#201 2019-05-15 11:22:58
晕哥小弟
已发帖子: 311
Re: 荔枝派Zero V3s开发板入坑记录 (TF/SD卡启动)(主线Linux,主线u-boot)
晕哥,使用BSP内核,选通了ov5640。然后也更改了fex。
[csi1]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_define_sensor_list   = 0
vip_csi_pck              = port:PE00<2><default><default><default>
vip_csi_mck              = port:PE01<2><default><default><default>
vip_csi_hsync            = port:PE02<2><default><default><default>
vip_csi_vsync            = port:PE03<2><default><default><default>
vip_csi_d0               = port:PE04<2><default><default><default>
vip_csi_d1               = port:PE05<2><default><default><default>
vip_csi_d2               = port:PE06<2><default><default><default>
vip_csi_d3               = port:PE07<2><default><default><default>
vip_csi_d4               = port:PE08<2><default><default><default>
vip_csi_d5               = port:PE09<2><default><default><default>
vip_csi_d6               = port:PE10<2><default><default><default>
vip_csi_d7               = port:PE11<2><default><default><default>
vip_csi_d8               = port:PE12<2><default><default><default>
;vip_csi_d9               = port:PE13<2><default><default><default>
vip_csi_d10               = port:PE14<2><default><default><default>
vip_csi_d11               = port:PE15<2><default><default><default>
vip_csi_sck               = port:PE21<2><default><default><default>
vip_csi_sda               = port:PE22<2><default><default><default>
vip_dev0_mname           = "ov5640"
vip_dev0_pos             = "front"
vip_dev0_twi_id          = 4
vip_dev0_twi_addr        = 0x78
vip_dev0_isp_used        = 0
vip_dev0_fmt             = 0
vip_dev0_stby_mode       = 0
vip_dev0_vflip           = 0
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_iovdd_vol       = 2800000
vip_dev0_avdd            = ""
vip_dev0_avdd_vol        = 2800000
vip_dev0_dvdd            = ""
vip_dev0_dvdd_vol        = 1500000
vip_dev0_afvdd           = ""
vip_dev0_afvdd_vol       = 2800000
vip_dev0_power_en        =
vip_dev0_reset           = port:PE23<1><default><default><default>
vip_dev0_pwdn            = port:PE24<1><default><default><default>
vip_dev0_flash_en        =
vip_dev0_flash_mode      =
vip_dev0_af_pwdn         =
vip_dev0_act_used        = 0
vip_dev0_act_name        = "ad5820_act"
vip_dev0_act_slave       = 0x18
vip_dev1_mname           = "gc2035"
vip_dev1_pos                 = "front"
vip_dev1_lane            = 1
vip_dev1_twi_id          = 4
vip_dev1_twi_addr        = 0x78
vip_dev1_isp_used        = 0
vip_dev1_fmt             = 1
vip_dev1_stby_mode       = 0
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_iovdd_vol       = 2800000
vip_dev1_avdd            = ""
vip_dev1_avdd_vol        = 2800000
vip_dev1_dvdd            = ""
vip_dev1_dvdd_vol        = 1500000
vip_dev1_afvdd           = ""
vip_dev1_afvdd_vol       = 2800000
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
vip_dev1_flash_mode      =
vip_dev1_af_pwdn         =
可是在用fswebcam拍照时
# fswebcam -S 10 -d /dev/video1 -p YUV420P -r 640x480 test21.jpg
[   26.003939] [VFE]vfe_open
--- Opening /dev/video1...
[   26.007092] [VFE]..........................vfe clk open!.......................
Trying source module v4l2...[   26.018941] [VFE]vfe_open ok
/dev/video1 opened.
[   26.024950] [VFE_ERR]input index(0) > dev->dev_qty(1)-1 invalid!, device_valid_flag[0] = 0
No input was specified, usin[   26.037247] [VFE]vfe_close
g the first.
Unable to[   26.042806] [VFE]vfe select input flag = 0, s_input have not be used .
 query input 0.
VIDIOC[   26.053040] [VFE]..........................vfe clk close!.......................
_ENUMINPUT: Invalid argument
   26.064499] [VFE]vfe_close end
0m#
# i2cd
i2cdetect  i2cdump
# i2cd
i2cdetect  i2cdump
# i2cdetect -l
i2cdetect: can't open '/sys/class/i2c-dev': No such file or directory
# i2cdetect -y 1
i2cdetect: can't open '/dev/i2c/1': No such file or directory
# ls
这是什么原因呢
#202 2019-05-15 11:33:22
已发帖子: 9,439
有没有 /dev/i2cX,   /dev/i2c/X 这些设备, 如果没有可能是 menuconfig 上面没有勾选 I2C User Interface
#203 2019-05-15 11:40:59
晕哥小弟
已发帖子: 311
主要是这个错误
[   33.650171] [VFE]vfe_open
Trying source module v4l2...[   33.656150] [VFE]..........................vfe clk open!.......................
[   33.667840] [VFE]vfe_open ok
[   33.671467] [VFE_ERR]input index(0) > dev->dev_qty(1)-1 invalid!, device_valid_flag[0] = 0
/dev/video1 opened.
No [   33.681675] [VFE]vfe_close
input was specified, using the f[   33.686958] [VFE]vfe select input flag = 0, s_input have not be used .
irst.
Unable to query [   33.697235] [VFE]..........................vfe clk close!.......................
input 0.
VIDIOC_ENUMIN[   33.708530] [VFE]vfe_close end
不知道这个是什么造成的
最近编辑记录 晕哥小弟 (2019-05-15 11:41:19)
#204 2019-05-15 11:42:03
晕哥小弟
已发帖子: 311
https://www.kancloud.cn/lichee/lpi0/470832
群主也有这个问题,但是没有说清楚。
#205 2019-05-15 11:43:09
晕哥小弟
已发帖子: 311
[    0.000000] Linux version 3.4.39 (he@he) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-29) ) #37 Wed May 15 11:39:13 CST 2019
[    0.000000] Initialized persistent memory from 41d20800-41d307ff
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 29176k/29176k available, 36360k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc052b000   (5260 kB)
[    0.000000]       .init : 0xc052b000 - 0xc054f000   ( 144 kB)
[    0.000000]       .data : 0xc0550000 - 0xc05cd490   ( 502 kB)
[    0.000000]        .bss : 0xc05cd4b4 - 0xc06ae354   ( 900 kB)
[    0.000000] NR_IRQS:544
[    0.000148] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000168] pid_max: default: 32768 minimum: 301
[    0.000312] Mount-cache hash table entries: 512
[    0.000870] CPU: Testing write buffer coherency: ok
[    0.001132] Setting up static identity map for 0x403aa208 - 0x403aa260
[    0.001816] devtmpfs: initialized
[    0.003522] pinctrl core: initialized pinctrl subsystem
[    0.004012] NET: Registered protocol family 16
[    0.004320] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.004380] script_sysfs_init success
[    0.005154] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.006059] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.006427] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.007202] persistent_ram: found existing buffer, size 21180, start 21180
[    0.101129] console [ram-1] enabled
[    0.102061] Not Found clk pll_isp in script
[    0.102194] Not Found clk pll_video in script
[    0.102422] Not Found clk pll_ve in script
[    0.102544] Not Found clk pll_periph0 in script
[    0.102665] Not Found clk pll_de in script
[    0.107130] bio: create slab <bio-0> at 0
[    0.107512] pwm module init!
[    0.109723] SCSI subsystem initialized
[    0.110225] usbcore: registered new interface driver usbfs
[    0.110433] usbcore: registered new interface driver hub
[    0.110801] usbcore: registered new device driver usb
[    0.111097] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.111227] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.111456] Linux video capture interface: v2.00
[    0.111650] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[    0.112215] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.113108] Switching to clocksource arch_sys_counter
[    0.119984] NET: Registered protocol family 2
[    0.119984] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.119984] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.119984] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.119984] TCP: Hash tables configured (established 2048 bind 2048)
[    0.120225] TCP: reno registered
[    0.120355] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.120593] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.120985] NET: Registered protocol family 1
[    0.121452] standby_mode = 1.
[    0.121680] wakeup src cnt is : 3.
[    0.121820] pmu1_enable = 0x1.
[    0.121940] pmux_id = 0x1.
[    0.122172] config_pmux_para: script_parser_fetch err.
[    0.122296] pmu2_enable = 0x0.
[    0.122423] add_sys_pwr_dm: get ldo name failed
[    0.122651] add_sys_pwr_dm: get ldo name failed
[    0.122774] add_sys_pwr_dm: get ldo name failed
[    0.122897] add_sys_pwr_dm: get ldo name failed
[    0.123125] add_sys_pwr_dm: get ldo name failed
[    0.123248] add_sys_pwr_dm: get ldo name failed
[    0.123474] add_sys_pwr_dm: get ldo name failed
[    0.123598] add_sys_pwr_dm: get ldo name failed
[    0.123720] add_sys_pwr_dm: get ldo name failed
[    0.123947] add_sys_pwr_dm: get ldo name failed
[    0.124068] after inited: sys_mask config = 0x0.
[    0.124291] dynamic_standby enalbe = 0x0.
