005064+0xcc>
    5124:  fec42783           lw a5,-20(s0)
    5128:  1007e793           ori a5,a5,256
    512c:  fef42623           sw a5,-20(s0)
    5130:  f9043783           ld a5,-112(s0)
    5134:  4fdc                 lw a5,28(a5)
    5136:  8b85                 andi a5,a5,1
    5138:  2781                 sext.w a5,a5
    513a:  cb81                 beqz a5,514a <FUN_00005064+0xe6>
    513c:  fec42703           lw a4,-20(s0)
    5140:  050007b7           lui a5,0x5000
    5144:  8fd9                 or a5,a5,a4
    5146:  fef42623           sw a5,-20(s0)
    514a:  f9043783           ld a5,-112(s0)
    514e:  4798                 lw a4,8(a5)
    5150:  fd043783           ld a5,-48(s0)
    5154:  cfd8                 sw a4,28(a5)
    5156:  f8843783           ld a5,-120(s0)
    515a:  ef89                 bnez a5,5174 <FUN_00005064+0x110>
    515c:  f9043783           ld a5,-112(s0)
    5160:  4398                 lw a4,0(a5)
    5162:  fec42783           lw a5,-20(s0)
    5166:  8fd9                 or a5,a5,a4
    5168:  0007871b           sext.w a4,a5
    516c:  fd043783           ld a5,-48(s0)
    5170:  cf98                 sw a4,24(a5)
    5172:  aa2d                 j 52ac <FUN_00005064+0x248>
    5174:  f8843783           ld a5,-120(s0)
    5178:  639c                 ld a5,0(a5)
    517a:  8b8d                 andi a5,a5,3
    517c:  c789                 beqz a5,5186 <FUN_00005064+0x122>
    517e:  57f1                 li a5,-4
    5180:  fef42423           sw a5,-24(s0)
    5184:  a35d                 j 572a <FUN_00005064+0x6c6>
    5186:  fec42703           lw a4,-20(s0)
    518a:  6789                 lui a5,0x2
    518c:  20078793           addi a5,a5,512 # 2200 <FUN_000021f0+0x10>
    5190:  8fd9                 or a5,a5,a4
    5192:  fef42623           sw a5,-20(s0)
    5196:  f8843783           ld a5,-120(s0)
    519a:  479c                 lw a5,8(a5)
    519c:  8b89                 andi a5,a5,2
    519e:  2781                 sext.w a5,a5
    51a0:  c799                 beqz a5,51ae <FUN_00005064+0x14a>
    51a2:  fec42783           lw a5,-20(s0)
    51a6:  4007e793           ori a5,a5,1024
    51aa:  fef42623           sw a5,-20(s0)
    51ae:  f8843783           ld a5,-120(s0)
    51b2:  47d8                 lw a4,12(a5)
    51b4:  f8843783           ld a5,-120(s0)
    51b8:  4b9c                 lw a5,16(a5)
    51ba:  02f707bb           mulw a5,a4,a5
    51be:  fcf42423           sw a5,-56(s0)
    51c2:  f8843783           ld a5,-120(s0)
    51c6:  4b98                 lw a4,16(a5)
    51c8:  fd043783           ld a5,-48(s0)
    51cc:  cb98                 sw a4,16(a5)
    51ce:  fd043783           ld a5,-48(s0)
    51d2:  fc842703           lw a4,-56(s0)
    51d6:  cbd8                 sw a4,20(a5)
    51d8:  fc842783           lw a5,-56(s0)
    51dc:  0007871b           sext.w a4,a5
    51e0:  04000793           li a5,64
    51e4:  06e7f263           bgeu a5,a4,5248 <FUN_00005064+0x1e4>
    51e8:  fe042783           lw a5,-32(s0)
    51ec:  2781                 sext.w a5,a5
    51ee:  cfa9                 beqz a5,5248 <FUN_00005064+0x1e4>
    51f0:  4785                 li a5,1
    51f2:  fef42223           sw a5,-28(s0)
    51f6:  fd043783           ld a5,-48(s0)
    51fa:  439c                 lw a5,0(a5)
    51fc:  2781                 sext.w a5,a5
    51fe:  873e                 mv a4,a5
    5200:  800007b7           lui a5,0x80000
    5204:  fff7c793           not a5,a5
    5208:  8ff9                 and a5,a5,a4
    520a:  0007871b           sext.w a4,a5
    520e:  fd043783           ld a5,-48(s0)
    5212:  c398                 sw a4,0(a5)
    5214:  f8843583           ld a1,-120(s0)
    5218:  f9843503           ld a0,-104(s0)
    521c:  b03ff0ef           jal ra,4d1e <FUN_00004d1e>
    5220:  87aa                 mv a5,a0
    5222:  fef42423           sw a5,-24(s0)
    5226:  fe842783           lw a5,-24(s0)
    522a:  2781                 sext.w a5,a5
    522c:  4e079e63           bnez a5,5728 <FUN_00005064+0x6c4>
    5230:  f9043783           ld a5,-112(s0)
    5234:  4398                 lw a4,0(a5)
    5236:  fec42783           lw a5,-20(s0)
    523a:  8fd9                 or a5,a5,a4
    523c:  0007871b           sext.w a4,a5
    5240:  fd043783           ld a5,-48(s0)
    5244:  cf98                 sw a4,24(a5)
    5246:  a899                 j 529c <FUN_00005064+0x238>
    5248:  fd043783           ld a5,-48(s0)
    524c:  439c                 lw a5,0(a5)
    524e:  2781                 sext.w a5,a5
    5250:  873e                 mv a4,a5
    5252:  800007b7           lui a5,0x80000
    5256:  8fd9                 or a5,a5,a4
    5258:  0007871b           sext.w a4,a5
    525c:  fd043783           ld a5,-48(s0)
    5260:  c398                 sw a4,0(a5)
    5262:  f9043783           ld a5,-112(s0)
    5266:  4398                 lw a4,0(a5)
    5268:  fec42783           lw a5,-20(s0)
    526c:  8fd9                 or a5,a5,a4
    526e:  0007871b           sext.w a4,a5
    5272:  fd043783           ld a5,-48(s0)
    5276:  cf98                 sw a4,24(a5)
    5278:  f9043783           ld a5,-112(s0)
    527c:  4fdc                 lw a5,28(a5)
    527e:  8b85                 andi a5,a5,1
    5280:  2781                 sext.w a5,a5
    5282:  c781                 beqz a5,528a <FUN_00005064+0x226>
    5284:  fe042423           sw zero,-24(s0)
    5288:  a811                 j 529c <FUN_00005064+0x238>
    528a:  f8843583           ld a1,-120(s0)
    528e:  f9843503           ld a0,-104(s0)
    5292:  953ff0ef           jal ra,4be4 <FUN_00004be4>
    5296:  87aa                 mv a5,a0
    5298:  fef42423           sw a5,-24(s0)
    529c:  fe842783           lw a5,-24(s0)
    52a0:  2781                 sext.w a5,a5
    52a2:  c789                 beqz a5,52ac <FUN_00005064+0x248>
    52a4:  57f5                 li a5,-3
    52a6:  fef42423           sw a5,-24(s0)
    52aa:  a141                 j 572a <FUN_00005064+0x6c6>
    52ac:  f9043783           ld a5,-112(s0)
    52b0:  4fdc                 lw a5,28(a5)
    52b2:  8b85                 andi a5,a5,1
    52b4:  2781                 sext.w a5,a5
    52b6:  20078463           beqz a5,54be <FUN_00005064+0x45a>
    52ba:  6c5040ef           jal ra,a17e <rdtime>
    52be:  fca43023           sd a0,-64(s0)
    52c2:  06400593           li a1,100
    52c6:  fd843503           ld a0,-40(s0)
    52ca:  f6ffe0ef           jal ra,4238 <FUN_00004238>
    52ce:  faa43823           sd a0,-80(s0)
    52d2:  6ad040ef           jal ra,a17e <rdtime>
    52d6:  872a                 mv a4,a0
    52d8:  fc043783           ld a5,-64(s0)
    52dc:  40f707b3           sub a5,a4,a5
    52e0:  faf43c23           sd a5,-72(s0)
    52e4:  fd043783           ld a5,-48(s0)
    52e8:  5f9c                 lw a5,56(a5)
    52ea:  2781                 sext.w a5,a5
    52ec:  873e                 mv a4,a5
    52ee:  67b1                 lui a5,0xc
    52f0:  9c278793           addi a5,a5,-1598 # b9c2 <FUN_0000b908+0xba>
    52f4:  8ff9                 and a5,a5,a4
    52f6:  2781                 sext.w a5,a5
    52f8:  eb81                 bnez a5,5308 <FUN_00005064+0x2a4>
    52fa:  fb843703           ld a4,-72(s0)
    52fe:  fb043783           ld a5,-80(s0)
    5302:  fcf768e3           bltu a4,a5,52d2 <FUN_00005064+0x26e>
    5306:  a011                 j 530a <FUN_00005064+0x2a6>
    5308:  0001                 nop
    530a:  fb843703           ld a4,-72(s0)
    530e:  fb043783           ld a5,-80(s0)
    5312:  00f77d63           bgeu a4,a5,532c <FUN_00005064+0x2c8>
    5316:  fd043783           ld a5,-48(s0)
    531a:  5f9c                 lw a5,56(a5)
    531c:  2781                 sext.w a5,a5
    531e:  873e                 mv a4,a5
    5320:  67b1                 lui a5,0xc
    5322:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    5326:  8ff9                 and a5,a5,a4
    5328:  2781                 sext.w a5,a5
    532a:  cb8d                 beqz a5,535c <FUN_00005064+0x2f8>
    532c:  fd043783           ld a5,-48(s0)
    5330:  5f9c                 lw a5,56(a5)
    5332:  2781                 sext.w a5,a5
    5334:  873e                 mv a4,a5
    5336:  67b1                 lui a5,0xc
    5338:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    533c:  8ff9                 and a5,a5,a4
    533e:  2781                 sext.w a5,a5
    5340:  c789                 beqz a5,534a <FUN_00005064+0x2e6>
    5342:  57f5                 li a5,-3
    5344:  fef42423           sw a5,-24(s0)
    5348:  a021                 j 5350 <FUN_00005064+0x2ec>
    534a:  57ed                 li a5,-5
    534c:  fef42423           sw a5,-24(s0)
    5350:  fd043783           ld a5,-48(s0)
    5354:  88000737           lui a4,0x88000
    5358:  cf98                 sw a4,24(a5)
    535a:  aec1                 j 572a <FUN_00005064+0x6c6>
    535c:  fd043783           ld a5,-48(s0)
    5360:  10000713           li a4,256
    5364:  df98                 sw a4,56(a5)
    5366:  619040ef           jal ra,a17e <rdtime>
    536a:  fca43023           sd a0,-64(s0)
    536e:  3b600593           li a1,950
    5372:  fd843503           ld a0,-40(s0)
    5376:  ec3fe0ef           jal ra,4238 <FUN_00004238>
    537a:  faa43823           sd a0,-80(s0)
    537e:  601040ef           jal ra,a17e <rdtime>
    5382:  872a                 mv a4,a0
    5384:  fc043783           ld a5,-64(s0)
    5388:  40f707b3           sub a5,a4,a5
    538c:  faf43c23           sd a5,-72(s0)
    5390:  fd043783           ld a5,-48(s0)
    5394:  5f9c                 lw a5,56(a5)
    5396:  2781                 sext.w a5,a5
    5398:  873e                 mv a4,a5
    539a:  67b1                 lui a5,0xc
    539c:  ac278793           addi a5,a5,-1342 # bac2 <FUN_0000ba8a+0x38>
    53a0:  8ff9                 and a5,a5,a4
    53a2:  2781                 sext.w a5,a5
    53a4:  eb81                 bnez a5,53b4 <FUN_00005064+0x350>
    53a6:  fb843703           ld a4,-72(s0)
    53aa:  fb043783           ld a5,-80(s0)
    53ae:  fcf768e3           bltu a4,a5,537e <FUN_00005064+0x31a>
    53b2:  a011                 j 53b6 <FUN_00005064+0x352>
    53b4:  0001                 nop
    53b6:  fb843703           ld a4,-72(s0)
    53ba:  fb043783           ld a5,-80(s0)
    53be:  00f77d63           bgeu a4,a5,53d8 <FUN_00005064+0x374>
    53c2:  fd043783           ld a5,-48(s0)
    53c6:  5f9c                 lw a5,56(a5)
    53c8:  2781                 sext.w a5,a5
    53ca:  873e                 mv a4,a5
    53cc:  67b1                 lui a5,0xc
    53ce:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    53d2:  8ff9                 and a5,a5,a4
    53d4:  2781                 sext.w a5,a5
    53d6:  cb8d                 beqz a5,5408 <FUN_00005064+0x3a4>
    53d8:  fd043783           ld a5,-48(s0)
    53dc:  5f9c                 lw a5,56(a5)
    53de:  2781                 sext.w a5,a5
    53e0:  873e                 mv a4,a5
    53e2:  67b1                 lui a5,0xc
    53e4:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    53e8:  8ff9                 and a5,a5,a4
    53ea:  2781                 sext.w a5,a5
    53ec:  c789                 beqz a5,53f6 <FUN_00005064+0x392>
    53ee:  57f5                 li a5,-3
    53f0:  fef42423           sw a5,-24(s0)
    53f4:  a021                 j 53fc <FUN_00005064+0x398>
    53f6:  57e9                 li a5,-6
    53f8:  fef42423           sw a5,-24(s0)
    53fc:  fd043783           ld a5,-48(s0)
    5400:  88000737           lui a4,0x88000
    5404:  cf98                 sw a4,24(a5)
    5406:  a615                 j 572a <FUN_00005064+0x6c6>
    5408:  fd043783           ld a5,-48(s0)
    540c:  20000713           li a4,512
    5410:  df98                 sw a4,56(a5)
    5412:  fe442783           lw a5,-28(s0)
    5416:  2781                 sext.w a5,a5
    5418:  eb99                 bnez a5,542e <FUN_00005064+0x3ca>
    541a:  f8843583           ld a1,-120(s0)
    541e:  f9843503           ld a0,-104(s0)
    5422:  fc2ff0ef           jal ra,4be4 <FUN_00004be4>
    5426:  87aa                 mv a5,a0
    5428:  fef42423           sw a5,-24(s0)
    542c:  a849                 j 54be <FUN_00005064+0x45a>
    542e:  551040ef           jal ra,a17e <rdtime>
    5432:  fca43023           sd a0,-64(s0)
    5436:  5dc00593           li a1,1500
    543a:  fd843503           ld a0,-40(s0)
    543e:  dfbfe0ef           jal ra,4238 <FUN_00004238>
    5442:  faa43823           sd a0,-80(s0)
    5446:  539040ef           jal ra,a17e <rdtime>
    544a:  872a                 mv a4,a0
    544c:  fc043783           ld a5,-64(s0)
    5450:  40f707b3           sub a5,a4,a5
    5454:  faf43c23           sd a5,-72(s0)
    5458:  fd043783           ld a5,-48(s0)
    545c:  0887a783           lw a5,136(a5)
    5460:  2781                 sext.w a5,a5
    5462:  8b89                 andi a5,a5,2
    5464:  2781                 sext.w a5,a5
    5466:  e395                 bnez a5,548a <FUN_00005064+0x426>
    5468:  fd043783           ld a5,-48(s0)
    546c:  5f9c                 lw a5,56(a5)
    546e:  2781                 sext.w a5,a5
    5470:  873e                 mv a4,a5
    5472:  67b1                 lui a5,0xc
    5474:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    5478:  8ff9                 and a5,a5,a4
    547a:  2781                 sext.w a5,a5
    547c:  e799                 bnez a5,548a <FUN_00005064+0x426>
    547e:  fb843703           ld a4,-72(s0)
    5482:  fb043783           ld a5,-80(s0)
    5486:  fcf760e3           bltu a4,a5,5446 <FUN_00005064+0x3e2>
    548a:  fb843703           ld a4,-72(s0)
    548e:  fb043783           ld a5,-80(s0)
    5492:  00f77d63           bgeu a4,a5,54ac <FUN_00005064+0x448>
    5496:  fd043783           ld a5,-48(s0)
    549a:  5f9c                 lw a5,56(a5)
    549c:  2781                 sext.w a5,a5
    549e:  873e                 mv a4,a5
    54a0:  67b1                 lui a5,0xc
    54a2:  8c278793           addi a5,a5,-1854 # b8c2 <FUN_0000b876+0x4c>
    54a6:  8ff9                 and a5,a5,a4
    54a8:  2781                 sext.w a5,a5
    54aa:  cb91                 beqz a5,54be <FUN_00005064+0x45a>
    54ac:  57e1                 li a5,-8
    54ae:  fef42423           sw a5,-24(s0)
    54b2:  fd043783           ld a5,-48(s0)
    54b6:  88000737           lui a4,0x88000
    54ba:  cf98                 sw a4,24(a5)
    54bc:  a4bd                 j 572a <FUN_00005064+0x6c6>
    54be:  4c1040ef           jal ra,a17e <rdtime>
    54c2:  fca43023           sd a0,-64(s0)
    54c6:  4589                 li a1,2
    54c8:  fd843503           ld a0,-40(s0)
    54cc:  d6dfe0ef           jal ra,4238 <FUN_00004238>
    54d0:  faa43823           sd a0,-80(s0)
    54d4:  4ab040ef           jal ra,a17e <rdtime>
    54d8:  872a                 mv a4,a0
    54da:  fc043783           ld a5,-64(s0)
    54de:  40f707b3           sub a5,a4,a5
    54e2:  faf43c23           sd a5,-72(s0)
    54e6:  fd043783           ld a5,-48(s0)
    54ea:  5f9c                 lw a5,56(a5)
    54ec:  fcf42623           sw a5,-52(s0)
    54f0:  fcc42703           lw a4,-52(s0)
    54f4:  67b1                 lui a5,0xc
    54f6:  bc678793           addi a5,a5,-1082 # bbc6 <FUN_0000bbb0+0x16>
    54fa:  8ff9                 and a5,a5,a4
    54fc:  2781                 sext.w a5,a5
    54fe:  eb81                 bnez a5,550e <FUN_00005064+0x4aa>
    5500:  fb843703           ld a4,-72(s0)
    5504:  fb043783           ld a5,-80(s0)
    5508:  fcf766e3           bltu a4,a5,54d4 <FUN_00005064+0x470>
    550c:  a011                 j 5510 <FUN_00005064+0x4ac>
    550e:  0001                 nop
    5510:  fb843703           ld a4,-72(s0)
    5514:  fb043783           ld a5,-80(s0)
    5518:  00f77a63           bgeu a4,a5,552c <FUN_00005064+0x4c8>
    551c:  fcc42703           lw a4,-52(s0)
    5520:  67b1                 lui a5,0xc
    5522:  bc278793           addi a5,a5,-1086 # bbc2 <FUN_0000bbb0+0x12>
    5526:  8ff9                 and a5,a5,a4
    5528:  2781                 sext.w a5,a5
    552a:  c789                 beqz a5,5534 <FUN_00005064+0x4d0>
    552c:  57f9                 li a5,-2
    552e:  fef42423           sw a5,-24(s0)
    5532:  aae5                 j 572a <FUN_00005064+0x6c6>
    5534:  f8843783           ld a5,-120(s0)
    5538:  12078063           beqz a5,5658 <FUN_00005064+0x5f4>
    553c:  fa042623           sw zero,-84(s0)
    5540:  43f040ef           jal ra,a17e <rdtime>
    5544:  fca43023           sd a0,-64(s0)
    5548:  5dc00593           li a1,1500
    554c:  fd843503           ld a0,-40(s0)
    5550:  ce9fe0ef           jal ra,4238 <FUN_00004238>
    5554:  faa43823           sd a0,-80(s0)
    5558:  67b1                 lui a5,0xc
    555a:  bca7879b           addiw a5,a5,-1078
    555e:  faf42623           sw a5,-84(s0)
    5562:  41d040ef           jal ra,a17e <rdtime>
    5566:  872a                 mv a4,a0
    5568:  fc043783           ld a5,-64(s0)
    556c:  40f707b3           sub a5,a4,a5
    5570:  faf43c23           sd a5,-72(s0)
    5574:  fd043783           ld a5,-48(s0)
    5578:  5f9c                 lw a5,56(a5)
    557a:  fcf42623           sw a5,-52(s0)
    557e:  fcc42703           lw a4,-52(s0)
    5582:  fac42783           lw a5,-84(s0)
    5586:  8ff9                 and a5,a5,a4
    5588:  2781                 sext.w a5,a5
    558a:  eb81                 bnez a5,559a <FUN_00005064+0x536>
    558c:  fb843703           ld a4,-72(s0)
    5590:  fb043783           ld a5,-80(s0)
    5594:  fcf767e3           bltu a4,a5,5562 <FUN_00005064+0x4fe>
    5598:  a011                 j 559c <FUN_00005064+0x538>
    559a:  0001                 nop
    559c:  fb843703           ld a4,-72(s0)
    55a0:  fb043783           ld a5,-80(s0)
    55a4:  00f77a63           bgeu a4,a5,55b8 <FUN_00005064+0x554>
    55a8:  fcc42703           lw a4,-52(s0)
    55ac:  67b1                 lui a5,0xc
    55ae:  bc278793           addi a5,a5,-1086 # bbc2 <FUN_0000bbb0+0x12>
    55b2:  8ff9                 and a5,a5,a4
    55b4:  2781                 sext.w a5,a5
    55b6:  c789                 beqz a5,55c0 <FUN_00005064+0x55c>
    55b8:  57f5                 li a5,-3
    55ba:  fef42423           sw a5,-24(s0)
    55be:  a2b5                 j 572a <FUN_00005064+0x6c6>
    55c0:  fe442783           lw a5,-28(s0)
    55c4:  2781                 sext.w a5,a5
    55c6:  cbc9                 beqz a5,5658 <FUN_00005064+0x5f4>
    55c8:  f9043783           ld a5,-112(s0)
    55cc:  4fdc                 lw a5,28(a5)
    55ce:  8b85                 andi a5,a5,1
    55d0:  2781                 sext.w a5,a5
    55d2:  e3d9                 bnez a5,5658 <FUN_00005064+0x5f4>
    55d4:  3ab040ef           jal ra,a17e <rdtime>
    55d8:  fca43023           sd a0,-64(s0)
    55dc:  5dc00593           li a1,1500
    55e0:  fd843503           ld a0,-40(s0)
    55e4:  c55fe0ef           jal ra,4238 <FUN_00004238>
    55e8:  faa43823           sd a0,-80(s0)
    55ec:  393040ef           jal ra,a17e <rdtime>
    55f0:  872a                 mv a4,a0
    55f2:  fc043783           ld a5,-64(s0)
    55f6:  40f707b3           sub a5,a4,a5
    55fa:  faf43c23           sd a5,-72(s0)
    55fe:  fd043783           ld a5,-48(s0)
    5602:  5f9c                 lw a5,56(a5)
    5604:  fcf42623           sw a5,-52(s0)
    5608:  fd043783           ld a5,-48(s0)
    560c:  0887a783           lw a5,136(a5)
    5610:  2781                 sext.w a5,a5
    5612:  8b89                 andi a5,a5,2
    5614:  2781                 sext.w a5,a5
    5616:  ef99                 bnez a5,5634 <FUN_00005064+0x5d0>
    5618:  fcc42703           lw a4,-52(s0)
    561c:  67b1                 lui a5,0xc
    561e:  bc278793           addi a5,a5,-1086 # bbc2 <FUN_0000bbb0+0x12>
    5622:  8ff9                 and a5,a5,a4
    5624:  2781                 sext.w a5,a5
    5626:  e799                 bnez a5,5634 <FUN_00005064+0x5d0>
    5628:  fb843703           ld a4,-72(s0)
    562c:  fb043783           ld a5,-80(s0)
    5630:  faf76ee3           bltu a4,a5,55ec <FUN_00005064+0x588>
    5634:  fb843703           ld a4,-72(s0)
    5638:  fb043783           ld a5,-80(s0)
    563c:  00f77a63           bgeu a4,a5,5650 <FUN_00005064+0x5ec>
    5640:  fcc42703           lw a4,-52(s0)
    5644:  67b1                 lui a5,0xc
    5646:  bc278793           addi a5,a5,-1086 # bbc2 <FUN_0000bbb0+0x12>
    564a:  8ff9                 and a5,a5,a4
    564c:  2781                 sext.w a5,a5
    564e:  c789                 beqz a5,5658 <FUN_00005064+0x5f4>
    5650:  57e1                 li a5,-8
    5652:  fef42423           sw a5,-24(s0)
    5656:  a8d1                 j 572a <FUN_00005064+0x6c6>
    5658:  f9043783           ld a5,-112(s0)
    565c:  43dc                 lw a5,4(a5)
    565e:  8ba1                 andi a5,a5,8
    5660:  2781                 sext.w a5,a5
    5662:  c3bd                 beqz a5,56c8 <FUN_00005064+0x664>
    5664:  31b040ef           jal ra,a17e <rdtime>
    5668:  fca43023           sd a0,-64(s0)
    566c:  0c800593           li a1,200
    5670:  fd843503           ld a0,-40(s0)
    5674:  bc5fe0ef           jal ra,4238 <FUN_00004238>
    5678:  faa43823           sd a0,-80(s0)
    567c:  303040ef           jal ra,a17e <rdtime>
    5680:  872a                 mv a4,a0
    5682:  fc043783           ld a5,-64(s0)
    5686:  40f707b3           sub a5,a4,a5
    568a:  faf43c23           sd a5,-72(s0)
    568e:  fd043783           ld a5,-48(s0)
    5692:  5fdc                 lw a5,60(a5)
    5694:  fcf42623           sw a5,-52(s0)
    5698:  fcc42783           lw a5,-52(s0)
    569c:  2007f793           andi a5,a5,512
    56a0:  2781                 sext.w a5,a5
    56a2:  cb81                 beqz a5,56b2 <FUN_00005064+0x64e>
    56a4:  fb843703           ld a4,-72(s0)
    56a8:  fb043783           ld a5,-80(s0)
    56ac:  fcf768e3           bltu a4,a5,567c <FUN_00005064+0x618>
    56b0:  a011                 j 56b4 <FUN_00005064+0x650>
    56b2:  0001                 nop
    56b4:  fb843703           ld a4,-72(s0)
    56b8:  fb043783           ld a5,-80(s0)
    56bc:  00f76663           bltu a4,a5,56c8 <FUN_00005064+0x664>
    56c0:  57f5                 li a5,-3
    56c2:  fef42423           sw a5,-24(s0)
    56c6:  a095                 j 572a <FUN_00005064+0x6c6>
    56c8:  f9043783           ld a5,-112(s0)
    56cc:  43dc                 lw a5,4(a5)
    56ce:  8b89                 andi a5,a5,2
    56d0:  2781                 sext.w a5,a5
    56d2:  c3b1                 beqz a5,5716 <FUN_00005064+0x6b2>
    56d4:  fd043783           ld a5,-48(s0)
    56d8:  57dc                 lw a5,44(a5)
    56da:  0007871b           sext.w a4,a5
    56de:  f9043783           ld a5,-112(s0)
    56e2:  c7d8                 sw a4,12(a5)
    56e4:  fd043783           ld a5,-48(s0)
    56e8:  579c                 lw a5,40(a5)
    56ea:  0007871b           sext.w a4,a5
    56ee:  f9043783           ld a5,-112(s0)
    56f2:  cb98                 sw a4,16(a5)
    56f4:  fd043783           ld a5,-48(s0)
    56f8:  53dc                 lw a5,36(a5)
    56fa:  0007871b           sext.w a4,a5
    56fe:  f9043783           ld a5,-112(s0)
    5702:  cbd8                 sw a4,20(a5)
    5704:  fd043783           ld a5,-48(s0)
    5708:  539c                 lw a5,32(a5)
    570a:  0007871b           sext.w a4,a5
    570e:  f9043783           ld a5,-112(s0)
    5712:  cf98                 sw a4,24(a5)
    5714:  a819                 j 572a <FUN_00005064+0x6c6>
    5716:  fd043783           ld a5,-48(s0)
    571a:  539c                 lw a5,32(a5)
    571c:  0007871b           sext.w a4,a5
    5720:  f9043783           ld a5,-112(s0)
    5724:  c7d8                 sw a4,12(a5)
    5726:  a011                 j 572a <FUN_00005064+0x6c6>
    5728:  0001                 nop
    572a:  f8843783           ld a5,-120(s0)
    572e:  c7a1                 beqz a5,5776 <FUN_00005064+0x712>
    5730:  fe442783           lw a5,-28(s0)
    5734:  2781                 sext.w a5,a5
    5736:  c3a1                 beqz a5,5776 <FUN_00005064+0x712>
    5738:  fd043783           ld a5,-48(s0)
    573c:  0887a783           lw a5,136(a5)
    5740:  fcf42623           sw a5,-52(s0)
    5744:  fd043783           ld a5,-48(s0)
    5748:  fcc42703           lw a4,-52(s0)
    574c:  08e7a423           sw a4,136(a5)
    5750:  fd043783           ld a5,-48(s0)
    5754:  0807a623           sw zero,140(a5)
    5758:  fd043783           ld a5,-48(s0)
    575c:  0807a023           sw zero,128(a5)
    5760:  fd043783           ld a5,-48(s0)
    5764:  439c                 lw a5,0(a5)
    5766:  2781                 sext.w a5,a5
    5768:  fdf7f793           andi a5,a5,-33
    576c:  0007871b           sext.w a4,a5
    5770:  fd043783           ld a5,-48(s0)
    5774:  c398                 sw a4,0(a5)
    5776:  fe842783           lw a5,-24(s0)
    577a:  2781                 sext.w a5,a5
    577c:  c79d                 beqz a5,57aa <FUN_00005064+0x746>
    577e:  fd043783           ld a5,-48(s0)
    5782:  471d                 li a4,7
    5784:  c398                 sw a4,0(a5)
    5786:  f9843503           ld a0,-104(s0)
    578a:  e0dfe0ef           jal ra,4596 <FUN_00004596>
    578e:  87aa                 mv a5,a0
    5790:  faf42423           sw a5,-88(s0)
    5794:  fa842783           lw a5,-88(s0)
    5798:  2781                 sext.w a5,a5
    579a:  c781                 beqz a5,57a2 <FUN_00005064+0x73e>
    579c:  fa842783           lw a5,-88(s0)
    57a0:  a819                 j 57b6 <FUN_00005064+0x752>
    57a2:  f9843503           ld a0,-104(s0)
    57a6:  d33fe0ef           jal ra,44d8 <FUN_000044d8>
    57aa:  fd043783           ld a5,-48(s0)
    57ae:  577d                 li a4,-1
    57b0:  df98                 sw a4,56(a5)
    57b2:  fe842783           lw a5,-24(s0)
    57b6:  853e                 mv a0,a5
    57b8:  70e6                 ld ra,120(sp)
    57ba:  7446                 ld s0,112(sp)
    57bc:  6109                 addi sp,sp,128
    57be:  8082                 ret
00000000000057c0 <FUN_000057c0>:
    57c0:  7179                 addi sp,sp,-48
    57c2:  f406                 sd ra,40(sp)
    57c4:  f022                 sd s0,32(sp)
    57c6:  1800                 addi s0,sp,48
    57c8:  87aa                 mv a5,a0
    57ca:  fcb43823           sd a1,-48(s0)
    57ce:  fcf42e23           sw a5,-36(s0)
    57d2:  fd043783           ld a5,-48(s0)
    57d6:  639c                 ld a5,0(a5)
    57d8:  fef43423           sd a5,-24(s0)
    57dc:  fdc42783           lw a5,-36(s0)
    57e0:  fe843583           ld a1,-24(s0)
    57e4:  853e                 mv a0,a5
    57e6:  a7ffe0ef           jal ra,4264 <FUN_00004264>
    57ea:  fe843783           ld a5,-24(s0)
    57ee:  639c                 ld a5,0(a5)
    57f0:  471d                 li a4,7
    57f2:  c398                 sw a4,0(a5)
    57f4:  fd043503           ld a0,-48(s0)
    57f8:  d9ffe0ef           jal ra,4596 <FUN_00004596>
    57fc:  87aa                 mv a5,a0
    57fe:  fef42223           sw a5,-28(s0)
    5802:  fe442783           lw a5,-28(s0)
    5806:  2781                 sext.w a5,a5
    5808:  c781                 beqz a5,5810 <FUN_000057c0+0x50>
    580a:  fe442783           lw a5,-28(s0)
    580e:  a081                 j 584e <FUN_000057c0+0x8e>
    5810:  fd043783           ld a5,-48(s0)
    5814:  6705                 lui a4,0x1
    5816:  9117071b           addiw a4,a4,-1775
    581a:  d798                 sw a4,40(a5)
    581c:  fd043783           ld a5,-48(s0)
    5820:  00fe0737           lui a4,0xfe0
    5824:  c798                 sw a4,8(a5)
    5826:  fd043783           ld a5,-48(s0)
    582a:  00062737           lui a4,0x62
    582e:  a807071b           addiw a4,a4,-1408
    5832:  cb98                 sw a4,16(a5)
    5834:  fd043783           ld a5,-48(s0)
    5838:  03197737           lui a4,0x3197
    583c:  5007071b           addiw a4,a4,1280
    5840:  cbd8                 sw a4,20(a5)
    5842:  fd043783           ld a5,-48(s0)
    5846:  fdc42703           lw a4,-36(s0)
    584a:  cbb8                 sw a4,80(a5)
    584c:  4781                 li a5,0
    584e:  853e                 mv a0,a5
    5850:  70a2                 ld ra,40(sp)
    5852:  7402                 ld s0,32(sp)
    5854:  6145                 addi sp,sp,48
    5856:  8082                 ret
0000000000005858 <FUN_00005858>:
    5858:  7179                 addi sp,sp,-48
    585a:  f406                 sd ra,40(sp)
    585c:  f022                 sd s0,32(sp)
    585e:  1800                 addi s0,sp,48
    5860:  87aa                 mv a5,a0
    5862:  fcb43823           sd a1,-48(s0)
    5866:  fcf42e23           sw a5,-36(s0)
    586a:  fd043783           ld a5,-48(s0)
    586e:  639c                 ld a5,0(a5)
    5870:  fef43423           sd a5,-24(s0)
    5874:  fdc42783           lw a5,-36(s0)
    5878:  fe843583           ld a1,-24(s0)
    587c:  853e                 mv a0,a5
    587e:  b65fe0ef           jal ra,43e2 <FUN_000043e2>
    5882:  4781                 li a5,0
    5884:  853e                 mv a0,a5
    5886:  70a2                 ld ra,40(sp)
    5888:  7402                 ld s0,32(sp)
    588a:  6145                 addi sp,sp,48
    588c:  8082                 ret
000000000000588e <FUN_0000588e>:
    588e:  715d                 addi sp,sp,-80
    5890:  e486                 sd ra,72(sp)
    5892:  e0a2                 sd s0,64(sp)
    5894:  0880                 addi s0,sp,80
    5896:  faa43c23           sd a0,-72(s0)
    589a:  87ae                 mv a5,a1
    589c:  faf42a23           sw a5,-76(s0)
    58a0:  47b5                 li a5,13
    58a2:  fcf42423           sw a5,-56(s0)
    58a6:  47d5                 li a5,21
    58a8:  fcf42623           sw a5,-52(s0)
    58ac:  fb843783           ld a5,-72(s0)
    58b0:  5f9c                 lw a5,56(a5)
    58b2:  0107979b           slliw a5,a5,0x10
    58b6:  2781                 sext.w a5,a5
    58b8:  fcf42823           sw a5,-48(s0)
    58bc:  fe042223           sw zero,-28(s0)
    58c0:  fc840793           addi a5,s0,-56
    58c4:  4601                 li a2,0
    58c6:  85be                 mv a1,a5
    58c8:  fb843503           ld a0,-72(s0)
    58cc:  f98ff0ef           jal ra,5064 <FUN_00005064>
    58d0:  87aa                 mv a5,a0
    58d2:  fef42623           sw a5,-20(s0)
    58d6:  fec42783           lw a5,-20(s0)
    58da:  2781                 sext.w a5,a5
    58dc:  c781                 beqz a5,58e4 <FUN_0000588e+0x56>
    58de:  fec42783           lw a5,-20(s0)
    58e2:  a0b9                 j 5930 <FUN_0000588e+0xa2>
    58e4:  fd442783           lw a5,-44(s0)
    58e8:  1007f793           andi a5,a5,256
    58ec:  2781                 sext.w a5,a5
    58ee:  eb85                 bnez a5,591e <FUN_0000588e+0x90>
    58f0:  4505                 li a0,1
    58f2:  0bd040ef           jal ra,a1ae <udelay_x800>
    58f6:  fd442783           lw a5,-44(s0)
    58fa:  873e                 mv a4,a5
    58fc:  fdf947b7           lui a5,0xfdf94
    5900:  08078793           addi a5,a5,128 # fffffffffdf94080 <gpio_get_boot_device+
    5904:  8ff9                 and a5,a5,a4
    5906:  2781                 sext.w a5,a5
    5908:  c399                 beqz a5,590e <FUN_0000588e+0x80>
    590a:  57b9                 li a5,-18
    590c:  a015                 j 5930 <FUN_0000588e+0xa2>
    590e:  fb442783           lw a5,-76(s0)
    5912:  fff7871b           addiw a4,a5,-1
    5916:  fae42a23           sw a4,-76(s0)
    591a:  f3dd                 bnez a5,58c0 <FUN_0000588e+0x32>
    591c:  a011                 j 5920 <FUN_0000588e+0x92>
    591e:  0001                 nop
    5920:  fb442783           lw a5,-76(s0)
    5924:  2781                 sext.w a5,a5
    5926:  00f04463           bgtz a5,592e <FUN_0000588e+0xa0>
    592a:  57b5                 li a5,-19
    592c:  a011                 j 5930 <FUN_0000588e+0xa2>
    592e:  4781                 li a5,0
    5930:  853e                 mv a0,a5
    5932:  60a6                 ld ra,72(sp)
    5934:  6406                 ld s0,64(sp)
    5936:  6161                 addi sp,sp,80
    5938:  8082                 ret
000000000000593a <FUN_0000593a>:
    593a:  715d                 addi sp,sp,-80
    593c:  e486                 sd ra,72(sp)
    593e:  e0a2                 sd s0,64(sp)
    5940:  0880                 addi s0,sp,80
    5942:  faa43c23           sd a0,-72(s0)
    5946:  fe042623           sw zero,-20(s0)
    594a:  fc042423           sw zero,-56(s0)
    594e:  fc042823           sw zero,-48(s0)
    5952:  fc042623           sw zero,-52(s0)
    5956:  fe042223           sw zero,-28(s0)
    595a:  fc840793           addi a5,s0,-56
    595e:  4601                 li a2,0
    5960:  85be                 mv a1,a5
    5962:  fb843503           ld a0,-72(s0)
    5966:  efeff0ef           jal ra,5064 <FUN_00005064>
    596a:  87aa                 mv a5,a0
    596c:  fef42623           sw a5,-20(s0)
    5970:  4505                 li a0,1
    5972:  03d040ef           jal ra,a1ae <udelay_x800>
    5976:  fec42783           lw a5,-20(s0)
    597a:  853e                 mv a0,a5
    597c:  60a6                 ld ra,72(sp)
    597e:  6406                 ld s0,64(sp)
    5980:  6161                 addi sp,sp,80
    5982:  8082                 ret
0000000000005984 <FUN_00005984>:
    5984:  715d                 addi sp,sp,-80
    5986:  e486                 sd ra,72(sp)
    5988:  e0a2                 sd s0,64(sp)
    598a:  0880                 addi s0,sp,80
    598c:  faa43c23           sd a0,-72(s0)
    5990:  fe042623           sw zero,-20(s0)
    5994:  fc042423           sw zero,-56(s0)
    5998:  f0f0f7b7           lui a5,0xf0f0f
    599c:  0f07879b           addiw a5,a5,240
    59a0:  fcf42823           sw a5,-48(s0)
    59a4:  fc042623           sw zero,-52(s0)
    59a8:  fe042223           sw zero,-28(s0)
    59ac:  fc840793           addi a5,s0,-56
    59b0:  4601                 li a2,0
    59b2:  85be                 mv a1,a5
    59b4:  fb843503           ld a0,-72(s0)
    59b8:  eacff0ef           jal ra,5064 <FUN_00005064>
    59bc:  87aa                 mv a5,a0
    59be:  fef42623           sw a5,-20(s0)
    59c2:  fec42783           lw a5,-20(s0)
    59c6:  853e                 mv a0,a5
    59c8:  60a6                 ld ra,72(sp)
    59ca:  6406                 ld s0,64(sp)
    59cc:  6161                 addi sp,sp,80
    59ce:  8082                 ret
00000000000059d0 <FUN_000059d0>:
    59d0:  715d                 addi sp,sp,-80
    59d2:  e486                 sd ra,72(sp)
    59d4:  e0a2                 sd s0,64(sp)
    59d6:  0880                 addi s0,sp,80
    59d8:  faa43c23           sd a0,-72(s0)
    59dc:  fe042623           sw zero,-20(s0)
    59e0:  fc042423           sw zero,-56(s0)
    59e4:  f0f0f7b7           lui a5,0xf0f0f
    59e8:  0fa7879b           addiw a5,a5,250
    59ec:  fcf42823           sw a5,-48(s0)
    59f0:  fc042623           sw zero,-52(s0)
    59f4:  fe042223           sw zero,-28(s0)
    59f8:  fc840793           addi a5,s0,-56
    59fc:  4601                 li a2,0
    59fe:  85be                 mv a1,a5
    5a00:  fb843503           ld a0,-72(s0)
    5a04:  e60ff0ef           jal ra,5064 <FUN_00005064>
    5a08:  87aa                 mv a5,a0
    5a0a:  fef42623           sw a5,-20(s0)
    5a0e:  4505                 li a0,1
    5a10:  79e040ef           jal ra,a1ae <udelay_x800>
    5a14:  fec42783           lw a5,-20(s0)
    5a18:  853e                 mv a0,a5
    5a1a:  60a6                 ld ra,72(sp)
    5a1c:  6406                 ld s0,64(sp)
    5a1e:  6161                 addi sp,sp,80
    5a20:  8082                 ret
0000000000005a22 <FUN_00005a22>:
    5a22:  715d                 addi sp,sp,-80
    5a24:  e486                 sd ra,72(sp)
    5a26:  e0a2                 sd s0,64(sp)
    5a28:  0880                 addi s0,sp,80
    5a2a:  faa43c23           sd a0,-72(s0)
    5a2e:  3e800793           li a5,1000
    5a32:  fef42623           sw a5,-20(s0)
    5a36:  03700793           li a5,55
    5a3a:  fcf42023           sw a5,-64(s0)
    5a3e:  47d5                 li a5,21
    5a40:  fcf42223           sw a5,-60(s0)
    5a44:  fc042423           sw zero,-56(s0)
    5a48:  fc042e23           sw zero,-36(s0)
    5a4c:  fc040793           addi a5,s0,-64
    5a50:  4601                 li a2,0
    5a52:  85be                 mv a1,a5
    5a54:  fb843503           ld a0,-72(s0)
    5a58:  e0cff0ef           jal ra,5064 <FUN_00005064>
    5a5c:  87aa                 mv a5,a0
    5a5e:  fef42423           sw a5,-24(s0)
    5a62:  fe842783           lw a5,-24(s0)
    5a66:  2781                 sext.w a5,a5
    5a68:  c781                 beqz a5,5a70 <FUN_00005a22+0x4e>
    5a6a:  fe842783           lw a5,-24(s0)
    5a6e:  a8c5                 j 5b5e <FUN_00005a22+0x13c>
    5a70:  02900793           li a5,41
    5a74:  fcf42023           sw a5,-64(s0)
    5a78:  4785                 li a5,1
    5a7a:  fcf42223           sw a5,-60(s0)
    5a7e:  fb843783           ld a5,-72(s0)
    5a82:  479c                 lw a5,8(a5)
    5a84:  873e                 mv a4,a5
    5a86:  00ff87b7           lui a5,0xff8
    5a8a:  8ff9                 and a5,a5,a4
    5a8c:  2781                 sext.w a5,a5
    5a8e:  fcf42423           sw a5,-56(s0)
    5a92:  fb843783           ld a5,-72(s0)
    5a96:  47dc                 lw a5,12(a5)
    5a98:  873e                 mv a4,a5
    5a9a:  000207b7           lui a5,0x20
    5a9e:  02078793           addi a5,a5,32 # 20020 <gpio_get_boot_device+0x11c8a>
    5aa2:  00f71b63           bne a4,a5,5ab8 <FUN_00005a22+0x96>
    5aa6:  fc842783           lw a5,-56(s0)
    5aaa:  873e                 mv a4,a5
    5aac:  400007b7           lui a5,0x40000
    5ab0:  8fd9                 or a5,a5,a4
    5ab2:  2781                 sext.w a5,a5
    5ab4:  fcf42423           sw a5,-56(s0)
    5ab8:  fc040793           addi a5,s0,-64
    5abc:  4601                 li a2,0
    5abe:  85be                 mv a1,a5
    5ac0:  fb843503           ld a0,-72(s0)
    5ac4:  da0ff0ef           jal ra,5064 <FUN_00005064>
    5ac8:  87aa                 mv a5,a0
    5aca:  fef42423           sw a5,-24(s0)
    5ace:  fe842783           lw a5,-24(s0)
    5ad2:  2781                 sext.w a5,a5
    5ad4:  c781                 beqz a5,5adc <FUN_00005a22+0xba>
    5ad6:  fe842783           lw a5,-24(s0)
    5ada:  a051                 j 5b5e <FUN_00005a22+0x13c>
    5adc:  4505                 li a0,1
    5ade:  6d0040ef           jal ra,a1ae <udelay_x800>
    5ae2:  fcc42783           lw a5,-52(s0)
    5ae6:  2781                 sext.w a5,a5
    5ae8:  0007c963           bltz a5,5afa <FUN_00005a22+0xd8>
    5aec:  fec42783           lw a5,-20(s0)
    5af0:  fff7871b           addiw a4,a5,-1
    5af4:  fee42623           sw a4,-20(s0)
    5af8:  ff9d                 bnez a5,5a36 <FUN_00005a22+0x14>
    5afa:  fec42783           lw a5,-20(s0)
    5afe:  2781                 sext.w a5,a5
    5b00:  00f04463           bgtz a5,5b08 <FUN_00005a22+0xe6>
    5b04:  57bd                 li a5,-17
    5b06:  a8a1                 j 5b5e <FUN_00005a22+0x13c>
    5b08:  fb843783           ld a5,-72(s0)
    5b0c:  47dc                 lw a5,12(a5)
    5b0e:  873e                 mv a4,a5
    5b10:  000207b7           lui a5,0x20
    5b14:  02078793           addi a5,a5,32 # 20020 <gpio_get_boot_device+0x11c8a>
    5b18:  00f70863           beq a4,a5,5b28 <FUN_00005a22+0x106>
    5b1c:  fb843783           ld a5,-72(s0)
    5b20:  00020737           lui a4,0x20
    5b24:  2741                 addiw a4,a4,16
    5b26:  c7d8                 sw a4,12(a5)
    5b28:  fcc42703           lw a4,-52(s0)
    5b2c:  fb843783           ld a5,-72(s0)
    5b30:  d7d8                 sw a4,44(a5)
    5b32:  fb843783           ld a5,-72(s0)
    5b36:  57dc                 lw a5,44(a5)
    5b38:  873e                 mv a4,a5
    5b3a:  400007b7           lui a5,0x40000
    5b3e:  8ff9                 and a5,a5,a4
    5b40:  2781                 sext.w a5,a5
    5b42:  00f037b3           snez a5,a5
    5b46:  0ff7f793           andi a5,a5,255
    5b4a:  0007871b           sext.w a4,a5
    5b4e:  fb843783           ld a5,-72(s0)
    5b52:  cf98                 sw a4,24(a5)
    5b54:  fb843783           ld a5,-72(s0)
    5b58:  0207ac23           sw zero,56(a5) # 40000038 <gpio_get_boot_device+0x3fff1c
    5b5c:  4781                 li a5,0
    5b5e:  853e                 mv a0,a5
    5b60:  60a6                 ld ra,72(sp)
    5b62:  6406                 ld s0,64(sp)
    5b64:  6161                 addi sp,sp,80
    5b66:  8082                 ret
0000000000005b68 <FUN_00005b68>:
    5b68:  715d                 addi sp,sp,-80
    5b6a:  e486                 sd ra,72(sp)
    5b6c:  e0a2                 sd s0,64(sp)
    5b6e:  0880                 addi s0,sp,80
    5b70:  faa43c23           sd a0,-72(s0)
    5b74:  3e800793           li a5,1000
    5b78:  fef42623           sw a5,-20(s0)
    5b7c:  fb843503           ld a0,-72(s0)
    5b80:  dbbff0ef           jal ra,593a <FUN_0000593a>
    5b84:  4785                 li a5,1
    5b86:  fcf42023           sw a5,-64(s0)
    5b8a:  4785                 li a5,1
    5b8c:  fcf42223           sw a5,-60(s0)
    5b90:  fc042423           sw zero,-56(s0)
    5b94:  fc042e23           sw zero,-36(s0)
    5b98:  fc040793           addi a5,s0,-64
    5b9c:  4601                 li a2,0
    5b9e:  85be                 mv a1,a5
    5ba0:  fb843503           ld a0,-72(s0)
    5ba4:  cc0ff0ef           jal ra,5064 <FUN_00005064>
    5ba8:  87aa                 mv a5,a0
    5baa:  fef42423           sw a5,-24(s0)
    5bae:  fe842783           lw a5,-24(s0)
    5bb2:  2781                 sext.w a5,a5
    5bb4:  c781                 beqz a5,5bbc <FUN_00005b68+0x54>
    5bb6:  fe842783           lw a5,-24(s0)
    5bba:  a201                 j 5cba <FUN_00005b68+0x152>
    5bbc:  4505                 li a0,1
    5bbe:  5f0040ef           jal ra,a1ae <udelay_x800>
    5bc2:  4785                 li a5,1
    5bc4:  fcf42023           sw a5,-64(s0)
    5bc8:  4785                 li a5,1
    5bca:  fcf42223           sw a5,-60(s0)
    5bce:  fb843783           ld a5,-72(s0)
    5bd2:  4798                 lw a4,8(a5)
    5bd4:  fcc42783           lw a5,-52(s0)
    5bd8:  8ff9                 and a5,a5,a4
    5bda:  2781                 sext.w a5,a5
    5bdc:  873e                 mv a4,a5
    5bde:  010007b7           lui a5,0x1000
    5be2:  f8078793           addi a5,a5,-128 # ffff80 <gpio_get_boot_device+0xff1bea>
    5be6:  8ff9                 and a5,a5,a4
    5be8:  0007871b           sext.w a4,a5
    5bec:  fcc42783           lw a5,-52(s0)
    5bf0:  86be                 mv a3,a5
    5bf2:  600007b7           lui a5,0x60000
    5bf6:  8ff5                 and a5,a5,a3
    5bf8:  2781                 sext.w a5,a5
    5bfa:  8fd9                 or a5,a5,a4
    5bfc:  2781                 sext.w a5,a5
    5bfe:  fcf42423           sw a5,-56(s0)
    5c02:  fb843783           ld a5,-72(s0)
    5c06:  579c                 lw a5,40(a5)
    5c08:  873e                 mv a4,a5
    5c0a:  6785                 lui a5,0x1
    5c0c:  80078793           addi a5,a5,-2048 # 800 <FUN_00000660+0x1a0>
    5c10:  8ff9                 and a5,a5,a4
    5c12:  2781                 sext.w a5,a5
    5c14:  cb91                 beqz a5,5c28 <FUN_00005b68+0xc0>
    5c16:  fc842783           lw a5,-56(s0)
    5c1a:  873e                 mv a4,a5
    5c1c:  400007b7           lui a5,0x40000
    5c20:  8fd9                 or a5,a5,a4
    5c22:  2781                 sext.w a5,a5
    5c24:  fcf42423           sw a5,-56(s0)
    5c28:  fc042e23           sw zero,-36(s0)
    5c2c:  fc040793           addi a5,s0,-64
    5c30:  4601                 li a2,0
    5c32:  85be                 mv a1,a5
    5c34:  fb843503           ld a0,-72(s0)
    5c38:  c2cff0ef           jal ra,5064 <FUN_00005064>
    5c3c:  87aa                 mv a5,a0
    5c3e:  fef42423           sw a5,-24(s0)
    5c42:  fe842783           lw a5,-24(s0)
    5c46:  2781                 sext.w a5,a5
    5c48:  c781                 beqz a5,5c50 <FUN_00005b68+0xe8>
    5c4a:  fe842783           lw a5,-24(s0)
    5c4e:  a0b5                 j 5cba <FUN_00005b68+0x152>
    5c50:  4505                 li a0,1
    5c52:  55c040ef           jal ra,a1ae <udelay_x800>
    5c56:  fcc42783           lw a5,-52(s0)
    5c5a:  2781                 sext.w a5,a5
    5c5c:  0007c963           bltz a5,5c6e <FUN_00005b68+0x106>
    5c60:  fec42783           lw a5,-20(s0)
    5c64:  fff7871b           addiw a4,a5,-1
    5c68:  fee42623           sw a4,-20(s0)
    5c6c:  fbb9                 bnez a5,5bc2 <FUN_00005b68+0x5a>
    5c6e:  fec42783           lw a5,-20(s0)
    5c72:  2781                 sext.w a5,a5
    5c74:  00f04463           bgtz a5,5c7c <FUN_00005b68+0x114>
    5c78:  57bd                 li a5,-17
    5c7a:  a081                 j 5cba <FUN_00005b68+0x152>
    5c7c:  fb843783           ld a5,-72(s0)
    5c80:  6741                 lui a4,0x10
    5c82:  c7d8                 sw a4,12(a5)
    5c84:  fcc42703           lw a4,-52(s0)
    5c88:  fb843783           ld a5,-72(s0)
    5c8c:  d7d8                 sw a4,44(a5)
    5c8e:  fb843783           ld a5,-72(s0)
    5c92:  57dc                 lw a5,44(a5)
    5c94:  873e                 mv a4,a5
    5c96:  400007b7           lui a5,0x40000
    5c9a:  8ff9                 and a5,a5,a4
    5c9c:  2781                 sext.w a5,a5
    5c9e:  00f037b3           snez a5,a5
    5ca2:  0ff7f793           andi a5,a5,255
    5ca6:  0007871b           sext.w a4,a5
    5caa:  fb843783           ld a5,-72(s0)
    5cae:  cf98                 sw a4,24(a5)
    5cb0:  fb843783           ld a5,-72(s0)
    5cb4:  4705                 li a4,1
    5cb6:  df98                 sw a4,56(a5)
    5cb8:  4781                 li a5,0
    5cba:  853e                 mv a0,a5
    5cbc:  60a6                 ld ra,72(sp)
    5cbe:  6406                 ld s0,64(sp)
    5cc0:  6161                 addi sp,sp,80
    5cc2:  8082                 ret
0000000000005cc4 <FUN_00005cc4>:
    5cc4:  711d                 addi sp,sp,-96
    5cc6:  ec86                 sd ra,88(sp)
    5cc8:  e8a2                 sd s0,80(sp)
    5cca:  1080                 addi s0,sp,96
    5ccc:  faa43423           sd a0,-88(s0)
    5cd0:  fab43023           sd a1,-96(s0)
    5cd4:  47a1                 li a5,8
    5cd6:  fcf42423           sw a5,-56(s0)
    5cda:  47d5                 li a5,21
    5cdc:  fcf42623           sw a5,-52(s0)
    5ce0:  fc042823           sw zero,-48(s0)
    5ce4:  fe042223           sw zero,-28(s0)
    5ce8:  fa043783           ld a5,-96(s0)
    5cec:  faf43823           sd a5,-80(s0)
    5cf0:  4785                 li a5,1
    5cf2:  faf42e23           sw a5,-68(s0)
    5cf6:  20000793           li a5,512
    5cfa:  fcf42023           sw a5,-64(s0)
    5cfe:  4785                 li a5,1
    5d00:  faf42c23           sw a5,-72(s0)
    5d04:  fb040713           addi a4,s0,-80
    5d08:  fc840793           addi a5,s0,-56
    5d0c:  863a                 mv a2,a4
    5d0e:  85be                 mv a1,a5
    5d10:  fa843503           ld a0,-88(s0)
    5d14:  b50ff0ef           jal ra,5064 <FUN_00005064>
    5d18:  87aa                 mv a5,a0
    5d1a:  fef42623           sw a5,-20(s0)
    5d1e:  fec42783           lw a5,-20(s0)
    5d22:  853e                 mv a0,a5
    5d24:  60e6                 ld ra,88(sp)
    5d26:  6446                 ld s0,80(sp)
    5d28:  6125                 addi sp,sp,96
    5d2a:  8082                 ret
0000000000005d2c <FUN_00005d2c>:
    5d2c:  715d                 addi sp,sp,-80
    5d2e:  e486                 sd ra,72(sp)
    5d30:  e0a2                 sd s0,64(sp)
    5d32:  0880                 addi s0,sp,80
    5d34:  faa43c23           sd a0,-72(s0)
    5d38:  87ae                 mv a5,a1
    5d3a:  8736                 mv a4,a3
    5d3c:  faf40ba3           sb a5,-73(s0)
    5d40:  87b2                 mv a5,a2
    5d42:  faf40b23           sb a5,-74(s0)
    5d46:  87ba                 mv a5,a4
    5d48:  faf40aa3           sb a5,-75(s0)
    5d4c:  3e800793           li a5,1000
    5d50:  fef42623           sw a5,-20(s0)
    5d54:  4799                 li a5,6
    5d56:  fcf42023           sw a5,-64(s0)
    5d5a:  47f5                 li a5,29
    5d5c:  fcf42223           sw a5,-60(s0)
    5d60:  fb644783           lbu a5,-74(s0)
    5d64:  2781                 sext.w a5,a5
    5d66:  0107979b           slliw a5,a5,0x10
    5d6a:  0007871b           sext.w a4,a5
    5d6e:  030007b7           lui a5,0x3000
    5d72:  8fd9                 or a5,a5,a4
    5d74:  0007871b           sext.w a4,a5
    5d78:  fb544783           lbu a5,-75(s0)
    5d7c:  2781                 sext.w a5,a5
    5d7e:  0087979b           slliw a5,a5,0x8
    5d82:  2781                 sext.w a5,a5
    5d84:  8fd9                 or a5,a5,a4
    5d86:  2781                 sext.w a5,a5
    5d88:  2781                 sext.w a5,a5
    5d8a:  fcf42423           sw a5,-56(s0)
    5d8e:  fc042e23           sw zero,-36(s0)
    5d92:  fc040793           addi a5,s0,-64
    5d96:  4601                 li a2,0
    5d98:  85be                 mv a1,a5
    5d9a:  fb843503           ld a0,-72(s0)
    5d9e:  ac6ff0ef           jal ra,5064 <FUN_00005064>
    5da2:  87aa                 mv a5,a0
    5da4:  fef42423           sw a5,-24(s0)
    5da8:  fec42783           lw a5,-20(s0)
    5dac:  85be                 mv a1,a5
    5dae:  fb843503           ld a0,-72(s0)
    5db2:  addff0ef           jal ra,588e <FUN_0000588e>
    5db6:  fe842783           lw a5,-24(s0)
    5dba:  853e                 mv a0,a5
    5dbc:  60a6                 ld ra,72(sp)
    5dbe:  6406                 ld s0,64(sp)
    5dc0:  6161                 addi sp,sp,80
    5dc2:  8082                 ret
0000000000005dc4 <FUN_00005dc4>:
    5dc4:  1101                 addi sp,sp,-32
    5dc6:  ec22                 sd s0,24(sp)
    5dc8:  1000                 addi s0,sp,32
    5dca:  fea43423           sd a0,-24(s0)
    5dce:  feb43023           sd a1,-32(s0)
    5dd2:  fe843783           ld a5,-24(s0)
    5dd6:  0207a223           sw zero,36(a5) # 3000024 <gpio_get_boot_device+0x2ff1c8e
    5dda:  fe843783           ld a5,-24(s0)
    5dde:  47dc                 lw a5,12(a5)
    5de0:  873e                 mv a4,a5
    5de2:  67c1                 lui a5,0x10
    5de4:  03f78793           addi a5,a5,63 # 1003f <gpio_get_boot_device+0x1ca9>
    5de8:  00e7e463           bltu a5,a4,5df0 <FUN_00005dc4+0x2c>
    5dec:  4781                 li a5,0
    5dee:  a035                 j 5e1a <FUN_00005dc4+0x56>
    5df0:  fe843783           ld a5,-24(s0)
    5df4:  53dc                 lw a5,36(a5)
    5df6:  1007e793           ori a5,a5,256
    5dfa:  0007871b           sext.w a4,a5
    5dfe:  fe843783           ld a5,-24(s0)
    5e02:  d3d8                 sw a4,36(a5)
    5e04:  fe843783           ld a5,-24(s0)
    5e08:  53dc                 lw a5,36(a5)
    5e0a:  0017e793           ori a5,a5,1
    5e0e:  0007871b           sext.w a4,a5
    5e12:  fe843783           ld a5,-24(s0)
    5e16:  d3d8                 sw a4,36(a5)
    5e18:  4781                 li a5,0
    5e1a:  853e                 mv a0,a5
    5e1c:  6462                 ld s0,24(sp)
    5e1e:  6105                 addi sp,sp,32
    5e20:  8082                 ret
0000000000005e22 <FUN_00005e22>:
    5e22:  7159                 addi sp,sp,-112
    5e24:  f486                 sd ra,104(sp)
    5e26:  f0a2                 sd s0,96(sp)
    5e28:  1880                 addi s0,sp,112
    5e2a:  f8a43c23           sd a0,-104(s0)
    5e2e:  f9843783           ld a5,-104(s0)
    5e32:  0207a223           sw zero,36(a5)
    5e36:  03700793           li a5,55
    5e3a:  fcf42023           sw a5,-64(s0)
    5e3e:  47d5                 li a5,21
    5e40:  fcf42223           sw a5,-60(s0)
    5e44:  f9843783           ld a5,-104(s0)
    5e48:  5f9c                 lw a5,56(a5)
    5e4a:  0107979b           slliw a5,a5,0x10
    5e4e:  2781                 sext.w a5,a5
    5e50:  fcf42423           sw a5,-56(s0)
    5e54:  fc042e23           sw zero,-36(s0)
    5e58:  fc040793           addi a5,s0,-64
    5e5c:  4601                 li a2,0
    5e5e:  85be                 mv a1,a5
    5e60:  f9843503           ld a0,-104(s0)
    5e64:  a00ff0ef           jal ra,5064 <FUN_00005064>
    5e68:  87aa                 mv a5,a0
    5e6a:  fef42423           sw a5,-24(s0)
    5e6e:  fe842783           lw a5,-24(s0)
    5e72:  2781                 sext.w a5,a5
    5e74:  c781                 beqz a5,5e7c <FUN_00005e22+0x5a>
    5e76:  fe842783           lw a5,-24(s0)
    5e7a:  a265                 j 6022 <FUN_00005e22+0x200>
    5e7c:  03300793           li a5,51
    5e80:  fcf42023           sw a5,-64(s0)
    5e84:  47d5                 li a5,21
    5e86:  fcf42223           sw a5,-60(s0)
    5e8a:  fc042423           sw zero,-56(s0)
    5e8e:  fc042e23           sw zero,-36(s0)
    5e92:  478d                 li a5,3
    5e94:  fef42623           sw a5,-20(s0)
    5e98:  fb840793           addi a5,s0,-72
    5e9c:  faf43023           sd a5,-96(s0)
    5ea0:  47a1                 li a5,8
    5ea2:  faf42823           sw a5,-80(s0)
    5ea6:  4785                 li a5,1
    5ea8:  faf42623           sw a5,-84(s0)
    5eac:  4785                 li a5,1
    5eae:  faf42423           sw a5,-88(s0)
    5eb2:  fa040713           addi a4,s0,-96
    5eb6:  fc040793           addi a5,s0,-64
    5eba:  863a                 mv a2,a4
    5ebc:  85be                 mv a1,a5
    5ebe:  f9843503           ld a0,-104(s0)
    5ec2:  9a2ff0ef           jal ra,5064 <FUN_00005064>
    5ec6:  87aa                 mv a5,a0
    5ec8:  fef42423           sw a5,-24(s0)
    5ecc:  fe842783           lw a5,-24(s0)
    5ed0:  2781                 sext.w a5,a5
    5ed2:  cf81                 beqz a5,5eea <FUN_00005e22+0xc8>
    5ed4:  fec42783           lw a5,-20(s0)
    5ed8:  fff7871b           addiw a4,a5,-1
    5edc:  fee42623           sw a4,-20(s0)
    5ee0:  c391                 beqz a5,5ee4 <FUN_00005e22+0xc2>
    5ee2:  bf5d                 j 5e98 <FUN_00005e22+0x76>
    5ee4:  fe842783           lw a5,-24(s0)
    5ee8:  aa2d                 j 6022 <FUN_00005e22+0x200>
    5eea:  fb842783           lw a5,-72(s0)
    5eee:  0187d79b           srliw a5,a5,0x18
    5ef2:  0007871b           sext.w a4,a5
    5ef6:  fb842783           lw a5,-72(s0)
    5efa:  0087d79b           srliw a5,a5,0x8
    5efe:  2781                 sext.w a5,a5
    5f00:  86be                 mv a3,a5
    5f02:  67c1                 lui a5,0x10
    5f04:  f0078793           addi a5,a5,-256 # ff00 <gpio_get_boot_device+0x1b6a>
    5f08:  8ff5                 and a5,a5,a3
    5f0a:  2781                 sext.w a5,a5
    5f0c:  8fd9                 or a5,a5,a4
    5f0e:  0007871b           sext.w a4,a5
    5f12:  fb842783           lw a5,-72(s0)
    5f16:  0087979b           slliw a5,a5,0x8
    5f1a:  2781                 sext.w a5,a5
    5f1c:  86be                 mv a3,a5
    5f1e:  00ff07b7           lui a5,0xff0
    5f22:  8ff5                 and a5,a5,a3
    5f24:  2781                 sext.w a5,a5
    5f26:  8fd9                 or a5,a5,a4
    5f28:  0007871b           sext.w a4,a5
    5f2c:  fb842783           lw a5,-72(s0)
    5f30:  0187979b           slliw a5,a5,0x18
    5f34:  2781                 sext.w a5,a5
    5f36:  8fd9                 or a5,a5,a4
    5f38:  0007871b           sext.w a4,a5
    5f3c:  f9843783           ld a5,-104(s0)
    5f40:  db98                 sw a4,48(a5)
    5f42:  fbc42783           lw a5,-68(s0)
    5f46:  0187d79b           srliw a5,a5,0x18
    5f4a:  0007871b           sext.w a4,a5
    5f4e:  fbc42783           lw a5,-68(s0)
    5f52:  0087d79b           srliw a5,a5,0x8
    5f56:  2781                 sext.w a5,a5
    5f58:  86be                 mv a3,a5
    5f5a:  67c1                 lui a5,0x10
    5f5c:  f0078793           addi a5,a5,-256 # ff00 <gpio_get_boot_device+0x1b6a>
    5f60:  8ff5                 and a5,a5,a3
    5f62:  2781                 sext.w a5,a5
    5f64:  8fd9                 or a5,a5,a4
    5f66:  0007871b           sext.w a4,a5
    5f6a:  fbc42783           lw a5,-68(s0)
    5f6e:  0087979b           slliw a5,a5,0x8
    5f72:  2781                 sext.w a5,a5
    5f74:  86be                 mv a3,a5
    5f76:  00ff07b7           lui a5,0xff0
    5f7a:  8ff5                 and a5,a5,a3
    5f7c:  2781                 sext.w a5,a5
    5f7e:  8fd9                 or a5,a5,a4
    5f80:  0007871b           sext.w a4,a5
    5f84:  fbc42783           lw a5,-68(s0)
    5f88:  0187979b           slliw a5,a5,0x18
    5f8c:  2781                 sext.w a5,a5
    5f8e:  8fd9                 or a5,a5,a4
    5f90:  0007871b           sext.w a4,a5
    5f94:  f9843783           ld a5,-104(s0)
    5f98:  dbd8                 sw a4,52(a5)
    5f9a:  f9843783           ld a5,-104(s0)
    5f9e:  5b9c                 lw a5,48(a5)
    5fa0:  0187d79b           srliw a5,a5,0x18
    5fa4:  2781                 sext.w a5,a5
    5fa6:  8bbd                 andi a5,a5,15
    5fa8:  2781                 sext.w a5,a5
    5faa:  86be                 mv a3,a5
    5fac:  4705                 li a4,1
    5fae:  02e68063           beq a3,a4,5fce <FUN_00005e22+0x1ac>
    5fb2:  873e                 mv a4,a5
    5fb4:  c711                 beqz a4,5fc0 <FUN_00005e22+0x19e>
    5fb6:  873e                 mv a4,a5
    5fb8:  4789                 li a5,2
    5fba:  02f70163           beq a4,a5,5fdc <FUN_00005e22+0x1ba>
    5fbe:  a03d                 j 5fec <FUN_00005e22+0x1ca>
    5fc0:  f9843783           ld a5,-104(s0)
    5fc4:  00020737           lui a4,0x20
    5fc8:  2741                 addiw a4,a4,16
    5fca:  c7d8                 sw a4,12(a5)
    5fcc:  a03d                 j 5ffa <FUN_00005e22+0x1d8>
    5fce:  f9843783           ld a5,-104(s0)
    5fd2:  00020737           lui a4,0x20
    5fd6:  2769                 addiw a4,a4,26
    5fd8:  c7d8                 sw a4,12(a5)
    5fda:  a005                 j 5ffa <FUN_00005e22+0x1d8>
    5fdc:  f9843783           ld a5,-104(s0)
    5fe0:  00020737           lui a4,0x20
    5fe4:  0207071b           addiw a4,a4,32
    5fe8:  c7d8                 sw a4,12(a5)
    5fea:  a801                 j 5ffa <FUN_00005e22+0x1d8>
    5fec:  f9843783           ld a5,-104(s0)
    5ff0:  00020737           lui a4,0x20
    5ff4:  2741                 addiw a4,a4,16
    5ff6:  c7d8                 sw a4,12(a5)
    5ff8:  0001                 nop
    5ffa:  f9843783           ld a5,-104(s0)
    5ffe:  5b9c                 lw a5,48(a5)
    6000:  873e                 mv a4,a5
    6002:  000407b7           lui a5,0x40
    6006:  8ff9                 and a5,a5,a4
    6008:  2781                 sext.w a5,a5
    600a:  cb99                 beqz a5,6020 <FUN_00005e22+0x1fe>
    600c:  f9843783           ld a5,-104(s0)
    6010:  53dc                 lw a5,36(a5)
    6012:  1007e793           ori a5,a5,256
    6016:  0007871b           sext.w a4,a5
    601a:  f9843783           ld a5,-104(s0)
    601e:  d3d8                 sw a4,36(a5)
    6020:  4781                 li a5,0
    6022:  853e                 mv a0,a5
    6024:  70a6                 ld ra,104(sp)
    6026:  7406                 ld s0,96(sp)
    6028:  6165                 addi sp,sp,112
    602a:  8082                 ret
000000000000602c <FUN_0000602c>:
    602c:  1101                 addi sp,sp,-32
    602e:  ec06                 sd ra,24(sp)
    6030:  e822                 sd s0,16(sp)
    6032:  1000                 addi s0,sp,32
    6034:  fea43423           sd a0,-24(s0)
    6038:  87ae                 mv a5,a1
    603a:  fef42223           sw a5,-28(s0)
    603e:  fe843783           ld a5,-24(s0)
    6042:  4bd8                 lw a4,20(a5)
    6044:  fe442783           lw a5,-28(s0)
    6048:  2781                 sext.w a5,a5
    604a:  00f77763           bgeu a4,a5,6058 <FUN_0000602c+0x2c>
    604e:  fe843783           ld a5,-24(s0)
    6052:  4bdc                 lw a5,20(a5)
    6054:  fef42223           sw a5,-28(s0)
    6058:  fe843783           ld a5,-24(s0)
    605c:  4b98                 lw a4,16(a5)
    605e:  fe442783           lw a5,-28(s0)
    6062:  2781                 sext.w a5,a5
    6064:  00e7f763           bgeu a5,a4,6072 <FUN_0000602c+0x46>
    6068:  fe843783           ld a5,-24(s0)
    606c:  4b9c                 lw a5,16(a5)
    606e:  fef42223           sw a5,-28(s0)
    6072:  fe843783           ld a5,-24(s0)
    6076:  fe442703           lw a4,-28(s0)
    607a:  d398                 sw a4,32(a5)
    607c:  fe843503           ld a0,-24(s0)
    6080:  8a5fe0ef           jal ra,4924 <FUN_00004924>
    6084:  0001                 nop
    6086:  60e2                 ld ra,24(sp)
    6088:  6442                 ld s0,16(sp)
    608a:  6105                 addi sp,sp,32
    608c:  8082                 ret
000000000000608e <FUN_0000608e>:
    608e:  1101                 addi sp,sp,-32
    6090:  ec06                 sd ra,24(sp)
    6092:  e822                 sd s0,16(sp)
    6094:  1000                 addi s0,sp,32
    6096:  fea43423           sd a0,-24(s0)
    609a:  87ae                 mv a5,a1
    609c:  fef42223           sw a5,-28(s0)
    60a0:  fe843783           ld a5,-24(s0)
    60a4:  fe442703           lw a4,-28(s0)
    60a8:  cfd8                 sw a4,28(a5)
    60aa:  fe843503           ld a0,-24(s0)
    60ae:  877fe0ef           jal ra,4924 <FUN_00004924>
    60b2:  0001                 nop
    60b4:  60e2                 ld ra,24(sp)
    60b6:  6442                 ld s0,16(sp)
    60b8:  6105                 addi sp,sp,32
    60ba:  8082                 ret
00000000000060bc <FUN_000060bc>:
    60bc:  db010113           addi sp,sp,-592
    60c0:  24113423           sd ra,584(sp)
    60c4:  24813023           sd s0,576(sp)
    60c8:  0c80                 addi s0,sp,592
    60ca:  daa43c23           sd a0,-584(s0)
    60ce:  3e800793           li a5,1000
    60d2:  fef42423           sw a5,-24(s0)
    60d6:  4789                 li a5,2
    60d8:  fcf42023           sw a5,-64(s0)
    60dc:  479d                 li a5,7
    60de:  fcf42223           sw a5,-60(s0)
    60e2:  fc042423           sw zero,-56(s0)
    60e6:  fc042e23           sw zero,-36(s0)
    60ea:  fc040793           addi a5,s0,-64
    60ee:  4601                 li a2,0
    60f0:  85be                 mv a1,a5
    60f2:  db843503           ld a0,-584(s0)
    60f6:  f6ffe0ef           jal ra,5064 <FUN_00005064>
    60fa:  87aa                 mv a5,a0
    60fc:  fef42623           sw a5,-20(s0)
    6100:  fec42783           lw a5,-20(s0)
    6104:  2781                 sext.w a5,a5
    6106:  c781                 beqz a5,610e <FUN_000060bc+0x52>
    6108:  fec42783           lw a5,-20(s0)
    610c:  a9c9                 j 65de <FUN_000060bc+0x522>
    610e:  478d                 li a5,3
    6110:  fcf42023           sw a5,-64(s0)
    6114:  db843783           ld a5,-584(s0)
    6118:  5f9c                 lw a5,56(a5)
    611a:  0107979b           slliw a5,a5,0x10
    611e:  2781                 sext.w a5,a5
    6120:  fcf42423           sw a5,-56(s0)
    6124:  47d5                 li a5,21
    6126:  fcf42223           sw a5,-60(s0)
    612a:  fc042e23           sw zero,-36(s0)
    612e:  fc040793           addi a5,s0,-64
    6132:  4601                 li a2,0
    6134:  85be                 mv a1,a5
    6136:  db843503           ld a0,-584(s0)
    613a:  f2bfe0ef           jal ra,5064 <FUN_00005064>
    613e:  87aa                 mv a5,a0
    6140:  fef42623           sw a5,-20(s0)
    6144:  fec42783           lw a5,-20(s0)
    6148:  2781                 sext.w a5,a5
    614a:  c781                 beqz a5,6152 <FUN_000060bc+0x96>
    614c:  fec42783           lw a5,-20(s0)
    6150:  a179                 j 65de <FUN_000060bc+0x522>
    6152:  db843783           ld a5,-584(s0)
    6156:  47dc                 lw a5,12(a5)
    6158:  873e                 mv a4,a5
    615a:  000207b7           lui a5,0x20
    615e:  8ff9                 and a5,a5,a4
    6160:  2781                 sext.w a5,a5
    6162:  cb91                 beqz a5,6176 <FUN_000060bc+0xba>
    6164:  fcc42783           lw a5,-52(s0)
    6168:  0107d79b           srliw a5,a5,0x10
    616c:  0007871b           sext.w a4,a5
    6170:  db843783           ld a5,-584(s0)
    6174:  df98                 sw a4,56(a5)
    6176:  005b97b7           lui a5,0x5b9
    617a:  d8078593           addi a1,a5,-640 # 5b8d80 <gpio_get_boot_device+0x5aa9ea>
    617e:  db843503           ld a0,-584(s0)
    6182:  eabff0ef           jal ra,602c <FUN_0000602c>
    6186:  47a5                 li a5,9
    6188:  fcf42023           sw a5,-64(s0)
    618c:  479d                 li a5,7
    618e:  fcf42223           sw a5,-60(s0)
    6192:  db843783           ld a5,-584(s0)
    6196:  5f9c                 lw a5,56(a5)
    6198:  0107979b           slliw a5,a5,0x10
    619c:  2781                 sext.w a5,a5
    619e:  fcf42423           sw a5,-56(s0)
    61a2:  fc042e23           sw zero,-36(s0)
    61a6:  fc040793           addi a5,s0,-64
    61aa:  4601                 li a2,0
    61ac:  85be                 mv a1,a5
    61ae:  db843503           ld a0,-584(s0)
    61b2:  eb3fe0ef           jal ra,5064 <FUN_00005064>
    61b6:  87aa                 mv a5,a0
    61b8:  fef42623           sw a5,-20(s0)
    61bc:  fec42783           lw a5,-20(s0)
    61c0:  2781                 sext.w a5,a5
    61c2:  c781                 beqz a5,61ca <FUN_000060bc+0x10e>
    61c4:  fec42783           lw a5,-20(s0)
    61c8:  a919                 j 65de <FUN_000060bc+0x522>
    61ca:  fe842783           lw a5,-24(s0)
    61ce:  85be                 mv a1,a5
    61d0:  db843503           ld a0,-584(s0)
    61d4:  ebaff0ef           jal ra,588e <FUN_0000588e>
    61d8:  db843783           ld a5,-584(s0)
    61dc:  47dc                 lw a5,12(a5)
    61de:  873e                 mv a4,a5
    61e0:  67c1                 lui a5,0x10
    61e2:  08f71363           bne a4,a5,6268 <FUN_000060bc+0x1ac>
    61e6:  fcc42783           lw a5,-52(s0)
    61ea:  01a7d79b           srliw a5,a5,0x1a
    61ee:  2781                 sext.w a5,a5
    61f0:  2781                 sext.w a5,a5
    61f2:  8bbd                 andi a5,a5,15
    61f4:  fef42223           sw a5,-28(s0)
    61f8:  fe442783           lw a5,-28(s0)
    61fc:  0007871b           sext.w a4,a5
    6200:  4791                 li a5,4
    6202:  04e7ed63           bltu a5,a4,625c <FUN_000060bc+0x1a0>
    6206:  fe446783           lwu a5,-28(s0)
    620a:  00279713           slli a4,a5,0x2
    620e:  67b9                 lui a5,0xe
    6210:  4dc78793           addi a5,a5,1244 # e4dc <gpio_get_boot_device+0x146>
    6214:  97ba                 add a5,a5,a4
    6216:  439c                 lw a5,0(a5)
    6218:  8782                 jr a5
    621a:  db843783           ld a5,-584(s0)
    621e:  6741                 lui a4,0x10
    6220:  2749                 addiw a4,a4,18
    6222:  c7d8                 sw a4,12(a5)
    6224:  a099                 j 626a <FUN_000060bc+0x1ae>
    6226:  db843783           ld a5,-584(s0)
    622a:  6741                 lui a4,0x10
    622c:  2751                 addiw a4,a4,20
    622e:  c7d8                 sw a4,12(a5)
    6230:  a82d                 j 626a <FUN_000060bc+0x1ae>
    6232:  db843783           ld a5,-584(s0)
    6236:  6741                 lui a4,0x10
    6238:  0227071b           addiw a4,a4,34
    623c:  c7d8                 sw a4,12(a5)
    623e:  a035                 j 626a <FUN_000060bc+0x1ae>
    6240:  db843783           ld a5,-584(s0)
    6244:  6741                 lui a4,0x10
    6246:  0307071b           addiw a4,a4,48
    624a:  c7d8                 sw a4,12(a5)
    624c:  a839                 j 626a <FUN_000060bc+0x1ae>
    624e:  db843783           ld a5,-584(s0)
    6252:  6741                 lui a4,0x10
    6254:  0407071b           addiw a4,a4,64
    6258:  c7d8                 sw a4,12(a5)
    625a:  a801                 j 626a <FUN_000060bc+0x1ae>
    625c:  db843783           ld a5,-584(s0)
    6260:  6741                 lui a4,0x10
    6262:  2749                 addiw a4,a4,18
    6264:  c7d8                 sw a4,12(a5)
    6266:  a011                 j 626a <FUN_000060bc+0x1ae>
    6268:  0001                 nop
    626a:  fd042783           lw a5,-48(s0)
    626e:  0107d79b           srliw a5,a5,0x10
    6272:  2781                 sext.w a5,a5
    6274:  8bbd                 andi a5,a5,15
    6276:  2781                 sext.w a5,a5
    6278:  4705                 li a4,1
    627a:  00f717bb           sllw a5,a4,a5
    627e:  2781                 sext.w a5,a5
    6280:  0007871b           sext.w a4,a5
    6284:  db843783           ld a5,-584(s0)
    6288:  c7b8                 sw a4,72(a5)
    628a:  db843783           ld a5,-584(s0)
    628e:  47bc                 lw a5,72(a5)
    6290:  873e                 mv a4,a5
    6292:  20000793           li a5,512
    6296:  00e7f763           bgeu a5,a4,62a4 <FUN_000060bc+0x1e8>
    629a:  db843783           ld a5,-584(s0)
    629e:  20000713           li a4,512
    62a2:  c7b8                 sw a4,72(a5)
    62a4:  479d                 li a5,7
    62a6:  fcf42023           sw a5,-64(s0)
    62aa:  47f5                 li a5,29
    62ac:  fcf42223           sw a5,-60(s0)
    62b0:  db843783           ld a5,-584(s0)
    62b4:  5f9c                 lw a5,56(a5)
    62b6:  0107979b           slliw a5,a5,0x10
    62ba:  2781                 sext.w a5,a5
    62bc:  fcf42423           sw a5,-56(s0)
    62c0:  fc042e23           sw zero,-36(s0)
    62c4:  fc040793           addi a5,s0,-64
    62c8:  4601                 li a2,0
    62ca:  85be                 mv a1,a5
    62cc:  db843503           ld a0,-584(s0)
    62d0:  d95fe0ef           jal ra,5064 <FUN_00005064>
    62d4:  87aa                 mv a5,a0
    62d6:  fef42623           sw a5,-20(s0)
    62da:  fec42783           lw a5,-20(s0)
    62de:  2781                 sext.w a5,a5
    62e0:  c781                 beqz a5,62e8 <FUN_000060bc+0x22c>
    62e2:  fec42783           lw a5,-20(s0)
    62e6:  ace5                 j 65de <FUN_000060bc+0x522>
    62e8:  db843783           ld a5,-584(s0)
    62ec:  0ff00713           li a4,255
    62f0:  dfd8                 sw a4,60(a5)
    62f2:  db843783           ld a5,-584(s0)
    62f6:  0ff00713           li a4,255
    62fa:  c3b8                 sw a4,64(a5)
    62fc:  db843783           ld a5,-584(s0)
    6300:  47dc                 lw a5,12(a5)
    6302:  873e                 mv a4,a5
    6304:  000207b7           lui a5,0x20
    6308:  8ff9                 and a5,a5,a4
    630a:  2781                 sext.w a5,a5
    630c:  ebf1                 bnez a5,63e0 <FUN_000060bc+0x324>
    630e:  db843783           ld a5,-584(s0)
    6312:  47dc                 lw a5,12(a5)
    6314:  873e                 mv a4,a5
    6316:  67c1                 lui a5,0x10
    6318:  03f78793           addi a5,a5,63 # 1003f <gpio_get_boot_device+0x1ca9>
    631c:  0ce7f263           bgeu a5,a4,63e0 <FUN_000060bc+0x324>
    6320:  dc040793           addi a5,s0,-576
    6324:  85be                 mv a1,a5
    6326:  db843503           ld a0,-584(s0)
    632a:  99bff0ef           jal ra,5cc4 <FUN_00005cc4>
    632e:  87aa                 mv a5,a0
    6330:  fef42623           sw a5,-20(s0)
    6334:  e8044783           lbu a5,-384(s0)
    6338:  2781                 sext.w a5,a5
    633a:  86be                 mv a3,a5
    633c:  4719                 li a4,6
    633e:  06d76463           bltu a4,a3,63a6 <FUN_000060bc+0x2ea>
    6342:  00279713           slli a4,a5,0x2
    6346:  67b9                 lui a5,0xe
    6348:  4f078793           addi a5,a5,1264 # e4f0 <gpio_get_boot_device+0x15a>
    634c:  97ba                 add a5,a5,a4
    634e:  439c                 lw a5,0(a5)
    6350:  8782                 jr a5
    6352:  db843783           ld a5,-584(s0)
    6356:  6741                 lui a4,0x10
    6358:  0407071b           addiw a4,a4,64
    635c:  c7d8                 sw a4,12(a5)
    635e:  a0a1                 j 63a6 <FUN_000060bc+0x2ea>
    6360:  db843783           ld a5,-584(s0)
    6364:  6741                 lui a4,0x10
    6366:  0417071b           addiw a4,a4,65
    636a:  c7d8                 sw a4,12(a5)
    636c:  a82d                 j 63a6 <FUN_000060bc+0x2ea>
    636e:  db843783           ld a5,-584(s0)
    6372:  6741                 lui a4,0x10
    6374:  0427071b           addiw a4,a4,66
    6378:  c7d8                 sw a4,12(a5)
    637a:  a035                 j 63a6 <FUN_000060bc+0x2ea>
    637c:  db843783           ld a5,-584(s0)
    6380:  6741                 lui a4,0x10
    6382:  0437071b           addiw a4,a4,67
    6386:  c7d8                 sw a4,12(a5)
    6388:  a839                 j 63a6 <FUN_000060bc+0x2ea>
    638a:  db843783           ld a5,-584(s0)
    638e:  6741                 lui a4,0x10
    6390:  0447071b           addiw a4,a4,68
    6394:  c7d8                 sw a4,12(a5)
    6396:  a801                 j 63a6 <FUN_000060bc+0x2ea>
    6398:  db843783           ld a5,-584(s0)
    639c:  6741                 lui a4,0x10
    639e:  0457071b           addiw a4,a4,69
    63a2:  c7d8                 sw a4,12(a5)
    63a4:  0001                 nop
    63a6:  e6044783           lbu a5,-416(s0)
    63aa:  2781                 sext.w a5,a5
    63ac:  8b85                 andi a5,a5,1
    63ae:  2781                 sext.w a5,a5
    63b0:  cb81                 beqz a5,63c0 <FUN_000060bc+0x304>
    63b2:  e7344783           lbu a5,-397(s0)
    63b6:  0007871b           sext.w a4,a5
    63ba:  db843783           ld a5,-584(s0)
    63be:  dfd8                 sw a4,60(a5)
    63c0:  db843783           ld a5,-584(s0)
    63c4:  47dc                 lw a5,12(a5)
    63c6:  873e                 mv a4,a5
    63c8:  67c1                 lui a5,0x10