[    0.124462] sunxi_reg_init enter
[    0.126525] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.126818] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.127135] msgmni has been set to 56
[    0.128317] io scheduler noop registered
[    0.128454] io scheduler deadline registered
[    0.128654] io scheduler cfq registered (default)
[    0.129271] [DISP]disp_module_init
[    0.129786] cmdline,disp=
[    0.130184] [DISP] disp_get_rotation_sw,line:68:disp 0 out of range? g_rot_sw=0
[    0.130534] [DISP] disp_init_connections,line:289:NULL pointer: 0, 0
[    0.131503] [DISP] lcd_clk_config,line:886:disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
[    0.132966] [DISP]disp_module_init finish
[    0.133477] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.133936] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.134173] sw_uart_pm()890 - uart0 clk is already enable
[    0.134307] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.247778] console [ttyS0] enabled
[    0.737814] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.745700] spi spi0: master is unqueued, this is deprecated
[    0.753808] Failed to alloc md5
[    0.757463] eth0: Use random mac address
[    0.762122] usbcore: registered new interface driver catc
[    0.768378] usbcore: registered new interface driver kaweth
[    0.774700] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[    0.783272] usbcore: registered new interface driver pegasus
[    0.789803] usbcore: registered new interface driver rtl8150
[    0.796290] usbcore: registered new interface driver asix
[    0.802556] usbcore: registered new interface driver cdc_ether
[    0.809180] usbcore: registered new interface driver cdc_eem
[    0.815721] usbcore: registered new interface driver dm9601
[    0.822081] usbcore: registered new interface driver smsc75xx
[    0.828731] usbcore: registered new interface driver smsc95xx
[    0.835257] [DISP] disp_lcd_pwm_enable,line:1021:pwm device hdl is NULL
[    0.843015] usbcore: registered new interface driver gl620a
[    0.849351] usbcore: registered new interface driver net1080
[    0.855901] usbcore: registered new interface driver plusb
[    0.862163] usbcore: registered new interface driver rndis_host
[    0.868983] usbcore: registered new interface driver cdc_subset
[    0.875716] usbcore: registered new interface driver zaurus
[    0.882171] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    0.890577] usbcore: registered new interface driver int51x1
[    0.897114] usbcore: registered new interface driver kalmia
[    0.903471] usbcore: registered new interface driver ipheth
[    0.909918] usbcore: registered new interface driver sierra_net
[    0.916652] usbcore: registered new interface driver cx82310_eth
[    0.923594] usbcore: registered new interface driver cdc_ncm
[    0.930052] usbcore: registered new interface driver lg-vl600
[    0.936686] usbcore: registered new interface driver qmi_wwan
[    0.943549] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.971131] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.980494] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.989127] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.010037] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.016821] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.024598] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.032841] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.041277] usb usb1: Manufacturer: Linux 3.4.39 ehci_hcd
[    1.047482] usb usb1: SerialNumber: sunxi-ehci
[    1.053225] hub 1-0:1.0: USB hub found
[    1.057525] hub 1-0:1.0: 1 port detected
[    1.062594] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.089650] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.098627] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    1.107320] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.174098] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.181867] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.189997] usb usb2: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.198140] usb usb2: Manufacturer: Linux 3.4.39 ohci_hcd
[    1.204353] usb usb2: SerialNumber: sunxi-ohci
[    1.209963] hub 2-0:1.0: USB hub found
[    1.214293] hub 2-0:1.0: 1 port detected
[    1.219417] usbcore: registered new interface driver cdc_acm
[    1.225859] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.235026] usbcore: registered new interface driver cdc_wdm
[    1.241433] Initializing USB Mass Storage driver...
[    1.247153] usbcore: registered new interface driver usb-storage
[    1.253944] USB Mass Storage support registered.
[    1.259413] usbcore: registered new interface driver usbserial
[    1.266023] usbserial: USB Serial Driver core
[    1.271140] usbcore: registered new interface driver option
[    1.277468] USB Serial support registered for GSM modem (1-port)
[    1.284447] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    1.291574] sunxikbd_script_init: key para not found, used default para.
[    1.300339] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.307857] i2c /dev entries driver
[    1.312242] [VFE]cci probe start cci_sel = 0!
[    1.317218] [VFE]cci probe end cci_sel = 0!
[    1.322029] [VFE]cci_init end
[    1.325551] [VFE]Welcome to Video Front End driver
[    1.331245] [VFE]pdev->id = 1
[    1.334651] [VFE]dev->mipi_sel = 1
[    1.338637] [VFE]dev->vip_sel = 1
[    1.342448] [VFE]dev->isp_sel = 0
[    1.352354] [VFE_WARN]vfe vpu clock is null
[    1.357517] [VFE_ERR]vip1 request pinctrl handle for device [csi1] failed!
[    1.365478] [VFE]vfe_init end
[    1.369790] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.378681] [VFE]probe_work_handle start!
[    1.383365] [VFE]..........................vfe clk open!.......................
[    1.391748] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.400719] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.409444] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.418282] [VFE]v4l2 subdev register input_num = 0
[    1.423928] [VFE]vfe sensor detect start! input_num = 0
[    1.429842] [VFE]Find sensor name is "ov5640", i2c address is 78, type is "YUV" !
[    1.438371] [VFE]Sub device register "ov5640" i2c_addr = 0x78 start!
[    1.445540] [VFE_ERR]Error registering v4l2 subdevice No such device!
[    1.452910] [VFE_ERR]vfe sensor register check error at input_num = 0
[    1.460313] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.469051] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.477814] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.487041] [VFE]V4L2 device registered as video1
[    1.492418] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.499681] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.510965] [VFE]..........................vfe clk close!.......................
[    1.519711] [VFE]probe_work_handle end!
[    1.524273] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.531757] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.538056] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.549954] sunxi_leds_fetch_sysconfig_para leds is not used in config
[    1.557480] =========script_get_err============
[    1.564103] usbcore: registered new interface driver usbhid
[    1.570538] usbhid: USB HID core driver
[    1.575561] ashmem: initialized
[    1.579298] logger: created 256K log 'log_main'
[    1.584942] logger: created 32K log 'log_events'
[    1.590357] logger: created 32K log 'log_radio'
[    1.595636] logger: created 32K log 'log_system'
[    1.606895] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.612686] *******************Try sdio*******************
[    1.621126] TCP: cubic registered
[    1.625001] NET: Registered protocol family 17
[    1.630254] VFP support v0.3: [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 5,  RTO !!
[    1.640507] ThumbEE CPU extension supported.
[    1.645483] *******************Try sd *******************
[    1.651613] Registering SWP/SWPB emulation handler
[    1.658081] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.667140] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.677168] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.688018] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.696613] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.705301] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.714174] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.722981] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:00:10 UTC (10)
[    1.733372] ALSA device list:
[    1.736805]   #0: audiocodec
[    1.740542] Waiting for root device /dev/mmcblk0p2...
[    1.777498] mmc0: new high speed SDHC card at address aaaa
[    1.784150] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.793829]  mmcblk0: p1 p2
[    1.797839] mmcblk mmc0:aaaa: Card claimed for testing.
[    1.803921] mmc0:aaaa: SC16G 14.8 GiB
[    1.808312] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.817174] *******************sd init ok*******************
[    1.823657] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.832519] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.841079] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.849727] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.858414] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.866975] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.962903] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.974732] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.020978] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.030169] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.041157] devtmpfs: mounted
[    2.044757] Freeing init memory: 144K
[    2.163985] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting syslogd: OK
Starting klogd: OK
Starting network: OK
Welcome to Buildroot
buildroot login: root
# i2cdetect -y
BusyBox v1.29.3 (2019-04-29 11:17:35 CST) multi-call binary.
Usage: i2cdetect -l | -F I2CBUS | [-ya] [-q|-r] I2CBUS [FIRST LAST]
Detect I2C chips
        -l      List installed buses
        -F BUS# List functionalities on this bus
        -y      Disable interactive mode
        -a      Force scanning of non-regular addresses
        -q      Use smbus quick write commands for probing (default)
        -r      Use smbus read byte commands for probing
        FIRST and LAST limit probing range
# i2cdetect -l
/dev/video1 opened.
irst.
input 0.
附上我的启动信息。有时间帮我分析原因。
#206 2019-05-15 13:44:08
已发帖子: 9,439
看前面的错误, 觉得应该是 没有生成 /dev/videoX 设备,
看log 果然是视频设备没有注册成功:
menuconfig 里面有 ov5640 吗? ov5640 与 ov5647 的设备Id 不同的。
#207 2019-05-15 13:46:25
晕哥小弟
已发帖子: 311
不对吧,你往下看,产生了 /dev/video1啊
#208 2019-05-15 14:19:19
已发帖子: 9,439
晕哥小弟 说:
嗯, 眼花了。
找到这个, 问题和你的一样,
https://licheezero.readthedocs.io/zh/latest/系统开发/bsp_cam.html
但是我仍然没看出来他是如何解决的.
#209 2019-05-15 14:29:25
晕哥小弟
已发帖子: 311
这就咋玩了,主线生成不了/dev/video*  BSP 虽然生成了/dev/video1但是拍照会发生上面的错误。。。。。。
#210 2019-05-15 14:32:49
已发帖子: 9,439
晕哥小弟 说:
有没有试过这个: https://whycan.cn/t_1780.html
#211 2019-05-15 14:35:41
晕哥小弟
已发帖子: 311
晕哥小弟 说:
我这边是得到的消息是 ov5647停产了。而且市面上不好购买。另外我用fswebcam拍照的话,10次大概有1-2次拍照出来是个空照片。
#212 2019-05-15 15:05:07
已发帖子: 9,439
晕哥小弟 说:
晕哥小弟 说:
用上面的固件, 会有空照片?
#213 2019-05-15 15:39:58
晕哥小弟
已发帖子: 311
晕哥小弟 说:
用上面的固件, 会有空照片?
是的,我之前测试的时候发现的,好像拍了十几张的样子,然后有一张图片生成了,但是就是没有图像。后来我就没有管了。换linux了。
#214 2019-05-15 18:57:05
lgliang
Jmhh247 说:
先用 bmp 文件测试, 如果 bmp 文件都正常, 说明缺 png 库.
那可能 buildroot 没有勾上 libpng,
也可能勾上了 libpng,
但是你的 Qt 路径, plugins 子目录下面没有 png 插件,
缺一不可.
折腾了两天,终于能显示png了。。。
确实在buildroot里面勾上 png相关支持就可以了,然后要删除掉qt5目录内的.stamp_built .stamp_configured 。
刚开始我没删掉这些,生成的根文件系统还是不支持显示png
感觉自己蠢哭了。。。
我也遇到了这个问题,请问是删除掉“./buildroot-2017.08.1/output/build/qt5base-5.9.1/.stamp_built”,和 “./buildroot-2017.08.1/output/build/qt5base-5.9.1/.stamp_configured” 这两个目录下的文件么,请指教!!