    63ca:  04278793           addi a5,a5,66 # 10042 <gpio_get_boot_device+0x1cac>
    63ce:  00e7f963           bgeu a5,a4,63e0 <FUN_000060bc+0x324>
    63d2:  e7144783           lbu a5,-399(s0)
    63d6:  0007871b           sext.w a4,a5
    63da:  db843783           ld a5,-584(s0)
    63de:  c3b8                 sw a4,64(a5)
    63e0:  db843783           ld a5,-584(s0)
    63e4:  47dc                 lw a5,12(a5)
    63e6:  873e                 mv a4,a5
    63e8:  000207b7           lui a5,0x20
    63ec:  8ff9                 and a5,a5,a4
    63ee:  2781                 sext.w a5,a5
    63f0:  cb89                 beqz a5,6402 <FUN_000060bc+0x346>
    63f2:  db843503           ld a0,-584(s0)
    63f6:  a2dff0ef           jal ra,5e22 <FUN_00005e22>
    63fa:  87aa                 mv a5,a0
    63fc:  fef42623           sw a5,-20(s0)
    6400:  a819                 j 6416 <FUN_000060bc+0x35a>
    6402:  dc040793           addi a5,s0,-576
    6406:  85be                 mv a1,a5
    6408:  db843503           ld a0,-584(s0)
    640c:  9b9ff0ef           jal ra,5dc4 <FUN_00005dc4>
    6410:  87aa                 mv a5,a0
    6412:  fef42623           sw a5,-20(s0)
    6416:  fec42783           lw a5,-20(s0)
    641a:  2781                 sext.w a5,a5
    641c:  c781                 beqz a5,6424 <FUN_000060bc+0x368>
    641e:  fec42783           lw a5,-20(s0)
    6422:  aa75                 j 65de <FUN_000060bc+0x522>
    6424:  db843783           ld a5,-584(s0)
    6428:  53d8                 lw a4,36(a5)
    642a:  db843783           ld a5,-584(s0)
    642e:  579c                 lw a5,40(a5)
    6430:  8ff9                 and a5,a5,a4
    6432:  0007871b           sext.w a4,a5
    6436:  db843783           ld a5,-584(s0)
    643a:  d3d8                 sw a4,36(a5)
    643c:  db843783           ld a5,-584(s0)
    6440:  47dc                 lw a5,12(a5)
    6442:  873e                 mv a4,a5
    6444:  000207b7           lui a5,0x20
    6448:  8ff9                 and a5,a5,a4
    644a:  2781                 sext.w a5,a5
    644c:  c7e9                 beqz a5,6516 <FUN_000060bc+0x45a>
    644e:  db843783           ld a5,-584(s0)
    6452:  53dc                 lw a5,36(a5)
    6454:  1007f793           andi a5,a5,256
    6458:  2781                 sext.w a5,a5
    645a:  c7d1                 beqz a5,64e6 <FUN_000060bc+0x42a>
    645c:  03700793           li a5,55
    6460:  fcf42023           sw a5,-64(s0)
    6464:  47d5                 li a5,21
    6466:  fcf42223           sw a5,-60(s0)
    646a:  db843783           ld a5,-584(s0)
    646e:  5f9c                 lw a5,56(a5)
    6470:  0107979b           slliw a5,a5,0x10
    6474:  2781                 sext.w a5,a5
    6476:  fcf42423           sw a5,-56(s0)
    647a:  fc042e23           sw zero,-36(s0)
    647e:  fc040793           addi a5,s0,-64
    6482:  4601                 li a2,0
    6484:  85be                 mv a1,a5
    6486:  db843503           ld a0,-584(s0)
    648a:  bdbfe0ef           jal ra,5064 <FUN_00005064>
    648e:  87aa                 mv a5,a0
    6490:  fef42623           sw a5,-20(s0)
    6494:  fec42783           lw a5,-20(s0)
    6498:  2781                 sext.w a5,a5
    649a:  c781                 beqz a5,64a2 <FUN_000060bc+0x3e6>
    649c:  fec42783           lw a5,-20(s0)
    64a0:  aa3d                 j 65de <FUN_000060bc+0x522>
    64a2:  4799                 li a5,6
    64a4:  fcf42023           sw a5,-64(s0)
    64a8:  47d5                 li a5,21
    64aa:  fcf42223           sw a5,-60(s0)
    64ae:  4789                 li a5,2
    64b0:  fcf42423           sw a5,-56(s0)
    64b4:  fc042e23           sw zero,-36(s0)
    64b8:  fc040793           addi a5,s0,-64
    64bc:  4601                 li a2,0
    64be:  85be                 mv a1,a5
    64c0:  db843503           ld a0,-584(s0)
    64c4:  ba1fe0ef           jal ra,5064 <FUN_00005064>
    64c8:  87aa                 mv a5,a0
    64ca:  fef42623           sw a5,-20(s0)
    64ce:  fec42783           lw a5,-20(s0)
    64d2:  2781                 sext.w a5,a5
    64d4:  c781                 beqz a5,64dc <FUN_000060bc+0x420>
    64d6:  fec42783           lw a5,-20(s0)
    64da:  a211                 j 65de <FUN_000060bc+0x522>
    64dc:  4591                 li a1,4
    64de:  db843503           ld a0,-584(s0)
    64e2:  badff0ef           jal ra,608e <FUN_0000608e>
    64e6:  db843783           ld a5,-584(s0)
    64ea:  53dc                 lw a5,36(a5)
    64ec:  8b85                 andi a5,a5,1
    64ee:  2781                 sext.w a5,a5
    64f0:  cb91                 beqz a5,6504 <FUN_000060bc+0x448>
    64f2:  02faf7b7           lui a5,0x2faf
    64f6:  08078593           addi a1,a5,128 # 2faf080 <gpio_get_boot_device+0x2fa0cea
    64fa:  db843503           ld a0,-584(s0)
    64fe:  b2fff0ef           jal ra,602c <FUN_0000602c>
    6502:  a8e9                 j 65dc <FUN_000060bc+0x520>
    6504:  017d87b7           lui a5,0x17d8
    6508:  84078593           addi a1,a5,-1984 # 17d7840 <gpio_get_boot_device+0x17c94
    650c:  db843503           ld a0,-584(s0)
    6510:  b1dff0ef           jal ra,602c <FUN_0000602c>
    6514:  a0e1                 j 65dc <FUN_000060bc+0x520>
    6516:  db843783           ld a5,-584(s0)
    651a:  53dc                 lw a5,36(a5)
    651c:  1007f793           andi a5,a5,256
    6520:  2781                 sext.w a5,a5
    6522:  cb8d                 beqz a5,6554 <FUN_000060bc+0x498>
    6524:  4685                 li a3,1
    6526:  0b700613           li a2,183
    652a:  4585                 li a1,1
    652c:  db843503           ld a0,-584(s0)
    6530:  ffcff0ef           jal ra,5d2c <FUN_00005d2c>
    6534:  87aa                 mv a5,a0
    6536:  fef42623           sw a5,-20(s0)
    653a:  fec42783           lw a5,-20(s0)
    653e:  2781                 sext.w a5,a5
    6540:  c781                 beqz a5,6548 <FUN_000060bc+0x48c>
    6542:  fec42783           lw a5,-20(s0)
    6546:  a861                 j 65de <FUN_000060bc+0x522>
    6548:  4591                 li a1,4
    654a:  db843503           ld a0,-584(s0)
    654e:  b41ff0ef           jal ra,608e <FUN_0000608e>
    6552:  a83d                 j 6590 <FUN_000060bc+0x4d4>
    6554:  db843783           ld a5,-584(s0)
    6558:  53dc                 lw a5,36(a5)
    655a:  2007f793           andi a5,a5,512
    655e:  2781                 sext.w a5,a5
    6560:  cb85                 beqz a5,6590 <FUN_000060bc+0x4d4>
    6562:  4689                 li a3,2
    6564:  0b700613           li a2,183
    6568:  4585                 li a1,1
    656a:  db843503           ld a0,-584(s0)
    656e:  fbeff0ef           jal ra,5d2c <FUN_00005d2c>
    6572:  87aa                 mv a5,a0
    6574:  fef42623           sw a5,-20(s0)
    6578:  fec42783           lw a5,-20(s0)
    657c:  2781                 sext.w a5,a5
    657e:  c781                 beqz a5,6586 <FUN_000060bc+0x4ca>
    6580:  fec42783           lw a5,-20(s0)
    6584:  a8a9                 j 65de <FUN_000060bc+0x522>
    6586:  45a1                 li a1,8
    6588:  db843503           ld a0,-584(s0)
    658c:  b03ff0ef           jal ra,608e <FUN_0000608e>
    6590:  db843783           ld a5,-584(s0)
    6594:  53dc                 lw a5,36(a5)
    6596:  8b85                 andi a5,a5,1
    6598:  2781                 sext.w a5,a5
    659a:  cb8d                 beqz a5,65cc <FUN_000060bc+0x510>
    659c:  db843783           ld a5,-584(s0)
    65a0:  53dc                 lw a5,36(a5)
    65a2:  8bc1                 andi a5,a5,16
    65a4:  2781                 sext.w a5,a5
    65a6:  cb91                 beqz a5,65ba <FUN_000060bc+0x4fe>
    65a8:  031977b7           lui a5,0x3197
    65ac:  50078593           addi a1,a5,1280 # 3197500 <gpio_get_boot_device+0x318916
    65b0:  db843503           ld a0,-584(s0)
    65b4:  a79ff0ef           jal ra,602c <FUN_0000602c>
    65b8:  a015                 j 65dc <FUN_000060bc+0x520>
    65ba:  018cc7b7           lui a5,0x18cc
    65be:  a8078593           addi a1,a5,-1408 # 18cba80 <gpio_get_boot_device+0x18bd6
    65c2:  db843503           ld a0,-584(s0)
    65c6:  a67ff0ef           jal ra,602c <FUN_0000602c>
    65ca:  a809                 j 65dc <FUN_000060bc+0x520>
    65cc:  013137b7           lui a5,0x1313
    65d0:  d0078593           addi a1,a5,-768 # 1312d00 <gpio_get_boot_device+0x130496
    65d4:  db843503           ld a0,-584(s0)
    65d8:  a55ff0ef           jal ra,602c <FUN_0000602c>
    65dc:  4781                 li a5,0
    65de:  853e                 mv a0,a5
    65e0:  24813083           ld ra,584(sp)
    65e4:  24013403           ld s0,576(sp)
    65e8:  25010113           addi sp,sp,592
    65ec:  8082                 ret
00000000000065ee <FUN_000065ee>:
    65ee:  715d                 addi sp,sp,-80
    65f0:  e486                 sd ra,72(sp)
    65f2:  e0a2                 sd s0,64(sp)
    65f4:  0880                 addi s0,sp,80
    65f6:  faa43c23           sd a0,-72(s0)
    65fa:  47a1                 li a5,8
    65fc:  fcf42423           sw a5,-56(s0)
    6600:  fb843783           ld a5,-72(s0)
    6604:  479c                 lw a5,8(a5)
    6606:  873e                 mv a4,a5
    6608:  00ff87b7           lui a5,0xff8
    660c:  8ff9                 and a5,a5,a4
    660e:  2781                 sext.w a5,a5
    6610:  c781                 beqz a5,6618 <FUN_000065ee+0x2a>
    6612:  1aa00793           li a5,426
    6616:  a019                 j 661c <FUN_000065ee+0x2e>
    6618:  0aa00793           li a5,170
    661c:  fcf42823           sw a5,-48(s0)
    6620:  47d5                 li a5,21
    6622:  fcf42623           sw a5,-52(s0)
    6626:  fe042223           sw zero,-28(s0)
    662a:  fc840793           addi a5,s0,-56
    662e:  4601                 li a2,0
    6630:  85be                 mv a1,a5
    6632:  fb843503           ld a0,-72(s0)
    6636:  a2ffe0ef           jal ra,5064 <FUN_00005064>
    663a:  87aa                 mv a5,a0
    663c:  fef42623           sw a5,-20(s0)
    6640:  fec42783           lw a5,-20(s0)
    6644:  2781                 sext.w a5,a5
    6646:  c781                 beqz a5,664e <FUN_000065ee+0x60>
    6648:  fec42783           lw a5,-20(s0)
    664c:  a02d                 j 6676 <FUN_000065ee+0x88>
    664e:  fd442783           lw a5,-44(s0)
    6652:  0ff7f793           andi a5,a5,255
    6656:  2781                 sext.w a5,a5
    6658:  873e                 mv a4,a5
    665a:  0aa00793           li a5,170
    665e:  00f70463           beq a4,a5,6666 <FUN_000065ee+0x78>
    6662:  57bd                 li a5,-17
    6664:  a809                 j 6676 <FUN_000065ee+0x88>
    6666:  fb843783           ld a5,-72(s0)
    666a:  00020737           lui a4,0x20
    666e:  0207071b           addiw a4,a4,32
    6672:  c7d8                 sw a4,12(a5)
    6674:  4781                 li a5,0
    6676:  853e                 mv a0,a5
    6678:  60a6                 ld ra,72(sp)
    667a:  6406                 ld s0,64(sp)
    667c:  6161                 addi sp,sp,80
    667e:  8082                 ret
0000000000006680 <FUN_00006680>:
    6680:  7159                 addi sp,sp,-112
    6682:  f486                 sd ra,104(sp)
    6684:  f0a2                 sd s0,96(sp)
    6686:  1880                 addi s0,sp,112
    6688:  faa43423           sd a0,-88(s0)
    668c:  fab43023           sd a1,-96(s0)
    6690:  87b2                 mv a5,a2
    6692:  8736                 mv a4,a3
    6694:  f8f42e23           sw a5,-100(s0)
    6698:  87ba                 mv a5,a4
    669a:  f8f42c23           sw a5,-104(s0)
    669e:  f9842783           lw a5,-104(s0)
    66a2:  2781                 sext.w a5,a5
    66a4:  cb99                 beqz a5,66ba <FUN_00006680+0x3a>
    66a6:  47c9                 li a5,18
    66a8:  fcf42423           sw a5,-56(s0)
    66ac:  fe042423           sw zero,-24(s0)
    66b0:  fa843783           ld a5,-88(s0)
    66b4:  4f9c                 lw a5,24(a5)
    66b6:  cb89                 beqz a5,66c8 <FUN_00006680+0x48>
    66b8:  a019                 j 66be <FUN_00006680+0x3e>
    66ba:  4781                 li a5,0
    66bc:  a84d                 j 676e <FUN_00006680+0xee>
    66be:  f9c42783           lw a5,-100(s0)
    66c2:  fcf42823           sw a5,-48(s0)
    66c6:  a819                 j 66dc <FUN_00006680+0x5c>
    66c8:  fa843783           ld a5,-88(s0)
    66cc:  47bc                 lw a5,72(a5)
    66ce:  f9c42703           lw a4,-100(s0)
    66d2:  02f707bb           mulw a5,a4,a5
    66d6:  2781                 sext.w a5,a5
    66d8:  fcf42823           sw a5,-48(s0)
    66dc:  47d5                 li a5,21
    66de:  fcf42623           sw a5,-52(s0)
    66e2:  fe042223           sw zero,-28(s0)
    66e6:  fa043783           ld a5,-96(s0)
    66ea:  faf43823           sd a5,-80(s0)
    66ee:  f9842783           lw a5,-104(s0)
    66f2:  faf42e23           sw a5,-68(s0)
    66f6:  fa843783           ld a5,-88(s0)
    66fa:  47bc                 lw a5,72(a5)
    66fc:  fcf42023           sw a5,-64(s0)
    6700:  4785                 li a5,1
    6702:  faf42c23           sw a5,-72(s0)
    6706:  fb040713           addi a4,s0,-80
    670a:  fc840793           addi a5,s0,-56
    670e:  863a                 mv a2,a4
    6710:  85be                 mv a1,a5
    6712:  fa843503           ld a0,-88(s0)
    6716:  94ffe0ef           jal ra,5064 <FUN_00005064>
    671a:  87aa                 mv a5,a0
    671c:  fef42623           sw a5,-20(s0)
    6720:  fc842783           lw a5,-56(s0)
    6724:  873e                 mv a4,a5
    6726:  47c9                 li a5,18
    6728:  02f71b63           bne a4,a5,675e <FUN_00006680+0xde>
    672c:  fe842783           lw a5,-24(s0)
    6730:  e79d                 bnez a5,675e <FUN_00006680+0xde>
    6732:  47b1                 li a5,12
    6734:  fcf42423           sw a5,-56(s0)
    6738:  47f5                 li a5,29
    673a:  fcf42623           sw a5,-52(s0)
    673e:  fc042823           sw zero,-48(s0)
    6742:  fe042223           sw zero,-28(s0)
    6746:  fc840793           addi a5,s0,-56
    674a:  4601                 li a2,0
    674c:  85be                 mv a1,a5
    674e:  fa843503           ld a0,-88(s0)
    6752:  913fe0ef           jal ra,5064 <FUN_00005064>
    6756:  87aa                 mv a5,a0
    6758:  c399                 beqz a5,675e <FUN_00006680+0xde>
    675a:  4781                 li a5,0
    675c:  a809                 j 676e <FUN_00006680+0xee>
    675e:  fec42783           lw a5,-20(s0)
    6762:  2781                 sext.w a5,a5
    6764:  c399                 beqz a5,676a <FUN_00006680+0xea>
    6766:  4781                 li a5,0
    6768:  a019                 j 676e <FUN_00006680+0xee>
    676a:  f9842783           lw a5,-104(s0)
    676e:  853e                 mv a0,a5
    6770:  70a6                 ld ra,104(sp)
    6772:  7406                 ld s0,96(sp)
    6774:  6165                 addi sp,sp,112
    6776:  8082                 ret
0000000000006778 <sd_read_sectors>:
    6778:  7139                 addi sp,sp,-64
    677a:  fc06                 sd ra,56(sp)
    677c:  f822                 sd s0,48(sp)
    677e:  0080                 addi s0,sp,64
    6780:  fca43c23           sd a0,-40(s0)
    6784:  87ae                 mv a5,a1
    6786:  8732                 mv a4,a2
    6788:  fcd43423           sd a3,-56(s0)
    678c:  fcf42a23           sw a5,-44(s0)
    6790:  87ba                 mv a5,a4
    6792:  fcf42823           sw a5,-48(s0)
    6796:  fd042783           lw a5,-48(s0)
    679a:  fef42623           sw a5,-20(s0)
    679e:  fd042783           lw a5,-48(s0)
    67a2:  2781                 sext.w a5,a5
    67a4:  e399                 bnez a5,67aa <sd_read_sectors+0x32>
    67a6:  4781                 li a5,0
    67a8:  a851                 j 683c <sd_read_sectors+0xc4>
    67aa:  fd843783           ld a5,-40(s0)
    67ae:  47fc                 lw a5,76(a5)
    67b0:  863e                 mv a2,a5
    67b2:  fec42783           lw a5,-20(s0)
    67b6:  0007869b           sext.w a3,a5
    67ba:  0006071b           sext.w a4,a2
    67be:  00d77363           bgeu a4,a3,67c4 <sd_read_sectors+0x4c>
    67c2:  87b2                 mv a5,a2
    67c4:  fef42423           sw a5,-24(s0)
    67c8:  fe842703           lw a4,-24(s0)
    67cc:  fd442783           lw a5,-44(s0)
    67d0:  86ba                 mv a3,a4
    67d2:  863e                 mv a2,a5
    67d4:  fc843583           ld a1,-56(s0)
    67d8:  fd843503           ld a0,-40(s0)
    67dc:  ea5ff0ef           jal ra,6680 <FUN_00006680>
    67e0:  87aa                 mv a5,a0
    67e2:  0007871b           sext.w a4,a5
    67e6:  fe842783           lw a5,-24(s0)
    67ea:  2781                 sext.w a5,a5
    67ec:  00e78463           beq a5,a4,67f4 <sd_read_sectors+0x7c>
    67f0:  4781                 li a5,0
    67f2:  a0a9                 j 683c <sd_read_sectors+0xc4>
    67f4:  fec42703           lw a4,-20(s0)
    67f8:  fe842783           lw a5,-24(s0)
    67fc:  40f707bb           subw a5,a4,a5
    6800:  fef42623           sw a5,-20(s0)
    6804:  fd442703           lw a4,-44(s0)
    6808:  fe842783           lw a5,-24(s0)
    680c:  9fb9                 addw a5,a5,a4
    680e:  fcf42a23           sw a5,-44(s0)
    6812:  fd843783           ld a5,-40(s0)
    6816:  47bc                 lw a5,72(a5)
    6818:  fe842703           lw a4,-24(s0)
    681c:  02f707bb           mulw a5,a4,a5
    6820:  2781                 sext.w a5,a5
    6822:  1782                 slli a5,a5,0x20
    6824:  9381                 srli a5,a5,0x20
    6826:  fc843703           ld a4,-56(s0)
    682a:  97ba                 add a5,a5,a4
    682c:  fcf43423           sd a5,-56(s0)
    6830:  fec42783           lw a5,-20(s0)
    6834:  2781                 sext.w a5,a5
    6836:  fbb5                 bnez a5,67aa <sd_read_sectors+0x32>
    6838:  fd042783           lw a5,-48(s0)
    683c:  853e                 mv a0,a5
    683e:  70e2                 ld ra,56(sp)
    6840:  7442                 ld s0,48(sp)
    6842:  6121                 addi sp,sp,64
    6844:  8082                 ret
0000000000006846 <FUN_00006846>:
    6846:  7119                 addi sp,sp,-128
    6848:  fc86                 sd ra,120(sp)
    684a:  f8a2                 sd s0,112(sp)
    684c:  0100                 addi s0,sp,128
    684e:  f8a43c23           sd a0,-104(s0)
    6852:  87ae                 mv a5,a1
    6854:  8732                 mv a4,a2
    6856:  f8d43423           sd a3,-120(s0)
    685a:  f8f42a23           sw a5,-108(s0)
    685e:  87ba                 mv a5,a4
    6860:  f8f42823           sw a5,-112(s0)
    6864:  fe042423           sw zero,-24(s0)
    6868:  4785                 li a5,1
    686a:  fef42623           sw a5,-20(s0)
    686e:  f9843783           ld a5,-104(s0)
    6872:  00b72737           lui a4,0xb72
    6876:  b007071b           addiw a4,a4,-1280
    687a:  d398                 sw a4,32(a5)
    687c:  f9843503           ld a0,-104(s0)
    6880:  85cfe0ef           jal ra,48dc <FUN_000048dc>
    6884:  f9843503           ld a0,-104(s0)
    6888:  89cfe0ef           jal ra,4924 <FUN_00004924>
    688c:  12c00513           li a0,300
    6890:  0f5030ef           jal ra,a184 <udelay>
    6894:  f9843503           ld a0,-104(s0)
    6898:  8ecff0ef           jal ra,5984 <FUN_00005984>
    689c:  fc042023           sw zero,-64(s0)
    68a0:  fc042423           sw zero,-56(s0)
    68a4:  fc042223           sw zero,-60(s0)
    68a8:  4785                 li a5,1
    68aa:  fcf42e23           sw a5,-36(s0)
    68ae:  f8843783           ld a5,-120(s0)
    68b2:  faf43423           sd a5,-88(s0)
    68b6:  f9042783           lw a5,-112(s0)
    68ba:  faf42a23           sw a5,-76(s0)
    68be:  20000793           li a5,512
    68c2:  faf42c23           sw a5,-72(s0)
    68c6:  4785                 li a5,1
    68c8:  faf42823           sw a5,-80(s0)
    68cc:  fa840713           addi a4,s0,-88
    68d0:  fc040793           addi a5,s0,-64
    68d4:  863a                 mv a2,a4
    68d6:  85be                 mv a1,a5
    68d8:  f9843503           ld a0,-104(s0)
    68dc:  f88fe0ef           jal ra,5064 <FUN_00005064>
    68e0:  87aa                 mv a5,a0
    68e2:  fef42423           sw a5,-24(s0)
    68e6:  fe842783           lw a5,-24(s0)
    68ea:  0007871b           sext.w a4,a5
    68ee:  57ed                 li a5,-5
    68f0:  00f70963           beq a4,a5,6902 <FUN_00006846+0xbc>
    68f4:  fe842783           lw a5,-24(s0)
    68f8:  0007871b           sext.w a4,a5
    68fc:  57e9                 li a5,-6
    68fe:  00f71563           bne a4,a5,6908 <FUN_00006846+0xc2>
    6902:  fe842783           lw a5,-24(s0)
    6906:  a83d                 j 6944 <FUN_00006846+0xfe>
    6908:  fe842783           lw a5,-24(s0)
    690c:  2781                 sext.w a5,a5
    690e:  c395                 beqz a5,6932 <FUN_00006846+0xec>
    6910:  fec42783           lw a5,-20(s0)
    6914:  2781                 sext.w a5,a5
    6916:  cf91                 beqz a5,6932 <FUN_00006846+0xec>
    6918:  fe042623           sw zero,-20(s0)
    691c:  f9843783           ld a5,-104(s0)
    6920:  005b9737           lui a4,0x5b9
    6924:  d807071b           addiw a4,a4,-640
    6928:  d398                 sw a4,32(a5)
    692a:  4505                 li a0,1
    692c:  083030ef           jal ra,a1ae <udelay_x800>
    6930:  b7b1                 j 687c <FUN_00006846+0x36>
    6932:  fe842783           lw a5,-24(s0)
    6936:  2781                 sext.w a5,a5
    6938:  c781                 beqz a5,6940 <FUN_00006846+0xfa>
    693a:  fe842783           lw a5,-24(s0)
    693e:  a019                 j 6944 <FUN_00006846+0xfe>
    6940:  f9042783           lw a5,-112(s0)
    6944:  853e                 mv a0,a5
    6946:  70e6                 ld ra,120(sp)
    6948:  7446                 ld s0,112(sp)
    694a:  6109                 addi sp,sp,128
    694c:  8082                 ret
000000000000694e <FUN_0000694e>:
    694e:  7179                 addi sp,sp,-48
    6950:  f406                 sd ra,40(sp)
    6952:  f022                 sd s0,32(sp)
    6954:  1800                 addi s0,sp,48
    6956:  fca43c23           sd a0,-40(s0)
    695a:  fe042623           sw zero,-20(s0)
    695e:  fd843503           ld a0,-40(s0)
    6962:  848fe0ef           jal ra,49aa <FUN_000049aa>
    6966:  87aa                 mv a5,a0
    6968:  fef42623           sw a5,-20(s0)
    696c:  fec42783           lw a5,-20(s0)
    6970:  2781                 sext.w a5,a5
    6972:  c781                 beqz a5,697a <FUN_0000694e+0x2c>
    6974:  fec42783           lw a5,-20(s0)
    6978:  a075                 j 6a24 <FUN_0000694e+0xd6>
    697a:  fd843783           ld a5,-40(s0)
    697e:  4bbc                 lw a5,80(a5)
    6980:  873e                 mv a4,a5
    6982:  4789                 li a5,2
    6984:  00f71663           bne a4,a5,6990 <FUN_0000694e+0x42>
    6988:  fd843503           ld a0,-40(s0)
    698c:  f51fd0ef           jal ra,48dc <FUN_000048dc>
    6990:  fd843783           ld a5,-40(s0)
    6994:  00062737           lui a4,0x62
    6998:  a807071b           addiw a4,a4,-1408
    699c:  d398                 sw a4,32(a5)
    699e:  fd843783           ld a5,-40(s0)
    69a2:  4705                 li a4,1
    69a4:  cfd8                 sw a4,28(a5)
    69a6:  fd843503           ld a0,-40(s0)
    69aa:  f7bfd0ef           jal ra,4924 <FUN_00004924>
    69ae:  fd843783           ld a5,-40(s0)
    69b2:  4bbc                 lw a5,80(a5)
    69b4:  873e                 mv a4,a5
    69b6:  4789                 li a5,2
    69b8:  00f71663           bne a4,a5,69c4 <FUN_0000694e+0x76>
    69bc:  12c00513           li a0,300
    69c0:  7c4030ef           jal ra,a184 <udelay>
    69c4:  fd843503           ld a0,-40(s0)
    69c8:  f73fe0ef           jal ra,593a <FUN_0000593a>
    69cc:  87aa                 mv a5,a0
    69ce:  fef42623           sw a5,-20(s0)
    69d2:  fec42783           lw a5,-20(s0)
    69d6:  2781                 sext.w a5,a5
    69d8:  c781                 beqz a5,69e0 <FUN_0000694e+0x92>
    69da:  fec42783           lw a5,-20(s0)
    69de:  a099                 j 6a24 <FUN_0000694e+0xd6>
    69e0:  fd843783           ld a5,-40(s0)
    69e4:  0407a223           sw zero,68(a5) # ff8044 <gpio_get_boot_device+0xfe9cae>
    69e8:  fd843503           ld a0,-40(s0)
    69ec:  c03ff0ef           jal ra,65ee <FUN_000065ee>
    69f0:  fd843503           ld a0,-40(s0)
    69f4:  82eff0ef           jal ra,5a22 <FUN_00005a22>
    69f8:  87aa                 mv a5,a0
    69fa:  fef42623           sw a5,-20(s0)
    69fe:  fec42783           lw a5,-20(s0)
    6a02:  2781                 sext.w a5,a5
    6a04:  cf91                 beqz a5,6a20 <FUN_0000694e+0xd2>
    6a06:  fd843503           ld a0,-40(s0)
    6a0a:  95eff0ef           jal ra,5b68 <FUN_00005b68>
    6a0e:  87aa                 mv a5,a0
    6a10:  fef42623           sw a5,-20(s0)
    6a14:  fec42783           lw a5,-20(s0)
    6a18:  2781                 sext.w a5,a5
    6a1a:  c399                 beqz a5,6a20 <FUN_0000694e+0xd2>
    6a1c:  57bd                 li a5,-17
    6a1e:  a019                 j 6a24 <FUN_0000694e+0xd6>
    6a20:  fec42783           lw a5,-20(s0)
    6a24:  853e                 mv a0,a5
    6a26:  70a2                 ld ra,40(sp)
    6a28:  7402                 ld s0,32(sp)
    6a2a:  6145                 addi sp,sp,48
    6a2c:  8082                 ret
0000000000006a2e <FUN_00006a2e>:
    6a2e:  7179                 addi sp,sp,-48
    6a30:  f406                 sd ra,40(sp)
    6a32:  f022                 sd s0,32(sp)
    6a34:  1800                 addi s0,sp,48
    6a36:  87aa                 mv a5,a0
    6a38:  fcb43823           sd a1,-48(s0)
    6a3c:  fcf42e23           sw a5,-36(s0)
    6a40:  57fd                 li a5,-1
    6a42:  fef42623           sw a5,-20(s0)
    6a46:  fdc42783           lw a5,-36(s0)
    6a4a:  fd043583           ld a1,-48(s0)
    6a4e:  853e                 mv a0,a5
    6a50:  d71fe0ef           jal ra,57c0 <FUN_000057c0>
    6a54:  87aa                 mv a5,a0
    6a56:  fef42623           sw a5,-20(s0)
    6a5a:  fec42783           lw a5,-20(s0)
    6a5e:  2781                 sext.w a5,a5
    6a60:  c399                 beqz a5,6a66 <FUN_00006a2e+0x38>
    6a62:  57fd                 li a5,-1
    6a64:  a089                 j 6aa6 <FUN_00006a2e+0x78>
    6a66:  fd043783           ld a5,-48(s0)
    6a6a:  12c00713           li a4,300
    6a6e:  c7f8                 sw a4,76(a5)
    6a70:  fd043503           ld a0,-48(s0)
    6a74:  edbff0ef           jal ra,694e <FUN_0000694e>
    6a78:  87aa                 mv a5,a0
    6a7a:  fef42623           sw a5,-20(s0)
    6a7e:  fec42783           lw a5,-20(s0)
    6a82:  2781                 sext.w a5,a5
    6a84:  c399                 beqz a5,6a8a <FUN_00006a2e+0x5c>
    6a86:  57fd                 li a5,-1
    6a88:  a839                 j 6aa6 <FUN_00006a2e+0x78>
    6a8a:  fd043503           ld a0,-48(s0)
    6a8e:  e2eff0ef           jal ra,60bc <FUN_000060bc>
    6a92:  87aa                 mv a5,a0
    6a94:  fef42623           sw a5,-20(s0)
    6a98:  fec42783           lw a5,-20(s0)
    6a9c:  2781                 sext.w a5,a5
    6a9e:  c399                 beqz a5,6aa4 <FUN_00006a2e+0x76>
    6aa0:  57fd                 li a5,-1
    6aa2:  a011                 j 6aa6 <FUN_00006a2e+0x78>
    6aa4:  4781                 li a5,0
    6aa6:  853e                 mv a0,a5
    6aa8:  70a2                 ld ra,40(sp)
    6aaa:  7402                 ld s0,32(sp)
    6aac:  6145                 addi sp,sp,48
    6aae:  8082                 ret
0000000000006ab0 <FUN_00006ab0>:
    6ab0:  7179                 addi sp,sp,-48
    6ab2:  f406                 sd ra,40(sp)
    6ab4:  f022                 sd s0,32(sp)
    6ab6:  1800                 addi s0,sp,48
    6ab8:  87aa                 mv a5,a0
    6aba:  fcb43823           sd a1,-48(s0)
    6abe:  fcf42e23           sw a5,-36(s0)
    6ac2:  57fd                 li a5,-1
    6ac4:  fef42623           sw a5,-20(s0)
    6ac8:  fdc42783           lw a5,-36(s0)
    6acc:  fd043583           ld a1,-48(s0)
    6ad0:  853e                 mv a0,a5
    6ad2:  ceffe0ef           jal ra,57c0 <FUN_000057c0>
    6ad6:  87aa                 mv a5,a0
    6ad8:  fef42623           sw a5,-20(s0)
    6adc:  fec42783           lw a5,-20(s0)
    6ae0:  2781                 sext.w a5,a5
    6ae2:  c399                 beqz a5,6ae8 <FUN_00006ab0+0x38>
    6ae4:  57fd                 li a5,-1
    6ae6:  a8a1                 j 6b3e <FUN_00006ab0+0x8e>
    6ae8:  fd043783           ld a5,-48(s0)
    6aec:  12c00713           li a4,300
    6af0:  c7f8                 sw a4,76(a5)
    6af2:  fd043503           ld a0,-48(s0)
    6af6:  eb5fd0ef           jal ra,49aa <FUN_000049aa>
    6afa:  87aa                 mv a5,a0
    6afc:  fef42623           sw a5,-20(s0)
    6b00:  fec42783           lw a5,-20(s0)
    6b04:  2781                 sext.w a5,a5
    6b06:  c781                 beqz a5,6b0e <FUN_00006ab0+0x5e>
    6b08:  fec42783           lw a5,-20(s0)
    6b0c:  a80d                 j 6b3e <FUN_00006ab0+0x8e>
    6b0e:  fd043503           ld a0,-48(s0)
    6b12:  dcbfd0ef           jal ra,48dc <FUN_000048dc>
    6b16:  fd043783           ld a5,-48(s0)
    6b1a:  00b72737           lui a4,0xb72
    6b1e:  b007071b           addiw a4,a4,-1280
    6b22:  d398                 sw a4,32(a5)
    6b24:  fd043783           ld a5,-48(s0)
    6b28:  4711                 li a4,4
    6b2a:  cfd8                 sw a4,28(a5)
    6b2c:  fd043503           ld a0,-48(s0)
    6b30:  df5fd0ef           jal ra,4924 <FUN_00004924>
    6b34:  12c00513           li a0,300
    6b38:  64c030ef           jal ra,a184 <udelay>
    6b3c:  4781                 li a5,0
    6b3e:  853e                 mv a0,a5
    6b40:  70a2                 ld ra,40(sp)
    6b42:  7402                 ld s0,32(sp)
    6b44:  6145                 addi sp,sp,48
    6b46:  8082                 ret
0000000000006b48 <FUN_00006b48>:
    6b48:  1101                 addi sp,sp,-32
    6b4a:  ec06                 sd ra,24(sp)
    6b4c:  e822                 sd s0,16(sp)
    6b4e:  1000                 addi s0,sp,32
    6b50:  87aa                 mv a5,a0
    6b52:  feb43023           sd a1,-32(s0)
    6b56:  fef42623           sw a5,-20(s0)
    6b5a:  fec42783           lw a5,-20(s0)
    6b5e:  fe043583           ld a1,-32(s0)
    6b62:  853e                 mv a0,a5
    6b64:  cf5fe0ef           jal ra,5858 <FUN_00005858>
    6b68:  4781                 li a5,0
    6b6a:  853e                 mv a0,a5
    6b6c:  60e2                 ld ra,24(sp)
    6b6e:  6442                 ld s0,16(sp)
    6b70:  6105                 addi sp,sp,32
    6b72:  8082                 ret
0000000000006b74 <FUN_00006b74>:
    6b74:  1101                 addi sp,sp,-32
    6b76:  ec06                 sd ra,24(sp)
    6b78:  e822                 sd s0,16(sp)
    6b7a:  1000                 addi s0,sp,32
    6b7c:  f9900793           li a5,-103
    6b80:  fef407a3           sb a5,-17(s0)
    6b84:  fef40793           addi a5,s0,-17
    6b88:  85be                 mv a1,a5
    6b8a:  4505                 li a0,1
    6b8c:  205000ef           jal ra,7590 <FUN_00007590>
    6b90:  87aa                 mv a5,a0
    6b92:  873e                 mv a4,a5
    6b94:  4789                 li a5,2
    6b96:  00f71c63           bne a4,a5,6bae <FUN_00006b74+0x3a>
    6b9a:  4605                 li a2,1
    6b9c:  00eff7b7           lui a5,0xeff
    6ba0:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    6ba4:  450d                 li a0,3
    6ba6:  083010ef           jal ra,8428 <rtc_brom_debug>
    6baa:  4789                 li a5,2
    6bac:  a029                 j 6bb6 <FUN_00006b74+0x42>
    6bae:  4505                 li a0,1
    6bb0:  5fe030ef           jal ra,a1ae <udelay_x800>
    6bb4:  4781                 li a5,0
    6bb6:  853e                 mv a0,a5
    6bb8:  60e2                 ld ra,24(sp)
    6bba:  6442                 ld s0,16(sp)
    6bbc:  6105                 addi sp,sp,32
    6bbe:  8082                 ret
0000000000006bc0 <FUN_00006bc0>:
    6bc0:  1101                 addi sp,sp,-32
    6bc2:  ec06                 sd ra,24(sp)
    6bc4:  e822                 sd s0,16(sp)
    6bc6:  1000                 addi s0,sp,32
    6bc8:  06600793           li a5,102
    6bcc:  fef407a3           sb a5,-17(s0)
    6bd0:  fef40793           addi a5,s0,-17
    6bd4:  85be                 mv a1,a5
    6bd6:  4505                 li a0,1
    6bd8:  1b9000ef           jal ra,7590 <FUN_00007590>
    6bdc:  87aa                 mv a5,a0
    6bde:  873e                 mv a4,a5
    6be0:  4789                 li a5,2
    6be2:  00f71c63           bne a4,a5,6bfa <FUN_00006bc0+0x3a>
    6be6:  4609                 li a2,2
    6be8:  00eff7b7           lui a5,0xeff
    6bec:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    6bf0:  450d                 li a0,3
    6bf2:  037010ef           jal ra,8428 <rtc_brom_debug>
    6bf6:  4789                 li a5,2
    6bf8:  a029                 j 6c02 <FUN_00006bc0+0x42>
    6bfa:  4505                 li a0,1
    6bfc:  5b2030ef           jal ra,a1ae <udelay_x800>
    6c00:  4781                 li a5,0
    6c02:  853e                 mv a0,a5
    6c04:  60e2                 ld ra,24(sp)
    6c06:  6442                 ld s0,16(sp)
    6c08:  6105                 addi sp,sp,32
    6c0a:  8082                 ret
0000000000006c0c <FUN_00006c0c>:
    6c0c:  1101                 addi sp,sp,-32
    6c0e:  ec22                 sd s0,24(sp)
    6c10:  1000                 addi s0,sp,32
    6c12:  020007b7           lui a5,0x2000
    6c16:  06478793           addi a5,a5,100 # 2000064 <gpio_get_boot_device+0x1ff1cce
    6c1a:  439c                 lw a5,0(a5)
    6c1c:  fef42623           sw a5,-20(s0)
    6c20:  fec42703           lw a4,-20(s0)
    6c24:  900007b7           lui a5,0x90000
    6c28:  17fd                 addi a5,a5,-1
    6c2a:  8ff9                 and a5,a5,a4
    6c2c:  fef42623           sw a5,-20(s0)
    6c30:  fec42703           lw a4,-20(s0)
    6c34:  400007b7           lui a5,0x40000
    6c38:  8fd9                 or a5,a5,a4
    6c3a:  fef42623           sw a5,-20(s0)
    6c3e:  020007b7           lui a5,0x2000
    6c42:  06478793           addi a5,a5,100 # 2000064 <gpio_get_boot_device+0x1ff1cce
    6c46:  fec42703           lw a4,-20(s0)
    6c4a:  c398                 sw a4,0(a5)
    6c4c:  020007b7           lui a5,0x2000
    6c50:  06878793           addi a5,a5,104 # 2000068 <gpio_get_boot_device+0x1ff1cd2
    6c54:  439c                 lw a5,0(a5)
    6c56:  fef42623           sw a5,-20(s0)
    6c5a:  fec42783           lw a5,-20(s0)
    6c5e:  9be1                 andi a5,a5,-8
    6c60:  fef42623           sw a5,-20(s0)
    6c64:  fec42783           lw a5,-20(s0)
    6c68:  0047e793           ori a5,a5,4
    6c6c:  fef42623           sw a5,-20(s0)
    6c70:  020007b7           lui a5,0x2000
    6c74:  06878793           addi a5,a5,104 # 2000068 <gpio_get_boot_device+0x1ff1cd2
    6c78:  fec42703           lw a4,-20(s0)
    6c7c:  c398                 sw a4,0(a5)
    6c7e:  020007b7           lui a5,0x2000
    6c82:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6c86:  439c                 lw a5,0(a5)
    6c88:  fef42623           sw a5,-20(s0)
    6c8c:  fec42703           lw a4,-20(s0)
    6c90:  400007b7           lui a5,0x40000
    6c94:  17fd                 addi a5,a5,-1
    6c96:  8ff9                 and a5,a5,a4
    6c98:  fef42623           sw a5,-20(s0)
    6c9c:  fec42703           lw a4,-20(s0)
    6ca0:  400007b7           lui a5,0x40000
    6ca4:  8fd9                 or a5,a5,a4
    6ca6:  fef42623           sw a5,-20(s0)
    6caa:  020007b7           lui a5,0x2000
    6cae:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6cb2:  fec42703           lw a4,-20(s0)
    6cb6:  c398                 sw a4,0(a5)
    6cb8:  020007b7           lui a5,0x2000
    6cbc:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6cc0:  439c                 lw a5,0(a5)
    6cc2:  fef42623           sw a5,-20(s0)
    6cc6:  fec42703           lw a4,-20(s0)
    6cca:  400007b7           lui a5,0x40000
    6cce:  17fd                 addi a5,a5,-1
    6cd0:  8ff9                 and a5,a5,a4
    6cd2:  fef42623           sw a5,-20(s0)
    6cd6:  020007b7           lui a5,0x2000
    6cda:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6cde:  fec42703           lw a4,-20(s0)
    6ce2:  c398                 sw a4,0(a5)
    6ce4:  0001                 nop
    6ce6:  6462                 ld s0,24(sp)
    6ce8:  6105                 addi sp,sp,32
    6cea:  8082                 ret
0000000000006cec <FUN_00006cec>:
    6cec:  1101                 addi sp,sp,-32
    6cee:  ec22                 sd s0,24(sp)
    6cf0:  1000                 addi s0,sp,32
    6cf2:  040257b7           lui a5,0x4025
    6cf6:  08878793           addi a5,a5,136 # 4025088 <gpio_get_boot_device+0x4016cf2
    6cfa:  439c                 lw a5,0(a5)
    6cfc:  fef42623           sw a5,-20(s0)
    6d00:  fec42703           lw a4,-20(s0)
    6d04:  e00007b7           lui a5,0xe0000
    6d08:  17fd                 addi a5,a5,-1
    6d0a:  8ff9                 and a5,a5,a4
    6d0c:  fef42623           sw a5,-20(s0)
    6d10:  fec42703           lw a4,-20(s0)
    6d14:  200007b7           lui a5,0x20000
    6d18:  8fd9                 or a5,a5,a4
    6d1a:  fef42623           sw a5,-20(s0)
    6d1e:  040257b7           lui a5,0x4025
    6d22:  08878793           addi a5,a5,136 # 4025088 <gpio_get_boot_device+0x4016cf2
    6d26:  fec42703           lw a4,-20(s0)
    6d2a:  c398                 sw a4,0(a5)
    6d2c:  0001                 nop
    6d2e:  6462                 ld s0,24(sp)
    6d30:  6105                 addi sp,sp,32
    6d32:  8082                 ret
0000000000006d34 <FUN_00006d34>:
    6d34:  7179                 addi sp,sp,-48
    6d36:  f422                 sd s0,40(sp)
    6d38:  1800                 addi s0,sp,48
    6d3a:  87aa                 mv a5,a0
    6d3c:  fcf42e23           sw a5,-36(s0)
    6d40:  040257b7           lui a5,0x4025
    6d44:  07a1                 addi a5,a5,8
    6d46:  439c                 lw a5,0(a5)
    6d48:  2781                 sext.w a5,a5
    6d4a:  fcf7f793           andi a5,a5,-49
    6d4e:  fef42623           sw a5,-20(s0)
    6d52:  fdc42783           lw a5,-36(s0)
    6d56:  0047979b           slliw a5,a5,0x4
    6d5a:  0007871b           sext.w a4,a5
    6d5e:  fec42783           lw a5,-20(s0)
    6d62:  8fd9                 or a5,a5,a4
    6d64:  fef42623           sw a5,-20(s0)
    6d68:  040257b7           lui a5,0x4025
    6d6c:  07a1                 addi a5,a5,8
    6d6e:  fec42703           lw a4,-20(s0)
    6d72:  c398                 sw a4,0(a5)
    6d74:  0001                 nop
    6d76:  7422                 ld s0,40(sp)
    6d78:  6145                 addi sp,sp,48
    6d7a:  8082                 ret
0000000000006d7c <FUN_00006d7c>:
    6d7c:  1101                 addi sp,sp,-32
    6d7e:  ec06                 sd ra,24(sp)
    6d80:  e822                 sd s0,16(sp)
    6d82:  1000                 addi s0,sp,32
    6d84:  fe042623           sw zero,-20(s0)
    6d88:  fe042423           sw zero,-24(s0)
    6d8c:  020007b7           lui a5,0x2000
    6d90:  34878793           addi a5,a5,840 # 2000348 <gpio_get_boot_device+0x1ff1fb2
    6d94:  439c                 lw a5,0(a5)
    6d96:  fef42623           sw a5,-20(s0)
    6d9a:  fec42783           lw a5,-20(s0)
    6d9e:  8b91                 andi a5,a5,4
    6da0:  fef42623           sw a5,-20(s0)
    6da4:  fec42783           lw a5,-20(s0)
    6da8:  2781                 sext.w a5,a5
    6daa:  c795                 beqz a5,6dd6 <FUN_00006d7c+0x5a>
    6dac:  020007b7           lui a5,0x2000
    6db0:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6db4:  439c                 lw a5,0(a5)
    6db6:  fef42423           sw a5,-24(s0)
    6dba:  fe842783           lw a5,-24(s0)
    6dbe:  0047e793           ori a5,a5,4
    6dc2:  fef42423           sw a5,-24(s0)
    6dc6:  020007b7           lui a5,0x2000
    6dca:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6dce:  fe842703           lw a4,-24(s0)
    6dd2:  c398                 sw a4,0(a5)
    6dd4:  a025                 j 6dfc <FUN_00006d7c+0x80>
    6dd6:  020007b7           lui a5,0x2000
    6dda:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6dde:  439c                 lw a5,0(a5)
    6de0:  fef42423           sw a5,-24(s0)
    6de4:  fe842783           lw a5,-24(s0)
    6de8:  9bed                 andi a5,a5,-5
    6dea:  fef42423           sw a5,-24(s0)
    6dee:  020007b7           lui a5,0x2000
    6df2:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6df6:  fe842703           lw a4,-24(s0)
    6dfa:  c398                 sw a4,0(a5)
    6dfc:  4529                 li a0,10
    6dfe:  386030ef           jal ra,a184 <udelay>
    6e02:  0001                 nop
    6e04:  60e2                 ld ra,24(sp)
    6e06:  6442                 ld s0,16(sp)
    6e08:  6105                 addi sp,sp,32
    6e0a:  8082                 ret
0000000000006e0c <FUN_00006e0c>:
    6e0c:  1101                 addi sp,sp,-32
    6e0e:  ec22                 sd s0,24(sp)
    6e10:  1000                 addi s0,sp,32
    6e12:  fe042623           sw zero,-20(s0)
    6e16:  020007b7           lui a5,0x2000
    6e1a:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6e1e:  439c                 lw a5,0(a5)
    6e20:  fef42623           sw a5,-20(s0)
    6e24:  fec42783           lw a5,-20(s0)
    6e28:  9bed                 andi a5,a5,-5
    6e2a:  fef42623           sw a5,-20(s0)
    6e2e:  020007b7           lui a5,0x2000
    6e32:  34078793           addi a5,a5,832 # 2000340 <gpio_get_boot_device+0x1ff1faa
    6e36:  fec42703           lw a4,-20(s0)
    6e3a:  c398                 sw a4,0(a5)
    6e3c:  0001                 nop
    6e3e:  6462                 ld s0,24(sp)
    6e40:  6105                 addi sp,sp,32
    6e42:  8082                 ret
0000000000006e44 <FUN_00006e44>:
    6e44:  1101                 addi sp,sp,-32
    6e46:  ec06                 sd ra,24(sp)
    6e48:  e822                 sd s0,16(sp)
    6e4a:  1000                 addi s0,sp,32
    6e4c:  87aa                 mv a5,a0
    6e4e:  fef42623           sw a5,-20(s0)
    6e52:  f2bff0ef           jal ra,6d7c <FUN_00006d7c>
    6e56:  020007b7           lui a5,0x2000
    6e5a:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    6e5e:  22222737           lui a4,0x22222
    6e62:  2ff7071b           addiw a4,a4,767
    6e66:  c398                 sw a4,0(a5)
    6e68:  020007b7           lui a5,0x2000
    6e6c:  07078793           addi a5,a5,112 # 2000070 <gpio_get_boot_device+0x1ff1cda
    6e70:  0c000713           li a4,192
    6e74:  c398                 sw a4,0(a5)
    6e76:  020007b7           lui a5,0x2000
    6e7a:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6e7e:  04000713           li a4,64
    6e82:  c398                 sw a4,0(a5)
    6e84:  fec42783           lw a5,-20(s0)
    6e88:  0007871b           sext.w a4,a5
    6e8c:  47a1                 li a5,8
    6e8e:  00f71463           bne a4,a5,6e96 <FUN_00006e44+0x52>
    6e92:  d7bff0ef           jal ra,6c0c <FUN_00006c0c>
    6e96:  0001                 nop
    6e98:  60e2                 ld ra,24(sp)
    6e9a:  6442                 ld s0,16(sp)
    6e9c:  6105                 addi sp,sp,32
    6e9e:  8082                 ret
0000000000006ea0 <FUN_00006ea0>:
    6ea0:  1141                 addi sp,sp,-16
    6ea2:  e406                 sd ra,8(sp)
    6ea4:  e022                 sd s0,0(sp)
    6ea6:  0800                 addi s0,sp,16
    6ea8:  020007b7           lui a5,0x2000
    6eac:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    6eb0:  577d                 li a4,-1
    6eb2:  c398                 sw a4,0(a5)
    6eb4:  020007b7           lui a5,0x2000
    6eb8:  07078793           addi a5,a5,112 # 2000070 <gpio_get_boot_device+0x1ff1cda
    6ebc:  0007a023           sw zero,0(a5)
    6ec0:  020007b7           lui a5,0x2000
    6ec4:  08478793           addi a5,a5,132 # 2000084 <gpio_get_boot_device+0x1ff1cee
    6ec8:  54000713           li a4,1344
    6ecc:  c398                 sw a4,0(a5)
    6ece:  f3fff0ef           jal ra,6e0c <FUN_00006e0c>
    6ed2:  0001                 nop
    6ed4:  60a2                 ld ra,8(sp)
    6ed6:  6402                 ld s0,0(sp)
    6ed8:  0141                 addi sp,sp,16
    6eda:  8082                 ret
0000000000006edc <FUN_00006edc>:
    6edc:  1101                 addi sp,sp,-32
    6ede:  ec06                 sd ra,24(sp)
    6ee0:  e822                 sd s0,16(sp)
    6ee2:  1000                 addi s0,sp,32
    6ee4:  87aa                 mv a5,a0
    6ee6:  fef42623           sw a5,-20(s0)
    6eea:  020027b7           lui a5,0x2002
    6eee:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    6ef2:  439c                 lw a5,0(a5)
    6ef4:  0007871b           sext.w a4,a5
    6ef8:  020027b7           lui a5,0x2002
    6efc:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    6f00:  86ba                 mv a3,a4
    6f02:  6741                 lui a4,0x10
    6f04:  8f55                 or a4,a4,a3
    6f06:  2701                 sext.w a4,a4
    6f08:  c398                 sw a4,0(a5)
    6f0a:  020027b7           lui a5,0x2002
    6f0e:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    6f12:  439c                 lw a5,0(a5)
    6f14:  0007871b           sext.w a4,a5
    6f18:  020027b7           lui a5,0x2002
    6f1c:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    6f20:  00176713           ori a4,a4,1
    6f24:  2701                 sext.w a4,a4
    6f26:  c398                 sw a4,0(a5)
    6f28:  020027b7           lui a5,0x2002
    6f2c:  94078793           addi a5,a5,-1728 # 2001940 <gpio_get_boot_device+0x1ff35
    6f30:  80000737           lui a4,0x80000
    6f34:  c398                 sw a4,0(a5)
    6f36:  fec42783           lw a5,-20(s0)
    6f3a:  853e                 mv a0,a5
    6f3c:  f09ff0ef           jal ra,6e44 <FUN_00006e44>
    6f40:  fec42783           lw a5,-20(s0)
    6f44:  0007871b           sext.w a4,a5
    6f48:  47a1                 li a5,8
    6f4a:  00f71463           bne a4,a5,6f52 <FUN_00006edc+0x76>
    6f4e:  d9fff0ef           jal ra,6cec <FUN_00006cec>
    6f52:  637020ef           jal ra,9d88 <FUN_00009d88>
    6f56:  040257b7           lui a5,0x4025
    6f5a:  0791                 addi a5,a5,4
    6f5c:  80000737           lui a4,0x80000
    6f60:  0837071b           addiw a4,a4,131
    6f64:  c398                 sw a4,0(a5)
    6f66:  0003b7b7           lui a5,0x3b
    6f6a:  98078613           addi a2,a5,-1664 # 3a980 <gpio_get_boot_device+0x2c5ea>
    6f6e:  800005b7           lui a1,0x80000
    6f72:  040257b7           lui a5,0x4025
    6f76:  00478513           addi a0,a5,4 # 4025004 <gpio_get_boot_device+0x4016c6e>
    6f7a:  1cc000ef           jal ra,7146 <FUN_00007146>
    6f7e:  040257b7           lui a5,0x4025
    6f82:  07a1                 addi a5,a5,8
    6f84:  18400713           li a4,388
    6f88:  c398                 sw a4,0(a5)
    6f8a:  040257b7           lui a5,0x4025
    6f8e:  07e1                 addi a5,a5,24
    6f90:  80208737           lui a4,0x80208
    6f94:  0207071b           addiw a4,a4,32
    6f98:  c398                 sw a4,0(a5)
    6f9a:  0003b7b7           lui a5,0x3b
    6f9e:  98078613           addi a2,a5,-1664 # 3a980 <gpio_get_boot_device+0x2c5ea>
    6fa2:  800085b7           lui a1,0x80008
    6fa6:  040257b7           lui a5,0x4025
    6faa:  01878513           addi a0,a5,24 # 4025018 <gpio_get_boot_device+0x4016c82>
    6fae:  198000ef           jal ra,7146 <FUN_00007146>
    6fb2:  040257b7           lui a5,0x4025
    6fb6:  07c1                 addi a5,a5,16
    6fb8:  0007a023           sw zero,0(a5) # 4025000 <gpio_get_boot_device+0x4016c6a>
    6fbc:  040257b7           lui a5,0x4025
    6fc0:  07d1                 addi a5,a5,20
    6fc2:  577d                 li a4,-1
    6fc4:  c398                 sw a4,0(a5)
    6fc6:  0001                 nop
    6fc8:  60e2                 ld ra,24(sp)
    6fca:  6442                 ld s0,16(sp)
    6fcc:  6105                 addi sp,sp,32
    6fce:  8082                 ret
0000000000006fd0 <FUN_00006fd0>:
    6fd0:  1141                 addi sp,sp,-16
    6fd2:  e406                 sd ra,8(sp)
    6fd4:  e022                 sd s0,0(sp)
    6fd6:  0800                 addi s0,sp,16
    6fd8:  040257b7           lui a5,0x4025
    6fdc:  0791                 addi a5,a5,4
    6fde:  0007a023           sw zero,0(a5) # 4025000 <gpio_get_boot_device+0x4016c6a>
    6fe2:  ebfff0ef           jal ra,6ea0 <FUN_00006ea0>
    6fe6:  020027b7           lui a5,0x2002
    6fea:  94078793           addi a5,a5,-1728 # 2001940 <gpio_get_boot_device+0x1ff35
    6fee:  0007a023           sw zero,0(a5)
    6ff2:  020027b7           lui a5,0x2002
    6ff6:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    6ffa:  439c                 lw a5,0(a5)
    6ffc:  0007871b           sext.w a4,a5
    7000:  020027b7           lui a5,0x2002
    7004:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    7008:  86ba                 mv a3,a4
    700a:  7741                 lui a4,0xffff0
    700c:  177d                 addi a4,a4,-1
    700e:  8f75                 and a4,a4,a3
    7010:  2701                 sext.w a4,a4
    7012:  c398                 sw a4,0(a5)
    7014:  020027b7           lui a5,0x2002
    7018:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    701c:  439c                 lw a5,0(a5)
    701e:  0007871b           sext.w a4,a5
    7022:  020027b7           lui a5,0x2002
    7026:  96c78793           addi a5,a5,-1684 # 200196c <gpio_get_boot_device+0x1ff35
    702a:  9b79                 andi a4,a4,-2
    702c:  2701                 sext.w a4,a4
    702e:  c398                 sw a4,0(a5)
    7030:  020017b7           lui a5,0x2001
    7034:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    7038:  439c                 lw a5,0(a5)
    703a:  0007871b           sext.w a4,a5
    703e:  020017b7           lui a5,0x2001
    7042:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    7046:  86ba                 mv a3,a4
    7048:  7741                 lui a4,0xffff0
    704a:  177d                 addi a4,a4,-1
    704c:  8f75                 and a4,a4,a3
    704e:  2701                 sext.w a4,a4
    7050:  c398                 sw a4,0(a5)
    7052:  020017b7           lui a5,0x2001
    7056:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    705a:  439c                 lw a5,0(a5)
    705c:  0007871b           sext.w a4,a5
    7060:  020017b7           lui a5,0x2001
    7064:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    7068:  9b79                 andi a4,a4,-2
    706a:  2701                 sext.w a4,a4
    706c:  c398                 sw a4,0(a5)
    706e:  0001                 nop
    7070:  60a2                 ld ra,8(sp)
    7072:  6402                 ld s0,0(sp)
    7074:  0141                 addi sp,sp,16
    7076:  8082                 ret
0000000000007078 <FUN_00007078>:
    7078:  7139                 addi sp,sp,-64
    707a:  fc06                 sd ra,56(sp)
    707c:  f822                 sd s0,48(sp)
    707e:  0080                 addi s0,sp,64
    7080:  87aa                 mv a5,a0
    7082:  fcf42623           sw a5,-52(s0)
    7086:  fe043423           sd zero,-24(s0)
    708a:  fe043023           sd zero,-32(s0)
    708e:  fcc46783           lwu a5,-52(s0)
    7092:  fcf43c23           sd a5,-40(s0)
    7096:  0e8030ef           jal ra,a17e <rdtime>
    709a:  fea43423           sd a0,-24(s0)
    709e:  030027b7           lui a5,0x3002
    70a2:  03078793           addi a5,a5,48 # 3002030 <gpio_get_boot_device+0x2ff3c9a>
    70a6:  439c                 lw a5,0(a5)
    70a8:  2781                 sext.w a5,a5
    70aa:  8b85                 andi a5,a5,1
    70ac:  2781                 sext.w a5,a5
    70ae:  e399                 bnez a5,70b4 <FUN_00007078+0x3c>
    70b0:  4781                 li a5,0
    70b2:  a00d                 j 70d4 <FUN_00007078+0x5c>
    70b4:  0ca030ef           jal ra,a17e <rdtime>
    70b8:  872a                 mv a4,a0
    70ba:  fe843783           ld a5,-24(s0)
    70be:  40f707b3           sub a5,a4,a5
    70c2:  fef43023           sd a5,-32(s0)
    70c6:  fe043703           ld a4,-32(s0)
    70ca:  fd843783           ld a5,-40(s0)
    70ce:  fcf768e3           bltu a4,a5,709e <FUN_00007078+0x26>
    70d2:  4789                 li a5,2
    70d4:  853e                 mv a0,a5
    70d6:  70e2                 ld ra,56(sp)
    70d8:  7442                 ld s0,48(sp)
    70da:  6121                 addi sp,sp,64
    70dc:  8082                 ret
00000000000070de <FUN_000070de>:
    70de:  7139                 addi sp,sp,-64
    70e0:  fc06                 sd ra,56(sp)
    70e2:  f822                 sd s0,48(sp)
    70e4:  0080                 addi s0,sp,64
    70e6:  87aa                 mv a5,a0
    70e8:  fcf42623           sw a5,-52(s0)
    70ec:  fe043423           sd zero,-24(s0)
    70f0:  fe043023           sd zero,-32(s0)
    70f4:  fcc46783           lwu a5,-52(s0)
    70f8:  fcf43c23           sd a5,-40(s0)
    70fc:  082030ef           jal ra,a17e <rdtime>
    7100:  fea43423           sd a0,-24(s0)
    7104:  040257b7           lui a5,0x4025
    7108:  07d1                 addi a5,a5,20
    710a:  439c                 lw a5,0(a5)
    710c:  2781                 sext.w a5,a5
    710e:  873e                 mv a4,a5
    7110:  6785                 lui a5,0x1
    7112:  8ff9                 and a5,a5,a4
    7114:  2781                 sext.w a5,a5
    7116:  c399                 beqz a5,711c <FUN_000070de+0x3e>
    7118:  4781                 li a5,0
    711a:  a00d                 j 713c <FUN_000070de+0x5e>
    711c:  062030ef           jal ra,a17e <rdtime>
    7120:  872a                 mv a4,a0
    7122:  fe843783           ld a5,-24(s0)
    7126:  40f707b3           sub a5,a4,a5
    712a:  fef43023           sd a5,-32(s0)
    712e:  fe043703           ld a4,-32(s0)
    7132:  fd843783           ld a5,-40(s0)
    7136:  fcf767e3           bltu a4,a5,7104 <FUN_000070de+0x26>
    713a:  4789                 li a5,2
    713c:  853e                 mv a0,a5
    713e:  70e2                 ld ra,56(sp)
    7140:  7442                 ld s0,48(sp)
    7142:  6121                 addi sp,sp,64
    7144:  8082                 ret
0000000000007146 <FUN_00007146>:
    7146:  715d                 addi sp,sp,-80
    7148:  e486                 sd ra,72(sp)
    714a:  e0a2                 sd s0,64(sp)
    714c:  0880                 addi s0,sp,80
    714e:  fca43423           sd a0,-56(s0)
    7152:  87ae                 mv a5,a1
    7154:  fac43c23           sd a2,-72(s0)
    7158:  fcf42223           sw a5,-60(s0)
    715c:  fe043423           sd zero,-24(s0)
    7160:  fe043023           sd zero,-32(s0)
    7164:  fb843783           ld a5,-72(s0)
    7168:  fcf43c23           sd a5,-40(s0)
    716c:  012030ef           jal ra,a17e <rdtime>
    7170:  fea43423           sd a0,-24(s0)
    7174:  00a030ef           jal ra,a17e <rdtime>
    7178:  872a                 mv a4,a0
    717a:  fe843783           ld a5,-24(s0)
    717e:  40f707b3           sub a5,a4,a5
    7182:  fef43023           sd a5,-32(s0)
    7186:  fc843783           ld a5,-56(s0)
    718a:  439c                 lw a5,0(a5)
    718c:  0007871b           sext.w a4,a5
    7190:  fc442783           lw a5,-60(s0)
    7194:  8ff9                 and a5,a5,a4
    7196:  2781                 sext.w a5,a5
    7198:  e399                 bnez a5,719e <FUN_00007146+0x58>
    719a:  4781                 li a5,0
    719c:  a801                 j 71ac <FUN_00007146+0x66>
    719e:  fe043703           ld a4,-32(s0)
    71a2:  fd843783           ld a5,-40(s0)
    71a6:  fcf767e3           bltu a4,a5,7174 <FUN_00007146+0x2e>
    71aa:  4789                 li a5,2
    71ac:  853e                 mv a0,a5
    71ae:  60a6                 ld ra,72(sp)
    71b0:  6406                 ld s0,64(sp)
    71b2:  6161                 addi sp,sp,80
    71b4:  8082                 ret
00000000000071b6 <FUN_000071b6>:
    71b6:  715d                 addi sp,sp,-80
    71b8:  e486                 sd ra,72(sp)
    71ba:  e0a2                 sd s0,64(sp)
    71bc:  0880                 addi s0,sp,80
    71be:  87aa                 mv a5,a0
    71c0:  872e                 mv a4,a1
    71c2:  fcc43023           sd a2,-64(s0)
    71c6:  fad43c23           sd a3,-72(s0)
    71ca:  fcf42623           sw a5,-52(s0)
    71ce:  87ba                 mv a5,a4
    71d0:  fcf42423           sw a5,-56(s0)
    71d4:  47c1                 li a5,16
    71d6:  fef42423           sw a5,-24(s0)
    71da:  048007b7           lui a5,0x4800
    71de:  5967879b           addiw a5,a5,1430
    71e2:  fef42223           sw a5,-28(s0)
    71e6:  040257b7           lui a5,0x4025
    71ea:  3007879b           addiw a5,a5,768
    71ee:  fef42023           sw a5,-32(s0)
    71f2:  040257b7           lui a5,0x4025
    71f6:  2007879b           addiw a5,a5,512
    71fa:  fcf42e23           sw a5,-36(s0)
    71fe:  fcc42703           lw a4,-52(s0)
    7202:  fc842783           lw a5,-56(s0)
    7206:  9fb9                 addw a5,a5,a4
    7208:  0007871b           sext.w a4,a5
    720c:  0003b7b7           lui a5,0x3b
    7210:  9807879b           addiw a5,a5,-1664
    7214:  9fb9                 addw a5,a5,a4
    7216:  fcf42c23           sw a5,-40(s0)
    721a:  040257b7           lui a5,0x4025
    721e:  03478793           addi a5,a5,52 # 4025034 <gpio_get_boot_device+0x4016c9e>
    7222:  fcc42703           lw a4,-52(s0)
    7226:  c398                 sw a4,0(a5)
    7228:  040257b7           lui a5,0x4025
    722c:  03078793           addi a5,a5,48 # 4025030 <gpio_get_boot_device+0x4016c9a>
    7230:  fcc42683           lw a3,-52(s0)
    7234:  fc842703           lw a4,-56(s0)
    7238:  9f35                 addw a4,a4,a3
    723a:  2701                 sext.w a4,a4
    723c:  c398                 sw a4,0(a5)
    723e:  040257b7           lui a5,0x4025
    7242:  03878793           addi a5,a5,56 # 4025038 <gpio_get_boot_device+0x4016ca2>
    7246:  fcc42703           lw a4,-52(s0)
    724a:  c398                 sw a4,0(a5)
    724c:  040257b7           lui a5,0x4025
    7250:  07e1                 addi a5,a5,24
    7252:  439c                 lw a5,0(a5)
    7254:  0007871b           sext.w a4,a5
    7258:  040257b7           lui a5,0x4025
    725c:  07e1                 addi a5,a5,24
    725e:  10076713           ori a4,a4,256
    7262:  2701                 sext.w a4,a4
    7264:  c398                 sw a4,0(a5)
    7266:  fc842703           lw a4,-56(s0)
    726a:  fe042603           lw a2,-32(s0)
    726e:  fe842583           lw a1,-24(s0)
    7272:  fe442783           lw a5,-28(s0)
    7276:  fb843683           ld a3,-72(s0)
    727a:  853e                 mv a0,a5
    727c:  1c1020ef           jal ra,9c3c <FUN_00009c3c>
    7280:  fe042623           sw zero,-20(s0)
    7284:  a00d                 j 72a6 <FUN_000071b6+0xf0>
    7286:  fec46783           lwu a5,-20(s0)
    728a:  fc043703           ld a4,-64(s0)
    728e:  97ba                 add a5,a5,a4
    7290:  fdc46703           lwu a4,-36(s0)
    7294:  0007c783           lbu a5,0(a5) # 4025000 <gpio_get_boot_device+0x4016c6a>
    7298:  00f70023           sb a5,0(a4) # ffffffffffff0000 <gpio_get_boot_device+0xf
    729c:  fec42783           lw a5,-20(s0)
    72a0:  2785                 addiw a5,a5,1
    72a2:  fef42623           sw a5,-20(s0)
    72a6:  fec42703           lw a4,-20(s0)
    72aa:  fcc42783           lw a5,-52(s0)
    72ae:  2701                 sext.w a4,a4
    72b0:  2781                 sext.w a5,a5
    72b2:  fcf76ae3           bltu a4,a5,7286 <FUN_000071b6+0xd0>
    72b6:  040257b7           lui a5,0x4025
    72ba:  07a1                 addi a5,a5,8
    72bc:  439c                 lw a5,0(a5)
    72be:  0007871b           sext.w a4,a5
    72c2:  040257b7           lui a5,0x4025
    72c6:  07a1                 addi a5,a5,8
    72c8:  86ba                 mv a3,a4
    72ca:  80000737           lui a4,0x80000
    72ce:  8f55                 or a4,a4,a3
    72d0:  2701                 sext.w a4,a4
    72d2:  c398                 sw a4,0(a5)
    72d4:  fd842783           lw a5,-40(s0)
    72d8:  853e                 mv a0,a5
    72da:  d9fff0ef           jal ra,7078 <FUN_00007078>
    72de:  87aa                 mv a5,a0
    72e0:  873e                 mv a4,a5
    72e2:  4789                 li a5,2
    72e4:  00f71e63           bne a4,a5,7300 <FUN_000071b6+0x14a>
    72e8:  249020ef           jal ra,9d30 <FUN_00009d30>
    72ec:  4615                 li a2,5
    72ee:  00eff7b7           lui a5,0xeff
    72f2:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    72f6:  450d                 li a0,3
    72f8:  130010ef           jal ra,8428 <rtc_brom_debug>
    72fc:  4789                 li a5,2
    72fe:  a0ad                 j 7368 <FUN_000071b6+0x1b2>
    7300:  fd842783           lw a5,-40(s0)
    7304:  853e                 mv a0,a5
    7306:  dd9ff0ef           jal ra,70de <FUN_000070de>
    730a:  87aa                 mv a5,a0
    730c:  873e                 mv a4,a5
    730e:  4789                 li a5,2
    7310:  00f71e63           bne a4,a5,732c <FUN_000071b6+0x176>
    7314:  21d020ef           jal ra,9d30 <FUN_00009d30>
    7318:  4619                 li a2,6
    731a:  00eff7b7           lui a5,0xeff
    731e:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    7322:  450d                 li a0,3
    7324:  104010ef           jal ra,8428 <rtc_brom_debug>
    7328:  4789                 li a5,2
    732a:  a83d                 j 7368 <FUN_000071b6+0x1b2>
    732c:  205020ef           jal ra,9d30 <FUN_00009d30>
    7330:  040257b7           lui a5,0x4025
    7334:  07d1                 addi a5,a5,20
    7336:  6705                 lui a4,0x1
    7338:  c398                 sw a4,0(a5)
    733a:  040257b7           lui a5,0x4025
    733e:  07d1                 addi a5,a5,20
    7340:  439c                 lw a5,0(a5)
    7342:  2781                 sext.w a5,a5
    7344:  873e                 mv a4,a5
    7346:  6785                 lui a5,0x1
    7348:  f0078793           addi a5,a5,-256 # f00 <sunxi_sha_calc+0x232>
    734c:  8ff9                 and a5,a5,a4
    734e:  2781                 sext.w a5,a5
    7350:  cb99                 beqz a5,7366 <FUN_000071b6+0x1b0>
    7352:  461d                 li a2,7
    7354:  00eff7b7           lui a5,0xeff
    7358:  80078593           addi a1,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    735c:  450d                 li a0,3
    735e:  0ca010ef           jal ra,8428 <rtc_brom_debug>
    7362:  4789                 li a5,2
    7364:  a011                 j 7368 <FUN_000071b6+0x1b2>
    7366:  4781                 li a5,0
    7368:  853e                 mv a0,a5
    736a:  60a6                 ld ra,72(sp)
    736c:  6406                 ld s0,64(sp)
    736e:  6161                 addi sp,sp,80
    7370:  8082                 ret
    7372:  7139                 addi sp,sp,-64
    7374:  fc06                 sd ra,56(sp)
    7376:  f822                 sd s0,48(sp)
    7378:  0080                 addi s0,sp,64
    737a:  87aa                 mv a5,a0
    737c:  fcb43023           sd a1,-64(s0)
    7380:  8732                 mv a4,a2
    7382:  fcf42623           sw a5,-52(s0)
    7386:  87ba                 mv a5,a4
    7388:  fcf42423           sw a5,-56(s0)
    738c:  fc043783           ld a5,-64(s0)
    7390:  fef43023           sd a5,-32(s0)
    7394:  fe042423           sw zero,-24(s0)
    7398:  fcc42783           lw a5,-52(s0)
    739c:  0087979b           slliw a5,a5,0x8
    73a0:  fef42623           sw a5,-20(s0)
    73a4:  fc842783           lw a5,-56(s0)
    73a8:  0087979b           slliw a5,a5,0x8
    73ac:  fcf42e23           sw a5,-36(s0)
    73b0:  a05d                 j 7456 <FUN_000071b6+0x2a0>
    73b2:  478d                 li a5,3
    73b4:  fcf40823           sb a5,-48(s0)
    73b8:  fec42783           lw a5,-20(s0)
    73bc:  0107d79b           srliw a5,a5,0x10
    73c0:  2781                 sext.w a5,a5
    73c2:  0ff7f793           andi a5,a5,255
    73c6:  fcf408a3           sb a5,-47(s0)
    73ca:  fec42783           lw a5,-20(s0)
    73ce:  0087d79b           srliw a5,a5,0x8
    73d2:  2781                 sext.w a5,a5
    73d4:  0ff7f793           andi a5,a5,255
    73d8:  fcf40923           sb a5,-46(s0)
    73dc:  fec42783           lw a5,-20(s0)
    73e0:  0ff7f793           andi a5,a5,255
    73e4:  fcf409a3           sb a5,-45(s0)
    73e8:  fdc42703           lw a4,-36(s0)
    73ec:  fe842783           lw a5,-24(s0)
    73f0:  40f707bb           subw a5,a4,a5
    73f4:  2781                 sext.w a5,a5
    73f6:  0007869b           sext.w a3,a5
    73fa:  6705                 lui a4,0x1
    73fc:  80070713           addi a4,a4,-2048 # 800 <FUN_00000660+0x1a0>
    7400:  00d77563           bgeu a4,a3,740a <FUN_000071b6+0x254>
    7404:  6785                 lui a5,0x1
    7406:  8007879b           addiw a5,a5,-2048
    740a:  fcf42c23           sw a5,-40(s0)
    740e:  fe846703           lwu a4,-24(s0)
    7412:  fe043783           ld a5,-32(s0)
    7416:  97ba                 add a5,a5,a4
    7418:  86be                 mv a3,a5
    741a:  fd040713           addi a4,s0,-48
    741e:  fd842783           lw a5,-40(s0)
    7422:  863a                 mv a2,a4
    7424:  85be                 mv a1,a5
    7426:  4511                 li a0,4
    7428:  d8fff0ef           jal ra,71b6 <FUN_000071b6>
    742c:  87aa                 mv a5,a0
    742e:  873e                 mv a4,a5
    7430:  4789                 li a5,2
    7432:  00f71463           bne a4,a5,743a <FUN_000071b6+0x284>
    7436:  4789                 li a5,2
    7438:  a805                 j 7468 <FUN_000071b6+0x2b2>
    743a:  fec42703           lw a4,-20(s0)
    743e:  fd842783           lw a5,-40(s0)
    7442:  9fb9                 addw a5,a5,a4
    7444:  fef42623           sw a5,-20(s0)
    7448:  fe842703           lw a4,-24(s0)
    744c:  fd842783           lw a5,-40(s0)
    7450:  9fb9                 addw a5,a5,a4
    7452:  fef42423           sw a5,-24(s0)
    7456:  fe842703           lw a4,-24(s0)
    745a:  fdc42783           lw a5,-36(s0)
    745e:  2701                 sext.w a4,a4
    7460:  2781                 sext.w a5,a5
    7462:  f4f768e3           bltu a4,a5,73b2 <FUN_000071b6+0x1fc>
    7466:  4781                 li a5,0
    7468:  853e                 mv a0,a5
    746a:  70e2                 ld ra,56(sp)
    746c:  7442                 ld s0,48(sp)
    746e:  6121                 addi sp,sp,64
    7470:  8082                 ret
    7472:  7139                 addi sp,sp,-64
    7474:  fc06                 sd ra,56(sp)
    7476:  f822                 sd s0,48(sp)
    7478:  0080                 addi s0,sp,64
    747a:  87aa                 mv a5,a0
    747c:  fcb43023           sd a1,-64(s0)
    7480:  8732                 mv a4,a2
    7482:  fcf42623           sw a5,-52(s0)
    7486:  87ba                 mv a5,a4
    7488:  fcf42423           sw a5,-56(s0)
    748c:  fc043783           ld a5,-64(s0)
    7490:  fcf43c23           sd a5,-40(s0)
    7494:  fd040793           addi a5,s0,-48
    7498:  0791                 addi a5,a5,4
    749a:  0007a023           sw zero,0(a5) # 1000 <FUN_00000f2c+0xd4>
    749e:  fe042623           sw zero,-20(s0)
    74a2:  fe042223           sw zero,-28(s0)
    74a6:  fcc42783           lw a5,-52(s0)
    74aa:  0097979b           slliw a5,a5,0x9
    74ae:  fef42423           sw a5,-24(s0)
    74b2:  a059                 j 7538 <FUN_000071b6+0x382>
    74b4:  57a1                 li a5,-24
    74b6:  fcf40823           sb a5,-48(s0)
    74ba:  fe842783           lw a5,-24(s0)
    74be:  0107d79b           srliw a5,a5,0x10
    74c2:  2781                 sext.w a5,a5
    74c4:  0ff7f793           andi a5,a5,255
    74c8:  fcf408a3           sb a5,-47(s0)
    74cc:  fe842783           lw a5,-24(s0)
    74d0:  0087d79b           srliw a5,a5,0x8
    74d4:  2781                 sext.w a5,a5
    74d6:  0ff7f793           andi a5,a5,255
    74da:  fcf40923           sb a5,-46(s0)
    74de:  fe842783           lw a5,-24(s0)
    74e2:  0ff7f793           andi a5,a5,255
    74e6:  fcf409a3           sb a5,-45(s0)
    74ea:  fe446703           lwu a4,-28(s0)
    74ee:  fd843783           ld a5,-40(s0)
    74f2:  97ba                 add a5,a5,a4
    74f4:  873e                 mv a4,a5
    74f6:  fd040793           addi a5,s0,-48
    74fa:  86ba                 mv a3,a4
    74fc:  863e                 mv a2,a5
    74fe:  10000593           li a1,256
    7502:  4521                 li a0,8
    7504:  cb3ff0ef           jal ra,71b6 <FUN_000071b6>
    7508:  87aa                 mv a5,a0
    750a:  873e                 mv a4,a5
    750c:  4789                 li a5,2
    750e:  00f71463           bne a4,a5,7516 <FUN_000071b6+0x360>
    7512:  4789                 li a5,2
    7514:  a81d                 j 754a <FUN_000071b6+0x394>
    7516:  fec42783           lw a5,-20(s0)
    751a:  2785                 addiw a5,a5,1
    751c:  fef42623           sw a5,-20(s0)
    7520:  fe442783           lw a5,-28(s0)
    7524:  1007879b           addiw a5,a5,256
    7528:  fef42223           sw a5,-28(s0)
    752c:  fe842783           lw a5,-24(s0)
    7530:  2007879b           addiw a5,a5,512
    7534:  fef42423           sw a5,-24(s0)
    7538:  fec42703           lw a4,-20(s0)
    753c:  fc842783           lw a5,-56(s0)
    7540:  2701                 sext.w a4,a4
    7542:  2781                 sext.w a5,a5
    7544:  f6f768e3           bltu a4,a5,74b4 <FUN_000071b6+0x2fe>
    7548:  4781                 li a5,0
    754a:  853e                 mv a0,a5
    754c:  70e2                 ld ra,56(sp)
    754e:  7442                 ld s0,48(sp)
    7550:  6121                 addi sp,sp,64
    7552:  8082                 ret
0000000000007554 <FUN_00007554>:
    7554:  7179                 addi sp,sp,-48
    7556:  f422                 sd s0,40(sp)
    7558:  1800                 addi s0,sp,48
    755a:  87aa                 mv a5,a0
    755c:  fcf42e23           sw a5,-36(s0)
    7560:  000077b7           lui a5,0x7
    7564:  37278793           addi a5,a5,882 # 7372 <FUN_000071b6+0x1bc>
    7568:  fef43023           sd a5,-32(s0)
    756c:  000077b7           lui a5,0x7
    7570:  47278793           addi a5,a5,1138 # 7472 <FUN_000071b6+0x2bc>
    7574:  fef43423           sd a5,-24(s0)
    7578:  fdc46783           lwu a5,-36(s0)
    757c:  078e                 slli a5,a5,0x3
    757e:  ff040713           addi a4,s0,-16
    7582:  97ba                 add a5,a5,a4
    7584:  ff07b783           ld a5,-16(a5)
    7588:  853e                 mv a0,a5
    758a:  7422                 ld s0,40(sp)
    758c:  6145                 addi sp,sp,48
    758e:  8082                 ret
0000000000007590 <FUN_00007590>:
    7590:  7179                 addi sp,sp,-48
    7592:  f406                 sd ra,40(sp)
    7594:  f022                 sd s0,32(sp)
    7596:  1800                 addi s0,sp,48
    7598:  87aa                 mv a5,a0
    759a:  fcb43823           sd a1,-48(s0)
    759e:  fcf42e23           sw a5,-36(s0)
    75a2:  040257b7           lui a5,0x4025
    75a6:  2007879b           addiw a5,a5,512
    75aa:  fef42423           sw a5,-24(s0)
    75ae:  040257b7           lui a5,0x4025
    75b2:  03478793           addi a5,a5,52 # 4025034 <gpio_get_boot_device+0x4016c9e>
    75b6:  fdc42703           lw a4,-36(s0)
    75ba:  c398                 sw a4,0(a5)
    75bc:  040257b7           lui a5,0x4025
    75c0:  03078793           addi a5,a5,48 # 4025030 <gpio_get_boot_device+0x4016c9a>
    75c4:  fdc42703           lw a4,-36(s0)
    75c8:  c398                 sw a4,0(a5)
    75ca:  040257b7           lui a5,0x4025
    75ce:  03878793           addi a5,a5,56 # 4025038 <gpio_get_boot_device+0x4016ca2>
    75d2:  fdc42703           lw a4,-36(s0)
    75d6:  c398                 sw a4,0(a5)
    75d8:  fdc42703           lw a4,-36(s0)
    75dc:  0003b7b7           lui a5,0x3b
    75e0:  9807879b           addiw a5,a5,-1664
    75e4:  9fb9                 addw a5,a5,a4
    75e6:  fef42223           sw a5,-28(s0)
    75ea:  fe042623           sw zero,-20(s0)
    75ee:  a00d                 j 7610 <FUN_00007590+0x80>
    75f0:  fec46783           lwu a5,-20(s0)
    75f4:  fd043703           ld a4,-48(s0)
    75f8:  97ba                 add a5,a5,a4
    75fa:  fe846703           lwu a4,-24(s0)
    75fe:  0007c783           lbu a5,0(a5) # 3b000 <gpio_get_boot_device+0x2cc6a>
    7602:  00f70023           sb a5,0(a4)
    7606:  fec42783           lw a5,-20(s0)
    760a:  2785                 addiw a5,a5,1
    760c:  fef42623           sw a5,-20(s0)
    7610:  fec42703           lw a4,-20(s0)
    7614:  fdc42783           lw a5,-36(s0)
    7618:  2701                 sext.w a4,a4
    761a:  2781                 sext.w a5,a5
    761c:  fcf76ae3           bltu a4,a5,75f0 <FUN_00007590+0x60>
    7620:  040257b7           lui a5,0x4025
    7624:  07a1                 addi a5,a5,8
    7626:  439c                 lw a5,0(a5)
    7628:  0007871b           sext.w a4,a5
    762c:  040257b7           lui a5,0x4025
    7630:  07a1                 addi a5,a5,8
    7632:  86ba                 mv a3,a4
    7634:  80000737           lui a4,0x80000
    7638:  8f55                 or a4,a4,a3
    763a:  2701                 sext.w a4,a4
    763c:  c398                 sw a4,0(a5)
    763e:  fe442783           lw a5,-28(s0)
    7642:  853e                 mv a0,a5
    7644:  a9bff0ef           jal ra,70de <FUN_000070de>