#215 2019-05-15 20:22:44
已发帖子: 9,439
可以先这样试一试
#216 2019-05-15 22:36:06
晕哥小弟
已发帖子: 311
晕哥,有方法可以把主线的uboot.bin   +  bsp kernel  + script.bin 等等打包一个img文件,我烧到flash中,之前好像在论坛里面看到。今天早了很长时间没有找到。
#217 2019-05-16 08:08:45
已发帖子: 9,439
晕哥小弟 说:
https://whycan.cn/t_682.html (licheepi zero BSP 内核(linux3.4) 编译教程)
#218 2019-05-16 08:38:46
晕哥小弟
已发帖子: 311
晕哥,上面你提供的链接,我搜到了,我现在的环境是主线u-boot + BSP 内核。想烧写到spi-flash中。
#219 2019-05-16 08:46:58
已发帖子: 9,439
晕哥小弟 说:
可以的, 貌似我以前做过 flash 固件, 刚刚没找到。
#220 2019-05-16 08:51:54
晕哥小弟
已发帖子: 311
我其实不需要固件,我需要个步骤。 因为现在我有主线的uboot  BSPkernel +  boot.scr  + script.bin +还有一个rootfs (我不知道是什么格式,是buildroot生成的) 这些我不知道烧写到什么位置。
#221 2019-05-16 10:27:41
晕哥小弟
已发帖子: 311
晕哥,按照自己的理解,和参照网上。自己折腾了下。
21、启动不起来,任何串口任何信息都没有。
最近编辑记录 晕哥小弟 (2019-05-16 11:46:59)
#222 2019-05-16 10:48:33
已发帖子: 9,439
串口连 u-boot 信息都没有?
到这里跟帖吧:
#223 2019-05-17 16:09:25
jianke512
晕哥,现在调试LecheePi Zero,屏幕800x480,已按照1楼的配置更改UBOOT,kernel用的800x480的dtb,启动过程中UBOOT屏幕可以显示,linux kernel屏幕不显示并且kernel hang住,请帮忙给些调试建议
kernle停在Console: switching to colour dummy device 80x30位置不动了
U-Boot SPL 2017.01-rc2 (May 17 2019 - 15:06:54)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2 (May 17 2019 - 15:06:54 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
reading zImage
4021504 bytes read in 218 ms (17.6 MiB/s)
reading sun8i-v3s-licheepi-zero-with-800x480-lcd.dtb
11953 bytes read in 27 ms (431.6 KiB/s)
   Loading Device Tree to 42dfa000, end 42dffeb0 ... OK
[    0.000000] Linux version 4.14.14-licheepi-zero (root@muwei) (gcc version 7.9
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33740 r8192 d23604 u6556
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15883
[    0.000000] Kernel command line: console=ttyS0,115200 rootwait root=/dev/mmcw
[    0.000000] Memory: 53512K/64036K available (6144K kernel code, 284K rwdata,)
[    0.000000]       .data : 0xc0a00000 - 0xc0a473a0   ( 285 kB)
[    0.000000]        .bss : 0xc0a4e6dc - 0xc0a902e4   ( 264 kB)
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s
[    0.000179] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, maxs
[    0.000430] Console: colour dummy device 80x30
[    0.000470] Calibrating delay loop (skipped), value calculated using timer f)
[    0.000486] pid_max: default: 32768 minimum: 301
[    0.000612] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000627] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001273] CPU: Testing write buffer coherency: ok
[    0.001665] /cpus/cpu@0 missing clock-frequency property
[    0.001692] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002158] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002338] Hierarchical SRCU implementation.
[    0.002846] smp: Bringing up secondary CPUs ...
[    0.002860] smp: Brought up 1 node, 1 CPU
[    0.002868] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002876] CPU: All CPU(s) started in SVC mode.
[    0.003681] devtmpfs: initialized
[    0.006874] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[    0.007170] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.007198] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007379] pinctrl core: initialized pinctrl subsystem
[    0.008361] NET: Registered protocol family 16
[    0.008834] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009885] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[    0.009982] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021743] SCSI subsystem initialized
[    0.021993] usbcore: registered new interface driver usbfs
[    0.022046] usbcore: registered new interface driver hub
[    0.022140] usbcore: registered new device driver usb
[    0.022382] pps_core: LinuxPPS API ver. 1 registered
[    0.022393] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    0.022415] PTP clock support registered
[    0.022612] Advanced Linux Sound Architecture Driver Initialized.
[    0.024319] clocksource: Switched to clocksource arch_sys_counter
[    0.034142] NET: Registered protocol family 2
[    0.034814] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.034849] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.034872] TCP: Hash tables configured (established 1024 bind 1024)
[    0.035007] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.035059] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.035282] NET: Registered protocol family 1
[    0.035967] RPC: Registered named UNIX socket transport module.
[    0.035989] RPC: Registered udp transport module.
[    0.035995] RPC: Registered tcp transport module.
[    0.036001] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.037885] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.043680] NFS: Registering the id_resolver key type
[    0.043740] Key type id_resolver registered
[    0.043749] Key type id_legacy registered
[    0.047928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    0.047952] io scheduler noop registered
[    0.047960] io scheduler deadline registered
[    0.048260] io scheduler cfq registered (default)
[    0.048274] io scheduler mq-deadline registered
[    0.048282] io scheduler kyber registered
[    0.048869] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.052104] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.052982] pwm-backlight backlight: backlight supply power not found, usingr
[    0.147212] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.150251] console [ttyS0] disabled
[    0.170534] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1A
[    0.749735] console [ttyS0] enabled
[    0.756268] panel-simple panel: panel supply power not found, using dummy rer
[    0.765453] libphy: Fixed MDIO Bus: probed
[    0.769921] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.776531] ehci-platform: EHCI generic platform driver
[    0.782032] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.787700] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus 1
[    0.795653] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.824364] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.831462] hub 1-0:1.0: USB hub found
[    0.835402] hub 1-0:1.0: 1 port detected
[    0.839938] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.846239] ohci-platform: OHCI generic platform driver
[    0.851805] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.858530] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus 2
[    0.866485] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    0.939323] hub 2-0:1.0: USB hub found
[    0.943162] hub 2-0:1.0: 1 port detected
[    0.950768] udc-core: couldn't find an available UDC - added [g_cdc] to lists
[    0.960467] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.967364] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.971933] i2c /dev entries driver
[    0.976832] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-000
[    0.985861] IR NEC protocol handler initialized
[    0.990400] IR RC5(x/sz) protocol handler initialized
[    0.995533] IR RC6 protocol handler initialized
[    1.000061] IR JVC protocol handler initialized
[    1.004610] IR Sony protocol handler initialized
[    1.009220] IR SANYO protocol handler initialized
[    1.013917] IR Sharp protocol handler initialized
[    1.018628] IR MCE Keyboard/mouse protocol handler initialized
[    1.024464] IR XMP protocol handler initialized
[    1.029670] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, no)
[    1.094359] sunxi-mmc 1c0f000.mmc: base:0xc406b000 irq:24
[    1.101308] usbcore: registered new interface driver usbhid
[    1.106979] usbhid: USB HID core driver
[    1.112789] NET: Registered protocol family 17
[    1.117475] Key type dns_resolver registered
[    1.121869] Registering SWP/SWPB emulation handler
[    1.134778] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e8900
[    1.145375] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=80
[    1.161569] Console: switching to colour frame buffer device 100x30
[    1.174080] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registere!
[    1.182839] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.189586] [drm] No driver support for vblank timestamp query.
[    1.204990] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0743094)
[    1.212352] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0)
[    1.220086] fb: switching to sun4i-drm-fb from simple
[    1.225268] Console: switching to colour dummy device 80x30
#224 2019-05-17 16:18:32
已发帖子: 9,439
感觉应该是你的 u-boot bootargs 里面的 console 参数不是 /dev/ttyS0
导致默认控制台发生了切换.
#225 2019-05-17 17:17:37
jianke512
晕哥,在Kernel的log中已确认console=ttyS0,与你在一楼推荐的CONFIG_BOOTARGS设置一样
另外Kernel version 4.14
困扰中
#226 2019-05-17 17:20:57
已发帖子: 9,439
jianke512 说:
困扰中
参考1: https://whycan.cn/t_2388.html (荔枝派zero/小智极客S3/V3s使用sunxi-fel 借 u-boot 启动 Linux系统, 无需 spi flash / TF 卡)
参考这个帖子, 一个一个替换文件, 逐步排除问题。
#227 2019-05-19 16:31:06
lgliang
晕哥版主:“buildroot-2017.08.1” 自带的/usr/bin/ts_calibrate,测试时,提示“tslib: Selected device is not a touchscreen (must support ABS and KEY event types)”。 以前手动按装tslib. 设置:export TSLIB_TSDEVICE=/dev/input/event1
就可以找到touchscreen , “buildroot-2017.08.1” 自带的/usr/bin/ts_calibrate设置没有效果。
最近编辑记录 lgliang (2019-05-19 16:31:34)
#228 2019-05-19 16:37:42
已发帖子: 9,439
是 TSLIB_TSDEVICE 环境变量没有测试
那现在可以了吗?
#229 2019-05-19 16:49:34
lgliang
手动export TSLIB_TSDEVICE=/dev/input/event1 就可以了,我之前把这个命令写入/etc/profile里面没有效果,发现这个电阻触摸屏不是很准确。有时会跳动
最近编辑记录 lgliang (2019-05-19 17:04:13)
#230 2019-05-19 17:09:28
已发帖子: 9,439
lgliang 说:
触摸不准是因为驱动没有防抖, 据说 tslib 的插件有防抖功能, 你研究一下.