    7648:  87aa                 mv a5,a0
    764a:  873e                 mv a4,a5
    764c:  4789                 li a5,2
    764e:  00f71463           bne a4,a5,7656 <FUN_00007590+0xc6>
    7652:  4789                 li a5,2
    7654:  a02d                 j 767e <FUN_00007590+0xee>
    7656:  040257b7           lui a5,0x4025
    765a:  07d1                 addi a5,a5,20
    765c:  6705                 lui a4,0x1
    765e:  c398                 sw a4,0(a5)
    7660:  040257b7           lui a5,0x4025
    7664:  07d1                 addi a5,a5,20
    7666:  439c                 lw a5,0(a5)
    7668:  2781                 sext.w a5,a5
    766a:  873e                 mv a4,a5
    766c:  6785                 lui a5,0x1
    766e:  f0078793           addi a5,a5,-256 # f00 <sunxi_sha_calc+0x232>
    7672:  8ff9                 and a5,a5,a4
    7674:  2781                 sext.w a5,a5
    7676:  c399                 beqz a5,767c <FUN_00007590+0xec>
    7678:  4789                 li a5,2
    767a:  a011                 j 767e <FUN_00007590+0xee>
    767c:  4781                 li a5,0
    767e:  853e                 mv a0,a5
    7680:  70a2                 ld ra,40(sp)
    7682:  7402                 ld s0,32(sp)
    7684:  6145                 addi sp,sp,48
    7686:  8082                 ret
0000000000007688 <FUN_00007688>:
    7688:  1101                 addi sp,sp,-32
    768a:  ec06                 sd ra,24(sp)
    768c:  e822                 sd s0,16(sp)
    768e:  1000                 addi s0,sp,32
    7690:  57fd                 li a5,-1
    7692:  fef407a3           sb a5,-17(s0)
    7696:  fef40793           addi a5,s0,-17
    769a:  85be                 mv a1,a5
    769c:  4505                 li a0,1
    769e:  ef3ff0ef           jal ra,7590 <FUN_00007590>
    76a2:  87aa                 mv a5,a0
    76a4:  873e                 mv a4,a5
    76a6:  4789                 li a5,2
    76a8:  00f71463           bne a4,a5,76b0 <FUN_00007688+0x28>
    76ac:  4789                 li a5,2
    76ae:  a029                 j 76b8 <FUN_00007688+0x30>
    76b0:  4505                 li a0,1
    76b2:  2fd020ef           jal ra,a1ae <udelay_x800>
    76b6:  4781                 li a5,0
    76b8:  853e                 mv a0,a5
    76ba:  60e2                 ld ra,24(sp)
    76bc:  6442                 ld s0,16(sp)
    76be:  6105                 addi sp,sp,32
    76c0:  8082                 ret
00000000000076c2 <FUN_000076c2>:
    76c2:  7119                 addi sp,sp,-128
    76c4:  fc86                 sd ra,120(sp)
    76c6:  f8a2                 sd s0,112(sp)
    76c8:  0100                 addi s0,sp,128
    76ca:  88aa                 mv a7,a0
    76cc:  f8b43823           sd a1,-112(s0)
    76d0:  8532                 mv a0,a2
    76d2:  85b6                 mv a1,a3
    76d4:  863a                 mv a2,a4
    76d6:  86be                 mv a3,a5
    76d8:  8742                 mv a4,a6
    76da:  87c6                 mv a5,a7
    76dc:  f8f42e23           sw a5,-100(s0)
    76e0:  87aa                 mv a5,a0
    76e2:  f8f42c23           sw a5,-104(s0)
    76e6:  87ae                 mv a5,a1
    76e8:  f8f42623           sw a5,-116(s0)
    76ec:  87b2                 mv a5,a2
    76ee:  f8f42423           sw a5,-120(s0)
    76f2:  87b6                 mv a5,a3
    76f4:  f8f42223           sw a5,-124(s0)
    76f8:  87ba                 mv a5,a4
    76fa:  f8f42023           sw a5,-128(s0)
    76fe:  fe042223           sw zero,-28(s0)
    7702:  f9043783           ld a5,-112(s0)
    7706:  fcf43c23           sd a5,-40(s0)
    770a:  fa0407a3           sb zero,-81(s0)
    770e:  fc043823           sd zero,-48(s0)
    7712:  fc043423           sd zero,-56(s0)
    7716:  fc043023           sd zero,-64(s0)
    771a:  f9c42783           lw a5,-100(s0)
    771e:  fef42423           sw a5,-24(s0)
    7722:  aa4d                 j 78d4 <FUN_000076c2+0x212>
    7724:  47cd                 li a5,19
    7726:  faf40c23           sb a5,-72(s0)
    772a:  fe842783           lw a5,-24(s0)
    772e:  0107d79b           srliw a5,a5,0x10
    7732:  2781                 sext.w a5,a5
    7734:  0ff7f793           andi a5,a5,255
    7738:  faf40ca3           sb a5,-71(s0)
    773c:  fe842783           lw a5,-24(s0)
    7740:  0087d79b           srliw a5,a5,0x8
    7744:  2781                 sext.w a5,a5
    7746:  0ff7f793           andi a5,a5,255
    774a:  faf40d23           sb a5,-70(s0)
    774e:  fe842783           lw a5,-24(s0)
    7752:  0ff7f793           andi a5,a5,255
    7756:  faf40da3           sb a5,-69(s0)
    775a:  fb840793           addi a5,s0,-72
    775e:  85be                 mv a1,a5
    7760:  4511                 li a0,4
    7762:  e2fff0ef           jal ra,7590 <FUN_00007590>
    7766:  87aa                 mv a5,a0
    7768:  873e                 mv a4,a5
    776a:  4789                 li a5,2
    776c:  00f71663           bne a4,a5,7778 <FUN_000076c2+0xb6>
    7770:  4789                 li a5,2
    7772:  fef42223           sw a5,-28(s0)
    7776:  aaa5                 j 78ee <FUN_000076c2+0x22c>
    7778:  47bd                 li a5,15
    777a:  faf40823           sb a5,-80(s0)
    777e:  fc000793           li a5,-64
    7782:  faf408a3           sb a5,-79(s0)
    7786:  67b1                 lui a5,0xc
    7788:  b8078793           addi a5,a5,-1152 # bb80 <FUN_0000bb76+0xa>
    778c:  fcf43023           sd a5,-64(s0)
    7790:  1ef020ef           jal ra,a17e <rdtime>
    7794:  fca43823           sd a0,-48(s0)
    7798:  1e7020ef           jal ra,a17e <rdtime>
    779c:  872a                 mv a4,a0
    779e:  fd043783           ld a5,-48(s0)
    77a2:  40f707b3           sub a5,a4,a5
    77a6:  fcf43423           sd a5,-56(s0)
    77aa:  faf40713           addi a4,s0,-81
    77ae:  fb040793           addi a5,s0,-80
    77b2:  86ba                 mv a3,a4
    77b4:  863e                 mv a2,a5
    77b6:  4585                 li a1,1
    77b8:  4509                 li a0,2
    77ba:  9fdff0ef           jal ra,71b6 <FUN_000071b6>
    77be:  87aa                 mv a5,a0
    77c0:  873e                 mv a4,a5
    77c2:  4789                 li a5,2
    77c4:  00f71663           bne a4,a5,77d0 <FUN_000076c2+0x10e>
    77c8:  4789                 li a5,2
    77ca:  fef42223           sw a5,-28(s0)
    77ce:  a205                 j 78ee <FUN_000076c2+0x22c>
    77d0:  faf44783           lbu a5,-81(s0)
    77d4:  8b85                 andi a5,a5,1
    77d6:  0ff7f793           andi a5,a5,255
    77da:  faf407a3           sb a5,-81(s0)
    77de:  faf44783           lbu a5,-81(s0)
    77e2:  cb81                 beqz a5,77f2 <FUN_000076c2+0x130>
    77e4:  fc843703           ld a4,-56(s0)
    77e8:  fc043783           ld a5,-64(s0)
    77ec:  faf766e3           bltu a4,a5,7798 <FUN_000076c2+0xd6>
    77f0:  a011                 j 77f4 <FUN_000076c2+0x132>
    77f2:  0001                 nop
    77f4:  fc843703           ld a4,-56(s0)
    77f8:  fc043783           ld a5,-64(s0)
    77fc:  00f76c63           bltu a4,a5,7814 <FUN_000076c2+0x152>
    7800:  faf44783           lbu a5,-81(s0)
    7804:  2781                 sext.w a5,a5
    7806:  8b85                 andi a5,a5,1
    7808:  2781                 sext.w a5,a5
    780a:  c789                 beqz a5,7814 <FUN_000076c2+0x152>
    780c:  4789                 li a5,2
    780e:  fef42223           sw a5,-28(s0)
    7812:  a8f1                 j 78ee <FUN_000076c2+0x22c>
    7814:  47ad                 li a5,11
    7816:  faf40c23           sb a5,-72(s0)
    781a:  f8442783           lw a5,-124(s0)
    781e:  0007871b           sext.w a4,a5
    7822:  4785                 li a5,1
    7824:  02f71063           bne a4,a5,7844 <FUN_000076c2+0x182>
    7828:  fe842703           lw a4,-24(s0)
    782c:  f8042783           lw a5,-128(s0)
    7830:  02f757bb           divuw a5,a4,a5
    7834:  2781                 sext.w a5,a5
    7836:  8b85                 andi a5,a5,1
    7838:  2781                 sext.w a5,a5
    783a:  c789                 beqz a5,7844 <FUN_000076c2+0x182>
    783c:  47c1                 li a5,16
    783e:  faf40ca3           sb a5,-71(s0)
    7842:  a019                 j 7848 <FUN_000076c2+0x186>
    7844:  fa040ca3           sb zero,-71(s0)
    7848:  fa040d23           sb zero,-70(s0)
    784c:  fa040da3           sb zero,-69(s0)
    7850:  4791                 li a5,4
    7852:  fef407a3           sb a5,-17(s0)
    7856:  f8c42783           lw a5,-116(s0)
    785a:  0007871b           sext.w a4,a5
    785e:  4785                 li a5,1
    7860:  00f71d63           bne a4,a5,787a <FUN_000076c2+0x1b8>
    7864:  fa040ca3           sb zero,-71(s0)
    7868:  fa040d23           sb zero,-70(s0)
    786c:  fa040da3           sb zero,-69(s0)
    7870:  fa040e23           sb zero,-68(s0)
    7874:  4795                 li a5,5
    7876:  fef407a3           sb a5,-17(s0)
    787a:  fef44783           lbu a5,-17(s0)
    787e:  0007851b           sext.w a0,a5
    7882:  fe842703           lw a4,-24(s0)
    7886:  f9c42783           lw a5,-100(s0)
    788a:  40f707bb           subw a5,a4,a5
    788e:  2781                 sext.w a5,a5
    7890:  f8842703           lw a4,-120(s0)
    7894:  02f707bb           mulw a5,a4,a5
    7898:  2781                 sext.w a5,a5
    789a:  02079713           slli a4,a5,0x20
    789e:  9301                 srli a4,a4,0x20
    78a0:  fd843783           ld a5,-40(s0)
    78a4:  97ba                 add a5,a5,a4
    78a6:  86be                 mv a3,a5
    78a8:  fb840713           addi a4,s0,-72
    78ac:  f8842783           lw a5,-120(s0)
    78b0:  863a                 mv a2,a4
    78b2:  85be                 mv a1,a5
    78b4:  903ff0ef           jal ra,71b6 <FUN_000071b6>
    78b8:  87aa                 mv a5,a0
    78ba:  873e                 mv a4,a5
    78bc:  4789                 li a5,2
    78be:  00f71663           bne a4,a5,78ca <FUN_000076c2+0x208>
    78c2:  4789                 li a5,2
    78c4:  fef42223           sw a5,-28(s0)
    78c8:  a01d                 j 78ee <FUN_000076c2+0x22c>
    78ca:  fe842783           lw a5,-24(s0)
    78ce:  2785                 addiw a5,a5,1
    78d0:  fef42423           sw a5,-24(s0)
    78d4:  f9c42703           lw a4,-100(s0)
    78d8:  f9842783           lw a5,-104(s0)
    78dc:  9fb9                 addw a5,a5,a4
    78de:  0007871b           sext.w a4,a5
    78e2:  fe842783           lw a5,-24(s0)
    78e6:  2781                 sext.w a5,a5
    78e8:  e2e7eee3           bltu a5,a4,7724 <FUN_000076c2+0x62>
    78ec:  0001                 nop
    78ee:  fe442783           lw a5,-28(s0)
    78f2:  853e                 mv a0,a5
    78f4:  70e6                 ld ra,120(sp)
    78f6:  7446                 ld s0,112(sp)
    78f8:  6109                 addi sp,sp,128
    78fa:  8082                 ret
00000000000078fc <FUN_000078fc>:
    78fc:  1141                 addi sp,sp,-16
    78fe:  e406                 sd ra,8(sp)
    7900:  e022                 sd s0,0(sp)
    7902:  0800                 addi s0,sp,16
    7904:  abcff0ef           jal ra,6bc0 <FUN_00006bc0>
    7908:  a6cff0ef           jal ra,6b74 <FUN_00006b74>
    790c:  0001                 nop
    790e:  60a2                 ld ra,8(sp)
    7910:  6402                 ld s0,0(sp)
    7912:  0141                 addi sp,sp,16
    7914:  8082                 ret
0000000000007916 <FUN_00007916>:
    7916:  7139                 addi sp,sp,-64
    7918:  fc06                 sd ra,56(sp)
    791a:  f822                 sd s0,48(sp)
    791c:  0080                 addi s0,sp,64
    791e:  87aa                 mv a5,a0
    7920:  fcf42623           sw a5,-52(s0)
    7924:  fe043023           sd zero,-32(s0)
    7928:  fc043c23           sd zero,-40(s0)
    792c:  fcc42783           lw a5,-52(s0)
    7930:  853e                 mv a0,a5
    7932:  daaff0ef           jal ra,6edc <FUN_00006edc>
    7936:  64a000ef           jal ra,7f80 <brom_config_bit_13>
    793a:  87aa                 mv a5,a0
    793c:  e399                 bnez a5,7942 <FUN_00007916+0x2c>
    793e:  fbfff0ef           jal ra,78fc <FUN_000078fc>
    7942:  fe042623           sw zero,-20(s0)
    7946:  aa85                 j 7ab6 <FUN_00007916+0x1a0>
    7948:  fec42783           lw a5,-20(s0)
    794c:  853e                 mv a0,a5
    794e:  c07ff0ef           jal ra,7554 <FUN_00007554>
    7952:  fca43823           sd a0,-48(s0)
    7956:  fd043783           ld a5,-48(s0)
    795a:  4605                 li a2,1
    795c:  000205b7           lui a1,0x20
    7960:  4501                 li a0,0
    7962:  9782                 jalr a5
    7964:  87aa                 mv a5,a0
    7966:  873e                 mv a4,a5
    7968:  4789                 li a5,2
    796a:  00f71963           bne a4,a5,797c <FUN_00007916+0x66>
    796e:  0f000613           li a2,240
    7972:  4581                 li a1,0
    7974:  450d                 li a0,3
    7976:  2b3000ef           jal ra,8428 <rtc_brom_debug>
    797a:  aa0d                 j 7aac <FUN_00007916+0x196>
    797c:  000487b7           lui a5,0x48
    7980:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7984:  cba1                 beqz a5,79d4 <FUN_00007916+0xbe>
    7986:  67b9                 lui a5,0xe
    7988:  51078593           addi a1,a5,1296 # e510 <gpio_get_boot_device+0x17a>
    798c:  00020537           lui a0,0x20
    7990:  483000ef           jal ra,8612 <boot0_check_magic>
    7994:  87aa                 mv a5,a0
    7996:  cb81                 beqz a5,79a6 <FUN_00007916+0x90>
    7998:  0f100613           li a2,241
    799c:  4581                 li a1,0
    799e:  450d                 li a0,3
    79a0:  289000ef           jal ra,8428 <rtc_brom_debug>
    79a4:  a221                 j 7aac <FUN_00007916+0x196>
    79a6:  000207b7           lui a5,0x20
    79aa:  fcf43c23           sd a5,-40(s0)
    79ae:  fd843783           ld a5,-40(s0)
    79b2:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    79b6:  01d7c683           lbu a3,29(a5)
    79ba:  06a2                 slli a3,a3,0x8
    79bc:  8f55                 or a4,a4,a3
    79be:  01e7c683           lbu a3,30(a5)
    79c2:  06c2                 slli a3,a3,0x10
    79c4:  8f55                 or a4,a4,a3
    79c6:  01f7c783           lbu a5,31(a5)
    79ca:  07e2                 slli a5,a5,0x18
    79cc:  8fd9                 or a5,a5,a4
    79ce:  fef42423           sw a5,-24(s0)
    79d2:  a815                 j 7a06 <FUN_00007916+0xf0>
    79d4:  67b9                 lui a5,0xe
    79d6:  52078593           addi a1,a5,1312 # e520 <gpio_get_boot_device+0x18a>
    79da:  00020537           lui a0,0x20
    79de:  435000ef           jal ra,8612 <boot0_check_magic>
    79e2:  87aa                 mv a5,a0
    79e4:  cb81                 beqz a5,79f4 <FUN_00007916+0xde>
    79e6:  0f100613           li a2,241
    79ea:  4581                 li a1,0
    79ec:  450d                 li a0,3
    79ee:  23b000ef           jal ra,8428 <rtc_brom_debug>
    79f2:  a86d                 j 7aac <FUN_00007916+0x196>
    79f4:  000207b7           lui a5,0x20
    79f8:  fef43023           sd a5,-32(s0)
    79fc:  fe043783           ld a5,-32(s0)
    7a00:  4b9c                 lw a5,16(a5)
    7a02:  fef42423           sw a5,-24(s0)
    7a06:  fe842783           lw a5,-24(s0)
    7a0a:  1ff7f793           andi a5,a5,511
    7a0e:  2781                 sext.w a5,a5
    7a10:  cb81                 beqz a5,7a20 <FUN_00007916+0x10a>
    7a12:  0f200613           li a2,242
    7a16:  4581                 li a1,0
    7a18:  450d                 li a0,3
    7a1a:  20f000ef           jal ra,8428 <rtc_brom_debug>
    7a1e:  a079                 j 7aac <FUN_00007916+0x196>
    7a20:  fe842783           lw a5,-24(s0)
    7a24:  0087d79b           srliw a5,a5,0x8
    7a28:  2781                 sext.w a5,a5
    7a2a:  fd043703           ld a4,-48(s0)
    7a2e:  863e                 mv a2,a5
    7a30:  000205b7           lui a1,0x20
    7a34:  4501                 li a0,0
    7a36:  9702                 jalr a4
    7a38:  87aa                 mv a5,a0
    7a3a:  873e                 mv a4,a5
    7a3c:  4789                 li a5,2
    7a3e:  00f71963           bne a4,a5,7a50 <FUN_00007916+0x13a>
    7a42:  0f300613           li a2,243
    7a46:  4581                 li a1,0
    7a48:  450d                 li a0,3
    7a4a:  1df000ef           jal ra,8428 <rtc_brom_debug>
    7a4e:  a8b9                 j 7aac <FUN_00007916+0x196>
    7a50:  fe842783           lw a5,-24(s0)
    7a54:  85be                 mv a1,a5
    7a56:  00020537           lui a0,0x20
    7a5a:  45d000ef           jal ra,86b6 <FUN_000086b6>
    7a5e:  87aa                 mv a5,a0
    7a60:  e3a1                 bnez a5,7aa0 <FUN_00007916+0x18a>
    7a62:  000487b7           lui a5,0x48
    7a66:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7a6a:  c799                 beqz a5,7a78 <FUN_00007916+0x162>
    7a6c:  fd843783           ld a5,-40(s0)
    7a70:  470d                 li a4,3
    7a72:  02e78023           sb a4,32(a5)
    7a76:  a031                 j 7a82 <FUN_00007916+0x16c>
    7a78:  fe043783           ld a5,-32(s0)
    7a7c:  470d                 li a4,3
    7a7e:  02e78423           sb a4,40(a5)
    7a82:  4581                 li a1,0
    7a84:  450d                 li a0,3
    7a86:  7e7010ef           jal ra,9a6c <FUN_00009a6c>
    7a8a:  6785                 lui a5,0x1
    7a8c:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    7a90:  4581                 li a1,0
    7a92:  450d                 li a0,3
    7a94:  195000ef           jal ra,8428 <rtc_brom_debug>
    7a98:  d38ff0ef           jal ra,6fd0 <FUN_00006fd0>
    7a9c:  4781                 li a5,0
    7a9e:  a035                 j 7aca <FUN_00007916+0x1b4>
    7aa0:  0f400613           li a2,244
    7aa4:  4581                 li a1,0
    7aa6:  450d                 li a0,3
    7aa8:  181000ef           jal ra,8428 <rtc_brom_debug>
    7aac:  fec42783           lw a5,-20(s0)
    7ab0:  2785                 addiw a5,a5,1
    7ab2:  fef42623           sw a5,-20(s0)
    7ab6:  fec42783           lw a5,-20(s0)
    7aba:  0007871b           sext.w a4,a5
    7abe:  4785                 li a5,1
    7ac0:  e8e7f4e3           bgeu a5,a4,7948 <FUN_00007916+0x32>
    7ac4:  d0cff0ef           jal ra,6fd0 <FUN_00006fd0>
    7ac8:  57fd                 li a5,-1
    7aca:  853e                 mv a0,a5
    7acc:  70e2                 ld ra,56(sp)
    7ace:  7442                 ld s0,48(sp)
    7ad0:  6121                 addi sp,sp,64
    7ad2:  8082                 ret
0000000000007ad4 <FUN_00007ad4>:
    7ad4:  715d                 addi sp,sp,-80
    7ad6:  e486                 sd ra,72(sp)
    7ad8:  e0a2                 sd s0,64(sp)
    7ada:  0880                 addi s0,sp,80
    7adc:  87aa                 mv a5,a0
    7ade:  faf42e23           sw a5,-68(s0)
    7ae2:  fe042223           sw zero,-28(s0)
    7ae6:  fc043c23           sd zero,-40(s0)
    7aea:  fc043823           sd zero,-48(s0)
    7aee:  fbc42783           lw a5,-68(s0)
    7af2:  853e                 mv a0,a5
    7af4:  be8ff0ef           jal ra,6edc <FUN_00006edc>
    7af8:  488000ef           jal ra,7f80 <brom_config_bit_13>
    7afc:  87aa                 mv a5,a0
    7afe:  e399                 bnez a5,7b04 <FUN_00007ad4+0x30>
    7b00:  dfdff0ef           jal ra,78fc <FUN_000078fc>
    7b04:  fe042623           sw zero,-20(s0)
    7b08:  aadd                 j 7cfe <FUN_00007ad4+0x22a>
    7b0a:  fec42783           lw a5,-20(s0)
    7b0e:  853e                 mv a0,a5
    7b10:  a45ff0ef           jal ra,7554 <FUN_00007554>
    7b14:  fca43423           sd a0,-56(s0)
    7b18:  4785                 li a5,1
    7b1a:  fef42223           sw a5,-28(s0)
    7b1e:  10000793           li a5,256
    7b22:  fef42023           sw a5,-32(s0)
    7b26:  a2c1                 j 7ce6 <FUN_00007ad4+0x212>
    7b28:  fe042783           lw a5,-32(s0)
    7b2c:  fc843703           ld a4,-56(s0)
    7b30:  4605                 li a2,1
    7b32:  000205b7           lui a1,0x20
    7b36:  853e                 mv a0,a5
    7b38:  9702                 jalr a4
    7b3a:  87aa                 mv a5,a0
    7b3c:  873e                 mv a4,a5
    7b3e:  4789                 li a5,2
    7b40:  00f71b63           bne a4,a5,7b56 <FUN_00007ad4+0x82>
    7b44:  fe442783           lw a5,-28(s0)
    7b48:  0f000613           li a2,240
    7b4c:  85be                 mv a1,a5
    7b4e:  450d                 li a0,3
    7b50:  0d9000ef           jal ra,8428 <rtc_brom_debug>
    7b54:  aab5                 j 7cd0 <FUN_00007ad4+0x1fc>
    7b56:  000487b7           lui a5,0x48
    7b5a:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7b5e:  cbb1                 beqz a5,7bb2 <FUN_00007ad4+0xde>
    7b60:  67b9                 lui a5,0xe
    7b62:  51078593           addi a1,a5,1296 # e510 <gpio_get_boot_device+0x17a>
    7b66:  00020537           lui a0,0x20
    7b6a:  2a9000ef           jal ra,8612 <boot0_check_magic>
    7b6e:  87aa                 mv a5,a0
    7b70:  cb91                 beqz a5,7b84 <FUN_00007ad4+0xb0>
    7b72:  fe442783           lw a5,-28(s0)
    7b76:  0f100613           li a2,241
    7b7a:  85be                 mv a1,a5
    7b7c:  450d                 li a0,3
    7b7e:  0ab000ef           jal ra,8428 <rtc_brom_debug>
    7b82:  a2b9                 j 7cd0 <FUN_00007ad4+0x1fc>
    7b84:  000207b7           lui a5,0x20
    7b88:  fcf43823           sd a5,-48(s0)
    7b8c:  fd043783           ld a5,-48(s0)
    7b90:  01c7c703           lbu a4,28(a5) # 2001c <gpio_get_boot_device+0x11c86>
    7b94:  01d7c683           lbu a3,29(a5)
    7b98:  06a2                 slli a3,a3,0x8
    7b9a:  8f55                 or a4,a4,a3
    7b9c:  01e7c683           lbu a3,30(a5)
    7ba0:  06c2                 slli a3,a3,0x10
    7ba2:  8f55                 or a4,a4,a3
    7ba4:  01f7c783           lbu a5,31(a5)
    7ba8:  07e2                 slli a5,a5,0x18
    7baa:  8fd9                 or a5,a5,a4
    7bac:  fef42423           sw a5,-24(s0)
    7bb0:  a825                 j 7be8 <FUN_00007ad4+0x114>
    7bb2:  67b9                 lui a5,0xe
    7bb4:  52078593           addi a1,a5,1312 # e520 <gpio_get_boot_device+0x18a>
    7bb8:  00020537           lui a0,0x20
    7bbc:  257000ef           jal ra,8612 <boot0_check_magic>
    7bc0:  87aa                 mv a5,a0
    7bc2:  cb91                 beqz a5,7bd6 <FUN_00007ad4+0x102>
    7bc4:  fe442783           lw a5,-28(s0)
    7bc8:  0f100613           li a2,241
    7bcc:  85be                 mv a1,a5
    7bce:  450d                 li a0,3
    7bd0:  059000ef           jal ra,8428 <rtc_brom_debug>
    7bd4:  a8f5                 j 7cd0 <FUN_00007ad4+0x1fc>
    7bd6:  000207b7           lui a5,0x20
    7bda:  fcf43c23           sd a5,-40(s0)
    7bde:  fd843783           ld a5,-40(s0)
    7be2:  4b9c                 lw a5,16(a5)
    7be4:  fef42423           sw a5,-24(s0)
    7be8:  fe842783           lw a5,-24(s0)
    7bec:  1ff7f793           andi a5,a5,511
    7bf0:  2781                 sext.w a5,a5
    7bf2:  cb91                 beqz a5,7c06 <FUN_00007ad4+0x132>
    7bf4:  fe442783           lw a5,-28(s0)
    7bf8:  0f200613           li a2,242
    7bfc:  85be                 mv a1,a5
    7bfe:  450d                 li a0,3
    7c00:  029000ef           jal ra,8428 <rtc_brom_debug>
    7c04:  a0f1                 j 7cd0 <FUN_00007ad4+0x1fc>
    7c06:  fe842783           lw a5,-24(s0)
    7c0a:  0087d79b           srliw a5,a5,0x8
    7c0e:  0007871b           sext.w a4,a5
    7c12:  fe042783           lw a5,-32(s0)
    7c16:  fc843683           ld a3,-56(s0)
    7c1a:  863a                 mv a2,a4
    7c1c:  000205b7           lui a1,0x20
    7c20:  853e                 mv a0,a5
    7c22:  9682                 jalr a3
    7c24:  87aa                 mv a5,a0
    7c26:  873e                 mv a4,a5
    7c28:  4789                 li a5,2
    7c2a:  00f71b63           bne a4,a5,7c40 <FUN_00007ad4+0x16c>
    7c2e:  fe442783           lw a5,-28(s0)
    7c32:  0f300613           li a2,243
    7c36:  85be                 mv a1,a5
    7c38:  450d                 li a0,3
    7c3a:  7ee000ef           jal ra,8428 <rtc_brom_debug>
    7c3e:  a849                 j 7cd0 <FUN_00007ad4+0x1fc>
    7c40:  fe842783           lw a5,-24(s0)
    7c44:  85be                 mv a1,a5
    7c46:  00020537           lui a0,0x20
    7c4a:  26d000ef           jal ra,86b6 <FUN_000086b6>
    7c4e:  87aa                 mv a5,a0
    7c50:  eba5                 bnez a5,7cc0 <FUN_00007ad4+0x1ec>
    7c52:  000487b7           lui a5,0x48
    7c56:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7c5a:  c395                 beqz a5,7c7e <FUN_00007ad4+0x1aa>
    7c5c:  fe442783           lw a5,-28(s0)
    7c60:  0ff7f793           andi a5,a5,255
    7c64:  0047979b           slliw a5,a5,0x4
    7c68:  0ff7f793           andi a5,a5,255
    7c6c:  0037e793           ori a5,a5,3
    7c70:  0ff7f713           andi a4,a5,255
    7c74:  fd043783           ld a5,-48(s0)
    7c78:  02e78023           sb a4,32(a5)
    7c7c:  a00d                 j 7c9e <FUN_00007ad4+0x1ca>
    7c7e:  fe442783           lw a5,-28(s0)
    7c82:  0ff7f793           andi a5,a5,255
    7c86:  0047979b           slliw a5,a5,0x4
    7c8a:  0ff7f793           andi a5,a5,255
    7c8e:  0037e793           ori a5,a5,3
    7c92:  0ff7f713           andi a4,a5,255
    7c96:  fd843783           ld a5,-40(s0)
    7c9a:  02e78423           sb a4,40(a5)
    7c9e:  4581                 li a1,0
    7ca0:  450d                 li a0,3
    7ca2:  5cb010ef           jal ra,9a6c <FUN_00009a6c>
    7ca6:  fe442703           lw a4,-28(s0)
    7caa:  6785                 lui a5,0x1
    7cac:  fff78613           addi a2,a5,-1 # fff <FUN_00000f2c+0xd3>
    7cb0:  85ba                 mv a1,a4
    7cb2:  450d                 li a0,3
    7cb4:  774000ef           jal ra,8428 <rtc_brom_debug>
    7cb8:  b18ff0ef           jal ra,6fd0 <FUN_00006fd0>
    7cbc:  4781                 li a5,0
    7cbe:  a891                 j 7d12 <FUN_00007ad4+0x23e>
    7cc0:  fe442783           lw a5,-28(s0)
    7cc4:  0f400613           li a2,244
    7cc8:  85be                 mv a1,a5
    7cca:  450d                 li a0,3
    7ccc:  75c000ef           jal ra,8428 <rtc_brom_debug>
    7cd0:  fe442783           lw a5,-28(s0)
    7cd4:  2785                 addiw a5,a5,1
    7cd6:  fef42223           sw a5,-28(s0)
    7cda:  fe042783           lw a5,-32(s0)
    7cde:  1007879b           addiw a5,a5,256
    7ce2:  fef42023           sw a5,-32(s0)
    7ce6:  fe442783           lw a5,-28(s0)
    7cea:  0007871b           sext.w a4,a5
    7cee:  478d                 li a5,3
    7cf0:  e2e7fce3           bgeu a5,a4,7b28 <FUN_00007ad4+0x54>
    7cf4:  fec42783           lw a5,-20(s0)
    7cf8:  2785                 addiw a5,a5,1
    7cfa:  fef42623           sw a5,-20(s0)
    7cfe:  fec42783           lw a5,-20(s0)
    7d02:  0007871b           sext.w a4,a5
    7d06:  4785                 li a5,1
    7d08:  e0e7f1e3           bgeu a5,a4,7b0a <FUN_00007ad4+0x36>
    7d0c:  ac4ff0ef           jal ra,6fd0 <FUN_00006fd0>
    7d10:  57fd                 li a5,-1
    7d12:  853e                 mv a0,a5
    7d14:  60a6                 ld ra,72(sp)
    7d16:  6406                 ld s0,64(sp)
    7d18:  6161                 addi sp,sp,80
    7d1a:  8082                 ret
0000000000007d1c <FUN_00007d1c>:
    7d1c:  1101                 addi sp,sp,-32
    7d1e:  ec06                 sd ra,24(sp)
    7d20:  e822                 sd s0,16(sp)
    7d22:  1000                 addi s0,sp,32
    7d24:  87aa                 mv a5,a0
    7d26:  fef42623           sw a5,-20(s0)
    7d2a:  070907b7           lui a5,0x7090
    7d2e:  31c78513           addi a0,a5,796 # 709031c <gpio_get_boot_device+0x7081f86
    7d32:  656000ef           jal ra,8388 <debug_select_word>
    7d36:  fec42783           lw a5,-20(s0)
    7d3a:  853e                 mv a0,a5
    7d3c:  bdbff0ef           jal ra,7916 <FUN_00007916>
    7d40:  87aa                 mv a5,a0
    7d42:  e399                 bnez a5,7d48 <FUN_00007d1c+0x2c>
    7d44:  4781                 li a5,0
    7d46:  a819                 j 7d5c <FUN_00007d1c+0x40>
    7d48:  fec42783           lw a5,-20(s0)
    7d4c:  853e                 mv a0,a5
    7d4e:  d87ff0ef           jal ra,7ad4 <FUN_00007ad4>
    7d52:  87aa                 mv a5,a0
    7d54:  e399                 bnez a5,7d5a <FUN_00007d1c+0x3e>
    7d56:  4781                 li a5,0
    7d58:  a011                 j 7d5c <FUN_00007d1c+0x40>
    7d5a:  57fd                 li a5,-1
    7d5c:  853e                 mv a0,a5
    7d5e:  60e2                 ld ra,24(sp)
    7d60:  6442                 ld s0,16(sp)
    7d62:  6105                 addi sp,sp,32
    7d64:  8082                 ret
0000000000007d66 <sid_readl>:
    7d66:  7179                 addi sp,sp,-48
    7d68:  f422                 sd s0,40(sp)
    7d6a:  1800                 addi s0,sp,48
    7d6c:  87aa                 mv a5,a0
    7d6e:  fcf42e23           sw a5,-36(s0)
    7d72:  fe042623           sw zero,-20(s0)
    7d76:  fdc46703           lwu a4,-36(s0)
    7d7a:  030067b7           lui a5,0x3006
    7d7e:  20078793           addi a5,a5,512 # 3006200 <gpio_get_boot_device+0x2ff7e6a
    7d82:  97ba                 add a5,a5,a4
    7d84:  439c                 lw a5,0(a5)
    7d86:  fef42623           sw a5,-20(s0)
    7d8a:  fec42783           lw a5,-20(s0)
    7d8e:  853e                 mv a0,a5
    7d90:  7422                 ld s0,40(sp)
    7d92:  6145                 addi sp,sp,48
    7d94:  8082                 ret
0000000000007d96 <FUN_00007d96>:
    7d96:  1101                 addi sp,sp,-32
    7d98:  ec22                 sd s0,24(sp)
    7d9a:  1000                 addi s0,sp,32
    7d9c:  fe042623           sw zero,-20(s0)
    7da0:  030067b7           lui a5,0x3006
    7da4:  0a078793           addi a5,a5,160 # 30060a0 <gpio_get_boot_device+0x2ff7d0a
    7da8:  439c                 lw a5,0(a5)
    7daa:  fef42623           sw a5,-20(s0)
    7dae:  fec42783           lw a5,-20(s0)
    7db2:  853e                 mv a0,a5
    7db4:  6462                 ld s0,24(sp)
    7db6:  6105                 addi sp,sp,32
    7db8:  8082                 ret
0000000000007dba <sid_init_brom_config>:
    7dba:  1101                 addi sp,sp,-32
    7dbc:  ec06                 sd ra,24(sp)
    7dbe:  e822                 sd s0,16(sp)
    7dc0:  1000                 addi s0,sp,32
    7dc2:  fe042623           sw zero,-20(s0)
    7dc6:  fe042423           sw zero,-24(s0)
    7dca:  000487b7           lui a5,0x48
    7dce:  e007a823           sw zero,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7dd2:  4541                 li a0,16
    7dd4:  f93ff0ef           jal ra,7d66 <sid_readl>
    7dd8:  87aa                 mv a5,a0
    7dda:  fef42623           sw a5,-20(s0)
    7dde:  fec42703           lw a4,-20(s0)
    7de2:  67c1                 lui a5,0x10
    7de4:  17fd                 addi a5,a5,-1
    7de6:  8ff9                 and a5,a5,a4
    7de8:  0007871b           sext.w a4,a5
    7dec:  000487b7           lui a5,0x48
    7df0:  e2e7a023           sw a4,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7df4:  fec42703           lw a4,-20(s0)
    7df8:  800007b7           lui a5,0x80000
    7dfc:  8ff9                 and a5,a5,a4
    7dfe:  0007871b           sext.w a4,a5
    7e02:  000487b7           lui a5,0x48
    7e06:  e0e7a823           sw a4,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    7e0a:  0001                 nop
    7e0c:  60e2                 ld ra,24(sp)
    7e0e:  6442                 ld s0,16(sp)
    7e10:  6105                 addi sp,sp,32
    7e12:  8082                 ret
0000000000007e14 <sid_get_boot_mode>:
    7e14:  1101                 addi sp,sp,-32
    7e16:  ec06                 sd ra,24(sp)
    7e18:  e822                 sd s0,16(sp)
    7e1a:  1000                 addi s0,sp,32
    7e1c:  fe042623           sw zero,-20(s0)
    7e20:  4541                 li a0,16
    7e22:  f45ff0ef           jal ra,7d66 <sid_readl>
    7e26:  87aa                 mv a5,a0
    7e28:  fef42623           sw a5,-20(s0)
    7e2c:  fec42783           lw a5,-20(s0)
    7e30:  8b85                 andi a5,a5,1
    7e32:  fef42623           sw a5,-20(s0)
    7e36:  fec42783           lw a5,-20(s0)
    7e3a:  853e                 mv a0,a5
    7e3c:  60e2                 ld ra,24(sp)
    7e3e:  6442                 ld s0,16(sp)
    7e40:  6105                 addi sp,sp,32
    7e42:  8082                 ret
0000000000007e44 <brom_config_bit_2>:
    7e44:  1101                 addi sp,sp,-32
    7e46:  ec22                 sd s0,24(sp)
    7e48:  1000                 addi s0,sp,32
    7e4a:  fe042623           sw zero,-20(s0)
    7e4e:  000487b7           lui a5,0x48
    7e52:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7e56:  8b91                 andi a5,a5,4
    7e58:  2781                 sext.w a5,a5
    7e5a:  c789                 beqz a5,7e64 <brom_config_bit_2+0x20>
    7e5c:  4785                 li a5,1
    7e5e:  fef42623           sw a5,-20(s0)
    7e62:  a019                 j 7e68 <brom_config_bit_2+0x24>
    7e64:  fe042623           sw zero,-20(s0)
    7e68:  fec42783           lw a5,-20(s0)
    7e6c:  853e                 mv a0,a5
    7e6e:  6462                 ld s0,24(sp)
    7e70:  6105                 addi sp,sp,32
    7e72:  8082                 ret
0000000000007e74 <brom_config_skip_cache_setup>:
    7e74:  1101                 addi sp,sp,-32
    7e76:  ec22                 sd s0,24(sp)
    7e78:  1000                 addi s0,sp,32
    7e7a:  fe042623           sw zero,-20(s0)
    7e7e:  000487b7           lui a5,0x48
    7e82:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7e86:  8ba1                 andi a5,a5,8
    7e88:  2781                 sext.w a5,a5
    7e8a:  c789                 beqz a5,7e94 <brom_config_skip_cache_setup+0x20>
    7e8c:  4785                 li a5,1
    7e8e:  fef42623           sw a5,-20(s0)
    7e92:  a019                 j 7e98 <brom_config_skip_cache_setup+0x24>
    7e94:  fe042623           sw zero,-20(s0)
    7e98:  fec42783           lw a5,-20(s0)
    7e9c:  853e                 mv a0,a5
    7e9e:  6462                 ld s0,24(sp)
    7ea0:  6105                 addi sp,sp,32
    7ea2:  8082                 ret
0000000000007ea4 <brom_config_bit_4>:
    7ea4:  1141                 addi sp,sp,-16
    7ea6:  e422                 sd s0,8(sp)
    7ea8:  0800                 addi s0,sp,16
    7eaa:  000487b7           lui a5,0x48
    7eae:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7eb2:  8bc1                 andi a5,a5,16
    7eb4:  2781                 sext.w a5,a5
    7eb6:  c399                 beqz a5,7ebc <brom_config_bit_4+0x18>
    7eb8:  4785                 li a5,1
    7eba:  a011                 j 7ebe <brom_config_bit_4+0x1a>
    7ebc:  4781                 li a5,0
    7ebe:  853e                 mv a0,a5
    7ec0:  6422                 ld s0,8(sp)
    7ec2:  0141                 addi sp,sp,16
    7ec4:  8082                 ret
0000000000007ec6 <brom_config_bit_5>:
    7ec6:  1101                 addi sp,sp,-32
    7ec8:  ec22                 sd s0,24(sp)
    7eca:  1000                 addi s0,sp,32
    7ecc:  fe042623           sw zero,-20(s0)
    7ed0:  000487b7           lui a5,0x48
    7ed4:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7ed8:  0207f793           andi a5,a5,32
    7edc:  2781                 sext.w a5,a5
    7ede:  c789                 beqz a5,7ee8 <brom_config_bit_5+0x22>
    7ee0:  4785                 li a5,1
    7ee2:  fef42623           sw a5,-20(s0)
    7ee6:  a019                 j 7eec <brom_config_bit_5+0x26>
    7ee8:  fe042623           sw zero,-20(s0)
    7eec:  fec42783           lw a5,-20(s0)
    7ef0:  853e                 mv a0,a5
    7ef2:  6462                 ld s0,24(sp)
    7ef4:  6105                 addi sp,sp,32
    7ef6:  8082                 ret
0000000000007ef8 <brom_config_bit_7_switch>:
    7ef8:  1101                 addi sp,sp,-32
    7efa:  ec22                 sd s0,24(sp)
    7efc:  1000                 addi s0,sp,32
    7efe:  57fd                 li a5,-1
    7f00:  fef42623           sw a5,-20(s0)
    7f04:  fe042423           sw zero,-24(s0)
    7f08:  fe042223           sw zero,-28(s0)
    7f0c:  000487b7           lui a5,0x48
    7f10:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7f14:  0807f793           andi a5,a5,128
    7f18:  2781                 sext.w a5,a5
    7f1a:  c39d                 beqz a5,7f40 <brom_config_bit_7_switch+0x48>
    7f1c:  4785                 li a5,1
    7f1e:  fef42423           sw a5,-24(s0)
    7f22:  03000793           li a5,48
    7f26:  fef42223           sw a5,-28(s0)
    7f2a:  fe842703           lw a4,-24(s0)
    7f2e:  fe442783           lw a5,-28(s0)
    7f32:  02f707bb           mulw a5,a4,a5
    7f36:  fef42623           sw a5,-20(s0)
    7f3a:  fec42783           lw a5,-20(s0)
    7f3e:  a019                 j 7f44 <brom_config_bit_7_switch+0x4c>
    7f40:  02000793           li a5,32
    7f44:  853e                 mv a0,a5
    7f46:  6462                 ld s0,24(sp)
    7f48:  6105                 addi sp,sp,32
    7f4a:  8082                 ret
0000000000007f4c <brom_config_bit_6>:
    7f4c:  1141                 addi sp,sp,-16
    7f4e:  e422                 sd s0,8(sp)
    7f50:  0800                 addi s0,sp,16
    7f52:  000487b7           lui a5,0x48
    7f56:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7f5a:  0407f793           andi a5,a5,64
    7f5e:  2781                 sext.w a5,a5
    7f60:  c399                 beqz a5,7f66 <brom_config_bit_6+0x1a>
    7f62:  4785                 li a5,1
    7f64:  a011                 j 7f68 <brom_config_bit_6+0x1c>
    7f66:  4781                 li a5,0
    7f68:  853e                 mv a0,a5
    7f6a:  6422                 ld s0,8(sp)
    7f6c:  0141                 addi sp,sp,16
    7f6e:  8082                 ret
0000000000007f70 <FUN_00007f70>:
    7f70:  1141                 addi sp,sp,-16
    7f72:  e422                 sd s0,8(sp)
    7f74:  0800                 addi s0,sp,16
    7f76:  4781                 li a5,0
    7f78:  853e                 mv a0,a5
    7f7a:  6422                 ld s0,8(sp)
    7f7c:  0141                 addi sp,sp,16
    7f7e:  8082                 ret
0000000000007f80 <brom_config_bit_13>:
    7f80:  1141                 addi sp,sp,-16
    7f82:  e422                 sd s0,8(sp)
    7f84:  0800                 addi s0,sp,16
    7f86:  000487b7           lui a5,0x48
    7f8a:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7f8e:  873e                 mv a4,a5
    7f90:  6789                 lui a5,0x2
    7f92:  8ff9                 and a5,a5,a4
    7f94:  2781                 sext.w a5,a5
    7f96:  c399                 beqz a5,7f9c <brom_config_bit_13+0x1c>
    7f98:  4785                 li a5,1
    7f9a:  a011                 j 7f9e <brom_config_bit_13+0x1e>
    7f9c:  4781                 li a5,0
    7f9e:  853e                 mv a0,a5
    7fa0:  6422                 ld s0,8(sp)
    7fa2:  0141                 addi sp,sp,16
    7fa4:  8082                 ret
0000000000007fa6 <brom_config_lower_ce_freq>:
    7fa6:  1141                 addi sp,sp,-16
    7fa8:  e422                 sd s0,8(sp)
    7faa:  0800                 addi s0,sp,16
    7fac:  000487b7           lui a5,0x48
    7fb0:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7fb4:  873e                 mv a4,a5
    7fb6:  6791                 lui a5,0x4
    7fb8:  8ff9                 and a5,a5,a4
    7fba:  2781                 sext.w a5,a5
    7fbc:  c399                 beqz a5,7fc2 <brom_config_lower_ce_freq+0x1c>
    7fbe:  4785                 li a5,1
    7fc0:  a011                 j 7fc4 <brom_config_lower_ce_freq+0x1e>
    7fc2:  4781                 li a5,0
    7fc4:  853e                 mv a0,a5
    7fc6:  6422                 ld s0,8(sp)
    7fc8:  0141                 addi sp,sp,16
    7fca:  8082                 ret
0000000000007fcc <brom_config_disable_fel>:
    7fcc:  1141                 addi sp,sp,-16
    7fce:  e422                 sd s0,8(sp)
    7fd0:  0800                 addi s0,sp,16
    7fd2:  000487b7           lui a5,0x48
    7fd6:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    7fda:  2007f793           andi a5,a5,512
    7fde:  2781                 sext.w a5,a5
    7fe0:  c399                 beqz a5,7fe6 <brom_config_disable_fel+0x1a>
    7fe2:  4785                 li a5,1
    7fe4:  a011                 j 7fe8 <brom_config_disable_fel+0x1c>
    7fe6:  4781                 li a5,0
    7fe8:  853e                 mv a0,a5
    7fea:  6422                 ld s0,8(sp)
    7fec:  0141                 addi sp,sp,16
    7fee:  8082                 ret
0000000000007ff0 <FUN_00007ff0>:
    7ff0:  1141                 addi sp,sp,-16
    7ff2:  e422                 sd s0,8(sp)
    7ff4:  0800                 addi s0,sp,16
    7ff6:  4781                 li a5,0
    7ff8:  853e                 mv a0,a5
    7ffa:  6422                 ld s0,8(sp)
    7ffc:  0141                 addi sp,sp,16
    7ffe:  8082                 ret
0000000000008000 <brom_config_bit_10>:
    8000:  1141                 addi sp,sp,-16
    8002:  e422                 sd s0,8(sp)
    8004:  0800                 addi s0,sp,16
    8006:  000487b7           lui a5,0x48
    800a:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    800e:  4007f793           andi a5,a5,1024
    8012:  2781                 sext.w a5,a5
    8014:  c399                 beqz a5,801a <brom_config_bit_10+0x1a>
    8016:  4785                 li a5,1
    8018:  a011                 j 801c <brom_config_bit_10+0x1c>
    801a:  4781                 li a5,0
    801c:  853e                 mv a0,a5
    801e:  6422                 ld s0,8(sp)
    8020:  0141                 addi sp,sp,16
    8022:  8082                 ret
0000000000008024 <brom_config_bit_15>:
    8024:  1141                 addi sp,sp,-16
    8026:  e422                 sd s0,8(sp)
    8028:  0800                 addi s0,sp,16
    802a:  000487b7           lui a5,0x48
    802e:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    8032:  873e                 mv a4,a5
    8034:  67a1                 lui a5,0x8
    8036:  8ff9                 and a5,a5,a4
    8038:  2781                 sext.w a5,a5
    803a:  c399                 beqz a5,8040 <brom_config_bit_15+0x1c>
    803c:  4785                 li a5,1
    803e:  a011                 j 8042 <brom_config_bit_15+0x1e>
    8040:  4781                 li a5,0
    8042:  853e                 mv a0,a5
    8044:  6422                 ld s0,8(sp)
    8046:  0141                 addi sp,sp,16
    8048:  8082                 ret
000000000000804a <brom_config_bit_8>:
    804a:  1141                 addi sp,sp,-16
    804c:  e422                 sd s0,8(sp)
    804e:  0800                 addi s0,sp,16
    8050:  000487b7           lui a5,0x48
    8054:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    8058:  1007f793           andi a5,a5,256
    805c:  2781                 sext.w a5,a5
    805e:  c399                 beqz a5,8064 <brom_config_bit_8+0x1a>
    8060:  4785                 li a5,1
    8062:  a011                 j 8066 <brom_config_bit_8+0x1c>
    8064:  4781                 li a5,0
    8066:  853e                 mv a0,a5
    8068:  6422                 ld s0,8(sp)
    806a:  0141                 addi sp,sp,16
    806c:  8082                 ret
000000000000806e <brom_config_bit_1>:
    806e:  1141                 addi sp,sp,-16
    8070:  e422                 sd s0,8(sp)
    8072:  0800                 addi s0,sp,16
    8074:  000487b7           lui a5,0x48
    8078:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    807c:  8b89                 andi a5,a5,2
    807e:  2781                 sext.w a5,a5
    8080:  c399                 beqz a5,8086 <brom_config_bit_1+0x18>
    8082:  4785                 li a5,1
    8084:  a011                 j 8088 <brom_config_bit_1+0x1a>
    8086:  4781                 li a5,0
    8088:  853e                 mv a0,a5
    808a:  6422                 ld s0,8(sp)
    808c:  0141                 addi sp,sp,16
    808e:  8082                 ret
0000000000008090 <brom_config_bit_12>:
    8090:  1141                 addi sp,sp,-16
    8092:  e422                 sd s0,8(sp)
    8094:  0800                 addi s0,sp,16
    8096:  000487b7           lui a5,0x48
    809a:  e207a783           lw a5,-480(a5) # 47e20 <gpio_get_boot_device+0x39a8a>
    809e:  873e                 mv a4,a5
    80a0:  6785                 lui a5,0x1
    80a2:  8ff9                 and a5,a5,a4
    80a4:  2781                 sext.w a5,a5
    80a6:  c399                 beqz a5,80ac <brom_config_bit_12+0x1c>
    80a8:  4785                 li a5,1
    80aa:  a011                 j 80ae <brom_config_bit_12+0x1e>
    80ac:  4781                 li a5,0
    80ae:  853e                 mv a0,a5
    80b0:  6422                 ld s0,8(sp)
    80b2:  0141                 addi sp,sp,16
    80b4:  8082                 ret
00000000000080b6 <sid_get_boot_device>:
    80b6:  7179                 addi sp,sp,-48
    80b8:  f406                 sd ra,40(sp)
    80ba:  f022                 sd s0,32(sp)
    80bc:  1800                 addi s0,sp,48
    80be:  fe042623           sw zero,-20(s0)
    80c2:  479d                 li a5,7
    80c4:  fef42023           sw a5,-32(s0)
    80c8:  fc042e23           sw zero,-36(s0)
    80cc:  fe042423           sw zero,-24(s0)
    80d0:  fc042c23           sw zero,-40(s0)
    80d4:  4785                 li a5,1
    80d6:  fef403a3           sb a5,-25(s0)
    80da:  4541                 li a0,16
    80dc:  c8bff0ef           jal ra,7d66 <sid_readl>
    80e0:  87aa                 mv a5,a0
    80e2:  fcf42c23           sw a5,-40(s0)
    80e6:  fd842783           lw a5,-40(s0)
    80ea:  0107d79b           srliw a5,a5,0x10
    80ee:  2781                 sext.w a5,a5
    80f0:  873e                 mv a4,a5
    80f2:  6785                 lui a5,0x1
    80f4:  17fd                 addi a5,a5,-1
    80f6:  8ff9                 and a5,a5,a4
    80f8:  fcf42c23           sw a5,-40(s0)
    80fc:  fd842783           lw a5,-40(s0)
    8100:  fef42423           sw a5,-24(s0)
    8104:  fe842703           lw a4,-24(s0)
    8108:  fe042783           lw a5,-32(s0)
    810c:  8ff9                 and a5,a5,a4
    810e:  fcf42e23           sw a5,-36(s0)
    8112:  fdc42783           lw a5,-36(s0)
    8116:  0007871b           sext.w a4,a5
    811a:  479d                 li a5,7
    811c:  08f71a63           bne a4,a5,81b0 <sid_get_boot_device+0xfa>
    8120:  fe744783           lbu a5,-25(s0)
    8124:  0ff7f713           andi a4,a5,255
    8128:  478d                 li a5,3
    812a:  08e7e363           bltu a5,a4,81b0 <sid_get_boot_device+0xfa>
    812e:  fe744783           lbu a5,-25(s0)
    8132:  0ff7f713           andi a4,a5,255
    8136:  4785                 li a5,1
    8138:  02f71163           bne a4,a5,815a <sid_get_boot_device+0xa4>
    813c:  fd842783           lw a5,-40(s0)
    8140:  0037d79b           srliw a5,a5,0x3
    8144:  2781                 sext.w a5,a5
    8146:  1ff7f793           andi a5,a5,511
    814a:  fef42423           sw a5,-24(s0)
    814e:  fe744783           lbu a5,-25(s0)
    8152:  2785                 addiw a5,a5,1
    8154:  fef403a3           sb a5,-25(s0)
    8158:  b775                 j 8104 <sid_get_boot_device+0x4e>
    815a:  fe744783           lbu a5,-25(s0)
    815e:  0ff7f713           andi a4,a5,255
    8162:  4789                 li a5,2
    8164:  02f71163           bne a4,a5,8186 <sid_get_boot_device+0xd0>
    8168:  fd842783           lw a5,-40(s0)
    816c:  0067d79b           srliw a5,a5,0x6
    8170:  2781                 sext.w a5,a5
    8172:  03f7f793           andi a5,a5,63
    8176:  fef42423           sw a5,-24(s0)
    817a:  fe744783           lbu a5,-25(s0)
    817e:  2785                 addiw a5,a5,1
    8180:  fef403a3           sb a5,-25(s0)
    8184:  b741                 j 8104 <sid_get_boot_device+0x4e>
    8186:  fe744783           lbu a5,-25(s0)
    818a:  0ff7f713           andi a4,a5,255
    818e:  478d                 li a5,3
    8190:  0af71263           bne a4,a5,8234 <sid_get_boot_device+0x17e>
    8194:  fd842783           lw a5,-40(s0)
    8198:  0097d79b           srliw a5,a5,0x9
    819c:  2781                 sext.w a5,a5
    819e:  8b9d                 andi a5,a5,7
    81a0:  fef42423           sw a5,-24(s0)
    81a4:  fe744783           lbu a5,-25(s0)
    81a8:  2785                 addiw a5,a5,1
    81aa:  fef403a3           sb a5,-25(s0)
    81ae:  bf99                 j 8104 <sid_get_boot_device+0x4e>
    81b0:  fdc42783           lw a5,-36(s0)
    81b4:  0007871b           sext.w a4,a5
    81b8:  479d                 li a5,7
    81ba:  04e7eb63           bltu a5,a4,8210 <sid_get_boot_device+0x15a>
    81be:  fdc46783           lwu a5,-36(s0)
    81c2:  00279713           slli a4,a5,0x2
    81c6:  67b9                 lui a5,0xe
    81c8:  52c78793           addi a5,a5,1324 # e52c <gpio_get_boot_device+0x196>
    81cc:  97ba                 add a5,a5,a4
    81ce:  439c                 lw a5,0(a5)
    81d0:  8782                 jr a5
    81d2:  fe042623           sw zero,-20(s0)
    81d6:  a835                 j 8212 <sid_get_boot_device+0x15c>
    81d8:  4785                 li a5,1
    81da:  fef42623           sw a5,-20(s0)
    81de:  a815                 j 8212 <sid_get_boot_device+0x15c>
    81e0:  4789                 li a5,2
    81e2:  fef42623           sw a5,-20(s0)
    81e6:  a035                 j 8212 <sid_get_boot_device+0x15c>
    81e8:  478d                 li a5,3
    81ea:  fef42623           sw a5,-20(s0)
    81ee:  a015                 j 8212 <sid_get_boot_device+0x15c>
    81f0:  4791                 li a5,4
    81f2:  fef42623           sw a5,-20(s0)
    81f6:  a831                 j 8212 <sid_get_boot_device+0x15c>
    81f8:  4795                 li a5,5
    81fa:  fef42623           sw a5,-20(s0)
    81fe:  a811                 j 8212 <sid_get_boot_device+0x15c>
    8200:  4799                 li a5,6
    8202:  fef42623           sw a5,-20(s0)
    8206:  a031                 j 8212 <sid_get_boot_device+0x15c>
    8208:  479d                 li a5,7
    820a:  fef42623           sw a5,-20(s0)
    820e:  a011                 j 8212 <sid_get_boot_device+0x15c>
    8210:  0001                 nop
    8212:  fe744783           lbu a5,-25(s0)
    8216:  0ff7f713           andi a4,a5,255
    821a:  4791                 li a5,4
    821c:  00f71d63           bne a4,a5,8236 <sid_get_boot_device+0x180>
    8220:  fec42783           lw a5,-20(s0)
    8224:  0007871b           sext.w a4,a5
    8228:  479d                 li a5,7
    822a:  00f71663           bne a4,a5,8236 <sid_get_boot_device+0x180>
    822e:  fe042623           sw zero,-20(s0)
    8232:  a011                 j 8236 <sid_get_boot_device+0x180>
    8234:  0001                 nop
    8236:  fec42783           lw a5,-20(s0)
    823a:  853e                 mv a0,a5
    823c:  70a2                 ld ra,40(sp)
    823e:  7402                 ld s0,32(sp)
    8240:  6145                 addi sp,sp,48
    8242:  8082                 ret
0000000000008244 <debug_state_save>:
    8244:  7179                 addi sp,sp,-48
    8246:  f422                 sd s0,40(sp)
    8248:  1800                 addi s0,sp,48
    824a:  87aa                 mv a5,a0
    824c:  872e                 mv a4,a1
    824e:  fcf42e23           sw a5,-36(s0)
    8252:  87ba                 mv a5,a4
    8254:  fcf42c23           sw a5,-40(s0)
    8258:  fe042623           sw zero,-20(s0)
    825c:  fe042423           sw zero,-24(s0)
    8260:  070907b7           lui a5,0x7090
    8264:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    8268:  439c                 lw a5,0(a5)
    826a:  fef42623           sw a5,-20(s0)
    826e:  fec42703           lw a4,-20(s0)
    8272:  67a1                 lui a5,0x8
    8274:  8ff9                 and a5,a5,a4
    8276:  fef42423           sw a5,-24(s0)
    827a:  fe842783           lw a5,-24(s0)
    827e:  2781                 sext.w a5,a5
    8280:  cfad                 beqz a5,82fa <debug_state_save+0xb6>
    8282:  fdc42783           lw a5,-36(s0)
    8286:  2781                 sext.w a5,a5
    8288:  cb8d                 beqz a5,82ba <debug_state_save+0x76>
    828a:  fec42703           lw a4,-20(s0)
    828e:  77e1                 lui a5,0xffff8
    8290:  8ff9                 and a5,a5,a4
    8292:  fef42623           sw a5,-20(s0)
    8296:  fdc42783           lw a5,-36(s0)
    829a:  0087979b           slliw a5,a5,0x8
    829e:  0007871b           sext.w a4,a5
    82a2:  fec42783           lw a5,-20(s0)
    82a6:  8fd9                 or a5,a5,a4
    82a8:  fef42623           sw a5,-20(s0)
    82ac:  070907b7           lui a5,0x7090
    82b0:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    82b4:  fec42703           lw a4,-20(s0)
    82b8:  c398                 sw a4,0(a5)
    82ba:  fd842783           lw a5,-40(s0)
    82be:  2781                 sext.w a5,a5
    82c0:  c3e1                 beqz a5,8380 <debug_state_save+0x13c>
    82c2:  070907b7           lui a5,0x7090
    82c6:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    82ca:  439c                 lw a5,0(a5)
    82cc:  fef42623           sw a5,-20(s0)
    82d0:  fec42783           lw a5,-20(s0)
    82d4:  f007f793           andi a5,a5,-256
    82d8:  fef42623           sw a5,-20(s0)
    82dc:  fec42703           lw a4,-20(s0)
    82e0:  fd842783           lw a5,-40(s0)
    82e4:  8fd9                 or a5,a5,a4
    82e6:  fef42623           sw a5,-20(s0)
    82ea:  070907b7           lui a5,0x7090
    82ee:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    82f2:  fec42703           lw a4,-20(s0)
    82f6:  c398                 sw a4,0(a5)
    82f8:  a061                 j 8380 <debug_state_save+0x13c>
    82fa:  fdc42783           lw a5,-36(s0)
    82fe:  2781                 sext.w a5,a5
    8300:  cb9d                 beqz a5,8336 <debug_state_save+0xf2>
    8302:  fec42703           lw a4,-20(s0)
    8306:  800107b7           lui a5,0x80010
    830a:  17fd                 addi a5,a5,-1
    830c:  8ff9                 and a5,a5,a4
    830e:  fef42623           sw a5,-20(s0)
    8312:  fdc42783           lw a5,-36(s0)
    8316:  0187979b           slliw a5,a5,0x18
    831a:  0007871b           sext.w a4,a5
    831e:  fec42783           lw a5,-20(s0)
    8322:  8fd9                 or a5,a5,a4
    8324:  fef42623           sw a5,-20(s0)
    8328:  070907b7           lui a5,0x7090
    832c:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    8330:  fec42703           lw a4,-20(s0)
    8334:  c398                 sw a4,0(a5)
    8336:  fd842783           lw a5,-40(s0)
    833a:  2781                 sext.w a5,a5
    833c:  c3b1                 beqz a5,8380 <debug_state_save+0x13c>
    833e:  070907b7           lui a5,0x7090
    8342:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    8346:  439c                 lw a5,0(a5)
    8348:  fef42623           sw a5,-20(s0)
    834c:  fec42703           lw a4,-20(s0)
    8350:  ff0107b7           lui a5,0xff010
    8354:  17fd                 addi a5,a5,-1
    8356:  8ff9                 and a5,a5,a4
    8358:  fef42623           sw a5,-20(s0)
    835c:  fd842783           lw a5,-40(s0)
    8360:  0107979b           slliw a5,a5,0x10
    8364:  0007871b           sext.w a4,a5
    8368:  fec42783           lw a5,-20(s0)
    836c:  8fd9                 or a5,a5,a4
    836e:  fef42623           sw a5,-20(s0)
    8372:  070907b7           lui a5,0x7090
    8376:  30478793           addi a5,a5,772 # 7090304 <gpio_get_boot_device+0x7081f6e
    837a:  fec42703           lw a4,-20(s0)
    837e:  c398                 sw a4,0(a5)
    8380:  0001                 nop
    8382:  7422                 ld s0,40(sp)
    8384:  6145                 addi sp,sp,48
    8386:  8082                 ret
0000000000008388 <debug_select_word>:
    8388:  7179                 addi sp,sp,-48
    838a:  f422                 sd s0,40(sp)
    838c:  1800                 addi s0,sp,48
    838e:  87aa                 mv a5,a0
    8390:  fcf42e23           sw a5,-36(s0)
    8394:  fe042623           sw zero,-20(s0)
    8398:  fe042423           sw zero,-24(s0)
    839c:  fdc46783           lwu a5,-36(s0)
    83a0:  439c                 lw a5,0(a5)
    83a2:  fef42623           sw a5,-20(s0)
    83a6:  fec42783           lw a5,-20(s0)
    83aa:  2781                 sext.w a5,a5
    83ac:  ef91                 bnez a5,83c8 <debug_select_word+0x40>
    83ae:  fec42703           lw a4,-20(s0)
    83b2:  67a1                 lui a5,0x8
    83b4:  8fd9                 or a5,a5,a4
    83b6:  fef42623           sw a5,-20(s0)
    83ba:  fdc46783           lwu a5,-36(s0)
    83be:  873e                 mv a4,a5
    83c0:  fec42783           lw a5,-20(s0)
    83c4:  c31c                 sw a5,0(a4)
    83c6:  a8b1                 j 8422 <debug_select_word+0x9a>
    83c8:  fec42703           lw a4,-20(s0)
    83cc:  67a1                 lui a5,0x8
    83ce:  8ff9                 and a5,a5,a4
    83d0:  fef42423           sw a5,-24(s0)
    83d4:  fe842783           lw a5,-24(s0)
    83d8:  2781                 sext.w a5,a5
    83da:  c38d                 beqz a5,83fc <debug_select_word+0x74>
    83dc:  fec42703           lw a4,-20(s0)
    83e0:  f80087b7           lui a5,0xf8008
    83e4:  17fd                 addi a5,a5,-1
    83e6:  8ff9                 and a5,a5,a4
    83e8:  fef42623           sw a5,-20(s0)
    83ec:  fec42703           lw a4,-20(s0)
    83f0:  800007b7           lui a5,0x80000
    83f4:  8fd9                 or a5,a5,a4
    83f6:  fef42623           sw a5,-20(s0)
    83fa:  a831                 j 8416 <debug_select_word+0x8e>
    83fc:  fec42703           lw a4,-20(s0)
    8400:  7fff87b7           lui a5,0x7fff8
    8404:  8ff9                 and a5,a5,a4
    8406:  fef42623           sw a5,-20(s0)
    840a:  fec42703           lw a4,-20(s0)
    840e:  67a1                 lui a5,0x8
    8410:  8fd9                 or a5,a5,a4
    8412:  fef42623           sw a5,-20(s0)
    8416:  fdc46783           lwu a5,-36(s0)
    841a:  873e                 mv a4,a5
    841c:  fec42783           lw a5,-20(s0)
    8420:  c31c                 sw a5,0(a4)
    8422:  7422                 ld s0,40(sp)
    8424:  6145                 addi sp,sp,48
    8426:  8082                 ret
0000000000008428 <rtc_brom_debug>:
    8428:  7179                 addi sp,sp,-48
    842a:  f422                 sd s0,40(sp)
    842c:  1800                 addi s0,sp,48
    842e:  87aa                 mv a5,a0
    8430:  86ae                 mv a3,a1
    8432:  8732                 mv a4,a2
    8434:  fcf42e23           sw a5,-36(s0)
    8438:  87b6                 mv a5,a3
    843a:  fcf42c23           sw a5,-40(s0)
    843e:  87ba                 mv a5,a4
    8440:  fcf42a23           sw a5,-44(s0)
    8444:  fe042423           sw zero,-24(s0)
    8448:  fe042223           sw zero,-28(s0)
    844c:  070907b7           lui a5,0x7090
    8450:  31c7879b           addiw a5,a5,796
    8454:  fef42623           sw a5,-20(s0)
    8458:  fdc42783           lw a5,-36(s0)
    845c:  0007871b           sext.w a4,a5
    8460:  478d                 li a5,3
    8462:  00f71963           bne a4,a5,8474 <rtc_brom_debug+0x4c>
    8466:  070907b7           lui a5,0x7090
    846a:  31c7879b           addiw a5,a5,796
    846e:  fef42623           sw a5,-20(s0)
    8472:  a8b1                 j 84ce <rtc_brom_debug+0xa6>
    8474:  fdc42783           lw a5,-36(s0)
    8478:  0007871b           sext.w a4,a5
    847c:  4791                 li a5,4
    847e:  00f71963           bne a4,a5,8490 <rtc_brom_debug+0x68>
    8482:  070907b7           lui a5,0x7090
    8486:  3207879b           addiw a5,a5,800
    848a:  fef42623           sw a5,-20(s0)
    848e:  a081                 j 84ce <rtc_brom_debug+0xa6>
    8490:  fdc42783           lw a5,-36(s0)
    8494:  0007871b           sext.w a4,a5
    8498:  4795                 li a5,5
    849a:  00f71963           bne a4,a5,84ac <rtc_brom_debug+0x84>
    849e:  070907b7           lui a5,0x7090
    84a2:  3187879b           addiw a5,a5,792
    84a6:  fef42623           sw a5,-20(s0)
    84aa:  a015                 j 84ce <rtc_brom_debug+0xa6>
    84ac:  fdc42783           lw a5,-36(s0)
    84b0:  0007871b           sext.w a4,a5
    84b4:  4789                 li a5,2
    84b6:  00f70663           beq a4,a5,84c2 <rtc_brom_debug+0x9a>
    84ba:  fdc42783           lw a5,-36(s0)
    84be:  2781                 sext.w a5,a5
    84c0:  e799                 bnez a5,84ce <rtc_brom_debug+0xa6>
    84c2:  070907b7           lui a5,0x7090
    84c6:  3147879b           addiw a5,a5,788
    84ca:  fef42623           sw a5,-20(s0)
    84ce:  fec46783           lwu a5,-20(s0)
    84d2:  439c                 lw a5,0(a5)
    84d4:  fef42423           sw a5,-24(s0)
    84d8:  fe842703           lw a4,-24(s0)
    84dc:  67a1                 lui a5,0x8
    84de:  8ff9                 and a5,a5,a4
    84e0:  fef42223           sw a5,-28(s0)
    84e4:  fe442783           lw a5,-28(s0)
    84e8:  2781                 sext.w a5,a5
    84ea:  c7c9                 beqz a5,8574 <rtc_brom_debug+0x14c>
    84ec:  fd842783           lw a5,-40(s0)
    84f0:  0007871b           sext.w a4,a5
    84f4:  00eff7b7           lui a5,0xeff
    84f8:  80078793           addi a5,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    84fc:  02f70963           beq a4,a5,852e <rtc_brom_debug+0x106>
    8500:  fe842703           lw a4,-24(s0)
    8504:  77e1                 lui a5,0xffff8
    8506:  8ff9                 and a5,a5,a4
    8508:  fef42423           sw a5,-24(s0)
    850c:  fd842783           lw a5,-40(s0)
    8510:  00c7979b           slliw a5,a5,0xc
    8514:  0007871b           sext.w a4,a5
    8518:  fe842783           lw a5,-24(s0)
    851c:  8fd9                 or a5,a5,a4
    851e:  fef42423           sw a5,-24(s0)
    8522:  fec46783           lwu a5,-20(s0)
    8526:  873e                 mv a4,a5
    8528:  fe842783           lw a5,-24(s0)
    852c:  c31c                 sw a5,0(a4)
    852e:  fd442783           lw a5,-44(s0)
    8532:  0007871b           sext.w a4,a5
    8536:  00eff7b7           lui a5,0xeff
    853a:  80078793           addi a5,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    853e:  0cf70663           beq a4,a5,860a <rtc_brom_debug+0x1e2>
    8542:  fec46783           lwu a5,-20(s0)
    8546:  439c                 lw a5,0(a5)
    8548:  fef42423           sw a5,-24(s0)
    854c:  fe842703           lw a4,-24(s0)
    8550:  77fd                 lui a5,0xfffff
    8552:  8ff9                 and a5,a5,a4
    8554:  fef42423           sw a5,-24(s0)
    8558:  fe842703           lw a4,-24(s0)
    855c:  fd442783           lw a5,-44(s0)
    8560:  8fd9                 or a5,a5,a4
    8562:  fef42423           sw a5,-24(s0)
    8566:  fec46783           lwu a5,-20(s0)
    856a:  873e                 mv a4,a5
    856c:  fe842783           lw a5,-24(s0)
    8570:  c31c                 sw a5,0(a4)
    8572:  a861                 j 860a <rtc_brom_debug+0x1e2>
    8574:  fd842783           lw a5,-40(s0)
    8578:  0007871b           sext.w a4,a5
    857c:  00eff7b7           lui a5,0xeff
    8580:  80078793           addi a5,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    8584:  02f70b63           beq a4,a5,85ba <rtc_brom_debug+0x192>
    8588:  fe842703           lw a4,-24(s0)
    858c:  800107b7           lui a5,0x80010
    8590:  17fd                 addi a5,a5,-1
    8592:  8ff9                 and a5,a5,a4
    8594:  fef42423           sw a5,-24(s0)
    8598:  fd842783           lw a5,-40(s0)
    859c:  01c7979b           slliw a5,a5,0x1c
    85a0:  0007871b           sext.w a4,a5
    85a4:  fe842783           lw a5,-24(s0)
    85a8:  8fd9                 or a5,a5,a4
    85aa:  fef42423           sw a5,-24(s0)
    85ae:  fec46783           lwu a5,-20(s0)
    85b2:  873e                 mv a4,a5
    85b4:  fe842783           lw a5,-24(s0)
    85b8:  c31c                 sw a5,0(a4)
    85ba:  fd442783           lw a5,-44(s0)
    85be:  0007871b           sext.w a4,a5
    85c2:  00eff7b7           lui a5,0xeff
    85c6:  80078793           addi a5,a5,-2048 # efe800 <gpio_get_boot_device+0xef046a
    85ca:  04f70063           beq a4,a5,860a <rtc_brom_debug+0x1e2>
    85ce:  fec46783           lwu a5,-20(s0)
    85d2:  439c                 lw a5,0(a5)
    85d4:  fef42423           sw a5,-24(s0)
    85d8:  fe842703           lw a4,-24(s0)
    85dc:  f00107b7           lui a5,0xf0010
    85e0:  17fd                 addi a5,a5,-1
    85e2:  8ff9                 and a5,a5,a4
    85e4:  fef42423           sw a5,-24(s0)
    85e8:  fd442783           lw a5,-44(s0)
    85ec:  0107979b           slliw a5,a5,0x10
    85f0:  0007871b           sext.w a4,a5
    85f4:  fe842783           lw a5,-24(s0)
    85f8:  8fd9                 or a5,a5,a4
    85fa:  fef42423           sw a5,-24(s0)
    85fe:  fec46783           lwu a5,-20(s0)
    8602:  873e                 mv a4,a5
    8604:  fe842783           lw a5,-24(s0)
    8608:  c31c                 sw a5,0(a4)
    860a:  0001                 nop
    860c:  7422                 ld s0,40(sp)
    860e:  6145                 addi sp,sp,48
    8610:  8082                 ret
0000000000008612 <boot0_check_magic>:
    8612:  7139                 addi sp,sp,-64
    8614:  fc22                 sd s0,56(sp)
    8616:  0080                 addi s0,sp,64
    8618:  fca43423           sd a0,-56(s0)
    861c:  fcb43023           sd a1,-64(s0)
    8620:  fc043c23           sd zero,-40(s0)
    8624:  fc043823           sd zero,-48(s0)
    8628:  000487b7           lui a5,0x48
    862c:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    8630:  cf89                 beqz a5,864a <boot0_check_magic+0x38>
    8632:  fc843783           ld a5,-56(s0)
    8636:  fcf43823           sd a5,-48(s0)
    863a:  fd043783           ld a5,-48(s0)
    863e:  fef43023           sd a5,-32(s0)
    8642:  47a1                 li a5,8
    8644:  fef42423           sw a5,-24(s0)
    8648:  a829                 j 8662 <boot0_check_magic+0x50>
    864a:  fc843783           ld a5,-56(s0)
    864e:  fcf43c23           sd a5,-40(s0)
    8652:  fd843783           ld a5,-40(s0)
    8656:  0791                 addi a5,a5,4
    8658:  fef43023           sd a5,-32(s0)
    865c:  47a1                 li a5,8
    865e:  fef42423           sw a5,-24(s0)
    8662:  fe042623           sw zero,-20(s0)
    8666:  a81d                 j 869c <boot0_check_magic+0x8a>
    8668:  fe043783           ld a5,-32(s0)
    866c:  00178713           addi a4,a5,1
    8670:  fee43023           sd a4,-32(s0)
    8674:  0007c683           lbu a3,0(a5)
    8678:  fc043783           ld a5,-64(s0)
    867c:  00178713           addi a4,a5,1
    8680:  fce43023           sd a4,-64(s0)
    8684:  0007c783           lbu a5,0(a5)
    8688:  8736                 mv a4,a3
    868a:  00f70463           beq a4,a5,8692 <boot0_check_magic+0x80>
    868e:  4785                 li a5,1
    8690:  a839                 j 86ae <boot0_check_magic+0x9c>
    8692:  fec42783           lw a5,-20(s0)
    8696:  2785                 addiw a5,a5,1
    8698:  fef42623           sw a5,-20(s0)
    869c:  fec42703           lw a4,-20(s0)
    86a0:  fe842783           lw a5,-24(s0)
    86a4:  2701                 sext.w a4,a4
    86a6:  2781                 sext.w a5,a5
    86a8:  fcf760e3           bltu a4,a5,8668 <boot0_check_magic+0x56>
    86ac:  4781                 li a5,0
    86ae:  853e                 mv a0,a5
    86b0:  7462                 ld s0,56(sp)
    86b2:  6121                 addi sp,sp,64
    86b4:  8082                 ret
00000000000086b6 <FUN_000086b6>:
    86b6:  715d                 addi sp,sp,-80
    86b8:  e4a2                 sd s0,72(sp)
    86ba:  0880                 addi s0,sp,80
    86bc:  faa43c23           sd a0,-72(s0)
    86c0:  87ae                 mv a5,a1
    86c2:  faf42a23           sw a5,-76(s0)
    86c6:  fc043823           sd zero,-48(s0)
    86ca:  fc043423           sd zero,-56(s0)
    86ce:  000487b7           lui a5,0x48
    86d2:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    86d6:  c7b5                 beqz a5,8742 <FUN_000086b6+0x8c>
    86d8:  fb843783           ld a5,-72(s0)
    86dc:  fcf43423           sd a5,-56(s0)
    86e0:  fc843783           ld a5,-56(s0)
    86e4:  00c7c703           lbu a4,12(a5)
    86e8:  00d7c683           lbu a3,13(a5)
    86ec:  06a2                 slli a3,a3,0x8
    86ee:  8f55                 or a4,a4,a3
    86f0:  00e7c683           lbu a3,14(a5)
    86f4:  06c2                 slli a3,a3,0x10
    86f6:  8f55                 or a4,a4,a3
    86f8:  00f7c783           lbu a5,15(a5)
    86fc:  07e2                 slli a5,a5,0x18
    86fe:  8fd9                 or a5,a5,a4
    8700:  fef42023           sw a5,-32(s0)
    8704:  fc843783           ld a5,-56(s0)
    8708:  00c7c703           lbu a4,12(a5)
    870c:  8b01                 andi a4,a4,0
    870e:  03976713           ori a4,a4,57
    8712:  00e78623           sb a4,12(a5)
    8716:  00d7c703           lbu a4,13(a5)
    871a:  8b01                 andi a4,a4,0
    871c:  06c76713           ori a4,a4,108
    8720:  00e786a3           sb a4,13(a5)
    8724:  00e7c703           lbu a4,14(a5)
    8728:  8b01                 andi a4,a4,0
    872a:  00a76713           ori a4,a4,10
    872e:  00e78723           sb a4,14(a5)
    8732:  00f7c703           lbu a4,15(a5)
    8736:  8b01                 andi a4,a4,0
    8738:  05f76713           ori a4,a4,95
    873c:  00e787a3           sb a4,15(a5)
    8740:  a00d                 j 8762 <FUN_000086b6+0xac>
    8742:  fb843783           ld a5,-72(s0)
    8746:  fcf43823           sd a5,-48(s0)
    874a:  fd043783           ld a5,-48(s0)
    874e:  47dc                 lw a5,12(a5)
    8750:  fef42023           sw a5,-32(s0)
    8754:  fd043783           ld a5,-48(s0)
    8758:  5f0a7737           lui a4,0x5f0a7
    875c:  c397071b           addiw a4,a4,-967
    8760:  c7d8                 sw a4,12(a5)
    8762:  fb442783           lw a5,-76(s0)
    8766:  0027d79b           srliw a5,a5,0x2
    876a:  fef42223           sw a5,-28(s0)
    876e:  fc042e23           sw zero,-36(s0)
    8772:  fb843783           ld a5,-72(s0)
    8776:  fef43423           sd a5,-24(s0)
    877a:  fe843783           ld a5,-24(s0)
    877e:  00478713           addi a4,a5,4
    8782:  fee43423           sd a4,-24(s0)
    8786:  439c                 lw a5,0(a5)
    8788:  fdc42703           lw a4,-36(s0)
    878c:  9fb9                 addw a5,a5,a4
    878e:  fcf42e23           sw a5,-36(s0)
    8792:  fe843783           ld a5,-24(s0)
    8796:  00478713           addi a4,a5,4
    879a:  fee43423           sd a4,-24(s0)
    879e:  439c                 lw a5,0(a5)
    87a0:  fdc42703           lw a4,-36(s0)
    87a4:  9fb9                 addw a5,a5,a4
    87a6:  fcf42e23           sw a5,-36(s0)
    87aa:  fe843783           ld a5,-24(s0)
    87ae:  00478713           addi a4,a5,4
    87b2:  fee43423           sd a4,-24(s0)
    87b6:  439c                 lw a5,0(a5)
    87b8:  fdc42703           lw a4,-36(s0)
    87bc:  9fb9                 addw a5,a5,a4
    87be:  fcf42e23           sw a5,-36(s0)
    87c2:  fe843783           ld a5,-24(s0)
    87c6:  00478713           addi a4,a5,4
    87ca:  fee43423           sd a4,-24(s0)
    87ce:  439c                 lw a5,0(a5)
    87d0:  fdc42703           lw a4,-36(s0)
    87d4:  9fb9                 addw a5,a5,a4
    87d6:  fcf42e23           sw a5,-36(s0)
    87da:  fe442783           lw a5,-28(s0)
    87de:  37f1                 addiw a5,a5,-4
    87e0:  fef42223           sw a5,-28(s0)
    87e4:  fe442783           lw a5,-28(s0)
    87e8:  0007871b           sext.w a4,a5
    87ec:  478d                 li a5,3
    87ee:  f8e7e6e3           bltu a5,a4,877a <FUN_000086b6+0xc4>
    87f2:  a829                 j 880c <FUN_000086b6+0x156>
    87f4:  fe843783           ld a5,-24(s0)
    87f8:  00478713           addi a4,a5,4
    87fc:  fee43423           sd a4,-24(s0)
    8800:  439c                 lw a5,0(a5)
    8802:  fdc42703           lw a4,-36(s0)
    8806:  9fb9                 addw a5,a5,a4
    8808:  fcf42e23           sw a5,-36(s0)
    880c:  fe442783           lw a5,-28(s0)
    8810:  fff7871b           addiw a4,a5,-1
    8814:  fee42223           sw a4,-28(s0)
    8818:  fff1                 bnez a5,87f4 <FUN_000086b6+0x13e>
    881a:  000487b7           lui a5,0x48
    881e:  e107a783           lw a5,-496(a5) # 47e10 <gpio_get_boot_device+0x39a7a>
    8822:  cfbd                 beqz a5,88a0 <FUN_000086b6+0x1ea>
    8824:  fc843783           ld a5,-56(s0)
    8828:  fe046703           lwu a4,-32(s0)
    882c:  0ff77613           andi a2,a4,255
    8830:  00c7c703           lbu a4,12(a5)
    8834:  8b01                 andi a4,a4,0
    8836:  86ba                 mv a3,a4
    8838:  8732                 mv a4,a2
    883a:  8f55                 or a4,a4,a3
    883c:  00e78623           sb a4,12(a5)
    8840:  fe042703           lw a4,-32(s0)
    8844:  0087571b           srliw a4,a4,0x8
    8848:  1702                 slli a4,a4,0x20
    884a:  9301                 srli a4,a4,0x20
    884c:  0ff77613           andi a2,a4,255
    8850:  00d7c703           lbu a4,13(a5)
    8854:  8b01                 andi a4,a4,0
    8856:  86ba                 mv a3,a4
    8858:  8732                 mv a4,a2
    885a:  8f55                 or a4,a4,a3
    885c:  00e786a3           sb a4,13(a5)
    8860:  fe042703           lw a4,-32(s0)
    8864:  0107571b           srliw a4,a4,0x10
    8868:  1702                 slli a4,a4,0x20
    886a:  9301                 srli a4,a4,0x20
    886c:  0ff77613           andi a2,a4,255
    8870:  00e7c703           lbu a4,14(a5)
    8874:  8b01                 andi a4,a4,0
    8876:  86ba                 mv a3,a4
    8878:  8732                 mv a4,a2
    887a:  8f55                 or a4,a4,a3
    887c:  00e78723           sb a4,14(a5)
    8880:  fe042703           lw a4,-32(s0)
    8884:  0187571b           srliw a4,a4,0x18
    8888:  02071613           slli a2,a4,0x20
    888c:  9201                 srli a2,a2,0x20
    888e:  00f7c703           lbu a4,15(a5)
    8892:  8b01                 andi a4,a4,0
    8894:  86ba                 mv a3,a4
    8896:  8732                 mv a4,a2
    8898:  8f55                 or a4,a4,a3
    889a:  00e787a3           sb a4,15(a5)
    889e:  a031                 j 88aa <FUN_000086b6+0x1f4>
    88a0:  fd043783           ld a5,-48(s0)
    88a4:  fe042703           lw a4,-32(s0)
    88a8:  c7d8                 sw a4,12(a5)
    88aa:  fdc42703           lw a4,-36(s0)
    88ae:  fe042783           lw a5,-32(s0)
    88b2:  2701                 sext.w a4,a4
    88b4:  2781                 sext.w a5,a5
    88b6:  00f71463           bne a4,a5,88be <FUN_000086b6+0x208>
    88ba:  4781                 li a5,0
    88bc:  a011                 j 88c0 <FUN_000086b6+0x20a>
    88be:  4785                 li a5,1
    88c0:  853e                 mv a0,a5
    88c2:  6426                 ld s0,72(sp)
    88c4:  6161                 addi sp,sp,80
    88c6:  8082                 ret
00000000000088c8 <FUN_000088c8>:
    88c8:  7139                 addi sp,sp,-64
    88ca:  fc22                 sd s0,56(sp)
    88cc:  0080                 addi s0,sp,64
    88ce:  fca43423           sd a0,-56(s0)
    88d2:  fcb43023           sd a1,-64(s0)
    88d6:  fc843783           ld a5,-56(s0)
    88da:  fcf43c23           sd a5,-40(s0)
    88de:  fd843783           ld a5,-40(s0)
    88e2:  0791                 addi a5,a5,4
    88e4:  fef43023           sd a5,-32(s0)
    88e8:  fe042623           sw zero,-20(s0)
    88ec:  47a1                 li a5,8
    88ee:  fcf42a23           sw a5,-44(s0)
    88f2:  a81d                 j 8928 <FUN_000088c8+0x60>
    88f4:  fe043783           ld a5,-32(s0)
    88f8:  00178713           addi a4,a5,1
    88fc:  fee43023           sd a4,-32(s0)
    8900:  0007c683           lbu a3,0(a5)
    8904:  fc043783           ld a5,-64(s0)
    8908:  00178713           addi a4,a5,1
    890c:  fce43023           sd a4,-64(s0)
    8910:  0007c783           lbu a5,0(a5)
    8914:  8736                 mv a4,a3
    8916:  00f70463           beq a4,a5,891e <FUN_000088c8+0x56>
    891a:  4785                 li a5,1
    891c:  a839                 j 893a <FUN_000088c8+0x72>
    891e:  fec42783           lw a5,-20(s0)
    8922:  2785                 addiw a5,a5,1
    8924:  fef42623           sw a5,-20(s0)
    8928:  fec42703           lw a4,-20(s0)
    892c:  fd442783           lw a5,-44(s0)
    8930:  2701                 sext.w a4,a4
    8932:  2781                 sext.w a5,a5
    8934:  fcf760e3           bltu a4,a5,88f4 <FUN_000088c8+0x2c>
    8938:  4781                 li a5,0
    893a:  853e                 mv a0,a5
    893c:  7462                 ld s0,56(sp)
    893e:  6121                 addi sp,sp,64
    8940:  8082                 ret
0000000000008942 <FUN_00008942>:
    8942:  7139                 addi sp,sp,-64
    8944:  fc22                 sd s0,56(sp)
    8946:  0080                 addi s0,sp,64
    8948:  fca43423           sd a0,-56(s0)
    894c:  87ae                 mv a5,a1
    894e:  fcf42223           sw a5,-60(s0)
    8952:  fc843783           ld a5,-56(s0)
    8956:  fcf43c23           sd a5,-40(s0)
    895a:  fd843783           ld a5,-40(s0)
    895e:  47dc                 lw a5,12(a5)
    8960:  fcf42a23           sw a5,-44(s0)
    8964:  fd843783           ld a5,-40(s0)
    8968:  5f0a7737           lui a4,0x5f0a7
    896c:  c397071b           addiw a4,a4,-967
    8970:  c7d8                 sw a4,12(a5)
    8972:  fc442783           lw a5,-60(s0)
    8976:  0027d79b           srliw a5,a5,0x2
    897a:  fef42223           sw a5,-28(s0)
    897e:  fe042023           sw zero,-32(s0)
    8982:  fc843783           ld a5,-56(s0)
    8986:  fef43423           sd a5,-24(s0)
    898a:  fe843783           ld a5,-24(s0)
    898e:  00478713           addi a4,a5,4
    8992:  fee43423           sd a4,-24(s0)
    8996:  439c                 lw a5,0(a5)
    8998:  fe042703           lw a4,-32(s0)
    899c:  9fb9                 addw a5,a5,a4
    899e:  fef42023           sw a5,-32(s0)
    89a2:  fe843783           ld a5,-24(s0)
    89a6:  00478713           addi a4,a5,4
    89aa:  fee43423           sd a4,-24(s0)
    89ae:  439c                 lw a5,0(a5)
    89b0:  fe042703           lw a4,-32(s0)
    89b4:  9fb9                 addw a5,a5,a4
    89b6:  fef42023           sw a5,-32(s0)
    89ba:  fe843783           ld a5,-24(s0)
    89be:  00478713           addi a4,a5,4
    89c2:  fee43423           sd a4,-24(s0)
    89c6:  439c                 lw a5,0(a5)
    89c8:  fe042703           lw a4,-32(s0)
    89cc:  9fb9                 addw a5,a5,a4
    89ce:  fef42023           sw a5,-32(s0)
    89d2:  fe843783           ld a5,-24(s0)
    89d6:  00478713           addi a4,a5,4
    89da:  fee43423           sd a4,-24(s0)
    89de:  439c                 lw a5,0(a5)
    89e0:  fe042703           lw a4,-32(s0)
    89e4:  9fb9                 addw a5,a5,a4
    89e6:  fef42023           sw a5,-32(s0)
    89ea:  fe442783           lw a5,-28(s0)
    89ee:  37f1                 addiw a5,a5,-4
    89f0:  fef42223           sw a5,-28(s0)
    89f4:  fe442783           lw a5,-28(s0)
    89f8:  0007871b           sext.w a4,a5
    89fc:  478d                 li a5,3
    89fe:  f8e7e6e3           bltu a5,a4,898a <FUN_00008942+0x48>
    8a02:  a829                 j 8a1c <FUN_00008942+0xda>
    8a04:  fe843783           ld a5,-24(s0)
    8a08:  00478713           addi a4,a5,4
    8a0c:  fee43423           sd a4,-24(s0)
    8a10:  439c                 lw a5,0(a5)
    8a12:  fe042703           lw a4,-32(s0)
    8a16:  9fb9                 addw a5,a5,a4
    8a18:  fef42023           sw a5,-32(s0)
    8a1c:  fe442783           lw a5,-28(s0)
    8a20:  fff7871b           addiw a4,a5,-1
    8a24:  fee42223           sw a4,-28(s0)
    8a28:  fff1                 bnez a5,8a04 <FUN_00008942+0xc2>
    8a2a:  fd843783           ld a5,-40(s0)
    8a2e:  fd442703           lw a4,-44(s0)
    8a32:  c7d8                 sw a4,12(a5)
    8a34:  fe042703           lw a4,-32(s0)
    8a38:  fd442783           lw a5,-44(s0)
    8a3c:  2701                 sext.w a4,a4
    8a3e:  2781                 sext.w a5,a5
    8a40:  00f71463           bne a4,a5,8a48 <FUN_00008942+0x106>
    8a44:  4781                 li a5,0
    8a46:  a011                 j 8a4a <FUN_00008942+0x108>
    8a48:  4785                 li a5,1
    8a4a:  853e                 mv a0,a5
    8a4c:  7462                 ld s0,56(sp)
    8a4e:  6121                 addi sp,sp,64
    8a50:  8082                 ret
0000000000008a52 <FUN_00008a52>:
    8a52:  7179                 addi sp,sp,-48
    8a54:  f406                 sd ra,40(sp)
    8a56:  f022                 sd s0,32(sp)
    8a58:  1800                 addi s0,sp,48
    8a5a:  fea43423           sd a0,-24(s0)
    8a5e:  87ae                 mv a5,a1
    8a60:  fcc43c23           sd a2,-40(s0)
    8a64:  fef42223           sw a5,-28(s0)
    8a68:  fd843583           ld a1,-40(s0)
    8a6c:  fe843503           ld a0,-24(s0)
    8a70:  ba3ff0ef           jal ra,8612 <boot0_check_magic>
    8a74:  87aa                 mv a5,a0
    8a76:  ef81                 bnez a5,8a8e <FUN_00008a52+0x3c>
    8a78:  fe442783           lw a5,-28(s0)
    8a7c:  85be                 mv a1,a5
    8a7e:  fe843503           ld a0,-24(s0)
    8a82:  c35ff0ef           jal ra,86b6 <FUN_000086b6>
    8a86:  87aa                 mv a5,a0
    8a88:  e399                 bnez a5,8a8e <FUN_00008a52+0x3c>
    8a8a:  4781                 li a5,0
    8a8c:  a011                 j 8a90 <FUN_00008a52+0x3e>
    8a8e:  4785                 li a5,1
    8a90:  853e                 mv a0,a5
    8a92:  70a2                 ld ra,40(sp)
    8a94:  7402                 ld s0,32(sp)
    8a96:  6145                 addi sp,sp,48
    8a98:  8082                 ret
0000000000008a9a <ccu_enable_pll_lock>:
    8a9a:  7139                 addi sp,sp,-64
    8a9c:  fc06                 sd ra,56(sp)
    8a9e:  f822                 sd s0,48(sp)
    8aa0:  0080                 addi s0,sp,64
    8aa2:  87aa                 mv a5,a0
    8aa4:  86ae                 mv a3,a1
    8aa6:  8732                 mv a4,a2
    8aa8:  fcf42623           sw a5,-52(s0)
    8aac:  87b6                 mv a5,a3
    8aae:  fcf42423           sw a5,-56(s0)
    8ab2:  87ba                 mv a5,a4
    8ab4:  fcf42223           sw a5,-60(s0)
    8ab8:  fe042623           sw zero,-20(s0)
    8abc:  fe043023           sd zero,-32(s0)
    8ac0:  fc043c23           sd zero,-40(s0)
    8ac4:  fc043823           sd zero,-48(s0)
    8ac8:  fcc46783           lwu a5,-52(s0)
    8acc:  439c                 lw a5,0(a5)
    8ace:  fef42623           sw a5,-20(s0)
    8ad2:  fc842783           lw a5,-56(s0)
    8ad6:  4705                 li a4,1
    8ad8:  00f717bb           sllw a5,a4,a5
    8adc:  2781                 sext.w a5,a5
    8ade:  0007871b           sext.w a4,a5
    8ae2:  fec42783           lw a5,-20(s0)
    8ae6:  8fd9                 or a5,a5,a4
    8ae8:  fef42623           sw a5,-20(s0)
    8aec:  fcc46783           lwu a5,-52(s0)
    8af0:  873e                 mv a4,a5
    8af2:  fec42783           lw a5,-20(s0)
    8af6:  c31c                 sw a5,0(a4)
    8af8:  0024a7b7           lui a5,0x24a
    8afc:  f0078793           addi a5,a5,-256 # 249f00 <gpio_get_boot_device+0x23bb6a>
    8b00:  fcf43823           sd a5,-48(s0)
    8b04:  67a010ef           jal ra,a17e <rdtime>
    8b08:  fea43023           sd a0,-32(s0)
    8b0c:  fcc46783           lwu a5,-52(s0)
    8b10:  439c                 lw a5,0(a5)
    8b12:  fef42623           sw a5,-20(s0)
    8b16:  fc442783           lw a5,-60(s0)
    8b1a:  4705                 li a4,1
    8b1c:  00f717bb           sllw a5,a4,a5
    8b20:  2781                 sext.w a5,a5
    8b22:  0007871b           sext.w a4,a5
    8b26:  fec42783           lw a5,-20(s0)
    8b2a:  8ff9                 and a5,a5,a4
    8b2c:  fef42623           sw a5,-20(s0)
    8b30:  fec42783           lw a5,-20(s0)
    8b34:  2781                 sext.w a5,a5
    8b36:  c399                 beqz a5,8b3c <ccu_enable_pll_lock+0xa2>
    8b38:  4781                 li a5,0
    8b3a:  a00d                 j 8b5c <ccu_enable_pll_lock+0xc2>
    8b3c:  642010ef           jal ra,a17e <rdtime>
    8b40:  872a                 mv a4,a0
    8b42:  fe043783           ld a5,-32(s0)
    8b46:  40f707b3           sub a5,a4,a5
    8b4a:  fcf43c23           sd a5,-40(s0)
    8b4e:  fd843703           ld a4,-40(s0)
    8b52:  fd043783           ld a5,-48(s0)
    8b56:  faf76be3           bltu a4,a5,8b0c <ccu_enable_pll_lock+0x72>
    8b5a:  57fd                 li a5,-1
    8b5c:  853e                 mv a0,a5
    8b5e:  70e2                 ld ra,56(sp)
    8b60:  7442                 ld s0,48(sp)
    8b62:  6121                 addi sp,sp,64
    8b64:  8082                 ret
0000000000008b66 <ccu_disable_pll_lock_output>:
    8b66:  7179                 addi sp,sp,-48
    8b68:  f422                 sd s0,40(sp)
    8b6a:  1800                 addi s0,sp,48
    8b6c:  87aa                 mv a5,a0
    8b6e:  fcf42e23           sw a5,-36(s0)
    8b72:  fe042623           sw zero,-20(s0)
    8b76:  fdc46783           lwu a5,-36(s0)
    8b7a:  439c                 lw a5,0(a5)
    8b7c:  fef42623           sw a5,-20(s0)
    8b80:  fec42703           lw a4,-20(s0)
    8b84:  580007b7           lui a5,0x58000
    8b88:  17fd                 addi a5,a5,-1
    8b8a:  8ff9                 and a5,a5,a4
    8b8c:  fef42623           sw a5,-20(s0)
    8b90:  fdc46783           lwu a5,-36(s0)
    8b94:  873e                 mv a4,a5
    8b96:  fec42783           lw a5,-20(s0)
    8b9a:  c31c                 sw a5,0(a4)
    8b9c:  0001                 nop
    8b9e:  7422                 ld s0,40(sp)
    8ba0:  6145                 addi sp,sp,48
    8ba2:  8082                 ret
0000000000008ba4 <ccu_enable_pll_output>:
    8ba4:  7179                 addi sp,sp,-48
    8ba6:  f422                 sd s0,40(sp)
    8ba8:  1800                 addi s0,sp,48
    8baa:  87aa                 mv a5,a0
    8bac:  fcf42e23           sw a5,-36(s0)
    8bb0:  fe042623           sw zero,-20(s0)
    8bb4:  fdc46783           lwu a5,-36(s0)
    8bb8:  439c                 lw a5,0(a5)
    8bba:  fef42623           sw a5,-20(s0)
    8bbe:  fec42703           lw a4,-20(s0)
    8bc2:  080007b7           lui a5,0x8000
    8bc6:  8fd9                 or a5,a5,a4
    8bc8:  fef42623           sw a5,-20(s0)
    8bcc:  fdc46783           lwu a5,-36(s0)
    8bd0:  873e                 mv a4,a5
    8bd2:  fec42783           lw a5,-20(s0)
    8bd6:  c31c                 sw a5,0(a4)
    8bd8:  0001                 nop
    8bda:  7422                 ld s0,40(sp)
    8bdc:  6145                 addi sp,sp,48
    8bde:  8082                 ret
0000000000008be0 <ccu_enable_pll_ldo>:
    8be0:  7179                 addi sp,sp,-48
    8be2:  f406                 sd ra,40(sp)
    8be4:  f022                 sd s0,32(sp)
    8be6:  1800                 addi s0,sp,48
    8be8:  87aa                 mv a5,a0
    8bea:  fcf42e23           sw a5,-36(s0)
    8bee:  fe042623           sw zero,-20(s0)
    8bf2:  fdc46783           lwu a5,-36(s0)
    8bf6:  439c                 lw a5,0(a5)
    8bf8:  fef42623           sw a5,-20(s0)
    8bfc:  fec42703           lw a4,-20(s0)
    8c00:  400007b7           lui a5,0x40000
    8c04:  8fd9                 or a5,a5,a4
    8c06:  fef42623           sw a5,-20(s0)
    8c0a:  fdc46783           lwu a5,-36(s0)
    8c0e:  873e                 mv a4,a5
    8c10:  fec42783           lw a5,-20(s0)
    8c14:  c31c                 sw a5,0(a4)
    8c16:  4515                 li a0,5
    8c18:  56c010ef           jal ra,a184 <udelay>
    8c1c:  0001                 nop
    8c1e:  70a2                 ld ra,40(sp)
    8c20:  7402                 ld s0,32(sp)
    8c22:  6145                 addi sp,sp,48
    8c24:  8082                 ret
0000000000008c26 <ccu_enable_pll_cpux>:
    8c26:  7179                 addi sp,sp,-48
    8c28:  f406                 sd ra,40(sp)
    8c2a:  f022                 sd s0,32(sp)
    8c2c:  1800                 addi s0,sp,48
    8c2e:  87aa                 mv a5,a0
    8c30:  fcf42e23           sw a5,-36(s0)
    8c34:  fe042623           sw zero,-20(s0)
    8c38:  fe042423           sw zero,-24(s0)
    8c3c:  02001537           lui a0,0x2001
    8c40:  fa1ff0ef           jal ra,8be0 <ccu_enable_pll_ldo>
    8c44:  02001537           lui a0,0x2001
    8c48:  f1fff0ef           jal ra,8b66 <ccu_disable_pll_lock_output>
    8c4c:  020017b7           lui a5,0x2001
    8c50:  439c                 lw a5,0(a5)
    8c52:  fef42623           sw a5,-20(s0)
    8c56:  fec42703           lw a4,-20(s0)
    8c5a:  77c1                 lui a5,0xffff0
    8c5c:  0fc78793           addi a5,a5,252 # ffffffffffff00fc <gpio_get_boot_device+
    8c60:  8ff9                 and a5,a5,a4
    8c62:  fef42623           sw a5,-20(s0)
    8c66:  fdc42783           lw a5,-36(s0)
    8c6a:  0087979b           slliw a5,a5,0x8
    8c6e:  0007871b           sext.w a4,a5
    8c72:  fec42783           lw a5,-20(s0)
    8c76:  8fd9                 or a5,a5,a4
    8c78:  fef42623           sw a5,-20(s0)
    8c7c:  020017b7           lui a5,0x2001
    8c80:  fec42703           lw a4,-20(s0)
    8c84:  c398                 sw a4,0(a5)
    8c86:  4529                 li a0,10
    8c88:  4fc010ef           jal ra,a184 <udelay>
    8c8c:  020017b7           lui a5,0x2001
    8c90:  439c                 lw a5,0(a5)
    8c92:  fef42623           sw a5,-20(s0)
    8c96:  fec42703           lw a4,-20(s0)
    8c9a:  800007b7           lui a5,0x80000
    8c9e:  8fd9                 or a5,a5,a4
    8ca0:  fef42623           sw a5,-20(s0)
    8ca4:  020017b7           lui a5,0x2001
    8ca8:  fec42703           lw a4,-20(s0)
    8cac:  c398                 sw a4,0(a5)
    8cae:  4529                 li a0,10
    8cb0:  4d4010ef           jal ra,a184 <udelay>
    8cb4:  4671                 li a2,28
    8cb6:  45f5                 li a1,29
    8cb8:  02001537           lui a0,0x2001
    8cbc:  ddfff0ef           jal ra,8a9a <ccu_enable_pll_lock>
    8cc0:  87aa                 mv a5,a0
    8cc2:  fef42423           sw a5,-24(s0)
    8cc6:  fe842783           lw a5,-24(s0)
    8cca:  2781                 sext.w a5,a5
    8ccc:  0007d463           bgez a5,8cd4 <ccu_enable_pll_cpux+0xae>
    8cd0:  57fd                 li a5,-1
    8cd2:  a809                 j 8ce4 <ccu_enable_pll_cpux+0xbe>
    8cd4:  02001537           lui a0,0x2001
    8cd8:  ecdff0ef           jal ra,8ba4 <ccu_enable_pll_output>
    8cdc:  4529                 li a0,10
    8cde:  4a6010ef           jal ra,a184 <udelay>
    8ce2:  4781                 li a5,0
    8ce4:  853e                 mv a0,a5
    8ce6:  70a2                 ld ra,40(sp)
    8ce8:  7402                 ld s0,32(sp)
    8cea:  6145                 addi sp,sp,48
    8cec:  8082                 ret
0000000000008cee <FUN_00008cee>:
    8cee:  1101                 addi sp,sp,-32
    8cf0:  ec06                 sd ra,24(sp)
    8cf2:  e822                 sd s0,16(sp)
    8cf4:  1000                 addi s0,sp,32
    8cf6:  fe042623           sw zero,-20(s0)
    8cfa:  fe042423           sw zero,-24(s0)
    8cfe:  020017b7           lui a5,0x2001
    8d02:  02078513           addi a0,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d06:  edbff0ef           jal ra,8be0 <ccu_enable_pll_ldo>
    8d0a:  020017b7           lui a5,0x2001
    8d0e:  02078513           addi a0,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d12:  e55ff0ef           jal ra,8b66 <ccu_disable_pll_lock_output>
    8d16:  020017b7           lui a5,0x2001
    8d1a:  02078793           addi a5,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d1e:  439c                 lw a5,0(a5)
    8d20:  fef42623           sw a5,-20(s0)
    8d24:  fec42703           lw a4,-20(s0)
    8d28:  ffcc07b7           lui a5,0xffcc0
    8d2c:  0fd78793           addi a5,a5,253 # ffffffffffcc00fd <gpio_get_boot_device+
    8d30:  8ff9                 and a5,a5,a4
    8d32:  fef42623           sw a5,-20(s0)
    8d36:  fec42703           lw a4,-20(s0)
    8d3a:  002167b7           lui a5,0x216
    8d3e:  30078793           addi a5,a5,768 # 216300 <gpio_get_boot_device+0x207f6a>
    8d42:  8fd9                 or a5,a5,a4
    8d44:  fef42623           sw a5,-20(s0)
    8d48:  020017b7           lui a5,0x2001
    8d4c:  02078793           addi a5,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d50:  fec42703           lw a4,-20(s0)
    8d54:  c398                 sw a4,0(a5)
    8d56:  4529                 li a0,10
    8d58:  42c010ef           jal ra,a184 <udelay>
    8d5c:  020017b7           lui a5,0x2001
    8d60:  02078793           addi a5,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d64:  439c                 lw a5,0(a5)
    8d66:  fef42623           sw a5,-20(s0)
    8d6a:  fec42703           lw a4,-20(s0)
    8d6e:  800007b7           lui a5,0x80000
    8d72:  8fd9                 or a5,a5,a4
    8d74:  fef42623           sw a5,-20(s0)
    8d78:  020017b7           lui a5,0x2001
    8d7c:  02078793           addi a5,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d80:  fec42703           lw a4,-20(s0)
    8d84:  c398                 sw a4,0(a5)
    8d86:  4529                 li a0,10
    8d88:  3fc010ef           jal ra,a184 <udelay>
    8d8c:  4671                 li a2,28
    8d8e:  45f5                 li a1,29
    8d90:  020017b7           lui a5,0x2001
    8d94:  02078513           addi a0,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8d98:  d03ff0ef           jal ra,8a9a <ccu_enable_pll_lock>
    8d9c:  87aa                 mv a5,a0
    8d9e:  fef42423           sw a5,-24(s0)
    8da2:  fe842783           lw a5,-24(s0)
    8da6:  2781                 sext.w a5,a5
    8da8:  0007d463           bgez a5,8db0 <FUN_00008cee+0xc2>
    8dac:  57fd                 li a5,-1
    8dae:  a819                 j 8dc4 <FUN_00008cee+0xd6>
    8db0:  020017b7           lui a5,0x2001
    8db4:  02078513           addi a0,a5,32 # 2001020 <gpio_get_boot_device+0x1ff2c8a>
    8db8:  dedff0ef           jal ra,8ba4 <ccu_enable_pll_output>
    8dbc:  4529                 li a0,10
    8dbe:  3c6010ef           jal ra,a184 <udelay>
    8dc2:  4781                 li a5,0
    8dc4:  853e                 mv a0,a5
    8dc6:  60e2                 ld ra,24(sp)
    8dc8:  6442                 ld s0,16(sp)
    8dca:  6105                 addi sp,sp,32
    8dcc:  8082                 ret
0000000000008dce <FUN_00008dce>:
    8dce:  1101                 addi sp,sp,-32
    8dd0:  ec06                 sd ra,24(sp)
    8dd2:  e822                 sd s0,16(sp)
    8dd4:  1000                 addi s0,sp,32
    8dd6:  fe042623           sw zero,-20(s0)
    8dda:  fe042423           sw zero,-24(s0)
    8dde:  020017b7           lui a5,0x2001
    8de2:  01078513           addi a0,a5,16 # 2001010 <gpio_get_boot_device+0x1ff2c7a>
    8de6:  dfbff0ef           jal ra,8be0 <ccu_enable_pll_ldo>
    8dea:  020017b7           lui a5,0x2001
    8dee:  01078513           addi a0,a5,16 # 2001010 <gpio_get_boot_device+0x1ff2c7a>
    8df2:  d75ff0ef           jal ra,8b66 <ccu_disable_pll_lock_output>
    8df6:  020017b7           lui a5,0x2001
    8dfa:  07c1                 addi a5,a5,16
    8dfc:  439c                 lw a5,0(a5)
    8dfe:  fef42623           sw a5,-20(s0)
    8e02:  fec42703           lw a4,-20(s0)
    8e06:  77c1                 lui a5,0xffff0
    8e08:  0fc78793           addi a5,a5,252 # ffffffffffff00fc <gpio_get_boot_device+
    8e0c:  8ff9                 and a5,a5,a4
    8e0e:  fef42623           sw a5,-20(s0)
    8e12:  fec42703           lw a4,-20(s0)
    8e16:  6789                 lui a5,0x2
    8e18:  30178793           addi a5,a5,769 # 2301 <FUN_00002256+0xab>
    8e1c:  8fd9                 or a5,a5,a4
    8e1e:  fef42623           sw a5,-20(s0)
    8e22:  020017b7           lui a5,0x2001
    8e26:  07c1                 addi a5,a5,16
    8e28:  fec42703           lw a4,-20(s0)
    8e2c:  c398                 sw a4,0(a5)
    8e2e:  4515                 li a0,5
    8e30:  354010ef           jal ra,a184 <udelay>
    8e34:  020017b7           lui a5,0x2001
    8e38:  07c1                 addi a5,a5,16
    8e3a:  439c                 lw a5,0(a5)
    8e3c:  fef42623           sw a5,-20(s0)
    8e40:  fec42703           lw a4,-20(s0)
    8e44:  800007b7           lui a5,0x80000
    8e48:  8fd9                 or a5,a5,a4
    8e4a:  fef42623           sw a5,-20(s0)
    8e4e:  020017b7           lui a5,0x2001
    8e52:  07c1                 addi a5,a5,16
    8e54:  fec42703           lw a4,-20(s0)
    8e58:  c398                 sw a4,0(a5)
    8e5a:  4515                 li a0,5
    8e5c:  328010ef           jal ra,a184 <udelay>
    8e60:  4671                 li a2,28
    8e62:  45f5                 li a1,29
    8e64:  020017b7           lui a5,0x2001
    8e68:  01078513           addi a0,a5,16 # 2001010 <gpio_get_boot_device+0x1ff2c7a>
    8e6c:  c2fff0ef           jal ra,8a9a <ccu_enable_pll_lock>
    8e70:  87aa                 mv a5,a0
    8e72:  fef42423           sw a5,-24(s0)
    8e76:  fe842783           lw a5,-24(s0)
    8e7a:  2781                 sext.w a5,a5
    8e7c:  0007d463           bgez a5,8e84 <FUN_00008dce+0xb6>
    8e80:  57fd                 li a5,-1
    8e82:  a819                 j 8e98 <FUN_00008dce+0xca>
    8e84:  020017b7           lui a5,0x2001
    8e88:  01078513           addi a0,a5,16 # 2001010 <gpio_get_boot_device+0x1ff2c7a>
    8e8c:  d19ff0ef           jal ra,8ba4 <ccu_enable_pll_output>
    8e90:  4529                 li a0,10
    8e92:  2f2010ef           jal ra,a184 <udelay>
    8e96:  4781                 li a5,0
    8e98:  853e                 mv a0,a5
    8e9a:  60e2                 ld ra,24(sp)
    8e9c:  6442                 ld s0,16(sp)
    8e9e:  6105                 addi sp,sp,32
    8ea0:  8082                 ret
0000000000008ea2 <FUN_00008ea2>:
    8ea2:  1101                 addi sp,sp,-32
    8ea4:  ec06                 sd ra,24(sp)
    8ea6:  e822                 sd s0,16(sp)
    8ea8:  1000                 addi s0,sp,32
    8eaa:  fe042623           sw zero,-20(s0)
    8eae:  020027b7           lui a5,0x2002
    8eb2:  d0078793           addi a5,a5,-768 # 2001d00 <gpio_get_boot_device+0x1ff396
    8eb6:  439c                 lw a5,0(a5)
    8eb8:  fef42623           sw a5,-20(s0)
    8ebc:  fec42783           lw a5,-20(s0)
    8ec0:  ce07f793           andi a5,a5,-800
    8ec4:  fef42623           sw a5,-20(s0)
    8ec8:  fec42783           lw a5,-20(s0)
    8ecc:  1007e793           ori a5,a5,256
    8ed0:  fef42623           sw a5,-20(s0)
    8ed4:  020027b7           lui a5,0x2002
    8ed8:  d0078793           addi a5,a5,-768 # 2001d00 <gpio_get_boot_device+0x1ff396
    8edc:  fec42703           lw a4,-20(s0)
    8ee0:  c398                 sw a4,0(a5)
    8ee2:  4529                 li a0,10
    8ee4:  2a0010ef           jal ra,a184 <udelay>
    8ee8:  020027b7           lui a5,0x2002
    8eec:  d0078793           addi a5,a5,-768 # 2001d00 <gpio_get_boot_device+0x1ff396
    8ef0:  439c                 lw a5,0(a5)
    8ef2:  fef42623           sw a5,-20(s0)
    8ef6:  fec42703           lw a4,-20(s0)
    8efa:  f90007b7           lui a5,0xf9000
    8efe:  17fd                 addi a5,a5,-1
    8f00:  8ff9                 and a5,a5,a4
    8f02:  fef42623           sw a5,-20(s0)
    8f06:  fec42703           lw a4,-20(s0)
    8f0a:  050007b7           lui a5,0x5000
    8f0e:  8fd9                 or a5,a5,a4
    8f10:  fef42623           sw a5,-20(s0)
    8f14:  020027b7           lui a5,0x2002
    8f18:  d0078793           addi a5,a5,-768 # 2001d00 <gpio_get_boot_device+0x1ff396
    8f1c:  fec42703           lw a4,-20(s0)
    8f20:  c398                 sw a4,0(a5)
    8f22:  4529                 li a0,10
    8f24:  260010ef           jal ra,a184 <udelay>
    8f28:  0001                 nop
    8f2a:  60e2                 ld ra,24(sp)
    8f2c:  6442                 ld s0,16(sp)
    8f2e:  6105                 addi sp,sp,32
    8f30:  8082                 ret
0000000000008f32 <FUN_00008f32>:
    8f32:  7179                 addi sp,sp,-48
    8f34:  f406                 sd ra,40(sp)
    8f36:  f022                 sd s0,32(sp)
    8f38:  1800                 addi s0,sp,48
    8f3a:  87aa                 mv a5,a0
    8f3c:  fcf42e23           sw a5,-36(s0)
    8f40:  fe042623           sw zero,-20(s0)
    8f44:  020017b7           lui a5,0x2001
    8f48:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    8f4c:  439c                 lw a5,0(a5)
    8f4e:  fef42623           sw a5,-20(s0)
    8f52:  fec42783           lw a5,-20(s0)
    8f56:  cfc7f793           andi a5,a5,-772
    8f5a:  fef42623           sw a5,-20(s0)
    8f5e:  fdc42783           lw a5,-36(s0)
    8f62:  0087979b           slliw a5,a5,0x8
    8f66:  0007871b           sext.w a4,a5
    8f6a:  fec42783           lw a5,-20(s0)
    8f6e:  8fd9                 or a5,a5,a4
    8f70:  2781                 sext.w a5,a5
    8f72:  0027e793           ori a5,a5,2
    8f76:  fef42623           sw a5,-20(s0)
    8f7a:  020017b7           lui a5,0x2001
    8f7e:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    8f82:  fec42703           lw a4,-20(s0)
    8f86:  c398                 sw a4,0(a5)
    8f88:  4529                 li a0,10
    8f8a:  1fa010ef           jal ra,a184 <udelay>
    8f8e:  020017b7           lui a5,0x2001
    8f92:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    8f96:  439c                 lw a5,0(a5)
    8f98:  fef42623           sw a5,-20(s0)
    8f9c:  fec42703           lw a4,-20(s0)
    8fa0:  f90007b7           lui a5,0xf9000
    8fa4:  17fd                 addi a5,a5,-1
    8fa6:  8ff9                 and a5,a5,a4
    8fa8:  fef42623           sw a5,-20(s0)
    8fac:  fec42703           lw a4,-20(s0)
    8fb0:  030007b7           lui a5,0x3000
    8fb4:  8fd9                 or a5,a5,a4
    8fb6:  fef42623           sw a5,-20(s0)
    8fba:  020017b7           lui a5,0x2001
    8fbe:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    8fc2:  fec42703           lw a4,-20(s0)
    8fc6:  c398                 sw a4,0(a5)
    8fc8:  4529                 li a0,10
    8fca:  1ba010ef           jal ra,a184 <udelay>
    8fce:  0001                 nop
    8fd0:  70a2                 ld ra,40(sp)
    8fd2:  7402                 ld s0,32(sp)
    8fd4:  6145                 addi sp,sp,48
    8fd6:  8082                 ret
0000000000008fd8 <FUN_00008fd8>:
    8fd8:  1101                 addi sp,sp,-32
    8fda:  ec06                 sd ra,24(sp)
    8fdc:  e822                 sd s0,16(sp)
    8fde:  1000                 addi s0,sp,32
    8fe0:  fe042623           sw zero,-20(s0)
    8fe4:  020017b7           lui a5,0x2001
    8fe8:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    8fec:  439c                 lw a5,0(a5)
    8fee:  fef42623           sw a5,-20(s0)
    8ff2:  fec42783           lw a5,-20(s0)
    8ff6:  ce07f793           andi a5,a5,-800
    8ffa:  fef42623           sw a5,-20(s0)
    8ffe:  fec42783           lw a5,-20(s0)
    9002:  1007e793           ori a5,a5,256
    9006:  fef42623           sw a5,-20(s0)
    900a:  020017b7           lui a5,0x2001
    900e:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9012:  fec42703           lw a4,-20(s0)
    9016:  c398                 sw a4,0(a5)
    9018:  4529                 li a0,10
    901a:  16a010ef           jal ra,a184 <udelay>
    901e:  020017b7           lui a5,0x2001
    9022:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9026:  439c                 lw a5,0(a5)
    9028:  fef42623           sw a5,-20(s0)
    902c:  fec42703           lw a4,-20(s0)
    9030:  fd0007b7           lui a5,0xfd000
    9034:  17fd                 addi a5,a5,-1
    9036:  8ff9                 and a5,a5,a4
    9038:  fef42623           sw a5,-20(s0)
    903c:  fec42703           lw a4,-20(s0)
    9040:  020007b7           lui a5,0x2000
    9044:  8fd9                 or a5,a5,a4
    9046:  fef42623           sw a5,-20(s0)
    904a:  020017b7           lui a5,0x2001
    904e:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9052:  fec42703           lw a4,-20(s0)
    9056:  c398                 sw a4,0(a5)
    9058:  4529                 li a0,10
    905a:  12a010ef           jal ra,a184 <udelay>
    905e:  0001                 nop
    9060:  60e2                 ld ra,24(sp)
    9062:  6442                 ld s0,16(sp)
    9064:  6105                 addi sp,sp,32
    9066:  8082                 ret
0000000000009068 <ccu_set_cpux_to_24_MHz>:
    9068:  1101                 addi sp,sp,-32
    906a:  ec06                 sd ra,24(sp)
    906c:  e822                 sd s0,16(sp)
    906e:  1000                 addi s0,sp,32
    9070:  fe042623           sw zero,-20(s0)
    9074:  020017b7           lui a5,0x2001
    9078:  50078793           addi a5,a5,1280 # 2001500 <gpio_get_boot_device+0x1ff316
    907c:  439c                 lw a5,0(a5)
    907e:  fef42623           sw a5,-20(s0)
    9082:  fec42703           lw a4,-20(s0)
    9086:  f90007b7           lui a5,0xf9000
    908a:  17fd                 addi a5,a5,-1
    908c:  8ff9                 and a5,a5,a4
    908e:  fef42623           sw a5,-20(s0)
    9092:  020017b7           lui a5,0x2001
    9096:  50078793           addi a5,a5,1280 # 2001500 <gpio_get_boot_device+0x1ff316
    909a:  fec42703           lw a4,-20(s0)
    909e:  c398                 sw a4,0(a5)
    90a0:  4529                 li a0,10
    90a2:  0e2010ef           jal ra,a184 <udelay>
    90a6:  020017b7           lui a5,0x2001
    90aa:  50078793           addi a5,a5,1280 # 2001500 <gpio_get_boot_device+0x1ff316
    90ae:  439c                 lw a5,0(a5)
    90b0:  fef42623           sw a5,-20(s0)
    90b4:  fec42783           lw a5,-20(s0)
    90b8:  9bf1                 andi a5,a5,-4
    90ba:  fef42623           sw a5,-20(s0)
    90be:  020017b7           lui a5,0x2001
    90c2:  50078793           addi a5,a5,1280 # 2001500 <gpio_get_boot_device+0x1ff316
    90c6:  fec42703           lw a4,-20(s0)
    90ca:  c398                 sw a4,0(a5)
    90cc:  4515                 li a0,5
    90ce:  0b6010ef           jal ra,a184 <udelay>
    90d2:  0001                 nop
    90d4:  60e2                 ld ra,24(sp)
    90d6:  6442                 ld s0,16(sp)
    90d8:  6105                 addi sp,sp,32
    90da:  8082                 ret
00000000000090dc <ccu_set_psi_to_24_MHz>:
    90dc:  1101                 addi sp,sp,-32
    90de:  ec06                 sd ra,24(sp)
    90e0:  e822                 sd s0,16(sp)
    90e2:  1000                 addi s0,sp,32
    90e4:  fe042623           sw zero,-20(s0)
    90e8:  020017b7           lui a5,0x2001
    90ec:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    90f0:  439c                 lw a5,0(a5)
    90f2:  fef42623           sw a5,-20(s0)
    90f6:  fec42703           lw a4,-20(s0)
    90fa:  f90007b7           lui a5,0xf9000
    90fe:  17fd                 addi a5,a5,-1
    9100:  8ff9                 and a5,a5,a4
    9102:  fef42623           sw a5,-20(s0)
    9106:  020017b7           lui a5,0x2001
    910a:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    910e:  fec42703           lw a4,-20(s0)
    9112:  c398                 sw a4,0(a5)
    9114:  4529                 li a0,10
    9116:  06e010ef           jal ra,a184 <udelay>
    911a:  020017b7           lui a5,0x2001
    911e:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    9122:  439c                 lw a5,0(a5)
    9124:  fef42623           sw a5,-20(s0)
    9128:  fec42783           lw a5,-20(s0)
    912c:  cfc7f793           andi a5,a5,-772
    9130:  fef42623           sw a5,-20(s0)
    9134:  020017b7           lui a5,0x2001
    9138:  51078793           addi a5,a5,1296 # 2001510 <gpio_get_boot_device+0x1ff317
    913c:  fec42703           lw a4,-20(s0)
    9140:  c398                 sw a4,0(a5)
    9142:  4515                 li a0,5
    9144:  040010ef           jal ra,a184 <udelay>
    9148:  0001                 nop
    914a:  60e2                 ld ra,24(sp)
    914c:  6442                 ld s0,16(sp)
    914e:  6105                 addi sp,sp,32
    9150:  8082                 ret
0000000000009152 <ccu_set_apb_to_24_MHz>:
    9152:  1101                 addi sp,sp,-32
    9154:  ec06                 sd ra,24(sp)
    9156:  e822                 sd s0,16(sp)
    9158:  1000                 addi s0,sp,32
    915a:  fe042623           sw zero,-20(s0)
    915e:  020017b7           lui a5,0x2001
    9162:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9166:  439c                 lw a5,0(a5)
    9168:  fef42623           sw a5,-20(s0)
    916c:  fec42703           lw a4,-20(s0)
    9170:  f90007b7           lui a5,0xf9000
    9174:  17fd                 addi a5,a5,-1
    9176:  8ff9                 and a5,a5,a4
    9178:  fef42623           sw a5,-20(s0)
    917c:  020017b7           lui a5,0x2001
    9180:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9184:  fec42703           lw a4,-20(s0)
    9188:  c398                 sw a4,0(a5)
    918a:  4529                 li a0,10
    918c:  7f9000ef           jal ra,a184 <udelay>
    9190:  020017b7           lui a5,0x2001
    9194:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    9198:  439c                 lw a5,0(a5)
    919a:  fef42623           sw a5,-20(s0)
    919e:  fec42783           lw a5,-20(s0)
    91a2:  ce07f793           andi a5,a5,-800
    91a6:  fef42623           sw a5,-20(s0)
    91aa:  020017b7           lui a5,0x2001
    91ae:  52078793           addi a5,a5,1312 # 2001520 <gpio_get_boot_device+0x1ff318
    91b2:  fec42703           lw a4,-20(s0)
    91b6:  c398                 sw a4,0(a5)
    91b8:  4529                 li a0,10
    91ba:  7cb000ef           jal ra,a184 <udelay>
    91be:  020017b7           lui a5,0x2001
    91c2:  52478793           addi a5,a5,1316 # 2001524 <gpio_get_boot_device+0x1ff318
    91c6:  439c                 lw a5,0(a5)
    91c8:  fef42623           sw a5,-20(s0)
    91cc:  fec42703           lw a4,-20(s0)
    91d0:  f90007b7           lui a5,0xf9000
    91d4:  17fd                 addi a5,a5,-1
    91d6:  8ff9                 and a5,a5,a4
    91d8:  fef42623           sw a5,-20(s0)
    91dc:  020017b7           lui a5,0x2001
    91e0:  52478793           addi a5,a5,1316 # 2001524 <gpio_get_boot_device+0x1ff318
    91e4:  fec42703           lw a4,-20(s0)
    91e8:  c398                 sw a4,0(a5)
    91ea:  4529                 li a0,10
    91ec:  799000ef           jal ra,a184 <udelay>
    91f0:  020017b7           lui a5,0x2001
    91f4:  52478793           addi a5,a5,1316 # 2001524 <gpio_get_boot_device+0x1ff318
    91f8:  439c                 lw a5,0(a5)
    91fa:  fef42623           sw a5,-20(s0)
    91fe:  fec42783           lw a5,-20(s0)
    9202:  ce07f793           andi a5,a5,-800
    9206:  fef42623           sw a5,-20(s0)
    920a:  020017b7           lui a5,0x2001
    920e:  52478793           addi a5,a5,1316 # 2001524 <gpio_get_boot_device+0x1ff318
    9212:  fec42703           lw a4,-20(s0)
    9216:  c398                 sw a4,0(a5)
    9218:  4515                 li a0,5
    921a:  76b000ef           jal ra,a184 <udelay>
    921e:  0001                 nop
    9220:  60e2                 ld ra,24(sp)
    9222:  6442                 ld s0,16(sp)
    9224:  6105                 addi sp,sp,32
    9226:  8082                 ret
0000000000009228 <ccu_set_ce_to_hosc>:
    9228:  1101                 addi sp,sp,-32
    922a:  ec06                 sd ra,24(sp)
    922c:  e822                 sd s0,16(sp)
    922e:  1000                 addi s0,sp,32
    9230:  fe042623           sw zero,-20(s0)
    9234:  020017b7           lui a5,0x2001
    9238:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    923c:  439c                 lw a5,0(a5)
    923e:  fef42623           sw a5,-20(s0)
    9242:  fec42783           lw a5,-20(s0)
    9246:  cf07f793           andi a5,a5,-784
    924a:  fef42623           sw a5,-20(s0)
    924e:  020017b7           lui a5,0x2001
    9252:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    9256:  fec42703           lw a4,-20(s0)
    925a:  c398                 sw a4,0(a5)
    925c:  4529                 li a0,10
    925e:  727000ef           jal ra,a184 <udelay>
    9262:  020017b7           lui a5,0x2001
    9266:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    926a:  439c                 lw a5,0(a5)
    926c:  fef42623           sw a5,-20(s0)
    9270:  fec42703           lw a4,-20(s0)
    9274:  fd0007b7           lui a5,0xfd000
    9278:  17fd                 addi a5,a5,-1
    927a:  8ff9                 and a5,a5,a4
    927c:  fef42623           sw a5,-20(s0)
    9280:  020017b7           lui a5,0x2001
    9284:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    9288:  fec42703           lw a4,-20(s0)
    928c:  c398                 sw a4,0(a5)
    928e:  4529                 li a0,10
    9290:  6f5000ef           jal ra,a184 <udelay>
    9294:  020017b7           lui a5,0x2001
    9298:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    929c:  439c                 lw a5,0(a5)
    929e:  fef42623           sw a5,-20(s0)
    92a2:  fec42703           lw a4,-20(s0)
    92a6:  800007b7           lui a5,0x80000
    92aa:  8fd9                 or a5,a5,a4
    92ac:  fef42623           sw a5,-20(s0)
    92b0:  020017b7           lui a5,0x2001
    92b4:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    92b8:  fec42703           lw a4,-20(s0)
    92bc:  c398                 sw a4,0(a5)
    92be:  0001                 nop
    92c0:  60e2                 ld ra,24(sp)
    92c2:  6442                 ld s0,16(sp)
    92c4:  6105                 addi sp,sp,32
    92c6:  8082                 ret
00000000000092c8 <FUN_000092c8>:
    92c8:  7179                 addi sp,sp,-48
    92ca:  f406                 sd ra,40(sp)
    92cc:  f022                 sd s0,32(sp)
    92ce:  1800                 addi s0,sp,48
    92d0:  87aa                 mv a5,a0
    92d2:  fcf42e23           sw a5,-36(s0)
    92d6:  fe042623           sw zero,-20(s0)
    92da:  020027b7           lui a5,0x2002
    92de:  80c78793           addi a5,a5,-2036 # 200180c <gpio_get_boot_device+0x1ff34
    92e2:  439c                 lw a5,0(a5)
    92e4:  fef42623           sw a5,-20(s0)
    92e8:  fec42783           lw a5,-20(s0)
    92ec:  9bf9                 andi a5,a5,-2
    92ee:  fef42623           sw a5,-20(s0)
    92f2:  fec42703           lw a4,-20(s0)
    92f6:  fdc42783           lw a5,-36(s0)
    92fa:  8fd9                 or a5,a5,a4
    92fc:  fef42623           sw a5,-20(s0)
    9300:  020027b7           lui a5,0x2002
    9304:  80c78793           addi a5,a5,-2036 # 200180c <gpio_get_boot_device+0x1ff34
    9308:  fec42703           lw a4,-20(s0)
    930c:  c398                 sw a4,0(a5)
    930e:  4529                 li a0,10
    9310:  675000ef           jal ra,a184 <udelay>
    9314:  0001                 nop
    9316:  70a2                 ld ra,40(sp)
    9318:  7402                 ld s0,32(sp)
    931a:  6145                 addi sp,sp,48
    931c:  8082                 ret
000000000000931e <FUN_0000931e>:
    931e:  1101                 addi sp,sp,-32
    9320:  ec06                 sd ra,24(sp)
    9322:  e822                 sd s0,16(sp)
    9324:  1000                 addi s0,sp,32
    9326:  fe042623           sw zero,-20(s0)
    932a:  4501                 li a0,0
    932c:  f9dff0ef           jal ra,92c8 <FUN_000092c8>
    9330:  020027b7           lui a5,0x2002
    9334:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    9338:  439c                 lw a5,0(a5)
    933a:  fef42623           sw a5,-20(s0)
    933e:  fec42703           lw a4,-20(s0)
    9342:  800007b7           lui a5,0x80000
    9346:  fff7c793           not a5,a5
    934a:  8ff9                 and a5,a5,a4
    934c:  fef42623           sw a5,-20(s0)
    9350:  020027b7           lui a5,0x2002
    9354:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    9358:  fec42703           lw a4,-20(s0)
    935c:  c398                 sw a4,0(a5)
    935e:  4515                 li a0,5
    9360:  625000ef           jal ra,a184 <udelay>
    9364:  020027b7           lui a5,0x2002
    9368:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    936c:  439c                 lw a5,0(a5)
    936e:  fef42623           sw a5,-20(s0)
    9372:  fec42783           lw a5,-20(s0)
    9376:  cfc7f793           andi a5,a5,-772
    937a:  fef42623           sw a5,-20(s0)
    937e:  fec42783           lw a5,-20(s0)
    9382:  0017e793           ori a5,a5,1
    9386:  fef42623           sw a5,-20(s0)
    938a:  020027b7           lui a5,0x2002
    938e:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    9392:  fec42703           lw a4,-20(s0)
    9396:  c398                 sw a4,0(a5)
    9398:  4515                 li a0,5
    939a:  5eb000ef           jal ra,a184 <udelay>
    939e:  020027b7           lui a5,0x2002
    93a2:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    93a6:  439c                 lw a5,0(a5)
    93a8:  fef42623           sw a5,-20(s0)
    93ac:  fec42703           lw a4,-20(s0)
    93b0:  fd0007b7           lui a5,0xfd000
    93b4:  17fd                 addi a5,a5,-1
    93b6:  8ff9                 and a5,a5,a4
    93b8:  fef42623           sw a5,-20(s0)
    93bc:  fec42703           lw a4,-20(s0)
    93c0:  020007b7           lui a5,0x2000
    93c4:  8fd9                 or a5,a5,a4
    93c6:  fef42623           sw a5,-20(s0)
    93ca:  020027b7           lui a5,0x2002
    93ce:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    93d2:  fec42703           lw a4,-20(s0)
    93d6:  c398                 sw a4,0(a5)
    93d8:  4515                 li a0,5
    93da:  5ab000ef           jal ra,a184 <udelay>
    93de:  020027b7           lui a5,0x2002
    93e2:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    93e6:  439c                 lw a5,0(a5)
    93e8:  fef42623           sw a5,-20(s0)
    93ec:  fec42703           lw a4,-20(s0)
    93f0:  800007b7           lui a5,0x80000
    93f4:  8fd9                 or a5,a5,a4
    93f6:  fef42623           sw a5,-20(s0)
    93fa:  020027b7           lui a5,0x2002
    93fe:  80078793           addi a5,a5,-2048 # 2001800 <gpio_get_boot_device+0x1ff34
    9402:  fec42703           lw a4,-20(s0)
    9406:  c398                 sw a4,0(a5)
    9408:  4515                 li a0,5
    940a:  57b000ef           jal ra,a184 <udelay>
    940e:  0001                 nop
    9410:  60e2                 ld ra,24(sp)
    9412:  6442                 ld s0,16(sp)
    9414:  6105                 addi sp,sp,32
    9416:  8082                 ret
0000000000009418 <FUN_00009418>:
    9418:  7179                 addi sp,sp,-48
    941a:  f406                 sd ra,40(sp)
    941c:  f022                 sd s0,32(sp)
    941e:  1800                 addi s0,sp,48
    9420:  87aa                 mv a5,a0
    9422:  fcf42e23           sw a5,-36(s0)
    9426:  fe042623           sw zero,-20(s0)
    942a:  020017b7           lui a5,0x2001
    942e:  54078793           addi a5,a5,1344 # 2001540 <gpio_get_boot_device+0x1ff31a
    9432:  439c                 lw a5,0(a5)
    9434:  fef42623           sw a5,-20(s0)
    9438:  fec42703           lw a4,-20(s0)
    943c:  c00007b7           lui a5,0xc0000
    9440:  17fd                 addi a5,a5,-1
    9442:  8ff9                 and a5,a5,a4
    9444:  fef42623           sw a5,-20(s0)
    9448:  fdc42783           lw a5,-36(s0)
    944c:  01e7979b           slliw a5,a5,0x1e
    9450:  0007871b           sext.w a4,a5
    9454:  fec42783           lw a5,-20(s0)
    9458:  8fd9                 or a5,a5,a4
    945a:  fef42623           sw a5,-20(s0)
    945e:  020017b7           lui a5,0x2001
    9462:  54078793           addi a5,a5,1344 # 2001540 <gpio_get_boot_device+0x1ff31a
    9466:  fec42703           lw a4,-20(s0)
    946a:  c398                 sw a4,0(a5)
    946c:  4529                 li a0,10
    946e:  517000ef           jal ra,a184 <udelay>
    9472:  0001                 nop
    9474:  70a2                 ld ra,40(sp)
    9476:  7402                 ld s0,32(sp)
    9478:  6145                 addi sp,sp,48
    947a:  8082                 ret
000000000000947c <ccu_reset_mbus_dram>:
    947c:  1141                 addi sp,sp,-16
    947e:  e406                 sd ra,8(sp)
    9480:  e022                 sd s0,0(sp)
    9482:  0800                 addi s0,sp,16
    9484:  94bff0ef           jal ra,8dce <FUN_00008dce>
    9488:  e97ff0ef           jal ra,931e <FUN_0000931e>
    948c:  4501                 li a0,0
    948e:  f8bff0ef           jal ra,9418 <FUN_00009418>
    9492:  4505                 li a0,1
    9494:  e35ff0ef           jal ra,92c8 <FUN_000092c8>
    9498:  4501                 li a0,0
    949a:  e2fff0ef           jal ra,92c8 <FUN_000092c8>
    949e:  4505                 li a0,1
    94a0:  f79ff0ef           jal ra,9418 <FUN_00009418>
    94a4:  4505                 li a0,1
    94a6:  e23ff0ef           jal ra,92c8 <FUN_000092c8>
    94aa:  0001                 nop
    94ac:  60a2                 ld ra,8(sp)
    94ae:  6402                 ld s0,0(sp)
    94b0:  0141                 addi sp,sp,16
    94b2:  8082                 ret
00000000000094b4 <ccu_set_ce_reset>:
    94b4:  7179                 addi sp,sp,-48
    94b6:  f406                 sd ra,40(sp)
    94b8:  f022                 sd s0,32(sp)
    94ba:  1800                 addi s0,sp,48
    94bc:  87aa                 mv a5,a0
    94be:  fcf42e23           sw a5,-36(s0)
    94c2:  fe042623           sw zero,-20(s0)
    94c6:  020017b7           lui a5,0x2001
    94ca:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
    94ce:  439c                 lw a5,0(a5)
    94d0:  fef42623           sw a5,-20(s0)
    94d4:  fec42703           lw a4,-20(s0)
    94d8:  77c1                 lui a5,0xffff0
    94da:  17fd                 addi a5,a5,-1
    94dc:  8ff9                 and a5,a5,a4
    94de:  fef42623           sw a5,-20(s0)
    94e2:  fdc42783           lw a5,-36(s0)
    94e6:  0107979b           slliw a5,a5,0x10
    94ea:  0007871b           sext.w a4,a5
    94ee:  fec42783           lw a5,-20(s0)
    94f2:  8fd9                 or a5,a5,a4
    94f4:  fef42623           sw a5,-20(s0)
    94f8:  020017b7           lui a5,0x2001
    94fc:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
    9500:  fec42703           lw a4,-20(s0)
    9504:  c398                 sw a4,0(a5)
    9506:  4529                 li a0,10
    9508:  47d000ef           jal ra,a184 <udelay>
    950c:  0001                 nop
    950e:  70a2                 ld ra,40(sp)
    9510:  7402                 ld s0,32(sp)
    9512:  6145                 addi sp,sp,48
    9514:  8082                 ret
0000000000009516 <ccu_set_ce_gating>:
    9516:  7179                 addi sp,sp,-48
    9518:  f406                 sd ra,40(sp)
    951a:  f022                 sd s0,32(sp)
    951c:  1800                 addi s0,sp,48
    951e:  87aa                 mv a5,a0
    9520:  fcf42e23           sw a5,-36(s0)
    9524:  fe042623           sw zero,-20(s0)
    9528:  020017b7           lui a5,0x2001
    952c:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
    9530:  439c                 lw a5,0(a5)
    9532:  fef42623           sw a5,-20(s0)
    9536:  fec42783           lw a5,-20(s0)
    953a:  9bf9                 andi a5,a5,-2
    953c:  fef42623           sw a5,-20(s0)
    9540:  fec42703           lw a4,-20(s0)
    9544:  fdc42783           lw a5,-36(s0)
    9548:  8fd9                 or a5,a5,a4
    954a:  fef42623           sw a5,-20(s0)
    954e:  020017b7           lui a5,0x2001
    9552:  68c78793           addi a5,a5,1676 # 200168c <gpio_get_boot_device+0x1ff32f
    9556:  fec42703           lw a4,-20(s0)
    955a:  c398                 sw a4,0(a5)
    955c:  4529                 li a0,10
    955e:  427000ef           jal ra,a184 <udelay>
    9562:  0001                 nop
    9564:  70a2                 ld ra,40(sp)
    9566:  7402                 ld s0,32(sp)
    9568:  6145                 addi sp,sp,48
    956a:  8082                 ret
000000000000956c <ccu_set_ce_to_pll>:
    956c:  7179                 addi sp,sp,-48
    956e:  f406                 sd ra,40(sp)
    9570:  f022                 sd s0,32(sp)
    9572:  1800                 addi s0,sp,48
    9574:  87aa                 mv a5,a0
    9576:  fcf42e23           sw a5,-36(s0)
    957a:  fe042623           sw zero,-20(s0)
    957e:  4501                 li a0,0
    9580:  f97ff0ef           jal ra,9516 <ccu_set_ce_gating>
    9584:  020017b7           lui a5,0x2001
    9588:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    958c:  439c                 lw a5,0(a5)
    958e:  fef42623           sw a5,-20(s0)
    9592:  fec42703           lw a4,-20(s0)
    9596:  800007b7           lui a5,0x80000
    959a:  fff7c793           not a5,a5
    959e:  8ff9                 and a5,a5,a4
    95a0:  fef42623           sw a5,-20(s0)
    95a4:  020017b7           lui a5,0x2001
    95a8:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    95ac:  fec42703           lw a4,-20(s0)
    95b0:  c398                 sw a4,0(a5)
    95b2:  4515                 li a0,5
    95b4:  3d1000ef           jal ra,a184 <udelay>
    95b8:  020017b7           lui a5,0x2001
    95bc:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    95c0:  439c                 lw a5,0(a5)
    95c2:  fef42623           sw a5,-20(s0)
    95c6:  fec42783           lw a5,-20(s0)
    95ca:  cf07f793           andi a5,a5,-784
    95ce:  fef42623           sw a5,-20(s0)
    95d2:  fec42703           lw a4,-20(s0)
    95d6:  fdc42783           lw a5,-36(s0)
    95da:  8fd9                 or a5,a5,a4
    95dc:  fef42623           sw a5,-20(s0)
    95e0:  020017b7           lui a5,0x2001
    95e4:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    95e8:  fec42703           lw a4,-20(s0)
    95ec:  c398                 sw a4,0(a5)
    95ee:  4515                 li a0,5
    95f0:  395000ef           jal ra,a184 <udelay>
    95f4:  020017b7           lui a5,0x2001
    95f8:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    95fc:  439c                 lw a5,0(a5)
    95fe:  fef42623           sw a5,-20(s0)
    9602:  fec42703           lw a4,-20(s0)
    9606:  fd0007b7           lui a5,0xfd000
    960a:  17fd                 addi a5,a5,-1
    960c:  8ff9                 and a5,a5,a4
    960e:  fef42623           sw a5,-20(s0)
    9612:  fec42703           lw a4,-20(s0)
    9616:  010007b7           lui a5,0x1000
    961a:  8fd9                 or a5,a5,a4
    961c:  fef42623           sw a5,-20(s0)
    9620:  020017b7           lui a5,0x2001
    9624:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    9628:  fec42703           lw a4,-20(s0)
    962c:  c398                 sw a4,0(a5)
    962e:  4515                 li a0,5
    9630:  355000ef           jal ra,a184 <udelay>
    9634:  020017b7           lui a5,0x2001
    9638:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    963c:  439c                 lw a5,0(a5)
    963e:  fef42623           sw a5,-20(s0)
    9642:  fec42703           lw a4,-20(s0)
    9646:  800007b7           lui a5,0x80000
    964a:  8fd9                 or a5,a5,a4
    964c:  fef42623           sw a5,-20(s0)
    9650:  020017b7           lui a5,0x2001
    9654:  68078793           addi a5,a5,1664 # 2001680 <gpio_get_boot_device+0x1ff32e
    9658:  fec42703           lw a4,-20(s0)
    965c:  c398                 sw a4,0(a5)
    965e:  0001                 nop
    9660:  70a2                 ld ra,40(sp)
    9662:  7402                 ld s0,32(sp)
    9664:  6145                 addi sp,sp,48
    9666:  8082                 ret
0000000000009668 <ccu_set_ce_clocks>:
    9668:  7179                 addi sp,sp,-48
    966a:  f406                 sd ra,40(sp)
    966c:  f022                 sd s0,32(sp)
    966e:  1800                 addi s0,sp,48
    9670:  87aa                 mv a5,a0
    9672:  fcf42e23           sw a5,-36(s0)
    9676:  fe042423           sw zero,-24(s0)
    967a:  4789                 li a5,2
    967c:  fef42623           sw a5,-20(s0)
    9680:  dfdff0ef           jal ra,947c <ccu_reset_mbus_dram>
    9684:  fdc42783           lw a5,-36(s0)
    9688:  2781                 sext.w a5,a5
    968a:  e781                 bnez a5,9692 <ccu_set_ce_clocks+0x2a>
    968c:  b9dff0ef           jal ra,9228 <ccu_set_ce_to_hosc>
    9690:  a829                 j 96aa <ccu_set_ce_clocks+0x42>
    9692:  915fe0ef           jal ra,7fa6 <brom_config_lower_ce_freq>
    9696:  87aa                 mv a5,a0
    9698:  c781                 beqz a5,96a0 <ccu_set_ce_clocks+0x38>
    969a:  478d                 li a5,3
    969c:  fef42623           sw a5,-20(s0)
    96a0:  fec42783           lw a5,-20(s0)
    96a4:  853e                 mv a0,a5
    96a6:  ec7ff0ef           jal ra,956c <ccu_set_ce_to_pll>
    96aa:  4501                 li a0,0
    96ac:  e09ff0ef           jal ra,94b4 <ccu_set_ce_reset>
    96b0:  4505                 li a0,1
    96b2:  e65ff0ef           jal ra,9516 <ccu_set_ce_gating>
    96b6:  4501                 li a0,0
    96b8:  e5fff0ef           jal ra,9516 <ccu_set_ce_gating>
    96bc:  4505                 li a0,1
    96be:  df7ff0ef           jal ra,94b4 <ccu_set_ce_reset>
    96c2:  4505                 li a0,1
    96c4:  e53ff0ef           jal ra,9516 <ccu_set_ce_gating>
    96c8:  020027b7           lui a5,0x2002
    96cc:  80478793           addi a5,a5,-2044 # 2001804 <gpio_get_boot_device+0x1ff34
    96d0:  439c                 lw a5,0(a5)
    96d2:  fef42423           sw a5,-24(s0)
    96d6:  fe842783           lw a5,-24(s0)
    96da:  0047e793           ori a5,a5,4
    96de:  fef42423           sw a5,-24(s0)
    96e2:  020027b7           lui a5,0x2002
    96e6:  80478793           addi a5,a5,-2044 # 2001804 <gpio_get_boot_device+0x1ff34
    96ea:  fe842703           lw a4,-24(s0)
    96ee:  c398                 sw a4,0(a5)
    96f0:  0001                 nop
    96f2:  70a2                 ld ra,40(sp)
    96f4:  7402                 ld s0,32(sp)
    96f6:  6145                 addi sp,sp,48
    96f8:  8082                 ret
00000000000096fa <ccu_init_cpu_ce_clocks>:
    96fa:  1101                 addi sp,sp,-32
    96fc:  ec06                 sd ra,24(sp)
    96fe:  e822                 sd s0,16(sp)
    9700:  1000                 addi s0,sp,32
    9702:  fe042423           sw zero,-24(s0)
    9706:  47c1                 li a5,16
    9708:  fef42223           sw a5,-28(s0)
    970c:  fe042623           sw zero,-20(s0)
    9710:  897fe0ef           jal ra,7fa6 <brom_config_lower_ce_freq>
    9714:  87aa                 mv a5,a0
    9716:  c781                 beqz a5,971e <ccu_init_cpu_ce_clocks+0x24>
    9718:  4785                 li a5,1
    971a:  fef42623           sw a5,-20(s0)
    971e:  fe442783           lw a5,-28(s0)
    9722:  853e                 mv a0,a5
    9724:  d02ff0ef           jal ra,8c26 <ccu_enable_pll_cpux>
    9728:  87aa                 mv a5,a0
    972a:  fef42423           sw a5,-24(s0)
    972e:  fe842783           lw a5,-24(s0)
    9732:  2781                 sext.w a5,a5
    9734:  0007d663           bgez a5,9740 <ccu_init_cpu_ce_clocks+0x46>
    9738:  4501                 li a0,0
    973a:  f2fff0ef           jal ra,9668 <ccu_set_ce_clocks>
    973e:  a81d                 j 9774 <ccu_init_cpu_ce_clocks+0x7a>
    9740:  daeff0ef           jal ra,8cee <FUN_00008cee>
    9744:  87aa                 mv a5,a0
    9746:  fef42423           sw a5,-24(s0)
    974a:  fe842783           lw a5,-24(s0)
    974e:  2781                 sext.w a5,a5
    9750:  0007d663           bgez a5,975c <ccu_init_cpu_ce_clocks+0x62>
    9754:  4501                 li a0,0
    9756:  f13ff0ef           jal ra,9668 <ccu_set_ce_clocks>
    975a:  a829                 j 9774 <ccu_init_cpu_ce_clocks+0x7a>
    975c:  f46ff0ef           jal ra,8ea2 <FUN_00008ea2>
    9760:  fec42783           lw a5,-20(s0)
    9764:  853e                 mv a0,a5
    9766:  fccff0ef           jal ra,8f32 <FUN_00008f32>
    976a:  86fff0ef           jal ra,8fd8 <FUN_00008fd8>
    976e:  4505                 li a0,1
    9770:  ef9ff0ef           jal ra,9668 <ccu_set_ce_clocks>
    9774:  60e2                 ld ra,24(sp)
    9776:  6442                 ld s0,16(sp)
    9778:  6105                 addi sp,sp,32
    977a:  8082                 ret
000000000000977c <set_audio_codec_gating_bias>:
    977c:  7179                 addi sp,sp,-48
    977e:  f422                 sd s0,40(sp)
    9780:  1800                 addi s0,sp,48
    9782:  87aa                 mv a5,a0
    9784:  fcf42e23           sw a5,-36(s0)
    9788:  020027b7           lui a5,0x2002
    978c:  a5c78793           addi a5,a5,-1444 # 2001a5c <gpio_get_boot_device+0x1ff36
    9790:  439c                 lw a5,0(a5)
    9792:  fef42623           sw a5,-20(s0)
    9796:  fec42703           lw a4,-20(s0)
    979a:  67c1                 lui a5,0x10
    979c:  8fd9                 or a5,a5,a4
    979e:  fef42623           sw a5,-20(s0)
    97a2:  020027b7           lui a5,0x2002
    97a6:  a5c78793           addi a5,a5,-1444 # 2001a5c <gpio_get_boot_device+0x1ff36
    97aa:  fec42703           lw a4,-20(s0)
    97ae:  c398                 sw a4,0(a5)
    97b0:  020027b7           lui a5,0x2002
    97b4:  a5c78793           addi a5,a5,-1444 # 2001a5c <gpio_get_boot_device+0x1ff36
    97b8:  439c                 lw a5,0(a5)
    97ba:  fef42623           sw a5,-20(s0)
    97be:  fec42783           lw a5,-20(s0)
    97c2:  0017e793           ori a5,a5,1
    97c6:  fef42623           sw a5,-20(s0)
    97ca:  020027b7           lui a5,0x2002
    97ce:  a5c78793           addi a5,a5,-1444 # 2001a5c <gpio_get_boot_device+0x1ff36
    97d2:  fec42703           lw a4,-20(s0)
    97d6:  c398                 sw a4,0(a5)
    97d8:  020307b7           lui a5,0x2030
    97dc:  32078793           addi a5,a5,800 # 2030320 <gpio_get_boot_device+0x2021f8a
    97e0:  439c                 lw a5,0(a5)
    97e2:  fef42623           sw a5,-20(s0)
    97e6:  fec42783           lw a5,-20(s0)
    97ea:  f007f793           andi a5,a5,-256
    97ee:  fef42623           sw a5,-20(s0)
    97f2:  fec42703           lw a4,-20(s0)
    97f6:  fdc42783           lw a5,-36(s0)
    97fa:  8fd9                 or a5,a5,a4
    97fc:  fef42623           sw a5,-20(s0)
    9800:  020307b7           lui a5,0x2030
    9804:  32078793           addi a5,a5,800 # 2030320 <gpio_get_boot_device+0x2021f8a
    9808:  fec42703           lw a4,-20(s0)
    980c:  c398                 sw a4,0(a5)
    980e:  0001                 nop
    9810:  7422                 ld s0,40(sp)
    9812:  6145                 addi sp,sp,48
    9814:  8082                 ret
0000000000009816 <set_bg_trim_voltage>:
    9816:  7179                 addi sp,sp,-48
    9818:  f422                 sd s0,40(sp)
    981a:  1800                 addi s0,sp,48
    981c:  87aa                 mv a5,a0
    981e:  fcf42e23           sw a5,-36(s0)
    9822:  020307b7           lui a5,0x2030
    9826:  34878793           addi a5,a5,840 # 2030348 <gpio_get_boot_device+0x2021fb2
    982a:  439c                 lw a5,0(a5)
    982c:  fef42623           sw a5,-20(s0)
    9830:  fec42783           lw a5,-20(s0)
    9834:  f007f793           andi a5,a5,-256
    9838:  fef42623           sw a5,-20(s0)
    983c:  fec42703           lw a4,-20(s0)
    9840:  fdc42783           lw a5,-36(s0)
    9844:  8fd9                 or a5,a5,a4
    9846:  fef42623           sw a5,-20(s0)
    984a:  020307b7           lui a5,0x2030
    984e:  34878793           addi a5,a5,840 # 2030348 <gpio_get_boot_device+0x2021fb2
    9852:  fec42703           lw a4,-20(s0)
    9856:  c398                 sw a4,0(a5)
    9858:  0001                 nop
    985a:  7422                 ld s0,40(sp)
    985c:  6145                 addi sp,sp,48
    985e:  8082                 ret
0000000000009860 <sid_read_voltages_0x14>:
    9860:  1101                 addi sp,sp,-32
    9862:  ec22                 sd s0,24(sp)
    9864:  1000                 addi s0,sp,32
    9866:  030067b7           lui a5,0x3006
    986a:  21478793           addi a5,a5,532 # 3006214 <gpio_get_boot_device+0x2ff7e7e
    986e:  439c                 lw a5,0(a5)
    9870:  fef42623           sw a5,-20(s0)
    9874:  fec42783           lw a5,-20(s0)
    9878:  01c7d79b           srliw a5,a5,0x1c
    987c:  fef42423           sw a5,-24(s0)
    9880:  fec42783           lw a5,-20(s0)
    9884:  00c7d79b           srliw a5,a5,0xc
    9888:  2781                 sext.w a5,a5
    988a:  8bbd                 andi a5,a5,15
    988c:  fef42223           sw a5,-28(s0)
    9890:  fe842783           lw a5,-24(s0)
    9894:  0047979b           slliw a5,a5,0x4
    9898:  0007871b           sext.w a4,a5
    989c:  fe442783           lw a5,-28(s0)
    98a0:  8fd9                 or a5,a5,a4
    98a2:  fef42623           sw a5,-20(s0)
    98a6:  fec42783           lw a5,-20(s0)
    98aa:  853e                 mv a0,a5
    98ac:  6462                 ld s0,24(sp)
    98ae:  6105                 addi sp,sp,32
    98b0:  8082                 ret
00000000000098b2 <sid_read_voltage_0x1c>:
    98b2:  1101                 addi sp,sp,-32
    98b4:  ec22                 sd s0,24(sp)
    98b6:  1000                 addi s0,sp,32
    98b8:  030067b7           lui a5,0x3006
    98bc:  21c78793           addi a5,a5,540 # 300621c <gpio_get_boot_device+0x2ff7e86
    98c0:  439c                 lw a5,0(a5)
    98c2:  fef42623           sw a5,-20(s0)
    98c6:  fec42783           lw a5,-20(s0)
    98ca:  0ff7f793           andi a5,a5,255
    98ce:  fef42623           sw a5,-20(s0)
    98d2:  fec42783           lw a5,-20(s0)
    98d6:  853e                 mv a0,a5
    98d8:  6462                 ld s0,24(sp)
    98da:  6105                 addi sp,sp,32
    98dc:  8082                 ret
00000000000098de <prcm_set_gpu_pwroff_gating>:
    98de:  1101                 addi sp,sp,-32
    98e0:  ec22                 sd s0,24(sp)
    98e2:  1000                 addi s0,sp,32
    98e4:  fe042623           sw zero,-20(s0)
    98e8:  070107b7           lui a5,0x7010
    98ec:  25478793           addi a5,a5,596 # 7010254 <gpio_get_boot_device+0x7001ebe
    98f0:  439c                 lw a5,0(a5)
    98f2:  fef42623           sw a5,-20(s0)
    98f6:  fec42783           lw a5,-20(s0)
    98fa:  9bf1                 andi a5,a5,-4
    98fc:  fef42623           sw a5,-20(s0)
    9900:  070107b7           lui a5,0x7010
    9904:  25478793           addi a5,a5,596 # 7010254 <gpio_get_boot_device+0x7001ebe
    9908:  fec42703           lw a4,-20(s0)
    990c:  c398                 sw a4,0(a5)
    990e:  0001                 nop
    9910:  6462                 ld s0,24(sp)
    9912:  6105                 addi sp,sp,32
    9914:  8082                 ret
0000000000009916 <prcm_set_ldo_voltage_bias>:
    9916:  1101                 addi sp,sp,-32
    9918:  ec06                 sd ra,24(sp)
    991a:  e822                 sd s0,16(sp)
    991c:  1000                 addi s0,sp,32
    991e:  fe042623           sw zero,-20(s0)
    9922:  fe042423           sw zero,-24(s0)
    9926:  f3bff0ef           jal ra,9860 <sid_read_voltages_0x14>
    992a:  87aa                 mv a5,a0
    992c:  fef42623           sw a5,-20(s0)
    9930:  f83ff0ef           jal ra,98b2 <sid_read_voltage_0x1c>
    9934:  87aa                 mv a5,a0
    9936:  fef42423           sw a5,-24(s0)
    993a:  fa5ff0ef           jal ra,98de <prcm_set_gpu_pwroff_gating>
    993e:  fe842783           lw a5,-24(s0)
    9942:  2781                 sext.w a5,a5
    9944:  c791                 beqz a5,9950 <prcm_set_ldo_voltage_bias+0x3a>
    9946:  fe842783           lw a5,-24(s0)
    994a:  853e                 mv a0,a5
    994c:  ecbff0ef           jal ra,9816 <set_bg_trim_voltage>
    9950:  fec42783           lw a5,-20(s0)
    9954:  2781                 sext.w a5,a5
    9956:  c791                 beqz a5,9962 <prcm_set_ldo_voltage_bias+0x4c>
    9958:  fec42783           lw a5,-20(s0)
    995c:  853e                 mv a0,a5
    995e:  e1fff0ef           jal ra,977c <set_audio_codec_gating_bias>
    9962:  0001                 nop
    9964:  60e2                 ld ra,24(sp)
    9966:  6442                 ld s0,16(sp)
    9968:  6105                 addi sp,sp,32
    996a:  8082                 ret
000000000000996c <rtc_enable_hosc_iosc>:
    996c:  1101                 addi sp,sp,-32
    996e:  ec06                 sd ra,24(sp)
    9970:  e822                 sd s0,16(sp)
    9972:  1000                 addi s0,sp,32
    9974:  fe042623           sw zero,-20(s0)
    9978:  070907b7           lui a5,0x7090
    997c:  16078793           addi a5,a5,352 # 7090160 <gpio_get_boot_device+0x7081dca
    9980:  439c                 lw a5,0(a5)
    9982:  fef42623           sw a5,-20(s0)
    9986:  fec42783           lw a5,-20(s0)
    998a:  8b8d                 andi a5,a5,3
    998c:  2781                 sext.w a5,a5
    998e:  873e                 mv a4,a5
    9990:  478d                 li a5,3
    9992:  02f70263           beq a4,a5,99b6 <rtc_enable_hosc_iosc+0x4a>
    9996:  fec42783           lw a5,-20(s0)
    999a:  0037e793           ori a5,a5,3
    999e:  fef42623           sw a5,-20(s0)
    99a2:  070907b7           lui a5,0x7090
    99a6:  16078793           addi a5,a5,352 # 7090160 <gpio_get_boot_device+0x7081dca
    99aa:  fec42703           lw a4,-20(s0)
    99ae:  c398                 sw a4,0(a5)
    99b0:  4515                 li a0,5
    99b2:  7fc000ef           jal ra,a1ae <udelay_x800>
    99b6:  0001                 nop
    99b8:  60e2                 ld ra,24(sp)
    99ba:  6442                 ld s0,16(sp)
    99bc:  6105                 addi sp,sp,32
    99be:  8082                 ret
00000000000099c0 <ccu_init_bus_clocks>:
    99c0:  1141                 addi sp,sp,-16
    99c2:  e406                 sd ra,8(sp)
    99c4:  e022                 sd s0,0(sp)
    99c6:  0800                 addi s0,sp,16
    99c8:  fa5ff0ef           jal ra,996c <rtc_enable_hosc_iosc>
    99cc:  f4bff0ef           jal ra,9916 <prcm_set_ldo_voltage_bias>
    99d0:  e98ff0ef           jal ra,9068 <ccu_set_cpux_to_24_MHz>
    99d4:  f08ff0ef           jal ra,90dc <ccu_set_psi_to_24_MHz>
    99d8:  f7aff0ef           jal ra,9152 <ccu_set_apb_to_24_MHz>
    99dc:  0001                 nop
    99de:  60a2                 ld ra,8(sp)
    99e0:  6402                 ld s0,0(sp)
    99e2:  0141                 addi sp,sp,16
    99e4:  8082                 ret
00000000000099e6 <ccu_init>:
    99e6:  1141                 addi sp,sp,-16
    99e8:  e406                 sd ra,8(sp)
    99ea:  e022                 sd s0,0(sp)
    99ec:  0800                 addi s0,sp,16
    99ee:  fd3ff0ef           jal ra,99c0 <ccu_init_bus_clocks>
    99f2:  d09ff0ef           jal ra,96fa <ccu_init_cpu_ce_clocks>
    99f6:  0001                 nop
    99f8:  60a2                 ld ra,8(sp)
    99fa:  6402                 ld s0,0(sp)
    99fc:  0141                 addi sp,sp,16
    99fe:  8082                 ret
0000000000009a00 <debug_syscon>:
    9a00:  1101                 addi sp,sp,-32
    9a02:  ec22                 sd s0,24(sp)
    9a04:  1000                 addi s0,sp,32
    9a06:  87aa                 mv a5,a0
    9a08:  872e                 mv a4,a1
    9a0a:  fef42623           sw a5,-20(s0)
    9a0e:  87ba                 mv a5,a4
    9a10:  fef42423           sw a5,-24(s0)
    9a14:  fe842783           lw a5,-24(s0)
    9a18:  2781                 sext.w a5,a5
    9a1a:  ef81                 bnez a5,9a32 <debug_syscon+0x32>
    9a1c:  030007b7           lui a5,0x3000
    9a20:  0b078793           addi a5,a5,176 # 30000b0 <gpio_get_boot_device+0x2ff1d1a
    9a24:  fec42703           lw a4,-20(s0)
    9a28:  0087171b           slliw a4,a4,0x8
    9a2c:  2701                 sext.w a4,a4
    9a2e:  c398                 sw a4,0(a5)
    9a30:  a801                 j 9a40 <debug_syscon+0x40>
    9a32:  030007b7           lui a5,0x3000
    9a36:  0b078793           addi a5,a5,176 # 30000b0 <gpio_get_boot_device+0x2ff1d1a
    9a3a:  fec42703           lw a4,-20(s0)
    9a3e:  c398                 sw a4,0(a5)
    9a40:  0001                 nop
    9a42:  6462                 ld s0,24(sp)
    9a44:  6105                 addi sp,sp,32
    9a46:  8082                 ret
0000000000009a48 <rtc_get_fast_boot_status>:
    9a48:  1101                 addi sp,sp,-32
    9a4a:  ec22                 sd s0,24(sp)
    9a4c:  1000                 addi s0,sp,32
    9a4e:  fe042623           sw zero,-20(s0)
    9a52:  070907b7           lui a5,0x7090
    9a56:  12078793           addi a5,a5,288 # 7090120 <gpio_get_boot_device+0x7081d8a
    9a5a:  439c                 lw a5,0(a5)
    9a5c:  fef42623           sw a5,-20(s0)
    9a60:  fec42783           lw a5,-20(s0)
    9a64:  853e                 mv a0,a5
    9a66:  6462                 ld s0,24(sp)
    9a68:  6105                 addi sp,sp,32
    9a6a:  8082                 ret
0000000000009a6c <FUN_00009a6c>:
    9a6c:  7179                 addi sp,sp,-48
    9a6e:  f422                 sd s0,40(sp)
    9a70:  1800                 addi s0,sp,48
    9a72:  87aa                 mv a5,a0
    9a74:  872e                 mv a4,a1
    9a76:  fcf42e23           sw a5,-36(s0)
    9a7a:  87ba                 mv a5,a4
    9a7c:  fcf42c23           sw a5,-40(s0)
    9a80:  fe042623           sw zero,-20(s0)
    9a84:  070907b7           lui a5,0x7090
    9a88:  12078793           addi a5,a5,288 # 7090120 <gpio_get_boot_device+0x7081d8a
    9a8c:  0007a023           sw zero,0(a5)
    9a90:  fdc42783           lw a5,-36(s0)
    9a94:  01c7979b           slliw a5,a5,0x1c
    9a98:  0007871b           sext.w a4,a5
    9a9c:  fd842783           lw a5,-40(s0)
    9aa0:  8fd9                 or a5,a5,a4
    9aa2:  0007871b           sext.w a4,a5
    9aa6:  fec42783           lw a5,-20(s0)
    9aaa:  8fd9                 or a5,a5,a4
    9aac:  fef42623           sw a5,-20(s0)
    9ab0:  070907b7           lui a5,0x7090
    9ab4:  12078793           addi a5,a5,288 # 7090120 <gpio_get_boot_device+0x7081d8a
    9ab8:  fec42703           lw a4,-20(s0)
    9abc:  c398                 sw a4,0(a5)
    9abe:  0001                 nop
    9ac0:  7422                 ld s0,40(sp)
    9ac2:  6145                 addi sp,sp,48
    9ac4:  8082                 ret
0000000000009ac6 <gpio_enable_jtag_pf>:
    9ac6:  1101                 addi sp,sp,-32
    9ac8:  ec22                 sd s0,24(sp)
    9aca:  1000                 addi s0,sp,32
    9acc:  fe042623           sw zero,-20(s0)
    9ad0:  020007b7           lui a5,0x2000
    9ad4:  0f07879b           addiw a5,a5,240
    9ad8:  fef42423           sw a5,-24(s0)
    9adc:  fe846783           lwu a5,-24(s0)
    9ae0:  439c                 lw a5,0(a5)
    9ae2:  fef42623           sw a5,-20(s0)
    9ae6:  fec42703           lw a4,-20(s0)
    9aea:  ff0f17b7           lui a5,0xff0f1
    9aee:  f0078793           addi a5,a5,-256 # ffffffffff0f0f00 <gpio_get_boot_device
    9af2:  8ff9                 and a5,a5,a4
    9af4:  fef42623           sw a5,-20(s0)
    9af8:  fec42703           lw a4,-20(s0)
    9afc:  004047b7           lui a5,0x404
    9b00:  04478793           addi a5,a5,68 # 404044 <gpio_get_boot_device+0x3f5cae>