驱动防抖 @john78 大神已经实现了: https://whycan.cn/t_1259.html#p14265
#231 2019-05-19 17:11:19
lgliang
好的,谢谢晕哥
#232 2019-05-20 14:01:19
jianke512
jianke512 说:
困扰中
Hi,
   晕哥,此问题解决,参考以下链接的改法OK了,谢谢
https://www.lotlab.org/2018/07/28/record-of-using-licheepi-zero-part-1-u-boot-linux-buildroot/
#233 2019-05-21 09:33:13
lgliang
请问晕哥,buildroot上的mPlayer是使用的软解码还是硬解码。
#234 2019-05-21 09:36:35
已发帖子: 9,439
lgliang 说:
软解。
因为硬解码没有统一的标准。
#235 2019-06-19 15:40:02
tobunto
我跟着教程都走通了,但是挂载emdebian系统后,启动时出错了,emdebian系统是根据https://licheezero.readthedocs.io/zh/latest/系统开发/emdebian.html制作的,错误是Starting init: /etc/init exists but couldn't execute it (error -13)
/bin/sh: 0: Can't open earlyprintk,没找到原因,有了解的能指点下吗。
#236 2019-06-19 15:46:49
nuvoton
已发帖子: 59
/etc/init 存在, 但是不能执行, 看文件是不是没有执行属性, 或者依赖的库不存在,还是别的问题?
#237 2019-06-20 09:13:32
tobunto
debian系统的/etc/init是个目录,/etc/init/下也都是一些配置文件,应该与执行权限没关
#238 2019-06-20 09:20:08
已发帖子: 9,439
tobunto 说:
那你的 bootargs 是什么? 系统第一个执行程序是 init=/etc/init ?
#239 2019-06-20 09:35:47
tobunto
没指定第一个启动程序,是按帖子上面的配的:#define CONFIG_BOOTARGS      "console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw rootfstype=ext4 rootdelay=8 vt.global_cursor_default=0"
#240 2019-07-04 00:14:25
xk100
已发帖子: 75
jianke512 说:
jianke512 说:
困扰中
Hi,
碰到同样的问题。明天试试。
#241 2019-07-05 21:47:30
晕哥小弟
已发帖子: 311
买了一块licheepi zero ,准备在家试试 主线 uboot  +主线  kernel 。我发现kernel 的提交记录都是两年前的,是不是太老了。如果想玩是不是可以用最新的kernel 5.几版本好像。
#242 2019-07-05 21:53:24
4.13/4.14 还行, 用来量产了.
#243 2019-07-24 17:18:36
太一酱鸭
已发帖子: 154
root@wuyu-virtual-machine:/disk3/linuxzero/linux-master# make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules
  CALL    scripts/atomic/check-atomics.sh
  CALL    scripts/checksyscalls.sh
  Building modules, stage 2.
  MODPOST 4591 modules
ERROR: "__sync_icache_dcache" [drivers/xen/xen-privcmd.ko] undefined!
scripts/Makefile.modpost:94: recipe for target '__modpost' failed
make[1]: *** [__modpost] Error 1
Makefile:1294: recipe for target 'modules' failed
make: *** [modules] Error 2
编译的时候出现这个问题,找了网上好多都没有找到答案
#244 2019-07-24 17:32:09
太一酱鸭
已发帖子: 154
太一酱鸭 说:
貌似找到一个,明天上班再看看能不能解决
#245 2019-08-05 10:33:34
太一酱鸭
已发帖子: 154
晕哥我用linux3.4编译的zImage,然后一直点亮不了板子无法启动内核
 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
284 bytes read in 14 ms (19.5 KiB/s)
reading zImage
1866504 bytes read in 129 ms (13.8 MiB/s)
reading sun8i-v3s-blueberrypi-csi-ov2640.dtb
12240 bytes read in 26 ms (459 KiB/s)
   Loading Device Tree to 42dfa000, end 42dfffcf ... OK
#246 2019-08-05 10:39:58
太一酱鸭
已发帖子: 154
晕哥小弟 说:
主要是这个错误
/dev/video1 opened.
irst.
input 0.
不知道这个是什么造成的
我也是这个问题,请问您解决了吗
#247 2019-08-05 11:31:36
晕哥小弟
已发帖子: 311
我的解决了,你的是自己的板子,还是开发板?
#248 2019-08-05 15:13:57
太一酱鸭
已发帖子: 154
晕哥小弟 说:
我的是荔枝派zero,方便加qq(你猜)细聊吗
#249 2019-08-05 16:48:26
太一酱鸭
已发帖子: 154
晕哥小弟 说:
大佬方便加或者告诉我一下你的联系方式吗QAQ
#250 2019-08-06 08:13:48
晕哥小弟
已发帖子: 311
已经加了。不一定能解决,你的问题还是贴出来,晕哥都能解决的。我的很多很多的问题都是晕哥帮助解决的。
#251 2019-08-15 16:40:54
a1326268019
各位大神,请问我编译uboot报这个错误怎么解决啊,u-boot是https://github.com/Lichee-Pi/u-boot下载的
里面确实没有LicheePi_Zero_defconfig
板子是荔枝派Zero V3s开发板
# make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- LicheePi_Zero_defconfig
*** Can't find default configuration "arch/../configs/LicheePi_Zero_defconfig"!
make[1]: *** [LicheePi_Zero_defconfig] Error 1
make: *** [LicheePi_Zero_defconfig] Error 2
最近编辑记录 a1326268019 (2019-08-15 16:46:09)
#252 2019-08-15 17:32:32
已发帖子: 9,439
用指定的分支, 比如 v3s-spi-experimental
#253 2019-08-29 19:58:39
晕哥小弟
已发帖子: 311
主线的kernel 是全志的官网弄出来的,还是索智弄出来的呢?还是licheepi zero的作者弄出来的呢?
#254 2019-10-19 10:07:30
tianjianwudi
编译buildroot过程中下载文件太慢了,贼痛苦。
很不易的下载,在此分享下,拷贝到buildroot-2017.08/dl/ 下即可。
https://pan.baidu.com/s/1Pb18GiPxJedcUI-sYFqKQA&shfl=sharepset
#255 2019-10-19 10:15:58
已发帖子: 9,439
感谢楼上的朋友分享!
#256 2019-10-19 15:38:40
tianjianwudi
请教晕哥及各位大神,为什么我将qt widgets中的例程编译后放 荔枝派zero 中运行时不显示文字。
一开始报未找到/lib/fonts文件夹,后来将buildroot-2017.08/output/target/usr/share/fonts拷贝到荔枝派中,未报任何信息,但还是不显示文字。
#257 2019-10-19 16:05:10
已发帖子: 9,439
勾选这个选项就可以显示了: BR2_PACKAGE_LIBERATION
#258 2019-10-23 00:41:50
tianjianwudi
晕哥,请问 BR2_PACKAGE_LIBERATION 选项在哪啊?
我在buildroot 下 menuconfig 里找不到 BR2_PACKAGE_LIBERATION ,只在.config里找到以下内容。
# Fonts
BR2_PACKAGE_BITSTREAM_VERA=y
BR2_PACKAGE_CANTARELL=y
BR2_PACKAGE_DEJAVU=y
BR2_PACKAGE_DEJAVU_MONO=y
BR2_PACKAGE_DEJAVU_SANS=y
BR2_PACKAGE_DEJAVU_SERIF=y
BR2_PACKAGE_DEJAVU_SANS_CONDENSED=y
BR2_PACKAGE_DEJAVU_SERIF_CONDENSED=y
BR2_PACKAGE_FONT_AWESOME=y
BR2_PACKAGE_GHOSTSCRIPT_FONTS=y
BR2_PACKAGE_INCONSOLATA=y
BR2_PACKAGE_LIBERATION=y
BR2_PACKAGE_LIBERATION_MONO=y
BR2_PACKAGE_LIBERATION_SANS=y
BR2_PACKAGE_LIBERATION_SERIF=y
#259 2019-10-23 09:19:49
已发帖子: 9,439
Target packages  --->
    Fonts, cursors, icons, sounds and themes  --->
        [ ] Liberation (Free fonts)
#260 2019-10-27 14:06:25
tianjianwudi
谢谢解答!
搞了好几天,还去重新移植qt5,结果还是只要将fonts下子目录中的字体文件移动到fonts目录下就能显示文字了。
#261 2019-11-22 15:38:35
augyy
已发帖子: 46
大家好!!請教各位大佬!! 本人用A33-Vstar開發板,想选通ov5640,但出現以下問題.
同sys_config.fex setting
開啟
--- I2C support
[x] I2C device interface
#262 2019-11-22 15:49:13
已发帖子: 9,439
最前面 axp22_dldo3 创建 debugfs 出错了, 有没有影响?
#263 2019-11-22 17:20:56
augyy
已发帖子: 46
改為以下. 但都出現問題
vip_dev0_iovdd = ""
vip_dev0_avdd = ""
vip_dev0_dvdd = ""
#264 2019-11-22 18:43:56
用逻辑分析仪抓 i2c 和 camera 的数据,看有什么情况
#265 2019-11-25 17:25:41
augyy
已发帖子: 46
超级萌新 说:
我發現 DOVDD-CSI 無 2.8V, AVDD-CSI 無 2.8V, DVDD18V-CSI 無1.8V, 是什麼原因?
#266 2019-11-25 17:33:36
已发帖子: 9,439
augyy 说:
电源有问题
#267 2019-11-25 18:11:08
augyy
已发帖子: 46
电源有问题
是否關 axp22_dldo3 创建 debugfs 出错了問題?
#268 2019-11-25 18:14:00
已发帖子: 9,439
augyy 说:
不排除, 有可能的.
#269 2019-11-26 13:45:59
augyy
已发帖子: 46
不排除, 有可能的.
請問有冇解決方法!!因為找了很多網,都找不到解決方法
#270 2019-11-26 14:11:16
已发帖子: 9,439
另起一个帖子吧: https://whycan.cn/t_3297.html#p28559
#271 2019-12-11 11:34:35
ma6254
已发帖子: 41
我用win10的subsystem编译出现了这个错误,似乎是wsl内部IPC实现的问题
一会儿换用doker编译看看,可以的话我上传个编译用的docker镜像
fakeroot, while creating message channels: Function not implemented This may be due to a lack of SYSV IPC support. fakeroot: error while starting the `faked' daemon.