    9b04:  8fd9                 or a5,a5,a4
    9b06:  fef42623           sw a5,-20(s0)
    9b0a:  fe846783           lwu a5,-24(s0)
    9b0e:  873e                 mv a4,a5
    9b10:  fec42783           lw a5,-20(s0)
    9b14:  c31c                 sw a5,0(a4)
    9b16:  0001                 nop
    9b18:  6462                 ld s0,24(sp)
    9b1a:  6105                 addi sp,sp,32
    9b1c:  8082                 ret
0000000000009b1e <riscv_init_caches>:
    9b1e:  1141                 addi sp,sp,-16
    9b20:  e406                 sd ra,8(sp)
    9b22:  e022                 sd s0,0(sp)
    9b24:  0800                 addi s0,sp,16
    9b26:  b4efe0ef           jal ra,7e74 <brom_config_skip_cache_setup>
    9b2a:  87aa                 mv a5,a0
    9b2c:  eb91                 bnez a5,9b40 <riscv_init_caches+0x22>
    9b2e:  7c1022f3           csrr t0,mhcr
    9b32:  0012e313           ori t1,t0,1
    9b36:  ffd37393           andi t2,t1,-3
    9b3a:  7c139073           csrw mhcr,t2
    9b3e:  a011                 j 9b42 <riscv_init_caches+0x24>
    9b40:  0001                 nop
    9b42:  60a2                 ld ra,8(sp)
    9b44:  6402                 ld s0,0(sp)
    9b46:  0141                 addi sp,sp,16
    9b48:  8082                 ret
0000000000009b4a <fel_boot>:
    9b4a:  1101                 addi sp,sp,-32
    9b4c:  ec06                 sd ra,24(sp)
    9b4e:  e822                 sd s0,16(sp)
    9b50:  1000                 addi s0,sp,32
    9b52:  87aa                 mv a5,a0
    9b54:  fef42623           sw a5,-20(s0)
    9b58:  f6fff0ef           jal ra,9ac6 <gpio_enable_jtag_pf>
    9b5c:  fec42783           lw a5,-20(s0)
    9b60:  0007871b           sext.w a4,a5
    9b64:  07f00793           li a5,127
    9b68:  00f71a63           bne a4,a5,9b7c <fel_boot+0x32>
    9b6c:  a4efe0ef           jal ra,7dba <sid_init_brom_config>
    9b70:  e77ff0ef           jal ra,99e6 <ccu_init>
    9b74:  4581                 li a1,0
    9b76:  4541                 li a0,16
    9b78:  e89ff0ef           jal ra,9a00 <debug_syscon>
    9b7c:  c50fe0ef           jal ra,7fcc <brom_config_disable_fel>
    9b80:  87aa                 mv a5,a0
    9b82:  c791                 beqz a5,9b8e <fel_boot+0x44>
    9b84:  4581                 li a1,0
    9b86:  4531                 li a0,12
    9b88:  ebcfe0ef           jal ra,8244 <debug_state_save>
    9b8c:  a001                 j 9b8c <fel_boot+0x42>
    9b8e:  4581                 li a1,0
    9b90:  453d                 li a0,15
    9b92:  e6fff0ef           jal ra,9a00 <debug_syscon>
    9b96:  0f3030ef           jal ra,d488 <fel_main>
    9b9a:  0001                 nop
    9b9c:  60e2                 ld ra,24(sp)
    9b9e:  6442                 ld s0,16(sp)
    9ba0:  6105                 addi sp,sp,32
    9ba2:  8082                 ret
0000000000009ba4 <boot_finish>:
    9ba4:  7179                 addi sp,sp,-48
    9ba6:  f406                 sd ra,40(sp)
    9ba8:  f022                 sd s0,32(sp)
    9baa:  1800                 addi s0,sp,48
    9bac:  87aa                 mv a5,a0
    9bae:  872e                 mv a4,a1
    9bb0:  fcf42e23           sw a5,-36(s0)
    9bb4:  87ba                 mv a5,a4
    9bb6:  fcf42c23           sw a5,-40(s0)
    9bba:  fe042623           sw zero,-20(s0)
    9bbe:  fdc46783           lwu a5,-36(s0)
    9bc2:  fef43023           sd a5,-32(s0)
    9bc6:  fdc42783           lw a5,-36(s0)
    9bca:  853e                 mv a0,a5
    9bcc:  de8f60ef           jal ra,1b4 <boot_jump>
    9bd0:  0001                 nop
    9bd2:  70a2                 ld ra,40(sp)
    9bd4:  7402                 ld s0,32(sp)
    9bd6:  6145                 addi sp,sp,48
    9bd8:  8082                 ret
0000000000009bda <trap_handler>:
    9bda:  7179                 addi sp,sp,-48
    9bdc:  f406                 sd ra,40(sp)
    9bde:  f022                 sd s0,32(sp)
    9be0:  1800                 addi s0,sp,48
    9be2:  fca43c23           sd a0,-40(s0)
    9be6:  fe042623           sw zero,-20(s0)
    9bea:  fd843783           ld a5,-40(s0)
    9bee:  2781                 sext.w a5,a5
    9bf0:  8bbd                 andi a5,a5,15
    9bf2:  fef42623           sw a5,-20(s0)
    9bf6:  fd843783           ld a5,-40(s0)
    9bfa:  0207d563           bgez a5,9c24 <trap_handler+0x4a>
    9bfe:  fec42783           lw a5,-20(s0)
    9c02:  0007871b           sext.w a4,a5
    9c06:  47ad                 li a5,11
    9c08:  00f71563           bne a4,a5,9c12 <trap_handler+0x38>
    9c0c:  3ca010ef           jal ra,afd6 <interrupt_handler>
    9c10:  a00d                 j 9c32 <trap_handler+0x58>
    9c12:  fec42783           lw a5,-20(s0)
    9c16:  85be                 mv a1,a5
    9c18:  4501                 li a0,0
    9c1a:  e2afe0ef           jal ra,8244 <debug_state_save>
    9c1e:  a001                 j 9c1e <trap_handler+0x44>
    9c20:  0001                 nop
    9c22:  a801                 j 9c32 <trap_handler+0x58>
    9c24:  fec42783           lw a5,-20(s0)
    9c28:  85be                 mv a1,a5
    9c2a:  4501                 li a0,0
    9c2c:  e18fe0ef           jal ra,8244 <debug_state_save>
    9c30:  a001                 j 9c30 <trap_handler+0x56>
    9c32:  0001                 nop
    9c34:  70a2                 ld ra,40(sp)
    9c36:  7402                 ld s0,32(sp)
    9c38:  6145                 addi sp,sp,48
    9c3a:  8082                 ret
0000000000009c3c <FUN_00009c3c>:
    9c3c:  7139                 addi sp,sp,-64
    9c3e:  fc06                 sd ra,56(sp)
    9c40:  f822                 sd s0,48(sp)
    9c42:  0080                 addi s0,sp,64
    9c44:  87aa                 mv a5,a0
    9c46:  fcd43423           sd a3,-56(s0)
    9c4a:  fcf42e23           sw a5,-36(s0)
    9c4e:  87ae                 mv a5,a1
    9c50:  fcf42c23           sw a5,-40(s0)
    9c54:  87b2                 mv a5,a2
    9c56:  fcf42a23           sw a5,-44(s0)
    9c5a:  87ba                 mv a5,a4
    9c5c:  fcf42823           sw a5,-48(s0)
    9c60:  000457b7           lui a5,0x45
    9c64:  fef43423           sd a5,-24(s0)
    9c68:  fe843783           ld a5,-24(s0)
    9c6c:  fdc42703           lw a4,-36(s0)
    9c70:  c398                 sw a4,0(a5)
    9c72:  fe843783           ld a5,-24(s0)
    9c76:  fd442703           lw a4,-44(s0)
    9c7a:  c3d8                 sw a4,4(a5)
    9c7c:  fc843783           ld a5,-56(s0)
    9c80:  0007871b           sext.w a4,a5
    9c84:  fe843783           ld a5,-24(s0)
    9c88:  c798                 sw a4,8(a5)
    9c8a:  fe843783           ld a5,-24(s0)
    9c8e:  fd042703           lw a4,-48(s0)
    9c92:  c7d8                 sw a4,12(a5)
    9c94:  fe843783           ld a5,-24(s0)
    9c98:  fd842703           lw a4,-40(s0)
    9c9c:  cb98                 sw a4,16(a5)
    9c9e:  fe843783           ld a5,-24(s0)
    9ca2:  80000713           li a4,-2048
    9ca6:  cbd8                 sw a4,20(a5)
    9ca8:  030027b7           lui a5,0x3002
    9cac:  10078793           addi a5,a5,256 # 3002100 <gpio_get_boot_device+0x2ff3d6a
    9cb0:  0007a023           sw zero,0(a5)
    9cb4:  030027b7           lui a5,0x3002
    9cb8:  07c1                 addi a5,a5,16
    9cba:  473d                 li a4,15
    9cbc:  c398                 sw a4,0(a5)
    9cbe:  fe843703           ld a4,-24(s0)
    9cc2:  030027b7           lui a5,0x3002
    9cc6:  10878793           addi a5,a5,264 # 3002108 <gpio_get_boot_device+0x2ff3d72
    9cca:  2701                 sext.w a4,a4
    9ccc:  c398                 sw a4,0(a5)
    9cce:  a7efe0ef           jal ra,7f4c <brom_config_bit_6>
    9cd2:  87aa                 mv a5,a0
    9cd4:  cb81                 beqz a5,9ce4 <FUN_00009c3c+0xa8>
    9cd6:  030027b7           lui a5,0x3002
    9cda:  12878793           addi a5,a5,296 # 3002128 <gpio_get_boot_device+0x2ff3d92
    9cde:  0007a023           sw zero,0(a5)
    9ce2:  a039                 j 9cf0 <FUN_00009c3c+0xb4>
    9ce4:  030027b7           lui a5,0x3002
    9ce8:  12878793           addi a5,a5,296 # 3002128 <gpio_get_boot_device+0x2ff3d92
    9cec:  4731                 li a4,12
    9cee:  c398                 sw a4,0(a5)
    9cf0:  030027b7           lui a5,0x3002
    9cf4:  10078793           addi a5,a5,256 # 3002100 <gpio_get_boot_device+0x2ff3d6a
    9cf8:  4705                 li a4,1
    9cfa:  c398                 sw a4,0(a5)
    9cfc:  4781                 li a5,0
    9cfe:  853e                 mv a0,a5
    9d00:  70e2                 ld ra,56(sp)
    9d02:  7442                 ld s0,48(sp)
    9d04:  6121                 addi sp,sp,64
    9d06:  8082                 ret
0000000000009d08 <FUN_00009d08>:
    9d08:  1141                 addi sp,sp,-16
    9d0a:  e422                 sd s0,8(sp)
    9d0c:  0800                 addi s0,sp,16
    9d0e:  030027b7           lui a5,0x3002
    9d12:  03078793           addi a5,a5,48 # 3002030 <gpio_get_boot_device+0x2ff3c9a>
    9d16:  439c                 lw a5,0(a5)
    9d18:  2781                 sext.w a5,a5
    9d1a:  8b85                 andi a5,a5,1
    9d1c:  2781                 sext.w a5,a5
    9d1e:  0017b793           seqz a5,a5
    9d22:  0ff7f793           andi a5,a5,255
    9d26:  2781                 sext.w a5,a5
    9d28:  853e                 mv a0,a5
    9d2a:  6422                 ld s0,8(sp)
    9d2c:  0141                 addi sp,sp,16
    9d2e:  8082                 ret
0000000000009d30 <FUN_00009d30>:
    9d30:  1141                 addi sp,sp,-16
    9d32:  e422                 sd s0,8(sp)
    9d34:  0800                 addi s0,sp,16
    9d36:  030027b7           lui a5,0x3002
    9d3a:  10478793           addi a5,a5,260 # 3002104 <gpio_get_boot_device+0x2ff3d6e
    9d3e:  4705                 li a4,1
    9d40:  c398                 sw a4,0(a5)
    9d42:  030027b7           lui a5,0x3002
    9d46:  10078793           addi a5,a5,256 # 3002100 <gpio_get_boot_device+0x2ff3d6a
    9d4a:  0007a023           sw zero,0(a5)
    9d4e:  030027b7           lui a5,0x3002
    9d52:  10478793           addi a5,a5,260 # 3002104 <gpio_get_boot_device+0x2ff3d6e
    9d56:  0007a023           sw zero,0(a5)
    9d5a:  030027b7           lui a5,0x3002
    9d5e:  10878793           addi a5,a5,264 # 3002108 <gpio_get_boot_device+0x2ff3d72
    9d62:  80000713           li a4,-2048
    9d66:  c398                 sw a4,0(a5)
    9d68:  030027b7           lui a5,0x3002
    9d6c:  12878793           addi a5,a5,296 # 3002128 <gpio_get_boot_device+0x2ff3d92
    9d70:  0007a023           sw zero,0(a5)
    9d74:  030027b7           lui a5,0x3002
    9d78:  07c1                 addi a5,a5,16
    9d7a:  473d                 li a4,15
    9d7c:  c398                 sw a4,0(a5)
    9d7e:  4781                 li a5,0
    9d80:  853e                 mv a0,a5
    9d82:  6422                 ld s0,8(sp)
    9d84:  0141                 addi sp,sp,16
    9d86:  8082                 ret
0000000000009d88 <FUN_00009d88>:
    9d88:  1101                 addi sp,sp,-32
    9d8a:  ec22                 sd s0,24(sp)
    9d8c:  1000                 addi s0,sp,32
    9d8e:  fe042623           sw zero,-20(s0)
    9d92:  fe042423           sw zero,-24(s0)
    9d96:  020017b7           lui a5,0x2001
    9d9a:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9d9e:  439c                 lw a5,0(a5)
    9da0:  0007871b           sext.w a4,a5
    9da4:  020017b7           lui a5,0x2001
    9da8:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9dac:  9b79                 andi a4,a4,-2
    9dae:  2701                 sext.w a4,a4
    9db0:  c398                 sw a4,0(a5)
    9db2:  020017b7           lui a5,0x2001
    9db6:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9dba:  439c                 lw a5,0(a5)
    9dbc:  0007871b           sext.w a4,a5
    9dc0:  020017b7           lui a5,0x2001
    9dc4:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9dc8:  86ba                 mv a3,a4
    9dca:  7741                 lui a4,0xffff0
    9dcc:  177d                 addi a4,a4,-1
    9dce:  8f75                 and a4,a4,a3
    9dd0:  2701                 sext.w a4,a4
    9dd2:  c398                 sw a4,0(a5)
    9dd4:  020017b7           lui a5,0x2001
    9dd8:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9ddc:  439c                 lw a5,0(a5)
    9dde:  0007871b           sext.w a4,a5
    9de2:  020017b7           lui a5,0x2001
    9de6:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9dea:  86ba                 mv a3,a4
    9dec:  6741                 lui a4,0x10
    9dee:  8f55                 or a4,a4,a3
    9df0:  2701                 sext.w a4,a4
    9df2:  c398                 sw a4,0(a5)
    9df4:  020017b7           lui a5,0x2001
    9df8:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9dfc:  439c                 lw a5,0(a5)
    9dfe:  0007871b           sext.w a4,a5
    9e02:  020017b7           lui a5,0x2001
    9e06:  70c78793           addi a5,a5,1804 # 200170c <gpio_get_boot_device+0x1ff337
    9e0a:  00176713           ori a4,a4,1
    9e0e:  2701                 sext.w a4,a4
    9e10:  c398                 sw a4,0(a5)
    9e12:  030027b7           lui a5,0x3002
    9e16:  02078793           addi a5,a5,32 # 3002020 <gpio_get_boot_device+0x2ff3c8a>
    9e1a:  439c                 lw a5,0(a5)
    9e1c:  fef42423           sw a5,-24(s0)
    9e20:  fe842703           lw a4,-24(s0)
    9e24:  77c1                 lui a5,0xffff0
    9e26:  8ff9                 and a5,a5,a4
    9e28:  fef42423           sw a5,-24(s0)
    9e2c:  030027b7           lui a5,0x3002
    9e30:  02078793           addi a5,a5,32 # 3002020 <gpio_get_boot_device+0x2ff3c8a>
    9e34:  fe842703           lw a4,-24(s0)
    9e38:  c398                 sw a4,0(a5)
    9e3a:  fe042623           sw zero,-20(s0)
    9e3e:  a02d                 j 9e68 <FUN_00009d88+0xe0>
    9e40:  fec42783           lw a5,-20(s0)
    9e44:  0067979b           slliw a5,a5,0x6
    9e48:  2781                 sext.w a5,a5
    9e4a:  02079713           slli a4,a5,0x20
    9e4e:  9301                 srli a4,a4,0x20
    9e50:  030027b7           lui a5,0x3002
    9e54:  10078793           addi a5,a5,256 # 3002100 <gpio_get_boot_device+0x2ff3d6a
    9e58:  97ba                 add a5,a5,a4
    9e5a:  0007a023           sw zero,0(a5)
    9e5e:  fec42783           lw a5,-20(s0)
    9e62:  2785                 addiw a5,a5,1
    9e64:  fef42623           sw a5,-20(s0)
    9e68:  fec42783           lw a5,-20(s0)
    9e6c:  0007871b           sext.w a4,a5
    9e70:  479d                 li a5,7
    9e72:  fce7f7e3           bgeu a5,a4,9e40 <FUN_00009d88+0xb8>
    9e76:  030027b7           lui a5,0x3002
    9e7a:  02878793           addi a5,a5,40 # 3002028 <gpio_get_boot_device+0x2ff3c92>
    9e7e:  471d                 li a4,7
    9e80:  c398                 sw a4,0(a5)
    9e82:  0001                 nop
    9e84:  6462                 ld s0,24(sp)
    9e86:  6105                 addi sp,sp,32
    9e88:  8082                 ret
0000000000009e8a <memcpy>:
    9e8a:  7139                 addi sp,sp,-64
    9e8c:  fc22                 sd s0,56(sp)
    9e8e:  0080                 addi s0,sp,64
    9e90:  fca43c23           sd a0,-40(s0)
    9e94:  fcb43823           sd a1,-48(s0)
    9e98:  87b2                 mv a5,a2
    9e9a:  fcf42623           sw a5,-52(s0)
    9e9e:  fd843783           ld a5,-40(s0)
    9ea2:  fef43423           sd a5,-24(s0)
    9ea6:  fd043783           ld a5,-48(s0)
    9eaa:  fef43023           sd a5,-32(s0)
    9eae:  a00d                 j 9ed0 <memcpy+0x46>
    9eb0:  fe043703           ld a4,-32(s0)
    9eb4:  00170793           addi a5,a4,1 # 10001 <gpio_get_boot_device+0x1c6b>
    9eb8:  fef43023           sd a5,-32(s0)
    9ebc:  fe843783           ld a5,-24(s0)
    9ec0:  00178693           addi a3,a5,1
    9ec4:  fed43423           sd a3,-24(s0)
    9ec8:  00074703           lbu a4,0(a4)
    9ecc:  00e78023           sb a4,0(a5)
    9ed0:  fcc42783           lw a5,-52(s0)
    9ed4:  fff7871b           addiw a4,a5,-1
    9ed8:  fce42623           sw a4,-52(s0)
    9edc:  fbf1                 bnez a5,9eb0 <memcpy+0x26>
    9ede:  fd843783           ld a5,-40(s0)
    9ee2:  853e                 mv a0,a5
    9ee4:  7462                 ld s0,56(sp)
    9ee6:  6121                 addi sp,sp,64
    9ee8:  8082                 ret
0000000000009eea <memset>:
    9eea:  7179                 addi sp,sp,-48
    9eec:  f422                 sd s0,40(sp)
    9eee:  1800                 addi s0,sp,48
    9ef0:  fca43c23           sd a0,-40(s0)
    9ef4:  87ae                 mv a5,a1
    9ef6:  8732                 mv a4,a2
    9ef8:  fcf40ba3           sb a5,-41(s0)
    9efc:  87ba                 mv a5,a4
    9efe:  fcf42823           sw a5,-48(s0)
    9f02:  fd843783           ld a5,-40(s0)
    9f06:  fef43423           sd a5,-24(s0)
    9f0a:  a819                 j 9f20 <memset+0x36>
    9f0c:  fe843783           ld a5,-24(s0)
    9f10:  00178713           addi a4,a5,1
    9f14:  fee43423           sd a4,-24(s0)
    9f18:  fd744703           lbu a4,-41(s0)
    9f1c:  00e78023           sb a4,0(a5)
    9f20:  fd042783           lw a5,-48(s0)
    9f24:  fff7871b           addiw a4,a5,-1
    9f28:  fce42823           sw a4,-48(s0)
    9f2c:  f3e5                 bnez a5,9f0c <memset+0x22>
    9f2e:  fd843783           ld a5,-40(s0)
    9f32:  853e                 mv a0,a5
    9f34:  7422                 ld s0,40(sp)
    9f36:  6145                 addi sp,sp,48
    9f38:  8082                 ret
0000000000009f3a <FUN_00009f3a>:
    9f3a:  7179                 addi sp,sp,-48
    9f3c:  f406                 sd ra,40(sp)
    9f3e:  f022                 sd s0,32(sp)
    9f40:  1800                 addi s0,sp,48
    9f42:  fea43423           sd a0,-24(s0)
    9f46:  feb43023           sd a1,-32(s0)
    9f4a:  87b2                 mv a5,a2
    9f4c:  fcf42e23           sw a5,-36(s0)
    9f50:  fdc42783           lw a5,-36(s0)
    9f54:  863e                 mv a2,a5
    9f56:  fe043583           ld a1,-32(s0)
    9f5a:  fe843503           ld a0,-24(s0)
    9f5e:  f2dff0ef           jal ra,9e8a <memcpy>
    9f62:  0001                 nop
    9f64:  70a2                 ld ra,40(sp)
    9f66:  7402                 ld s0,32(sp)
    9f68:  6145                 addi sp,sp,48
    9f6a:  8082                 ret
0000000000009f6c <FUN_00009f6c>:
    9f6c:  7159                 addi sp,sp,-112
    9f6e:  f4a2                 sd s0,104(sp)
    9f70:  1880                 addi s0,sp,112
    9f72:  faa43423           sd a0,-88(s0)
    9f76:  fab43023           sd a1,-96(s0)
    9f7a:  87b2                 mv a5,a2
    9f7c:  f8f42e23           sw a5,-100(s0)
    9f80:  fe042623           sw zero,-20(s0)
    9f84:  fa843783           ld a5,-88(s0)
    9f88:  fef43023           sd a5,-32(s0)
    9f8c:  fa043783           ld a5,-96(s0)
    9f90:  fcf43c23           sd a5,-40(s0)
    9f94:  f9c42783           lw a5,-100(s0)
    9f98:  0027d79b           srliw a5,a5,0x2
    9f9c:  fcf42a23           sw a5,-44(s0)
    9fa0:  fd442783           lw a5,-44(s0)
    9fa4:  0027979b           slliw a5,a5,0x2
    9fa8:  2781                 sext.w a5,a5
    9faa:  02079713           slli a4,a5,0x20
    9fae:  9301                 srli a4,a4,0x20
    9fb0:  fa843783           ld a5,-88(s0)
    9fb4:  97ba                 add a5,a5,a4
    9fb6:  fcf43423           sd a5,-56(s0)
    9fba:  fd442783           lw a5,-44(s0)
    9fbe:  0027979b           slliw a5,a5,0x2
    9fc2:  2781                 sext.w a5,a5
    9fc4:  02079713           slli a4,a5,0x20
    9fc8:  9301                 srli a4,a4,0x20
    9fca:  fa043783           ld a5,-96(s0)
    9fce:  97ba                 add a5,a5,a4
    9fd0:  fcf43023           sd a5,-64(s0)
    9fd4:  fd442783           lw a5,-44(s0)
    9fd8:  0027979b           slliw a5,a5,0x2
    9fdc:  2781                 sext.w a5,a5
    9fde:  f9c42703           lw a4,-100(s0)
    9fe2:  40f707bb           subw a5,a4,a5
    9fe6:  faf42e23           sw a5,-68(s0)
    9fea:  fe042623           sw zero,-20(s0)
    9fee:  a025                 j a016 <FUN_00009f6c+0xaa>
    9ff0:  fec42783           lw a5,-20(s0)
    9ff4:  078a                 slli a5,a5,0x2
    9ff6:  fd843703           ld a4,-40(s0)
    9ffa:  973e                 add a4,a4,a5
    9ffc:  fec42783           lw a5,-20(s0)
    a000:  078a                 slli a5,a5,0x2
    a002:  fe043683           ld a3,-32(s0)
    a006:  97b6                 add a5,a5,a3
    a008:  4318                 lw a4,0(a4)
    a00a:  c398                 sw a4,0(a5)
    a00c:  fec42783           lw a5,-20(s0)
    a010:  2785                 addiw a5,a5,1
    a012:  fef42623           sw a5,-20(s0)
    a016:  fec42703           lw a4,-20(s0)
    a01a:  fd442783           lw a5,-44(s0)
    a01e:  2781                 sext.w a5,a5
    a020:  fcf768e3           bltu a4,a5,9ff0 <FUN_00009f6c+0x84>
    a024:  fe042623           sw zero,-20(s0)
    a028:  a025                 j a050 <FUN_00009f6c+0xe4>
    a02a:  fec42783           lw a5,-20(s0)
    a02e:  fc043703           ld a4,-64(s0)
    a032:  973e                 add a4,a4,a5
    a034:  fec42783           lw a5,-20(s0)
    a038:  fc843683           ld a3,-56(s0)
    a03c:  97b6                 add a5,a5,a3
    a03e:  00074703           lbu a4,0(a4)
    a042:  00e78023           sb a4,0(a5)
    a046:  fec42783           lw a5,-20(s0)
    a04a:  2785                 addiw a5,a5,1
    a04c:  fef42623           sw a5,-20(s0)
    a050:  fec42703           lw a4,-20(s0)
    a054:  fbc42783           lw a5,-68(s0)
    a058:  2781                 sext.w a5,a5
    a05a:  fcf768e3           bltu a4,a5,a02a <FUN_00009f6c+0xbe>
    a05e:  0001                 nop
    a060:  7426                 ld s0,104(sp)
    a062:  6165                 addi sp,sp,112
    a064:  8082                 ret
000000000000a066 <memset>:
    a066:  1101                 addi sp,sp,-32
    a068:  ec06                 sd ra,24(sp)
    a06a:  e822                 sd s0,16(sp)
    a06c:  1000                 addi s0,sp,32
    a06e:  fea43423           sd a0,-24(s0)
    a072:  87ae                 mv a5,a1
    a074:  8732                 mv a4,a2
    a076:  fef42223           sw a5,-28(s0)
    a07a:  87ba                 mv a5,a4
    a07c:  fef42023           sw a5,-32(s0)
    a080:  fe442783           lw a5,-28(s0)
    a084:  0ff7f793           andi a5,a5,255
    a088:  fe042703           lw a4,-32(s0)
    a08c:  863a                 mv a2,a4
    a08e:  85be                 mv a1,a5
    a090:  fe843503           ld a0,-24(s0)
    a094:  e57ff0ef           jal ra,9eea <memset>
    a098:  0001                 nop
    a09a:  60e2                 ld ra,24(sp)
    a09c:  6442                 ld s0,16(sp)
    a09e:  6105                 addi sp,sp,32
    a0a0:  8082                 ret
000000000000a0a2 <FUN_0000a0a2>:
    a0a2:  7139                 addi sp,sp,-64
    a0a4:  fc22                 sd s0,56(sp)
    a0a6:  0080                 addi s0,sp,64
    a0a8:  fca43c23           sd a0,-40(s0)
    a0ac:  fcb43823           sd a1,-48(s0)
    a0b0:  87b2                 mv a5,a2
    a0b2:  fcf42623           sw a5,-52(s0)
    a0b6:  fe042623           sw zero,-20(s0)
    a0ba:  fe042623           sw zero,-20(s0)
    a0be:  a80d                 j a0f0 <FUN_0000a0a2+0x4e>
    a0c0:  fec42783           lw a5,-20(s0)
    a0c4:  fd843703           ld a4,-40(s0)
    a0c8:  97ba                 add a5,a5,a4
    a0ca:  0007c683           lbu a3,0(a5)
    a0ce:  fec42783           lw a5,-20(s0)
    a0d2:  fd043703           ld a4,-48(s0)
    a0d6:  97ba                 add a5,a5,a4
    a0d8:  0007c783           lbu a5,0(a5)
    a0dc:  8736                 mv a4,a3
    a0de:  00f70463           beq a4,a5,a0e6 <FUN_0000a0a2+0x44>
    a0e2:  57fd                 li a5,-1
    a0e4:  a831                 j a100 <FUN_0000a0a2+0x5e>
    a0e6:  fec42783           lw a5,-20(s0)
    a0ea:  2785                 addiw a5,a5,1
    a0ec:  fef42623           sw a5,-20(s0)
    a0f0:  fec42703           lw a4,-20(s0)
    a0f4:  fcc42783           lw a5,-52(s0)
    a0f8:  2781                 sext.w a5,a5
    a0fa:  fcf763e3           bltu a4,a5,a0c0 <FUN_0000a0a2+0x1e>
    a0fe:  4781                 li a5,0
    a100:  853e                 mv a0,a5
    a102:  7462                 ld s0,56(sp)
    a104:  6121                 addi sp,sp,64
    a106:  8082                 ret
000000000000a108 <strncmp>:
    a108:  7179                 addi sp,sp,-48
    a10a:  f422                 sd s0,40(sp)
    a10c:  f026                 sd s1,32(sp)
    a10e:  1800                 addi s0,sp,48
    a110:  fea43423           sd a0,-24(s0)
    a114:  feb43023           sd a1,-32(s0)
    a118:  87b2                 mv a5,a2
    a11a:  fcf42e23           sw a5,-36(s0)
    a11e:  4481                 li s1,0
    a120:  a0a1                 j a168 <strncmp+0x60>
    a122:  fe843783           ld a5,-24(s0)
    a126:  0007c703           lbu a4,0(a5)
    a12a:  fe043783           ld a5,-32(s0)
    a12e:  00178693           addi a3,a5,1
    a132:  fed43023           sd a3,-32(s0)
    a136:  0007c783           lbu a5,0(a5)
    a13a:  40f707bb           subw a5,a4,a5
    a13e:  0ff7f793           andi a5,a5,255
    a142:  0187949b           slliw s1,a5,0x18
    a146:  4184d49b           sraiw s1,s1,0x18
    a14a:  e09d                 bnez s1,a170 <strncmp+0x68>
    a14c:  fe843783           ld a5,-24(s0)
    a150:  00178713           addi a4,a5,1
    a154:  fee43423           sd a4,-24(s0)
    a158:  0007c783           lbu a5,0(a5)
    a15c:  cb91                 beqz a5,a170 <strncmp+0x68>
    a15e:  fdc42783           lw a5,-36(s0)
    a162:  37fd                 addiw a5,a5,-1
    a164:  fcf42e23           sw a5,-36(s0)
    a168:  fdc42783           lw a5,-36(s0)
    a16c:  2781                 sext.w a5,a5
    a16e:  fbd5                 bnez a5,a122 <strncmp+0x1a>
    a170:  0004879b           sext.w a5,s1
    a174:  853e                 mv a0,a5
    a176:  7422                 ld s0,40(sp)
    a178:  7482                 ld s1,32(sp)
    a17a:  6145                 addi sp,sp,48
    a17c:  8082                 ret
000000000000a17e <rdtime>:
    a17e:  c0102573           rdtime a0
    a182:  8082                 ret
000000000000a184 <udelay>:
    a184:  1101                 addi sp,sp,-32
    a186:  ec06                 sd ra,24(sp)
    a188:  e822                 sd s0,16(sp)
    a18a:  e426                 sd s1,8(sp)
    a18c:  00351413           slli s0,a0,0x3
    a190:  0512                 slli a0,a0,0x4
    a192:  942a                 add s0,s0,a0
    a194:  febff0ef           jal ra,a17e <rdtime>
    a198:  84aa                 mv s1,a0
    a19a:  fe5ff0ef           jal ra,a17e <rdtime>
    a19e:  8d05                 sub a0,a0,s1
    a1a0:  fe856de3           bltu a0,s0,a19a <udelay+0x16>
    a1a4:  60e2                 ld ra,24(sp)
    a1a6:  6442                 ld s0,16(sp)
    a1a8:  64a2                 ld s1,8(sp)
    a1aa:  6105                 addi sp,sp,32
    a1ac:  8082                 ret
000000000000a1ae <udelay_x800>:
    a1ae:  c505                 beqz a0,a1d6 <udelay_x800+0x28>
    a1b0:  1101                 addi sp,sp,-32
    a1b2:  ec06                 sd ra,24(sp)
    a1b4:  e822                 sd s0,16(sp)
    a1b6:  e426                 sd s1,8(sp)
    a1b8:  fff50413           addi s0,a0,-1 # 2000fff <gpio_get_boot_device+0x1ff2c69>
    a1bc:  54fd                 li s1,-1
    a1be:  32000513           li a0,800
    a1c2:  fc3ff0ef           jal ra,a184 <udelay>
    a1c6:  147d                 addi s0,s0,-1
    a1c8:  fe941be3           bne s0,s1,a1be <udelay_x800+0x10>
    a1cc:  60e2                 ld ra,24(sp)
    a1ce:  6442                 ld s0,16(sp)
    a1d0:  64a2                 ld s1,8(sp)
    a1d2:  6105                 addi sp,sp,32
    a1d4:  8082                 ret
    a1d6:  8082                 ret
000000000000a1d8 <FUN_0000a1d8>:
    a1d8:  1141                 addi sp,sp,-16
    a1da:  e422                 sd s0,8(sp)
    a1dc:  0800                 addi s0,sp,16
    a1de:  0001                 nop
    a1e0:  6422                 ld s0,8(sp)
    a1e2:  0141                 addi sp,sp,16
    a1e4:  8082                 ret
000000000000a1e6 <FUN_0000a1e6>:
    a1e6:  1141                 addi sp,sp,-16
    a1e8:  e422                 sd s0,8(sp)
    a1ea:  0800                 addi s0,sp,16
    a1ec:  0001                 nop
    a1ee:  6422                 ld s0,8(sp)
    a1f0:  0141                 addi sp,sp,16
    a1f2:  8082                 ret
000000000000a1f4 <FUN_0000a1f4>:
    a1f4:  7179                 addi sp,sp,-48
    a1f6:  f406                 sd ra,40(sp)
    a1f8:  f022                 sd s0,32(sp)
    a1fa:  1800                 addi s0,sp,48
    a1fc:  fca43c23           sd a0,-40(s0)
    a200:  fe042623           sw zero,-20(s0)
    a204:  a839                 j a222 <FUN_0000a1f4+0x2e>
    a206:  fec42783           lw a5,-20(s0)
    a20a:  2785                 addiw a5,a5,1
    a20c:  fef42623           sw a5,-20(s0)
    a210:  000487b7           lui a5,0x48
    a214:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    a218:  0807a783           lw a5,128(a5)
    a21c:  c399                 beqz a5,a222 <FUN_0000a1f4+0x2e>
    a21e:  671020ef           jal ra,d08e <fel_irq_handler>
    a222:  fd843783           ld a5,-40(s0)
    a226:  0207c783           lbu a5,32(a5)
    a22a:  0187979b           slliw a5,a5,0x18
    a22e:  4187d79b           sraiw a5,a5,0x18
    a232:  873e                 mv a4,a5
    a234:  4785                 li a5,1
    a236:  fcf708e3           beq a4,a5,a206 <FUN_0000a1f4+0x12>
    a23a:  0001                 nop
    a23c:  70a2                 ld ra,40(sp)
    a23e:  7402                 ld s0,32(sp)
    a240:  6145                 addi sp,sp,48
    a242:  8082                 ret
000000000000a244 <FUN_0000a244>:
    a244:  1101                 addi sp,sp,-32
    a246:  ec06                 sd ra,24(sp)
    a248:  e822                 sd s0,16(sp)
    a24a:  1000                 addi s0,sp,32
    a24c:  fea43423           sd a0,-24(s0)
    a250:  02200613           li a2,34
    a254:  4581                 li a1,0
    a256:  fe843503           ld a0,-24(s0)
    a25a:  c91ff0ef           jal ra,9eea <memset>
    a25e:  fe843783           ld a5,-24(s0)
    a262:  02078023           sb zero,32(a5)
    a266:  fe843783           ld a5,-24(s0)
    a26a:  020780a3           sb zero,33(a5)
    a26e:  0001                 nop
    a270:  60e2                 ld ra,24(sp)
    a272:  6442                 ld s0,16(sp)
    a274:  6105                 addi sp,sp,32
    a276:  8082                 ret
000000000000a278 <FUN_0000a278>:
    a278:  7179                 addi sp,sp,-48
    a27a:  f422                 sd s0,40(sp)
    a27c:  1800                 addi s0,sp,48
    a27e:  fea43423           sd a0,-24(s0)
    a282:  feb43023           sd a1,-32(s0)
    a286:  87b2                 mv a5,a2
    a288:  fcf42e23           sw a5,-36(s0)
    a28c:  fe843783           ld a5,-24(s0)
    a290:  fe043703           ld a4,-32(s0)
    a294:  e398                 sd a4,0(a5)
    a296:  fe843783           ld a5,-24(s0)
    a29a:  fdc42703           lw a4,-36(s0)
    a29e:  c798                 sw a4,8(a5)
    a2a0:  fe843783           ld a5,-24(s0)
    a2a4:  00078623           sb zero,12(a5)
    a2a8:  fe843783           ld a5,-24(s0)
    a2ac:  0007ac23           sw zero,24(a5)
    a2b0:  fe843783           ld a5,-24(s0)
    a2b4:  4705                 li a4,1
    a2b6:  02e78023           sb a4,32(a5)
    a2ba:  0001                 nop
    a2bc:  7422                 ld s0,40(sp)
    a2be:  6145                 addi sp,sp,48
    a2c0:  8082                 ret
000000000000a2c2 <FUN_0000a2c2>:
    a2c2:  715d                 addi sp,sp,-80
    a2c4:  e486                 sd ra,72(sp)
    a2c6:  e0a2                 sd s0,64(sp)
    a2c8:  0880                 addi s0,sp,80
    a2ca:  faa43c23           sd a0,-72(s0)
    a2ce:  fab43823           sd a1,-80(s0)
    a2d2:  fe043423           sd zero,-24(s0)
    a2d6:  fb843783           ld a5,-72(s0)
    a2da:  77bc                 ld a5,104(a5)
    a2dc:  fef43423           sd a5,-24(s0)
    a2e0:  fe843503           ld a0,-24(s0)
    a2e4:  f11ff0ef           jal ra,a1f4 <FUN_0000a1f4>
    a2e8:  fc840793           addi a5,s0,-56
    a2ec:  02000613           li a2,32
    a2f0:  4581                 li a1,0
    a2f2:  853e                 mv a0,a5
    a2f4:  bf7ff0ef           jal ra,9eea <memset>
    a2f8:  fb843503           ld a0,-72(s0)
    a2fc:  581000ef           jal ra,b07c <disable_interrupts>
    a300:  fc840793           addi a5,s0,-56
    a304:  02000613           li a2,32
    a308:  85be                 mv a1,a5
    a30a:  fe843503           ld a0,-24(s0)
    a30e:  f6bff0ef           jal ra,a278 <FUN_0000a278>
    a312:  fb043783           ld a5,-80(s0)
    a316:  4705                 li a4,1
    a318:  02e78023           sb a4,32(a5)
    a31c:  4601                 li a2,0
    a31e:  fe843583           ld a1,-24(s0)
    a322:  fb843503           ld a0,-72(s0)
    a326:  2e6020ef           jal ra,c60c <FUN_0000c60c>
    a32a:  fe843503           ld a0,-24(s0)
    a32e:  ec7ff0ef           jal ra,a1f4 <FUN_0000a1f4>
    a332:  fb043703           ld a4,-80(s0)
    a336:  fe843783           ld a5,-24(s0)
    a33a:  639c                 ld a5,0(a5)
    a33c:  02200613           li a2,34
    a340:  85be                 mv a1,a5
    a342:  853a                 mv a0,a4
    a344:  b47ff0ef           jal ra,9e8a <memcpy>
    a348:  0001                 nop
    a34a:  60a6                 ld ra,72(sp)
    a34c:  6406                 ld s0,64(sp)
    a34e:  6161                 addi sp,sp,80
    a350:  8082                 ret
000000000000a352 <FUN_0000a352>:
    a352:  7139                 addi sp,sp,-64
    a354:  fc06                 sd ra,56(sp)
    a356:  f822                 sd s0,48(sp)
    a358:  0080                 addi s0,sp,64
    a35a:  87aa                 mv a5,a0
    a35c:  fcb43823           sd a1,-48(s0)
    a360:  fcc43423           sd a2,-56(s0)
    a364:  fcd43023           sd a3,-64(s0)
    a368:  fcf40fa3           sb a5,-33(s0)
    a36c:  fe043423           sd zero,-24(s0)
    a370:  fdf44783           lbu a5,-33(s0)
    a374:  0ff7f793           andi a5,a5,255
    a378:  e799                 bnez a5,a386 <FUN_0000a352+0x34>
    a37a:  fd043783           ld a5,-48(s0)
    a37e:  77bc                 ld a5,104(a5)
    a380:  fef43423           sd a5,-24(s0)
    a384:  a031                 j a390 <FUN_0000a352+0x3e>
    a386:  fd043783           ld a5,-48(s0)
    a38a:  73bc                 ld a5,96(a5)
    a38c:  fef43423           sd a5,-24(s0)
    a390:  fe843503           ld a0,-24(s0)
    a394:  e61ff0ef           jal ra,a1f4 <FUN_0000a1f4>
    a398:  fc843783           ld a5,-56(s0)
    a39c:  4709                 li a4,2
    a39e:  02e78023           sb a4,32(a5)
    a3a2:  fd043503           ld a0,-48(s0)
    a3a6:  4d7000ef           jal ra,b07c <disable_interrupts>
    a3aa:  fc043783           ld a5,-64(s0)
    a3ae:  6398                 ld a4,0(a5)
    a3b0:  fc043783           ld a5,-64(s0)
    a3b4:  479c                 lw a5,8(a5)
    a3b6:  863e                 mv a2,a5
    a3b8:  85ba                 mv a1,a4
    a3ba:  fe843503           ld a0,-24(s0)
    a3be:  ebbff0ef           jal ra,a278 <FUN_0000a278>
    a3c2:  4601                 li a2,0
    a3c4:  fe843583           ld a1,-24(s0)
    a3c8:  fd043503           ld a0,-48(s0)
    a3cc:  240020ef           jal ra,c60c <FUN_0000c60c>
    a3d0:  fe843503           ld a0,-24(s0)
    a3d4:  e21ff0ef           jal ra,a1f4 <FUN_0000a1f4>
    a3d8:  0001                 nop
    a3da:  70e2                 ld ra,56(sp)
    a3dc:  7442                 ld s0,48(sp)
    a3de:  6121                 addi sp,sp,64
    a3e0:  8082                 ret
000000000000a3e2 <FUN_0000a3e2>:
    a3e2:  7139                 addi sp,sp,-64
    a3e4:  fc06                 sd ra,56(sp)
    a3e6:  f822                 sd s0,48(sp)
    a3e8:  0080                 addi s0,sp,64
    a3ea:  fca43c23           sd a0,-40(s0)
    a3ee:  fcb43823           sd a1,-48(s0)
    a3f2:  fcc43423           sd a2,-56(s0)
    a3f6:  fd043783           ld a5,-48(s0)
    a3fa:  0107c783           lbu a5,16(a5)
    a3fe:  fef407a3           sb a5,-17(s0)
    a402:  fef44783           lbu a5,-17(s0)
    a406:  0007871b           sext.w a4,a5
    a40a:  86ba                 mv a3,a4
    a40c:  47c5                 li a5,17
    a40e:  00f68663           beq a3,a5,a41a <FUN_0000a3e2+0x38>
    a412:  47c9                 li a5,18
    a414:  00f70d63           beq a4,a5,a42e <FUN_0000a3e2+0x4c>
    a418:  a02d                 j a442 <FUN_0000a3e2+0x60>
    a41a:  fc843683           ld a3,-56(s0)
    a41e:  fd043603           ld a2,-48(s0)
    a422:  fd843583           ld a1,-40(s0)
    a426:  4505                 li a0,1
    a428:  f2bff0ef           jal ra,a352 <FUN_0000a352>
    a42c:  a819                 j a442 <FUN_0000a3e2+0x60>
    a42e:  fc843683           ld a3,-56(s0)
    a432:  fd043603           ld a2,-48(s0)
    a436:  fd843583           ld a1,-40(s0)
    a43a:  4501                 li a0,0
    a43c:  f17ff0ef           jal ra,a352 <FUN_0000a352>
    a440:  0001                 nop
    a442:  0001                 nop
    a444:  70e2                 ld ra,56(sp)
    a446:  7442                 ld s0,48(sp)
    a448:  6121                 addi sp,sp,64
    a44a:  8082                 ret
000000000000a44c <FUN_0000a44c>:
    a44c:  715d                 addi sp,sp,-80
    a44e:  e486                 sd ra,72(sp)
    a450:  e0a2                 sd s0,64(sp)
    a452:  0880                 addi s0,sp,80
    a454:  fca43423           sd a0,-56(s0)
    a458:  fcb43023           sd a1,-64(s0)
    a45c:  fac43c23           sd a2,-72(s0)
    a460:  fe043423           sd zero,-24(s0)
    a464:  fc843783           ld a5,-56(s0)
    a468:  73bc                 ld a5,96(a5)
    a46a:  fef43423           sd a5,-24(s0)
    a46e:  fc043783           ld a5,-64(s0)
    a472:  470d                 li a4,3
    a474:  02e78023           sb a4,32(a5)
    a478:  535557b7           lui a5,0x53555
    a47c:  7417879b           addiw a5,a5,1857
    a480:  fcf42c23           sw a5,-40(s0)
    a484:  fc043783           ld a5,-64(s0)
    a488:  0047c703           lbu a4,4(a5) # 53555004 <gpio_get_boot_device+0x53546c6e
    a48c:  0057c683           lbu a3,5(a5)
    a490:  06a2                 slli a3,a3,0x8
    a492:  8f55                 or a4,a4,a3
    a494:  0067c683           lbu a3,6(a5)
    a498:  06c2                 slli a3,a3,0x10
    a49a:  8f55                 or a4,a4,a3
    a49c:  0077c783           lbu a5,7(a5)
    a4a0:  07e2                 slli a5,a5,0x18
    a4a2:  8fd9                 or a5,a5,a4
    a4a4:  2781                 sext.w a5,a5
    a4a6:  fcf42e23           sw a5,-36(s0)
    a4aa:  fe042023           sw zero,-32(s0)
    a4ae:  fe040223           sb zero,-28(s0)
    a4b2:  fc843503           ld a0,-56(s0)
    a4b6:  3c7000ef           jal ra,b07c <disable_interrupts>
    a4ba:  fd840793           addi a5,s0,-40
    a4be:  4635                 li a2,13
    a4c0:  85be                 mv a1,a5
    a4c2:  fe843503           ld a0,-24(s0)
    a4c6:  db3ff0ef           jal ra,a278 <FUN_0000a278>
    a4ca:  4601                 li a2,0
    a4cc:  fe843583           ld a1,-24(s0)
    a4d0:  fc843503           ld a0,-56(s0)
    a4d4:  138020ef           jal ra,c60c <FUN_0000c60c>
    a4d8:  fe843503           ld a0,-24(s0)
    a4dc:  d19ff0ef           jal ra,a1f4 <FUN_0000a1f4>
    a4e0:  0001                 nop
    a4e2:  60a6                 ld ra,72(sp)
    a4e4:  6406                 ld s0,64(sp)
    a4e6:  6161                 addi sp,sp,80
    a4e8:  8082                 ret
000000000000a4ea <FUN_0000a4ea>:
    a4ea:  715d                 addi sp,sp,-80
    a4ec:  e486                 sd ra,72(sp)
    a4ee:  e0a2                 sd s0,64(sp)
    a4f0:  0880                 addi s0,sp,80
    a4f2:  faa43c23           sd a0,-72(s0)
    a4f6:  fab43823           sd a1,-80(s0)
    a4fa:  fc840793           addi a5,s0,-56
    a4fe:  853e                 mv a0,a5
    a500:  d45ff0ef           jal ra,a244 <FUN_0000a244>
    a504:  fc840793           addi a5,s0,-56
    a508:  85be                 mv a1,a5
    a50a:  fb843503           ld a0,-72(s0)
    a50e:  db5ff0ef           jal ra,a2c2 <FUN_0000a2c2>
    a512:  fc840793           addi a5,s0,-56
    a516:  fb043603           ld a2,-80(s0)
    a51a:  85be                 mv a1,a5
    a51c:  fb843503           ld a0,-72(s0)
    a520:  ec3ff0ef           jal ra,a3e2 <FUN_0000a3e2>
    a524:  fc840793           addi a5,s0,-56
    a528:  fb043603           ld a2,-80(s0)
    a52c:  85be                 mv a1,a5
    a52e:  fb843503           ld a0,-72(s0)
    a532:  f1bff0ef           jal ra,a44c <FUN_0000a44c>
    a536:  fb043783           ld a5,-80(s0)
    a53a:  00078623           sb zero,12(a5)
    a53e:  0001                 nop
    a540:  60a6                 ld ra,72(sp)
    a542:  6406                 ld s0,64(sp)
    a544:  6161                 addi sp,sp,80
    a546:  8082                 ret
000000000000a548 <FUN_0000a548>:
    a548:  1101                 addi sp,sp,-32
    a54a:  ec06                 sd ra,24(sp)
    a54c:  e822                 sd s0,16(sp)
    a54e:  1000                 addi s0,sp,32
    a550:  fea43423           sd a0,-24(s0)
    a554:  feb43023           sd a1,-32(s0)
    a558:  fe043583           ld a1,-32(s0)
    a55c:  fe843503           ld a0,-24(s0)
    a560:  f8bff0ef           jal ra,a4ea <FUN_0000a4ea>
    a564:  0001                 nop
    a566:  60e2                 ld ra,24(sp)
    a568:  6442                 ld s0,16(sp)
    a56a:  6105                 addi sp,sp,32
    a56c:  8082                 ret
000000000000a56e <FUN_0000a56e>:
    a56e:  1101                 addi sp,sp,-32
    a570:  ec06                 sd ra,24(sp)
    a572:  e822                 sd s0,16(sp)
    a574:  1000                 addi s0,sp,32
    a576:  fea43423           sd a0,-24(s0)
    a57a:  87ae                 mv a5,a1
    a57c:  fef42223           sw a5,-28(s0)
    a580:  4641                 li a2,16
    a582:  4581                 li a1,0
    a584:  000487b7           lui a5,0x48
    a588:  d0078513           addi a0,a5,-768 # 47d00 <gpio_get_boot_device+0x3996a>
    a58c:  95fff0ef           jal ra,9eea <memset>
    a590:  000487b7           lui a5,0x48
    a594:  fe843703           ld a4,-24(s0)
    a598:  d0e7b023           sd a4,-768(a5) # 47d00 <gpio_get_boot_device+0x3996a>
    a59c:  000487b7           lui a5,0x48
    a5a0:  d0078793           addi a5,a5,-768 # 47d00 <gpio_get_boot_device+0x3996a>
    a5a4:  fe442703           lw a4,-28(s0)
    a5a8:  c798                 sw a4,8(a5)
    a5aa:  000487b7           lui a5,0x48
    a5ae:  d0078793           addi a5,a5,-768 # 47d00 <gpio_get_boot_device+0x3996a>
    a5b2:  4709                 li a4,2
    a5b4:  00e78623           sb a4,12(a5)
    a5b8:  000487b7           lui a5,0x48
    a5bc:  d0078793           addi a5,a5,-768 # 47d00 <gpio_get_boot_device+0x3996a>
    a5c0:  853e                 mv a0,a5
    a5c2:  60e2                 ld ra,24(sp)
    a5c4:  6442                 ld s0,16(sp)
    a5c6:  6105                 addi sp,sp,32
    a5c8:  8082                 ret
000000000000a5ca <FUN_0000a5ca>:
    a5ca:  715d                 addi sp,sp,-80
    a5cc:  e486                 sd ra,72(sp)
    a5ce:  e0a2                 sd s0,64(sp)
    a5d0:  0880                 addi s0,sp,80
    a5d2:  faa43c23           sd a0,-72(s0)
    a5d6:  fe043423           sd zero,-24(s0)
    a5da:  fc840793           addi a5,s0,-56
    a5de:  02000613           li a2,32
    a5e2:  4581                 li a1,0
    a5e4:  853e                 mv a0,a5
    a5e6:  905ff0ef           jal ra,9eea <memset>
    a5ea:  fc840713           addi a4,s0,-56
    a5ee:  4621                 li a2,8
    a5f0:  67b9                 lui a5,0xe
    a5f2:  55078593           addi a1,a5,1360 # e550 <gpio_get_boot_device+0x1ba>
    a5f6:  853a                 mv a0,a4
    a5f8:  893ff0ef           jal ra,9e8a <memcpy>
    a5fc:  001867b7           lui a5,0x186
    a600:  9007879b           addiw a5,a5,-1792
    a604:  fcf42823           sw a5,-48(s0)
    a608:  4785                 li a5,1
    a60a:  fcf42a23           sw a5,-44(s0)
    a60e:  4785                 li a5,1
    a610:  fcf41c23           sh a5,-40(s0)
    a614:  04400793           li a5,68
    a618:  fcf40d23           sb a5,-38(s0)
    a61c:  47a1                 li a5,8
    a61e:  fcf40da3           sb a5,-37(s0)
    a622:  000457b7           lui a5,0x45
    a626:  fcf42e23           sw a5,-36(s0)
    a62a:  fc840793           addi a5,s0,-56
    a62e:  02000593           li a1,32
    a632:  853e                 mv a0,a5
    a634:  f3bff0ef           jal ra,a56e <FUN_0000a56e>
    a638:  fea43423           sd a0,-24(s0)
    a63c:  fe843583           ld a1,-24(s0)
    a640:  fb843503           ld a0,-72(s0)
    a644:  ea7ff0ef           jal ra,a4ea <FUN_0000a4ea>
    a648:  0001                 nop
    a64a:  60a6                 ld ra,72(sp)
    a64c:  6406                 ld s0,64(sp)
    a64e:  6161                 addi sp,sp,80
    a650:  8082                 ret
000000000000a652 <FUN_0000a652>:
    a652:  715d                 addi sp,sp,-80
    a654:  e486                 sd ra,72(sp)
    a656:  e0a2                 sd s0,64(sp)
    a658:  0880                 addi s0,sp,80
    a65a:  faa43c23           sd a0,-72(s0)
    a65e:  fe043423           sd zero,-24(s0)
    a662:  fc840793           addi a5,s0,-56
    a666:  02000613           li a2,32
    a66a:  4581                 li a1,0
    a66c:  853e                 mv a0,a5
    a66e:  87dff0ef           jal ra,9eea <memset>
    a672:  fc840713           addi a4,s0,-56
    a676:  4621                 li a2,8
    a678:  67b9                 lui a5,0xe
    a67a:  55078593           addi a1,a5,1360 # e550 <gpio_get_boot_device+0x1ba>
    a67e:  853a                 mv a0,a4
    a680:  80bff0ef           jal ra,9e8a <memcpy>
    a684:  fc840793           addi a5,s0,-56
    a688:  00878713           addi a4,a5,8
    a68c:  4611                 li a2,4
    a68e:  67b9                 lui a5,0xe
    a690:  56078593           addi a1,a5,1376 # e560 <gpio_get_boot_device+0x1ca>
    a694:  853a                 mv a0,a4
    a696:  ff4ff0ef           jal ra,9e8a <memcpy>
    a69a:  000487b7           lui a5,0x48
    a69e:  d1078793           addi a5,a5,-752 # 47d10 <gpio_get_boot_device+0x3997a>
    a6a2:  2781                 sext.w a5,a5
    a6a4:  fcf42a23           sw a5,-44(s0)
    a6a8:  000277b7           lui a5,0x27
    a6ac:  fcf42c23           sw a5,-40(s0)
    a6b0:  fb843783           ld a5,-72(s0)
    a6b4:  0947a783           lw a5,148(a5) # 27094 <gpio_get_boot_device+0x18cfe>
    a6b8:  c789                 beqz a5,a6c2 <FUN_0000a652+0x70>
    a6ba:  4785                 li a5,1
    a6bc:  fcf41e23           sh a5,-36(s0)
    a6c0:  a019                 j a6c6 <FUN_0000a652+0x74>
    a6c2:  fc041e23           sh zero,-36(s0)
    a6c6:  fc840793           addi a5,s0,-56
    a6ca:  02000593           li a1,32
    a6ce:  853e                 mv a0,a5
    a6d0:  e9fff0ef           jal ra,a56e <FUN_0000a56e>
    a6d4:  fea43423           sd a0,-24(s0)
    a6d8:  fe843583           ld a1,-24(s0)
    a6dc:  fb843503           ld a0,-72(s0)
    a6e0:  e0bff0ef           jal ra,a4ea <FUN_0000a4ea>
    a6e4:  0001                 nop
    a6e6:  60a6                 ld ra,72(sp)
    a6e8:  6406                 ld s0,64(sp)
    a6ea:  6161                 addi sp,sp,80
    a6ec:  8082                 ret
000000000000a6ee <FUN_0000a6ee>:
    a6ee:  7139                 addi sp,sp,-64
    a6f0:  fc06                 sd ra,56(sp)
    a6f2:  f822                 sd s0,48(sp)
    a6f4:  0080                 addi s0,sp,64
    a6f6:  fca43423           sd a0,-56(s0)
    a6fa:  fe043423           sd zero,-24(s0)
    a6fe:  fd840793           addi a5,s0,-40
    a702:  4641                 li a2,16
    a704:  4581                 li a1,0
    a706:  853e                 mv a0,a5
    a708:  fe2ff0ef           jal ra,9eea <memset>
    a70c:  4789                 li a5,2
    a70e:  fcf41c23           sh a5,-40(s0)
    a712:  fc041d23           sh zero,-38(s0)
    a716:  fd840793           addi a5,s0,-40
    a71a:  45c1                 li a1,16
    a71c:  853e                 mv a0,a5
    a71e:  e51ff0ef           jal ra,a56e <FUN_0000a56e>
    a722:  fea43423           sd a0,-24(s0)
    a726:  fe843583           ld a1,-24(s0)
    a72a:  fc843503           ld a0,-56(s0)
    a72e:  dbdff0ef           jal ra,a4ea <FUN_0000a4ea>
    a732:  0001                 nop
    a734:  70e2                 ld ra,56(sp)
    a736:  7442                 ld s0,48(sp)
    a738:  6121                 addi sp,sp,64
    a73a:  8082                 ret
000000000000a73c <FUN_0000a73c>:
    a73c:  7139                 addi sp,sp,-64
    a73e:  fc06                 sd ra,56(sp)
    a740:  f822                 sd s0,48(sp)
    a742:  0080                 addi s0,sp,64
    a744:  fca43423           sd a0,-56(s0)
    a748:  fe043423           sd zero,-24(s0)
    a74c:  fd840793           addi a5,s0,-40
    a750:  4641                 li a2,16
    a752:  4581                 li a1,0
    a754:  853e                 mv a0,a5
    a756:  f94ff0ef           jal ra,9eea <memset>
    a75a:  1f400793           li a5,500
    a75e:  fcf41d23           sh a5,-38(s0)
    a762:  4789                 li a5,2
    a764:  fcf41c23           sh a5,-40(s0)
    a768:  fd840793           addi a5,s0,-40
    a76c:  45c1                 li a1,16
    a76e:  853e                 mv a0,a5
    a770:  dffff0ef           jal ra,a56e <FUN_0000a56e>
    a774:  fea43423           sd a0,-24(s0)
    a778:  fe843583           ld a1,-24(s0)
    a77c:  fc843503           ld a0,-56(s0)
    a780:  d6bff0ef           jal ra,a4ea <FUN_0000a4ea>
    a784:  0001                 nop
    a786:  70e2                 ld ra,56(sp)
    a788:  7442                 ld s0,48(sp)
    a78a:  6121                 addi sp,sp,64
    a78c:  8082                 ret
000000000000a78e <FUN_0000a78e>:
    a78e:  7179                 addi sp,sp,-48
    a790:  f422                 sd s0,40(sp)
    a792:  1800                 addi s0,sp,48
    a794:  87aa                 mv a5,a0
    a796:  fcf42e23           sw a5,-36(s0)
    a79a:  4785                 li a5,1
    a79c:  fef42423           sw a5,-24(s0)
    a7a0:  fe042623           sw zero,-20(s0)
    a7a4:  a825                 j a7dc <FUN_0000a78e+0x4e>
    a7a6:  67b9                 lui a5,0xe
    a7a8:  fec42703           lw a4,-20(s0)
    a7ac:  070e                 slli a4,a4,0x3
    a7ae:  5c078793           addi a5,a5,1472 # e5c0 <gpio_get_boot_device+0x22a>
    a7b2:  97ba                 add a5,a5,a4
    a7b4:  4398                 lw a4,0(a5)
    a7b6:  fdc42783           lw a5,-36(s0)
    a7ba:  2781                 sext.w a5,a5
    a7bc:  00e7eb63           bltu a5,a4,a7d2 <FUN_0000a78e+0x44>
    a7c0:  00038737           lui a4,0x38
    a7c4:  fdc42783           lw a5,-36(s0)
    a7c8:  2781                 sext.w a5,a5
    a7ca:  00e7f463           bgeu a5,a4,a7d2 <FUN_0000a78e+0x44>
    a7ce:  4785                 li a5,1
    a7d0:  a839                 j a7ee <FUN_0000a78e+0x60>
    a7d2:  fec42783           lw a5,-20(s0)
    a7d6:  2785                 addiw a5,a5,1
    a7d8:  fef42623           sw a5,-20(s0)
    a7dc:  fec42703           lw a4,-20(s0)
    a7e0:  fe842783           lw a5,-24(s0)
    a7e4:  2701                 sext.w a4,a4
    a7e6:  2781                 sext.w a5,a5
    a7e8:  faf74fe3           blt a4,a5,a7a6 <FUN_0000a78e+0x18>
    a7ec:  4781                 li a5,0
    a7ee:  853e                 mv a0,a5
    a7f0:  7422                 ld s0,40(sp)
    a7f2:  6145                 addi sp,sp,48
    a7f4:  8082                 ret
000000000000a7f6 <do_fel_write>:
    a7f6:  7179                 addi sp,sp,-48
    a7f8:  f406                 sd ra,40(sp)
    a7fa:  f022                 sd s0,32(sp)
    a7fc:  1800                 addi s0,sp,48
    a7fe:  fca43c23           sd a0,-40(s0)
    a802:  fcb43823           sd a1,-48(s0)
    a806:  fe043423           sd zero,-24(s0)
    a80a:  fe043023           sd zero,-32(s0)
    a80e:  fd043783           ld a5,-48(s0)
    a812:  e399                 bnez a5,a818 <do_fel_write+0x22>
    a814:  4785                 li a5,1
    a816:  aa29                 j a930 <do_fel_write+0x13a>
    a818:  fd043783           ld a5,-48(s0)
    a81c:  fef43423           sd a5,-24(s0)
    a820:  fe843783           ld a5,-24(s0)
    a824:  0087c703           lbu a4,8(a5)
    a828:  0097c683           lbu a3,9(a5)
    a82c:  06a2                 slli a3,a3,0x8
    a82e:  8f55                 or a4,a4,a3
    a830:  00a7c683           lbu a3,10(a5)
    a834:  06c2                 slli a3,a3,0x10
    a836:  8f55                 or a4,a4,a3
    a838:  00b7c783           lbu a5,11(a5)
    a83c:  07e2                 slli a5,a5,0x18
    a83e:  8fd9                 or a5,a5,a4
    a840:  2781                 sext.w a5,a5
    a842:  e399                 bnez a5,a848 <do_fel_write+0x52>
    a844:  4785                 li a5,1
    a846:  a0ed                 j a930 <do_fel_write+0x13a>
    a848:  fe843783           ld a5,-24(s0)
    a84c:  0047c703           lbu a4,4(a5)
    a850:  0057c683           lbu a3,5(a5)
    a854:  06a2                 slli a3,a3,0x8
    a856:  8f55                 or a4,a4,a3
    a858:  0067c683           lbu a3,6(a5)
    a85c:  06c2                 slli a3,a3,0x10
    a85e:  8f55                 or a4,a4,a3
    a860:  0077c783           lbu a5,7(a5)
    a864:  07e2                 slli a5,a5,0x18
    a866:  8fd9                 or a5,a5,a4
    a868:  2781                 sext.w a5,a5
    a86a:  853e                 mv a0,a5
    a86c:  f23ff0ef           jal ra,a78e <FUN_0000a78e>
    a870:  87aa                 mv a5,a0
    a872:  ebb9                 bnez a5,a8c8 <do_fel_write+0xd2>
    a874:  fe843783           ld a5,-24(s0)
    a878:  0047c703           lbu a4,4(a5)
    a87c:  0057c683           lbu a3,5(a5)
    a880:  06a2                 slli a3,a3,0x8
    a882:  8f55                 or a4,a4,a3
    a884:  0067c683           lbu a3,6(a5)
    a888:  06c2                 slli a3,a3,0x10
    a88a:  8f55                 or a4,a4,a3
    a88c:  0077c783           lbu a5,7(a5)
    a890:  07e2                 slli a5,a5,0x18
    a892:  8fd9                 or a5,a5,a4
    a894:  0007871b           sext.w a4,a5
    a898:  fe843783           ld a5,-24(s0)
    a89c:  0087c683           lbu a3,8(a5)
    a8a0:  0097c603           lbu a2,9(a5)
    a8a4:  0622                 slli a2,a2,0x8
    a8a6:  8ed1                 or a3,a3,a2
    a8a8:  00a7c603           lbu a2,10(a5)
    a8ac:  0642                 slli a2,a2,0x10
    a8ae:  8ed1                 or a3,a3,a2
    a8b0:  00b7c783           lbu a5,11(a5)
    a8b4:  07e2                 slli a5,a5,0x18
    a8b6:  8fd5                 or a5,a5,a3
    a8b8:  2781                 sext.w a5,a5
    a8ba:  9fb9                 addw a5,a5,a4
    a8bc:  2781                 sext.w a5,a5
    a8be:  853e                 mv a0,a5
    a8c0:  ecfff0ef           jal ra,a78e <FUN_0000a78e>
    a8c4:  87aa                 mv a5,a0
    a8c6:  c399                 beqz a5,a8cc <do_fel_write+0xd6>
    a8c8:  4785                 li a5,1
    a8ca:  a09d                 j a930 <do_fel_write+0x13a>
    a8cc:  fe843783           ld a5,-24(s0)
    a8d0:  0047c703           lbu a4,4(a5)
    a8d4:  0057c683           lbu a3,5(a5)
    a8d8:  06a2                 slli a3,a3,0x8
    a8da:  8f55                 or a4,a4,a3
    a8dc:  0067c683           lbu a3,6(a5)
    a8e0:  06c2                 slli a3,a3,0x10
    a8e2:  8f55                 or a4,a4,a3
    a8e4:  0077c783           lbu a5,7(a5)
    a8e8:  07e2                 slli a5,a5,0x18
    a8ea:  8fd9                 or a5,a5,a4
    a8ec:  2781                 sext.w a5,a5
    a8ee:  1782                 slli a5,a5,0x20
    a8f0:  9381                 srli a5,a5,0x20
    a8f2:  863e                 mv a2,a5
    a8f4:  fe843783           ld a5,-24(s0)
    a8f8:  0087c703           lbu a4,8(a5)
    a8fc:  0097c683           lbu a3,9(a5)
    a900:  06a2                 slli a3,a3,0x8
    a902:  8f55                 or a4,a4,a3
    a904:  00a7c683           lbu a3,10(a5)
    a908:  06c2                 slli a3,a3,0x10
    a90a:  8f55                 or a4,a4,a3
    a90c:  00b7c783           lbu a5,11(a5)
    a910:  07e2                 slli a5,a5,0x18
    a912:  8fd9                 or a5,a5,a4
    a914:  2781                 sext.w a5,a5
    a916:  85be                 mv a1,a5
    a918:  8532                 mv a0,a2
    a91a:  c55ff0ef           jal ra,a56e <FUN_0000a56e>
    a91e:  fea43023           sd a0,-32(s0)
    a922:  fe043583           ld a1,-32(s0)
    a926:  fd843503           ld a0,-40(s0)
    a92a:  bc1ff0ef           jal ra,a4ea <FUN_0000a4ea>
    a92e:  4781                 li a5,0
    a930:  853e                 mv a0,a5
    a932:  70a2                 ld ra,40(sp)
    a934:  7402                 ld s0,32(sp)
    a936:  6145                 addi sp,sp,48
    a938:  8082                 ret
000000000000a93a <do_fel_read>:
    a93a:  7179                 addi sp,sp,-48
    a93c:  f406                 sd ra,40(sp)
    a93e:  f022                 sd s0,32(sp)
    a940:  1800                 addi s0,sp,48
    a942:  fca43c23           sd a0,-40(s0)
    a946:  fcb43823           sd a1,-48(s0)
    a94a:  fe043423           sd zero,-24(s0)
    a94e:  fe043023           sd zero,-32(s0)
    a952:  fd043783           ld a5,-48(s0)
    a956:  e399                 bnez a5,a95c <do_fel_read+0x22>
    a958:  4785                 li a5,1
    a95a:  a859                 j a9f0 <do_fel_read+0xb6>
    a95c:  fd043783           ld a5,-48(s0)
    a960:  fef43423           sd a5,-24(s0)
    a964:  fe843783           ld a5,-24(s0)
    a968:  0087c703           lbu a4,8(a5)
    a96c:  0097c683           lbu a3,9(a5)
    a970:  06a2                 slli a3,a3,0x8
    a972:  8f55                 or a4,a4,a3
    a974:  00a7c683           lbu a3,10(a5)
    a978:  06c2                 slli a3,a3,0x10
    a97a:  8f55                 or a4,a4,a3
    a97c:  00b7c783           lbu a5,11(a5)
    a980:  07e2                 slli a5,a5,0x18
    a982:  8fd9                 or a5,a5,a4
    a984:  2781                 sext.w a5,a5
    a986:  e399                 bnez a5,a98c <do_fel_read+0x52>
    a988:  4785                 li a5,1
    a98a:  a09d                 j a9f0 <do_fel_read+0xb6>
    a98c:  fe843783           ld a5,-24(s0)
    a990:  0047c703           lbu a4,4(a5)
    a994:  0057c683           lbu a3,5(a5)
    a998:  06a2                 slli a3,a3,0x8
    a99a:  8f55                 or a4,a4,a3
    a99c:  0067c683           lbu a3,6(a5)
    a9a0:  06c2                 slli a3,a3,0x10
    a9a2:  8f55                 or a4,a4,a3
    a9a4:  0077c783           lbu a5,7(a5)
    a9a8:  07e2                 slli a5,a5,0x18
    a9aa:  8fd9                 or a5,a5,a4
    a9ac:  2781                 sext.w a5,a5
    a9ae:  1782                 slli a5,a5,0x20
    a9b0:  9381                 srli a5,a5,0x20
    a9b2:  863e                 mv a2,a5
    a9b4:  fe843783           ld a5,-24(s0)
    a9b8:  0087c703           lbu a4,8(a5)
    a9bc:  0097c683           lbu a3,9(a5)
    a9c0:  06a2                 slli a3,a3,0x8
    a9c2:  8f55                 or a4,a4,a3
    a9c4:  00a7c683           lbu a3,10(a5)
    a9c8:  06c2                 slli a3,a3,0x10
    a9ca:  8f55                 or a4,a4,a3
    a9cc:  00b7c783           lbu a5,11(a5)
    a9d0:  07e2                 slli a5,a5,0x18
    a9d2:  8fd9                 or a5,a5,a4
    a9d4:  2781                 sext.w a5,a5
    a9d6:  85be                 mv a1,a5
    a9d8:  8532                 mv a0,a2
    a9da:  b95ff0ef           jal ra,a56e <FUN_0000a56e>
    a9de:  fea43023           sd a0,-32(s0)
    a9e2:  fe043583           ld a1,-32(s0)
    a9e6:  fd843503           ld a0,-40(s0)
    a9ea:  b01ff0ef           jal ra,a4ea <FUN_0000a4ea>
    a9ee:  4781                 li a5,0
    a9f0:  853e                 mv a0,a5
    a9f2:  70a2                 ld ra,40(sp)
    a9f4:  7402                 ld s0,32(sp)
    a9f6:  6145                 addi sp,sp,48
    a9f8:  8082                 ret
000000000000a9fa <FUN_0000a9fa>:
    a9fa:  7179                 addi sp,sp,-48
    a9fc:  f422                 sd s0,40(sp)
    a9fe:  1800                 addi s0,sp,48
    aa00:  fca43c23           sd a0,-40(s0)
    aa04:  fcb43823           sd a1,-48(s0)
    aa08:  fe043423           sd zero,-24(s0)
    aa0c:  fd043783           ld a5,-48(s0)
    aa10:  e781                 bnez a5,aa18 <FUN_0000a9fa+0x1e>
    aa12:  57fd                 li a5,-1
    aa14:  9381                 srli a5,a5,0x20
    aa16:  a805                 j aa46 <FUN_0000a9fa+0x4c>
    aa18:  fd043783           ld a5,-48(s0)
    aa1c:  fef43423           sd a5,-24(s0)
    aa20:  fe843783           ld a5,-24(s0)
    aa24:  0047c703           lbu a4,4(a5)
    aa28:  0057c683           lbu a3,5(a5)
    aa2c:  06a2                 slli a3,a3,0x8
    aa2e:  8f55                 or a4,a4,a3
    aa30:  0067c683           lbu a3,6(a5)
    aa34:  06c2                 slli a3,a3,0x10
    aa36:  8f55                 or a4,a4,a3
    aa38:  0077c783           lbu a5,7(a5)
    aa3c:  07e2                 slli a5,a5,0x18
    aa3e:  8fd9                 or a5,a5,a4
    aa40:  2781                 sext.w a5,a5
    aa42:  1782                 slli a5,a5,0x20
    aa44:  9381                 srli a5,a5,0x20
    aa46:  853e                 mv a0,a5
    aa48:  7422                 ld s0,40(sp)
    aa4a:  6145                 addi sp,sp,48
    aa4c:  8082                 ret
000000000000aa4e <FUN_0000aa4e>:
    aa4e:  7179                 addi sp,sp,-48
    aa50:  f406                 sd ra,40(sp)
    aa52:  f022                 sd s0,32(sp)
    aa54:  1800                 addi s0,sp,48
    aa56:  fca43c23           sd a0,-40(s0)
    aa5a:  87ae                 mv a5,a1
    aa5c:  8732                 mv a4,a2
    aa5e:  fcf41b23           sh a5,-42(s0)
    aa62:  87ba                 mv a5,a4
    aa64:  fcf40aa3           sb a5,-43(s0)
    aa68:  fe043423           sd zero,-24(s0)
    aa6c:  fe040793           addi a5,s0,-32
    aa70:  4621                 li a2,8
    aa72:  4581                 li a1,0
    aa74:  853e                 mv a0,a5
    aa76:  c74ff0ef           jal ra,9eea <memset>
    aa7a:  57fd                 li a5,-1
    aa7c:  fef41023           sh a5,-32(s0)
    aa80:  fd645783           lhu a5,-42(s0)
    aa84:  fef41123           sh a5,-30(s0)
    aa88:  fd544783           lbu a5,-43(s0)
    aa8c:  fef40223           sb a5,-28(s0)
    aa90:  fe040793           addi a5,s0,-32
    aa94:  45a1                 li a1,8
    aa96:  853e                 mv a0,a5
    aa98:  ad7ff0ef           jal ra,a56e <FUN_0000a56e>
    aa9c:  fea43423           sd a0,-24(s0)
    aaa0:  fe843583           ld a1,-24(s0)
    aaa4:  fd843503           ld a0,-40(s0)
    aaa8:  a43ff0ef           jal ra,a4ea <FUN_0000a4ea>
    aaac:  0001                 nop
    aaae:  70a2                 ld ra,40(sp)
    aab0:  7402                 ld s0,32(sp)
    aab2:  6145                 addi sp,sp,48
    aab4:  8082                 ret
000000000000aab6 <FUN_0000aab6>:
    aab6:  7139                 addi sp,sp,-64
    aab8:  fc06                 sd ra,56(sp)
    aaba:  f822                 sd s0,48(sp)
    aabc:  0080                 addi s0,sp,64
    aabe:  fca43c23           sd a0,-40(s0)
    aac2:  fcb43823           sd a1,-48(s0)
    aac6:  87b2                 mv a5,a2
    aac8:  fcf42623           sw a5,-52(s0)
    aacc:  fe043423           sd zero,-24(s0)
    aad0:  fcc42783           lw a5,-52(s0)
    aad4:  863e                 mv a2,a5
    aad6:  4581                 li a1,0
    aad8:  fd043503           ld a0,-48(s0)
    aadc:  c0eff0ef           jal ra,9eea <memset>
    aae0:  fcc42783           lw a5,-52(s0)
    aae4:  85be                 mv a1,a5
    aae6:  fd043503           ld a0,-48(s0)
    aaea:  a85ff0ef           jal ra,a56e <FUN_0000a56e>
    aaee:  fea43423           sd a0,-24(s0)
    aaf2:  fe843583           ld a1,-24(s0)
    aaf6:  fd843503           ld a0,-40(s0)
    aafa:  a4fff0ef           jal ra,a548 <FUN_0000a548>
    aafe:  0001                 nop
    ab00:  70e2                 ld ra,56(sp)
    ab02:  7442                 ld s0,48(sp)
    ab04:  6121                 addi sp,sp,64
    ab06:  8082                 ret
000000000000ab08 <FUN_0000ab08>:
    ab08:  711d                 addi sp,sp,-96
    ab0a:  ec86                 sd ra,88(sp)
    ab0c:  e8a2                 sd s0,80(sp)
    ab0e:  1080                 addi s0,sp,96
    ab10:  faa43423           sd a0,-88(s0)
    ab14:  fe043023           sd zero,-32(s0)
    ab18:  fc041f23           sh zero,-34(s0)
    ab1c:  fc041e23           sh zero,-36(s0)
    ab20:  4785                 li a5,1
    ab22:  fef407a3           sb a5,-17(s0)
    ab26:  fb840793           addi a5,s0,-72
    ab2a:  4641                 li a2,16
    ab2c:  85be                 mv a1,a5
    ab2e:  fa843503           ld a0,-88(s0)
    ab32:  f85ff0ef           jal ra,aab6 <FUN_0000aab6>
    ab36:  fb840793           addi a5,s0,-72
    ab3a:  fef43023           sd a5,-32(s0)
    ab3e:  fe043783           ld a5,-32(s0)
    ab42:  0007c703           lbu a4,0(a5)
    ab46:  0017c783           lbu a5,1(a5)
    ab4a:  07a2                 slli a5,a5,0x8
    ab4c:  8fd9                 or a5,a5,a4
    ab4e:  fcf41f23           sh a5,-34(s0)
    ab52:  fe043783           ld a5,-32(s0)
    ab56:  0027c703           lbu a4,2(a5)
    ab5a:  0037c783           lbu a5,3(a5)
    ab5e:  07a2                 slli a5,a5,0x8
    ab60:  8fd9                 or a5,a5,a4
    ab62:  fcf41e23           sh a5,-36(s0)
    ab66:  fde45783           lhu a5,-34(s0)
    ab6a:  2781                 sext.w a5,a5
    ab6c:  86be                 mv a3,a5
    ab6e:  4711                 li a4,4
    ab70:  0ae68e63           beq a3,a4,ac2c <FUN_0000ab08+0x124>
    ab74:  86be                 mv a3,a5
    ab76:  4711                 li a4,4
    ab78:  00d74f63           blt a4,a3,ab96 <FUN_0000ab08+0x8e>
    ab7c:  86be                 mv a3,a5
    ab7e:  4709                 li a4,2
    ab80:  1ce68063           beq a3,a4,ad40 <FUN_0000ab08+0x238>
    ab84:  86be                 mv a3,a5
    ab86:  4709                 li a4,2
    ab88:  08d74b63           blt a4,a3,ac1e <FUN_0000ab08+0x116>
    ab8c:  873e                 mv a4,a5
    ab8e:  4785                 li a5,1
    ab90:  02f70d63           beq a4,a5,abca <FUN_0000ab08+0xc2>
    ab94:  a255                 j ad38 <FUN_0000ab08+0x230>
    ab96:  86be                 mv a3,a5
    ab98:  10100713           li a4,257
    ab9c:  08e68f63           beq a3,a4,ac3a <FUN_0000ab08+0x132>
    aba0:  86be                 mv a3,a5
    aba2:  10100713           li a4,257
    aba6:  00d74763           blt a4,a3,abb4 <FUN_0000ab08+0xac>
    abaa:  873e                 mv a4,a5
    abac:  47c1                 li a5,16
    abae:  18f70b63           beq a4,a5,ad44 <FUN_0000ab08+0x23c>
    abb2:  a259                 j ad38 <FUN_0000ab08+0x230>
    abb4:  86be                 mv a3,a5
    abb6:  10200713           li a4,258
    abba:  0ae68663           beq a3,a4,ac66 <FUN_0000ab08+0x15e>
    abbe:  873e                 mv a4,a5
    abc0:  10300793           li a5,259
    abc4:  08f70663           beq a4,a5,ac50 <FUN_0000ab08+0x148>
    abc8:  aa85                 j ad38 <FUN_0000ab08+0x230>
    abca:  fdc45783           lhu a5,-36(s0)
    abce:  0007871b           sext.w a4,a5
    abd2:  4789                 li a5,2
    abd4:  00f71763           bne a4,a5,abe2 <FUN_0000ab08+0xda>
    abd8:  fa843503           ld a0,-88(s0)
    abdc:  a77ff0ef           jal ra,a652 <FUN_0000a652>
    abe0:  a825                 j ac18 <FUN_0000ab08+0x110>
    abe2:  fdc45783           lhu a5,-36(s0)
    abe6:  0007871b           sext.w a4,a5
    abea:  478d                 li a5,3
    abec:  02f71263           bne a4,a5,ac10 <FUN_0000ab08+0x108>
    abf0:  00027537           lui a0,0x27
    abf4:  322030ef           jal ra,df16 <FUN_0000df16>
    abf8:  87aa                 mv a5,a0
    abfa:  c791                 beqz a5,ac06 <FUN_0000ab08+0xfe>
    abfc:  fa843783           ld a5,-88(s0)
    ac00:  0807a823           sw zero,144(a5)
    ac04:  a031                 j ac10 <FUN_0000ab08+0x108>
    ac06:  fa843783           ld a5,-88(s0)
    ac0a:  4705                 li a4,1
    ac0c:  08e7a823           sw a4,144(a5)
    ac10:  fa843503           ld a0,-88(s0)
    ac14:  9b7ff0ef           jal ra,a5ca <FUN_0000a5ca>
    ac18:  fe0407a3           sb zero,-17(s0)
    ac1c:  a23d                 j ad4a <FUN_0000ab08+0x242>
    ac1e:  fa843503           ld a0,-88(s0)
    ac22:  b1bff0ef           jal ra,a73c <FUN_0000a73c>
    ac26:  fe0407a3           sb zero,-17(s0)
    ac2a:  a205                 j ad4a <FUN_0000ab08+0x242>
    ac2c:  fa843503           ld a0,-88(s0)
    ac30:  abfff0ef           jal ra,a6ee <FUN_0000a6ee>
    ac34:  fe0407a3           sb zero,-17(s0)
    ac38:  aa09                 j ad4a <FUN_0000ab08+0x242>
    ac3a:  fb840793           addi a5,s0,-72
    ac3e:  85be                 mv a1,a5
    ac40:  fa843503           ld a0,-88(s0)
    ac44:  bb3ff0ef           jal ra,a7f6 <do_fel_write>
    ac48:  87aa                 mv a5,a0
    ac4a:  fef407a3           sb a5,-17(s0)
    ac4e:  a8f5                 j ad4a <FUN_0000ab08+0x242>
    ac50:  fb840793           addi a5,s0,-72
    ac54:  85be                 mv a1,a5
    ac56:  fa843503           ld a0,-88(s0)
    ac5a:  ce1ff0ef           jal ra,a93a <do_fel_read>
    ac5e:  87aa                 mv a5,a0
    ac60:  fef407a3           sb a5,-17(s0)
    ac64:  a0dd                 j ad4a <FUN_0000ab08+0x242>
    ac66:  fc043823           sd zero,-48(s0)
    ac6a:  4785                 li a5,1
    ac6c:  fef40723           sb a5,-18(s0)
    ac70:  fb840793           addi a5,s0,-72
    ac74:  85be                 mv a1,a5
    ac76:  fa843503           ld a0,-88(s0)
    ac7a:  d81ff0ef           jal ra,a9fa <FUN_0000a9fa>
    ac7e:  fca43823           sd a0,-48(s0)
    ac82:  fa843783           ld a5,-88(s0)
    ac86:  0847a783           lw a5,132(a5)
    ac8a:  cf99                 beqz a5,aca8 <FUN_0000ab08+0x1a0>
    ac8c:  fd043583           ld a1,-48(s0)
    ac90:  fa843503           ld a0,-88(s0)
    ac94:  0ca030ef           jal ra,dd5e <FUN_0000dd5e>
    ac98:  87aa                 mv a5,a0
    ac9a:  0007871b           sext.w a4,a5
    ac9e:  fa843783           ld a5,-88(s0)
    aca2:  08e7a423           sw a4,136(a5)
    aca6:  a031                 j acb2 <FUN_0000ab08+0x1aa>
    aca8:  fa843783           ld a5,-88(s0)
    acac:  4705                 li a4,1
    acae:  08e7a423           sw a4,136(a5)
    acb2:  fa843783           ld a5,-88(s0)
    acb6:  0947a783           lw a5,148(a5)
    acba:  cb81                 beqz a5,acca <FUN_0000ab08+0x1c2>
    acbc:  fa843783           ld a5,-88(s0)
    acc0:  0907a783           lw a5,144(a5)
    acc4:  fef40723           sb a5,-18(s0)
    acc8:  a021                 j acd0 <FUN_0000ab08+0x1c8>
    acca:  4785                 li a5,1
    accc:  fef40723           sb a5,-18(s0)
    acd0:  fa843783           ld a5,-88(s0)
    acd4:  0887a783           lw a5,136(a5)
    acd8:  cb81                 beqz a5,ace8 <FUN_0000ab08+0x1e0>
    acda:  fee44783           lbu a5,-18(s0)
    acde:  0ff7f793           andi a5,a5,255
    ace2:  c399                 beqz a5,ace8 <FUN_0000ab08+0x1e0>
    ace4:  4785                 li a5,1
    ace6:  a011                 j acea <FUN_0000ab08+0x1e2>
    ace8:  4781                 li a5,0
    acea:  0007871b           sext.w a4,a5
    acee:  fa843783           ld a5,-88(s0)
    acf2:  08e7a423           sw a4,136(a5)
    acf6:  fa843783           ld a5,-88(s0)
    acfa:  0887a783           lw a5,136(a5)
    acfe:  c7a9                 beqz a5,ad48 <FUN_0000ab08+0x240>
    ad00:  fe0407a3           sb zero,-17(s0)
    ad04:  fef44703           lbu a4,-17(s0)
    ad08:  fdc45783           lhu a5,-36(s0)
    ad0c:  863a                 mv a2,a4
    ad0e:  85be                 mv a1,a5
    ad10:  fa843503           ld a0,-88(s0)
    ad14:  d3bff0ef           jal ra,aa4e <FUN_0000aa4e>
    ad18:  fa843503           ld a0,-88(s0)
    ad1c:  183020ef           jal ra,d69e <FUN_0000d69e>
    ad20:  fd043783           ld a5,-48(s0)
    ad24:  fcf43423           sd a5,-56(s0)
    ad28:  fc843783           ld a5,-56(s0)
    ad2c:  9782                 jalr a5
    ad2e:  fa843783           ld a5,-88(s0)
    ad32:  0807a423           sw zero,136(a5)
    ad36:  a025                 j ad5e <FUN_0000ab08+0x256>
    ad38:  4785                 li a5,1
    ad3a:  fef407a3           sb a5,-17(s0)
    ad3e:  a031                 j ad4a <FUN_0000ab08+0x242>
    ad40:  0001                 nop
    ad42:  a021                 j ad4a <FUN_0000ab08+0x242>
    ad44:  0001                 nop
    ad46:  a011                 j ad4a <FUN_0000ab08+0x242>
    ad48:  0001                 nop
    ad4a:  fef44703           lbu a4,-17(s0)
    ad4e:  fdc45783           lhu a5,-36(s0)
    ad52:  863a                 mv a2,a4
    ad54:  85be                 mv a1,a5
    ad56:  fa843503           ld a0,-88(s0)
    ad5a:  cf5ff0ef           jal ra,aa4e <FUN_0000aa4e>
    ad5e:  60e6                 ld ra,88(sp)
    ad60:  6446                 ld s0,80(sp)
    ad62:  6125                 addi sp,sp,96
    ad64:  8082                 ret
000000000000ad66 <FUN_0000ad66>:
    ad66:  7179                 addi sp,sp,-48
    ad68:  f406                 sd ra,40(sp)
    ad6a:  f022                 sd s0,32(sp)
    ad6c:  1800                 addi s0,sp,48
    ad6e:  fca43c23           sd a0,-40(s0)
    ad72:  fe042623           sw zero,-20(s0)
    ad76:  c62ff0ef           jal ra,a1d8 <FUN_0000a1d8>
    ad7a:  fd843503           ld a0,-40(s0)
    ad7e:  d8bff0ef           jal ra,ab08 <FUN_0000ab08>
    ad82:  fec42783           lw a5,-20(s0)
    ad86:  2785                 addiw a5,a5,1
    ad88:  fef42623           sw a5,-20(s0)
    ad8c:  b7ed                 j ad76 <FUN_0000ad66+0x10>
    ad8e:  1101                 addi sp,sp,-32
    ad90:  ec22                 sd s0,24(sp)
    ad92:  1000                 addi s0,sp,32
    ad94:  fea43423           sd a0,-24(s0)
    ad98:  fe843783           ld a5,-24(s0)
    ad9c:  02078023           sb zero,32(a5)
    ada0:  0001                 nop
    ada2:  6462                 ld s0,24(sp)
    ada4:  6105                 addi sp,sp,32
    ada6:  8082                 ret
    ada8:  1101                 addi sp,sp,-32
    adaa:  ec22                 sd s0,24(sp)
    adac:  1000                 addi s0,sp,32
    adae:  fea43423           sd a0,-24(s0)
    adb2:  fe843783           ld a5,-24(s0)
    adb6:  02078023           sb zero,32(a5)
    adba:  0001                 nop
    adbc:  6462                 ld s0,24(sp)
    adbe:  6105                 addi sp,sp,32
    adc0:  8082                 ret
    adc2:  1101                 addi sp,sp,-32
    adc4:  ec22                 sd s0,24(sp)
    adc6:  1000                 addi s0,sp,32
    adc8:  fea43423           sd a0,-24(s0)
    adcc:  fe843783           ld a5,-24(s0)
    add0:  02078023           sb zero,32(a5)
    add4:  0001                 nop
    add6:  6462                 ld s0,24(sp)
    add8:  6105                 addi sp,sp,32
    adda:  8082                 ret
000000000000addc <FUN_0000addc>:
    addc:  7179                 addi sp,sp,-48
    adde:  f422                 sd s0,40(sp)
    ade0:  1800                 addi s0,sp,48
    ade2:  87aa                 mv a5,a0
    ade4:  8736                 mv a4,a3
    ade6:  fcf42e23           sw a5,-36(s0)
    adea:  87ae                 mv a5,a1
    adec:  fcf42c23           sw a5,-40(s0)
    adf0:  87b2                 mv a5,a2
    adf2:  fcf42a23           sw a5,-44(s0)
    adf6:  87ba                 mv a5,a4
    adf8:  fcf42823           sw a5,-48(s0)
    adfc:  fd442783           lw a5,-44(s0)
    ae00:  4705                 li a4,1
    ae02:  00f717bb           sllw a5,a4,a5
    ae06:  2781                 sext.w a5,a5
    ae08:  37fd                 addiw a5,a5,-1
    ae0a:  2781                 sext.w a5,a5
    ae0c:  fef42623           sw a5,-20(s0)
    ae10:  fdc46783           lwu a5,-36(s0)
    ae14:  439c                 lw a5,0(a5)
    ae16:  0007869b           sext.w a3,a5
    ae1a:  fd842783           lw a5,-40(s0)
    ae1e:  fec42703           lw a4,-20(s0)
    ae22:  00f717bb           sllw a5,a4,a5
    ae26:  2781                 sext.w a5,a5
    ae28:  fff7c793           not a5,a5
    ae2c:  2781                 sext.w a5,a5
    ae2e:  8736                 mv a4,a3
    ae30:  8ff9                 and a5,a5,a4
    ae32:  fef42423           sw a5,-24(s0)
    ae36:  fd842783           lw a5,-40(s0)
    ae3a:  fd042703           lw a4,-48(s0)
    ae3e:  00f717bb           sllw a5,a4,a5
    ae42:  0007871b           sext.w a4,a5
    ae46:  fe842783           lw a5,-24(s0)
    ae4a:  8fd9                 or a5,a5,a4
    ae4c:  fef42423           sw a5,-24(s0)
    ae50:  fdc46783           lwu a5,-36(s0)
    ae54:  873e                 mv a4,a5
    ae56:  fe842783           lw a5,-24(s0)
    ae5a:  c31c                 sw a5,0(a4)
    ae5c:  0001                 nop
    ae5e:  7422                 ld s0,40(sp)
    ae60:  6145                 addi sp,sp,48
    ae62:  8082                 ret
000000000000ae64 <usb_irq_handler>:
    ae64:  1101                 addi sp,sp,-32
    ae66:  ec06                 sd ra,24(sp)
    ae68:  e822                 sd s0,16(sp)
    ae6a:  1000                 addi s0,sp,32
    ae6c:  87aa                 mv a5,a0
    ae6e:  fef42623           sw a5,-20(s0)
    ae72:  21c020ef           jal ra,d08e <fel_irq_handler>
    ae76:  0001                 nop
    ae78:  60e2                 ld ra,24(sp)
    ae7a:  6442                 ld s0,16(sp)
    ae7c:  6105                 addi sp,sp,32
    ae7e:  8082                 ret
000000000000ae80 <FUN_0000ae80>:
    ae80:  7179                 addi sp,sp,-48
    ae82:  f406                 sd ra,40(sp)
    ae84:  f022                 sd s0,32(sp)
    ae86:  1800                 addi s0,sp,48
    ae88:  87aa                 mv a5,a0
    ae8a:  fcf42e23           sw a5,-36(s0)
    ae8e:  fdc42783           lw a5,-36(s0)
    ae92:  0057d79b           srliw a5,a5,0x5
    ae96:  fef42623           sw a5,-20(s0)
    ae9a:  fec42703           lw a4,-20(s0)
    ae9e:  040017b7           lui a5,0x4001
    aea2:  8007879b           addiw a5,a5,-2048
    aea6:  9fb9                 addw a5,a5,a4
    aea8:  2781                 sext.w a5,a5
    aeaa:  0027979b           slliw a5,a5,0x2
    aeae:  fef42423           sw a5,-24(s0)
    aeb2:  fdc42783           lw a5,-36(s0)
    aeb6:  8bfd                 andi a5,a5,31
    aeb8:  fef42223           sw a5,-28(s0)
    aebc:  fe442703           lw a4,-28(s0)
    aec0:  fe842783           lw a5,-24(s0)
    aec4:  4685                 li a3,1
    aec6:  4605                 li a2,1
    aec8:  85ba                 mv a1,a4
    aeca:  853e                 mv a0,a5
    aecc:  f11ff0ef           jal ra,addc <FUN_0000addc>
    aed0:  4781                 li a5,0
    aed2:  853e                 mv a0,a5
    aed4:  70a2                 ld ra,40(sp)
    aed6:  7402                 ld s0,32(sp)
    aed8:  6145                 addi sp,sp,48
    aeda:  8082                 ret
000000000000aedc <FUN_0000aedc>:
    aedc:  7179                 addi sp,sp,-48
    aede:  f422                 sd s0,40(sp)
    aee0:  1800                 addi s0,sp,48
    aee2:  fca43c23           sd a0,-40(s0)
    aee6:  fe042623           sw zero,-20(s0)
    aeea:  fd843783           ld a5,-40(s0)
    aeee:  0807a783           lw a5,128(a5) # 4001080 <gpio_get_boot_device+0x3ff2cea>
    aef2:  e7c5                 bnez a5,af9a <FUN_0000aedc+0xbe>
    aef4:  fe042623           sw zero,-20(s0)
    aef8:  a01d                 j af1e <FUN_0000aedc+0x42>
    aefa:  fec42703           lw a4,-20(s0)
    aefe:  040017b7           lui a5,0x4001
    af02:  8007879b           addiw a5,a5,-2048
    af06:  9fb9                 addw a5,a5,a4
    af08:  2781                 sext.w a5,a5
    af0a:  0027979b           slliw a5,a5,0x2
    af0e:  2781                 sext.w a5,a5
    af10:  0007a023           sw zero,0(a5) # 4001000 <gpio_get_boot_device+0x3ff2c6a>
    af14:  fec42783           lw a5,-20(s0)
    af18:  2785                 addiw a5,a5,1
    af1a:  fef42623           sw a5,-20(s0)
    af1e:  fec42783           lw a5,-20(s0)
    af22:  0007871b           sext.w a4,a5
    af26:  47a1                 li a5,8
    af28:  fce7d9e3           bge a5,a4,aefa <FUN_0000aedc+0x1e>
    af2c:  fe042623           sw zero,-20(s0)
    af30:  a00d                 j af52 <FUN_0000aedc+0x76>
    af32:  fec42703           lw a4,-20(s0)
    af36:  040007b7           lui a5,0x4000
    af3a:  9fb9                 addw a5,a5,a4
    af3c:  2781                 sext.w a5,a5
    af3e:  0027979b           slliw a5,a5,0x2
    af42:  2781                 sext.w a5,a5
    af44:  0007a023           sw zero,0(a5) # 4000000 <gpio_get_boot_device+0x3ff1c6a>
    af48:  fec42783           lw a5,-20(s0)
    af4c:  2785                 addiw a5,a5,1
    af4e:  fef42623           sw a5,-20(s0)
    af52:  fec42783           lw a5,-20(s0)
    af56:  0007871b           sext.w a4,a5
    af5a:  0ff00793           li a5,255
    af5e:  fce7dae3           bge a5,a4,af32 <FUN_0000aedc+0x56>
    af62:  fe042623           sw zero,-20(s0)
    af66:  a01d                 j af8c <FUN_0000aedc+0xb0>
    af68:  fec42703           lw a4,-20(s0)
    af6c:  040007b7           lui a5,0x4000
    af70:  4007879b           addiw a5,a5,1024
    af74:  9fb9                 addw a5,a5,a4
    af76:  2781                 sext.w a5,a5
    af78:  0027979b           slliw a5,a5,0x2
    af7c:  2781                 sext.w a5,a5
    af7e:  0007a023           sw zero,0(a5) # 4000000 <gpio_get_boot_device+0x3ff1c6a>
    af82:  fec42783           lw a5,-20(s0)
    af86:  2785                 addiw a5,a5,1
    af88:  fef42623           sw a5,-20(s0)
    af8c:  fec42783           lw a5,-20(s0)
    af90:  0007871b           sext.w a4,a5
    af94:  47a1                 li a5,8
    af96:  fce7d9e3           bge a5,a4,af68 <FUN_0000aedc+0x8c>
    af9a:  0001                 nop
    af9c:  7422                 ld s0,40(sp)
    af9e:  6145                 addi sp,sp,48
    afa0:  8082                 ret
000000000000afa2 <FUN_0000afa2>:
    afa2:  1101                 addi sp,sp,-32
    afa4:  ec06                 sd ra,24(sp)
    afa6:  e822                 sd s0,16(sp)
    afa8:  1000                 addi s0,sp,32
    afaa:  fe042623           sw zero,-20(s0)
    afae:  100007b7           lui a5,0x10000
    afb2:  0b47879b           addiw a5,a5,180
    afb6:  fef42623           sw a5,-20(s0)
    afba:  fec46783           lwu a5,-20(s0)
    afbe:  873e                 mv a4,a5
    afc0:  4799                 li a5,6
    afc2:  c31c                 sw a5,0(a4)
    afc4:  02d00513           li a0,45
    afc8:  eb9ff0ef           jal ra,ae80 <FUN_0000ae80>
    afcc:  0001                 nop
    afce:  60e2                 ld ra,24(sp)
    afd0:  6442                 ld s0,16(sp)
    afd2:  6105                 addi sp,sp,32
    afd4:  8082                 ret
000000000000afd6 <interrupt_handler>:
    afd6:  1101                 addi sp,sp,-32
    afd8:  ec06                 sd ra,24(sp)
    afda:  e822                 sd s0,16(sp)
    afdc:  1000                 addi s0,sp,32
    afde:  102007b7           lui a5,0x10200
    afe2:  0791                 addi a5,a5,4
    afe4:  439c                 lw a5,0(a5)
    afe6:  fef42623           sw a5,-20(s0)
    afea:  fec42783           lw a5,-20(s0)
    afee:  3ff7f793           andi a5,a5,1023
    aff2:  fef42623           sw a5,-20(s0)
    aff6:  fec42783           lw a5,-20(s0)
    affa:  0007871b           sext.w a4,a5
    affe:  02d00793           li a5,45
    b002:  00f71763           bne a4,a5,b010 <interrupt_handler+0x3a>
    b006:  fec42783           lw a5,-20(s0)
    b00a:  853e                 mv a0,a5
    b00c:  e59ff0ef           jal ra,ae64 <usb_irq_handler>
    b010:  102007b7           lui a5,0x10200
    b014:  0791                 addi a5,a5,4
    b016:  fec42703           lw a4,-20(s0)
    b01a:  c398                 sw a4,0(a5)
    b01c:  0001                 nop
    b01e:  60e2                 ld ra,24(sp)
    b020:  6442                 ld s0,16(sp)
    b022:  6105                 addi sp,sp,32
    b024:  8082                 ret
000000000000b026 <FUN_0000b026>:
    b026:  1101                 addi sp,sp,-32
    b028:  ec22                 sd s0,24(sp)
    b02a:  1000                 addi s0,sp,32
    b02c:  102007b7           lui a5,0x10200
    b030:  0791                 addi a5,a5,4
    b032:  439c                 lw a5,0(a5)
    b034:  fef42623           sw a5,-20(s0)
    b038:  fec42783           lw a5,-20(s0)
    b03c:  3ff7f793           andi a5,a5,1023
    b040:  fef42623           sw a5,-20(s0)
    b044:  102007b7           lui a5,0x10200
    b048:  0791                 addi a5,a5,4
    b04a:  fec42703           lw a4,-20(s0)
    b04e:  c398                 sw a4,0(a5)
    b050:  0001                 nop
    b052:  6462                 ld s0,24(sp)
    b054:  6105                 addi sp,sp,32
    b056:  8082                 ret
000000000000b058 <FUN_0000b058>:
    b058:  1101                 addi sp,sp,-32
    b05a:  ec06                 sd ra,24(sp)
    b05c:  e822                 sd s0,16(sp)
    b05e:  1000                 addi s0,sp,32
    b060:  fea43423           sd a0,-24(s0)
    b064:  fe843783           ld a5,-24(s0)
    b068:  0807a783           lw a5,128(a5) # 10200080 <gpio_get_boot_device+0x101f1ce
    b06c:  e399                 bnez a5,b072 <FUN_0000b058+0x1a>
    b06e:  f35ff0ef           jal ra,afa2 <FUN_0000afa2>
    b072:  0001                 nop
    b074:  60e2                 ld ra,24(sp)
    b076:  6442                 ld s0,16(sp)
    b078:  6105                 addi sp,sp,32
    b07a:  8082                 ret
000000000000b07c <disable_interrupts>:
    b07c:  1101                 addi sp,sp,-32
    b07e:  ec22                 sd s0,24(sp)
    b080:  1000                 addi s0,sp,32
    b082:  fea43423           sd a0,-24(s0)
    b086:  000012b7           lui t0,0x1
    b08a:  8002829b           addiw t0,t0,-2048
    b08e:  3042b073           csrc mie,t0
    b092:  0001                 nop
    b094:  6462                 ld s0,24(sp)
    b096:  6105                 addi sp,sp,32
    b098:  8082                 ret
000000000000b09a <enable_interrupts>:
    b09a:  1101                 addi sp,sp,-32
    b09c:  ec22                 sd s0,24(sp)
    b09e:  1000                 addi s0,sp,32
    b0a0:  fea43423           sd a0,-24(s0)
    b0a4:  000012b7           lui t0,0x1
    b0a8:  8002829b           addiw t0,t0,-2048
    b0ac:  3042a073           csrs mie,t0
    b0b0:  0001                 nop
    b0b2:  6462                 ld s0,24(sp)
    b0b4:  6105                 addi sp,sp,32
    b0b6:  8082                 ret
000000000000b0b8 <clear_interrupts>:
    b0b8:  1141                 addi sp,sp,-16
    b0ba:  e422                 sd s0,8(sp)
    b0bc:  0800                 addi s0,sp,16
    b0be:  42a1                 li t0,8
    b0c0:  3002a073           csrs mstatus,t0
    b0c4:  0001                 nop
    b0c6:  6422                 ld s0,8(sp)
    b0c8:  0141                 addi sp,sp,16
    b0ca:  8082                 ret
000000000000b0cc <FUN_0000b0cc>:
    b0cc:  1101                 addi sp,sp,-32
    b0ce:  ec22                 sd s0,24(sp)
    b0d0:  1000                 addi s0,sp,32
    b0d2:  87aa                 mv a5,a0
    b0d4:  fef407a3           sb a5,-17(s0)
    b0d8:  041007b7           lui a5,0x4100
    b0dc:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    b0e0:  fef44703           lbu a4,-17(s0)
    b0e4:  00e78023           sb a4,0(a5)
    b0e8:  0001                 nop
    b0ea:  6462                 ld s0,24(sp)
    b0ec:  6105                 addi sp,sp,32
    b0ee:  8082                 ret
000000000000b0f0 <FUN_0000b0f0>:
    b0f0:  1141                 addi sp,sp,-16
    b0f2:  e422                 sd s0,8(sp)
    b0f4:  0800                 addi s0,sp,16
    b0f6:  041007b7           lui a5,0x4100
    b0fa:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    b0fe:  0007c783           lbu a5,0(a5)
    b102:  0ff7f793           andi a5,a5,255
    b106:  853e                 mv a0,a5
    b108:  6422                 ld s0,8(sp)
    b10a:  0141                 addi sp,sp,16
    b10c:  8082                 ret
000000000000b10e <FUN_0000b10e>:
    b10e:  1101                 addi sp,sp,-32
    b110:  ec22                 sd s0,24(sp)
    b112:  1000                 addi s0,sp,32
    b114:  fea43423           sd a0,-24(s0)
    b118:  fe843783           ld a5,-24(s0)
    b11c:  4749                 li a4,18
    b11e:  00e78023           sb a4,0(a5)
    b122:  fe843783           ld a5,-24(s0)
    b126:  4705                 li a4,1
    b128:  00e780a3           sb a4,1(a5)
    b12c:  fe843783           ld a5,-24(s0)
    b130:  11000713           li a4,272
    b134:  00e79123           sh a4,2(a5)
    b138:  fe843783           ld a5,-24(s0)
    b13c:  00078223           sb zero,4(a5)
    b140:  fe843783           ld a5,-24(s0)
    b144:  000782a3           sb zero,5(a5)
    b148:  fe843783           ld a5,-24(s0)
    b14c:  00078323           sb zero,6(a5)
    b150:  fe843783           ld a5,-24(s0)
    b154:  04000713           li a4,64
    b158:  00e783a3           sb a4,7(a5)
    b15c:  fe843783           ld a5,-24(s0)
    b160:  6709                 lui a4,0x2
    b162:  f3a7071b           addiw a4,a4,-198
    b166:  00e79423           sh a4,8(a5)
    b16a:  fe843783           ld a5,-24(s0)
    b16e:  777d                 lui a4,0xfffff
    b170:  3721                 addiw a4,a4,-24
    b172:  00e79523           sh a4,10(a5)
    b176:  fe843783           ld a5,-24(s0)
    b17a:  2b300713           li a4,691
    b17e:  00e79623           sh a4,12(a5)
    b182:  fe843783           ld a5,-24(s0)
    b186:  00078723           sb zero,14(a5)
    b18a:  fe843783           ld a5,-24(s0)
    b18e:  000787a3           sb zero,15(a5)
    b192:  fe843783           ld a5,-24(s0)
    b196:  00078823           sb zero,16(a5)
    b19a:  fe843783           ld a5,-24(s0)
    b19e:  4705                 li a4,1
    b1a0:  00e788a3           sb a4,17(a5)
    b1a4:  0001                 nop
    b1a6:  6462                 ld s0,24(sp)
    b1a8:  6105                 addi sp,sp,32
    b1aa:  8082                 ret
000000000000b1ac <FUN_0000b1ac>:
    b1ac:  1101                 addi sp,sp,-32
    b1ae:  ec22                 sd s0,24(sp)
    b1b0:  1000                 addi s0,sp,32
    b1b2:  fea43423           sd a0,-24(s0)
    b1b6:  fe843783           ld a5,-24(s0)
    b1ba:  4729                 li a4,10
    b1bc:  00e78023           sb a4,0(a5)
    b1c0:  fe843783           ld a5,-24(s0)
    b1c4:  4709                 li a4,2
    b1c6:  00e780a3           sb a4,1(a5)
    b1ca:  fe843783           ld a5,-24(s0)
    b1ce:  02000713           li a4,32
    b1d2:  00e79123           sh a4,2(a5)
    b1d6:  fe843783           ld a5,-24(s0)
    b1da:  4705                 li a4,1
    b1dc:  00e78223           sb a4,4(a5)
    b1e0:  fe843783           ld a5,-24(s0)
    b1e4:  4705                 li a4,1
    b1e6:  00e782a3           sb a4,5(a5)
    b1ea:  fe843783           ld a5,-24(s0)
    b1ee:  00078323           sb zero,6(a5)
    b1f2:  fe843783           ld a5,-24(s0)
    b1f6:  f8000713           li a4,-128
    b1fa:  00e783a3           sb a4,7(a5)
    b1fe:  fe843783           ld a5,-24(s0)
    b202:  f9600713           li a4,-106
    b206:  00e78423           sb a4,8(a5)
    b20a:  0001                 nop
    b20c:  6462                 ld s0,24(sp)
    b20e:  6105                 addi sp,sp,32
    b210:  8082                 ret
000000000000b212 <FUN_0000b212>:
    b212:  1101                 addi sp,sp,-32
    b214:  ec22                 sd s0,24(sp)
    b216:  1000                 addi s0,sp,32
    b218:  fea43423           sd a0,-24(s0)
    b21c:  fe843783           ld a5,-24(s0)
    b220:  4725                 li a4,9
    b222:  00e78023           sb a4,0(a5)
    b226:  fe843783           ld a5,-24(s0)
    b22a:  4711                 li a4,4
    b22c:  00e780a3           sb a4,1(a5)
    b230:  fe843783           ld a5,-24(s0)
    b234:  00078123           sb zero,2(a5)
    b238:  fe843783           ld a5,-24(s0)
    b23c:  000781a3           sb zero,3(a5)
    b240:  fe843783           ld a5,-24(s0)
    b244:  4709                 li a4,2
    b246:  00e78223           sb a4,4(a5)
    b24a:  fe843783           ld a5,-24(s0)
    b24e:  577d                 li a4,-1
    b250:  00e782a3           sb a4,5(a5)
    b254:  fe843783           ld a5,-24(s0)
    b258:  577d                 li a4,-1
    b25a:  00e78323           sb a4,6(a5)
    b25e:  fe843783           ld a5,-24(s0)
    b262:  577d                 li a4,-1
    b264:  00e783a3           sb a4,7(a5)
    b268:  fe843783           ld a5,-24(s0)
    b26c:  00078423           sb zero,8(a5)
    b270:  0001                 nop
    b272:  6462                 ld s0,24(sp)
    b274:  6105                 addi sp,sp,32
    b276:  8082                 ret
000000000000b278 <FUN_0000b278>:
    b278:  1101                 addi sp,sp,-32
    b27a:  ec22                 sd s0,24(sp)
    b27c:  1000                 addi s0,sp,32
    b27e:  fea43423           sd a0,-24(s0)
    b282:  fe843783           ld a5,-24(s0)
    b286:  471d                 li a4,7
    b288:  00e78023           sb a4,0(a5)
    b28c:  fe843783           ld a5,-24(s0)
    b290:  4715                 li a4,5
    b292:  00e780a3           sb a4,1(a5)
    b296:  fe843783           ld a5,-24(s0)
    b29a:  04000713           li a4,64
    b29e:  00e79223           sh a4,4(a5)
    b2a2:  fe843783           ld a5,-24(s0)
    b2a6:  4705                 li a4,1
    b2a8:  00e78123           sb a4,2(a5)
    b2ac:  fe843783           ld a5,-24(s0)
    b2b0:  4709                 li a4,2
    b2b2:  00e781a3           sb a4,3(a5)
    b2b6:  fe843783           ld a5,-24(s0)
    b2ba:  00078323           sb zero,6(a5)
    b2be:  0001                 nop
    b2c0:  6462                 ld s0,24(sp)
    b2c2:  6105                 addi sp,sp,32
    b2c4:  8082                 ret
000000000000b2c6 <FUN_0000b2c6>:
    b2c6:  1101                 addi sp,sp,-32
    b2c8:  ec22                 sd s0,24(sp)
    b2ca:  1000                 addi s0,sp,32
    b2cc:  fea43423           sd a0,-24(s0)
    b2d0:  fe843783           ld a5,-24(s0)
    b2d4:  471d                 li a4,7
    b2d6:  00e78023           sb a4,0(a5)
    b2da:  fe843783           ld a5,-24(s0)
    b2de:  4715                 li a4,5
    b2e0:  00e780a3           sb a4,1(a5)
    b2e4:  fe843783           ld a5,-24(s0)
    b2e8:  04000713           li a4,64
    b2ec:  00e79223           sh a4,4(a5)
    b2f0:  fe843783           ld a5,-24(s0)
    b2f4:  f8200713           li a4,-126
    b2f8:  00e78123           sb a4,2(a5)
    b2fc:  fe843783           ld a5,-24(s0)
    b300:  4709                 li a4,2
    b302:  00e781a3           sb a4,3(a5)
    b306:  fe843783           ld a5,-24(s0)
    b30a:  00078323           sb zero,6(a5)
    b30e:  0001                 nop
    b310:  6462                 ld s0,24(sp)
    b312:  6105                 addi sp,sp,32
    b314:  8082                 ret
000000000000b316 <FUN_0000b316>:
    b316:  7179                 addi sp,sp,-48
    b318:  f422                 sd s0,40(sp)
    b31a:  1800                 addi s0,sp,48
    b31c:  fea43423           sd a0,-24(s0)
    b320:  feb43023           sd a1,-32(s0)
    b324:  fcc43c23           sd a2,-40(s0)
    b328:  fe843783           ld a5,-24(s0)
    b32c:  fd843703           ld a4,-40(s0)
    b330:  e398                 sd a4,0(a5)
    b332:  fe843783           ld a5,-24(s0)
    b336:  07a1                 addi a5,a5,8
    b338:  fe043703           ld a4,-32(s0)
    b33c:  e398                 sd a4,0(a5)
    b33e:  0001                 nop
    b340:  7422                 ld s0,40(sp)
    b342:  6145                 addi sp,sp,48
    b344:  8082                 ret
000000000000b346 <FUN_0000b346>:
    b346:  1101                 addi sp,sp,-32
    b348:  ec22                 sd s0,24(sp)
    b34a:  1000                 addi s0,sp,32
    b34c:  fea43423           sd a0,-24(s0)
    b350:  fe843783           ld a5,-24(s0)
    b354:  471d                 li a4,7
    b356:  00e78023           sb a4,0(a5)
    b35a:  fe843783           ld a5,-24(s0)
    b35e:  4715                 li a4,5
    b360:  00e780a3           sb a4,1(a5)
    b364:  fe843783           ld a5,-24(s0)
    b368:  04000713           li a4,64
    b36c:  00e79223           sh a4,4(a5)
    b370:  fe843783           ld a5,-24(s0)
    b374:  4705                 li a4,1
    b376:  00e78123           sb a4,2(a5)
    b37a:  fe843783           ld a5,-24(s0)
    b37e:  4709                 li a4,2
    b380:  00e781a3           sb a4,3(a5)
    b384:  fe843783           ld a5,-24(s0)
    b388:  00078323           sb zero,6(a5)
    b38c:  0001                 nop
    b38e:  6462                 ld s0,24(sp)
    b390:  6105                 addi sp,sp,32
    b392:  8082                 ret
000000000000b394 <FUN_0000b394>:
    b394:  1101                 addi sp,sp,-32
    b396:  ec22                 sd s0,24(sp)
    b398:  1000                 addi s0,sp,32
    b39a:  fea43423           sd a0,-24(s0)
    b39e:  fe843783           ld a5,-24(s0)
    b3a2:  471d                 li a4,7
    b3a4:  00e78023           sb a4,0(a5)
    b3a8:  fe843783           ld a5,-24(s0)
    b3ac:  4715                 li a4,5
    b3ae:  00e780a3           sb a4,1(a5)
    b3b2:  fe843783           ld a5,-24(s0)
    b3b6:  04000713           li a4,64
    b3ba:  00e79223           sh a4,4(a5)
    b3be:  fe843783           ld a5,-24(s0)
    b3c2:  f8200713           li a4,-126
    b3c6:  00e78123           sb a4,2(a5)
    b3ca:  fe843783           ld a5,-24(s0)
    b3ce:  4709                 li a4,2
    b3d0:  00e781a3           sb a4,3(a5)
    b3d4:  fe843783           ld a5,-24(s0)
    b3d8:  00078323           sb zero,6(a5)
    b3dc:  0001                 nop
    b3de:  6462                 ld s0,24(sp)
    b3e0:  6105                 addi sp,sp,32
    b3e2:  8082                 ret
000000000000b3e4 <FUN_0000b3e4>:
    b3e4:  7179                 addi sp,sp,-48
    b3e6:  f422                 sd s0,40(sp)
    b3e8:  1800                 addi s0,sp,48
    b3ea:  fea43423           sd a0,-24(s0)
    b3ee:  feb43023           sd a1,-32(s0)
    b3f2:  fcc43c23           sd a2,-40(s0)
    b3f6:  fe843783           ld a5,-24(s0)
    b3fa:  fd843703           ld a4,-40(s0)
    b3fe:  e398                 sd a4,0(a5)
    b400:  fe843783           ld a5,-24(s0)
    b404:  07a1                 addi a5,a5,8
    b406:  fe043703           ld a4,-32(s0)
    b40a:  e398                 sd a4,0(a5)
    b40c:  0001                 nop
    b40e:  7422                 ld s0,40(sp)
    b410:  6145                 addi sp,sp,48
    b412:  8082                 ret
000000000000b414 <FUN_0000b414>:
    b414:  7179                 addi sp,sp,-48
    b416:  f422                 sd s0,40(sp)
    b418:  1800                 addi s0,sp,48
    b41a:  fea43423           sd a0,-24(s0)
    b41e:  feb43023           sd a1,-32(s0)
    b422:  fcc43c23           sd a2,-40(s0)
    b426:  fe843783           ld a5,-24(s0)
    b42a:  000784a3           sb zero,9(a5)
    b42e:  fe843783           ld a5,-24(s0)
    b432:  00078523           sb zero,10(a5)
    b436:  fe843783           ld a5,-24(s0)
    b43a:  0007b023           sd zero,0(a5)
    b43e:  fe843783           ld a5,-24(s0)
    b442:  00078423           sb zero,8(a5)
    b446:  fe843783           ld a5,-24(s0)
    b44a:  04000713           li a4,64
    b44e:  c7d8                 sw a4,12(a5)
    b450:  fe843783           ld a5,-24(s0)
    b454:  0007b823           sd zero,16(a5)
    b458:  fe043783           ld a5,-32(s0)
    b45c:  0027c703           lbu a4,2(a5)
    b460:  fe843783           ld a5,-24(s0)
    b464:  02e780a3           sb a4,33(a5)
    b468:  fe043783           ld a5,-32(s0)
    b46c:  0037c703           lbu a4,3(a5)
    b470:  fe843783           ld a5,-24(s0)
    b474:  02e78123           sb a4,34(a5)
    b478:  fe843783           ld a5,-24(s0)
    b47c:  fe043703           ld a4,-32(s0)
    b480:  ef98                 sd a4,24(a5)
    b482:  fe843783           ld a5,-24(s0)
    b486:  4705                 li a4,1
    b488:  02e78023           sb a4,32(a5)
    b48c:  fe043783           ld a5,-32(s0)
    b490:  0047d783           lhu a5,4(a5)
    b494:  0007871b           sext.w a4,a5
    b498:  fe843783           ld a5,-24(s0)
    b49c:  d3d8                 sw a4,36(a5)
    b49e:  fe843783           ld a5,-24(s0)
    b4a2:  0207b423           sd zero,40(a5)
    b4a6:  fd843783           ld a5,-40(s0)
    b4aa:  0027c703           lbu a4,2(a5)
    b4ae:  fe843783           ld a5,-24(s0)
    b4b2:  02e78ca3           sb a4,57(a5)
    b4b6:  fd843783           ld a5,-40(s0)
    b4ba:  0037c703           lbu a4,3(a5)
    b4be:  fe843783           ld a5,-24(s0)
    b4c2:  02e78d23           sb a4,58(a5)
    b4c6:  fe843783           ld a5,-24(s0)
    b4ca:  fd843703           ld a4,-40(s0)
    b4ce:  fb98                 sd a4,48(a5)
    b4d0:  fe843783           ld a5,-24(s0)
    b4d4:  4709                 li a4,2
    b4d6:  02e78c23           sb a4,56(a5)
    b4da:  fd843783           ld a5,-40(s0)
    b4de:  0047d783           lhu a5,4(a5)
    b4e2:  0007871b           sext.w a4,a5
    b4e6:  fe843783           ld a5,-24(s0)
    b4ea:  dfd8                 sw a4,60(a5)
    b4ec:  fe843783           ld a5,-24(s0)
    b4f0:  0407b023           sd zero,64(a5)
    b4f4:  fe843783           ld a5,-24(s0)
    b4f8:  0407a423           sw zero,72(a5)
    b4fc:  fe843783           ld a5,-24(s0)
    b500:  04078623           sb zero,76(a5)
    b504:  fe843783           ld a5,-24(s0)
    b508:  0407a823           sw zero,80(a5)
    b50c:  fe843783           ld a5,-24(s0)
    b510:  04078a23           sb zero,84(a5)
    b514:  fe843783           ld a5,-24(s0)
    b518:  04078aa3           sb zero,85(a5)
    b51c:  0001                 nop
    b51e:  7422                 ld s0,40(sp)
    b520:  6145                 addi sp,sp,48
    b522:  8082                 ret
000000000000b524 <FUN_0000b524>:
    b524:  7179                 addi sp,sp,-48
    b526:  f422                 sd s0,40(sp)
    b528:  1800                 addi s0,sp,48
    b52a:  fea43423           sd a0,-24(s0)
    b52e:  feb43023           sd a1,-32(s0)
    b532:  fcc43c23           sd a2,-40(s0)
    b536:  fcd43823           sd a3,-48(s0)
    b53a:  fe843783           ld a5,-24(s0)
    b53e:  fe043703           ld a4,-32(s0)
    b542:  e398                 sd a4,0(a5)
    b544:  fe843783           ld a5,-24(s0)
    b548:  0007a423           sw zero,8(a5)
    b54c:  fe843783           ld a5,-24(s0)
    b550:  0007a623           sw zero,12(a5)
    b554:  fe843783           ld a5,-24(s0)
    b558:  fd843703           ld a4,-40(s0)
    b55c:  f398                 sd a4,32(a5)
    b55e:  fe843783           ld a5,-24(s0)
    b562:  0207a423           sw zero,40(a5)
    b566:  fe843783           ld a5,-24(s0)
    b56a:  fd043703           ld a4,-48(s0)
    b56e:  eb98                 sd a4,16(a5)
    b570:  fe843783           ld a5,-24(s0)
    b574:  0007ac23           sw zero,24(a5)
    b578:  0001                 nop
    b57a:  7422                 ld s0,40(sp)
    b57c:  6145                 addi sp,sp,48
    b57e:  8082                 ret
000000000000b580 <FUN_0000b580>:
    b580:  1101                 addi sp,sp,-32
    b582:  ec22                 sd s0,24(sp)
    b584:  1000                 addi s0,sp,32
    b586:  fea43423           sd a0,-24(s0)
    b58a:  feb43023           sd a1,-32(s0)
    b58e:  fe843783           ld a5,-24(s0)
    b592:  fe043703           ld a4,-32(s0)
    b596:  e398                 sd a4,0(a5)
    b598:  fe843783           ld a5,-24(s0)
    b59c:  0007a423           sw zero,8(a5)
    b5a0:  fe843783           ld a5,-24(s0)
    b5a4:  0000b737           lui a4,0xb
    b5a8:  d8e70713           addi a4,a4,-626 # ad8e <FUN_0000ad66+0x28>
    b5ac:  eb98                 sd a4,16(a5)
    b5ae:  fe843783           ld a5,-24(s0)
    b5b2:  0007ac23           sw zero,24(a5)
    b5b6:  fe843783           ld a5,-24(s0)
    b5ba:  00078623           sb zero,12(a5)
    b5be:  fe843783           ld a5,-24(s0)
    b5c2:  02078023           sb zero,32(a5)
    b5c6:  fe843783           ld a5,-24(s0)
    b5ca:  0007ae23           sw zero,28(a5)
    b5ce:  0001                 nop
    b5d0:  6462                 ld s0,24(sp)
    b5d2:  6105                 addi sp,sp,32
    b5d4:  8082                 ret
000000000000b5d6 <FUN_0000b5d6>:
    b5d6:  1101                 addi sp,sp,-32
    b5d8:  ec22                 sd s0,24(sp)
    b5da:  1000                 addi s0,sp,32
    b5dc:  fea43423           sd a0,-24(s0)
    b5e0:  feb43023           sd a1,-32(s0)
    b5e4:  fe843783           ld a5,-24(s0)
    b5e8:  fe043703           ld a4,-32(s0)
    b5ec:  e398                 sd a4,0(a5)
    b5ee:  fe843783           ld a5,-24(s0)
    b5f2:  0007a423           sw zero,8(a5)
    b5f6:  fe843783           ld a5,-24(s0)
    b5fa:  0000b737           lui a4,0xb
    b5fe:  dc270713           addi a4,a4,-574 # adc2 <FUN_0000ad66+0x5c>
    b602:  eb98                 sd a4,16(a5)
    b604:  fe843783           ld a5,-24(s0)
    b608:  0007ac23           sw zero,24(a5)
    b60c:  fe843783           ld a5,-24(s0)
    b610:  00078623           sb zero,12(a5)
    b614:  fe843783           ld a5,-24(s0)
    b618:  02078023           sb zero,32(a5)
    b61c:  fe843783           ld a5,-24(s0)
    b620:  4705                 li a4,1
    b622:  cfd8                 sw a4,28(a5)
    b624:  0001                 nop
    b626:  6462                 ld s0,24(sp)
    b628:  6105                 addi sp,sp,32
    b62a:  8082                 ret
000000000000b62c <FUN_0000b62c>:
    b62c:  1101                 addi sp,sp,-32
    b62e:  ec22                 sd s0,24(sp)
    b630:  1000                 addi s0,sp,32
    b632:  fea43423           sd a0,-24(s0)
    b636:  feb43023           sd a1,-32(s0)
    b63a:  fe843783           ld a5,-24(s0)
    b63e:  fe043703           ld a4,-32(s0)
    b642:  e398                 sd a4,0(a5)
    b644:  fe843783           ld a5,-24(s0)
    b648:  0007a423           sw zero,8(a5)
    b64c:  fe843783           ld a5,-24(s0)
    b650:  0000b737           lui a4,0xb
    b654:  da870713           addi a4,a4,-600 # ada8 <FUN_0000ad66+0x42>
    b658:  eb98                 sd a4,16(a5)
    b65a:  fe843783           ld a5,-24(s0)
    b65e:  0007ac23           sw zero,24(a5)
    b662:  fe843783           ld a5,-24(s0)
    b666:  00078623           sb zero,12(a5)
    b66a:  fe843783           ld a5,-24(s0)
    b66e:  02078023           sb zero,32(a5)
    b672:  fe843783           ld a5,-24(s0)
    b676:  4709                 li a4,2
    b678:  cfd8                 sw a4,28(a5)
    b67a:  0001                 nop
    b67c:  6462                 ld s0,24(sp)
    b67e:  6105                 addi sp,sp,32
    b680:  8082                 ret
000000000000b682 <FUN_0000b682>:
    b682:  7179                 addi sp,sp,-48
    b684:  f422                 sd s0,40(sp)
    b686:  1800                 addi s0,sp,48
    b688:  fea43423           sd a0,-24(s0)
    b68c:  feb43023           sd a1,-32(s0)
    b690:  fcc43c23           sd a2,-40(s0)
    b694:  fcd43823           sd a3,-48(s0)
    b698:  fe843783           ld a5,-24(s0)
    b69c:  fe043703           ld a4,-32(s0)
    b6a0:  eb98                 sd a4,16(a5)
    b6a2:  fe843783           ld a5,-24(s0)
    b6a6:  fd843703           ld a4,-40(s0)
    b6aa:  f798                 sd a4,40(a5)
    b6ac:  fe843783           ld a5,-24(s0)
    b6b0:  fd043703           ld a4,-48(s0)
    b6b4:  e3b8                 sd a4,64(a5)
    b6b6:  0001                 nop
    b6b8:  7422                 ld s0,40(sp)
    b6ba:  6145                 addi sp,sp,48
    b6bc:  8082                 ret
000000000000b6be <FUN_0000b6be>:
    b6be:  1101                 addi sp,sp,-32
    b6c0:  ec22                 sd s0,24(sp)
    b6c2:  1000                 addi s0,sp,32
    b6c4:  fe0407a3           sb zero,-17(s0)
    b6c8:  041007b7           lui a5,0x4100
    b6cc:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    b6d0:  0007c783           lbu a5,0(a5)
    b6d4:  fef407a3           sb a5,-17(s0)
    b6d8:  fef44783           lbu a5,-17(s0)
    b6dc:  fdf7f793           andi a5,a5,-33
    b6e0:  fef407a3           sb a5,-17(s0)
    b6e4:  041007b7           lui a5,0x4100
    b6e8:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    b6ec:  fef44703           lbu a4,-17(s0)
    b6f0:  00e78023           sb a4,0(a5)
    b6f4:  041007b7           lui a5,0x4100
    b6f8:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    b6fc:  0007c783           lbu a5,0(a5)
    b700:  fef407a3           sb a5,-17(s0)
    b704:  0001                 nop
    b706:  6462                 ld s0,24(sp)
    b708:  6105                 addi sp,sp,32
    b70a:  8082                 ret
000000000000b70c <FUN_0000b70c>:
    b70c:  1101                 addi sp,sp,-32
    b70e:  ec22                 sd s0,24(sp)
    b710:  1000                 addi s0,sp,32
    b712:  fe042623           sw zero,-20(s0)
    b716:  041007b7           lui a5,0x4100
    b71a:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b71e:  439c                 lw a5,0(a5)
    b720:  fef42623           sw a5,-20(s0)
    b724:  fec42703           lw a4,-20(s0)
    b728:  67b1                 lui a5,0xc
    b72a:  8fd9                 or a5,a5,a4
    b72c:  fef42623           sw a5,-20(s0)
    b730:  041007b7           lui a5,0x4100
    b734:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b738:  fec42703           lw a4,-20(s0)
    b73c:  c398                 sw a4,0(a5)
    b73e:  0001                 nop
    b740:  6462                 ld s0,24(sp)
    b742:  6105                 addi sp,sp,32
    b744:  8082                 ret
000000000000b746 <FUN_0000b746>:
    b746:  1101                 addi sp,sp,-32
    b748:  ec22                 sd s0,24(sp)
    b74a:  1000                 addi s0,sp,32
    b74c:  fe042423           sw zero,-24(s0)
    b750:  fe042623           sw zero,-20(s0)
    b754:  041007b7           lui a5,0x4100
    b758:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b75c:  439c                 lw a5,0(a5)
    b75e:  fef42423           sw a5,-24(s0)
    b762:  fe842703           lw a4,-24(s0)
    b766:  67c1                 lui a5,0x10
    b768:  8fd9                 or a5,a5,a4
    b76a:  fef42423           sw a5,-24(s0)
    b76e:  041007b7           lui a5,0x4100
    b772:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b776:  fe842703           lw a4,-24(s0)
    b77a:  c398                 sw a4,0(a5)
    b77c:  7d000793           li a5,2000
    b780:  fef42623           sw a5,-20(s0)
    b784:  0001                 nop
    b786:  fec42783           lw a5,-20(s0)
    b78a:  fff7871b           addiw a4,a5,-1
    b78e:  fee42623           sw a4,-20(s0)
    b792:  fbf5                 bnez a5,b786 <FUN_0000b746+0x40>
    b794:  fe842703           lw a4,-24(s0)
    b798:  6785                 lui a5,0x1
    b79a:  c0078793           addi a5,a5,-1024 # c00 <FUN_00000bbe+0x42>
    b79e:  8fd9                 or a5,a5,a4
    b7a0:  fef42423           sw a5,-24(s0)
    b7a4:  041007b7           lui a5,0x4100
    b7a8:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b7ac:  fe842703           lw a4,-24(s0)
    b7b0:  c398                 sw a4,0(a5)
    b7b2:  0001                 nop
    b7b4:  6462                 ld s0,24(sp)
    b7b6:  6105                 addi sp,sp,32
    b7b8:  8082                 ret
000000000000b7ba <FUN_0000b7ba>:
    b7ba:  1101                 addi sp,sp,-32
    b7bc:  ec22                 sd s0,24(sp)
    b7be:  1000                 addi s0,sp,32
    b7c0:  fe042623           sw zero,-20(s0)
    b7c4:  041007b7           lui a5,0x4100
    b7c8:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b7cc:  439c                 lw a5,0(a5)
    b7ce:  2781                 sext.w a5,a5
    b7d0:  fef405a3           sb a5,-21(s0)
    b7d4:  feb44783           lbu a5,-21(s0)
    b7d8:  0007871b           sext.w a4,a5
    b7dc:  0c0007b7           lui a5,0xc000
    b7e0:  8ff9                 and a5,a5,a4
    b7e2:  2781                 sext.w a5,a5
    b7e4:  e7b1                 bnez a5,b830 <FUN_0000b7ba+0x76>
    b7e6:  041007b7           lui a5,0x4100
    b7ea:  04178793           addi a5,a5,65 # 4100041 <gpio_get_boot_device+0x40f1cab>
    b7ee:  0007c783           lbu a5,0(a5)
    b7f2:  0ff7f793           andi a5,a5,255
    b7f6:  2781                 sext.w a5,a5
    b7f8:  8be1                 andi a5,a5,24
    b7fa:  2781                 sext.w a5,a5
    b7fc:  873e                 mv a4,a5
    b7fe:  47e1                 li a5,24
    b800:  02f70663           beq a4,a5,b82c <FUN_0000b7ba+0x72>
    b804:  041007b7           lui a5,0x4100
    b808:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b80c:  439c                 lw a5,0(a5)
    b80e:  fef42623           sw a5,-20(s0)
    b812:  fec42703           lw a4,-20(s0)
    b816:  678d                 lui a5,0x3
    b818:  8fd9                 or a5,a5,a4
    b81a:  fef42623           sw a5,-20(s0)
    b81e:  041007b7           lui a5,0x4100
    b822:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b826:  fec42703           lw a4,-20(s0)
    b82a:  c398                 sw a4,0(a5)
    b82c:  4785                 li a5,1
    b82e:  a011                 j b832 <FUN_0000b7ba+0x78>
    b830:  4781                 li a5,0
    b832:  853e                 mv a0,a5
    b834:  6462                 ld s0,24(sp)
    b836:  6105                 addi sp,sp,32
    b838:  8082                 ret
000000000000b83a <FUN_0000b83a>:
    b83a:  1101                 addi sp,sp,-32
    b83c:  ec22                 sd s0,24(sp)
    b83e:  1000                 addi s0,sp,32
    b840:  fe042623           sw zero,-20(s0)
    b844:  041007b7           lui a5,0x4100
    b848:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b84c:  439c                 lw a5,0(a5)
    b84e:  fef42623           sw a5,-20(s0)
    b852:  fec42703           lw a4,-20(s0)
    b856:  77c1                 lui a5,0xffff0
    b858:  17fd                 addi a5,a5,-1
    b85a:  8ff9                 and a5,a5,a4
    b85c:  fef42623           sw a5,-20(s0)
    b860:  041007b7           lui a5,0x4100
    b864:  40078793           addi a5,a5,1024 # 4100400 <gpio_get_boot_device+0x40f206
    b868:  fec42703           lw a4,-20(s0)
    b86c:  c398                 sw a4,0(a5)
    b86e:  0001                 nop
    b870:  6462                 ld s0,24(sp)
    b872:  6105                 addi sp,sp,32
    b874:  8082                 ret
000000000000b876 <FUN_0000b876>:
    b876:  1101                 addi sp,sp,-32
    b878:  ec22                 sd s0,24(sp)
    b87a:  1000                 addi s0,sp,32
    b87c:  041007b7           lui a5,0x4100
    b880:  04178793           addi a5,a5,65 # 4100041 <gpio_get_boot_device+0x40f1cab>
    b884:  0007c783           lbu a5,0(a5)
    b888:  fef407a3           sb a5,-17(s0)
    b88c:  fef40783           lb a5,-17(s0)
    b890:  0207d563           bgez a5,b8ba <FUN_0000b876+0x44>
    b894:  041007b7           lui a5,0x4100
    b898:  04178793           addi a5,a5,65 # 4100041 <gpio_get_boot_device+0x40f1cab>
    b89c:  0007c783           lbu a5,0(a5)
    b8a0:  fef40723           sb a5,-18(s0)
    b8a4:  fee44783           lbu a5,-18(s0)
    b8a8:  2781                 sext.w a5,a5
    b8aa:  8be1                 andi a5,a5,24
    b8ac:  2781                 sext.w a5,a5
    b8ae:  873e                 mv a4,a5
    b8b0:  47e1                 li a5,24
    b8b2:  00f71463           bne a4,a5,b8ba <FUN_0000b876+0x44>
    b8b6:  4785                 li a5,1
    b8b8:  a011                 j b8bc <FUN_0000b876+0x46>
    b8ba:  4781                 li a5,0
    b8bc:  853e                 mv a0,a5
    b8be:  6462                 ld s0,24(sp)
    b8c0:  6105                 addi sp,sp,32
    b8c2:  8082                 ret
000000000000b8c4 <FUN_0000b8c4>:
    b8c4:  1101                 addi sp,sp,-32
    b8c6:  ec06                 sd ra,24(sp)
    b8c8:  e822                 sd s0,16(sp)
    b8ca:  1000                 addi s0,sp,32
    b8cc:  e41ff0ef           jal ra,b70c <FUN_0000b70c>
    b8d0:  e77ff0ef           jal ra,b746 <FUN_0000b746>
    b8d4:  fa3ff0ef           jal ra,b876 <FUN_0000b876>
    b8d8:  87aa                 mv a5,a0
    b8da:  fef42623           sw a5,-20(s0)
    b8de:  eddff0ef           jal ra,b7ba <FUN_0000b7ba>
    b8e2:  87aa                 mv a5,a0
    b8e4:  fef42423           sw a5,-24(s0)
    b8e8:  fec42783           lw a5,-20(s0)
    b8ec:  2781                 sext.w a5,a5
    b8ee:  e791                 bnez a5,b8fa <FUN_0000b8c4+0x36>
    b8f0:  fe842783           lw a5,-24(s0)
    b8f4:  2781                 sext.w a5,a5
    b8f6:  e391                 bnez a5,b8fa <FUN_0000b8c4+0x36>
    b8f8:  bff1                 j b8d4 <FUN_0000b8c4+0x10>
    b8fa:  f41ff0ef           jal ra,b83a <FUN_0000b83a>
    b8fe:  0001                 nop
    b900:  60e2                 ld ra,24(sp)
    b902:  6442                 ld s0,16(sp)
    b904:  6105                 addi sp,sp,32
    b906:  8082                 ret
000000000000b908 <FUN_0000b908>:
    b908:  1101                 addi sp,sp,-32
    b90a:  ec06                 sd ra,24(sp)
    b90c:  e822                 sd s0,16(sp)
    b90e:  1000                 addi s0,sp,32
    b910:  fea43423           sd a0,-24(s0)
    b914:  f5afc0ef           jal ra,806e <brom_config_bit_1>
    b918:  87aa                 mv a5,a0
    b91a:  c785                 beqz a5,b942 <FUN_0000b908+0x3a>
    b91c:  041007b7           lui a5,0x4100
    b920:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    b924:  0007c783           lbu a5,0(a5)
    b928:  0ff7f713           andi a4,a5,255
    b92c:  041007b7           lui a5,0x4100
    b930:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    b934:  02076713           ori a4,a4,32
    b938:  0ff77713           andi a4,a4,255
    b93c:  00e78023           sb a4,0(a5)
    b940:  a019                 j b946 <FUN_0000b908+0x3e>
    b942:  d7dff0ef           jal ra,b6be <FUN_0000b6be>
    b946:  13d020ef           jal ra,e282 <FUN_0000e282>
    b94a:  041007b7           lui a5,0x4100
    b94e:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    b952:  4705                 li a4,1
    b954:  00e78023           sb a4,0(a5)
    b958:  041007b7           lui a5,0x4100
    b95c:  09478793           addi a5,a5,148 # 4100094 <gpio_get_boot_device+0x40f1cfe
    b960:  471d                 li a4,7
    b962:  00e78023           sb a4,0(a5)
    b966:  041007b7           lui a5,0x4100
    b96a:  09678793           addi a5,a5,150 # 4100096 <gpio_get_boot_device+0x40f1d00
    b96e:  08000713           li a4,128
    b972:  00e79023           sh a4,0(a5)
    b976:  041007b7           lui a5,0x4100
    b97a:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    b97e:  4709                 li a4,2
    b980:  00e78023           sb a4,0(a5)
    b984:  041007b7           lui a5,0x4100
    b988:  09078793           addi a5,a5,144 # 4100090 <gpio_get_boot_device+0x40f1cfa
    b98c:  471d                 li a4,7
    b98e:  00e78023           sb a4,0(a5)
    b992:  041007b7           lui a5,0x4100
    b996:  09278793           addi a5,a5,146 # 4100092 <gpio_get_boot_device+0x40f1cfc
    b99a:  10000713           li a4,256
    b99e:  00e79023           sh a4,0(a5)
    b9a2:  041007b7           lui a5,0x4100
    b9a6:  05078793           addi a5,a5,80 # 4100050 <gpio_get_boot_device+0x40f1cba>
    b9aa:  471d                 li a4,7
    b9ac:  00e78023           sb a4,0(a5)
    b9b0:  041007b7           lui a5,0x4100
    b9b4:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    b9b8:  0007c783           lbu a5,0(a5)
    b9bc:  0ff7f713           andi a4,a5,255
    b9c0:  041007b7           lui a5,0x4100
    b9c4:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    b9c8:  00176713           ori a4,a4,1
    b9cc:  0ff77713           andi a4,a4,255
    b9d0:  00e78023           sb a4,0(a5)
    b9d4:  000487b7           lui a5,0x48
    b9d8:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    b9dc:  853e                 mv a0,a5
    b9de:  5a9000ef           jal ra,c786 <FUN_0000c786>
    b9e2:  e8cfc0ef           jal ra,806e <brom_config_bit_1>
    b9e6:  87aa                 mv a5,a0
    b9e8:  cb81                 beqz a5,b9f8 <FUN_0000b908+0xf0>
    b9ea:  fe843783           ld a5,-24(s0)
    b9ee:  67bc                 ld a5,72(a5)
    b9f0:  470d                 li a4,3
    b9f2:  04e78623           sb a4,76(a5)
    b9f6:  a039                 j ba04 <FUN_0000b908+0xfc>
    b9f8:  fe843783           ld a5,-24(s0)
    b9fc:  67bc                 ld a5,72(a5)
    b9fe:  4709                 li a4,2
    ba00:  04e78623           sb a4,76(a5)
    ba04:  ec1ff0ef           jal ra,b8c4 <FUN_0000b8c4>
    ba08:  041007b7           lui a5,0x4100
    ba0c:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    ba10:  0007c783           lbu a5,0(a5)
    ba14:  0ff7f713           andi a4,a5,255
    ba18:  041007b7           lui a5,0x4100
    ba1c:  04078793           addi a5,a5,64 # 4100040 <gpio_get_boot_device+0x40f1caa>
    ba20:  04076713           ori a4,a4,64
    ba24:  0ff77713           andi a4,a4,255
    ba28:  00e78023           sb a4,0(a5)
    ba2c:  0001                 nop
    ba2e:  60e2                 ld ra,24(sp)
    ba30:  6442                 ld s0,16(sp)
    ba32:  6105                 addi sp,sp,32
    ba34:  8082                 ret
000000000000ba36 <FUN_0000ba36>:
    ba36:  1101                 addi sp,sp,-32
    ba38:  ec06                 sd ra,24(sp)
    ba3a:  e822                 sd s0,16(sp)
    ba3c:  1000                 addi s0,sp,32
    ba3e:  fea43423           sd a0,-24(s0)
    ba42:  041007b7           lui a5,0x4100
    ba46:  04378793           addi a5,a5,67 # 4100043 <gpio_get_boot_device+0x40f1cad>
    ba4a:  0007c783           lbu a5,0(a5)
    ba4e:  0ff7f713           andi a4,a5,255
    ba52:  041007b7           lui a5,0x4100
    ba56:  04378793           addi a5,a5,67 # 4100043 <gpio_get_boot_device+0x40f1cad>
    ba5a:  9b79                 andi a4,a4,-2
    ba5c:  0ff77713           andi a4,a4,255
    ba60:  00e78023           sb a4,0(a5)
    ba64:  fe843503           ld a0,-24(s0)
    ba68:  ea1ff0ef           jal ra,b908 <FUN_0000b908>
    ba6c:  fe843503           ld a0,-24(s0)
    ba70:  de8ff0ef           jal ra,b058 <FUN_0000b058>
    ba74:  fe843503           ld a0,-24(s0)
    ba78:  e22ff0ef           jal ra,b09a <enable_interrupts>
    ba7c:  f6afe0ef           jal ra,a1e6 <FUN_0000a1e6>
    ba80:  0001                 nop
    ba82:  60e2                 ld ra,24(sp)
    ba84:  6442                 ld s0,16(sp)
    ba86:  6105                 addi sp,sp,32
    ba88:  8082                 ret
000000000000ba8a <FUN_0000ba8a>:
    ba8a:  7179                 addi sp,sp,-48
    ba8c:  f422                 sd s0,40(sp)
    ba8e:  1800                 addi s0,sp,48
    ba90:  fea43423           sd a0,-24(s0)
    ba94:  feb43023           sd a1,-32(s0)
    ba98:  fcc43c23           sd a2,-40(s0)
    ba9c:  fe843783           ld a5,-24(s0)
    baa0:  0097c783           lbu a5,9(a5)
    baa4:  2781                 sext.w a5,a5
    baa6:  07f7f793           andi a5,a5,127
    baaa:  2781                 sext.w a5,a5
    baac:  873e                 mv a4,a5
    baae:  4791                 li a5,4
    bab0:  00e7d463           bge a5,a4,bab8 <FUN_0000ba8a+0x2e>
    bab4:  57fd                 li a5,-1
    bab6:  a06d                 j bb60 <FUN_0000ba8a+0xd6>
    bab8:  fe843783           ld a5,-24(s0)
    babc:  0097c783           lbu a5,9(a5)
    bac0:  2781                 sext.w a5,a5
    bac2:  07f7f793           andi a5,a5,127
    bac6:  2781                 sext.w a5,a5
    bac8:  86be                 mv a3,a5
    baca:  4709                 li a4,2
    bacc:  04e68863           beq a3,a4,bb1c <FUN_0000ba8a+0x92>
    bad0:  86be                 mv a3,a5
    bad2:  4709                 li a4,2
    bad4:  00d74763           blt a4,a3,bae2 <FUN_0000ba8a+0x58>
    bad8:  873e                 mv a4,a5
    bada:  4785                 li a5,1
    badc:  02f70563           beq a4,a5,bb06 <FUN_0000ba8a+0x7c>
    bae0:  a809                 j baf2 <FUN_0000ba8a+0x68>
    bae2:  86be                 mv a3,a5
    bae4:  470d                 li a4,3
    bae6:  04e68663           beq a3,a4,bb32 <FUN_0000ba8a+0xa8>
    baea:  873e                 mv a4,a5
    baec:  4791                 li a5,4
    baee:  04f70d63           beq a4,a5,bb48 <FUN_0000ba8a+0xbe>
    baf2:  fe043783           ld a5,-32(s0)
    baf6:  0007a023           sw zero,0(a5)
    bafa:  fd843783           ld a5,-40(s0)
    bafe:  04100737           lui a4,0x4100
    bb02:  c398                 sw a4,0(a5)
    bb04:  a8a9                 j bb5e <FUN_0000ba8a+0xd4>
    bb06:  fe043783           ld a5,-32(s0)
    bb0a:  4705                 li a4,1
    bb0c:  c398                 sw a4,0(a5)
    bb0e:  fd843783           ld a5,-40(s0)
    bb12:  04100737           lui a4,0x4100
    bb16:  2711                 addiw a4,a4,4
    bb18:  c398                 sw a4,0(a5)
    bb1a:  a091                 j bb5e <FUN_0000ba8a+0xd4>
    bb1c:  fe043783           ld a5,-32(s0)
    bb20:  4709                 li a4,2
    bb22:  c398                 sw a4,0(a5)
    bb24:  fd843783           ld a5,-40(s0)
    bb28:  04100737           lui a4,0x4100
    bb2c:  2721                 addiw a4,a4,8
    bb2e:  c398                 sw a4,0(a5)
    bb30:  a03d                 j bb5e <FUN_0000ba8a+0xd4>
    bb32:  fe043783           ld a5,-32(s0)
    bb36:  470d                 li a4,3
    bb38:  c398                 sw a4,0(a5)
    bb3a:  fd843783           ld a5,-40(s0)
    bb3e:  04100737           lui a4,0x4100
    bb42:  2731                 addiw a4,a4,12
    bb44:  c398                 sw a4,0(a5)
    bb46:  a821                 j bb5e <FUN_0000ba8a+0xd4>
    bb48:  fe043783           ld a5,-32(s0)
    bb4c:  4711                 li a4,4
    bb4e:  c398                 sw a4,0(a5)
    bb50:  fd843783           ld a5,-40(s0)
    bb54:  04100737           lui a4,0x4100
    bb58:  2741                 addiw a4,a4,16
    bb5a:  c398                 sw a4,0(a5)
    bb5c:  0001                 nop
    bb5e:  4781                 li a5,0
    bb60:  853e                 mv a0,a5
    bb62:  7422                 ld s0,40(sp)
    bb64:  6145                 addi sp,sp,48
    bb66:  8082                 ret
000000000000bb68 <FUN_0000bb68>:
    bb68:  1141                 addi sp,sp,-16
    bb6a:  e422                 sd s0,8(sp)
    bb6c:  0800                 addi s0,sp,16
    bb6e:  0001                 nop
    bb70:  6422                 ld s0,8(sp)
    bb72:  0141                 addi sp,sp,16
    bb74:  8082                 ret
000000000000bb76 <FUN_0000bb76>:
    bb76:  1101                 addi sp,sp,-32
    bb78:  ec22                 sd s0,24(sp)
    bb7a:  1000                 addi s0,sp,32
    bb7c:  fea43423           sd a0,-24(s0)
    bb80:  fe843783           ld a5,-24(s0)
    bb84:  5bbc                 lw a5,112(a5)
    bb86:  ef91                 bnez a5,bba2 <FUN_0000bb76+0x2c>
    bb88:  041007b7           lui a5,0x4100
    bb8c:  04478793           addi a5,a5,68 # 4100044 <gpio_get_boot_device+0x40f1cae>
    bb90:  0007c783           lbu a5,0(a5)
    bb94:  0ff7f793           andi a5,a5,255
    bb98:  0007871b           sext.w a4,a5
    bb9c:  fe843783           ld a5,-24(s0)
    bba0:  dbb8                 sw a4,112(a5)
    bba2:  fe843783           ld a5,-24(s0)
    bba6:  5bbc                 lw a5,112(a5)
    bba8:  853e                 mv a0,a5
    bbaa:  6462                 ld s0,24(sp)
    bbac:  6105                 addi sp,sp,32
    bbae:  8082                 ret
000000000000bbb0 <FUN_0000bbb0>:
    bbb0:  1101                 addi sp,sp,-32
    bbb2:  ec22                 sd s0,24(sp)
    bbb4:  1000                 addi s0,sp,32
    bbb6:  fea43423           sd a0,-24(s0)
    bbba:  fe843783           ld a5,-24(s0)
    bbbe:  5bfc                 lw a5,116(a5)
    bbc0:  ef91                 bnez a5,bbdc <FUN_0000bbb0+0x2c>
    bbc2:  041007b7           lui a5,0x4100
    bbc6:  04678793           addi a5,a5,70 # 4100046 <gpio_get_boot_device+0x40f1cb0>
    bbca:  0007c783           lbu a5,0(a5)
    bbce:  0ff7f793           andi a5,a5,255
    bbd2:  0007871b           sext.w a4,a5
    bbd6:  fe843783           ld a5,-24(s0)
    bbda:  dbf8                 sw a4,116(a5)
    bbdc:  fe843783           ld a5,-24(s0)
    bbe0:  5bfc                 lw a5,116(a5)
    bbe2:  853e                 mv a0,a5
    bbe4:  6462                 ld s0,24(sp)
    bbe6:  6105                 addi sp,sp,32
    bbe8:  8082                 ret
000000000000bbea <FUN_0000bbea>:
    bbea:  1101                 addi sp,sp,-32
    bbec:  ec22                 sd s0,24(sp)
    bbee:  1000                 addi s0,sp,32
    bbf0:  fea43423           sd a0,-24(s0)
    bbf4:  fe843783           ld a5,-24(s0)
    bbf8:  5fbc                 lw a5,120(a5)
    bbfa:  ef91                 bnez a5,bc16 <FUN_0000bbea+0x2c>
    bbfc:  041007b7           lui a5,0x4100
    bc00:  04c78793           addi a5,a5,76 # 410004c <gpio_get_boot_device+0x40f1cb6>
    bc04:  0007c783           lbu a5,0(a5)
    bc08:  0ff7f793           andi a5,a5,255
    bc0c:  0007871b           sext.w a4,a5
    bc10:  fe843783           ld a5,-24(s0)
    bc14:  dfb8                 sw a4,120(a5)
    bc16:  fe843783           ld a5,-24(s0)
    bc1a:  5fbc                 lw a5,120(a5)
    bc1c:  853e                 mv a0,a5
    bc1e:  6462                 ld s0,24(sp)
    bc20:  6105                 addi sp,sp,32
    bc22:  8082                 ret
000000000000bc24 <FUN_0000bc24>:
    bc24:  1101                 addi sp,sp,-32
    bc26:  ec22                 sd s0,24(sp)
    bc28:  1000                 addi s0,sp,32
    bc2a:  fea43423           sd a0,-24(s0)
    bc2e:  87ae                 mv a5,a1
    bc30:  fef403a3           sb a5,-25(s0)
    bc34:  fe843783           ld a5,-24(s0)
    bc38:  5bb8                 lw a4,112(a5)
    bc3a:  fe744783           lbu a5,-25(s0)
    bc3e:  2781                 sext.w a5,a5
    bc40:  fff7c793           not a5,a5
    bc44:  2781                 sext.w a5,a5
    bc46:  8ff9                 and a5,a5,a4
    bc48:  0007871b           sext.w a4,a5
    bc4c:  fe843783           ld a5,-24(s0)
    bc50:  dbb8                 sw a4,112(a5)
    bc52:  041007b7           lui a5,0x4100
    bc56:  04478793           addi a5,a5,68 # 4100044 <gpio_get_boot_device+0x40f1cae>
    bc5a:  fe744703           lbu a4,-25(s0)
    bc5e:  00e78023           sb a4,0(a5)
    bc62:  4781                 li a5,0
    bc64:  853e                 mv a0,a5
    bc66:  6462                 ld s0,24(sp)
    bc68:  6105                 addi sp,sp,32
    bc6a:  8082                 ret
000000000000bc6c <FUN_0000bc6c>:
    bc6c:  1101                 addi sp,sp,-32
    bc6e:  ec22                 sd s0,24(sp)
    bc70:  1000                 addi s0,sp,32
    bc72:  fea43423           sd a0,-24(s0)
    bc76:  87ae                 mv a5,a1
    bc78:  fef403a3           sb a5,-25(s0)
    bc7c:  fe843783           ld a5,-24(s0)
    bc80:  5bf8                 lw a4,116(a5)
    bc82:  fe744783           lbu a5,-25(s0)
    bc86:  2781                 sext.w a5,a5
    bc88:  fff7c793           not a5,a5
    bc8c:  2781                 sext.w a5,a5
    bc8e:  8ff9                 and a5,a5,a4
    bc90:  0007871b           sext.w a4,a5
    bc94:  fe843783           ld a5,-24(s0)
    bc98:  dbf8                 sw a4,116(a5)
    bc9a:  041007b7           lui a5,0x4100
    bc9e:  04678793           addi a5,a5,70 # 4100046 <gpio_get_boot_device+0x40f1cb0>
    bca2:  fe744703           lbu a4,-25(s0)
    bca6:  00e78023           sb a4,0(a5)
    bcaa:  4781                 li a5,0
    bcac:  853e                 mv a0,a5
    bcae:  6462                 ld s0,24(sp)
    bcb0:  6105                 addi sp,sp,32
    bcb2:  8082                 ret
000000000000bcb4 <FUN_0000bcb4>:
    bcb4:  1101                 addi sp,sp,-32
    bcb6:  ec22                 sd s0,24(sp)
    bcb8:  1000                 addi s0,sp,32
    bcba:  fea43423           sd a0,-24(s0)
    bcbe:  87ae                 mv a5,a1
    bcc0:  fef403a3           sb a5,-25(s0)
    bcc4:  fe843783           ld a5,-24(s0)
    bcc8:  5fb8                 lw a4,120(a5)
    bcca:  fe744783           lbu a5,-25(s0)
    bcce:  2781                 sext.w a5,a5
    bcd0:  fff7c793           not a5,a5
    bcd4:  2781                 sext.w a5,a5
    bcd6:  8ff9                 and a5,a5,a4
    bcd8:  0007871b           sext.w a4,a5
    bcdc:  fe843783           ld a5,-24(s0)
    bce0:  dfb8                 sw a4,120(a5)
    bce2:  041007b7           lui a5,0x4100
    bce6:  04c78793           addi a5,a5,76 # 410004c <gpio_get_boot_device+0x40f1cb6>
    bcea:  fe744703           lbu a4,-25(s0)
    bcee:  00e78023           sb a4,0(a5)
    bcf2:  4781                 li a5,0
    bcf4:  853e                 mv a0,a5
    bcf6:  6462                 ld s0,24(sp)
    bcf8:  6105                 addi sp,sp,32
    bcfa:  8082                 ret
000000000000bcfc <FUN_0000bcfc>:
    bcfc:  1101                 addi sp,sp,-32
    bcfe:  ec22                 sd s0,24(sp)
    bd00:  1000                 addi s0,sp,32
    bd02:  fea43423           sd a0,-24(s0)
    bd06:  fe843783           ld a5,-24(s0)
    bd0a:  0607ac23           sw zero,120(a5)
    bd0e:  fe843783           ld a5,-24(s0)
    bd12:  0607a823           sw zero,112(a5)
    bd16:  fe843783           ld a5,-24(s0)
    bd1a:  0607aa23           sw zero,116(a5)
    bd1e:  4781                 li a5,0
    bd20:  853e                 mv a0,a5
    bd22:  6462                 ld s0,24(sp)
    bd24:  6105                 addi sp,sp,32
    bd26:  8082                 ret
000000000000bd28 <FUN_0000bd28>:
    bd28:  7179                 addi sp,sp,-48
    bd2a:  f406                 sd ra,40(sp)
    bd2c:  f022                 sd s0,32(sp)
    bd2e:  1800                 addi s0,sp,48
    bd30:  fea43423           sd a0,-24(s0)
    bd34:  feb43023           sd a1,-32(s0)
    bd38:  87b2                 mv a5,a2
    bd3a:  fcf42e23           sw a5,-36(s0)
    bd3e:  fdc42783           lw a5,-36(s0)
    bd42:  0187971b           slliw a4,a5,0x18
    bd46:  4187571b           sraiw a4,a4,0x18
    bd4a:  fe043783           ld a5,-32(s0)
    bd4e:  02e78023           sb a4,32(a5)
    bd52:  fe043783           ld a5,-32(s0)
    bd56:  6b9c                 ld a5,16(a5)
    bd58:  fe043503           ld a0,-32(s0)
    bd5c:  9782                 jalr a5
    bd5e:  0001                 nop
    bd60:  70a2                 ld ra,40(sp)
    bd62:  7402                 ld s0,32(sp)
    bd64:  6145                 addi sp,sp,48
    bd66:  8082                 ret
000000000000bd68 <FUN_0000bd68>:
    bd68:  7179                 addi sp,sp,-48
    bd6a:  f422                 sd s0,40(sp)
    bd6c:  1800                 addi s0,sp,48
    bd6e:  87aa                 mv a5,a0
    bd70:  fcb43823           sd a1,-48(s0)
    bd74:  8732                 mv a4,a2
    bd76:  fcf42e23           sw a5,-36(s0)
    bd7a:  87ba                 mv a5,a4
    bd7c:  fcf42c23           sw a5,-40(s0)
    bd80:  fe042223           sw zero,-28(s0)
    bd84:  fd043783           ld a5,-48(s0)
    bd88:  639c                 ld a5,0(a5)
    bd8a:  873e                 mv a4,a5
    bd8c:  fd043783           ld a5,-48(s0)
    bd90:  4f9c                 lw a5,24(a5)
    bd92:  1782                 slli a5,a5,0x20
    bd94:  9381                 srli a5,a5,0x20
    bd96:  97ba                 add a5,a5,a4
    bd98:  fef43423           sd a5,-24(s0)
    bd9c:  fd043783           ld a5,-48(s0)
    bda0:  4798                 lw a4,8(a5)
    bda2:  fd043783           ld a5,-48(s0)
    bda6:  4f9c                 lw a5,24(a5)
    bda8:  40f707bb           subw a5,a4,a5
    bdac:  2781                 sext.w a5,a5
    bdae:  863e                 mv a2,a5
    bdb0:  fd842783           lw a5,-40(s0)
    bdb4:  0007869b           sext.w a3,a5
    bdb8:  0006071b           sext.w a4,a2
    bdbc:  00d77363           bgeu a4,a3,bdc2 <FUN_0000bd68+0x5a>
    bdc0:  87b2                 mv a5,a2
    bdc2:  fef42223           sw a5,-28(s0)
    bdc6:  fd043783           ld a5,-48(s0)
    bdca:  4f9c                 lw a5,24(a5)
    bdcc:  fe442703           lw a4,-28(s0)
    bdd0:  9fb9                 addw a5,a5,a4
    bdd2:  0007871b           sext.w a4,a5
    bdd6:  fd043783           ld a5,-48(s0)
    bdda:  cf98                 sw a4,24(a5)
    bddc:  fe442783           lw a5,-28(s0)
    bde0:  fcf42c23           sw a5,-40(s0)
    bde4:  a829                 j bdfe <FUN_0000bd68+0x96>
    bde6:  fe843783           ld a5,-24(s0)
    bdea:  00178713           addi a4,a5,1
    bdee:  fee43423           sd a4,-24(s0)
    bdf2:  fdc46703           lwu a4,-36(s0)
    bdf6:  0007c783           lbu a5,0(a5)
    bdfa:  00f70023           sb a5,0(a4) # 4100000 <gpio_get_boot_device+0x40f1c6a>
    bdfe:  fd842783           lw a5,-40(s0)
    be02:  fff7871b           addiw a4,a5,-1
    be06:  fce42c23           sw a4,-40(s0)
    be0a:  fff1                 bnez a5,bde6 <FUN_0000bd68+0x7e>
    be0c:  fe442783           lw a5,-28(s0)
    be10:  853e                 mv a0,a5
    be12:  7422                 ld s0,40(sp)
    be14:  6145                 addi sp,sp,48
    be16:  8082                 ret
000000000000be18 <FUN_0000be18>:
    be18:  715d                 addi sp,sp,-80
    be1a:  e486                 sd ra,72(sp)
    be1c:  e0a2                 sd s0,64(sp)
    be1e:  0880                 addi s0,sp,80
    be20:  fca43423           sd a0,-56(s0)
    be24:  fcb43023           sd a1,-64(s0)
    be28:  fac43c23           sd a2,-72(s0)
    be2c:  fe042423           sw zero,-24(s0)
    be30:  fdc40713           addi a4,s0,-36
    be34:  fe040793           addi a5,s0,-32
    be38:  863a                 mv a2,a4
    be3a:  85be                 mv a1,a5
    be3c:  fc043503           ld a0,-64(s0)
    be40:  c4bff0ef           jal ra,ba8a <FUN_0000ba8a>
    be44:  87aa                 mv a5,a0
    be46:  c399                 beqz a5,be4c <FUN_0000be18+0x34>
    be48:  57fd                 li a5,-1
    be4a:  a245                 j bfea <FUN_0000be18+0x1d2>
    be4c:  fc043783           ld a5,-64(s0)
    be50:  47dc                 lw a5,12(a5)
    be52:  fef42223           sw a5,-28(s0)
    be56:  fdc42783           lw a5,-36(s0)
    be5a:  fe442703           lw a4,-28(s0)
    be5e:  863a                 mv a2,a4
    be60:  fb843583           ld a1,-72(s0)
    be64:  853e                 mv a0,a5
    be66:  f03ff0ef           jal ra,bd68 <FUN_0000bd68>
    be6a:  87aa                 mv a5,a0
    be6c:  fef42223           sw a5,-28(s0)
    be70:  fc043783           ld a5,-64(s0)
    be74:  47d8                 lw a4,12(a5)
    be76:  fe442783           lw a5,-28(s0)
    be7a:  2781                 sext.w a5,a5
    be7c:  00e78663           beq a5,a4,be88 <FUN_0000be18+0x70>
    be80:  4785                 li a5,1
    be82:  fef42623           sw a5,-20(s0)
    be86:  a025                 j beae <FUN_0000be18+0x96>
    be88:  fb843783           ld a5,-72(s0)
    be8c:  4798                 lw a4,8(a5)
    be8e:  fb843783           ld a5,-72(s0)
    be92:  4f9c                 lw a5,24(a5)
    be94:  00f71b63           bne a4,a5,beaa <FUN_0000be18+0x92>
    be98:  fb843783           ld a5,-72(s0)
    be9c:  00c7c783           lbu a5,12(a5)
    bea0:  e789                 bnez a5,beaa <FUN_0000be18+0x92>
    bea2:  4789                 li a5,2
    bea4:  fef42623           sw a5,-20(s0)
    bea8:  a019                 j beae <FUN_0000be18+0x96>
    beaa:  fe042623           sw zero,-20(s0)
    beae:  fec42783           lw a5,-20(s0)
    beb2:  2781                 sext.w a5,a5
    beb4:  cbf1                 beqz a5,bf88 <FUN_0000be18+0x170>
    beb6:  fe042783           lw a5,-32(s0)
    beba:  e3d9                 bnez a5,bf40 <FUN_0000be18+0x128>
    bebc:  fc843503           ld a0,-56(s0)
    bec0:  d2bff0ef           jal ra,bbea <FUN_0000bbea>
    bec4:  87aa                 mv a5,a0
    bec6:  8b91                 andi a5,a5,4
    bec8:  2781                 sext.w a5,a5
    beca:  e3c5                 bnez a5,bf6a <FUN_0000be18+0x152>
    becc:  fec42783           lw a5,-20(s0)
    bed0:  0007871b           sext.w a4,a5
    bed4:  4785                 li a5,1
    bed6:  02f71c63           bne a4,a5,bf0e <FUN_0000be18+0xf6>
    beda:  fe042703           lw a4,-32(s0)
    bede:  041007b7           lui a5,0x4100
    bee2:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    bee6:  0ff77713           andi a4,a4,255
    beea:  00e78023           sb a4,0(a5)
    beee:  041007b7           lui a5,0x4100
    bef2:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    bef6:  4729                 li a4,10
    bef8:  00e79023           sh a4,0(a5)
    befc:  fc843783           ld a5,-56(s0)
    bf00:  67bc                 ld a5,72(a5)
    bf02:  0407a423           sw zero,72(a5)
    bf06:  4785                 li a5,1
    bf08:  fef42423           sw a5,-24(s0)
    bf0c:  a8b9                 j bf6a <FUN_0000be18+0x152>
    bf0e:  fec42783           lw a5,-20(s0)
    bf12:  0007871b           sext.w a4,a5
    bf16:  4789                 li a5,2
    bf18:  04f71963           bne a4,a5,bf6a <FUN_0000be18+0x152>
    bf1c:  fe042703           lw a4,-32(s0)
    bf20:  041007b7           lui a5,0x4100
    bf24:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    bf28:  0ff77713           andi a4,a4,255
    bf2c:  00e78023           sb a4,0(a5)
    bf30:  041007b7           lui a5,0x4100
    bf34:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    bf38:  4709                 li a4,2
    bf3a:  00e79023           sh a4,0(a5)
    bf3e:  a035                 j bf6a <FUN_0000be18+0x152>
    bf40:  fe042703           lw a4,-32(s0)
    bf44:  041007b7           lui a5,0x4100
    bf48:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    bf4c:  0ff77713           andi a4,a4,255
    bf50:  00e78023           sb a4,0(a5)
    bf54:  041007b7           lui a5,0x4100
    bf58:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    bf5c:  6709                 lui a4,0x2
    bf5e:  2705                 addiw a4,a4,1
    bf60:  00e79023           sh a4,0(a5)
    bf64:  4785                 li a5,1
    bf66:  fef42423           sw a5,-24(s0)
    bf6a:  fe842783           lw a5,-24(s0)
    bf6e:  0007871b           sext.w a4,a5
    bf72:  4785                 li a5,1
    bf74:  06f71963           bne a4,a5,bfe6 <FUN_0000be18+0x1ce>
    bf78:  4601                 li a2,0
    bf7a:  fb843583           ld a1,-72(s0)
    bf7e:  fc043503           ld a0,-64(s0)
    bf82:  da7ff0ef           jal ra,bd28 <FUN_0000bd28>
    bf86:  a085                 j bfe6 <FUN_0000be18+0x1ce>
    bf88:  fe042783           lw a5,-32(s0)
    bf8c:  eb9d                 bnez a5,bfc2 <FUN_0000be18+0x1aa>
    bf8e:  fc843503           ld a0,-56(s0)
    bf92:  c59ff0ef           jal ra,bbea <FUN_0000bbea>
    bf96:  87aa                 mv a5,a0
    bf98:  8b91                 andi a5,a5,4
    bf9a:  2781                 sext.w a5,a5
    bf9c:  e7a9                 bnez a5,bfe6 <FUN_0000be18+0x1ce>
    bf9e:  fe042703           lw a4,-32(s0)
    bfa2:  041007b7           lui a5,0x4100
    bfa6:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    bfaa:  0ff77713           andi a4,a4,255
    bfae:  00e78023           sb a4,0(a5)
    bfb2:  041007b7           lui a5,0x4100
    bfb6:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    bfba:  4709                 li a4,2
    bfbc:  00e79023           sh a4,0(a5)
    bfc0:  a01d                 j bfe6 <FUN_0000be18+0x1ce>
    bfc2:  fe042703           lw a4,-32(s0)
    bfc6:  041007b7           lui a5,0x4100
    bfca:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    bfce:  0ff77713           andi a4,a4,255
    bfd2:  00e78023           sb a4,0(a5)
    bfd6:  041007b7           lui a5,0x4100
    bfda:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    bfde:  6709                 lui a4,0x2
    bfe0:  2705                 addiw a4,a4,1
    bfe2:  00e79023           sh a4,0(a5)
    bfe6:  fe842783           lw a5,-24(s0)
    bfea:  853e                 mv a0,a5
    bfec:  60a6                 ld ra,72(sp)
    bfee:  6406                 ld s0,64(sp)
    bff0:  6161                 addi sp,sp,80
    bff2:  8082                 ret
000000000000bff4 <FUN_0000bff4>:
    bff4:  715d                 addi sp,sp,-80
    bff6:  e4a2                 sd s0,72(sp)
    bff8:  0880                 addi s0,sp,80
    bffa:  87aa                 mv a5,a0
    bffc:  fcb43023           sd a1,-64(s0)
    c000:  fac43c23           sd a2,-72(s0)
    c004:  8736                 mv a4,a3
    c006:  fcf42623           sw a5,-52(s0)
    c00a:  87ba                 mv a5,a4
    c00c:  fcf42423           sw a5,-56(s0)
    c010:  fe042623           sw zero,-20(s0)
    c014:  fb843783           ld a5,-72(s0)
    c018:  4798                 lw a4,8(a5)
    c01a:  fb843783           ld a5,-72(s0)
    c01e:  4f9c                 lw a5,24(a5)
    c020:  40f707bb           subw a5,a4,a5
    c024:  2781                 sext.w a5,a5
    c026:  863e                 mv a2,a5
    c028:  fc842783           lw a5,-56(s0)
    c02c:  0007869b           sext.w a3,a5
    c030:  0006071b           sext.w a4,a2
    c034:  00d77363           bgeu a4,a3,c03a <FUN_0000bff4+0x46>
    c038:  87b2                 mv a5,a2
    c03a:  fef42423           sw a5,-24(s0)
    c03e:  fb843783           ld a5,-72(s0)
    c042:  4f9c                 lw a5,24(a5)
    c044:  fe842703           lw a4,-24(s0)
    c048:  9fb9                 addw a5,a5,a4
    c04a:  0007871b           sext.w a4,a5
    c04e:  fb843783           ld a5,-72(s0)
    c052:  cf98                 sw a4,24(a5)
    c054:  fe842783           lw a5,-24(s0)
    c058:  fcf42423           sw a5,-56(s0)
    c05c:  fc842783           lw a5,-56(s0)
    c060:  0007871b           sext.w a4,a5
    c064:  4791                 li a5,4
    c066:  04e7f663           bgeu a5,a4,c0b2 <FUN_0000bff4+0xbe>
    c06a:  a825                 j c0a2 <FUN_0000bff4+0xae>
    c06c:  fcc42783           lw a5,-52(s0)
    c070:  0007c783           lbu a5,0(a5)
    c074:  0ff7f713           andi a4,a5,255
    c078:  fc043783           ld a5,-64(s0)
    c07c:  00e78023           sb a4,0(a5)
    c080:  fec42783           lw a5,-20(s0)
    c084:  0007871b           sext.w a4,a5
    c088:  479d                 li a5,7
    c08a:  00e7e763           bltu a5,a4,c098 <FUN_0000bff4+0xa4>