#272 2019-12-19 09:32:29
dml1048147924
所在地: 江苏无锡
已发帖子: 119
哪位大神直到:
我的usb 插到荔枝派zero里,不工作。
USB 热插拔不起作用.pdf
#273 2019-12-28 11:06:34
泽被苍生
已发帖子: 24
git clone https://github.com/Lichee-Pi/linux.git -b zero-4.13.y  这条指令下载4.13y文件6个多G正常吗?
#274 2019-12-28 11:13:38
raspberryman
已发帖子: 503
我这里用 du -sh linux/ 命令显示 4 G 左右,
6G 可能是空间占用吧, 应该是正常的。
#275 2019-12-28 11:19:09
泽被苍生
已发帖子: 24
raspberryman 说:
哦哦我以为有问题,这个还不能断点续传是吧。下载一点就中断了每次从头开始
#276 2019-12-28 11:26:39
raspberryman
已发帖子: 503
泽被苍生 说:
墙内访问 github 是有这个问题, 最好是凌晨下载,速度飞快。
#277 2019-12-28 12:15:25
泽被苍生
已发帖子: 24
raspberryman 说:
谢谢大佬的指点
#278 2020-01-11 16:39:56
yuanlwjt
已发帖子: 129
沉鱼 说:
这是我编译好的uboot, linux&dtb, rootfs: V3s_TFCard.7z
荔枝派Zero开发板网卡验证通过, 登陆账号root,无密码。
sha1sum文件校验码: 43c635802438e26c8fe96ada66255b664d52cddd
这里下载的文件按照步骤烧写到SD卡,V3S无法启动,出现 Starting init: /sbin/init exists but couldn't execute it (error -8)
Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
Rebooting in 5 seconds..
这种错误,什么原因呢?
#279 2020-01-11 17:04:13
已发帖子: 9,439
搜一下,这个问题问过很多次了。
#280 2020-01-15 15:29:13
三哥
好长贴,翻死我了,下次继续来翻
#281 2020-01-17 00:23:14
xql2008
你这个咋跟官方介绍的不一样呢?是因为官方的是最新的编译方式吗?我的板子是最新买的,按你的编译过程,烧进去,跑步起来,串口也没信息。如果,烧lichee_zero_test_Debian_LXDE,就可以跑起来,说明硬件没问题。可能是编译哪里不对。晕哥,能帮我分析下吗?
#282 2020-01-19 17:16:57
晕哥小弟
已发帖子: 311
请教下,这是为什么?
17648] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.826401] *******************sd init ok*******************
[    1.832989] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.841895] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.851727] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.860402] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.869054] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.877799] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.896177] *******************Try sdio*******************
[    1.905705] *******************Try sd *******************
[    1.915233] *******************Try mmc*******************
[    1.967081] *******************Try sdio*******************
[    1.977772] *******************Try sd *******************
[    1.985450] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.996146] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.005425] *******************Try mmc*******************
[    2.012949] EXT4-fs (mmcblk0p2): couldn't mount RDWR because of unsupported optional features (400)
[    2.033832] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[    2.043468] Backtrace:
[    2.046441] [<c00133a4>] (dump_backtrace+0x0/0x104) from [<c03a7b7c>] (dump_stack+0x18/0x1c)
[    2.056035]  r6:c05e24f0 r5:c303b024 r4:c303b024 r3:00000001
[    2.062918] [<c03a7b64>] (dump_stack+0x0/0x1c) from [<c03a7f4c>] (panic+0x78/0x1bc)
[    2.071651] [<c03a7ed4>] (panic+0x0/0x1bc) from [<c0531d5c>] (mount_block_root+0x248/0x280)
[    2.081144]  r3:c3023efc r2:c04c4e7a r1:c3023f30 r0:c04aae7e
[    2.088007]  r7:c04aaee2
[    2.091061] [<c0531b14>] (mount_block_root+0x0/0x280) from [<c0531dec>] (mount_root+0x58/0x6c)
[    2.100850] [<c0531d94>] (mount_root+0x0/0x6c) from [<c0531f30>] (prepare_namespace+0x130/0x190)
[    2.110826]  r5:c055015d r4:c05e1364
[    2.115149] [<c0531e00>] (prepare_namespace+0x0/0x190) from [<c053197c>] (kernel_init+0x174/0x1b4)
[    2.125317]  r5:c0550120 r4:00000007
[    2.129643] [<c0531808>] (kernel_init+0x0/0x1b4) from [<c0031fd4>] (do_exit+0x0/0x638)
[    2.138654]  r9:00000000 r8:00000000 r7:00000013 r6:c0031fd4 r5:c0531808
[    2.146596] r4:00000000
[    2.149851] Rebooting in 5 seconds..
[    7.154200] Restarting Linux version 3.4.39 (he@he) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-29) ) #55 Thu Dec 12 16:12:04 CST 2019
[    7.154212]
#283 2020-01-19 17:54:14
已发帖子: 9,439
根文件系统 mount 失败.
#284 2020-01-20 21:42:59
joyhope
已发帖子: 39
#282 楼的错误我也遇到多次,在主线上没有遇到,在3.4 上遇到。 我不知道哪里下载的3.4 和 这个论坛里面一个3.4 的版本有差异。我用论坛3.4的配置,结果Menuconfig  一堆的问题。后来重新下载论坛的3.4,按照指南操作就没有遇到#282的问题。
#285 2020-02-25 17:25:29
yytyu
已发帖子: 35
mark
#286 2020-03-09 08:11:45
mcu1234mcu
编译uboot出现上面的错误,在下小白,刚入手荔枝派ZERO,请教晕哥
#287 2020-03-09 08:31:23
已发帖子: 9,439
sudo apt-get install device-tree-compiler
提示缺啥装啥就行
@mcu1234mcu
#288 2020-03-11 09:11:08
mcu1234mcu
提示缺啥装啥就行
@mcu1234mcu
搞定了,谢谢
#289 2020-03-15 09:19:47
yuanlwjt
已发帖子: 129
按照论坛里的教程:
    1) 删除TF卡所有分区
    2) 将uboot写入到sd卡8k偏移处(必须8K偏移, brom龟腚的)。
        sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdX bs=1024 seek=8
    3) 建立第一个分区,大小32M(可以随意填写), 格式FAT16, 把zImage, sun8i-v3s-licheepi-zero-dock.dtb拷贝到 这个分区
    4) 建立第二个分区,用尽剩余空间,格式ext4, 把buildroot产生的rootfs.tar解压到该分区根目录
在V3S ZERO开发板上运行后,出现如下情况:
[    1.391582] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.401860] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.552817] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    1.567509] EXT4-fs (mmcblk0p2): recovery complete
[    1.577550] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.585719] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.594166] devtmpfs: mounted
[    1.598397] Freeing unused kernel memory: 1024K
[    1.613776] Starting init: /sbin/init exists but couldn't execute it (error -5)
[    1.623757] Starting init: /bin/sh exists but couldn't execute it (error -5)
[    1.630930] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    1.645087] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #1
[    1.652298] Hardware name: Allwinner sun8i Family
[    1.657036] [<c010e514>] (unwind_backtrace) from [<c010b1b8>] (show_stack+0x10/0x14)
[    1.664779] [<c010b1b8>] (show_stack) from [<c065e5a4>] (dump_stack+0x88/0x9c)
[    1.672001] [<c065e5a4>] (dump_stack) from [<c011b48c>] (panic+0xdc/0x248)
[    1.678875] [<c011b48c>] (panic) from [<c06700ec>] (kernel_init+0x100/0x110)
[    1.685919] [<c06700ec>] (kernel_init) from [<c0107538>] (ret_from_fork+0x14/0x3c)
[    1.693492] Rebooting in 5 seconds..
板子启动不了?是什么情况?
如果把第二步改一下:
  4) 建立第二个分区,大小100M,格式ext4, 把buildroot产生的rootfs.tar解压到该分区根目录
第二个分区改成100M,就可以正常启动。200M就不行了,是什么问题呢?
遇到同样问题,该如何解决?
#290 2020-03-15 09:29:45
异乡是故乡
已发帖子: 74
你的根文件系统出问题了, 换张卡试一试.
#291 2020-03-15 10:46:55
yuanlwjt
已发帖子: 129
异乡是故乡 说:
好的,我换张卡试试看
#292 2020-03-21 14:29:40
yuanlwjt
已发帖子: 129
换了张SD可以了,但是按照
1) 删除TF卡所有分区
        sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8
        sudo tar xvf output/images/rootfs.tar -C /media/bao/rootfs
这样子烧写到SD卡
偶尔几次就又启动不了,偶尔几次又可以
#293 2020-03-21 14:31:15
你把rootfs文件系统写坏了吗?  或者再换一张卡试一试。
#294 2020-03-30 19:36:49
jengy
各位老大,我刷了V3s_TFCard.7z,我是一体的板子,用了_dock 设备树,可是网卡还是没看到,是什么情况呀?
是dts文件还要做修改吗?请不吝赐教。
log:
DRAM: 64 MiB
DRAM:  64 MiB
In:    serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   phy interface0
eth0: ethernet@1c30000
reading zImage
4016104 bytes read in 634 ms (6 MiB/s)
11803 bytes read in 27 ms (426.8 KiB/s)
   Loading Device Tree to 42dfa000, end 42dffe1a ... OK
[    0.000000] Linux version 4.13.0-licheepi-zero+ (hexing@ubuntu) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1)) #46 SMP Fri Dec 15 14:36:43 CST 2017
[    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33920 r8192 d23424 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0
[    0.000000] Memory: 53572K/64036K available (6144K kernel code, 222K rwdata, 1480K rodata, 1024K init, 266K bss, 10464K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a37b00   ( 223 kB)
[    0.000000]        .bss : 0xc0a3ebec - 0xc0a8153c   ( 267 kB)
[    0.000193] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000426] Console: colour dummy device 80x30
[    0.000464] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000480] pid_max: default: 32768 minimum: 301
[    0.000610] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000624] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001225] CPU: Testing write buffer coherency: ok
[    0.001606] /cpus/cpu@0 missing clock-frequency property
[    0.001630] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002066] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002239] Hierarchical SRCU implementation.