    c08e:  fec42783           lw a5,-20(s0)
    c092:  2785                 addiw a5,a5,1
    c094:  fef42623           sw a5,-20(s0)
    c098:  fc043783           ld a5,-64(s0)
    c09c:  0785                 addi a5,a5,1
    c09e:  fcf43023           sd a5,-64(s0)
    c0a2:  fc842783           lw a5,-56(s0)
    c0a6:  fff7871b           addiw a4,a5,-1
    c0aa:  fce42423           sw a4,-56(s0)
    c0ae:  ffdd                 bnez a5,c06c <FUN_0000bff4+0x78>
    c0b0:  a051                 j c134 <FUN_0000bff4+0x140>
    c0b2:  fc043783           ld a5,-64(s0)
    c0b6:  fef43023           sd a5,-32(s0)
    c0ba:  fc043783           ld a5,-64(s0)
    c0be:  fcf43c23           sd a5,-40(s0)
    c0c2:  fc842783           lw a5,-56(s0)
    c0c6:  0007871b           sext.w a4,a5
    c0ca:  4791                 li a5,4
    c0cc:  00f71b63           bne a4,a5,c0e2 <FUN_0000bff4+0xee>
    c0d0:  fcc42783           lw a5,-52(s0)
    c0d4:  439c                 lw a5,0(a5)
    c0d6:  0007871b           sext.w a4,a5
    c0da:  fe043783           ld a5,-32(s0)
    c0de:  c398                 sw a4,0(a5)
    c0e0:  a891                 j c134 <FUN_0000bff4+0x140>
    c0e2:  fc842783           lw a5,-56(s0)
    c0e6:  0007871b           sext.w a4,a5
    c0ea:  4789                 li a5,2
    c0ec:  02f71d63           bne a4,a5,c126 <FUN_0000bff4+0x132>
    c0f0:  fcc42783           lw a5,-52(s0)
    c0f4:  0007d783           lhu a5,0(a5)
    c0f8:  03079713           slli a4,a5,0x30
    c0fc:  9341                 srli a4,a4,0x30
    c0fe:  fd843783           ld a5,-40(s0)
    c102:  00e79023           sh a4,0(a5)
    c106:  a03d                 j c134 <FUN_0000bff4+0x140>
    c108:  fcc42783           lw a5,-52(s0)
    c10c:  0007c783           lbu a5,0(a5)
    c110:  0ff7f713           andi a4,a5,255
    c114:  fc043783           ld a5,-64(s0)
    c118:  00e78023           sb a4,0(a5)
    c11c:  fc043783           ld a5,-64(s0)
    c120:  0785                 addi a5,a5,1
    c122:  fcf43023           sd a5,-64(s0)
    c126:  fc842783           lw a5,-56(s0)
    c12a:  fff7871b           addiw a4,a5,-1
    c12e:  fce42423           sw a4,-56(s0)
    c132:  fbf9                 bnez a5,c108 <FUN_0000bff4+0x114>
    c134:  fe842783           lw a5,-24(s0)
    c138:  853e                 mv a0,a5
    c13a:  6426                 ld s0,72(sp)
    c13c:  6161                 addi sp,sp,80
    c13e:  8082                 ret
000000000000c140 <FUN_0000c140>:
    c140:  711d                 addi sp,sp,-96
    c142:  ec86                 sd ra,88(sp)
    c144:  e8a2                 sd s0,80(sp)
    c146:  1080                 addi s0,sp,96
    c148:  faa43c23           sd a0,-72(s0)
    c14c:  fab43823           sd a1,-80(s0)
    c150:  fac43423           sd a2,-88(s0)
    c154:  4785                 li a5,1
    c156:  fef42623           sw a5,-20(s0)
    c15a:  fe042223           sw zero,-28(s0)
    c15e:  fc840713           addi a4,s0,-56
    c162:  fcc40793           addi a5,s0,-52
    c166:  863a                 mv a2,a4
    c168:  85be                 mv a1,a5
    c16a:  fb043503           ld a0,-80(s0)
    c16e:  91dff0ef           jal ra,ba8a <FUN_0000ba8a>
    c172:  87aa                 mv a5,a0
    c174:  c399                 beqz a5,c17a <FUN_0000c140+0x3a>
    c176:  57fd                 li a5,-1
    c178:  a405                 j c398 <FUN_0000c140+0x258>
    c17a:  fa843783           ld a5,-88(s0)
    c17e:  639c                 ld a5,0(a5)
    c180:  873e                 mv a4,a5
    c182:  fa843783           ld a5,-88(s0)
    c186:  4f9c                 lw a5,24(a5)
    c188:  1782                 slli a5,a5,0x20
    c18a:  9381                 srli a5,a5,0x20
    c18c:  97ba                 add a5,a5,a4
    c18e:  fcf43c23           sd a5,-40(s0)
    c192:  fa843783           ld a5,-88(s0)
    c196:  4798                 lw a4,8(a5)
    c198:  fa843783           ld a5,-88(s0)
    c19c:  4f9c                 lw a5,24(a5)
    c19e:  40f707bb           subw a5,a4,a5
    c1a2:  fcf42a23           sw a5,-44(s0)
    c1a6:  fd442783           lw a5,-44(s0)
    c1aa:  2781                 sext.w a5,a5
    c1ac:  e399                 bnez a5,c1b2 <FUN_0000c140+0x72>
    c1ae:  57fd                 li a5,-1
    c1b0:  a2e5                 j c398 <FUN_0000c140+0x258>
    c1b2:  fcc42703           lw a4,-52(s0)
    c1b6:  041007b7           lui a5,0x4100
    c1ba:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c1be:  0ff77713           andi a4,a4,255
    c1c2:  00e78023           sb a4,0(a5)
    c1c6:  041007b7           lui a5,0x4100
    c1ca:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c1ce:  439c                 lw a5,0(a5)
    c1d0:  fef42223           sw a5,-28(s0)
    c1d4:  fb043783           ld a5,-80(s0)
    c1d8:  47d8                 lw a4,12(a5)
    c1da:  fe442783           lw a5,-28(s0)
    c1de:  2781                 sext.w a5,a5
    c1e0:  00f77863           bgeu a4,a5,c1f0 <FUN_0000c140+0xb0>
    c1e4:  fb043783           ld a5,-80(s0)
    c1e8:  47dc                 lw a5,12(a5)
    c1ea:  fef42423           sw a5,-24(s0)
    c1ee:  a029                 j c1f8 <FUN_0000c140+0xb8>
    c1f0:  fe442783           lw a5,-28(s0)
    c1f4:  fef42423           sw a5,-24(s0)
    c1f8:  fc842783           lw a5,-56(s0)
    c1fc:  2781                 sext.w a5,a5
    c1fe:  fe842703           lw a4,-24(s0)
    c202:  86ba                 mv a3,a4
    c204:  fa843603           ld a2,-88(s0)
    c208:  fd843583           ld a1,-40(s0)
    c20c:  853e                 mv a0,a5
    c20e:  de7ff0ef           jal ra,bff4 <FUN_0000bff4>
    c212:  87aa                 mv a5,a0
    c214:  fef42223           sw a5,-28(s0)
    c218:  fb043783           ld a5,-80(s0)
    c21c:  47d8                 lw a4,12(a5)
    c21e:  fe442783           lw a5,-28(s0)
    c222:  2781                 sext.w a5,a5
    c224:  02e7f363           bgeu a5,a4,c24a <FUN_0000c140+0x10a>
    c228:  4785                 li a5,1
    c22a:  fef42623           sw a5,-20(s0)
    c22e:  fe442703           lw a4,-28(s0)
    c232:  fe842783           lw a5,-24(s0)
    c236:  2701                 sext.w a4,a4
    c238:  2781                 sext.w a5,a5
    c23a:  02f70663           beq a4,a5,c266 <FUN_0000c140+0x126>
    c23e:  fa843783           ld a5,-88(s0)
    c242:  577d                 li a4,-1
    c244:  02e78023           sb a4,32(a5)
    c248:  a839                 j c266 <FUN_0000c140+0x126>
    c24a:  fa843783           ld a5,-88(s0)
    c24e:  4798                 lw a4,8(a5)
    c250:  fa843783           ld a5,-88(s0)
    c254:  4f9c                 lw a5,24(a5)
    c256:  00f71663           bne a4,a5,c262 <FUN_0000c140+0x122>
    c25a:  4785                 li a5,1
    c25c:  fef42623           sw a5,-20(s0)
    c260:  a019                 j c266 <FUN_0000c140+0x126>
    c262:  fe042623           sw zero,-20(s0)
    c266:  fcc42703           lw a4,-52(s0)
    c26a:  041007b7           lui a5,0x4100
    c26e:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c272:  0ff77713           andi a4,a4,255
    c276:  00e78023           sb a4,0(a5)
    c27a:  041007b7           lui a5,0x4100
    c27e:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c282:  439c                 lw a5,0(a5)
    c284:  fef42223           sw a5,-28(s0)
    c288:  fec42783           lw a5,-20(s0)
    c28c:  2781                 sext.w a5,a5
    c28e:  cbd1                 beqz a5,c322 <FUN_0000c140+0x1e2>
    c290:  fcc42783           lw a5,-52(s0)
    c294:  eb8d                 bnez a5,c2c6 <FUN_0000c140+0x186>
    c296:  fcc42703           lw a4,-52(s0)
    c29a:  041007b7           lui a5,0x4100
    c29e:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c2a2:  0ff77713           andi a4,a4,255
    c2a6:  00e78023           sb a4,0(a5)
    c2aa:  041007b7           lui a5,0x4100
    c2ae:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c2b2:  04800713           li a4,72
    c2b6:  00e79023           sh a4,0(a5)
    c2ba:  fb843783           ld a5,-72(s0)
    c2be:  67bc                 ld a5,72(a5)
    c2c0:  0407a423           sw zero,72(a5)
    c2c4:  a0a1                 j c30c <FUN_0000c140+0x1cc>
    c2c6:  fcc42703           lw a4,-52(s0)
    c2ca:  041007b7           lui a5,0x4100
    c2ce:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c2d2:  0ff77713           andi a4,a4,255
    c2d6:  00e78023           sb a4,0(a5)
    c2da:  041007b7           lui a5,0x4100
    c2de:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c2e2:  0007d783           lhu a5,0(a5)
    c2e6:  17c2                 slli a5,a5,0x30
    c2e8:  93c1                 srli a5,a5,0x30
    c2ea:  fcf42823           sw a5,-48(s0)
    c2ee:  fd042783           lw a5,-48(s0)
    c2f2:  9bf9                 andi a5,a5,-2
    c2f4:  fcf42823           sw a5,-48(s0)
    c2f8:  041007b7           lui a5,0x4100
    c2fc:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c300:  fd042703           lw a4,-48(s0)
    c304:  1742                 slli a4,a4,0x30
    c306:  9341                 srli a4,a4,0x30
    c308:  00e79023           sh a4,0(a5)
    c30c:  4601                 li a2,0
    c30e:  fa843583           ld a1,-88(s0)
    c312:  fb043503           ld a0,-80(s0)
    c316:  a13ff0ef           jal ra,bd28 <FUN_0000bd28>
    c31a:  4785                 li a5,1
    c31c:  fef42623           sw a5,-20(s0)
    c320:  a895                 j c394 <FUN_0000c140+0x254>
    c322:  fcc42783           lw a5,-52(s0)
    c326:  e785                 bnez a5,c34e <FUN_0000c140+0x20e>
    c328:  fcc42703           lw a4,-52(s0)
    c32c:  041007b7           lui a5,0x4100
    c330:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c334:  0ff77713           andi a4,a4,255
    c338:  00e78023           sb a4,0(a5)
    c33c:  041007b7           lui a5,0x4100
    c340:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c344:  04000713           li a4,64
    c348:  00e79023           sh a4,0(a5)
    c34c:  a0a1                 j c394 <FUN_0000c140+0x254>
    c34e:  fcc42703           lw a4,-52(s0)
    c352:  041007b7           lui a5,0x4100
    c356:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c35a:  0ff77713           andi a4,a4,255
    c35e:  00e78023           sb a4,0(a5)
    c362:  041007b7           lui a5,0x4100
    c366:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c36a:  0007d783           lhu a5,0(a5)
    c36e:  17c2                 slli a5,a5,0x30
    c370:  93c1                 srli a5,a5,0x30
    c372:  fcf42823           sw a5,-48(s0)
    c376:  fd042783           lw a5,-48(s0)
    c37a:  9bf9                 andi a5,a5,-2
    c37c:  fcf42823           sw a5,-48(s0)
    c380:  041007b7           lui a5,0x4100
    c384:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c388:  fd042703           lw a4,-48(s0)
    c38c:  1742                 slli a4,a4,0x30
    c38e:  9341                 srli a4,a4,0x30
    c390:  00e79023           sh a4,0(a5)
    c394:  fec42783           lw a5,-20(s0)
    c398:  853e                 mv a0,a5
    c39a:  60e6                 ld ra,88(sp)
    c39c:  6446                 ld s0,80(sp)
    c39e:  6125                 addi sp,sp,96
    c3a0:  8082                 ret
000000000000c3a2 <FUN_0000c3a2>:
    c3a2:  715d                 addi sp,sp,-80
    c3a4:  e486                 sd ra,72(sp)
    c3a6:  e0a2                 sd s0,64(sp)
    c3a8:  0880                 addi s0,sp,80
    c3aa:  fca43423           sd a0,-56(s0)
    c3ae:  fcb43023           sd a1,-64(s0)
    c3b2:  87b2                 mv a5,a2
    c3b4:  faf40fa3           sb a5,-65(s0)
    c3b8:  fe043023           sd zero,-32(s0)
    c3bc:  fe042623           sw zero,-20(s0)
    c3c0:  fc042e23           sw zero,-36(s0)
    c3c4:  fc043783           ld a5,-64(s0)
    c3c8:  4fdc                 lw a5,28(a5)
    c3ca:  9bf1                 andi a5,a5,-4
    c3cc:  2781                 sext.w a5,a5
    c3ce:  c399                 beqz a5,c3d4 <FUN_0000c3a2+0x32>
    c3d0:  57fd                 li a5,-1
    c3d2:  ac05                 j c602 <FUN_0000c3a2+0x260>
    c3d4:  fbf44783           lbu a5,-65(s0)
    c3d8:  0ff7f793           andi a5,a5,255
    c3dc:  e789                 bnez a5,c3e6 <FUN_0000c3a2+0x44>
    c3de:  fc843503           ld a0,-56(s0)
    c3e2:  c9bfe0ef           jal ra,b07c <disable_interrupts>
    c3e6:  fc843783           ld a5,-56(s0)
    c3ea:  67b4                 ld a3,72(a5)
    c3ec:  fc043783           ld a5,-64(s0)
    c3f0:  4fdc                 lw a5,28(a5)
    c3f2:  02079713           slli a4,a5,0x20
    c3f6:  9301                 srli a4,a4,0x20
    c3f8:  87ba                 mv a5,a4
    c3fa:  0786                 slli a5,a5,0x1
    c3fc:  97ba                 add a5,a5,a4
    c3fe:  078e                 slli a5,a5,0x3
    c400:  97b6                 add a5,a5,a3
    c402:  fef43023           sd a5,-32(s0)
    c406:  fc043783           ld a5,-64(s0)
    c40a:  0007ac23           sw zero,24(a5)
    c40e:  fe043783           ld a5,-32(s0)
    c412:  0097c783           lbu a5,9(a5)
    c416:  c3b5                 beqz a5,c47a <FUN_0000c3a2+0xd8>
    c418:  fe043783           ld a5,-32(s0)
    c41c:  0097c703           lbu a4,9(a5)
    c420:  041007b7           lui a5,0x4100
    c424:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c428:  07f77713           andi a4,a4,127
    c42c:  0ff77713           andi a4,a4,255
    c430:  00e78023           sb a4,0(a5)
    c434:  fe043783           ld a5,-32(s0)
    c438:  0097c783           lbu a5,9(a5)
    c43c:  0187979b           slliw a5,a5,0x18
    c440:  4187d79b           sraiw a5,a5,0x18
    c444:  0007d763           bgez a5,c452 <FUN_0000c3a2+0xb0>
    c448:  041007b7           lui a5,0x4100
    c44c:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c450:  a029                 j c45a <FUN_0000c3a2+0xb8>
    c452:  041007b7           lui a5,0x4100
    c456:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c45a:  0007d783           lhu a5,0(a5)
    c45e:  17c2                 slli a5,a5,0x30
    c460:  93c1                 srli a5,a5,0x30
    c462:  fef42623           sw a5,-20(s0)
    c466:  041007b7           lui a5,0x4100
    c46a:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c46e:  0007d783           lhu a5,0(a5)
    c472:  17c2                 slli a5,a5,0x30
    c474:  93c1                 srli a5,a5,0x30
    c476:  fcf42e23           sw a5,-36(s0)
    c47a:  fe043783           ld a5,-32(s0)
    c47e:  0097c783           lbu a5,9(a5)
    c482:  efa1                 bnez a5,c4da <FUN_0000c3a2+0x138>
    c484:  fc843783           ld a5,-56(s0)
    c488:  67bc                 ld a5,72(a5)
    c48a:  47b8                 lw a4,72(a5)
    c48c:  86ba                 mv a3,a4
    c48e:  4785                 li a5,1
    c490:  00f68663           beq a3,a5,c49c <FUN_0000c3a2+0xfa>
    c494:  4789                 li a5,2
    c496:  02f70163           beq a4,a5,c4b8 <FUN_0000c3a2+0x116>
    c49a:  a02d                 j c4c4 <FUN_0000c3a2+0x122>
    c49c:  fc043603           ld a2,-64(s0)
    c4a0:  fe043583           ld a1,-32(s0)
    c4a4:  fc843503           ld a0,-56(s0)
    c4a8:  971ff0ef           jal ra,be18 <FUN_0000be18>
    c4ac:  87aa                 mv a5,a0
    c4ae:  12078f63           beqz a5,c5ec <FUN_0000c3a2+0x24a>
    c4b2:  fc043023           sd zero,-64(s0)
    c4b6:  aa1d                 j c5ec <FUN_0000c3a2+0x24a>
    c4b8:  fc843783           ld a5,-56(s0)
    c4bc:  67bc                 ld a5,72(a5)
    c4be:  0407a423           sw zero,72(a5)
    c4c2:  a235                 j c5ee <FUN_0000c3a2+0x24c>
    c4c4:  fbf44783           lbu a5,-65(s0)
    c4c8:  0ff7f793           andi a5,a5,255
    c4cc:  e789                 bnez a5,c4d6 <FUN_0000c3a2+0x134>
    c4ce:  fc843503           ld a0,-56(s0)
    c4d2:  bc9fe0ef           jal ra,b09a <enable_interrupts>
    c4d6:  57fd                 li a5,-1
    c4d8:  a22d                 j c602 <FUN_0000c3a2+0x260>
    c4da:  fe043783           ld a5,-32(s0)
    c4de:  0097c783           lbu a5,9(a5)
    c4e2:  0187979b           slliw a5,a5,0x18
    c4e6:  4187d79b           sraiw a5,a5,0x18
    c4ea:  0207d463           bgez a5,c512 <FUN_0000c3a2+0x170>
    c4ee:  fec42783           lw a5,-20(s0)
    c4f2:  8b85                 andi a5,a5,1
    c4f4:  2781                 sext.w a5,a5
    c4f6:  ef91                 bnez a5,c512 <FUN_0000c3a2+0x170>
    c4f8:  fc043603           ld a2,-64(s0)
    c4fc:  fe043583           ld a1,-32(s0)
    c500:  fc843503           ld a0,-56(s0)
    c504:  915ff0ef           jal ra,be18 <FUN_0000be18>
    c508:  87aa                 mv a5,a0
    c50a:  c781                 beqz a5,c512 <FUN_0000c3a2+0x170>
    c50c:  fc043023           sd zero,-64(s0)
    c510:  a8f9                 j c5ee <FUN_0000c3a2+0x24c>
    c512:  fe043783           ld a5,-32(s0)
    c516:  0097c783           lbu a5,9(a5)
    c51a:  0187979b           slliw a5,a5,0x18
    c51e:  4187d79b           sraiw a5,a5,0x18
    c522:  0c07c663           bltz a5,c5ee <FUN_0000c3a2+0x24c>
    c526:  fec42783           lw a5,-20(s0)
    c52a:  8b85                 andi a5,a5,1
    c52c:  2781                 sext.w a5,a5
    c52e:  c3e1                 beqz a5,c5ee <FUN_0000c3a2+0x24c>
    c530:  041007b7           lui a5,0x4100
    c534:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c538:  0007d783           lhu a5,0(a5)
    c53c:  17c2                 slli a5,a5,0x30
    c53e:  93c1                 srli a5,a5,0x30
    c540:  fcf42e23           sw a5,-36(s0)
    c544:  fdc42783           lw a5,-36(s0)
    c548:  2781                 sext.w a5,a5
    c54a:  c3d5                 beqz a5,c5ee <FUN_0000c3a2+0x24c>
    c54c:  fc043603           ld a2,-64(s0)
    c550:  fe043583           ld a1,-32(s0)
    c554:  fc843503           ld a0,-56(s0)
    c558:  be9ff0ef           jal ra,c140 <FUN_0000c140>
    c55c:  fe043783           ld a5,-32(s0)
    c560:  0097c703           lbu a4,9(a5)
    c564:  041007b7           lui a5,0x4100
    c568:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    c56c:  07f77713           andi a4,a4,127
    c570:  0ff77713           andi a4,a4,255
    c574:  00e78023           sb a4,0(a5)
    c578:  fe043783           ld a5,-32(s0)
    c57c:  0097c783           lbu a5,9(a5)
    c580:  0187979b           slliw a5,a5,0x18
    c584:  4187d79b           sraiw a5,a5,0x18
    c588:  0007d763           bgez a5,c596 <FUN_0000c3a2+0x1f4>
    c58c:  041007b7           lui a5,0x4100
    c590:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c594:  a029                 j c59e <FUN_0000c3a2+0x1fc>
    c596:  041007b7           lui a5,0x4100
    c59a:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c59e:  0007d783           lhu a5,0(a5)
    c5a2:  17c2                 slli a5,a5,0x30
    c5a4:  93c1                 srli a5,a5,0x30
    c5a6:  fef42623           sw a5,-20(s0)
    c5aa:  041007b7           lui a5,0x4100
    c5ae:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c5b2:  0007d783           lhu a5,0(a5)
    c5b6:  17c2                 slli a5,a5,0x30
    c5b8:  93c1                 srli a5,a5,0x30
    c5ba:  fcf42e23           sw a5,-36(s0)
    c5be:  fc043783           ld a5,-64(s0)
    c5c2:  0207c783           lbu a5,32(a5)
    c5c6:  0187979b           slliw a5,a5,0x18
    c5ca:  4187d79b           sraiw a5,a5,0x18
    c5ce:  cb99                 beqz a5,c5e4 <FUN_0000c3a2+0x242>
    c5d0:  fec42783           lw a5,-20(s0)
    c5d4:  8b85                 andi a5,a5,1
    c5d6:  2781                 sext.w a5,a5
    c5d8:  c799                 beqz a5,c5e6 <FUN_0000c3a2+0x244>
    c5da:  fdc42783           lw a5,-36(s0)
    c5de:  2781                 sext.w a5,a5
    c5e0:  f7b5                 bnez a5,c54c <FUN_0000c3a2+0x1aa>
    c5e2:  a011                 j c5e6 <FUN_0000c3a2+0x244>
    c5e4:  0001                 nop
    c5e6:  fc043023           sd zero,-64(s0)
    c5ea:  a011                 j c5ee <FUN_0000c3a2+0x24c>
    c5ec:  0001                 nop
    c5ee:  fbf44783           lbu a5,-65(s0)
    c5f2:  0ff7f793           andi a5,a5,255
    c5f6:  e789                 bnez a5,c600 <FUN_0000c3a2+0x25e>
    c5f8:  fc843503           ld a0,-56(s0)
    c5fc:  a9ffe0ef           jal ra,b09a <enable_interrupts>
    c600:  4781                 li a5,0
    c602:  853e                 mv a0,a5
    c604:  60a6                 ld ra,72(sp)
    c606:  6406                 ld s0,64(sp)
    c608:  6161                 addi sp,sp,80
    c60a:  8082                 ret
000000000000c60c <FUN_0000c60c>:
    c60c:  7179                 addi sp,sp,-48
    c60e:  f406                 sd ra,40(sp)
    c610:  f022                 sd s0,32(sp)
    c612:  1800                 addi s0,sp,48
    c614:  fea43423           sd a0,-24(s0)
    c618:  feb43023           sd a1,-32(s0)
    c61c:  87b2                 mv a5,a2
    c61e:  fcf40fa3           sb a5,-33(s0)
    c622:  fdf44783           lbu a5,-33(s0)
    c626:  863e                 mv a2,a5
    c628:  fe043583           ld a1,-32(s0)
    c62c:  fe843503           ld a0,-24(s0)
    c630:  d73ff0ef           jal ra,c3a2 <FUN_0000c3a2>
    c634:  87aa                 mv a5,a0
    c636:  853e                 mv a0,a5
    c638:  70a2                 ld ra,40(sp)
    c63a:  7402                 ld s0,32(sp)
    c63c:  6145                 addi sp,sp,48
    c63e:  8082                 ret
000000000000c640 <FUN_0000c640>:
    c640:  1101                 addi sp,sp,-32
    c642:  ec22                 sd s0,24(sp)
    c644:  1000                 addi s0,sp,32
    c646:  fea43423           sd a0,-24(s0)
    c64a:  fe843783           ld a5,-24(s0)
    c64e:  0007a423           sw zero,8(a5)
    c652:  fe843783           ld a5,-24(s0)
    c656:  0007a223           sw zero,4(a5)
    c65a:  fe843783           ld a5,-24(s0)
    c65e:  0007a023           sw zero,0(a5)
    c662:  0001                 nop
    c664:  6462                 ld s0,24(sp)
    c666:  6105                 addi sp,sp,32
    c668:  8082                 ret
000000000000c66a <FUN_0000c66a>:
    c66a:  7179                 addi sp,sp,-48
    c66c:  f406                 sd ra,40(sp)
    c66e:  f022                 sd s0,32(sp)
    c670:  1800                 addi s0,sp,48
    c672:  fca43c23           sd a0,-40(s0)
    c676:  fe042623           sw zero,-20(s0)
    c67a:  fd843783           ld a5,-40(s0)
    c67e:  0087c783           lbu a5,8(a5)
    c682:  853e                 mv a0,a5
    c684:  a49fe0ef           jal ra,b0cc <FUN_0000b0cc>
    c688:  fd843783           ld a5,-40(s0)
    c68c:  0097c783           lbu a5,9(a5)
    c690:  0187979b           slliw a5,a5,0x18
    c694:  4187d79b           sraiw a5,a5,0x18
    c698:  0607d863           bgez a5,c708 <FUN_0000c66a+0x9e>
    c69c:  041007b7           lui a5,0x4100
    c6a0:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c6a4:  04800713           li a4,72
    c6a8:  00e79023           sh a4,0(a5)
    c6ac:  fd843783           ld a5,-40(s0)
    c6b0:  47d8                 lw a4,12(a5)
    c6b2:  041007b7           lui a5,0x4100
    c6b6:  08078793           addi a5,a5,128 # 4100080 <gpio_get_boot_device+0x40f1cea
    c6ba:  7ff77713           andi a4,a4,2047
    c6be:  2701                 sext.w a4,a4
    c6c0:  c398                 sw a4,0(a5)
    c6c2:  041007b7           lui a5,0x4100
    c6c6:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    c6ca:  0007c783           lbu a5,0(a5)
    c6ce:  0ff7f793           andi a5,a5,255
    c6d2:  fef42623           sw a5,-20(s0)
    c6d6:  fec42783           lw a5,-20(s0)
    c6da:  0ff7f693           andi a3,a5,255
    c6de:  fd843783           ld a5,-40(s0)
    c6e2:  0087c783           lbu a5,8(a5)
    c6e6:  2781                 sext.w a5,a5
    c6e8:  4705                 li a4,1
    c6ea:  00f717bb           sllw a5,a4,a5
    c6ee:  2781                 sext.w a5,a5
    c6f0:  0ff7f713           andi a4,a5,255
    c6f4:  041007b7           lui a5,0x4100
    c6f8:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    c6fc:  8f55                 or a4,a4,a3
    c6fe:  0ff77713           andi a4,a4,255
    c702:  00e78023           sb a4,0(a5)
    c706:  a89d                 j c77c <FUN_0000c66a+0x112>
    c708:  041007b7           lui a5,0x4100
    c70c:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    c710:  09000713           li a4,144
    c714:  00e79023           sh a4,0(a5)
    c718:  fd843783           ld a5,-40(s0)
    c71c:  47dc                 lw a5,12(a5)
    c71e:  03079713           slli a4,a5,0x30
    c722:  9341                 srli a4,a4,0x30
    c724:  041007b7           lui a5,0x4100
    c728:  08478793           addi a5,a5,132 # 4100084 <gpio_get_boot_device+0x40f1cee
    c72c:  7ff77713           andi a4,a4,2047
    c730:  1742                 slli a4,a4,0x30
    c732:  9341                 srli a4,a4,0x30
    c734:  00e79023           sh a4,0(a5)
    c738:  041007b7           lui a5,0x4100
    c73c:  04a78793           addi a5,a5,74 # 410004a <gpio_get_boot_device+0x40f1cb4>
    c740:  0007c783           lbu a5,0(a5)
    c744:  0ff7f793           andi a5,a5,255
    c748:  fef42623           sw a5,-20(s0)
    c74c:  fec42783           lw a5,-20(s0)
    c750:  0ff7f693           andi a3,a5,255
    c754:  fd843783           ld a5,-40(s0)
    c758:  0087c783           lbu a5,8(a5)
    c75c:  2781                 sext.w a5,a5
    c75e:  4705                 li a4,1
    c760:  00f717bb           sllw a5,a4,a5
    c764:  2781                 sext.w a5,a5
    c766:  0ff7f713           andi a4,a5,255
    c76a:  041007b7           lui a5,0x4100
    c76e:  04a78793           addi a5,a5,74 # 410004a <gpio_get_boot_device+0x40f1cb4>
    c772:  8f55                 or a4,a4,a3
    c774:  0ff77713           andi a4,a4,255
    c778:  00e78023           sb a4,0(a5)
    c77c:  0001                 nop
    c77e:  70a2                 ld ra,40(sp)
    c780:  7402                 ld s0,32(sp)
    c782:  6145                 addi sp,sp,48
    c784:  8082                 ret
000000000000c786 <FUN_0000c786>:
    c786:  1101                 addi sp,sp,-32
    c788:  ec06                 sd ra,24(sp)
    c78a:  e822                 sd s0,16(sp)
    c78c:  1000                 addi s0,sp,32
    c78e:  fea43423           sd a0,-24(s0)
    c792:  fe843783           ld a5,-24(s0)
    c796:  67bc                 ld a5,72(a5)
    c798:  03078793           addi a5,a5,48
    c79c:  853e                 mv a0,a5
    c79e:  ecdff0ef           jal ra,c66a <FUN_0000c66a>
    c7a2:  fe843783           ld a5,-24(s0)
    c7a6:  67bc                 ld a5,72(a5)
    c7a8:  07e1                 addi a5,a5,24
    c7aa:  853e                 mv a0,a5
    c7ac:  ebfff0ef           jal ra,c66a <FUN_0000c66a>
    c7b0:  0001                 nop
    c7b2:  60e2                 ld ra,24(sp)
    c7b4:  6442                 ld s0,16(sp)
    c7b6:  6105                 addi sp,sp,32
    c7b8:  8082                 ret
000000000000c7ba <FUN_0000c7ba>:
    c7ba:  7139                 addi sp,sp,-64
    c7bc:  fc06                 sd ra,56(sp)
    c7be:  f822                 sd s0,48(sp)
    c7c0:  0080                 addi s0,sp,64
    c7c2:  fca43423           sd a0,-56(s0)
    c7c6:  fe042623           sw zero,-20(s0)
    c7ca:  fe042423           sw zero,-24(s0)
    c7ce:  fc843783           ld a5,-56(s0)
    c7d2:  fcf43c23           sd a5,-40(s0)
    c7d6:  4501                 li a0,0
    c7d8:  8f5fe0ef           jal ra,b0cc <FUN_0000b0cc>
    c7dc:  041007b7           lui a5,0x4100
    c7e0:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c7e4:  0007d783           lhu a5,0(a5)
    c7e8:  17c2                 slli a5,a5,0x30
    c7ea:  93c1                 srli a5,a5,0x30
    c7ec:  fef42423           sw a5,-24(s0)
    c7f0:  fe842783           lw a5,-24(s0)
    c7f4:  0007871b           sext.w a4,a5
    c7f8:  47a1                 li a5,8
    c7fa:  06f70763           beq a4,a5,c868 <FUN_0000c7ba+0xae>
    c7fe:  fe042223           sw zero,-28(s0)
    c802:  a005                 j c822 <FUN_0000c7ba+0x68>
    c804:  041007b7           lui a5,0x4100
    c808:  08878793           addi a5,a5,136 # 4100088 <gpio_get_boot_device+0x40f1cf2
    c80c:  0007d783           lhu a5,0(a5)
    c810:  17c2                 slli a5,a5,0x30
    c812:  93c1                 srli a5,a5,0x30
    c814:  fef42423           sw a5,-24(s0)
    c818:  fe442783           lw a5,-28(s0)
    c81c:  2785                 addiw a5,a5,1
    c81e:  fef42223           sw a5,-28(s0)
    c822:  fe442783           lw a5,-28(s0)
    c826:  0007871b           sext.w a4,a5
    c82a:  47bd                 li a5,15
    c82c:  02e7ce63           blt a5,a4,c868 <FUN_0000c7ba+0xae>
    c830:  fe842783           lw a5,-24(s0)
    c834:  0007871b           sext.w a4,a5
    c838:  47a1                 li a5,8
    c83a:  fcf715e3           bne a4,a5,c804 <FUN_0000c7ba+0x4a>
    c83e:  a02d                 j c868 <FUN_0000c7ba+0xae>
    c840:  041007b7           lui a5,0x4100
    c844:  0007c783           lbu a5,0(a5) # 4100000 <gpio_get_boot_device+0x40f1c6a>
    c848:  0ff7f713           andi a4,a5,255
    c84c:  fd843783           ld a5,-40(s0)
    c850:  00e78023           sb a4,0(a5)
    c854:  fd843783           ld a5,-40(s0)
    c858:  0785                 addi a5,a5,1
    c85a:  fcf43c23           sd a5,-40(s0)
    c85e:  fec42783           lw a5,-20(s0)
    c862:  2785                 addiw a5,a5,1
    c864:  fef42623           sw a5,-20(s0)
    c868:  fe842783           lw a5,-24(s0)
    c86c:  fff7871b           addiw a4,a5,-1
    c870:  fee42423           sw a4,-24(s0)
    c874:  f7f1                 bnez a5,c840 <FUN_0000c7ba+0x86>
    c876:  fec42783           lw a5,-20(s0)
    c87a:  853e                 mv a0,a5
    c87c:  70e2                 ld ra,56(sp)
    c87e:  7442                 ld s0,48(sp)
    c880:  6121                 addi sp,sp,64
    c882:  8082                 ret
000000000000c884 <FUN_0000c884>:
    c884:  715d                 addi sp,sp,-80
    c886:  e486                 sd ra,72(sp)
    c888:  e0a2                 sd s0,64(sp)
    c88a:  0880                 addi s0,sp,80
    c88c:  faa43c23           sd a0,-72(s0)
    c890:  fe043423           sd zero,-24(s0)
    c894:  fe043023           sd zero,-32(s0)
    c898:  fc042e23           sw zero,-36(s0)
    c89c:  fb843783           ld a5,-72(s0)
    c8a0:  67bc                 ld a5,72(a5)
    c8a2:  fef43423           sd a5,-24(s0)
    c8a6:  fe843783           ld a5,-24(s0)
    c8aa:  6b9c                 ld a5,16(a5)
    c8ac:  fef43023           sd a5,-32(s0)
    c8b0:  fe843783           ld a5,-24(s0)
    c8b4:  0087c783           lbu a5,8(a5)
    c8b8:  853e                 mv a0,a5
    c8ba:  813fe0ef           jal ra,b0cc <FUN_0000b0cc>
    c8be:  041007b7           lui a5,0x4100
    c8c2:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c8c6:  0007d783           lhu a5,0(a5)
    c8ca:  17c2                 slli a5,a5,0x30
    c8cc:  93c1                 srli a5,a5,0x30
    c8ce:  fcf42c23           sw a5,-40(s0)
    c8d2:  fd842783           lw a5,-40(s0)
    c8d6:  8b91                 andi a5,a5,4
    c8d8:  2781                 sext.w a5,a5
    c8da:  cf89                 beqz a5,c8f4 <FUN_0000c884+0x70>
    c8dc:  041007b7           lui a5,0x4100
    c8e0:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c8e4:  00079023           sh zero,0(a5)
    c8e8:  fb843783           ld a5,-72(s0)
    c8ec:  67bc                 ld a5,72(a5)
    c8ee:  0407a423           sw zero,72(a5)
    c8f2:  a4c1                 j cbb2 <FUN_0000c884+0x32e>
    c8f4:  fd842783           lw a5,-40(s0)
    c8f8:  8bc1                 andi a5,a5,16
    c8fa:  2781                 sext.w a5,a5
    c8fc:  cf9d                 beqz a5,c93a <FUN_0000c884+0xb6>
    c8fe:  041007b7           lui a5,0x4100
    c902:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c906:  0007d783           lhu a5,0(a5)
    c90a:  17c2                 slli a5,a5,0x30
    c90c:  93c1                 srli a5,a5,0x30
    c90e:  fcf42e23           sw a5,-36(s0)
    c912:  fdc42783           lw a5,-36(s0)
    c916:  9bbd                 andi a5,a5,-17
    c918:  fcf42e23           sw a5,-36(s0)
    c91c:  041007b7           lui a5,0x4100
    c920:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c924:  fdc42703           lw a4,-36(s0)
    c928:  1742                 slli a4,a4,0x30
    c92a:  9341                 srli a4,a4,0x30
    c92c:  00e79023           sh a4,0(a5)
    c930:  fb843783           ld a5,-72(s0)
    c934:  67bc                 ld a5,72(a5)
    c936:  0407a423           sw zero,72(a5)
    c93a:  fb843783           ld a5,-72(s0)
    c93e:  67bc                 ld a5,72(a5)
    c940:  47bc                 lw a5,72(a5)
    c942:  86be                 mv a3,a5
    c944:  4711                 li a4,4
    c946:  24d76f63           bltu a4,a3,cba4 <FUN_0000c884+0x320>
    c94a:  00279713           slli a4,a5,0x2
    c94e:  67b9                 lui a5,0xe
    c950:  56878793           addi a5,a5,1384 # e568 <gpio_get_boot_device+0x1d2>
    c954:  97ba                 add a5,a5,a4
    c956:  439c                 lw a5,0(a5)
    c958:  8782                 jr a5
    c95a:  fd842783           lw a5,-40(s0)
    c95e:  8b85                 andi a5,a5,1
    c960:  2781                 sext.w a5,a5
    c962:  24078363           beqz a5,cba8 <FUN_0000c884+0x324>
    c966:  fc040793           addi a5,s0,-64
    c96a:  853e                 mv a0,a5
    c96c:  e4fff0ef           jal ra,c7ba <FUN_0000c7ba>
    c970:  87aa                 mv a5,a0
    c972:  fcf42a23           sw a5,-44(s0)
    c976:  fd442783           lw a5,-44(s0)
    c97a:  0007871b           sext.w a4,a5
    c97e:  47a1                 li a5,8
    c980:  00f70b63           beq a4,a5,c996 <FUN_0000c884+0x112>
    c984:  041007b7           lui a5,0x4100
    c988:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c98c:  06000713           li a4,96
    c990:  00e79023           sh a4,0(a5)
    c994:  ac39                 j cbb2 <FUN_0000c884+0x32e>
    c996:  fb843783           ld a5,-72(s0)
    c99a:  67bc                 ld a5,72(a5)
    c99c:  05678793           addi a5,a5,86
    c9a0:  fc040713           addi a4,s0,-64
    c9a4:  4621                 li a2,8
    c9a6:  85ba                 mv a1,a4
    c9a8:  853e                 mv a0,a5
    c9aa:  ce0fd0ef           jal ra,9e8a <memcpy>
    c9ae:  fb843783           ld a5,-72(s0)
    c9b2:  67bc                 ld a5,72(a5)
    c9b4:  4705                 li a4,1
    c9b6:  04e78aa3           sb a4,85(a5)
    c9ba:  fc144783           lbu a5,-63(s0)
    c9be:  2781                 sext.w a5,a5
    c9c0:  86be                 mv a3,a5
    c9c2:  4725                 li a4,9
    c9c4:  00e68b63           beq a3,a4,c9da <FUN_0000c884+0x156>
    c9c8:  86be                 mv a3,a5
    c9ca:  472d                 li a4,11
    c9cc:  02e68463           beq a3,a4,c9f4 <FUN_0000c884+0x170>
    c9d0:  873e                 mv a4,a5
    c9d2:  4795                 li a5,5
    c9d4:  02f70763           beq a4,a5,ca02 <FUN_0000c884+0x17e>
    c9d8:  a0b5                 j ca44 <FUN_0000c884+0x1c0>
    c9da:  fc044783           lbu a5,-64(s0)
    c9de:  efa5                 bnez a5,ca56 <FUN_0000c884+0x1d2>
    c9e0:  0001                 nop
    c9e2:  041007b7           lui a5,0x4100
    c9e6:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    c9ea:  04800713           li a4,72
    c9ee:  00e79023           sh a4,0(a5)
    c9f2:  a2c1                 j cbb2 <FUN_0000c884+0x32e>
    c9f4:  fc044783           lbu a5,-64(s0)
    c9f8:  873e                 mv a4,a5
    c9fa:  4785                 li a5,1
    c9fc:  04f71f63           bne a4,a5,ca5a <FUN_0000c884+0x1d6>
    ca00:  b7cd                 j c9e2 <FUN_0000c884+0x15e>
    ca02:  fc044783           lbu a5,-64(s0)
    ca06:  efa1                 bnez a5,ca5e <FUN_0000c884+0x1da>
    ca08:  fc245783           lhu a5,-62(s0)
    ca0c:  2781                 sext.w a5,a5
    ca0e:  07f7f793           andi a5,a5,127
    ca12:  fcf42823           sw a5,-48(s0)
    ca16:  fb843783           ld a5,-72(s0)
    ca1a:  67bc                 ld a5,72(a5)
    ca1c:  fd042703           lw a4,-48(s0)
    ca20:  0ff77713           andi a4,a4,255
    ca24:  04e78a23           sb a4,84(a5)
    ca28:  041007b7           lui a5,0x4100
    ca2c:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    ca30:  04a00713           li a4,74
    ca34:  00e79023           sh a4,0(a5)
    ca38:  fb843783           ld a5,-72(s0)
    ca3c:  67bc                 ld a5,72(a5)
    ca3e:  470d                 li a4,3
    ca40:  c7b8                 sw a4,72(a5)
    ca42:  aa85                 j cbb2 <FUN_0000c884+0x32e>
    ca44:  041007b7           lui a5,0x4100
    ca48:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    ca4c:  04000713           li a4,64
    ca50:  00e79023           sh a4,0(a5)
    ca54:  a031                 j ca60 <FUN_0000c884+0x1dc>
    ca56:  0001                 nop
    ca58:  a021                 j ca60 <FUN_0000c884+0x1dc>
    ca5a:  0001                 nop
    ca5c:  a011                 j ca60 <FUN_0000c884+0x1dc>
    ca5e:  0001                 nop
    ca60:  fc044783           lbu a5,-64(s0)
    ca64:  0187979b           slliw a5,a5,0x18
    ca68:  4187d79b           sraiw a5,a5,0x18
    ca6c:  0007d863           bgez a5,ca7c <FUN_0000c884+0x1f8>
    ca70:  fb843783           ld a5,-72(s0)
    ca74:  67bc                 ld a5,72(a5)
    ca76:  4705                 li a4,1
    ca78:  c7b8                 sw a4,72(a5)
    ca7a:  a031                 j ca86 <FUN_0000c884+0x202>
    ca7c:  fb843783           ld a5,-72(s0)
    ca80:  67bc                 ld a5,72(a5)
    ca82:  4709                 li a4,2
    ca84:  c7b8                 sw a4,72(a5)
    ca86:  fc040793           addi a5,s0,-64
    ca8a:  85be                 mv a1,a5
    ca8c:  fb843503           ld a0,-72(s0)
    ca90:  416000ef           jal ra,cea6 <FUN_0000cea6>
    ca94:  87aa                 mv a5,a0
    ca96:  fcf42623           sw a5,-52(s0)
    ca9a:  fcc42783           lw a5,-52(s0)
    ca9e:  2781                 sext.w a5,a5
    caa0:  0207d863           bgez a5,cad0 <FUN_0000c884+0x24c>
    caa4:  041007b7           lui a5,0x4100
    caa8:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    caac:  06000713           li a4,96
    cab0:  00e79023           sh a4,0(a5)
    cab4:  041007b7           lui a5,0x4100
    cab8:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    cabc:  04800713           li a4,72
    cac0:  00e79023           sh a4,0(a5)
    cac4:  fb843783           ld a5,-72(s0)
    cac8:  67bc                 ld a5,72(a5)
    caca:  0407a423           sw zero,72(a5)
    cace:  a8e9                 j cba8 <FUN_0000c884+0x324>
    cad0:  fb843783           ld a5,-72(s0)
    cad4:  67bc                 ld a5,72(a5)
    cad6:  0557c783           lbu a5,85(a5)
    cada:  c7f9                 beqz a5,cba8 <FUN_0000c884+0x324>
    cadc:  fb843783           ld a5,-72(s0)
    cae0:  67bc                 ld a5,72(a5)
    cae2:  04078aa3           sb zero,85(a5)
    cae6:  a0c9                 j cba8 <FUN_0000c884+0x324>
    cae8:  fd842783           lw a5,-40(s0)
    caec:  8b89                 andi a5,a5,2
    caee:  2781                 sext.w a5,a5
    caf0:  efd5                 bnez a5,cbac <FUN_0000c884+0x328>
    caf2:  fe043783           ld a5,-32(s0)
    caf6:  cbdd                 beqz a5,cbac <FUN_0000c884+0x328>
    caf8:  fe043603           ld a2,-32(s0)
    cafc:  fe843583           ld a1,-24(s0)
    cb00:  fb843503           ld a0,-72(s0)
    cb04:  b14ff0ef           jal ra,be18 <FUN_0000be18>
    cb08:  a055                 j cbac <FUN_0000c884+0x328>
    cb0a:  fd842783           lw a5,-40(s0)
    cb0e:  8b85                 andi a5,a5,1
    cb10:  2781                 sext.w a5,a5
    cb12:  cfd9                 beqz a5,cbb0 <FUN_0000c884+0x32c>
    cb14:  fe043783           ld a5,-32(s0)
    cb18:  cfc1                 beqz a5,cbb0 <FUN_0000c884+0x32c>
    cb1a:  fe043603           ld a2,-32(s0)
    cb1e:  fe843583           ld a1,-24(s0)
    cb22:  fb843503           ld a0,-72(s0)
    cb26:  e1aff0ef           jal ra,c140 <FUN_0000c140>
    cb2a:  a059                 j cbb0 <FUN_0000c884+0x32c>
    cb2c:  fb843783           ld a5,-72(s0)
    cb30:  67bc                 ld a5,72(a5)
    cb32:  0577c783           lbu a5,87(a5)
    cb36:  2781                 sext.w a5,a5
    cb38:  873e                 mv a4,a5
    cb3a:  4795                 li a5,5
    cb3c:  04f71763           bne a4,a5,cb8a <FUN_0000c884+0x306>
    cb40:  041007b7           lui a5,0x4100
    cb44:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    cb48:  0c000713           li a4,192
    cb4c:  00e79023           sh a4,0(a5)
    cb50:  fc042423           sw zero,-56(s0)
    cb54:  d9cfe0ef           jal ra,b0f0 <FUN_0000b0f0>
    cb58:  87aa                 mv a5,a0
    cb5a:  fcf42423           sw a5,-56(s0)
    cb5e:  4501                 li a0,0
    cb60:  d6cfe0ef           jal ra,b0cc <FUN_0000b0cc>
    cb64:  fb843783           ld a5,-72(s0)
    cb68:  67b8                 ld a4,72(a5)
    cb6a:  041007b7           lui a5,0x4100
    cb6e:  09878793           addi a5,a5,152 # 4100098 <gpio_get_boot_device+0x40f1d02
    cb72:  05474703           lbu a4,84(a4) # 2054 <FUN_00001f22+0x132>
    cb76:  00e78023           sb a4,0(a5)
    cb7a:  fc842783           lw a5,-56(s0)
    cb7e:  0ff7f793           andi a5,a5,255
    cb82:  853e                 mv a0,a5
    cb84:  d48fe0ef           jal ra,b0cc <FUN_0000b0cc>
    cb88:  a011                 j cb8c <FUN_0000c884+0x308>
    cb8a:  0001                 nop
    cb8c:  fb843783           ld a5,-72(s0)
    cb90:  67bc                 ld a5,72(a5)
    cb92:  0407a423           sw zero,72(a5)
    cb96:  a831                 j cbb2 <FUN_0000c884+0x32e>
    cb98:  fb843783           ld a5,-72(s0)
    cb9c:  67bc                 ld a5,72(a5)
    cb9e:  0407a423           sw zero,72(a5)
    cba2:  a801                 j cbb2 <FUN_0000c884+0x32e>
    cba4:  0001                 nop
    cba6:  a031                 j cbb2 <FUN_0000c884+0x32e>
    cba8:  0001                 nop
    cbaa:  a021                 j cbb2 <FUN_0000c884+0x32e>
    cbac:  0001                 nop
    cbae:  a011                 j cbb2 <FUN_0000c884+0x32e>
    cbb0:  0001                 nop
    cbb2:  60a6                 ld ra,72(sp)
    cbb4:  6406                 ld s0,64(sp)
    cbb6:  6161                 addi sp,sp,80
    cbb8:  8082                 ret
000000000000cbba <FUN_0000cbba>:
    cbba:  715d                 addi sp,sp,-80
    cbbc:  e486                 sd ra,72(sp)
    cbbe:  e0a2                 sd s0,64(sp)
    cbc0:  0880                 addi s0,sp,80
    cbc2:  fca43423           sd a0,-56(s0)
    cbc6:  fcb43023           sd a1,-64(s0)
    cbca:  87b2                 mv a5,a2
    cbcc:  8736                 mv a4,a3
    cbce:  faf40fa3           sb a5,-65(s0)
    cbd2:  87ba                 mv a5,a4
    cbd4:  faf42c23           sw a5,-72(s0)
    cbd8:  fc043783           ld a5,-64(s0)
    cbdc:  fef43023           sd a5,-32(s0)
    cbe0:  fb842783           lw a5,-72(s0)
    cbe4:  2781                 sext.w a5,a5
    cbe6:  c399                 beqz a5,cbec <FUN_0000cbba+0x32>
    cbe8:  57fd                 li a5,-1
    cbea:  a0c5                 j ccca <FUN_0000cbba+0x110>
    cbec:  c82fb0ef           jal ra,806e <brom_config_bit_1>
    cbf0:  87aa                 mv a5,a0
    cbf2:  c799                 beqz a5,cc00 <FUN_0000cbba+0x46>
    cbf4:  fc843783           ld a5,-56(s0)
    cbf8:  63bc                 ld a5,64(a5)
    cbfa:  fef43423           sd a5,-24(s0)
    cbfe:  a031                 j cc0a <FUN_0000cbba+0x50>
    cc00:  fc843783           ld a5,-56(s0)
    cc04:  779c                 ld a5,40(a5)
    cc06:  fef43423           sd a5,-24(s0)
    cc0a:  fc042e23           sw zero,-36(s0)
    cc0e:  fc843783           ld a5,-56(s0)
    cc12:  679c                 ld a5,8(a5)
    cc14:  4625                 li a2,9
    cc16:  85be                 mv a1,a5
    cc18:  fc043503           ld a0,-64(s0)
    cc1c:  a6efd0ef           jal ra,9e8a <memcpy>
    cc20:  fc043783           ld a5,-64(s0)
    cc24:  07a5                 addi a5,a5,9
    cc26:  fcf43023           sd a5,-64(s0)
    cc2a:  fc843783           ld a5,-56(s0)
    cc2e:  6b9c                 ld a5,16(a5)
    cc30:  4625                 li a2,9
    cc32:  85be                 mv a1,a5
    cc34:  fc043503           ld a0,-64(s0)
    cc38:  a52fd0ef           jal ra,9e8a <memcpy>
    cc3c:  fc043783           ld a5,-64(s0)
    cc40:  07a5                 addi a5,a5,9
    cc42:  fcf43023           sd a5,-64(s0)
    cc46:  fe843783           ld a5,-24(s0)
    cc4a:  639c                 ld a5,0(a5)
    cc4c:  461d                 li a2,7
    cc4e:  85be                 mv a1,a5
    cc50:  fc043503           ld a0,-64(s0)
    cc54:  a36fd0ef           jal ra,9e8a <memcpy>
    cc58:  fc043783           ld a5,-64(s0)
    cc5c:  079d                 addi a5,a5,7
    cc5e:  fcf43023           sd a5,-64(s0)
    cc62:  fe843783           ld a5,-24(s0)
    cc66:  07a1                 addi a5,a5,8
    cc68:  639c                 ld a5,0(a5)
    cc6a:  461d                 li a2,7
    cc6c:  85be                 mv a1,a5
    cc6e:  fc043503           ld a0,-64(s0)
    cc72:  a18fd0ef           jal ra,9e8a <memcpy>
    cc76:  fc043783           ld a5,-64(s0)
    cc7a:  079d                 addi a5,a5,7
    cc7c:  fcf43023           sd a5,-64(s0)
    cc80:  02000793           li a5,32
    cc84:  fcf42e23           sw a5,-36(s0)
    cc88:  fe043783           ld a5,-32(s0)
    cc8c:  4725                 li a4,9
    cc8e:  00e78023           sb a4,0(a5)
    cc92:  fe043783           ld a5,-32(s0)
    cc96:  4709                 li a4,2
    cc98:  00e780a3           sb a4,1(a5)
    cc9c:  fdc42783           lw a5,-36(s0)
    cca0:  03079713           slli a4,a5,0x30
    cca4:  9341                 srli a4,a4,0x30
    cca6:  fe043783           ld a5,-32(s0)
    ccaa:  00e79123           sh a4,2(a5)
    ccae:  fe043783           ld a5,-32(s0)
    ccb2:  0077c783           lbu a5,7(a5)
    ccb6:  f807e793           ori a5,a5,-128
    ccba:  0ff7f713           andi a4,a5,255
    ccbe:  fe043783           ld a5,-32(s0)
    ccc2:  00e783a3           sb a4,7(a5)
    ccc6:  fdc42783           lw a5,-36(s0)
    ccca:  853e                 mv a0,a5
    cccc:  60a6                 ld ra,72(sp)
    ccce:  6406                 ld s0,64(sp)
    ccd0:  6161                 addi sp,sp,80
    ccd2:  8082                 ret
000000000000ccd4 <FUN_0000ccd4>:
    ccd4:  7139                 addi sp,sp,-64
    ccd6:  fc06                 sd ra,56(sp)
    ccd8:  f822                 sd s0,48(sp)
    ccda:  0080                 addi s0,sp,64
    ccdc:  fca43423           sd a0,-56(s0)
    cce0:  87ae                 mv a5,a1
    cce2:  fcf42223           sw a5,-60(s0)
    cce6:  fe043023           sd zero,-32(s0)
    ccea:  fc043c23           sd zero,-40(s0)
    ccee:  fc040ba3           sb zero,-41(s0)
    ccf2:  fc442783           lw a5,-60(s0)
    ccf6:  2781                 sext.w a5,a5
    ccf8:  1a078063           beqz a5,ce98 <FUN_0000ccd4+0x1c4>
    ccfc:  fc843783           ld a5,-56(s0)
    cd00:  67b4                 ld a3,72(a5)
    cd02:  fc442703           lw a4,-60(s0)
    cd06:  87ba                 mv a5,a4
    cd08:  0786                 slli a5,a5,0x1
    cd0a:  97ba                 add a5,a5,a4
    cd0c:  078e                 slli a5,a5,0x3
    cd0e:  97b6                 add a5,a5,a3
    cd10:  fcf43c23           sd a5,-40(s0)
    cd14:  fd843783           ld a5,-40(s0)
    cd18:  6b9c                 ld a5,16(a5)
    cd1a:  fef43023           sd a5,-32(s0)
    cd1e:  fd843783           ld a5,-40(s0)
    cd22:  0097c783           lbu a5,9(a5)
    cd26:  f807f793           andi a5,a5,-128
    cd2a:  fcf40ba3           sb a5,-41(s0)
    cd2e:  fd843783           ld a5,-40(s0)
    cd32:  0097c783           lbu a5,9(a5)
    cd36:  2781                 sext.w a5,a5
    cd38:  07f7f793           andi a5,a5,127
    cd3c:  fcf42823           sw a5,-48(s0)
    cd40:  fe043783           ld a5,-32(s0)
    cd44:  0207c783           lbu a5,32(a5)
    cd48:  0187979b           slliw a5,a5,0x18
    cd4c:  4187d79b           sraiw a5,a5,0x18
    cd50:  873e                 mv a4,a5
    cd52:  4785                 li a5,1
    cd54:  14f71463           bne a4,a5,ce9c <FUN_0000ccd4+0x1c8>
    cd58:  fd744783           lbu a5,-41(s0)
    cd5c:  0ff7f793           andi a5,a5,255
    cd60:  cbb5                 beqz a5,cdd4 <FUN_0000ccd4+0x100>
    cd62:  fd843783           ld a5,-40(s0)
    cd66:  0087c783           lbu a5,8(a5)
    cd6a:  853e                 mv a0,a5
    cd6c:  b60fe0ef           jal ra,b0cc <FUN_0000b0cc>
    cd70:  041007b7           lui a5,0x4100
    cd74:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    cd78:  0007d783           lhu a5,0(a5)
    cd7c:  17c2                 slli a5,a5,0x30
    cd7e:  93c1                 srli a5,a5,0x30
    cd80:  fef42623           sw a5,-20(s0)
    cd84:  fec42783           lw a5,-20(s0)
    cd88:  0207f793           andi a5,a5,32
    cd8c:  2781                 sext.w a5,a5
    cd8e:  c395                 beqz a5,cdb2 <FUN_0000ccd4+0xde>
    cd90:  041007b7           lui a5,0x4100
    cd94:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    cd98:  fd042703           lw a4,-48(s0)
    cd9c:  1742                 slli a4,a4,0x30
    cd9e:  9341                 srli a4,a4,0x30
    cda0:  00e79023           sh a4,0(a5)
    cda4:  041007b7           lui a5,0x4100
    cda8:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    cdac:  00079023           sh zero,0(a5)
    cdb0:  a0fd                 j ce9e <FUN_0000ccd4+0x1ca>
    cdb2:  fec42783           lw a5,-20(s0)
    cdb6:  8b85                 andi a5,a5,1
    cdb8:  2781                 sext.w a5,a5
    cdba:  e3f5                 bnez a5,ce9e <FUN_0000ccd4+0x1ca>
    cdbc:  fe043783           ld a5,-32(s0)
    cdc0:  cff9                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    cdc2:  fe043603           ld a2,-32(s0)
    cdc6:  fd843583           ld a1,-40(s0)
    cdca:  fc843503           ld a0,-56(s0)
    cdce:  84aff0ef           jal ra,be18 <FUN_0000be18>
    cdd2:  a0f1                 j ce9e <FUN_0000ccd4+0x1ca>
    cdd4:  041007b7           lui a5,0x4100
    cdd8:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    cddc:  fd042703           lw a4,-48(s0)
    cde0:  0ff77713           andi a4,a4,255
    cde4:  00e78023           sb a4,0(a5)
    cde8:  041007b7           lui a5,0x4100
    cdec:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    cdf0:  0007d783           lhu a5,0(a5)
    cdf4:  17c2                 slli a5,a5,0x30
    cdf6:  93c1                 srli a5,a5,0x30
    cdf8:  fef42623           sw a5,-20(s0)
    cdfc:  fec42783           lw a5,-20(s0)
    ce00:  0407f793           andi a5,a5,64
    ce04:  2781                 sext.w a5,a5
    ce06:  c395                 beqz a5,ce2a <FUN_0000ccd4+0x156>
    ce08:  041007b7           lui a5,0x4100
    ce0c:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    ce10:  fd042703           lw a4,-48(s0)
    ce14:  1742                 slli a4,a4,0x30
    ce16:  9341                 srli a4,a4,0x30
    ce18:  00e79023           sh a4,0(a5)
    ce1c:  041007b7           lui a5,0x4100
    ce20:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    ce24:  00079023           sh zero,0(a5)
    ce28:  a89d                 j ce9e <FUN_0000ccd4+0x1ca>
    ce2a:  0001                 nop
    ce2c:  fec42783           lw a5,-20(s0)
    ce30:  8b85                 andi a5,a5,1
    ce32:  2781                 sext.w a5,a5
    ce34:  c7ad                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    ce36:  fe043783           ld a5,-32(s0)
    ce3a:  c3b5                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    ce3c:  fe043603           ld a2,-32(s0)
    ce40:  fd843583           ld a1,-40(s0)
    ce44:  fc843503           ld a0,-56(s0)
    ce48:  af8ff0ef           jal ra,c140 <FUN_0000c140>
    ce4c:  fe043783           ld a5,-32(s0)
    ce50:  0207c783           lbu a5,32(a5)
    ce54:  0187979b           slliw a5,a5,0x18
    ce58:  4187d79b           sraiw a5,a5,0x18
    ce5c:  c3a9                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    ce5e:  041007b7           lui a5,0x4100
    ce62:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    ce66:  fd042703           lw a4,-48(s0)
    ce6a:  0ff77713           andi a4,a4,255
    ce6e:  00e78023           sb a4,0(a5)
    ce72:  041007b7           lui a5,0x4100
    ce76:  08678793           addi a5,a5,134 # 4100086 <gpio_get_boot_device+0x40f1cf0
    ce7a:  0007d783           lhu a5,0(a5)
    ce7e:  17c2                 slli a5,a5,0x30
    ce80:  93c1                 srli a5,a5,0x30
    ce82:  fef42623           sw a5,-20(s0)
    ce86:  fec42783           lw a5,-20(s0)
    ce8a:  8b85                 andi a5,a5,1
    ce8c:  2781                 sext.w a5,a5
    ce8e:  cb81                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    ce90:  fe043783           ld a5,-32(s0)
    ce94:  c789                 beqz a5,ce9e <FUN_0000ccd4+0x1ca>
    ce96:  bf59                 j ce2c <FUN_0000ccd4+0x158>
    ce98:  0001                 nop
    ce9a:  a011                 j ce9e <FUN_0000ccd4+0x1ca>
    ce9c:  0001                 nop
    ce9e:  70e2                 ld ra,56(sp)
    cea0:  7442                 ld s0,48(sp)
    cea2:  6121                 addi sp,sp,64
    cea4:  8082                 ret
000000000000cea6 <FUN_0000cea6>:
    cea6:  715d                 addi sp,sp,-80
    cea8:  e486                 sd ra,72(sp)
    ceaa:  e0a2                 sd s0,64(sp)
    ceac:  0880                 addi s0,sp,80
    ceae:  faa43c23           sd a0,-72(s0)
    ceb2:  fab43823           sd a1,-80(s0)
    ceb6:  fe043023           sd zero,-32(s0)
    ceba:  fc043c23           sd zero,-40(s0)
    cebe:  fb043783           ld a5,-80(s0)
    cec2:  0027d783           lhu a5,2(a5)
    cec6:  fcf41b23           sh a5,-42(s0)
    ceca:  fe042623           sw zero,-20(s0)
    cece:  fb843783           ld a5,-72(s0)
    ced2:  67bc                 ld a5,72(a5)
    ced4:  fcf43c23           sd a5,-40(s0)
    ced8:  fd843783           ld a5,-40(s0)
    cedc:  6b9c                 ld a5,16(a5)
    cede:  fef43023           sd a5,-32(s0)
    cee2:  fb043783           ld a5,-80(s0)
    cee6:  0017c783           lbu a5,1(a5)
    ceea:  0007871b           sext.w a4,a5
    ceee:  86ba                 mv a3,a4
    cef0:  4799                 li a5,6
    cef2:  00f68763           beq a3,a5,cf00 <FUN_0000cea6+0x5a>
    cef6:  0fe00793           li a5,254
    cefa:  14f70c63           beq a4,a5,d052 <FUN_0000cea6+0x1ac>
    cefe:  aa9d                 j d074 <FUN_0000cea6+0x1ce>
    cf00:  fb043783           ld a5,-80(s0)
    cf04:  0007c783           lbu a5,0(a5)
    cf08:  873e                 mv a4,a5
    cf0a:  08000793           li a5,128
    cf0e:  16f71063           bne a4,a5,d06e <FUN_0000cea6+0x1c8>
    cf12:  fd645783           lhu a5,-42(s0)
    cf16:  0087d79b           srliw a5,a5,0x8
    cf1a:  17c2                 slli a5,a5,0x30
    cf1c:  93c1                 srli a5,a5,0x30
    cf1e:  2781                 sext.w a5,a5
    cf20:  86be                 mv a3,a5
    cf22:  4709                 li a4,2
    cf24:  06e68463           beq a3,a4,cf8c <FUN_0000cea6+0xe6>
    cf28:  86be                 mv a3,a5
    cf2a:  470d                 li a4,3
    cf2c:  0ce68963           beq a3,a4,cffe <FUN_0000cea6+0x158>
    cf30:  873e                 mv a4,a5
    cf32:  4785                 li a5,1
    cf34:  12f71f63           bne a4,a5,d072 <FUN_0000cea6+0x1cc>
    cf38:  fb043783           ld a5,-80(s0)
    cf3c:  0067d783           lhu a5,6(a5)
    cf40:  0007871b           sext.w a4,a5
    cf44:  47c9                 li a5,18
    cf46:  00e7f663           bgeu a5,a4,cf52 <FUN_0000cea6+0xac>
    cf4a:  47c9                 li a5,18
    cf4c:  fef42623           sw a5,-20(s0)
    cf50:  a039                 j cf5e <FUN_0000cea6+0xb8>
    cf52:  fb043783           ld a5,-80(s0)
    cf56:  0067d783           lhu a5,6(a5)
    cf5a:  fef42623           sw a5,-20(s0)
    cf5e:  fe043783           ld a5,-32(s0)
    cf62:  6398                 ld a4,0(a5)
    cf64:  fb843783           ld a5,-72(s0)
    cf68:  639c                 ld a5,0(a5)
    cf6a:  fec42683           lw a3,-20(s0)
    cf6e:  8636                 mv a2,a3
    cf70:  85be                 mv a1,a5
    cf72:  853a                 mv a0,a4
    cf74:  f17fc0ef           jal ra,9e8a <memcpy>
    cf78:  fec42703           lw a4,-20(s0)
    cf7c:  fe043783           ld a5,-32(s0)
    cf80:  c798                 sw a4,8(a5)
    cf82:  fe043783           ld a5,-32(s0)
    cf86:  00078623           sb zero,12(a5)
    cf8a:  a0d9                 j d050 <FUN_0000cea6+0x1aa>
    cf8c:  fe043783           ld a5,-32(s0)
    cf90:  6398                 ld a4,0(a5)
    cf92:  fd645783           lhu a5,-42(s0)
    cf96:  0087d79b           srliw a5,a5,0x8
    cf9a:  17c2                 slli a5,a5,0x30
    cf9c:  93c1                 srli a5,a5,0x30
    cf9e:  0ff7f793           andi a5,a5,255
    cfa2:  fd645683           lhu a3,-42(s0)
    cfa6:  2681                 sext.w a3,a3
    cfa8:  0ff6f693           andi a3,a3,255
    cfac:  2681                 sext.w a3,a3
    cfae:  863e                 mv a2,a5
    cfb0:  85ba                 mv a1,a4
    cfb2:  fb843503           ld a0,-72(s0)
    cfb6:  c05ff0ef           jal ra,cbba <FUN_0000cbba>
    cfba:  87aa                 mv a5,a0
    cfbc:  fef42623           sw a5,-20(s0)
    cfc0:  fb043783           ld a5,-80(s0)
    cfc4:  0067d783           lhu a5,6(a5)
    cfc8:  0007871b           sext.w a4,a5
    cfcc:  fec42783           lw a5,-20(s0)
    cfd0:  2781                 sext.w a5,a5
    cfd2:  00f74863           blt a4,a5,cfe2 <FUN_0000cea6+0x13c>
    cfd6:  fec42703           lw a4,-20(s0)
    cfda:  fe043783           ld a5,-32(s0)
    cfde:  c798                 sw a4,8(a5)
    cfe0:  a811                 j cff4 <FUN_0000cea6+0x14e>
    cfe2:  fb043783           ld a5,-80(s0)
    cfe6:  0067d783           lhu a5,6(a5)
    cfea:  0007871b           sext.w a4,a5
    cfee:  fe043783           ld a5,-32(s0)
    cff2:  c798                 sw a4,8(a5)
    cff4:  fe043783           ld a5,-32(s0)
    cff8:  00078623           sb zero,12(a5)
    cffc:  a891                 j d050 <FUN_0000cea6+0x1aa>
    cffe:  fd645783           lhu a5,-42(s0)
    d002:  2781                 sext.w a5,a5
    d004:  0ff7f793           andi a5,a5,255
    d008:  fcf42823           sw a5,-48(s0)
    d00c:  fd042783           lw a5,-48(s0)
    d010:  2781                 sext.w a5,a5
    d012:  ef95                 bnez a5,d04e <FUN_0000cea6+0x1a8>
    d014:  fe043783           ld a5,-32(s0)
    d018:  639c                 ld a5,0(a5)
    d01a:  fcf43423           sd a5,-56(s0)
    d01e:  fc843783           ld a5,-56(s0)
    d022:  4711                 li a4,4
    d024:  00e78023           sb a4,0(a5)
    d028:  fc843783           ld a5,-56(s0)
    d02c:  0785                 addi a5,a5,1
    d02e:  470d                 li a4,3
    d030:  00e78023           sb a4,0(a5)
    d034:  fc843783           ld a5,-56(s0)
    d038:  0789                 addi a5,a5,2
    d03a:  4725                 li a4,9
    d03c:  00e78023           sb a4,0(a5)
    d040:  fc843783           ld a5,-56(s0)
    d044:  078d                 addi a5,a5,3
    d046:  4711                 li a4,4
    d048:  00e78023           sb a4,0(a5)
    d04c:  a011                 j d050 <FUN_0000cea6+0x1aa>
    d04e:  0001                 nop
    d050:  a00d                 j d072 <FUN_0000cea6+0x1cc>
    d052:  fe043783           ld a5,-32(s0)
    d056:  639c                 ld a5,0(a5)
    d058:  fcf43023           sd a5,-64(s0)
    d05c:  fe043783           ld a5,-32(s0)
    d060:  4705                 li a4,1
    d062:  c798                 sw a4,8(a5)
    d064:  fc043783           ld a5,-64(s0)
    d068:  00078023           sb zero,0(a5)
    d06c:  a021                 j d074 <FUN_0000cea6+0x1ce>
    d06e:  0001                 nop
    d070:  a011                 j d074 <FUN_0000cea6+0x1ce>
    d072:  0001                 nop
    d074:  4605                 li a2,1
    d076:  fe043583           ld a1,-32(s0)
    d07a:  fb843503           ld a0,-72(s0)
    d07e:  d8eff0ef           jal ra,c60c <FUN_0000c60c>
    d082:  4781                 li a5,0
    d084:  853e                 mv a0,a5
    d086:  60a6                 ld ra,72(sp)
    d088:  6406                 ld s0,64(sp)
    d08a:  6161                 addi sp,sp,80
    d08c:  8082                 ret
000000000000d08e <fel_irq_handler>:
    d08e:  7139                 addi sp,sp,-64
    d090:  fc06                 sd ra,56(sp)
    d092:  f822                 sd s0,48(sp)
    d094:  0080                 addi s0,sp,64
    d096:  fe042023           sw zero,-32(s0)
    d09a:  fe042623           sw zero,-20(s0)
    d09e:  fc042e23           sw zero,-36(s0)
    d0a2:  fc042c23           sw zero,-40(s0)
    d0a6:  fc042a23           sw zero,-44(s0)
    d0aa:  846fe0ef           jal ra,b0f0 <FUN_0000b0f0>
    d0ae:  87aa                 mv a5,a0
    d0b0:  fef42023           sw a5,-32(s0)
    d0b4:  000487b7           lui a5,0x48
    d0b8:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d0bc:  853e                 mv a0,a5
    d0be:  b2dfe0ef           jal ra,bbea <FUN_0000bbea>
    d0c2:  87aa                 mv a5,a0
    d0c4:  fcf42e23           sw a5,-36(s0)
    d0c8:  000487b7           lui a5,0x48
    d0cc:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d0d0:  853e                 mv a0,a5
    d0d2:  aa5fe0ef           jal ra,bb76 <FUN_0000bb76>
    d0d6:  87aa                 mv a5,a0
    d0d8:  fcf42c23           sw a5,-40(s0)
    d0dc:  000487b7           lui a5,0x48
    d0e0:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d0e4:  853e                 mv a0,a5
    d0e6:  acbfe0ef           jal ra,bbb0 <FUN_0000bbb0>
    d0ea:  87aa                 mv a5,a0
    d0ec:  fcf42a23           sw a5,-44(s0)
    d0f0:  fdc42783           lw a5,-36(s0)
    d0f4:  8b91                 andi a5,a5,4
    d0f6:  2781                 sext.w a5,a5
    d0f8:  c3f1                 beqz a5,d1bc <fel_irq_handler+0x12e>
    d0fa:  f75fa0ef           jal ra,806e <brom_config_bit_1>
    d0fe:  87aa                 mv a5,a0
    d100:  cb91                 beqz a5,d114 <fel_irq_handler+0x86>
    d102:  000487b7           lui a5,0x48
    d106:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d10a:  67bc                 ld a5,72(a5)
    d10c:  470d                 li a4,3
    d10e:  04e78623           sb a4,76(a5)
    d112:  a809                 j d124 <fel_irq_handler+0x96>
    d114:  000487b7           lui a5,0x48
    d118:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d11c:  67bc                 ld a5,72(a5)
    d11e:  4709                 li a4,2
    d120:  04e78623           sb a4,76(a5)
    d124:  000487b7           lui a5,0x48
    d128:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d12c:  67bc                 ld a5,72(a5)
    d12e:  0407a423           sw zero,72(a5)
    d132:  000487b7           lui a5,0x48
    d136:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d13a:  4591                 li a1,4
    d13c:  853e                 mv a0,a5
    d13e:  b77fe0ef           jal ra,bcb4 <FUN_0000bcb4>
    d142:  041007b7           lui a5,0x4100
    d146:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    d14a:  fe042703           lw a4,-32(s0)
    d14e:  0ff77713           andi a4,a4,255
    d152:  00e78023           sb a4,0(a5)
    d156:  a13fe0ef           jal ra,bb68 <FUN_0000bb68>
    d15a:  041007b7           lui a5,0x4100
    d15e:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    d162:  0007c783           lbu a5,0(a5)
    d166:  0ff7f713           andi a4,a5,255
    d16a:  041007b7           lui a5,0x4100
    d16e:  04878793           addi a5,a5,72 # 4100048 <gpio_get_boot_device+0x40f1cb2>
    d172:  00176713           ori a4,a4,1
    d176:  0ff77713           andi a4,a4,255
    d17a:  00e78023           sb a4,0(a5)
    d17e:  000487b7           lui a5,0x48
    d182:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d186:  853e                 mv a0,a5
    d188:  dfeff0ef           jal ra,c786 <FUN_0000c786>
    d18c:  fc042823           sw zero,-48(s0)
    d190:  f61fd0ef           jal ra,b0f0 <FUN_0000b0f0>
    d194:  87aa                 mv a5,a0
    d196:  fcf42823           sw a5,-48(s0)
    d19a:  4501                 li a0,0
    d19c:  f31fd0ef           jal ra,b0cc <FUN_0000b0cc>
    d1a0:  041007b7           lui a5,0x4100
    d1a4:  09878793           addi a5,a5,152 # 4100098 <gpio_get_boot_device+0x40f1d02
    d1a8:  00078023           sb zero,0(a5)
    d1ac:  fd042783           lw a5,-48(s0)
    d1b0:  0ff7f793           andi a5,a5,255
    d1b4:  853e                 mv a0,a5
    d1b6:  f17fd0ef           jal ra,b0cc <FUN_0000b0cc>
    d1ba:  aafd                 j d3b8 <fel_irq_handler+0x32a>
    d1bc:  fdc42783           lw a5,-36(s0)
    d1c0:  8b89                 andi a5,a5,2
    d1c2:  2781                 sext.w a5,a5
    d1c4:  cb89                 beqz a5,d1d6 <fel_irq_handler+0x148>
    d1c6:  000487b7           lui a5,0x48
    d1ca:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d1ce:  4589                 li a1,2
    d1d0:  853e                 mv a0,a5
    d1d2:  ae3fe0ef           jal ra,bcb4 <FUN_0000bcb4>
    d1d6:  fdc42783           lw a5,-36(s0)
    d1da:  8b85                 andi a5,a5,1
    d1dc:  2781                 sext.w a5,a5
    d1de:  c385                 beqz a5,d1fe <fel_irq_handler+0x170>
    d1e0:  000487b7           lui a5,0x48
    d1e4:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d1e8:  4585                 li a1,1
    d1ea:  853e                 mv a0,a5
    d1ec:  ac9fe0ef           jal ra,bcb4 <FUN_0000bcb4>
    d1f0:  000487b7           lui a5,0x48
    d1f4:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d1f8:  67bc                 ld a5,72(a5)
    d1fa:  0407a423           sw zero,72(a5)
    d1fe:  fd842783           lw a5,-40(s0)
    d202:  8b85                 andi a5,a5,1
    d204:  2781                 sext.w a5,a5
    d206:  c385                 beqz a5,d226 <fel_irq_handler+0x198>
    d208:  000487b7           lui a5,0x48
    d20c:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d210:  4585                 li a1,1
    d212:  853e                 mv a0,a5
    d214:  a11fe0ef           jal ra,bc24 <FUN_0000bc24>
    d218:  000487b7           lui a5,0x48
    d21c:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d220:  853e                 mv a0,a5
    d222:  e62ff0ef           jal ra,c884 <FUN_0000c884>
    d226:  4785                 li a5,1
    d228:  fef42623           sw a5,-20(s0)
    d22c:  a04d                 j d2ce <fel_irq_handler+0x240>
    d22e:  fec42783           lw a5,-20(s0)
    d232:  4705                 li a4,1
    d234:  00f717bb           sllw a5,a4,a5
    d238:  2781                 sext.w a5,a5
    d23a:  fcf42623           sw a5,-52(s0)
    d23e:  fd842703           lw a4,-40(s0)
    d242:  fcc42783           lw a5,-52(s0)
    d246:  8ff9                 and a5,a5,a4
    d248:  2781                 sext.w a5,a5
    d24a:  cfad                 beqz a5,d2c4 <fel_irq_handler+0x236>
    d24c:  fe042423           sw zero,-24(s0)
    d250:  000487b7           lui a5,0x48
    d254:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d258:  fcc42703           lw a4,-52(s0)
    d25c:  0ff77713           andi a4,a4,255
    d260:  85ba                 mv a1,a4
    d262:  853e                 mv a0,a5
    d264:  9c1fe0ef           jal ra,bc24 <FUN_0000bc24>
    d268:  4785                 li a5,1
    d26a:  fef42423           sw a5,-24(s0)
    d26e:  a0a1                 j d2b6 <fel_irq_handler+0x228>
    d270:  000487b7           lui a5,0x48
    d274:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d278:  67b4                 ld a3,72(a5)
    d27a:  fe842703           lw a4,-24(s0)
    d27e:  87ba                 mv a5,a4
    d280:  0786                 slli a5,a5,0x1
    d282:  97ba                 add a5,a5,a4
    d284:  078e                 slli a5,a5,0x3
    d286:  97b6                 add a5,a5,a3
    d288:  0097c783           lbu a5,9(a5)
    d28c:  0187979b           slliw a5,a5,0x18
    d290:  4187d79b           sraiw a5,a5,0x18
    d294:  0007dc63           bgez a5,d2ac <fel_irq_handler+0x21e>
    d298:  000487b7           lui a5,0x48
    d29c:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d2a0:  fe842703           lw a4,-24(s0)
    d2a4:  85ba                 mv a1,a4
    d2a6:  853e                 mv a0,a5
    d2a8:  a2dff0ef           jal ra,ccd4 <FUN_0000ccd4>
    d2ac:  fe842783           lw a5,-24(s0)
    d2b0:  2785                 addiw a5,a5,1
    d2b2:  fef42423           sw a5,-24(s0)
    d2b6:  fe842783           lw a5,-24(s0)
    d2ba:  0007871b           sext.w a4,a5
    d2be:  4789                 li a5,2
    d2c0:  fae7d8e3           bge a5,a4,d270 <fel_irq_handler+0x1e2>
    d2c4:  fec42783           lw a5,-20(s0)
    d2c8:  2785                 addiw a5,a5,1
    d2ca:  fef42623           sw a5,-20(s0)
    d2ce:  fec42783           lw a5,-20(s0)
    d2d2:  0007871b           sext.w a4,a5
    d2d6:  4795                 li a5,5
    d2d8:  f4e7dbe3           bge a5,a4,d22e <fel_irq_handler+0x1a0>
    d2dc:  4785                 li a5,1
    d2de:  fef42623           sw a5,-20(s0)
    d2e2:  a04d                 j d384 <fel_irq_handler+0x2f6>
    d2e4:  fec42783           lw a5,-20(s0)
    d2e8:  4705                 li a4,1
    d2ea:  00f717bb           sllw a5,a4,a5
    d2ee:  2781                 sext.w a5,a5
    d2f0:  fcf42423           sw a5,-56(s0)
    d2f4:  fd442703           lw a4,-44(s0)
    d2f8:  fc842783           lw a5,-56(s0)
    d2fc:  8ff9                 and a5,a5,a4
    d2fe:  2781                 sext.w a5,a5
    d300:  cfad                 beqz a5,d37a <fel_irq_handler+0x2ec>
    d302:  fe042223           sw zero,-28(s0)
    d306:  000487b7           lui a5,0x48
    d30a:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d30e:  fc842703           lw a4,-56(s0)
    d312:  0ff77713           andi a4,a4,255
    d316:  85ba                 mv a1,a4
    d318:  853e                 mv a0,a5
    d31a:  953fe0ef           jal ra,bc6c <FUN_0000bc6c>
    d31e:  4785                 li a5,1
    d320:  fef42223           sw a5,-28(s0)
    d324:  a0a1                 j d36c <fel_irq_handler+0x2de>
    d326:  000487b7           lui a5,0x48
    d32a:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d32e:  67b4                 ld a3,72(a5)
    d330:  fe442703           lw a4,-28(s0)
    d334:  87ba                 mv a5,a4
    d336:  0786                 slli a5,a5,0x1
    d338:  97ba                 add a5,a5,a4
    d33a:  078e                 slli a5,a5,0x3
    d33c:  97b6                 add a5,a5,a3
    d33e:  0097c783           lbu a5,9(a5)
    d342:  0187979b           slliw a5,a5,0x18
    d346:  4187d79b           sraiw a5,a5,0x18
    d34a:  0007cc63           bltz a5,d362 <fel_irq_handler+0x2d4>
    d34e:  000487b7           lui a5,0x48
    d352:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d356:  fe442703           lw a4,-28(s0)
    d35a:  85ba                 mv a1,a4
    d35c:  853e                 mv a0,a5
    d35e:  977ff0ef           jal ra,ccd4 <FUN_0000ccd4>
    d362:  fe442783           lw a5,-28(s0)
    d366:  2785                 addiw a5,a5,1
    d368:  fef42223           sw a5,-28(s0)
    d36c:  fe442783           lw a5,-28(s0)
    d370:  0007871b           sext.w a4,a5
    d374:  4789                 li a5,2
    d376:  fae7d8e3           bge a5,a4,d326 <fel_irq_handler+0x298>
    d37a:  fec42783           lw a5,-20(s0)
    d37e:  2785                 addiw a5,a5,1
    d380:  fef42623           sw a5,-20(s0)
    d384:  fec42783           lw a5,-20(s0)
    d388:  0007871b           sext.w a4,a5
    d38c:  4795                 li a5,5
    d38e:  f4e7dbe3           bge a5,a4,d2e4 <fel_irq_handler+0x256>
    d392:  fd6fe0ef           jal ra,bb68 <FUN_0000bb68>
    d396:  041007b7           lui a5,0x4100
    d39a:  04278793           addi a5,a5,66 # 4100042 <gpio_get_boot_device+0x40f1cac>
    d39e:  fe042703           lw a4,-32(s0)
    d3a2:  0ff77713           andi a4,a4,255
    d3a6:  00e78023           sb a4,0(a5)
    d3aa:  000487b7           lui a5,0x48
    d3ae:  e187b783           ld a5,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d3b2:  853e                 mv a0,a5
    d3b4:  949fe0ef           jal ra,bcfc <FUN_0000bcfc>
    d3b8:  70e2                 ld ra,56(sp)
    d3ba:  7442                 ld s0,48(sp)
    d3bc:  6121                 addi sp,sp,64
    d3be:  8082                 ret
000000000000d3c0 <FUN_0000d3c0>:
    d3c0:  1141                 addi sp,sp,-16
    d3c2:  e406                 sd ra,8(sp)
    d3c4:  e022                 sd s0,0(sp)
    d3c6:  0800                 addi s0,sp,16
    d3c8:  10000613           li a2,256
    d3cc:  0cc00593           li a1,204
    d3d0:  00045537           lui a0,0x45
    d3d4:  b17fc0ef           jal ra,9eea <memset>
    d3d8:  0001                 nop
    d3da:  60a2                 ld ra,8(sp)
    d3dc:  6402                 ld s0,0(sp)
    d3de:  0141                 addi sp,sp,16
    d3e0:  8082                 ret
000000000000d3e2 <FUN_0000d3e2>:
    d3e2:  7179                 addi sp,sp,-48
    d3e4:  f406                 sd ra,40(sp)
    d3e6:  f022                 sd s0,32(sp)
    d3e8:  1800                 addi s0,sp,48
    d3ea:  fca43c23           sd a0,-40(s0)
    d3ee:  fe042623           sw zero,-20(s0)
    d3f2:  030067b7           lui a5,0x3006
    d3f6:  21078793           addi a5,a5,528 # 3006210 <gpio_get_boot_device+0x2ff7e7a
    d3fa:  439c                 lw a5,0(a5)
    d3fc:  fef42623           sw a5,-20(s0)
    d400:  fd843783           ld a5,-40(s0)
    d404:  0807a023           sw zero,128(a5)
    d408:  fec42703           lw a4,-20(s0)
    d40c:  6785                 lui a5,0x1
    d40e:  80078793           addi a5,a5,-2048 # 800 <FUN_00000660+0x1a0>
    d412:  8ff9                 and a5,a5,a4
    d414:  2781                 sext.w a5,a5
    d416:  cb99                 beqz a5,d42c <FUN_0000d3e2+0x4a>
    d418:  4581                 li a1,0
    d41a:  4521                 li a0,8
    d41c:  e29fa0ef           jal ra,8244 <debug_state_save>
    d420:  fd843783           ld a5,-40(s0)
    d424:  4705                 li a4,1
    d426:  08e7a223           sw a4,132(a5)
    d42a:  a029                 j d434 <FUN_0000d3e2+0x52>
    d42c:  fd843783           ld a5,-40(s0)
    d430:  0807a223           sw zero,132(a5)
    d434:  fec42703           lw a4,-20(s0)
    d438:  6785                 lui a5,0x1
    d43a:  8ff9                 and a5,a5,a4
    d43c:  2781                 sext.w a5,a5
    d43e:  c785                 beqz a5,d466 <FUN_0000d3e2+0x84>
    d440:  4581                 li a1,0
    d442:  4529                 li a0,10
    d444:  e01fa0ef           jal ra,8244 <debug_state_save>
    d448:  fd843783           ld a5,-40(s0)
    d44c:  4705                 li a4,1
    d44e:  08e7aa23           sw a4,148(a5) # 1094 <FUN_00000f2c+0x168>
    d452:  000487b7           lui a5,0x48
    d456:  d1078793           addi a5,a5,-752 # 47d10 <gpio_get_boot_device+0x3997a>
    d45a:  10000593           li a1,256
    d45e:  853e                 mv a0,a5
    d460:  261000ef           jal ra,dec0 <FUN_0000dec0>
    d464:  a029                 j d46e <FUN_0000d3e2+0x8c>
    d466:  fd843783           ld a5,-40(s0)
    d46a:  0807aa23           sw zero,148(a5)
    d46e:  fd843783           ld a5,-40(s0)
    d472:  0807a823           sw zero,144(a5)
    d476:  fd843783           ld a5,-40(s0)
    d47a:  0807a423           sw zero,136(a5)
    d47e:  0001                 nop
    d480:  70a2                 ld ra,40(sp)
    d482:  7402                 ld s0,32(sp)
    d484:  6145                 addi sp,sp,48
    d486:  8082                 ret
000000000000d488 <fel_main>:
    d488:  d9010113           addi sp,sp,-624
    d48c:  26113423           sd ra,616(sp)
    d490:  26813023           sd s0,608(sp)
    d494:  1c80                 addi s0,sp,624
    d496:  737d                 lui t1,0xfffff
    d498:  911a                 add sp,sp,t1
    d49a:  65f000ef           jal ra,e2f8 <usb_init>
    d49e:  f23ff0ef           jal ra,d3c0 <FUN_0000d3c0>
    d4a2:  000487b7           lui a5,0x48
    d4a6:  f5840713           addi a4,s0,-168
    d4aa:  e0e7bc23           sd a4,-488(a5) # 47e18 <gpio_get_boot_device+0x39a82>
    d4ae:  f4040793           addi a5,s0,-192
    d4b2:  f4f43c23           sd a5,-168(s0)
    d4b6:  f3040793           addi a5,s0,-208
    d4ba:  f6f43023           sd a5,-160(s0)
    d4be:  f2040793           addi a5,s0,-224
    d4c2:  f6f43423           sd a5,-152(s0)
    d4c6:  f1840793           addi a5,s0,-232
    d4ca:  f6f43823           sd a5,-144(s0)
    d4ce:  f1040793           addi a5,s0,-240
    d4d2:  f6f43c23           sd a5,-136(s0)
    d4d6:  f0040793           addi a5,s0,-256
    d4da:  f8f43023           sd a5,-128(s0)
    d4de:  ef840793           addi a5,s0,-264
    d4e2:  f8f43423           sd a5,-120(s0)
    d4e6:  ef040793           addi a5,s0,-272
    d4ea:  f8f43823           sd a5,-112(s0)
    d4ee:  ee040793           addi a5,s0,-288
    d4f2:  f8f43c23           sd a5,-104(s0)
    d4f6:  e8040793           addi a5,s0,-384
    d4fa:  faf43023           sd a5,-96(s0)
    d4fe:  e5040793           addi a5,s0,-432
    d502:  faf43423           sd a5,-88(s0)
    d506:  e2840793           addi a5,s0,-472
    d50a:  faf43823           sd a5,-80(s0)
    d50e:  e0040793           addi a5,s0,-512
    d512:  faf43c23           sd a5,-72(s0)
    d516:  dd840793           addi a5,s0,-552
    d51a:  fcf43023           sd a5,-64(s0)
    d51e:  f5840793           addi a5,s0,-168
    d522:  07078793           addi a5,a5,112
    d526:  853e                 mv a0,a5
    d528:  918ff0ef           jal ra,c640 <FUN_0000c640>
    d52c:  b8dfd0ef           jal ra,b0b8 <clear_interrupts>
    d530:  f5840793           addi a5,s0,-168
    d534:  853e                 mv a0,a5
    d536:  eadff0ef           jal ra,d3e2 <FUN_0000d3e2>
    d53a:  f5840793           addi a5,s0,-168
    d53e:  853e                 mv a0,a5
    d540:  99dfd0ef           jal ra,aedc <FUN_0000aedc>
    d544:  f4040793           addi a5,s0,-192
    d548:  853e                 mv a0,a5
    d54a:  bc5fd0ef           jal ra,b10e <FUN_0000b10e>
    d54e:  f3040793           addi a5,s0,-208
    d552:  853e                 mv a0,a5
    d554:  c59fd0ef           jal ra,b1ac <FUN_0000b1ac>
    d558:  f2040793           addi a5,s0,-224
    d55c:  853e                 mv a0,a5
    d55e:  cb5fd0ef           jal ra,b212 <FUN_0000b212>
    d562:  f1840793           addi a5,s0,-232
    d566:  853e                 mv a0,a5
    d568:  d11fd0ef           jal ra,b278 <FUN_0000b278>
    d56c:  f1040793           addi a5,s0,-240
    d570:  853e                 mv a0,a5
    d572:  d55fd0ef           jal ra,b2c6 <FUN_0000b2c6>
    d576:  f1840693           addi a3,s0,-232
    d57a:  f1040713           addi a4,s0,-240
    d57e:  f0040793           addi a5,s0,-256
    d582:  8636                 mv a2,a3
    d584:  85ba                 mv a1,a4
    d586:  853e                 mv a0,a5
    d588:  d8ffd0ef           jal ra,b316 <FUN_0000b316>
    d58c:  ef840793           addi a5,s0,-264
    d590:  853e                 mv a0,a5
    d592:  db5fd0ef           jal ra,b346 <FUN_0000b346>
    d596:  ef040793           addi a5,s0,-272
    d59a:  853e                 mv a0,a5
    d59c:  df9fd0ef           jal ra,b394 <FUN_0000b394>
    d5a0:  ef840693           addi a3,s0,-264
    d5a4:  ef040713           addi a4,s0,-272
    d5a8:  ee040793           addi a5,s0,-288
    d5ac:  8636                 mv a2,a3
    d5ae:  85ba                 mv a1,a4
    d5b0:  853e                 mv a0,a5
    d5b2:  e33fd0ef           jal ra,b3e4 <FUN_0000b3e4>
    d5b6:  ab9fa0ef           jal ra,806e <brom_config_bit_1>
    d5ba:  87aa                 mv a5,a0
    d5bc:  cf89                 beqz a5,d5d6 <fel_main+0x14e>
    d5be:  ef040693           addi a3,s0,-272
    d5c2:  ef840713           addi a4,s0,-264
    d5c6:  e8040793           addi a5,s0,-384
    d5ca:  8636                 mv a2,a3
    d5cc:  85ba                 mv a1,a4
    d5ce:  853e                 mv a0,a5
    d5d0:  e45fd0ef           jal ra,b414 <FUN_0000b414>
    d5d4:  a821                 j d5ec <fel_main+0x164>
    d5d6:  f1040693           addi a3,s0,-240
    d5da:  f1840713           addi a4,s0,-232
    d5de:  e8040793           addi a5,s0,-384
    d5e2:  8636                 mv a2,a3
    d5e4:  85ba                 mv a1,a4
    d5e6:  853e                 mv a0,a5
    d5e8:  e2dfd0ef           jal ra,b414 <FUN_0000b414>
    d5ec:  e0040693           addi a3,s0,-512
    d5f0:  dd840613           addi a2,s0,-552
    d5f4:  77fd                 lui a5,0xfffff
    d5f6:  de878793           addi a5,a5,-536 # ffffffffffffede8 <gpio_get_boot_device
    d5fa:  ff040713           addi a4,s0,-16
    d5fe:  973e                 add a4,a4,a5
    d600:  e5040793           addi a5,s0,-432
    d604:  85ba                 mv a1,a4
    d606:  853e                 mv a0,a5
    d608:  f1dfd0ef           jal ra,b524 <FUN_0000b524>
    d60c:  77fd                 lui a5,0xfffff
    d60e:  da078793           addi a5,a5,-608 # ffffffffffffeda0 <gpio_get_boot_device
    d612:  ff040713           addi a4,s0,-16
    d616:  973e                 add a4,a4,a5
    d618:  e2840793           addi a5,s0,-472
    d61c:  85ba                 mv a1,a4
    d61e:  853e                 mv a0,a5
    d620:  f61fd0ef           jal ra,b580 <FUN_0000b580>
    d624:  77fd                 lui a5,0xfffff
    d626:  de878793           addi a5,a5,-536 # ffffffffffffede8 <gpio_get_boot_device
    d62a:  ff040713           addi a4,s0,-16
    d62e:  973e                 add a4,a4,a5
    d630:  e0040793           addi a5,s0,-512
    d634:  85ba                 mv a1,a4
    d636:  853e                 mv a0,a5
    d638:  ff5fd0ef           jal ra,b62c <FUN_0000b62c>
    d63c:  77fd                 lui a5,0xfffff
    d63e:  de878793           addi a5,a5,-536 # ffffffffffffede8 <gpio_get_boot_device
    d642:  ff040713           addi a4,s0,-16
    d646:  973e                 add a4,a4,a5
    d648:  dd840793           addi a5,s0,-552
    d64c:  85ba                 mv a1,a4
    d64e:  853e                 mv a0,a5
    d650:  f87fd0ef           jal ra,b5d6 <FUN_0000b5d6>
    d654:  fa043783           ld a5,-96(s0)
    d658:  e0040693           addi a3,s0,-512
    d65c:  dd840613           addi a2,s0,-552
    d660:  e2840713           addi a4,s0,-472
    d664:  85ba                 mv a1,a4
    d666:  853e                 mv a0,a5
    d668:  81afe0ef           jal ra,b682 <FUN_0000b682>
    d66c:  f5840793           addi a5,s0,-168
    d670:  853e                 mv a0,a5
    d672:  a0bfd0ef           jal ra,b07c <disable_interrupts>
    d676:  f5840793           addi a5,s0,-168
    d67a:  853e                 mv a0,a5
    d67c:  bbafe0ef           jal ra,ba36 <FUN_0000ba36>
    d680:  f5840793           addi a5,s0,-168
    d684:  853e                 mv a0,a5
    d686:  ee0fd0ef           jal ra,ad66 <FUN_0000ad66>
    d68a:  0001                 nop
    d68c:  6305                 lui t1,0x1
    d68e:  911a                 add sp,sp,t1
    d690:  26813083           ld ra,616(sp)
    d694:  26013403           ld s0,608(sp)
    d698:  27010113           addi sp,sp,624
    d69c:  8082                 ret
000000000000d69e <FUN_0000d69e>:
    d69e:  7179                 addi sp,sp,-48
    d6a0:  f406                 sd ra,40(sp)
    d6a2:  f022                 sd s0,32(sp)
    d6a4:  1800                 addi s0,sp,48
    d6a6:  fca43c23           sd a0,-40(s0)
    d6aa:  fe043023           sd zero,-32(s0)
    d6ae:  6795                 lui a5,0x5
    d6b0:  e207879b           addiw a5,a5,-480
    d6b4:  fef42623           sw a5,-20(s0)
    d6b8:  fd843783           ld a5,-40(s0)
    d6bc:  67bc                 ld a5,72(a5)
    d6be:  03078793           addi a5,a5,48 # 5030 <FUN_00004d1e+0x312>
    d6c2:  fef43023           sd a5,-32(s0)
    d6c6:  fe043783           ld a5,-32(s0)
    d6ca:  0087c783           lbu a5,8(a5)
    d6ce:  853e                 mv a0,a5
    d6d0:  9fdfd0ef           jal ra,b0cc <FUN_0000b0cc>
    d6d4:  041007b7           lui a5,0x4100
    d6d8:  08278793           addi a5,a5,130 # 4100082 <gpio_get_boot_device+0x40f1cec
    d6dc:  0007d783           lhu a5,0(a5)
    d6e0:  17c2                 slli a5,a5,0x30
    d6e2:  93c1                 srli a5,a5,0x30
    d6e4:  2781                 sext.w a5,a5
    d6e6:  8b85                 andi a5,a5,1
    d6e8:  2781                 sext.w a5,a5
    d6ea:  e399                 bnez a5,d6f0 <FUN_0000d69e+0x52>
    d6ec:  4785                 li a5,1
    d6ee:  a829                 j d708 <FUN_0000d69e+0x6a>
    d6f0:  fec42783           lw a5,-20(s0)
    d6f4:  2781                 sext.w a5,a5
    d6f6:  e399                 bnez a5,d6fc <FUN_0000d69e+0x5e>
    d6f8:  4789                 li a5,2
    d6fa:  a039                 j d708 <FUN_0000d69e+0x6a>
    d6fc:  fec42783           lw a5,-20(s0)
    d700:  37fd                 addiw a5,a5,-1
    d702:  fef42623           sw a5,-20(s0)
    d706:  b7f9                 j d6d4 <FUN_0000d69e+0x36>
    d708:  853e                 mv a0,a5
    d70a:  70a2                 ld ra,40(sp)
    d70c:  7402                 ld s0,32(sp)
    d70e:  6145                 addi sp,sp,48
    d710:  8082                 ret
000000000000d712 <FUN_0000d712>:
    d712:  1101                 addi sp,sp,-32
    d714:  ec06                 sd ra,24(sp)
    d716:  e822                 sd s0,16(sp)
    d718:  1000                 addi s0,sp,32
    d71a:  fe042623           sw zero,-20(s0)
    d71e:  fe042423           sw zero,-24(s0)
    d722:  e74fa0ef           jal ra,7d96 <FUN_00007d96>
    d726:  87aa                 mv a5,a0
    d728:  cf99                 beqz a5,d746 <FUN_0000d712+0x34>
    d72a:  070907b7           lui a5,0x7090
    d72e:  30878793           addi a5,a5,776 # 7090308 <gpio_get_boot_device+0x7081f72
    d732:  439c                 lw a5,0(a5)
    d734:  fef42623           sw a5,-20(s0)
    d738:  fec42783           lw a5,-20(s0)
    d73c:  0ff7f793           andi a5,a5,255
    d740:  fef42623           sw a5,-20(s0)
    d744:  a801                 j d754 <FUN_0000d712+0x42>
    d746:  0d000513           li a0,208
    d74a:  e1cfa0ef           jal ra,7d66 <sid_readl>
    d74e:  87aa                 mv a5,a0
    d750:  fef42623           sw a5,-20(s0)
    d754:  fec42783           lw a5,-20(s0)
    d758:  2781                 sext.w a5,a5
    d75a:  cb85                 beqz a5,d78a <FUN_0000d712+0x78>
    d75c:  a821                 j d774 <FUN_0000d712+0x62>
    d75e:  fe842783           lw a5,-24(s0)
    d762:  2785                 addiw a5,a5,1
    d764:  fef42423           sw a5,-24(s0)
    d768:  fec42783           lw a5,-20(s0)
    d76c:  0017d79b           srliw a5,a5,0x1
    d770:  fef42623           sw a5,-20(s0)
    d774:  fec42783           lw a5,-20(s0)
    d778:  2781                 sext.w a5,a5
    d77a:  f3f5                 bnez a5,d75e <FUN_0000d712+0x4c>
    d77c:  fe842783           lw a5,-24(s0)
    d780:  fef42623           sw a5,-20(s0)
    d784:  fec42783           lw a5,-20(s0)
    d788:  a011                 j d78c <FUN_0000d712+0x7a>
    d78a:  57fd                 li a5,-1
    d78c:  853e                 mv a0,a5
    d78e:  60e2                 ld ra,24(sp)
    d790:  6442                 ld s0,16(sp)
    d792:  6105                 addi sp,sp,32
    d794:  8082                 ret
000000000000d796 <FUN_0000d796>:
    d796:  7139                 addi sp,sp,-64
    d798:  fc06                 sd ra,56(sp)
    d79a:  f822                 sd s0,48(sp)
    d79c:  0080                 addi s0,sp,64
    d79e:  fca43c23           sd a0,-40(s0)
    d7a2:  fcb43823           sd a1,-48(s0)
    d7a6:  fcc43423           sd a2,-56(s0)
    d7aa:  fe043423           sd zero,-24(s0)
    d7ae:  fe043023           sd zero,-32(s0)
    d7b2:  67b9                 lui a5,0xe
    d7b4:  58078593           addi a1,a5,1408 # e580 <gpio_get_boot_device+0x1ea>
    d7b8:  fd043503           ld a0,-48(s0)
    d7bc:  e57fa0ef           jal ra,8612 <boot0_check_magic>
    d7c0:  87aa                 mv a5,a0
    d7c2:  ef8d                 bnez a5,d7fc <FUN_0000d796+0x66>
    d7c4:  fd043783           ld a5,-48(s0)
    d7c8:  fef43423           sd a5,-24(s0)
    d7cc:  fe843783           ld a5,-24(s0)
    d7d0:  4b98                 lw a4,16(a5)
    d7d2:  fc843783           ld a5,-56(s0)
    d7d6:  c398                 sw a4,0(a5)
    d7d8:  fe843783           ld a5,-24(s0)
    d7dc:  4b9c                 lw a5,16(a5)
    d7de:  1782                 slli a5,a5,0x20
    d7e0:  9381                 srli a5,a5,0x20
    d7e2:  fd043703           ld a4,-48(s0)
    d7e6:  973e                 add a4,a4,a5
    d7e8:  6785                 lui a5,0x1
    d7ea:  c0078613           addi a2,a5,-1024 # c00 <FUN_00000bbe+0x42>
    d7ee:  85ba                 mv a1,a4
    d7f0:  fd843503           ld a0,-40(s0)
    d7f4:  e96fc0ef           jal ra,9e8a <memcpy>
    d7f8:  4781                 li a5,0
    d7fa:  a825                 j d832 <FUN_0000d796+0x9c>
    d7fc:  fd043783           ld a5,-48(s0)
    d800:  fef43023           sd a5,-32(s0)
    d804:  fe043783           ld a5,-32(s0)
    d808:  4bd8                 lw a4,20(a5)
    d80a:  fc843783           ld a5,-56(s0)
    d80e:  c398                 sw a4,0(a5)
    d810:  fe043783           ld a5,-32(s0)
    d814:  4bdc                 lw a5,20(a5)
    d816:  1782                 slli a5,a5,0x20
    d818:  9381                 srli a5,a5,0x20
    d81a:  fd043703           ld a4,-48(s0)
    d81e:  973e                 add a4,a4,a5
    d820:  6785                 lui a5,0x1
    d822:  c0078613           addi a2,a5,-1024 # c00 <FUN_00000bbe+0x42>
    d826:  85ba                 mv a1,a4
    d828:  fd843503           ld a0,-40(s0)
    d82c:  e5efc0ef           jal ra,9e8a <memcpy>
    d830:  4781                 li a5,0
    d832:  853e                 mv a0,a5
    d834:  70e2                 ld ra,56(sp)
    d836:  7442                 ld s0,48(sp)
    d838:  6121                 addi sp,sp,64
    d83a:  8082                 ret
000000000000d83c <FUN_0000d83c>:
    d83c:  d8010113           addi sp,sp,-640
    d840:  26113c23           sd ra,632(sp)
    d844:  26813823           sd s0,624(sp)
    d848:  0500                 addi s0,sp,640
    d84a:  d8a43423           sd a0,-632(s0)
    d84e:  fe042623           sw zero,-20(s0)
    d852:  fe042423           sw zero,-24(s0)
    d856:  fe042223           sw zero,-28(s0)
    d85a:  fe042023           sw zero,-32(s0)
    d85e:  fc043c23           sd zero,-40(s0)
    d862:  fb840793           addi a5,s0,-72
    d866:  02000613           li a2,32
    d86a:  4581                 li a1,0
    d86c:  853e                 mv a0,a5
    d86e:  e7cfc0ef           jal ra,9eea <memset>
    d872:  d9840793           addi a5,s0,-616
    d876:  22000613           li a2,544
    d87a:  4581                 li a1,0
    d87c:  853e                 mv a0,a5
    d87e:  e6cfc0ef           jal ra,9eea <memset>
    d882:  d8843783           ld a5,-632(s0)
    d886:  4fdc                 lw a5,28(a5)
    d888:  0037d79b           srliw a5,a5,0x3
    d88c:  2781                 sext.w a5,a5
    d88e:  0017979b           slliw a5,a5,0x1
    d892:  2781                 sext.w a5,a5
    d894:  fef42223           sw a5,-28(s0)
    d898:  d9840793           addi a5,s0,-616
    d89c:  02000593           li a1,32
    d8a0:  853e                 mv a0,a5
    d8a2:  907f40ef           jal ra,21a8 <ALIGN>
    d8a6:  87aa                 mv a5,a0
    d8a8:  fcf43c23           sd a5,-40(s0)
    d8ac:  d8843783           ld a5,-632(s0)
    d8b0:  02c78713           addi a4,a5,44
    d8b4:  d8843783           ld a5,-632(s0)
    d8b8:  53dc                 lw a5,36(a5)
    d8ba:  863e                 mv a2,a5
    d8bc:  85ba                 mv a1,a4
    d8be:  fd843503           ld a0,-40(s0)
    d8c2:  dc8fc0ef           jal ra,9e8a <memcpy>
    d8c6:  d8843783           ld a5,-632(s0)
    d8ca:  53dc                 lw a5,36(a5)
    d8cc:  02079713           slli a4,a5,0x20
    d8d0:  9301                 srli a4,a4,0x20
    d8d2:  fd843783           ld a5,-40(s0)
    d8d6:  97ba                 add a5,a5,a4
    d8d8:  86be                 mv a3,a5
    d8da:  d8843783           ld a5,-632(s0)
    d8de:  12c78713           addi a4,a5,300
    d8e2:  d8843783           ld a5,-632(s0)
    d8e6:  579c                 lw a5,40(a5)
    d8e8:  863e                 mv a2,a5
    d8ea:  85ba                 mv a1,a4
    d8ec:  8536                 mv a0,a3
    d8ee:  d9cfc0ef           jal ra,9e8a <memcpy>
    d8f2:  d8843783           ld a5,-632(s0)
    d8f6:  53d8                 lw a4,36(a5)
    d8f8:  d8843783           ld a5,-632(s0)
    d8fc:  579c                 lw a5,40(a5)
    d8fe:  9fb9                 addw a5,a5,a4
    d900:  2781                 sext.w a5,a5
    d902:  fef42023           sw a5,-32(s0)
    d906:  fe042703           lw a4,-32(s0)
    d90a:  fe442783           lw a5,-28(s0)
    d90e:  2701                 sext.w a4,a4
    d910:  2781                 sext.w a5,a5
    d912:  00e7d863           bge a5,a4,d922 <FUN_0000d83c+0xe6>
    d916:  4591                 li a1,4
    d918:  4501                 li a0,0
    d91a:  92bfa0ef           jal ra,8244 <debug_state_save>
    d91e:  57fd                 li a5,-1
    d920:  a221                 j da28 <FUN_0000d83c+0x1ec>
    d922:  fe042703           lw a4,-32(s0)
    d926:  fd843783           ld a5,-40(s0)
    d92a:  97ba                 add a5,a5,a4
    d92c:  86be                 mv a3,a5
    d92e:  fe442703           lw a4,-28(s0)
    d932:  fe042783           lw a5,-32(s0)
    d936:  40f707bb           subw a5,a4,a5
    d93a:  2781                 sext.w a5,a5
    d93c:  2781                 sext.w a5,a5
    d93e:  863e                 mv a2,a5
    d940:  09100593           li a1,145
    d944:  8536                 mv a0,a3
    d946:  da4fc0ef           jal ra,9eea <memset>
    d94a:  fe442783           lw a5,-28(s0)
    d94e:  fb840693           addi a3,s0,-72
    d952:  02000713           li a4,32
    d956:  863e                 mv a2,a5
    d958:  fd843583           ld a1,-40(s0)
    d95c:  4505                 li a0,1
    d95e:  b70f30ef           jal ra,cce <sunxi_sha_calc>
    d962:  fe042623           sw zero,-20(s0)
    d966:  a81d                 j d99c <FUN_0000d83c+0x160>
    d968:  fec42703           lw a4,-20(s0)
    d96c:  00c027b7           lui a5,0xc02
    d970:  8487879b           addiw a5,a5,-1976
    d974:  9fb9                 addw a5,a5,a4
    d976:  2781                 sext.w a5,a5
    d978:  0027979b           slliw a5,a5,0x2
    d97c:  2781                 sext.w a5,a5
    d97e:  873e                 mv a4,a5
    d980:  fec42783           lw a5,-20(s0)
    d984:  078a                 slli a5,a5,0x2
    d986:  ff040693           addi a3,s0,-16
    d98a:  97b6                 add a5,a5,a3
    d98c:  fc87a783           lw a5,-56(a5) # c01fc8 <gpio_get_boot_device+0xbf3c32>
    d990:  c31c                 sw a5,0(a4)
    d992:  fec42783           lw a5,-20(s0)
    d996:  2785                 addiw a5,a5,1
    d998:  fef42623           sw a5,-20(s0)
    d99c:  fec42783           lw a5,-20(s0)
    d9a0:  0007871b           sext.w a4,a5
    d9a4:  479d                 li a5,7
    d9a6:  fce7d1e3           bge a5,a4,d968 <FUN_0000d83c+0x12c>
    d9aa:  030067b7           lui a5,0x3006
    d9ae:  14078793           addi a5,a5,320 # 3006140 <gpio_get_boot_device+0x2ff7daa
    d9b2:  439c                 lw a5,0(a5)
    d9b4:  fef42423           sw a5,-24(s0)
    d9b8:  fe842703           lw a4,-24(s0)
    d9bc:  800007b7           lui a5,0x80000
    d9c0:  8fd9                 or a5,a5,a4
    d9c2:  fef42423           sw a5,-24(s0)
    d9c6:  030067b7           lui a5,0x3006
    d9ca:  14078793           addi a5,a5,320 # 3006140 <gpio_get_boot_device+0x2ff7daa
    d9ce:  fe842703           lw a4,-24(s0)
    d9d2:  c398                 sw a4,0(a5)
    d9d4:  fe042623           sw zero,-20(s0)
    d9d8:  a031                 j d9e4 <FUN_0000d83c+0x1a8>
    d9da:  fec42783           lw a5,-20(s0)
    d9de:  2785                 addiw a5,a5,1
    d9e0:  fef42623           sw a5,-20(s0)
    d9e4:  fec42783           lw a5,-20(s0)
    d9e8:  0007871b           sext.w a4,a5
    d9ec:  0ff00793           li a5,255
    d9f0:  fee7d5e3           bge a5,a4,d9da <FUN_0000d83c+0x19e>
    d9f4:  030067b7           lui a5,0x3006
    d9f8:  14078793           addi a5,a5,320 # 3006140 <gpio_get_boot_device+0x2ff7daa
    d9fc:  439c                 lw a5,0(a5)
    d9fe:  fef42423           sw a5,-24(s0)
    da02:  fe842783           lw a5,-24(s0)
    da06:  8b89                 andi a5,a5,2
    da08:  2781                 sext.w a5,a5
    da0a:  cb91                 beqz a5,da1e <FUN_0000d83c+0x1e2>
    da0c:  fe842783           lw a5,-24(s0)
    da10:  8b85                 andi a5,a5,1
    da12:  2781                 sext.w a5,a5
    da14:  c399                 beqz a5,da1a <FUN_0000d83c+0x1de>
    da16:  4781                 li a5,0
    da18:  a801                 j da28 <FUN_0000d83c+0x1ec>
    da1a:  57fd                 li a5,-1
    da1c:  a031                 j da28 <FUN_0000d83c+0x1ec>
    da1e:  4595                 li a1,5
    da20:  4501                 li a0,0
    da22:  823fa0ef           jal ra,8244 <debug_state_save>
    da26:  4781                 li a5,0
    da28:  853e                 mv a0,a5
    da2a:  27813083           ld ra,632(sp)
    da2e:  27013403           ld s0,624(sp)
    da32:  28010113           addi sp,sp,640
    da36:  8082                 ret
000000000000da38 <FUN_0000da38>:
    da38:  81010113           addi sp,sp,-2032
    da3c:  7e113423           sd ra,2024(sp)
    da40:  7e813023           sd s0,2016(sp)
    da44:  7f010413           addi s0,sp,2032
    da48:  b6010113           addi sp,sp,-1184
    da4c:  77fd                 lui a5,0xfffff
    da4e:  ff040713           addi a4,s0,-16
    da52:  97ba                 add a5,a5,a4
    da54:  38a7b423           sd a0,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    da58:  fe043423           sd zero,-24(s0)
    da5c:  fe042223           sw zero,-28(s0)
    da60:  77fd                 lui a5,0xfffff
    da62:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    da66:  ff040713           addi a4,s0,-16
    da6a:  973e                 add a4,a4,a5
    da6c:  6785                 lui a5,0x1
    da6e:  c2078613           addi a2,a5,-992 # c20 <FUN_00000bbe+0x62>
    da72:  4581                 li a1,0
    da74:  853a                 mv a0,a4
    da76:  c74fc0ef           jal ra,9eea <memset>
    da7a:  77fd                 lui a5,0xfffff
    da7c:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    da80:  ff040713           addi a4,s0,-16
    da84:  97ba                 add a5,a5,a4
    da86:  02000613           li a2,32
    da8a:  4581                 li a1,0
    da8c:  853e                 mv a0,a5
    da8e:  c5cfc0ef           jal ra,9eea <memset>
    da92:  77fd                 lui a5,0xfffff
    da94:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    da98:  ff040713           addi a4,s0,-16
    da9c:  97ba                 add a5,a5,a4
    da9e:  02000613           li a2,32
    daa2:  4581                 li a1,0
    daa4:  853e                 mv a0,a5
    daa6:  c44fc0ef           jal ra,9eea <memset>
    daaa:  77fd                 lui a5,0xfffff
    daac:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    dab0:  ff040713           addi a4,s0,-16
    dab4:  97ba                 add a5,a5,a4
    dab6:  02000593           li a1,32
    daba:  853e                 mv a0,a5
    dabc:  eecf40ef           jal ra,21a8 <ALIGN>
    dac0:  87aa                 mv a5,a0
    dac2:  fef43423           sd a5,-24(s0)
    dac6:  77fd                 lui a5,0xfffff
    dac8:  ff040713           addi a4,s0,-16
    dacc:  97ba                 add a5,a5,a4
    dace:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    dad2:  47d8                 lw a4,12(a5)
    dad4:  77fd                 lui a5,0xfffff
    dad6:  ff040693           addi a3,s0,-16
    dada:  97b6                 add a5,a5,a3
    dadc:  863a                 mv a2,a4
    dade:  3887b583           ld a1,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    dae2:  fe843503           ld a0,-24(s0)
    dae6:  ba4fc0ef           jal ra,9e8a <memcpy>
    daea:  77fd                 lui a5,0xfffff
    daec:  ff040713           addi a4,s0,-16
    daf0:  97ba                 add a5,a5,a4
    daf2:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    daf6:  47d0                 lw a2,12(a5)
    daf8:  77fd                 lui a5,0xfffff
    dafa:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    dafe:  ff040713           addi a4,s0,-16
    db02:  97ba                 add a5,a5,a4
    db04:  02000713           li a4,32
    db08:  86be                 mv a3,a5
    db0a:  fe843583           ld a1,-24(s0)
    db0e:  4505                 li a0,1
    db10:  9bef30ef           jal ra,cce <sunxi_sha_calc>
    db14:  77fd                 lui a5,0xfffff
    db16:  ff040713           addi a4,s0,-16
    db1a:  97ba                 add a5,a5,a4
    db1c:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    db20:  4fc8                 lw a0,28(a5)
    db22:  77fd                 lui a5,0xfffff
    db24:  ff040713           addi a4,s0,-16
    db28:  97ba                 add a5,a5,a4
    db2a:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    db2e:  12c78593           addi a1,a5,300
    db32:  77fd                 lui a5,0xfffff
    db34:  ff040713           addi a4,s0,-16
    db38:  97ba                 add a5,a5,a4
    db3a:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    db3e:  5790                 lw a2,40(a5)
    db40:  77fd                 lui a5,0xfffff
    db42:  ff040713           addi a4,s0,-16
    db46:  97ba                 add a5,a5,a4
    db48:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    db4c:  37878693           addi a3,a5,888
    db50:  77fd                 lui a5,0xfffff
    db52:  ff040713           addi a4,s0,-16
    db56:  97ba                 add a5,a5,a4
    db58:  3887b783           ld a5,904(a5) # fffffffffffff388 <gpio_get_boot_device+0
    db5c:  02c78713           addi a4,a5,44
    db60:  77fd                 lui a5,0xfffff
    db62:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    db66:  ff040813           addi a6,s0,-16
    db6a:  97c2                 add a5,a5,a6
    db6c:  88ba                 mv a7,a4
    db6e:  02000813           li a6,32
    db72:  10000713           li a4,256
    db76:  bb6f30ef           jal ra,f2c <FUN_00000f2c>
    db7a:  77fd                 lui a5,0xfffff
    db7c:  39078793           addi a5,a5,912 # fffffffffffff390 <gpio_get_boot_device+
    db80:  ff040713           addi a4,s0,-16
    db84:  973e                 add a4,a4,a5
    db86:  77fd                 lui a5,0xfffff
    db88:  3b078793           addi a5,a5,944 # fffffffffffff3b0 <gpio_get_boot_device+
    db8c:  ff040693           addi a3,s0,-16
    db90:  97b6                 add a5,a5,a3
    db92:  02000613           li a2,32
    db96:  85ba                 mv a1,a4
    db98:  853e                 mv a0,a5
    db9a:  d08fc0ef           jal ra,a0a2 <FUN_0000a0a2>
    db9e:  87aa                 mv a5,a0
    dba0:  fef42223           sw a5,-28(s0)
    dba4:  fe442783           lw a5,-28(s0)
    dba8:  2781                 sext.w a5,a5
    dbaa:  e399                 bnez a5,dbb0 <FUN_0000da38+0x178>
    dbac:  4781                 li a5,0
    dbae:  a011                 j dbb2 <FUN_0000da38+0x17a>
    dbb0:  57fd                 li a5,-1
    dbb2:  853e                 mv a0,a5
    dbb4:  4a010113           addi sp,sp,1184
    dbb8:  7e813083           ld ra,2024(sp)
    dbbc:  7e013403           ld s0,2016(sp)
    dbc0:  7f010113           addi sp,sp,2032
    dbc4:  8082                 ret
000000000000dbc6 <FUN_0000dbc6>:
    dbc6:  7179                 addi sp,sp,-48
    dbc8:  f406                 sd ra,40(sp)
    dbca:  f022                 sd s0,32(sp)
    dbcc:  1800                 addi s0,sp,48
    dbce:  fca43c23           sd a0,-40(s0)
    dbd2:  fe043423           sd zero,-24(s0)
    dbd6:  fe042223           sw zero,-28(s0)
    dbda:  fd843783           ld a5,-40(s0)
    dbde:  e399                 bnez a5,dbe4 <FUN_0000dbc6+0x1e>
    dbe0:  57fd                 li a5,-1
    dbe2:  a041                 j dc62 <FUN_0000dbc6+0x9c>
    dbe4:  fd843783           ld a5,-40(s0)
    dbe8:  fef43423           sd a5,-24(s0)
    dbec:  fe843703           ld a4,-24(s0)
    dbf0:  4621                 li a2,8
    dbf2:  67b9                 lui a5,0xe
    dbf4:  59078593           addi a1,a5,1424 # e590 <gpio_get_boot_device+0x1fa>
    dbf8:  853a                 mv a0,a4
    dbfa:  d0efc0ef           jal ra,a108 <strncmp>
    dbfe:  87aa                 mv a5,a0
    dc00:  fef42223           sw a5,-28(s0)
    dc04:  fe442783           lw a5,-28(s0)
    dc08:  2781                 sext.w a5,a5
    dc0a:  c799                 beqz a5,dc18 <FUN_0000dbc6+0x52>
    dc0c:  4589                 li a1,2
    dc0e:  4501                 li a0,0
    dc10:  e34fa0ef           jal ra,8244 <debug_state_save>
    dc14:  57fd                 li a5,-1
    dc16:  a0b1                 j dc62 <FUN_0000dbc6+0x9c>
    dc18:  fd843503           ld a0,-40(s0)
    dc1c:  c21ff0ef           jal ra,d83c <FUN_0000d83c>
    dc20:  87aa                 mv a5,a0
    dc22:  fef42223           sw a5,-28(s0)
    dc26:  fe442783           lw a5,-28(s0)
    dc2a:  2781                 sext.w a5,a5
    dc2c:  0007d863           bgez a5,dc3c <FUN_0000dbc6+0x76>
    dc30:  4599                 li a1,6
    dc32:  4501                 li a0,0
    dc34:  e10fa0ef           jal ra,8244 <debug_state_save>
    dc38:  57fd                 li a5,-1
    dc3a:  a025                 j dc62 <FUN_0000dbc6+0x9c>
    dc3c:  fd843503           ld a0,-40(s0)
    dc40:  df9ff0ef           jal ra,da38 <FUN_0000da38>
    dc44:  87aa                 mv a5,a0
    dc46:  fef42223           sw a5,-28(s0)
    dc4a:  fe442783           lw a5,-28(s0)
    dc4e:  2781                 sext.w a5,a5
    dc50:  0007d863           bgez a5,dc60 <FUN_0000dbc6+0x9a>
    dc54:  459d                 li a1,7
    dc56:  4501                 li a0,0
    dc58:  decfa0ef           jal ra,8244 <debug_state_save>
    dc5c:  57fd                 li a5,-1
    dc5e:  a011                 j dc62 <FUN_0000dbc6+0x9c>
    dc60:  4781                 li a5,0
    dc62:  853e                 mv a0,a5
    dc64:  70a2                 ld ra,40(sp)
    dc66:  7402                 ld s0,32(sp)
    dc68:  6145                 addi sp,sp,48
    dc6a:  8082                 ret
000000000000dc6c <FUN_0000dc6c>:
    dc6c:  7119                 addi sp,sp,-128
    dc6e:  fc86                 sd ra,120(sp)
    dc70:  f8a2                 sd s0,112(sp)
    dc72:  0100                 addi s0,sp,128
    dc74:  f8a43c23           sd a0,-104(s0)
    dc78:  87ae                 mv a5,a1
    dc7a:  f8c43423           sd a2,-120(s0)
    dc7e:  f8f42a23           sw a5,-108(s0)
    dc82:  fe043423           sd zero,-24(s0)
    dc86:  fe042223           sw zero,-28(s0)
    dc8a:  f9843783           ld a5,-104(s0)
    dc8e:  8bbd                 andi a5,a5,15
    dc90:  c399                 beqz a5,dc96 <FUN_0000dc6c+0x2a>
    dc92:  57fd                 li a5,-1
    dc94:  a0ad                 j dcfe <FUN_0000dc6c+0x92>
    dc96:  f9442783           lw a5,-108(s0)
    dc9a:  2781                 sext.w a5,a5
    dc9c:  e399                 bnez a5,dca2 <FUN_0000dc6c+0x36>
    dc9e:  57fd                 li a5,-1
    dca0:  a8b9                 j dcfe <FUN_0000dc6c+0x92>
    dca2:  fa040793           addi a5,s0,-96
    dca6:  04000613           li a2,64
    dcaa:  4581                 li a1,0
    dcac:  853e                 mv a0,a5
    dcae:  a3cfc0ef           jal ra,9eea <memset>
    dcb2:  fa040693           addi a3,s0,-96
    dcb6:  f9442783           lw a5,-108(s0)
    dcba:  02000713           li a4,32
    dcbe:  863e                 mv a2,a5
    dcc0:  f9843583           ld a1,-104(s0)
    dcc4:  4505                 li a0,1
    dcc6:  808f30ef           jal ra,cce <sunxi_sha_calc>
    dcca:  f8843783           ld a5,-120(s0)
    dcce:  fef43423           sd a5,-24(s0)
    dcd2:  fe843783           ld a5,-24(s0)
    dcd6:  22c78713           addi a4,a5,556
    dcda:  fa040793           addi a5,s0,-96
    dcde:  02000613           li a2,32
    dce2:  85ba                 mv a1,a4
    dce4:  853e                 mv a0,a5
    dce6:  bbcfc0ef           jal ra,a0a2 <FUN_0000a0a2>
    dcea:  87aa                 mv a5,a0
    dcec:  fef42223           sw a5,-28(s0)
    dcf0:  fe442783           lw a5,-28(s0)
    dcf4:  2781                 sext.w a5,a5
    dcf6:  e399                 bnez a5,dcfc <FUN_0000dc6c+0x90>
    dcf8:  4781                 li a5,0
    dcfa:  a011                 j dcfe <FUN_0000dc6c+0x92>
    dcfc:  57fd                 li a5,-1
    dcfe:  853e                 mv a0,a5
    dd00:  70e6                 ld ra,120(sp)
    dd02:  7446                 ld s0,112(sp)
    dd04:  6109                 addi sp,sp,128
    dd06:  8082                 ret
000000000000dd08 <FUN_0000dd08>:
    dd08:  7179                 addi sp,sp,-48
    dd0a:  f406                 sd ra,40(sp)
    dd0c:  f022                 sd s0,32(sp)
    dd0e:  1800                 addi s0,sp,48
    dd10:  fca43c23           sd a0,-40(s0)
    dd14:  fe042623           sw zero,-20(s0)
    dd18:  9fbff0ef           jal ra,d712 <FUN_0000d712>
    dd1c:  87aa                 mv a5,a0
    dd1e:  fef42623           sw a5,-20(s0)
    dd22:  fec42783           lw a5,-20(s0)
    dd26:  2781                 sext.w a5,a5
    dd28:  0007d863           bgez a5,dd38 <FUN_0000dd08+0x30>
    dd2c:  4585                 li a1,1
    dd2e:  4501                 li a0,0
    dd30:  d14fa0ef           jal ra,8244 <debug_state_save>
    dd34:  4781                 li a5,0
    dd36:  a839                 j dd54 <FUN_0000dd08+0x4c>
    dd38:  fd843783           ld a5,-40(s0)
    dd3c:  fef43023           sd a5,-32(s0)
    dd40:  fe043783           ld a5,-32(s0)
    dd44:  4f98                 lw a4,24(a5)
    dd46:  fec42783           lw a5,-20(s0)
    dd4a:  00f76463           bltu a4,a5,dd52 <FUN_0000dd08+0x4a>
    dd4e:  4781                 li a5,0
    dd50:  a011                 j dd54 <FUN_0000dd08+0x4c>
    dd52:  57fd                 li a5,-1
    dd54:  853e                 mv a0,a5
    dd56:  70a2                 ld ra,40(sp)
    dd58:  7402                 ld s0,32(sp)
    dd5a:  6145                 addi sp,sp,48
    dd5c:  8082                 ret
000000000000dd5e <FUN_0000dd5e>:
    dd5e:  81010113           addi sp,sp,-2032
    dd62:  7e113423           sd ra,2024(sp)
    dd66:  7e813023           sd s0,2016(sp)
    dd6a:  7f010413           addi s0,sp,2032
    dd6e:  b9010113           addi sp,sp,-1136
    dd72:  77fd                 lui a5,0xfffff
    dd74:  ff040713           addi a4,s0,-16
    dd78:  97ba                 add a5,a5,a4
    dd7a:  3aa7bc23           sd a0,952(a5) # fffffffffffff3b8 <gpio_get_boot_device+0
    dd7e:  77fd                 lui a5,0xfffff
    dd80:  ff040713           addi a4,s0,-16
    dd84:  97ba                 add a5,a5,a4
    dd86:  3ab7b823           sd a1,944(a5) # fffffffffffff3b0 <gpio_get_boot_device+0
    dd8a:  fe043423           sd zero,-24(s0)
    dd8e:  fe042223           sw zero,-28(s0)
    dd92:  77fd                 lui a5,0xfffff
    dd94:  ff040713           addi a4,s0,-16
    dd98:  97ba                 add a5,a5,a4
    dd9a:  3c07a623           sw zero,972(a5) # fffffffffffff3cc <gpio_get_boot_device
    dd9e:  77fd                 lui a5,0xfffff
    dda0:  ff040713           addi a4,s0,-16
    dda4:  97ba                 add a5,a5,a4
    dda6:  3b07b783           ld a5,944(a5) # fffffffffffff3b0 <gpio_get_boot_device+0
    ddaa:  e799                 bnez a5,ddb8 <FUN_0000dd5e+0x5a>
    ddac:  4585                 li a1,1
    ddae:  4501                 li a0,0
    ddb0:  c94fa0ef           jal ra,8244 <debug_state_save>
    ddb4:  4781                 li a5,0
    ddb6:  a8dd                 j deac <FUN_0000dd5e+0x14e>
    ddb8:  77fd                 lui a5,0xfffff
    ddba:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    ddbe:  ff040713           addi a4,s0,-16
    ddc2:  973e                 add a4,a4,a5
    ddc4:  6785                 lui a5,0x1
    ddc6:  c2078613           addi a2,a5,-992 # c20 <FUN_00000bbe+0x62>
    ddca:  4581                 li a1,0
    ddcc:  853a                 mv a0,a4
    ddce:  91cfc0ef           jal ra,9eea <memset>
    ddd2:  77fd                 lui a5,0xfffff
    ddd4:  3d078793           addi a5,a5,976 # fffffffffffff3d0 <gpio_get_boot_device+
    ddd8:  ff040713           addi a4,s0,-16
    dddc:  97ba                 add a5,a5,a4
    ddde:  07bd                 addi a5,a5,15
    dde0:  9bc1                 andi a5,a5,-16
    dde2:  fef43423           sd a5,-24(s0)
    dde6:  fe843703           ld a4,-24(s0)
    ddea:  77fd                 lui a5,0xfffff
    ddec:  3cc78793           addi a5,a5,972 # fffffffffffff3cc <gpio_get_boot_device+
    ddf0:  ff040693           addi a3,s0,-16
    ddf4:  96be                 add a3,a3,a5
    ddf6:  77fd                 lui a5,0xfffff
    ddf8:  ff040613           addi a2,s0,-16
    ddfc:  97b2                 add a5,a5,a2
    ddfe:  8636                 mv a2,a3
    de00:  3b07b583           ld a1,944(a5) # fffffffffffff3b0 <gpio_get_boot_device+0
    de04:  853a                 mv a0,a4
    de06:  991ff0ef           jal ra,d796 <FUN_0000d796>
    de0a:  87aa                 mv a5,a0
    de0c:  fef42223           sw a5,-28(s0)
    de10:  fe442783           lw a5,-28(s0)
    de14:  2781                 sext.w a5,a5
    de16:  0007d863           bgez a5,de26 <FUN_0000dd5e+0xc8>
    de1a:  4589                 li a1,2
    de1c:  4501                 li a0,0
    de1e:  c26fa0ef           jal ra,8244 <debug_state_save>
    de22:  4781                 li a5,0
    de24:  a061                 j deac <FUN_0000dd5e+0x14e>
    de26:  fe843783           ld a5,-24(s0)
    de2a:  853e                 mv a0,a5
    de2c:  d9bff0ef           jal ra,dbc6 <FUN_0000dbc6>
    de30:  87aa                 mv a5,a0
    de32:  fef42223           sw a5,-28(s0)
    de36:  fe442783           lw a5,-28(s0)
    de3a:  2781                 sext.w a5,a5
    de3c:  0007d463           bgez a5,de44 <FUN_0000dd5e+0xe6>
    de40:  4781                 li a5,0
    de42:  a0ad                 j deac <FUN_0000dd5e+0x14e>
    de44:  fe843783           ld a5,-24(s0)
    de48:  853e                 mv a0,a5
    de4a:  ebfff0ef           jal ra,dd08 <FUN_0000dd08>
    de4e:  87aa                 mv a5,a0
    de50:  fef42223           sw a5,-28(s0)
    de54:  fe442783           lw a5,-28(s0)
    de58:  2781                 sext.w a5,a5
    de5a:  0007d863           bgez a5,de6a <FUN_0000dd5e+0x10c>
    de5e:  45a1                 li a1,8
    de60:  4501                 li a0,0
    de62:  be2fa0ef           jal ra,8244 <debug_state_save>
    de66:  4781                 li a5,0
    de68:  a091                 j deac <FUN_0000dd5e+0x14e>
    de6a:  77fd                 lui a5,0xfffff
    de6c:  ff040713           addi a4,s0,-16
    de70:  97ba                 add a5,a5,a4
    de72:  3cc7a703           lw a4,972(a5) # fffffffffffff3cc <gpio_get_boot_device+0
    de76:  fe843683           ld a3,-24(s0)
    de7a:  77fd                 lui a5,0xfffff
    de7c:  ff040613           addi a2,s0,-16
    de80:  97b2                 add a5,a5,a2
    de82:  8636                 mv a2,a3
    de84:  85ba                 mv a1,a4
    de86:  3b07b503           ld a0,944(a5) # fffffffffffff3b0 <gpio_get_boot_device+0
    de8a:  de3ff0ef           jal ra,dc6c <FUN_0000dc6c>
    de8e:  87aa                 mv a5,a0
    de90:  fef42223           sw a5,-28(s0)
    de94:  fe442783           lw a5,-28(s0)
    de98:  2781                 sext.w a5,a5
    de9a:  0007d863           bgez a5,deaa <FUN_0000dd5e+0x14c>
    de9e:  45a5                 li a1,9
    dea0:  4501                 li a0,0
    dea2:  ba2fa0ef           jal ra,8244 <debug_state_save>
    dea6:  4781                 li a5,0
    dea8:  a011                 j deac <FUN_0000dd5e+0x14e>
    deaa:  4785                 li a5,1
    deac:  853e                 mv a0,a5
    deae:  47010113           addi sp,sp,1136
    deb2:  7e813083           ld ra,2024(sp)
    deb6:  7e013403           ld s0,2016(sp)
    deba:  7f010113           addi sp,sp,2032
    debe:  8082                 ret
000000000000dec0 <FUN_0000dec0>:
    dec0:  7179                 addi sp,sp,-48
    dec2:  f406                 sd ra,40(sp)
    dec4:  f022                 sd s0,32(sp)
    dec6:  1800                 addi s0,sp,48
    dec8:  fca43c23           sd a0,-40(s0)
    decc:  87ae                 mv a5,a1
    dece:  fcf42a23           sw a5,-44(s0)
    ded2:  fd446783           lwu a5,-44(s0)
    ded6:  fd843703           ld a4,-40(s0)
    deda:  97ba                 add a5,a5,a4
    dedc:  fef43423           sd a5,-24(s0)
    dee0:  a821                 j def8 <FUN_0000dec0+0x38>
    dee2:  fd843783           ld a5,-40(s0)
    dee6:  853e                 mv a0,a5
    dee8:  b62f30ef           jal ra,124a <FUN_0000124a>
    deec:  fd843783           ld a5,-40(s0)
    def0:  02078793           addi a5,a5,32
    def4:  fcf43c23           sd a5,-40(s0)
    def8:  fd843703           ld a4,-40(s0)
    defc:  fe843783           ld a5,-24(s0)
    df00:  fef761e3           bltu a4,a5,dee2 <FUN_0000dec0+0x22>
    df04:  000487b7           lui a5,0x48
    df08:  d0078823           sb zero,-752(a5) # 47d10 <gpio_get_boot_device+0x3997a>
    df0c:  0001                 nop
    df0e:  70a2                 ld ra,40(sp)
    df10:  7402                 ld s0,32(sp)
    df12:  6145                 addi sp,sp,48
    df14:  8082                 ret
000000000000df16 <FUN_0000df16>:
    df16:  c5010113           addi sp,sp,-944
    df1a:  3a113423           sd ra,936(sp)
    df1e:  3a813023           sd s0,928(sp)
    df22:  1f00                 addi s0,sp,944
    df24:  c4a43c23           sd a0,-936(s0)
    df28:  fe043423           sd zero,-24(s0)
    df2c:  fe042223           sw zero,-28(s0)
    df30:  fe042023           sw zero,-32(s0)
    df34:  fc042e23           sw zero,-36(s0)
    df38:  000487b7           lui a5,0x48
    df3c:  d1078793           addi a5,a5,-752 # 47d10 <gpio_get_boot_device+0x3997a>
    df40:  fcf43823           sd a5,-48(s0)
    df44:  c5843783           ld a5,-936(s0)
    df48:  fcf43423           sd a5,-56(s0)
    df4c:  fc843703           ld a4,-56(s0)
    df50:  4621                 li a2,8
    df52:  67b9                 lui a5,0xe
    df54:  59078593           addi a1,a5,1424 # e590 <gpio_get_boot_device+0x1fa>
    df58:  853a                 mv a0,a4
    df5a:  9aefc0ef           jal ra,a108 <strncmp>
    df5e:  87aa                 mv a5,a0
    df60:  fcf42e23           sw a5,-36(s0)
    df64:  fdc42783           lw a5,-36(s0)
    df68:  2781                 sext.w a5,a5
    df6a:  c799                 beqz a5,df78 <FUN_0000df16+0x62>
    df6c:  45a9                 li a1,10
    df6e:  4501                 li a0,0
    df70:  ad4fa0ef           jal ra,8244 <debug_state_save>
    df74:  4785                 li a5,1
    df76:  a271                 j e102 <FUN_0000df16+0x1ec>
    df78:  fa840793           addi a5,s0,-88
    df7c:  02000613           li a2,32
    df80:  4581                 li a1,0
    df82:  853e                 mv a0,a5
    df84:  f67fb0ef           jal ra,9eea <memset>
    df88:  d6840793           addi a5,s0,-664
    df8c:  24000613           li a2,576
    df90:  4581                 li a1,0
    df92:  853e                 mv a0,a5
    df94:  f57fb0ef           jal ra,9eea <memset>
    df98:  fc843783           ld a5,-56(s0)
    df9c:  4fdc                 lw a5,28(a5)
    df9e:  0037d79b           srliw a5,a5,0x3
    dfa2:  2781                 sext.w a5,a5
    dfa4:  0017979b           slliw a5,a5,0x1
    dfa8:  2781                 sext.w a5,a5
    dfaa:  fef42223           sw a5,-28(s0)
    dfae:  d6840793           addi a5,s0,-664
    dfb2:  02000593           li a1,32
    dfb6:  853e                 mv a0,a5
    dfb8:  9f0f40ef           jal ra,21a8 <ALIGN>
    dfbc:  87aa                 mv a5,a0
    dfbe:  fef43423           sd a5,-24(s0)
    dfc2:  fc843783           ld a5,-56(s0)
    dfc6:  02c78713           addi a4,a5,44
    dfca:  fc843783           ld a5,-56(s0)
    dfce:  53dc                 lw a5,36(a5)
    dfd0:  863e                 mv a2,a5
    dfd2:  85ba                 mv a1,a4
    dfd4:  fe843503           ld a0,-24(s0)
    dfd8:  eb3fb0ef           jal ra,9e8a <memcpy>
    dfdc:  fc843783           ld a5,-56(s0)
    dfe0:  53dc                 lw a5,36(a5)
    dfe2:  02079713           slli a4,a5,0x20
    dfe6:  9301                 srli a4,a4,0x20
    dfe8:  fe843783           ld a5,-24(s0)
    dfec:  97ba                 add a5,a5,a4
    dfee:  86be                 mv a3,a5
    dff0:  fc843783           ld a5,-56(s0)
    dff4:  12c78713           addi a4,a5,300
    dff8:  fc843783           ld a5,-56(s0)
    dffc:  579c                 lw a5,40(a5)
    dffe:  863e                 mv a2,a5
    e000:  85ba                 mv a1,a4
    e002:  8536                 mv a0,a3
    e004:  e87fb0ef           jal ra,9e8a <memcpy>
    e008:  fc843783           ld a5,-56(s0)
    e00c:  53d8                 lw a4,36(a5)
    e00e:  fc843783           ld a5,-56(s0)
    e012:  579c                 lw a5,40(a5)
    e014:  9fb9                 addw a5,a5,a4
    e016:  2781                 sext.w a5,a5
    e018:  fef42023           sw a5,-32(s0)
    e01c:  fe042703           lw a4,-32(s0)
    e020:  fe843783           ld a5,-24(s0)
    e024:  97ba                 add a5,a5,a4
    e026:  86be                 mv a3,a5
    e028:  fe442703           lw a4,-28(s0)
    e02c:  fe042783           lw a5,-32(s0)
    e030:  40f707bb           subw a5,a4,a5
    e034:  2781                 sext.w a5,a5
    e036:  2781                 sext.w a5,a5
    e038:  863e                 mv a2,a5
    e03a:  09100593           li a1,145
    e03e:  8536                 mv a0,a3
    e040:  eabfb0ef           jal ra,9eea <memset>
    e044:  fe442783           lw a5,-28(s0)
    e048:  fa840693           addi a3,s0,-88
    e04c:  02000713           li a4,32
    e050:  863e                 mv a2,a5
    e052:  fe843583           ld a1,-24(s0)
    e056:  4505                 li a0,1
    e058:  c77f20ef           jal ra,cce <sunxi_sha_calc>
    e05c:  fa840713           addi a4,s0,-88
    e060:  02000613           li a2,32
    e064:  67b9                 lui a5,0xe
    e066:  5a078593           addi a1,a5,1440 # e5a0 <gpio_get_boot_device+0x20a>
    e06a:  853a                 mv a0,a4
    e06c:  836fc0ef           jal ra,a0a2 <FUN_0000a0a2>
    e070:  87aa                 mv a5,a0
    e072:  fcf42e23           sw a5,-36(s0)
    e076:  fdc42783           lw a5,-36(s0)
    e07a:  2781                 sext.w a5,a5
    e07c:  c799                 beqz a5,e08a <FUN_0000df16+0x174>
    e07e:  45ad                 li a1,11
    e080:  4501                 li a0,0
    e082:  9c2fa0ef           jal ra,8244 <debug_state_save>
    e086:  4785                 li a5,1
    e088:  a8ad                 j e102 <FUN_0000df16+0x1ec>
    e08a:  c6840793           addi a5,s0,-920
    e08e:  02000613           li a2,32
    e092:  4581                 li a1,0
    e094:  853e                 mv a0,a5
    e096:  e55fb0ef           jal ra,9eea <memset>
    e09a:  fc843783           ld a5,-56(s0)
    e09e:  4fc8                 lw a0,28(a5)
    e0a0:  fc843783           ld a5,-56(s0)
    e0a4:  12c78593           addi a1,a5,300
    e0a8:  fc843783           ld a5,-56(s0)
    e0ac:  5790                 lw a2,40(a5)
    e0ae:  fc843783           ld a5,-56(s0)
    e0b2:  37878693           addi a3,a5,888
    e0b6:  fc843783           ld a5,-56(s0)
    e0ba:  53d8                 lw a4,36(a5)
    e0bc:  fc843783           ld a5,-56(s0)
    e0c0:  02c78813           addi a6,a5,44
    e0c4:  c6840793           addi a5,s0,-920
    e0c8:  88c2                 mv a7,a6
    e0ca:  883a                 mv a6,a4
    e0cc:  10000713           li a4,256
    e0d0:  e5df20ef           jal ra,f2c <FUN_00000f2c>
    e0d4:  c6840793           addi a5,s0,-920
    e0d8:  10000613           li a2,256
    e0dc:  85be                 mv a1,a5
    e0de:  fd043503           ld a0,-48(s0)
    e0e2:  fc1fb0ef           jal ra,a0a2 <FUN_0000a0a2>
    e0e6:  87aa                 mv a5,a0
    e0e8:  fcf42e23           sw a5,-36(s0)
    e0ec:  fdc42783           lw a5,-36(s0)
    e0f0:  2781                 sext.w a5,a5
    e0f2:  c799                 beqz a5,e100 <FUN_0000df16+0x1ea>
    e0f4:  45b1                 li a1,12
    e0f6:  4501                 li a0,0
    e0f8:  94cfa0ef           jal ra,8244 <debug_state_save>
    e0fc:  4785                 li a5,1
    e0fe:  a011                 j e102 <FUN_0000df16+0x1ec>
    e100:  4781                 li a5,0
    e102:  853e                 mv a0,a5
    e104:  3a813083           ld ra,936(sp)
    e108:  3a013403           ld s0,928(sp)
    e10c:  3b010113           addi sp,sp,944
    e110:  8082                 ret
000000000000e112 <usb_bgr_disable>:
    e112:  1101                 addi sp,sp,-32
    e114:  ec22                 sd s0,24(sp)
    e116:  1000                 addi s0,sp,32
    e118:  fe042623           sw zero,-20(s0)
    e11c:  020027b7           lui a5,0x2002
    e120:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e124:  439c                 lw a5,0(a5)
    e126:  fef42623           sw a5,-20(s0)
    e12a:  fec42703           lw a4,-20(s0)
    e12e:  ff0007b7           lui a5,0xff000
    e132:  eff78793           addi a5,a5,-257 # fffffffffefffeff <gpio_get_boot_device
    e136:  8ff9                 and a5,a5,a4
    e138:  fef42623           sw a5,-20(s0)
    e13c:  020027b7           lui a5,0x2002
    e140:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e144:  fec42703           lw a4,-20(s0)
    e148:  c398                 sw a4,0(a5)
    e14a:  0001                 nop
    e14c:  6462                 ld s0,24(sp)
    e14e:  6105                 addi sp,sp,32
    e150:  8082                 ret
000000000000e152 <usb_bgr_enable>:
    e152:  1101                 addi sp,sp,-32
    e154:  ec06                 sd ra,24(sp)
    e156:  e822                 sd s0,16(sp)
    e158:  1000                 addi s0,sp,32
    e15a:  fe042623           sw zero,-20(s0)
    e15e:  020027b7           lui a5,0x2002
    e162:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e166:  439c                 lw a5,0(a5)
    e168:  fef42623           sw a5,-20(s0)
    e16c:  fec42703           lw a4,-20(s0)
    e170:  010007b7           lui a5,0x1000
    e174:  8fd9                 or a5,a5,a4
    e176:  fef42623           sw a5,-20(s0)
    e17a:  020027b7           lui a5,0x2002
    e17e:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e182:  fec42703           lw a4,-20(s0)
    e186:  c398                 sw a4,0(a5)
    e188:  03200513           li a0,50
    e18c:  ff9fb0ef           jal ra,a184 <udelay>
    e190:  020027b7           lui a5,0x2002
    e194:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e198:  439c                 lw a5,0(a5)
    e19a:  fef42623           sw a5,-20(s0)
    e19e:  fec42783           lw a5,-20(s0)
    e1a2:  1007e793           ori a5,a5,256
    e1a6:  fef42623           sw a5,-20(s0)
    e1aa:  020027b7           lui a5,0x2002
    e1ae:  a8c78793           addi a5,a5,-1396 # 2001a8c <gpio_get_boot_device+0x1ff36
    e1b2:  fec42703           lw a4,-20(s0)
    e1b6:  c398                 sw a4,0(a5)
    e1b8:  03200513           li a0,50
    e1bc:  fc9fb0ef           jal ra,a184 <udelay>
    e1c0:  0001                 nop
    e1c2:  60e2                 ld ra,24(sp)
    e1c4:  6442                 ld s0,16(sp)
    e1c6:  6105                 addi sp,sp,32
    e1c8:  8082                 ret
000000000000e1ca <usb_phy_disable>:
    e1ca:  1101                 addi sp,sp,-32
    e1cc:  ec22                 sd s0,24(sp)
    e1ce:  1000                 addi s0,sp,32
    e1d0:  fe042623           sw zero,-20(s0)
    e1d4:  020027b7           lui a5,0x2002
    e1d8:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e1dc:  439c                 lw a5,0(a5)
    e1de:  fef42623           sw a5,-20(s0)
    e1e2:  fec42703           lw a4,-20(s0)
    e1e6:  c00007b7           lui a5,0xc0000
    e1ea:  17fd                 addi a5,a5,-1
    e1ec:  8ff9                 and a5,a5,a4
    e1ee:  fef42623           sw a5,-20(s0)
    e1f2:  020027b7           lui a5,0x2002
    e1f6:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e1fa:  fec42703           lw a4,-20(s0)
    e1fe:  c398                 sw a4,0(a5)
    e200:  0001                 nop
    e202:  6462                 ld s0,24(sp)
    e204:  6105                 addi sp,sp,32
    e206:  8082                 ret
000000000000e208 <usb_clk_phy_enable>:
    e208:  1101                 addi sp,sp,-32
    e20a:  ec06                 sd ra,24(sp)
    e20c:  e822                 sd s0,16(sp)
    e20e:  1000                 addi s0,sp,32
    e210:  fe042623           sw zero,-20(s0)
    e214:  020027b7           lui a5,0x2002
    e218:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e21c:  439c                 lw a5,0(a5)
    e21e:  fef42623           sw a5,-20(s0)
    e222:  fec42703           lw a4,-20(s0)
    e226:  800007b7           lui a5,0x80000
    e22a:  8fd9                 or a5,a5,a4
    e22c:  fef42623           sw a5,-20(s0)
    e230:  020027b7           lui a5,0x2002
    e234:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e238:  fec42703           lw a4,-20(s0)
    e23c:  c398                 sw a4,0(a5)
    e23e:  03200513           li a0,50
    e242:  f43fb0ef           jal ra,a184 <udelay>
    e246:  020027b7           lui a5,0x2002
    e24a:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e24e:  439c                 lw a5,0(a5)
    e250:  fef42623           sw a5,-20(s0)
    e254:  fec42703           lw a4,-20(s0)
    e258:  400007b7           lui a5,0x40000
    e25c:  8fd9                 or a5,a5,a4
    e25e:  fef42623           sw a5,-20(s0)
    e262:  020027b7           lui a5,0x2002
    e266:  a7078793           addi a5,a5,-1424 # 2001a70 <gpio_get_boot_device+0x1ff36
    e26a:  fec42703           lw a4,-20(s0)
    e26e:  c398                 sw a4,0(a5)
    e270:  03200513           li a0,50
    e274:  f11fb0ef           jal ra,a184 <udelay>
    e278:  0001                 nop
    e27a:  60e2                 ld ra,24(sp)
    e27c:  6442                 ld s0,16(sp)
    e27e:  6105                 addi sp,sp,32
    e280:  8082                 ret
000000000000e282 <FUN_0000e282>:
    e282:  1101                 addi sp,sp,-32
    e284:  ec22                 sd s0,24(sp)
    e286:  1000                 addi s0,sp,32
    e288:  fe042623           sw zero,-20(s0)
    e28c:  041007b7           lui a5,0x4100
    e290:  42078793           addi a5,a5,1056 # 4100420 <gpio_get_boot_device+0x40f208
    e294:  439c                 lw a5,0(a5)
    e296:  fef42623           sw a5,-20(s0)
    e29a:  fec42783           lw a5,-20(s0)
    e29e:  0017e793           ori a5,a5,1
    e2a2:  fef42623           sw a5,-20(s0)
    e2a6:  041007b7           lui a5,0x4100
    e2aa:  42078793           addi a5,a5,1056 # 4100420 <gpio_get_boot_device+0x40f208
    e2ae:  fec42703           lw a4,-20(s0)
    e2b2:  c398                 sw a4,0(a5)
    e2b4:  041007b7           lui a5,0x4100
    e2b8:  4107879b           addiw a5,a5,1040
    e2bc:  fef42423           sw a5,-24(s0)
    e2c0:  fe042223           sw zero,-28(s0)
    e2c4:  fe846783           lwu a5,-24(s0)
    e2c8:  439c                 lw a5,0(a5)
    e2ca:  fef42223           sw a5,-28(s0)
    e2ce:  fe442783           lw a5,-28(s0)
    e2d2:  9bdd                 andi a5,a5,-9
    e2d4:  fef42223           sw a5,-28(s0)
    e2d8:  fe442783           lw a5,-28(s0)
    e2dc:  0207e793           ori a5,a5,32
    e2e0:  fef42223           sw a5,-28(s0)
    e2e4:  fe846783           lwu a5,-24(s0)
    e2e8:  873e                 mv a4,a5
    e2ea:  fe442783           lw a5,-28(s0)
    e2ee:  c31c                 sw a5,0(a4)
    e2f0:  0001                 nop
    e2f2:  6462                 ld s0,24(sp)
    e2f4:  6105                 addi sp,sp,32
    e2f6:  8082                 ret
000000000000e2f8 <usb_init>:
    e2f8:  1141                 addi sp,sp,-16
    e2fa:  e406                 sd ra,8(sp)
    e2fc:  e022                 sd s0,0(sp)
    e2fe:  0800                 addi s0,sp,16
    e300:  e13ff0ef           jal ra,e112 <usb_bgr_disable>
    e304:  ec7ff0ef           jal ra,e1ca <usb_phy_disable>
    e308:  e4bff0ef           jal ra,e152 <usb_bgr_enable>
    e30c:  efdff0ef           jal ra,e208 <usb_clk_phy_enable>
    e310:  0001                 nop
    e312:  60a2                 ld ra,8(sp)
    e314:  6402                 ld s0,0(sp)
    e316:  0141                 addi sp,sp,16
    e318:  8082                 ret
000000000000e31a <syscon_read_fel_button>:
    e31a:  1101                 addi sp,sp,-32
    e31c:  ec06                 sd ra,24(sp)
    e31e:  e822                 sd s0,16(sp)
    e320:  1000                 addi s0,sp,32
    e322:  fe042623           sw zero,-20(s0)
    e326:  fe042423           sw zero,-24(s0)
    e32a:  b7bf90ef           jal ra,7ea4 <brom_config_bit_4>
    e32e:  87aa                 mv a5,a0
    e330:  c399                 beqz a5,e336 <syscon_read_fel_button+0x1c>
    e332:  4781                 li a5,0
    e334:  a8a1                 j e38c <syscon_read_fel_button+0x72>
    e336:  4791                 li a5,4
    e338:  fef42623           sw a5,-20(s0)
    e33c:  a825                 j e374 <syscon_read_fel_button+0x5a>
    e33e:  0fa00513           li a0,250
    e342:  e43fb0ef           jal ra,a184 <udelay>
    e346:  030007b7           lui a5,0x3000
    e34a:  02478793           addi a5,a5,36 # 3000024 <gpio_get_boot_device+0x2ff1c8e>
    e34e:  439c                 lw a5,0(a5)
    e350:  2781                 sext.w a5,a5
    e352:  0087d79b           srliw a5,a5,0x8
    e356:  2781                 sext.w a5,a5
    e358:  8b85                 andi a5,a5,1
    e35a:  0007871b           sext.w a4,a5
    e35e:  fe842783           lw a5,-24(s0)
    e362:  9fb9                 addw a5,a5,a4
    e364:  2781                 sext.w a5,a5
    e366:  fef42423           sw a5,-24(s0)
    e36a:  fec42783           lw a5,-20(s0)
    e36e:  37fd                 addiw a5,a5,-1
    e370:  fef42623           sw a5,-20(s0)
    e374:  fec42783           lw a5,-20(s0)
    e378:  2781                 sext.w a5,a5
    e37a:  fcf042e3           bgtz a5,e33e <syscon_read_fel_button+0x24>
    e37e:  fe842783           lw a5,-24(s0)
    e382:  2781                 sext.w a5,a5
    e384:  e399                 bnez a5,e38a <syscon_read_fel_button+0x70>
    e386:  57fd                 li a5,-1
    e388:  a011                 j e38c <syscon_read_fel_button+0x72>
    e38a:  4781                 li a5,0
    e38c:  853e                 mv a0,a5
    e38e:  60e2                 ld ra,24(sp)
    e390:  6442                 ld s0,16(sp)
    e392:  6105                 addi sp,sp,32
    e394:  8082                 ret
000000000000e396 <gpio_get_boot_device>:
    e396:  1101                 addi sp,sp,-32
    e398:  ec06                 sd ra,24(sp)
    e39a:  e822                 sd s0,16(sp)
    e39c:  1000                 addi s0,sp,32
    e39e:  fe042623           sw zero,-20(s0)
    e3a2:  020007b7           lui a5,0x2000
    e3a6:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    e3aa:  ff450737           lui a4,0xff450
    e3ae:  377d                 addiw a4,a4,-1
    e3b0:  c398                 sw a4,0(a5)
    e3b2:  4551                 li a0,20
    e3b4:  dd1fb0ef           jal ra,a184 <udelay>
    e3b8:  030007b7           lui a5,0x3000
    e3bc:  02478793           addi a5,a5,36 # 3000024 <gpio_get_boot_device+0x2ff1c8e>
    e3c0:  439c                 lw a5,0(a5)
    e3c2:  2781                 sext.w a5,a5
    e3c4:  00b7d79b           srliw a5,a5,0xb
    e3c8:  2781                 sext.w a5,a5
    e3ca:  8b8d                 andi a5,a5,3
    e3cc:  fef42623           sw a5,-20(s0)
    e3d0:  020007b7           lui a5,0x2000
    e3d4:  06078793           addi a5,a5,96 # 2000060 <gpio_get_boot_device+0x1ff1cca>
    e3d8:  577d                 li a4,-1
    e3da:  c398                 sw a4,0(a5)
    e3dc:  fec42783           lw a5,-20(s0)
    e3e0:  853e                 mv a0,a5
    e3e2:  60e2                 ld ra,24(sp)
    e3e4:  6442                 ld s0,16(sp)
    e3e6:  6105                 addi sp,sp,32
    e3e8:  8082                 ret
    e3ea:  0000                 unimp
    e3ec:  0000                 unimp
           ...离线
D1内部函数调用关系图,SVG格式
callgraph.zip
最近编辑记录 xboot (2021-08-20 14:33:51)
D1 BROM ELF版本
blob.zip
好奇这个ELF版本是在那里找到的,大佬能指点下么?
由bin文件根据逆向的符号信息,合成出来的elf
很有意思啊,我还有个疑问,大佬时怎么推测出这些符号的呢?很想了解下这个重构elf的过程,我试了下ghidra目前无法打开riscv的bin文件,但是可以打开elf文件,大佬能分享思路或者过程下不?
这些符号是高人分析出来的,合成脚本在这里
https://github.com/smaeul/sunxi-blobs/blob/master/scripts/bin2elf
#!/bin/bash -eu
# Copyright © 2017 Samuel Holland <samuel@sholland.org>
# See LICENSE in the project directory for license terms.
# bash is only required for hexadecimal math.
# Adjust these as needed
ARCH=${ARCH:-or1k}
BLOCK_SIZE=4096
CROSS_COMPILE=${CROSS_COMPILE:-${ARCH}-linux-musl-}
# Generated, but might need adjustment
case "$ARCH" in
  or1k) ENDIANNESS=big ;;
  *)    ENDIANNESS=little ;;
esac
case "$ARCH" in
  *64*) WORDSIZE=64 ;;
  *)    WORDSIZE=32 ;;
esac
case "$ARCH" in
  riscv*) ARCH=riscv ;;
esac
case "$ARCH" in
  arm|riscv)
        BFDNAME=elf${WORDSIZE}-${ENDIANNESS}${ARCH} ;;
  *)    BFDNAME=elf${WORDSIZE}-${ARCH} ;;
esac
# Command-line parameters
input_file=$1
section_file=$2
symbol_file=$3
output_file=$4
# Internal variables
base=0
# Temporary files, deleted when the script exits
ldscript=$(mktemp)
tmpdir=$(mktemp -d)
tmpfile=$(mktemp)
trap 'rm -fr "$ldscript" "$tmpdir" "$tmpfile"' EXIT
# Usage: elfify <file> <start> <end> <type>
elfify() {
  # Convert raw binary into an ELF section of the appropriate type
  case "$4" in
    data)
      flags=alloc,contents,data,load,readonly
      stype=object
    text)
      flags=alloc,code,contents,load,readonly
      stype=function
  esac
  case "$ENDIANNESS" in
    big)    reverse="--reverse-bytes $((WORDSIZE / 8))" ;;
    little) reverse= ;;
  esac
  ${CROSS_COMPILE}objcopy -B "$ARCH" -I binary -O "$BFDNAME" \
    --rename-section ".data=.${4},${flags}" $reverse "$1"
  # Remove start/end symbols added by objcopy
  ${CROSS_COMPILE}strip -s "$1"
  printf '  .%s %s : {\n    %s(.%s)\n' "$2" "$2" "$1" "$4" >> "$ldscript"
  # Import symbols for this section. File format: "<address> <name>" lines
  while read -r address name; do
    if [[ "$address" -ge "$2" && "$address" -lt "$3" ]]; then
      ${CROSS_COMPILE}objcopy \
        --add-symbol "${name}=.${4}:$((address - $2)),${stype}" "$1"
    fi
  done < "$symbol_file"
  printf '  }\n' >> "$ldscript"
# Usage: hex <number>
hex() {
  if [ "$WORDSIZE" -eq 64 ]; then
    printf '0x%016x' "$*"
    printf '0x%08x' "$*"
  fi
# Usage: warn <message>
warn() {
  printf 'warning: %s\n' "$*" >&2
printf 'SECTIONS\n{\n' > "$ldscript"
start=-1
type=data
# Section file contains lines of the format "<virtual address> <section type>"
while read -r newstart newtype; do
  # Sanity check the section start address and length
  newstart=$((newstart - base))
  length=$((newstart - start))
  if [ "$length" -le 0 ]; then
    warn "Ignoring negative or zero-length section at $(hex "$newstart")."
    continue
  fi
  # Set the base from the first starting address
  if [ "$start" -lt 0 ]; then
    base=$newstart
    start=0
    type=$newtype
    continue
  fi
  # Sanity check the section type -- new types need flags in elfify function
  if [ "$newtype" != 'data' ] && [ "$newtype" != 'text' ]; then
    warn "Handling unknown type '$newtype' at $(hex "$start") as 'data'."
    newtype=data
  fi
  # Handle the section beginning at $start and ending before $newstart
  if [ "$start" -gt 0 ]; then
    bs=$start
    skip=1
    bs=$BLOCK_SIZE
    skip=0
  fi
  of=$tmpdir/$(hex "$start").$type
  dd bs="$newstart" count=1 if="$input_file" of="$tmpfile" 2> /dev/null
  dd bs="$bs" if="$tmpfile" of="$of" skip="$skip" 2> /dev/null
  elfify "$of" "$(hex "$((base + start))")" "$((base + newstart))" "$type"
  start=$newstart
  type=$newtype
done < "$section_file"
  warn "No sections were provided! Addresses will be wrong."
fi
# Handle remaining part of the input file (after last section start)
  bs=$start
  skip=1
  bs=$BLOCK_SIZE
  skip=0
fi
dd bs="$bs" if="$input_file" of="$of" skip="$skip" 2> /dev/null
# The end address doesn't matter as long as it's past the end of the file
elfify "$of" "$(hex "$((base + start))")" "$((2 ** WORDSIZE))" "$type"
printf '}\n' >> "$ldscript"
# Merge all section files in the correct order
${CROSS_COMPILE}ld -e 0 -o "$output_file" -r -T "$ldscript"离线
对xboot老大佩服的五体投地
能不能讲下 老大好像没有JTAG这种调试工具 串口又不能确定能甩前 大概有什么调试经验?
我看到的是利用了原来官方的uboot先调试了一下自己的代码 等用了再把uboot去掉
对xboot老大佩服的五体投地
是的,在没有任何工具前,肯定是借用现成的二进制程序,验证自己的代码,调试经验的话,对于跑不起来,完全没反应的情况,需要做的工作就是定位问题点,而定位问题点,就需要对待验证的代码很熟悉,能加能砍,折半验证等等,如果还没法定位,就只能点LED灯了,一般情况下,是不需要上这种大杀器的,串口还是比较容易搞定的。
XFEL工具现已支持spi nand flash的烧写,感兴趣的可以体验下,如果碰到问题了,也不妨提个issue。
https://whycan.com/t_7323.html
F133内存带宽测试
xboot: /# wboxtest benchmark
[benchmark]-[memcmp]
 Bandwidth: 154.423MB/s
[benchmark]-[memcpy]
 Bandwidth: 897.000MB/s
[benchmark]-[memmove]
 Bandwidth: 234.500MB/s
[benchmark]-[memset]
 Bandwidth: 1.907GB/sF133是DDR2,D1是DDR3,memcpy部分F133比D1的带宽低,但其他几项尽然高了,我估计当时测试D1带宽时用的标准工具链,现在测试F133用的玄铁工具链,不然解释不通,DDR2的性能还能超过DDR3?不深究了,权当工具链的功劳了。
还发现一个F133跟D1的差异,就是唯一序列号,D1读出来的sid看起来比较正确,但F133读出来的sid信息量太少,大部分全零,感觉不太对劲。
00005c00000000000000000000000000离线
以为大佬要弃坑了,现在大佬又回来了,开心!
实在找不到DE寄存器的资料,只搞通了TCON的测试模式。
搞定DE显示
F133内部含有一个电阻触摸控制器TSADC,可以直接连接标准的电阻触摸,这个控制器基本跟F1C100S的类似,所以编写驱动也就手到擒来,拷贝下,基本就可以了。对于电阻触摸屏,所涉及到的均值滤波,中值滤波,触摸校正参数等,这些xboot里都有成熟的解决方案,就不细说了。
下面是演示视频,感觉还是比较丝滑的。
F133运行自制立即式UI框架--XUI
挪威科技大学的Michael Engel教授就在操作系统的课程中介绍并使用了哪吒D1及玄铁C906,并在课件中详细展示了如何在哪吒上玩转MIT的xv6 OS。
附件是课件,里面用xfel来引导xv6操作系统。
xv6-riscv.pdf
教授的主页,有个项目挺有意思,用于解决IOT领域,当云或者服务失效时,IOT设备沦为电子垃圾的问题。完全云化会产生很多电子垃圾,深有同感。教授的思路是服务自动迁移,一次开发,到处运行?
X大佬用上了小麻雀的开发板啊
太强了,对我很有帮助。
F133内存带宽测试好奇怪,按说不该这样的。
奇怪在什么地方,DDR2肯定比DDR3要慢一些,而且主频也有差别。
nezha是穿裤衩肚兜的。。。哈哈
D1一定是和allwinner的某个SOC公用平台(只做了小调整),因此无论是手册,SDK都用了全局替换操作,但影子还在。
boot0/1部分主要是为了适配opensbi做了些调整。DRAM部分如果不完全开放, 可能不太好合并到主线。
PLL的确是8个, 手册没错。 其中一些比如PLL_PERI/VIDEO0/VIDEO1只是PLL输出加了分频器(1X/4X)。
至于内部有没有锁一个A7, 其实就两个可以考虑的因素:
1. 基于成本考虑。 投一个片子22nm片子代价不小, 担心RISC-V的生态。 这种考虑下包一个A7的内核,相当于做了两个产品。
2. A7内核要授权的,并且要抽版税。。。这笔开销其实也非常高了。。。
我倾向于第二种考虑, 比较投片基本上是一次性投入,一般不计入产品成本,而是算公司的研发投入。这对于allwinner可能更容易接受。
T113,也就是T133(这两名字原厂还没想好?)已经确认是双核A7,跟F133为同一个晶圆,同一个封装,pin脚定义。开的是双核cortex-a7,无RISC-V。
最近编辑记录 xboot (2021-12-10 10:55:04)
只要A7核锁了,就无需交任何版税的,参考全志A40I,T507,hdmi功能的版税规则,只要不用,是可以不交钱的。
怪不得叫 F133, 原来里面还藏有个 T133。
已支持spi nand flash 自举引导,并扩展xfel烧录工具,支持烧录spl镜像到spi nand flash
烧写普通镜像到SPI Nand Flash
sudo xfel spinand splwrite 2048 1048576 xboot.bin烧写压缩镜像到SPI Nand Flash
sudo xfel spinand splwrite 2048 1048576 xboot.bin.zxfel 1.2.2版本支持的命令
xfel(v1.2.2) - https://github.com/xboot/xfel
usage:
    xfel version                                             - Show chip version
    xfel hexdump <address> <length>                          - Dumps memory region in hex
    xfel dump <address> <length>                             - Binary memory dump to stdout
    xfel exec <address>                                      - Call function address
    xfel read32 <address>                                    - Read 32-bits value from device memory
    xfel write32 <address> <value>                           - Write 32-bits value to device memory
    xfel read <address> <length> <file>                      - Read memory to file
    xfel write <address> <file>                              - Write file to memory
    xfel reset                                               - Reset device using watchdog
    xfel sid                                                 - Show sid information
    xfel jtag                                                - Enable jtag debug
    xfel ddr [type]                                          - Initial ddr controller with optional type
    xfel spinor                                              - Detect spi nor flash
    xfel spinor read <address> <length> <file>               - Read spi nor flash to file
    xfel spinor write <address> <file>                       - Write file to spi nor flash
    xfel spinand                                             - Detect spi nand flash
    xfel spinand read <address> <length> <file>              - Read spi nand flash to file
    xfel spinand write <address> <file>                      - Write file to spi nand flash
    xfel spinand splwrite <valid-page-size> <address> <file> - Write file to spi nand flash with spl mode离线
T系列?那就是品质规格可以高些了,用于工业没关系。这块还有个R528的
楼主能不能把bare metal的代码共享一下
waycan就有,搜索下,就能找到,D1的裸奔代码
为方便大家研究全志RISCV D1芯片,花了点时间编写了一个精简版的裸机程序,方便大家学习参考。
https://whycan.com/t_6683.html
最近编辑记录 xboot (2021-12-14 17:01:26)
r528-arm-brom.7z
贴个arm核的brom,感兴趣可以逆向下。D1里面也有这个BROM的,只是你dump不出来。
在d1上无法dump 出arm的brom是因为riscv的brom 启动后覆盖了arm的nbrom,也就是覆盖了0地址,但r528上是可以dump 2个brom的,因为仅启动了arm的brom,riscv的还没启动。
如果找到启动riscv的机关,也就是说在r528是可以变成d1的,但这个时候arm核是否还能用,这个是未知的
而R528里面的RISCV BROM跟D1里面的BROM一模一样,也就是说芯片出厂后,各种马甲芯片,两个BROM都固化了,就看启动谁而已,这个部分全志绝对不希望被扯裤衩的。
@xboot
对于 spi nand 的支持,有点疑问,麻烦老大解释下。
目前的烧写支持不支持坏块?如果在烧写过程中发现有坏块,可以标记出坏块吗?
@xboot
现在不支持坏快处理,对全志的坏块处理细节不清楚,特别是brom引导时遇到坏块,brom会怎么处理,还有一个问题,坏块标识对每一个芯片,行为都是一致的吗?这些缺少细节,所以暂时就不处理了。
@xboot
SPI NAND 之前搞新唐NUC980时用过, 这玩意芯片自带的1bit 坏块管理不是很靠谱, 出现过用一段时间后,启动是内核启动失败的情况(坏块出现了)
后来换SD NAND 解决了
xfel已支持R528,DDR初始化,Spi Nor Flash 以及Spi Nand flash烧写都已支持,为了区分芯片是RISCV版还是ARM版马甲,扩展了一个detect接口,现在判断方法是判断第一条指令是arm指令还是riscv指令。如果能找到全志的绑定,封装信息寄存器,那是最完美的,不过大概率是不会公开的。
下面是xfel的支持列表
https://xboot.org/xfel
D1芯片的SVD寄存器文件,有什么好用的工具去看这玩意吗?
@xboot 大佬,spinand splwrite 模式,指定的splitsize,brom是如何知道这个值的,比如spi nand是4k页,我指定了splitsize=1k,brom怎么启动spl
大佬, 感谢您的工作!
我头一次接触xboot, 我现在烧进去跑起来了,
请问, 我想运行SD卡里面的helloworld.lua该怎么做?
keil有所谓的svd文件,就是看寄存器的,但是keil肯定不可能支持riscv啊。
xboot 说:D1芯片的SVD寄存器文件,有什么好用的工具去看这玩意吗?
SVD不是ARM搞出来的寄存器布局描述文件吗,应该一般适用于ARM处理器吧
@xboot
关于 bonding 信息寄存器,据我所知至少之前应该是在 CE 里,可以参考下 Linux 内核 sun8i-ce 驱动的代码?
以及叫什么名字似乎和 SID 也有关系,同时用 bonding id 和 sid 应该能惟一确定芯片 variant
splitsize 是 brom 里写死的值,不同芯片不一样;据我所知 V3s/F1C100s 是 0x400 ,D1 是 0x800
d1-brom.zip
利用xfel工具dump出来的D1 brom,感兴趣的可以逆向看看
大佬,BROM里面是怎么实现搬运boot0代码的呢?除了初始化RAM是不是还要初始化对应的外部存储介质
lz消失一年多了?
最近刚听说D1芯片的新型号D1H,都说是D1芯片换了个丝印,这不会是老D1把ARM核给去掉了吧?
lz消失一年多了?
D1H和D1应该是一样的,据说是HDMI组织要求加上个H在后面,参考A40i-H
@xboot
试了下H616芯片,从0x20000地址开始写,发现只能写4916个字节以内的文件,不知道是什么原因。小于这个大小的固件是可以正常下载执行。
SRAM里面有brom的使用的栈或堆空间,别破坏brom的环境
能分享下d1spl SRAM版本的源代码不,我运行了是可以的。 但是 为啥我写了个编译,下载进去就挂了? 就是说 栈或堆空间 的问题。谢谢!
最近编辑记录 coldfire2000 (2023-06-29 12:13:09)
@mapleft
大佬,请教个问题,nuc980能支持sd nand吗,使用sd nand的话能用NuWriter烧写吗?需要在贴片前烧写sd nand吗?
最新源码没有VS2007工程. 另外的连接还停留在2022.