[    0.002732] smp: Bringing up secondary CPUs ...
[    0.002747] smp: Brought up 1 node, 1 CPU
[    0.002757] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002764] CPU: All CPU(s) started in SVC mode.
[    0.003531] devtmpfs: initialized
[    0.006677] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006973] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006999] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007167] pinctrl core: initialized pinctrl subsystem
[    0.008048] random: get_random_u32 called from bucket_table_alloc+0xf0/0x250 with crng_init=0
[    0.008190] NET: Registered protocol family 16
[    0.008677] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009802] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009819] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023331] SCSI subsystem initialized
[    0.023635] usbcore: registered new interface driver usbfs
[    0.023704] usbcore: registered new interface driver hub
[    0.023803] usbcore: registered new device driver usb
[    0.024055] pps_core: LinuxPPS API ver. 1 registered
[    0.024068] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.024093] PTP clock support registered
[    0.024322] Advanced Linux Sound Architecture Driver Initialized.
[    0.026178] clocksource: Switched to clocksource arch_sys_counter
[    0.036999] NET: Registered protocol family 2
[    0.037589] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037623] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037647] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037772] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037820] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.038043] NET: Registered protocol family 1
[    0.038633] RPC: Registered named UNIX socket transport module.
[    0.038653] RPC: Registered udp transport module.
[    0.038659] RPC: Registered tcp transport module.
[    0.038664] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040625] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049604] NFS: Registering the id_resolver key type
[    0.049659] Key type id_resolver registered
[    0.049666] Key type id_legacy registered
[    0.049715] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.051190] random: fast init done
[    0.053994] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.054019] io scheduler noop registered
[    0.054028] io scheduler deadline registered
[    0.054276] io scheduler cfq registered (default)
[    0.054290] io scheduler mq-deadline registered
[    0.054298] io scheduler kyber registered
[    0.058664] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.127674] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.130946] console [ttyS0] disabled
[    0.151221] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.741916] console [ttyS0] enabled
[    0.750108] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[    0.756757] m25p80: probe of spi32766.0 failed with error -2
[    0.762967] libphy: Fixed MDIO Bus: probed
[    0.767734] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.773529] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.779313] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.785307] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[    0.794892] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.800586] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.807816] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.813469] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.820693] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.825653] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.832628] libphy: stmmac: probed
[    0.837960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.844499] ehci-platform: EHCI generic platform driver
[    0.850145] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.855767] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.863738] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.896194] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.903449] hub 1-0:1.0: USB hub found
[    0.907395] hub 1-0:1.0: 1 port detected
[    0.911889] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.918189] ohci-platform: OHCI generic platform driver
[    0.923762] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.930493] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.938454] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.011305] hub 2-0:1.0: USB hub found
[    1.015145] hub 2-0:1.0: 1 port detected
[    1.022794] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.032379] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.041390] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.048300] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.052851] i2c /dev entries driver
[    1.057877] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.067389] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.136223] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[    1.196204] sunxi-mmc 1c10000.mmc: base:0xc423b000 irq:24
[    1.202595] usbcore: registered new interface driver usbhid
[    1.208266] usbhid: USB HID core driver
[    1.214142] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.222206] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.230865] NET: Registered protocol family 17
[    1.235451] Key type dns_resolver registered
[    1.239988] Registering SWP/SWPB emulation handler
[    1.251716] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4400000
[    1.262392] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.278762] Console: switching to colour frame buffer device 100x30
[    1.291196] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.299828] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.311262] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.317113] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.325057] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.334326] hub 3-0:1.0: USB hub found
[    1.338495] mmc0: new high speed SDHC card at address b368
[    1.344629] hub 3-0:1.0: 1 port detected
[    1.348840] mmcblk0: mmc0:b368 CBADS 30.0 GiB
[    1.355532] using random self ethernet address
[    1.360101] using random host ethernet address
[    1.364963]  mmcblk0: p1 p2
[    1.369819] usb0: HOST MAC 02:51:3b:c0:fe:f4
[    1.374141] usb0: MAC c2:86:96:e9:19:df
[    1.378164] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.385642] g_cdc gadget: g_cdc ready
[    1.392015] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.400718] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:17:46 UTC (1066)
[    1.409260] vcc5v0: disabling
[    1.412238] ALSA device list:
[    1.415201]   #0: V3s Audio Codec
[    1.420572] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.429785] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.440045] mmc1: new high speed SDIO card at address 0001
[    1.555346] EXT4-fs (mmcblk0p2): recovery complete
[    1.562454] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.570666] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.578269] devtmpfs: mounted
[    1.582532] Freeing unused kernel memory: 1024K
[    1.685800] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
buildroot login:
最近编辑记录 jengy (2020-03-30 19:42:02)
#295 2020-03-31 09:19:00
jengy
以太网功能正常!设备树和驱动都已经开启以太网了。
@晕哥 我用了你发的 V3s_TFCard,为什么我的网卡在登录后用 ifconfig 命令没看到。
u-boot启动日志如下:
DRAM:  64 MiB
In:    serial@01c28000
Net:   phy interface0
reading zImage
#296 2020-03-31 09:22:33
已发帖子: 9,439
ifconfig -a
#297 2020-03-31 12:33:06
jengy
嗯,找到网卡了,谢谢!
#298 2020-04-13 08:38:19
zhang235hai
已发帖子: 212
# ls
analogclock  lib          media        root         tmp
bin          lib32        mnt          run          usr
dev          linuxrc      opt          sbin         var
etc          lost+found   proc         sys
# ./analogclock -platform linuxfb
-/bin/sh: ./analogclock: Permission denied
在运行QT文件的时候报错 Permission denied
请问是什么原因呢?
#299 2020-04-13 08:45:47
X3
已发帖子: 85
没有执行属性吧, 试一试 chmod +x analogclock
#300 2020-04-13 09:15:15
zhang235hai
已发帖子: 212
X3 说:
谢谢,按照你的方式已经可以了!
#301 2020-04-22 15:46:24
whoam1
多谢分享、大佬,请问怎么启动有线网络?
#302 2020-05-07 10:00:58
yyb390931229
搞了半天没起来,学习中感谢楼主
#303 2020-05-08 08:58:53
mysteryli
已发帖子: 509
为啥推荐vm,我用的virtual,请问这里面是有什么坑么
#304 2020-05-08 09:07:57
已发帖子: 3,394
mysteryli 说:
virtual pc容易挂,换过几台电脑都一样,后来换VMWARE一直到今,很稳定。
#305 2020-05-08 15:23:17
zyj
系统刷完后大部分时间无法启动,其少数断电后可以起来,但是系统起来后有时出现系统加载中途死机或无限重启的情况,有时启动后几分钟系统出现死机的情况
#306 2020-05-09 12:21:40
JQH
是的,都没理解这句话,谢谢各位
#307 2020-05-10 12:12:40
grantho
已发帖子: 71
请问串口控制台是ttyS0,而与SDC0引脚是复用的,从TF卡启动,控制台与TF卡都同时工作正常吗?
#308 2020-05-10 12:14:04
有梦的地方
已发帖子: 284
grantho 说:
只能二选一。
#309 2020-05-10 12:18:53
grantho
已发帖子: 71
有梦的地方 说:
只能二选一。
那为什么看到评论中的打印,控制台工作正常,TF卡文件系统分区挂载也正常呢?不大明白
最近编辑记录 grantho (2020-05-10 12:19:25)
#310 2020-05-10 12:45:36
已发帖子: 3,394
grantho 说:
是另外一组串口0,详情参考荔枝派zero原理图。
#311 2020-05-11 16:14:08
lhb882
请问有没有32M得sunxi工具
#312 2020-05-11 16:19:04
已发帖子: 3,394
lhb882 说:
请问有没有32M得sunxi工具
https://whycan.cn/t_444.html
#313 2020-05-21 21:13:09
yvan
膜拜大佬! 请问一下要如何支持双屏异显示啊?
#314 2020-05-28 09:59:43
andrewchen175
已发帖子: 24
请教各位大咖,按步骤进行烧录之后,插卡启动,屏幕只出现一张LOGO图,然后图没了,屏幕亮但没内容,LED 在闪,这样是正常的吗?如果不正常,会是哪里出问题,在线等,多谢了
#315 2020-05-28 10:16:48
已发帖子: 3,394
正常,接串口终端操作吧。
#316 2020-05-31 14:31:01
TDA2030
编译老是失败,好想下载楼主打包好的镜像,给我个机会
#317 2020-05-31 14:37:26
TDA2030
编译u-boot 报错:arch/arm/dts/sun8i-v3s-licheepi-zero.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@01c81000 simple-bus unit address format error, expected "1c81000"
重新clone后也是一个样,求救大神
#318 2020-06-07 08:57:56
andrewchen175
已发帖子: 24
社区主任好,版主好,楼主好,这个启动系统已经建立,同时学到了一些linux的入门操作,谢谢楼主。接下来应该怎么写用户程序?怎么把用户程序加入系统中运行?有没有类似“helloword!"之类的例程详细介绍?翻了半天没发现有相关主题,求相关资源,入门小白也能看懂的。
#319 2020-06-07 09:11:44
已发帖子: 3,394
andrewchen175 说:
写一个简单的 HelloWorld app程序, 用gcc编译,
比如路径是 /opt/helloworld
你创建 /etc/profile.d/app 文件
添加一行: /opt/helloworld
就能开机执行了.
#320 2020-06-17 21:25:09
forcaowu
感觉这个站还比较靠谱些,其他地方找资料好少
#321 2020-06-18 16:47:20
panchuane
刚买了这个板子,学习一下你的经验。很有用,谢谢了。
#322 2020-06-29 16:13:44
liuy
这个F1C100S能不能用SD卡烧录SPI  NAND啊
#323 2020-07-03 16:35:04
JiuHuan
对于buildroot,翻了又翻。 一直不能理解,到底需要勾选哪些(除了 cpu 和 工具链 必配置之外的)。 百度找的相关资料也描述的不多。这块 有没有好的资料推荐。
#324 2020-07-08 14:09:17
174high
不能执行 /sbin/init 。 启动的时候,请问是什么情况。
#325 2020-07-08 15:32:21
174high
是不是已经被勾选了, 看下 output/target/usr/bin 目录, 有没有 ts_xxxx 文件.
buildroot 版本多少合适呢?
#326 2020-07-12 21:34:21
v3s_tester
第一次接触V3S,想自己编译uboot,内核和文件系统,然后烧到TF卡中。这篇文章正好是需要的,学习了!
#327 2020-07-17 12:30:03
selected
刚入门这个荔枝派zero,把linux源码、设备树编译好了,那个跟文件系统是真的难受。。。求讲解视频
#328 2020-07-17 12:50:23
selected
根文件系统编译需要从网络上下载其他资源吗??进度条一直卡着,等待很久才跳出去,死活下载不了。哎。
#329 2020-07-18 07:35:57
selected
根文件系统的版本:buildroot-2017.08.1.tar.gz  ubantu用的是16的版本 ,编译的时候下载很多资源 例如uclibc 等等,进度条不走,可以把获取源文件的网址换成一个网速快的嘛?
#330 2020-07-18 08:17:28
已发帖子: 3,394
selected 说:
建议在vultr的日本vps上面编译, 没有进度条问题,可以按时长租用,销毁实例停止收费:
https://whycan.cn/t_3759.html
https://whycan.cn/t_3884.html
其他的不方便多说。
#331 2020-08-05 21:03:50
白菜爱西瓜
这里的内容下载下来试试看,希望可以解决啊
#332 2020-08-07 16:05:23
haxxjj77
写的很详细真好,新手都能照搬操作下来,什么时候能出一个烧写SPIFLASH的教程就好了,期待!
#333 2020-08-08 09:52:59
hilam8899
好资料,这里的内容下载下来试试看,谢谢!
#334 2020-08-10 19:18:59
popmark
刚刚入手zero dock,好好读了一下,受益匪浅
#335 2020-08-11 00:35:03
yongzong
#336 2020-08-12 09:38:19
jkl
已发帖子: 269
沉鱼 说:
但是lcd上出现了用户登陆提示,这种情况你把 uboot,设备树, Linux都用我上面写的。
log跑屏幕上去这个是在哪里配置的,我现在还没找到,如果你找到麻烦跟帖一下。
你好,请问log跑到屏幕上这个问题您解决了吗?
#337 2020-09-10 20:24:41
andrewchen175
已发帖子: 24
想把Vrtc 和其它3.3V分开,找不到J12和R6,求荔枝派Zero V3s开发板的PCB丝印图,多谢先!
#338 2020-12-15 11:04:07
xcxd
好不容易把串口调试通了,但是发现串口波特率设置高了(比如115200)就不能通信了,怎么让高频率的 也能用,请教大神指点
#339 2021-04-02 03:40:53
yelong98
已发帖子: 97
又一个入坑的重头开始炒作业
#340 2021-04-02 03:41:48
yelong98
已发帖子: 97
这个上手教程贴有更新么?看起来还是3年前的了
#341 2021-04-02 10:52:47
mysteryli
已发帖子: 509
最高只能用到115200
xcxd 说:
#342 2021-04-03 01:17:44
mysteryli
已发帖子: 509
感谢分享,亲测成功运行,可以扫描到wifi的SSID了,验证了硬件没问题,回头会测试一下是否可以连接并上网!
千石级灯 说:
@晕哥
晕哥这次我终于调试好v3s的esp8089的驱动了呢
(1)下载源码 https://github.com/al177/esp8089
修改Makefile,修改如下的内容:
KVERS_UNAME = 4.13.16-licheepi-zero+
KVERS_ARCH = arm
KBUILD ?=/home/gec/v3s/linux4.13-y/linux
modules:
    $(MAKE) ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -C $(KBUILD) M=$(SRC_DIR)
然后直接在文件夹内make 即可生成esp8089.ko文件
(2)参考RTL8723bs的配置方法
a.wpa_supplicant-2.6交叉编译
使用wpa_supplicant与wpa_cli相关的工具测试wifi
(1)1. libnl交叉编译
下载:https://www.infradead.org/~tgr/libnl/files/libnl-1.1.4.tar.gz
解压:tar zxvf libnl-1.1.4.tar.gz
          cd libnl-1.1.4/
配置
./configure --prefix=/mnt/nfsroot/frank.yu/android-O/factorytest/wifi/out
删除:(这一步一定不能忘记)
rm lib/libnl.a
可能导致编译报错(编译出错Relocations in generic ELF (EM: 62))
编译:make CC=arm-linux-gnueabihf-gcc AR=aarch64-linux-gnu-ar LD=arm-linux-gnueabihf-ld
          make install
(2)openssl-1.0.0交叉编译
下载:https://www.openssl.org/source/old/1.0.1/openssl-1.0.1s.tar.gz
解压:tar -xzvf  openssl-1.0.0.tart.gz
配置:
./config no-asm shared --prefix=/mnt/nfsroot/frank.yu/android-O/factorytest/wifi/out
修改makfile:
(1)修改交叉编译器
CC= gcc
AR= ar $(ARFLAGS) r
RANLIB= /usr/bin/ranlib
NM= nm
修改为:
AR= arm-linux-gnueabihf-ar $(ARFLAGS) r
RANLIB= arm-linux-gnueabihf-gcc-ranlib
NM= arm-linux-gnueabihf-gcc-nm
(2)去掉里面的-m64
make make install
备注:
no-asm是在交叉编译过程中不使用汇编代码代码加速编译过程.原因是它的汇编代码是对arm格式不支持的。我试过了,如果没有这个参数,你的交叉编译一定出错。shared生成动态连接库。prefix=路径  就是你的安装目录。
3. wpa_supplicant交叉编译
下载:http://hostap.epitest.fi/releases/wpa_supplicant-2.6.tar.gz
解压:tar -zxvf wpa_supplicant-2.6.tar.gz
           cd  wpa_supplicant-2.6/wpa_supplicant
拷贝配置:
          cp defconfig .config
修改.config
(-O后面不能有空格)
CC=arm-linux-gnueabihf-gcc -L/mnt/nfsroot/frank.yu/android-O/factorytest/wifi/out/lib
CFLAGS += -I/mnt/nfsroot/frank.yu/android-O/factorytest/wifi/out/include
LIBS += -L/mnt/nfsroot/frank.yu/android-O/factorytest/wifi/out/lib
makefile修改:(这里是为了生成静态链接的bin文件)
wpa_supplicant: $(BCHECK) $(OBJS) $(EXTRA_progs)
    $(Q)$(LDO) $(LDFLAGS) -o wpa_supplicant $(OBJS) $(LIBS) $(EXTRALIBS)
    @$(E) "  LD " $@
修改为
    $(Q)$(LDO) --static $(LDFLAGS) -o wpa_supplicant $(OBJS) $(LIBS) $(EXTRALIBS) -lm -lpthread
    @$(E) "  LD " $@
wpa_cli: $(OBJS_c)
    $(Q)$(LDO) $(LDFLAGS) -o wpa_cli $(OBJS_c) $(LIBS_c)
    @$(E) "  LD " $@
修改为
wpa_cli: $(OBJS_c)
    $(Q)$(LDO) --static $(LDFLAGS) -o wpa_cli $(OBJS_c) $(LIBS_c)
    @$(E) "  LD " $@
编译:
make
即可生成静态链接的wpa_supplicant/wpa_cli工具,不需要依赖其他的库文件。
工具wpa_cli ,wpa_passphrase,wpa_supplicant拷贝进开发板的/bin 目录
三,在开发板中设置
(1)insmod esp8089.ko
然后输入ifconfig wlan0 up命令启动wlan0
(3)建立 /etc/wpa_supplicant.conf 文件:
#可有可无,没有的话无法用wpa_cli terminate来关闭wpa_supplicant
# 确保只有root用户能读取WPA的配置,可有可无,尤其是在嵌入式设备上
ctrl_interface_group=0
# 使用wpa_supplicant来扫描和选择AP,也可以设置成0或2,但只有1才能正确工作
ap_scan=1
#设置需要链接上的网络信息
network={
    ssid="unicompy1F"
    scan_ssid=1
    key_mgmt=WPA-EAP WPA-PSK IEEE8021X NONE
    pairwise=TKIP CCMP
    group=CCMP TKIP WEP104 WEP40
    psk="unicomp#38468350"
    priority=5
(4)输入命令wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf
使用这个命令来链接上wifi
测试wlan0:            udhcpc -i wlan0
补充:运维常用linux命令整理
1.临时添加
1 route add default gw 192.168.1.4
2.永久添加
12 vim /etc/sysconfig/networkGATEWAY=192.168.1.4
(5)配置网络ping通外网部分了
一.手动测试是否成功加载网卡驱动,可执行如下命令:ifconfig eth0 192.168.1.218 up
二。以下是在配置好内核以及成功加载网卡的前提下实现能够自动配置网络,能够ping通的步骤
(1)修改 /etc/network/interfaces
即vi /etc/network/interfaces后添加如下语句:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet static
address 192.168.1.218    # 3 你要变化的IP地址
gateway 192.168.1.251   (该网关最好需要设置成跟电脑的网关一致,我这里是 192.168.1.251,跟路由器设置相关)
netmask 255.255.255.0
(2)vi  /etc/resolv.conf
添加以下语句
nameserver 127.0.0.1
nameserver 202.96.134.33
nameserver 114.114.114.114
(3)为了能够实现自动开机设置
可以  vi   /etc/init.d/rcS
然后添加以下三句即可:
echo "nameserver 127.0.0.1" > /etc/resolv.conf
echo "nameserver 202.96.134.33" >> /etc/resolv.conf
echo "nameserver 114.114.114" >> /etc/resolv.conf
之后就可以直接ping通了!!!
#343 2021-04-03 03:35:02
yelong98
已发帖子: 97
Re: 荔枝派Zero V3s开发板入坑记录 (TF/SD卡启动)(主线Linux,主线u-boot)
折腾到后半夜终于正常登录了,但是uboot可以看到lcd有输出,之后一直保持蓝色屏幕,串口后台能登录,请问大佬怎么可以lcdu也能显示出来登录界面?
#344 2021-04-04 22:05:34
mysteryli
已发帖子: 509
来还愿了,测试速度看下图,内网ssh传输,天线设计的不好,所以只是勉强能用
mysteryli 说:
#345 2021-09-26 20:47:19
yzg092
你好,我直接写入你发布的文件TFCard.7z总是不断重启,换了2张卡也一样。
下面是我的启动信息
DRAM:  64 MiB
In:    serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   phy interface0
reading zImage
4016104 bytes read in 633 ms (6.1 MiB/s)
[    0.000000] 	RCU event tracing is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000427] Console: colour dummy device 80x30
[    0.000465] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000482] pid_max: default: 32768 minimum: 301
[    0.000608] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000622] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001238] CPU: Testing write buffer coherency: ok
[    0.001614] /cpus/cpu@0 missing clock-frequency property
[    0.001637] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002082] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002260] Hierarchical SRCU implementation.
[    0.002752] smp: Bringing up secondary CPUs ...
[    0.002768] smp: Brought up 1 node, 1 CPU
[    0.002777] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002783] CPU: All CPU(s) started in SVC mode.
[    0.003561] devtmpfs: initialized
[    0.006709] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007007] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007034] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007201] pinctrl core: initialized pinctrl subsystem
[    0.008073] random: get_random_u32 called from bucket_table_alloc+0xf0/0x250 with crng_init=0
[    0.008217] NET: Registered protocol family 16
[    0.008704] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009841] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009859] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023348] SCSI subsystem initialized
[    0.023654] usbcore: registered new interface driver usbfs
[    0.023724] usbcore: registered new interface driver hub
[    0.023826] usbcore: registered new device driver usb
[    0.024074] pps_core: LinuxPPS API ver. 1 registered
[    0.024086] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.024109] PTP clock support registered
[    0.024336] Advanced Linux Sound Architecture Driver Initialized.
[    0.026198] clocksource: Switched to clocksource arch_sys_counter
[    0.037042] NET: Registered protocol family 2
[    0.037624] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037658] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037682] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037807] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037856] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.038076] NET: Registered protocol family 1
[    0.038651] RPC: Registered named UNIX socket transport module.
[    0.038671] RPC: Registered udp transport module.
[    0.038677] RPC: Registered tcp transport module.
[    0.038683] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040660] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049657] Key type id_resolver registered
[    0.049665] Key type id_legacy registered
[    0.049712] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.051191] random: fast init done
[    0.054018] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.054043] io scheduler noop registered
[    0.054051] io scheduler deadline registered
[    0.054299] io scheduler cfq registered (default)
[    0.054312] io scheduler mq-deadline registered
[    0.054319] io scheduler kyber registered
[    0.058665] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.127881] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.131112] console [ttyS0] disabled
[    0.151384] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.742080] console [ttyS0] enabled
[    0.750265] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[    0.756919] m25p80: probe of spi32766.0 failed with error -2
[    0.763133] libphy: Fixed MDIO Bus: probed
[    0.767882] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.773678] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.779460] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.785453] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[    0.795037] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.800727] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.807957] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.813611] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.820838] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.825797] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.832770] libphy: stmmac: probed
[    0.838095] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.844634] ehci-platform: EHCI generic platform driver
[    0.850276] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.855897] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.863874] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.896215] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.903461] hub 1-0:1.0: USB hub found
[    0.907419] hub 1-0:1.0: 1 port detected
[    0.911904] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.918198] ohci-platform: OHCI generic platform driver
[    0.923767] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.930496] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.938456] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.011323] hub 2-0:1.0: USB hub found
[    1.015160] hub 2-0:1.0: 1 port detected
[    1.022813] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.032402] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.041418] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.048325] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.052877] i2c /dev entries driver
[    1.057905] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.067416] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.136247] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[    1.186271] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.196228] sunxi-mmc 1c10000.mmc: base:0xc423b000 irq:24
[    1.202628] usbcore: registered new interface driver usbhid
[    1.208282] usbhid: USB HID core driver
[    1.213010] mmc0: new high speed SDHC card at address aaaa
[    1.219288] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.225830] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.233919] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.240418]  mmcblk0: p1 p2
[    1.248541] NET: Registered protocol family 17
[    1.253107] Key type dns_resolver registered
[    1.257653] Registering SWP/SWPB emulation handler
[    1.267152] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4400000
[    1.277839] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.293997] Console: switching to colour frame buffer device 100x30
[    1.306476] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.315054] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.326576] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.332346] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.341491] hub 3-0:1.0: USB hub found
[    1.345356] hub 3-0:1.0: 1 port detected
[    1.350673] using random self ethernet address
[    1.355163] using random host ethernet address
[    1.361788] usb0: HOST MAC 36:a3:e9:ea:2b:58
[    1.366103] usb0: MAC da:14:24:62:2a:9c
[    1.370110] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.377625] g_cdc gadget: g_cdc ready
[    1.383985] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.392507] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:08:04 UTC (484)
[    1.400920] vcc5v0: disabling
[    1.403898] ALSA device list:
[    1.406921]   #0: V3s Audio Codec
[    1.414081] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.425191] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.462122] EXT4-fs (mmcblk0p2): recovery complete
[    1.467034] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.475185] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.484913] devtmpfs: error mounting -2
[    1.489977] Freeing unused kernel memory: 1024K
[    1.494762] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    1.508921] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.0-licheepi-zero+ #46
[    1.516219] Hardware name: Allwinner sun8i Family
[    1.520955] [<c010e22c>] (unwind_backtrace) from [<c010af9c>] (show_stack+0x10/0x14)
[    1.528701] [<c010af9c>] (show_stack) from [<c0674fd0>] (dump_stack+0x90/0xa4)
[    1.535927] [<c0674fd0>] (dump_stack) from [<c011b05c>] (panic+0xf0/0x268)
[    1.542801] [<c011b05c>] (panic) from [<c06870d4>] (kernel_init+0x100/0x110)
[    1.549846] [<c06870d4>] (kernel_init) from [<c0107358>] (ret_from_fork+0x14/0x3c)
[    1.557418] Rebooting in 5 seconds..
#346 2021-10-01 00:29:30
sunxiang
已发帖子: 222
切换到主线试试,哈哈
#347 2021-10-02 01:07:28
sunxiang
已发帖子: 222
现在有个问题,我看大家的背光脚都是pb4,pb5。因为我这个板子是参照樱桃派画的,背光脚在pb2。跑bsp版本的时候,lcd可以正常亮起来。我不知道,如果切换主线的话,pb2是可以模拟pwm,以实现背光吗?可以给一个思路吗?
#348 2021-10-02 08:14:34
tigger
已发帖子: 172
sunxiang 说:
不行,定时器IO模拟的PWM第一浪费CPU,第二不准。
#349 2021-11-20 14:01:24
TwoOne
谢谢晕哥。我自己编译到uboot就不动了
#350 2021-12-12 20:46:32
jack123321
我搞了两天,硬是没搞出来。。。
#351 2021-12-13 13:14:37
jack123321
楼主一开始那个修改文件是增加还是全删除了用您的?
#352 2021-12-13 13:20:53
jack123321
3). 执行编译, 生成文件跟文件系统。   执行编译是在bulildroot目录下执行编译:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make
这个吗?
#353 2021-12-13 13:32:49
已发帖子: 3,394
jack123321 说:
这个吗?
是的。
这个帖子过时了,建议用这个:
(V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
https://whycan.com/t_7248.html#p69168
#354 2022-02-13 19:02:42
zjf0519
已发帖子: 22
图形界面QT的7寸电容屏有没有成功驱动的镜像的?
#355 2022-03-13 10:21:18
东方总败
已发帖子: 33
晕哥有没有移植过H616的uboot,我用的是香橙派zero2开发板,自己移植uboot一直没成功,头大,可以指点一下吗
#358 2022-06-15 00:27:50
hahahah
我也遇到了5秒重启的问题,全部都是按照教程来的,前几次烧录成功正常启动可以进系统,后来又试了几次一直都有问题,不能理解,我前面整套流程下来至少2次都成功了,后面就出现这个问题,方法一模一样就是不对,我也是醉了
#359 2022-07-25 16:20:51
tevada2010
已发帖子: 54
I compile buildroot it error why
freadahead.c: In function 'freadahead':
freadahead.c:92:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
make[5]: *** [Makefile:1915: freadahead.o] Error 1
make[5]: *** Waiting for unfinished jobs....
fseeko.c: In function 'rpl_fseeko':
fseeko.c:110:4: error: #error "Please port gnulib fseeko.c to your platform! Look at the code in fseeko.c, then report this to bug-gnulib."
make[5]: *** [Makefile:1915: fseeko.o] Error 1
make[4]: *** [Makefile:1674: all] Error 2
make[3]: *** [Makefile:1572: all-recursive] Error 1
make[2]: *** [Makefile:1528: all] Error 2
#361 2022-08-31 11:00:10
zevinl
我怎么bulidroot出错?而且tf卡第一个分区挂载不了
#362 2022-10-13 22:53:01
lsmcld
所在地: 成都
已发帖子: 27
我的荔枝派吃灰了
#363 2023-06-05 10:30:33
cpl
我按教程试了一遍,使用tf卡启动,结果lcd没反应,连uart0串口都没识别出来T T
#365 2023-08-30 21:21:18
砍柴少年
小白发问,想知道为啥官方镜像,8G的TF卡,烧录后可用的内存只有几百兆啊:(
#366 2024-03-13 12:06:37
paul_zdchun
已发帖子: 26
内存几百兆?内存这个概念看来要好好定义一下
砍柴少年 说:
#370 2025-12-20 20:18:11
csa
主线Linux,主线U-boot, Randrom出问题了,有碰到过这种情况的没有,如何解决
#371 2025-12-24 18:14:36
qwb233
v3s Linux5.2版本好用吗
